[RTEMS SMP ISVV] : rtems_clock_get_ticks_per_second and rtems_clock_get_ticks_since_boot
Sebastian Huber
Fri Sep 23 11:51:10 UTC 2022
Hello Luis,
On 23.09.22 13:20, Luis Alves wrote:
> Dear RTEMS community,
> I’m part of the team performing the Independent Software Verification
> and Validation (ISVV) of the RTEMS SMP Qualification Data Pack (which is
> being provided through https://rtems-qual.io.esa.int/
> <https://rtems-qual.io.esa.int/>).
> While analysing in the Software Configuration File (SCF) which items are
> or not pre-qualified, the following has been noticed:
> * rtems_clock_get_ticks_per_second() and
> rtems_clock_get_ticks_since_boot() functions are listed in section
> 4.10 of the SCF (which list pre-qualified items “which may be
> directly used by applications”).
> * In the ICD there are duplicated items described with these names, a
> function, and a macro. Moreover:
> o In the ICDs the macros using these names are described with the
> “The directive is not included in the pre-qualified feature set
> of RTEMS. Applications which are restricted to only use
> interfaces of the pre-qualified feature set of RTEMS shall not
> use the directive.”
> * Looking at the code (at retems-qual-only), the macros are defined
> alongside and right after the function’s declarations (redirecting
> function calls to the values of the _Watchdog_Ticks_per_second and
> _Watchdog_Ticks_since_boot, respectively).
> o So, rtems_clock_get_ticks_per_second and
> rtems_clock_get_ticks_since_boot macros will be used in the
> qual-only setup, whereas ICD tells us that these macros are “not
> included in the pre-qualified feature set”.
> Can the community help to clarify these points, and tell us what and how
> can one improve the RTEMS SMP QDP w.r.t. this (at the documentation and
> qual-only implementation level)?
this issue is already fixed:
https://git.rtems.org/rtems-central/commit/?id=1167cbc0cbce5972409ef4e334f39c56f2337ef0
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
