[rtems-source-builder commit] sb/setbuilder: Correctly create build set tar files
Christian MAUDERER
christian.mauderer at embedded-brains.de
Thu Sep 29 07:13:21 UTC 2022
Am 29.09.22 um 08:56 schrieb Chris Johns:
> On 29/9/2022 4:55 pm, Christian MAUDERER wrote:
>> Am 29.09.22 um 08:54 schrieb Chris Johns:
>>> On 29/9/2022 4:42 pm, Christian MAUDERER wrote:
>>>>> It could be a bug if the tools builds work, ie 6/rtems-*. Please raise a
>>>>> ticket?
>>>> The tool builds work except for the 6/rtems-microblaze.
>>> Thanks, I will take a look.
>> I just checked it: There is the same behavior for devel/dtc (which is much
>> faster to build). Without the patch an archive is created. With the patch it
>> doesn't create one.
> Awesome, that will help.
In case of dtc, it seems to not work because dtc is in
devel/dtc-1.6.1-1.cfg
which ends in a ".cfg" and not in a ".bset".
The bset_tar(...) function is only called if the have_staging is set here:
https://git.rtems.org/rtems-source-builder/tree/source-builder/sb/setbuilder.py?id=161b7f108c3daa0f71ac289ba048a68b730d422c#n623
That variable seems to be only set to True here:
https://git.rtems.org/rtems-source-builder/tree/source-builder/sb/setbuilder.py?id=161b7f108c3daa0f71ac289ba048a68b730d422c#n489
And that statement is in a
if configs[s].endswith('.bset')
Does that mean that only bsets can be packed? I think having a tarball
for tools like qemu or dtc could be quite useful too.
PS: Not sure yet why microblaze is affected too. That maybe is another case.
Best regards
Christian
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRB 157899
