How can I use the GCC -frandom-seed=<file name> option with the waf build system?
Karel Gardas
karel at functional.vision
Fri Sep 23 16:47:43 UTC 2022
On 9/23/22 18:35, Sebastian Huber wrote:
> Hello,
> I have a question for the waf experts. How can I use the GCC
> https://stackoverflow.com/questions/73829827/how-can-i-use-the-gcc-frandom-seed-file-name-option-with-the-waf-build-system
Unix? Why not to use pure and simple -frandom-seed=$RANDOM ? E.g. I hope
you'd like to have something there hence went for file name which will
give you stable "random" value per every file compiled while $RANDOM
will give you more randomness and certainly not the same value per same
file...
Karel
