[PATCH] bsps/motorola_powerpc: Add spec support for BSP defines
chrisj at rtems.org chrisj at rtems.org
Thu Apr 6 04:27:14 UTC 2023
- These are need by the net legacy stack
 .../bsps/powerpc/motorola_powerpc/grp.yml      |  4 ++++
 .../powerpc/motorola_powerpc/optmvme2307.yml   | 18 ++++++++++++++++++
 .../powerpc/motorola_powerpc/optmvme2700.yml   | 18 ++++++++++++++++++
 3 files changed, 40 insertions(+)
 create mode 100644 spec/build/bsps/powerpc/motorola_powerpc/optmvme2307.yml
 create mode 100644 spec/build/bsps/powerpc/motorola_powerpc/optmvme2700.yml
diff --git a/spec/build/bsps/powerpc/motorola_powerpc/grp.yml b/spec/build/bsps/powerpc/motorola_powerpc/grp.yml
index 0e5506ad88..c4849b6061 100644
--- a/spec/build/bsps/powerpc/motorola_powerpc/grp.yml
+++ b/spec/build/bsps/powerpc/motorola_powerpc/grp.yml
@@ -32,6 +32,10 @@ links:
   uid: optmpc8240
 - role: build-dependency
   uid: optmvme2100
+- role: build-dependency
+  uid: optmvme2307
+  uid: optmvme2700
   uid: optqemu
diff --git a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2307.yml b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2307.yml
new file mode 100644
index 0000000000..da417b9c9b
--- /dev/null
+++ b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2307.yml
@@ -0,0 +1,18 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-boolean: null
+- define-condition: null
+build-type: option
+copyrights:
+- Copyright (C) 2023 Chris Johns
+default:
+- enabled-by: powerpc/mvme2307
+  value: true
+- enabled-by: true
+  value: false
+description: |
+  Defined for MVME2307 -- undefined for others
+enabled-by: true
+links: []
+name: mvme2307
+type: build
diff --git a/spec/build/bsps/powerpc/motorola_powerpc/optmvme2700.yml b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2700.yml
index 0000000000..5b968bd1f0
--- /dev/null
+++ b/spec/build/bsps/powerpc/motorola_powerpc/optmvme2700.yml
@@ -0,0 +1,18 @@
+actions:
+build-type: option
+copyrights:
+default:
+- enabled-by: powerpc/mvme2700
+  value: true
+- enabled-by: true
+  value: false
+description: |
+  Defined for MVME2700 -- undefined for others
+enabled-by: true
+links: []
+name: mvme2700
+type: build
2.37.1
