[PATCH] c-user: Add application config info directives
Fri Sep 30 13:34:59 UTC 2022
On 17/09/2022 09:31, Chris Johns wrote:
>> +rtems_get_version_string()
>> +Gets the RTEMS version string.
>> +.. rubric:: CALLING SEQUENCE:
>> +.. code-block:: c
>> +    const char *rtems_get_version_string( void );
>> +.. rubric:: RETURN VALUES:
>> +Returns the pointer to the RTEMS version string.
> Is the version string subject to change across releases or do as set this string
> format?
> Is it worth discussing the revision values and what they mean?
The version string contains a lot of stuff:
const char _RTEMS_version[] =
   "rtems-" RTEMS_VERSION " (" CPU_NAME "/" CPU_MODEL_NAME "/"
   RTEMS_XSTRING( RTEMS_BSP ) ")";
I don't know if we should specify a particular format.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
