[PATCH 10/13] score: INTERNAL_ERROR_IDLE_THREAD_CREATE_FAILED
Fri Sep 30 09:21:33 UTC 2022
Add the INTERNAL_ERROR_IDLE_THREAD_CREATE_FAILED fatal error in case the
creation of an idle thread fails.  This may happen due to a failing create
extension provided by the application.
 cpukit/include/rtems/score/interr.h           |   3 +-
 cpukit/sapi/src/interrtext.c                  |   3 +-
 cpukit/score/src/threadcreateidle.c           |  12 +-
 .../fatal-idle-thread-create-failed.yml       |  20 +++
 spec/build/testsuites/validation/grp.yml      |   2 +
 testsuites/sptests/spinternalerror02/init.c   |   2 +-
 .../tr-fatal-idle-thread-create-failed.c      | 158 ++++++++++++++++++
 .../tr-fatal-idle-thread-create-failed.h      |  84 ++++++++++
 .../ts-fatal-idle-thread-create-failed.c      |  90 ++++++++++
 testsuites/validation/ts-fatal-sysinit.h      |   7 +
 10 files changed, 375 insertions(+), 6 deletions(-)
 create mode 100644 spec/build/testsuites/validation/fatal-idle-thread-create-failed.yml
 create mode 100644 testsuites/validation/tr-fatal-idle-thread-create-failed.c
 create mode 100644 testsuites/validation/tr-fatal-idle-thread-create-failed.h
 create mode 100644 testsuites/validation/ts-fatal-idle-thread-create-failed.c
diff --git a/cpukit/include/rtems/score/interr.h b/cpukit/include/rtems/score/interr.h
index 6e6926ab61..1eeb93cc6e 100644
--- a/cpukit/include/rtems/score/interr.h
+++ b/cpukit/include/rtems/score/interr.h
@@ -229,7 +229,8 @@ typedef enum {
   INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA = 40,
   INTERNAL_ERROR_TOO_LARGE_TLS_SIZE = 41,
   INTERNAL_ERROR_RTEMS_INIT_TASK_CONSTRUCT_FAILED = 42,
-  INTERNAL_ERROR_NO_MEMORY_FOR_IDLE_TASK_STACK = 43
+  INTERNAL_ERROR_NO_MEMORY_FOR_IDLE_TASK_STACK = 43,
+  INTERNAL_ERROR_IDLE_THREAD_CREATE_FAILED = 44
 } Internal_errors_Core_list;
 typedef CPU_Uint32ptr Internal_errors_t;
diff --git a/cpukit/sapi/src/interrtext.c b/cpukit/sapi/src/interrtext.c
index 005cdc4508..85ccf13201 100644
--- a/cpukit/sapi/src/interrtext.c
+++ b/cpukit/sapi/src/interrtext.c
@@ -84,7 +84,8 @@ static const char *const internal_error_text[] = {
   "INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA",
   "INTERNAL_ERROR_TOO_LARGE_TLS_SIZE",
   "INTERNAL_ERROR_RTEMS_INIT_TASK_CONSTRUCT_FAILED",
-  "INTERNAL_ERROR_NO_MEMORY_FOR_IDLE_TASK_STACK"
+  "INTERNAL_ERROR_NO_MEMORY_FOR_IDLE_TASK_STACK",
+  "INTERNAL_ERROR_IDLE_THREAD_CREATE_FAILED"
 const char *rtems_internal_error_text( rtems_fatal_code error )
diff --git a/cpukit/score/src/threadcreateidle.c b/cpukit/score/src/threadcreateidle.c
index 3e3c7cfc83..d2037b36f0 100644
--- a/cpukit/score/src/threadcreateidle.c
+++ b/cpukit/score/src/threadcreateidle.c
@@ -39,13 +39,16 @@
 #include "config.h"
 #endif
-#include <rtems/score/threadidledata.h>
-#include <rtems/score/cpuimpl.h>
+#include <rtems/score/cpuimpl.h>
+#include <rtems/score/interr.h>
 #include <rtems/score/stackimpl.h>
 #include <rtems/score/sysstate.h>
+#include <rtems/score/threadidledata.h>
+#include <rtems/score/tls.h>
 #include <rtems/score/userextimpl.h>
@@ -66,6 +69,7 @@ static void _Thread_Create_idle_for_CPU( Per_CPU_Control *cpu )
   config.name = _Objects_Build_name( 'I', 'D', 'L', 'E' );
   config.is_fp = CPU_IDLE_TASK_IS_FP;
   config.is_preemptible = true;
+  config.stack_free = _Objects_Free_nothing;
   config.stack_size = _Thread_Idle_stack_size
     + CPU_IDLE_TASK_IS_FP * CONTEXT_FP_SIZE;
@@ -87,7 +91,9 @@ static void _Thread_Create_idle_for_CPU( Per_CPU_Control *cpu )
   _Assert( idle != NULL );
   status = _Thread_Initialize( &_Thread_Information, idle, &config );
-  _Assert_Unused_variable_equals( status, STATUS_SUCCESSFUL );
+  if ( status != STATUS_SUCCESSFUL ) {
+    _Internal_error( INTERNAL_ERROR_IDLE_THREAD_CREATE_FAILED );
    *  WARNING!!! This is necessary to "kick" start the system and
diff --git a/spec/build/testsuites/validation/fatal-idle-thread-create-failed.yml b/spec/build/testsuites/validation/fatal-idle-thread-create-failed.yml
new file mode 100644
index 0000000000..49af89452a
--- /dev/null
+++ b/spec/build/testsuites/validation/fatal-idle-thread-create-failed.yml
@@ -0,0 +1,20 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2022 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/validation/tr-fatal-idle-thread-create-failed.c
+- testsuites/validation/ts-fatal-idle-thread-create-failed.c
+stlib: []
+target: testsuites/validation/ts-fatal-idle-thread-create-failed.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/validation/grp.yml b/spec/build/testsuites/validation/grp.yml
index b9205cc28c..7a5fbb1c90 100644
--- a/spec/build/testsuites/validation/grp.yml
+++ b/spec/build/testsuites/validation/grp.yml
@@ -17,6 +17,8 @@ links:
   uid: libvalidation
 - role: build-dependency
   uid: fatal-boot-processor-not-assigned-to-scheduler
+- role: build-dependency
+  uid: fatal-idle-thread-create-failed
   uid: fatal-init-task-construct-failed
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index e139547ca5..f94759a99b 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -49,7 +49,7 @@ static void test_internal_error_text(void)
   } while ( text != text_last );
   rtems_test_assert(
-    error - 3 == INTERNAL_ERROR_NO_MEMORY_FOR_IDLE_TASK_STACK
+    error - 3 == INTERNAL_ERROR_IDLE_THREAD_CREATE_FAILED
diff --git a/testsuites/validation/tr-fatal-idle-thread-create-failed.c b/testsuites/validation/tr-fatal-idle-thread-create-failed.c
index 0000000000..8c66f01c82
--- /dev/null
+++ b/testsuites/validation/tr-fatal-idle-thread-create-failed.c
@@ -0,0 +1,158 @@
+ * @file
+ * @ingroup RTEMSTestCaseScoreThreadValFatalIdleThreadCreateFailed
+ * Copyright (C) 2022 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include "tr-fatal-idle-thread-create-failed.h"
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseScoreThreadValFatalIdleThreadCreateFailed \
+ *   spec:/score/thread/val/fatal-idle-thread-create-failed
+ * @ingroup RTEMSTestSuiteTestsuitesFatalIdleThreadCreateFailed
+ * @brief Tests a fatal error caused by a failing task create extension.
+ * This test case performs the following actions:
+ * - The test action is carried out by configuring a task create extension
+ *   which always fails.
+ *   - Check that the expected fatal source is present.
+ *   - Check that the expected fatal code is present.
+ * @brief Test context for
+ *   spec:/score/thread/val/fatal-idle-thread-create-failed test case.
+typedef struct {
+   * @brief This member contains a copy of the corresponding
+   *   ScoreThreadValFatalIdleThreadCreateFailed_Run() parameter.
+  rtems_fatal_source source;
+  rtems_fatal_code code;
+} ScoreThreadValFatalIdleThreadCreateFailed_Context;
+static ScoreThreadValFatalIdleThreadCreateFailed_Context
+  ScoreThreadValFatalIdleThreadCreateFailed_Instance;
+static T_fixture ScoreThreadValFatalIdleThreadCreateFailed_Fixture = {
+  .setup = NULL,
+  .stop = NULL,
+  .teardown = NULL,
+  .scope = NULL,
+  .initial_context = &ScoreThreadValFatalIdleThreadCreateFailed_Instance
+ * @brief The test action is carried out by configuring a task create extension
+static void ScoreThreadValFatalIdleThreadCreateFailed_Action_0(
+  ScoreThreadValFatalIdleThreadCreateFailed_Context *ctx
+  /* Nothing to do */
+   * Check that the expected fatal source is present.
+  T_step_eq_int( 0, ctx->source, INTERNAL_ERROR_CORE );
+   * Check that the expected fatal code is present.
+  T_step_eq_ulong(
+    1,
+    ctx->code,
+void ScoreThreadValFatalIdleThreadCreateFailed_Run(
+  rtems_fatal_source source,
+  ScoreThreadValFatalIdleThreadCreateFailed_Context *ctx;
+  ctx = &ScoreThreadValFatalIdleThreadCreateFailed_Instance;
+  ctx->source = source;
+  ctx->code = code;
+  ctx = T_case_begin(
+    "ScoreThreadValFatalIdleThreadCreateFailed",
+    &ScoreThreadValFatalIdleThreadCreateFailed_Fixture
+  T_plan( 2 );
+  ScoreThreadValFatalIdleThreadCreateFailed_Action_0( ctx );
+  T_case_end();
diff --git a/testsuites/validation/tr-fatal-idle-thread-create-failed.h b/testsuites/validation/tr-fatal-idle-thread-create-failed.h
index 0000000000..15d4c9a086
--- /dev/null
+++ b/testsuites/validation/tr-fatal-idle-thread-create-failed.h
@@ -0,0 +1,84 @@
+ * @file
+ * are met:
+#ifndef _TR_FATAL_IDLE_THREAD_CREATE_FAILED_H
+#define _TR_FATAL_IDLE_THREAD_CREATE_FAILED_H
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup RTEMSTestCaseScoreThreadValFatalIdleThreadCreateFailed
+ * @brief Runs the parameterized test case.
+ * @param source is the fatal source.
+ * @param code is the fatal code.
+#ifdef __cplusplus
+#endif
+#endif /* _TR_FATAL_IDLE_THREAD_CREATE_FAILED_H */
diff --git a/testsuites/validation/ts-fatal-idle-thread-create-failed.c b/testsuites/validation/ts-fatal-idle-thread-create-failed.c
index 0000000000..55173f21d1
--- /dev/null
+++ b/testsuites/validation/ts-fatal-idle-thread-create-failed.c
@@ -0,0 +1,90 @@
+ * @file
+ * are met:
+#endif
+ * @defgroup RTEMSTestSuiteTestsuitesFatalIdleThreadCreateFailed \
+ *   spec:/testsuites/fatal-idle-thread-create-failed
+ * @ingroup RTEMSTestSuites
+ * @brief This validation test suite contains a test case which is triggered by
+ *   a fatal error during system initialization.
+const char rtems_test_name[] = "FatalIdleThreadCreateFailed";
+static bool CreateTask( rtems_tcb *executing, rtems_tcb *created )
+  (void) executing;
+  (void) created;
+  return false;
+#define FATAL_SYSINIT_RUN ScoreThreadValFatalIdleThreadCreateFailed_Run
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
+#define FATAL_SYSINIT_INITIAL_EXTENSION { .thread_create = CreateTask }
+#include "ts-fatal-sysinit.h"
diff --git a/testsuites/validation/ts-fatal-sysinit.h b/testsuites/validation/ts-fatal-sysinit.h
index 5744bc6fea..09d86d02ea 100644
--- a/testsuites/validation/ts-fatal-sysinit.h
+++ b/testsuites/validation/ts-fatal-sysinit.h
@@ -122,7 +122,14 @@ RTEMS_SYSINIT_ITEM(
 #define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
+#ifdef FATAL_SYSINIT_INITIAL_EXTENSION
+#define OPTIONAL_FATAL_SYSINIT_INITIAL_EXTENSION FATAL_SYSINIT_INITIAL_EXTENSION,
+#else
+#endif
 #define CONFIGURE_INITIAL_EXTENSIONS \
+  OPTIONAL_FATAL_SYSINIT_INITIAL_EXTENSION \
   { .fatal = FatalInitialExtension }, \
   { .fatal = TestSuiteFatalExtension }
2.35.3
