[docs 3/5] c-user: INTERNAL_ERROR_NO_MEMORY_FOR_IDLE_TASK_STACK
Sebastian Huber
Fri Sep 30 09:15:32 UTC 2022
Document this fatal error.
c-user/fatal-error/background.rst | 5 +++++
1 file changed, 5 insertions(+)
diff --git a/c-user/fatal-error/background.rst b/c-user/fatal-error/background.rst
index 3bc170f..6b47ab3 100644
--- a/c-user/fatal-error/background.rst
+++ b/c-user/fatal-error/background.rst
@@ -361,3 +361,8 @@ INTERNAL_ERROR_RTEMS_INIT_TASK_CONSTRUCT_FAILED (42)
The construction of the RTEMS initialization task failed. This fatal error
may occur during system initialization. It is an application configuration
error.
+INTERNAL_ERROR_NO_MEMORY_FOR_IDLE_TASK_STACK (43)
+ There was not enough memory available to allocate an IDLE task stack. This
+ fatal error may occur during system initialization. It is an application
+ configuration error.
2.35.3
