[PATCH 04/18] ptpd: Add implementation of eventtimer based on kqueue
Gabriel Moyano
gabriel.moyano at dlr.de
Wed Apr 12 13:54:08 UTC 2023
freebsd/contrib/ptpd/src/dep/datatypes_dep.h | 10 +
freebsd/contrib/ptpd/src/dep/eventtimer.h | 6 +-
.../contrib/ptpd/src/dep/eventtimer_kqueue.c | 184 ++++++++++++++++++
freebsd/contrib/ptpd/src/dep/kqueue.c | 80 ++++++++
freebsd/contrib/ptpd/src/dep/net.c | 111 ++++++++++-
freebsd/contrib/ptpd/src/dep/ptpd_dep.h | 11 +-
freebsd/contrib/ptpd/src/protocol.c | 22 ++-
freebsd/contrib/ptpd/src/ptpd.h | 3 +
8 files changed, 411 insertions(+), 16 deletions(-)
create mode 100644 freebsd/contrib/ptpd/src/dep/eventtimer_kqueue.c
create mode 100644 freebsd/contrib/ptpd/src/dep/kqueue.c
diff --git a/freebsd/contrib/ptpd/src/dep/datatypes_dep.h b/freebsd/contrib/ptpd/src/dep/datatypes_dep.h
index 77a645c4..9496ed60 100644
--- a/freebsd/contrib/ptpd/src/dep/datatypes_dep.h
+++ b/freebsd/contrib/ptpd/src/dep/datatypes_dep.h
@@ -43,6 +43,16 @@ typedef struct {
int ifIndex;
} InterfaceInfo;
+* \brief Support for kqueue or select
+#ifdef HAVE_KQUEUE
+#define PTPD_KQUEUE_EVENTS (4) /* 2 for PTP, 2 for PCAP */
+typedef struct kevent PtpNetWaitEvents;
+#else
+typedef struct fd_set PtpNetWaitEvents;
+#endif
* \brief Struct describing network transport data
diff --git a/freebsd/contrib/ptpd/src/dep/eventtimer.h b/freebsd/contrib/ptpd/src/dep/eventtimer.h
index 9d41156d..dc4080df 100644
--- a/freebsd/contrib/ptpd/src/dep/eventtimer.h
+++ b/freebsd/contrib/ptpd/src/dep/eventtimer.h
@@ -51,9 +51,11 @@ struct EventTimer {
Boolean (*isRunning) (EventTimer* timer);
/* implementation data */
-#ifdef PTPD_PTIMERS
+#ifdef HAVE_KQUEUE
+ int timerId;
+#elif defined PTPD_PTIMERS
timer_t timerId;
-#else
+#else /* HAVE_KQUEUE */
int32_t itimerInterval;
int32_t itimerLeft;
#endif /* PTPD_PTIMERS */
diff --git a/freebsd/contrib/ptpd/src/dep/eventtimer_kqueue.c b/freebsd/contrib/ptpd/src/dep/eventtimer_kqueue.c
new file mode 100644
index 00000000..914bbc4a
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/eventtimer_kqueue.c
@@ -0,0 +1,184 @@
+ * Copyright (c) 2020 Chris Johns,
+ * All Rights Reserved
+ * modification, are permitted provided that the following conditions are
+ * met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ * this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE AUTHORS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
+ * BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
+ * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
+ * IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * @file eventtimer_kqueue.c
+ * @date
+ * @brief EventTimer implementation using kqueue timers
+ * Needs support in the kqueue to pass timer events to here.
+#include "../ptpd.h"
+static void eventTimerStart_kqueue(EventTimer *timer, double interval);
+static void eventTimerStop_kqueue(EventTimer *timer);
+static void eventTimerReset_kqueue(EventTimer *timer);
+static void eventTimerShutdown_kqueue(EventTimer *timer);
+static Boolean eventTimerIsRunning_kqueue(EventTimer *timer);
+static Boolean eventTimerIsExpired_kqueue(EventTimer *timer);
+static int timerInstance;
+void
+setupEventTimer(EventTimer *timer)
+ struct kevent evset;
+ if(timer == NULL) {
+ return;
+ memset(timer, 0, sizeof(EventTimer));
+ timer->start = eventTimerStart_kqueue;
+ timer->stop = eventTimerStop_kqueue;
+ timer->reset = eventTimerReset_kqueue;
+ timer->shutdown = eventTimerShutdown_kqueue;
+ timer->isExpired = eventTimerIsExpired_kqueue;
+ timer->isRunning = eventTimerIsRunning_kqueue;
+ timer->timerId = ++timerInstance;
+ EV_SET(&evset, timer->timerId, EVFILT_TIMER, EV_ADD | EV_DISABLE, 0, 0, timer);
+ if (kevent(ptpKqueueGet(), &evset, 1, NULL, 0, NULL) < 0)
+ PERROR("kevent timer add | disable");
+ DBGV("Created kqueue timer %s (%d)", timer->id, timer->timerId);
+static void
+eventTimerStart_kqueue(EventTimer *timer, double interval)
+ int kq = ptpKqueueGet();
+ if (kq >= 0) {
+ intptr_t data = interval * 1000000;
+ EVFILT_TIMER, EV_ADD | EV_ENABLE | EV_CLEAR,
+ NOTE_USECONDS, data, timer);
+ DBGV("Timer %s start requested at %ld us interval\n", timer->id, data);
+ if (kevent(kq, &evset, 1, NULL, 0, NULL) < 0) {
+ PERROR("kevent timer add | enable");
+ return;
+ DBG2("timerStart: Set timer %s to %f\n", timer->id, interval);
+ timer->expired = FALSE;
+ timer->running = TRUE;
+static void
+eventTimerStop_kqueue(EventTimer *timer)
+ if (kq >= 0) {
+ DBGV("Timer %s stop requested\n", timer->id);
+ timer->running = FALSE;
+ DBG2("timerStop: stopped timer %s\n", timer->id);
+static void
+eventTimerReset_kqueue(EventTimer *timer)
+static void
+eventTimerShutdown_kqueue(EventTimer *timer)
+ if (kq >= 0) {
+ EV_SET(&evset, timer->timerId, EVFILT_TIMER, EV_DELETE, 0, 0, timer);
+ PERROR("kevent timer disable");
+ DBG2("timerShutdown: %s\n", timer->id);
+static Boolean
+eventTimerIsRunning_kqueue(EventTimer *timer)
+ DBG2("timerIsRunning: Timer %s %s running\n", timer->id,
+ timer->running ? "is" : "is not");
+ return timer->running;
+static Boolean
+eventTimerIsExpired_kqueue(EventTimer *timer)
+ Boolean ret;
+ ret = timer->expired;
+ DBG2("timerIsExpired: Timer %s %s expired\n", timer->id,
+ timer->expired ? "is" : "is not");
+ /* the five monkeys experiment */
+ if(ret) {
+ return ret;
+void
+startEventTimers(void)
+ DBG("initTimer\n");
+void
+shutdownEventTimers(void)
diff --git a/freebsd/contrib/ptpd/src/dep/kqueue.c b/freebsd/contrib/ptpd/src/dep/kqueue.c
index 00000000..d516c186
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/kqueue.c
@@ -0,0 +1,80 @@
+ * met:
+ * @file kqueue.c
+ * @date
+ * @brief Kqueue support code
+ * The kqueue is shared between the networking and timer code and there
+ * no shared data in their interfaces so kqueue handle is held here.
+static int kq = -1;
+int
+ptpKqueueGet(void)
+#ifdef HAVE_KQUEUE
+ if(kq < 0) {
+ kq = kqueue();
+ if (kq < 0)
+ PERROR("kqueue failed");
+#endif
+ return kq;
+int
+ptpKqueueWait(struct timespec* ts, struct kevent* events, int nevents)
+ int ret;
+ if (kq < 0) {
+ PERROR("kqueue not initialised");
+ return -1;
+ ret = kevent(kq, NULL, 0, events, nevents, ts);
+ if (ret > 0) {
+ int e;
+ for (e = 0; e < ret; ++e) {
+ DBG2("kevent: %d: %2d: %s\n", e, events[e].ident,
+ events[e].filter == EVFILT_TIMER ? "timer" : "sock");
+ if (events[e].filter == EVFILT_TIMER) {
+ EventTimer* timer = events[e].udata;
+ timer->expired = TRUE;
+ return ret;
diff --git a/freebsd/contrib/ptpd/src/dep/net.c b/freebsd/contrib/ptpd/src/dep/net.c
index 86db9b83..edee5dc6 100644
--- a/freebsd/contrib/ptpd/src/dep/net.c
+++ b/freebsd/contrib/ptpd/src/dep/net.c
@@ -149,6 +149,41 @@ isIpMulticast(struct in_addr in)
+/* KQUEUE support to add and delete events */
+static int netKqueueAdd(int fd)
+ int res = 0;
+#ifdef HAVE_KQUEUE
+ if (fd >= 0 && kq >= 0) {
+ EV_SET(&evset, fd, EVFILT_READ, EV_ADD, 0, 0, NULL);
+ res = kevent(kq, &evset, 1, NULL, 0, NULL);
+ if (res == -1)
+ PERROR("kevent sock read add");
+ DBG("add sock kevent: %d --> %d\n", fd, kq);
+#endif
+ return res;
+static int netKqueueDelete(int fd)
+ int res = 0;
+#ifdef HAVE_KQUEUE
+ EV_SET(&evset, fd, EVFILT_READ, EV_DELETE, 0, 0, NULL);
+ if (res == -1)
+ PERROR("kevent sock read delete");
+ DBG("delete sock kevent: %d x-> %d\n", fd, kq);
+#endif
+ return res;
/* shut down the UDP stuff */
Boolean
netShutdown(NetPath * netPath)
@@ -156,20 +191,26 @@ netShutdown(NetPath * netPath)
netShutdownMulticast(netPath);
/* Close sockets */
- if (netPath->eventSock >= 0)
+ if (netPath->eventSock >= 0) {
+ netKqueueDelete(netPath->eventSock);
close(netPath->eventSock);
netPath->eventSock = -1;
- if (netPath->generalSock >= 0)
+ if (netPath->generalSock >= 0) {
+ netKqueueDelete(netPath->generalSock);
close(netPath->generalSock);
netPath->generalSock = -1;
#ifdef PTPD_PCAP
if (netPath->pcapEvent != NULL) {
+ netKqueueDelete(netPath->pcapEventSock);
pcap_close(netPath->pcapEvent);
netPath->pcapEventSock = -1;
if (netPath->pcapGeneral != NULL) {
+ netKqueueDelete(netPath->pcapGeneralSock);
pcap_close(netPath->pcapGeneral);
netPath->pcapGeneralSock = -1;
@@ -1039,6 +1080,10 @@ netInit(NetPath * netPath, RunTimeOpts * rtOpts, PtpClock * ptpClock)
return FALSE;
+ if((netKqueueAdd(netPath->eventSock) < 0)
+ || (netKqueueAdd(netPath->generalSock) < 0))
+ return FALSE;
/* let's see if we have another interface left before we die */
if(!testInterface(rtOpts->ifaceName, rtOpts)) {
@@ -1127,7 +1172,8 @@ netInit(NetPath * netPath, RunTimeOpts * rtOpts, PtpClock * ptpClock)
pcap_get_selectable_fd(netPath->pcapEvent)) < 0) {
PERROR("failed to get pcap event fd");
return FALSE;
+ netKqueueAdd(netPath->pcapEventSock);
if ((netPath->pcapGeneral = pcap_open_live(rtOpts->ifaceName,
PACKET_SIZE, promisc,
PCAP_TIMEOUT,
@@ -1157,14 +1203,17 @@ netInit(NetPath * netPath, RunTimeOpts * rtOpts, PtpClock * ptpClock)
PERROR("failed to get pcap general fd");
return FALSE;
+ netKqueueAdd(netPath->pcapGeneralSock);
#endif
#ifdef PTPD_PCAP
if(rtOpts->transport == IEEE_802_3) {
/* TX timestamp is not generated for PCAP mode and Ethernet transport */
@@ -1409,18 +1458,52 @@ netInit(NetPath * netPath, RunTimeOpts * rtOpts, PtpClock * ptpClock)
rtOpts->managementAclDenyText, rtOpts->managementAclOrder);
return TRUE;
/*Check if data has been received*/
+#ifdef HAVE_KQUEUE
+#if defined PTPD_SNMP
+#error No KQUEUE support for SNMP
+#endif
int
-netSelect(TimeInternal * timeout, NetPath * netPath, fd_set *readfds)
+netWait(TimeInternal * timeout, NetPath * netPath, PtpNetWaitEvents *readfds)
+ int ret;
+ struct timespec ts, *ts_ptr;
+ if (timeout) {
+ if(isTimeInternalNegative(timeout)) {
+ ERROR("Negative timeout attempted for kevent()\n");
+ return -1;
+ ts.tv_sec = timeout->seconds;
+ ts.tv_nsec = timeout->nanoseconds;
+ ts_ptr = &ts;
+ } else {
+ ts_ptr = NULL;
+ ret = ptpKqueueWait(ts_ptr, readfds, PTPD_KQUEUE_EVENTS);
+ if (ret < 0) {
+ if (errno == EAGAIN || errno == EINTR)
+ ret = 0;
+ return ret;
+int
int ret, nfds;
struct timeval tv, *tv_ptr;
extern const RunTimeOpts rtOpts;
struct timeval snmp_timer_wait = { 0, 0}; // initialise to avoid unused warnings when SNMP disabled
@@ -1499,6 +1582,22 @@ if (rtOpts.snmpEnabled) {
return ret;
+#endif /* HAVE_KQUEUE */
+Boolean netCheckEvent(int fd, PtpNetWaitEvents * readfds)
+#ifdef HAVE_KQUEUE
+ size_t e;
+ for (e = 0; e < PTPD_KQUEUE_EVENTS; ++e) {
+ if (readfds[e].ident == fd && readfds[e].filter == EVFILT_READ)
+ return TRUE;
+ return FALSE;
+#else
+ return FD_ISSET(fd, readfds);
+#endif
* store received data from network to "buf" , get and store the
* SO_TIMESTAMP value in "time" for an event message
diff --git a/freebsd/contrib/ptpd/src/dep/ptpd_dep.h b/freebsd/contrib/ptpd/src/dep/ptpd_dep.h
index e0bcdf11..2db43f62 100644
--- a/freebsd/contrib/ptpd/src/dep/ptpd_dep.h
+++ b/freebsd/contrib/ptpd/src/dep/ptpd_dep.h
@@ -377,7 +377,8 @@ UInteger16 msgPackManagementResponse(Octet * buf,MsgHeader*,MsgManagement*,PtpCl
Boolean testInterface(char* ifaceName, const RunTimeOpts* rtOpts);
Boolean netInit(NetPath*,RunTimeOpts*,PtpClock*);
Boolean netShutdown(NetPath*);
-int netSelect(TimeInternal*,NetPath*,fd_set*);
+int netWait(TimeInternal*,NetPath*,PtpNetWaitEvents*);
+Boolean netCheckEvent(int,PtpNetWaitEvents*);
ssize_t netRecvEvent(Octet*,TimeInternal*,NetPath*,int);
ssize_t netRecvGeneral(Octet*,NetPath*);
ssize_t netSendEvent(Octet*,UInteger16,NetPath*,const RunTimeOpts*,Integer32,TimeInternal*);
@@ -389,6 +390,14 @@ Boolean hostLookup(const char* hostname, Integer32* addr);
+/** \name kqueue.c (Kqueue support) */
+int ptpKqueueGet(void);
+int ptpKqueueWait(struct timespec*, struct kevent*, int);
/** \name snmp.c (SNMP subsystem)
* -Handle SNMP subsystem*/
diff --git a/freebsd/contrib/ptpd/src/protocol.c b/freebsd/contrib/ptpd/src/protocol.c
index 1514add2..2ca49d8a 100644
--- a/freebsd/contrib/ptpd/src/protocol.c
+++ b/freebsd/contrib/ptpd/src/protocol.c
@@ -1450,11 +1450,17 @@ handle(RunTimeOpts *rtOpts, PtpClock *ptpClock)
ssize_t length = -1;
TimeInternal timeStamp = { 0, 0 };
- fd_set readfds;
+#ifdef HAVE_KQUEUE
+ PtpNetWaitEvents readfds[PTPD_KQUEUE_EVENTS] = { 0 };
+ PtpNetWaitEvents * readfds_ptr = &readfds[0];
+#else
+ PtpNetWaitEvents readfds;
+ PtpNetWaitEvents * readfds_ptr = &readfds;
FD_ZERO(&readfds);
+#endif
if (!ptpClock->message_activity) {
- ret = netSelect(NULL, &ptpClock->netPath, &readfds);
+ ret = netWait(NULL, &ptpClock->netPath, readfds_ptr);
if (ret < 0) {
PERROR("failed to poll sockets");
ptpClock->counters.messageRecvErrors++;
@@ -1471,7 +1477,8 @@ handle(RunTimeOpts *rtOpts, PtpClock *ptpClock)
#ifdef PTPD_PCAP
if (rtOpts->pcap == TRUE) {
- if (ptpClock->netPath.pcapEventSock >=0 && FD_ISSET(ptpClock->netPath.pcapEventSock, &readfds)) {
+ if (ptpClock->netPath.pcapEventSock >=0
+ && netCheckEvent(ptpClock->netPath.pcapEventSock, readfds_ptr)) {
length = netRecvEvent(ptpClock->msgIbuf, &timeStamp,
&ptpClock->netPath,0);
if (length == 0){ /* timeout, return for now */
@@ -1493,7 +1500,8 @@ handle(RunTimeOpts *rtOpts, PtpClock *ptpClock)
processMessage(rtOpts, ptpClock, &timeStamp, length);
- if (ptpClock->netPath.pcapGeneralSock >=0 && FD_ISSET(ptpClock->netPath.pcapGeneralSock, &readfds)) {
+ if (ptpClock->netPath.pcapGeneralSock >=0
+ && netCheckEvent(ptpClock->netPath.pcapGeneralSock, readfds_ptr)) {
length = netRecvGeneral(ptpClock->msgIbuf, &ptpClock->netPath);
if (length == 0) /* timeout, return for now */
return;
@@ -1507,7 +1515,7 @@ handle(RunTimeOpts *rtOpts, PtpClock *ptpClock)
} else {
#endif
- if (FD_ISSET(ptpClock->netPath.eventSock, &readfds)) {
+ if (netCheckEvent(ptpClock->netPath.eventSock, readfds_ptr)) {
&ptpClock->netPath, 0);
if (length < 0) {
@@ -1523,7 +1531,7 @@ handle(RunTimeOpts *rtOpts, PtpClock *ptpClock)
- if (FD_ISSET(ptpClock->netPath.generalSock, &readfds)) {
+ if (netCheckEvent(ptpClock->netPath.generalSock, readfds_ptr)) {
if (length < 0) {
PERROR("failed to receive on the general socket");
diff --git a/freebsd/contrib/ptpd/src/ptpd.h b/freebsd/contrib/ptpd/src/ptpd.h
index c5287cf5..08090317 100644
--- a/freebsd/contrib/ptpd/src/ptpd.h
+++ b/freebsd/contrib/ptpd/src/ptpd.h
@@ -83,6 +83,9 @@
#include <utmp.h>
#endif /* HAVE_UTMP_H */
#endif /* HAVE_UTMPX_H */
+#ifdef HAVE_KQUEUE
+#include <sys/event.h>
#ifdef HAVE_NET_ETHERNET_H
#include <net/ethernet.h>
2.25.1
