[PATCH 08/13] score: Add CPU_THREAD_LOCAL_STORAGE_VARIANT
Sebastian Huber
Fri Sep 30 09:21:31 UTC 2022
Update #3835.
bsps/powerpc/shared/cpu.c | 2 +-
cpukit/include/rtems/score/tls.h | 204 ++++++++----------
cpukit/score/cpu/aarch64/cpu.c | 2 +-
.../cpu/aarch64/include/rtems/score/cpuimpl.h | 3 +
cpukit/score/cpu/arm/__aeabi_read_tp.c | 6 +-
cpukit/score/cpu/arm/__tls_get_addr.c | 6 +-
.../score/cpu/arm/armv7m-context-initialize.c | 2 +-
cpukit/score/cpu/arm/cpu.c | 17 +-
.../score/cpu/arm/include/rtems/score/cpu.h | 10 +-
.../cpu/arm/include/rtems/score/cpuimpl.h | 2 +
.../cpu/bfin/include/rtems/score/cpuimpl.h | 2 +
cpukit/score/cpu/i386/cpu.c | 2 +-
.../cpu/i386/include/rtems/score/cpuimpl.h | 2 +
.../cpu/lm32/include/rtems/score/cpuimpl.h | 2 +
cpukit/score/cpu/m68k/__m68k_read_tp.c | 4 +-
cpukit/score/cpu/m68k/cpu.c | 5 +-
.../score/cpu/m68k/include/rtems/score/cpu.h | 1 +
.../cpu/m68k/include/rtems/score/cpuimpl.h | 2 +
cpukit/score/cpu/microblaze/__tls_get_addr.c | 10 +-
cpukit/score/cpu/microblaze/cpu.c | 2 +-
.../cpu/microblaze/include/rtems/score/cpu.h | 1 +
.../microblaze/include/rtems/score/cpuimpl.h | 3 +
.../cpu/mips/include/rtems/score/cpuimpl.h | 2 +
.../cpu/moxie/include/rtems/score/cpuimpl.h | 2 +
.../cpu/nios2/include/rtems/score/cpuimpl.h | 2 +
.../cpu/nios2/nios2-context-initialize.c | 5 +-
.../cpu/no_cpu/include/rtems/score/cpuimpl.h | 18 ++
.../cpu/or1k/include/rtems/score/cpuimpl.h | 2 +
.../cpu/powerpc/include/rtems/score/cpuimpl.h | 2 +
.../cpu/riscv/include/rtems/score/cpuimpl.h | 2 +
.../cpu/riscv/riscv-context-initialize.c | 2 +-
.../cpu/sh/include/rtems/score/cpuimpl.h | 2 +
cpukit/score/cpu/sparc/cpu.c | 2 +-
.../cpu/sparc/include/rtems/score/cpuimpl.h | 2 +
cpukit/score/cpu/sparc64/cpu.c | 2 +-
.../cpu/sparc64/include/rtems/score/cpuimpl.h | 2 +
.../cpu/v850/include/rtems/score/cpuimpl.h | 2 +
.../cpu/x86_64/include/rtems/score/cpuimpl.h | 2 +
cpukit/score/src/threadinitialize.c | 6 +-
cpukit/score/src/tlsallocsize.c | 44 ++--
40 files changed, 208 insertions(+), 183 deletions(-)
diff --git a/bsps/powerpc/shared/cpu.c b/bsps/powerpc/shared/cpu.c
index a06b8c0868..c38b60b4ee 100644
--- a/bsps/powerpc/shared/cpu.c
+++ b/bsps/powerpc/shared/cpu.c
@@ -130,7 +130,7 @@ void _CPU_Context_Initialize(
#endif
if ( tls_area != NULL ) {
- void *tls_block = _TLS_TCB_before_TLS_block_initialize( tls_area );
+ void *tls_block = _TLS_Initialize_area( tls_area );
the_ppc_context->tp = (uintptr_t) tls_block + 0x7000;
diff --git a/cpukit/include/rtems/score/tls.h b/cpukit/include/rtems/score/tls.h
index ee4fb9a22e..9c90b6362b 100644
--- a/cpukit/include/rtems/score/tls.h
+++ b/cpukit/include/rtems/score/tls.h
@@ -10,7 +10,7 @@
- * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * Copyright (C) 2014, 2022 embedded brains GmbH
* modification, are permitted provided that the following conditions
@@ -37,7 +37,7 @@
#ifndef _RTEMS_SCORE_TLS_H
#define _RTEMS_SCORE_TLS_H
-#include <rtems/score/cpu.h>
+#include <rtems/score/cpuimpl.h>
@@ -116,9 +116,9 @@ typedef struct {
} TLS_Index;
- * @brief Gets the TLS size.
+ * @brief Gets the size of the thread-local storage data in bytes.
- * @return The TLS size.
+ * @return Returns the size of the thread-local storage data in bytes.
static inline uintptr_t _TLS_Get_size( void )
@@ -135,82 +135,64 @@ static inline uintptr_t _TLS_Get_size( void )
- * @brief Returns the value aligned up to the stack alignment.
+ * @brief Gets the size of the thread control block area in bytes.
- * @param val The value to align.
- * @return The value aligned to the stack alignment.
+ * @return Returns the size of the thread control block area in bytes.
-static inline uintptr_t _TLS_Align_up( uintptr_t val )
+static inline uintptr_t _TLS_Get_thread_control_block_area_size( void )
- uintptr_t alignment = CPU_STACK_ALIGNMENT;
+#if CPU_THREAD_LOCAL_STORAGE_VARIANT == 11
+ uintptr_t alignment;
- return RTEMS_ALIGN_UP( val, alignment );
+ alignment = (uintptr_t) _TLS_Alignment;
- * @brief Returns the size of the thread control block area size for this
- * alignment, or the minimum size if alignment is too small.
- * @param alignment The alignment for the operation.
- * @return The size of the thread control block area.
-static inline uintptr_t _TLS_Get_thread_control_block_area_size(
- return alignment <= sizeof(TLS_Thread_control_block) ?
- sizeof(TLS_Thread_control_block) : alignment;
+ return RTEMS_ALIGN_UP( sizeof( TLS_Thread_control_block ), alignment );
+#else
+ return sizeof( TLS_Thread_control_block );
+#endif
- * @brief Return the TLS area allocation size.
+ * @brief Gets the allocation size of the thread-local storage area in bytes.
- * @return The TLS area allocation size.
+ * @return Returns the allocation size of the thread-local storage area in
+ * bytes.
uintptr_t _TLS_Get_allocation_size( void );
- * @brief Copies TLS size bytes from the address tls_area and returns a pointer
- * to the start of the area after clearing it.
- * @param tls_area The starting address of the area to clear.
+ * @brief Initializes the thread-local storage data.
- * @return The pointer to the beginning of the cleared section.
+ * @param[out] tls_data is the thread-local storage data to initialize.
-static inline void *_TLS_Copy_and_clear( void *tls_area )
+static inline void _TLS_Copy_and_clear( void *tls_data )
- tls_area = memcpy(
- tls_area,
+ tls_data = memcpy(
+ tls_data,
_TLS_Data_begin,
(size_t) ((uintptr_t)_TLS_Data_size)
memset(
- (char *) tls_area + (size_t)((intptr_t) _TLS_BSS_begin) -
+ (char *) tls_data + (size_t)((intptr_t) _TLS_BSS_begin) -
(size_t)((intptr_t) _TLS_Data_begin),
0,
((size_t) (intptr_t)_TLS_BSS_size)
- return tls_area;
- * @brief Initializes the dynamic thread vector.
+ * @brief Initializes the thread control block and the dynamic thread vector.
+ * @param tls_data is the thread-local storage data address.
- * @param tls_block The tls block for @a dtv.
- * @param tcb The thread control block for @a dtv.
- * @param[out] dtv The dynamic thread vector to initialize.
+ * @param[out] tcb is the thread control block to initialize.
- * @return Pointer to an area that was copied and cleared from tls_block
- * onwards (@see _TLS_Copy_and_clear).
+ * @param[out] dtv is the dynamic thread vector to initialize.
-static inline void *_TLS_Initialize(
- void *tls_block,
- TLS_Thread_control_block *tcb,
+static inline void _TLS_Initialize_TCB_and_DTV(
+ void *tls_data,
+ TLS_Thread_control_block *tcb,
TLS_Dynamic_thread_vector *dtv
@@ -220,86 +202,70 @@ static inline void *_TLS_Initialize(
#else
tcb->dtv = dtv;
dtv->generation_number = 1;
- dtv->tls_blocks[0] = tls_block;
+ dtv->tls_blocks[0] = tls_data;
#endif
- return _TLS_Copy_and_clear( tls_block );
- * @brief Initializes a dynamic thread vector beginning at the given starting
- * address.
- * Use Variant I, TLS offsets emitted by linker takes the TCB into account.
+ * @brief Initializes the thread-local storage area.
- * @param tls_area The tls area for the initialization.
+ * @param tls_area[out] is the thread-local storage area to initialize.
+ * @return Where the architectures uses Variant I and the TLS offsets emitted
+ * by the linker neglect the TCB, returns the address of the thread-local
+ * storage data. Otherwise, returns the address of the thread control block.
-static inline void *_TLS_TCB_at_area_begin_initialize( void *tls_area )
+static inline void *_TLS_Initialize_area( void *tls_area )
- void *tls_block = (char *) tls_area
- + _TLS_Get_thread_control_block_area_size( (uintptr_t) _TLS_Alignment );
- TLS_Thread_control_block *tcb = (TLS_Thread_control_block *) tls_area;
- uintptr_t aligned_size = _TLS_Align_up( (uintptr_t) _TLS_Size );
- TLS_Dynamic_thread_vector *dtv = (TLS_Dynamic_thread_vector *)
- ((char *) tls_block + aligned_size);
- return _TLS_Initialize( tls_block, tcb, dtv );
+ void *tls_data;
+ TLS_Thread_control_block *tcb;
+ TLS_Dynamic_thread_vector *dtv;
+ void *return_value;
+ uintptr_t tcb_size;
+#endif
+#if CPU_THREAD_LOCAL_STORAGE_VARIANT == 20
+ uintptr_t size;
+ uintptr_t alignment_2;
+#endif
- * @brief Initializes a dynamic thread vector with the area before a given
- * starting address as thread control block.
- * Use Variant I, TLS offsets emitted by linker neglects the TCB.
-static inline void *_TLS_TCB_before_TLS_block_initialize( void *tls_area )
- ((char *) tls_block - sizeof(*tcb));
- * @brief Initializes a dynamic thread vector with the area after a given
- * Use Variant II
-static inline void *_TLS_TCB_after_TLS_block_initialize( void *tls_area )
- uintptr_t size = (uintptr_t) _TLS_Size;
- uintptr_t tls_align = (uintptr_t) _TLS_Alignment;
- uintptr_t tls_mask = tls_align - 1;
- uintptr_t heap_align = _TLS_Align_up( tls_align );
- uintptr_t heap_mask = heap_align - 1;
- ((char *) tls_area + ((size + heap_mask) & ~heap_mask));
- void *tls_block = (char *) tcb - ((size + tls_mask) & ~tls_mask);
- ((char *) tcb + sizeof(*tcb));
- _TLS_Initialize( tls_block, tcb, dtv );
- return tcb;
+#ifdef __i386__
+ dtv = NULL;
+#else
+ dtv = (TLS_Dynamic_thread_vector *) tls_area;
+ tls_area = (char *) tls_area + sizeof( *dtv );
+#endif
+#if CPU_THREAD_LOCAL_STORAGE_VARIANT == 10
+ tls_data = (void *)
+ RTEMS_ALIGN_UP( (uintptr_t) tls_area + sizeof( *tcb ), alignment );
+ tcb = (TLS_Thread_control_block *) ((char *) tls_data - sizeof( *tcb ));
+ return_value = tls_data;
+#elif CPU_THREAD_LOCAL_STORAGE_VARIANT == 11
+ tcb_size = RTEMS_ALIGN_UP( sizeof( *tcb ), alignment );
+ RTEMS_ALIGN_UP( (uintptr_t) tls_area + tcb_size, alignment );
+ tcb = (TLS_Thread_control_block *) ((char *) tls_data - tcb_size);
+ return_value = tcb;
+#elif CPU_THREAD_LOCAL_STORAGE_VARIANT == 20
+ alignment_2 = RTEMS_ALIGN_UP( alignment, CPU_SIZEOF_POINTER );
+ tls_area = (void *) RTEMS_ALIGN_UP( (uintptr_t) tls_area, alignment_2 );
+ size = _TLS_Get_size();
+ ((char *) tls_area + RTEMS_ALIGN_UP( size, alignment_2 ));
+ tls_data = (char *) tcb - RTEMS_ALIGN_UP( size, alignment );
+#else
+#error "unexpected CPU_THREAD_LOCAL_STORAGE_VARIANT value"
+#endif
+ _TLS_Initialize_TCB_and_DTV( tls_data, tcb, dtv );
+ _TLS_Copy_and_clear( tls_data );
+ return return_value;
diff --git a/cpukit/score/cpu/aarch64/cpu.c b/cpukit/score/cpu/aarch64/cpu.c
index 923f53da08..207508302b 100644
--- a/cpukit/score/cpu/aarch64/cpu.c
+++ b/cpukit/score/cpu/aarch64/cpu.c
@@ -142,7 +142,7 @@ void _CPU_Context_Initialize(
the_context->thread_id = (uintptr_t) tls_area;
- _TLS_TCB_at_area_begin_initialize( tls_area );
+ the_context->thread_id = (uintptr_t) _TLS_Initialize_area( tls_area );
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
index 880ae7d9f7..b520e8bffb 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h
@@ -50,8 +50,11 @@
#define CPU_PER_CPU_CONTROL_SIZE 0
#define CPU_INTERRUPT_FRAME_SIZE 0x2E0
+#define CPU_THREAD_LOCAL_STORAGE_VARIANT 11
#ifndef ASM
#ifdef __cplusplus
diff --git a/cpukit/score/cpu/arm/__aeabi_read_tp.c b/cpukit/score/cpu/arm/__aeabi_read_tp.c
index 671065825d..8ae218bbcb 100644
--- a/cpukit/score/cpu/arm/__aeabi_read_tp.c
+++ b/cpukit/score/cpu/arm/__aeabi_read_tp.c
@@ -42,15 +42,15 @@ void __attribute__((naked)) __aeabi_read_tp(void)
"ldr r0, =_Per_CPU_Information\n"
"ldr r0, [r0, %[executingoff]]\n"
#if defined(__thumb__) && !defined(__thumb2__)
- "add r0, %[tlsareaoff]\n"
+ "add r0, %[threadidoff]\n"
"ldr r0, [r0]\n"
#else
- "ldr r0, [r0, %[tlsareaoff]]\n"
+ "ldr r0, [r0, %[threadidoff]]\n"
#endif
"bx lr\n"
: [executingoff] "I" (offsetof(Per_CPU_Control, executing)),
- [tlsareaoff] "I" (offsetof(Thread_Control, Start.tls_area))
+ [threadidoff] "I" (offsetof(Thread_Control, Registers.thread_id))
diff --git a/cpukit/score/cpu/arm/__tls_get_addr.c b/cpukit/score/cpu/arm/__tls_get_addr.c
index 5c8e60ae06..d75ddf93de 100644
--- a/cpukit/score/cpu/arm/__tls_get_addr.c
+++ b/cpukit/score/cpu/arm/__tls_get_addr.c
@@ -39,10 +39,10 @@ void *__tls_get_addr(const TLS_Index *ti);
const Thread_Control *executing = _Thread_Get_executing();
- void *tls_block = (char *) executing->Start.tls_area
+ void *tls_data = (char *) executing->Registers.thread_id
+ + _TLS_Get_thread_control_block_area_size();
assert(ti->module == 1);
- return (char *) tls_block + ti->offset;
+ return (char *) tls_data + ti->offset;
diff --git a/cpukit/score/cpu/arm/armv7m-context-initialize.c b/cpukit/score/cpu/arm/armv7m-context-initialize.c
index 6bdedecb77..58c7269193 100644
--- a/cpukit/score/cpu/arm/armv7m-context-initialize.c
+++ b/cpukit/score/cpu/arm/armv7m-context-initialize.c
@@ -61,7 +61,7 @@ void _CPU_Context_Initialize(
context->register_sp = stack_area_end;
+ _TLS_Initialize_area( tls_area );
diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
index b2cc6039b0..b685c4d6ab 100644
--- a/cpukit/score/cpu/arm/cpu.c
+++ b/cpukit/score/cpu/arm/cpu.c
@@ -56,13 +56,11 @@
#endif
-#ifdef ARM_MULTILIB_HAS_THREAD_ID_REGISTER
- RTEMS_STATIC_ASSERT(
- offsetof( Context_Control, thread_id )
- == ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET,
- ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET
-#endif
+RTEMS_STATIC_ASSERT(
+ offsetof( Context_Control, thread_id )
+ == ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET,
+ ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET
#ifdef ARM_MULTILIB_ARCH_V4
@@ -118,13 +116,10 @@ void _CPU_Context_Initialize(
the_context->register_sp = (uint32_t) stack_area_begin + stack_area_size;
the_context->register_lr = (uint32_t) entry_point;
the_context->isr_dispatch_disable = 0;
the_context->thread_id = (uint32_t) tls_area;
-#endif
+ the_context->thread_id = (uint32_t) _TLS_Initialize_area( tls_area );
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu.h b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
index beb917a0b7..70b53ded62 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
@@ -176,9 +176,7 @@
#define CPU_MAXIMUM_PROCESSORS 32
- #define ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET 44
-#endif
+#define ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET 44
#ifdef ARM_MULTILIB_VFP
#define ARM_CONTEXT_CONTROL_D8_OFFSET 48
@@ -191,10 +189,8 @@
#ifdef RTEMS_SMP
#if defined(ARM_MULTILIB_VFP)
#define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 112
- #elif defined(ARM_MULTILIB_HAS_THREAD_ID_REGISTER)
- #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 48
#else
- #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 44
+ #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 48
#endif
#endif
@@ -240,9 +236,7 @@ typedef struct {
#else
void *register_sp;
#endif
uint32_t thread_id;
-#endif
uint64_t register_d8;
uint64_t register_d9;
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
index 6e8230ce30..56eccf2e6f 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
@@ -60,6 +60,8 @@
#endif /* ARM_MULTILIB_ARCH_V4 */
#ifndef ASM
#ifdef __cplusplus
diff --git a/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h
index a03bc596ba..695963858a 100644
--- a/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h
@@ -29,6 +29,8 @@
+#define CPU_THREAD_LOCAL_STORAGE_VARIANT 10
#ifndef ASM
#ifdef __cplusplus
diff --git a/cpukit/score/cpu/i386/cpu.c b/cpukit/score/cpu/i386/cpu.c
index e89cdebdbe..9a3b188d10 100644
--- a/cpukit/score/cpu/i386/cpu.c
+++ b/cpukit/score/cpu/i386/cpu.c
@@ -193,7 +193,7 @@ void _CPU_Context_Initialize(
the_context->esp = (void *) _stack;
- tcb = (uint32_t) _TLS_TCB_after_TLS_block_initialize( tls_area );
+ tcb = (uint32_t) _TLS_Initialize_area( tls_area );
} else {
tcb = 0;
diff --git a/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
index 4f99f64711..6f67fa2878 100644
--- a/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h
@@ -50,6 +50,8 @@
#define CPU_INTERRUPT_FRAME_SIZE 52
+#define CPU_THREAD_LOCAL_STORAGE_VARIANT 20
#ifndef ASM
#ifdef __cplusplus
diff --git a/cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h
index dce0cc6017..c49012af1f 100644
--- a/cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h
@@ -28,6 +28,8 @@
#ifndef ASM
#ifdef __cplusplus
diff --git a/cpukit/score/cpu/m68k/__m68k_read_tp.c b/cpukit/score/cpu/m68k/__m68k_read_tp.c
index e15ac3fed3..43dd1d16ac 100644
--- a/cpukit/score/cpu/m68k/__m68k_read_tp.c
+++ b/cpukit/score/cpu/m68k/__m68k_read_tp.c
@@ -37,9 +37,7 @@ void __m68k_read_tp(void);
- void *tp = (char *) executing->Start.tls_area +
- _TLS_Get_thread_control_block_area_size((uintptr_t) _TLS_Alignment)
- + 0x7000;
+ void *tp = executing->Registers.thread_pointer;
__asm__ volatile (
"move.l %0, %%a0"
diff --git a/cpukit/score/cpu/m68k/cpu.c b/cpukit/score/cpu/m68k/cpu.c
index 9f6fb9223e..44dc06cc91 100644
--- a/cpukit/score/cpu/m68k/cpu.c
+++ b/cpukit/score/cpu/m68k/cpu.c
@@ -279,6 +279,9 @@ void _CPU_Context_Initialize(
#endif
- _TLS_TCB_before_TLS_block_initialize( tls_area );
+ the_context->thread_pointer =
+ (char *) _TLS_Initialize_area( tls_area ) + 0x7000;
+ } else {
+ the_context->thread_pointer = NULL;
diff --git a/cpukit/score/cpu/m68k/include/rtems/score/cpu.h b/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
index 8fdcb8c15a..ae3194b9bb 100644
--- a/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/include/rtems/score/cpu.h
@@ -145,6 +145,7 @@ typedef struct {
#if defined( __mcoldfire__ ) && ( M68K_HAS_FPU == 1 )
uint8_t fpu_dis;
#endif
+ void *thread_pointer;
} Context_Control;
#define _CPU_Context_Get_SP( _context ) \
diff --git a/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h
index b94c846bf2..f712433833 100644
--- a/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h
@@ -48,6 +48,8 @@
#ifndef ASM
#ifdef __cplusplus
diff --git a/cpukit/score/cpu/microblaze/__tls_get_addr.c b/cpukit/score/cpu/microblaze/__tls_get_addr.c
index e779a63488..b7e7890013 100644
--- a/cpukit/score/cpu/microblaze/__tls_get_addr.c
+++ b/cpukit/score/cpu/microblaze/__tls_get_addr.c
@@ -46,9 +46,11 @@ void *__tls_get_addr( const TLS_Index *ti );
- const Thread_Control *executing = _Thread_Get_executing();
+ const Thread_Control *executing;
+ (void) ti;
+ executing = _Thread_Get_executing();
+ return executing->Registers.thread_pointer;
diff --git a/cpukit/score/cpu/microblaze/cpu.c b/cpukit/score/cpu/microblaze/cpu.c
index 1e829a4714..823825d2b1 100644
--- a/cpukit/score/cpu/microblaze/cpu.c
+++ b/cpukit/score/cpu/microblaze/cpu.c
@@ -73,7 +73,7 @@ void _CPU_Context_Initialize(
context->rmsr = msr;
+ context->thread_pointer = _TLS_Initialize_area( tls_area );
diff --git a/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h b/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h
index 1325962f7c..3d865732d6 100644
--- a/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/microblaze/include/rtems/score/cpu.h
@@ -137,6 +137,7 @@ typedef struct {
uint32_t r30;
uint32_t r31;
uint32_t rmsr;
} Context_Control;
diff --git a/cpukit/score/cpu/microblaze/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/microblaze/include/rtems/score/cpuimpl.h
index 0b9e06cfa8..4e315e856d 100644
--- a/cpukit/score/cpu/microblaze/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/microblaze/include/rtems/score/cpuimpl.h
@@ -49,8 +49,11 @@
#define CPU_INTERRUPT_FRAME_SIZE 56
#define MICROBLAZE_INTERRUPT_FRAME_R3 0
#define MICROBLAZE_INTERRUPT_FRAME_R4 4
#define MICROBLAZE_INTERRUPT_FRAME_R5 8
diff --git a/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h
index cb4c925630..64be130906 100644
--- a/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h
@@ -48,6 +48,8 @@
#ifndef ASM
#ifdef __cplusplus
diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
index 9c6ae11d74..d009186bbc 100644
--- a/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
@@ -48,6 +48,8 @@
#ifndef ASM
#ifdef __cplusplus
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
index 56c2cb0108..f257cba55f 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
@@ -48,6 +48,8 @@
#ifndef ASM
#ifdef __cplusplus
diff --git a/cpukit/score/cpu/nios2/nios2-context-initialize.c b/cpukit/score/cpu/nios2/nios2-context-initialize.c
index fe458cc2ca..14a06374b4 100644
--- a/cpukit/score/cpu/nios2/nios2-context-initialize.c
+++ b/cpukit/score/cpu/nios2/nios2-context-initialize.c
@@ -90,9 +90,6 @@ void _CPU_Context_Initialize(
- context->r23 = (uintptr_t) tls_area +
- _TLS_Get_thread_control_block_area_size( (uintptr_t) _TLS_Alignment ) +
- 0x7000;
+ context->r23 = (uintptr_t) _TLS_Initialize_area( tls_area ) + 0x7000;
diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
index d5082383e8..72d223de24 100644
--- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h
@@ -54,6 +54,24 @@
+ * @brief Defines the thread-local storage (TLS) variant.
+ * Use one of the following values:
+ * 10: The architecture uses Variant I and the TLS offsets emitted by the
+ * linker neglect the TCB (examples: nios2, m68k, microblaze, powerpc,
+ * riscv). The thread pointer directly references the thread-local data
+ * area.
+ * 11: The architecture uses Variant I and the TLS offsets emitted by the
+ * linker take the TCB into account (examples: arm, aarch64).
+ * The thread pointer references the TCB.
+ * 20: The architecture uses Variant II (examples: i386, sparc).
#ifndef ASM
#ifdef __cplusplus
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h
index 352f14589a..8fbf8ba547 100644
--- a/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h
@@ -48,6 +48,8 @@
#ifndef ASM
#ifdef __cplusplus
diff --git a/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h
index c81675b53d..fa223f9aa8 100644
--- a/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h
@@ -151,6 +151,8 @@
#ifdef RTEMS_SMP
/* Use SPRG0 for the per-CPU control of the current processor */
diff --git a/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h
index 5fd25e32cf..627c48f94c 100644
--- a/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h
@@ -54,6 +54,8 @@
#define CPU_PER_CPU_CONTROL_SIZE 16
#endif
#ifdef RTEMS_SMP
#define RISCV_CONTEXT_IS_EXECUTING 0
#endif
diff --git a/cpukit/score/cpu/riscv/riscv-context-initialize.c b/cpukit/score/cpu/riscv/riscv-context-initialize.c
index c6bd99ebbd..572dc3ede3 100644
--- a/cpukit/score/cpu/riscv/riscv-context-initialize.c
+++ b/cpukit/score/cpu/riscv/riscv-context-initialize.c
@@ -68,7 +68,7 @@ void _CPU_Context_Initialize(
void *tls_block;
- tls_block = _TLS_TCB_before_TLS_block_initialize( tls_area );
+ tls_block = _TLS_Initialize_area( tls_area );
context->tp = (uintptr_t) tls_block;
diff --git a/cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h
index 295b01eeaa..1746d677c0 100644
--- a/cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h
@@ -29,6 +29,8 @@
#ifndef ASM
#ifdef __cplusplus
diff --git a/cpukit/score/cpu/sparc/cpu.c b/cpukit/score/cpu/sparc/cpu.c
index b910d96d8d..ca11229023 100644
--- a/cpukit/score/cpu/sparc/cpu.c
+++ b/cpukit/score/cpu/sparc/cpu.c
@@ -319,7 +319,7 @@ void _CPU_Context_Initialize(
- void *tcb = _TLS_TCB_after_TLS_block_initialize( tls_area );
+ void *tcb = _TLS_Initialize_area( tls_area );
the_context->g7 = (uintptr_t) tcb;
diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
index e98a75cf32..7a97db7097 100644
--- a/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
@@ -120,6 +120,8 @@
#endif
#if ( SPARC_HAS_FPU == 1 )
* @brief Offset of the CPU_Per_CPU_control::fsr field relative to the
diff --git a/cpukit/score/cpu/sparc64/cpu.c b/cpukit/score/cpu/sparc64/cpu.c
index c93b68a2cc..ae3b359876 100644
--- a/cpukit/score/cpu/sparc64/cpu.c
+++ b/cpukit/score/cpu/sparc64/cpu.c
@@ -132,7 +132,7 @@ void _CPU_Context_Initialize(
diff --git a/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h
index 8df4c8814c..10fe696fab 100644
--- a/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h
@@ -48,6 +48,8 @@
#ifndef ASM
#ifdef __cplusplus
diff --git a/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
index 4b0f78c845..df0b9bc9e9 100644
--- a/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h
@@ -48,6 +48,8 @@
#ifndef ASM
#ifdef __cplusplus
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
index 742763c168..bee49ca124 100644
--- a/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
@@ -32,6 +32,8 @@
#ifndef ASM
#ifdef __cplusplus
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index 9b37206c6d..31698524a9 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -267,12 +267,8 @@ static bool _Thread_Try_initialize(
/* Allocate thread-local storage (TLS) area in stack area */
if ( tls_size > 0 ) {
- uintptr_t tls_align;
stack_end -= tls_size;
- tls_align = (uintptr_t) _TLS_Alignment;
- the_thread->Start.tls_area = (void *)
- ( ( (uintptr_t) stack_end + tls_align - 1 ) & ~( tls_align - 1 ) );
+ the_thread->Start.tls_area = stack_end;
_Stack_Initialize(
diff --git a/cpukit/score/src/tlsallocsize.c b/cpukit/score/src/tlsallocsize.c
index d761f3b6cf..1a4027d517 100644
--- a/cpukit/score/src/tlsallocsize.c
+++ b/cpukit/score/src/tlsallocsize.c
@@ -10,7 +10,7 @@
- * Copyright (C) 2014, 2020 embedded brains GmbH (http://www.embedded-brains.de)
@@ -58,29 +58,45 @@ uintptr_t _TLS_Get_allocation_size( void )
allocation_size = _TLS_Allocation_size;
if ( allocation_size == 0 ) {
- uintptr_t alignment;
- alignment = _TLS_Align_up( (uintptr_t) _TLS_Alignment );
- allocation_size = size;
- allocation_size += _TLS_Get_thread_control_block_area_size( alignment );
-#ifndef __i386__
- allocation_size += sizeof( TLS_Dynamic_thread_vector );
-#endif
+ uintptr_t tls_align;
+ uintptr_t stack_align;
* The TLS area is allocated in the thread storage area. Each allocation
* shall meet the stack alignment requirement.
- allocation_size = _TLS_Align_up( allocation_size );
+ stack_align = CPU_STACK_ALIGNMENT;
+ tls_align = RTEMS_ALIGN_UP( (uintptr_t) _TLS_Alignment, stack_align );
+#ifndef __i386__
+ /* Reserve space for the dynamic thread vector */
+ allocation_size +=
+ RTEMS_ALIGN_UP( sizeof( TLS_Dynamic_thread_vector ), stack_align );
+#endif
+ /* Reserve space for the thread control block */
+ RTEMS_ALIGN_UP( sizeof( TLS_Thread_control_block ), tls_align );
+#else
+ RTEMS_ALIGN_UP( sizeof( TLS_Thread_control_block ), stack_align );
+#endif
+ /* Reserve space for the thread-local storage data */
+ RTEMS_ALIGN_UP( size, tls_align );
+#else
+ RTEMS_ALIGN_UP( size, stack_align );
+#endif
* The stack allocator does not support aligned allocations. Allocate
* enough to do the alignment manually.
- if ( alignment > CPU_STACK_ALIGNMENT ) {
- _Assert( alignment % CPU_STACK_ALIGNMENT == 0 );
- allocation_size += alignment - CPU_STACK_ALIGNMENT;
+ if ( tls_align > stack_align ) {
+ _Assert( tls_align % stack_align == 0 );
+ allocation_size += tls_align - stack_align;
if ( _Thread_Maximum_TLS_size != 0 ) {
2.35.3
