[PATCH] sb/set-builder: Fix staging and tar file generation with a single config build
Christian MAUDERER
christian.mauderer at embedded-brains.de
Fri Sep 30 07:01:53 UTC 2022
Am 30.09.22 um 08:48 schrieb Chris Johns:
> On 30/9/2022 4:08 pm, Christian MAUDERER wrote:
>> Am 30.09.22 um 07:37 schrieb Chris Johns:
>>> On 30/9/2022 3:33 pm, Christian MAUDERER wrote:
>>>> Am 30.09.22 um 05:49 schrieb Chris Johns:
>>>>> On 29/9/2022 9:50 pm, Chris Johns wrote:
>>>>>> On 29/9/22 9:45 pm, Christian MAUDERER wrote:
>>>>>>> Hello Chris,
>>>>>>> thanks for the quick patch. With this qemu and microblaze work again like
>>>>>>> expected.
>>>>>>> I tested all tools starting with devel/* and from the ones that work only
>>>>>>> devel/autotools-internal didn't generate a tar archive. But that one has a
>>>>>>> comment "Do not use via the command line" in the bset file so that is most
>>>>>>> likely fine.
>>>>>>> Some of other devel/* packages didn't build in my test setup, but I have
>>>>>>> never
>>>>>>> tested or used them before so that is probably a problem of my build
>>>>>>> environment
>>>>>>> or maybe a known bug.
>>>>>> Thanks for the testing. I will push to the devel branch and 5.
>>>>> Tarfile creation is working however installing is not. I am working on fixing
>>>>> this.
>>>>> Chris
>>>> Sorry that I missed that. I only tried to generate the tar archives.
>>> Same. Testing a fix but it takes time to check properly.
>>> I am wondering if I can create a test mode in the deployment repo. The hard part
>>> is how to automatically check the build has worked.
>>> Chris
>> I'm currently trying to create a basic CI/CD setup for testing our embedded
>> brains patches using GitHub. At the moment it's still quite experimental and
>> still a bit thrown together but it basically runs:
>> https://github.com/embedded-brains/rtems-source-builder/actions/runs/3151126889
> Nice.
>> It didn't catch that bug because it doesn't use installed tools for the
>> simulator runs, but maybe I can change that.
>> If it works well enough, we maybe could re-use some scripts or work flows to set
>> up an official RTEMS CI/CD with whatever community preferred CI system. It
>> shouldn't be too big of a problem to port the logic to Gitlab CI, Cirrus CI or
>> any other modern CI system.
> I have started https://git.rtems.org/chrisj/rtems-deployment.git/. I would like
> it to be the landing place for this type of stuff if it fits. The repo is being
> actively worked on by me.
I have seen that repo after you mentioned it recently, but I have to
admit I haven't looked at it yet. From the name I have guessed that it
is more for building release versions and not for continuous checks.
I'll take a more detailed look.
> I can build RPMs on Rocky 8 and 9. These RPMs are the base for EPICS RPMs built
> into docker containers used to build Gemini's EPICS based systems. All handled
> via CI in gitlab.
That's quite interesting. Do you have a public GitLab instance where you
build these or is that a private instance? The rtems-deployment repo
doesn't have a .gitlab-ci.yml. Did you keep that separate?
Best regards
Christian
> To build an RPM you configure with the path to the RSB and then run `./waf
> rpmspec`. A spec file is created you can use with `rpmbuild` to make an RPM. I
> am keeping the generation and building of the RPM separate. By default the repo
> builds a tarfile.
> Once this repo stabilises I would like to see if it can move to the top level. I
> am working on better documentation for it and with that some constraints about
> what is offered.
> Deployment is something varies and I hope this repo can grow to make common
> solutions widely available. I am fine for organisation to send in specific
> configurations if they are open to having them in the repo.
> Chris
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRB 157899
