[rtems-net-legacy PATCH 1/2] waf: Add test network configuration support
chrisj at rtems.org chrisj at rtems.org
Thu Apr 6 05:08:49 UTC 2023
- Add a support call to use the configuration
 config.inc                             |  6 ++
 netlegacy.py                           | 82 ++++++++++++++++++++++++--
 testsuites/include/net-legacy-config.h | 18 ++++++
 testsuites/include/network-config.h.in | 41 +++++++++++++
 testsuites/support/net-legacy-config.c | 53 +++++++++++++++++
 wscript                                |  6 ++
 6 files changed, 201 insertions(+), 5 deletions(-)
 create mode 100644 config.inc
 create mode 100644 testsuites/include/net-legacy-config.h
 create mode 100755 testsuites/include/network-config.h.in
 create mode 100644 testsuites/support/net-legacy-config.c
diff --git a/config.inc b/config.inc
new file mode 100644
index 0000000..56497b3
--- /dev/null
+++ b/config.inc
@@ -0,0 +1,6 @@
+NET_CFG_IFACE = lo0
+NET_CFG_BOOT_PROT = dhcp
+NET_CFG_SELF_IP = 127.0.0.1
+NET_CFG_NETMASK = 255.0.0.0
+NET_CFG_MAC_ADDR = 00:00:00:00:00:00
+NET_CFG_GATEWAY_IP = 0.0.0.0
diff --git a/netlegacy.py b/netlegacy.py
index 7897a2c..60775dc 100644
--- a/netlegacy.py
+++ b/netlegacy.py
@@ -35,8 +35,56 @@ import bsp_drivers
 import netsources
+def net_config_header(bld):
+    if not os.path.exists(bld.env.NET_CONFIG):
+        bld.fatal('network configuraiton \'%s\' not found' %
+                  (bld.env.NET_CONFIG))
+    net_tags = [
+        'NET_CFG_IFACE', 'NET_CFG_BOOT_PROT', 'NET_CFG_SELF_IP',
+        'NET_CFG_NETMASK', 'NET_CFG_MAC_ADDR', 'NET_CFG_GATEWAY_IP'
+    try:
+        net_cfg_lines = open(bld.env.NET_CONFIG).readlines()
+    except:
+        bld.fatal('network configuraiton \'%s\' read failed' %
+    lc = 0
+    sed = 'sed '
+    net_defaults = {}
+    for l in net_cfg_lines:
+        lc += 1
+        if not l.strip().startswith('NET_CFG_'):
+            bld.fatal('network configuration \'%s\' ' \
+                      'invalid config: %d: %s' % (bld.env.NET_CONFIG, lc, l))
+        ls = l.split('=')
+        if len(ls) != 2:
+                      'parse error: %d: %s' % (bld.env.NET_CONFIG, lc, l))
+        lhs = ls[0].strip()
+        rhs = ls[1].strip()
+        if lhs in net_tags:
+            net_defaults[lhs] = rhs
+        else:
+    for cfg in net_defaults:
+        sed += "-e 's/@%s@/%s/' " % (cfg, net_defaults[cfg])
+    bld(target=bld.env.NETWORK_CONFIG,
+        source='testsuites/include/network-config.h.in',
+        rule=sed + ' < ${SRC} > ${TGT}',
+        update_outputs=True)
 def options(opt):
-    pass
+    copts = opt.option_groups['configure options']
+    copts.add_option('--net-test-config',
+                     default='config.inc',
+                     dest='net_config',
+                     help='Network test configuration (default: %default)')
+    copts.add_option('--optimization',
+                     default='-O2',
+                     dest='optimization',
+                     help='Optimaization level (default: %default)')
 def bsp_configure(conf, arch_bsp, mandatory=True):
@@ -49,15 +97,39 @@ def bsp_configure(conf, arch_bsp, mandatory=True):
     if ab in bsp_drivers.include:
         includes += bsp_drivers.include[ab]
-    conf.env.IFLAGS = [str(conf.path.find_node(i))
-                       for i in includes] + conf.env.IFLAGS
-    conf.env.OPTIMIZATION = ['-O2']
+    bld_inc = conf.path.get_bld().find_or_declare('include')
+    conf.env.NETWORK_CONFIG = str(bld_inc.find_or_declare('network-config.h'))
+    conf.env.IFLAGS = [str(bld_inc)
+                       ] + [str(conf.path.find_node(i))
+                            for i in includes] + conf.env.IFLAGS
+    conf.env.OPTIMIZATION = [conf.options.optimization]
+    # BSPs must define:
+    #  - RTEMS_BSP_NETWORK_DRIVER_NAME
+    #  - RTEMS_BSP_NETWORK_DRIVER_ATTACH
+    for define in [
+            'RTEMS_BSP_NETWORK_DRIVER_NAME', 'RTEMS_BSP_NETWORK_DRIVER_ATTACH'
+        code = ['#include <bspopts.h>']
+        code += ['#include <bsp.h>']
+        code += ['#ifndef %s' % (define)]
+        code += ['  #error %s not defined' % (define)]
+        code += ['#endif']
+        try:
+            conf.check_cc(fragment=rtems.test_application(code),
+                          execute=False,
+                          msg='Checking for %s' % (define))
+        except conf.errors.WafError:
+            conf.fatal(ab + ' does not provide %s' % (define))
 def build(bld):
     arch_bsp = bld.env.RTEMS_ARCH_BSP
     ab = rtems.arch(arch_bsp) + '/' + rtems.bsp(arch_bsp)
+    net_config_header(bld)
     if ab in bsp_drivers.source:
         bld(target='bspobjs',
             features='c',
@@ -94,7 +166,7 @@ def build(bld):
                                                 bld.env.RTEMS_ARCH_BSP)
     bld.install_files(os.path.join(bld.env.PREFIX, arch_lib_path),
-                      ["libnetworking.a", 'libpppd.a', 'libnfs.a'])
+                      ['libnetworking.a', 'libpppd.a', 'libnfs.a'])
     for inc_dir in netsources.header:
         for header in netsources.header[inc_dir]:
             hname = os.path.basename(header)
diff --git a/testsuites/include/net-legacy-config.h b/testsuites/include/net-legacy-config.h
index 0000000..e4e5579
--- /dev/null
+++ b/testsuites/include/net-legacy-config.h
@@ -0,0 +1,18 @@
+ * Copyright (c) 2023 Chris Johns.  All rights reserved.
+#ifndef _NET_LEGACY_CONFIG_H
+#define _NET_LEGACY_CONFIG_H
+#include <stdbool.h>
+struct rtems_bsdnet_config;
+bool rtems_net_legacy_config(struct rtems_bsdnet_config* bsd);
+#endif
diff --git a/testsuites/include/network-config.h.in b/testsuites/include/network-config.h.in
new file mode 100755
index 0000000..756e3b5
--- /dev/null
+++ b/testsuites/include/network-config.h.in
@@ -0,0 +1,41 @@
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#ifndef _TEST_NETWORK_CONFIG_H_
+#define _TEST_NETWORK_CONFIG_H_
+#define NET_CFG_IFACE "@NET_CFG_IFACE@"
+#define NET_CFG_BOOT_PROT "@NET_CFG_BOOT_PROT@"
+#define NET_CFG_SELF_IP "@NET_CFG_SELF_IP@"
+#define NET_CFG_NETMASK "@NET_CFG_NETMASK@"
+#define NET_CFG_MAC_ADDR "@NET_CFG_MAC_ADDR@"
+#define NET_CFG_GATEWAY_IP "@NET_CFG_GATEWAY_IP@"
+#endif /* _TEST_NETWORK_CONFIG_H_ */
diff --git a/testsuites/support/net-legacy-config.c b/testsuites/support/net-legacy-config.c
index 0000000..bb512d2
--- /dev/null
+++ b/testsuites/support/net-legacy-config.c
@@ -0,0 +1,53 @@
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <stdio.h>
+#include <bsp.h>
+#include <rtems.h>
+#include <rtems/dhcp.h>
+#include <rtems/rtems_bsdnet.h>
+#include <net-legacy-config.h>
+#include <network-config.h>
+static char* iface = NET_CFG_IFACE;
+static char* boot_prot = NET_CFG_BOOT_PROT;
+static char* ip = NET_CFG_SELF_IP;
+static char* netmask = NET_CFG_NETMASK;
+static char* gateway = NET_CFG_GATEWAY_IP;
+static struct rtems_bsdnet_ifconfig ifcfg = {
+  RTEMS_BSP_NETWORK_DRIVER_NAME,
+  RTEMS_BSP_NETWORK_DRIVER_ATTACH
+bool rtems_net_legacy_config(struct rtems_bsdnet_config* bsd) {
+  if (bsd->ifconfig == NULL) {
+    bsd->ifconfig = &ifcfg;
+  ifcfg.name = iface;
+  ifcfg.ip_address = ip;
+  ifcfg.ip_netmask = netmask;
+  bsd->gateway = gateway;
+  if (strcmp(boot_prot, "static") == 0) {
+    bsd->bootp = NULL;
+  } else if (strcmp(boot_prot, "bootp") == 0) {
+    bsd->bootp = rtems_bsdnet_do_bootp;
+  } else if (strcmp(boot_prot, "dhcp") == 0) {
+    bsd->bootp = rtems_bsdnet_do_dhcp;
+  } else {
+    printf("%s: %d: invalid network configuration: %s\n",
+           __FILE__, __LINE__, boot_prot);
+    return false;
+  return true;
diff --git a/wscript b/wscript
index b146db6..c365f14 100644
--- a/wscript
+++ b/wscript
@@ -51,6 +51,11 @@ def init(ctx):
 def options(opt):
     rtems.options(opt)
     netlegacy.options(opt)
 def bsp_configure(conf, arch_bsp):
@@ -63,6 +68,7 @@ def bsp_configure(conf, arch_bsp):
 def configure(conf):
+    conf.env.NET_CONFIG = conf.options.net_config
     rtems.configure(conf, bsp_configure)
2.37.1
