[PATCH rtems-docs v2] TFTPFS: New documentation
Frank Kühndel
frank.kuehndel at embedded-brains.de
Fri Sep 30 12:36:52 UTC 2022
ping!
Since this patch was sent in June to the list I will shortly recap the
context:
* I extended the TFTP file system by block and window size options.
These patches are already part of RTEMS.
* The patch below is the documentation for it. Version 1 of this patch
has already been reviewed by Chris, Joel and Sebastian (many thanks
again) and I fixed all raised issues (see
https://lists.rtems.org/pipermail/devel/2022-June/071822.html).
* What is missing is an OK for this patch.
For your convenience, I put v2 of the generated filesystem.pdf for
download at the link shown below. I hope the PDF is more convenient to
read than the patch itself. Please, remind that only chapter "Trivial
FTP Client Filesystem" is affected by this patch.
https://share.embedded-brains.de/index.php/s/Qg6aoX7kByxfQLZ
My question is: Do you have more critic or are you OK with v2 of this patch?
Thanks in advance
Frank
On 6/9/22 15:21, Frank Kuehndel wrote:
> Subject:
> From:
> Frank Kuehndel <frank.kuehndel at embedded-brains.de>
> Date:
> 6/9/22, 15:21
> To:
> devel at rtems.org
> From: Frank Kühndel<frank.kuehndel at embedded-brains.de>
> filesystem/index.rst | 1 +
> filesystem/trivial_ftp.rst | 564 ++++++++++++++++++++++++++++++++++++-
> 2 files changed, 562 insertions(+), 3 deletions(-)
> diff --git a/filesystem/index.rst b/filesystem/index.rst
> index f4e2ed6..64a2f1d 100644
> --- a/filesystem/index.rst
> +++ b/filesystem/index.rst
> @@ -9,6 +9,7 @@ RTEMS Filesystem Design Guide (|version|).
> .. topic:: Copyrights and License
> ||copy| 1988, 2015 On-Line Applications Research Corporation (OAR)
> + ||copy| 2022 embedded brains GmbH (http://www.embedded-brains.de)
> .. include:: ../common/license.rst
> diff --git a/filesystem/trivial_ftp.rst b/filesystem/trivial_ftp.rst
> index e43c036..3ef8bba 100644
> --- a/filesystem/trivial_ftp.rst
> +++ b/filesystem/trivial_ftp.rst
> @@ -3,7 +3,565 @@
> Trivial FTP Client Filesystem
> -This chapter describes the Trivial FTP (TFTP) Client Filesystem.
> +This chapter describes the Trivial File Transfer Protocol (TFTP) Client
> +Filesystem. TFTP is designed to be an especially simple protocol which
> +uses the User Datagram Protocol (UDP) for data transfer over the Internet.
> +Its purpose is to send a single file between to network nodes (client and
> +server). A file can be sent in both directions, i.e. a client can either
> +read a file from a server or write a file to the server.
> -This chapter should be written after the IMFS chapter is completed and describe
> -the implementation of the TFTP.
> +Besides reading or writing a file no other operations are supported. That
> +is, one cannot seek the file, not append to the end of a file, not open
> +the file for reading and writing at the same time, not list directories,
> +not move files and so on.
> +TFTP is inherent insecure as it does not provide any means for
> +authentication or encryption. Therefore, it is highly recommended not
> +to employ it on public networks. Nevertheless, it is still widely used
> +to load software and configuration data during early boot stages over
> +a Local Area Network (LAN).
> +RTEMS TFTP Filesystem Implementation
> +The RTEMS TFTP filesystem implements a TFTP client which can be used
> +through the file system. With other words, one needs to mount the
> +TFTP filesystem and can afterwards open a file for reading or writing
> +below that mount point. The content of that file is then effectively
> +read from or written to the remote server. The RTEMS implementation
> +implements the following features:
> +* `RFC 1350<https://www.rfc-editor.org/rfc/rfc1350.html>`_
> + *The TFTP Protocol (Revision 2)*
> +* `RFC 2347<https://www.rfc-editor.org/rfc/rfc2347.html>`_
> +*TFTP Option Extension*
> +* `RFC 2348<https://www.rfc-editor.org/rfc/rfc2348.html>`_
> +*TFTP Blocksize Option*
> +* `RFC 7440<https://www.rfc-editor.org/rfc/rfc7440.html>`_
> +*TFTP Windowsize Option*
> +Many simple TFTP server do not support options (RFC 2347). Therefore, in
> +case the server rejects the first request with options, the RTEMS client
> +makes automatically a second attempt using only the "classical" RFC 1350.
> +The implementation has the following shortcomings:
> +* IPv6 is not supported (yet).
> +* No congestion control is implemented.
> + (Congestion is simply expressed a network traffic jam which involves
> + package loss.) This implementation would worsen a congestion situation
> + and squeeze out TCP connections. If that is a concern in your setup,
> + it can be prevented by using value `1` as `windowsize` when mounting
> + the TFTP file system.
> +* One must call ``open()``, ``read()``, ``write()`` and ``close()``
> + at a good pace.
> + TFTP is designed to read or write a whole already existing file in
> + one sweep. It uses timeouts (of unspecified length) and it does not
> + know keep-alive messages. If the client does not respond to the
> + server in due time, the server sets the connection faulty and drops it.
> + To avoid this, the user must read or write enough data fast enough.
> + The point here is, one cannot pause the reading or writing for longer
> + periods of time. TFTP cannot be used for example to write log files
> + where all few seconds a line is written. Also opening the
> + file at the beginning of an application and closing it that the end
> + will certainly lead to a timeout. As another example, one cannot
> + read a file by reading one byte per second, this will trigger a
> + timeout and the server closes the connection. The opening, reading
> + or writing and closing must happen in swift consecutive steps.
> +* The transfer mode is always ``octet``. The only alternative
> + ``netascii`` cannot be selected.
> +* Block number roll-over is currently not supported. Therefore,
> + the maximum file size is limited to max-block-number times blocksize.
> + For RFC 1350 blocksize is would be 65535 * 512 = 32 MB. For the
> + default blocksize is would be 65535 * 1456 = 90 MB.
> +* The inherent insecurity of the protocol has already be mentioned but
> + it is worth repeating.
> +Prerequisites
> +To use the RTEMS TFTP filesystem one needs:
> +* The RTEMS tools (cross-compiler, linker, debugger etc.)
> +* The RTEMS Board Support Package (BSP)
> +* A network stack for RTEMS, for example RTEMS libbsd
> +As an example the ARM architecture and a xilinx_zynq_a9 BSP is used below
> +together with RTEMS libbsd. The instructions are tested with RTEMS
> +version 6. It is recommended to actually use ``arm/xilinx_zynq_a9_qemu``
> +for the first experiments as other BSPs tend to require different
> +configuration values and/or command line options.
> +Moreover, it is recommended to first execute any code using QEMU as
> +simulator so that no hardware is needed. Therefore, ``qemu-system-arm``
> +must be installed. In Linux distributions this executable is usually
> +available in the repositories as package ``qemu-arm``.
> +RTEMS Tools
> +Instructions on how to obtain, compile and install the RTEMS tools can
> +be found in the*RTEMS User Manual* chapter *2. Quick Start*. To
> +follow the suggested example ``6/rtems-arm`` should be used as
> +target architecture argument of the ``../source-builder/sb-set-builder``
> +command.
> +RTEMS Board Support Package
> +Instructions on how to obtain, compile and install a BSP can be found
> +in the*RTEMS User Manual* section *Build a Board Support Package (BSP)*.
> +The bsp-option should have the following value to match the example BSP:
> +.. code-block:: none
> + --rtems-bsps=arm/xilinx_zynq_a9_qemu
> +RTEMS libbsd
> +Instructions on how to obtain, compile and install RTEMS libbsd can be
> +found in the ``README.rst`` of the ``rtems-libbsd`` GIT repository:
> +``git://git.rtems.org/rtems-libbsd.git``.
> +Make sure to compile and install libbsd for the correct RTEMS version
> +(here ``6``). The default build set (``--buildset=buildset/default.ini``)
> +does suffice and as BSP ``--rtems-bsp=arm/xilinx_zynq_a9_qemu`` is
> +to be used with the ``waf configure`` command.
> +RTEMS Configuration
> +To make the TFTP filesystem available to an RTEMS application and have
> +it initialized, the macro ``CONFIGURE_FILESYSTEM_TFTPFS`` must be
> +defined when configuring RTEMS (typically in the ``init.c`` file):
> +.. code-block:: c
> + #define CONFIGURE_FILESYSTEM_TFTPFS
> +Moreover, libbsd and RTEMS must be configured appropriately as well.
> +For orientation, the code below is from an application using TFTP FS
> +(file ``tftp_init.c``).
> +.. code-block:: c
> + /* Configure libbsd. */
> + #define RTEMS_BSD_CONFIG_NET_PF_UNIX
> + #define RTEMS_BSD_CONFIG_NET_IF_BRIDGE
> + #define RTEMS_BSD_CONFIG_NET_IF_LAGG
> + #define RTEMS_BSD_CONFIG_NET_IF_VLAN
> + #define RTEMS_BSD_CONFIG_BSP_CONFIG
> + #define RTEMS_BSD_CONFIG_INIT
> + #include <machine/rtems-bsd-config.h>
> + /* RTEMS configuration for libbsd */
> + #define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
> + #define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
> + #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
> + #define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
> + #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
> + /* RTEMS configuration for tftp */
> + #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 64
> + /* Simple RTEMS configuration */
> + #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> + #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> + #define CONFIGURE_UNLIMITED_OBJECTS
> + #define CONFIGURE_UNIFIED_WORK_AREAS
> + #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> + #include <rtems/confdefs.h>
> +Application Linkage
> +The TFTP filesystem is compiled and linked into ``libtftpfs``. After
> +installation it should be in a place like:
> + <PREFIX>/arm-rtems6/xilinx_zynq_a9_qemu/lib/libtftpfs.a
> +An RTEMS application which wants to use the TFTP filesystem must be linked
> +with the libraries ``libtftpfs``, ``libbsd``, and ``libm`` --- in this order.
> +An example build target in a ``wscript`` for use with the RTEMS WAF build
> +system could be:
> +.. code-block:: python
> + def build(ctx):
> + rtems.build(ctx)
> + ctx(features = 'c cprogram',
> + target = 'tftp_app.exe',
> + cflags = '-g -O2',
> + source = ['tftp_app.c', 'tftp_init.c'],
> + lib = ['tftpfs', 'bsd', 'm'])
> +Network Configuration and TFTP Server
> +QEMU has a simple build-in TFTP server which can serve files for reading
> +only. By default it is reachable from the application executed by QEMU
> +at IP address ``10.0.2.2`` if SLIRP networking is used. For the
> +example ``arm/xilinx_zynq_a9_qemu`` BSP, the QEMU option
> + -nic user,model=cadence_gem,tftp=/tmp
> +will cause this TFTP server to deliver files found below directory
> +``/tmp``. Note that SLIRP requires that the application uses DHCP.
> +Alternatively, it is of course possible to use other kinds of QEMU
> +networking (as for example the TAP virtual Ethernet interface described
> +in the above mentioned ``README.rst`` in section*Qemu and Networking*).
> +Also an external TFTP server can be used.
> +External TFTP Server Example for OpenSUSE
> +This example uses ``atftp`` as an external TFTP server to which the RTEMS
> +TFTP file system running in an QEMU instance connects to. ``atftp`` was
> +compiled from the sources. Instructions how to compile and install
> +``atftp`` can be found in the ``INSTALL`` file which comes with its sources.
> +On an OpenSUSE 15.3 machine, the following commands sets up ``atftp``
> +for use with the mentioned TAP interface (these commands must be executed
> +as root; ``<APP-USER>`` must be replaced by the name of the "normal"
> +user starting the RTEMS application in QEMU later on; for other
> +distributions the ``firewall-cmd`` commands must be
> +replaced by the equivalent of that distribution):
> +.. code-block:: shell
> + # Create and configure TAP interface
> + ip tuntap add qtap mode tap user <APP-USER>
> + ip link set dev qtap up
> + ip addr add 169.254.1.1/16 dev qtap
> + # Open firewalld as non-permanent configuration
> + firewall-cmd --zone=home --add-service=tftp
> + firewall-cmd --zone=home --add-interface=qtap
> + # Start TFTP daemon
> + touch /var/log/atftpd/atftp.log
> + chown tftp.tftp /var/log/atftpd/atftp.log
> + atftpd --user tftp --group tftp --daemon --verbose \
> + --logfile /var/log/atftpd/atftp.log /srv/tftpboot
> +The ``atftp`` server will then be reachable from an application executed
> +by QEMU at the address of the TAP interface which is in this case
> +``169.254.1.1``. When used with this TAP interface, the QEMU network
> +option must be changed to (replacing the ``-net`` options in the examples
> +found in the already mentioned ``README.rst`` of the ``rtems-libbsd`` GIT
> +repository):
> + -nic tap,model=cadence_gem,ifname=qtap,script=no,downscript=no
> +Usage
> +The following diagram shows how the TFTP filesystem is used by an
> +application. The mount point can be any directory. The name ``/tftp``
> +used in the figure serves only as an example. The final unmounting and
> +remove directory steps are optional.
> +.. figure:: ../images/filesystem/tftpfs_usage.png
> + :width: 90%
> + :align: center
> + :alt: TFTP Usage Diagram
> +Mounting the TFTP Filesystem
> +When mounting the TFTP filesystem, the argument ``filesystemtype`` must
> +be ``RTEMS_FILESYSTEM_TYPE_TFTPFS`` (``#include <rtems/libio.h>``).
> +The argument ``data`` can either be
> +* a 0-terminated C string of comma separated mount options or
> +* ``NULL`` for mounting with default values.
> +The mount options are case sensitive. Spaces are not allowed in the string.
> +If conflicting options are specified, the ones more to the right (i.e. end
> +of the string) take precedence. These mount options are supported:
> +``blocksize=N``
> + where ``N`` is a decimal integer number.
> + The TFTP blocksize option is introduced in RFC 2348. It defines the
> + number of octets in the data packages transferred. Valid values
> + range between 8 and 65464 octets, inclusive. Values larger
> + than 1468 may cause package fragmentation over standard Ethernet.
> + A value of 512 will prevent this option from being sent to
> + the server.
> + The default value is 1456.
> +``windowsize=N``
> + The TFTP windowsize option is introduced in RFC 7440. It defines the
> + number of data packages send before the receiver must send an
> + acknowledgment package. Valid values range between 1 and 65535
> + packages, inclusive. Simple TFTP servers usually do not support this
> + option. This option may negatively contribute to network
> + congestion. This can be avoided by using a window size of 1.
> + A value of 1 will prevent this option from being sent to
> + the server.
> + The default value is 8.
> +``rfc1350``
> + The TFTP client should strictly follow RFC 1350 and not send any
> + options to the server. Many simple TFTP server do still not support
> + the option extension defined in RFC 2347. The TFTP filesystem will
> + always make a second option-less connection attempt to the TFTP server
> + in case a first attempt with options was rejected with an error message.
> + This option is equivalent to ``blocksize=512,windowsize=1``.
> +``verbose``
> + During operation, print messages to ``stdout``. This option has
> + currently little effect. It is kept to be compatible to older
> + implementations.
> +Opening a File
> +Files must be opened by using either ``O_RDONLY`` or ``O_WRONLY``
> +as flags but not both. Other flags are not supported.
> +The ``pathname`` argument to ``open()`` has the following format:
> + <PREFIX>/<server-address>:<path-on-server>
> +``<PREFIX>``
> + The path to the point where the TFTP filesystem is mounted. This can
> + be a relative path from the current working directory or an absolute
> + path.
> +``<server-address>``
> + The network address for the TFTP server from which to download the
> + file or to which the file should be sent. This is either
> + * an IPv4 address (like `127.0.0.1`) or
> + * the (full-qualified) name of an IPv4 host (acceptable to
> + ``gethostbyname()``)
> + The port number cannot be specified and will always be the one reserved
> + for TFTP: 69.
> +``<path-on-server>``
> + The path and file name at which the TFTP server will find or create the
> + file. Any directories in this path must already exist. It is not
> + possible to create or read directories with TFTP. RFC 1350 specifies
> + that this ``<path-on-server>`` must be in*netascii*:
> + This is ascii as defined in "USA Standard Code for Information
> + Interchange" [1] with the modifications specified in "Telnet
> + Protocol Specification" [3].
> + [1] USA Standard Code for Information Interchange, USASI X3.4-1968.
> + [3] Postel, J., "Telnet Protocol Specification," RFC 764,
> + USC/Information Sciences Institute, June, 1980.
> +Example pathnames:
> +.. code-block:: c
> + "/tftp/169.254.1.1:file.txt"
> + "/TFTPFS/tftp-server.sample.org:bootfiles/image"
> +In the above examples, ``/tftp`` and ``/TFTPFS`` are the directory at which
> +the TFTP filesystem is mounted. ``169.254.1.1`` and
> +``tftp-server.sample.org`` are the network address of the TFTP server to
> +contact. ``file.txt`` and ``bootfiles/image`` are the file name and
> +the path at the server side.
> +Closing a File
> +Especially, when writing a file to the server, the return
> +code of ``close()`` should be checked. Invoking ``close()`` triggers
> +the sending of the last -- not completely filled -- data block. This
> +may fail the same way as any ``write()`` may fail. Therefore, an error
> +returned by ``close()`` likely indicates that the file was not completely
> +transferred.
> +Use From Shell
> +It is possible to use the RTEMS shell through test ``media01`` of
> +libbsd to exercise the TFTP filesystem. This text assumes that libbsd
> +has already been setup, configured, compiled and installed as described
> +in the ``README.rst`` of the ``rtems-libbsd`` GIT repository.
> +How the test ``media01.exe`` can be executed is described in
> +section*Qemu and Networking* of that file.
> +A TFTP server must be setup and run. The instructions to setup an TAP
> +device and an ``atftp`` server found above in section `External TFTP
> +Server Example for OpenSUSE`_ could be followed for this purpose.
> +It may be useful to create a sample file for later download in the
> +directory served by the TFTP server. For ``atftp`` "root" could create
> +a file with these instructions:
> + # echo "Hello World!" >/srv/tftpboot/hello.txt
> + # chown tftp.tftp /srv/tftpboot/hello.txt
> +Start the ``media01`` test in one terminal --- as "normal" user:
> + $ qemu-system-arm -serial null -serial mon:stdio -nographic \
> + -M xilinx-zynq-a9 -m 256M \
> + -nic tap,model=cadence_gem,ifname=qtap,script=no,downscript=no \
> + -kernel build/arm-rtems6-xilinx_zynq_a9_qemu-default/media01.exe
> +Wait till a line like the following is printed in the terminal:
> + info: cgem0: using IPv4LL address 169.254.191.13
> +Next use the displayed IP address to open a telnet connection in a second terminal:
> + $ telnet 169.254.191.13
> +At the telnet prompt, enter this command to list the filesystems
> +available for mounting:
> + TLNT [/] # mount -L
> + File systems: / dosfs tftpfs
> +``tftpfs`` should be among them. Create a directory and mount the TFTP
> +filesystem:
> + TLNT [/] # mkdir /tftp
> + TLNT [/] # mount -t tftpfs -o verbose "" /tftp
> + mounted -> /tftp
> +Now, files can be sent to and read from the TFTP server using the usual
> +shell commands:
> + TLNT [/] # cp /etc/dhcpcd.duid /tftp/169.254.1.1:dhcpcd.duid
> + TFTPFS: /169.254.1.1:dhcpcd.duid
> + TLNT [/] # cat /tftp/169.254.1.1:hello.txt
> + TFTPFS: /169.254.1.1:hello.txt
> + Hello World!
> +The terminal session can be terminated with key combination "CTRL-]"
> +followed by a ``quit`` command; the
> +QEMU simulation with "CTRL-a x" and ``tail -f`` with "CTRL-c".
> +TFTP Client API
> +The TFTP filesystem has a TFTP client which is responsible to handle all
> +network traffic. It permits the use of TFTP without filesystem.
> +Essentially, one saves the mounting of the filesystem. Otherwise the
> +usage is similar to the one of the filesystem. The equivalent of the
> +``open()``, ``read()``, ``write()``, and ``close()`` functions are:
> +.. code-block:: c
> + int tftp_open(
> + const char *hostname,
> + const char *path,
> + bool is_for_reading,
> + const tftp_net_config *config,
> + void **tftp_handle
> + ssize_t tftp_read( void *tftp_handle, void *buffer, size_t count );
> + ssize_t tftp_write( void *tftp_handle, const void *buffer, size_t count );
> + int tftp_close( void *tftp_handle );
> +``tftp_open()`` accepts as input a data structure of type
> +``tftp_net_config``. It can be used to specify certain values governing
> +the file transfer such as the already described options. Data of
> +``tftp_net_config`` type can be initialized using function
> +.. code-block:: c
> + void tftp_initialize_net_config( tftp_net_config *config );
> +The full description can be found in the file ``cpukit/include/rtems/tftp.h``.
> +The function ``rtems_tftpfs_initialize()`` found there is only for RTEMS
> +internal use by the ``mount()`` function.
> +Software Design
> +The original source code contained only the files
> +``cpukit/include/rtems/tftp.h`` and ``cpukit/libfs/src/ftpfs/tftpDriver.c``.
> +There was no test suite nor any documentation.
> +When the code was extended to support options (RFC 2347 and others),
> +the code in ``tftpDriver.c`` was split. The new file ``tftpfs.c`` is
> +responsible to handle all filesystem related issues while ``tftpDriver.c``
> +provides the network related functions. In effect ``tftpDriver.c`` is
> +a TFTP client library which can be used independently of the filesystem.
> +``tftpfs.c`` calls the functions of ``tftpDriver.c`` to do the actual
> +TFTP file transfer.
> +At this occasion a test suite and this documentation in the *RTEMS
> +Filesystem Design Guide* was added.
> +Test Suite
> +The TFTP filesystem comes with an extensive test suite.
> +``libtftpfs`` source code is situated in the RTEMS repository. For
> +testing it, either ``libbsd`` or RTEMS legacy networking would have been
> +required. This implies that the tests for ``libtftpfs`` would have
> +needed to be placed in the ``libbsd`` repository --- a different one
> +than the ``libtftpfs`` source code.
> +Yet, ``libtftpfs`` uses only a handful of networking functions. The
> +test suite provides fake implementations of those functions. These fake
> +functions permit to simulate the exchange of UDP packages
> +with the ``libtftpfs`` code and thus permits testing the TFTP filesystem
> +without the need of a full network stack.
> +Consequently, the test suite is placed in the RTEMS repository together
> +with the TFTP filesystem source code. Neither ``libbsd`` nor RTEMS
> +legacy networking is required to run the tests.
> +The test suite can be executed using the ``rtems-test`` tool:
> + $ cd <path-to-rtems-git-worktree>
> + $ rtems-test --log-mode=all --rtems-bsp=xilinx_zynq_a9_qemu \
> + build/arm/xilinx_zynq_a9_qemu/testsuites/fstests/tftpfs.exe
> -- 2.35.3 _______________________________________________ devel mailing
> list devel at rtems.org http://lists.rtems.org/mailman/listinfo/devel
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone: +49-89-18 94 741 - 23
mobile: +49-176-15 22 06 - 11
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
