[PATCH] gdb-common: Fix the python-config library parsing
Karel Gardas karel at functional.vision
Tue Apr 11 07:19:40 UTC 2023
Thanks for the quick fix. I tested here and indeed this fixes the
reported issue.
Karel
On 4/11/23 08:03, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
> Closes #4894
>   source-builder/config/gdb-common-1.cfg | 6 +++---
>   1 file changed, 3 insertions(+), 3 deletions(-)
> diff --git a/source-builder/config/gdb-common-1.cfg b/source-builder/config/gdb-common-1.cfg
> index a52e64d..0fea334 100644
> --- a/source-builder/config/gdb-common-1.cfg
> +++ b/source-builder/config/gdb-common-1.cfg
> @@ -109,8 +109,8 @@
>     %define gdb-host-libs -L '%{host_ldflags}'
>   %endif
>   %if %{gdb-python-config} != %{nil}
> -  %define gdb-python-lib-filter awk 'BEGIN{FS=" "}/python/{for(i=1;i<NF;++i)if(match($i,".*lpython.*")) print "lib"substr($i,3)"\\*";}'
> -  %define gdb-python-libpath-filter awk 'BEGIN{FS=" "}/python/{for(i=1;i<NF;++i)if(match($i,".*L.*")) print substr($i,3);}'
> +  %define gdb-python-lib-filter awk '{for(i=1;i<NF;++i)if(match($i,".*lpython.*")) print "lib"substr($i,3)"\\*";}'
> +  %define gdb-python-libpath-filter awk '{for(i=1;i<NF;++i) if (match($i,"-L.*") == 1) l[substr($i,3)]=1;} END{for(i in l) printf("-L " i " "); printf("\n");}'
>     %if %{gdb-python-ver-major} < 3 || \
>         %{gdb-python-ver-major} == 3 && %{gdb-python-ver-minor} < 8
>         %define gdb-python-config-lib-check-flags --ldflags
> @@ -119,7 +119,7 @@
>     %endif
>     %define gdb-python-config-libs %(%{gdb-python-config} %{gdb-python-config-lib-check-flags} | %{gdb-python-lib-filter})
>     %define gdb-python-config-libpath %(%{gdb-python-config} %{gdb-python-config-lib-check-flags} | %{gdb-python-libpath-filter} | uniq)
> -  %define gdb-python-lib-check %(%{_sbdir}/sb/rtems-build-dep -c %{__cc} %{gdb-host-libs} -L %{gdb-python-config-libpath} -l %{gdb-python-config-libs})
> +  %define gdb-python-lib-check %(%{_sbdir}/sb/rtems-build-dep -c %{__cc} %{gdb-host-libs} %{gdb-python-config-libpath} -l %{gdb-python-config-libs})
>   %else
>     %define gdb-python-lib-check %(%{_sbdir}/sb/rtems-build-dep -c %{__cc} %{gdb-host-libs} -l %{gdb-python-ver-lib})
>   %endif
