[PATCH v3 0/3] bsps/microblaze: FDT support and UART driver improvements
Alex White
alex.white at oarcorp.com
Mon Apr 10 03:47:56 UTC 2023
v3:
- Support multiple UARTs only if the BSP is configured to use FDT. This allows
for flexibility since the user now just has to specify the maximum number of
UARTs, and the UART configurations will be read from the FDT. In the previous
version of this patch set, the extra UARTs were all configured at build time
which was not very flexible and required adding a lot of extra BSP options.
v2:
- Allow UART driver to fill the transmit FIFO rather than just sending one byte
at a time.
Maldonado, Sergio E. (GSFC-580.0) (3):
bsps/microblaze: Allow copying FDT from U-Boot
bsps/microblaze: Add support for multiple UARTs
bsps/microblaze: Fix UART transmit interrupt
bsps/microblaze/include/dev/serial/uartlite.h | 4 +
.../microblaze_fpga/console/console-io.c | 205 ++++++++++++++++--
bsps/microblaze/microblaze_fpga/include/bsp.h | 3 +
.../microblaze_fpga/start/crtinit.S | 6 +-
.../microblaze_invalidate_dcache_range.S | 104 +++++++++
bsps/microblaze/shared/dev/serial/uartlite.c | 30 ++-
.../shared/fdt/microblaze-fdt-support.c | 36 ++-
.../bsps/microblaze/microblaze_fpga/grp.yml | 14 ++
.../bsps/microblaze/microblaze_fpga/obj.yml | 2 +-
.../microblaze_fpga/optconsoleuart.yml | 21 ++
.../microblaze_fpga/optmaxuarts.yml | 21 ++
.../microblaze/microblaze_fpga/optuartirq.yml | 20 ++
.../microblaze/microblaze_fpga/optuseuart.yml | 17 ++
13 files changed, 446 insertions(+), 37 deletions(-)
create mode 100644 bsps/microblaze/microblaze_fpga/start/microblaze_invalidate_dcache_range.S
create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optconsoleuart.yml
create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optmaxuarts.yml
create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optuartirq.yml
create mode 100644 spec/build/bsps/microblaze/microblaze_fpga/optuseuart.yml
2.34.1
