[PATCH 2/2] bsps/powerpc: Fix warnings with PPC_SPECIAL_PURPOSE_REGISTER
Tue Apr 11 12:29:22 UTC 2023
Anything to add to the message beyond "fix" to explain this patch? :)
I think the software engineering guide uses a comment similar to this as an
anti-pattern. Lol
On Tue, Apr 11, 2023, 12:00 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
>  bsps/powerpc/include/libcpu/powerpc-utility.h | 40 +++++++++++--------
>  .../powerpc/shared/exceptions/ppc_exc_print.c | 25 +++++++-----
>  2 files changed, 38 insertions(+), 27 deletions(-)
> diff --git a/bsps/powerpc/include/libcpu/powerpc-utility.h
> b/bsps/powerpc/include/libcpu/powerpc-utility.h
> index 922e5d2407..fb831c9fa8 100644
> --- a/bsps/powerpc/include/libcpu/powerpc-utility.h
> +++ b/bsps/powerpc/include/libcpu/powerpc-utility.h
> @@ -577,15 +577,11 @@ static inline void
> ppc_set_decrementer_register(uint32_t dec)
>   * @note This macro uses a GNU C extension.
> -#define PPC_SPECIAL_PURPOSE_REGISTER(spr) \
> -    uint32_t val; \
> -    __asm__ volatile (\
> -      "mfspr %0, " PPC_STRINGOF(spr) \
> -      : "=r" (val) \
> -    val;\
> +#define PPC_SPECIAL_PURPOSE_REGISTER(spr, val) \
> +  __asm__ volatile (\
> +    "mfspr %0, " PPC_STRINGOF(spr) \
> +    : "=r" (val) \
>   * @brief Sets the Special Purpose Register with number @a spr to the
> value in
> @@ -612,7 +608,7 @@ static inline void
>      uint32_t val; \
>      uint32_t mybits = bits; \
>      _ISR_Local_disable(level); \
> -    val = PPC_SPECIAL_PURPOSE_REGISTER(spr); \
> +    PPC_SPECIAL_PURPOSE_REGISTER(spr, val); \
>      val |= mybits; \
>      PPC_SET_SPECIAL_PURPOSE_REGISTER(spr, val); \
>      _ISR_Local_enable(level); \
> @@ -632,7 +628,7 @@ static inline void
>      uint32_t mymask = mask; \
>      val &= ~mymask; \
>      val |= mybits; \
> @@ -651,7 +647,7 @@ static inline void
>      uint32_t val; \
>      val &= ~mybits; \
> @@ -790,7 +786,9 @@ static inline void ppc_set_time_base(uint32_t val)
>  static inline uint32_t ppc_time_base_upper(void)
> -  return PPC_SPECIAL_PURPOSE_REGISTER(TBRU);
> +  uint32_t val;
> +  PPC_SPECIAL_PURPOSE_REGISTER(TBRU, val);
> +  return val;
>  static inline void ppc_set_time_base_upper(uint32_t val)
> @@ -810,12 +808,16 @@ static inline void ppc_set_time_base_64(uint64_t val)
>  static inline uint32_t ppc_alternate_time_base(void)
> -  return PPC_SPECIAL_PURPOSE_REGISTER(FSL_EIS_ATBL);
> +  uint32_t val;
> +  PPC_SPECIAL_PURPOSE_REGISTER(FSL_EIS_ATBL, val);
> +  return val;
>  static inline uint32_t ppc_alternate_time_base_upper(void)
> -  return PPC_SPECIAL_PURPOSE_REGISTER(FSL_EIS_ATBU);
> +  uint32_t val;
> +  PPC_SPECIAL_PURPOSE_REGISTER(FSL_EIS_ATBU, val);
> +  return val;
>  static inline uint64_t ppc_alternate_time_base_64(void)
> @@ -835,7 +837,9 @@ static inline uint64_t ppc_alternate_time_base_64(void)
>  static inline uint32_t ppc_processor_id(void)
> -  return PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_PIR);
> +  uint32_t val;
> +  PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_PIR, val);
> +  return val;
>  static inline void ppc_set_processor_id(uint32_t val)
> @@ -845,7 +849,9 @@ static inline void ppc_set_processor_id(uint32_t val)
>  static inline uint32_t ppc_fsl_system_version(void)
> -  return PPC_SPECIAL_PURPOSE_REGISTER(FSL_EIS_SVR);
> +  uint32_t val;
> +  PPC_SPECIAL_PURPOSE_REGISTER(FSL_EIS_SVR, val);
> +  return val;
>  static inline uint32_t ppc_fsl_system_version_cid(uint32_t svr)
> diff --git a/bsps/powerpc/shared/exceptions/ppc_exc_print.c
> b/bsps/powerpc/shared/exceptions/ppc_exc_print.c
> index e4fcc73cb1..ff231beff9 100644
> --- a/bsps/powerpc/shared/exceptions/ppc_exc_print.c
> +++ b/bsps/powerpc/shared/exceptions/ppc_exc_print.c
> @@ -42,18 +42,23 @@ typedef struct LRFrameRec_ {
>  static uint32_t ppc_exc_get_DAR_dflt(void)
> -  if (ppc_cpu_is_60x())
> -    return PPC_SPECIAL_PURPOSE_REGISTER(PPC_DAR);
> -  else
> +  uint32_t val;
> +  if (ppc_cpu_is_60x()) {
> +    PPC_SPECIAL_PURPOSE_REGISTER(PPC_DAR, val);
> +    return val;
> +  } else {
>      switch (ppc_cpu_is_bookE()) {
>        default:
>          break;
>        case PPC_BOOKE_STD:
>        case PPC_BOOKE_E500:
> -        return PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_DEAR);
> +        PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_DEAR, val);
> +        return val;
>        case PPC_BOOKE_405:
> -        return PPC_SPECIAL_PURPOSE_REGISTER(PPC405_DEAR);
> +        PPC_SPECIAL_PURPOSE_REGISTER(PPC405_DEAR, val);
> +        return val;
>    return 0xdeadbeef;
> @@ -170,13 +175,13 @@ void _CPU_Exception_frame_print(const
> CPU_Exception_frame *excPtr)
>      printk(" %s = 0x%08" PRIx32 "\n", reg, ppc_exc_get_DAR());
>    if (ppc_cpu_is_bookE()) {
> -    unsigned esr, mcsr;
> +    uint32_t esr, mcsr;
>      if (ppc_cpu_is_bookE() == PPC_BOOKE_405) {
> -      esr  = PPC_SPECIAL_PURPOSE_REGISTER(PPC405_ESR);
> -      mcsr = PPC_SPECIAL_PURPOSE_REGISTER(PPC405_MCSR);
> +      PPC_SPECIAL_PURPOSE_REGISTER(PPC405_ESR, esr);
> +      PPC_SPECIAL_PURPOSE_REGISTER(PPC405_MCSR, mcsr);
>      } else {
> -      esr  = PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_ESR);
> -      mcsr = PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_MCSR);
> +      PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_ESR, esr);
> +      PPC_SPECIAL_PURPOSE_REGISTER(BOOKE_MCSR, mcsr);
>      printk("  ESR = 0x%08x\n", esr);
>      printk(" MCSR = 0x%08x\n", mcsr);
> 2.37.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230411/fca445f2/attachment.htm>
