[PATCH 16/18] ptpd: Add to build system
Gabriel Moyano gabriel.moyano at dlr.de
Wed Apr 12 13:54:20 UTC 2023
 buildset/default.ini |  1 +
 libbsd.py            | 47 ++++++++++++++++++++++++++++++++++++++++++++
 2 files changed, 48 insertions(+)
diff --git a/buildset/default.ini b/buildset/default.ini
index 88379a96..9145be9b 100644
--- a/buildset/default.ini
+++ b/buildset/default.ini
@@ -40,6 +40,7 @@ iic = on
 pinmux = on
 display = on
 dhcpcd = on
+ptpd = on
 dpaa = on
 evdev = on
 fdt = on
diff --git a/libbsd.py b/libbsd.py
index e3840f37..1e9b60b5 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -88,6 +88,7 @@ _defaults = {
                  'freebsd/contrib/expat/lib',
                  'freebsd/contrib/libpcap',
                  'freebsd/contrib/libxo',
+                 'freebsd/contrib/ptpd/src',
                  'mDNSResponder/mDNSCore',
                  'mDNSResponder/mDNSShared',
                  'mDNSResponder/mDNSPosix',
@@ -5363,6 +5364,51 @@ class regulator(builder.Module):
             mm.generator['source']()
+# PTPD
+class ptpd(builder.Module):
+    def __init__(self, manager):
+        super(ptpd, self).__init__(manager, type(self).__name__)
+    def generate(self):
+        mm = self.manager
+        self.addUserSpaceSourceFiles(
+                'contrib/ptpd/src/dep/iniparser/dictionary.c',
+                'contrib/ptpd/src/dep/iniparser/iniparser.c',
+                'contrib/ptpd/src/dep/ntpengine/ntp_isc_md5.c',
+                'contrib/ptpd/src/dep/ntpengine/ntpdcontrol.c',
+                'contrib/ptpd/src/dep/alarms.c',
+                'contrib/ptpd/src/dep/configdefaults.c',
+                'contrib/ptpd/src/dep/daemonconfig.c',
+                'contrib/ptpd/src/dep/eventtimer.c',
+                'contrib/ptpd/src/dep/eventtimer_kqueue.c',
+                'contrib/ptpd/src/dep/ipv4_acl.c',
+                'contrib/ptpd/src/dep/kqueue.c',
+                'contrib/ptpd/src/dep/msg.c',
+                'contrib/ptpd/src/dep/net.c',
+                'contrib/ptpd/src/dep/outlierfilter.c',
+                'contrib/ptpd/src/dep/servo.c',
+                'contrib/ptpd/src/dep/startup.c',
+                'contrib/ptpd/src/dep/statistics.c',
+                'contrib/ptpd/src/dep/sys.c',
+                'contrib/ptpd/src/arith.c',
+                'contrib/ptpd/src/bmc.c',
+                'contrib/ptpd/src/display.c',
+                'contrib/ptpd/src/management.c',
+                'contrib/ptpd/src/protocol.c',
+                'contrib/ptpd/src/ptp_timers.c',
+                'contrib/ptpd/src/ptpd.c',
+                'contrib/ptpd/src/signaling.c',
+                'contrib/ptpd/src/timingdomain.c',
+            mm.generator['source'](['-DPTPD_NO_DAEMON',
+                                    '-DDATADIR=""',
+                                    '-DPACKAGE_NAME=""'])
 # Tests
@@ -5546,6 +5592,7 @@ def load(mm):
     mm.addModule(dhcpcd(mm))
     mm.addModule(mdnsresponder(mm))
+    mm.addModule(ptpd(mm))
     mm.addModule(tests(mm))
2.25.1
