rtems bsp builder failures
Joel Sherrill
joel at rtems.org
Sun Sep 25 19:45:19 UTC 2022
Hi
Now that the versal ilp32 BSP variants have been removed, the BSP builder
sweep reports these oddities:
Failures Report
1 smp riscv/rv32iac build:
configure: /home/tester/rtems-cron-6/rtems/waf configure\
--prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
/rtems-cron-6/rtems --rtems-config=config-riscv-rv32iac-smp.ini
error: ld/collect2:0 error: no error message found!
2 smp riscv/rv32imafd build:
/rtems-cron-6/rtems --rtems-config=config-riscv-rv32imafd-smp.ini
3 smp riscv/rv32imafdc build:
/rtems-cron-6/rtems --rtems-config=config-riscv-rv32imafdc-smp.ini
I'm guessing it's a combination of some test not linking and the way it
fails, there isn't any particularly useful output for bsp builder to grab.
Help clearing these up would be appreciated.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220925/5d3d5153/attachment.htm>
