[PATCH rtems-lwip] rtemslwip/xil_shims: Perform flush with invalidate
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Apr 4 12:23:07 UTC 2023
On Mon, Apr 3, 2023 at 8:00 PM Chris Johns <chrisj at rtems.org> wrote:
> On 31/3/2023 8:13 am, Kinsey Moore wrote:
> > Xilinx wrote their A53 HAL with the assumption that the CPU did not
> > support cache invalidation without a flush, so the flush and
> > invalidation functions were combined and all range invalidations are
> > promoted to flush/invalidate. The implementation written for lwIP was
> > written to the original intent of the function and thus was not flushing
> > in some cases when it needed to. This resolves that issue which prevents
> > DMA transmit errors in some cases.
> > rtemslwip/zynqmp/xil_shims.c | 7 ++++++-
> > 1 file changed, 6 insertions(+), 1 deletion(-)
> > diff --git a/rtemslwip/zynqmp/xil_shims.c b/rtemslwip/zynqmp/xil_shims.c
> > index 2eda0c5..1b1b3cf 100644
> > --- a/rtemslwip/zynqmp/xil_shims.c
> > +++ b/rtemslwip/zynqmp/xil_shims.c
> > @@ -102,7 +102,12 @@ void XScuGic_DisableIntr ( u32 DistBaseAddress, u32
> Int_Id )
> > rtems_interrupt_vector_disable( Int_Id );
> > + * The Xilinx code was written such that it assumed there was no
> invalidate-only
> > + * functionality on A53 cores. This function must flush and invalidate
> because
> > + * of how they mapped things.
> > void Xil_DCacheInvalidateRange( INTPTR adr, INTPTR len )
> > - rtems_cache_invalidate_multiple_data_lines( (const void *) adr, len );
> > + rtems_cache_flush_multiple_data_lines( (const void *) adr, len );
> Does the Xilinx code use Xil_DCacheInvalidateRange in any DMA receive
> paths? If
> it does is this change correct as the invalidate has been removed?
It just so happens that the way the code was written, a flush and
invalidate works fine for the receive path. The invalidation that occurs in
the receive path occurs before the pointer to the memory is passed to the
DMA engine, so a flush there doesn't hurt anything (at least for this
particular driver). If more Xilinx drivers get pulled in, that may have to
be reevaluated.
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230404/6fa1f510/attachment.htm>
