[PATCH] print/texinfo: Add texinfo package
chrisj at rtems.org
chrisj at rtems.org
Wed Apr 12 02:09:14 UTC 2023
- MacOS systems do not come with makeinfo
- Fix the internal build logic. There was config logic in a
bset file that does not support logic operators. Use a
special tmp internal path to isolate the internal tools.
bare/config/print/texinfo-7.0.3.cfg | 12 +++
bare/config/print/texinfo-internal.bset | 11 ++
bare/config/print/texinfo.bset | 4 +
bare/config/print/texinfo.cfg | 8 ++
bare/config/textproc/gsed-internal.bset | 4 -
rtems/config/tools/rtems-default-tools.bset | 13 ++-
source-builder/config/gsed-1.cfg | 6 +-
source-builder/config/texinfo-1.cfg | 107 ++++++++++++++++++++
source-builder/defaults.mc | 5 +-
9 files changed, 158 insertions(+), 12 deletions(-)
create mode 100644 bare/config/print/texinfo-7.0.3.cfg
create mode 100644 bare/config/print/texinfo-internal.bset
create mode 100644 bare/config/print/texinfo.bset
create mode 100644 bare/config/print/texinfo.cfg
create mode 100644 source-builder/config/texinfo-1.cfg
diff --git a/bare/config/print/texinfo-7.0.3.cfg b/bare/config/print/texinfo-7.0.3.cfg
new file mode 100644
index 0000000..f8e67be
--- /dev/null
+++ b/bare/config/print/texinfo-7.0.3.cfg
@@ -0,0 +1,12 @@
+# GNU texinfo 7.0.3
+%include %{_configdir}/base.cfg
+%define texinfo_version 7.0.3
+%hash sha512 texinfo-%{texinfo_version}.tar.gz \
+ uJXP+WVCInQgPxcWNogeOx5VfrmruXIwd6OnnpTgrcXW12Icuqe+R9PF1l/8k/uybwfb+0MMdFoYbq7iiIQGSA==
+%include %{_configdir}/texinfo-1.cfg
diff --git a/bare/config/print/texinfo-internal.bset b/bare/config/print/texinfo-internal.bset
index 0000000..8fa5544
--- /dev/null
+++ b/bare/config/print/texinfo-internal.bset
@@ -0,0 +1,11 @@
+# Internal GNU texinfo
+%define _internal_texinfo yes
+%define _disable_collecting yes
+%define _disable_packaging yes
+%define _disable_reporting yes
+%define _disable_installing yes
+%include print/texinfo.bset
diff --git a/bare/config/print/texinfo.bset b/bare/config/print/texinfo.bset
index 0000000..347c48d
--- /dev/null
+++ b/bare/config/print/texinfo.bset
@@ -0,0 +1,4 @@
+# GNU texinfo
+print/texinfo.cfg
diff --git a/bare/config/print/texinfo.cfg b/bare/config/print/texinfo.cfg
index 0000000..5fa0cba
--- /dev/null
+++ b/bare/config/print/texinfo.cfg
@@ -0,0 +1,8 @@
+# GNU makeinfo has a version option, check for it.
+# If not found build it.
+%define has_makeinfo %(makeinfo --version > /dev/null 2>&1; echo $?)
+%if %{has_makeinfo} != 0
+ %include %{_configdir}/print/texinfo-7.0.3.cfg
+%endif
diff --git a/bare/config/textproc/gsed-internal.bset b/bare/config/textproc/gsed-internal.bset
index c45e498..7b2c3b8 100644
--- a/bare/config/textproc/gsed-internal.bset
+++ b/bare/config/textproc/gsed-internal.bset
@@ -2,10 +2,6 @@
# Internal GNU sed
-%if !{defined _internal_gsed_path}
- %error no gsed internal install path defined
-%endif
%define _internal_gsed yes
diff --git a/rtems/config/tools/rtems-default-tools.bset b/rtems/config/tools/rtems-default-tools.bset
index b81f1e8..0291786 100644
--- a/rtems/config/tools/rtems-default-tools.bset
+++ b/rtems/config/tools/rtems-default-tools.bset
@@ -5,16 +5,23 @@
# GCC requires a GNU sed so build an internal version if one is not
# available
-%define _internal_gsed_path %{_tmppath}/sb-%{_uid}/${SB_PREFIX_CLEAN}
-textproc/gsed-internal
+%define _internal_gsed_path %{_tmpinternal}
+%defineifnot with_rtems_gmp textproc/gsed-internal
+# GNU tools need texinfo for makeinfo to build documentation
+%define _internal_texinfo_path %{_tmpinternal}
+%defineifnot with_rtems_texinfo print/texinfo-internal
# Build gdb first to raise the Python install error as early as
-# possible. GDB needs expat so it needs to be built before gdb.
+# possible.
+# GCC and GDB need GMP.
%{with_rtems_dtc}
%{with_rtems_expat}
%{with_rtems_gmp}
+%{with_rtems_texinfo}
%{with_rtems_gdb}
%{with_rtems_binutils}
%{with_rtems_gcc}
diff --git a/source-builder/config/gsed-1.cfg b/source-builder/config/gsed-1.cfg
index 87eb0fb..9135414 100644
--- a/source-builder/config/gsed-1.cfg
+++ b/source-builder/config/gsed-1.cfg
@@ -11,9 +11,6 @@
%ifn %{defined _internal_gsed}
%define _internal_gsed no
%endif
-%ifn %{defined _internal_gsed_path}
- %define _internal_gsed_path %{_prefix}
-%endif
Summary: GNU sed v%{gsed_version} for host %{_host}
@@ -30,6 +27,9 @@ URL: https://www.gnu.org/software/sed/
# Remap the install paths if it is an internal build
%if %{_internal_gsed} == yes
+ %if !%{defined _internal_gsed_path}
+ %error no gsed internal install path defined
+ %endif
%define gsed_prefix %{_internal_gsed_path}
%else
%define gsed_prefix %{_prefix}
diff --git a/source-builder/config/texinfo-1.cfg b/source-builder/config/texinfo-1.cfg
index 0000000..d1fc2a0
--- /dev/null
+++ b/source-builder/config/texinfo-1.cfg
@@ -0,0 +1,107 @@
+# GNU texinfo 7.xx Version 1.
+# This configuration file configure's, make's and install's GNU's texinfo
+%if %{release} == %{nil}
+ %define release 1
+%endif
+%ifn %{defined _internal_texinfo}
+ %define _internal_texinfo no
+%endif
+Name: texinfo-%{texinfo_version}-%{_host}-%{release}
+Summary: GNU texinfo v%{texinfo_version} for host %{_host}
+Version: %{texinfo_version}
+Release: %{release}
+URL: https://www.gnu.org/software/texinfo/
+# Source
+%source set texinfo https://ftp.gnu.org/gnu/texinfo/texinfo-%{texinfo_version}.tar.gz
+# Remap the install paths if it is an internal build
+%if %{_internal_texinfo} == yes
+ %if !%{defined _internal_texinfo_path}
+ %error no texinfo internal install path defined
+ %endif
+ %define texinfo_prefix %{_internal_texinfo_path}
+%else
+ %define texinfo_prefix %{_prefix}
+%endif
+%define texinfo_exec_prefix %{texinfo_prefix}
+%define texinfo_bindir %{texinfo_exec_prefix}/bin
+%define texinfo_sbindir %{texinfo_exec_prefix}/sbin
+%define texinfo_libexecdir %{texinfo_exec_prefix}/libexec
+%define texinfo_datarootdir %{texinfo_prefix}/share
+%define texinfo_datadir %{texinfo_datarootdir}
+%define texinfo_sysconfdir %{texinfo_prefix}/etc
+%define texinfo_sharedstatedir %{texinfo_prefix}/com
+%define texinfo_localstatedir %{texinfo_prefix}/var
+%define texinfo_includedir %{texinfo_prefix}/include
+%define texinfo_libdir %{texinfo_exec_prefix}/%{_lib}
+%define texinfo_mandir %{texinfo_datarootdir}/man
+%define texinfo_infodir %{texinfo_datarootdir}/info
+%define texinfo_localedir %{texinfo_datarootdir}/locale
+# Prepare the source code.
+%prep
+ build_top=$(pwd)
+ source_dir_texinfo="texinfo-%{texinfo_version}"
+ %source setup texinfo -q -n texinfo-%{texinfo_version}
+ %patch setup texinfo -p1
+ cd ${build_top}
+%build
+ build_top=$(pwd)
+ %if %{defined _internal_texinfo_path}
+ export PATH="%{_internal_texinfo_path}/bin:${PATH}"
+ %endif
+ %{build_directory}
+ mkdir -p ${build_dir}
+ cd ${build_dir}
+ %{host_build_flags}
+ ../${source_dir_texinfo}/configure \
+ --prefix=%{texinfo_prefix} \
+ --bindir=%{texinfo_bindir} \
+ --exec_prefix=%{texinfo_exec_prefix} \
+ --includedir=%{texinfo_includedir} \
+ --libdir=%{texinfo_libdir} \
+ --libexecdir=%{texinfo_libexecdir} \
+ --mandir=%{texinfo_mandir} \
+ --infodir=%{texinfo_infodir} \
+ --datadir=%{texinfo_datadir} \
+ %{__make} %{?_smp_mflags} all
+ cd ${build_top}
+%install
+ build_top=$(pwd)
+ %{__rmdir} $SB_BUILD_ROOT
+ cd ${build_dir}
+ %if %{_internal_texinfo} == yes
+ %{__make} install
+ %else
+ %{__make} DESTDIR=$SB_BUILD_ROOT install
+ %endif
+ cd ${build_top}
diff --git a/source-builder/defaults.mc b/source-builder/defaults.mc
index 503dd92..6575e35 100644
--- a/source-builder/defaults.mc
+++ b/source-builder/defaults.mc
@@ -109,6 +109,7 @@ _docdir: dir, none, '%{_defaultdocdir}'
_tmppath: dir, none, '%{_topdir}/build/tmp'
_tmproot: dir, none, '%{_tmppath}/sb-%{_uid}/%{_bset_tmp}'
_tmpcxcroot: dir, none, '%{_tmppath}/sb-%{_uid}-cxc/%{_bset_tmp}'
+_tmpinternal: dir, none, '%{_tmppath}/sb-%{_uid}-internal'
_datadir: dir, none, '%{_prefix}/share'
_defaultdocdir: dir, none, '%{_prefix}/share/doc'
_dry_run: none, none, '0'
@@ -131,7 +132,7 @@ _infodir: dir, none, '%{_datarootdir}/info'
_localedir: dir, none, '%{_datarootdir}/locale'
_localedir: dir, none, '%{_datadir}/locale'
_localstatedir: dir, none, '%{_prefix}/var'
-_pathprepend: none, none, ''
+_pathprepend: none, none, '%{_tmpinternal}/bin'
_pathpostpend: none, none, ''
_prefix: dir, none, '%{_usr}'
_usr: dir, none, '/usr/local'
@@ -179,7 +180,7 @@ __ld: exe, required, '/usr/bin/ld'
__ldconfig: exe, required, '/sbin/ldconfig'
__ln_s: exe, none, 'ln -s'
__make: exe, required, 'make'
-__makeinfo: exe, required, '/usr/bin/makeinfo'
+__makeinfo: exe, optional, '/usr/bin/makeinfo'
__mkdir: exe, required, '/bin/mkdir'
__mkdir_p: exe, none, '/bin/mkdir -p'
__mv: exe, required, '/bin/mv'
2.37.1
