[PATCH 1/2] user/microblaze: Document QSPI NOR JFFS2 driver
Alex White
alex.white at oarcorp.com
Tue Apr 4 15:00:40 UTC 2023
user/bsps/bsps-microblaze.rst | 10 ++++++++++
1 file changed, 10 insertions(+)
diff --git a/user/bsps/bsps-microblaze.rst b/user/bsps/bsps-microblaze.rst
index 32aad90..2a8a6dd 100644
--- a/user/bsps/bsps-microblaze.rst
+++ b/user/bsps/bsps-microblaze.rst
@@ -61,6 +61,16 @@ to include it in the BSP build.
BSP_MICROBLAZE_FPGA_DTB_HEADER_PATH = /path/to/my_dtb.c
+QSPI NOR JFFS2 Driver
+The QSPI NOR JFFS2 driver supports the QEMU emulated n25q512a11 QSPI NOR flash
+device. It is initialized to a page size of 256 bytes and a sector size of 64
+KiB. If device tree support is enabled in the build configuration, the QSPI NOR
+JFFS2 driver will use the node that is compatible with `xlnx,xps-spi-2.00.a`
+from the device tree to configure the QSPI NOR JFFS2 driver.
Running Executables
2.34.1
