[PATCH 3/3] testsuites/libtests: Add test for flashdev
aaron.nyholm at unfoldedeffective.com
Thu Apr 6 06:52:38 UTC 2023
From: Aaron Nyholm <aaron.nyholm at southerninnovation.com>
spec/build/testsuites/libtests/flashdev01.yml | 20 ++
spec/build/testsuites/libtests/grp.yml | 2 +
testsuites/libtests/flashdev01/flashdev01.doc | 11 +
testsuites/libtests/flashdev01/flashdev01.scn | 2 +
testsuites/libtests/flashdev01/init.c | 190 +++++++++++++
.../libtests/flashdev01/test_flashdev.c | 264 ++++++++++++++++++
.../libtests/flashdev01/test_flashdev.h | 35 +++
7 files changed, 524 insertions(+)
create mode 100644 spec/build/testsuites/libtests/flashdev01.yml
create mode 100644 testsuites/libtests/flashdev01/flashdev01.doc
create mode 100644 testsuites/libtests/flashdev01/flashdev01.scn
create mode 100644 testsuites/libtests/flashdev01/init.c
create mode 100644 testsuites/libtests/flashdev01/test_flashdev.c
create mode 100644 testsuites/libtests/flashdev01/test_flashdev.h
diff --git a/spec/build/testsuites/libtests/flashdev01.yml b/spec/build/testsuites/libtests/flashdev01.yml
new file mode 100644
index 0000000000..c943caa2e7
--- /dev/null
+++ b/spec/build/testsuites/libtests/flashdev01.yml
@@ -0,0 +1,20 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2023 Aaron Nyholm (Southern Innovation)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/libtests/flashdev01/init.c
+- testsuites/libtests/flashdev01/test_flashdev.c
+stlib: []
+target: testsuites/libtests/flashdev01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
index 8f2cadb890..30965e5b2c 100644
--- a/spec/build/testsuites/libtests/grp.yml
+++ b/spec/build/testsuites/libtests/grp.yml
@@ -124,6 +124,8 @@ links:
uid: exit03
- role: build-dependency
uid: fcntl
+- role: build-dependency
+ uid: flashdev01
uid: flashdisk01
diff --git a/testsuites/libtests/flashdev01/flashdev01.doc b/testsuites/libtests/flashdev01/flashdev01.doc
index 0000000000..0638a5a842
--- /dev/null
+++ b/testsuites/libtests/flashdev01/flashdev01.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts testd by this test set.
+test set name: flashdev01
+directives:
+ TBD
+concepts:
+ - Ensure that the flashdev driver API works.
diff --git a/testsuites/libtests/flashdev01/flashdev01.scn b/testsuites/libtests/flashdev01/flashdev01.scn
index 0000000000..809ff3cd80
--- /dev/null
+++ b/testsuites/libtests/flashdev01/flashdev01.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST FLASHDEV 1 ***
+*** END OF TEST FLASHDEV 1 ***
diff --git a/testsuites/libtests/flashdev01/init.c b/testsuites/libtests/flashdev01/init.c
index 0000000000..924afb6696
--- /dev/null
+++ b/testsuites/libtests/flashdev01/init.c
@@ -0,0 +1,190 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2023 Aaron Nyholm
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include "tmacros.h"
+#include "test_flashdev.h"
+#include <stdio.h>
+#include <stdlib.h>
+#include <fcntl.h>
+#include <sys/ioctl.h>
+#define TEST_NAME_LENGTH 10
+#define TEST_DATA_SIZE (PAGE_SIZE * PAGE_COUNT)
+#define PAGE_COUNT 16
+#define PAGE_SIZE 128
+#define WB_SIZE 1
+const char rtems_test_name[] = "FLASHDEV 1";
+static void run_test(void);
+static void run_test(void) {
+ char buff[TEST_DATA_SIZE] = {0};
+ FILE *file;
+ int fd;
+ rtems_flashdev* flash;
+ int status;
+ char* read_data;
+ rtems_flashdev_ioctl_erase_args e_args;
+ rtems_flashdev_ioctl_page_info pg_info;
+ rtems_flashdev_ioctl_region region;
+ uint32_t jedec;
+ size_t page_count;
+ int type;
+ size_t wb_size;
+ /* Initalize the flash device driver and flashdev */
+ flash = test_flashdev_init();
+ rtems_test_assert(flash != NULL);
+ /* Register the flashdev as a device */
+ status = rtems_flashdev_register(flash, "dev/flashdev0");
+ rtems_test_assert(!status);
+ /* Open the flashdev */
+ file = fopen("dev/flashdev0", "r+");
+ rtems_test_assert(file != NULL);
+ fd = fileno(file);
+ /* Read data from flash */
+ read_data = fgets(buff, TEST_DATA_SIZE, file);
+ rtems_test_assert(read_data != NULL);
+ /* Fseek to start of flash */
+ status = fseek(file, 0x0, SEEK_SET);
+ /* Write the test name to the flash */
+ status = fwrite(rtems_test_name, TEST_NAME_LENGTH, 1, file);
+ rtems_test_assert(status == 1);
+ /* Fseek to start of flash and read again */
+ fgets(buff, TEST_DATA_SIZE, file);
+ rtems_test_assert(!strncmp(buff, rtems_test_name, TEST_NAME_LENGTH));
+ /* Test Erasing */
+ e_args.offset = 0x0;
+ e_args.size = PAGE_SIZE;
+ status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_ERASE, &e_args);
+ fseek(file, 0x0, SEEK_SET);
+ rtems_test_assert(buff[0] == 0);
+ /* Test getting JEDEC ID */
+ status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_JEDEC_ID, &jedec);
+ rtems_test_assert(jedec == 0x00ABCDEF);
+ /* Test getting flash type */
+ status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_TYPE, &type);
+ rtems_test_assert(type == RTEMS_FLASHDEV_TYPE_NOR);
+ /* Test getting page info from offset */
+ pg_info.offset_or_index = PAGE_SIZE + PAGE_SIZE/2;
+ status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET, &pg_info);
+ rtems_test_assert(pg_info.return_page_info.offset == PAGE_SIZE);
+ rtems_test_assert(pg_info.return_page_info.size == PAGE_SIZE);
+ /* Test getting page info from index */
+ pg_info.offset_or_index = 2;
+ status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX, &pg_info);
+ rtems_test_assert(pg_info.return_page_info.offset == 2*PAGE_SIZE);
+ /* Test getting page count */
+ status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_PAGE_COUNT, &page_count);
+ rtems_test_assert(page_count == PAGE_COUNT);
+ /* Test getting write block size */
+ status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE, &wb_size);
+ rtems_test_assert(wb_size == WB_SIZE);
+ /* Test Regions */
+ region.offset = 0x400;
+ region.size = 0x200;
+ status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_REGION_SET, ®ion);
+ // Test read to larger then region
+ read_data = fgets(buff, 2048, file);
+ rtems_test_assert(read_data == NULL);
+ // Test fseek outside of region
+ status = fseek(file, 0x201, SEEK_SET);
+ rtems_test_assert(status);
+ // Write to base unset region and check the writes location
+ fwrite("HELLO WORLD", 11, 1, file);
+ ioctl(fd, RTEMS_FLASHDEV_IOCTL_REGION_UNSET, NULL);
+ fseek(file, 0x400, SEEK_SET);
+ fgets(buff, 11, file);
+ rtems_test_assert(strncmp(buff, "HELLO WORLD", 11));
+static void Init(rtems_task_argument arg)
+ TEST_BEGIN();
+ run_test();
+ TEST_END();
+ rtems_test_exit(0);
+#define CONFIGURE_MICROSECONDS_PER_TICK 2000
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 7
+#define CONFIGURE_MAXIMUM_TASKS 2
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/flashdev01/test_flashdev.c b/testsuites/libtests/flashdev01/test_flashdev.c
index 0000000000..d26cafdcaa
--- /dev/null
+++ b/testsuites/libtests/flashdev01/test_flashdev.c
@@ -0,0 +1,264 @@
+ * are met:
+#include <string.h>
+#include <rtems/seterr.h>
+#define WB_SIZE 1
+ * This flash device driver is for testing flashdev
+ * API calls.
+typedef struct test_flashdev {
+ char* data;
+ uint32_t jedec_id;
+ int flash_type;
+} test_flashdev;
+int test_flashdev_page_by_off(
+ rtems_flashdev *flash,
+ off_t search_offset,
+ off_t *page_offset,
+ size_t *page_size
+int test_flashdev_page_by_index(
+ off_t search_index,
+ size_t *page_size
+int test_flashdev_page_count(
+ int *page_count
+int test_flashdev_wb_size(
+ size_t *write_block_size
+uint32_t test_flashdev_jedec_id(
+int test_flashdev_type(
+int test_flashdev_read(
+ rtems_flashdev* flash,
+ uint32_t offset,
+ uint32_t count,
+ void* buffer
+int test_flashdev_write(
+ uint32_t offset,
+ uint32_t count,
+ const void* buffer
+int test_flashdev_erase(
+ uint32_t offset,
+ uint32_t count
+/* Function to handle find page info by offset */
+ size_t *page_size
+ *page_offset = search_offset - (search_offset%PAGE_SIZE);
+ *page_size = PAGE_SIZE;
+ return 0;
+/* Function to handle find page by index */
+ size_t *page_size
+ *page_offset = search_index * PAGE_SIZE;
+ return 0;
+/* Page count handler */
+ int *page_count
+ *page_count = PAGE_COUNT;
+ return 0;
+/* Write block size handler */
+ *write_block_size = WB_SIZE;
+ return 0;
+/* JEDEC ID handler, this would normally require a READID
+ * call to the physical flash device.
+ test_flashdev* driver = flash->driver;
+ return driver->jedec_id;
+/* Function to identify what kind of flash is attached. */
+ return driver->flash_type;
+/* Read flash call. Any offset or count protections are
+ * required to be done in the driver function. */
+ uint32_t offset,
+ uint32_t count,
+ void* buffer
+ if (offset + count > TEST_DATA_SIZE) {
+ rtems_set_errno_and_return_minus_one( EINVAL );
+ memcpy(buffer, &driver->data[offset], count);
+ return 0;
+/* Write Flash call. Any offset or count protections are
+ uint32_t offset,
+ uint32_t count,
+ memcpy(&driver->data[offset], buffer, count);
+ return 0;
+/* Erase Flash call. Any offset or count protections are
+ uint32_t offset,
+ uint32_t count
+ if (offset%PAGE_SIZE || count%PAGE_SIZE) {
+ memset(&driver->data[offset], 0, count);
+ return 0;
+/* Initialize Flashdev and underlying driver. */
+rtems_flashdev* test_flashdev_init(void)
+ rtems_flashdev *flash = rtems_flashdev_alloc_and_init(sizeof(rtems_flashdev));
+ if (flash == NULL) {
+ return NULL;
+ test_flashdev* flash_driver = calloc(1, sizeof(test_flashdev));
+ if (flash_driver == NULL) {
+ rtems_flashdev_destroy_and_free(flash);
+ return NULL;
+ flash_driver->data = calloc(1, TEST_DATA_SIZE);
+ if (flash_driver->data == NULL) {
+ free(flash_driver);
+ return NULL;
+ flash_driver->jedec_id = 0x00ABCDEF;
+ flash_driver->flash_type = RTEMS_FLASHDEV_TYPE_NOR;
+ flash->driver = flash_driver;
+ flash->read = &test_flashdev_read;
+ flash->write = &test_flashdev_write;
+ flash->erase = &test_flashdev_erase;
+ flash->jedec_id = &test_flashdev_jedec_id;
+ flash->flash_type = &test_flashdev_type;
+ flash->page_info_by_off = &test_flashdev_page_by_off;
+ flash->page_info_by_index = &test_flashdev_page_by_index;
+ flash->page_count = &test_flashdev_page_count;
+ flash->write_block_size = &test_flashdev_wb_size;
+ return flash;
diff --git a/testsuites/libtests/flashdev01/test_flashdev.h b/testsuites/libtests/flashdev01/test_flashdev.h
index 0000000000..8b03959c42
--- /dev/null
+++ b/testsuites/libtests/flashdev01/test_flashdev.h
@@ -0,0 +1,35 @@
+ * are met:
+#ifndef __TEST_FLASHDEV_H
+#define __TEST_FLASHDEV_H
+#include <dev/flash/flashdev.h>
+rtems_flashdev* test_flashdev_init(void);
+#endif /* __TEST_FLASHDEV_H */
2.25.1
