Aw: Re: [PATCH 0/2] GCC errors when building C++ Applications with libbsd
Tue Sep 27 01:04:55 UTC 2022
Jeff Johnson pushed the patch to newlib. The github mirrored it after a
while. I bumped the hash in the RSB.
This should be ok now.
How often does the github mirroring of gcc, newlib, etc run?
On Mon, Sep 26, 2022 at 3:53 PM Joel Sherrill <joel at rtems.org> wrote:
> I'm not sure what triggers the newlib mirror to update on github. When
> it's up to date, I'm ready to update rteems-source-builder.
> Sebastian.. what's the trigger?
> --joel
> On Mon, Sep 26, 2022 at 1:08 PM Joel Sherrill <joel at rtems.org> wrote:
>> On Mon, Sep 26, 2022, 1:51 PM Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> On 26/09/2022 18:58, Markus Moessner wrote:
>>> >>> The second one is triggered by the function getrusage in
>>> rtemsbsd/include/bsd/sys/ressource.h.
>>> >>> There is a another declaration in include/sys/ressource.h provided
>>> with the toolchain.
>>> >>> Now, one has C Linkage the other one C++ Linkage which leads to a
>>> conflict. I ve simply made the one in libbsd invisible to the C++ compiler.
>>> >> This is a bug in Newlib (newlib/libc/include/sys/resource.h). This
>>> file
>>> >> needs the C++ extern "C" stuff.
>>> > Okay, I ll re-submit the first patch. On the second one, are you
>>> submitting it to newlib or do you expect me to do that?
>>> I have a very long TODO list.
>> I'm at an Open Group meeting this week but hope to tackle a few odds and
>> ends. Jeff pushed this to newlib. Do you want me to bump the rsb newlib
>> hash for 6 and 7?
>> --joel
>>> embedded brains GmbH
>>> Herr Sebastian HUBER
>>> Dornierstr. 4
>>> 82178 Puchheim
>>> Germany
>>> email: sebastian.huber at embedded-brains.de
>>> phone: +49-89-18 94 741 - 16
>>> fax:   +49-89-18 94 741 - 08
>>> Registergericht: Amtsgericht München
>>> Registernummer: HRB 157899
>>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>>> Unsere Datenschutzerklärung finden Sie hier:
>>> https://embedded-brains.de/datenschutzerklaerung/
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220926/0929e2df/attachment-0001.htm>
