[PATCH 1/8] build: Add assert-in-set option action
Sebastian Huber
Tue Apr 4 14:52:51 UTC 2023
wscript | 8 ++++++++
1 file changed, 8 insertions(+)
diff --git a/wscript b/wscript
index 567f42db2f..a5c8b5f236 100755
--- a/wscript
+++ b/wscript
@@ -825,6 +825,13 @@ class OptionItem(Item):
value, self.data["name"], arg))
return value
+ def _assert_in_set(self, conf, cic, value, arg):
+ if value is not None and value not in arg:
+ conf.fatal(
+ "Value '{}' for option '{}' is not an element of {}"
+ .format(value, self.data["name"], arg))
+ return value
def _assert_in_interval(self, conf, cic, value, arg):
if value is not None and (value < arg[0] or value > arg[1]):
conf.fatal(
@@ -1056,6 +1063,7 @@ class OptionItem(Item):
"assert-eq": self._assert_eq,
"assert-ge": self._assert_ge,
"assert-gt": self._assert_gt,
+ "assert-in-set": self._assert_in_set,
"assert-int8": self._assert_int8,
"assert-int16": self._assert_int16,
"assert-int32": self._assert_int32,
2.35.3
