[PATCH v2 1/3] cpukit/flash: Add API for Flash devices
aaron.nyholm at unfoldedeffective.com
Thu Apr 6 07:08:20 UTC 2023
From: Aaron Nyholm <aaron.nyholm at southerninnovation.com>
cpukit/dev/flash/flashdev.c | 732 ++++++++++++++++++++++++++++
cpukit/include/dev/flash/flashdev.h | 437 +++++++++++++++++
spec/build/cpukit/librtemscpu.yml | 4 +
3 files changed, 1173 insertions(+)
create mode 100644 cpukit/dev/flash/flashdev.c
create mode 100644 cpukit/include/dev/flash/flashdev.h
diff --git a/cpukit/dev/flash/flashdev.c b/cpukit/dev/flash/flashdev.c
new file mode 100644
index 0000000000..08e1c16e34
--- /dev/null
+++ b/cpukit/dev/flash/flashdev.c
@@ -0,0 +1,732 @@
+ * Copyright (C) 2023 Aaron Nyholm
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <dev/flash/flashdev.h>
+#include <rtems/imfs.h>
+#include <rtems/score/assert.h>
+#include <errno.h>
+#include <fcntl.h>
+#include <stdlib.h>
+#include <string.h>
+#include <unistd.h>
+#define RTEMS_FLASHDEV_REGION_ALLOC_FULL 0xFFFFFFFFUL
+#define RTEMS_FLASHDEV_REGION_UNDEFINED 0xFFFFFFFFUL
+static int rtems_flashdev_do_init(
+ rtems_flashdev *flash,
+ void ( *destroy )( rtems_flashdev *flash )
+static int rtems_flashdev_ioctl_erase(
+ rtems_libio_t *iop,
+ void *arg
+static off_t rtems_flashdev_get_region_offset(
+static size_t rtems_flashdev_get_region_size(
+static int rtems_flashdev_ioctl_set_region(
+ void *arg
+static int rtems_flashdev_ioctl_create_region(
+ rtems_flashdev_ioctl_region *region_in
+static int rtems_flashdev_ioctl_update_region(
+static int rtems_flashdev_ioctl_clear_region(
+static uint32_t rtems_flashdev_ioctl_jedec_id(
+static uint32_t rtems_flashdev_ioctl_flash_type(
+static int rtems_flashdev_ioctl_pageinfo_offset(
+ void *arg
+static int rtems_flashdev_ioctl_pageinfo_index(
+ void *arg
+static int rtems_flashdev_ioctl_page_count(
+ void *arg
+static int rtems_flashdev_ioctl_write_block_size(
+ void *arg
+static int rtems_flashdev_get_addr(
+ size_t count,
+ off_t *addr
+static int rtems_flashdev_update_and_return(
+ int status,
+ size_t count,
+ off_t new_offset
+static uint32_t rtems_flashdev_get_region_index(
+ return (uint32_t)iop->data0;
+static int rtems_flashdev_is_region_defined(
+ return (rtems_flashdev_get_region_index( iop ) != RTEMS_FLASHDEV_REGION_UNDEFINED);
+static void rtems_flashdev_set_region_index(
+ uint32_t index
+ iop->data0 = index;
+static int rtems_flashdev_check_offset_region(
+ off_t offset
+ if ( ( rtems_flashdev_is_region_defined( iop ) ) &&
+ ( offset > rtems_flashdev_get_region_size( flash, iop ) ) ) {
+ rtems_set_errno_and_return_minus_one( EINVAL );
+ return 0;
+static void rtems_flashdev_obtain( rtems_flashdev *flash )
+ rtems_recursive_mutex_lock( &flash->mutex );
+static void rtems_flashdev_release( rtems_flashdev *flash )
+ rtems_recursive_mutex_unlock( &flash->mutex );
+static ssize_t rtems_flashdev_read(
+ void *buffer,
+ size_t count
+ rtems_flashdev *flash = IMFS_generic_get_context_by_iop( iop );
+ off_t addr;
+ int status;
+ if ( flash->read == NULL ) {
+ return 0;
+ /* Get flash address */
+ status = rtems_flashdev_get_addr( flash, iop, count, &addr );
+ if ( status == -1 ) {
+ return status;
+ /* Read flash */
+ rtems_flashdev_obtain( flash );
+ status = ( *flash->read )( flash, addr, count, buffer );
+ rtems_flashdev_release( flash );
+ /* Update offset and return */
+ return rtems_flashdev_update_and_return( iop, status, count, addr + count );
+static ssize_t rtems_flashdev_write(
+ const void *buffer,
+ size_t count
+ off_t addr;
+ int status;
+ if ( flash->write == NULL ) {
+ return 0;
+ return status;
+ /* Write to flash */
+ status = ( *flash->write )( flash, addr, count, buffer );
+static int rtems_flashdev_ioctl(
+ ioctl_command_t command,
+ void *arg
+ int err = 0;
+ switch ( command ) {
+ case RTEMS_FLASHDEV_IOCTL_OBTAIN:
+ err = 0;
+ break;
+ case RTEMS_FLASHDEV_IOCTL_RELEASE:
+ err = 0;
+ break;
+ case RTEMS_FLASHDEV_IOCTL_JEDEC_ID:
+ *( (uint32_t *) arg ) = rtems_flashdev_ioctl_jedec_id( flash );
+ err = 0;
+ break;
+ case RTEMS_FLASHDEV_IOCTL_ERASE:
+ err = rtems_flashdev_ioctl_erase( flash, iop, arg );
+ break;
+ case RTEMS_FLASHDEV_IOCTL_REGION_SET:
+ err = rtems_flashdev_ioctl_set_region( flash, iop, arg );
+ break;
+ case RTEMS_FLASHDEV_IOCTL_REGION_UNSET:
+ err = rtems_flashdev_ioctl_clear_region( flash, iop );
+ break;
+ case RTEMS_FLASHDEV_IOCTL_TYPE:
+ *( (uint32_t *) arg ) = rtems_flashdev_ioctl_flash_type( flash );
+ err = 0;
+ break;
+ case RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET:
+ err = rtems_flashdev_ioctl_pageinfo_offset( flash, arg );
+ break;
+ case RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX:
+ err = rtems_flashdev_ioctl_pageinfo_index( flash, arg );
+ break;
+ case RTEMS_FLASHDEV_IOCTL_PAGE_COUNT:
+ err = rtems_flashdev_ioctl_page_count( flash, arg );
+ break;
+ case RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE:
+ err = rtems_flashdev_ioctl_write_block_size( flash, arg );
+ break;
+ if ( err != 0 ) {
+ rtems_set_errno_and_return_minus_one( err );
+ } else {
+ return 0;
+static off_t rtems_flashdev_lseek(
+ off_t offset,
+ int whence
+ off_t tmp_offset;
+ if ( offset < 0 ) {
+ switch ( whence ) {
+ case SEEK_CUR:
+ tmp_offset = iop->offset + offset;
+ break;
+ case SEEK_SET:
+ tmp_offset = offset;
+ break;
+ case SEEK_END:
+ default:
+ if ( ( rtems_flashdev_is_region_defined(iop) ) &&
+ ( tmp_offset > rtems_flashdev_get_region_size( flash, iop ) ) ) {
+ iop->offset = tmp_offset;
+ return iop->offset;
+static int rtems_flashdev_close( rtems_libio_t *iop )
+ rtems_flashdev_ioctl_clear_region( flash, iop );
+ return rtems_filesystem_default_close( iop );
+static int rtems_flashdev_open(
+ const char *path,
+ int oflag,
+ mode_t mode
+ int ret = rtems_filesystem_default_open( iop, path, oflag, mode );
+ rtems_flashdev_set_region_index(iop, RTEMS_FLASHDEV_REGION_UNDEFINED);
+ return ret;
+static const rtems_filesystem_file_handlers_r rtems_flashdev_handler = {
+ .open_h = rtems_flashdev_open,
+ .close_h = rtems_flashdev_close,
+ .read_h = rtems_flashdev_read,
+ .write_h = rtems_flashdev_write,
+ .ioctl_h = rtems_flashdev_ioctl,
+ .lseek_h = rtems_flashdev_lseek,
+ .fstat_h = IMFS_stat,
+ .ftruncate_h = rtems_filesystem_default_ftruncate,
+ .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
+ .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
+ .fcntl_h = rtems_filesystem_default_fcntl,
+ .kqfilter_h = rtems_filesystem_default_kqfilter,
+ .mmap_h = rtems_filesystem_default_mmap,
+ .poll_h = rtems_filesystem_default_poll,
+ .readv_h = rtems_filesystem_default_readv,
+ .writev_h = rtems_filesystem_default_writev };
+static void rtems_flashdev_node_destroy( IMFS_jnode_t *node )
+ rtems_flashdev *flash;
+ flash = IMFS_generic_get_context_by_node( node );
+ ( *flash->destroy )( flash );
+ IMFS_node_destroy_default( node );
+static const IMFS_node_control
+ rtems_flashdev_node_control = IMFS_GENERIC_INITIALIZER(
+ &rtems_flashdev_handler,
+ IMFS_node_initialize_generic,
+ rtems_flashdev_node_destroy
+int rtems_flashdev_register( rtems_flashdev *flash, const char *flash_path )
+ int rv;
+ rv = IMFS_make_generic_node( flash_path,
+ S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO,
+ &rtems_flashdev_node_control,
+ flash );
+ if ( rv != 0 ) {
+ return rv;
+ rtems_recursive_mutex_init( &flash->mutex, "RTEMS_FLASHDEV Flash" );
+ flash->destroy = destroy;
+ flash->region_bit_allocator = 0;
+ flash->read = NULL;
+ flash->write = NULL;
+ flash->erase = NULL;
+ flash->jedec_id = NULL;
+ flash->flash_type = NULL;
+ flash->page_info_by_off = NULL;
+ flash->page_info_by_index = NULL;
+ flash->page_count = NULL;
+ flash->write_block_size = NULL;
+ return 0;
+void rtems_flashdev_destroy( rtems_flashdev *flash )
+ rtems_recursive_mutex_destroy( &flash->mutex );
+void rtems_flashdev_destroy_and_free( rtems_flashdev *flash )
+ if ( flash == NULL ) {
+ return;
+ rtems_recursive_mutex_destroy( &( flash->mutex ) );
+ free( flash );
+ flash = NULL;
+ return;
+int rtems_flashdev_init( rtems_flashdev *flash )
+ memset( flash, 0, sizeof( *flash ) );
+ return rtems_flashdev_do_init( flash, rtems_flashdev_destroy );
+rtems_flashdev *rtems_flashdev_alloc_and_init( size_t size )
+ rtems_flashdev *flash = NULL;
+ if ( size >= sizeof( *flash ) ) {
+ flash = calloc( 1, size );
+ if ( flash != NULL ) {
+ int rv;
+ rv = rtems_flashdev_do_init( flash, rtems_flashdev_destroy_and_free );
+ if ( rv != 0 ) {
+ free( flash );
+ return NULL;
+ return flash;
+ size_t count,
+ off_t *addr
+ off_t new_offset;
+ /* Check address is in valid region */
+ new_offset = iop->offset + count;
+ if (rtems_flashdev_check_offset_region(flash, iop, new_offset)) {
+ return -1;
+ /* Get address for operation */
+ if ( !rtems_flashdev_is_region_defined( iop ) ) {
+ *addr = iop->offset;
+ } else {
+ *addr = ( iop->offset + rtems_flashdev_get_region_offset( flash, iop ) );
+ return 0;
+ int status,
+ size_t count,
+ off_t new_offset
+ if ( status == 0 ) {
+ iop->offset = new_offset;
+ return count;
+ } else {
+ rtems_set_errno_and_return_minus_one( status );
+ void *arg
+ rtems_flashdev_ioctl_erase_args *erase_args_1;
+ off_t check_offset;
+ int status;
+ if ( flash->erase == NULL ) {
+ return 0;
+ erase_args_1 = (rtems_flashdev_ioctl_erase_args *) arg;
+ /* Check erasing valid region */
+ check_offset = erase_args_1->offset + erase_args_1->size;
+ if ( rtems_flashdev_is_region_defined( iop ) && (
+ rtems_flashdev_check_offset_region(flash, iop, check_offset) ||
+ ( erase_args_1->offset <
+ rtems_flashdev_get_region_offset( flash, iop ) ) ) ) {
+ /* Erase flash */
+ status = ( *flash->erase )( flash, erase_args_1->offset, erase_args_1->size );
+ return status;
+ void *arg
+ rtems_flashdev_ioctl_region *region_in;
+ region_in = (rtems_flashdev_ioctl_region *) arg;
+ if ( !rtems_flashdev_is_region_defined( iop ) &&
+ flash->region_bit_allocator == RTEMS_FLASHDEV_REGION_ALLOC_FULL ) {
+ /* New region to allocate and all regions allocated */
+ rtems_set_errno_and_return_minus_one( ENOMEM );
+ } else if ( !rtems_flashdev_is_region_defined( iop ) &&
+ flash->region_bit_allocator !=
+ RTEMS_FLASHDEV_REGION_ALLOC_FULL ) {
+ /* New region to allocate and space to allocate region */
+ return rtems_flashdev_ioctl_create_region( flash, iop, region_in );
+ } else {
+ /* Updating existing region */
+ return rtems_flashdev_ioctl_update_region( flash, iop, region_in );
+ uint32_t i = 0;
+ /* Find unallocated region slot */
+ for ( i = 0; i < RTEMS_FLASHDEV_MAX_REGIONS; i++ ) {
+ if ( ( flash->region_bit_allocator & ( ( 1u ) << i ) ) == 0 ) {
+ break;
+ if ( i >= RTEMS_FLASHDEV_MAX_REGIONS ) {
+ /* Set region values */
+ flash->regions[ i ].offset = region_in->offset;
+ flash->regions[ i ].size = region_in->size;
+ /* Set region as allocated and link iop */
+ flash->region_bit_allocator = ( flash->region_bit_allocator |
+ ( ( 1u ) << i ) );
+ rtems_flashdev_set_region_index( iop, i );
+ return 0;
+ uint32_t region_index = rtems_flashdev_get_region_index( iop );
+ * If region index is larger then maximum region index or region
+ * index at given index is undefined return an error.
+ if (
+ ( region_index >= RTEMS_FLASHDEV_MAX_REGIONS ) ||
+ ( ( flash->region_bit_allocator &
+ ( ( 1u ) << ( region_index ) ) ) == 0 )
+ flash->regions[ region_index ].offset = region_in->offset;
+ flash->regions[ region_index ].size = region_in->size;
+ return 0;
+ /* Check region to clear */
+ if ( region_index == RTEMS_FLASHDEV_REGION_UNDEFINED ) {
+ /* Clear region */
+ flash->region_bit_allocator = ( flash->region_bit_allocator &
+ ~( ( 1u ) << ( region_index ) ) );
+ rtems_flashdev_set_region_index( iop, RTEMS_FLASHDEV_REGION_UNDEFINED );
+ return 0;
+ return flash->regions[ rtems_flashdev_get_region_index( iop ) ].offset;
+ return flash->regions[ rtems_flashdev_get_region_index( iop ) ].size;
+static uint32_t rtems_flashdev_ioctl_jedec_id( rtems_flashdev *flash )
+ if ( flash->jedec_id == NULL ) {
+ return 0;
+ } else {
+ return ( *flash->jedec_id )( flash );
+static uint32_t rtems_flashdev_ioctl_flash_type( rtems_flashdev *flash )
+ if ( flash->flash_type == NULL ) {
+ return 0;
+ } else {
+ return ( *flash->flash_type )( flash );
+ void *arg
+ rtems_flashdev_ioctl_page_info *page_info;
+ if ( arg == NULL ) {
+ if ( flash->page_info_by_off == NULL ) {
+ return 0;
+ } else {
+ page_info = (rtems_flashdev_ioctl_page_info *) arg;
+ return ( *flash->page_info_by_off )( flash,
+ page_info->offset_or_index,
+ &page_info->return_page_info.offset,
+ &page_info->return_page_info.size );
+static int rtems_flashdev_ioctl_pageinfo_index( rtems_flashdev *flash,
+ void *arg )
+ if ( flash->page_info_by_index == NULL ) {
+ return 0;
+ } else {
+ return ( *flash->page_info_by_index )( flash,
+static int rtems_flashdev_ioctl_page_count( rtems_flashdev *flash, void *arg )
+ if ( flash->page_count == NULL ) {
+ return 0;
+ } else {
+ return ( *flash->page_count )( flash, ( (int *) arg ) );
+ void *arg
+ if ( flash->write_block_size == NULL ) {
+ return 0;
+ } else {
+ return ( *flash->write_block_size )( flash, ( (size_t *) arg ) );
diff --git a/cpukit/include/dev/flash/flashdev.h b/cpukit/include/dev/flash/flashdev.h
index 0000000000..5d53ea7b97
--- /dev/null
+++ b/cpukit/include/dev/flash/flashdev.h
@@ -0,0 +1,437 @@
+ * @file
+ * @ingroup Flash
+ * @brief Generic Flash API
+ * are met:
+#ifndef _DEV_FLASHDEV_H
+#define _DEV_FLASHDEV_H
+#include <rtems/thread.h>
+#include <sys/types.h>
+typedef struct rtems_flashdev rtems_flashdev;
+ * @defgroup Generic Flash API
+ * @ingroup RTEMSDeviceDrivers
+ * @brief Generic Flash API to wrap specific device drivers.
+/* IOCTL Calls */
+ * @brief Obtains the flash device.
+ * This command has no argument.
+#define RTEMS_FLASHDEV_IOCTL_OBTAIN 0
+ * @brief Releases the flash device.
+#define RTEMS_FLASHDEV_IOCTL_RELEASE 1
+ * @brief Returns the JEDEC ID of the flash device.
+ * @param[out] jedec_id Pointer to uint32_t in which the JEDEC ID is
+ * returned in.
+#define RTEMS_FLASHDEV_IOCTL_JEDEC_ID 2
+ * @brief Erases flash device.
+ * @param[in] erase_args Pointer to rtems_flashdev_ioctl_erase_args struct
+ * containing offset and size of erase to be performed.
+#define RTEMS_FLASHDEV_IOCTL_ERASE 3
+ * @brief Set a region that limits read, write and erase calls to within it.
+ * Regions are file descriptor specific and limited to a single region per
+ * file descriptor and 32 regions total per flash device. Regions can be
+ * changed or updated by calling this IOCTL again.
+ * @param[in] region Pointer to rtems_flashdev_ioctl_region struct containing
+ * base and length of defined region.
+#define RTEMS_FLASHDEV_IOCTL_REGION_SET 4
+ * @brief Removes the set region on the file descriptor.
+#define RTEMS_FLASHDEV_IOCTL_REGION_UNSET 5
+ * @brief Returns the type of flash device (e.g. NOR or NAND).
+ * @param[out] flash_type Pointer to integer which is set to the flash
+ * type macro value.
+#define RTEMS_FLASHDEV_IOCTL_TYPE 6
+ * @brief Get the size and address of flash page at given offset
+ * The offset ignores the region limiting. To find page of region
+ * limited offset add the base of the region to the desired offset.
+ * @param[in,out] rtems_flashdev_ioctl_page_info arg Pointer to struct
+ * with offset and space for return values.
+#define RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET 7
+ * @brief Get the size and address of nth flash page where n is index passed in.
+ * The index ignores the region limiting.
+ * with index and space for return values.
+#define RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX 8
+ * @brief Get the number of pages in flash device.
+ * @param[out] count Integer containing the number of pages.
+#define RTEMS_FLASHDEV_IOCTL_PAGE_COUNT 9
+ * @brief Get the minimum write size supported by the driver.
+ * @param[out] count Integer containing the minimum write size.
+#define RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE 10
+/* Flash Types */
+ * @brief Returned from IOCTL call if flash is of type NOR.
+#define RTEMS_FLASHDEV_TYPE_NOR 0
+ * @brief Returned from IOCTL call if flash is of type NAND.
+#define RTEMS_FLASHDEV_TYPE_NAND 1
+ * @brief The maximum number of region limited file descriptors
+ * allowed to be open at once.
+#define RTEMS_FLASHDEV_MAX_REGIONS 32
+ * @brief General definition for on flash device.
+typedef struct rtems_flashdev_region {
+ * @brief Base of region.
+ off_t offset;
+ * @brief Length of region.
+ size_t size;
+} rtems_flashdev_ioctl_region,
+ rtems_flashdev_ioctl_erase_args,
+ rtems_flashdev_returned_page_info;
+ * @brief Page information returned from IOCTL calls.
+typedef struct rtems_flashdev_ioctl_page_info {
+ * @brief Offset or index to find page at.
+ off_t offset_or_index;
+ * @brief Information returned about the page. Including the
+ * base offset and size of page.
+ rtems_flashdev_returned_page_info return_page_info;
+} rtems_flashdev_ioctl_page_info;
+ * @brief Flash device.
+struct rtems_flashdev {
+ * @brief Call to the device driver to read the flash device.
+ * @param[in] flash Pointer to flash device.
+ * @param[in] offset Address to read from.
+ * @param[in] count Number of bytes to read.
+ * @param[out] buffer Buffer for data to be read into.
+ * @retval 0 Successful operation.
+ * @retval 1 Failed operation.
+ int ( *read )(
+ uint32_t offset,
+ uint32_t count,
+ void *buffer
+ * @brief Call to the device driver to write to the flash device.
+ * @param[in] offset Address to write to.
+ * @param[in] buffer Buffer for data to be written from.
+ int ( *write )(
+ uint32_t offset,
+ uint32_t count,
+ * @brief Call to the device driver to erase the flash device.
+ * @param[in] offset Address to erase at.
+ * @param[in] count Number of bytes to erase.
+ int ( *erase )(
+ uint32_t offset,
+ uint32_t count
+ * @brief Call to the device driver to return the JEDEC ID.
+ * @param[in] flash The flash device.
+ * @retval JEDEC ID.
+ uint32_t ( *jedec_id )(
+ * @brief Call to the device driver to return the flash type.
+ * @retval The RTEMS_FLASHDEV_TYPE_* for the given flash type.
+ int ( *flash_type )(
+ * @brief Call to device driver to get size and offset of page at
+ * given offset
+ * @param[in] search_offset The offset of the page which info is to be
+ * returned.
+ * @param[out] page_offset The offset of the start of the page
+ * @param[out] page_size The size of the page
+ * @retval 0 Success.
+ * @retval non-zero Failed.
+ int ( *page_info_by_off )(
+ off_t search_offset,
+ off_t *page_offset,
+ size_t *page_size
+ * given offset
+ * @param[in] search_index The index of the page which info is to be returned.
+ * @retval 0 Sucess.
+ int ( *page_info_by_index )(
+ rtems_flashdev *flashdev,
+ off_t search_index,
+ size_t *page_size
+ * @brief Call to device driver to return the number of pages on the flash
+ * device.
+ * @param[out] page_count The number of pages on the flash device.
+ int ( *page_count )(
+ int *page_count
+ * @brief Call to device driver to return the minimum write size of the
+ * flash device.
+ * @param[out] write_block_size The mimimum write size of the flash device.
+ int ( *write_block_size )(
+ size_t *write_block_size
+ * @brief Destroys the flash device.
+ * @brief Pointer to device driver.
+ void *driver;
+ * @brief Mutex to protect the flash device access.
+ rtems_recursive_mutex mutex;
+ * @brief Bit allocator for regions.
+ uint32_t region_bit_allocator;
+ * @brief Regions stored.
+ rtems_flashdev_ioctl_region regions[ RTEMS_FLASHDEV_MAX_REGIONS ];
+ * @brief Allocate and initialize the flash device.
+ * After a successful allocation and initialization of the flash device
+ * it must be destoryed via rtems_flashdev_destroy_and_free().
+ * @param[in] size The number of bytes to allocate.
+ * @retval NULL Failed to set up flash device.
+ * @retval non-NULL The new flash device.
+ size_t size
+ * @brief Initialize the flash device.
+ * After a successful initialization of the flash device it must be
+ * destroyed via rtems_flashdev_destory().
+ * After initalization and before registration read, write, erase, jedec_id
+ * and flash_type functions need to be set in the flashdev.
+ * @param[in] flash The flash device to initialize.
+ * @retval 1 Failed to set up flash device.
+ * @retval 0 Successful set up of flash device.
+ * @brief Register the flash device.
+ * This function always claims ownership of the flash device.
+ * @param[in] flash_path The path to the flash device file.
+ * @retval non-zero Failed operation.
+ const char *flash_path
+ * @brief Destorys the flash device.
+ * @brief Destorys the flash device and frees it's memory.
+#endif /* _DEV_FLASHDEV_H */
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 2c969aa5f6..86c5c8ff2b 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -52,6 +52,9 @@ install:
- destination: ${BSP_INCLUDEDIR}/dev/spi
source:
- cpukit/include/dev/spi/spi.h
+- destination: ${BSP_INCLUDEDIR}/dev/flash
+ source:
+ - cpukit/include/dev/flash/flashdev.h
- destination: ${BSP_INCLUDEDIR}/dev/can
source:
- cpukit/include/dev/can/can.h
@@ -522,6 +525,7 @@ links:
- role: build-dependency
uid: vckey
source:
+- cpukit/dev/flash/flashdev.c
- cpukit/dev/i2c/eeprom.c
- cpukit/dev/i2c/fpga-i2c-slave.c
- cpukit/dev/i2c/gpio-nxp-pca9535.c
2.25.1
