[rtems-net-legacy PATCH 2/2] testsuite: Add telenet02 test
Thu Apr 6 05:16:47 UTC 2023
The commit missed the doco update. I will send a v2.
On 6/4/2023 3:08 pm, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
>  testsuites/telnetd02/init.c        | 116 +++++++++++++++++++++++++++++
>  testsuites/telnetd02/telnetd02.doc |  11 +++
>  testsuites/telnetd02/telnetd02.scn |  11 +++
>  testsuites/telnetd02/wscript       |  50 +++++++++++++
>  testsuites/wscript                 |   2 +-
>  5 files changed, 189 insertions(+), 1 deletion(-)
>  create mode 100644 testsuites/telnetd02/init.c
>  create mode 100644 testsuites/telnetd02/telnetd02.doc
>  create mode 100644 testsuites/telnetd02/telnetd02.scn
>  create mode 100644 testsuites/telnetd02/wscript
> diff --git a/testsuites/telnetd02/init.c b/testsuites/telnetd02/init.c
> new file mode 100644
> index 0000000..6f762db
> --- /dev/null
> +++ b/testsuites/telnetd02/init.c
> @@ -0,0 +1,116 @@
> + * Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <sys/stat.h>
> +#include <fcntl.h>
> +#include <string.h>
> +#include <rtems.h>
> +#include <rtems/dhcp.h>
> +#include <rtems/rtems_bsdnet.h>
> +#include <rtems/telnetd.h>
> +#include <tmacros.h>
> +#include <net-legacy-config.h>
> +#include <network-config.h>
> +const char rtems_test_name[] = "TELNETD 2";
> +struct rtems_bsdnet_config rtems_bsdnet_config;
> +rtems_shell_env_t env;
> +static void telnet_shell( char *name, void *arg )
> +  rtems_shell_dup_current_env( &env );
> +  env.devname = name;
> +  env.taskname = "TLNT";
> +  rtems_shell_main_loop( &env );
> +rtems_telnetd_config_table rtems_telnetd_config = {
> +  .command = telnet_shell,
> +  .stack_size = 8 * RTEMS_MINIMUM_STACK_SIZE,
> +static rtems_task Init(rtems_task_argument argument)
> +  rtems_status_code sc;
> +  int rv;
> +  TEST_BEGIN();
> +  rtems_test_assert(rtems_net_legacy_config(&rtems_bsdnet_config));
> +  rv = rtems_bsdnet_initialize_network();
> +  rtems_test_assert(rv == 0);
> +  sc = rtems_telnetd_start( &rtems_telnetd_config );
> +  rtems_test_assert( sc == RTEMS_SUCCESSFUL );
> +  sc = rtems_shell_init(
> +    "SHLL",                       /* task name */
> +    RTEMS_MINIMUM_STACK_SIZE * 4, /* task stack size */
> +    1,                            /* task priority */
> +    "/dev/console",               /* device name */
> +    false,                        /* run forever */
> +    true,                         /* wait for shell to terminate */
> +    NULL                          /* login check function,
> +                                     use NULL to disable a login check */
> +  TEST_END();
> +  rtems_test_exit(0);
> +#define CONFIGURE_INIT
> +#define CONFIGURE_MICROSECONDS_PER_TICK 10000
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
> +#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 32
> +#define CONFIGURE_MAXIMUM_TASKS 12
> +#define CONFIGURE_MAXIMUM_POSIX_KEYS 10
> +#define CONFIGURE_MAXIMUM_SEMAPHORES 20
> +#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 10
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
> +#define CONFIGURE_UNLIMITED_OBJECTS
> +#define CONFIGURE_UNIFIED_WORK_AREAS
> +#define RTEMS_NETWORKING 1
> +#define CONFIGURE_SHELL_COMMANDS_INIT
> +#define CONFIGURE_SHELL_COMMANDS_ALL
> +#define CONFIGURE_SHELL_COMMANDS_ALL_NETWORKING
> +#include <rtems/shellconfig.h>
> +#include <rtems/confdefs.h>
> diff --git a/testsuites/telnetd02/telnetd02.doc b/testsuites/telnetd02/telnetd02.doc
> index 0000000..7931c3c
> --- /dev/null
> +++ b/testsuites/telnetd02/telnetd02.doc
> @@ -0,0 +1,11 @@
> +This file describes the directives and concepts tested by this test set.
> +test set name: telnetd01
> +directives:
> +  - rtems_telnetd_start()
> +concepts:
> ++ Check if Telnet server works.
> diff --git a/testsuites/telnetd02/telnetd02.scn b/testsuites/telnetd02/telnetd02.scn
> index 0000000..3e9cc00
> --- /dev/null
> +++ b/testsuites/telnetd02/telnetd02.scn
> @@ -0,0 +1,11 @@
> +*** BEGIN OF TEST TELNETD 1 ***
> +*** TEST VERSION: 5.0.0.dc32b6aa0807fb70f9b26bc0bc6e164ddb49bd3a
> +*** TEST STATE: EXPECTED_PASS
> +*** TEST BUILD: RTEMS_NETWORKING
> +*** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB 9670d7541e0621915e521fe76e7bb33de8cee661, Newlib d13c84eb07e35984bf7a974cd786a6cdac29e6b9)
> +syslog: telnetd: configuration with invalid command
> +syslog: telnetd: cannot create session task
> +syslog: telnetd: started successfully on port 23
> +syslog: telnetd: cannot bind server socket
> +*** END OF TEST TELNETD 1 ***
> diff --git a/testsuites/telnetd02/wscript b/testsuites/telnetd02/wscript
> index 0000000..b59c040
> --- /dev/null
> +++ b/testsuites/telnetd02/wscript
> @@ -0,0 +1,50 @@
> +# RTEMS Project (https://www.rtems.org/)
> +# Copyright (c) 2021 Regents of University of Colorado
> +# Written by Vijay Kumar Banerjee <vijay at rtems.org>.
> +# All rights reserved.
> +#  Redistribution and use in source and binary forms, with or without
> +#  modification, are permitted provided that the following conditions
> +#  are met:
> +#  1. Redistributions of source code must retain the above copyright
> +#     notice, this list of conditions and the following disclaimer.
> +#  2. Redistributions in binary form must reproduce the above copyright
> +#     notice, this list of conditions and the following disclaimer in the
> +#     documentation and/or other materials provided with the distribution.
> +#  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> +#  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
> +#  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
> +#  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
> +#  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
> +#  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
> +#  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
> +#  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
> +#  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
> +#  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
> +#  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> +from rtems_waf import rtems
> +def init(ctx):
> +    pass
> +def configure(conf):
> +    pass
> +def build(bld):
> +    legacy_config = bld.path.parent.find_node('support/net-legacy-config.c')
> +    source = ['init.c', legacy_config]
> +    bld.program(target='telnetd02.exe',
> +                features='c cprogram',
> +                cflags=bld.env.OPTIMIZATION + ['-g'],
> +                includes=bld.env.IFLAGS,
> +                lib=['telnetd', 'networking'],
> +                libpath=['.'],
> +                source=source,
> +                install_path=False)
> diff --git a/testsuites/wscript b/testsuites/wscript
> index 040c5c6..3ce5153 100644
> --- a/testsuites/wscript
> +++ b/testsuites/wscript
> @@ -29,7 +29,7 @@
>  subdirs = [
> -    'ftp01', 'loopback', 'networking01', 'pppd', 'syscall01', 'telnetd01'
> +    'ftp01', 'loopback', 'networking01', 'pppd', 'syscall01', 'telnetd01', 'telnetd02'
