rtems-tester for raspberry pi 4B
Noor Aman nooraman5718 at gmail.com
Sun Sep 25 15:06:21 UTC 2022
Oh I see, I thought that aarch64/raspberry had the same issue too. Yes, the
aarch64 BSP works fine with the latest firmware. I was able to boot from
USB too. I wanted to setup rtems-tester for aarch64/raspberry BSP using
TFTP/PXE boot, So I needed help with that.
On Sun, 25 Sept 2022 at 20:31, Alan Cudmore <alan.cudmore at gmail.com> wrote:
> Hi Noor,
> The firmware issue that I am aware of is for the 32 bit arm/raspberrypi
> BSPs. I would expect that your Aarch64 BSP would work with the latest
> Raspberry Pi firmware. Are you talking about aarch64/raspberrypi or
> arm/raspberrypi?
> Alan
> *From: *Noor Aman <nooraman5718 at gmail.com>
> *Sent: *Sunday, September 25, 2022 3:53 AM
> *To: *William Moore <WKMoore at gmail.com>; Alan Cudmore
> <alancudmore at gmail.com>; Hesham Moustafa <heshamelmatary at gmail.com>;
> rtems-devel at rtems.org <devel at rtems.org>
> *Subject: *rtems-tester for raspberry pi 4B
> Hey,
> Now that I have built a BSP, I wanted to run the rtems-tester for
> Raspberry Pi. But I'm confused on what to do now. The raspberry pi 2 bsp
> required u-boot in order to run the test which is understandable as rpi2
> didnt had support for PXE boot, but the raspberry pi 4b has support for
> tftp boot but I'm unable to use it. Any ideas about how to do that? I would
> still like to know how u-boot was used for the earlier raspberry pi.
> One thing more, once you said
> Current Raspberry Pi BSPs have problem with the firmware that we have not
> resolved. Once we are past a certain commit of the Raspberry Pi firmware,
> RTEMS will not boot. This has prevented me from booting RTEMS on the
> Raspberry Pi Zero 2 W (Quad core). I know your project is for the Pi 4, but
> it would be great if we could finally figure that out.
> because of this I was using old firmwares (1.20200601), but after I
> finished building BSP, I thought of booting from USB but newer firmware was
> required. So I tried the firmware-1.20220830 (latest) and it just worked. I
> tried some more releases and everything worked just fine. I'm just
> wondering what caused things to change.
> Thanks,
> Noor
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220925/ece285bf/attachment.htm>
