[docs 5/5] c-user: INTERNAL_ERROR_IDLE_THREAD_STACK_TOO_SMALL
Sebastian Huber
Fri Sep 30 09:15:34 UTC 2022
Document this fatal error.
c-user/fatal-error/background.rst | 7 +++++++
1 file changed, 7 insertions(+)
diff --git a/c-user/fatal-error/background.rst b/c-user/fatal-error/background.rst
index 3c4212e..ef1e2e1 100644
--- a/c-user/fatal-error/background.rst
+++ b/c-user/fatal-error/background.rst
@@ -371,3 +371,10 @@ INTERNAL_ERROR_IDLE_THREAD_CREATE_FAILED (44)
The creation of an IDLE task failed. This fatal error may occur during
system initialization. It happens if a task create extension fails for an
IDLE task.
+INTERNAL_ERROR_IDLE_THREAD_STACK_TOO_SMALL (45)
+ The task stack size of an IDLE task would have been less than the
+ configured minimum stack size for IDLE tasks, see
+ :ref:`CONFIGURE_IDLE_TASK_MINIMUM_STACK_SIZE <CONFIGURE_IDLE_TASK_MINIMUM_STACK_SIZE>`.
+ This fatal error may occur during system initialization. It is an
+ application configuration error.
2.35.3
