Motorola PowerPC asm warning
Chris Johns
chrisj at rtems.org
Tue Apr 11 04:39:31 UTC 2023
On 9/4/2023 1:26 am, Joel Sherrill wrote:
> On Fri, Apr 7, 2023, 6:55 PM Joel Sherrill <joel at rtems.org
> <mailto:joel at rtems.org>> wrote:
> On Fri, Apr 7, 2023, 5:54 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> Hi
> Building the motorola_powerpc BSPs I noticed this warning:
> ../../../bsps/powerpc/shared/exceptions/ppc_exc.S: Assembler messages:
> ../../../bsps/powerpc/shared/exceptions/ppc_exc.S:132: Warning: invalid
> register
> expression
> ../../../bsps/powerpc/shared/exceptions/ppc_exc.S:135: Warning: invalid
> register
> expression
> https://git.rtems.org/rtems/tree/bsps/powerpc/shared/exceptions/ppc_exc.S#n132 <https://git.rtems.org/rtems/tree/bsps/powerpc/shared/exceptions/ppc_exc.S#n132>
> Can someone with an understanding of the PowerPC processors please
> comment if
> this is an issue or how we can remove the warning?
> It's from something in the macro. Any chance of a cut down of the
> preprocessed output and command it fails with?
> With that, we can compare the PPC model being compiled against with the
> instructions and registers.
> If it is Book E for an old PPC model, I don't think they will work since Book E
> is way newer.
There are 3 machine flags used to build the file in the motorola_powerpc:
-mcpu=603e
-mcpu=604
-mcpu=7400
and all have the warning. This is the command line for the mvme2100 BSP:
powerpc-rtems6-gcc -MMD -mcpu=603e -DASM -g \
-Icpukit/include -I../../../cpukit/include \
-Icpukit/score/cpu/powerpc/include \
-I../../../cpukit/score/cpu/powerpc/include \
-Ibsps/include -I../../../bsps/include -Ibsps/powerpc/include \
-I../../../bsps/powerpc/include \
-Ibsps/powerpc/motorola_powerpc/include \
-I../../../bsps/powerpc/motorola_powerpc/include \
../../../bsps/powerpc/shared/exceptions/ppc_exc.S -c \
-obsps/powerpc/shared/exceptions/ppc_exc.S.46.o
The warning is from the WRAP assembler macro:
https://git.rtems.org/rtems/tree/bsps/powerpc/shared/exceptions/ppc_exc_asm_macros.h#n730
The instruction in the TEST_LOCK_ assembler macro that is generating the warning is:
https://git.rtems.org/rtems/tree/bsps/powerpc/shared/exceptions/ppc_exc_asm_macros.h#n242
If I comment this instruction the warning goes away. The assembled object file
shows the instruction as:
000006ac <TEST_LOCK_crit_done_bookE_crit>:
6ac: 4e 52 11 02 crandc 4*cr4+eq,4*cr4+eq,eq
The pre-processed code is:
TEST_LOCK_crit_done_\_FLVR:
crandc ((4)*4+2), ((4)*4+2), ((cr0)*4+2)
And in this case FLVR is bookE_crit. I have no idea what is happening in the code.
