[PATCH] sb/execute: Use a decoder that maintains state aross blocks
Frank Kühndel
frank.kuehndel at embedded-brains.de
Thu Sep 29 13:14:17 UTC 2022
Hello Chris,
I reviewed this patch and I also tested it in the environment which made
problems earlier. The UnicodeDecodeError disappeared. This patch is fine
for me.
Many tanks for fix this issue.
Frank
On 9/29/22 12:59, chrisj at rtems.org wrote:
> From: Chris Johns<chrisj at rtems.org>
> Update #4726
> source-builder/sb/execute.py | 4 +++-
> 1 file changed, 3 insertions(+), 1 deletion(-)
> diff --git a/source-builder/sb/execute.py b/source-builder/sb/execute.py
> index 3db9abc..bdab373 100755
> --- a/source-builder/sb/execute.py
> +++ b/source-builder/sb/execute.py
> @@ -27,6 +27,7 @@
> from __future__ import print_function
> import functools
> +import codecs
> import io
> import os
> import re
> @@ -181,6 +182,7 @@ class execute(object):
> if trace_threads:
> print('execute:_readthread: start')
> + decoder = codecs.getincrementaldecoder(sys.stdout.encoding)()
> count = 0
> line = ''
> try:
> @@ -201,7 +203,7 @@ class execute(object):
> break
> # str and bytes are the same type in Python2
> if type(data) is not str and type(data) is bytes:
> - data = data.decode(sys.stdout.encoding)
> + data = decoder.decode(data)
> last_ch = data[-1]
> sd = (line + data).split('\n')
> if last_ch != '\n':
embedded brains GmbH
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone: +49-89-18 94 741 - 23
mobile: +49-176-15 22 06 - 11
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
