[rtems-net-legacy PATCH v2 2/2] testsuite: Add telenet02 test
chrisj at rtems.org chrisj at rtems.org
Thu Apr 6 05:15:37 UTC 2023
 testsuites/telnetd02/init.c        | 116 +++++++++++++++++++++++++++++
 testsuites/telnetd02/telnetd02.doc |  12 +++
 testsuites/telnetd02/telnetd02.scn |   9 +++
 testsuites/telnetd02/wscript       |  50 +++++++++++++
 testsuites/wscript                 |   2 +-
 5 files changed, 188 insertions(+), 1 deletion(-)
 create mode 100644 testsuites/telnetd02/init.c
 create mode 100644 testsuites/telnetd02/telnetd02.doc
 create mode 100644 testsuites/telnetd02/telnetd02.scn
 create mode 100644 testsuites/telnetd02/wscript
diff --git a/testsuites/telnetd02/init.c b/testsuites/telnetd02/init.c
new file mode 100644
index 0000000..6f762db
--- /dev/null
+++ b/testsuites/telnetd02/init.c
@@ -0,0 +1,116 @@
+ * Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <sys/stat.h>
+#include <fcntl.h>
+#include <string.h>
+#include <rtems.h>
+#include <rtems/dhcp.h>
+#include <rtems/rtems_bsdnet.h>
+#include <rtems/telnetd.h>
+#include <tmacros.h>
+#include <net-legacy-config.h>
+#include <network-config.h>
+const char rtems_test_name[] = "TELNETD 2";
+struct rtems_bsdnet_config rtems_bsdnet_config;
+rtems_shell_env_t env;
+static void telnet_shell( char *name, void *arg )
+  rtems_shell_dup_current_env( &env );
+  env.devname = name;
+  env.taskname = "TLNT";
+  rtems_shell_main_loop( &env );
+rtems_telnetd_config_table rtems_telnetd_config = {
+  .command = telnet_shell,
+  .stack_size = 8 * RTEMS_MINIMUM_STACK_SIZE,
+static rtems_task Init(rtems_task_argument argument)
+  rtems_status_code sc;
+  int rv;
+  TEST_BEGIN();
+  rtems_test_assert(rtems_net_legacy_config(&rtems_bsdnet_config));
+  rv = rtems_bsdnet_initialize_network();
+  rtems_test_assert(rv == 0);
+  sc = rtems_telnetd_start( &rtems_telnetd_config );
+  rtems_test_assert( sc == RTEMS_SUCCESSFUL );
+  sc = rtems_shell_init(
+    "SHLL",                       /* task name */
+    RTEMS_MINIMUM_STACK_SIZE * 4, /* task stack size */
+    1,                            /* task priority */
+    "/dev/console",               /* device name */
+    false,                        /* run forever */
+    true,                         /* wait for shell to terminate */
+    NULL                          /* login check function,
+                                     use NULL to disable a login check */
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_INIT
+#define CONFIGURE_MICROSECONDS_PER_TICK 10000
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 32
+#define CONFIGURE_MAXIMUM_TASKS 12
+#define CONFIGURE_MAXIMUM_POSIX_KEYS 10
+#define CONFIGURE_MAXIMUM_SEMAPHORES 20
+#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 10
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+#define CONFIGURE_UNLIMITED_OBJECTS
+#define CONFIGURE_UNIFIED_WORK_AREAS
+#define RTEMS_NETWORKING 1
+#define CONFIGURE_SHELL_COMMANDS_INIT
+#define CONFIGURE_SHELL_COMMANDS_ALL
+#define CONFIGURE_SHELL_COMMANDS_ALL_NETWORKING
+#include <rtems/shellconfig.h>
+#include <rtems/confdefs.h>
diff --git a/testsuites/telnetd02/telnetd02.doc b/testsuites/telnetd02/telnetd02.doc
index 0000000..9d0a9da
--- /dev/null
+++ b/testsuites/telnetd02/telnetd02.doc
@@ -0,0 +1,12 @@
+This file describes the directives and concepts tested by this test set.
+test set name: telnetd02
+directives:
+  - rtems_telnetd_start()
+concepts:
++ Runs a telnet server with a suitable network configuration to
+  test the networking is running.
diff --git a/testsuites/telnetd02/telnetd02.scn b/testsuites/telnetd02/telnetd02.scn
index 0000000..1503dc5
--- /dev/null
+++ b/testsuites/telnetd02/telnetd02.scn
@@ -0,0 +1,9 @@
+*** BEGIN OF TEST TELNETD 2 ***
+*** TEST VERSION: 6.0.0.d15640249372de3106a66304569a44f6f32cca23
+*** TEST STATE: EXPECTED_PASS
+*** TEST BUILD: RTEMS_POSIX_API
+*** TEST TOOLS: 12.2.1 20230224 (RTEMS 6, RSB 77dc54ce841a04598c64073c217aa9e66df31d8f, Newlib 17ac400)
+syslog: telnetd: started successfully on port 23
+RTEMS Shell on /dev/console. Use 'help' to list commands.
+SHLL [/] #
diff --git a/testsuites/telnetd02/wscript b/testsuites/telnetd02/wscript
index 0000000..b59c040
--- /dev/null
+++ b/testsuites/telnetd02/wscript
@@ -0,0 +1,50 @@
+# RTEMS Project (https://www.rtems.org/)
+# Copyright (c) 2021 Regents of University of Colorado
+# Written by Vijay Kumar Banerjee <vijay at rtems.org>.
+# All rights reserved.
+#  Redistribution and use in source and binary forms, with or without
+#  modification, are permitted provided that the following conditions
+#  are met:
+#  1. Redistributions of source code must retain the above copyright
+#     notice, this list of conditions and the following disclaimer.
+#  2. Redistributions in binary form must reproduce the above copyright
+#     notice, this list of conditions and the following disclaimer in the
+#     documentation and/or other materials provided with the distribution.
+#  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+#  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+#  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
+#  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+#  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+#  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+#  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+#  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+#  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+#  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
+#  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+from rtems_waf import rtems
+def init(ctx):
+    pass
+def configure(conf):
+    pass
+def build(bld):
+    legacy_config = bld.path.parent.find_node('support/net-legacy-config.c')
+    source = ['init.c', legacy_config]
+    bld.program(target='telnetd02.exe',
+                features='c cprogram',
+                cflags=bld.env.OPTIMIZATION + ['-g'],
+                includes=bld.env.IFLAGS,
+                lib=['telnetd', 'networking'],
+                libpath=['.'],
+                source=source,
+                install_path=False)
diff --git a/testsuites/wscript b/testsuites/wscript
index 040c5c6..3ce5153 100644
--- a/testsuites/wscript
+++ b/testsuites/wscript
@@ -29,7 +29,7 @@
 subdirs = [
-    'ftp01', 'loopback', 'networking01', 'pppd', 'syscall01', 'telnetd01'
+    'ftp01', 'loopback', 'networking01', 'pppd', 'syscall01', 'telnetd01', 'telnetd02'
2.37.1
