[PATCH 12/13] stackchk: Add rtems_stack_checker_iterate()
Sebastian Huber
Fri Sep 30 09:21:35 UTC 2022
cpukit/include/rtems/stackchk.h | 75 +++++++++++++++
cpukit/libmisc/stackchk/check.c | 158 +++++++++++++++++++-------------
2 files changed, 170 insertions(+), 63 deletions(-)
diff --git a/cpukit/include/rtems/stackchk.h b/cpukit/include/rtems/stackchk.h
index 7968211a51..c836263925 100644
--- a/cpukit/include/rtems/stackchk.h
+++ b/cpukit/include/rtems/stackchk.h
@@ -90,6 +90,81 @@ void rtems_stack_checker_report_usage_with_plugin(
const rtems_printer *printer
+ * @brief This structure contains the stack information provided by the stack
+ * checker for a stack.
+typedef struct {
+ * @brief This member contains the object identifier associated with the
+ * object using the stack.
+ * For interrupt stacks, the object identifier is the processor index.
+ rtems_id id;
+ * @brief This member provides the object name associated with the
+ * For interrupt stacks, the object name is "Interrupt Stack".
+ const char *name;
+ * @brief This member provides the begin address of the stack area.
+ const void *begin;
+ * @brief This member contains the size in byes of the stack area.
+ uintptr_t size;
+ * @brief This member provides the current stack pointer of the stack.
+ * If the current stack pointer is not available, then the value is set to
+ * NULL.
+ const void *current;
+ * @brief This member contains the size in byes of the used stack area.
+ * If the stack checker is not initialized, then the value is set to
+ * UINTPTR_MAX.
+ uintptr_t used;
+} rtems_stack_checker_info;
+ * @brief Visitor routines invoked by rtems_stack_checker_iterate() shall have
+ * this type.
+ * @param info is the stack information.
+ * @param arg is the argument passed to rtems_stack_checker_iterate().
+typedef void ( *rtems_stack_checker_visitor )(
+ const rtems_stack_checker_info *info,
+ void *arg
+ * @brief Iterates over all stacks used by the system and invokes the visitor
+ * routine for each stack.
+ * This method prints a stack usage report for the curently executing
+ * task.
+ * @param visitor is the visitor routine invoked for each stack.
+ * @param arg is the argument passed to each visitor routine invocation during
+ * the iteration.
+void rtems_stack_checker_iterate( rtems_stack_checker_visitor visit, void *arg );
** Prototyped only so the user extension can be installed **
diff --git a/cpukit/libmisc/stackchk/check.c b/cpukit/libmisc/stackchk/check.c
index 48342ce957..53b96f462c 100644
--- a/cpukit/libmisc/stackchk/check.c
+++ b/cpukit/libmisc/stackchk/check.c
@@ -413,134 +413,166 @@ static inline void *Stack_check_Find_high_water_mark(
return (void *) base;
#endif
- return (void *)0;
+ return NULL;
-static bool Stack_check_Dump_stack_usage(
- const Stack_Control *stack,
- const void *current,
- const char *name,
- uint32_t id,
- const rtems_printer *printer
+static void Stack_check_Visit_stack(
+ const Stack_Control *stack,
+ const void *current,
+ const char *name,
+ rtems_id id,
+ rtems_stack_checker_visitor visit,
+ void *arg
- uint32_t size;
- uint32_t used;
- void *low;
- void *high_water_mark;
+ rtems_stack_checker_info info;
/* This is likely to occur if the stack checker is not actually enabled */
if ( stack->area == NULL ) {
- return false;
+ return;
- low = Stack_check_Usable_stack_start(stack);
- size = Stack_check_Usable_stack_size(stack);
+ info.id = id;
+ info.name = name;
+ info.current = current;
+ info.begin = Stack_check_Usable_stack_start( stack );
+ info.size = Stack_check_Usable_stack_size( stack );
- high_water_mark = Stack_check_Find_high_water_mark(low, size);
+ if ( Stack_check_Initialized ) {
+ void *high_water_mark;
- if ( high_water_mark )
- used = Stack_check_Calculate_used( low, size, high_water_mark );
- else
- used = 0;
+ high_water_mark =
+ Stack_check_Find_high_water_mark( info.begin, info.size );
- rtems_printf(
- printer,
- "0x%08" PRIx32 " %-21s 0x%08" PRIxPTR " 0x%08" PRIxPTR " 0x%08" PRIxPTR " %6" PRId32 " ",
- id,
- name,
- (uintptr_t) stack->area,
- (uintptr_t) stack->area + (uintptr_t) stack->size - 1,
- (uintptr_t) current,
- size
- if (Stack_check_Initialized) {
- rtems_printf( printer, "%6" PRId32 "\n", used );
+ if ( high_water_mark != NULL ) {
+ info.used =
+ Stack_check_Calculate_used( info.begin, info.size, high_water_mark );
+ } else {
+ info.used = 0;
} else {
- rtems_printf( printer, "N/A\n" );
+ info.used = UINTPTR_MAX;
- return false;
+ ( *visit )( &info, arg );
-static bool Stack_check_Dump_threads_usage(
+typedef struct {
+ rtems_stack_checker_visitor visit;
+ void *arg;
+} Stack_check_Visitor;
+static bool Stack_check_Visit_thread(
Thread_Control *the_thread,
void *arg
+ Stack_check_Visitor *visitor;
char name[ 22 ];
- const rtems_printer *printer;
uintptr_t sp = _CPU_Context_Get_SP( &the_thread->Registers );
- printer = arg;
+ visitor = arg;
_Thread_Get_name( the_thread, name, sizeof( name ) );
- Stack_check_Dump_stack_usage(
+ Stack_check_Visit_stack(
&the_thread->Start.Initial_stack,
(void *) sp,
name,
the_thread->Object.id,
- printer
+ visitor->visit,
+ visitor->arg
return false;
-static void Stack_check_Dump_interrupt_stack_usage(
- uint32_t id,
+static void Stack_check_Visit_interrupt_stack(
+ uint32_t id,
+ void *arg
stack,
NULL,
"Interrupt Stack",
id,
- printer
+ visit,
+ arg
- * rtems_stack_checker_report_usage
+static void Stack_check_Print_info(
+ void *arg
+ const rtems_printer *printer;
+ printer = arg;
+ rtems_printf(
+ printer,
+ "0x%08" PRIx32 " %-21s 0x%08" PRIxPTR " 0x%08" PRIxPTR " 0x%08" PRIxPTR " %6" PRIuPTR " ",
+ info->id,
+ info->name,
+ (uintptr_t) info->begin,
+ (uintptr_t) info->begin + info->size - 1,
+ (uintptr_t) info->current,
+ info->size
+ if ( info->used != UINTPTR_MAX ) {
+ rtems_printf( printer, "%6" PRIuPTR "\n", info->used );
+ } else {
+ rtems_printf( printer, "N/A\n" );
const rtems_printer* printer
- uint32_t cpu_max;
- uint32_t cpu_index;
rtems_printf(
printer,
" STACK USAGE BY THREAD\n"
"ID NAME LOW HIGH CURRENT AVAIL USED\n"
- /* iterate over all threads and dump the usage */
- rtems_task_iterate(
- Stack_check_Dump_threads_usage,
+ rtems_stack_checker_iterate(
+ Stack_check_Print_info,
RTEMS_DECONST( rtems_printer *, printer )
+void rtems_stack_checker_report_usage( void )
+ rtems_printer printer;
+ rtems_print_printer_printk(&printer);
+ rtems_stack_checker_report_usage_with_plugin( &printer );
+ Stack_check_Visitor visitor;
+ uint32_t cpu_max;
+ uint32_t cpu_index;
+ visitor.visit = visit;
+ visitor.arg = arg;
+ rtems_task_iterate( Stack_check_Visit_thread, &visitor );
cpu_max = rtems_scheduler_get_processor_maximum();
for ( cpu_index = 0; cpu_index < cpu_max; ++cpu_index ) {
- Stack_check_Dump_interrupt_stack_usage(
+ Stack_check_Visit_interrupt_stack(
&Stack_check_Interrupt_stack[ cpu_index ],
cpu_index,
- printer
+ visit,
+ arg
-void rtems_stack_checker_report_usage( void )
- rtems_printer printer;
- rtems_print_printer_printk(&printer);
- rtems_stack_checker_report_usage_with_plugin( &printer );
static void Stack_check_Prepare_interrupt_stacks( void )
Stack_Control stack;
2.35.3
