[PATCH 01/18] ptpd: Add files as contrib
Gabriel Moyano gabriel.moyano at dlr.de
Wed Apr 12 13:54:05 UTC 2023
 freebsd/contrib/ptpd/COPYRIGHT                |   49 +
 freebsd/contrib/ptpd/ChangeLog                |  429 ++
 freebsd/contrib/ptpd/INSTALL                  |  153 +
 freebsd/contrib/ptpd/Makefile.am              |   53 +
 freebsd/contrib/ptpd/Makefile.old             |   33 +
 freebsd/contrib/ptpd/README.md                |   43 +
 freebsd/contrib/ptpd/README.repocheckout      |   18 +
 freebsd/contrib/ptpd/TODO                     |   49 +
 freebsd/contrib/ptpd/configure.ac             |  777 +++
 .../ptpd/doc/IEEE1588v1_vs_IEEE1588v2.pdf     |  Bin 0 -> 272225 bytes
 freebsd/contrib/ptpd/doc/PTPBASE-MIB.txt      | 5710 +++++++++++++++++
 .../ptpd/doc/draft-ietf-tictoc-ptp-mib-01.txt | 3693 +++++++++++
 freebsd/contrib/ptpd/doc/index.html           |  125 +
 .../ptpd/doc/ptpd-2.3.0-migration-guide.html  |  243 +
 .../doc/ptpd_2005_1588_conference_paper.pdf   |  Bin 0 -> 323600 bytes
 freebsd/contrib/ptpd/m4/version.m4            |    4 +
 .../ptpd/packagebuild/rpm-rh/README.RH        |   44 +
 .../ptpd/packagebuild/rpm-rh/ptpd.conf        |   62 +
 .../ptpd/packagebuild/rpm-rh/ptpd.init        |  205 +
 .../ptpd/packagebuild/rpm-rh/ptpd.service     |   17 +
 .../ptpd/packagebuild/rpm-rh/ptpd.spec        |  241 +
 .../ptpd/packagebuild/rpm-rh/ptpd.sysconfig   |   10 +
 .../ptpd/packagebuild/rpm-rh/rpmbuild.sh      |  101 +
 freebsd/contrib/ptpd/src/Doxyfile             | 1511 +++++
 freebsd/contrib/ptpd/src/Makefile.am          |  102 +
 freebsd/contrib/ptpd/src/Makefile.old         |  109 +
 freebsd/contrib/ptpd/src/arith.c              |  373 ++
 freebsd/contrib/ptpd/src/bmc.c                |  779 +++
 freebsd/contrib/ptpd/src/constants.h          |  470 ++
 freebsd/contrib/ptpd/src/datatypes.h          |  715 +++
 freebsd/contrib/ptpd/src/def/README           |   11 +
 .../ptpd/src/def/derivedData/clockQuality.def |    8 +
 .../ptpd/src/def/derivedData/faultRecord.def  |   11 +
 .../src/def/derivedData/physicalAddress.def   |   13 +
 .../ptpd/src/def/derivedData/portAddress.def  |    8 +
 .../ptpd/src/def/derivedData/portIdentity.def |    7 +
 .../ptpd/src/def/derivedData/ptpText.def      |    7 +
 .../ptpd/src/def/derivedData/timeInterval.def |    6 +
 .../src/def/derivedData/timePropertiesDS.def  |   13 +
 .../ptpd/src/def/derivedData/timestamp.def    |    7 +
 .../contrib/ptpd/src/def/derivedData/tlv.def  |    8 +
 .../managementTLV/announceReceiptTimeout.def  |    7 +
 .../src/def/managementTLV/clockAccuracy.def   |    7 +
 .../def/managementTLV/clockDescription.def    |   35 +
 .../src/def/managementTLV/currentDataSet.def  |    8 +
 .../src/def/managementTLV/defaultDataSet.def  |   14 +
 .../src/def/managementTLV/delayMechanism.def  |    7 +
 .../ptpd/src/def/managementTLV/domain.def     |    7 +
 .../src/def/managementTLV/errorStatus.def     |    8 +
 .../ptpd/src/def/managementTLV/initialize.def |    6 +
 .../def/managementTLV/logAnnounceInterval.def |    7 +
 .../managementTLV/logMinPdelayReqInterval.def |    7 +
 .../src/def/managementTLV/logSyncInterval.def |    7 +
 .../src/def/managementTLV/managementTLV.def   |    8 +
 .../src/def/managementTLV/parentDataSet.def   |   14 +
 .../src/def/managementTLV/portDataSet.def     |   16 +
 .../ptpd/src/def/managementTLV/priority1.def  |    7 +
 .../ptpd/src/def/managementTLV/priority2.def  |    7 +
 .../ptpd/src/def/managementTLV/slaveOnly.def  |    7 +
 .../ptpd/src/def/managementTLV/time.def       |    6 +
 .../managementTLV/timePropertiesDataSet.def   |    8 +
 .../def/managementTLV/timescaleProperties.def |    7 +
 .../managementTLV/traceabilityProperties.def  |    7 +
 .../unicastNegotiationEnable.def              |    7 +
 .../src/def/managementTLV/userDescription.def |    8 +
 .../src/def/managementTLV/utcProperties.def   |    8 +
 .../src/def/managementTLV/versionNumber.def   |    8 +
 .../contrib/ptpd/src/def/message/header.def   |   20 +
 .../ptpd/src/def/message/management.def       |   12 +
 .../ptpd/src/def/message/signaling.def        |    6 +
 .../acknowledgeCancelUnicastTransmission.def  |    9 +
 .../cancelUnicastTransmission.def             |    9 +
 .../signalingTLV/grantUnicastTransmission.def |   12 +
 .../requestUnicastTransmission.def            |    9 +
 .../src/def/signalingTLV/signalingTLV.def     |    6 +
 freebsd/contrib/ptpd/src/dep/alarms.c         |  427 ++
 freebsd/contrib/ptpd/src/dep/alarms.h         |  100 +
 freebsd/contrib/ptpd/src/dep/configdefaults.c |  675 ++
 freebsd/contrib/ptpd/src/dep/configdefaults.h |   52 +
 freebsd/contrib/ptpd/src/dep/constants_dep.h  |  251 +
 freebsd/contrib/ptpd/src/dep/daemonconfig.c   | 3192 +++++++++
 freebsd/contrib/ptpd/src/dep/daemonconfig.h   |   89 +
 freebsd/contrib/ptpd/src/dep/datatypes_dep.h  |  179 +
 freebsd/contrib/ptpd/src/dep/eventtimer.c     |  133 +
 freebsd/contrib/ptpd/src/dep/eventtimer.h     |   77 +
 .../contrib/ptpd/src/dep/eventtimer_itimer.c  |  239 +
 .../contrib/ptpd/src/dep/eventtimer_posix.c   |  239 +
 .../contrib/ptpd/src/dep/iniparser/AUTHORS    |    7 +
 .../contrib/ptpd/src/dep/iniparser/LICENSE    |   21 +
 freebsd/contrib/ptpd/src/dep/iniparser/README |   12 +
 .../ptpd/src/dep/iniparser/dictionary.c       |  520 ++
 .../ptpd/src/dep/iniparser/dictionary.h       |  189 +
 .../ptpd/src/dep/iniparser/iniparser.c        |  771 +++
 .../ptpd/src/dep/iniparser/iniparser.h        |  311 +
 freebsd/contrib/ptpd/src/dep/ipv4_acl.c       |  486 ++
 freebsd/contrib/ptpd/src/dep/ipv4_acl.h       |   52 +
 freebsd/contrib/ptpd/src/dep/msg.c            | 2757 ++++++++
 freebsd/contrib/ptpd/src/dep/net.c            | 2300 +++++++
 .../ptpd/src/dep/ntpengine/ntp_isc_md5.c      |  273 +
 .../ptpd/src/dep/ntpengine/ntp_isc_md5.h      |   99 +
 .../ptpd/src/dep/ntpengine/ntpdcontrol.c      |  874 +++
 .../ptpd/src/dep/ntpengine/ntpdcontrol.h      |  362 ++
 freebsd/contrib/ptpd/src/dep/outlierfilter.c  |  369 ++
 freebsd/contrib/ptpd/src/dep/outlierfilter.h  |  125 +
 freebsd/contrib/ptpd/src/dep/ptpd_dep.h       |  516 ++
 freebsd/contrib/ptpd/src/dep/servo.c          | 1262 ++++
 freebsd/contrib/ptpd/src/dep/snmp.c           | 2186 +++++++
 freebsd/contrib/ptpd/src/dep/startup.c        | 1020 +++
 freebsd/contrib/ptpd/src/dep/statistics.c     | 1047 +++
 freebsd/contrib/ptpd/src/dep/statistics.h     |  230 +
 freebsd/contrib/ptpd/src/dep/sys.c            | 2661 ++++++++
 freebsd/contrib/ptpd/src/display.c            | 1152 ++++
 freebsd/contrib/ptpd/src/leap-seconds.list    |  250 +
 freebsd/contrib/ptpd/src/management.c         | 1896 ++++++
 freebsd/contrib/ptpd/src/protocol.c           | 3534 ++++++++++
 freebsd/contrib/ptpd/src/ptp_datatypes.h      |  592 ++
 freebsd/contrib/ptpd/src/ptp_primitives.h     |   41 +
 freebsd/contrib/ptpd/src/ptp_timers.c         |  160 +
 freebsd/contrib/ptpd/src/ptp_timers.h         |   95 +
 freebsd/contrib/ptpd/src/ptpd.c               |  139 +
 freebsd/contrib/ptpd/src/ptpd.h               |  494 ++
 freebsd/contrib/ptpd/src/ptpd2.8.in           |  397 ++
 freebsd/contrib/ptpd/src/ptpd2.conf.5.in      | 3100 +++++++++
 .../contrib/ptpd/src/ptpd2.conf.default-full  |  841 +++
 freebsd/contrib/ptpd/src/ptpd2.conf.minimal   |   38 +
 freebsd/contrib/ptpd/src/signaling.c          | 1376 ++++
 freebsd/contrib/ptpd/src/templates.conf       |   22 +
 freebsd/contrib/ptpd/src/timingdomain.c       |  969 +++
 freebsd/contrib/ptpd/src/timingdomain.h       |  131 +
 .../contrib/ptpd/test/client-e2e-8023.conf    |  447 ++
 .../contrib/ptpd/test/client-e2e-pcap.conf    |  447 ++
 .../contrib/ptpd/test/client-e2e-socket.conf  |  447 ++
 freebsd/contrib/ptpd/test/testing.org         |   22 +
 freebsd/contrib/ptpd/tools/README.md          |   80 +
 freebsd/contrib/ptpd/tools/cleanup.sed        |   11 +
 freebsd/contrib/ptpd/tools/cleanup_sf2.sed    |    9 +
 freebsd/contrib/ptpd/tools/compare.R          |   62 +
 freebsd/contrib/ptpd/tools/filter_response.m  |   29 +
 freebsd/contrib/ptpd/tools/graph.R            |   52 +
 freebsd/contrib/ptpd/tools/ntplib/DESCRIPTION |   13 +
 freebsd/contrib/ptpd/tools/ntplib/NAMESPACE   |    7 +
 freebsd/contrib/ptpd/tools/ntplib/R/ntplib.R  |  184 +
 .../contrib/ptpd/tools/ntplib/man/ntpGraph.Rd |   19 +
 .../ptpd/tools/ntplib/man/ntpHistogram.Rd     |   21 +
 .../ptpd/tools/ntplib/man/ntpLoopRead.Rd      |   20 +
 .../ptpd/tools/ntplib/man/ntpLoopStats.Rd     |   17 +
 .../ptpd/tools/ntplib/man/ntpPeerRead.Rd      |   18 +
 freebsd/contrib/ptpd/tools/ntpoffset.R        |   53 +
 freebsd/contrib/ptpd/tools/offset.R           |   53 +
 freebsd/contrib/ptpd/tools/offset_stats.m     |  102 +
 freebsd/contrib/ptpd/tools/ptplib/DESCRIPTION |   13 +
 freebsd/contrib/ptpd/tools/ptplib/NAMESPACE   |   12 +
 freebsd/contrib/ptpd/tools/ptplib/R/ptplib.R  |  397 ++
 .../ptpd/tools/ptplib/man/ptpCompare.Rd       |   22 +
 .../contrib/ptpd/tools/ptplib/man/ptpGraph.Rd |   19 +
 .../ptpd/tools/ptplib/man/ptpHistogram.Rd     |   16 +
 .../tools/ptplib/man/ptpHistogramCompare.Rd   |   12 +
 .../ptpd/tools/ptplib/man/ptpLogRead.Rd       |   20 +
 .../ptpd/tools/ptplib/man/ptpOffsetStats.Rd   |   21 +
 .../ptpd/tools/ptplib/man/ptpQualityGraph.Rd  |   22 +
 .../ptplib/man/ptpQualityGraphCompare.Rd      |   22 +
 .../ptpd/tools/ptplib/man/ptpQualityRead.Rd   |   18 +
 .../ptpd/tools/ptplib/man/ptpQualityStats.Rd  |   15 +
 .../contrib/ptpd/tools/ptplib/man/ptpStats.Rd |   22 +
 freebsd/contrib/ptpd/tools/snmptpq            |  303 +
 freebsd/contrib/ptpd/tools/stats.R            |   48 +
 166 files changed, 58963 insertions(+)
 create mode 100644 freebsd/contrib/ptpd/COPYRIGHT
 create mode 100644 freebsd/contrib/ptpd/ChangeLog
 create mode 100644 freebsd/contrib/ptpd/INSTALL
 create mode 100644 freebsd/contrib/ptpd/Makefile.am
 create mode 100644 freebsd/contrib/ptpd/Makefile.old
 create mode 100644 freebsd/contrib/ptpd/README.md
 create mode 100644 freebsd/contrib/ptpd/README.repocheckout
 create mode 100644 freebsd/contrib/ptpd/TODO
 create mode 100644 freebsd/contrib/ptpd/configure.ac
 create mode 100644 freebsd/contrib/ptpd/doc/IEEE1588v1_vs_IEEE1588v2.pdf
 create mode 100644 freebsd/contrib/ptpd/doc/PTPBASE-MIB.txt
 create mode 100644 freebsd/contrib/ptpd/doc/draft-ietf-tictoc-ptp-mib-01.txt
 create mode 100644 freebsd/contrib/ptpd/doc/index.html
 create mode 100644 freebsd/contrib/ptpd/doc/ptpd-2.3.0-migration-guide.html
 create mode 100644 freebsd/contrib/ptpd/doc/ptpd_2005_1588_conference_paper.pdf
 create mode 100644 freebsd/contrib/ptpd/m4/version.m4
 create mode 100644 freebsd/contrib/ptpd/packagebuild/rpm-rh/README.RH
 create mode 100644 freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.conf
 create mode 100644 freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.init
 create mode 100644 freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.service
 create mode 100644 freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.spec
 create mode 100644 freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.sysconfig
 create mode 100755 freebsd/contrib/ptpd/packagebuild/rpm-rh/rpmbuild.sh
 create mode 100644 freebsd/contrib/ptpd/src/Doxyfile
 create mode 100644 freebsd/contrib/ptpd/src/Makefile.am
 create mode 100644 freebsd/contrib/ptpd/src/Makefile.old
 create mode 100644 freebsd/contrib/ptpd/src/arith.c
 create mode 100644 freebsd/contrib/ptpd/src/bmc.c
 create mode 100644 freebsd/contrib/ptpd/src/constants.h
 create mode 100644 freebsd/contrib/ptpd/src/datatypes.h
 create mode 100644 freebsd/contrib/ptpd/src/def/README
 create mode 100644 freebsd/contrib/ptpd/src/def/derivedData/clockQuality.def
 create mode 100644 freebsd/contrib/ptpd/src/def/derivedData/faultRecord.def
 create mode 100644 freebsd/contrib/ptpd/src/def/derivedData/physicalAddress.def
 create mode 100644 freebsd/contrib/ptpd/src/def/derivedData/portAddress.def
 create mode 100644 freebsd/contrib/ptpd/src/def/derivedData/portIdentity.def
 create mode 100644 freebsd/contrib/ptpd/src/def/derivedData/ptpText.def
 create mode 100644 freebsd/contrib/ptpd/src/def/derivedData/timeInterval.def
 create mode 100644 freebsd/contrib/ptpd/src/def/derivedData/timePropertiesDS.def
 create mode 100644 freebsd/contrib/ptpd/src/def/derivedData/timestamp.def
 create mode 100644 freebsd/contrib/ptpd/src/def/derivedData/tlv.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/announceReceiptTimeout.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/clockAccuracy.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/clockDescription.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/currentDataSet.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/defaultDataSet.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/delayMechanism.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/domain.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/errorStatus.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/initialize.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/logAnnounceInterval.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/logMinPdelayReqInterval.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/logSyncInterval.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/managementTLV.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/parentDataSet.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/portDataSet.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/priority1.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/priority2.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/slaveOnly.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/time.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/timePropertiesDataSet.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/timescaleProperties.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/traceabilityProperties.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/unicastNegotiationEnable.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/userDescription.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/utcProperties.def
 create mode 100644 freebsd/contrib/ptpd/src/def/managementTLV/versionNumber.def
 create mode 100644 freebsd/contrib/ptpd/src/def/message/header.def
 create mode 100644 freebsd/contrib/ptpd/src/def/message/management.def
 create mode 100644 freebsd/contrib/ptpd/src/def/message/signaling.def
 create mode 100644 freebsd/contrib/ptpd/src/def/signalingTLV/acknowledgeCancelUnicastTransmission.def
 create mode 100644 freebsd/contrib/ptpd/src/def/signalingTLV/cancelUnicastTransmission.def
 create mode 100644 freebsd/contrib/ptpd/src/def/signalingTLV/grantUnicastTransmission.def
 create mode 100644 freebsd/contrib/ptpd/src/def/signalingTLV/requestUnicastTransmission.def
 create mode 100644 freebsd/contrib/ptpd/src/def/signalingTLV/signalingTLV.def
 create mode 100644 freebsd/contrib/ptpd/src/dep/alarms.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/alarms.h
 create mode 100644 freebsd/contrib/ptpd/src/dep/configdefaults.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/configdefaults.h
 create mode 100644 freebsd/contrib/ptpd/src/dep/constants_dep.h
 create mode 100644 freebsd/contrib/ptpd/src/dep/daemonconfig.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/daemonconfig.h
 create mode 100644 freebsd/contrib/ptpd/src/dep/datatypes_dep.h
 create mode 100644 freebsd/contrib/ptpd/src/dep/eventtimer.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/eventtimer.h
 create mode 100644 freebsd/contrib/ptpd/src/dep/eventtimer_itimer.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/eventtimer_posix.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/iniparser/AUTHORS
 create mode 100644 freebsd/contrib/ptpd/src/dep/iniparser/LICENSE
 create mode 100644 freebsd/contrib/ptpd/src/dep/iniparser/README
 create mode 100644 freebsd/contrib/ptpd/src/dep/iniparser/dictionary.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/iniparser/dictionary.h
 create mode 100644 freebsd/contrib/ptpd/src/dep/iniparser/iniparser.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/iniparser/iniparser.h
 create mode 100644 freebsd/contrib/ptpd/src/dep/ipv4_acl.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/ipv4_acl.h
 create mode 100644 freebsd/contrib/ptpd/src/dep/msg.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/net.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/ntpengine/ntp_isc_md5.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/ntpengine/ntp_isc_md5.h
 create mode 100644 freebsd/contrib/ptpd/src/dep/ntpengine/ntpdcontrol.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/ntpengine/ntpdcontrol.h
 create mode 100644 freebsd/contrib/ptpd/src/dep/outlierfilter.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/outlierfilter.h
 create mode 100644 freebsd/contrib/ptpd/src/dep/ptpd_dep.h
 create mode 100644 freebsd/contrib/ptpd/src/dep/servo.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/snmp.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/startup.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/statistics.c
 create mode 100644 freebsd/contrib/ptpd/src/dep/statistics.h
 create mode 100644 freebsd/contrib/ptpd/src/dep/sys.c
 create mode 100644 freebsd/contrib/ptpd/src/display.c
 create mode 100644 freebsd/contrib/ptpd/src/leap-seconds.list
 create mode 100644 freebsd/contrib/ptpd/src/management.c
 create mode 100644 freebsd/contrib/ptpd/src/protocol.c
 create mode 100644 freebsd/contrib/ptpd/src/ptp_datatypes.h
 create mode 100644 freebsd/contrib/ptpd/src/ptp_primitives.h
 create mode 100644 freebsd/contrib/ptpd/src/ptp_timers.c
 create mode 100644 freebsd/contrib/ptpd/src/ptp_timers.h
 create mode 100644 freebsd/contrib/ptpd/src/ptpd.c
 create mode 100644 freebsd/contrib/ptpd/src/ptpd.h
 create mode 100644 freebsd/contrib/ptpd/src/ptpd2.8.in
 create mode 100644 freebsd/contrib/ptpd/src/ptpd2.conf.5.in
 create mode 100644 freebsd/contrib/ptpd/src/ptpd2.conf.default-full
 create mode 100644 freebsd/contrib/ptpd/src/ptpd2.conf.minimal
 create mode 100644 freebsd/contrib/ptpd/src/signaling.c
 create mode 100644 freebsd/contrib/ptpd/src/templates.conf
 create mode 100644 freebsd/contrib/ptpd/src/timingdomain.c
 create mode 100644 freebsd/contrib/ptpd/src/timingdomain.h
 create mode 100644 freebsd/contrib/ptpd/test/client-e2e-8023.conf
 create mode 100644 freebsd/contrib/ptpd/test/client-e2e-pcap.conf
 create mode 100644 freebsd/contrib/ptpd/test/client-e2e-socket.conf
 create mode 100644 freebsd/contrib/ptpd/test/testing.org
 create mode 100644 freebsd/contrib/ptpd/tools/README.md
 create mode 100644 freebsd/contrib/ptpd/tools/cleanup.sed
 create mode 100644 freebsd/contrib/ptpd/tools/cleanup_sf2.sed
 create mode 100755 freebsd/contrib/ptpd/tools/compare.R
 create mode 100755 freebsd/contrib/ptpd/tools/filter_response.m
 create mode 100755 freebsd/contrib/ptpd/tools/graph.R
 create mode 100644 freebsd/contrib/ptpd/tools/ntplib/DESCRIPTION
 create mode 100644 freebsd/contrib/ptpd/tools/ntplib/NAMESPACE
 create mode 100644 freebsd/contrib/ptpd/tools/ntplib/R/ntplib.R
 create mode 100644 freebsd/contrib/ptpd/tools/ntplib/man/ntpGraph.Rd
 create mode 100644 freebsd/contrib/ptpd/tools/ntplib/man/ntpHistogram.Rd
 create mode 100644 freebsd/contrib/ptpd/tools/ntplib/man/ntpLoopRead.Rd
 create mode 100644 freebsd/contrib/ptpd/tools/ntplib/man/ntpLoopStats.Rd
 create mode 100644 freebsd/contrib/ptpd/tools/ntplib/man/ntpPeerRead.Rd
 create mode 100755 freebsd/contrib/ptpd/tools/ntpoffset.R
 create mode 100755 freebsd/contrib/ptpd/tools/offset.R
 create mode 100755 freebsd/contrib/ptpd/tools/offset_stats.m
 create mode 100644 freebsd/contrib/ptpd/tools/ptplib/DESCRIPTION
 create mode 100644 freebsd/contrib/ptpd/tools/ptplib/NAMESPACE
 create mode 100644 freebsd/contrib/ptpd/tools/ptplib/R/ptplib.R
 create mode 100644 freebsd/contrib/ptpd/tools/ptplib/man/ptpCompare.Rd
 create mode 100644 freebsd/contrib/ptpd/tools/ptplib/man/ptpGraph.Rd
 create mode 100644 freebsd/contrib/ptpd/tools/ptplib/man/ptpHistogram.Rd
 create mode 100644 freebsd/contrib/ptpd/tools/ptplib/man/ptpHistogramCompare.Rd
 create mode 100644 freebsd/contrib/ptpd/tools/ptplib/man/ptpLogRead.Rd
 create mode 100644 freebsd/contrib/ptpd/tools/ptplib/man/ptpOffsetStats.Rd
 create mode 100644 freebsd/contrib/ptpd/tools/ptplib/man/ptpQualityGraph.Rd
 create mode 100644 freebsd/contrib/ptpd/tools/ptplib/man/ptpQualityGraphCompare.Rd
 create mode 100644 freebsd/contrib/ptpd/tools/ptplib/man/ptpQualityRead.Rd
 create mode 100644 freebsd/contrib/ptpd/tools/ptplib/man/ptpQualityStats.Rd
 create mode 100644 freebsd/contrib/ptpd/tools/ptplib/man/ptpStats.Rd
 create mode 100755 freebsd/contrib/ptpd/tools/snmptpq
 create mode 100755 freebsd/contrib/ptpd/tools/stats.R
diff --git a/freebsd/contrib/ptpd/COPYRIGHT b/freebsd/contrib/ptpd/COPYRIGHT
new file mode 100644
index 00000000..86a257d1
--- /dev/null
+++ b/freebsd/contrib/ptpd/COPYRIGHT
@@ -0,0 +1,49 @@
+ * Copyright (c) 2015      Wojciech Owczarek.
+ * Copyright (c) 2014      Perseus Telecom.
+ * Copyright (c) 2013-2014 Harlan Stenn,
+ *                         George N. Neville-Neil,
+ *                         Wojciech Owczarek,
+ *                         Jan Breuer.
+ * Copyright (c) 2011-2012 George V. Neville-Neil,
+ *                         Steven Kreuzer,
+ *                         Martin Burnicki,
+ *                         Jan Breuer,
+ *                         Gael Mace,
+ *                         Alexandre Van Kempen,
+ *                         Inaqui Delgado,
+ *                         Rick Ratzel,
+ *                         National Instruments.
+ * Copyright (c) 2009-2010 George V. Neville-Neil,
+ *                         Steven Kreuzer,
+ *                         Jan Breuer,
+ *                         Gael Mace,
+ *                         Alexandre Van Kempen.
+ * Copyright (c) 2005-2008 Kendall Correll, Aidan Williams
+ * All Rights Reserved
+ * modification, are permitted provided that the following conditions are
+ * met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ *    this list of conditions and the following disclaimer.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE AUTHORS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
+ * BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
+ * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
+ * IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
diff --git a/freebsd/contrib/ptpd/ChangeLog b/freebsd/contrib/ptpd/ChangeLog
index 00000000..775bd399
--- /dev/null
+++ b/freebsd/contrib/ptpd/ChangeLog
@@ -0,0 +1,429 @@
+2013-10-23  Wojciech Owczarek <wojciech at owczarek.co.uk>
+	* 2.3.2 release
+	* Bug fixes / improvements since 2.3.1:
+	- systemd service file added and RPM spec updated
+	  to handle systemd
+	- fixed segfault when shutting down NTP time service
+	- ptpengine:always_respect_utc_offset is now enabled
+	  by default, to protect from clock jumps when GM
+	  stops announcing currentUtcOffsetValid flag
+	- re-arranged order of InterfaceInfo fields to
+	  fix memory alignment issues (SF bug #70)
+	- corrected logMessageInterval field values
+	  for hybrid mode (SF bug #69)
+	- fixed NTPd check failures resulting from signals
+	  interrupting select()
+	- increased statistics file line buffer size to prevent
+	  truncation and merging of lines
+	- added Sequence ID to statistics log
+	- Solaris build fixes - linking lnsl and lsocket when
+	  building without SNMP support
+	- critical: added minimum POSIX timer interval to prevent from
+	  timers firing to quickly for the process to handle,
+	  resulting in 100% CPU and endless signal queue
+	- improved processing of unicast destination, domain
+	  and local preference lists
+	- CPU affinity setting moved to a separate function
+	- fixed incorrect PTP_UNICAST flag setting for multicast
+	- fixed missing management or signalling message acceptance
+	  condition (clockid==clockid, portid=0xffff): ISPCS 2015 plugfest,
+	  fourth missing: (clockid=0x(f), portid==portid)
+	- signaling.c: fixed order of grant processing for PTP messages
+	  (ann,syn,fup,dresp,pdelayresp) instead of numeric loop,
+	  to assist with interop where transmission request order
+	  makes a difference to the master
+	- signaling.c: do not reset known clock ID when changing GMs,
+	  to allow to keep accepting announce from other masters
+	- signaling.c: update unicast index when transport address
+	  match only: fix for cache misses for non-best masters
+	- daemonconfig:c - reworked all config mapping macros
+	  to functions, parseConfig now handless all operations:
+	  parsing, quiet parsing, reload check, help - no hidden
+	  values in dictionary anymore
+	- closed sf bug #64 - leaving mcast group with 0x0 address
+	- peer multicast group only joined when needed, not always
+	- logMessage now keeps hash of the last message body,
+	  preventing from same message being repeated
+	- null checks getInterfaceInfo set of helper functions
+	  in case if some data returned by getifaddrs() is null:
+	  fixes segfaults on some exotic interface types
+	- signaling.c: use message type <-> smaller index number
+	  conversion so grant table is 5-element, not 16-element:
+	  significantly reduced memory footprint
+	- added dummy Makefile to src/dep to allow make commands
+	  from that directory
+	- added buffer overflow protection for management
+	  TLVs: protects against read past message length,
+	  and against read past buffer space
+	* New features since 2.3.1:
+	- support for user variables in configuration:
+	    - variables specified variables:name=val, and
+	      used as @name@
+	    - built-in variables: @pid@, @hostname@
+	- support for configuration templates:
+	    - built-in
+	    - template files
+	- unicast port number mask to assist with nodes
+	  using different port IDs for negotiation
+	- option to accept any GM when unicast negotiation
+	  is enabled
+	- UDP checksums disabled on Linux by default:
+	  enables interop with TCs that don't correct checksums
+	- Added QNX support:
+	    - clean build on QNX 6.5 out of the box
+	    - adjfreq emulation using native ClockAdjust
+	    - binding to CPU cores
+	    - Experimental (but yield best results):
+		* interpolated getTime attached to IRQ0
+		* RX/TX timestamps in software on send or receive,
+		  bypassing pcap or socket timestamping
+	- support for systems without getopt_long (like QNX)
+	- adjfreq-like behaviour on systems with adjtime only:
+	  properly scaled adjtime() pulled into PI servo
+	  (vastly improved sync on systems like OpenBSD and OSX),
+	  support for drift file for those systems
+	- fixed preserving incorrect master address when
+	  best master lowers priority (GM change as a result
+	  of announce from current master, not foreign)
+	- PTP MIB enhanced with string values, counter support,
+	  clearing counters and more, added some missing items
+	  from previously supported items
+	- SNMP trap support for common alarm conditions
+	- enhanced management message support: enable/disable port,
+	  some missing values, PTPd now properly applies
+	  configuration when receiving SET messages
+	- added simple SNMP poller script: snmptpq
+	- SNMP MIB now using PTPd's own Enterprise number
+2013-06-10  Wojciech Owczarek <wojciech at owczarek.co.uk>
+	* 2.3.1 release
+	* New features since 2.3.0:
+	- full unicast support both in master and in slave mode:
+	  + support for multiple unicast destinations for masters
+	  + feature-complete Telecom Profile support:
+	     * unicast negotiation for masters and slaves
+	     * disabling BMCA for masters (also works for multicast)
+	     * support for slaves with masters in multiple domains
+	     * influencing slave BMCA with local preference
+	     * serving multiple Telecom slaves at different rates
+	     * slaves correctly negotiate message rates over supported
+	       range of intervals until an acceptable interval is granted
+	  + support for unicast Peer Delay target - exotic use case
+	- greatly improved network robustness
+	- added support for slave-only builds (configure --slave-only):
+	  allows building a binary incapable of running as master
+	- simple failover mechanism - ptpengine:backup_interface
+	- ptpengine:max_delay_max_rejected setting to unblock ptpd
+	  rejecting all messages when max_delay set
+	- ptpengine:max_delay_stable to only use max_dely when clock
+	  is stable
+	- selectable log timestamp format (unix or datetime)
+	- ptpd now compiles and runs out of he box on NetBSD, OpenBSD, FreeBSD,
+	  OSX and Solaris and its derivatives (OpenIndiana, OmniOS etc.)
+	- major rework of the ACL code
+	- outlier filter auto-tune to improve operation in noisy environments(high PDV)
+	- added support for statistical filters (min/mean/median) for sync
+	  and delay messages - min or median can be used in envifonments with high PDV
+	- added small step detection (millisecond level)
+	- added ptpengine:clock_update_timeout setting to reset slave
+	  if no clock updates for a period of time
+	- when running slave-only in unicast mode, unicast address
+	  does not have to be specified - ptpd will wait for a GM and latch onto it
+	- automatic Delay Request override for Hybrid and Unicast modes
+	- added options allowing to step the clock on startup
+	- improved sequence and re-ordering checks
+	- added support for "any domain" operation where ptpd will sync with
+	  any available domain
+	- idle timeout (PTPd hands over clock control)
+	- clock update timeout (PTPd restarts slave on timeout)
+	- maximum state machine reset count - full network restart when exceeded:
+	  allows ptpd to survive situations where network interface is removed,
+	  shut down or IP address changes
+	- support for NIST/IETF leap seconds file both for master and slave
+	- configurable leap second handling: accept, ignore, step
+	- support for leap second smear for slave operation
+	- option to step clock on startup
+	- TimingDomain API: all NTP failover code removed
+	  in favour of a generic interface for multiple time controllers.
+	- configurable port number - useful when running multiple instances
+	- periodic log file updates with slave or master information - separate
+	  from statistics file: allows sending statistics into syslog
+	- support for software transmit timestamping on Linux
+	- lookup tables used for matching Sync and FollowUp when
+	  no transport information available
+	- added periodic status updates to log file (global:periodic_updates)
+	- status file will always display counters for common error events
+	  if they are non-zero (includes denied unicast grants and ignored
+	  Announce resulting from rejected UTC properties)
+	- reporting on message receive and transmit rates
+	  in the status file
+	- restored compatibility with 802.1AS
+	* Bug fixes / improvements since 2.3.0:
+	- added CentOS / RHEL 7.x support
+	- statistics code enabled by default - can be disabled
+	- NTPd failover code enabled by default - can be disabled
+	- Improved status file - more error conditions included,
+	  message performance statistics included
+	- Rewritten timer subsystem allowing for easily implementing
+	  other implementations: included is the old interval timer implementation,
+	  and new (now default), POSIX timer implementation. This allows for
+	  fully standards-compliant message rates. This can be disabled with
+	  a configure flag
+	- ptpd now usable on systems with no adjtimex() call like OSX,
+	  OpenBSD and LynxOS ()
+	- moving standard deviation algorithm fix improving the outlier
+	  filters
+	- major servo.c spaghetti code cleanups
+	- network code cleanup
+	- fixed bug #66 - Ethernet interfaces no longer need IP addresses
+	  to run PTP Ethernet transport
+	- fixed bug / feature request #21: timestamping initialisation on
+	  PHC kernels
+	- fixed bug where ptpd would cause 100% CPU usage because of a
+	  late TX timestamp
+	- fixed bug / feature request #22: prevent FMR from overwriting
+	   best master
+	- improved servo stability detection: servo no longer reporting
+	  stable when discarding most samples or heavily slewing
+	- ptpd will now join and leave multicast groups only when running
+	  multicast or hybrid: allows running unicast and multicast
+	  independently
+	- ptpd will now ignore unicast packets in multicast-only mode
+	  and vice versa. In hybrid mode, only unicast Delay Request /
+	  response is accepted; multicast management messages are always
+	  accepted
+	- further autoconf improvements across all supported OSes
+	- added missing files to distribution
+	- ptpd will now recover even from critical network failures,
+	  such as reloading drivers
+	- remaining memory leaks fixed
+	- more code cleanup, no more ajtimex() and similar calls in protocol.c
+	- some refactoring, constified rtOpts wherever possible
+	- less "dramatic" warnings about drift file
+	  and clock stability detection
+	- fixed unnecessary TX timestamp attempts in PCAP mode
+	- fixed issue where drift file would not be correctly
+	  written on exit under certain conditions
+	- other minor bugs fixed
+2013-11-22  George Neville-Neil  <gnn at neville-neil.com>, Wojciech Owczarek <wojciech at owczarek.co.uk>
+	* 2.3.0 release
+	* New Features:
+	- IEEE 802.3 Support
+	- Support for reading from the Berkeley Packet Filter, resulting in lower jitter
+	- Configuration file support, multiple previously unsupported options
+	- Rewritten command line parameter handling, new parameters
+	- Command line options to print default configuration, print lock file,	check configuration and more,
+	- Full help (-H) for all configuration options,
+	- Configuration reload support with SIGHUP,
+	- Rewritten logging subsystem,
+	- Separate log file and statistics file, SIGHUP reprints the headers
+  	- Support for mode and interface specific lock files
+	- Network interface checks before startup and during config reload
+	- Added ./configure --sigusr2=counters - will dump PTP engine countersto current log target when SIGUSR2 received
+	- Support for presets - groups of PTP protocol options defining	ptpd behaviour
+		presets available: slaveonly, masteronly, masterslave
+	- Support for tick adjustment as well as frequency
+		maximum frequency offset is now configurable and can be above 512 ppm - tick is used above 512 ppm,
+	- Added a compatibility option to always honour the UTC offset announced by a GM when in slave state
+	- Added an announce receipt timeout "grace period" for slave state
+	  	slave can wait n times timeout without fully resetting
+	  	allows a seamless failover without resetting delay values etc.,
+	- Added support for DELAY_DISABLED delay mode - syntonisation only
+	- Initial support for informing the clock subsystem about the sync status
+		STA_UNSYNC is unset when adjusting the clock (allows syncing hardware RTC clocks with the system clock)
+		also maxerror and esterror are set,
+	- Support for RTC clock control on Linux
+	- Support for legacy command line switches from previous versions
+	- Configurable log level for normal logs, not only debug logs.
+	- Generic log file handler mechanism with a simple built-in logrotate implementation
+		for each log file container you can specify max size and max number of files
+	- Extensive support for realtime statistics
+	  	online long term statistics and moving statistics
+	  	mean and std dev.
+	  		Some new features included depend on statistics support, enabled with the --enable-statistics
+	  		configure switch. Statistics rely on double precision so may be disabled for simple embedded systems
+	- Outlier filters based on Peirce's criterion
+	  blocks / filters spikes from delayMS and delaySM
+	- Generic PI controler model
+	- P and I components changed from attenuations to gains
+	- Double precision servo allows for tighter clock control
+	- Clock stabilisation detection based on the standard dev of observed drift
+	- Clock "calibration delay"
+		allows a configurable delay between seeing a GM for the first time and enabling clock control
+	- Realtime statistics - mean and std dev of one-way delay, ofm and observed drift
+	- Status file: one-screen dump of information about the current state of ptpd, updated in configurable intervals.
+	- Support for "panic mode"
+		if ptpd sees offset from master above 1 second, it will pause clock updates for a given amount of time
+	- NTPd integration and failover
+		ptpd can now connect to local ntpd using mode 7 packets (code derived from ntpdc)
+	  	and using authenticated requests can enable/disable ntpd clock control.
+	  		Enable with configure --enable-ntpdc
+	- Dump counters + clear counters using a SIGUSR2 handler to dump all counters to the log file
+	  	configure --enable-sigusr2=counters
+	- Support for ACLs for management and timing messages
+	- Basic support for SO_TIMESTAMPING (RX, TX) on Linux
+	- Support for non-Ethernet interfaces on Linux (Infiniband, GRE etc.)
+	- Support for offset / delay asymmetry correction
+	- Ptpd can now prefer or require GMs with valid UTC time
+	- Support for setting IP DSCP values
+	- Periodic IGMP joins also in master mode - improved robustness against network port failures
+	- Support for binding PTPd to a CPU core
+	- Control over tick rate on Linux, allowing faster clock slewing if needed
+	* Bug fixes:
+	- TTL no longer defaults to 64 in P2P mode - in P2P it's set to 1,
+	- Fixed an issue whereby observed drift would be reset to 0 if it
+	  could not be read from the drift file (empty or nonexistent drift file),
+	  now the kernel value is used if read from file fails.
+	 - Support for updating utmp/wtmp when stepping the clock (FR #38)
+	 - Mean Path Delay filtering now done in float (patch #49)
+	 - Multiple other SourceForge bugs closed: Bugs closed:
+		    #25, #34, #26, #42, #39, #33, #46, #45, #28,
+		    #27, #48, #54, #47, #40, #37, #53, #50, #52, #59, #60
+	* Cleanups and other changes:
+	- Major startup.c cleanup, removed the parallel daemon checks,
+	  in favour of better lock handling and the automatic lock file
+	  name support,
+	- Some minor refactoring,
+	- Added a TimePropertiesDS structure and removed its fields
+	  from PtpClock
+	- Improved log file format with full date and interface name,
+	  removed the "===" indents
+	- Delay Request interval no longer mandatory in hybrid mode,
+	  but a warning will be issued if it's not explicitly defined -
+	  default of 0 is used,
+	- Removed the experimental status of hybrid mode,
+	- Manual stepping of the clock no longer just resets the observed
+	  drift: resets it or restores it based on the drift handling setting,
+	  and sets the time immediately before writing any logs - this allows
+	  to re-sync and stabilise time almost instantly
+	- Up to date man pages written
+2012-06-20  George Neville-Neil  <gnn at neville-neil.com>
+	* 2.2.2 release
+	* Leap second fix
+2012-01-05  George Neville-Neil  <gnn at neville-neil.com>
+	* 2.2.0 release
+	* Patches: 3134556, 3296405
+	* Added support for Mac OS X (tested on Snow Leopard and Lion)
+	* Protocol implementation Fixes:
+	* Bugs Fixed
+	- Client now correctly accepts the Master DelayReq rate
+	- DelayMS and delaySM now correctly show the sign when negative
+	- Sanity Flags: client now requires -g or -G for slave/master operation.
+	- Client can print the MAC address of its master (instead of EEUI)
+	- master now sends ARB timescale only with utc_offset of zero
+	- slave now only uses the last UTC_Offset if UTC_Valid bit is on.
+	- passive masters no longer become active every 12s,
+	- first delayreq is postponed until we receive the first sync
+	- -G (master with ntpd) now announces a better clock class of 13
+	- delayReq period is now uniformly randomized from range
+	- updated to the PTPv2 messages rates (sync / delayreq / announce )
+	- operator is warned once when the we slew the clock at maximum speed
+	- and several others too minor too mention
+	* System fixes and new features
+	- Frequency adjustment is now calculated in double precision
+	- Kernel timestamps are now in nanoseconds precision
+	- Timer system overhead was reduced to 16 alarms per second (was 1000)
+	- each reset now generates an IGMP leave/join operation to
+	  the multicast group
+	- Log file is now appended, with the right permissions
+	- Debug messages show a timestamp
+	- Signals are now processed synchronously (to avoid race conditions)
+	- Configurable amount of logging (to avoid filling up /var/log)
+	- client now checks own filelock, $0 and well-known daemons.
+	- unicast messages can use DNS
+	- syslog support (-S)
+	- quality file can be generated with received syncs (-R)
+	- messages can be dumped for debug (-P)
+	- gnore packets that result in large deltas (-M)
+	- SIGUSR1 now steps the clock to the current PTP offset
+	- SIGUSR2 now cycles the domain number (useful for testing)
+	- reverted R135 timer change from integer back to floating point
+	- rand() is now seeded with last digits of our own mac address
+	- IGMP_refresh waits 100ms between drop() and add()
+	- checked to run without leaks inside valgrind 3.5.0
+	- last message received is identified by a column on the statistics log
+	- messages are sent to Syslog by default. reversed -S flag
+	- statistcs file now display /etc/ethers names (besides mac address)
+	- option -C is console mode with full verbosity
+	- startup warnings are also duplicated in stdout
+	- startup: lockfile is checked twice: once at init, to return
+	  correct errorlevel, and a second time after deaemon()
+	- check for root uid()
+	- improvements in parallel daemons checking
+	- command line parameters are dumped at init
+	- Set the unicast flag when sending unicast packets
+	  (experimental, hybrid mode only).
+	- Reimplemented integer64_to_internalTime not to use doubles
+	- Replaced divTime by div2Time
+	- Replaced all time.seconds = time.nanoseconds = 0 by clearTime(&time)
+	- Replaced all hex values by named flags
+	- Optimized comparison of clockIdentity in bmc.c
+	- Resolved issue of comparison of offsetScaledLogVariance
+	- Optimized bmcStateDecision not to call bmcDataSetComparison so often with the same parameters
+	- displayStats now uses getTime instead of gettimeofday
+2011-02-01  George Neville-Neil  <gnn at neville-neil.com>
+	* Add support for DNS lookup of timeserver for unicast.
+	* Add support for unicasting delay requests.
+	* Add code to dump packets on demand via the -P flag as well as in
+	response to updates that violate either the -M or -O flags.
+2010-10-12  George Neville-Neil  <gnn at neville-neil.com>
+	* 2.1.0 First main line release of PTPv2 code base
+	(IEEE-1588-2008)
+	* Add code to limit how much of an offset or delay the client is
+	willing to tolerate.
+	* Add support for BINTIME on FreeBSD which gives more accurate
+	packet timestamps.
+	* Add quality file support
+	* Fix significant bugs that prevented correct operation in
+	End-to-End mode.
+	* Add support for syslog.
+	* Add support for user configurable TTL.
+	* Clean up code formatting, headers, comments etc.
diff --git a/freebsd/contrib/ptpd/INSTALL b/freebsd/contrib/ptpd/INSTALL
index 00000000..0e218aa0
--- /dev/null
+++ b/freebsd/contrib/ptpd/INSTALL
@@ -0,0 +1,153 @@
+PTP Daemon Version 2 Build and Installation Instructions
+15 June 2015
+George V. Neville-Neil, Wojciech Owczarek
+The PTP Daemon is known to work on FreeBSD, NetBSD, OpenBSD,
+OpenSolaris and its derivatives, Mac OS X and Linux systems.
+*) Requirements
+You will need the following tools and libraries to build ptpd2:
+1. GNU autotools (automake, autoconf, libtool etc.) - essential
+2. PCAP libraries (libpcap/bpf) and development headers
+   (optional but recommended) - required for Ethernet transport
+   and generally recommended for message performance
+   *NOTE: Libpcap seems to be broken on OpenSolaris / OmniOS,
+    builds and runs, but no data is being received.
+3. SNMP libraries (optional) - will allow building with SNMP
+   support
+*) Building
+1. cd into the root of the tree (which is where the file you're
+   reading resides)
+2. If building from a repository such as Subversion, CVS or GIT, run:
+   autoreconf -vi
+3. If building from a distribution .tar.gz package, you may run autoreconf -vi,
+   but in most cases running ./configure should be enough - you must run
+   autoreconf if configure or result in errors.
+4. ./configure
+   The final section of the configure script output will show
+   the results of all library dependency checks and feature checks:
+   features and dependencies can be controled using the options
+   described below. Running ./configure --help will show all available
+   options.
+   *NOTE* On QNX systems, the configure script may not accept the
+   'rm' command implementation available, so if it complains,
+   run ./configure with the following environment variable:
+   export ACCEPT_INFERIOR_RM_PROGRAM=yes
+   ========= configure script options for ptpd ========================
+   * To disable the statistics code in order to lower computational
+   expense and RAM usage, configure the build with the following options:
+   ./configure --disable-statistics
+   * To build a slave-only version (with GM logic disabled), build with:
+    ./configure --enable-slave-only
+    This will build a version incapable of running as master.
+    * As of 2.3.1, the default timer implamentation used for periodic
+    actions uses POSIX timers if only the OS supports it. To disable
+    POSIX timer support and use the old interval timer implementation,
+    the following switch can be used:
+    ./configure --disable-posix-timers
+    * As of 2.3.1, support was added for multiple unicast destinations
+    (both GMs and slaves) - with negotiation (signaling) and without.
+    The default maximum number of unicast destinations (also the
+    maximum number of slaves for a signaling GM) is set to 128. This
+    setting has an impact on the amount of RAM used by PTPd. The
+    unicast table capacity can be changed to a maximum of 2048 using:
+   ./configure --with-max-unicast-destinations=[16...2048]
+    It is possible to change this limit to more than 2048, but realistically
+    due to message scheduling, timer signal usage and single-threaded
+    architecture, anywhere above 1000 ptpd will show high CPU utilisation.
+    Ptpd has been successfully tested as unicast Telecom (negotiation) master
+    at 1000 slaves and high message rates (32/sec) and provided adequate
+    performance. When running high numbers of slaves, it is recommended
+    to use libpcap (ptpengine:use_libpcap=y) to allow easier matching
+    of Sync and FollowUp, unless the NIC supports software transmit
+    timestamps. Without those and without libpcap, ptpd loops packets
+    back into its own socket, so the followUp destination cannot be
+    matched with the Sync destination, and a lookup table is used.
+    Hash collissions are low, but they may happen, in which case
+    ptpd will iterate over a table of last timestamps.  This is only and issue
+    in extreme scenarios.
+    * With certain NIC drivers on Linux providing the SO_TIMESTAMPING
+    functionality with software transmit timestamps (SOF_TIMESTAMPING_
+    TX_SOFTWARE), unpredictable transmit timestamp failures can occur,
+    which may cause unstable operation and in some cases high CPU usage
+    (see https://sourceforge.net/p/ptpd/discussion/469208/thread/4aea6e47).
+    While fixes have been implemented and have shown success,
+    there is still some risk. To disable SO_TIMESTAMPING support on Linux
+    completely, regardless of OS support, use:
+    ./configure --disable-so-timestamping
+    * To enable experimental options use:
+    ./configure --enable-experimental-options
+    This enables:
+     - running SO_TIMESTAMPING without verifying if NIC driver
+       supports the given timestamping options
+     - running message intervals outside of PTP specification
+    *NOTE* On QNX systems, when experimental options are enabled,
+     a clock_gettime approximation using CPU clock counter and
+     attaching to IRQ0 is used, and this is also used to retrieve
+     packet RX and TX timestamps, ignoring PCAP timestamps and
+     socket options. This is recommended for best performance,
+     but requires more testing before becoming the default.
+     by default in QNX, clock is incremented in ticks that
+     can be as long as 10 milliseconds, and PCAP and socket
+     timestamps are only accurate to several milliseconds.
+5. make
+6. Read the manual pages ptpd2(8) and ptpd2.conf(5). The man pages
+   are the most complete source of configuration information.
+   ptpd2 itself also provides an extensive help:
+   run ptpd2 --help to see the short help
+   run ptpd2 --long-help to see the long help for all settings
+   run ptpd2 -e [key:setting] to display help for a single setting
+7. Update test/client-e2e-socket.conf so that its
+   "ptpengine:interface = " setting points to a network interface on
+   your test machine that can see PTP packets from a grandmaster.
+8. Test it in place: ./src/ptpd2 -c test/client-e2e-socket.conf
+9. Check the log output of the daemon in /var/run/ptpd2.event.log
+   Check statistics output of the daemon in /var/run/ptpd2.stats.log
+   Check the status file /var/run/ptpd2.status.log
+10. If the results look good, make install
+The daemon may work on other POSIX based systems but this is not
+guaranteed.  Patches and fixes are welcome on the SourceForge page:
+http://ptpd.sf.net
diff --git a/freebsd/contrib/ptpd/Makefile.am b/freebsd/contrib/ptpd/Makefile.am
index 00000000..41422be6
--- /dev/null
+++ b/freebsd/contrib/ptpd/Makefile.am
@@ -0,0 +1,53 @@
+ACLOCAL_AMFLAGS = -I m4
+NULL =
+SUBDIRS =		\
+	src		\
+	$(NULL)
+EXTRA_DIST =			\
+	COPYRIGHT		\
+	ChangeLog		\
+	README.md		\
+	doc			\
+	tools			\
+	test			\
+	packagebuild		\
+	src/ptpd2.conf.default-full\
+	src/ptpd2.conf.minimal\
+	src/ptpd2.8\
+	src/ptpd2.conf.5\
+	src/leap-seconds.list\
+	src/dep/iniparser/AUTHORS\
+	src/dep/iniparser/LICENSE\
+	src/dep/iniparser/README\
+	src/templates.conf\
+	$(NULL)
+dist-hook:
+	rm -f $(distdir)/packagebuild/rpm-rh/*.rpm
+CLEANFILES =
+#DISTCLEANFILES = .gcc-warning
+BUILT_SOURCES =				\
+	libtool				\
+	$(NULL)
+ptpd2dir = $(datadir)/$(PACKAGE)
+ptpd2_DATA = 	src/leap-seconds.list		\
+		src/ptpd2.conf.minimal		\
+		src/ptpd2.conf.default-full	\
+		src/templates.conf		\
+		doc/PTPBASE-MIB.txt		\
+		$(NULL)
+#dist-hook:
+#	@find $(distdir) -type d -name SCCS -print | xargs rm -rf
+libtool: $(LIBTOOL_DEPS)
+	./config.status --recheck
diff --git a/freebsd/contrib/ptpd/Makefile.old b/freebsd/contrib/ptpd/Makefile.old
index 00000000..3de584ca
--- /dev/null
+++ b/freebsd/contrib/ptpd/Makefile.old
@@ -0,0 +1,33 @@
+# Root Makefile for ptpd, used for cutting releases and release candidates
+NAME = ptpd
+VERSION = ${NAME}-2.2.2
+RC = ${NAME}-2-RC-0
+rc:
+	(cd src; make clean)
+	mkdir $(RC)
+	(cd $(RC); \
+	ln -s ../src .; \
+	ln -s ../doc .; \
+	ln -s ../tools .; \
+	ln -s ../COPYRIGHT .; \
+	ln -s ../ChangeLog .; \
+	ln -s ../Makefile .; \
+	ln -s ../README .; \
+	ln -s ../RELEASE_NOTES .)
+	tar cvzf $(RC).tar.gz -L --exclude .o --exclude Doxygen --exclude .svn --exclude .dep --exclude core $(RC)
+release:
+	mkdir $(VERSION)
+	(cd $(VERSION); \
+	ln -s ../src .; \
+	ln -s ../doc .; \
+	tar cvzf $(VERSION).tar.gz -L --exclude .o --exclude Doxygen --exclude .svn --exclude .dep --exclude core $(VERSION)
diff --git a/freebsd/contrib/ptpd/README.md b/freebsd/contrib/ptpd/README.md
index 00000000..469a64ab
--- /dev/null
+++ b/freebsd/contrib/ptpd/README.md
@@ -0,0 +1,43 @@
+PTPd
+PTP daemon (PTPd) is an implementation the Precision Time Protocol (PTP) version
+2 as defined by 'IEEE Std 1588-2008'. PTP provides precise time coordination of
+Ethernet LAN connected computers. It was designed primarily for instrumentation
+and control systems.
+Use
+PTPd can coordinate the clocks of a group of LAN connected computers with each
+other. It has been shown to achieve microsecond level coordination, even on
+limited platforms.
+The 'ptpd' program can be built from the included source code.  To use the
+program, run 'ptpd' on a group of LAN connected computers. Compile with
+'PTPD_DBG' defined and run with the '-C' or -V argument to watch what's going on.
+If you are just looking for software to update the time on your desktop, you
+probably want something that implements the Network Time Protocol. It can
+coordinate computer clocks with an absolute time reference such as UTC.
+Please refer to the
+[INSTALL](https://raw.githubusercontent.com/ptpd/ptpd/master/INSTALL) file
+for build instructions and configuration options. Please refer to the
+[README.repocheckout](https://github.com/ptpd/ptpd/blob/master/README.repocheckout)
+file for information on how to build from source code repositories.
+Legal notice
+PTPd was written by using only information contained within 'IEEE Std
+1588-2008'. IEEE 1588 may contain patented technology, the use of which is not
+under the control of the authors of PTPd. Users of IEEE 1588 may need to obtain
+a license for the patented technology in the protocol. Contact the IEEE for
+licensing information.
+PTPd is licensed under a 2 Clause BSD Open Source License. Please refer to the
+[COPYRIGHT](https://github.com/ptpd/ptpd/blob/master/COPYRIGHT) file for
+additional information.
+PTPd comes with absolutely no warranty.
diff --git a/freebsd/contrib/ptpd/README.repocheckout b/freebsd/contrib/ptpd/README.repocheckout
index 00000000..422dc448
--- /dev/null
+++ b/freebsd/contrib/ptpd/README.repocheckout
@@ -0,0 +1,18 @@
+If you are getting this code from a tarball distribution, this
+file does not apply to you.
+If you are getting this code from a repo checkout, you will need to
+have autoconf, automake, and libtool installed.
+Run:
+ % autoreconf -vi
+to generate the build environment. On some older systems you may get
+libtool errors (./libtool: line nnnn: X[command]: command not found) -
+in that case use:
+ % libtoolize --force --copy; aclocal; autoconf; automake
diff --git a/freebsd/contrib/ptpd/TODO b/freebsd/contrib/ptpd/TODO
index 00000000..b0277ef5
--- /dev/null
+++ b/freebsd/contrib/ptpd/TODO
@@ -0,0 +1,49 @@
+# not part of distribution - TODO notes to implement before next release
+2.3.1.1 / 2.3.2:
+- man page updates for template files x
+- clock ID printed in reverse in L2 mode
+  with (grandmasterID present?) - not an issue, looks like a White Rabbit problem x
+- compact grantable message types and use smaller array to save memory x
+- 16.1.1: may be granted in listening state or passive state <- but g.8265 is no BMCA x
+- sig/msg message acceptance 4 options: all1,port, clockid,port, clock,all1, all1,all1 x
+- rework config option parsing x
+- rework parseConfig to support an opcode, get rid of remaining macros x
+- pointer to best master x
+- disqualification flag x
+- remove masteraddr in favour of bestMaster->sourceAddr x
+- use pointer to best master x
+- management TLV buffer guard and don't unpack GET x
+- SNMP - implement statistics tables x
+- SNMP - implement remaining traps x
+- add alarm events -> trigger SNMP traps x
+- add offset alarm threshold to config x
+- clean up object order in the MIB x
+- call alarm handlers before shutdown (on port disabled?) x
+- add alarm initial delay to config + man x
+- add alarm timeout to config + man x
+- add snmp traps enable/disable to config + man x
+- implement ofm threshold alarm triggering x
+- SNMP MIB: add domain mismatch trap + last domain x
+- add alarm messages to log notifications x
+- add alarm messages to alarm table (for fault record)
+- rework trigger and dependency macros: 2nd pass?
+- complete built-in templates
+- add dummy or populated default template file x [dummy]
+- NVRAM write?
+- use split token loop macros
+- SET messages to refresh the config properly x/-
+  add set + commit + rollback as snmp handles
+- remaining management message SET handling
+- add fault record and numberfaults to snmp and mgmt
+- update man page with alarm descriptions
+- improve alarm dump
+- add alarm descriptions to help output
+- eventually add support for an event queue
+- SNMP MIB: add alarm list so that
+  informs can also send date and time
+- MGMT clear and get fault record
+- configurable alarm severities?
diff --git a/freebsd/contrib/ptpd/configure.ac b/freebsd/contrib/ptpd/configure.ac
index 00000000..95e4ff48
--- /dev/null
+++ b/freebsd/contrib/ptpd/configure.ac
@@ -0,0 +1,777 @@
+# Process this file with autoconf to produce a configure script.
+m4_include([m4/version.m4])
+AC_PREREQ(2.59)
+AC_INIT(
+    [ptpd],
+    [VERSION_NUMBER],
+    [ptpd-bugs at nwtime.org],
+    [PTPD_URL]dnl
+AC_CONFIG_SRCDIR([src/arith.c])
+AC_CONFIG_HEADER([config.h])
+AC_CONFIG_AUX_DIR([build-aux])
+AC_CONFIG_MACRO_DIR([m4])
+AM_INIT_AUTOMAKE([1.9 foreign -Wall])
+[RELEASE_DATE]="RELEASE_DATE"
+AC_SUBST([RELEASE_DATE])
+[VERSION_NUMBER]="VERSION_NUMBER"
+AC_SUBST([VERSION_NUMBER])
+# Checks for programs.
+AC_PROG_AWK
+AC_PROG_CC
+ifdef([AC_PROG_CC_C99], [AC_PROG_CC_C99])
+AC_PROG_LIBTOOL
+AM_PROG_CC_C_O
+# Check for svnversion, cut and tr
+AC_PATH_PROG(cutpath, cut)
+AC_PATH_PROG(trpath, tr)
+AC_PATH_PROG(datepath, date)
+if test -n "$datepath"; then
+    build_date=`$datepath +%Y%m%d`
+    AC_DEFINE_UNQUOTED(BUILD_DATE, ["$build_date"], [build date year-month-day])
+fi
+# Set CODE_REVISION if svnversion found, version is suffixed with "-svn" and code is versioned
+if test -n "$cutpath" && test -n "$trpath"; then
+    ver_prefix=`echo VERSION_NUMBER | $cutpath -s -d- -f2`
+    AC_PATH_PROG(svnverpath, svnversion)
+    if test "$ver_prefix" = "svn" && test -n "$svnverpath"; then
+	svn_rev=`$svnverpath 2>/dev/null | $cutpath -s -d: -f2 | $trpath -d MS`
+	if test -n "$svn_rev"; then
+	    AC_DEFINE_UNQUOTED(CODE_REVISION, ["$svn_rev"], [source code revision])
+	else
+	svn_rev=`$svnverpath 2>/dev/null | $trpath -d MS`
+	    fi
+	fi
+    fi
+fi
+case $host in
+*linux*)
+    AC_CHECK_HEADERS([linux/net_tstamp.h], [], [
+    if [ test -d "/usr/src/kernels/`uname -r`/include" ]; then
+	LINUX_KERNEL_INCLUDES="-I/usr/src/kernels/`uname -r`/include"
+	LINUX_KERNEL_HEADERS=yes
+    fi
+    if [ test -d "/usr/src/linux-headers-`uname -r`/include" ]; then
+	LINUX_KERNEL_INCLUDES="-I/usr/src/linux-headers-`uname -r`/include"
+    fi
+esac
+AM_CONDITIONAL(LINUX_KERNEL_HEADERS, test x$LINUX_KERNEL_HEADERS = xyes)
+AC_SUBST(LINUX_KERNEL_INCLUDES)
+# Checks for libraries.
+AC_SEARCH_LIBS([pow], [m])
+AC_SEARCH_LIBS([clock_gettime], [rt])
+AC_SEARCH_LIBS([timer_create], [rt])
+AC_SEARCH_LIBS([connect], [socket])
+AC_SEARCH_LIBS([gethostbyname], [nsl])
+# Checks for header files.
+AC_HEADER_STDC
+AC_CHECK_HEADERS([arpa/inet.h fcntl.h limits.h netdb.h net/ethernet.h netinet/in.h netinet/in_systm.h netinet/ether.h sys/uio.h stdlib.h string.h sys/ioctl.h sys/param.h sys/socket.h sys/sockio.h ifaddrs.h sys/time.h syslog.h unistd.h glob.h sched.h utmp.h utmpx.h unix.h linux/rtc.h sys/timex.h getopt.h])
+AC_CHECK_HEADERS([endian.h machine/endian.h sys/isa_defs.h])
+AC_CHECK_HEADERS([math.h],[],[AC_MSG_ERROR([math.h is required to compile PTPd])],[])
+# MUST chck for cpuset AFTER the check for param as the latter needs
+# the former to pass the compile check.
+AC_CHECK_HEADERS([sys/cpuset.h], [], [],
+[#ifdef HAVE_SYS_PARAM_H
+    # include <sys/param.h>
+#endif
+# Similar case for if.h
+AC_CHECK_HEADERS([net/if.h], [], [],
+#ifdef HAVE_SYS_SOCKET_H
+    #include <sys/socket.h>
+#endif
+#ifdef HAVE_SYS_TYPES_H
+    #include <sys/types.h>
+#endif
+# Similar case for if_arp.h
+AC_CHECK_HEADERS([net/if_arp.h], [], [],
+#endif
+#endif
+#ifdef HAVE_NET_IF_H
+    #include <net/if.h>
+#endif
+# Similar case for netinet/if_ether.h
+AC_CHECK_HEADERS([netinet/if_ether.h], [], [],
+#endif
+#ifdef HAVE_ARPA_INET_H
+    #include <arpa/inet.h>
+#endif
+#endif
+#ifdef HAVE_NET_IF_ARP_H
+    #include <net/if_arp.h>
+#endif
+#endif
+# ...and for if_ether.h
+AC_CHECK_HEADERS([net/if_ether.h], [], [],
+#endif
+#endif
+# Checks for typedefs, structures, and compiler characteristics.
+AC_C_CONST
+AC_HEADER_STDBOOL
+AC_HEADER_TIME
+AC_C_VOLATILE
+# Automake 2.59 has a problem with those on RHEL5
+m4_version_prereq(2.60,[
+    AC_TYPE_UINT32_T
+    AC_TYPE_UINT64_T
+    AC_TYPE_UINT8_T
+    AC_TYPE_SIZE_T
+    AC_TYPE_SSIZE_T
+    AC_TYPE_INT64_T
+    [AC_TYPE_SIZE_T]
+# Check for tick in the timex structure
+AC_CHECK_MEMBERS([struct utmp.ut_time], [], [], [
+#ifdef HAVE_UTMP_H
+#include <utmp.h>
+#endif
+AC_CHECK_MEMBERS([struct timex.tick], [], [], [[#include <sys/timex.h>]])
+AC_CHECK_MEMBERS([struct timex.tai], [], [], [[#include <sys/timex.h>]])
+AC_CHECK_MEMBERS([struct ntptimeval.tai], [], [],
+#include <sys/time.h>
+#include <sys/timex.h>
+# Check for ifr_hwaddr in the ifreq structure
+AC_CHECK_MEMBERS([struct ifreq.ifr_hwaddr], [], [], [[#include <net/if.h>]])
+# Check for ifr_index in the ifreq structure
+AC_CHECK_MEMBERS([struct ifreq.ifr_index], [], [], [[#include <net/if.h>]])
+# Check for ifr_ifindex in the ifreq structure
+AC_CHECK_MEMBERS([struct ifreq.ifr_ifindex], [], [], [[#include <net/if.h>]])
+# ether_add: octet vs. ether_addr_octet - FreeBSD, any others?
+AC_CHECK_MEMBERS([struct ether_addr.octet], [], [],
+#endif
+#ifdef HAVE_NETINET_ETHER_H
+    #include <netinet/ether.h>
+#endif
+#ifdef HAVE_NET_ETHERNET_H
+    #include <net/ethernet.h>
+#endif
+#ifdef HAVE_NET_IF_ETHER_H
+#endif
+    #include <net/if_ether.h>
+#endif
+# Checks for library functions
+AC_PROG_GCC_TRADITIONAL
+AC_FUNC_MALLOC
+AC_FUNC_MEMCMP
+AC_FUNC_SELECT_ARGTYPES
+AC_TYPE_SIGNAL
+AC_FUNC_STRFTIME
+AC_FUNC_VPRINTF
+AC_CHECK_FUNCS([clock_gettime dup2 ftruncate gethostbyname2 gettimeofday inet_ntoa memset pow select socket strchr strdup strerror strtol glob pututline utmpxname updwtmpx setutent endutent signal ntp_gettime getopt_long])
+if test -n "$GCC"; then
+    AC_MSG_CHECKING(if GCC -fstack-protector is usable)
+    OLDCFLAGS="$CFLAGS"
+    CFLAGS="$CFLAGS -fstack-protector"
+    AC_TRY_LINK(,,[
+	AC_MSG_RESULT(yes)
+	AC_MSG_RESULT(no)
+	CFLAGS="$OLDCFLAGS"
+fi
+AC_MSG_NOTICE([************************************************************])
+AC_MSG_NOTICE([* PTPD BUILD FLAG AND LIBRARY DEPENDENCY CHECKS START HERE *])
+AC_CHECK_DECLS([MSG_ERRQUEUE], [], [], [[#include <sys/socket.h>]])
+AC_CHECK_DECLS([POSIX_TIMERS_SUPPORTED], [posix_timers=true], [posix_timers=false], [
+#ifdef __sun && !defined(_XPG6)
+#define _XPG6
+#endif
+#include <unistd.h>
+#if _POSIX_TIMERS && (_POSIX_TIMERS - 200112L) >= 0
+#define POSIX_TIMERS_SUPPORTED
+#else
+#endif
+# ALL USER-CONTROLLED KNOBS START HERE
+AC_ARG_ENABLE([posix_timers],
+	    AS_HELP_STRING( [--disable-posix-timers (enabled by default if supported)],
+			    [Disable POSIX timer support and use interval timers even if POSIX timers supported by the OS])
+AS_IF([test "x$enable_posix_timers" == "xno"], [
+posix_timers=false
+AM_CONDITIONAL([PTIMERS], [test x$posix_timers = xtrue ])
+AC_MSG_CHECKING([if we want to build POSIX timer support])
+case "$posix_timers" in
+     "true")
+	PTP_PTIMERS="-DPTPD_PTIMERS"
+	AC_MSG_RESULT([yes])
+     *) PTP_PTIMERS=""
+	AC_MSG_RESULT([no])
+esac
+AC_SUBST(PTP_PTIMERS)
+AC_ARG_WITH(
+    [pcap-config],
+    [AS_HELP_STRING(
+	[--with-pcap-config],
+	[+ =pcap-config]
+    [ans=$withval],
+    [ans=yes]
+case "$ans" in
+ no)
+ yes)
+    ans=pcap-config
+    pcap_config_dirname=`dirname $ans`
+    pcap_config_basename=`basename $ans`
+    ans=abspath
+    AC_MSG_ERROR([--with-pcap-config takes either a name or an absolute path])
+esac
+PROG_PCAP_CONFIG=$ans
+case "$PROG_PCAP_CONFIG" in
+ no)
+ abspath)
+    AC_PATH_PROG([PATH_PCAP_CONFIG], [$pcap_config_basename], [], [$pcap_config_dirname])
+    AS_UNSET([ac_cv_path_PATH_PCAP_CONFIG])
+    AC_PATH_PROG([PATH_PCAP_CONFIG], [$PROG_PCAP_CONFIG])
+esac
+AC_MSG_CHECKING([if we want to build with libpcap support])
+AC_ARG_ENABLE(
+    [pcap],
+    [AS_HELP_STRING(
+	[--disable-pcap],
+	[disable support for PCAP (enabled by default / if we find pcap-config)]
+    [try_pcap=$enableval],
+    [try_pcap=yes]
+if test "x$try_pcap" = "xyes"; then
+case "$PATH_PCAP_CONFIG" in
+	AC_MSG_RESULT([yes, pcap-config])
+	AC_CHECK_HEADERS([pcap/pcap.h pcap.h])
+	try_pcap=yes
+	AC_MSG_RESULT([yes, guessing flags])
+	try_pcap=guess
+esac
+fi
+ptpd_pcap_enabled=0
+case "$try_pcap" in
+ yes)
+    case "$PATH_PCAP_CONFIG" in
+	PCAP_LIBS=`$PATH_PCAP_CONFIG --libs`
+	AC_SUBST([PCAP_LIBS])
+	# Separate CPPFLAGS and CFLAGS
+	foo=`$PATH_PCAP_CONFIG --cflags`
+	PCAP_CPPFLAGS=
+	PCAP_CFLAGS=
+	for i in $foo; do
+	    case "$i" in
+	     -D*|-F*|-U*|-I*)
+		PCAP_CPPFLAGS="$PCAP_CPPFLAGS $i"
+	    *)	PCAP_CFLAGS="$PCAP_CFLAGS $i"
+	    esac
+	done
+	AC_SUBST([PCAP_CPPFLAGS])
+	AC_SUBST([PCAP_CFLAGS])
+	save_CFLAGS=$CFLAGS
+	save_CPPFLAGS=$CPPFLAGS
+	save_LIBS=$LIBS
+	CFLAGS=$PCAP_CFLAGS
+	CPPFLAGS=$PCAP_CPPFLAGS
+	CFLAGS=$save_CFLAGS
+	AS_UNSET([save_CFLAGS])
+	CPPFLAGS=$save_CPPFLAGS
+	AS_UNSET([save_CPPFLAGS])
+	LIBS=$save_LIBS
+	AS_UNSET([save_LIBS])
+	AC_MSG_CHECKING([if we can build with libpcap support])
+	case "$ac_cv_header_pcap_pcap_h" in
+	 yes)
+		ptpd_pcap_enabled=1
+		PTP_PCAP="-DPTPD_PCAP"
+	 no)
+		case "$ac_cv_header_pcap_h" in
+		 yes)
+		 no)
+			PTP_PCAP=""
+			PCAP_LIBS=""
+			PCAP_CPPFLAGS=""
+			PCAP_CFLAGS=""
+		esac
+	esac
+	# This case can't be triggered - we won't get here unless we
+	# have an absolute path to pcap-config.
+	AC_MSG_WARN([Cannot build with libpcap support - pcap-config cannot be found])
+    esac
+ guess)
+	PCAP_LIBS="-lpcap"
+	AC_MSG_CHECKING([if we can build with PCAP support])
+	 yes)
+	 no)
+		 yes)
+		 no)
+			PTP_PCAP=""
+			PCAP_LIBS=""
+			PCAP_CPPFLAGS=""
+			PCAP_CFLAGS=""
+		esac
+	esac
+ no)
+			PTP_PCAP=""
+			PCAP_LIBS=""
+			PCAP_CPPFLAGS=""
+			PCAP_CFLAGS=""
+esac
+AC_SUBST(PTP_PCAP)
+AM_CONDITIONAL([PCAP], [test x$ptpd_pcap_enabled = x1])
+AC_ARG_WITH(
+    [net-snmp-config],
+    [AS_HELP_STRING(
+	[--with-net-snmp-config],
+	[+ =net-snmp-config]
+    [ans=$withval],
+    [ans=yes]
+case "$ans" in
+ no)
+ yes)
+    ans=net-snmp-config
+    net_snmp_config_dirname=`dirname $ans`
+    net_snmp_config_basename=`basename $ans`
+    ans=abspath
+    AC_MSG_ERROR([--with-net-snmp-config takes either a name or an absolute path])
+esac
+PROG_NET_SNMP_CONFIG=$ans
+case "$PROG_NET_SNMP_CONFIG" in
+ no)
+ abspath)
+    AC_PATH_PROG([PATH_NET_SNMP_CONFIG], [$net_snmp_config_basename], [], [$net_snmp_config_dirname])
+    AS_UNSET([ac_cv_path_PATH_NET_SNMP_CONFIG])
+    AC_PATH_PROG([PATH_NET_SNMP_CONFIG], [$PROG_NET_SNMP_CONFIG])
+esac
+AC_MSG_CHECKING([if we want to try building SNMP support])
+AC_ARG_ENABLE(
+    [snmp],
+    [AS_HELP_STRING(
+	[--disable-snmp],
+	[disable support for SNMP (enabled if we find net-snmp-config)]
+    [try_snmp=$enableval],
+    [case "$PATH_NET_SNMP_CONFIG" in
+	try_snmp=yes
+	try_snmp=no
+    esac]
+AC_MSG_RESULT([$try_snmp])
+ptpd_snmp_enabled=0
+case "$try_snmp" in
+ yes)
+    case "$PATH_NET_SNMP_CONFIG" in
+	SNMP_LIBS=`$PATH_NET_SNMP_CONFIG --agent-libs`
+	AC_SUBST([SNMP_LIBS])
+	# HMS: we really want to separate CPPFLAGS and CFLAGS
+	foo=`$PATH_NET_SNMP_CONFIG --base-cflags`
+	SNMP_CPPFLAGS=
+	SNMP_CFLAGS=
+	for i in $foo; do
+	    case "$i" in
+	     -D*|-F*|-U*|-I*)
+		SNMP_CPPFLAGS="$SNMP_CPPFLAGS $i"
+	    *)	SNMP_CFLAGS="$SNMP_CFLAGS $i"
+	    esac
+	done
+	AC_SUBST([SNMP_CPPFLAGS])
+	AC_SUBST([SNMP_CFLAGS])
+	save_LIBS=$LIBS
+	CFLAGS=$SNMP_CFLAGS
+	CPPFLAGS=$SNMP_CPPFLAGS
+	AC_CHECK_HEADER([net-snmp/net-snmp-config.h])
+	LIBS=$save_LIBS
+	AC_MSG_CHECKING([if we are building SNMP support])
+	case "$ac_cv_header_net_snmp_net_snmp_config_h" in
+	 yes)
+		ptpd_snmp_enabled=1
+		PTP_SNMP="-DPTPD_SNMP"
+	 no)
+		PTP_SNMP=""
+		SNMP_LIBS=""
+		SNMP_CPPFLAGS=""
+		SNMP_CFLAGS=""
+	esac
+	# have an absolute path to net-snmp-config.
+	AC_MSG_WARN([Cannot build with SNMP support - net-snmp-config cannot be found])
+    esac
+esac
+AC_SUBST(PTP_SNMP)
+AM_CONDITIONAL([SNMP], [test x$ptpd_snmp_enabled = x1])
+AC_MSG_CHECKING([for RUNTIME_DEBUG])
+AC_ARG_ENABLE(
+    [runtime-debug],
+    [AS_HELP_STRING(
+	[--enable-runtime-debug (disabled by default)],
+	[Enable all debug messages]
+    [enable_runtime_debug=no]
+AC_MSG_RESULT([$enable_runtime_debug])
+case "$enable_runtime_debug" in
+ yes)
+    PTP_DBL="-DRUNTIME_DEBUG"
+    AC_MSG_CHECKING([for (old-style) debug message level])
+    AC_ARG_ENABLE(
+        [debug-level],
+        [AS_HELP_STRING(
+	    [[[[--enable-debug-level={basic,medium,all}]]]],
+	    [debug message level: basic, medium, all]
+        [ptp_dblevel=$enableval],
+        [ptp_dblevel=no]
+    AC_MSG_RESULT([$ptp_dblevel])
+    case "$ptp_dblevel" in
+     "basic")
+	PTP_DBL="-DPTPD_DBG"
+     "medium")
+	PTP_DBL="-DPTPD_DBG2"
+     "all")
+	PTP_DBL="-DPTPD_DBGV"
+     *) PTP_DBL=""
+    esac
+esac
+AC_SUBST(PTP_DBL)
+AC_MSG_CHECKING([for maximum unicast destination table size])
+AC_ARG_WITH(
+    [max-unicast-destinations],
+    [AS_HELP_STRING(
+	[--with-max-unicast-destinations = [ 16 .. 2048 (default: 128)]],
+	[Change maximum supported number of unicast destinations -
+	    this determines the maximum supported number of slaves
+	    in unicast mode (with and without signaling)]
+    [max_destinations=$with_max_unicast_destinations],
+    [max_destinations=128]
+test $max_destinations -lt 16 && max_destinations=16
+test $max_destinations -gt 2048 && max_destinations=2048
+PTP_UNICAST_MAX="-DPTPD_UNICAST_MAX=$max_destinations"
+AC_SUBST([PTP_UNICAST_MAX])
+AC_MSG_RESULT([$max_destinations])
+AC_MSG_CHECKING([for daemon mode])
+AC_ARG_ENABLE(
+    [daemon],
+    [AS_HELP_STRING(
+	[--disable-daemon (enabled by default)],
+	[Disable daemon mode]
+    [enable_daemon=yes]
+AC_MSG_RESULT([$enable_daemon])
+case "$enable_daemon" in
+ no)
+    PTP_DAEMON="-DPTPD_NO_DAEMON"
+esac
+AC_SUBST(PTP_DAEMON)
+AC_MSG_CHECKING([for experimental options])
+AC_ARG_ENABLE(
+    [experimental-options],
+    [AS_HELP_STRING(
+	[--enable-experimental-options (disabled by default)],
+	[Enable experimental options]
+    [enable_experimental_options=no]
+AC_MSG_RESULT([$enable_experimental_options])
+case "$enable_experimental_options" in
+ yes)
+    PTP_EXP="-DPTPD_EXPERIMENTAL"
+esac
+AC_SUBST(PTP_EXP)
+AM_CONDITIONAL([EXP], [test x$enable_experimental_options = xyes])
+AC_MSG_CHECKING([for realtime statistics support])
+AC_ARG_ENABLE(
+    [statistics],
+    [AS_HELP_STRING(
+	[--disable-statistics (enabled by default)],
+	[Disable support for realtime statistics and statistics based filtering]
+    [enable_statistics=yes]
+AC_MSG_RESULT([$enable_statistics])
+case "$enable_statistics" in
+ yes)
+    PTP_STATISTICS="-DPTPD_STATISTICS"
+esac
+AC_SUBST(PTP_STATISTICS)
+AM_CONDITIONAL([STATISTICS], [test x$enable_statistics = xyes])
+AC_MSG_CHECKING([if we want to enable SO_TIMESTAMPING support on Linux if available])
+AC_ARG_ENABLE(
+    [so-timestamping],
+    [AS_HELP_STRING(
+	[--disable-so-timestamping (enabled by default)],
+	[Disable support for SO_TIMESTAMPING on Linux builds]
+    [enable_so_timestamping=yes]
+AC_MSG_RESULT([$enable_so_timestamping])
+case "$enable_so_timestamping" in
+ no)
+    PTP_DISABLE_SOTIMESTAMPING="-DPTPD_DISABLE_SOTIMESTAMPING"
+esac
+AC_SUBST(PTP_DISABLE_SOTIMESTAMPING)
+AM_CONDITIONAL([DISABLE_SOTIMESTAMPING], [test x$enable_so_timestamping = xno])
+AC_MSG_CHECKING([if we're building a slave-only build])
+AC_ARG_ENABLE(
+    [slave-only],
+    [AS_HELP_STRING(
+	[--enable-slave-only (disabled by default)],
+	[Build a slave-only version incapable of running as PTP master]
+    [enable_slave_only=no]
+AC_MSG_RESULT([$enable_slave_only])
+case "$enable_slave_only" in
+ yes)
+    PTP_SLAVE_ONLY="-DPTPD_SLAVE_ONLY"
+esac
+AC_SUBST(PTP_SLAVE_ONLY)
+AM_CONDITIONAL([SLAVE_ONLY], [test x$enable_slave_only = xyes])
+AC_MSG_NOTICE([*   END OF PTPD BUILD FLAG AND LIBRARY DEPENDENCY CHECKS   *])
+AC_CONFIG_FILES([Makefile])
+AC_CONFIG_FILES([src/Makefile])
+AC_CONFIG_FILES([src/ptpd2.8])
+AC_CONFIG_FILES([src/ptpd2.conf.5])
+AC_OUTPUT
diff --git a/freebsd/contrib/ptpd/doc/IEEE1588v1_vs_IEEE1588v2.pdf b/freebsd/contrib/ptpd/doc/IEEE1588v1_vs_IEEE1588v2.pdf
index 0000000000000000000000000000000000000000..8f26177eb488a6a1167e9fd04fd08c0cebd7b7a5
GIT binary patch
literal 272225
zcma&MQ<NxSmu;E0ZQHhOXP&fq(zb2ewr$(CZCic*+f{uZ>Y?i)Mnvp*jWO1o-`b=K
zB4V_RbSzM$qgSy7P^<(D1h$5Mp?G-cWlU_$oXiQ>{!NtV#Vo9xOdJU4#jFgROhinK
zY>iF$_ at Eq}983(Xq1>{XwKiS0T2OVmd8Yr|jg#UB9r(DbSP#n at a!2qu<0sYBs3)MZ
zrx=U382K9Z7W2;oBMoulIG936IjD6p5YU}A)Z5zu_?B at XHyqse_Sm^JA1o`s{W?4w
z9H&S4ZooHrxu||ycYj=lSK>S_P-s-|R&hWRnr}8EB*P{<23Y7+*Q!0^XFU6=<!kas
z4)^x;?VRG9EQ?<*$1<db3k~c#4#6aw%vhK-rcEGI0xxDws!dTvPzDE`%;Q`>E?anS
zLG%Zq=l`^Gh7IQld#|gT8bkE-j1^bJ&-9=D=w03>q`ewSVq{6mAM;fIuHl%ICA0SY
zC=;V3Dut+10x{FAeauF)rPv!OrhGD`17W-Io3Kp_al at olS9bg%?qk={n68p*Y)OkK
zxB<<VQscJ5NyNfhz0D&Da0dHA&;A?e at SIA<KqnfvX94;MLVIzk%{5!RTW}xk!sXFh
zTZP3CxumpOn*luQ#^9GWC?;hZpzs_S!h9PAxU0fYXej2U=bPKJDz1YcSM9T74rXKt
zJ2sgte(28vgVLS(M;x@$C>F6e{1OKYziM)uZE43Z0+^dG8f>oLE}Q1Kx$-wv`c~7R
zSwuA&pcx=j7Xw<%V)<cYIaV?Kx20!ZjHJ0qe{13*Pq|iHWh|q`7uIRimiC6Ps_DVc
zsD`t#rbE+$*8S(b<`eR#?%d2Oir-h`yRoB(*fct*U%wb)G)mO5b>W-C$O<qJ!&K!-
zmA~yOHD4vcUT=MdyIN~SUlz3uGzmbpU+Hv$TBmp9!nIx#>%2OwZ&tQXzE4~CL19<_
zk{wp!xTr7}pZtnjQcHIfOv;`5GS-`%>t~O9O^;f@&3m(XZY1>RN$nJ%QW4n`N@!&T
zOF*);2EdNdgy;Z6p;jI^jH<>AohK$w1`F^_L!C(iykff%Y<M7VwzYlMWfeS6o--~5
zp|69}4;Ku_{320Ioh;b(8GbvXK>$pCqhw>_1Ap6WwKhpz+`~7M^E6bf&lUE?d!B>x
zbyEprjbAK9VTL&sLz|S<b$yXyH=u4TZw~|<Y?%<)b#ELPIs&RR<&FJJEsN&~$37^`
z4`<8~r`lpq{u^=(qiiBm;zK}RZs6vQ4+*0xzfHZ5zt5e`kP`};X8ndD0&sjHXTlFI
z{~f3kjWXe?Lf|0VB{}jsBb2V5I{uU)BN7 at yRo4u;C#T^KRP)i17<EzT{lnTZPvj`3
zjX$tT+e1Im+;Y}GeWxIV-F at m(yQ7=G7A2i9K`koE$}9kMM7}5)oRWa{%8 at 6q3FOp1
zvh*N_z!LX(@0?MM2)KJlAC#(aY!5={FFljLs>rR*n}4)N*{eqk+y<OyHj;e~u(KE+
zY7B^q<8VFGh+HvQbIv+!<V%uVlrRTwIu2!Slh=wm;fpkNyOGgU-<u2&0r%J?&=|UZ
zEin;tEUgF7vn#n9PKRGu8P6=C8tTZ|i$rQz$Q^itSa9-bdqR^J@~35(t&WzAiqrh!
zqThlNE}ReB7PC_P6^ZJm4i-mA*9<qT#RsC<FD}9nhU>zCOwqCPiB`dU<=eJ2dI7ak
zuFr%5f5d$ki&|XApY0Lzak2uk^Ckc-<e8++Y{-2&r+d4yIOVyE>EtIs(pHt3K&_yd
zqQ_}OML%K!<5D5hF4 at m?6koZ`B&KH*u!%PGdTw?*?W=1Ws4G4ts;f=;sKa`*hR>ql
z*BVEqOak^z%)adiC`MtMFl_VC)6dvWdtm?V?1~5r;H{y$8_EP`n|QY{{*1FOn;>H~
z5P3(yb3Yh0l5xM(cJ_6>^Q~`Fdl4+nOD at M7hNz&&W}I~;u(}=%zhb0Z5*p0R!)tCM
zNxESrG()<Sy1_|K^@TwVImy1KB%F0Pec$C3%YzLw&g_7DXreO<OY&ODjc}owSZiH5
zLJN2&vjcDmxHY3iKd3c{=JJ6s0xiEhBzY1Li{T?)KnYq<1^PklucH at Gl^_o#`e<q3
zQJ1^4ARxn&%<{HJko~Z%p!6wLvAoVZLa$Coxa&fF{WVv#KBL7Mp=$<~SSeMp5H{X6
z7y|poY_Kt>$@IE#4>zI>8gCepU19H^9WXOFn3xHYG~QeoT3_jVqE<>bh5G at +@xQc*
z{O`nKb&;69A^b-UzQ*%XUxH8W>A;7zjLYYnX<t~!oP(N3e*70ecX_PU-b}}vY>v<Y
zmevfPf+ruZYm)=>fP7Xb{9rw<pgr`Bst>$>?w`Kwdj3p$=ZaF_^Uj}Uda-o&?`3~P
zrr0XX>=F}mBPSjVdFIx=`Pd;{v3{3}{rU|3W!iwvL4>QjrX2!DC`}ivjr49L-P7dY
zgj<%NBiQwgMqcZ)W>?kvC|{T4>;Z5wvANJM^$ufafCuO9#&Ds~1iUKa(=rzt;&v at R
zGp)-ebLa`kq5o{TWsl8}*7;NR*CE>yxGK~!TjQpKMl<{}jBnJvb#1Mb+5PH;NF(>p
zVtQ~7DP=-F9XXRoYvN$5 at nV7T+?%xSp4QtwGH#pgX9~+()Hm7wCu%RbJ<3q!Q0I`h
zPlH59^n%*Gr?jkOGo)82kXPzH;r`|XL}ch-t4_=<jV5GIIA7 at c4hcwynAhp{;o{vR
zhk6Ib`y*W5Zi4l;pEn51Kn{sxF98X7*)8E`xvg8IUaJrvYq6y%<B at pzX6VQ#2L2~g
zizYYH=j_bdL@}mTRxN>%bnq5h&}+gxh8LIBh2=fd0~8f3z^c}o)~8gL0onRjE62QZ
z3>|$ZP7m_;B>prfGGTU!yeD)<2Kz|b58;MPD%yIbV>!~js9L%7vSI4UyOg$6kXM$D
z)K?h$+mK1G+(*(DtM7I9uTNZ|{1aPzVK2XUbX6U at JXr6z_4rk`*tX>gUT|7EB{6P{
zshMVZMH-Dalk;<zrN^ORmlTQmY+PT3L8-EbHMgT7c?eu)amVBRicgux%pU3`o=8_0
z?GkU>zwa3$TV5cT!G!B$hv8qxk~VGb-iFaiPaR%4Y6R?sWI%Lll}Syw*9gT7<hc#S
zd^!uQO5XhR_BWz9wvN1GX_v`H5eU!}1;*v15qqZN!#gaZG~H2xgeOWME*v at Xh$73x
zAAM-`tNe3m?S=$c3%~}Z^}+ZqT%?e1?ZyV1qJK<5Y7b04=ODUImcZPfXSDUTt=jBD
z5D$oxVPo^|&x<Y5N;)s?b{1Rb$LN#T9!`5YS)tv4y}0eJX?7rldtuy(d$Z`w;POl%
z+}TpYRS^0h_zmIO{W!&_?QBuX3~fp|AeN*9`*?H&VI)L&27*3Q!^wjJ!I_`-_uj(i
zWPKC at 0lD039G8ivCHW;X;}9NGdHCG#{e|O!0n&4$I!Fn-W(;{RN0bVDPmq)GasgX|
zODb at 9jdriRiA%C}9>uKgjZ|?u_M$P8!SMkL6&dZty?EU>$ae9M9l`CfIQtxF;2OEV
z0R-$24nTK9Wbb!T?B>lDo9&_=KkfD6`>o1QrsjIDRF7>ga+(ha9&?)$_?UMOHvQ{n
z1=aU-p}}~`ZfPHO{8CR6;l=c1c!&9|_Vi6 at s;J9?0HU<|22(=o9`Vk!a0}aHKPfm&
z?+C=;R-tipjX#?7RmUh3tigwhq1oVd8uY_?7NOZ3cR9V6*6FKfzv&3rYQ<Ztt4KrW
z7HBXvE3(?w&`jxBo$xw_=0tM1F*W&$@*`OyQAV77(u>iR)$xk_2I^+_r&8a22(B4<
z1#Umg0$9HNV`uT?MJJAqS8qb!uN#YGn^k$%JUAZ;b at oPyB3+=xgr53KwcTA!2lAoO
zV3JRbsnTU~V&HSn`tl{HtxIxkb7l3mr?r%zwHa5uM<GGgP==nK^3^_CV}8Lih$Hk&
zY>fX4t^Ym!2gm;d;s3caad5Ij{nw1~zlZ;q)fw6UH?V%KsbP!Fjv!Wx{vF|cX#-e)
zWasu=9g3ZYo~3pcIS>A4W_d%+P+VXmciwk-cY%L?AMdEDsb#giNW#KUBu{dtpYSwO
z*hf(!KQHdS6nl!Eties-H&;eirfcqAue)#bG4ddC{b&(ics~fdFh7kqM*>kuVDm~L
zxLC9l#E`KwEh{Paj~u|l$wQVHmAcu4__7M6L7>ZVB^3lDm4LgZg#lw875(BFO>|8K
zB~&0BucB+BXt4w=2#s$|iSC$yg9L#egW&l?s1(#~6l98vTr!%NyPi+xN-Wd-D=L&>
zj5^-wc%ieLM3zsww=kKVYg(U>WxzxC-xq9+rBA~bov-V|@p-F<ICGgMcJG+RHq at E?
z7Rjs^jf_+wDahtFq6lEn0dR^EC4^zj?Lm7{vOl_ at OioQbP#6>B$*5pLVPe-}qM$SJ
z0Qj@(=3E~-Tc#+6bai%5^M5^*d{F37n^=3k@(Mly{S<oSFF*}&wl_jiv8apcHIij9
zWfvRGI-Jym_fhZ7qgG^WmOz?9f<--gtG7PvqZ}xvQB;l5;v^;|r^krn<Oz-Pz4YoL
zjngNu4d=0y5=Er_d)jNk?|T?9!n0d16n>OrdAJ<z&gdc5x1)$=3pSsM7&uL at HFnw_
zCa>guSKs`^nsb7sB&6Y6?bB|Y@?Ww8yh?v0c2IoBEeov(gn7`I0}51$qhfA06a@<w
z<Txm*Y(>PVrzG5Qi%7Kz{uH!QG_R`vXu9XC+)22kB>=m}5fbTaC>))OZhWStX)Fct
zdVOEg9B3Q?fOV-J)ieoP+U9GY?5h@=hdOgfJs!zxZaj1#Mva7mXtZL4?xYp7pTzgp
zyV)^aUnL?dK^!i-FP<Sw7_lhgd!&->d^5q<9w40G=)gW*(`3&qWK%0CKbxMr`{n1|
zX^5ugDNyx1m$ofiO4dCy&E|;FB<{UyQ%CRwFY2i%8`c(&$gsqgJU08tGb8e^nzTBn
zogY>`5!vdG+Pq5n(Kx61tkdQ)-(O>Ni_5*x+=vG4l;^-Rx~X*H1Lo#eYf=<?@0qn5
zzf`h9 at +P(@YwQFh%K4WBHWZiTqEe6-wZfug&ly+OmZWXrx5$Xg*m!<NLv+_Fom4l7
zcu_#Hl2UrS<zH#?HhN}?vYf44PaNr7x*{sV$w2B*)Qfr)N2KX@?lG at eE*f_Gr-7<Z
zfG$Zf*;%>?tdC5?iUVWd!<ssKJ+j&D`3xbn6#DShP2JVPFXPUy10aeoFGf}Psvrc3
zDP;BdYX)YMKuvcmEH?05`&*1M23|Xt5N3g68z!u8yEX-k5q&mRV!ObAJF~>;s at Lk$
zV}14B>C4mB2O_+9%<I!zH?ZbshNI~#U<90#9kwJ?z-V9^bv*cJ7fFoqGb#BYI$*~O
z#m1tDx7)N$xp}f7P^m-KV~j0hiwUg1=|rt8$8uw4n1$VnW-M3nVBoQZP{*Ze(9}YG
z+?N)gv(21SMJ1|u!=uywab|c>dXWltFRp?B8$|)5ju=_Znv4Z))y1VcOQ*;d0<F}b
zIHLkptPXV9=T*I^6VgGZh6tInA}?RlSlYxKsQe`M61s|qpclTlwME&t=Na%twFERX
z1irel>K<XJ<ossP?j0L6F^vOZV39|-nzX<dL0)w(SgOVZo4M??%Ux!ziqa>%Iw#QR
zWnZf3JL1zgMBP2-ss)?B+(~?hT0Y-Eq**qf1UqR)S<pZ28Z_<AmmY3b(uK0Cq-(d`
z at r@H=M>1ts;GsICB=+OAB)vhFBj3UeT_iheDeg7MVmq||;4nLwYDIRct7^>M-APHp
zKP~DSeN55)nvUC at oNF|hQTq@>F~cB;9-r$ZJoONc*|F9+hi!&8sosDHI at 5vL`Q0Ik
z|HW(c#x61u8HBAV3AYVSE)Va;<DP%SV3;NFb)*#(R#>YgMZ$z;{sM^f-%ENv9Tw at d
zZA;*a^=94>n0*A;ce72dVBFx$_wddXzAAvvV~n!RHdDui9Gr=KV~4;FHRv?K==me=
zMKH=&yUGfp&l`v*L5gziZPvLWt|!kxJnbOxS!8yVy~s;d38uW0I-N>Jz`nrw8$0_Q
z$9?Ka=0u;ofwAbC{m70*c#~Ocwug^NK?BhmEwHaktx$)P!iuM^@J9V}jOg#NS2pEV
zuaQDd2d+G#E7qO!Fw0q)e^h&!-S`N5T2i%cKLITKLByu at IlIJk>#DWlc^mm9Lqv}`
z{XnN}rCQ$lI_cjHfzIwLYq!R>uF=-_85#-lOFRgwL_6}b>RbM0_dq|hW%K?&!twv4
z-ha}Ok)4V2ztfS4;lCpD|E41o<Nqcdn>9Bba9R<owW;90BD^PM4sZ{B#xskQ+K<NQ
zHVnRq-VH>hP>3U_HHwOl*bj0iT93#Vq5<ckF=- at KIn^{+2LQICd$M|_dUnGkE28`O
zkN2Oh<JY`Ee{=D>`Joa=eixvBygpnW?~cwUZx2W01vRSK$ZKPUP>fh?b_m(wbUipR
z8#&!QpRC*%J|r>Mc(ex+qh>bukK2+R927tI7ct25ja3G1mJ*rg$M!4uvX at J9N2=4S
z?#cSj8`>~Q!wixzeK1-LkPzPhgp0|ri}8AJhf%tk=lf@>mlBf+VSKA^@fY)L#h3x@
zjY5nxy}C+_{T5=$^#Y;3aH;I5D)rx{-5%iQ%po!pOW$hw at p$<-Kj3E6m)O6&`J+3>
zJqvYAN`dX64UvS(hHL__l2nw#{x+f_XK?^?<HY7UU>bvn7QUFU*mK}-8>>c at Ej=`0
zCcpL(?D3jO-d>}(Qi6ubn;!1h(wsN$!<(xVXTuKOiq*v`QNi_s-X9qAs$ahr*4rSh
z#8dR9EU>ikCKj7d%LoERYgjxU)K&nwnX%3I{hIcSbKamTWI$30(n?{t=?sftAsS9F
zATc#X@!}CvwKlT$2c-3B%8*UHd_Y~B6rh%fRK^VYE-EwN0pT1DQ$Vp(6E^f^0D^?{
z$;6{p;o~Xte3S17)-#Ex#3$PAwK?`BZ4RSwV~1rw{fQ>~0`LBO at PteV<e1Uyh$rIh
zz)*lcXL8u$QlJ`oWr(&@Eq<nHtN$A?On#^)zff)t7`L}GfUzHPi6}$`LJ4Z91Vwoo
z%G(#p4#jY2wNp`zW#fk?LiqM=#|4DNp&s&xpf&Kpplw_dpIs9LVb&*)NbL>dL~OmD
z+?9C|t-wM|kVWRkB4)9-R%O$VwgDcE9*tNaOtc3Ge3&?-zoSn80chi2{vro=dm<`u
z_TAQ;2>v*^FWk|=4ChB2pPDb_6^UQa1y at I9_h&@k)5GbZ)NByaBMgcTt~S26<xCZQ
z4C)q0rWH>|(gS7JA6&9l at zCTl2T$JOR at Olbz?HQNR4;iYBgtQ%d<gXn=L{Nku4%7g
zLMT8paWwmC4qPGPSzmnStaOM10x^A#p2^jE^Rc^9d-3oRRjc%E1^P+&4kQex4K+>G
zA|Do`60g&k8{<?ARHKgCV_IabSe3ksvJ#7l)~t)Z!U%+|$yvU#w!wzjcebpiwlnXU
zgfmqMPFs4q?G*;8DM&?MN9tG|N<?C>31XDhtsanclBk^Y!XE|Uq*CY%UdxMRoGIcZ
z!a<h?o)*-bFAg2&k78dVsxfMqLrYt^)Vu$XnM`gh3G`u~)fA7-?i#~lHQ0pig?3|n
zCj{i9eNvoLu~pT;^h{W{jZ++C6%m?i1N4<z1hUk9XIIv6%iye}H4;G)B0=Kv45O~6
z!)oQaM&H}S#sQ7`s=yB-)UI_jC=Q!VqEx;%5#yVisDYiO*TGKe)7T3hdE#F}=Cm18
zV^2&wC&HTUbuJ}L`T<!kki5LU_u at p+?EDM}gqW_n`+QauCRYQbTWT^|ud=YD0Rp{`
zw60GOJ7g(8{dXen5PtyD{2*fzTi75_foI(6*zMX6eYHn`O^=afUSI?j^!hfG!53e{
zIT1^sNZ^RURp<@V6y{!UA)xJO^LLoV7}_Cz_&JZ*zgIzy6V7xq!}7XDgxb#|NyEC#
zr)Jn>9ZZZF*@Kqe5N;9)cxy*26#eZxsOfZxQcVFDCdt4$G&b>qfu)@y+x?<UNb?KT
zVMcb7--xHgU^T6P2VrAO>GYRG+87zcQ9UZN#xU(S=pas40p{P8DKwbyUc%1es!GsI
zCc>ie@;HTRc~O(#Llrp=J0^W`CpxX>9S6Y*oX-ZJQf<#Ab%tjndy&M3geuU)Vkc2F
zUcyAE&l#fCOv(>D{5M=N5-SFzYfu(>535yiVjC-&2b#Y(1((jP5**mqTY{~{oCN6+
z9bA|6BK5E{4wc}r`l+f=k|Xiu!RG-ySrvks+|~$Pae7N!8hsh1a02d?`_29v15J*r
z!e<jyqpZt5h@)&?LvomRf)90FNA|PK7M#xkUUe&?&&}iJeTf7qqQi|i9%_6~pv#)H
zOqAws`H|Lf7OS)>E2scA>cU=|tvd4u?#k4nuza+{qmkeFu*G;9B at 0!D4T<R`xvOLc
z!&OsRpSIDt=pC}on)+wF;8`{!nyEgytAUJ8gM`7!U>UdcVk<JFfccM~EnMie2NAZe
zNyW0Y0_)X7WBGz+CtMUVWEVhqvOQq>kOJkj<3)7}c*9rGniFyc;aavSnhS(G8`bPm
z`V<|vJ8u=8`O=rb=v2(!f at W)%CERp!zS&d7G`;iLV1)X{3yk=NTAw+?Q?4V{4G^N*
zJp4yU*77<2rF<#f14$jIfF?C+`$^Qx6(dM4F3B92mN$ARk^unHvHtuiAE1A=j!zJ?
zDk1}1QfzP|uv~l=qidIs0#|XMgKxNwhc!wk4S$rR;X?AGW~V0_Q=Fyp$91Y!i(IaK
zq{{sb&f$!fCAL|-lF6srFkGP~zNHR0(Hb^iPX)e-{NEk$ed#Wq$S=6Q&t-Ezy!8`r
zS0A2F6)Hytsrx&*cid32ad3J~B&C&aaI2g9^gb(5r)WQ8iak$;PLg_GuhxV}DzrjJ
zFJkuZfpM&$p%1#p1`R at qXPFpHjgC^?w8f#Ne%j$;>5<6Km4D+o+Wqh%gzYeCeP=^v
z|9HX4E}nKg`vjUx?DYkM&2#wua6cPeQaojV16B6nPXjYAFHugF!beH`MCs83^5W`w
zB`vh2UhA8nj!C at 0^8N&*VRxHLR999EuZ5ZTnF^OPXHY5#LX`xVb_t=rSIGBV5F!!#
zq?$3O;8%KNaNX at W!5Dq?5qxz(1He+nD<OYDM9U3@@~e7kpppGz3lR;3{%9Y;`aAkc
zZOlG{h~9FYhxNOm8gEO_MyLxD;qTTf=l*S7eG0SF6_Kc#6~mH8^?k3e;l-~Mx;#g!
z+AP?*{^AYm`7705fT2sIJFOSl;-qmx=qCYa2c~a)Gr9osvVWF*(bNZ5t1g|`i;(<u
z-nWlF^;G7ZmbI?~G`T7}aEveR!8n>B($mggzU8{`J7{W`DLeEbDR$mPzt#Z;Bc?pF
z_pyTpo3A00w!C!Ft$k$>J!LE9`bc5I9o}2vHplMAMvyc&1#li1Er*N;%c&0p?;$~T
z>EnOt+ghn~^_H&N>`HJ%J<mr%&tE;|zg3=wrxJL7c#1n_4y)NpH<1|S45~5!IElJk
zaNN}~?a;2 at +R`+xPRw7jXTiskbpKrl3>K{nqxniKC8!K=*Dt;)>)!41!mYgaEg63X
zL*g1LEwL$=dn0nl%}2~%as6(BPpl6A6%yUvSu!ov!%Y$ES;G6npOFGfoNlA*^00V{
zLKRwuXCA+rJNyAFX7q&A{@ToGc;aE27)p8^uhp%5$ig-o3x4Qs;#Bv3;mVK2{~@ya
z!%#+8L>7w=8i_eB{8q|&`n3T_k~E?zasp8G$pUzk7-J at F+Uzs7^$psDP5C_$H)QLJ
zRsYj3zFVJh|FBR6y=pa*$Fe7{-TWuip*%f+^#w0X#??Kd8uUp?ecCCy;4U&T-n&p8
zx;67OZJ6RX6k^W#NIoSlZO2*YIkFzyNWOD_^|Njfd;P_tA;G+LiEQJpgcz5ZhhEiH
z2b-1Or_IE!ktV^RgjbKrn#`w5jN0-QSLkrZ6hemz^aV5PqWcMzXIz`XP^&7IF1Xjy
z(x>rld;S*yZ1n~If57+uf$IPFXo`j7|ATLq{|Vp!X_o(gd*o`Z&6t1iElMZg_Z{Ib
zWeOx4`6|7WCBl});ZG0UJLax_EgMm+BiTv4{sVhj`at_0j<Vi`)3BaVZ-9xWX~m{N
zqn6F3depUE7aj=<{d*kx_=nu;5%SyD`{86rmgy^;{_g#2`DC_~Jht}<o0~Jgcr8me
zyKdaGc4{lo7N)z&OX;uU$Hme4OJR0)P{GV*>eEnny at zM}rXwFF{q;*{c5d39uGOrI
z1JeX`PdBAJ`tkX-O)Xh<mBW*>&DIr1cz)1^PxoeLxO+w at 8H(XT&g3<}tCfSArES at 1
z&ZMN{X^SuYZSGR+PrWiSY|YZk<HnmYXF@^zkMjq+l0R=A5OD%jOYcVZPbSO7*2z=j
zT`hkW4=3+?K+nA3?$fJ17JFi|R0dPFlQY{W*+^R0qV<4NK;*c4{d!|~Pg|b%o0mA%
zX^f|m(;VOHgl(;>>B7Kg-qKgoI;5oq5c&$Iv`3SUmjortTM=8zk5mHR_79y^MVwgY
zwXI7NzYs+4H*5GQxwXZrPp9&Rj7%og1bs1!q$zxZadr8)J(iK$#@1V8h2Ktjw4!mZ
z#f~|SIA;=wAZNKKgJ^AJngNVFU$H*K%|^KOTUE@%zD4pP37PCP+40Hu2gz0HLq_>k
z^@8m$dTv(3(O$n^QrS%jr#sqp39<h;W1$(Rb*pdr&(m%g{J)bUjR^UvxcwQp#6PEn
zw^n1W2YSPq1N;}Aqk0YrSwoDPtEk}>;)gnO!rD=5*RYhyU!L68=H)^Y8g|9QBGDiq
zRz&QkAe^?YL}^gXx*_C)Nn1Iqw|ZAE4hLdx-QCo;dPRcYFDZS)RDxj+$S4x@%@EAT
zwsMo67-y&knJsi~WbTy;Bm3kU9M>vnF?~-ic)Aqb-Q>+4V!%fu45#jA<=J;@Z%h-E
z#)y)P8VWbSY^Y1;LnJsECU#k~a&o_KNob;46j}G1r$vjB7y5+uv@&Z9{knGClnKY9
z<}@)&*a8t=nLi+1r5HkB#zsvNyNNT_3}k=35n1+<Nfrr<m96TUHcFn^Vx(_s19t`y
zj>PN at ODwLTM22Q{uU~Qm!X=Z3ohhzQ4JefIl_(Cav-kMcf*Z5YAdyJMiy7BmP0|D?
z30r^5jrxsut<XCdk&bGtcd!1=imL))ToTDyrUg6eh*ptelffEG3j9fZzPCx)ohx#e
z8HWVr0#)3k9ssT>etdiPPCs*RqREFa8jjMFZxl-!S4zp2G9t^Cig;=rgsZi at TyPM&
zbWiT3Lq&5A&s2)u|HNfaT&>X9*I^(W&`UV^)OR0Y4*bhaA3Ymt7!CU<YLy&NHV1FA
zGAVrF#<x|?YVcTBXNLg|R+gzAqGUd}Y-d}k(f?_CX~ftMAUdzjvYrh$FE}~IMnT1Z
zSY?<yMf8w3q(xWp8mq&XnPM#f{K-dM_NV|3%ns`3zb-^Upi62Mblqj3?}NVnmTHr*
zm1cg8GA4VeZ9#(ZYqgf)8pFeNofW^<rtObtao9BAkEhUss1%^G8jYx`7$C~MY5rN|
z(mh at Q@EW{YN007Im9!Unz?53HSFDNB at v$C7x&T6J#sDb)>vFcMf6s8$n12K-M6(L9
z8*9*bu=80L9Q6p+FThA(8QJU}kcx_5!5jTYU1nApE|C~S=x)JocjeBW*$tK}bAp3F
zJC9*Xi*gmv;%35es-TA9^cX=@Gc@!B at XZ*Ttz$IF7!QK#UtOm@*~ULQYjs1*F6pqF
zlCy`=jQA#n{CwHKwj4e?!mI0&MCR;{Z_a+M?3BigLtATaVp^vYCX3#dXfLWu4`8Ef
zKj=<HI%a*RDB3`#pYl4)mMUdqR}r3q%6+jlF4mvQ at O4aIp{zZlE`%B7z-J^07iiO2
zdoY!;8p8h4zJwORSoA0JLgg$A9}7I?F>aS{l2KZW68T?scp^7=<QHx9z-20uJSVW4
znP1$Op&!!t()i at Yt4>ugdDUYf{^IDMxTqtwCyY4m at h1_voRHIi?c+1+QnBY8Wzhf#
z%~^2cU`=YnVWH#fVJCBZWGVR!!lY2phhMT*2O#&3x0NT2*kn-dJ&iMXHXA~anq6qN
z5+F9>^G at UgabYAuI%{VxPf=A&Gm%A5a&3x&(pdf20$A$L+eM92 at cTH{lQE_E>DqIT
z+-DAx at Q9G2l~1iODQw3<#RO0f9FRk8l$2(ozm`zw?kEXMok$#L50d0c)(O58ZF4Ex
zVo}P(@fK6eCCMRPJNDWp?nyWXO+Y_Yd^E!%&jh%It*|J8tKZ7z#%qOSl><0H at AF>j
zhmYnb-+HnL6HkSt9W8<G;GeFJjGDoYeWUlOJT$D06m3|Zdx{M(WIOh8^@B5}avZb*
zfS%Lla#Vq`z(i6ASjT4j2_WDta$Sl5Ip&l=5bF+nf}OW!93&C1)c_;Sb%tH*Ai<s_
z5<kUSO|A^CE^HwCgh at trwFUKD1{(aEvA-VK+)mWe#7XMBA+L`a?lD>Y_{k$DJ at Cor
z)0|QIHEXH!ln^7Y0<ct%{j{^(h9^(FaLI+T4e0`C!I`k9RX_lHVyTp5v2HqL_}0k`
z$gW_Ox|PqBg?kl`J(VqUO)NTRkwdmu`>U1Q1nb7be>LL_OiV>*aK>!8oN_cpWEa#t
ze7LnatM<A`nr5+~DJp5F46hVTRJ;iUv6u^G4Wsw_giMOscLdw@&xtJP(~zdiVl{Cj
zguHbMg9NxR*hC*voMQ-z<sUtJmX9+m)XYI=acr+JqWybfM|H}xqEB!O?X|eDRgeUZ
zUyXvR22B!LSH#hc*|0QW@#6Y~N;E@|G(gBeWVx|nyXzW4$YnH>TS$t+Ifj<DfVaR1
z&ULIo=|qsJQJL6+sv?A;dtu#45VGrcR|Go^#~achUEcXP8c8proFgNLcbuNi6_e}a
zpmj38%^{;LlnzR?o2F>_aT+t%0lPjQ%xt?VhqD-xj6HY{PT=&rZbQ5vozths?HEeC
z*@_61z-aC}xl|S+FElU+b{(|-e3=(J08VN+q~(p6#N2Z2jqTPtHj*4&0?q-!;Rk|B
zYr;rr_bVbGw)kob at Zb|7FL7i}kfSK#SO_0w&xf%jk3G$^_vm`q_Z4*_HJlV)0-rr9
zt1Gz7C<Wc{Nja6Q__0AlEhe9gcGVqo1X7`?+g5Z&l<0ykL59%20o?rhH7fl*vDPZA
z0eya1qUA5(r<rKk#$1*NJZua$p-`_ZU0P7I_^25#`e?OuUz<~Q$T<F+v3#KO!ooA=
zg<%(q`r4sOSE!c3U-|7vIvhA>jHAqBiiE`no^wkyyZRn5MX#+A=fxxyp{}CdQd8%9
zrbq)oW2Zu1eGdt>W>m70p_y~`*Q#o=3=ldMj#3~x<PdXYAFb*+tgt}v{i%aUCr4%-
zn5L)yGP&R+Ok_3=vn@?LCAWi5;BG>47f1%o-2<YBT{@YvQx_itAuKuKet)hVCd`OU
z8K(#OMq|y)xiI7L;j5=Qj)wRF!y#r~?8dIHs3`#v)yo}&s at w$D0391?Gn)@pD{4fj
z8?zCYD&%c*<TeX=OOUhxayTLw+HU$BHOp`pcKuh>(Z{4Ll-VTJ5MV|SddD at 3)A?E+
z5Y2290DsME$4 at iI$VuX%Cda%MW{$kF+ztSSHx at qt*i0q^^}voD!>KCZc-_o3?%A9I
z0O41t7(LWw|Ez41{qWQ#m_sNOztY~tN5}06Co#Nl-GQXX at Edwd&AJE3HR0hewm}H#
z*u at or{$v2wq2wT2UpzTS*m1kj>F?xF at w@<9v*6vsa>Xxx6~PnOG1s2v- at 7s>^NUT~
z1-5XPj%85Nun4l_z3wGimVsqae`?#UeJ28=IcHI9KjOX5Y%FMTtRw<}_Kn0>75AVT
z%hJN~Q$&k{eJ>(-Fay{RHqqOskL{1`AVo%+=-nmS5c2Z2s$vp?=K_?iQ{QFkKbFtb
z!}BWUU04Z0{s#xijhKN0*1JNfDH(rc<#@s<yBo7x<J3*Db?vaT at 6aJDxBv!AS^zRb
z<eSY)->4vpa{{G{_Mf~#!F)F$mC&xtRvFt0INLbA6de>#Z{A_!(9Z1QCy@>4s>zQ(
zrQxYl9ZiV^%`LWg2m3t+l3?+r5EY~Wu<jMWuyvm`sCaUvlBCYHCGT_)aQR~s-j7A0
zDe_7|Xz+DlBT3)~0WYq5 at 4s_pWdczTc}FkfosQiuC?ZllyYLR=>nDuLA(n)Nc0)L3
z0Hx#l$ADqXoDTd`9ajE&6k2lbJC1*zWqJB&;$I^AxDMsw?Nf8KnrZMUZeEyR<m~#W
zjJ{X2Q`NQMvxr5Pi1kJp9}@otMUkP+oA%0Hz&|5Xe at Hu9vj2dyeE1mDU#2=%;syfe
z!bYL14^*%|Wv<~Cns%U_d*{4_W#YA8VsX#rc<^UAU-#&{#K2ydjN{e#j&yjYT0F$4
z at L{8uhZb9_TLu4`mHP|~kRDt$Y>Vnas5Vm8DqP}t#^lXNek^bG(m-9ZH!GoTCW(l$
zCe@*dGMNI;SFL($X)^XfcM&9r;OTn$*Y3hxpxIp;c#&v{>6Le?VJVe{4o62inap{v
zwYjt|V8LIju^@`E_@!1z_EZ}_beCeNX_sKZX^8#^3Q`<~bgIZ1&s}kbB6%^%v71%)
zVPpU=KBT!Q)@cjL^`-i_qxq7&nGz4c&ko?S<sUwaRG-nCksA%(TH^asUY*po=AR<+
z>u7i5qAxI>uxW=&4%WWEEX)hg6j?C+JfYM`F=0eoIW){Dv9lF7X2%-IZVy)$fa=#k
zXYqq*smV?6TnkGPrQ9dQCBSd|sL06zboEpyUiEA!{jtGTt8PS91VKn_E}+fGS{*$-
z&e{|Gz9?aVJL^MTNZz`&zC(3 at x3zm|%$NCt%9}7 at eDwAHJ?Vj?_{Ad+cj+Fz8{?3=
zfNUs`@|wq`=a+jD`*2FM?$UHZFZToQP&~%+KaKalcchuwnVJ9Fc$u00hw(Bq|8I=9
zSz9CFpYg)d<HvA{`f?0x!?|F7KAejtu&-;5e8uC$%+rw2&cq>w78F~Kr9NnQL6X0K
z#4T?x%_+qxP5~ha92`SAc{dwCqhq7}(8H&;npr&pez`lmET?N3ztQ*f&8D_y?q=nF
zUm*9^M<Q!ROutWKYIVI%6rp(;?G+zKDrG)yHqN&6?yQSan0I-@$!}p-wyt*ao<`m;
z*!(s>LL+ZQUJuLBiMbEAx;~#*@OgJ{R*F(r;ylp}O~(wfBq?l;c6Mu}h1%;25TaeT
zZ~d5zqM0?nfN9>eYqPl8e3pLvbg!HbW^4MjD{aPN-FK%a0?GOE{}PAw;UW4XYJhCw
zU(ftPB01YQ{+!;`>ScAi`n)hc%?s|_y;>l#NB+}Yt}G{OmQl2Sx;tn+U>6WM{2$!~
z_0aC;^J)T)cO2z~;F8GoJZ_bDF`XayB=}c3{nK3o0Q8k~Qx7IOI7rYm`oBi|wLFWn
zE&R}#R7LYPpNY6vu?PdUzA%fAku7zW{M(e)XeF|l6P-vIAZvx~DCOnD_IvR`DPgxN
zAa`=sQ9xfO_QV`=N)+K_6M{4Wlx{kum~L)!l)>tDtMFFBts}>GbrTk8WH8fc#|u8*
z2rts^(<<|7=dHid@^TsqcX{+uEY6EKEYL2C{Xv3^g{J>(x7YgPDc2l7=|rOuMK29-
zk1Uw7@=?*1Esy)YwnBCv|9ZQYZ=b=jMZI`Ff<!#PxS~ev>cy~r3h)Fy?Utw+D0z=s
zrIn%(6x>ifW>rw}MJhlNIPq!Urq*DCiAw4E7m7dS2mSec+y<V>VG6;!3t at QyXYG%A
zygi*2a=?h8Xx!L4J^yA7cs#V(*NcUw^jgWKK4e-Q6Nc&<*=U;hkn9qFe!rYvlU)9J
zfxfVH(@r{+HLMj$s15t|{W{zf+!(Hl^XIgU?cmEJSIuB|k5z4M at TwFf<O at F>Kpr at _
z0=`~zNmzg6%ARQ{phJXxSCEzf`Ko5J2D#i8jV^Y$`$;nv;!AN;7a!Xfs!e99>!KL>
zsuM5WEJG!fGUUuv32(u1J}$-OV}C^;BaHO8)^#5(n_)^1BjRfCVj%<#p#X#u3HAdf
z-fuzGQ4LR?NlN|nOV6`_bcb+f7WunL=5Tl>PDTNwfdJx{JbHjRF>QD^A{+Ha4}>v1
zRZ-lvzi-CQ5Q{fV$eJ4iL!^~YOKwy at vQ?swwnf*OvIp!vjCz_;WB~@`R9S}%Ca^!d
znb)KE8}Ow4fNc{Kg5Ub|bvoE%S+ViH-s~(NZ~ve(5C#mAnS=kl3<N_%VkialR>dB}
zvTa4YAlng~5d9sL9JoL<L at X8#O#vt%3##WbA(#~g$GdUO!(n3H!Cul--axmP$L0j6
zUR4O|8OLi~`X^hV{2*}{oY0VM<+lJq4-JK5y1SSn(@@y_Z9p$d3N%misVe;(Q4i?2
z`C-4{S7GxPNnStJ2<gr5a$6ICjP;=*QcCIY5HBJFM4v2G2|Qhhb|71qp77#Aq?oQ2
zs6;09^=1i at r9=cf%#Y$`c;&)thvfBjiT`RmrpzM-K`%O-kZLizXV^U<MC8CXfz%R5
z<hNxY8`9#cU<=a8s_d=%Bjs2(zzZ-|GjrwIZ0x^lsBjIO+jLnhJ*^qW&b`;cOK`Hi
zADz`rIXIH!rxk2BmEuT!c#V4n`AAO}$&MKHWe`ay at 47;_ERp;8zyP{GPI4zO at 1?ia
zrE66SvevBo+d1$@$8jN<8tKQ<uxhg9&C>8bsiqqr(aHqfJiG2u_2ri$&=uRa;OLj$
z^aKJ#^G+r+EAd1Gh#9$&N%Ds-sT at Hb?VMW!(t=lhkpaqhthwdwP7)i3uq&iw_Rx~D
z3&U_i7jtv1NJ;wCv-;-B!pDodyC#-`M=alJ)mn_iLp!s7t-S558wM4Hd9;?CB!F;>
zsSoZ;29B|r&cOX|I!Gmmfq$~ZT^$V5=QvQ{Es}Rp0{UH9u$zG!=x0A`gk9~1X-?QI
zm%oh6o0Ayg8w`fqdRZ*js}`BC at FA2L0hWW@$Y&afY+oL(n7NK(#g^T)Wpar5M7Cr(
z<^VJcNdv`o`x;6~U&#=U!lvkW0+^wvj?Afa*B%6N>f=QoKR?3A&_M+c=nd;1JSi+J
z*Kv_Qs|8v8gY(#AbuK*w?FXO*Fh;tUmx-kpm96Y~A at R!nE|h>l=ajddxR;H)8(e0~
z3u)>N&d^3g$MqJ%M)B<A#er0(;!>$xCNU;FV081gy#$;|&ue>mebtO~JU+1^uB*@_
zjii`e1ev;Q!=e{K8 at em*zU#|>p#oE_nVd98jRGJURXm}<yO5jff>e;8n;cQgz?Q>_
zZH~S*^MNVhfb7yDk0|WCq$*JVetg%YyjM^amTQwU6A0JbM&e>r$fhqYvm`P7xJ~(S
z%-JA|mYB1ma|}(()CXl83uymtll3^^wN358tJ=LDeWF=3_W=RI(W5<o6r{@JTxXn>
z?Df(;WAZ9pJBTugcXxcKvvKp^TFZzuP97IX=wLm#i%+jeT?K*UHxMjBpygqoXkH_1
z;)A}7QX|90*%ecveH9urq(5e$5F4hUElN{V^6xBr#Ge77+z4%Cx$suFN7K{d!Vw(?
zy!ql2!Psih>c@~?R at 78(tWj#1b}qby(5Mn$Pt2Jp<s&^!OzG+ek5&C_CwW2`J`Bl0
z7*-flRccZ3h{?s)e5aWBTPc=BcRZ&M&F*Dt$AC3go}6aH*_&Z+&><hTI{XOWUdgbk
z)aR7qu;H1jb0P841hh2vQ^ZqFfR0zPdJEcY=`TH?WGY^MSEc4rH*hNn4C<- at d&oQJ
z^t1eBRIOKJ&`A^RUe+g!ztj*#i3HbcPaNZ5>ER00e at 50GI&kurj;ySaZk+LVK9Nip
ztu)V;x`%WBq~pONKntUQ(okL4c&p(h0%pth4|*kE3vY)ChS_3V%e&uQ8rZ1X1bts#
zi3wmdtkHRXN#;4ozedC=uarOsmRGGo__tn9r<2^?mYNXha^>hjGELM)D{(2Ku=zAo
zM=+UD-;0E?AO|Y$;<%MMXk4R4!>kFQB<XZlEFt<6z!Vx7o|#Cqf${B}`gecibzZ_J
zy3Hm3lBUHp*Ia>E?u??73r%FwvH=b|6|tOEVB!|P^i709nFvuQo{3ZklZ at j`@Z-Ko
zs2X1XoTgAF(nns4+F1JLlS98*3xRM#m!f@|FJg1%n2mT{Zdd`-<oU>@dB6}P=Sj2Q
zbLLP1HII9YswGGwItahvOCxiqBu;U_WY-LPUnyX&J5)9VG_Jro(#<f8wsVgz7BhjS
zC@;~7NJaqf$56NV$b7lBzRVms<&)rN?B<1Boz{^PCyTHpd%Ko6irbAL(o6jv(*E0P
zvm~slh^j-+p8C=TBU%O;F}UlmXvVB-^d~XS)srcSKM=a at P7@bZ`X<XJk_`zX<iAyz
zsm;|T=K7#sskv8wzvL&Fs$Gj5&fCA3**(t6S}iCydoLu)aixNoZX`j7V1q%rhwe%J
zf1oVAeNsd4ExExN|BN=%p5emitQaS0u=K{1CNHpzf0pGXS<Avodx&eFY+38rUs!gi
zmU!{#sqEu~N;1rlzV#CSVOKv*KldWwg!slyJ9RJZXfCkI?}aSY;tpQMShl>Cn*3CC
zmdgwZ1X5`d*ulmeP1XiVwhQk=F77fiLFa!h-p288&DZmaEo2DC{oPk0ep9}v!m%L1
z6^6+Hl(iI_McBld!4u1aC7x5OC>w%22cCz{CYZyL74M}u>mHj2JX4qEp8G^S)gilc
z+DVm*54map_eS?l^^Ed4);_F6%jzPVn5Y!b5B?>Ly!q^-8dWHJ<g`BuUeTgH8PZu=
z-)b_qfMc9b>ozE1*)PBh75C;PUe%5*#u-cCv4)LMiOv}a4no4ABLEJ3fz?Pz&g?L5
z2eyFr4rv;wf~X5dUnEtU_}GIX(n4AFsDGh=T10XZhUgQ=d3p!#Fu4mWW6d@{{R<m9
zX4zpE)L^r#ZzP+w=(5c87fd2P!?~R-Q>i&u-&?AB`QA`#&Kg%LxgquSQkU=5T^fJ)
z3e%a$DFQbKotH#V)iyN9!);a)%n8+zma8CG7M-iCMaSQWE=g{z%q5>+1SZZWu!c8J
z_{2)!#>KMb-#@Y{3ZFd#xB6QN{<8hNmY at Lx_qKQZb<le{`7X}x)0W+<DLH<qoKOM}
zr{J)eoG>9VCbcY@&nWF?(=y20Xx*bscc&xMyOgO_0O at H_cpt;H#_zU^sH~CigwEL7
z$Pfe&{AtJKbzy6a->JC0Eiamr+cO_+)7*l+?FJn_YIAyTy`dR(MIR5hs>#iHcxg6D
zF9KO2h^XQ#uxj(7_8S873eq?rL<Li0?<XkUq)W5^YS()I5xp;#P=4KE^VEFJh);JV
z->#<&GIu=lSnD2we9qJN at tv{OmwIMTv8`IeKy83_6NP(&cyyyuCN^CZnV?wz7!joI
z5(}o1J(=7%HuZvXm_t&w>NBZ$h&be8t-ExubG^bj&Zj*#|Frk^pnpVpJCTpi8=O3{
zD4!)39>rM-`3%yOqtc2xCF{D{(A#N+$=Lz%T(NOt!b&=u87X{1JmN>!7RnS1CZ7qT
zxp=p+cMYxENS;Wg0=E*=7+Mex*_-U_WRB_cXABK7p;{Mz5yC at ta$c-ut&Rp~y~f|t
z#_#LrGM_91-kVv#5 at kI*qxIeQPjnwE<6Ie<BFf30ZCTgQcBEU7P;!IUg4KR-^I2Is
z$BS*oQfPGWZv`g}Yz{&`1e3KmJ?GqF#iz8+4}RMIq=ZE8`QX+7YJEYY<wn5M2?f)m
z&P!Co;SYNPXiYJPL7k#H?<2iuSaJ at 7j(4-yu^0Y!k`*O$hu<^q!n2{E8vF%w;ZK18
z=5tUccltT(I%N5iV;7Z^`K}Pt1v}js>M`Ru(f7yq2xFf{S?*a2w1H(zlha?+a$#2z
zFkhG03h^Mg9er<E*Udf`2H~^MiFIG_6P}g)+^&!Sja$@M*~+R9H_k4MapjoqGU-ws
z!bTRifK?qdN0n_v;EuHV2kum*l`+XEO8%hT)adn6j-F4xK(@ccZAkeWGw)zupR228
z?7=k98paLF$uzjH&%p^fN6Kf&#Cx;dwbQJ^*X8Ks-yJV~;3Q4Zkg{!7`U|y|gn at _q
zT2M5)WsY-M;>Up?(h~WPu2>EZN at 1(X7)TtA5Tpl+<6GZ7-Y%rRR>MM48XlJ)M`7e=
z`u!UL8~io9eu&SFh-c^%k`Xbm1JgoTXZ7ugQD|KE2L`*1h%{c9pf0(=dTiqPza=%N
z8eb*Rtc3fNy9Ms3e)OQ^Xy<LXh)@b34baB<X;qadI~^N<9WP63co{7#IjSAUH9c`D
zh*nU}#>9k2HBWb*b3XK8=b at _W73g!ovdoLBq@@Pr4u*V=?rS}qpq?O|t9*Kf^Pzz+
z3tXK7a|Q^y)QYYm=yHJ5YKkI~&gdxd$|50QfK*6*V4SaHqZGc at _}c9<WeNAK)S~qn
zMDllu<Kvp-xORP6Hh*6;+Y{5=H2DwLq~y|62tLD%=-J(&v+bLkH`-#(kn5X3I#)2-
zgif{^(uMP1X#6T9 at Tl(b+$dNIgsfo?45+s?CGW<T{6m8k688wxRGDLiuH6Ba6)h2&
zrfv5K=c};c0Vp})6HnOh7|d6qL+!JU;#s=x&ZehDX0Z4Q$^6EHY|TlAS0M<}tEgD5
zKV)J)IT8<7WR6I#({VsK5({Na9kjnh<RWv&Ebbqv at Gnx-B~04P>b3E&Hg6CAB&&24
zDLA#g|5ko1?WELJH0S1eLfiYm`eZsQkJ;by2H8etSN~x~C<&HYo5w7U at TWkK@XS6N
zLv9Dy-pEq*0PA1MaU?&3gT!kG7Iz{)hlAvJgjmT(Z9`)*m5{{+aSXvB479!>$SxF@
zV8~hlm^eQ}L=uQBJmz)AVh4jy=L3f)&J at C3FWMtqJl*s66A^$i#x}l-J2$#xh(~@*
zpB!w09vHh5#m5Vn#o=Xv_hdYeg-XA#(yg8pe^w5lw>!04O7!tj)PBJKi(XZG?ifCC
zBv1U(We?LqugCet=KZJshf6!C60Ko}&AK1r5=AT2c%b^syY^t?jK(3Dg-6+lg8QoU
z1~(EODzh9-W~Of1+tR|_(mL<7?(<M(03?|{UBI at L*}G{Ine#rUod-dK&Bs3`5OjK7
zWE{PXFNCq{^j_I>ico|Fq~)t9|JvERLzpff=rSPSxRpC!0G8!}CVGGJV at WjY+{YgX
z<sQ>&-c{ge(vGDYj`0`<uwEvcFhvgrVR8x5(C8B6-zx!|JgHn9^n#nohj|y7!wIjw
zd)a-1^iu_o*At`RRV3B5QCJ!<I2J;_6+jKsiVaf;nMf0gdJvmhb{Ir=48#eA2t#W?
z*ps1%NWn}PhNhVa$wgF{1(iX75)~3+Iv<fC5%~^tDmanQ8R?oNBEPb0rtfYx`?JRe
zTa6;?*`=MXVK-a;(W>ri*!WMN^eJzETyB#~3-z{W7UG)^H6Jf at C>x>Aprec);z|rW
zG4R>3VJzWf6_NBx2cno-ae)=nNa*`;++*@d!2NXHcNBnOiJSnA7CC|G1;~*5i2<(=
zdhVK;NID-GGcxD2F;OX@*$MoR*&CnroB$&KRR-XO at 7+6qfaPQ%M088oy(p$@0c}HN
z7-9x;Sosnn<NL5*+JcwR)EW;VnKJoMR5h|8le5qi&tn~)%_t1(G|8g4xy;f3!`NE|
z#}#YaqK=uF*>TLw7-P)LOmWQ2%*@Qp%rP_DZDw}N%-qK7WWPGE>h6zwetNXJR;jh7
z=9-em8k!pLIJmhI=gs3+HXvoS-rYc6HaaW1fSw96yzx(7Q)c8q#KWMj<g*Drn!0x?
z|E0CmcVhci7QArGvh#JL=5gBS8q;93>Svgipgxt7N%v<DZH>&s;D7c|v~*SvlN_0J
ztQ(J|#n<+q&~5REf{3T1zw#%uR$^4ku5cU{q;nh=!sN*1JQeHHj~(i{893%jf~sct
z`Cf=5Y=eUTi{Si6T>h2xuraeS{|~|W- at DCN{#U!r2DR7h3!Ck#zjf^>jf<2s at 51`*
zdbUIotSEdPu9tZcogAbeEn;6Gdo&fRiEF-Tcp{qxY4aO02u|c`Dw<vFCh{H1>$Ya~
zCG7kYCR3gz{xLgzzXn(Lg7fO)a{d0*lKU+I?&<M<Z6l_J-utei<yK2xwPItT0<LZl
zJBo&FZ&ENXC4;HGq8aPY*~k7Chf(g$JA&uvQOCv~Li(b0?RoEy?vNH3vVzra&ZCJm
z)4lgD?~VByq!6hFja?bvMeqwm)L?_em5&Eo9CnmEq9ggT3DL604>x43t3^>LHin|j
zN_c}0qQ=*V#iK*020vTF2R)9f2#xqJ5+6?Ym$l&Uab&izDf%BSAr&9N7zhR~_bSh8
z{5qa?PS;YVhI8)yIdWQd&2BcoD>ja&-Qj+s36-vI&^whBt_mr)OVtTR;7#{0L8*T#
z>jQ&iD;NsGUfKiJD#MxRsJ+e+0Uk%hg>K1ld}&xEm=J+B#)sQT_{SVCMBj?2&n=ff
z`oG*2B!<6qhinf{xKFPlAr7_4s4oTESBuOEc(7w?vNb@!Faz>2t}3NKjEoQAudrSw
z_FUry&DiB(#_~U3^l*=VBlVZTAr}hnGR#S5qbg}<>+NIAv#3jxzq at ZJWI(H8{8hz$
z at sZf=f33eYsvBv3U`(ctY0A>$+soKs1abPvZ}xCEd`1+RWU3)*-S@>VqIdf2XHyoz
zvg~_-rqZ(%&C5)UK!q3<NmW7Z0uvSXZm|{alXHtBBjNGAt}`XPj)tu|Gfs at W{G@=B
zygQ4ck^|Y-NKkPM<=PiL3PC|Q#+D_SR~=0-3~g`<li8mF6IddyzV{XN8VRb`7sLcd
zeTnyj={86yu;SH1Bi0y0h`&~RzNHa0koQ1ZHhH{uR507P4f5LQ=-^W%{?1Ty%G<V~
zf7?F^8SPyPt2glD%$cY6N{2J;GnKbb2c_Tp9z9gb%cy<JQAuy(@~4~?WjZU^YQQu}
z^$Yi+P=+_g2{B(^BwgtrC7ZI>YOi|Lc3A``Xc^Gc$IpBn0Gl<TKUXSMKlvM{pfo?a
zQWHN&8adn`E!Q8%sJbjnlb%VC$e?q{6C}Mv=pEGnY-h!k^Iv3E+B$4<a)5mXYL at a#
z9bP-APfkxf&lNW6A4pbZx{dE<eu8UAaMy4;7!uI+B8Kss{yFigA%-d`iZ$V#kkIU1
z`Ejr8Xu2YX>Vs=V&U}qrcGLuZt#q@`buh2ie;_ at Q5SA?v`pY}Fdos6KOy|0EsE at QR
zh?g}<7qtYeR0_klEaa>|LVlz8+KeUmKWGXnKa!7vlP+bMHH$Lb=4M_ME0S3<UzUku
z>>Dg0Qzz-*!o`Kzwd42b>nq7rmNR-Wx3^g5NN?1f_UO_>FxHK4dgT1J{qZ4gQMzhA
zg(tC<N^<5BVqB$VQgsJ3deKh3-K#z6AaXLRyf|deH03g|=HAU6#f<VO^A+KQI(WG-
z3BY|ead_%h#(7B39V^vFk52HhD$SDWL%BlaLzfIgUqdZ0zFg0E9aDYRS+y--^NZOV
zEJt~UscqOKCJQWIJZ{X<q at 6yBL-}Rh!5wzGDZy}d|L8;#V~)DdGNyaBm?f;gi^p!k
z?8aWzu3{n;Ga%Z-S0UDB0j3}I4!le5RjtwkM2oLHcGRpX&pTxZNv`-QRy=T=J6x&b
z3b9*o$B4iOOhe(QV($pyR&HM-M|h|Qg^+LQI0?~~ns%KVpe8LwiTF?OBi*EUn2C#t
zm&gY#;=@Q<KUY6bFlxNCfoa1NJ*n$9nr+zEl^U|2PQi8lslN(`)C2bZXh2+H?B35%
z!lEo{3wNV#D)7l6Gf3zbg!HetSx~bg=-vM052Uxog1x!bIgP2tAcMRGd4^NcL at Z_Y
zIVvPN)faxT18dC(G7s#Fj4R^wrG$TI=wRQsIX{mn5Z$h79Cz^tvO?WOPbES9R9T+Y
z*oZlcfXhxfvSu7uIq!e+f?qf#YwW}`OW{w`)gx6CXbK&`h|CE(DL^+Z9w0Z&<W2BX
zryiMPsgpN*z!z4(cQ2el7MKuA31mLqDbRi?<MY?xjG3A%FM$=C%;w+~O#@39y|}Ja
zKm_{5=p)icH0Hg!bO2quaE-61 at oG_YfOUD5zZ$VGUVynPYMYUDW&;_%?`Qnl^#U?j
zNAz1OF4WI^S%4`ZRgR|5*>Y>gS*}F_-=;e4LB-HYh`Y!QNtrrWNZVNQ=9WVRejR;{
ztpD~H#j}vn``580>iPrJk#z0e?uC&o4O*>+450s!Fy^sRVDm1(&9V>pK2P1uf{34d
z%R}X&c*(b}+woN$r4o6us}C13v9ZTDkCm$&K%$LOo$9&EHp=0*R06sHOW6Gf;ykNm
z%gNh;rvhPf(Hjgd%bGhYDB;<vlhR9}+nPBqQ8gLE2P8*75ydP|&|uaGRlclBZ(BZF
z!FMIk|5YYXSNB(ECEbZRHIpo&MU2$$o;g(`Z+)WjRcG?e{JDdBkGz3N(9{JP-G0oe
z!}zJ=sy~QOi56Y@#qbZws=c4dnxS#7VFsFe667>xbMvTOrC*S1#D)iF6_3LM;<fx9
ztMqgRiMhkB^AMoE76{_7dM>O*p<?d;7z+t&F|)nEG|<`pnps#H&M#*tSlI4{CbP*B
zzsc)S(;nyxA=$Ud)TcUKEzkh!1SOf4&D85fZw^3I782xb!Gf1o{<3PRpU+6A0-C4y
zJ0<$Gj|So3sVv=)WiiYb_tD;VQy-{3Te14Our4mc?3I~DTcF9LfpKD*8%<?fTfYcN
z&WL<kpPmeJ1ug~iobe6a5&cW4762rtAvSJCA~?*OigW{SikX>v6q>p6m#<Q7L!^H+
zb3B*<v(RAFJsb{B)-T@|?dblO+JDz0Srs*624dmWFo!}84xude4~bXe;D?5K+Y+Y{
zLvws6B=YrZ#IR(lu=E-=ns72~!5^}vZ7~CJCKJS59c@|19Jn}fz|O8A5tFCQoNc>@
zv&0 at UI629Psw(gjq{Y?}LAP~$ui~jUmuhNGgS{5|{6U|Qr?K`@y!0+hxpS}}A|-*N
zoopW@{u)3e6j~tCsyi$Os1*~2bGQl?hFCQCsx&U4v;|1Xf~Nd33rB5VH6FU|1cFf7
z@;nF*2b=ut(>{J|#9U@?W`CQY!SQ-POg@{uc__U+jIblqqgFoLz~K?-ApFdrkaRS?
z_&B-_GMW2fu3>1!k^fci6EtCDjU-pjwNV2L-yvOAeOEgDe43uDJhH_tjRfCN>;A=i
zh-0|&tjA&#ewa`j$ZHPMv+{9mq61R&S{b)-Nv(CE$lQ41G=6QmE>+VSFNl>;rbPzS
z2`p)E at Q^Crk-0ktY9~U0Sm>VkR}-e~;@(!NK&PMx%lLficWw893DEDBr85+z`~+B8
z5;6C`*BMs6M0OD(GW)Wo$pN?81K^^w=F?BRh-8&);Ws;~7?SC>94mK>ppi|-=+n<t
z5Lq=#@n<yl)fqoQVm}m#x at 5HgU`81LIHiK^z$1boNT$|qE9^(=rEDiOhW4oj$Z%5@
zuSo;W44&JoB;VB05YmKAPdY2~CZ1O4UpEAM(>7P$cvNf1nc at dcg2#DHS8X5}q6tPD
zW2}3 at ewYyI_x6DOpdcjXyYe-U;mysv<Gt#mbMt)~0Sgo(j7 at B~?iq4CP25}yEGw1^
zx8{4f{VLS1Yem9ew)W)_K9L;2`QTQU!fIpJ`BRHWJQ~H|=fGRIpOyZZ!1H<jDf<G)
ze)<5-a8J9l*_{qMj6w}vQV=L70$*5<*kz(XgSp6-KRq<<e0UE;7R+Bz_xM^X4+qL4
zfyMZ?8T8cRLc)8Y^KIYLBSlUF7TIDxV6XtZT5vMHx4VpF%!WFpyYkD#=bp*w^_0z@
zb6q at TUQWs{vQI$|C|Qj$5CNa?JLW0ZtNgopPVlV7AIWY<z0jBoxa}FQxWrp4LwYg#
zTyQ{>SMkG|*^R+Mu}G7is)-|uDEqAC)<ZJW*^e;WMAW8DTn9;FZY5AS$WKrJz4k*@
z_9zUjdYsQhE$$MyL;P|*Lqg2U4X%_!G`Wv_BLddK$i$L=41Dv)YmV?TkcdA(v<8r;
zD8Uf6n+R+)OD*rtM1Co2xIoEr`fTGTIDWR#qx}0xcJS<}Zbhvl)Mpz(wr2=p6CGN?
z$Y$-3GMyD(?*SOB3r)8ES>kT^^3k33gzAdu4(1t4a<+GxX+g#)S!@vy0iVDc at sz9a
zdBe${H>_&b`P+OztU}cFw|TrheTAw}iIr{%Q4adPEWcG>$(eB#x_5p0m{!cFPd_BK
z*1 at is%xOV-usj-8{00tcI$PDt{orlxLAofbndakI^ze at fHkn4jxwa+9EJC18(!5=n
z*?^b~DX)2YVW!L+^M}1Cj~-at1L$4x&|3w|(Ooi(!ZT+7GrQSrAy>IXnc9+M=p_4R
zGbg at suh8xUOemhu7@JXcPJ|ar3>%0r;rT at C_L}iQPhGZs+f+V=mb1TEpxK^Vpc$Q!
zk at Yj-I=*NG;9TmSI;vm<w&Wk#m-27RNvd<+Cs4xhs5!pH^tCBR9~~$oV&v;m{%F(^
zq{<NbBtjBr0;Ln?Wae1~%V8vMI!WBc4PCvc<*T;f%kcT!SaNo5x`pV6UkAN^uiA4(
zTaN%v0el-(QPqV8vPvt(ecp6dbE9)hH+9<4dz^vN98ObX`||A45<kLzvQOXpAFwl+
zgT1eQHGkXOGa4i~%1rC1`T1lKp%;F=Ra}964Eb~J3d$%|-Y}`>{~l*pQiO|m$uW4{
zLzz<gU1Lo{v=L3a1WQ*A?e!=4Qo!ce+q4l=iI59?a6i?OZ%#x#@)J}kV4z#j$yyfy
zQ;Fj!dDgEE4qUnUDfU0 at -3K%oSDxydkJ8<d^@$2r=~4=O>(+9?&RSG_%d{$#!&WH;
zm+)bK7&cpgnI|(>I^0r1pNEiCVM*bjlyZ#;IL4wFB~<>5lGdNLPZl&~0F!S|G-$Aj
zVn!zTrEZoAuXbIVh?30QrwO^rIjY}^pIuh*crcLO>t|X62^A0HZ+lB5a{PC2x#L`#
zEKl32UuDU}vJLJ>rBBG&<^`Jh8r}RGSg3Bvk+y{qW-{RPORAbi|J2Buo-3FF+1Gg|
zYEIcF|HNT(u%2sdE$ozSrQ5`$D7J1jiOZqtE+4N*L2D5SWqIDMz&%({7?vV|-`ZX)
zD8WKO)i3iHZ$<vOyZ(k=v at v^aMlpK5V3{z!O at +k<uG<N*Abvqrg5mGhXf1Eb?*xKK
zTZxArVC&^hnWxl^B8w7OF?|pO$$DR*ywua||5MWetYW?`#I{h7a~5R6E)^#)Vql5g
zk4s&MNx1emazX$ZDhq_vkHp?3Dvsy2e2 at V#ES7#ZR_GY|;J}=TLDRGgkN9O|S-mIu
zY|!qjJPLr=r3ZZxhLBCR`GdkpVpMW?gs at -e-PD+9d!nLHPg%+$LyRVWCc^<wX!waU
zl%Hf{MN2MhSn(g};S=BVaPDCS3e6gL1estZ6<EdoS&{@D4a(ya55>c8$Q&5-V42&z
zsGq}+RLVDPmDg4q*kf6)?|0?Nw0W~U`tMO2Eb(Mr+`uQ>X6U+Z0vj5Y=eoPN$g;lj
z0vM%Q`3SMYaM{ZEJv44r6%x{lp_3q$(7$C3ZdHZzIF)*C{7LHV6Oq&dQo(grPM5IS
zYTGy&MdiVq9PgCx&g+cYZ5n}mk&3)N;r5rB at 5*B>FXIU{rPpH+MI$bn*(OkkW^Th#
zm0al#5T^|-NMx*k$WpzpOJ3xaX2KvtkyvwANfAsb2 at r_a=K>r?Nl84fzJep^7D{rZ
zU`g0uj}iqxGXtC5`UT!r4WE-{=pJx|DBctWYxIP~-cUDBn->Z1v_fW2IiBopDM<xA
z=NbA6yd?l!_Zj2bZSIdN)?BjP+OOz+pt%sVm<>;B$qw_HHRx6yy!-DP3L+uq6xuVP
zli`TJ__Fd*vd{@e%DF|9&J||zaPibwSv7zTeNaBKS6fpRiMK$9ENRZ~&|*$IWvxLm
zXX<N~>5XP<FUP-5bDC1?vn+VB<xjb&$SeU%ho`k$5}W|EORUkPz)9X-e?N*)SzbZU
zEtmyDHzDC;x1AFtR`-ytBMz`mVcR=A-%XO1^f at 2dkeub4CGUm{>queW9+eYPs>RM?
z9X8HtvmYihJoWvubD^^7&cCv=ipw5K&D5%rEmnhT=UI0OictvJWE3Zz1)z^PV&mW1
zj%|{HozEzHzr%Ay%bgd&vot!%IQuEFjoU^OxlYa+)e>swdP(}T(*n(F1Raf&5h^+%
zXTmhtD<5#nzcY^oFX$TXxYsb*wJxQ$tXoL)KI)<=atHq6-vEvsG(@cpm3cPpsAb1a
zlgp@|6NgT&4*Ltfgvzdpc~0{!5H`vQA2-(Qx<k#_wFVrutP48wULp#uHv7p&AC8*A
z$%TH47R~%lwr3`Z at 8z1}em_PaWFmP4OyMccM<ctt8~e;OBb_*1p?4vUv808tLrR8B
zNF}H^*}Ra7fNh}tR<)QRGBV;_GyP7nF_yYJs-`j_QF*ku!G?UjTyzrQ7jXQ6AfhG1
z%|Ia4j0bdN{ey_<9;YF3G){q0GA{Y)a&pwsX-RpbsZWJFUmKV=VzxnwknwAHNT*gc
zdd-C5&r{>OIbuEM21xl}0GG&thc3|XI|BZ!Xv$X_^6p`!{=d+a7X_O<zmc^0w}Bxc
zkiVv2eIU7{neqHLm-v?>{Kq9SG5(KOlJ&oHbFluea&s(buhkPY+f{LTUjxJ6&@bO?
zhg$Rq3#2^5c1KXpv3QbxQpOoeE5>7#@5tT#P0WG7N*{2sau}N-sZxmA*a~uY2Lg8l
z$N2P6$ZjPI`(eeO-Pxs7lGE?QaM9H%l`-fe+57skaylm_cj5iu#y3cZV>59)ddt(e
zpQ%&Ic1I;(FrVR2LQ!-1Zu>qgwH_G&I8?imIz)a0R*ZEnYK^dGf4szV7&)>ZmSD9*
zq-61RA9r`1b-&xUx at 5S_keP1u%!vfxPPW`$GCZ0o;bem$u^QiMtliqsn at i2S;O8E6
zHf1bPWqq`!_;BOCjSX56ueaWsfW0P4*%KfC$$o`xBj%fi=#|IH{J6N;<IfXQ;{Fa~
zdp|F6$>D2#q5FNk{O9U$*PYjri5u^E*AiDw%3Mh@?WP5dZ_>1($Wr#vJOER#kJHoH
zkA6wQ<jC~QD@%v3yCrZUBePCvt!8d;02)dBDO+Vu>~=@9#P at 0<>+7pv`up}P8osh&
zfZSnsch3{H;SEqMS9jAhP~qiz5Lin^6iiK2K1Vz4JzI32z7`LO(>O={B-joDSf}FL
zV)))1yQ_c(kPSCK!Ysf?cVSZy4d&V>N8vsv!mnG2wSTLlcaujWtYS|&aec!d9y6-Z
z&ZuI~`6zjnr0)YC2JVcfTI=?Y`_D+{GD?p#H^j#r#teHtYiST=F0nRbZYqQ9EW*rf
z(x<dK__r#(A2q;yFax|FT2+U$eBYq=_hsNITQp)cZBkx907s@%?jio0L;dDOb_bMT
z`)H;NL)NmFwOR5A-{Iu=ee7B}4B#Y(Z}k`!ZJ7FT?;zXz3S+0H%<-`G&wdw=@awzX
zQKjO%fqSg}umXTeR_R9FloT!bT at n(iEJz*t5UCg-L}fTFE?}gVdwa}$5nWzTC{W8Q
z!A*Mc=a`f7D4Y{)=845RnAMSjU@&$kfrh=+(~ge-5E+rXqsj77r{-T5-oqH5>UFhw
zZ0c|53)e;wG*QKX9!kgWv1Y;u0XO#{J-#nt!4m3H<<3>pVi2QnlY*y;=Gi|)7^L}1
zAb#sh{gMFhSPJp-99e0OBaxefm?TkK+KT-8i;lmS1gZdUBzbXkO)>|O%ct`Q+}#X`
z)f~f5#BGebqV>L6IO-aEBf{$=saVgyt^0D*{{l{$Yzx~HTgh&kQ at 4B#eNPY#*80{n
z(of|aT|eFgw?3u~>KYYFjtA-TR<ARlt6#%73R8DhltN)eG=`BDw5SqYprn1XCkylU
zJQPlWGc>`Y8?`te%ui^epNh)D at bfb-UHd1yT4~FNc<MD0a at 4kHx`gA`)OyH{Ys+L&
z0hsWwF_{URt!a;lqo9)#M|W8Q41U&7+}iT^>Ih$06&*TjU~VzAS=ju<v0MdNnXfcS
zR2VMxLV~<iM~#vMhh|=JS(59f%WsPL4Ap+b7Wz$WS at Sbs^jdB+Afq)7kxwg;fOn>d
z57MOd7FM#LjlxUQo-)HjN0F!x=&ohmz%RB{FGV_|BI8!}{<MP$r2on)-60`**78_B
zR;wc_Qud&%mK;})dRKZ>E(VZ|H;7!&hRlnA7wDwy52!P`6gs-0H+>Sp(ZCao39okl
zML>>o{5xk~Mzr9I%ne2{*Q7?kui4GJvP+6!<O at jc5S^Yec~onP4tS&*y>{&$DGqzC
zMhn-sRTxlRcfZ|6yuioK8R<M>5QWh2!HA*83#>sRC<cS{Nx7FAhL at TeV}{&;-L5ox
zu;?th*1&q?s3dyn;8#9>hB}<4*r*~Qo`aQb#k?$QDG?S*r)ipM3eIB%g6Ep;ACRhg
zcq|+v1-bPDRoTRW%uoo_UQcNC%s;_)Ff8;V8|(ulIg8`3k8=f$zWNBUTc0Q|z=h^l
zYixXP3oq*e-yTe1<Poj;+o|CUGXqb*IgdffVyOVnPP)q9%Y0=Rqt$@^xmpydD?K#V
zD*-cAXpu!Vu`d&EbJ#I#VjktdH|?&R$bJU;wCtnRj<r?-*0sIXmK+xVyJD-^DvIX1
zO!K8-r`F>a83F{!to5$LlvU(q=lKxp&NbJ{a$o;kM=eN)Y*w=tJVw6wevu~P{ieJ{
z2`kPdRCpnR<C+yz7*b$;A)lf6Ay%iWz76-ouRw)@C#O+j5QO~ktnH2O=d|goo-9oH
zDzCe4M-LlUXi#tzhjty)c)ede)oz+4fwx2q<KH-;L5UB#geLsTNX^?UQA>=4aoDta
zv(piD%0?|n+3?yFmE<8Xq{$=Zzj+ps2UJ+n?~9s?ri!Klj>?`sIOYc;Ne-|!p(jUr
zx-P!Dpj!_jDZ2jd5;CyifM*~SF>nz#z$W$U3$%w->J>5&!U at ti{|BwqrTVObg^b%Y
zK{(n*4pbbtibjm}5GndfzdNF at -;BTZF&~I`@;hB|Y_xjuBp~;%#r6UDe_b}&*K(B(
zrA{obyXsfp5EI-G<C0$a%1?q(tGfzN?tZDz`3Gtc7z5zqw?W2-H5e^03`qN~7!1&D
zc3fj94S-Ex7Xee$CmnF4uW$HZ0KbF35DB4QDbsxlo`%^P!^3%W-@)NF*+3CoBqSuA
z#b?Jds$CG{6G#T%mX<@sZf=?vvk{d>zGiIlj2wPf*B+;Bf%Ttn*GA>J{#^yQ19Ih0
z<eppmdH6Lu5P}@D!@I#_qgoMon?ZaG-yA4$(znm2jaBcIIy+lQRj&kaen};|Z*XK&
zv_GlJ?-*@pE14C)&86Ah9hql&&E~Io*!#JX9M$ix-Cib?y(UZ>kCgFvvhTxqFxg;X
zH?QbReN})W$Za4bZs+>OGvL*yDM6`6Q>L#$17l=CR-rQ at OQ}WkY46-Q?>c7{v_7?r
z(Jkr>saCeHR4e*6`WWz_Gi&ir$TM`1HSO+~!gp#LD!)W=R~`<pZ(Y3PPR<8_qDGka
zn(GwdR)Pp>T+U}HTy#G=5%%#5{DTYwnWO7g|AC!~ykNzCY06cSA$)axYoeA_T?pfM
ztBWiw#oiC at uh?sKsUt5Mf7D(ysR^rmR>A<-;M=O~59tzwmE7#3suI0ad6|OBwTz+i
zL&U1>|DYO{+H~Gef?bk*^q(c0tCbNSn{*z$B3|B7=f at A`*oZv`6z at g;*k*Gytku+^
zOAzj{jNZQ(9TFO5D(U0b3?T>D4Li?Jj?$w7aKs?scA<?T4IBT#?q^p~KlUTH4_MNu
zqcwo)4#N3c8)>g>25nz34e+dr;>Uumsk8sc>R5TMZbAurIlOj=b%e%RAQ%j2wenw{
zb~EL0Vx!?Ob+zPHNmj%Sw8vHK6%rQ0LHP9WztBpZn>(Qq#%c*cg8<PHngYI&%^HoZ
zWwavlB40Pc2FE>D3xSC=W6M at 7cDjQfk*LHl6G-)wP<Nv-Fv6jwls~#C1O_YP1t%x0
z2*HTf3c at 3q-O-4uCW_YT2%sp4q0Cs+G}`HKh1<pHivQQ%NcC0Qo}NfVm%>nEF%(Cf
z-yf8BUdISKCBs=P__QvdIGA_(lkr4HVSjx~Oo)TUWJU#yjF at Bn0~J9CL$SxMpET-T
zB47UcY%?me;pR}Uz#b8^m&5nZ2^Fe~Lyq2I!*Xy)qqh{bt^*3x3?hd^-b=<{`b{8$
zkz1c??Gzfj;{@8xYLIDQwVTl27Jef`qx(jN8nvs^L435R!=k7C!{WJV<%4TR6q>0K
zSlVDy>93e=OIfD{=BGZi$|dr6&51)>bYDmtb#ZC{i8T8?x_Eeq>ql>pC8ZwHr$-~f
z7 at d+-=$J}UY9amg=$M^q^?tS8 at qhm8qz2Ew(0f#I87{+{_vK-|{#=LCjP%E^-ABbX
zH^$;DA;0F4>+~Reif*I^s%e$JcXeSd(o%f`@VrQrO6Px|jiEd(Lc{ETm4xyiAHKCi
zl*8r17;DBD35CimcKfD<zKR*R7p>Wh>~d(|D7}u60tZ3RqWxkx&_FiudcR;O6CfX=
zP(Fwqffg<=OG&K`Eka3(UZL|3KBLm_H{zFU`6dF-KWO2-D(ortG<lN2148;%!ld&H
zmO(#Cbyod>qJPAbuN}6DPZDVeW8QTEopvs;RV_aFVbSM_2#UxOloWCQfE1-dNBjpR
zDavQXtb&MNVe}*h{+Yrp1tf(u!en>WBjM=469+}^ZbS5XEy-E|Xjalg=@BIYM48Ef
ziMJw6YzT$L#6$t8513>9gHKOz!iJh~k!`i^!z#)A*K^J<n2hoYbOhG{sm&RRx_4f!
z8TIf}!(xYE9m%(#878wT862U`_-|%^;3x3kPyhw|)av>CLK=6&=2-bCfPDVX=eX1}
zIjq<dGi>OZS{K=obVjIes)v at 4le8Ftg^ZhXNe*+Ag0GDWFNA*&jVP*3jDqioiXkXS
zfwzT<FxvBIKx}G at 5Fc0?Lh*9oAM(US_>0j$2;ltOBtzHzjhlu+BrNd8DFHUwDM7x;
zx_&iiGO*q$p#l^({cMo3Zad<B-!_g;yp>HdGL at -eG9?DAMn0{is8G4fQTyV2t9Og|
zL*Pq(yr- at 5E-Wb`9hGB}z62fsdj|F)()0)bt&4{<Go6Iu|2bma{7hW_AK$>q3&&`5
zW+BqIdXW|vm$Aeh2bKW$Tv<BijvLg5OFSd{g+21Wcl2cn%MnIa*lHH!WpaJSw-EUu
z{LlFI7e4KRo%KW|*spfL*aA3Ew4UhFvc*+ty*2QG)>@y!Dd^zIw4?iTx1ZZ at wI&Ls
zCGb*15NmPS0a4iOi44X_eIiEta|Xt^Dlao!xmG?-UQ|T2{U7|TIMZ?wTCZ&6KcOCd
zT8nA0jA+|6HfnB(`gJ;Opo9R=h6@@f!IadiMU!BQPe~z2iY{OVl@>wc$rA~yPyDSw
zg7Od#gVvKY at j7aO{vTBM!@5(1<W%WL!Gd>$V}Wk~T01a^a*38)X=sh7s!i&CJd3}#
z-ObEBiS94hyZ&TPPPOJ*E;LTWi3a8!B6N~~$0Hc|{i0chibv1^lhAFK51wX=MOPMt
z$RZ#mF!A*C%&+Nx5(2;FQAzjY7(larrWn7iqDC-jE*JNwo`l$Lp4ORmuL-{!QtsJ2
zhi1?*P`;%*e9;)^oNhiP at wW;V#NV+9vtrPHXwlNG98t@&S>ondvVky0Uw8M5XIL|I
zbtLs}flGwWT)ZbbfFyID^bAnM0v^#MMrR={WXW|BLH12tD0xiJNAxekZJI4t4^!ei
zvLm$kTD^E#dR|`2Yc`DlwN4TzZjwigec?<51CBSrFn-!F($f+<?zgBgx!||?pbwZr
zFa=gCO^Vu<wqx5oI+Rv)!;30fQAs<O6z4-U_TSghNcTyEA3sGsQY0;-PK7oPth~Q}
zgO~$(>gwi~@JrcEK24xL0JrpULxow_%MN^v@^0k~6L5Azh3>)I7FyXUPobDe5}WJV
zYuC;~|NdinrAm#$VDPb%TVfc0DX0xmuhT$m-xxUouW@)mg8r^;W0t%o7$g_7SF>NA
z83sc~1caN)&y2i}Ko*|7AXhqA$~m6NRvOa|2f~Osem0(POB?1=aYhAFv_#Rzw at Sr7
z(w`Y;l3PL4v9Db at aWvH1JLLjoVP(VUECm;GX=Ov*(D{G>dNDb7&v?-kz|WRg+Ox&o
z244-<)W- at 5U%dg?T2-QvW|-P~zWIcjHTR7xEvxv!Sf#^h=NxZ^Zj}gyyGx{MDa{9W
zfl}r-!`Ql}2@{-)1_ynl`)e-=%@&x3yDvI!WkWgwPNf*_3@~2fx*IWC5!6uXUa556
z=8UOgXIlvPy6r1?feP|&{ne|1T*MVWB7e#;uDZ4g?&I2kbk(ir*2k8CJFtXhNxmwN
ziHHT(M?}xhi>%w||Af|QEb|sd>wgUv4I8w9ZqtbG{3Gym!ok=AYoo}Q_{TS=V#l^*
z8mS>H=PoL9CtxWNeVACC>-tup{;2FOXotg6jMQf6q2n&y-`YXVqeJvX-~7_VF1E|b
z+SE>Y!+RvT=C|@ZK~%Y3$+D<@8NqHWicrc1WQ&NklD+7QH<!!}OJ$miJxGD6Kg94_
zGmTxkqyN46&<Xt4%qe2}l0NAi?x1vh_Mp|%box-+;%Sukwe}B)>@BO!|6->8F;0J(
zDOPs&|H&H5`rnDGSpRPK{eLE|+Sgu-FXV_r#H at a%I*F$K`Yd+XzYnUbkA-Q7Ykh_=
zJn&SzNzgt_h_@@Yr{NkVBaue+CaL1&)<(<@itjk at 8LwEvphQ)4=i?@y!49SJUO>da
z->np)*Z0BynR}Gps_C_cJhEHQ+xuyye?#uiSV#-mZWR}=r+rCNW&<2u2p_n3q`Sk#
z)fI5#W!UHY-~{K0rzb?WBjOAZKi`H$XOQLYHA6`URY3z+7v~CH%h}yE-1|Ms$McEf
zCHrN*lze(mzl1PLrrj`q*2P>g^E?;^ZUeCL{F-0xA2UUK_>Y+)_z0N$a~$ODVUGvx
za`9vh^(QVKU;Mcy#3zI#R1RK{krRBFD3kCVN|d#zzuyMX?d|zE*}rj_7s;@T;8TNl
zT|0PWxpiWB(n!`wRU}<?Az#k2YDtyR-?^GQAjXJvnXNzKG>Ze-7TGmPPsIN{=#!Wl
z%bl(1A02?kD4d;IoUL%PGm{s1IzU8u*O&Uk?|mhbrt-;54HISS`$sYXpBSdQI)Kn~
z4+ROg21<N)P3z|Kv{&Ay at CX@ynJKGzT-P}!Use}rMCizSRcGxY1!vRJU;`$AATvk9
z$VjfTHFDlu*N%F)6IDuu)2J{@o_S;IJo#CQQJ3}uAg*oI^Hu9DNgEu20d`k<iK9la
zQJ)=+6`Qr8T=nMq>9$(lrwX#qEvkI~t{9ZD*$n=kUTvSt_hz2IQg)x{`+3QwnUgm%
zfK$l*Jj at T$dND=SrsM at AYG#J;9x=!n59vS>Ye4~W7HT>>aw9XlHm at Z(E@(C8L)G0%
zab$Qn0g*A0zDK|=O|A1mj8TY at ca*3*$Z<=Y>dqhm2AtEoe_zjGQkdbrw+_)=k(#KR
zz6c-Q2j9p5V%zmk!XHPVa9#{gTji;doSyTR5njFH>z{19(&GR$)gn;5`MAzitftvY
zRfs!seEp7b%pJi~Fv?>!qCZ|jwPef0mZbgc6+JNeJ60)%>WJIPwk#t^<n^BX2PNQh
zXxZ$@0=;mUpse&iHpF4)nY36jF{g&#Z&mV=5g9jYT;K5GyT6-F)2UPN|LS}#F6p}9
ze>o}RDmm0MyFTq<LprT87M?b)pHijlSew9%#@#XIkC>zYT=b{rpi0ZRW=H%?gkr(Y
z6w7#izcx85@>F#%&T1A3D{Z%d9j=;*koDhBr_yLS)TXSp<6}wDhd6`4|7{o&9OkB4
zHsBh#X(!~U8BU at c`bCz7us)sDFP(oP=zgAtl8F_~ZrHX$wMT|if+>>UX0vBvW*fP3
z1D#&n?h4}43ScA}V*v5&HwfQ`VXBt960pU!$9W|4h2=;GT8zy%h`Q;Ct=2c#d^Vis
zp}i}-%W|L|0B`w{O6EC1{T$4^C`*=f2HCYre2hl_E<uM*0+dPVN`S#BSo8-h(oK}!
zx1}pU&<h5jxhf=nrtpAn>WFsm|9%OIy|@ZN^<_pPFj(a$Rli$v?98+VWNNHnun8|@
z``>~n{I0%wUsSjxK)^BnQyp_ZxZHxR at WTX$J<W(m=mri4A<HN*5eg^nx_IxKp^Y7Q
zq~t}iMe%kK_o*K-G>_<7p;XIcLEz~;bW2oI;3<e?OLSPE#UaExH^bJVTYoh8_Edu{
zcL{<fiu8sbI^1K$&K(ZHZf+mL(~{V0MTxgc)>tBj25~{prG1$d<|fgZ7IyN5M- at 6Y
zB<Y!2Gty95l9xcsGF0E1vf+blq%tdxK|;GyFh25*;Qg*V at k8JcqQaLEm{ZUwj{0Ei
zje3a at N`(Lgkr!16+@)V%Z23b#yC_&O0iYx?S=k#<8o6Asp;BT73b}3Ip;9RVn57Lh
zI@#!LY|z&l2H@*~35jb|(#t(m at UR2<ay_p|0gACuC1b}4kYr<5rxiQY!|+;j{4t{*
z`zP5}c6fOUrJ_84{1Q#7v^>~m&zRZ-Bao{Q3)W(4{;XK1S`V7ym^TwWP`Nl}&%~l_
zv*PXLwi*;Cm88iUSi<Z?Z>tvhW?07m#P&Im9(K<^a9DduN%O8t-`qYVow^%C^j3`_
zF%%cRPP$x>IVEy+m{#h>=TN(6oQraN@%QP}W;$IuTY`z!XrwY>h_4Jdp&d;`;tbiX
z2A`2+ZqHerKA4XFCj5K6eq-t>u{|DsMu at qc0`y!Wm>_sep-Noz=?626+6wKy at i(v(
z=ra#VJZpHpF(aqUL$aF9%HmfS3N-etdK?I^MZ|GsZf^iid!}rDNSDRsXbzUBB~>Ad
zbF~ejZY?3akuK7Fe&jxMSoBH?ro(a#Fa5~-%yhJUbxop;$#)N*LU`uNz$Lr&tlgF|
z5^-V4QpUo>T8_fN$zbIJdVC5;_QLhVED|TGDz50Kal0=ZE8q5w at m-2()A&SdSwGHb
zFB`knuYh*dbyh{~?8u`zioqUWQa_;2_Zk+ at Gv*L@{e1X}z>X^s3tMKt{3t at y?<)ig
zg(X04tw1EEcJxiJU-C<R`X&)$i*ABovNcN-xNn9Vmg8(kYjP70gQZ)a7*Lz2lxflz
zbUVJm=F#m!a)j?4Wv>To=c>13`CYN_EO`<_{5RBa at i)HLy-RddyNcKm2G}f_`QROR
zI at f_9-8=DK7fO~WzgT0f{83|g<&LuLm?KNB{bKP^zrx~6G}Bt$IL)Zxe2`&??=Vdo
zhX(F%#3t~pPlD6lF-BJW(unTkHZM$8E$)Bre&qHh_bY3yn`uLMD+Jj0uFW7^%mia?
z%)CX*Y=!Is;tV`kZQ75PJ{3h at ov?t)dw#o*K0BqaD<i@<VP at I3*yksefRk9a<&FP@
zI^(_Go^;pRyw|}VuzO=7*JYv?dQc?Q7cwj-xMXbgH%ZL~4Out(X;R2g`}rU{0_;a;
z at ez9Z0b&3X?$8)Hm|Y4f#n$w55hUf57%O%3`2aY_R^!hw4&b+uyFe32qVz7;?pBer
zUI^Qg_#rEP#bkkQD2F&@I#PR|5p%Wu3D|iWd2k|p({$J(Ep(5bqph)v1kaq20JU1d
zDCR5q9T*!t*IK~P%Ic~+pKesi{h2~xA{Phk0_o91wIsk9c^c_e>YJ#zfFo)ig7Uf%
z_)vi6sOb?cscD0yST#j)LuBwIv;8~`j=oetqTkWCe)WoEW&lZH;@_x-4e5 at J<l6=>
z#f&_-F1*P)veg52!r2&L>PyYnU%H)4H&QE_VHpHL1yAD1i0-ti=9&h;$UY6L>^Y6C
zxnhol>p(=<c4l_0cr`-DbR~eixSW8`q9RP;>0uT?3EjbLLGF?R&%d-giSFh!PIq}V
z`HD;uAQyiQgbo~aH=+cQ{YA++FJGd4yBcg8e2!=mvU12NP~bm;#7>L^(dH3?Khtr-
zWIco%4E=*NhBnqv7gInr3^W&Drjt7(gGu=%NTnn$B!8~fIoPNqF4uiqta1RI-~Z}F
zER`U~gei1#qQ)D1+dA}^`0aic_S+!+XCg%&rd|ZsD)k*1J{acj+pQ->6{H3`$p~V!
z4=GwT5$f~zYiUv_aFl94O)C=E^&u=Hci2eaumeR#{HIUM+upF{1fffq3pO9tId7CM
z&YY$;0`6IfB4UHW!fSBL2<ZORuDm0|`?q%B7wS}#D;Hq>3|&9wQDId-=I=(=_F9P6
zkk1e9aDUUu9{RVhQ`MoGJx3J~Q^-lY{efX7p|IIu>q#bw9tSvVMpG;~x9KLS#IEGm
z<k{dG(I!lm#ZRh6DI2a$n(2Di8fVr#Q>-2~b{qOQeJ7rtom;!D1=>o1r>+l_DKWUg
z1?!qavSO{Nb||&WHr(0p>hdBlzJq&RzIyq6jdy%_wZ0O1X$n8cI++aeIr9BCzq%B0
z>}Ma#$gIraX-?d2RsmDDAUjm4|NePe_La0dl==Yy?c+&K_!_zpP%Mb5^hyXSe={Fe
z?WAYL7vgEfEe|YIlAtG00ty*}o7i5BAa}h1QC{hRTVF{t!&MrYT=%bS+OonJOw4k@
zm}XJtXYKHpT+6<VO|MYnE*Uy)#JOsR5`ub389j5^5D`Hg%sEsD+H`5eHUuGB0SZX;
zxCE-8_>KvNS73QFf3NsYn$<k-?YusU6uA#Zx#EkO)G`iPv8!)@y3dqZwJ}IP&rE%p
z(0HpIrMm-DC?iT`Jch~_;{S0`PL$}eh-41X<(ICvc<TYrBSN*=k(fr%Id2)1&z845
z{%G(%`<}@E at R>#oZc|E5%f?F#i+=8`gXZTB0G^cEEEooD0vUr9t(9hi@==<_9FT3C
z4z{MbQb(2UKTA-PB-s(Rgr9s6csL8+WIq_h{0eX2X0h{f1)uU-;wt($J$V(`(zUnJ
z9x*H2?m<egE$iS+6EY*-RTOm^$=f|KhrdrGca2=Nmtl;L5K1r_VoLI7Ab`q+jA);J
zc-+G|76n%>MtR<X9~&)@i1wdzOd`p4t*?Gr8*e7IG1(jO@}{}baRkk76QatXw3feE
z@!Y2DYp>EC?}{!w#QKS`(<k(mn(iC9G$yKo0g1?kq$1$Embf`!QV7!~L?T^m{hFk;
z3tl(`I{Er%{AJr`7|(T|m1+sat^sFTzn(eAW+B%eh- at 7$mg)m1ImUlKv%yQ;UBeH4
zVOw4BnNkzalzUZm>e$|Ee_ at pd>t#oR*&-^TH*s;GbP_b?n3#m<63XBGPY8b3TBt|v
z3%p$-bY at T;-5)Y3w|mr0LhU|}+oK_ at yy-*%0QUk^fPSG3)JU0WIas^XVTXNe?JB%U
z^f5rH-n+m<K6SQz<koduMTstTvXbp|57NnB-*4-YkqvAahH0F=DH(qx+Shr94m0wh
z2OKb%*Ve5&6 at UWdl#|(hC)>~G>E+xL5Y<dAnwww;IrMC?FPRv&wu1#4P0HEGOXb31
zV!!uEK=>h(kK4%8xhh$E2dwrSBbd`zt8(4LCfdj^U at G$lK9hyubqYG^!*sUZK{~08
zK&LTDIiGlgnu$4=m-`v%9CDN<J3LkpLkx7hQIE)i=!Gt<LQ>`BH9#}ogez!OkAJ;@
zjb?s25f-L;j9sEPQr<v554E1b5J>T20?<9reoje``s*2n+#6#JLe~48P%o3up}l8P
zf?;ubYhDzcGL5cOV#{|yt+}gT>~2kS8^0n^0pr+U-%y0&U_q at L*7Vo5*$o`5Gr_(z
z8(`StQGIEioMLqL4*uNV-I4Ej&p}!3s(2Xg6KCxLQ8+L+zJqe&Dr$$Mbyv#n7E^@>
zJ;;=p<tNV->$gQiY*dXxl$@-5QS0z<T~~%s at tXT$M#;#>PIs3J8bA!y^;$1LHkluM
zv?ODm7!M&3^ohR`WSH42Gv-ZON=X7)WXi!+&@E;?ltas+L3d^qQU{T_IsQb0QEWgB
z)>URb(2#u!qob!T0(=!(+OAoKl=(~c@~z76DU~4~t~ZK2+Ob${2*PJkgcWuP;%h}F
zUXCwpN;`M at k}Vrd?%Wj(y0rPbGz5Qh=UVgY&3zxhM=xNyDNZf6^KSUr9=Y5+&DtKp
zLBpN_+)xcz at EknG|6FX%=8<1pPe~=Slp$>kc@^RZig=X2*Jf(?w6q(`y@>=&Zr}To
zh}PAaGTM|6IY0#(4D(;yG at RNGnd42i*IsLr-o0d7Q&8MR#9f?he4ycNp4^{W9=RR0
zQlPzlI}f8kBc5u>vUqiIV-nOFY|zpp7`XqA|HF=`#@NO0aCMl8pDZ=|YQ4(FjF+`g
z*T!ve5ew6 at tCQsku~xVFMZ{YDP`^9AML;hXcQps|E+aAgI^R;~HeM&xtP~w>?2!Z+
ziA&C5`)LhkmmA6&&L&}FS$aSx#G(<@x{r<s3FY(gWb;$j>vC*aB|p5O<dw at Y2jp%8
zWY>O;xBej)4x4y3%ZMDDC~wi-Ph8t;@pEyV)2U~YS7|v9fU(+lxq^+eO69jz?&|*0
z`a<98Z}6_DgbjXW$HoaSEBQJ1_+pCt>n^K_#tMTOmwU`s0g3s^4 at CXr_rJxHwDAIB
zLAd`EGji51kQ24tFN>@6zgQiUx0SV<3R;xD1;`=%n}2k~`%%lDAGPoO!eT6cy1`b;
zh$Vkf_*8c`qgl<8X&)-|Ihlj6i)!^bfsknrgB$RyaKyDc>Go9J&W~xWG}q_I7%|my
ztbbjj3wqtd)bQxmaV5)(%Hfb-;7)z`d>;d4pS$|wg-bmC<cE^;ASbiH-cl|1=R~6<
zWc|va2l_W}l|`s<pSo}*LzNN22!%ob)%Bv0-w>+;*weAMPOhE&BC?D&rhxM-ha$Oh
zU`P3>ud5S*v#dXIKq<144%9%!Y3*%LR8I3j5>>j_ZKpX2Uq!NShV4W&&`Mc~LLIYL
zG%aGuHM^y?^)-Lay4x}jVpR5J-<!a-RgYXS<zcLL>#(G0tkqLc at zkPeELZziPRKcP
z-h$c26u}C=Xq5r$^EMiiljPw#lhbxxO*iM9<&R;3-#d5-5>a#tj!f~}ntvBdgG*#{
zGJKfj1q`(QE4AB1Zg^)KgI2W_7c1kBM6LzR<-pUf&KJa*M at VvgU~q0{yr0^-R!Et~
zy2LkSX8DO`cp5Mi40!Zb8ZfHIae>CRgi?%dJPEK&xPsNj;F*&u{UfB_2&+%sFDVbr
zsC}^)@wPn?<vzMAS&6zs- at d5)_1foBMHiYo<m3I~1Ek>f$mhSAz`qRNKaCnA%m19N
z$jbTu{rLZ%AH~Y`zhMG5v{&l!hwTs;<d*oEY_jdZH5(aX68)3O#@HqFfI;@0$RK{X
zBK~mDl26P&0o{ZA+vA$`$>Xh$ieO at t(vW`J$K`X4nE(J_^5RnVWcr}+>d*V`;F8P9
zoz&Ci{f3LnaqW{_E8~av_5JbTqYM8FZO%?yWb=XJ$B8TfmkE|Rj2Eme(@B5p+}n~%
zP7Z(DKtCs?=R2(TF at FB1!pW`p9;H6&kYD#EFLLtW_4Q}WR{h)|$K5H}+w=R)IKk%U
zIeX4fa##oxwnJGT=Qp$j)csyt!9)0b79Q`15!{M*d{C4?>9zjT#K{lwC4R!B_v0Nz
zVwa28Q4szEX~fj`xA!GR at as4d=wgIkAOrp52MlTY?D0FtlaG(b<MrD{iTv=c>*t<V
zyldNmBg@>i71oR7`MgBteP at b}teFGxmCWoiF!PQ;x2HW&;p&7*#%a!H?siXaFPIPx
zuHD=Ry^@G96zka9oW>%##X;c!(7g~Ik*9*jyW878TZOoIp4=Y`5C_B92~$2W6JsGU
zj21p#c6|7NkeNgzHdD-B{EbC1={)g}(cGpOuerh?OP?~eX`6N%l;H%-#4Ox$1NBII
z+qCpBe4NF^3`$2$8~nOeeYdA3dN)(@bxi{L1>iH;WXhOsYnP at K--jG9NjnfC`gAa@
zZoMNo38En_x3`vY3?Rvu?ZdP<=Y#dK)nQFDb}S5mY^}rC>C#%6g;tq$164)-nqzlv
zl4IuNg=~wz?SA~p2NEtCR>X`o{N)3)@BM|^qo6E`?Di?amMErmBfn?rGV-e}G1l9<
z{HD+^tn?3hM2&>M<5vNLCNt19m_B-_Wt0K&fFHVg8+;}`IJ2XCxv$ygK3XYMhCcf;
z`*7GCVDSv}eD#dlwN at OtwJOP<Bk*<+UGD7|Y`r2Hp2BisL~Uw+eAy6znhu2vYGgYd
z8)JcE-_&q;N8w3G+-%#Z=&lhi`x%Ge-x}jaZTNXATxpj2snrI!E&quApiIq2yA+AI
zB-y8&l$M={nI2P<d=SJHO_tujOPJTp3-t8*4a=p5+mfde&yuv4eP0|avq5&}n3Gh<
z8>ynZ*Lxd<p4U28ABI;y&$DmgB8%U?RB9h>wMP&04adTBE#NdCs_0aHU(4BPy7whQ
zR-p0?$X~i;Vl)9|bFTbC_x6lw9^eMuyVImgi8hj}_i#rOwe}6vL at t+ODK@MejsIXq
zm|?AD#fTS2H=GB<G&Kc?O22-<gA?TOt%d5By^rh$5H+RFneh1*EDETl+|8zWR5)Rc
zMN>X&98>Ezk*#cOuw3TPV`WN(gkRt&9T>u^<J&2eYgYQF(8_Q&U}()M3VLE#H%&TT
z&Dq+deT%$fJ#{xpkGRe1q6aGA9Q9#{^ml7SLc#NR+1E>lR92~6JwdpKtFuCXRnRDT
zts3>7tiwuj<iVeL-XLQrNPjv8d~kSPBdF;r#tWP4?0s at E9-FXe-y#w5A!APm?!wEv
zsgu6CrrAKf^ua(BEJ}~di=nbu1`Q6Bdzw2yw<9Mxm+%HORu;tTB7o{!)h=#%F$M=)
zqx(X}^>4!(;A3oX>D$TSCtsy at _9)C`f$>6=5s3EtGDQbl<NLbDft|qpy(Du%Q4c<|
z5<EKm0^fEZgLBqQXFsc8ESK(vz}h0S0&=j>a5?4kB-nlmC54ht{hBhYYZ_tn5((Dl
zavW4QIC$3y8N4GBboi7J`mNI`qrNs<j=qAFonf138j6*B$c&4>M33QkspZ+r?m<y?
z0~g0A8lFZ&MTu29D}(*U<Y-#BKa~!zNeJpD|Cv7e6PK(+)P%F{!*?N<404Khgq39w
zDmxZuMls5zT_Lbr%lwJ3%Dr8K3iDk<$Z1u-On#_V%VP}F^aRtemr2B_`S$OXg2<9p
zjg-%D!(_1Znw7K6T<u8H!ez{`IzA$NmdvKp)ZzVzVU)vRC7sDvA)5L)b%7B1YpSV3
zN*wsmS6ixB*l at micinhhS3Cw`PM659S9L*Z{OduC7 at kb9h*x8%H4!9!HeDCf;tu?X
zU<JgP@@%ys=+#a6TnJOgfzu~H_Sd|Ehpo5Pp|v-@!sm$6VG4Rgs_8IcS6In+We9Pk
z1qWm1EYopcP2{6$D$CE5ex82Ww-LxKB%C`d!%|5#Enpk+k_=HYG!q}){$-brOS=Uk
zS!*9Un!Iuj<j^(VuyNBM&hX>@7aQVvN1lJp at e-$pH_IiS7YRJqTR3!4)xm^1Ie(<U
zRSKCl#PBVSr{2ztWDva|*mt#qFjU7FssF>;TL(nlbp6B9(kLKZDlHAtASETzNQa1Y
zv*ZFwgLIcHC0)|e-LQmovxIcVvc$XKb=}W>-Ov60p1S at xv%~B%J9Flo&x!rc4BmQ|
zBf4{}Y?*;3?bL{#PXo7HSynx=e~uwi3~xP0VXbP)cq6KDAgL}m>3Cuo>QWOBR6Uph
zv2u(IVj9v`t44b|Q-hY at y^CmE7qECW(D5TQ;(g9ikvDaG61z5T;D=fAvSaT<Vs`T8
z)I)RZ$7~2Hc#U#VJKMsY^tTT%5y9V=hCEeU?Yv%!`>Gxs1o9Y8i31iNj}hnsX;6im
zGcpOZuRJ5Nw5wf#nV&)5He=$srwmhCwJ7i(jwuR#40)igYfJj#Y6$m6C}E#ypw`Y2
zdFXxKVyosw%2T`RBl6G8BJMboh<0B+)Sxf~FD@@HDQB0fWY$|F@@up)+s*ae*8wT7
zP2F@$LLJ%%1-3Q9RxDT-*%IxSC$7OuH>RrDvPnpeo|wiQk7!s;6>y?84j*B+k$Bq9
ze|6BzZA65&P=x8|4)N`ymh1%OX(c?}*!(qQtT*Imx<vk&pL}lN#yXgoP^U&ke at 4q*
z+OB>Vhu2|TCnl{Sl`^?jb7ktuP5JAGeMui$Mk^D^jmmP2*bLq~6sPNa*B-_|84S at P
zE at z>ewA|m&#6NJ|ew%^3L>1c0Q at ndv!N at xI-hs5wUjhl=eP)TTF|)7Km9RYvxD#o8
z8nnU6q_LK6^5O?U8EYQ*z!`FN`D$T at 86D!HQL)-87U4W&r4Onsc^As(tn|?KmM&)d
z+EtWrA5NTv@}5UVANi%lNTj)CS9{WJhLn}Mq9kJZLJ<<;?bVz%9&o=Q|9nv15bUd4
zT;4#Un@~fEi~n&pW0POb;8dN5spw^<?B`a1Gl?#JXe$7RST_(5I4i?Z>+BV%v*A(;
z&<C_bjjU1v#)w&y3~|SN?XJvj&G1UdbAXGv+^+GLQFy7SR8y35PT1S&<pe%RQ-JN^
zjpjE_?etn5*{|*KrKyV;J|zVDgVr#l$iz`jLOU^}c*Ic>vUD?k$$sxvUz)qj7bhhO
z8TAuf{naU`hJ7SRoVBZFlv+_BF#Fuf3#r-mluSVXD!_zgUx>maqhW=YyWs-6e`Y^<
zDwU6C!b^8X_6q}R&HVCfk%@^wbXQGZ{s&KR1NJ^Ym?Ib?7Av>SX_1I<XpDPmWi5*H
zk&bF_HON;+IU07@((sxyl?j2**QVNw`=A_o$^ENsf(a!-?arC at fP^5S;RDcPXWz|D
zv>pES5oIU0d4cnf^FFC5GO^E+OM<KT9xCG}b9`);>*UUVBZeEp^P|+uLav*lbuFHp
zb*|(6!)E1x5+Swfw^Ylm><42Io56jL7kd+2R0*{@5f|8maBZgwt3MR1C`-W+mhFzk
zl7h)h70Vx>8}TNR_S4GzVr}&@ilZi6r0oeILU(pbpdKlD?6*AKkd9%=xGCfFU4mlh
z_*v>`*6U^{yPDA~?n6@;0=)(MGbS?e?&*M6*F1%w=XiSUAOZ_F2C8Aw$qFYOeG}OR
z=-~YI;x*OULsUlTgJ+>(4Az__iSdQJUSSWX1(%tm2AdMIJ~}ninwG_-mY*zy%Yo4@
zlOJEM3blh0IT-w}7nF197T6eX_q#_5qii*g(2bVjS7qdgpFdeFe9qx=pxs7I$iV13
zMeF{stV<m*7-q?z+up{<(n*K?`pD0J#xP}&JO#O*?Z7GZ5sm0a%kvd^x8=6t at 4ZSZ
z40KF=_Lo6z?zXQV9E1_`0O_B&((I7Y&ls#Czq+yP+xHenOy__g90`2DV(Y9LKf=Q#
zvKc5Erky2y!%n$tgTdYQq_3Pr*;PBi)E6~1Xj2T6ufEZT0=&aqM?dn3c^@6u&Akc#
zI6WzCdL#Jb3}rNiZ&$Z9$(?J!*cUbEW%IFp_fx+$+0Mg~)zr21)#is`zN!+6LDSK<
z7KjV+SMS8wKI@!OH5C}1?=)+V$}EkI-eR2~*5Pw_9T+_g8$ol_9IUuy&)-)Zyx|Jb
z(NHTd82#QJA;+q^$p~Xp)p8hq>`oxb?qj*+;}8&DLSSde`Bd6IkXTxRH++TuF&fIG
zT$|!XS;xq*wtFl}7K<IRaM*n8^}CTO3RJ4thn}sxT*!AmfDNfxAsS_W$Sgl;oqY$p
zq7}JfV?XIWBxAR{OYqcU0A+khKLt>8SoS66mB7wJmKfF+z6iun)iEP^I}&UCI;`{u
zkVLy$r!>ceq2tkS$Kq_Z3Q)%j*O{e(Y_iNSk3K5$k5u3br0oK#hrDe@()(Q2{Ukk3
zFm}!x&gHT2cpuWvae{(EQYBa`(pk=rw#UMu?@@#>f?e|Jj97f6zII?JC>J3XEit^y
z(>7K>q%tmHZy3%I*Qa?cs at _w0K1^?PO6eEyWIqEk;PH#Q at SM6b#}!wy!UH$@x!qj!
z(QJ9%pw&fFEolQA>yU$SB0cRuE)Nq$ffQLMFjq8T*ia!<C2)V5b`n2p*l_9~mYOEi
z0#wc at J~pyaQU~ZeDaS?>2$ANIt4aE4`3ZFn4{n^XOBD|m2&@d%V%2LHnwOnh*5a|9
zk>A<Cub*^%O4+ycFo01^N=Q{;Lr_-wJ>KEqP7qJveogGS at HdYepPd`LO(fjd$;k7w
zSJQ at m9e_tHC01v|<lZWFxLs;J`P&Q$Z+8kkquxp+Ic3f`ZYc?1n~W|iw4$OaJdqe=
zF|Vbt`(ffs(HfUhF;|zro%Mnimwq5ucrB6FF%gvL$#=`3=k;S2lifxOGdOldEwE6P
zqVfYRX<u%g-c(LqhE)MslLA0uTJ0Ea<QwCQ{U$Tx4zw#Dr><!*XRup*%lg*RX4%Uv
zM6}Z?Z!YS}Dm)XdPmq#E7ApDDUe)6RnC#=`btm7H`ci8CbO~~eN}D5+vdLjVU&Edv
zt!ZF+hLnl(*IA{Fi6JIShJt|-)rB;p87&iRskmu%bPv_C&*79$ikK`fN;oHt&kFna
z`itEho)~Bj6C+2eP52+=^<C;9f9b<|QM0r<`G~$V^m>z7OnYqM0(N*jMq2t%OHpv$
zZ0%hvlm6PT82#1Swa{7DCI0l_Vc{2TPU?O`46Q$TVpHmzjko~VCOIX`DfyNRT!03~
zsaKXgGAwVs?=+I-P9x`1*V+>WaJ{cZIRPHrFvc7kzbB<#ZAKTgi}@M4CcAAp<pG>=
zJU~?~iKISP)xP#emQt#d2lGF9TzLU-Ud6 at z#IrsOyT-NNyf}8}Fxmc|yDy|&50o@?
zzg&=dsqa1#0IWJGtK3mHC()j+s3h(CX7c7q_P7!qi*Y%1aR8_JA)Nm_w5g at 2Ma%UF
zmIpR1eEnggeVq>G_>9nBj}$`ZvhtU%GC|a}Mm{AM`zK)~Y0(JL)lN%9U<(MeYcCO7
z*=!qGnLGANrrwm~h!R~$fNiE313ro^#!IEJP2KmBA(G!af(U}&2S2ip*O7Yk#S%rj
z<wh>=<jGg!HRwB<uNz-K6i<1ik2xcCA%+h5&MLV2C at 8I*6k3jzc5J?Tmtzn-R$B5#
z)E0xA9r8>s^wOrZ*+eLkXHE#7n->@Wl{<S0Hs1vB(KAJjhF8d#(`)N{_v4Q|VW!O#
z)?hlV)n8Jm3xFtH at GYR1VZLZQ7&S^!N&97z7S8q5uiaIN9HOfa_ty~p+Fn@))p^ov
z9W$!$&Gc)XbR8?+3XQrb-ZG3n<A2l`_3ru=Rjkk!Ia?=%b)G=Lj|RKtvxujRR~Bha
zhcPk>%F!E{lJ5ZT8<IpFR=Ly at o8BuayEj?^AIsu5c|At2Yc(hBGdn=X9Jx3w&VE at A
ze`07hiYU8n?(J-r77`opy6YNIkVpr86rz=kvO8?6k3Nc^Br_NIIRD9&s%Wqp=8 at u4
zF&A#H$Bfrn-j8}yUYMM_>KLTAcRR-7bI7q7NN$<rrat6(*j17T7*5T|6huk)S|R4g
zxS)+4GD={3s=UeQEv`r&JC|WxEiQ=BH}l95?oI`Kz7NY<u*+2pLQ}dH-x^3_G_Za8
z_?=<|-B??B0=}Q0<7*T0(neEgYLFqy)DPwYF-_Bo(yPqK0LA#sxAmVA@~vvW9&idb
z04W?0TvR>i(ge8Sbz}s#tQPx?l9TfZ;l59;4`+s5B1DJLq8dDegvCDt<R{0THBf?D
zlNJ0+_FML;B)2Y7d6vi2fUCZ|9A!s#mu0H{o3PjFwC1<&;%){GYKcwhYHRKLk)PBH
zhMhW at h^;H9vg!CHo<rg}lJ}J2diL?I=Qg7hN1n at p7<80gtLg;@lrA<fge;gd^_hn-
zkC-<s=vs+AepqOB4p5$*W-UYMI_zV^n<uqFTD)C#++%ACV#^7&3Is(`A0mk8`vEk4
zkYj^Ij*yPe)`;<OVX;>aOMUPZw$1GI6T&j|605&(8f8e0<=}S1k63rW at fC7CqMJD>
z&spk@<IK>`&u6^$NwI6l|3u^-{7d7wh}~jEOp-(B03mBl%moAiU8T=bZ3U0r_|2gb
zW6_8#D!<&lZWGw0n9u#1&}F{=OJrAE6;B~8oR(>@))@4#7V$3h!8NK_+qtqC=AGMR
ziy at kww*M$dn;GKxv@%VyQb+MF_}QN2xf+8%eHd%oIrpD)j(54l`<x>O_doW<^4#4R
za at Y7DIY*wm2NM6wrw^;X&PLPLBz<iUEW{D*z*)?z9+*KqpnCAekM((2cH;Lg8s*|7
z%y0>@?>Y+Du#OlrD31`^n(3iDanG}fnIDA(JmefQ<3pmj22Vd%c~M6t8Kkw*=BWO<
zE%FAQt!wdJmtVuSrW3$@QkS<mEf?pewr at o}Z+4`qCRLkaKSaL;-(I}XwJ6>?COuqb
zNrXt9o?H!9z_-vk3?*b+uhmcPmTC&m&i5aCh7y%V at 83-R&=(KknfG*$|6)1rdhQI{
z?mU}(x8c#4_>skW8?d}dP8LAd2<txf{NXnfK8BMx+G!D6e`}AE5ItB>!?T~I`y$@q
ze6i*Nd>(eQT$E7lI9_kCkLm5zNN??N2?F0X5sG<bKNMn-vOA|50^fd%Gh at u%Xx?h}
zI at s9&gRXO|jT;+gy+Il)UcFkKHSMzSlM>r#{UUSPzg{k at SZ%Mm*5M{pcYblE at ba{g
zqLeQxPWRaCE;!vApJt1<VCkn#dXhH8xZ&(Ks_69E)1lKfPfcZzh$UB-t**?=;hYL)
zqOhW|chi4q+5}VFfc at Mu2@)we0D&#M(ANbg&(-}#nF5jECnq}u?|z6^NhR_EOR1c!
z&M=)g%;i at L<@@(OAl2#3PG at N_I`jNF(c?5F^}=;&j(7I_=)kB-v)w8X=bH0v!hXW_
zmRVK0<#C+*`E5>f$oj;J2hwO|jp&!+{7!d9?AofI`T23qo!-^FWw(Op0ouCB$zAdX
zPIVxiVRvVM#hcuT#GG5J!NS`q<FRic#qdWpU!>hMUC+uD=+(}#HYBcn*%(WKCRCom
zFEsT!o2~9DG%Yr~<fNL6G=V?c`@{p=vdQbLo9Zo3ySzZK^jBVxS5>(I?(lZl<V-v*
z$wXv%(Xx%s4o?w31vPjh=I7f2d;Z`}(}HS>=Q*)6h?5-p1w)64+5m&BQv0<{YQ_TG
zdXQImy&^|%8H~SaSEN%z`uw`JZ*0$lq&xjI`^kF)CUr&6tWy0UlZ&6I6qUU&eJ%Bb
zKGIH)FE%_|<-{YU;86?lH;1eWJnXT2F9g5NCVv#$O9OSXW~`1fnH<Rz%1fNko1V`V
ze$&g$jaEE&vk20Ae_K61H|!@m-w2$a`J|;*4?AHq#mum^-!Go$J~h{QK?ZEFJy`2H
z+3hdYF+Ox|O5SU7gO30B>b%&%GmxIyz77WGBuu>Op9c*s_%RXIdpO2Bhh;-I`zruH
zu<T>{^M@^m8i(7}eiiF?r#97y+X9N>`T!Y$$vPS5Pu~n4otwyi&*4n%0}su7sO#dC
z^q#?(e<wYvfzykNq2H&nr!7I+-#GoYu-9Gvz|%LQXc3%{o<CAw!?x~V+nI35+DFSP
z)sGw3$R at RzJfL<m@#Q1iWqwt4NHurDaK}4~P#wo)qRQkNUV27=a@<c%7`W_)Tw at _c
zRq&%ua_;MRIX=$_qL=aT8&a)Nld73#3HVV8S!8tzSv6p1rlS*~Uby3_%xl1c6ph#D
z3YI*-a*U6C)KDpAzj4YHU7Koq<1pjWW+{9hr)Sx=tnBy&V<xc#Kz@!3$5nl}1n`(|
zZigXGW9&dQV577NKk>@|G-|yWwO%Lou~Dl{HP!1exsP)TM~e<q#yh{6cpKT-o2R^J
zNp`Ov;V0RipxOwt+W;n$)}32&9sWQB_GD<=56A|HEX(w6geAX at rKe&9RR8R=op~j)
z#BMWBC$h at EP?2K(rP9Q=F`hPf{&Tz9`K3v)!fw3#%UtTRu9TY!D^dDKkpwggA;~Kw
zD~}miee5?}{cGt$n2#8bNsdV1#DC0xPbTaAJqbyr)CNXPKEOCA(~<gmVauedbC4x_
zD87LuI$lJd{nD5uFc}##WWS2Pjt?i*RaH1~t#jRz<GSOj<9#n|&+dEihhp6I((^93
zbgkUD0q}(n2fon<oM|}6j{}Sk0!JIALXn|<aEgTz+*2qN3mOU~ho-`b^Vnpye;^^M
zl-)qAsSQX7Wja=0I(`MDyc at vMu?#T$W_gF|Zz!UsML92}Ki>BIqDs1cmgW87EF$#g
z-!uxT1yNEJw3AaYbr66FsF)-paL0{;1-oG2jF_qyN};A9xepEjt0obGUCf;u_L(eA
z&SPhMa7Hu!gV`kij at kadnf(mp_X%kI`Mr>;5NeS0a;<TLiV$rOJ%sNF{TLli=6<zI
z-CP|kN^@`q9AX at LE;;HM60;G2;mh`)7|w>e^hFHLWsb)Nq3|{5JLr at Ia*%W-DMl(L
z!YN5H>W;vP;7B+{fs?>dY+MGfn+AX+P>f^3Rpx<rQKg&)C`|-GY$&a at j^r0A&zlIa
zAsq>i558rSON$tZh~1Nkh?Izlh=hnSoJ>We at 94f0&flFx!aI>_>H`v9B<mYDpg->l
zR(yIOs}_y~dcG3#oY*D&8HgQ34PvLd3 at r10_&+HaE(6QG|14Cz7%`x0UZ%Ei)-&EJ
z^{~w<Likpx<e(-x>BOdg4A1!A4UhePc!>t28wml>Z}wj1|Bq@;Pwqf2oJ at O6;j}TZ
z0jGpN`G#`Ox57KVJqDpI9aEFLgyMswmyXTI(L at wGHe@-5fIh&sdkO*e0YiXYzyLUf
z1BdR3<X+z4e2;|7`#sB`OowX^fc(VWpV`JPB;gaGZ~C`l`9Elcnyg=O8hdH+HNQwS
zcrwI>xt`#E-0uT5S-vVa{M(v~5)Cwl*qGN7;*R at 6peAdF!66X*xNdr;a78srP#&L%
zvKugS<wElR@<ynlS^8mc^(*#0@>0B9c&&w9p8*Ggznkkoevc^sfhu>1f_0B5|A8v^
zTo$_%OgO51_O9HcJ(N0#IE%S>dLa$VCr4|Nxfyx#u<I+Nhkk$_PIt?md%x^|F1<9=
zWV at 6;NY!il3Bi5I(8bkB(`+T`4+*zlk&iT}26fpl$;TR0qlEnNcbk1T- at PWI|93IL
z_Yj?s6l8`;0O_D-7s(KZ;9Gw-PQ5_xqMv~a_#e1%hc5qtFu&paH*&&N`VKi!?vQge
z>kwU?7-aT)e5!Y~Fi1--x5&s7hC5h@*bc;j=GqCpn&a$L;GkqIL0K8YC%{w0OOUg_
zSM{b2AUgE%vDE690iq~2c7s<<EkJ~ehR2|HoqUIG2qJ9o=^noUrcprJ?BQnM&J_GM
z3wI{sj((dA`JRMCHX4HuO+mmY=+h&Vb<7^3ATZN`77rX02v;grh>748la-1hxZ>X9
z$vw8*;mdEV`RBpV{vHhHAA_lU4ASVXwIjc{#OESrgR^}M3z!@RfvaiYO~wvY$p50C
z*`e~e`M(#sqFpFDz+a0jnB<VQ!v}{M-ap_5<M^=VX8UN2FRiOqZ6#*we&z%#F`2~l
zBE2p2(|mtoLpU5KW-q#rxRiioqFP=|-OHEZ$I|gA0f&-@)>o#`O>$}Y>O6uzg|80g
z08u0x-l9nJT{BTAKD=fIy_0DBo6+(X_TON0*YO?r1l$8r-#>uqZh`;GQz+u$?lDpV
z2yXkyHmF!Ju^=5aU|U@;fo>GYJpgX}p%uS1B==rh0&h5my!D<?8@&Hxm8I at hIg#zb
zBA>UbmLVL-JiU&N#`sz9YbQsl{D02$Zcx9dK3_je_eMU8_;mAVN)+)@+VJ+_|6k)(
z)*AjZ1K8bE(L#K^D?xpS4-Zor(+D9^EBe%XU5Ci_g#^5Cp%8kd``hT<8$dP=1Mz!-
zzGE3&pd;DXsa6wI7 at Bn#`^vigAuaD1nyv2C?j1E;rSC=P4(<Os+27DW|68E{oa((m
z!>4Lc(veX3KJ~%@p-DFs(vrY+xV8gd;AbE%&>hi$IN-zydU{XyHt??_`mJKGfcl at o
zh4$nZ4R|1;d(lq4ZXXf--xoB^1X)+*EbO7GH%50DHDuq)w?>5uKZH6TZq<Kl+;3}c
zd~eyM?ybC0lOHe``uK=;{Ywu~65CS)!=_KbR0F2<gg)rE_g?w`RJ{Wf;x4#9apzOO
z>CV6S)8F{*d)%r2dw7R;>i>seP*a5|2DM!HJ-mPExM3<{fnzzW{(CiFsAAAC{0;ca
zhkHzM{KMV+jVY at 4ZYch${6In^d`%^rdhXQ#1+E5xH&Iifk1wU)-^%==3ch}p;r;w9
z!ta05$k+TP(SUA<4Szi$__*H>YO-?0Y2=l}*BqK?@Op^t*?L0MaeolhWc7;ky%!1p
z-_*<}^2inVbm>BJ=`i>c1pjk4Jz}^bG9~EY-~L9+g=7J at NEB13VzwLvKfmqY{%P_0
zFH-Rvga0ZOQh!Lr;==6(rT)@vRdcF4k-6L8_OW9jh%xRaZMKO!ww`wbHnq6HRM%Ab
z^Jso at c2=Po>ZHS01ohH%bYt7Ux>+y~_PA+R+-sUzbi1s+)?%yL+?uc7pEy6k!Gz}&
zCO%Z;a5t(q>{iLt!P=YJZZgM>#+&sPDlNwPlX87KHx({sUz3faRyEUJ^oQO2+8x-|
z at qxlGdjAD*Cxr5DPzjxV9GS?wTura@<XK|0HPK^z=l!e|t$`W9uXY at l+k6YC!z^i!
z64|6OFf$pgOL3vvO;}EGY^G|8>ux6p1Q_tAoj6ZHLt*k%?=M at p_V5KqUAu5={5Jj0
zkvtvFN6-~<#MVYZb3^@P7a&RX4OOlDQT)7Q&3Csh-wNDbMdwnF->gHtrLz|#EIxmg
zt2y6eEo}oWT&5nZP1l`c#$U|rCmPT+uI(N(XV-93Xe=1e%;z>$eH)`GdRe6LU~yJ3
zTc>Nz^!3 at B+pV=3m`4WDw1xYO0o{B at t!N6S?c{>g#r3}Ti0I&w at O7<6O|!rIZK3)0
zr88{t)@HU7*1Vap_p7{$oA2b at v842s_b6t%&iwFA!BPITa8-EC`=0zoO<iHL62)$S
ztbEZW!gxKc;<r%A^5zaVFWKXZt<!wY-UGU`#WNIym1suRkVBcn{HmS959Eq?`&IZW
z|7?5=@>+-r;Fu*&(*)0Nx7jaYCS8bYg#HG;XZOJOAK(Xf{y}$!;y1wjAxhM6fMGwX
zq6>w`L&my%l+^m1onPJysR$7TnZo^^KSS2L at Rj7=_hJ0Q7ea?a)V+uC^xnhx3`M;2
zFk0R*9mW;Fjg88uQUVCyLEIZ4tzeh`onvr^>ZbQ5?6+^9`-j7K4=3V(z{zi`8gcdP
zBiu(Eg9oumSMc8vLowl=d5m`@+`sz^GI8B|JO6 at Ae|Gg7nf{)*^<R21+Mx=#`QH~W
z|0%jv{6}<)*@e^v$iuU}R9xdbFsBh=3Ha?*eTDe^b=LnS9us|1WIB}Pfd at qdOED{V
zt_kSFQcThR)arb`P(f)@yZibTd6Wwk<!~f}zK(=)cqZX@)*$shgMjr%M&WmM!SCL5
zN!-fpP@!Kx`|kbxB%<RcYFP9!Oj`0bXou?2^|Nws$&-kln at 1y}PydF-hdWdV*U!ql
zkxwF8ZXOMbBEqC!-Tq%2SE&ehvZ6iI*dyc?lv at Ru_@z-Gd8=fER$0-OYV2WhY09mf
zO#H7=+VfV42zN50b=26u$muJ$GBNQ>p=9N);uBhBM$4<Q2g^|^w?1X!mqhW+Tg4^Z
z$%qytU=I{uP--E?;Fmx!W?02UvC4>KCSdm$Ph$^Pu4dpDN04AxMMK$1k0c{t_Z8Py
zYQezZ7ejc)u!@9Yl^%&n!2VgBQmF+IgZ~u*5<~Va%4&1uB at y23n;DSUB^RSN>M}SR
zM)E;4X3G at s`b{!O?1+oe3$+!TeNM6}5;J3p2YaIp65HZp^hC`7XCIS%5Q*tC#e=>f
z1&OV2F#=IPgR}QZR)u5gO!3a&%<QG_zWv(^oAlk+Gyf>wftr*>z~~3dt?7)xlq-7t
zGz*=Mq0%8PQ1TT$VU9HFh10)c-eRoe{vo4(7vF&bBX`FaIB4MjRWYy+|Hn~`(Q3*D
zGS;En+ZMRDh!&La<}i~uf&h%N^4D<S&QboIM);jl at cGaF865l$6tvEWL63Ji-U3w%
zggd^#K{-d4Y-O5*^<UKP|7F(ioxN46<J3>WX}zNB{0I`MSH@}h>~H{WNw{w?{!{sW
zr|<r%e0LGWy?e%a at 17w*5sx#x`Cx%re|td;3(WBT-xt_~D}$W$4^|}nT`LCAKV2x%
zEWB_;WM?JDC7#R>Z_rvtHYC5O!~;EP=Q}h<6&bv9o&QMZ{j(ur{3FEwiy?~o!w}KO
zU1XEOlVBJJvi9Ma at CxUFtj50t1swk-DELd<{R)_mXi#wX^@raOf%yz at Gi0(NKmFf`
z?f$I~oarrj77=vwXj&A0h{uQ9pkGu`*U$dXjsLyy?Y|%B-GA~Z0^>}%SC}bLnsz_W
zkRmQM%g0{rC=8=oxtE72 at ii?t&yXYze)^n|+R+ybXXRcNrbH>)(mX at LxYSG^WwoPV
zjF-y2v`mSTv=MoRkK)KPeZ<s`0x`~%dMPjxC1`9J46*%FGd^(;9Qh+wEA<d!B#P50
z5_dBs at FU=%Fdg|KIxF>HV<d{vurU~-_@}0SdPH#a8S$l34+=)&D;it|Lj-^F^iK!`
zqqm4h1~S)}LEdz`VCw6nSW({t)6r|Ja**sPSCALoAeb7OL?G(BWI77NasbKhas_$P
z6@#fylVU}DhfPPJSezi)HLf5aT^N}9Fo{6Kx5aey9P21ecAhK9gU;Gz*qQ!sFL;NY
zpIQG|)NkRRWzLCA at SW!eBybFQ7SJrn<3oH7UmfbFOEe at fbUo|vND>#ibF)4H at 7=7G
zluI=a;FhWp9AiWXJH8mD!e7Vn!2cUH;XTdoy7-w(3h98?0$lG^#db>-4yXTuTmNN{
ziU5TV;z`=28XjTL)7hW!>olYo1$-1d3pkRoGbPtvt=*H!D-%hRSKlO2J}UPzGigfE
z=H?j^!~rvX6x1AoG3b<gpD}4l(gx-k;>BHM_z0^x1R}00^^jp`O3;`x7-IPYGd{5p
zIQS#xDD~iDXo}NFGZ;Sfze at i^LEzwv_))0`6GKyshMvI?*&mqx37f#-Ga{W*4-$sv
zD;hKg!w3E+&7ZD_RBjPhK(a6{8E?8ZF!fcElc?{Gsme80CP?;}OU8??6HI-PbRyzA
zXQ~3jdJmG_=92NG`v#^yNpceL9WYgaVm$@PLbzmrbpBxKgQOE--v(2abF7s#*;$Ip
z`M<jetX{~9Xx`ateaH8tKKq8S1*+$=Ek9fLWFBa#b0~j%WSP8h&DZ#NFLwi`!j?gJ
zJ+C;l_oJEI#w&PsGeH%9tgI=(%d5=D8x!FDb at 7V0^YZD8TiB`auv>CdQ`4!J?(ykW
zU9*8mN|Phy<i6yIfy()0$2k$=Tb2*7=r}MKgT>NyGNaBb{=KfFK+CyG!!%6rM5GK@
zp&!3;-K*aq+PSjZs2{dX|2Ri~|I%^$H2m-;M>!Pk&UV6hBLZD-S2*Az3?qu5p^Ret
zBYz0bb)D+(<Lx)<haeg3pT2J(?g}nFckgy}hC}tA8IAj2On(1*0{;c&pOZ<yL!jTu
zB!dS{3)}v#`={cm7w)Alp+p<ChQDj3Yk$Tscd^UA#xH-E%0Dw1h{y1Fp=Z*g(WCa<
zor4Kas(N9YBJ)myPxaX(E5u^+$n#R~2`eu&4=WFTy4DLOHz}0Dyj23i(9CE>wX$G2
zR^`^`Om31WU-DM*2(dDwMb*jz<@S_X$T8d`5G)y1u~0%YBH0Ma{KZR at S_m-Q#1Z5f
zRv)5ZWkgaDl=+I=D79c=xQQV!Gpr(`gr-O05|n)wXH{xJ#&COufXT4>00k>O@`fn#
zR(#9g)fJbyH|i!h`-;R*G-l5<^7>5yNbH2m+zYiAoP9xpEE=<58VP%20TSEcGWSHy
z2WOv<_=&^}nMOk2FoDEYxy*s6!Qkuz5 at eB>Cez6CH(P09b6n>2zSV+%fAP7R%p8U<
zU|pO=$ofNZcR|2fVRaoxvp(RuBD2n^c@!$5r at dCRwl^x8F(MkRxxcbJ>cmO}kpIq7
zl#t{3((_!L)*v%}v!2L#Wb1Hmt$KZX)0jA3ZV%L=>2jG+;a81xxLHryzb85i*&jN0
z`2P56Z*ZEeIE!e1!S+j&@WvPQ?=u3a)?Z?Uy6Q!DVQ%%E237v<y*byal-s6Hw>mxC
z%i`YD7wPo6Qn at FJ+S+e@ou1gQ7D1{7X{Iem-S*BeDuB{u;)^L5yX0luE>&c<4fQ0e
zzOL6DbPlL-M|j`lcdN%ZT>%tfZ7#>j3g)?NQ7^pDuF>jG9^2|bzj5z=2H5)pYCzx@
z-}EB0cy1M8s;snrGpuR4+Ll4)x~HeFPd6(+YJ7Lz&8#Wb>k{@H=N&cUP at H8e^!l;C
zHG2(C;8LrqF9o0fQ1@*b$Ix5b^I9a at b)Ig8UqqOt&ph#Mf5Oqzqjp^x{ijCb>SG0r
z4$;|~OQ6B!=CZ%}X^Hx?T~M@@^fusyY=aXR-4WpC*krpwTg>HkUJ9GWdf3h=<X*>y
zJ7mxN!#>x;Q=mZdbdL%)8f{TnYCpdrEiHI?`a?GOwD1~usU*or3gdk?QEUX-E<lgq
z=fU#L6u;32(QdllNQ`@NOl10>R<vW*$Hvx1=z1Wq47SEwHvr7f2|X=v`j<Djtlo%}
z2wp+eMW>S`L`M%$qG6|7i|5Zabx{JkZXIrqPnF0mk4Gg3Etv$gn3eH_^K!ouZEY$^
z#|H#eIn7#>T;~`MHtZa6K6pVyrPI;x+yBDY(@XXUV&2fv{*n#HrH{7q#ZA8!TRe;?
zI^B=bwnyGb=o^jg>@JML;%K=wV7_`+wKjXW;6%f?d8W#l^+~Y3I#!JQKA1IxgWRmB
zZt|Nz(L({(Z2JDR8N%8{i at o8ah2qo4tLGE?xX!~`$+ at PRZ#_NxQuvxhUzEK=8+Q>s
z&rO8r8#0f$is7<NNy~`t(zJe**Llborf};}{pECnfw%KSS*mH8_wq_fK!!d3%OXnF
zsc<eSyT%nW?f%SR=R&}2R7 at 4B^7?aQ<){Rm$4BnkQ_b at sbZHi%^R-_k`kw^oT`yDH
z6CZ`_hnM at eUM%9MJI${}*6gGhqsCNzb2PH3QH3Qj4Hb~5Xkx#=*fsK;`eLQjqj-*K
zmlciW4&8ddtN?J)TK at P<$3;k{M+4PFS0KHa>Q)zHZvug?QE8LKZTw3iX{J6DD;|RT
zi5CDAn%ySUr*yy$bp1{=N~b2R!K>a at ExX-x={iMYaH+3Sjzru1s@<UV*2ds+a2aE9
z4}O_$ua63YaedcL7D%z^)OXGBN3|YKW+~&U%5mV1k=<eGk7z~a2GW at DH31-YdB#k|
z0Y}m^GJV#uF#Q&bwq}F#8+*Y`)M5<TzJyf$A at MO$ll*8(zRS5SszC&=X11$ZddBGx
z-xt{Q*IsM at f?Iup$5 at WJ+b52i$5W(%TW6;lKe{h30>5jXcMd<!$sFNF8<!6mG)p(D
ze$8Vk*8k*7iMHKTT^I9Dj2;Ps7wLe`<!rC!{a-{LE4MagBZY+xs4n`|P#e)v=aa?V
z{spQt{t0~1q3i&{CJ{B?Wq|=y<011l_fs1{#KcA1Th=h=O_8E7)AQ(s29D)lOcNLi
zzcd?xK%T_*Gf at NZ_v`khR&~epE|I*WvNk#zVP(c*NiNrYDvnJ9jf>9slZZeH_!$Oe
zkdp1P3Q?g<79}@rB8Cob#?y3??UJ+_3^EJGYJE?ugZ5;PeL}0vkGRG^1dPW>ewq}k
z)&xF{e`cjlnLM<t+})h<aKaZG`_N^!?Yw>j6wfNT?fj(qEjl}HQoj^`gos*pK3Rdu
zTxfu5^@sgDwr1;>;jY*AR(sp}py*ghTeL3Z_0}t|-JTco5ek!NdZcRWQGJD3SS(47
zpXS~xgn3Q|i6K-|bZ%o-gsZ<eq>*2<X#;+i)*}wsr~aX at 1GdlIGaP1_9X29<^8l^r
z&6ZSg#8}Bff84pd?)zVPKx9&5^UI|}WtYOz??2|&><Sf^nTidYr<|7Op|6Zk!FA;!
zD+1N0i at Ql3u)~mnz$3`b^TgY;4UJR%uMx<0f{YZ7bC8|e_SX`oT0IHotKJ1{I;B>G
z?RN7Bb$gMxejW)|^TVw=eXFhvt9<s0HJ7_-t2@!hXLc|IWC8TVIekLWRQ&TdFY!oH
z7T^#{G?}n?Br)j3bnrcnRU(*X0+- at pHdg((hs^iVm`fd~4)Z&f;<5}ap;liFn%4O5
zj~l2k?BgEo6;z at k3&)+thIe}@0VkbBdwS~|=We&0?NgU+k-nh?FBdWweT%8(37}c%
z4v03gtfj2H0h*_=2u|yHOhKD7RGs6F6es()vKVj81vAKws%?(_)&XjUiX3yk%P~eM
zJ>2m=X|EyT<3a~u{t?e3hs}zku6h><y|0s7H81)%p{17;%~S)tisyoUEO20GKw<8>
zJl{;vgjJRDUFTL!Y6JlU>fR!G91C}PhQU1JHX-A)OjMPdPD=o6p_H|Ta|7H|^V&Dx
zH$<;KSa~>lPT<)u8y|Wu<1O at GvtO<1d3lr1CVQ+O<a#a_S})h6_;~SHr+MHU9=*C5
zZ7pvm*(0!qQP#6>8`OU&!8Wo;lP3z@|MmiY7EC>r1q8vss&Z;fD`I}X9Y%ZRc+sz=
zO_&d04qZ4~cyqq&D6cn*lS8MXQ(scv_tVrv;ua_p+o9~g at YXa|YNAb-^dzKw$H2)l
zZyUjRHr4W2-M6r5Vx*8vrTx{UE>HY&@wxPJtEWAI<Mc0-q94RZgBf|t0bi?Df{eY%
zy4c^Hd$bMaWu%nh_~Swr1UJib4we=Knw){mM(t!{&9+ at 9u&#s2y4j2k_8cFbB(|^V
zE)YiR>GSx&mEvt^X(2h6gyNprrz^#Zq at 173r|RXHXj;;dWtupuOKdpDy+%~*nf8D(
zT8|JVl<-EYsg2=gin;>b4$mM9otJYa9^YAg+eGC01H;mDn;n4FF0S at L>jEsItn}mt
z!VKj`rrj>~)iG{(g8Qd7TjIr#qe(qg5KPliJu1GdlxOXWb(W{*Eu3)iud18ny>qt{
zmvJFh?ZS05)3+nzv0p9MwB9{vB;DK4v!1{*`8969+e5ay&Uo&i5pR?`*&gEbBb|&>
z_lML*I9JnlMi$_q1OHB77*El5CP4|z9cXt;4I{sl2>fwd3_Ef>xz2gRQ#!tThN8(j
z-UR(}m`UL at cM;Izj%Fkex$V<G;#rt{SAR~nd&CE#dQGxOfpJ{7A|mek+^#;4(uFQu
z+O6jO)vsSc-R-PsXZCZ*HnO8kRIuSCY6(10VUWJc{A-JFTY+?(HTgPza#x-dTT0U<
z)@O>m+GI=Px^b*@276?lUr2c-qVlh;>y*=klJ?J>VrtX?fxECCI)wsA_6M`=ZZthq
zVpYwGk?sv}^%s7H at rz+-#nHjlH0Wy$w4!vwRiCb{8cR5Q%(!{V*=gqdX3)u#8<`|$
za<Af}!Cs2D at U0fTqemb7f$`<1=7~@0ot!<MdRYos$z2mzk>AV+3b(fz&2)2q9xh5)
z)NVENk{cjW06684VKh+QGS&zLKtF7M^evr}`!vyzN(Xr(I6MMAd+98cyJGo369ZD;
zo-)mg_BO}I{JKmG`8C2WMbioiXGc~r8;H`%cZ at q{tiOUo5i=riJVCNhJvEYgB)J+o
z2 at T?zv<F3yoz$(ft2)+Z;V`b9KJPJlS91dUj_*m0l%aOv{(4OyC3~OuG`DXOp=noO
zzRy>5Y3oJRlBvhya_`UUw*(4CS_MZdb#nNIy+^pV9~BdByBc>|lLKI2O%7avo%R<s
z89#KvA#51C=8;#$4lNypxr4jfM`M6e-^*)Y{p8j0^~@e-V3M7^=%=rf9H4S>!X7 at f
zD|K6E{?D-Ikfk=jd{Z(%zh24rvfFcwsDKH3h}U)`p|Pm**G?WM{Zf!i9?TJaSoy0d
zcv9ZG^H$_})85hUOUpCEx9=(T5~&QDQ|6(K8B`merA;_uhr>pE>F3|+DDJve!oX<9
zH-XFo>^nGshB4do{?ouf{45AbXtrTL!mGAwrqkWzQk)9CfE2U#uUr}n`H;bi&5ap$
zriXmTnzZkV`I at fZc#6l#hrV2Y1dE- at z!cH%D(ubPZrNH6<4*n7M84;`v=4q4yz4Ib
zaoUQkB&$I9*M13cd;W5VL<7m`*?|mucf$Ik;ezzU$#KU**_Td~=6$D?^i;`v-!*ip
z<~dpy>wu2$EF6mMUpAiVNNygyTzbUOLQyj)rWx?@(yu;n+r~b8mQQNK-QS2&D16L7
zB?i73$7#UR_;MFi)9;|RebqI8gVdB&u*yrvw+~n at Gxp>OZrPZ<ZoKiJIBVuPPAjwv
z*lTwRp}bv*Z+M|@lIqc1Rb`}xn>#Q}&5ymd%$=~D*55AS2csxhe#o0EK_T?u;@3wA
zzP!#eZ>J_`HJy{n#4~K at if>rfEwn>tTf$uLG;HF+&gBZ~T!Bs{CrCWcZ}-K=?O+6N
z#-09ZOiEXKi&iHB)#BK_2NM11r~3~V&+7*`3xVGDc7U$@;z?uo2;Ksd6eBCV915Y!
z%0)5vPe}68)BRBsdJ`&|&RdM7=SY((3;W*Qqaap&So<O+0P|q|r at et;asQ;X|K&4w
zMBx*%>f<T3_cFyeUzSrKX at l1Ni|Y_;`M{wOs?wimj<*?&dyvYS4d_w!*JWe_szqXQ
zu+dn!{XC at N2WcIIQOH~5P1AY29iO7BrXz`&?fhaHIQNH}pvCm&@L9yJYgwd`e~K|f
zN{-%Q at ho7qtZnYs$408s?mE`^19#J~=)<*#i<BQc*wgHUupI0p at Lm&$ECnpJI$|5w
zxv2M=Jvk^2zJz5Vs!hP!O%G!CBeA?|9=bJE>ThVPhttP<a#*|!Z`zhR8uaS at K8yR~
zc!u(4AeSz^k~wKjU78SfDJI`uEcxO)k4g^*AZ(RzB6?egT8Fef&T)R9UGp*$T{Xgb
zs`b=QW!7Wo`CxZwdmUeu=O$UY3{J)4vkw<`(U+0LY#yX1#-gJ~>F~Q#8D=Gu=Zg#|
zr;gUj1UZGiIj1^P(K~eGYL2x}P3F4)JU%9473~?)7d9Z at Thh=G1=>Vp&t9 at byJvYg
z3FUEMy~f^N7{H<$se~L)v7OGaofS at ESy3cZ@p1||I9L)duQ_`tL7YAC=xBXewdzjT
zs>3Ogm&02ekh*Mzo^$67o$CE4FWfB_^lLwh4SJ&(z>BN3FV`mQiza3GAVbj86O_Mj
zeLO!7t?D|i5Z1Zc;Bo at S4+dNw-yDD;oA5J5g&D_N4*(>PVZe`5 at vv|1*le3qbWchY
zCC3|ejlBc6YN6#P-vuXOp9*D#dy))EyHBB_d||%&=m%nrWm)mg>Db#bT>UfwpTmq8
z2hwXNUXU-41xl2-0NCBb+-^<*KMvD^wrys!a7RaoN5Z+!Q&T}K`f4VH2POlbN<gVw
z63k^JxNT>ooK2%2%oghzum+uf$s3_o4&YrujEHvaSl4r<XAJ;qjVjNyH5!`sxE28V
zp}ek?$vx0vd~5|f8<F8M>UrSjF~AjiMacwYvFDp2uFy|+r0=C3CoPAA&Rk9>lRpL4
zxv^T_`fqM_ at xSO!ruvwTRwT?cK;hv6;J2SU<@4>FIJR?}>k)q&AtZEl(D2QkcvFT6
zbPy2p`SKS@(KkOav)ekG8TWK!8lOVXVceTz)*;=uF?_AQU`J5nx4~XM`m<{j1>Pzu
zj}MzGga%nhe);sYXZ63>6}H^X;Gw_z8hh2 at Xla>93BCj`3#ABN?Nu<YPzmr|gwVNq
zv#<~W_A53ZtR1EMYbH3buafel-S3y{<pv=4l2H*y5gA&V2K=7pQkS$o7^6B$>zeJB
z6p|%2iB3hi^wHEj_;&f=DQ at n?=7`2^70U_TjtY)#I0f%ubyT%yJiGe9%tlx+jw)SX
zO2j(|+9cSt1n7(3Kn7kD2qt;y?om5($aCY~;D_dteTG=ebn4q-nrJvJ at Sy7FY%ur?
zc!qTRZk_b#f*owhI&7r0a!CS4ViZHGr9^dS0MzaEl}=+eSZ}v_O`MW{TE4-d`_Nr_
zFvAsPly$usn{o~;iAe+Fg10W*J{uW;M9pg=X}-(@nTG{hE);jc6X!!+yDqLO at 2Mp9
z(cD6MZ^-+iz8LW00cw#vQ{z2lFnF`u+hN4Z`iFH}!}!<J6EkHd`;2p^1eFPB!95e_
zooCJGQ8 at b9$D3m7PN{wRi=!93t97?_v8l_#JPk}sW*5X=wi`Q{&AidJXbL*mn<FAR
zG&|slL%X*&nahzsv3QGakRg(25?p~0o=MxV9oP(gob|pgqkO<i&#=zAr(c^q=*GU(
zOO!#^I+8DSN)kZFv%%laaO20zOCF8h9G at OlsP{uR8jjA6k4<l#++nf2<lU<6rxRs?
z=>7e`wHxcCo2RA;{a190KXYFw(jTVe?$%WgRh^~n)ooYq){9<4=rK)_9(d7vZk+dC
z?rfUit-Z}PbuA`3Vm!57J at L2KS7zfWji4O-AbL4vCG_F;fl~e3To25#`XGZhi_{j=
zujI8YZ;_QlRo5bKqP|{#j|N#4UODM}o3yLB;T#?Qo_nh8VL7RyJ$))SLWLJ@@;C#q
z39FcxQS_*8866s^(XqG&46K{HWssQls80ouKGNs)7PO(9iF;^&`E!2|ADzfLKCNFv
zEpUS~Zgkgjq2S%El9)Nb_2P+g!k$Kv{5vPD_>^4BWK0vcU+x&Lmd2ya{gbS^Bonqw
zMB49hVP at MMH#av%N#~P|RdRDf;-khXyvsisAn@&;MncU6MEeE<n^n|c_;Um`03FOn
z2i`&`ec#m6Z#*l*ZoN=@SgtFoY;IgFv5Mhb$1W_TN{HV4y4w$)>{lGG`u3LDRunX&
za#-}MK(<h9?L%}zg!N#Djw<0M2x|&j+1%^Bk>a%n9P3+TGr(Jc9iqtw`v+z}zc at K9
zs$}Z*+EbXD5jALZr at O|N&R^f0-!CSa?v)eqJaxF?n<~upY~Eh?rBKm!$!M+;Ik|1e
zb%jca-+pMlK`5=YjwAD!7Ku1pCx<l-uf;h`?Aro_%~pPDYc<RA+?veOlF5yAq=}U*
zmkt58;)WV?O}5WB;?ueDL$@m!krWC!wI_A1T+kGQ$7C&z%Qq{?w`IMKS{{NATo<#Z
z+w0m6x9g28+LY_AFa&#Jsf5`ne~t!O_YGWKO<ldzb~DsGFLNAo%IvLaE8DY!*~@nY
zc%8=3@$7@`MV;H7^rK*SS0Pb_TD-!l9=P9}EkiCf>|kQH`tQ at eHY6|;yd2E;Tzb?<
zYnlRzz8uyrZwx#uEuz(x7hP>M&xHUM^$qIiD`U2kY+#r*6KSlA_L}aqj=k6r+-HMX
zSus at Xb?z?^sgCNB$-qeG-2+*n#Vfx$4Fidc8o)KQ%Y%<qZ^b_{^w)@Gdq1<khPq#q
zRD;I)w!yjDD at Yb~ny=+!=z29lXu9Nwyx<$r<^#O$|Fp;Pe(&Plc18|vZe9)y`1|)8
z9{=;fYCQj~gVm~Z=c9GItxK+ScU1 at UKB^=`Uf;Snto4*Ly-kfa(XjcD at MW6zU3oyZ
zOo+otkXw9%<O3(9umyf*8}e?ZUbM0K7Bp^BQBNG`+0x4cH0j%(_T54<mkaXS#%4DU
z)tXng5Cj+ywsoKgw(&YM5sWRqB)D3h?kB6Mns~p*wG?Sz*75|hJYASl8ZIgtHz=J7
zY*@mt)EzzS+{7wdd(sELD#6;3GFena)SspM$?}CZXzyfmev`b0K)$F}+e;|*fsrIt
z#I2XW<RDM1FJj}O3jCy#nwVJ&*?f~!w}3L*yweLdftzXFlWo<xNVm{#w)F^*o?}SQ
z<~i8QpN at fwL+q>_xw~0F81_uNa-zM$n|5p8M#RJUm`pdOXW?QoS4+tDTSuh2Zl0<(
zAjNU0q82Im_>&_B`H)RJp-U~ULF(|TQbtBb at 8$4&!3EG!JkSzgg?{VG2USrLr<D@?
zNiW!?2;UD`-s#R@{RL_JU3YVi^(jrR09F5??OW3buTAP%bZ?IkMqAdk;B7XOwogM*
zL}u^1$`F{iil)4;FjKO-B*NimHnDp2$Gp{Ke}%vT(d#hsmlYzVEH~49rH4YK{qo0E
z<&-9Vo8(A%byUs1<ILBo=r0aH3Bem)(Q(a#jxmG~ue4 at l*PrRuga{DXwJeRh8!6Cs
zn)wVnkRf?eQ at Uq?j-q0jdXRRfmiCU at 5r|X=Ihl^sZ9{!?FC*pqfbum5*Us3|!AAfw
zj4%~TGBqn_tZ}J6MY-COB$=vS+K;6|?VL{r>q>1MdTX(V&`F~~k^yW2&OhATka~W;
zGIe+={uoO)D4$d>a$ws`d*Ug-(cx-vl9qzMW+Vkqo(yde5Aj#j$m~pU-O3}8cUgqd
zgVd0bV6tATN^#DjEF(S3sKZ|!VIMfPX|yIr>de+2Rg73XkY!?O%T#}>pA>`rfZ}=l
zi<bwlKB$c1lf*hn`b4_wN2$3u_%XBEBt9w7&P}!Xg)LQ&oabdVxT6xP^+ at 34fsohO
z`D628x0p-HZqMM%rc%j(IAq$9%Gy#nx~GMwB at f34WjXUWdbpl3l&BGOnMjSh1iz8B
zS8xuNVtn%o_uxBAeYV`%z(7YL3RbwTE8P?ay=k(piAtqd0gi3&>S(^zOPN-k7vv<`
z)b6fI2=RP#-y<n&rNpH&eUv)7KPwF>{WwhIQ*;dIPe)cjiu2Mc!>fL5rkYAM#n9&e
z@`SC at C__DiQ`sjr)4)ubK{0j-XJiO#!2vyV7M)P-(xkO*N-iVL+|V-gb<v3HfL1|B
z=xdq69$UX090LabZprq?ED3MXlcS3QP%(`P2~fo;7POH1sV*m5jJ+~am45MNsAW7<
zAZb!!6!OCmH|h5ua?MlDd(T~|NlYens`OeY&;K>8;dr01eTL*~fF$~;3QL^Z8}2vb
z4jC~*RWgGXX7KT at _q4kUxdFx)+);z62FDVSOT?rydcKqs^=b7TYQnF*W375bimvJT
zCNrtCZR+VXU*KmJuE`AV{#7#B3ng|8MmA%gSRM_g=ukC3#D4$$7iO97HWN at VjSIDC
z--o({OUY#e!llJzXYkO&WgeGm#y*!(Zh5C6^|Ppzoiz4U!3)&^s|WT^9AX*8i+tEe
zT|=L8ADJmdSJN^r$$WzUEWYNOjk=*lp+1r8uTCEm?WR1DzQvCD<5jHF9#a_F*S8s5
zewEQo1&_DV^DMP`2C at q5SuqRW7NqMEg<&%VpcB9(i0w(JhielyTR6rO;@-$b8 at P#K
zH?cfF$jdhRX>YVfoG{k=)<{=Fje;&0fePiL5%v2=OP>nHKhjrm`-?B2gd}r*r{O0w
zcYA>TL?d`Nqn7XXBJTtD^VZeS2M+E+?0DaUHe?D-<mtaXd=-5qf5c<A%pto}gd9?c
z(vQI)j~29 at m%NbvJ~1uEH%5HOu?z725!gsWMI>5ix-{!;ugrK1Q)_Tneisc(5ucGf
zlsZej*J4MEoj;2YFEJJ<o$-2%amBs&=2vaF4B>cQ+E1I#81#ncfYrOH_QsD>6TZ{p
zd6`H2F at 1Gq_TdH|A|!hAvrlP4G=glw%fifXKkZSLl48tFH#Ke?B_fSCZ^ed-x}K;9
z$~K0U${K2PeH&wrVB!jCZOY4&%c~+mk8QzDa;s$Ae4_CcOU|dQwkXd%MohMYXjfB<
zdF=etCaK at groi2}s=*IP3ZtDS<;R%JXkV!1^qb5)ER_cJW$FVKqRb|TJ!r;wPD<Lr
zBB{E4;P7t;c?Po9Y13M#iIQh;dC6=^QN}}t%8jJHRZX_EG)D3kk4ScE)4udU4e02a
zY>AwjaZg6ujC&5*=8*jW9BzrcaJ4WD0t&^!Hz*Z<ra2nX2xBS0i3y=7{Y(=j|2b_^
zk`)F1ANhH`T4E8hPxrY$tSXQ5)%g=rSU(GjIQuyTmzn%k1Z=En4!oqa-fyoIkEtu7
zqk8h5YjTd5qhMnNhi`m{W12;ZR}MzTWC}>ikA{Dkzx=~@nQ$Qtxs|t{Q3FH at qNrog
zv1DoS%?x`)UK9zC#D-!($}{0T-+lN;`3D}QHD#06gaiatJnBm6=V(a^?7ag5j3udX
zUaINxGl%wvgcv!%{y)aPDLT at iTYDy&*tTukHakuxwrx+Wjy17u+qO9|Cbs{~_pSfj
zoSSpgy}DQJ{nma8 at 3X6F*XAW9nGkj%Iwq6KeSt0r5d^wQm)T{?mJ}*V0F@$<2d~Xl
z>%P=$CK|UIdPbJ at 7f3_YE%=0-3OmE4$={<D)B&j at s3|2Q(odCU at N-G=)uN5GHI#hd
zr5wnb&8-z(QWsQ3fNj+vpz$Y3r!+GkMsZ?NHw<(uG>iEOw9yi3dl1QL7E{pFlML86
zs;~*KR$<DIivxnjo^rg<Fr{Q3g@|xkHR@#&a8hi at lD#p;8X8JM at M~`ih-m+2Py=Q1
z0K!TY8(2}e1$Wk}f`~jsxHT+Q_Fht|+<>La#)1$uwEfi6<=HZ0Hqt)pL|4KQB+CG@
zNHOdm2In-`q2_d>!zJoK)dlff2j%nxB8D$ZlW6}7B-gn+)Ma!X`!Sx|9$|%#*w;r|
zvl2LXdJ0a4;90<sloU>C@@Zd$l#P;>)>o&0@=aK`_ea`d(r2M>HFv=cE?oMDCNl#t
zSnGxv7%X%8U7 at -o&RV+dYwqX-{$$nrhfZWrf|bUw=K6^<eBV^{mjRJT%cyLH?jnxD
zPGwBRPorfCWhiDfrL{u;jCFAQ5hJEWtXvedH`@Z#8<j0kVb+>c!-ta=A0Ja1a+`Z2
zO#An08Dwn5aDxLQH?g4r2LZBD9|XlkqzgBcN2Duv5b?#5lil`3Fn7(T(CtM28&uq~
zW299O0h(B0*kOisG&W>vs3GR+sE`?g`V4{&<HpkSztl{<dYGw`Mgq&aiF0Ik#~?4?
z<$h`F>vFbkpepMl*FqI69osQy7Fg`VewDwr?E*h3fDRNhinQz+#hjwFW7dHmcb0Nz
zczvb(yWc?3o5z#5D*3ZRLKz2Y0!?x#DHGg_%(07IW&}%>`GWxX at Qw?#C1TsxQ0<Hm
zuM|O7KlG(Q<#>$<Gp at -(k1=cQDOkoJl4=!FGmunPR2mIS)E~MN`+-=vN%$Z~bhN6*
zM!cws>8P~t-7e*yU^4 at T*llAEMim7qd})W2(}6}_UsUELYUeII at sRa1^^tqw{g+1q
zn<RL6FZToviRCW}sp?GOMCf07%tT4(V;v}{kSXAC54}X at QoUnS<)o)UL3-^`{G3n5
z+fcvKP>+wn{A+*@q#<b;$E0#~G7q;|4#cBcwMqn01wIs%jPx|rd{PFew0oqvlwQC<
zh}IN^kB5`lX~_~xL0yz&OB?T<oAr6Fc?v{20zcl6%Ae_Z2$}o!8S5X~iI)+Kk%@s+
zw^5C7OCxUwQxck)vsbBeA;VZC68Ws>FE9GP6{AJB%{$Tvo^_7bBacC6jMfAD;e&^2
zE&D)9aX+2=&YkER_Xt$yLR;V3uk$fBL`eS(&GnB=?tBs)<eAif^fn#hzM~Hn%XjBg
zD?_7oJ=7ObO?iJ~gL?@L|06T_Gr8M`605mvE+dl#-MLQ9ugduO8fo-!o)$TaqsxfT
z2#%)7SC$d5KIPV%w<!T0xw;)`bZ~agZu{cb_>w at xThlk)H4tnVvzw;H6g!BqExQ1J
zx;zcX;PLX|EdD$gYAD*tlhw)`Do8-1R at R}y#m|$4<X1H~55{|r>F>=YUsZh+OtsVg
zyyrwCxQqkZxug<UQ`6fUH9^2W_rsnHUmy!Gn4i$Jps3HyNW238_qJj`iSl85F&o?=
z%6^YNz!W1dBKZ52(S=aN9XNRyTXL1Dg!592!}$jN`M&p5b~-*itS;}cA!vNM4k4z`
zG`PVt{jot4xt<|^FE~M?%utoK>^`Kax;YBz0;tPV9gi#}3IT*U2c4lO^x6%F@^?wk
zUaBb0d3DWPVi*P;iw&Gl628*)X)N+Q_tv7Y#xv}hRIIAm9IR9{_=ar54$C{QWR|NW
zNmHs8jzkgNYqbhIY8Byd7WjtDso$LiOqB~H1l;0MnTlz;qmhKD!=6B-U}MUpVBg_n
zY9!v>NmDI+%sC)_GlVCW!9lT5JMrcjCKj%7mNczEuP;juAxR*P22jBV)%F+JaS8l>
zTsFVmLD}$^>b968Py&rb<Auz0HY0#0kA_sGvX5eB8WNCYrX)9#oCtM_;LZs2gn7oq
zpCZ3NBsTk%jByc0#-BQM^m5)i%-(fXz(MtUTy8mXXI;I71JK*;F2a(nh{gBPN##=~
z-RRpukYTu#33J>RBJjui;ZZ*qZ^~aOzKdwH<fU{a0gSciJ;}0C6<O;$$EF7^hd>|H
zo?9^CcrB<%=?VuxAI0YhPJ6IH^bf`v(ggOoyPNRYAolBUS<rO7N&$l^%_8NEb7~m>
z-rN3nqXR3v?)3~VECYN>?HmR~PBKIC2%@xu%l72LZ-+?F*UxXW6 at CWGFfW(S!>1ZX
zNuN|ciD$J41-w0LCaO|P8}eUKLBpo}F3qnIy3)}vK6LlAb!GzkQPenMO#{D3xda>P
zluX~`@%yi3W1Tg%H9~7a?VJ}qs9gsm;<n|i;ubL3{Y5JVATG&+j<SRr&$bf`XvRNn
zKiahPzICN`ccB9y8shzUTJ_9L2X<3nc564H{CEi9g0}IBS1ww*47ztHU~bE+NMenq
ztB{5cjRXZgE?Cn}mfRzUG56<ak`ZSYeMQw}TU)JDI)%I9gl(2kqE!$gO?h<*Jf9*R
z@?(EVnAO?MJbL8~u|p8V>Q9$43_O&%E!mh4+bwKWQ$iZfE6r;Jo*#c;yF}ShJYcjh
zF^%iX+uONr4o<KgGIjehHP=W)AcK5z=0&Di&b<9((&M>X7^Bsfz3w^G&>#IBk{Nnt
z7HV?*?(NM)5ZxU8?x2 at xA)A9e%(Xo~zv5HnBjL#$I<#{342xKOUy^bA9DOb8)YED|
zY{}s@{&+TOJp`AzR?-*BE~2<vYm-9mYYcxDIfxRxe5<S8x}NpASykTQ0oJGLZZAUS
zGQV9N-(Of+Xh~- at HL+l-OIA}sncqJ?YP~&d#^~PFl9LHL{x})a3>}OZz1M}Mrqa7s
zCb`1MVs`|kk$=W%Xu5%GzPGo_T*!+YZR<9bsy3L}YoVFH^lpTG5zI2aJRo0x5sA{|
zLUlmaF-_od3%5eBBv^Fcw}p=-rB3A3mc~TH$G@!xz<AG(7Vh&&x12Z7t<7RQGy?T}
zD<BzvM?k#R!XUu)O;1;zd1<q`Gc|G_(=|)8mSw(<%*S8)buW|?v4Yovnj&aonapwP
z0LQ-&JhXFdER)JaHcV at b&$rAh^g!h~exE!G40u4uiEn&jsFs#dx}Ve|tJ8;0GknS?
z>hV9vL8<+#J$Db}`>{T}w{x{vh>gSV*o}@`PJ`0-b$c7I2a8TUH>i?}sOg1?I9XV7
zNhY<=m)|ngv$bIR<4yysegVv<Ea_8H_QN$C$tVj-<JGf!YZI}4!k-mId at cMrfFHZG
z`r)B?p)=i*-DA6TiIFVXkJfygJdGe5wQ-nz<Fj=QvZ_3g9%3f2YU<3tVU{Ai-$>T{
z#h{4t_RK2W%<$10tyK{KjoZ5Kn at e$6kRjzTj%$BwK34VGnK#P1a`^U9kAHvZHhk&o
z_7J}&wj1iIW;%*(9r7N!S!2QzR6J1d70)EaU~T?18t2x0hJw&PVqZg0`e;jH7CFzm
zrl9L0PT<;$S=(L_738=59*c~ps-jV;=*R-Wh}5 at Y*S*_G&1|taU<~#iTJve&IO{ya
zzY3LS#oAFNXR4_D7ou>rNTFbc(Y+#i*l-W-GlQ}bVBh!I55KeNZ~oM+BfM=iYhKNB
z#<Xke=8ZnFo1*z%r`oB4OD~KxIJnxZzd6v6g|rt0hwsI7^y)!lX6sYM_uO0Ob0**%
zaCRY^H`FirwDWNQr6=e4W4j}%P=_O$0XK0{KU+{eN8gtpe~a&&?sm`5b^EyzpZUD!
z$>>Rcm1oW%YMTMk|0Bu_TVLys5r2nQuU$v>2Zt|jOsL)+4)43?<3u(KfI4p;@b;GQ
z%C8axJl at RR1~&T{eCH%7{P|%#T<&eNu}wL?IKnaid}&5<Cp0`vW?}8oNpdPdq2uv`
z=_M59vk;3uBQ4v)>fSQ~i(~MQkPRb^x{yI?ER7ifi~ju_LD{&s%0~7QZ47g#jLqn-
z7j~z<Zaqob at sbyfkY9VkjO#rkyRVoZkp$Jq&m-g6U~MmEH+BP|YNTUVe!cN?bt%If
zhwdx`HnbOwTmfdw{DkkXL$>KX%D1}mEX_5WCkjo!6w%v1l`nU?(~AG<ZDV_{v at dha
zo-vZ>cDy8M=z8HT5p>V2zcd2l#AJw&uDlzYI&4~ogkiTXa`Y~~*?=5w3aVOpZ~b}s
zFve*l`q`zG%Af)JS<W)bwmdZsf6KggmZjphdakN>2G~AJxUQ~#oI2_Xt#(_zDc>+L
zYKZOKFsa7pAFByDzo{GU+daQD6Hs}MpWN(!!qMZVV$f>~k{^qj{Cr!eh>dD}T1ZpC
z-DADW$oTv|Gkk9MzZXXT=khle#{Wq;!T!Hf&$6 at qUoL+e)LjQ=Hak>h+CESn((}+?
zf*l22;tskFhAZ>Ww8rbwf31jWiYOCPQTYz=%IFclv&}>gP0 at -CI~%6x-okx!U*~?m
z`+ltH>tjzr01y9}grK0e)zUwG>^E)K)n!o}_GusV{<eSchk#)7t-tyu_qWyv6E41w
z at 1A_;qv{aKhhj<Xi;8rp1cM!a`}=k6Z{fU9yXm{pN9Eh|`n{~j;yI(v_h}=6)*Y`F
zAMdDQpyy3<_1(P6``w{?iagii!m-Wsjs2Y{Nr?07<#4;JW7bP9ya?yP#ol>0-e&1y
zrdKY-r8lq1_S$*3`K!W`Og8>}cyO`v>sPvR1$r_v;9a|f00r8 at rIHYo3V5@hi}&4+
zIdiK}iBIUeM-BlG=UW+13X$!*PlBRr$1=9Tyv at NTPpgalOqh+$@0;KX)2e<gP86Pd
zRFnM-F$Ip>-V|aYuU*ByuWuUiTz6ZCiB~D1MkPs}=9tGhFTF5(K3Y(nzm<6we5Di4
z%$oh8E#PYRU0>a9YPUWnujyynoV!+jd_1H&a<%H9SH~9iNk-;dFNj88?^`gcMDC5p
zRsfUX$z}t8zu#Cs=is5kDJi5w(JR%@1xLwe&|)EVo#Ux at G!=AouP-pq7F6LC#TQ?i
zrDiSE%hdT8b-&wvEGQS^#lj`_t@*9a18(0J!Whq0w=APg-x3;oKO*78$9!!Y_Z6yw
z`!`pFnA at f@P6RW;KNXrWdMq<kLO#1Zd=rEVgbEy~@2`MyJi&+5GijbDf|`op(t$Ti
z$xV-CV_=qoHpHg^iWsO(P3Bu(4hdgpl`TvhMLruR_zh#tGp2og_e88s3Bl4{6DKOc
zBKr(iP-MNVHn!n at p*Pb{fz at Nh&6x8n5Irkq-uQBbALn>q`QoVAugW6`O$21mL7}T5
zioo_$gc#V}ueXoNBMXgZ;5W?=<TWk%<OP;1+G((cOIE7k$I5Fnm7#V(Q{csY@)S_R
zME(SYh33gok!+B$gRT#7au~Gva}v0TVX}?>n<L-ndoAl0_7bfFgA%t5>zi_hrWb1<
zunsocl*uGlHV$8*^HLE_p%y|Yi}eyVlW(}OZHDFCx1KpNDkY_MhV!ywh?YxP2wunx
zN|!BuGuQ3rah>)g2l<>r*a=X>f)N{#N6ErPsKm<NBix(z=L(FDDmAB$yc*{w8AkgT
z2;TsAE8B%WdAb?J5FD3~qDI^Y%?o5-dkw0AN at f!9+IT`cLxZOud}HLwDwe^{aR>kC
z$w^RqB#^O{$ks*=aV2<^hvyCnNN86Gs|vn~q(whLXCO5KJpx{7h~y}gfx!h{Pc%e=
z!Fb=7DDn45Yb1Q#IG9R{3KS}%A$rE%z!t9DK%+W^V~{E1+1kO}Nf*&nq(iQ^jNWkk
zBuJ>$AtS2Bgv5mKgs9n2!o0;Frxejn-b)d=K5aUA!e%RnHX|!jAdWF)RG0FKGBd}r
z5Ud6%K~hH5OTbPiRU0mDjl6m4J(8Wfxe!i at 01qJD<Y%#&7tzFjRFr62sHi9 at xuRO!
znax4J1E8WO<b4zlY0aa;szh6gSm?^7qy+I0+9IB|k&0_p{>f)?0|tKn-r-<iyU$xF
zu?v{hI(o7a%g}fVFNjSKDDcB~K-)?y9D)2po{~6`@77caE;JbRyQO#hfZK-Q**=Hs
z<FIuS>TA8lbX^(=jNPOv1ezlwGOC7x#Dv&jz8MLderIV1$}z1e1w<|9*?N3~{eX34
zR43R1VxCskV<3V!R#+S}GKo3v4)I^%3Ao?>#D}ABxgt}ys~0VFUz+y`A!X|s&nNSS
zY at BShY{bVz)fAVvrg1Rr&%$h-9)h$(rzep8omZsB_BlvpQBot0&abLqz-`9^Gn1GV
zG4>lDZ-+u!d%KQUABF8UK5_j*vnF=yDUh?+D{!tm at U~oX`)vA(z-S7ujzi?a*IqsL
z`g&I&we!G?=ovx75p;I|-9p!XV72Z8T*zP)*F&UOmAm**MRKT_w#kV8gpV0$fPBaq
zV{L-;8CqFU5Uyc%)&V?Ab!(N*I#aYTqX*oKqZ|@>6BO{z43RBumw{i4Iiv8zvI&1X
z_kJHZOhc${@C!{O#Cnz2JXC;$#OQ`CBQ;x!$(3}h at f-GAithZS@kUJl3m9}k5iM6)
zvX*7b%8$ZU)U1a_H at 3?g{f*#*GB{(^hLkn;HE1B at Tyf~3<Q{6|(FRNx_vx`}J6#vK
zkQA4$h9Lm9i=xFZatr=rk)1Qrxv=F)(-UMQ&$6e~u&;dKAt~PEWJ<pN>M}}BTB#SP
zXYg!iBXO1O<UcKe7fZ8F8;%wv(5G_b>q6b+>zWnf^l)bxd6WXq<iz>VnbRd?sfz7^
z>N0IsAPUhJ0BODNE(2_KdDLej9*cF+D>a7cNWVBOn6XGu;)jiPzX09DK!T?~sS2+M
z1dk^rTV(?~BOk-yDO#l_Y5Fok<9L72cW{jFZ12icicZM-t!7)x#Y-H}8yGT7YDGwl
z$e0H~3*G+D;#AYXuYH`q7-qkuni&X)$Tl~i9{5j|j`oTQ))VTLK=GQ%Lu^sleySWN
z4SATcnfFmsP-urG3{YBp?}aVti}M_;((QE;=L3~g6k3=MO`LnMht4P&2vXFeqK>|u
zvYZK4i}8U-H#SL2F(>7*b-_tIPAAlmIX>rFj*>%{wcIEpu^o*_SM+G?_>Y}f0Inu#
zRumMZ=>368gU~VTEf#<Y+$ScPD8;C`4fn1hyHXfi-aa<i8T(i3{?o1o-^7e-Sn=Y1
zwA3JS4vo(UFxgy#plLo0lUWx{YKtztvl;k>HcvZ}W0)0R!eAe!qzoBoo&>4=Q#tH_
zytehoctLQwQZsj5l*ld?7%%~lvSJ4Wk at HH??ly2XM*-y!2cXBOVad4<>zb*pzA&_x
zR_b#N^hFu0p{&MD{4Xl!1GL&<^AnWe;6k?d&`c_xS~~HoV&N-%#Z6!DLz(G^KXdtL
zY`Hh5QWlwR0NMJ!^8wPsES4!sE(jsp=r4g&4;o-ciEnEiG%J2d{BQwDjK>%10F5Rj
zoUh8%Ri+MfsJow+Tnh&w#b8^>mgo{~N1mo|IYeV4ER0oh?`l<+KqaZ$tcStT6s_(^
z8KT~9?KI{?Kt|it4Pm2DTNU^!fqt7ZfP?)4{J{t1AOlYYW-4Z-4x4o~0W3UD%ZT`e
z6UQK$jeMaB5ltNK8)p_<9A0|c3E+*qtcE|ZFNbxC=S%Zy!f~M_f~+X(+$y=%6Jrhp
zMwVOy#J9{<>=AgmO=mX;6!2IAHlwskF#{&VFV&o@!kH!Flib`m25<!28RqvL^=jdQ
z;6i%=Q}PyknK$GSd|l$i^^H{45P{_FU#Ej!IqwmGE{K2q&t7`JpWcJc^%DAW*$3jX
z;vYwU4gN|@C6FZbbqQ;Y%Jr~T<9&AG61#)-Fv6{!TL&Mp_()0uA&x;&8VCiRD1VF4
zbeFhl!V+wuY5FqgpO;yfNe;^gqBp^H^Be#Yid-d?Z)9C)&+s8!>0C49c`ZfbCE{Mm
zj7aK;N+gOp+=xJ#A9cM-pqru(+?K)7FySqMO8au8&YME$JxRuFJuWh;-<R>`hzB_6
z_FeX({D<D{7oL!mtQR(HH!ugyfd;3`W|KcH#G#h(s{S^ESOVp%Vso5>ZCy<MtWlnB
z^)@OkxP(}d2s_#sL0aI;id$viRi`wL1daX`W#PFK8<%%OcF_ at Y>Tt>1(uQ6L5q^y_
z#M7m0Si{(t<v86W75Y&ElL#_y&Jh2fnd?wK at 3|@$dU8Ow^xmIZW|8eNcTpAr{a2hz
z4!i?@rrF?Fb*$S#Vm#00$2F!xL4tn-S!uq9V+RS&S=b7#K4FlsgP_1hJc6Xn!mccq
zu{^)*5T0hkmSnkY$LBl=97+D^?)`NPyKym^ix>X`N at X-~l4AaCGd?rQsdf89kLSe{
z?cJNL8&=rs0dlQ&#g^(KM91SgiWpv6%;%HxeanScmggfTkajJ$-c{=UUV-`|?SK$3
zW38xgb-S9uFC;MObY1WIu92As@!Fl(4&MS;@bmP-T_Udx;r(GY9#Z*3vHzSRNGiN<
zLxod`O0iR<rvqu&@Od0%x_H9^4MyU{QK^7Pkus6{`onpq at Ocyxj7f=7m4(f)>fCx6
zI^XB0&!@?$Hu=X1^l<apY;_gV=UtdT?Xp<2dlW<`P@;W?Qxj925}ZmW<t{~sihw(?
z+<5Xv(@J^_ax at NmPh{>L3aXmo2maCN=UwfIK7S_)oSMkx<aNvhMl1Djg_ht&{CQrM
zg7MfzC4}C|*TG8f#w}0p?jOF}6;bye?Q9zPDGJW?Q)lDL<v|o{y(vTZ8}Z*Ai;Wvh
zxAZc*I`sxd6dX^Amtc|;`r+2yI6khNUbYELEmo?1*(2-sQwfQfGbxE%tx3=bvO~{2
z9a&}|p at wis)-mgbjwm=%HEsTI7d-zemC7r|jMf{%SsW=-S&GcipH8KdDb%p{&f@%u
zsV>+rhrp=NmAxU$DQ`ZcUHX;D)&Yb!>?=faZ{ENovKI(h()ow(z<?8ejh}R&5Lq9#
zSs)i7%<*MJkOJ~{6G|eEYuoXbF8Mf<H;hqfU7Ev=Ndp;6+U^a|gj`?0Cf>B`sABUY
zq(BL5pcIqwFu4)#_$cUYDNMR};Je29RKuSQiEYCgQs%_1C%QlXo>C(J{?TIA%=bub
zcsrT`TJ=bFh185ZR at r^jU=bsqwmZ&~nI|h_9VOp#xmQ{)Jd}fbVK3`)?cK2M-nQhO
zhmIPsG=4PC_xxDSPxS^1l+A65j4Qw!1(kx#dXlnRC!LhAQHOPeU<`B~eda>cSLQTM
zL5W)>FOB*`+^8FTR3vDFaZhw_6gCrtE4+iq1;It}^$(H3TBcaY7abkcqyn{ITV at yT
zH(78sX^?(b6)ayu0dJ5>4+%0B);a+%0wx>d*AfrgC<`0}CiO`o^QZ<?GHKH1H<j;B
zrupO=M#k~Nh at 6wXrb^Ou#uZ5^$EGs|Ava6Ct4af;4Y!J*Wj(+6sJM;#aK at L07QfPL
z#|?DaIc`#89X<IKC6p#a`H>U8SveYUXv=m;s0_eACiYdA+@;Ph9lIZezSK_IYjLG_
z5qdY&3&B{yQIq3rAg9eyiQm{AX9B1hPri65R-^8S<oX6o$x0r-C=Q;DV>@Gf=^ZiY
z`)$|(E%?!KuyOFBCRIqbb(0*uGHr^|IyjzsX|}NNSz{X{1)^RRDs}OyBOK#;L0gyv
z?eGcbHww~wl`U<ms0PE)^)Ftpye?)p<^Jsp&jQ~H$BdEEMO@{aCK}IHu at YWGuDqU7
z4k9dr7{HjI)@0)sv;V5j87^3(?qH_Zj=LM4*UsORIDn^`lg4ZZUt7uEov3&V-f!80
zMV-MId!7Ujhae|wAoaaU7-&bP^p0$b;#wTzpi)xGt;3hSsI7A1nB`y8cR^v$^vey1
zTBDzE2fk2+0$PK5glzA$l32fVU)yO0TU?^E*=9Hey;PEcf7P at heca;mD0;l)T-wv|
z4oK4kDfN!3Eyo3tDVa*#a<l89gkq|=!(MrK1CZXCwPI6eJOU(tmF|lQZN*Tm6_Y$2
zUa^dDBanRaFvFq#-FzE{hGsi&S!G_>v+Q~ORxd}r0E<z19<en(NdMJxmQY9;(w&g@
z))MNSNX at 5W{(BB*rNu^Oxf1W*;-;c-EfKAC|EO3)Q)E}1AYP;HLQ-;k?cxH8+OVmL
zf~wNGn0=CGKni{&&jXI<!sW^zdL_^*!z!OICR}meM?9McilBcAfI@;T(LRu<$+2C;
z`SUbaxy{*g%iWnH;e#%O=U at d`2p)@kpTw>;V6$o`#$R^Yo#<%5hH6@{_|p?yz5r9v
zIQGrO0A1X65lNys9J&Ibaw at _X=Rc*Hx01D~60MLn<V&*9;bAoz%YT1cHgH=Z#0Abn
zgR9zUDxq~W9DfV>=^FMciEDmI#f|^m&9i*UY)zi_O at i~CjH3S$N-iO19JCY2fANfr
z)t2taek5~Pc)s&^3RRIgqr{V`DgFG=PLgI8!KVStTzL~$Fz#yOWW_RbNGzP)nobn+
z+xdR{+ckc(5KgC@{0%aFvbwvbvpiWwwuFPF23&0%nUjHo(Y{=dvIi4eDS*IMyBs}5
z18^&0Ddz<t_Y{)8Oopy?uSfB-S-r9&wNe^Pui&&(-v6M&6AD#&OO$B=IabkKR*T16
zBRYbu%VBmb60^muQYvzzY|vrlT<ubo*ji{2CuM|shC1Z9MGa;}XHyie<lfpAr`F_)
z5*sg)^3(V6saD2 at C26Z+x_Zg2p?wJ`!|0?VF1&P47-=;I`Jk}n+>Ct*82m?oa!>~9
zBKI_l%J+{H<GJElGh(wkos8s`cG$Kh@&b~ZotRil@}kmTgMR|lOFw-q6KOgUpD$#_
zw-K$?D}SddYLWz3YbD3+Xu(Epl!03_+2-wNm2K at 8rT&+Z5_?u?Ib?97D1j4QRB7=s
z<+_HLcUht)ewDA-C_{_=k9W~;SE;3As5#lkO{otrKf25uuO>BI=^KP?U;_4_mY*|0
ztub?JVxg|Vp(N>5_RFYV?W?)r(m9h#<<CAXIXJ2lI~~fQMM~OynZ_#5F!Hge8EaOw
zwPUr}X{gt6^aFMOk==Y$*dMI*W~vq77n<X(KZ7G7bil>k-%A<@!x*qLQA={n6;*X=
z+}Z|PzkDmL>BEjrtA9RBOV%8jEG^`0B!nEec#C<D+Lz=n0`MadvHYCCpWWu2#!_EY
zR^H$ruF?+w!F6|~Nb=;n$;X7uc<Ym}E@%~0qc6;?U%Uu>;7;K^u+X7AriF~AjCCpW
z#?s at z!0t#%Co$IEoVNokmj=Ep*8<T*ddGnKMy=BkU~ewA=?rIrf_Af{RPsfv%Y{&W
z7ob*tTFHtMTy9{ywNRhbbg_ObvA>4s%SCgUZ)}iL{mu|AYFfSoj}6E-g!?MJDop1%
zt(5>lqSIhr&?|}oM{jyo_UjBMScUqu2xr-hRteOSFT+iGucIED^^dFc(u)A+b>2Ug
zPmgWIiuvch{VxPYw{PR71~`nV?cz)KUk)W$He?Gf%Kti7>r_%rijV&c=54kNL655W
zh)W~XunI6XL#vpRsiIcm*z|13BUjbqqxvVHTG4xcJl#r_B-}m(!{=nRl3O=qknj<f
zLFjJLX&lQ-j^{9uQS!Y}ncT5kE6`Nqt7p(g5F#N<FXVl|@^G^EAzMK%RM}q?bRUsJ
z>S-~o{&Tae*zzC)Q^bk0_*VYSFXqe);T%EzrOKLOF)L3mpa-#Wh`THC<q#-ifu`b=
zDf6FhY$zC5f3lSl@)_PuUF at uIct4O8<PehCC9{U!=OCsa_?&-PGwxQ$3^2uRT at z4#
zCCZ()<^SxJ<MEb8F}m1gA~;*!-(S`Ll=90t?d2j}9~g#!XW^1*EBGshyorA9QY`1(
z$a^eNmR4yh8T+G3{;k=HJzID7x}EIg{*}gS3pS4kpaOYq>2e2%#g+B!PI8dsnqj$p
zp{8$TZc;cV`6yDeeq{=h^vl!r<>Du!(ie$}78t!f{*i4Ft)O95tT*d&Ax<Ztg<V5|
z8hdW9Rvr0TZ`J=EHrCZFHj1lH-OkQXy?3|2+SuyZ3^!e(-ITBPC>H&*Rq^pX(kFs@
z^jiU_ZAwAj6z-le%TuER-uYOi at X(KyCGzfhf*({UFW){_#c^4CArV{rK^dohJXac=
ze{rbaQTi%X?7_P)=s{%hxpzZ$Pze1>Fr00s`8qxEs1U;vVpVjE^YHXLVc3DO&8Elf
zr1CxBxU&rotfc>#8kcU;mNY9b>~O4F4-)edmv4QcU&OSmXRE$pZ~X_`sxF6V=Jcen
zt2|6?c1Hoe)a~aTwt}xf^VO9;K|cXwzNm^jII)O4tRK@~Fi>eF!{}z;*W|v?IIFJc
znnilW_Ge~Xi)B)RgZmvuT4_fub1bu_57FL6f+T;HLl(5VU*Jl}y=-6CB#}JL%t#l@
z9gRa3YQ3pXn5OJMY*LxsK&g=1*uTaHFR2W~2Ds)z`CUaxracUwRjRLjB!B+ImZOV`
z at P2+Odox?!@(X1^fybdeQ(#0rLfJ_0Z5?_vmU?mY{(H!Pza~I&#F7DgHe0gyB!c)D
zmRZMi=V3c)Nwuf?2;d6an{6L_+nn35@}OD!K|iP`AEea(GoeD~91}fb6?UC>+Yg3~
zV;!T*$Gb7e2EVApO=hy_lS1YcOJSE{j#;?FcCA~7AliR>tIBrx20n|NjTXtuCuW&?
zu+LP^&v9RwTEgqFc~}N7WSv1g*K7d1Pg_f^)p-~vhe)-|#bVr>;~rb2&U1B%BPEh3
zHV4)PP_KZO64)MA8^0b}q9KrO3ztSA^Y=9|>VaWd0_<A at jyDwGZ)CaC=Y^zi2JXx`
zLN)S}uos(7%CD~wV0D42M>rH7hU#j|y%+C}F7ZF*<<ji2zU`>>E7qtOIJ&pf)h;H0
z6P=JWQ;+mRM(c9gd8YA at H!`HS7vapx32>t|vtmsStv>?#Ym~vTI$V+lvrqz;W^NoZ
zKPHPhbc$-osu$?f-tC4hVIeDMo|(rMDmMx%Q&6*>GZPxU+(Unf9=`sDP;<!E*XZ&}
zC@>_@{|nl2x5J#~bk{#g4~0c?)^YBq)|aRj=yNWTGCQ-IWMbUJwvG)A{|jjEfEA}T
zl2X0AkWm$d#F6*AWEB`*TmJNN=)tp$^Sq>J+<Br{KQZ2kcYiqIXX}P3>EZ11BHX|~
zT4-Rl-+QUH?J|A4;p;WM>HR4v);@cQ!UUeBna^}*P;5$iBOwaSS8RIHo$SWHJjFpL
zi}SpD>YPE568~Z7VvBhxuC>Jsc)LgYd_T3UJ|r_Dj at I;`HWkA#NTAT|Q5v^55 at pt-
z1^&$Tt~KV at W_AM=Gw`F&2w*mtJiDKzjoJLz89vKhq=`YUPW##C-M%#3yezk2I(77x
z(FGgy!wlVwbMx8jE5HDE?5-Ko<gLjMrl`AfN4F2H+E3xf<K%fK;gq+x_n>|nnf;pg
z3*xrzr-x6w9l6Jj=Zw7^1H$U0%&tc9kn;p#1naN5oz}PCI=r5-EB7{@A!GGy+bIFg
z?T|CY70aj0m&r^Yr@#Mr+1dMw1tEaPFQYbKjjo=%bk|hp%II1L<h$gnoZk01D2EqH
za)!NE?~Tn*$gAWKq%5NFXfI4HxlRK{GPSiG=(-qlqcpF!b<&afLvc5On{DK$TI9E`
z<5E`?p at 9s|pAIfDlUCc&`z&{_;|5htJ|f{O&DKm;D0?>S&M^#=1AO1L>k4B`z?o at U
zo^Hyr{3%IW==CNMvoEryC<F#zN9sk+YhBJPx4VYLbXR$atp<6I49FD8&=NGlL+1$0
z38M($s%m{>9hA|QUzhf78bkZYQKq(Lse5CQ0I)aCPP~0*I2OKEP6_2gcekJK3#kFR
zYr^;YLtT<T5Nw^=ohQZh)3 at 1QGTE)~X88NWvsE4`Y at MAPT_&s3vl_`pOcP`ed>r^P
z6mu!g#-)(7xpIfEZ=bFX`!9U)dEEyTlnl9cAdt+8IKAJj;g+j~-fWG8aQBEp9T3+0
zbFUT`vz_to8Oh$tF at MdzJ>q8a<SL)q;#Nj~a}u8mrDJY=QOfRk7*k_9g}8_4#eE2|
z?_*G=oaIaN3pC))b@=<3V)7_7`FtvMfahB#Tt8m+_b~gqr`tPd*G;X~8xMFJ-YtLr
z^0<e7;QEn))n0Yge*Rliz0kt)$}IXaqRY8$YkA1cuHSz|s8SXyzwmo4Gk0yv=2Efo
z4u%3B;dsh9)%>T|Z|1rytKf^5K^27S&VB~Qt6L2mjQ6j#mtya4`Xm&!#D80TpC>sj
zV?BMdJzI}F_X|5HMn&FY{|W{1TFjNpP%K(2$i%hcyI1~o=FJ!wNBk%oI0N;hsrJi7
z;8(-@%fvMWrhW5(EX>m_y<z at D_R*W870++IwvPzul13#7>Flr`7%xz$@Pso`rao|C
z2KbTYOQyd=Ce$?o4#o4h>9%L4+W0i-Cb0M$w)1vZp+GoyQ7+(wAT}OW_R>|2PxJR(
zqpna(Q$*E8o4#g5bgx<JO$gjT at H|aYYa1)JPiN`LAA_*>P7xQP3y#an?MRw}riuwZ
zma)?w{rFJ4^P!C`v~=G$@a}etLi+PtTU=answbME{g+$s^s})87|YR}3*Ryf8~uuz
zgI2w2Z>RI$b^_m$Q^pqUnxlO$r at oFcKrM7JTyApltI?+<{CYU|p041t;E46DZRwbk
z>1SY=SPsMZLwWtkxeWBSJ`Z$#iI!%@sC}90%&IKSqZO_FA^$Nm{ED8op|W+_jl-7p
zX1Q(0_Sp2;H6F0bVE6Gup`Q8Y|JpqN&!+glKq3w<M%MoyRK&sfzcQzBF#TUP&(HZ*
z9d()=lL~Kos#A-N$xZN$^nnzs>W*C3t~TPniWi__$_2#qKuPH(xdR&DSoJ>64c&7%
ztNl0Uy_`@Hn`UaY+VQG<h#B)c_#7tBM&txln)r`O0tpN+!+W?lx3))123hX+1f1i?
z*}>EDpiTzA7#aa^lSVB(-gOj}sM(g*P#rGwJ4a?y7yH^r<M*F?6ec;hFSuRC&RbOq
z?61o5^p at QpHYgOi#;Rxi(Z4gp#j6<BmmOX`J6Aap*tWnhbpy(y!I-0%&xSMJ8N(rO
zdxE9q*rhu^3`mN0Dx={&FJ$;MvHD&Jv|mMV at 7{-G{WntY6(GGi4VnE<5Pp1qqrKwM
z*ikj;eVJze at d<(pXW(+B`!c`%mydVll`pC`eEaJ2)nP+!3+H^znR~}tNLCm!saU)4
zBr%v at uj*kCj3h<~UckoxfO!NmN`50{cHsVGNDeTF86nAR->9_J4@*SnOn$!=;ees8
zdY1r2LqMTo?o;=1OA08=f;;Oj%l3W8$nXL8q$<eA`*1X>$Ov|kTrM`ug*dRsvq*~e
z1lFYX4PrfoYa&mKVJRLn+btz~X{M3~OYcM>L!{%RK}mp-uz-cYz7O!jiO{+!SOtPJ
z8(78<qz*pH0b{}esg_;bRi6}o;CsEh3E#0o9?Zy6)1y?r1@<b}mx9MVEt~)R%)<Ls
zTbG(1pI~p<D4?yVt2;5&0Ae)uX?2+N;cuh=K^x%6<Y6=#(Lfr7T2v`c)_6<o&m}8(
zSy1`iDUNo*y3aUM4cXs<3kek!-GcRr^Gaz)ixg5#6CA(lp<`5b2I*~9$}n)gW at CI~
zUK`VS(|_6_kLG7+^qTmZ6WjF3GKSQ*8EPQ-vPaC?G8Q~n0ZSldpuKatmCgY;CwO80
zfaZrsmR6FZauotIAK~r28{D*!zege2-Nrr}Hj&9~qFV_OWKT$3LxeeVjx-4G(>ets
zR at hg()x2@|LV;Q=2cZ(oCuyFKGFd7ol}2V_$T6 at 496Jy(p3uEH-Zo<C<bHeuc1q8r
zTD``%cGWE>aLy{CTo&dK at LDu2^Ts<kjWb~XOA-HaZ-J=9T-J3s95;)&KsG?-<laWW
z&SH8aYr?TN)XA(^IkDnASZ6M2hirnxC$`-HJFj6j0uh25l$jM9*7-eeI4;b&X%d}k
zZTqka9!zPafXLE~HUujeI;mnIVajFDRSvocl`?y|{>*Ex1R@@oRwZuhoQN8Lg~2r>
zCcP*JiVqN`*ZjcSrHCKD&cU|u%?zi10g at b)Nob?KyZ2L_o+;@cgH)Y at xEICGhT_OS
zL#fmEoXC`mXbCQ&Wtxk*57kC^&)uVFHJ$baZpyoZo<?My%`u<VcR`MDMwh)P2b<$G
z#u&E!>X`8)tGiTafGl(j1PhQU35M6<?<v$Qe1jsk7mu(#g5{eS<xRMZ4nvA>UP!Ta
z&_Tn%3eLR5Ga4M=DM85tL!0lgHsHe(p(L~24?FW5FC*lbpNHnLkpG*Balf7jpk!El
zxs1 at _lpR6~XPR5Ox|TV`3{f5A>NlISghAR~ku|a5&*QUtg%0 at f^sH;;r{h1{Ty^za
z?bKeS4Gw8eb&yHr8RkxZecP1VA-DtOOFSC77ol30w&ok+tg~A at alRJXXe8BTaef5p
z9hCi}@*NLEfA>hr>hpEzu+Du&rD5<Br7-m>7um0${-dGM4c8*OuJJaK$8I32W`fJ+
zoCA`#e_EpQolBP~=+hkndXJhwwZcMiEw-`Ya2PMbtxx({%1XctD<q1yFptctESO(p
z$4Ndy6ei~S7NIiBKE-_WkE6HY0A1+ktk<*xriD`%Kg-Rw{e2SoM(*$wg>3D~9};`b
znsdm>PSVSb*FWh`abVXRccr0_S$n_P7PyR>L>-%%^tJaj;O2>!lCQx$+x{5(;3$xj
z{fT!sLq={FqAOF6_2r}Wc)c_Bk$A5GV(2lC4k3{vs>?DD7HCZ$@g+t?Ovk|U#4LMA
z^TLz2UIvyH?DRlL4mcYA+y%>+MUW(wYVndvNN1k^Ll`1<Gp^v`N|8-svSpJMVH_OU
z*#n3^o}cCjON{HZGU_uep5}gY3D9n-OJu<kswd;0>>LO_hnQ!T4gKA?aN%K=ZZdJ*
z;^7dN%DU5 at 3^r9|(rr2B3uPyzdx|aiIj!X=zVYKHfSSM?Hu-lt!*zWbqdQOq9%Ubr
zF&=#_idQ3@`(X1 at 3xv(3D+kC%S~>o=#+6jB^wd8pE?ej~bQR}Zm7NB{TsewR2)7=R
z^|(cC)+RmDdd`V)eS(qemhWwORC;2Lr}Jo>J3~U&rc5etTMFJ*fFMEct>=_j^6eCV
z^6t$78M;V(Cs};gx?8qewJV~^E-#kLKpWbe+X9Qi1_(9mwZcGY3Lg+^;nNZNz)e~D
zt&hg}d$UW5B*>a!3Kz*S?+n`R>0^`{1`t%q01)OUvHb4if{3uDw2Z*`oioE(B%sG`
zt~L|><YC_+#`FY7oa2*G<d$h3Ve(~m>N7tWQpru3u63-q_&H~tyPkPSi26WXxvD^`
zlYi9<(4(hXL;KSXM<X;x3zTt`1b^`g)m<p~oyE5j+ZV;+b1kRF;8Cap)h%maJucZ+
zCNDK6C?IxBPWsfDm=N at Cx=W#KbQE(ez|C=_`1!A at g~|A)>h)Ys!j4ECf=#~mG)~7%
zpH)TBulM$c`xf0CgKjg<ClAoyaZYY0M2rDm0z**M>)+pLtrDxyyXrLEbm;9DcUs#U
z<gomW3jAyoSFRk?!{^pV+mfJivu6DkTdsNaDLhjiY?8p2M;}<jtaS=lZEHs=%I7Am
zV0$^TREJ901*?q_?qOsUhpd8O4zwcKnb>)Yc1snzYrt&2TZDk3ppz?~=tGJei^ql~
z&dlW?@hj-;K>T6(h>$esABJKGgF3$D-efVE^>DOnul5E*Nv<&~?jZy|SK7=QgRtT%
zy7dIA-1GI?oi^@sLxW5Ztpz+l!bM7Z-R~#*4Zu|8Yc{hQgK<oD%^X6If$3+?OMw$b
z?0PIg2;hX4AmtONV(re%;ZUeSgl6|3h62Py0(-Vh(WvY%tZK{z!3d{7lKaAtL;~m)
zzbzo*LWcGX at 1*9+;1bdWig0i~9sCmEz-4j1kb8wd4{ZkK8vUX_xmv2T3MXQAo|qxS
zW2&=Kl3tCE0nwew1u}Bs)`zQedxp*{KEfARMxPqC#LUs*NzTPVQ}_}`W(83wIbM<e
z{`x^#pLv$OGIBRvVen!`&iKxPk@}GaXVaNIF)cM>0X!7Bq7j2Th8_dw{ENH2|2D~$
za9fR?u-$l?k}~;M0o_3h!XB>37KeKq;^b#pDdwAo6B;-4q$uAv4t1p at 1N0YI3T}{R
zrjr<MwM2tsh7dL5Z{oFiWP9Jxz_EVT8UV7H1(91E-~2VJhp>1 at BFHQNEe2oMDJahl
z7(f&@9Q~M}=7!0gCT;OhA)nn5Ay>M-O9K;;pCYC99wAMaze@{#sGXhH*08{&t?2my
zQy#{j8*)N5NTGu4)IbfJoWhDTJ!mq7B*JSo89Vdx8->?q!b658Hsu$lN=R_mJn|wy
zW`at>w3_IbMlRJmE8qMPA8G*b0ujklBq=1-L at 5^?vQlvcQ{6pDag!e_?;HJ3(qnTf
zIP5>S1>m-b{Q1>ksO;VaAO&*%OV6HcR6Sy=X$Sq$N}$J6u$`8hL50z2sUV1>WeBGe
z&F5AN!I0~2e#PXemFYWyhOD{5KjbLkVB|_R|NBijBZNYou7^@#$HObc60`QNe`@{f
zpD+LEpKTy1x&cwG(#OOE1<{TYMEJhY{h{w>uyqk$^bjt9Gh#b3a(#B@%nqTBs16$E
zI5!K8k#<*teO+wy8~PccEi^d>yVTsQJxJ(gIxj`Hp!o=D_Z4aNH|$xACx3JJ05twz
zJ%OWyMIg;|MJ_@$J;Q_=DHVt+7MP4SLE91umu228!gF)uve2?fprxt}E4sy}3tA<R
z*qBi at rL<!E^RoF~$G(|!YL<Xm%*}n1GHZE>?5!eHRy96sG#19B_cmwIG({<fqnm~W
zv<cyZHUl$Uo6j?E=TkZM00_9s@>D4)egOMVBIt*`QgJU3VH;U8Y^PO+#tdDZ`8ZhT
zkm`MI&K<Jw9)*zX{aq2_yYIiVJ_55xn<}#^e#$pnHOgBY!2r=yTr2Ikj;m6Xx8_W{
z#6zpk_9!4B(Ol?5YU05ouMw^$QdOyZL$V7lnPiB${!qC2N1lo2Q&4RlQB{yg7Q-o0
z-~O at S|1;|gQeRT_wqCh^0B+m*+B$tON0}$CnuFq;@?OAO#_G53eq+yn at 0N~#N)i_Z
z<-SdV=v5EWxg}AAB=5pO5dtLX!c34%3XE-oNs at -&+Kh`V at h&{gvv*UaNxl|!gSs>6
zj3eUMQb!xwd{mZ-=lLCo90-ZWznlbOrK^%8Hk*B~0!@7f(J}@N`(n_ZNA$=HDa)^^
zu=EHYn)>13W~cLtoMIABCAyJ223PGqriRS8BT!3VVBv%mm}gNYY&vbSD8?(03%#o<
zpkz{!4}@WgE7N9^0J5r4A^%7V5%X}y6LXGltl5G)Qfg~w*#u~FCl?X_we(QX%9Km1
zN6zcaOSmyXuSV>(X?>TYt2{+DI~X?NI?qyn^W^6t2dIzk?jiauciuyE5U*=}D)U^4
z>dk{B;nhYF?%^WU-k8xcfzjN=RBQ3?+GX9|J$rX?BRKl3w->G5Q at IlQjDlZjx=@Xu
zZEIqcJQAMt*p$EIjOo9ZjDEBy`7Bp8ALF(uv!32tZflL1;?k`{SNg!>L{12~eH~VP
zxdI`XZz?mAckWn1hTY-58E2nWngXBIOTe&#ZBLN|l5kb9kD>$0oy#<q&h$B6A$sJ4
z>GAoc)u70ayGpXW29V+}95$uqx0~Wn)hgtJ)ju)l8g48UpO2NZm%=XbsFAyJ@?>C>
zO#lv*^;&H~TD_Y$bqsz at fd%ic(gmT)21yq)E?tq at pUY1rlLcI~P_wVf?rcy+$)yZE
z6ecMQOe;v_K#eOP)dJVxp$Kkw;YCEbH7WII3b9iE`AyLaroZ3oU80ycq*n&!o{c?p
z7Qtnw6!=yj?Kl{vu`-h9uX6<?&%vi_x<c{dujsF at xY!c>>r^zkVlOtx{;|?7*lOiA
zI*HtuakylT7#ITr-fJF=zIorh{zM-epEqVpm28kGtF~87jS937W at p|#m_}D|$D!*b
zr2{Fsp~5U9Rl-NkL4}Ipzj>Bcms?pbM1aV<m1daQ$pxIw$Z7sD2H<tbj}3zy)bHxX
za+U?tp2^Lqs5HOVMF);?=8)@AXGOawE2RZA=~P|Ivj at wW$##x(1NrDb!Cj205U~Q#
zdifnx2c?R+srgZ_?XoVeXB at nvoCy+2QS1?rr#YM)+8zg#5|{*RZ_0ND1V4821Z**B
zKEs!Lfx~Fr5!Ll>Zo;QLtH1v~i5;;}gS3sl)~aGiOI$ykjC&Uu3c0P>j9eI3$OByC
zOF^<D#X2KRrYw$c2f?QrSk52#D%PulB*{+rws at J-X5|N0wOl`Ifi!72a-HM+I%mLD
zQ;Bdv=h72Y4d~o*Z-X<sloP5h594`OlA^b}>;5`c$E&qV=e9nr8*c~ila{;6$XmKy
z#ajONt at v6msL>+5VDh`50zrb%?(7UAUqqH>tsbvI`XmKP$fXpVDaiKz2`?Iat=<Nj
zr0U(zo>UR%;Es4g%i7nD_8Z-$!yg&0l=m`jfm+<I&$d`1q|xaOHa~{MNRe-zUP1Bz
ze?vfLL#%Fy3**J?&_~j=-mMX`!mpZnn=ZdDJh{gBoo(xIbesFr)8MFg9g*-vdiT4M
zDexCE$_Z4tMF;CS{{u`}fbnqV#31*_!ex|huO#55;7F=nFIP<#%yZn}^ufYypy&cJ
z+j`f{CL4~_v)B8B*KRyH#SgH;inSf(79030zf8VU;Le37rQ?qh8(){6<tfM+^KnZH
z9l|-jAbR<_p}^$<zplHV<_EO))ZIE at P1#_}g`v(ET@!Oi at S}CLuNLkHxSw%$&^bRx
z?QJaoc?ld8ks2hGCiK^pf|oB?1*&s}c(4u!%Zb0OrLJGc*AP@%i}Xmjqos>QAL~xe
z4u|YnI`27u?~hDQM|-dlzd*3OU1nJInVKH8uFxaWwP5eJj at Wx#cHRC;(YJ0!Dl3Id
zvp%XWiQAjL;7 at ubbvNM(g;S}iM4rhjYrZuBCV9`2pF`pXAuB(kyMbmEF69KJVGBJs
zs0(?gM<VB7keq9}u9L*M)l5|9T{RQk+0gR&&CV&5BD;>G4XeSBzop5j2P^vAs|QIc
zFK4+yi0pRo>5^1c at c^D-&8RlF%t~Q4T?3Cj*A-b}i+u>#Z}E~&Q-^+(e}sM)eu)<>
zzJl6yhi<`aa2eK9^4WayoAP+Hkr1-sodw at V<sv`a>`UH8BKCa=Z0q1nd))jEX|VZt
z+%Y2mE~GNqWCg*ou<A89o**b$y*yCEpmZMW=};4+SCL0HZQ#M>JS^(6klc{%ZoYJO
z^$PHfSEp@#Q=)F2<tu<CDkVCjJqvMIjg=CyBY5dc#3pv9w?%NK9cF}^u;VUp(1;OU
zx!3C!=n+6!V(et!WHB(jP}dQchi}Dr)HK<&)4K6_M4*{CAh;(C{7c0X+w=A`zZ8M*
zO2NBj8n+F*qjW7G$h>uh0&BsvS&hHod^1H5nh5`7`?5XUQO>Ru*zuMs@$q@|88F>|
zX3zd+VG2qzjO}2jt~{n30H at vYNSV0(@mfV()BuC#=o3reE{9DkBENjm=yfwXTZw!^
z?VL2>#@C>Lp9C-6JqO5k?q2T!s99Ylyo)^F1=Wsv=@Z=n0k_LP8vSH>m!RXSuO;$E
zQJzRalgMT019_7f?7$&Ct$k;^s?OM1BhS at 5E7I|WN8Seh7*30h+ at 2Cl9|;WInd69h
z^1BTQ{62qgYkNCZXX1Vbd^a)C{`nH$(MAhGs(`S4s17?sRs}qwnJO8D(AMXn0POZd
z{*_ACZ{Ubph9phB0w21<*>aH&`%Waz?dyw46 at 0FLh{{ERH+quth%>FCM;@&Xe<v7#
z&qX)NJG_#>7!2Fzwpz-!=ys^G4LyKiOu<)FC+q#oahxvID}z};L<)*h7m+0D|FQR$
zQFSccx^N&!fB?aL;qGn=cXx*ng1c*wK#-sdcY*{<aCdhP?iSoVID8AT_kQ<#<QwPy
z*k_D8#{IEIudc4Dp7qRG)4IEgHnl9TywLB%mJ7>P%)1f!59N>fhBK5~5*u;fV`QS~
zjB<>^2 at qmDW{9Z!(>j?y_u8#bK|j2L<u$|Gl0F-UY1Dqz+9UYtyNDB2U{w0$yW7TI
zrxFEkn3cjNY8~TmZrtfiv4r(YFmy3z`n(c8G%I%zh`?H=e1de>{tv9H3SC*;(^Erv
zj}L2)yDzEnFJ)0WQ0^^}%5T=wO^72Z<}Sx<vZ5>xOZYP$vLB!kI`DeDUnOJlo(W#w
z)fUt6;&jyW>^hD%?=F}{9hor7`Ai4aPKoTszT;0?U}m3 at J|JdY#3PIPK;$8M231~o
zBb+YcE%I}x*JG(_2n0)vhIUZC>y at fY{*&EAkbtklHc~dWdrVrGUxExqo2 at L1ue5~p
ztjUtODp at fDuFdjrE6j!DJAo40gj|ie9sBgeZNw2jTppMBVKf$aeMO6PBx>S)@`_{z
ztHEZhAKzU9fuZu99*C-UqmPiE^Q$lZQ at Z;(js3iC7AGgyU+M0r55t}cfj~xCV;fT^
zGa^oo|4F*LNq631p&O-0_q%deNoz_OHGNp!`)=Fn!rIsw1|5Stl3N2g25K!-sn9IX
z>oBs%XxrYJb;_}qgB!1ZtVD+xHWd1OtUEt<O6OkW+dE2WMl0XxXxUj^pHy1*6n;!2
z^zvEf!Fa$CSUKw}*!;To^)mg+WIL5jnxn^5!fUH(+QotxSB4OF)O-=Yg~wygyB3G%
z+c*2$=r8^?pUf{)ir%DMSeW at NToos@54hAQrA at vK{Y4^>wwX7bQgj#wsQkLLV_bnk
z78qZDZ&Bf_cVrGoR_q^k%bXkG^xA?kY|M$*$>bqTwS0_j5ui!qpWlvvnXbRjYV at qc
zml~H`#(zvwWx`kVjZ=a?u;u7kjuKC^j1WNd`Eay7dNP_Y(F5f*p6)tcdk`o at o06we
zJh*vNeDr}^e%gO0JA>nsS+$o0pS(F?^Gsxa0NNLHf=b55UkBISF5(_XKjXs~Q^N6K
zlG_3T<g=D$nQX>G&PDR{Sg+(Iw9>0v5a(&)*o*H)Jn-k1t*fK=%ds%=?!3Q-A9xss
z>bAtfW8ef8iON{0re$=A(#tdY7{qZcYRbV7Y!MV~$OCc(6@`+cnsP_92AKjWDaV=o
z?Jhb+w$;V!ytEHq2TQ438sPOD+>-4_{K}o~^NO>5Waa1Pi|m1g9V@>|M_IRMca4Ce
zP$1A78jTR3L;7`u!c>VeI$62xL7Q^04qge++bK6N)%=dMLE}p1`qu-RP;?B}RAM=a
z*11^|f(JI%R}LK+Y4RZ321I%_8g{ti at cr$LwW0XJHfh^A4Je?=v2>M&(90%u at iB|D
zOD{W)Z$+W>i`(za&k-O~gk*#hIq at 76w|a9CsUzQXj44jeZz-WJzukO`WjstVw8P4@
zSiWb_Chszqxe7J at aK3#7QkY*WB^=XQ=KreZ+V9VYpD;Ec6j0ZzTbYqC(jilnlXYRu
zcWqkYq$sv~?yz7(4mTy^V^*J at 9E}mwmEFTBBxdtw!bPKr{8N+(6Vm}X?+dAXDb}&I
z%L;SV*$-DppZICzz7`_k at -wjT&ArLTHSGCBiVyq}f#61$CW<o_D^cU-R5?3;oZrVB
zs2-tB>d#`WKle+DN`u~M0iJfgWS*rJOG|i8S}H^A7bIimw1$|KR^YvdO1EFP##du0
zxv6yue|Owr!|2HiuOH6nOw<@})2ynYsM_Z&WZuHOywr|Lpe*{fR4D+p64?zuw>`G9
z(a-7x<v5>{B-DC#ZljO>TF-m#)x7&x0wnheCK)ldHTRthmU)uKJ8tAEQ%+0Ql-WS@
z%z2QQbJt<Xz(Cf)DGm&uX-|vE<yv7O6GL?ZYPBKi{I5 at dNnCoP^d(%jp96iGH?4V|
z<?*2`f;nzkPV0#_+4xTA=Pc*s26B1fw&LQbI|$mHw5YP!ti<v&3gPo*jEs&QUcR}Z
zr?s6avpT74DNarHaAFT_?!*~`YCF!!;y0$uqcD`lE@<RhC~vGRhm5mwkdep*#O?+_
zql)bwcF~R#!cIAS42aG#*+6ibqmZ0^HkK9&At;J8S)W+b>PpR<lHwCWwy>$&ZipBq
z4|su!z>ecS%9GWL#oje~UFjgA5Gok^onUDo{rJm9?}|uK)FJb*sfdjF6EDM*>D#Xr
zAE4hCyr*^$0=*}XkSGt_wj^R2X^Mpi$xz+K=2m(~QcroaIBLiwL!gReyQAo8VYjyF
zrhv|CrD><f_eO{t$v19%48$n%(ZHDrZ5&Y)?^BY$QWufztxK3<VYRvE>Y=nn=MO{-
zJOIwFo>uraqI-ahi-{~he{fxVf`M130W5r`{D5QwB<IR29CwD$bln#Xk}6By9-#59
zPdsbgZn9V_lEU=FW2m!@-`^Q at _b;SLY6*wzp_F`JU4efQ{sm)eiE%2Vxrs}(J4yby
zl~xAFw5qv=mFq3Hl!WyUix&cJUHg;^L^cX8k#;XTp}Tw=6XHywWAw`l^05^lo!^u#
z-8GKTxuz&pkQwFj+Ld;^23Dt+`ENqbcPlAqO?vBC-Q+cL9}}RTg<-sy;~)O~cH9#F
zCLn4jhsNWpq6#`Ms}g!htgibW#kJgMEO`ivLulo4FTK&p<`*x2n1J;TxIVPt&@g7!
z+RvbOY8hJ*2pX6 at Sr_aq>xk~4pJLRpKdAISqr#n3MPFeKqRlWIZ^rB&T`c94Suk#x
z at Gj#YXQq%`PlnugjhL(Ip+y^Cah*vJwKQzdn6Vwhd`5=9PKzL-_WEJj4!1NwX{S^S
zi46Gmj>a1f`WFpD3>F&F)Dp6E(XFQTs<NgWsH#*6Gh$;{G#q40^KDEOxT0F7T;-f3
z+-;szyFAkVkTX?`;-5IQ`92=C7#S_2tEK^pU^FAHYK9soo4q2Dd=~a+KRKTB#}9PF
z!@Y8~)utQx&3&!WL2BkPrglzOy at QmmVBp2pY(t=!Jrd2_Jly-ONIv(&uvUCD*j!;V
zb8cmdVYsM%f5*O}S7xo?fIdeaT0rrV#9rn*RpJ5;f?(H`zIqC?7`;CWwe at YK^v8^)
zEQVp^EQ29PWdy)w^M>ep at F0SV=J5r|VKJubjxUj{5D|8jyo at N+$0J&l_a?8C$Qk9^
zldg<iBCmNFeg=`AsH>(;v7MT)w)<k<j^H!?gw24 at mLPhBe0Bb=920&pwWd`~LaXym
zbZ|XS{`>1RoK>lMBkSyzHZIz}QnaiU$rscw6o!Dwgv-J at ZghdpD#_~K0_LNdR-^X)
zR$*!VOx-?lnFx>$CHi4A%S3<KV}0|6QW(}8u at INYwkAnvAWTqANfj48)qZ4H8=NxN
z^82A|4B>w$rCfePsY5ElOfiegsUoKSQ}$3}s4>4(shD{xpnZbn4At1=lws;t99bFU
zjy0O7&vKOI6vQGldVCuQNzYd`KE>Y5SqZ}oMJ at j}KzsFvrzZ~X10$r_n#hd^H{O_X
z;?+*(xcXc(TIH`7kWr;~)cDnNJIoXEzdZR-<+dP?Bo#_JylEXcSb3de>X7#5kwZE@
zCQV(By{goRp`uar7j=4ki?aZP!y_q&tlcrH?Q8lvIH%+An(7r at AosTg5=7O`d<VR`
zC6t^Tt=N74Ql53`wE+ST4ctw4t)Y=FB~vIai#=|ZP&Ppv8rtzvIM(D;blE~DS}M$H
zO%ncC1l4}m!)n!xJApjN4L%iL2-JOEQ^=Ui_BC{qg11*<`+Uv*GtI=^2L8D at jr6bx
z=oh&Dj^*KRB}WosiBvRT0^&pAdo at Sf;U(oHls#<Of4=toI_Ol(qh0xlyJ@?jZWT^n
zRP!6Xp!JKN$x<}tO!U=M0<iUJ*ADxRLHJAP3-fOvv%xRo%r>qk?#%*?zU8Q=-l*kh
z@^_>pLvpF6auok!nB`}%FUJIR8BC9PDYAqyU4`{bP8^32Pb3*(l|QB;CSDO|QXr8#
z=GUz!7Gs#_B2#X~`7`*?gXHX?D5y&y$K-N_^LW#ez3SDVU#dFI|9GXY=HIZ=(-Ad<
zDBLd3`~LcsVEaWH{(2jD9YZ||{LRT$npFA4kB!BhKrzhbSK1>2j+`9w{-rMQ--0X3
zqrb#PZj)nugIH;#0udBUUz at +#!yItl at t?}-H!WE(U6IJ&`_<<mB*n?yKHeTrXXwDW
z?bJb&l+N*;Bm4GUk9<@s9kh`lwD;Yuo(9(ok*zRIwP+GTpM?w5UZsf>Z(R5&7?y+`
z){kd+{)O<k3Ak=Lo2Z)3*aD&0)!YRdibXt9%6U+=&e8AUZNuVGk8`F&dAS27k9|4U
zu_2 at ZrLWC`NMmQ>$Pw@#VrI}B(ctq_a-!}OQ*O9UW%!M?>Ntc&803esIM3d!7$xAb
zE|L_ at X1k>A=;cDhaa at VLY1ohJz2^P(eeMpmU$$^BeCIZY&NnJ at ZAk``lsZwCuV4LS
zdiSkuH*GswwX8C4W6w(_$F73VpZHq?N}5 at jyYXlmQvP<H;O{EhK1aF~E4GMV$4`!M
z5{Vbvv*Lh~(BlYRFRlc7Cami)h&0Dj$$iu_6?MR6ohC{n=(eNN)p-@;8D9w1SVS}Y
z(<{KtP|cgct7Kc)8^{Q<{6<CL69+d>=QvEb;B3?~IJ?nJNcYa<yNf)p0h3IoZtWed
zq}rO8F}&_$RpWf&Cj;!Dz!~K7Jw%_442D(4#1XikPzu*7>B{9_^cn}a`{oM>nI at 2v
zP}Hjupv#35 at F>Fjkom!@TED4 at 5WLca_Dc#<B+_%!72~*4{5TE^iu`e)=#GL)?^fWL
zrT$V#h69z~4obsYJs-`-(lO^yxs_r}eok$vx<)xBYR;A8 at HI~9<JREA0p?x`k`e_c
z;_ECP`@{<VqYDK7WPMVX8Vs1#?0VhAq5Zq>@JQy=cX5H9ui`2otU_Fegs(Gq5Y}t=
zl@*fEzDc7Ef6~KFBcGq9D_YES$QziAq26%f;}n!1N>Ten2HwBMmA!X_HSmP}^^7D?
z+JITWSE=0BY*$~af2`i+^})(f?%_<0g0#6+O(~p~6r{ilF3ort#kHd1X4NvbuwAQ7
zfW}_;$?Z!Qzp4~gW(cQ*TV1yR3JHI-LyPuB&$eRmA*j*I`hhQFY(99LeZPdO2)8<3
z*&W at JOd1w)*umoEdJ+-m4Rq?;vKZKCI-l@*T)k2J;@Q(uFya+UEy<4rz+BrvBuGP6
z9Wb?3xB2pkc>P6QzpW|G_g2 at WU6_&~(UcNuf?;XKtKqJj&wEZk8Q at fYd9Pbj+%a5_
zRW(Fi=Sgg6169h4y#2}g6+V+t6+S|lCn*F-^b{pJuD=u_LgS4zr9Tpi?+5{QMT*E8
zprMyllZ#V*n;JQOaIUGfh1)?kJB}X$3D)okpfb!LOrCPm6y&!|_+(?P7GFsl_!S(N
zt_r$y$KVvhg4f4<_4)nnMw(0Lz{f!!y-({3{gsg$_e=*f1*xqf0HWI at nC}$OO7clj
zo37oTD^xY4EJ{+EVHeViKa9WEgBhFrIhc*k`~~{teH2uNRLrUC=0^&L4<y^`(mfdX
zvUfx9f`N_`(5C#jO}y|rJ3K=z(HjanN_Ig8!*PN#SCIBr?ga at tBn1oGY2JsNAqwMd
z&O;Y>W((W;C!9tDsk?<hmX^ZwLjtXv(26Te at c??i$W5|5K?n>ab(mtulH&7z)NJ0a
zRr9zlasv(LKD#huJ`YS6R+H+^j2)l}1C2u!mDdqr3=7u28+murBqsc#?ui56h6)z=
z#no2)qx)#9AwN-d5lUw$o<kjHER;i}W28Hq4|ZN=OS`U$C#((X)e%r>-|bR^KbXA5
z_P7>xl<4K^7(kvyke7LRwMwfSJF_8eXA4hWQqb~JE57IlEPmAl$13O93&KfT!S;{#
z*mnW|(eg9%2Rt at x#uP92bNxG7xw`+HD|pHQJf#KLnArYWSBC59J-C0*6>zcqk8%a-
zGB)T^Z!nk;RP%ZXl1SAe(|gl34UC9k at Y-Zq@j|<LtvSO>A;w9EUfDAYw`$cwMXAN5
zXW<!=A=E5{MD&J at gt{qRL`W$n_nr5(pJ-9eirnZsAJxC0xJL|B=jS*45PEo+9_9XO
z4tEGMFU=pDwEhIVlwa6e2ojxCXNkM!<BTYzvuUz#+l?EPSsL)VY+oKJNhFK1HXmQT
zL?Wf}ew%F^#UKiLH)@zMuhr+D#imI5sB;csl+A^%Xj!U+^B^kuYH4nJ+o<HVCI+OB
z?*8q?Sf(J+*5^BOwL{wv!l&o&Phf>sd|vpDqe0yTYBrLHio6T`biOBF)3W_#lpy6e
z_o#sQu=N95u|I33I09;RtjDV!Wv-&_Fpa_lLC*Mzpgcb!4Iwc|p3D*w at n%${!U$$r
zdYo8Uvm<I@$$*G&Z{3*~M8qVJu at gZbRf;9<Oe_jGhGD#UL%%GeHs#jE_E*7rqnQy%
z?peH at hR)1fwX2w534=k$V9n&BDZz>UI7p0mj_#TmPs=>W7EB{7E<@%h#d`f&l*LLn
zp9y(?ylQvjv=o~zM=I0UV(mwB&^KP}qE1<TwCe;R`0e16V8MLa$3hZtUfLIxA{R*&
zVd4Zf?p=CNfUmlostEL$`4s4N|74f1Y*;UwCx%B3;iL;S44ilXk;qF at rB?QuBCBFr
z<SE4j4`bqpvtx5Sv-X!&h-dQoNrWQIO?V3UCtGmPwx7m5={+QvsBFz(-}_N$HWP2Z
zfa4a3L=Vf^M02cYQW}dsfA=F}L$k^N{bh1_<DCBoL%4UzX}QHHudRe~gr<h*<v2Ek
z8Qzo9Awp|+JSwn at eyjXxTi~X=KcKGFIX-GL=1t#!8H0VlzI+vFG1%`@;HJBuBBjL_
zbuF^SPyA!+TxBS?Xcno$>j%BJfHczU10vi_RO!4tm6&(M7J7z7-`(Dp^L*<!j(NvX
zGS9n=zUU|1|B2>7?eIu#qp91A#+l|=Lu2Cn&=_NR-(t<A=c1#!pX3nZHiD*Xc(-s9
zR8_yFrkfy~vdgJf__DzwPOOp2rSLkS8u2W+pkTK_rwbA9KDoM|l*9|lddGTCH`21d
z3$dV6Fp@=?x^gf3*Je;kCt|{OT~fSsv+9!H`6Y+c!1swjnEBa|UM7wi2G^=pr_kvN
z`$g4lQ#=yn!IO=%U#q)k6Lw}zF(T7q^J$^ml)``qPsz2pWJ^fIAV3wIXXryJX at TBQ
zQ-0R`&o|1-^9ocRd|BU8n-<QsYA$}13$iAKV!xgI;;au5YLfo`KPif51 at NR3xH(z=
z%qepH=bR$f|0t)pp)KQxE`b`ccwz1>wp=}*Nxgf|1!)3j*otjZN97sGj%tF%CkWYi
zi+rzhN13Xor<Sy+$BJ4ucii at dD#XLc#Mt}#`_yd&D={zNF~03&HpCUQx|}k38)r)M
zAcf%M={dzWQ+U|)I?eDcE_uVyPDsTYzv?xlQ7ug;Kl4TFVfCQ<`!?op29A$N;v|};
zH!%kEP!&RT4++Ff3}TV at qZx^lLZJ_h5!KG;2AY;8mE!>Ugg%=$MBpr<4__hQ8pPEL
z5$Ys3;foR2;YL;p&6zsP5S&%7M?F0s|DZ33$q at EMw^&@)W>Qiwa|k&V1fdUMFf^0Y
zemok_+##^-deyk&K3-l<ejVC{<uc4_Ufnuivq^H)p6!=+U*F_jOC9Je4&BfG$S3b)
zIlR(|xqtlrMH~VnBo&W^J`}+X=O<(Fz?BNAF(XdNt&g8TSOj8C>`cGR#bA0Wk96Ph
z40y~uvL~z2Sb9FH;nY9ac4$K~)Rm4S&S`dsi`5-U2f())P-bDU(@?CiXoaq=6BKmr
z4O_f$+D!T3K#Qy*stA!BrQ6|v!8-P8#V9%Qjd%Y{m!YJwfX)HpXShOlHba)>H8TQ&
z*VA2IYTG_Cq$LDyo=!ycqmN-PG|+tA-(UmT>ylwZ1w>(Q*`Z%si at LDWW7m}HfB>pC
zSkbJ`E3!Kh&Lvlbx(%1gAJ>T@*kNqRlt3I;`9V%Ne1-H>82HVmFLl8=L-^uwBPKXs
z=-4$Pf8F+Mqql8Uj9+1D)y2iJXtqY|T|zr*I&fEvjG6B3&&9u4I{{yzV{)8pY&4b#
znSh|b9=~PT`F2ed-_yG5*Mrs{i54%By0z!m-?X`+^*T^n23q(PPXmky^_JR%@T(QR
zEFYY%jdxUU8V`Zt(J~vc)D=_UZ~uibHwr(_V(S)GE3pQ03x>TQc;SWd+TYe;m&O*O
zM$K;uC!z~2tAt<Ax|x3;S;((7+c%b!M2jJ9*C(vqgHpFXK9<Q=^^xAji%syD?U<6{
z70S?SAy$RC6U8^LqoLmfI2*U(eE1}?jBi6SlT!nM|3dLy*x^xlv?RbI81LFC|0CM=
zq{cO};uuv()thbON19-omy*umSU_RzElJDJ3JFrJ^st=7Euw+yL9x>}sFP-^oowe=
z;b>||X<Q~88 at 1tel(Zmx9%}y=uqztveip4Ft?k;rw-T<A_<p#pYt{?65bz5+SR{9Z
z;_SQw#O5ueoxOEyP_*WJWS+b*gB=gcR4+s1oNfs7k;4#y5ZKg{A_8kxeocXrTbpB>
z#7*lyQKIZ!&XX6zAGQnvvXZ{J^|idIG7}_ufZjdT+XxP+t-476`bz=Tc0doBETQ}n
z-|?lJ?{IlreI}|YFO?;=FFlf>J*3p90kckae={z#2F(V+UoyFchwP|K%qRq_#}?~v
zlDw>N51^dwIY`;R`<Ud8BD=cj0+bVIf&dh1T*R)}3AOg~+33rnesC7hGhJK?wsPym
z3~rbrWvcBGHMEk1Ye(8Ry)79F7uZ@~L!@-$4r(okrY#xrb)BN=z9OXzkPAk%uYXs7
zBE-*T?*$;ys7pdI5_0AVEEF>=B<Vv<Gk0hs1#@V?F)~qF392bJyTwq(4A-DtT4CqZ
zE8=<gn0<?(pe|qaBPm3J``E`^ZUBHVY5pPZg{xgh+7LNg6Iz;rf7u8bkbH{3Gwdby
z at q{Bjw@(l%)dERAsblgn`aHNu%7aoXW!)jr0>v!uHjd7>i*MmZE+os2QfdHRI8@=I
zk^`GM_5>98i^s7TbGGdiiZbzycSEli$S*yWzUXd((zH-HsBp;0`h?HB at srp+n;TUI
z-y8l6qEM)dzJhc7>3`wC!ds_ekvq9f+8-31n<2G5?Utu8*(pOA(m|_z7K>2HZ~@0D
z-vPl!_#+t}GFL{o#cIQm=Fz_4P*JheQZkwo1E5jl5Ug4F?Gg5?q0qF5nw<OwojD7c
z$_!WL%D})Gt{|%!i!vgSgP%vp^#f!O*}|mEk!02-%2>r%2Ig?l%w6NAQ+XWO!bnkS
z3!Tr;V+*F#M`CV9Doi8TpYk`~8^Wh41e0n%Pu~Q($w973ElNw{y<eej{~pYUfID#*
z8yCggWrtG6kd9PzdbHLqA-?eLTEhkPMJk7My0Jw$O<t~lzm!EgMZ)>lB;y7=a=$x6
zS-iKQdR-e4;ucU9WpTK*9BQo_etHXnW0X>{M)CWLVJJGhFpV;u-jcHnKQ}rpl#<32
zO})cAV7Y*T at selup8ozUf||R76Av4M)W0|nr1_>-=f(&4I+9bA9<<EfF|t*B5jTrw
zv&0iNA{|7=MNgkhb)Eo at +n5G}R~J<bMO2@&`hi~K?r6sB4=UqL;rN9)$C!-Zm~b(_
zPu{zHXC#uk?pz*-E}q4TW|^JaXTOF!Y5UcjQPtQnK30X$6j8hIXD`!B(rip^ZHh)`
zXe)J$H|q(-EOf2#>u at G0VXdMw=RPR;2;G`|^6|k6Rm_s-Y!EIXFDb5Nf?v{q<{T)-
z4`N%n!5xW2%)Y%hhxO6M!G!PhsNZ31AiSWNihij2{t#I*b69oo*g at dg)>_1q2>d{}
zxQaopUHzU`__WQL_4+_^0t%qnCJ&)!bF4S8oz8U25dAV1dHw2>N9w9kbDT0d%Rx=r
z9wa~AvJQJETTkrjS at IwQX8DMPw-vW{{~=M*kE*CTl;Td$fo-`J+<PO)X({3;+_aD>
zB|n1E`FrZGoB<D~Id)jb2*My5Ve`>Rq;-X4WFY~=YQ2ymGJ47#YbjG7vE_gi!M8BK
zj+jdcr)|<|hsBE5Upv0V==GK=En?EOxL41_G&H5>6W1bfOVj;0UDGD>w%E<4ZES at B
zfLnKXeiaP75PR%2*|Jbz3Qb7iUw!ow!rY1&UX>zT#8NWi;I#CH_<PshdG3t-uju)A
zMJ!$n(uCeuKkIsZ`;!wJJ9 at H|q`B#XDGr2|elV!L+7##+ at RixVA8M}RZ^EZ9IR4dB
zd^Q at V`VkwK>4s5Yccp4?x7vNu`ivr7TS2vFXhM{vTS!GC`(=lf{Hr_R^sm|muJaQs
z=Z1y`zYx9sziTEng|jCwT(6mVJ9((^V4iYYz*!Q6tgs&+dR0mjLxo((hhD93@)&3D
zTV1XiIeT#WcFy16X)2hVCkhzg%BjFh^=(;meoZ$;Q1h(fGV_}KM!5c~I?Y~lF)fuM
zif><kGhBKKG4QTgag0lY-vZdHi0(~UqOGXML>m0F$CQ-{NLR7&PD<dO9r_L<o@^Dl
zU>Ty5^#$gCb_M^88Clpkx&QP9|F#sVs=J*rqoRSSF{7NZk-34ets9Zf)5liq-0VbL
zY%F^4jLNo722RFAOyF7$#x_nwtWUuuxY*dy*4e?(*b)4UTG7GQP{r6uhfz^foCrJ{
z+?>Ge#BITqnV)W at 4A0LG&nN;u2e)@5dS3PPsR&H$latE)H_!B+Cg*8$s{cR^^RpNH
zcY6L at z7;&Of0!PY=ScnE;bD1#|Cz==@L_pE{ErC#AD~Cd8q9qWBF5*V)L-lqv9+>w
zP_Z*GG$vyCjT)n-!g~v2Lnk7Z=l#6?;4tf7<o=7pEPrwRk0G%BElKeY4B_t*$NJa3
z|3we$Uoihk&;OptvHlk#$NC>d4!rc}Kgr_1<HPnB7XQMB?Jpkwfe+h1D{}uv&tF*l
zjh?@F_$NJ_|7-ZLKYv&H?^BZPFCP9u5Bn2{|J;=PJ3j3H1wQP*b at 0DbDEmK)&z~yd
z54!%;1027h`mO0X{tLNc|BtwF{IhcP-_iMm4%lQpTO^LZX!@7DJ+ICEca_WWzc(K_
z|KjDp=z0F!`S0{_K23;!PTu|-+&F(j^&2<N-%9`AEIH?YH04}RisYZ8^Y8P5>%YM5
zIT!wS+_?T(-2RQ8-$M3p_&n#_{!Y)o#2;*D!JZe<v+LzZ#3*BK<Vd6g|6A`pJ4DLx
z%)b$THvh`-&n6Un_zn59!BB>O*3;m_?|VOMC1v<$WuOfIJlDX7- at QCbkTU!;gTRO1
zH_{^l%bfF*o5t~X|L5O%2(Dw`WME}$`X{l!fd~7GP6kHcD at 5FXapDi{`0VukAqC3J
zOz_Ol=7mw2nHiq>S!IC#vcNMxD-7^oR(R&;9vGE5;hzV>sLT!jO!dDM9P^VX{{MIR
z-#32tvi_^a|A$1dJgMTResmb6Y>bTEjE&$KMU7p|4UHun4BX*a*xBK!beWi#bXhq$
z!9NaNRwfo*W=>8~8r}D at x-4ugBp$jf?995X%&g!uCOcgwR&X6wHUSG=Ru)!QT_$D@
zUT_;GT^m+#0lS(mD+l;G2fHo{2Pc<_E(;U5m;>CDiBp$~PnVUAO$pqZ6Wj|kxCVzV
z3k&!<D+~BPvzwl-F1VacmzA9z`~zQSWzuC~W(QLTuFnGQk(mul!c#d5sSdaVe8vo>
znVl2dnhAUkCXyXIj;9)&;2zo8<d|*5!T+De#4cfI4<-WKF}Rbb;r_qh|HI(_G8v%O
z`$Jbf$2NcJ1{MzZ=Q*zYFU9j5>-=?{6Q1Q+L;dag)A=9QRh-{DJ%!WH=JYAx{Z|C_
z+lgb;FgF6f%gw>g0naFDY;J1iM8wI(0?#OH?&PQl-hsi^+RoPIDaPgkJ1gc^PR0(5
z;#T0`Th!Rl*2wtJSHao96Puf#-_gmz*uWazEp<N)L1zw#*K-y)MpF4o8%o%i_7xS4
zN+zHht{A>Q*YWm2e{(3UlFBqY$Jg{;KjGX{@`kmC*Y)ADMKM!203L&8LVygY1|h%@
z>!aP5haj%ffgY7r?speU(vvOuQGa7O&MY5jCjGhkr=)y-a*MRh09D-U^MSh*RKz$~
zxz`FF60?&Us45;Nj19 at WK^`$rwUzB0+?6%8baR5Eb!LY|n1ciRKT-ILi*-N1lNQt#
zczVpwDSU5U#4%6w%#|TfCmW)!eh;M(Ia6X at inb%{fP`Aj<n<w_D)Ol>AQQClq<)Vo
zOdlhCo^<mf7LzD>LQi=v0g)W79bhev#(TstJl<5z>2oj~`8?_Jk^wy#E)6m+f=n5z
zp1Y?poc<<}^Jzkl2mitGXW|^w25L~UL)h4nyHSY}_1W2j<<mIA12#mt!L at h#;qI;X
zOB=`Z0WC(Z6en&j5gUx8z+^1;u)bpX$@2q(DdDWl(~Ppx&YG8>OAokgR8vpWc2q2t
zLr<s(sB`QADfzxdH%uT*zi!31-i_xw1cA#EiJ~GKLSKc<_o1WI*-BWjY*??W_Ccz{
zq|Hjr5hquOUI}YX*AWs2{eEg+^!NCiI(QG at 3Q3<p6aVC328C)kI{(ucuZXB6*Ol~w
z8Bh`V3UBiAB8g+m*my&Nbln~&942QGj;tF=89O28PTGx*>MO8%8);^2h-y8%)v%Dj
zcao$;za*oMechfq+<zU(D;Zn3<>I9fnyE^;Mk{H&xO=RT=Ha})?9w)PT`_nB9!3FF
zFpwFMJvnTss07gCDO>zOxlxZ at Fj)Afwb|mrsB9p%@H>!;X%LVhCn^$ZWX(s77$jp(
zMn((@rJ82mqIsL-Gu#$JC-XFPQersw)Pmc=Dj$x1tfU}}#;hmCKGi*QvbvQZ?dAXV
zNFerSMN*qQmkkBNVT^{PNAN2`V6>wm{ei<%5HHY|X>J^AeyV$t3x+&_BTN#~W1hB|
zEH?SEO1L`~zLI7%XU_ukAQ~}_sZ!B}iQCdHU9qelb8tReTK0l;!Nw~KMYS=9Q}yl;
z at XU38Q7BN?p^cX|D)DTf!G4sNryn3kLaZHD;oOf;wZlz9ISRt#$Ghv#H~a7=UZGLB
zU(*AHV)dJwUE;?o_H6R4O0%W)p#}19X%HfFS;lYXg3pVBk5n1z*Xr7kSj>?<-Fptp
zL+_6MxEq-p05o#ST22SYuLk9e at G9gU(*j))hcKo(pe*a;Q1B*gmZhy`$<3d#vGdMz
zulIus+eDy$^g)KL12&@y(pll8(m;>xo;$sqBs2;nWoH|1t*GQYMRs<(yztl^{}032
zi!*u=fB?fo>QCfxbKa!BHNKmuS%Z|><*O{;Ar02RhH1CNp0IX~KzHE$$ypIG{rE!o
zbUq?TcsuZ9rZIyGmt|mJWXGq?n}f%V{ia+CAZ+q(y}9Q0*U^}+&-1i`lZphM#@Zu+
zsI^~(ZKn8Nx+FrSliM|nigfw=ra1+AD~+>NFgd`qY$=r&DnGQ2)Z|Ld4!rxiG#}WB
zmDG<yDl4}5rG22l)IUBbX*9B9Ewc_|3j%u!rG<#>_Bx&zM2JPdh*-5I$J{?j9`Num
zWgnkMv}x)o?Bt}O>TRsB?Yhy$iYTS*G}3p54H8>9X`qup_V&!U-Y{Cy(I;kG(P_%{
zm3(<EP$4Fsc%s^3FO1a^;%xv&y>$X{PjguIh!!M4^~+>|S14@}#O3v at uE@yRPVy;~
zkKDqv&?ci(e`=EqV6r7mj6%qLMPfY{3p%yLPKEB*u~L|YlkzwXr?jy7u at kC&coUjw
ze#&v2I7~T{61!)65#8;AZ{1K5$ZIVZ+IA(LAhAtHSGT2246?<AlgilW`D{KiRFbAJ
zxW}sVSzTrR1hqTif&;LrB;vWEa1r*PJ4XxG#|yCBuQCr0#H5mud~eIblv(<2Ulx*G
z4^Xjhl;0xTUm^ln2G25x>5|KahKm5VPReavmKk#xU2PFln`ToW?*-2J>(E0r)e!1s
zb=2sl8mxPj<si>Q#JRT70s}xvTW_;303V>$+&nT at NpT{1wnyu;tiq-WU_*^AE79y<
zVHjP+ at Eovsll^Y7y^V(LI>)^On(nF%pwr}pe3A7^tZHW at IPqWyXu;=-IM<<No!J_l
zZ)6aOm8Sz7Eq8-sNn@&U#O9=bgv~WxPW~VX>8+m?))UV+xCX&fkqs0 at S+h^U;6QZ-
z#_Ffoq`q0kBl<n>an?rtE%r at ap<UIIslHjn<mi0&Qp3}QM99~})<Dq|>(_5SN+A&=
zDd|5e+`8NKIlKH+D5-BIJ<JnoH~#L?ALS+94?uCb{d>-r%hutJ9g at Q13b;s#g)}Ok
zWa#owfOtT?t*yWVz9V+j=sw^ad4dE at d^|Itz=VytlXQ}~$d?76qE%gDRnfUe&gwZo
zwBG{bM8p3J(=R0MGCcV~@;5?#K$p`UIN;O|`#ipOL;A;d4JC!LcR4*e-v-XURN#D9
zcDZ?2Dp#=8y10ygbO&5k2v8nhNd$h0AqIq|OO387H7GgNzZX&|A(NtX1UHZ#$3<j0
zyl+_L3v+8c<z at J-ERzOF`IQUp0UIIa)rKO#r74}64V0J=ad&@jIAP_})Ge#e(S!cg
zvA?!#s!%PDPrZ5 at e(O^ew at yxJmsp8|5Q-1?1#`TB7JEnBpq@%=BE2nR(mjE8(nGuS
z-D<+k+QtjDlPZ}Qso%pg2fp_ccW(s0s_`?J6Toh4X@}NY8nhh}m1ViJ>k}YR*d at S(
zZ2-~bRXp(V4-)$gi3QpXqnrm<y>(1SEyif;E at 7+t-8z-(l|Kk!_|YtKkIdp at FnZw&
z8B%%{7qdPaGhvqQ;9p^cnlU>5#icHlFjqkn4Xz7c&V at Fna&DSEwq{axU3dA_Q}&58
z^B&YDnG0sx9PiGj at ne6Ha*o+{R1D{&^jhE>hCb_l)JneMl80mw?%$f6Oc8Jy!=l}F
zT<`Ptx6Od+BPG<uI^Ayh!vsb2yllB=f2_G6J{ozd!7T6h(|)Ar{mn+nwLlTb-3Rl@
z5wJ%^2PHo~BtLfCB-XHvD!TuWl=Pz$z*JCQOIvNpkL;Q3caLE2K<Av`4FDFaA3B=h
z;+)og6b5J%xQ={-K5a$R=v}j at YP+8nMnA394gh+~5`zlVde?gX`_su@$K-<am);c^
z;1*3j@^x4UyylzR`Wq*J>pi;<$=(^fTfS3YQC;4TOt$nJMxN=9$1-3036rLaosXQl
znO$K8v!XY2AzWJ`bzO{{CNAi7y%<ztFF_i{I+<>4EWBncle#f=@BEcx8^xtJZ(qpx
zv&7vT#kb<VSoo0v<P)nl$i-6#8&H>UL(5l0(}Kx;drotHbgC(P%@goLR18)g9h9xw
zy9RmV>fXs+xm!M+bGl?YB<nLYK(lTy!cNRaDXATfhb-aqV_TH*;not#eL+zUJ|ZBC
z5clwwm>oIp#cne(2=9CF>gX3MbM}r`7O>MNTi1E+>b+}$7Sf*?tkE07uJ#QxKO~7=
zzte6O0dT5T_+4Z$l3~!hd}+Q3%=Q%q7x8z-ZJt?~dQ*XKx*?(q#{VtY-Jo5!zkqkw
z)!pk|JA-fR3<VSVQ(FS?X!%t5aQcch{cSFDaT&Mb5UFnUdq!mhLj(%6(dvpCCQI^^
zta1}!Qgb-E&-C6dq&*3mpO%X_$Lmn%=~rP=$QqykH>4DU7L{VIw&UQZr2<z|4STmu
zqgscZ)a&-l>@b*y-f}S?`SHYEN_?Hq(I|)|*R1YB&+EK<_=BB{rIRc_eW^-t0l(Ee
z3dlL_X4<bc$e#kF)PGb6CrE%*L5e|`xep<SLMue&2XUlCCIdd}k(YHnev@@s;%-@@
z;2(ayB}WWG2;t&VZ(Qodc-gSb&_LSk6x)GK(U6%=)?;!zsR%_Hzy-94G4pGI^JH-a
zFmb5KbMs$?bTWTPh;-<5r=v|^iX%vgtk)+vHfwC*ui~i6itK^T;Q?|yb-AV_ftb+q
z0h%I2{-}d8*nW=W7W-bw1{-wivXwG4DA4WRNm>128UnO#>XLpk<4*Io0KfI;SMDeY
zPrFr({6;YQmF#QIABGYKSiOyQBq>xYjWmR=H6y%G1&hC#YlnX^rk1dRzw)f>V_XH&
z*eUg`N)g0b1tZ?l_Z#vsG6Pg#XR>XFHqk3|UIJ#_aklyw<|ZbD0a%lmYs_2M{KZRd
zvF}zOtVB^+cI$!P2R#zL#Cbsg!b6PJ5}}#5%8;-&y4}f2^*^~|$@HUaD2d<<h(cSn
zLtN9hm~1(x(Sk$(pW-j`{kX$j8kf5<)=qH57Vd7a27Q_d`GOQ2)VH`<*G@`KL(Vtf
zzTPEO9QhKd at AIv})oY-H`5`rq{0=t=egJ1ABRz_rxh4L~9YO+U0Fa?DJ3U8Y*pOQt
z$F0<?w6eycoszng#-6^*t&`l}Nu9FIK7Taq%<Y_m<A4vuLssf6=`NGs_o7nK8Wj}K
z_^1NG_${(0po&nU^HvW=7^~dMXPTOQ*<j&&y=_K%pss*%x at c3pxkVy)+u$3Vol~sZ
zO at s+EE|7**WkE5?O#u)Im#7agKjPL2D``<`(8Rvc?f+5(RSY%ak>%Rm+=Y)v=UdvH
z1X$hFR(sO%DQ9V3gQj$@S|=g9=X{gs3>S<))ZFB}N`<zbHK!eluQeHc-2mHzaQ9t3
z`GE|ybU3$mTQ+5ATe#sCvb4AP&ULPdDJ{jJ$t(c)(?o#<E2ezKUAct&-agZ0M}Mo#
zEn4h?;K&h(Y at QcU4(rPAnbt*aZ;Mgl%kKnz)8no>-~WpS|Hypa{Z?SJj|}^M9LO<J
zd{eMnXYH*N_5uji^w5K^y6CyxqWNTth}o)C`G2ag$t#05qP$0!d}RNy0D87k#B8$@
z7PRp at FM#D%OdwA>igjY#nTD!FWBa0yAo$X;^`LQ9TjHm{4_S88W0E1IYA<dp7jKZX
zMqxBl4p5)#CekEY+NbSKa2q%KmgmXqFf<6xScfNZ*932eVCN^dIa)<lWOCNU4EQGN
zzC{0IH4F`AgKsb^#>LbR0xktw*Qh<JTOQ7UfJ{G-J+B=1`nS(>GsWFelu>5y<D5Ad
zg(;3QvtHRqfK5MZTViGJKmt)pbQ4xw^S3WXUVU%76#VSu?hV>LB6hT2eSiV_-0cC?
zS@<Q6j4l#5Rt~BUWc0Z#Y-r=0 at iF$+r at 7-JKCSZjPq|%7xSw0=PFayBR5?|}iY)WA
zjgt||nhB6?AuI at goe^rzFRRygx?NsZlJKGQSD0E9v*(QX!lSvh*xpU8|2>a|O>Ubl
z%LoH+Ykyq<TL2HMe=8Vm4)}E=RVJ<U#Mk>9m0l5HWNHs at z?AXv%bUR9RMlGzT#h}|
z$@`Y>wd`(*Joi8b8!7n;#d2dUW+N>=Q^mHZ2*m{CPH{|%!By69bvb5IZAt;SUh=J+
zv&DqU%G3Bf<WQ&88X--NQtO}PNy^`y^x?#RMY8E7&2v5T2(AwZSX;5+ekopx>fu at +
z(R=yxV-Lbc>`AYVbM_gWt8PS(iPu<DqnSWGhX|@?>~H_Zaa at 9T6?-}2I59NkC4d|i
z8i0_`%ibNoc2a%N0AWlUdF|q<kzgmsPxB-PPxlxw0nE-Tt~t6HWy#2iML~d|b0pj+
zR^IZNhOG#XBz?v87>VeXc>UhwY>_T$e()U6w#)~T3udDf;Nxg>k+x>?vttTB>DT<t
z&6PwFWggxKX#<hpK9f68*_ at MZ+R5z>BEr^J!U`y+3n()ZcmWzYcf=c&QrpRK1C}jQ
zf}*Xl1>*FkIHqI!u*P8uboA;1A2HF{!w}jf9(YrJ<VzTJL|z8&GS%~bJ at 8h3+fcq9
z{oA22LIUjovE%XQ-RN3!rA+UQTMf%lzi#w!SPrCa+gMNo3{ZzT%QCgNlTpXx=&?-_
zMcBMz-mcScg^yP at uAFX1c5|>^XU>wQVon!vX}8o5{n;-(h(-?TXh&nQL}2PzZ=Vt%
zPngn5n)sy_`2IfRG_kS#u+-ayeKkVn<jSje?9<8TaO^^-%L!hOagx-IUmdr1VtHup
zjUpoK4-cfTN8a6ovfO1|y)Oku9pHS-<=*?L?V#P}+>Fok at Cam75cI*tkN at _^WLKk7
zxJHlEJ|1<~vo9qO%5{_Sd#*(Ra_h37(cm>GoY5J()|ePmC2kOCz5KuDP{`CfixPgO
z at y~z)9BcZv`?Sp#zQ)nfWT~D5;`_NzoMN1*&$>9GAKpR>;|N(La`UhaVYBQA at bkVg
zXtS8^k%RctoenmHg#VS<mD*)F#D3)__VznJ4a at i_%VJKIU1oQLpjOF36@}v#C+KQ>
zg<PTkisQTaH-0{L2>NW>YiGak_s$$ai}6}6T~+1zk!rhEZ?AqT0?HKUHtc^KE(%mS
z+FUUnaB?!0e#IwnrKkKYdFu~2k5#IVgJb|7+|u_#Y2fe48a0{+98#yu+$iU-JMV71
zYn2x3d-u74$z$;BH99$=EBbEwO?Yc3_4YQknUaTyXP<q-A1$AJ-R|aV+)I605pP&G
zFPIIOYQ_zZ5lDoo^7ki<VrLuByQ~RNvb5^y`j%&I_{UqPW*r$9sNGFG##P;CdljDP
zr at d)cr|;N%1d^U+5gQd*VrGBCfaX0vV%@m!uP+37O?fUT%LhFISOOxPJp2h-FF{t1
z#)!b~@bRUXq=}`DhIvAkUpFUih<!A20~Nfx8e;E@)S(J5)z(#=W)PO|^W5o%4hk>D
zF2+!?k{FL_0_Qsz<;H2=hsGU at t0P2^>qMl-7LNm#3{!MSy at 1wl=NV+&+kgPlDFFDp
z^wT{yw|3bsZtqc5d$N{@yS%eKQvI|OSrsIDR^P(iq3 at pM^`Ay&S-MU?AE16nR{|hs
zz``{ntmKiJ`%9d)=%#1RCZrGd=bHJ{ov^z8f*0?CLV25e4fGZ(6G&=eP1YCL`8j(s
zl<xiBc!l888l_%NQiWH?Ra*%0y2oA1b6f|o_D*q<i>ykm!f8GikQjoFCj7X0_8DP*
zwgW~ELCaapag$+GHlEgLh(&)#Cz-VlE*;O<FF5!KP9Ref+ at sxt^t_JCx$Jr07BS=H
z#qz_FT|MT?DC6(6Cq=wAeWbSc&S>$5$D{_)02#(iVsT`T7}(f>SHOu2j||_NIpx1R
zzli`1`>>IeEXDm;F#x-LX7Allx9zGwC2mZzMCM8NMWtR2`E)~&w5 at K3_sH&mH$Df;
z1_f;XsJi;t6$<m&ulO1rHd_>_n|ECEyV<d#kubGi-0t%31(Y#bjHB*nO&@F1t<ewM
zE<pt;A0)lcf6<g3ZGSMSBaV3T;!)&~RnKZGGW3tdj0tYp at 5CxtDhT7elDvRXuiNPd
zBembcZxDl0iq4w1Igd5K|L7a|z}ugSqRm at llXT;iWlp5A$sKPi`}sNe=C1u%SrX{B
zgV+7xD`cK<x3Bw&an^G_2d6?h0BBPgfdb#}g;OzF?WnmXKF`-^z5JyLE<L?ZSj%KI
z93^bR_<qb7TDHdqu5Ws0R{6{PM^+s>)imuEc=rXfG~#pe3<)7DlM`U`5t7aaK_*C(
z5(r>!Nrv at z-!II{-n>BV^bLW1QU1b?9X``)w43vX>&PBCb#9QNV$n#UjGlyELJx)C
zNr(r6+rn_UUK52lCeJ2N9f{$(ApGnz+O at d?ocn?iIRWy5(B~AlRx`(`NdL0>ynRWY
zfs(e`x}DcUo<++qK|Z7AXCZOqTp$kJSbMk1A3L#m{y>}Zw;y{%nMOR;MjbZy7yy^^
zA>D3+FAS}kZHf|Ee0%suE9oj|H-WjenWY13l{RIOJ&5Wth=EejXH4COH}ox28QOXj
z^Q~+2gmDmO&X$!C(8V@;`->J_gC&%E9VaaiH~kU_Fs#baCsz&p`6Hh1p##$RkMqki
z>4&)1P#)Fa9JT{{TsbDpy4^ir?Xf;e0T71`nN+$nMb0>K1V12KN-eajZA=x?NE9|n
z2rHe at Eg!M~Qmp-vlfEr-{OEDFswl8via!>EoB!|-3dBrXooI7&@sILOgSB&LpJ?r}
zH5Ct>lA$wOnj%}Pnanm7LL!JNJ%2r&O<o at wj`P at 6Qg7O<<Skp%_1b+w_d?ed&5|v>
zUIWbZVkA9)OxE)H8jmBsao8cU`-0{oH3O&($EZa2NvsgRFxq5+V?3RwFi}k`<6ZFT
z$>%qyi-9mw4*mn=!tV>uHWLMh;5YYb7u&h|n(nj*OMBi8h?p<621oV`#bX29Q?9sO
zt2!EwyB`I&h6=ob%HZTcrh)TNht>WS8%=z9Wo+yA739$pcE_UbR%ks?jt$EG%u%g|
zb#v*xr1FC&bEv1av#5PvBUD$ELiMP5V>`SWJ`JVE_V8WvmOmo7slLl?LNgst9>;w1
zRB^y?`UHKBR|Hm5EMba+r`<$#Jfh(AV-LJreQ^K~$uh}o`9<*h2`%J at o-OPY_FXsu
zKbZ-Hm;^%hY=yy+ at Sa&$aFlEXw_ZlHT>j1D2S<08$k(n$S=Up!?zJ4{FP(-CUsCp;
zhDHT|3no=Ix!99Ir at Ux%(F!6pk7ctKR+en{e5KJw&<8!hQOc|GG$WaT9BMS`1?nlW
zZD>2$!K8y(u$&JTc8YmjGMeAznia1%D-GaZg1J%M4qkV4@;ixQ=~Gx;5F*$Ho?D7V
zG?37ii0-fNQ|L*M?JI|$%G^JHb$$xc`$h1JDxN9>eww9$(-fJfZzT2#!QvYi#HDS@
zSK=X`2LcD;DB${vgvz~ZB;e}>irq|M6}H162AbH*MjPo;$t%9jveTZ?K6_4tXGk`J
zBgdRy;b4>Aj)RvYTAjXQueHRg&QYm94Y9wep*vy`c<(d3Ad!5o&gr=%?j4Hf`7+d&
ze|QOe_s_u2Q5w<r at y0Y1`elXq@)L}XII%{K`z}AM*SO*p3_l at Wm~v>_Ys%?NSud8W
zB9gCsXA{qz<QDyuWJBk{r1Xu at ch<6u;NT)_g}<(F{li^U8rDYd{d#_X-XO=e!+h}#
zRwY<NuM<b86K@(xiQ($oyDs3i8YT at PhtuL%ty9N_^`xe)cwZ#?R&5SH_A4ILEKY<I
z&<)g-q6*0!_fCIo3SvA&`#JSdVr!sc=vDHn;ln3zIzkkT9>!1X?#I_|Y(`bVDXmoM
zm)QDMyjH2kJ`UT%!<H*0A4otv4vtp*xGSB3aj?c%p5bMtZN0R=vd`Zdk$@8SZ!rI&
zEP|Ms$pE0hrW-*_rjO~{19hJvmYl$`J<Y95_pvy*J_3O^NP;3r0?1Uq2^`aDm1c-I
zWn$3&$~0CPFF?(4wSI^By~3P<591&a9C1g185w{NaHWnOw1~5rz%BX3-RdMLu>Fm0
z+W3lxv!6O(6Ur;<y at p+U#~MV1{RY{R+$M_2<&6~DBx5z1G2 at ECP06~LPpcui&B=-t
z?vfkuAa!7QwBLzdLcig54TJ&CuDOTUJa)O!ZSvZ9r%@=P at vFbcHJtF%!(2m&q3WX7
zVV8 at +pru@&Ui9U(i7*g=ro~(<wD`#*OPzNP<848?IeqXF*?07NzL$wu<)nE*tk|y&
zP128GGu$iUR3iLB!g0FU)qSDHXMAS3x6u1O>Br9{k+8GGC6VvLpKq0y(>o1s9H*LS
zd1q#1+C#qIWpD;BvuT>2ryffjic+3v-eu7V$cT(LhInb;>;|aCSh+hLQa)t>cS-j}
z-Urlq3~LGbt7n{Lf3al(SgN6yWQ3?(Y!k(e96_!f1@(ha8KF#I<?ZRJ7q?84sKjC|
zP69SM5wlMu0NiiCl<j>7S<ltwh-Br=>4BokGWuc411~>=O}Jlhd4RL*9xX1JE?=mE
zzi*0@(Af@~rR)UVCUhM_- at 8%iOSkq?F;0X?k%U>X_`sc!TR2?=r(0}K9)dP46c at D6
z98Wtmv#o5<{^>PO^^CA_O5H|E2WXd!>#}j4^!ZU4WGE|2{dgS|Q0rmeaC%txUdg*@
z86C_KXl(Pg0-0JrpYqva=$poln-3tbCwE=Yke-VVDzqcNvfyKXL~#h#5#`-eeiRzd
z+P6>Rwg*(xp(<tYVC|)b+VtV+aURu*8G^L;X+Hg=`oZ!UmNN6BO|v){JjK>g%-Fk)
zldl at 7GiW?=>R`TD>w!Zkbhk!m(lX!|f}6{8G3PrQ8_lQ6$0%5zJ5R6Ha}w;O*hh6t
zpPm3yU42FneeWJybiH*|?8-p)6uLu_FuV%hP(oo&rUR>kX4C;v)HYH$cU}GKzO~Vy
zBXC(Il&J0-)IDUPb$fHT&$UFAWFSN|sIN#eObwXvFX)o_r({jwtsI69LSMV<YCrWy
z-$&}oqTgN%-fd0s9fq;C_XM|re{a69q{k+oUGG=e=U(VQ#ne9tPobzHjz2G}n}8js
z=ib-jB;HG5;GbeQKHXM3UIK5SSP|+nIgiPMcb(bnkEYZd>JTYfas{aYKo~{{6fFP7
zjcM0 at SFMO6c5YBqWX}p2(NDifPCyaxwRah#Jv#oKRgBv4j8S024=1P2?o0I60*I;p
zL`2gL9?pIG<1&Fc$jw7ykR_chu-j&Jx^M+1BpGH`@insC_~3Ql*Zx8mgCEvvzPaT5
zE2(e$4oHk_CR5(k>}Ej+3itzy%i`Bhus8>=JCw=wz8n01Onqfo)Xmqhl1hk3gDlb|
z-LQawl9JL5OQ-bGN=h!RbT>*$cP-uB4bm*#@2=ke=X$^G_1lRvGv}N+J+{*`wuWA8
zU%554ObmyNf$cp|bcVFPkqeRb^}=7-WO{6*Cv>bnN5hQ-a054~_5CfT+O%v(iEFFr
z$}`9e$D86!`|`Rd`l2W(&y=jYS4?6a&Ypg_)Zxvpf{e%)#shr7ANLqoV~-BpY+KGt
z>AgYS at sqcErNNXGGGj9IWgC8bMErgZgqgloln$M;$b;1uT$>_h0)b2Pw7BP+4_DrT
z*Cv%&Hcna!a8AH-(o-nDY6}ga6HW<GFRj+v6Y(C?Q2~Xqnt<e|raMQo0p*+&E9D#Y
zd5x;oRl4zJD?9JTxsN{(z^;}@gTXXHF%udVHvw1{Q_4ItbA{u%fv!dkK{yvQ=Q at k6
zF;!t7W$J at 5X$rq$Q^}NGtj}N*t)AeOa!V<$T$bL2KTbrGXS>j-YxoW5Y$2naquv99
z;mZ=~ruOp2-dw^S1!1ofuBq*C&zFAn)L#OKe6Ge(WX#~8k2dmM9eefCL2PFoXdLsS
zJ3CO52;dCQwZS#7k+LWL4{x>oq&%M2e`$PGArlNeaz4eCvlqzgSm&|#b at p0<2*bDP
zA5Nn{IAS$uxuwy`0c!PyAVwbk$<@(-(>_YbgWS7L)J({!W at B~U=5+c9V at erbVv2!*
zv*iCx0*_KK9cNWs$IWlWLRa|F3L34_$>#eXHF$?Z1t}SD#u>UY^>A05z;Q+m!A`Eb
z>aJTE<0+WW>bfM8U(%LFF0%gz%NZr0p{U3;bE1G#%v%!Ozk_>O0pw*b!)Ft>N1n`C
z(tqK0!gYT?`ntuaXZ`OESin)p8-Yvk<w(%NF<%KTXUHPJ9$8-c_X8nceEEhc?g!>(
zo8{Iz0X?QQm%%6 at d(2`$(w>B*%tv^kU-)K96GNVD<~rI8teKxPH8RuuWvh_dcQjE_
z0sBXoNh3Ff$eXq==>ErI?lwntRUO=_`3r%M%@3iCjXx2(lwV}^myKf4+qYV()&1G8
z7fkkbNq3uU5rZK`R%g%@2&ZgM_w?+`?@a0+#4ansSm4S&2LGHNJOdPj8ovH?*boey
z*kD9_<()%{<p*G+b+b9+Z8*7jUf$;+SXqxIrcxHT(Z&2jjnWs}D5-O+llyAKAGOk$
zs(xTE4XZdM;~Vz}S-I%d-A2S81^k$r#s{81-rg4Cb~*uWG|VqM8W4sJvCbb)em;fN
z5=g){sSf3u3LJ{7plBZv(5k=I%c^<-91B0=iL`MK49#xZnO>W5`pY<*RbFbtt8iIC
zr`7};?^}B_e)b00A~^mRQAH(fGJt4Kk>bw;_=h*XRE7st(ZDn+Pu~YEOoXPqA$K*c
zNY<Mjpw#)D458e5J%7Bhq;`+Pjq$3BhC|!){kSxpHyZj{oMEp&6#->)fbV@(2rwy5
zs*9*W2EPAM6m13)wr?PA7{ut;W4YAu&4N*1Sr=e$aP)qp_qII2h2JvQxOY4gXt1ju
z=+f2b+TS*mXL|*M>*br_&d1qZQV3uqcBYk+q3d6TUJV3${)Oh*y`a at 8*hUC=^Z#{<
zSm#)a{CM_XC*fo3!iaTc9>C_2bn`{-zmfiZ#GSY*qyEi^u)ba6Bk$!!Y$(HpVRv2X
zKwuE?SFAWd0sv2jgTS#bCkh$`by4X7^{flZ{Je6eMyyMbqs(qj8o<K&m=cJHlz=g!
zsTVaIrZ=B(=yi&MzfN59i2M>UgpWYh3OZC0`^w;}{^OCi81AmRIW0IqL8hK|*EZ3F
zPm%_WM3%KOB3hDTI?9RuT1%4*ciFgXJ0y$6{8m4p4c{&JWQ2pq5g$#xH<kbI974ZN
z?hrf)xmm9?dg>js>W(fZZ0CYlNl0Y9*6ve4>YMau5*f;TU(gA-U)GLK>YU{lh;24&
zwaRammGnef-Bh>{{atrU at d)Ej4TFg5IpC&9G=&9W^Rill+gX_7D!0zW=bJVGHgAY^
zepwpYV|kb2ZhoD-;H%9OsxLtl?R{w6pDpoolLe73R5zSQcN*Cn&fXdz5UGU<j4GJ?
z!(Grxjg*cR?>+3CdSBH&#ooqPh3)k8+j~6V53BfJhRpVO4Z?0zhG2^)l{l|znnc8u
zjKZa=o1J&zZ1GiY=}W5h?C521Tv}4?)m1{{OLGf=7 at E&|xzBLq-8=MK at S}}gjFUZe
z4)BUNyw?#f2e!miMnU=9BW5NU#Xc21 at 0}%s%(LUOVJA}qB{O68kBQ|H_od?md>G7U
zEDEWSCs}mg1Y4BwfBE^YuO!DxOC4hTolU!d1jZjl5#2zVYXRdox+H^JkZmtCwT4$Y
z&{)HD;zYO%oZPt$x0vcxe3v67Dzsk}k{0Pl`kpzGl~XNReV7Y~($NOic5OBi{2S+$
z at QCy7aKODia1Gs3YStfrXjM5Va)&#&lz|KxaB_4-uJ<)gDaMpUVPeI3d}O54Y*0kp
zlNmFfnZCvDaMD!kdLLz_`-S`2>&jvkWcdqnSU0sbYi~w&`JHx_jJbU)sB$r%86I0A
z&~Hrp1XHA*Rxxq<2J9%%W*`96c99>qz|em$Q$I;h2}uLFs at +JI*QS>}MnDCRFNvDx
zi6NR5rFsB|%f5tT>lE6c at TzBmxfG8M7!aO~*y#o>M{rzA>(MxgNP~0{x~EKNrtCRf
z8FuwcXqCC$)KSOF0BZNS*3e6koO)lEL&0y=N4`jD_a=O1nG_i*32ooX{nZ&c;pK<{
z;s2)4G5_jrH-NTNM&<40Ji~|a9 at f2&NA02L<1Y~8#8%#bA-_KQri3nv(a7svF%Zq!
zK4%u%KzldBGLjPwD2d~AZj#(dn{p+et+}J7FpW;lIN$44B%BX92u5(8tZciYypvjw
zpV$zb$e+i-KV=YKi@!-3;KO!YLDm!(?6e3n<$8#DAn6v=`yyV&3uI+M%$+`J$YT41
zUCijFwh__EM^d6^{WUEM^K+hE&UEa`kxjXut>4e29s1|2*65bi%bi|duC#Ym+Wza@
zL<(pqk>B`4TI_4|!PeO8d)&h at o%Q+bB9ur^O^wWrShRQuqr1Ld(RzjH(`6(Z1^b->
zho}xYgn_mHA~1+YGurfAEg{}oOQihQ%zhg;%5>)&qPfDi1{p^%>aA^=A0w4Ex8qsE
ze>o+|V)1G;A9+8a<Uk~r<yAo%Cum at _I&zIz=;wls*lxgv3<=qY=z<y1`%ISxDQQ{C
z4Rt9_`xOZS at wkc69Qx8IDX?O;-o%pN7ftGBGKWB*O;;<+6MG!DVUT&^MHXWYg00uo
zb{B7-V35{CS5t`QKi7dVMVx$}aUsGvkrvfG73{r#I<bTCOD|QpxheI~)w7lMa+bfw
ze12L>aYV#ERhI*jzcbDa;IgTPeA*#TY6ao?!Haz&Zig-&ePM|A3W}xPkZN|IL({Zx
zTQ+d4Dbg2%eOKl^M9KQtRRTEX6&oSnGi&HyOx->>tUf?3iB2lWU8uQ34B at r0Tiw;c
zZ0evEI_mj at 5y86ajPTEFm^+syNfGS#L?yhQaB_65!`zxY0 at LJa^^Sckx6(>25*PdE
z!p?}jq#%Vx-zJ9q#Ab_&Kc;0OIuW!v5`W4dzaBlX#X$(WqWqa6RYol_SMwCot*BQs
zNC|MG>7B7Qq_*q)m6cxw2=MvSaPAFUanQ&jT{}U~ItNhSCOH2}fO?*Rw0#!Mb60PN
z7CY}q4c-c#DI);WP`&-d2be7|amG5vj{|H>mmnWxjF?1hU2j?VEYiPiseZ#}MvX?|
ziU- at HPB7piV~a)US{G{;h=9K4dK&}l3ISe>bnZ^0ATGR}`DthSj)P@`(mi`y221al
zrkO0#<C)+Ic?nB973=YvaBOvLT>QGPYrgW=ynXBTL)4La_+g&Mf!RvgB-;+lWtks#
zh&(d#JN;Hh<C@=>s*;l8saS$}hSqs(WG^-6_I!B~L(1WsJ8azR^HB at D%L>QvmlVq1
zS@!JpoRt|K<-Ep6uEuz}{YPmB*!vt6*`PaA>Sl!>v*lxpUqCjfi4Wa${Q0|DW63m_
zT9k^v&)n}09lygnRYsELlDxshbaza&Og|a;t(o~|GmeNkR<uKl_vLZIvGG)bj*pj^
zP6{-^R+~4)5sT8pz{jRcZo?~5I8!!qu#xZy<ah_gyD!=jhD6;>`-Kx)V`;+kqL=b^
zd(05?^qyAN57P-#6d@=C$V&@}v~4?y^t25<Wwv*iZ^NY)ORG%j_kSxH*oj)qu~Ob^
zS2m9dXerB!J5wXd4g))VlWO(~!r#TeC*P3S>Gk>S$Y7>?OR=B+To!SmX`8v1gX=n1
zIVLR~ZY_eP%#7E9;y?viSp>n0mJG!XPt9kmJ0C(A6 at dqSbQmVTae~3lx@@XDkF8>X
zJ`XH*9eyzc)ElEjh%>Y}>8+JieD`$w1g{?2h&sDE`loNr(S5?5XquUK=@iW7E!k&>
z3-%yW|1!aPbCD)h8zqt<A?K?|=z7!X?2)DrrvAtY!3k14d_Yjt{yip#wu}py`!pa&
z6BBlJM>-}|Blq=06X<xl3R4$;3XDdX4>(iqdVUM{D|T--7K!1^ylGLl9E9x{Y$;z_
zzeae8p3U>kh(+JyU(%?lwfHAKIs+p1Gw!bZzf&kDIhuI~3zwGHz(BU8m?;G5YwN(Z
zhq`MroReBM^G8#_(Ve3yg0Z%T+^C;2B(%SPG>S9*4(r&2=HaO@@Jd!QayQ;dhj|l-
zGdH^6 at mn+2{DC>#zXDt3Wl8bJ^ueqgP$J?ec#@t_%(_oq5A;D$UG*s+IRMsllp%C_
zwJZwrE860_ZC3p at GX7TkQZ&ErcBcP|wzXIX%qL>k<$WF!&R;rK9Y!*+)((VsGn%CQ
z%axyz*dGWNh|Vn`PbXy`2){hd85BXnTiuQq>CXNrNZWUpQ7G9j at x0Z<^jl2$rWITh
z32FBJbjdzJB++nrdvUzgaNk at NJRB7i%C4_XaePIK#zQj|7qBU6mm69*qxQ#Igj;kF
z+omV`9Sd=L6%V_SzRFLWB_mt_L at 8udbftXBpAg<2U+niKa7x8CF|Sn;Lv4GJXG1xI
z5G#|_frUcqH at tb~-Hi@;*WmV3NQ8A6>xR5cm3H8!AXi6_#P%#z^+hOJo%K*7HDNFH
zpIavi#APFjTZY7<*)k<dkh=oAiuqkKL1Hc2eh%sbwHFEs*r`WV_cZDuxu038bNpZP
z_I1MbAh?h`WymfbIB7AkF4%o^x(By3{~N6xv`r<?%;X4Njh?;5zZB%2Y!pEz%WwmV
zjG1sbPQnFZr)#{Y%p>C0JYwbZyo{&H+O$jbCV4YY->51$KtzbO{q%Dht44syYhZ4i
z`#K2X0!e?S`IT_Zp at mXrihL_ulPCVSkZ^$;@uO+{4 at IviW+5K$H>2^}s2&?p{3QCu
z`||(kAE-Cza2*j5qbuz^ArB9tgZ=Z3Z-^28qF<WFgZ;aosVN!lw6Zp_JaF7~5y5|N
zMwR*C;pqKxaO$TK+|9EJklM-<P~K8V%oYg0u9~F1<TuK0qgqKMp?JyrM8Ycj!gW+&
zlvua*P$|{Ok{HIIgb*Gi!6<weiFYh++7yFC?8Zxb=%B-^*W}(?rm{mFE2(l_V<lc_
zItd{(a$P+eL}fy+nSK^3zHrB9K+K*EM56KzglIHpw`LgiW1XQ?KO<sCmo^#pbC^UU
zPS+X9+735$wc)R`r|S$WylIn9N_!c-q?H*6#E9D|NG_5ACfO={LO$;X?^kh%47IOH
zRHi73-)K4pNy)EpK&52PMr_|McQHIJsc^!P=)KgUY6MIgYn^_VeK_T$3Au*IbY#)*
zVGi5tBDmeP)T{kI-FcdVWOCT>!8%xK8>zM<u$_*o{aloLbg`{toHY2qd6fahd5i?D
z8}B}~<=DLSo*3*f*3SpJzN{@^XdOyYdx|4Z{U^JSeA=DQ^(lCW5e(Kffa5$|%P35W
zGXSN{TWO>|2TI13YVqF*(8-Ls;q|X9)jn^|hr6Q9QL>pFu!TVjO)uPaDeA;VGGK++
zK?Ean=40G7eeCGDP637H4$El+_E}x8GV at H6^lnB|F|SdDx7*#)ib93QO?<jjRP>5X
z>`v#mZp`vO9zCfEtNlK(5)BxK$Eg(xe#F%<)Nd8MHj5w8V3`FQUvsQ}d at aQ+77TZ@
zokx?QFe*x;+8SY(o7E%n#!FBeup~SypAV>|_?Gc1=!A*=rruwF=GVn6=A!jWzqK>*
z at hx6`n?x0iL*%~Mi`h)$7qufW#-yKipA-y~2C9lb1nDX`V7Hr{%-F=XmA#k3uS4;x
zE5)<Xz@~+)Ne^u=Ut>728oDt+XB)QhskVRrgW<Wz`u7{dyGP`kKnLxw!`JXfPSnwM
zjwn!lM3awG$)-Pqw=l9Z1ww3GZ1QF*uDFSDjYW9cey468&omC<w+V!WKF+N4&6}~R
ztD3qUi+2Fi1UvM{YzB<wm!}iaUPzvKF8~8O{-8JCf4OY1^4D|8_qRv7MDhtnUutzK
zeRwkbS^|$H0DjnHDBbH%Nscuo*ejZ!ByPWi(B;r-#lkd|v}ycL%47T!2WKYGLBQs^
zMmw0jm)FK|t(tiQPPQg%n=GrmyXxrXiVWrj(e7MS3z8^4oMP-=(#*4GdE)j_C$~p$
zb$eb6zmW3 at 0>@Q&m-wRFGu}(3G-fpDk9N)SCA5A9u&sDtCUgE&e}B1<@|m3mZne7W
z<=u%uQxM;nQM->QMs at ev{G=e_dzTHT`s{agVo at pyYB8TaV3&J5TO42DoO9<j>U#-M
zC!@c?&o<T{bHo7C2~@m at pU}CH2G^vJ at X0rD77T}<^u#K!j2 at iED$_r5f>kUO%m2#r
zb}u!3QYEqZTBg2Kaehr`HUj7{#O$hs*Dl909iD`6wKDc<`j8tXihPO%foGk-Z#kw9
zz(Qf`Zy_QI#sXhGE!ewc|Kmk<Vurw7b~T*khoW~)Z_vD3JAi95ik|5(izh{*QEBc>
z;=!Dsx%GYGexVUW5}S<FJFXmS&igYv-=eg1TT<1trB^aJKh8B7J_j6~2jl2-C{sd^
zHqpealA~J2?vk!i`U#jXT=PSzz~NAU?1)Wu?&}U$At%*RY3^*_{?he*v=`rD8Dd)n
z3WB*Fzr&T|1di25!{Wb~rD+#=e`d^oeMINjRk#ONGR<P&7L*Whw#`}h)kNt}FRW_L
zkW+TuMQ;mn9r9#FNqu$nKgRS*Ou^Typ(ABoB9=^#zn<vUk^X5=%aB{{n)PTjzsq;`
zhNPQ99mhzL6C27R>rd<NoBQcfg&!jFq_U&M0<g?C1Rhs}vNtQ$EBuJ%`NJma4S>K?
zs)W%2mwU@!@5ArI6)ic7_xPkIUBc}$ytki{q3Jn~tck!~i>R`27C#9D*k^OgR58av
zC7YjyY*O-v_KA5ER-BC;KvsJj{C}uLjQN$jzcYJD1jjkdAoh-*#at8+GJk{XRW=|5
z3d#-lRNk at Sz;S3mt_F>==%>1Yfh*Xtt)SDGVcNI?1KEPF(Z)kRk`PRj5NlQVXi+n(
z`M9<8u8g_I9cU#a^I9kqNO(!5>5<h?zwPqgLacT31WA(FXKhpJnpw9B=UzT>nD{>N
z++;_MyOZIpW?K>E^SPH}X)E`4=#U)VBm+G4E6r``TOq|9SlnlkN=;qPI3h#9{j)_y
zhPDZYa^QeRY1d!HlOCy7ohyCIq<4<7-YD&~x2~ut9eZF-ko>k{6t-Rn!zjivG%#an
z&1QHMh8uL>KhY=y8fTp`Km?}f;@|(CZ`4*;cD$Xhfn^WvaS`&Z7LwL#{efGdOYcIS
zuo{4!x7kyNK_OEX-#Ql(N1ac;{1#Pzf^Z1V78=B2G`Isx-{HaS>-Bx<&sJc8QWYJ^
zLf?1O1yVhSkl>LF7;&Pwt(!QIDp$<-Sl{wT!3_r%_xIoOqW`;AH{i>@hElUUlav5_
zPxyDmuT*rCH+#gUv(?nXj}tL2leI{}TA2k~JLtf+1Sx$AIsYe(jwS6Ze|NTXm`=eo
z#?U+g{qmpGf6b4Tfi1tb2$@7>_f3ugYVQV!yq^EI&5#*nww<vjW$DCP&zc|l7=C)-
z^}qJ5p#5pTbL%oH)}@RVb}!uAOk}jYn?|d(Fl6G!tLG)`MtL~85|*~3`v$KeQ?D+V
zV*gs^=#jke#nciySO=*0NZxKu_VHpxec3q52%K$AlfwpoY}Y*v+28rNG!B1tq6N|8
z6}bxt>66|FcGsHSVQ(CCivnX+!?PuOVbvSN=8AkDTxvm&{Gh at Bal6n6-&<yY7(Vl2
zKT4>Tp;-9gIrUMvgPR(g4fHu#LReam4f&`z1_haM`9uGPIl@{C?3}eiUGLgbAnfRa
zgrasy=nhE~O*Q?b{v4mo^{GGwlucKSy^w23bJ at t@=BkmRv(Z**TJ<LuRycRZm2b(<
z@%`!>E)qb*g7qcE>mSDIh~P(Ukv{de-qALnijHqw<esu;*P=Bo3!4_B&Q>Svasha9
z7h1^gJIB>vOCz220}$Bh_*!97C+LOO3$22X<w*GuO1QW<0#oMwm35fUU<^4;V-O%1
zLr&BmdG|-u;W)g4n&;vTwGh`;K}G(Ci-`lkG(d!n991_QYOLGtK{y(N^gu&>jdy!s
z=nbt6O at Db-7qscLDQKB-#a06Swa<2?Dl&uIQR{C_8*2E~XX-PHE5Wi6&`N_F-))z?
zDdK at SEberTxhNffIKHV8*V-H*yh49a#2g*0a;11V)dBN<RC3LJ+|Gv1Rjag~$Vv$H
z&<j9Pd7WPiq`ep$KkA;y9zJIu<cn4QU82BKx_-sWI#ZWW5y-aAqWz0M=;<NtU6zGu
zOlwaD>I+N?(jN<ikX;=?56dm3%;@R9nrHO$mR{;@Y&lw=7t~aoYuXagO?iAmAp3wE
z$b8P^>r_4+gfh>u6>Q>t$>nYHu46cbKJ9bZSqrDN8jw=cGj5aNCvIv|#hrl6S5%<|
zbdqkWU9b9F#mb{v3WI_O$LjD}+z+GNEKW3P=T4&6sd)**C47 at t*u7QfvALN$i3u at n
zP<L#tq8qL}f5vS$+vzVCjCaIplcGEL+GYBwxKLb1kN75J!1)>5-W(F(Ku_(!m%^tR
zL5H9LoL&u2-EdG`I7!DZ^=vHfouAXm?|c@;pb7*<o$FnGzO3VhK++Vc#ntF^w_*ul
z*)1n$YIDaq)_tcw$jIlYybzJ5Ev()emu_l)0h-y>ZG>~AQS#pNdH at uVr7W7{o0jg^
zcb+`lXWI3R>cH&jD3TQ4bg}=f944?{?KT!{^VRduVR;8=D^NY?WrNI|)fOAaAs3)V
zYnA2$Zcgx at M2Burvbtpz?yWK6V5bXw+0xxRy`R9ow_K*M5bXZpLZ at J*=>}=fcBNOg
z2zoBAeRzyLQEg-wHH~YD1$Uxd8y(P+16)4rz6$VV;9E at BN+~R!0<3d*lM9yv_Hc+@
zs+jlc6pc!tX+qPz6tKhNQ-tp$ZT%tjZVT6(@;6hwck`Yqk9@)VrU6lhw718<0^xyh
zmKBMuW5FBMXf45{B3U+ at Z(Sp`I!Kq9=%jf<tmy`^bEr!`^b#&EhrNmox{ql*zFn=7
zk#0f#T?>jgVPnCxSHt-n6V>@G`WxaHJU3cyv3yR!!{N+pG1E6);y28Ct>fX>Xz#4q
z5Q|P9T at ixRdUcce?6MUDZtljm6k#JlO(K8Y4<y(Rr_U;Ft``dg<j&I`DPO+%*QE>t
za3YZhz>iqQ*&_XH6ZFqG*&z$g38l%3zvg!TwD|#M at xEO0zfp?UPFkq8NGma$d9~=H
znHE7MO at jLDiQHR(csEOz*8;yqgHD2{$}WV0D22Z~4pwzC=|+ at B<`2n8zDKB0qU%B%
z4%MwLpRs7m12lbQQ-6z+sw3I-)V at tt|GBS<J8<xZGmOzuD^!D>R|Wlh&Wi{BK3?lP
zOSjjG-LZmLf1&Gk>sj}dDQUQSZ;H7!6iVXO=>rPccV<6Kr`B8a at 3d>#OVH86TFR!V
zt;<gxuYAlR`|<0~i=*?S*%YPs?V>OByd#DxH2$vV8dV&yy!Q>;yyW+cpB6zIzQ?&&
z5^RQ&y&dUKZZvV_Zi4BDQ~7UwthH8^_^Q2ChF+wyiKOYQI4Px5i$f<NtS=B);N$Z(
z3VJzaG~!p3KkFy(flst}_xZJqJMhB|j+T^%c^s5EDdAy?BY|SF6vJ6}iI1~F+znsU
zv`6jx3AoIkY`M+ng&lBI7m<~)u}$>M-K*4A-Tr&6GDEn-#`W(Yj8|<mMhOg%73ZW1
zb(i7`J1l_2-1pFRni*dr_)F1Yk;6sdP(rIF6SFxY1YzCXAyGmqyTDbylH#BW_gQF5
z9&9(a?81e6&VvzR$V|ZB#fKsCvE2<f at +coWj5b)4Q!b+AO-Nz<itv7 at n^Gh)hLcO;
z%3H$P{rzU=w)o+A{yfd}H!3AeY&GYqc<GrXiA59+05z2Cv6RG2`f~<^+37C)C<;2;
zcalgxtLr6<&Bvnc#wvYSa+ZN)ANo;eAWtS+l}?^lL-_D~@IC42>~$#NUG>Z{rgcm?
z!jIWAd<ECx at cs=H6a_Wyx_?QTzHk`;bcB2NL;j(qL{GL<;KLwqEVPHWT*LO*U!}a?
zy`$wG|7`8GUjsJ9Ksch^67pl7A^7b>NNLIk4N+migqttMhg{nc0tW98D0uYM_tP7o
z>-^WzXPkbd^6H<{cigLNd$O~ifETuTlxc66ywx-q<pghs00c8%bULolk5|<Z9Vx^`
zmEgG|kf~}vnW`$CZXedDU?XUH6@~ile}6}no;D~<m}Y1deB$r%JYK)TRipfTdjE;_
zFR at Xy;e1 at lK4Vfc==+_17M<=-67%yq9{4Z~-v2!VBwfOol7I&{rds?OymaG}7zAQ0
zbg1I$zS2cIE&0I~Z+&O5euCE)L)Blw;@MjelrmMgz$;tdXI47I?n9n~v^$7ycP%^0
zZl12vknZiJ`3F_kYx<WZE^L+BO;5Y!B`hC?kUNrIlE$q2i1foQ0<y!bkRX;5fx3m5
zv8Y0vqANF*Hq`hOY(j#+8Ni#mDTDm`6RK*lY~`JKJ-pap?1)6iwp;v~KldBg at dWGz
z=errsVrt%u!VggJ#O|-<*&i~Z+QO4<S3Nx%q_wWr8WyfH)w_j~?Z2juZSz!W1Z}Sh
zLOhavxW@{sZqEp3y(q$Ovlu*34lO^Khf9%zJ9C|73Z47S4;q!L=gwa(70uLy<#evp
zx%vsk@&S^sn+e at R)_<8!7FU at VzGCljgr3#`#m`Z|Kx=xQ!Jc6jQGCl(I-#Q+cdG<r
zlV+7dRE5y^ElGqRi3q87x^Y-9Dw5TZ at lr@5BkH}ss<YFZbT#%R^TZCX7~WEQWV?>&
zz3jpEn85P8JyFEfYL|}WzL*fY4fBa~mcPzEnmUS^Ui>z2YQ4^cG44LmT<lgZB at 7dG
zvfrO-p4&B8-$q)-_h6?pf!YH_I##o=0(zrLlNG!TiVP?kPZ-F4l)j^CVsi at XXn7Ux
zR_!B=*PZ<?Hou1HLhq5O*>gp)W2fzxm+6o at Ih-wzfDMbdQ)6K{eiotM2;{~GtcXVa
z)cxJ3_gf6(K-Dl><dXO{bISXAhD=KpG6`F1vqJYDT_2VeMrCoWRJn-h$>(nlS&{?&
zx2CnRtvdtm1U-r^p%!0%t=(-*MP2@(E>B_O8K5q=usVQi=N at Gh_acLPjPtZYUqfJ=
zluzNw#Xql0`SeU<G`7=!*ODGg>|53T+eX7zIM?SI$GQ<~RmPy>H43saF^Ccpd4AG+
zQ^`xFu~~P{fw(~IJv2wpoMepCX?eQ^SoVwA-+)IXV9~OzV;eYb at AI73caKZ_FqzZB
zCT7vyZ5JBfK$fBG at l`RL5285W&Y09Z<|oXxV8fh|9P;8ma(Nj29}k#6ky`9PDe<nL
zeI)-Rkprb_nEpUx_CKK1f~9QcSW4JWJrYFHZ0r84^FwT?@E0AyHXC7Yy-P-tHUHF{
zm5&EWw+Lqgc~_DA^C8cZ{N9cf at Y{+fxdByjYj9PSCC8)|D&&v>VFXA(Nz3vXZsz^h
zV0+S6oOMf7!#}5nCsr-|1-Y}Sl3q&?MC4x835v5Pf65f!gFOeYawZ?YxGb*!#7EXF
z;eOGm0Otl7C#@z}+v|iaQYUqHg$|UXu<WTiyTkYCu}VHEt)P|%YH^Yk;L at b8b;;dT
z(Ge3)#9q)RAFl%6>IscA%zpFXJ|b-@;f}4y3$;IYJZW3LQ`f)>XOg2Qs at cFbdkhEn
z&UzTh>LCF|_VAE$vme{H@%ZB_AO_wBeZ7yr&&cEW(Fj(#y|3lcC`=#{dT7b{vmG<N
za;?)vMT+SoFGrHqL((iKf*+9LU`>?9+Jt^Z>m{gp?v+FBugZh96l}R*hFSX#RQ$cI
zMo*X8a^a_+hLQNV*k^^5KW%@!>kYzU7+7{_{!l&~EpR>$8QbWmf>%{oaMibvzaz9)
z>!mv1D+G2Yj=s4M!lj8nDTgJ9Nb+31>}IoQrRH88G0dSlTb#2oIb)H3du!YH3UCXO
ztZqC*a at u<NCl}|ya0C$FYczGNZ`F#)b%YP)WlmRAahduXmp~T~^qLKKuXtJ&P)CCF
z4w~}4qVDTbJjFGoSDf!UuK6GP1JoBw6?7-r;3DH~^$rj(M}6?gGmy6BRz;VYUKyTJ
zRX5wU56)6>^Jm;Gd4BFcj5>I>&TQthzYv-eUBDKemK at RCIM}9QHa7G!>VC=1_c-nX
zpOEK%ky6*Q)lHDKB6M8%*4x5)@gn>F*_E at b;^E>+cQ(*$yqHS+>wNzb$Ki!V<fpg_
z4Y-$uNJyxUV6bwPf}zs?DBgU33SWw#F6l%XLFG9suhA{@TgnKN44r6U-PytkwT0|X
z<ogjd&sTX!br)2?Y;{S3AYippzwBz^_4&XoF+$qthdPbSsRA}RFkj~LQAk~={&>X-
z8w}EVhkc694O;Q1*I&7Jf1-b#cQR9(_HQQG$?GcKc<9W`nG-7{xWq19uw)YyXgs`R
zRV{-er9v_U;zS+FOM$Ixdb4p9WBx7PK&^@zX3i`hMo{fy#*~+26RLcPWfnPt3Z<xp
zUT$;d?bf1|m*^(3C9_P|NZE~CMOSA0m@|#1_ppu!Xqaow*)c&<?<@*l1Cke9S-&P3
zq9dJ`y{?t<Wpo52ySGkS`o8{YK`>wW5s0|5xx`HmNV+3o!IIDW$%djs&uddSE{D*}
z+4I|f at MH<U+1fk*D8OgxXin1oVS)WE0Z9frc7o_AU%n>^zWIS8nn!nuur}S<D^JOm
zxi3&5b&||UJbgu at _^A6H`m})Kq|i?s?ggW^dcKB40?cQ+<PY8{S|%rjLy&iy=CZ}`
z>xCi?m37L+?&czc&1}w<YaB%ZE{kzftCnQW`q7mM(irmw(#bx$JD}9 at NcNjWF5_Pb
zzo|g|Ni2LdjAl1O<6}3~8Mge~1By(4yGw-^u81APef(^CVJlyU<^_1;lG_Mo at dby}
zvf7ZJw=$9o?e>bf?8G3R^axMPmLZ&WHgU*8<V%DLQ$;tW``TG5;MTnQu7+|dZmgsO
z!A!)6UyDwACG1Gebb$B0^55)_;g_F$o8acNvZ)=UN_c(m at 9>E0D(dnua(aZ1M~D3d
zkM8(K^iyV^b9-uRVH$4bfyR at W9L61P`Lz?S?uFco=ibbL58S0aM8MAMl0DyEftH=P
zcdb6JZeOU-5Y&s5y%oCwLk839f03Na^hQbn%AF at q9ItC*`u3v{?#h1vnN}OlXkpYc
z at B7UfH-9sDn*)Gwb80$5;7_eH%?L7?n%P-zD${mI3i1Q}di4n^d!HB&c$E*rHY&Ws
zE9XBaghrwR6|AGt;NAz*?=!Tc5*NJOB=rLqHo#75{4QCoZK~txMe#shxw6`>#QiuK
zEvOO4aBrPSlgcEDk>xK9fCKvVEHo-?(DU!58Lsrz>D(tU&P8>=O{ai21X?i`nv;Pu
zPm`43XTell;|dU|>YyHwDIWye%<pG^R`;mRJD>l+zelU48zVK=yZ2efTWPpZdgc)O
z<VQt`LW2Zb)}z^?YI at uAYJ6k>-Z9RMvtUJWiOoVUz2`ZK<h4j8*XaQD5UvTEp;bfF
zE`tb;9fGXiU^UJUu4I3?4!E#EixXCps%@F?9eZB__g8!!WfER5uVhvRBwrw6bP3Wa
zy=RBh)}LRyC`XD5k(twa%7>xiOL(aNe5g0^k-w-+U-j|#xHNDM^)(L$qh#}KlCg;%
znp$XO`bgNvcOwH5>*nc$r5<kIOPr{+HSUe#0RGJT#(ItQ-cf!-927~WF)$$>u&G=e
z%hIFz+$4N1!%JbfO#1#C4E&rRy26&{M*~Dc+O)eLf{Rk6z9MB#hZ4-;I>q7W{&9f4
zGp!R|H$*nBiGOd7VPXdBkloCgrsXh`P}jLcQwbujuxKvs6Y*T)<%^Mbbw6&~Kp6<F
zYVa9B)g`e*owR%B@&VQHRmr||qBUq)SfcxK=ebDg0IY8L<h}r=<Dr^?4R;B`{g*=L
ziA~(ipahjyKX8?J$M#E>6+DN{O`|W;6rVAX&+2v0MHtInr6i6J3tiPq?9rV}D+8>h
zK`-U{47>oj`O-?+iSSJ78thvIU*C*-c+ at iwwW@$Ntlx&fA;Jgi2N-E<-BKp+ddeen
zbl7J$gWiI!|Gjf%kmnhddb&~UoVAy$<<Bk=i at N0wD~zcZwPY7QLw at meO({z=ABT4N
zDULO5q at 0r8Gb@Jk_|cSXW6QU|3l3q+57Uyx5?B3d*pv$EbkEW*G3i%o+<3804zSP6
zZT at O>JZ+ldMrW?_hj0)>9N at 39;^0!fzj9OaK(aIRMeB|j5(vD{?@>0H(@{Xz#XNt;
zh9YzT=?mL3fkAf?D8mf0kO8SkTvejg@=Nh5USbT|a7SQ9Zu_mwmiC&8x8*kV(JiJm
zsKeIk;l*r=uR$a{vQR-xO3nJ|_m{E13-70q{xdTos#zEz^eVVVZw;O?0)IddmNENu
z?;(Lg=+;?a=G1NHScz{pqOH5p`)jJaKTk at ITd%?vz#MC77gXNGtZroFGtvhSdjC6!
zSrBvZ$Gtb{Z4os-?U?`xYm0tEgM(+?hpTcZ{-wzW1(PzSC%Kk$YU2|F{M--Hjkw+K
zDJnTN!=XuC+EMkt(izBEdma39K=SKbKPWuxdO%T0B&@L!JEiN$JM<-O3^hn&eYN|M
zZe*(*s1XaaWUet-+<DwexU5g9S*P~zeBM=A1DeVR*EsTXp7kZTgMgll?692^OYc*e
z>GfH7NfhD~v!K0q*XkWz=w4sbj%R;6h+RC7Iaj=hyh~JzZRjayHd&+$awpHEIC@>~
zv$13UZbvTZp}oxk5LWWt(}ATEbccBlt=qu at +vs=gd<vab;=Qt3PLy-!$ARx~C31q2
z5^yx2dqZ3(qAkU*osi9FYXb$u5}7<_2o4rIH7?m~<CAR()iUT!h}fm8T-yS2Qh&#)
zEvCvzef(j+76`WS&n8dOY5?k+@#J<bp|8*I!t2dZ2de1Q68)Sx4f+%WM9UYTY_M*e
zO4r<$JWW390heSJ81=k`PMX}crnHvRjIfK&-rkF(c;Uv=pbh(M;MAGDI3|XquWp#X
zourkC^c at La6bBY*oGecX1CEJX+F(y>ZY}k5%iXaFIZL<`n=1fs&-%s3;67Ib)^K&W
zJkuLtF$-7fk;23720hi&ZXA2pf`7=F4D5bxnz3lx(JP!x7f%z&k`UUxx})i%*Y7(*
zvhR1E*iSq#vU&^-x6-r%nW?Jwi6dbXFqut&pCg~?bE<nk#KNm(j1PQPdtM4r>de at E
zmFa?CZ>R at dc-|A`r1e=tk}`+BGD#MN+^w}zqwdABZ{yw7s1a at 0@l1e~3-j$74BR7I
zqbEr*Q`gjAI@|E0o62b`0KPqmt7E%F-Py2E-%RMUx%f1E0)wt9yv at l45KBz&>do)x
zfK&#^<w|{6Uf5{EzWzYLV*tQ<XdQ5Lv2|{}z9!)v9Cln#IT~v4tz%sn>9(@u={c!d
z9mQJoSLtSW9>aGt^pX-gxu}h^w<V^m*236QB}hZ2vOuG^SSL?yebh1Ye{z#)MK~GW
zC-oes=&`J{71)%Ndz<b_aD~2&GiaHiEzZ%LDQNc>w6)lt^&^dl4t9tzOKp0hYN&lt
zT^(@-_uR(p6zJ$;o at mBZIG&N65qzbYTGI#Shg`EETb(xg_ZU9P4+q&eJ6yW_-NRT!
zYj~i4JA%Q&edAs5e3Y_(Mv)GyZ8z+HWc@}on{vZJ9zpmpE>dy8^go+hwh=bmfXat8
zmFCYP@>_X`n|5Z%HhG?u?A7e_Rbs9E3lD2}+6f2$H3_zLYc|@0-|jV%=64PuK1`Cl
zg<q>^MM-KO{M|N|d}L9mdG!n}4-uytn?71b2pmgqxFP8-x_{P8Cn86D1f{*h!}0}W
zA4eJx><|?#uY9O{gtOxfbM6vM$dAS^E?S%ho&2}rt3pMqT;iYlwVy7P|7bxOA2fpp
z?e`5^Xkr4?)b9OaYTa{}+e&miUPtSFhDt<XMdqxM-<}=u$&2HXI8P0z_JBUa7dYi7
zRkTkC_L!(5+By}EiJFy8ZEwSzGdt3JCs^$i2i2+J@~nolUIeJxfVK`tn<at6s<*>C
zaSwg>TLi?vWztW0-V`#q?UTnUau6Gp8~QBbPmNTS{Lk97p7b|H9S;2uD3kcL`;f0L
z;F=}@{kkH+IPWXz)f2Tr9op5#?7`PDV|uE&?!%~xKPf80 at ena>aC2;#F+gbj^c|#d
z>&jEa=%O7bCX%cHZNmIBALyO8q|jGnCa(AE4`$nR-YA)vY)9n(MTT~Sy4xrNpj(G}
zO{9k@<;j0z!T*j{F4lYOz7>AWBr=*GS$C;p|DU-`?X+i0A*|$r1XTYad1?+1wqr2~
zT(j+y^j^c)X2!dkPTgZST>K9$)Q3PE7|sL5<5vZ at TvhLAtq%V04{BB}=*lESKwIm<
zQk~pZcb at ux>ra#NqA;bttGq8wYSzBrA!e7MS5Z(0Ff9M|J2GQbKc{3w-G9D4PY;d>
zKvDx{RLyAo1uoPt<@TxQPW<-znDl3EruqIMG)h(Y4fJMt%@BGW at HB@$T2J5^@ue}j
zFFo$_kN^J3XcJxgY0sC!A}^;+5gj7pT<=nXI{#~<7;!KUACUSbOVxEfbhUS-Qn~Fb
z{`<%*mUitX>I)|f5*P=eG<z;|6JD?e at p}Sw-!u?jUWp5ihpJOEHt?F2TyWX`kK!)W
zq>rNU-M!HI$-}Nx&$^_Ac2wy1lQ(l$Ftc~nT!KvKrx`APONPpRi>%n$2cLW6c@(DE
zm)tS#%k1e)!Vtme8NE-(_R^89q#OHn$x%*H;9*ZAoyT!|lb4q3xF6d-oT`Zs5t)4=
zQNa$s8YfL=5HmMO8J-LrPmnETD8u`m;3;OiBlzn@(vi_X13Vp80<Qz)Ly;7MocHHj
zwuZJ;yy<MUuaV4GOCiAGI@*ndZ<wc&>9>sZvOOEN+Z^ecsLkT~x5bC3Htu>9bQPs2
zBl7Tinj}g1Ded1ra3>2g1Y?v8=IBNUo<gxqHrhC3AcM&sny7qk>`t$ij5{)BI=K!}
zy{P0l7s5W7#lHBZ3D5e?lxgdoxs{mr(q at U<umvaPa{wZQlVqT-F9+UDJmGU|nQ44a
znB%z)96Jq8cPsM{T7qZQjOMIF;Zl>Yl*cP+GtKnaY~z$opg~{w|5?HsXIQ24W84&E
zOc~&7`~IHRY2bw;AQf}w{r>%^SaG0lAq(9z1hUYf2HW7+pK1- at SX@V|D(${Hz4i;)
z0PuYbGdxF)8Mg8Bd!E5-w^tzegJG!Y3#%zUMRCiWoTbJ~1XGm97$URO-BQ$>4r?4f
zz#C|SKLDJ3DeW7u4;<{d4|(Lop}oL{7h`fO?M9Q1I3<oYn(3n_sqp?oklwQb*o_y_
z_EmkE300U)Q{+_NRCL}9pj-XDC>S~}B at 0us-6N>3FyQbpxi#RJ3Ku?``0Pfk>7B!u
zb+hmlgSdxLwAgF!eLgCNRx`+xX8SehEPh%Vff_PxiE#%0n%Ct4_3)U+ at 3sveaqK0!
z=z=3T8D|Wh{(|;H#tIsOpI at IF>6qcfU9Z#PZw`;1N at mvO(pb1FZQGk<f)f{OQ~IpB
zST<iJk7laVu1DF?GQc=XEG$bl?Z;U{&?FREUu<z{d~jy*Cq<Pn{!!w9IWbmc at nPI*
zB{vkulP4-9q?b*{;NSkzb8*t2y at Yh_f5P4Rl<x at nq!6<c4Ops~H3ZHA)m&o?hU02(
zemgx~cQAMWdOZ&PXvp)-IsCBll?ZMl at E$fE7NA#}ya^pU0^iwj0=O=OgF-OTOK&e+
zRhL<Aw7sCzWf8-6SH(sH?j~$6#7Kw8vB02i&_xQ`gP>icDa9w3xqA!W2dT*)`#m2J
z3N|A at Dd}NHgYz7y{%yPvl at 4KYfOnL%EUoS at -ksHFMiHy(1Qe;bjy;Y>$XkvsY|<5R
z8q{@}w;J6GJfl|8*GRR64DDc=R4>w=BCdeY9T+)8 at 1{NuDpoW!4o&i8>jvR$rks`c
zZXKDe{Q+6S%iUn>eHaJt&z|vetmQ#YZx+dd58hxsiR*a2gn?iqc<U8Osd%%^Mcn#c
zIg?pvMNetjw1z<C#!s}q#fA^K0oOXfiLf7TP5Z~Y(>l8cb}%u+T^-B#qcVO-p1aPl
z1pOaw0M9isg?4MU)9hOpX0g^DHIm9FFA)eDK6rL64v0&c^%Sl)^Hu4FwQz@$LUwRg
z)Eh($;gxb^bAg8^l620k?m#0TFWX0H3N7Yay=aY=GtW!2piDPYf3wqyr?*GP06FEP
zDB+Gsy6tE}dIinW2~|K#$|Cb+>pE-0zI#2}ohLOvsaSdR3&cG%vhmFJ4d^Rf8}*XV
z!B3Nx-0;d47M%o_9w%i?+-~Xwm=+#X|7y=tUOlhp<w|tgcUo`*_MjXglLCWi9_5L1
zKSa5jJ9~XoDz6YI2}>pVh_(qmQ#H7f8W_Z&8Y{0hCO2^OB|l%ae}nKYh|6qH`QUvC
z98Rt8xM>dVD*nJTVH)=yciX`r&t=|xQxVtAGzmW at m2|54k_5u7NXKvcXt&nmvMfWf
zygU6R-G#tm4EpH~+2zn8ekVCrWH$`<ZEsozC{2;y5HRsn%9QU7a^V~iD&X?YCmmt_
z)n*Ty=VeKZnhcf9;h=O;!z~VfuZ1b};On{F9?v`8c_Ivwei<T8hLS*x?Utp2Pc?@z
z!@%%!>f+Wn(ajw1CF*8O)XMFKZzPK2 at Yc4zxw*DpvQ&?eLXsGlk<H`8v0RnmsU~|t
zWg$nAXynt%`RVBQZNFGUv4-Ayeih2Tq1O5VB`<!mezV?iv4z^H>~*Rs<H_sxf~amW
zJZMTucZd^RV5oG=Px}>9W020ewMpgUQvB=5<Dl@~5<!as-JN^r1ZV$X2H#+0`9AJR
zBC0;^_S+<Z?WP%P`~@8{KHGyNaXBA>_gk at 7saBoV_(_hGjF1~zOxIJ-0CDDCUPx&g
zS<S$8h_#n*wbN4!40@(Z2bSEv9ck62lB!3>D6 at A&KIL;)>23NIyKI-7y+tn at 8wiAG
z%a+<6q4iEdrA(&P<Kvy78JUimkaTB(>y>4j=e at 2(i;WAWc`1<{YC#-09By7=>nM;D
zC&@?Qz)zd>b;h~PdX@!cx<m~hq=4FPDbP<LlVWy3+fHxKc>+Az8Q#FxWf6$)tC8Hb
z&I_Rfil#u{Zl0q`;3{Hb4qK*=u>rT-QJ=7&;ESwrS*eaPxKauL6J(jT9W*N-TeRYo
zAI5Enti}p&#TBRU%9Z?r`U2IZPuzZM0nxHqIL8;SFd at Bi>wBz6;f~-54tj+OE9;XA
z&b4T!1AZTYq<y(CfNhtS9Au>Uj~7|f%Ln2|3{oZ{7)&n!2<wjH&Q<{```T<#zi<CI
zx*CnX3NYkiy64`)4X_FHZX0lF<*T&fFl)Hxj#?-A&QdmIZgR&AUrtZI8!i^)XPtzb
zT*1~9?59v~SC~H7hKEF0f;-FilRoBKdmbpz>UpZSOl5~-Uaypl>FcM4GQfF$Mbk(0
zbqX;F_>;x4kMVvh${|tKun&MHjaP0SAjuB*qVe9-u!`MD#Xq?IEx3DRH8^YX^Ziti
z at SZR&Et>B!KF4jFTT3s5h9|?%*?@U1NbpDA+Ng7K`f(v;lZ0wl{kHG-y<;q#41gZN
zPzsZFca;&Px~Q<Kbd at JS!ti`T{0SS=0qVv^<2Ym_)e3S85~4c*<~&V at d*{7J3GwSD
znLcgYx{~B5Ipm<O62d0!?n9Oh2c5a-O^X`#t!Q-NrRoM at Mv~KK5?K}SryQbg$s4}0
zN at 4ce?UDmFLmu0rq;#Gh&#dcFq6e`<qzYn>EM1%-Spr)phVAWsWG|EL+C2>~gseA$
z$WX&FICp$Ts&m&w@)u%ecrnb9KYwJpe!0B`<zI7;^)ZW=7o*wUwfBh(wMxx@@h(Mx
zGbaG3(1P{o?o|OTg8Gk+17YFM-RCJo@|++7maXpZJ-LLFQ7S;NwjFYqsxu$yBLK1o
z&;E@|%GXb`r5v^Q$_zV#S)7od at 9U&zu$0ace(+D3J(rSLpl{JEj_>?T-#x0RN5jDf
z3<TDzzOmd+Evkn0MhX_4W={?e!0Hp!Dog$tciZS_=QmFERk5eFWUppz^<8mojONl&
zFyi%+dZ4};X8HNa{X#kaD)Qs}SrUum!VB?Dvfr4peG34N4(w)f>JXFQTsbiYnN3@?
zXI=06B0l!U4vB!h(qJI1kYuM9x~nWUr^?H8*8cBL05$r$FZoGN3PxiRzFVyeb`?C#
zR0x6q2iba)g5m%@tF at 5k*wT|D+;XIPVQY%z9IMneuppsMk3|hr%5g-?doFz&khSU}
z)GFnT7p(#6YS3?ddj`A8=8Ea&^r{0;tzD}3F*w!B$oc_yRG{!PCi4!_Pv(1S4`g~3
z#o3!z9WJHd at Z)HUmv4i5iB48nAjkf%kr-johsY-dzdE~0ix+~kqolqkfvK1w=~Y~9
zAURU$z-i#zZAFCZl<LQ_{SbWH;o9m^-u3dC51*__8q`K!eN1B?s<;#b;N=9WSFaTh
z_RG%q$CN~NcL?c;XDuXb6F?fRm1Eq$%Wx)>p8R-y@=TE<|FIm4rP{4}y?b!w2Ndh*
zJY?Ij6}_@<^U#6GUa^KaoEIi<LxIKK&f3pX6j>MVF=i5$079FrBI4|vHTSK~J$odF
zc()sLhH$rmj-GZd2>~UcW-}T=AWz|~lQ2D59}=dGeCP8QkTXo7^Nta62w5Hnq&ixV
zI!!;T9H$sp6<}<o+CFe8IcMK~wH&k}QW8zeD^{bb#=}~^219R{Bv1y at XGs${+ST;U
z=&#i|@bC3Kx&Z|Rq*55zfOH;jX!K8|!J);m<09kkweRQ|*?{n*-nA;`Pen}~AV{hr
z_lNDACGonZ`oKuC!IfwoI!-|UA0!1HbAg;hX at gc~00$$;ou2yJK^ac}gB=+LGc~#a
z_}f&-U_A`JwE2YCC-SMoTjo8lV+#P at iI2nX?{!qM`4XTk8Y+{;3o?C}5F*2Lr0JaW
zrB!9h_*Ba6QQnNfQVVikxkwHNvxl at aD>Ml1MnDfiav^`Q at _W~SS07KLrGR;tnjv;o
zG)p~6Te#X6H2tKTl7|6vuOF6AG~3j-sPAwyp(g_3!*5CwDbog7O9RpG9Hs4pYBg at 2
z(Sh$ea7I`?Yq!#KhPH4!@z!guRrHhn%9=ID+v6hk1-bpDC~5COKtSZYK)fpqADw_6
zjIYMyx5-m4Z&5WH`NzC=`xG94rPk19PT at Ex3NnWmCVScAo$7WApZ=LumI`|Tx1rZQ
ztXn$J^Vebm2A8{yj5}78{#5-;XF~Z0t}W&6>!H9R<rQn#207qV66vGwE`-3>OMP$+
z*COeJnBugSy3eujE>x;$kGvN}SdOvHr}Q<4=~qL7o>dONc*y9RCJUWnqdr%ojfT}n
z2vp~{d}*%S>63tJh8XkOin74$gUkIN<M!YHiGFYyfJrpO);~+}_}R(nO!Nl=b9wlz
z%vkf^Z?cme*6U!skLw=+v9}+n(qD;ScvrX>rerr5ZQ8ouPp at sBE5cIABeG>*4K=1H
z>sucP8o2p?_s89O^aWOYG-=R}N}p*lHT`m)lCww|JurLN;xMM#=3eX-qe=<d>aHyP
zY%VVe_bxE7REF&x at B}_5+~?W9(vDP&v0~(J!Z`1fs+xu+Lov_3PQ*kCSPNI7G8<j%
zR1OHH3(v|oZ7TQ7ol7lRS<V7i-a7y21ueCg5^xVs$~{g4e<{9jY;z{azS}CNjUNO=
z%;pBF8*2<pPcDX`Y(|D?W|AY94+uT!-aL;S1hwsUmYWkMyO;hy_TD-uuCHqog^=Lx
z+PDVyK;ywJxI=J<;4Tpe78(g|Ay{yC3qcwuxI=K4Zd?M>o&3Ic=GOhbTX*J8)!aYc
zu7Wy!PH#PHuf6xP)_&HIV<I)an~jUucuZP5s-Ll<;$r<^t$IpE at +$C$L>2(+1VJ;k
zo^{t?OCuyA-(?M_@|1CUldmuW&4F6;FnTn~K2bd-vNZOfsj`gxF=Fc>E6ZOm^dnHT
zwztl8&+KriWaByGCPZt%2k;xl8&w3Og4+3Mfn#)5bEby&BOnO=6~=HBfu~6xV{y4(
zGAY4VGvppT=q8TSk-mMFUlto41aMoL2r3EXCMP)bLQ|Y=3!(NPgkHa>`<@t_@)YJk
zNNowofL!xMg5|q!dDoasRPBr%<7(7y2(M21s59hcHP);7a4nj~)Z-Rgqwb at F-!xya
zY(hNj-ZF1(+|3;btmBz}6r#qdB(#_oS at 43G)?kcp$5TI#6<f%#!=y=>U6{SrZS`Jp
znm^m0EfE5uw^UeC0$i5gYI#5_%YmLQNI$1|x*9weyXOH%Q*Ia}5=emWIKv^YYwmN_
zcocov_^Tzi?S)4+`l;9H=fNF3n-H2?>r4rk$Ph_fw;WLg)56MzrQtWGQYd+^R?hBu
zn`bEivLz)~nn<3M>k<is;+mhbfU&65M|V=(iaN&@hW0`q%v(`x_qm|TIyYpe2)EBZ
zJ>^_Qfl735u-x5+f~%YL6 at R4Dwjl5*gcyemd&^zOd)sL?Mr_rRr7D_=qUoO`G5Kw7
zu;vd;VlHoWMvh3vu-(OY&Tqf-d at BnEsG+iXoAXzR>~SJc`aJCF<L<bUFo}8G+xmX+
z$R=zLI*J2nmkPf(xAEg>+yH6rGh)eadG)kVq|9RRD~Rcz=wH-5&3Ti#9zUJ09>c%8
z!=6ZB*{Jp)d`T+VVI*OG1#lyJCLGOeH`Z@`j<UUh4Vn at Ur6wit6Wh_#7X3*rsj{l-
z8F268dzjk{O5>0wU`EDlD%fxY+~~h9P5XKDM$y%86X2qJNqQaD1MQ=O45UF6Mg|^2
zz4kdkyX+1{2>vRrRy;d-8g+w|V-O~Y7*+N<d#+Uiub22i9#N%|HR;)0HO_Zh*<y!T
zp?pk3g!c4gh}k-x|Bj|;I8pblfFluR^`%f=o8XuQ at UG3JV=F%BGV1|A)?rWv*zvfu
zyL)rF at wIl)vFbqBh?M!n*^f$(^Z5kU;ytD1P0n;Ep&{b$zR}P<=xx!4CQhU7LpM<E
z{NpTecUa+e^$wLI^7DPuC<^cgcSa^m+qx48QK+e&p|$5-n8hfXO;cYv=>_wT86Nh9
zq=C~kpRVc5HGP`NNpr~t&dLK<NUs97XI`?a^=$~v^vq1(iWBz|?J2zwn%Wh2wO<61
zUm|A8AEn<x?>Ggr3#ehSCO&)GShfiF4koCA3!q=4JX03UgiuOj;yc#H(<b(ZgOf&n
zgci*;QB0}SX!neeEe;0!L~#yC-7&dRO<epaih_A95?1-%*tEYra|t$rKf8<TVDNon
zr**`ZmB#Xpyq{RUT)U1 at _Df@UxE4z6j0>3jc-edzK)Oick}PT`1)yRMU at l#rR|x~E
z4Uhl=7>>+#?fIT_&R(OR$)`Yh6$5`kBwbtG%v$T%I?K{lXjZiP^WeFOpQaApPN)RO
z7b*{J#?gW}x2zM&a=?}nefKL7$;nkeQoHH55DyaD&X{EU+Ve~ccg3s^%i_48aTYoD
zL1+}sabVW+kKpCL>t{k(LLH~NQ^gm~kgT0k1yn)v2ls&NU2(P0We1WC=DxFjgEg2a
z<Lxi0|5B`L_icr(qLmKT;@j6_&kWBiD!mi)C{l at j?Y0N)oTh%qKH`^qUy6Gi`tItp
zYo7I3G~ct&NAdzT^fR0B4IV^i at 9%kG$sIT1>-+$I&u<oz$&^(_R>9*yK$tfH+brsu
z8RUDDMe}3uI1frzSKhFgMra_JPJs;N;>{OdRKLuLTVDns=+OFoDjG74C&`Kz0A#c9
zA&VBO!1Wr%`PAQp4syS`HqIle(K^RCW}<{h<xUW=aJ>s-`O)GnX9RB&YtHi&CS88j
z;X3hlbLMaX2&I762^el;z?1_SqL-Q3F+a0dD!urJp1;maz{uO6B-)WHJeN_1`N6U}
z7aznCAjHP)T66abP=1Ln>V=(S(Q>z=dd;xrcxktT^{P6c_Qt|Y(7;qeBzFe}c`B;;
znIx}9e%^jB&Sb9X;rEn$(ehKO^vq^}P!9Ksf}F!hnZ)s2P!1`Pw>*pm64MQkXIFR|
z(q##9p4CZI|J at W{!G at E-qBMuGdAduQ?*<Uy`Q%J>!wbb&<b%PPG>JQ(zKxCLEv<K;
zI1Z$XA?GN6wcRsW$=MWszBwu49y{(16VGk$wykTPKs{QJ_yGG0!0SgGU*kM!K+uFT
z$u%92&FxtAE<VEouz+%ZkmXd}78x)e at q82?<_G?UHg7Rbew9#Rq5PYyFCi-R9QPZ5
z!ALe=tvm}OmUuz5;+te#`9xF4&EPwkFyL*W<b;bXM^Bz7+MHzs5WDkNewrvW@$M%=
z(Rhhy`(@xheam<%j6~sYj$yv}eLR-2_~$6qMjUyaB;w|ji<pzZ1xtoA80kdD6UA1d
zdQy-X#m~A2-nsP&Rq8d|g=z_=9G}-`zLCWIZhiDdKxI7)<2g&fcx23ZXx7~VBaREZ
z1TOyFXfmEOXY^t0<VcVy;)5Jft2a-Gjb?w|iD3*lSeK90CU`%Q-DjNeYXS&&gE3??
zFP*7U!lpdziLc*i9{Z4NnX;4R5>9eF4#vW>VyV4iG_SsF$@!6u?7jx+29hYTaZJB+
zlW52{>pOM7K1-<|F^tGWnI?uCYDh(c2kG^V{b6D|coGDM`Rc5|`lAe95d<}D at Jqmk
zT}*N{dh~6%Hmvt&Er8N8No<EnR~7SPHmwgbKXT*DWKwlPdUj{e>V-i@(Vxrj2a7gQ
z?(S^YO(qW3T at SC-j8^v>FJ&n8B at oDMN&WlWY_6-Z(fsz<P+>rTA%Cur6b95+rQ~{0
zS%K!|(8$ZfABPIUG`t$72LhrgY-5<ow{p>Ea~ArTJ4ZbM>G>bRg^c3#FHK096q2cQ
zn{d(gPA{qm%&p&0XWnisVdRD6Ltf^<0TfvRe}XzxkejYKaPgh|h3;0`V6MN`4Y8jc
za2 at pArRQ}97NegPi9!j63a(M6e4SZab^xf1QRjYu_a#qZ$=p|SGxg{@F=O4I;{woB
zC!vrY;w!!p!<RdM at dFIzbL3ru7!oM at CeXE%e&-F at 0RISKysFDd>Atr<=cJnp)qp%F
z at ixyHn;AB|rNX&Fk~wd|#E!Bf8F9kv8sGtbLp}8bb42$(S-zo#S;dk?VER;pw9#(v
zxWYMO9?suHNQsK_SRcl|(+BqQ41j#xeB0ui(p;5VKIPQDf2f+lwIFJ*_iIZ!MwGh%
zzp%X@@=n{G`;!!y`yT%}A{9oCdY2`mvhFEnR^m~y6p<fMr2|<qt1WX||5L0ajPlcS
z@#w{kLWxK*PA#evpLh-Gv2z*!GcH_yZO%>GmhwV%0W-v26D_^=n5wJXbe*<r at n$wS
zq{N}<Ssi;5mT!4|!rnWRPyrV8ZJdFTyw0)tML#xnI7mN(XU`b#R74G6-T&2;b6YUl
zc`kC^R5lR1(e?;zNk&T{h!Tm<Ug;r%R~UL+u4>l|b&gfBz4Rg&9=SsKr2vq9dL~=F
zA(Zmx2fIn_$veQ~qGN;r$tRGk$}Ex;@$J`F{aobK-bFu7;N|&2`&I at m0X(jo3q#0j
z>ia(oS&b^354ISCl6`8G0k3983|3g*!!Ru4j?#H(GI(^(NU>COR<|oarzW~J(VcZU
zPk0y(53MkKr|=ux$lnh}5w|M1AaPU7xh#FY2}y+X8&-%T6(?am{)mLdeh~yn*^&H?
z$<DgBxIa5_patc`%FndrK447})=rJRj)vU;$t#p>eq*kbNGzk=?`y71bL-!*-Nd6Q
z@)>AB>SLTE8r;T at Cu)O{qZMt&vo<=aJx@=qc875^ug;P|uMPY%S-bLP$zTkgu%Ib0
za;bwgo~?jN0X>+DJWR}KUGZP@!Bh_m9KFl~mtaat?eJ8z{7SDJ*7O){-nR*ae9?<$
z+Z at +`0Z~8YL0&fR>>|FhG*`d>)Tv}Sc(m`jS8z+yn+xS$!G(NRHu;-tE>1QZ2@<Yb
zlw^1lcY98+C0A}PgcMnaYyhJ&k`@#TM*+os*)B4=>BA2qqhH=*ziMN!f7Ve;{qfC2
z1TN$y!#L8G^5 at Li&bU0LetV1iP%Vf`3;&wrYU44h-EBv{uB14fJkRJxlH1 at Yd1oXZ
z<a3t3$ol~Ia+dLif>tsdG(S&5m;j!4X;~k{fMe~6m3b5rFocsGAZ3_Yp0SjcKegUs
z)+NL%C$y+Qza#`pwb|KR(b!rOCcLA2YbrGVmGBaOK)Mc{k!t-C*klv=S(6t>M2FU`
zUy*kkRF^l6Ka^q7$?{LH+~M?YoJF9e)A)xaRh600r~4CqVcZ!XlOHBj@@`ssNjYS4
zU$F0$5Wm%*EuDUNo!Rp7nDI+1^N?6V&t3_mt?9PQw1r*G20xiQ7#TW82d)`5i6|?H
zlb44}(uu_95&GwqV=<z*444!;b$PsJsUufR9l?NNe$Hq?%w2r6D+0nFVq?J6wg-hO
z4F-UP0$b~YZv^pb>t-Cp_e*2%E+drXOy<O-E&N}3YP<L3&3vl4k1wAe!7_MAjouvJ
ztFIP|28*=p?%PrVD5yk3hHK4i!kj)q!Klcb9Is!DDV?H+TJM0$rav1n-1h~b|ErG;
zR<kZua(YfMFRJF$#Fg}ZpBtR<dVR|gvW55(C_f$_T~PsW3KFjc!m>RlB%<E=Ylk!(
zfIhwyQ16-hB<=484N_)omF&>bzMZUlXz|6$$p*K`W8?glk`l4L*zdpFuP(pL<f;e7
zAV^;EzbdIq{NN9Gol)@Gv;ysWNZR7h3HxRoB5ym{$}Soc!TDRMbZm at Q3K~J+%TFw&
zpN|O<!s`->wxU-MICrZXx;t9 at U}eZx{v#q=?41*1^v_1}Vr(2*EBdmA2lBSwwo_tW
zHMxRG9EV at b!e^S>-Rh2(y+AZcsWTS+l9H&2ylAa9_p~kGSUaT1ZFFCDuR1BJqEqa+
z{!g|2*+)n~3M;H{05=zYi5&K=xK$`w?hV$iVdX;*V1-U~NVU3Xkt5VRsJze5Gof9x
zYD`Z?;)2%^6Iz@^w3K+IN!T|zQ3S8y<`D&&ZbldVZzQF|1rf^;!Gi at 6^PKA6eTZ at W
z0yo6bM^|r`D4g5fRD(mM$36vMy}U5K{ra|wTA2?JrVMGrZroGeNYAO9KVC*~TK={P
zd=T|^HfC05I4}^c9kryqA~<9sP+t!;7fpsk>*$AD<x+3Y=BB-}Y^)=WB&FI|^cUI9
zN)4E_ at nvcJ`uP^fb!gb8AStNh*pgN_JtZ?W$h?dGQk%<8_};bU+KSKfk9Jt`HHi(E
z4$S;fPC;8BQ47RN->PPG&@WSaNLZFFGF-989Wq$R7gr&jo=0FWRL-3msZdTg5>52s
zvkkVJM&rv-mYkGIZ)*B!Pt$)b8M~(}8H7gBH&g{zXLYs~m?QaG&895MBGZZ+D{a4(
z at aDNsxIy?Jul7BNRByMylsHQpL8C8LAoyywhJ1sSKAm3cvv}cfIfMjs#}qU!OXZhO
zCqXDT`upi3R;F_#5v-T%q-zM~V^@{&buOcoL=LM%bXiX0oLIuDfQae&L%yFm+Pid<
z#!;|sP-6M6G}^OfBi*mPi6fQy<zcZghDJ7 at h%X;|V}p@<5QB9o`26 at A4E$jj(ntj|
z2VK#eV!D5ME-2eJqqX)2r6BfZ>J}&y%uKao(BVN3ALAYbX?n^pZQY_Ax$8p`MQPr7
zA{EWFV^5$}JPNsMl*RES2L-Ed at Td2swT<yAUknl7F at q<pkU at b~Q2)10FFoq;fPe`3
zQ>RQq16fFRFi5;g{Vc7%*%op=+q7?TNeOVZxN5EA$RT&Q$Cw5bxb`YP02ksf*eS_;
za9dNxC?Il1A0tRlPKttiMpv5S;me=q$l+4Pn%ZBCysR2Z-f_h)luu2jlZ4c~=3F%q
zy)qyXv|~L$M+Qv`ofoiJkBpg{G1i?GdbRq4-!Nnw?q5lrMaVo!bsTuTFCzGv>pY7o
z7~3E^ZOfV$o5J{eHYQQ~GvSCgWd~)W^i$X0WoQd<=4K6*xN0ahX08s;-u8`#U&tFs
z=z0dV=6qbp9thqeIZ?%dPvYqr{chUJrajGGbgX?FW(BJ;;59O!Q}OLGAt=gs0ys+w
zlE^=S1Rza1AFwU-J*a#H(`CnU=t$KgDWkct2RJ<&+315$c6P_L5C``eQ{0un4Qmc-
z0Xl;Q2V~^pLklOj-S#Q!q`)3+w*^O$t{SNtlksZy6WXZBtqZ{88X_!O+n at PM*Vk~x
zHiLA1g5{t;Z!()KsR`y3sVztb;>a*5vF33+%%wiI2VgKBHvSZ?FoT_SgHN})MA^gv
ztS>hR({7c5=|LkXhbMl%dnX#dqCJOvRUl|at(!UXv4L7w<AJ?v at mHRy-T`thwf7g%
z0gK81=<er0jz)5p)9T0k$eCF0q`Tf5%}FPBqtLg&xf;;xqg<*W&`zYHhbQ*raOi*|
z!iBS);_*&rI8fxz=oZ<N!|(8a6Z>f!5934blhZPb%Cy2l1eXu=ki*`0>w>bfm{Vfj
zCmQ$N;@+K*lMpNBH&;(m{@C332eMEJpZh8odx}L=Hp~O at m)VnR6>-rT9*{pszfJb$
z`{ZO(C;vJ9BK9*ytAvA1^`nto0J?B8y2w`8;NLt9l_ya0v3Bq>Tn=SaUXSTce^sNw
z6X|e#XBBnB18OzNlmOqk=H at L-CKLZLe5J68C;QhVPmWG*pEbz>q}Y#za#^!9zATX!
z at mBbl$=?aRIa>!D2S;?jKGo~dpO=sU=;`jdx`zAe6h_g%$0HbKrW6iLRB?}ta}UZ4
z<j{S^{4`U)vA0GEAuGo`mX%WvZeF|E!=?rC$yR(`6*g1lSD%pdnIAFK8u)xaZkLg_
zNpSh>?blDQHYt{Bb#C!u?K#$mCEzy1jhBru#zvX8v?8rO%dqoWyL*$ZXK#W%XWz2~
z7w)p$wBVV{!jSBU`kx9c?3H>jZX!&`rHVl>Ymau>`UpUo?9hM|OJy2$bX7AabMxSA
zd>*yIj{Ud+7Oqz(3^<DWf<(64|0N(Gf6Ns|GNj2hxshGr%1|D)gZ@)lgK%16>Gn=^
zVO at -%ZeaS#%;`Z~7rsC<Oc3963$HrCeI9Z_NvLAW>p05KJR<H`*gRsmh_vMOdX`Xt
z at 1v#R9P-%Qdqa#K8Z_9LGL#>LMd>Zl3L9#@rh}`a?1HX*X+TPX!^hX;zTQ9J%fzvX
z*P67TuD>hyJv?Yry7Z$BY&ZUg=~VR((<u|oCrcF=<$#MX191Mcm`+4+^*pp*T4nTX
zOD=-IPNP2RT{h*wLh}9J67p=iCBl4tp-qbDFh<oS2H48j9ng4bmt3Z(O-&dW40FR8
z8_x44a+L4ron>50u?o8Q?%0Qq?swk<bYU#RI8iCFEv}*(@+Z`I!vjlf3P91k`5h{0
zsyG=LAT$AUnuhQ}^tG8_8M$^C^K+_-m^wb_AM{ECBnUvCJ^K(3c at s(%s+3vix8%(*
zq;-uC>S2#aKp(y}w8lk2Ouu2Acu5~3q^Wk%F>JbxK$#E&@wS$^HHPU$m!H|t1{5&o
zf7trudjaFN9?E!Hr4u(>k}%2htudiz%*Hj=sxG=B=xEL`r-~f9tNLV)cXnFfx7 at nH
zF!&Jfm$?7-WFp65?vCX at ebz91k!<7br`l3@#4{t&tH`J2{Xi7hep>Qp6!MbY|Kjof
zDiy|Zc6IrxaTE8K5C7&kieDP$!A|wi!6!2N^4T=qcVOzoAsF#@O3FZ$3!v9z1avUm
zRKpi?1^Y3q`n+T_!vn&ca<73;%0eP0F#eRBh8gUJPXo%4fs24C)B8iMR8SoF#Xo98
zR|Cdy3IAPt5aCVfEqizIDNYEX57AmIM~G$Z<<%=yRs^q=9<lf?!c_mJn}#Amf1$&<
z&bgI{S)ROmjyKCS_0j}iEFOV~XF`ix0WuslNUk?Jp9{>q|07?&1aXZsjhc~#n$Qgn
z_e>nJFL{Mj#ghRER<<!j at 1MRhnQfIrbdXb=V<i)4kdU*|^Lko1D!5<m^z2upF~XFm
zn6#(KcfHc2@^%Y@!O$PA>W2tDL$FAYf3)=qP!XwH8JI-Foc1c>h+Cf<0eyo<#v74d
zT<tW1tC$h%OJ<+lVO`Wl*kFXbc6ioPwwD|bGeMujZx+O at wbM^G;x}Q$yI<fcTu2?N
zV<l^s0HISTx{dF9?I-9G54OV;T6Jz;t8S+5>>kGm&Dk6!q?acEvLS~LwMQ+-i#$-C
z`F{SvRm4ycXS<gp3UH<{$#sAJD+PUJ!bF|Ly|fN#&8;rhB$h)zY^@~tJNCMn%e4u~
zy!>i~$`nyi?08R9|5^{OUw at vf{~1FP{$5F29!PWeaQ&t7w|;sUBiv-|Zh#4S(rg_r
zbKpdx^gfIm3JSA=phZ=F-d-z?5smR<XxQ+sDZ<@iJ&KhVZQzL~dN*!p^)Aibfa`1;
z0ukBSXOOc`E~mHF4d{nHmXgNvNE6q$eBR#paF?V$*z_5n%cB{F;7m@{-g7>zd-XAN
zmA!B8EBC%90`X)9`i%PC)9pH6gde#_9}v0s3*XQ>fAVc3c^+6#Mh%5*lK}j@(HMGt
z%Z!P|)~ii650?!?=A%}E3HbIKpy^;?@#H5<hFG27XRN2PW54X5YI^+oxD>_JCrAtG
z*c(aQCA|yyPM>5x+GRG*Jv6wBUHR0-t4?pLeqc at sA23m*#@0WeMdxtVWI26}#*sX0
zrN!Mv->Zuw>h#^$$`-e6&8`19<*gOI>F8y(LxyD|Z0Am1JP&L*y(zin0ZECymnUtD
zN%#mu^Must);(J`W`TmO_zkuVb7OLQs=up;OOmWHD^TKjck+`NGr{7nkD-0cG251>
zC1UT%cB+gd0dJL7PQU&9&?o5+nIFF7tqs!y%AMP#{C13swJ%g6OgnsE|0#nCP^~5D
zgB?HM+o1OMO|HVCUY1UMue1b^84>2KVu$S(+=qiVgVEXOh&1V*XQ{T{g`Zv1xRDI%
zwQ*P0Z4dwf-*#AON7Q=#RE`6BEGPVfd-JY!{H(lU6#+U at uec2SRHsqxt1eZ>Z;QU&
zBYc!!$tF7!Zg8MDW4Yri9xsP)PFBQ~I13IM)_&j)8Kvn_i~#R;4{ouCgc>2DsAT<%
z<u>hT3t<(O`t6uA!nsXYWQb3*r*~xo$Z3prGTA_30VcC&bBYy~a%5)y;b%`lXe)a?
zepb_%9>%6c?nVue<3%Vrod{Q@*4&<zy7c$Q*08|?WBxiJqsDh?EjlnG{$_U2;qjtD
z`C!z85!xbO>(OBCa?`_2GB}TR2O<f4CzFj7HTPU#WCJT`GCO|yC&1 at 7y2#$E?F0`*
zCg0BmH7hjlMqrTCsg+Lc;0$S?ac$XPn`WxpKFD8saQ-Nbve^!}#z`{wHLXly&{tvF
ze|a at AI{b|2{?$*##waGRZ9 at saI}h6}ih at qNQt9HWNu#D4U;T|3>#BxOGjIJpCp`uK
z09F7fx1iQLI<lO6zQVHqKF;)Di>_|mjmelSyYIdJY*`&#6$ljc8*V-NuHD!@d2Mw5
z%G=Tj3$88=wW7*&5M#`CL>yDiNTI^z)6^}lKD$+}A%2gq(6z4ARNoE$juz&roiYDK
z9U&GrVFzPnGAos+8#vGm3VrvvSB-K7RVU(*fp1aHbJ8g&Fk!laGA2m92F7RTUH<UX
zlI>enSa&bXczsde6MAWrt#*&?mpQYK<9szSw?SGR{fG+6hDDw*gk|X$8!nEp$}Z&_
z0Sio883(q9rKe|$VK#A%Lwv=*9xnqRfjQaK>4w;SjJg%S+%II!uXv6ymfR2w at Tr{j
zSn(l(;nMJ at U}o{*R at KcXjCIeg^?5-+aQXB0tpbjB#%!&v$&(WghH7`zTRgUtHc%$p
zE|qtJ+^UBzn=<Bh9QG9htqO0gwof*56P7N|2v}jOCzjp(jG49jSF*D*W+%HnBB}L;
zQqAP=I{YqhGTQ1>iXb5_YUnTmY6nE28qJwm1(%IxnOc{+-Sr-b-b31vVaa8Wnqfk2
z9C`WdxpjcpA4D#H8}2HU8P at ON)10K~aRpJkxIFYn5z6C_j8+<82dI~6HAVJF0(|IL
zlv~ZP;O|L{r)W!6V)zMAdPN?m+0erK(k??|{b*4AJaT!AM)l%}li0We{xDUNcY?Yn
ziu*qHr%lfi;xC00P+}*qr{v~Dznl&GnyH`2Vq;*HBnyM2-v#vtyh>o{$4g%cXTkGW
z0C1c|ipT8;x+OVxd>iSgg)gPJRx?9@#C8kO${hLTmsyl?hy686 at rEN#wxyPYR&-Xo
zrpgP8C4G`K-A83!8Vpe?B}hu=Z|ln$zot<Y6ETlV at goLVxKI#s#&lIzBdPP}5sc;~
z5S`5hF7OQ7c(WYj&(KRNtDke#1in)MXVYizL at ynRV!)aUg^s`&xwJW_)0{C+80!vB
zoYtnn=dMk>`mNi%50r at 4jn65oDKBa`dl1M&s)m%A$bWI^z#@bZZ7D<~Qe3P4irH!j
zVby>46?KNn?*mfz at s@Unrp0+xTgMTVWab!_L&HYYM3dQhHvDz8`C8N8^wamxM{qf(
zuia&RD{JHY$(#4-y*-o_=Zht{)NY+$-sBfBszHKNr}1jiZTo|CXnNa&olq3vImCRH
zI)me~s5X#jr;4Iy9XQC<mty|VRCT`@zeU~W!^L@(8(hS-dNK*V-6+05 at puv1y-h8*
zE<t+{{aY9`24h<GrVwL-IiSoi+(}7U>~tRFB!t9RjM87Z<j3b6Hl0kEYpnrw<MhH7
zlP>*0v!8}ZPI`>sI6D-2bTdeA7m#mN!3UZ`wuYWd9i%nds?ZH>K8aPV$X;f9S^B~q
z)2~<{8muJvtfubhv?)W!@N>;!g-%3rZa%U1(XAzjaI3t?Nh^8Nv_bP{q%m#lv)id*
zM&e^_IFjW4dxmL~3&b8>R&$%t!I{J;y;>@=AT+o*yN91 at l5mv!QAOJE=TL$Rl??=y
zEIN)>82AIw>W3bN+Lh<PgReYy0j6po8Ih!wYfy4}bO8)*lD^*(<5;=^z+sGCdQQ4d
zzo$)~LbPTJra*)D6mP72+5im9!NXIfYneu^b<PVZY5fuMNCIUHA at h&NSv7vi at L7R4
zr2ht*1AfH^M?*HPd11loBH;JiRABrqSaA3^E at c45<xcz0GPG at NJPS>)s-;U!>KHS%
zaX7>6el=mFRPk;Ayn=RRCG3!MKF*dx{nYS&=GfHpfpM#|q4(I{^~KOOTysuO1{-#a
zInE2S22xt%fbpxRo$#r?NU>z0)>SAU?wl5oev4zLuN at 3(Nzb=OxoO}KzRiF8Tj6Jd
zNS~$}+8+V)!)Yk=1v2h5?Lx9wB%X>&*YQOvnAPXdU(sJqJdF%8l;@fcy_}|-NJEy{
zQ57#lYgVZ)JEQSZTo_01cW$_R1!aA?{O-qI5-zik<n^b5MG at 2;#pLm$j8TBkCi8b<
z#aO?4<xkX3suZ=#3%&w6@)45g)YQLgD2A5g;JrcOYM##uAOf at _vq1H$n#88F^^xZ1
z><6LP at z&4!8-}OWJ)GS|$XaWCzrN at nXAS_8eqr)Te>Emvea}cMQ!^aIw}|K>sF*2F
zW`FSVr#5p5(%9M;337WiDCBhcN2<JkJQyMe`62F~05-9J_AkD0m+HQE^BegEQGOp}
zD9qdX9BTj8KF0QxO1?uy{JG<~;kBb?pL3ds(3^Xzb~j(`&R;vkHzsSX4D{$5Zj<iv
zfuRv4*_QT8tFAv*!%JXWq6^L^c#l1<eK?$r8A*b7Y*lr4$;dH=T~<Evs|Fu%@B~5q
zIR!5C at ZIkF6z&;JK!5?(Q>w?k;#XC%ZgdvYb>#|F0KW(QH&E~)OUM*K9+x1<n-dAG
zi;~EgcR<09>tqFkHNWJbF1o<2=fgP<^tz!{azI|8OkiC at eTesHZcW|-sVeVw&bvV%
zPs!fBa$4nOwnf+)es<g+$@3 at pMg|<57Z2c=@_t?VRbpY8m)2gz^`ksEOvtRK?+p1O
zp0Tq#&+<Yx3?g8aP_L9RL%4HpkM?$aCcweq%YHhQt%c*c6%i(~4j&X7WJsJtVZ?7O
zB`4ob0K;-*H<p}oXQ$DT8DW%#Fc&(d4aY4?0t1?o+fa^lq^3xTxp5J<6gR)10!nf-
zusrsW6Zebt at fzjr)T)3zr?`RR;(Gfv?87DQa9}npR1p8ySK|n(1oC`z>g<%64+-vo
z`_`VQV~R4LL-AdG7WLC_tCmDHUFCk%11XGuJ2j7_3#LUZ=_Ptz#_ko`dxsI at WcN^k
z)n}=#d0nz8&n}FthSsXP?__xMSJyo%je2 at 6heL%@1QpuaVqbfY88RJekbwm9oQ^du
zKeq}HtcT4 at F>gDm2Z=^Olylz~yiMvgRcdV;-B_ at 6*Wfa^&hOq(NMRrM{5uyo53l2m
zmap!{gRX4zD`?qfh;B$mgWY^%HrThLOlTyOH|!1V-7p$@_;)+s+(|(-C8mSPV+Q#)
za33 at _!bOXPYmeIk5oTLty1&?7R^~I&Rsg;er62C^<*h}JsBal<N`-jd*QeXwuWINT
z>}Q^;fj>JN_4xb-yii(3Wja6E^VqVAjI95&+3fg~2E=aFN7eBYoTYpJq>nYVL}FhM
zG;-|wgk_b>5MjAt2PF)j?x+eq8AfL_B(P|&R7(MYB0iY?0m!X+*#*TX6IRm-UevE1
zkOyjd8*-`oxpnu9;MLc2rilFk`e7=~m)lgoTILnkvAT-EW$2guxfaNV;Xk`w6ktPU
zKRX6>obhGo<GX(p-_L9dnSV<701VDAHsk|o-pYAr^7OZDeBF9qtNI5IS=%(0jE3sR
zSs(r$SW}>NT-rRWs}EVPW5U8>*AECUU1xVYddHFbNjs;*Bu}lJ>@Jpf$In>6mh$c^
zTop2EdR7o`^0=5p9}%Yio-+}P6&2-$mKrUAA`^mNU!CK2MK++h-7n1sxhFz%KO==%
zdXz5xc<YWpem6~d at j=&xEeaX^#7&zJ at L**AXsx%-8r<3|_B?P^2)M%LgAE$o!vGZ-
zCRF;pSfsj}>WFgM$^Y?Cp3yi^EI#*VJz_Tb4oFTS44t6H`Si)xGx&HNS1lYz{tXF3
zo{#0n at Uh!H`x7y|bVf!jl}LOo%SKTefjJ7IYX2Aow0h;sFA3cE6M~y)jNO#v0mSn{
z1S$<k$HMt)CnZ!8N^FV&{g!XN%X?Dgt22`Z9g+_v3x`ITx&f`b4JxQ%$au9(yU5im
zD`tPDmr8pnz at nY`&$}xCNIvk}>^)ko?}wEF+s4+GezHspt0Ng-hR3gCUw8*&az^D$
zrjGlm+m<`yk*?E`?MWJfb1MOUW_?J*m&9Y^Pl=o=nXeB%YZU9t_HCRhh<@P$%GHOk
zTdT3ZqDZ9?I{dmyv1|S%*wp;7wdl5kS71#PuI7ej>u5kvazz8b2}V%~H1mM&ZSnhG
zw-t5MSAax;gH}lUajALn*QUC&7cOpb;T48S19svu+3TWTFrpTYV-?m|OR- at H%h)fJ
zm;}Y2xqYR5zE;2?aS`i2`iG2;&$C|#z}Fk2^PVhZ{#gNSKP?ZP7%Jq8PPqOl+b+Nc
zcO=36*|)by#P4}P;bOr&=G?od5eL&eAPVl^KeshbzV6Ai%f{CJb~&-H8~09p2keXd
zCeKR9NynfYA^LRhLWB2cpJ2<25=-1G3V2!Qt9`oWgF2ljQuhI$)dL_4C^OPqU4ffv
zdwrcOw0?14-kbUb4cs*(?oI~D`7JY3ygsu#vr{S)nDqU?#qUpJ0+M;xc6$B2<9BW&
z*0c1xpuRl6 at -@UftCoy&$X!O2rqL7`Xj}rJm<)*Dw->ab*8Wz8jt?+CX{9BG<rk<I
z4H1^C)v9w0{0NpKlNi#+9Qjqfkz=`ZWqqcv at QN?Nu10rI5ZInN)NxA6krtqdrsQN^
zzdo<s#j*h_#G%c>EJc<teI&P1-kwX=<}{ThBjAHWWCWQip}#?{wYF;dPZ;Olv<1+C
z?l)d%LhuuvYTmJhc{~7W{Atd|Q+1Jp$5<udqn@>KZ!c0?Wv!&(06*|^rB~NxXG*<k
zoJEIukGzRR4;ij)M86t*XYQCO`2%cOpJ7KmSt5cU%+JHZqsD28+E+O@{@{Rl_e_H~
zAi{bX<yub_3LjD*qh8&VnpXdgVtzBIw)){Vrg;9ZIxBp307{CL?dj^DbOalSAafsf
zijgpGM$Y2HP8aZ032ok9&(DP}Y;6BMjbe4}3L?plFvbwQG2L}4o#*(A1o}5TECOBr
zPKEGA*cQwrn3<e1 at Cys{gLh^X>SJ!gOTA;ZlJ&#4dlH7}-Cs7&_V|+4wGf}IQ7teU
z1gRoAP{F+HhK8(8Q@}{(5|=(%BS)>KEz9~l_r0*KAPh9 at fa>SP;v{)Flv<VXOu?|Y
zx;7PL3BNLimlBxI(Z>&OEvi5M%^@CKsNlMDvh@~wYN&o1O&U-Hv*uj)Z)goSMjVd!
z;K!RK!+d$+$sc_W+b>F*<d)T%nxVS1Ab8yZH>%UJL?1_GoRyWET8!lW-kllF6OU!G
zvzdL_ at 6@a0$${<%Z(o%SfHk-E^6-Zl78hq-)kA^+7Gim+BJtmKX<3%Mw8i4JDs=W}
zLvA=;U+y0TjswJ}I|lRzj~T?xP~R+T{ex)&AlECQp0nPVk``I1B(nz6o at dKN?SHKc
z at SfbeDtR>cD6a`!tl-!j7lL((V?#*Y(1EuMWO<bL at 15Y&IYs2xR}`?FFl;qkf5sv}
zNL|6VF=&=lKj_Fe^hb#%nlA(QIn3a<twx~N!GD&hD&YbiynsYVj=YI!Q4}r65|(|i
z8}v~(B<3S97S?|-c7nn<FbV87EvR(QEgS=&_s{Yg=1BMQZ_BzvK7*NVm5*A}M<#P9
zYhBYDr2L2Y4{CjKir^&+6<_N<Y5<7vHFV<d-?$-qO?1pfR^z4w7tgM99A<wKyw6xe
z_bG(WXvPfdpC4+07RL>iO-<j~0h6K#hK;CP*nkac<eSu2a2*`|GIJs%9gGpl!x~?N
zZbub~Id7Zn$riUz+i%MCJS}ckd2?@$hBeeV`qeWP6NWnEdYFBX%HcEVVxZR4c6_V-
zh!a+euDm64q%}>lPHqkjqiK_#Qy%jh;=hydmgC(R6h<G?Nfz>}5~8mW(xq3 at ztd_a
zYY_SEOCR81Gn!7}%gI$p;+$oUcCgaNq|d1D&b7qJpM1)mS-kxOsV7UhMZbv$*7^ZI
zk5VwJ+Ld%BNLW0w+1g{8Yt0Lt_^0T1w$-Z+cNw((eaDqY5<`}eHjK%Q<6;H?T<%!J
z1dapJyxq`rYCqRL_mp)m7!U<>)Xzny`J9;ADt93=pI}{brL+MhH*9BSH3Dy>*DDoD
zRkw9SRLguidT~Vo7sC;Z+KZemjqvoYC>5SAs+$Gm<7<Q0!1PMr&2drf00}8 at 6BW8Y
zK<`2rL^qCC71i&@{>3b2TZ<f|rSyU79dMucSn!u#y?lo)RwxSG at 91V>xM4RsW at G~o
z+u-gt;%El=_RJ)d;0%cU({*eUq9W_FrkVj3#gxBPmSAW^XoW`d3{pRT`u0%lmz(V#
zh430M9mi=4rw&D=O7(qa(?aD5+{g)=&jis;+g-c_<K%bs!%PJ^Qzqk-&OzlWY;J8y
zKW(9N%wo-!p(FG_#)gK-3dXNBipV2QO5O{6pUPen*NV;My+>B93CHaja2Z-iJoDIj
z|EIDSgZES6NwbRSmO16;&kps~?phX+R8N$sur!g5QD9C+W8^bb_et-a- at i%&QwWN_
z+QnVym*E&$oF$9LWNrL7b&2^d7qF$TQ~2T1uGB#Ai at KtP3zr{U{)D)O&74U=8F10g
z{gUWH1T%%f_nv>SJ88fUyj3vp$ViqJ<N;rq5qeIP!-C)a%Sti+6$r>!6qr#<l3&rW
zieaGhkS}~jcG&zJ<Ast at HW)oS!=#bXL$r>(ldUypU}$<o_->vuE#00JB_rgQ`9kTU
zsGzfl;Jk5vB78XftU+r>Gvs#J;W`jkRqN|^eWSpgyeMGn==+o*Jm>(Uxy>kBUJ75<
zvJ;1C?JAv#R~vwtq-0rIXXIZjuJDm7ktjIMHWcZAD;QKr<o??|U^RvhjoRW$bJdI?
z94?>#6i`vEA!+uN3%E~3nNGlc`oeRBaeb-m2Yu|_o;5c|n}1kUbka|kLyM)9W#y_v
z4-jmwEViK8riv+Af(2tR$$LqlM5^*N)89GmG8;b7lT~+Be_8-t=s~X=`dnv3)OOtX
ztugXigo1v>2c^<k)1>K8eqL*&jqzot195l^TSiY+NdV>b2b{duh(H?TK2Gd>eXrk^
z!rwMW#?Oo|&xQ_A_VnBidW~(a$kob_biIR-t|t*_M93XD2s2%t0kEV<vuEeaFFO$K
zO9*cEKaF&oI7#>yw5f0sc6=B5K#I~8QZQ!{5>!opr??QP!qlv;_8JkcqW@$syU2%B
zuRO&ADywq*`f>A!bcl_QzB3p at HNfC4xS~RjBWu|qy3UYzC?>2}vAk6$8r2eDfF;dD
z#tt^nowx8Qk3DkYOW-s)N1?HuE;D^T+UftV&V at NS+XR6pzA+_lcpH>q>s4(cio_X*
zz?M2jhq{x6#Wm5r&denj8h+)!QZO_<d=JkS58kw92R=1Tnq8(vH86Zuj|t9i``-Pp
z&gk`xf%-AewvJ{{kw<+^bw=Ks=Z*?2&jE*Q#x3u!dftk*&T;tEWH^Bqz-HVhlM(Bu
z*UUd$)M<PW_8aG}W`PORZ*Xb7d=;t-1#d(j_u*=Oi0Pckjt5{pQB1AJF_Vp_GO1nT
zXKa61RrXE!XK480m!k#gH8j0nJYAz4O#I%Z=mQR at kFlRq8VTaZ0d8NZXN&ujeJKPm
z7Folb at M_PU2>b~98uf_yAZ0ogX!Ez#sRG-2JpU4ncNbvaNZgiZipR!!U+x8nbLQlm
zqs*L(T5n`W>wqApY at _mOHumq603qJ@7AaPuT-6=Jq_paayJw5slWiHnID8|hi>u9!
zcbDiI7Do)qWSJ~8cH at 4vL@*1HuCS at _AICK*=4H0qDWJ`{0iSle4*Y$HBwCxm?rdi&
zlB{I8{n>dPs3d#sX`StUgx3vjA0UMOUs7{Ys@#nqQ-2!s at DAaoDr1KYf4kzkCEOqz
zfDegFzi=|p%2bt4WVw<WrVQ$|EnFhR`9SY>fUwCH(NV@%yT^8~2KBU?1_vquA^w0G
zD$d)~K3g8NW*}1ep3*tdjEKdwW_dkjhVNcL!4O%hJ{BQMAWzdLu<N5Rj%Er&ISmMk
zbi=!?fj8Fg^*bWaURs at DMyTmiL;3Efg;*+GZF{p>No}gLKOVzgor7L>GQOV&a8)!1
z^k1;pWGsukN??D(#mrJ|98pUZPN+o15+SPi^?Oy!&4!?;<cULzXUq$ugsTV4bgp*E
zUKjjx(hZFR^us6H*X~cgS(W1QjbpROIP@}?Pal~-=*JSXMT*hj%~v at 6aiO}?sgR-Q
z&U<Hr<Nq?bQK3`B$)I3a%BM~TxGjk1hVEXPmg^t(4NT5eSz5wQoyhT9%(XEd=>IiA
zCn%b~nQCFzUDc&9H(ix10g3LaMwSwZXp4!*+Ccq_8L<&uCbQf5sA1={CzLaH-StBv
zR*O11RG44SCwE(p3xkXges(rqM)&7=gl=42G7ItNHMH_ZQb#^D9ojv^bV`vJ-TJ-;
z5oC+RqN7H|VYtjN=}&VcfRe at uM$2z1wJN+jpAsdm1?QDp0-o!y%Ux_flLXaqhd5Q;
zpL|_EwNqypet}_3FyA$g at j@p>aZBexc)fbo*&KOcO!7c+>&B9brk3hYZs3?Y6J_fR
zTyrl`dt+mDXzFYOqnP5bZb>vYHK^doN?>tnHCm)LqkOi6uEAExfkV~?l3MB+k*U=G
zqU3#QrFL=K^bw4ODj#c&r+B4{>h3O^IHWpxK>Y%t<D$<fCoyot65YG_n_0n^V1|{U
z(^T<pByF<c(ksqcQGAM`H`da!L}TIfNGl8*LfKE6_E&e;H6YC)+=Q~fi7R?e7HY5K
zCM1JAz2OE2=wa5)H>@=`4>-p9XX^U2Jzh65uuU<-$qtrujto_Xcl-)tMhJSW{L#)*
z5cP&}wEAe;^Scj_J at b8^KiI5E%}vpFU;b9d=9<HLHy7B*f}PV?i+-|RZAxdwp at +SJ
z)d at S6b1M7xl(cBhoC?}x<Clrw!GZv2RQAqHfx9TcpFW(i#9s_<-2JJSFk at i+Bk)1d
zKu~yg&~Ov-8!ljfQbpWaO7&Niw_O^;YX%?F=!HSc6EI_VC472*HvO1-&j#c4Hu&?%
zC9rV%?oFrazou-f%Ei31DU(tmw3C0e*(Sj8K at G4Udw+T1U-2Jz^Uq@|Q}}9?=Xhbn
zFn at JH5`!m3uqmhJ#hC-(KjwW!pM)Ib8Yq5tme3zR1z4#L3qzx44jWl at 69EKTLc0G{
z(}9iQ-ZEdI4KQld`cHmDj3-5bEt+k=2SfsBHhB<w6}wXoQa2Mvw*L5<Kg;rb?nsj~
zYxZ%<vj!&GzLo#1LA-t|pBy~S_&+P~g~b5^Knnk{V0q;EM>3F;Y^Udg74%N)b0+!V
z6B;a=<GT99(TV{pqp!Dgxj{mjQZhtr+TUK~N{6BUxyX at yMC$ye@*UmU#md9e-P+t4
ze&uT6fX>HF!%YLf00Ox*dAQMe;NLZ2m%Qjaynio+(1re9yg+{ezYrJyS7LtH_y6U@
z!v7x<^TX@*pOpMx*Og!Je>Q~x&wrjmfE!)lpI-W}ixc=SiW3k(7Z8Bu3+v+lAs-$d
zbRKwV at Q&w0=i&Q%`CsQQ_&-)nkQ-g_PksLTi}~~YpYGA}vhehKW6h=LY;J3f&L!jO
z<m#^V#@y1H>!r1~y`{CLyfiwOp1qZ)9Sslv3juU41#5d-J5L%RUT$<QX?stPSJv(_
zuFh{<U94R^X at t?a<m{b1t=+j^%4ol|wsf_!=2EeCv4y1;5aQ+M5f}eQz8>cuj}fq?
zU_xe%V1)qtAU-Z4$RJ>&V_;#RVPj!p;o at N95i^hw6A}`$)6kML at N)_Y@^SL=ib!e6
ziHNC*^YSWKD5~k|o0ysi%i1_w8#-wjnHaz`LBzquB_<$dBOzfk5aks$_ at Dkfen-GV
zee(0!ED|Ce!V^41Bs|2&9t3Jw9iJio`M~Q7{~$g=dio3*1r-e)1NMV at T!bfxNJvkf
zB0YQd^eOCV5bQa^Q at m&Rv^-MC1RCZjbZ&&aZ{u at O>7}c?h&0Df8Tc&R-=U!slaP{;
zGcqx=u(I(B2nq?m5RrK)D<`j at sHCN>qpPQHU}$M&ZDVU^@8IF-<?Z9^=l}jgSop_?
z$f$(G&q>KCscGq7^YRM{i at p_?)YR71H#9aixBTet>Fope4-8IBPEF6u&do2Zt#52@
zZSU;v?L(kv=NFe(*EhHDb|E4l{cRTP|9{#pJXpJ)JbjAv6b0Tc#3w%RhT}bbM$3bY
zFQtKE?nXez`xcc at IzG3$3yq#n^OVTKeH@*bfq#t=0&m)%mi at nL*t`Fwmi?<?|Gixc
z2$)ESu$PB~haiD)p3d?$6#d_S|L%i-%fP>7;NLRvZyETv4E&#$0alhT&%Q>nApDnq
z3CaKGEBU`uP*_>*{_Dp6KXt_a#%K8j`A3ofkG1s~aki$`oq at K_><Otk?rz!#OGx<`
zrOke?=Q%TWg0XV!0Qt^^^VeFZBhv#J2;zs3e5v9ApnS(U?Z=&%U;$5K&eFmI{~8a1
zg;d%{1g}@g645-=r{sX{yO%AdWi75@=XMiloE68kI^n30=2KoZe+1F=_M!tHd{eM(
ziG7XzEZ-B0;Zi!q*e|?SRBpzJi!^no)6>&iTS;kkJOaIS8JJFQ<cv at d&Te#*3K~9p
z9XxHE6)-VeBkeD}EJznV<yNM2n+3E at 1|<HR2*Ec|W*;lEn>3x5JWMb~i^tZhm<BfP
z=~e{FxTKq8ZPoEEi|t{!qW|Knro#3m1v53zs4`YmRIqyuoKxgJ_iLEw&-IDfYO8tU
zap*Q#pmNo4n-cEC06|wJO?Ibm`{0Bs=iTofYz%S=ut<@*5IjF}Uw6Eyo~oPYzbnRV
zbFelbnz9r&U$QNb;)>uZOxKz4G;sYDHtfoiWue(!u>_q?D>7BLt}rmrcg$JTojk^u
z8)op;#ynmT>!*A~xXo*rUer*m;A&H7aiNMckp5P~ght9(Gwil2a{dLc9Ve25;b(@n
zbrPO_pT+Z(6>PzcsdU&uPo3i|2iwk{g^k#27Q=&GH6an9-kDavV&^LSdyO9OteVxu
z)@r8PZa##bu;4I${MOIB>uA*Hzmnni#g91U&C&pSd=(zI#TV`uPC=_`ZZlc+c&)_;
znnotk&oRgZFxKD6;0w#jUf2LJ&p-tdiZfW}(1m3~Mav*m%+prn!JKtnO1x}7<C!A+
zr@@>p&N4dflXNXng5mnMc=Si4);9EHl(=GJ<tC>W9a)bEXisYl91N3-*tw7Fx3jFn
zq-c&Xkv;m}2<L~7ro3wVs9uwPycX4so@{}v_U!f8dh~(9!)(wOW2qvywEJ_LR|*K9
zDPue83)WSoow;5%w>G|-_(IB#hLM20j$)oUOSaCMp!(#^152WI))Y0<9F5jHYy&+8
z7AklD2kmgj1Cj8r9bA*L71=Iyc+C+QVH$$k*3Em3Vz=9^fa!sir7q`nE*w=iHW|Ez
zIM?`hu{v*feJkpw#Uft_*JlLrb>Alat`F}Ghm3EWfkqd<b0i3ldPHUK^i0mTsC(p(
z0a6c3IESO-6GN4}kPdG2B>ee)IlD at n<AwYtukYN52ca0p&VwEiWDH597B4vWTNVwC
z!M5f$w_)dz+o<tBo~dP|fshtT=X~Rj>k|uAi-sIUB(38VZWg4FkSMuncHT&Y>D+0H
z=tb{jyo!JQ4!XdDSwl(lJhLLeYfQitOM3AY<V?|SU4K&D>P#=mf+7>}0rT!E|Jf0B
zkB>-GV=@)%#7LvxEC)9R8QCuCvsMqVnS<22(ZKAHpa|8-OeWt$9HWj6Qn5C$>U=M~
za?K8~vv&H9zCqC<P5UnS^>Y%Xk4h$V^j_;hx_!P{Rt<gUa+c;@Ix4o5ZmK7*MTR=@
zB$IWu45Y6TRztvbEYius0|R0R$M&8hE{++K=HK?9_E*^kNw4~Ao>#baV{gPhfA(wK
z^7J9;+3Mw|_PQF;E+0O&HcWRZ8<ZHRJjzPJgexb9*MSj+s+FU+dmeup+X({FJ7ceb
zjhu&e;wg-xo-55rPA5-;<GS5w<Yt3-#RWgMkI9sJQnnsMTlqrVRO2eSQ}MA_Zw6a5
ze}6qtnce=mgZ*Hg59K84+TlqY_1jf9`_WQ~wPNBxPE<Z}Zq6Ks|Aw2?HXQ5}L*17m
z8IXRiA&Wrx|I<H4k6>|xYq?Xvw#08N$NUOca3_>?`4OR=`XRi|aKk9}^sOCxg=e!O
zSJAMgrvGON-kko2q_^S+om6`Zk<6A$1Fj at Mr%!Lx*LyqJre-RPUQU17w0w{#SD_7Q
z=l$JveN2D)t at 7wuY~`A$&I at R|EW;xL-U4q3L3)r2gT1limAVf<xm+UCR~q+(fgN^*
zGLcZD6Fg07e8Y-(rZ3|vg+fr%rMKH?e4kP;2B^c_TY{24^O-K}o6<~qwx;fQ^KkqM
zqf+d*erlO{JH6;RuGM`TQ<J6k at WV08z&10SAqIy>9mP&~r;@M*MayQ<tkr0aqh6KC
z2+ at 6!CUMk&D1)pEybRRvsWhRuIpQy8Gm$EfFjyVcPf{fNzI^q`oMXsdPf$7UI%2<=
ze~7F$SvD;yJD+<?l3MD%q%RK;&)MvIP_kra7~}Lb##(>E4U|-+MjC8#CZ9 at S+2h?g
z2P#h8){*0>W0X&27!|af6;N$c46x<5)gEW8t&Q(-6mC*PWq>rxtM3`OU4PX4*nKwW
zVv)+Yz9|1K^)w8vEAHE`Uy!|vlbrPz79xQ!ucJ(K&DovCyK4t2q53qx{Ga%*XVqhW
zG%Im*Uo<U`%`s=n4X7QqoBqMZ>0b*#_WS;=ZWWJW*}_ at eh}GHZ9gd*7K)Ch}>Bc*r
z_nB8Eam!u#zTKM6a#oG8w=CIcjIT?)V|X`DQJICWO2h*V$D%H*tKx)%xPK&6F58T~
z3W&+Ha_h=R{sQ6H-1s}-)A=6aw at Ydfr%C|&{;)x+zasO^px4V~F*iwuwGUfNy#BlW
zt3BoXmo9DUC39owPRX#tbHh%;Y{fCKv0HW8hAWk8#8K6X+pwcvZ#hhp;O+(%ldtE&
zD0RfLbR#M#&rF$}Wc3Uqr9l at -w){>eT+(3pyJwb9f7xEsa9<fMT^Mt4h~*qx7)8Ly
zbZSS{n?v+YlY?%ld%M0TDt}-U{oNAwi;J>lCWRa at cWOPwCj|;UGjVBjd>mR-1YFS#
z{<!&&E+L<@-_0&g>B0|_&&kr?>;(Tpx2y!T|2OvDIxLPZO&@L~KnM~D?!kiucZcA?
z-Q8*23Bdvcw?KkJaA^qclHl%5aQEOA2=c4Ev$Ok>ncb0{op1NM=8tp1>8h?ib<U~B
z?)!O)yEH_(HSlG5-2PHc$1OI#Ipq>aK)OT$QTKDLa?MHh3H02Y#g5Q#eu^ahw1ubE
z^HeiOg*j?rnfl%5_BX^bsSXm(8P>dHvg$mq#698P&g4aMM5abz(6G_(^|mc!Ck$iT
zs6y9knstZ;zsQN6=6 at J1exs`Uo2K;FZC)=8Wh~0Srkokd+DuTZ2|F`&r;K=&<I8V?
z4Y7Adi(HwP{2}2Qz}NH9k}9dD5DCd_&Z7rdxy(oE`jj@!${U}*QPn0d%ng#o28&q`
zI&f3q@%eA0WPguZRg<#QkoBm#5FOLw?}KF~@?%NFU*&f%nf2cF5$p1bs41Zgb(s$k
zxzG*XL3f;`h@$I?22)M7tJe4#OM~@Pz2X#3vUA%Zp?9EV>gG71>RC$-6{`=7=g}-`
z(~?IF7IElGgE}oo at D86%Z4JG5!`B(@F`4z+P~tQX5oOkGRU`>`Wrf0AZL}z&F?9$>
zN+J-D-*kEK!-O?Eg0m&FEum8uiWL#THa5LlO3O4fHq1+=BnZ6dO2ULQ`n6P(bBWqP
z;oBGG-5Zx+@`efvd=%avH#S1Im??!%ZDzqZE8u5bPh6;kJD!n!66+=M<%MMH&$XB4
z2DOxMG~xuM4fhSA at tSp`#_!&Nc83+d)j`%9N3X>=qsbVw`#iDU7<!T@@jLNZl##rH
zS=1RO9&A$Sn9YtAD?EcYRjp3T)YDzqs(H^9d+CmuX`$3T^25~dmLpqiPD-2hqkj;V
zlJJ9nQhO{0eo*I2jkk));{Mg&on=QJk at 9L>d2E5t1WbfMRsY~st}rfQK^IG)x at 9KP
zgQ`cij2$d*VfT(}Q0q>+U#fr^APh0NX;qv%bFo-PFxL;XKKebIvx0J|Fx29>oyfGh
zu7zrajKr#wuzL*Hh4n}v$Hw>~`(VLnk9`^I)zq5#Y)4oS#v$zcROC}7m+01vPD<>U
z3c&&CA%i(YNf=){Ev at hCfQvo(%-$L%r;=NrckpT<kwuxz=i9*vSGk(8t;A%3 at +9-R
zI3A at LTcV{0#7>CRjdZlaV$L=X=JeGDFoyBha^B)AELnl~maE^0+oL#iHDhuhBQDWd
z)57E+DC5DRTNmOa8Nn-yqefOa_94Y$Qo-D26HU(0!sbA6+#gdunGs=l78%=Q-PiH~
z(O=!Kt&<T8MyZ5h2A_;G2G7*^06)^L(t?KqkA{CECw+mi;3e1NZU*25!&t1TPTU*<
zSTIAoF+0B2sP-n{Vyito^@<N4u^l`NH6OnY8H<+~e;$=jo$m`qO=5oJ0VW53VMnB)
zG&IeSr_cWAM^;-K48;y!pk0o1eiJELa0R2(pRYOWRLiC{+sk{Ju%g_)B{iu1(T^gL
zb|W-9ks}t*u((v at 8dcKD%*r%~VK1vzeeG>F68aL|AQp@~n6qnT*&@AfM(ce}G-f5b
zywso$99ESgj5yZ+-lnLl)9(66%n{33;wu%UVxMEr(vixj at MBqfly&|sllXqa?Pigg
z_ALA@%ea|`W>H#(k?TNeRz-l~50Xh>_SFv*Dw}7|8)dyCTipjE4M<;xWf;HtiUsas
ziDEg;9~H)CtlFiQCXm(P^Pu!?8to`jnDCc%&!1j=fa{icLHPP0g`h<+3EMgh6yE!`
zeI0M4LxK}b=(rtLMv`QNT{$ahVjClUv7-5o-baGjdJhX`&_>ZZV5>^or=~o=!T(%Z
z=4oWe5o|lWk1z6jvGLL=#kz at u<uItUiIj0oXf0B#_meit_}Q at rWMIoRxJF#iJ9DHp
z#g|FzQ!xm>iI{Al%|xD3SFbI=+ at B$QLll(AyhNIn{Vj2M#nB$^y9h?j=XZz&Dp5kn
zmEs_E9X{0to1B^;J0hbzB)Ctfj1y4_CiuA@{pdvUwRGgiMJ(*G$}ZBm6Ett6 at Jql>
zjEZ`R(F!$C_6tS9UX~Xub+=@ihS4U2F7Ff(1wLB6H?XgtsK$F*>$#$7QWIIrpcIk%
zWF$3xPJQihCm6XCUK-1qxgZQ%as)Xs3|_^Dw{t(Je|omLZTnfMY;-q%;bt)X+vH~}
z(k4d1l8SA&2)Q|#rZ_cjP{$8 at jLWrRLtkTPuY)9?r<ibjnUgiMJt>pcreY8xGB5pa
z3PEG-{$l-{icVJ(%!eD1Y7pX{hZJPJCy0723AI|u=+_>ycOV0IgDXK95Pzh_t?%g_
z=o-fNmQOOa<PJ1^n{fy7W4Z%%+sKE3297y0F7H6&cc8-uccAZkBodW(AfYSYTTtsA
zh#1043&++2_1(M!DcphDaPL5?)#^KX<_q53Ez^dJRv$Vu%Ijv|xDQ_~yxtHZm at gSr
zxfMFKzq+=+!QcShzgG4y*U1+LnR^lpU*CbYfggqihUgYep>+q!xDmPofeh|IQP4Cj
zn4~oup_4mM{vBxP(H-b$=HC5iyC@=9+`lKwU+%|hR2V<~-aY+m9RFwMqiBcKhLaaO
zzc|Z4`GcS7`EYsNeASbP%a+MTt#rV9inUR at 1C>d)p27(u{vX*E$|L`*9UNryywXu%
z&A|4PLFG&G;jeT1eH5EF_N2a~LE67OGz13MzPmza-&?Q93C1%~hVMU?qrW_o;~)Ll
z?md?O2r*Oji)g6Y`X`M8b4O3RmpoCY7+-N1#kSaTOUe@)4gG_c-6^DDV5)WX3)9t)
z>O0Wr5j5>@j$B}e+B}DN#r0!PMo7^lbEsFjlTk(l(hLy0U8&ETTM8X5Gu`;i`)*y*
zf__<%`=a#Eh~>Xxz9w}FT~j>2t^6<x^vN^9dEK>Yhp{NM>-pouwT)XPhr)N at u3C4G
zT2Eh0fPR_%e+lM)DXM=r0RBG3U0l#x@^!n`9Uy$he>-ey6zp1c8<A(*_ at TaM?h$`0
z4$-)6roID>p#IBj_?<Zhm at j}&wafKnLHxY`!4LK?3^$QO-#!ZZLXR$vzN?k}BAIgm
ztL_#s;0(g=Kp&q%c>i|u?yry||BK~6%k$jHlDKDP4dn?ahh2R&QEx(G6_+kU@(yHX
zO9s7f`N;wMpwZxll-O$IPyE9Bmh*VYAmS}Q)z9<GZb+#>R- at urASIxwn-|`JNUykV
zUUS{PO|IHyQ at sO4-w@um65fGc$O#j;0O4%shMGoitCH?~O)Fpfq~(*=)n((hA-)JN
z_ndI`Be;QZn&76oX+Mh}uPiKwY4A2G&wTfozRPFb_Wq!m5o~ilhs<&wZ0?_=C*)fJ
zu#U#e#~=3ROw+ZmPkK+>S7-Sxc101hTE(5u_ioZw8Vd;Dav<G~Bz at b0t-F>O|4z_e
zH}U-G2nVq_4Eb=OZi&M?-HI->NiwgPha_uC8;G9bo;k(#VA2`($R`~!*5Sdpn4)Vk
zl8SdA7I>0t^^Ws)m7^*vmPFdMaqL`iD!j-$kV|@Ydfk=R2%?!PyN|T1tVEsEfHjrJ
zVRz|x#1xNNo{r}C<O8uFgCDFL-Ger6v2WpP#sgC$A~y04sgta1@&{ev`KUc}B2%1+
zit0gzscs+JfO1YutGO0q5DcR1>NOEfSC#Z?NsZC0v1(LKFsDtpcX)s7gN{6N^H`bG
z_&86z)hJrH>fBPEs$Cz%PHn02rmxWNeU-&BLzGXQ at Yd3uwb=Bucdml2lWXEjc9gmu
zMuihc%Y!-eg at Qr`<eig2r(X2Im0<nV_N(gLcf1h~@Z}1dl;hqBd5V$b82UNSsp)ab
z;moR3ajx8fL|d&SKfJeIx07_`v2{{_UrnE<#n^Jucu*?xc*-v42rbRm)3j5rq~==}
zw<?+wRs_*ne6K)|wU!)8%j1l1Gk2hU)laykt^D*E4NlH=aDE>A0eng$KJs~C$2Ur+
zvV5eqTP!=|XL at -0;P*DD?Ns50kG))W#9eA*Xx{QmbEbKXaYW`I?ZMV7QPlDn^R%_C
zLc?JuM|Jr*3qO7zO{7WKTOHS1l{D@|*jIfL9}#uKro|bjZH?3GUAT4ow7K>D^XG=4
zHF;j19)=)N8PMqtJ?@taTz3KniCexmY4|ahNAKJeUn@%%;tjXhFm-T3yjS+9=j149
z4_{KU)IiOa5)cc90B4WbmOjlDy9W{>NN|Lff|k<4$9HoiYp0ha1{2fHvpF?Wpx?f{
zo3fibvDpA+QkUTNry>W*!-7KK at VciUaD09A{^K(n2cPdiHuHRQ+wO7<f>wg&6a2;A
zdz2=JkY;&HpneO<5Jk&F-*MA!7e(a2Gh-n-cuOm<{PUpB>(>hJ&v^!T=F_g>(o<b8
zATmq(=iZM<G5f7&X?%oVMBj|fO8A1T_j8xS<+x<)fOn<UN2}Dn?LW^;3zt$g-S7R3
zNX#NB8x4u-3R`v6f$-jr%Vuac$MM;`h4Tp}`;q4cTKmRB=F%<iH7SQ+W5a~S(UO3=
z-jaSENg>8tr at Zs}ICyh*SKRM_o=bG%4pe=5<ht%D)Z{YT=sr*B+E#*!D;}sfz6xbp
zs{@NVjY+b;>|aBPf%WeK!4(uQJdlWPFN&H?vUtbl(u?L~i54RJi=U$HnzW*DiBoNG
zb((Sq5 at v_V2clJQUdZd$^egUAn!1{%$fxy at AG)g^S7dVc^a`MB at 1T=SA!cvK>3bLx
zHj+P4s;o<tbvxr5QoIV_&axv$OFU3cCdK%=y;FY4g(0=yLEKi#66Lr!R;Igy;}%uu
z>JE<vunA0KRcps-lGnj!Qq}fPw%#ihs{i2MrIak<?o#~$HIHGk&rCcwKyEMUb*7JZ
z6c{i(ltKnxKnG&^t~4TPup(f at u1BtuYZ*~@GbXiUPZ^aq1T&27Hm+FNv@)~vaMo^x
zJXR+vY3V9J2ziC6#LnpOc@{~oVa at G}&k$v492HC)eK?fUUg9YFj}6r!vd!a6j7CvN
zBAjC-*4U!;@I+|buY4CJJ`A>PnVO>IPQYsL`+50N$jQD1pm8k|Cfut|6xJkseB!#Z
zQe)`a=Q8Si3Jh=odkjiCD8dYV1$%gfUeH5(oxNw at 9qB9un!fC1CtUwR at av;aN<=H0
z0<8rc9i2wcX~DxVapP890 at H?sh^G-#HAin8B3sn(Y%Q#MclUG;LaSy4$e~k8<6z^e
zhJY1j6r?8uC~er>J4gcC4H8LK-YY(@b^1N_QJl#{=z<?6toeELwr$S5p|E&4Vct0D
zDr<r9c8^kAG;=LjH#HUd2A5g);FvnffH6$48?`#bBr0U4j_*f*KUhZ(Ly}Ib>hPv?
zgPQPTv?ZeDZX7zzC&X6yO at -Q;n(|<J4)IzwLRc5FlZ;naqa%+19RtV4-U?XkP~Y7n
z-_sWy`C7^MoHp1n+RXo~q1 at MmQ1j+H5DA9w)O^`(bX3*W-%O#ouPLpd=7GTVFz-N9
z^HaCcaenMuAHzVjK%>8}DuKOU<lB7<Xcq&ZeWcDr<psz<nDvbiUu8Yx{dW1$*YoFw
zL5q7fqzm{&%vZN+V;Z>UgEHe?1XJg32{&1FBCR)1ji-aSf6P0_Un&x#>gc^*)BkK$
zysf-FrW^OEHMt_2$c3T#;U-+O+C-BW#A;Mmfhk02)UcQJrk+Rltcy*CvD(K*vHZPq
zdANK{<@+Iw(2ml51l-s*q8pFm78W3+prU*SDy6v$BWbIp7<UDmAFq&BS(2Jp$CwVE
zcf3L|eU)i?UX-{%0ky|it2o at ufbHp_{NeO`B`5GR{;nPZz{()owZB?x?a?4zo|n|B
z`4q>;h`1LM9xC;IFO)?7B;#E~l%;pT%%)hbjhweDRl<5|BJNRUY?eD3@@CPerHCUP
zj^S-Lt_y<xU4k4I9qF~V<N;g at O3raw<-NoCSO<i at J-G$IWCMfELdIhp+ at XI1t@1dX
zCs<UkNp>vCdP|s?5cMqvi9XdN-48iMb8PQar<qHs(zA1}Hnx*Jl8q%vhi48=(%KDU
zW>gog(j6yjg??90Qeo2m8$^^`#DWlOPC`}?iDx_7I^#v$DQB)(p4N_=+n}xXgh5vy
zc?=3zo$_eJKfNm<*zHu~!x#2h1)9C^!mWlLI)W>o{R-wT5uVQ~(MC}>HujwkO%0Jv
zQ&4xW#PGG%zABTBq at fK^fCK=!qHk!Tjm6a)JQ_4MoS+yxqh_Y&)ER;_jKd-FMaisL
z5OecS3Ay5itbI!N$eG{}P-eG3-BMS6)rL;CX$e<07L1syq^mGvF}ZgwkT=X<^gaf^
zRFBX`3R|*2_G|pmGY(YDMX4!v>`zt{)i#Nw7FPHPI#!p#(iHrg(6o~Ftl3e0M~=zT
zvI2wNVk_RETq1W=tcPGiJQKCm at 0zbVHhD@zzC4+$(ErTXl7(HR3}<VfO;7!WM>oBW
z=U^mE3V&Qlw=7~c&N~u^HrGS%0QNF8vOj@`ViCXSDk{l-IVGHMk7 at 92ze~&<h0Fl8
zIwhu)0@*Pt5?Wu_N_Ec2Ce)4sTAJS)k8E5KWJ>;^n+M73BsIetlC4vdpJUTti?B`}
zpk~8f*W(ezMY|cpiilVZa<5JS7kOT-ZzLPdo?DJy4^GcF@|zI3lz=4_Z>JA$Q@|wZ
za?0Xi;zZbL8wNekNFya^ZikL=-<DG7hI`XaYt;7T!<}Xu&V8dT<&!_`%*)T!*})x~
z>n~Jz{C-c=92MUvwh9&mCzya~{m6TnPs`Ousbq{N!X3>oxDHur208V_Kh+{D6Ky8!
zq(D9?e|JV{gz*4^>3Lm05Ki7r9@};~Oj8H3(c at k0Xo$*nEW8}+20IxBJf$G-u0r{Q
zEJ+zZ2m)`<<j+<UOHB1npFhLqvKzXN06_RNh|KycDqApzj~7D1#x$?d+WOnsE*~j8
z{DZKa0!*Are(5_9Ikfl=q#y6Qg#ei09T~@r)~#pTT(^Ff_<xTYl_H!t;1SzFS_!Ii
z;niuDv3w<Il26{fHYZNe_}Cq`u8XJJSEkw3*TSqyZ~n8L!G5Tz+Wcv6srsx+xW<u0
zs4E`r!i!x>ixN9#<m938+i4%Fy|otH5DiZ|;#b at ICWNAKutA1y{=!l1`jgpX?4D&@
z9lA{W35z5~rzEXG3Py$629&SGC!5At?dh at n-x7aEoC;elWq59UXjev(od>CMWQiN2
zi8VX+- at y)fNwk`;t3CmZ*)Gmm)NUtw_6TWRbA)!98is}>vg+0aW$RVP35rqhA*%-e
z(!~ubv#!{t^y6eUN^AUahrYm(4Ef;tclDOnk|YHKuZNxKzn(48MZa6US%2+=RI>Xv
z@>?RptG67*8*xfKjF`_U#J&k5lAOZKXfIALurWgBo4#duh?AEal%i5zMZSYo5IkOB
zdKS=fspj^i2T_2PSA%B-%sDJoRXyP{s|k6YSr>u+6xP%K18hFA2x2p9w|rIWQF_x<
z;*l;=Q(7opu%e8UgU2vzI81f!j`G4za&G0 at 4)r+lE>)sWX2Uex2ilKyKRdVfB=fwg
zq5VO`2_=r=C0IHr-QRPSb2W-mtzi4|y!0uBi_$mH9!b;LH<;4jG-t&<%{e+E-T+|G
zN%u5m$sp6M&{@XSwZRPr>Ywone}^6-+*g#lZ2Exbht#^eKXnI^?ACVq%{~0-BL1<d
z-`9k|CKUm`@z8g7e;4>h?;m`{pY$i}`<f8KJ1{A<dIypKyw5HmD)&SYAq at b{iH0C~
zHi#W8*2%J(X5glPT5*7kl<Jqgy^xx5_`zQ94)j%rm92JYh;O9<0B+DbuEe__CU_M|
zWKE&RaV%sY5p^QC3DObO3oiy--p6C@?2aGly0$-y*3C$+Jg^=WChGlk#L*Wn3y~S3
zw}aEwp(xpBW&4(M71q$8+P{*q$G8Q)?PB~AC%ccDdfLUZ$WbYdgkt}#w{@AGH*f7&
zuy+mIJKyN$9AScYQE)Akw?m*ZH#<mGRYNr+rN#9S#=IAW*Cc(iQ5>c|dWD!1EI%{D
zjgQsoNR;nM at l;+x1dzj4l?J+2WlzX(YRN6;r270M5Q#k@*0gY>D&sVb(9 at Kj85ZIc
zDN__FV|)je?vqZH_cD{GKW3Av=)>7i$1f{HJP56McKS5ZeNX|E50_a(qSc3W=h>On
z;92`+fJd*|+Xy2y=L?TD_oDc1f{jv~Db2d^&bXdZxhne&>8drjx at G4*Jvl~@^OQR8
zS at pLQE3U*!F+MxyMSF6JMI-&d*=h|z+}P9Nf}BPbA7_VJCfaC>5M?A7=L_%G)f2!X
zMdg3|9;h>xSKZq5>CK at MW5Rho9)&j-nd=g|LawwAN^xnnl}6%`jgYw#WAm5tC{x71
z7(}wo{B1oo3+rT(loIkt(NP-u3(a-S*AxhTJcF!{lK7q37UsmAS-<Y3^yy0Cn=d0$
zp2D9DbJ(HM>yM3SZEGaT89)4L7dsI9OaOt~)@{(vYQ`)v0WsFZE=EFLN-6Gj&ap2+
zqht(LRiiY6tx14Ql3lKDVxqFNvAn{Fw+7z|-gBCx*D(y6k98T?Soxl>_jJR1kw_Aq
z==rF|b<OB}w<qDB6U{a8=`bW|a$$F^Yrt10(9h+}$H|5a+nxwV#I##O${#uCF!oY9
zs+F)uy1zs<Gjlg&zxmcr-_hkdC%v7Pb22fdCJx8k#FssoqcyLiD^pn#-xPL9Sy3Z+
z*u}ORMbG!y&D*r4;RNMVNicNs?KUP$mq3NoHGS4Z)vTQQ$jn0Lrm&Q8W7sjT6A}kU
zbCdcf%EuDr;&@*^Mu2EB0 at 8`tbavG*B3krrJ|}ZV#PyCN#!g@)2ZL!kG|mU}7Z;}=
zQ4{K0n%MJ-?;{D(4i^l%sw%Rjw2qc7O&GO~tW{}Y&gtOUC4|``k_9vc?uplg7er&|
z?7Vk(lz+j5RZyg)NaBxxCgBV`ZlzISpbf*(vt~Zm^duk41{*eP)@*!3_{~RwfdTSt
z8rLkja at kwkR*vM-<UQZCq{#w0qB5OzuoPjT7NJ6G+LOM!WA-;7XxcBq&)>pK2`O1t
zzS9H_)hDkG7WnpOYY#9TBa#7}g=hV60K+5GMp1UX at +qb$Zm=;+9nsOH3f1A+oCa%e
zj`i{O(aQ~Kqhob72CszS`9T)|Atm&%`?~dH`?YQU9(+ at Ld4J^^arab=5OO(58sAo#
ziLaMkuB#bai80%-C}>NPG{IWcT(jdN`3|L_CbcJ-gTjswFQ~5tQ0y*J>|MsO?Ugn#
z!~GGrCS)02<;7Oa)^4G2l^vtZ9yt-q*+wIQ+U&}3X at Tvv%5&|{%ZmF8AdMkmOjO2-
z?OBF`N7%j!V}nsy1 at oS>x3lCe^L5ifU2N&TGUFf9I?QIQ=<U4=hbcmpZ{AgzF=IWL
zjo3`R#oEJ_1JjK{#6Ks`>wbWHj$)~REbrM}hV3(NBH?aWlo==81{;TOl1`O~k0~{0
zrib^q{c9M4EFicM%-{bE)eYagX1aYF42WOZpP at R7+g1R`ej)Z#V5^muK^PLWk9Quq
zn)sQ;P%8k1vwcinHoOzJFPI*Dx)nQA;!9=;dvlMnq>7;{#va#AG}_qVNL~!9_#<ip
zMgSXYT+;rLEPE)CCF{^PY~c%<Tsq#Ku&vJteq at 0$;vnhY#&gfp`pXLBkBa0!`}+ at 8
zFb}mj30$C8`}wcF1=E*57S7ox)Ij9-x*~uA*`0$^-^?aXbsA}r8R8|YW#h0&UsvZ#
zOCf<Nm}kVE7*>!Mb{AlawO_f+=%+(ZD%g^8;%S|j2c&iccGbg-k^7HuGB}H~=Cy=-
zDqd!();|^L;a?({_~`$kVc|VzRu<$PBS8-V+j~l;zP9v*iH6%G&V1sywxhy;eV$oQ
z3c8$4JU|m9(_#!SZfi&I<}^fwI@%MB7ieYGE1SG>Af)dhb5z#0@`{L^?=9SUZc(qm
zs6J642|9b38lUcD;}nMA6mKO+0aU|f-M^6crcq$rhqtpZ+n1uT^SyC(I*^^%%MH-O
zJm$a<eabmymP`$o?chX6+^xO%G2DMpWcf!*wy$Hc!o#MfTF&loMWPZP_R=-iHZx?x
z7->2%xA*dN^}n{8QyeGCddv=*!NKwHX;9#|2|*i*SUN$Dl~#FO-C{M~U%{>^KD}US
zs7KD~hB81qBncVkKwaZ~mrga(TD1>OUz0jG_g3S>fK4r*@1^nIn`s!7l&hR%9KeNc
z^Xo_Ok}7%y?$e<%iHx)Rbt_a#Y2BWfR+8Gr$qN+h5Tk6nKnxU`>r+JQDw*enQYdl#
zYqHZzay>Ukpoy_&u2w|DK3*5 at PXy2T-$X}Y<9;G7^BT{|L{sUCX*$`8?R*w2=Ed2A
z;1-huc<|5zb&9cS at 7Y-^*Wwh3;4uYOZirIIhqhNGozZy1B09M0oKtbLy^bUoHSq&)
z_bF^l%7}dlYDF;yN)sTO)?7|j?l`38O&<nnW|aE7IzWz9C*v)2U4hy2R>{G+9GyM&
zIyI7L9^f{jH5a&aW-s+K5l<V`y^_S*XD#@u#idd`S5cPu1D1(To3sjLiTw8%@e{E@
zMwBrKG3Z&Og%Iv4cixSBcgJ;s>TeGp3rpL<Ao81}LL-BMO4BS8p$-hpW#R at qUh(_Z
zlOU&0+xp}cwFEwiS;n?%GLr1&<>?%oAeiG+G*(}_IA7F$uu0zYcy?Lmd^T3XASy}*
zw3V-GnBHOA1(|5-o8r*2efHhP-F^ekv1QZar|O#L7d$*vEp^1NtNE|gAr=L5x?8n4
z0em&+>|9bE^d=A9l{x!={>=(QY at ZQWNO3Kc^K^R8=uTeefJ6g_NKyL<9(smVg+%{*
zx5Y;O7q7-Y`6rk_Wxl0ta4wO`_-c{wBI-xY-j9w{6Y8pMTDS}Yl+U<f61DIxI;<F!
zPd&^j2>pji6R5gFN=+KmS0yJ+$6t at kZbSn_(UeBe>urJEtdD*yPugpCv*)+>*vAMf
z2HE#T+)Nhp$D^&&$K}#o+{-7JP<L71oxBibtBNoIodbTDiA;caL_;Vc<um?_FMh1g
zU6Abfg-GJY>Qo<vN-oTy$@)kSZ&-KbX3y^6uxQ5}UQ%h}Q*c`*Nx&df733iDA%@uH
z)(7huXuMa_aYx6}m+8m~5pDBX5!g9POgNV_QEEM at y{XFYtt8}(a2 at 8krdLk<fUlk`
zGrO?k+_R$EYQ~8F@&Sz7D$k}+5TE$Cj!cz}l7o4z1~sTZkl at Le_;jF3m4UnFXxdl0
z0?IfCP)@MsW~f>4i#RTP4GDPWb8<f_AOjBW7vb-k^e12$ZPAnlG*JfP>H46dyp6Tz
z3C%1AYD;;Zo(y^IgzZMmsnn*rPz*cF>wB>^I=s at SNjaK%Q4*mwbrSG}r`%hXu-0_=
zn_)9JiJr=|6K24`q6<05W7 at FE0vG&<{~kr~_Y3;&De!Vb-PqH*V4jaQmGwV4hA26v
zBu!zUuOBOgmPtojw=jOPt5|)5NDrg87Eh6Wa>4M0z5sE%lHu=?0GkUQz at WaPWGqWw
zQvk3REIUBeLQpsa!gcg)w-^BO<xk*y3rF)^=?;YSGnywH2 at tqo;;(7p<iiH;KyQ2j
zHzrde10bFC-eUQF5z6)*q4)_Vo8EztLF2y;!a^=<o5G+n!pcohM|-IA_0R`OeogLf
zrTEJXZO}IDFGJEI$Sr+u?};50?4Lis*q3|GPFqM|LHJ>h-`hPCttf1nx;kD;#JS|V
zw`g*|13J|^Qg-2^x?&~@!Gw|iTn{foUqP^tY#0&T20up8t*NmeXF-W2dj`7h7wX#a
z)B2A>-9#)E86C($woT8wsBmUjtVAr^qL@<MDWW71^K(J=qngi*mXpk)X!l&)<J1-j
zN*pnFcMy0;RuW41nco{v?g6&4069x%6L7<h$)Nd<6&a!<tD*<FR(;uVgLZ!CW5psy
z%PDV3JQ&$MjiL`4Bnjz`(xr%Av%@rsJ2ohdoXHA^tb7`Y^B_?osIpWgznQWVJSZeG
zu7<dPiA$cQugZ-{vjlsR`=eMy#62W+9~nW|19&ER-|fz1wWh6bk(-`iDb<ncBAX_X
z;Dzy!$m$VeQcqK`JAxv&e9+4?QFrL68J~zIbHp(+$;INCvd(6~`#1vYbAR0cV8S^W
zEi`8^)2gCBPqUX|rek2x?oBx at t29OO$e%ge{Fjx!ztsRZRV(A(c8k8Z)d1I6-QwPM
z%l`dV1N`CpcJuwMTY0wkL^?!xA~*bHdDM&QgoMO-80E)H0f<;IqoaU-p3pP1tG%Dk
zamovZ#MtP(e>>=)`Bc#Z51*<rzOA%w>S2}*)a%977i$t*7Qw7%QA&iYm8NE|6&*Yf
zGqmBdvRzj^vk&*y52h38XP>=c6JBISbU;Lm2tX5;eO_L;eXhJ<tzI*0Mq873$mbcc
zH>#V?HlE*XxbsP70e8yvSymi+t!~#*H(5Kpy5d9P(6!ZVJ at hb$d5T<RU2SNdH~rgv
z6e-pr+yb~M#M4Y9>dCYDXW|RxR>roEf}Cx?=|7f-0nd?S=c>Nj>0Uwp at cQ$onSk8d
zJ5b>Q+xYjBRJUBH>#o6LE2nL3(P2k-2X#)BN3?HDP3y^EfUK*$#&lwuE_DT$K_X18
zN0w`JQWgu$P3{MS9Ca=X(#1Phk&_eJ*v%R7Hcvx08_nD6cCeW8yprS4F^jg7-(0;x
zSXfoyvk2AXqS;Rn4B=O|%P7+E(6`xTG#IFrtoO`J={J{Fi*i5?>^UtO-*)#}$XI#w
zH8T;X*>bQ+8MS1Wgjq_kZdGss$T^a8RlpD>Z)zB4Oz#t|5B}OX_X6FCCAiyxu5%w!
zFlQZaHAB_h*l$-fF6S~pAvzcI<yfAlXm^!R>!}nYV=2u<kD_gaZN!^Zz7#x=1>^;j
z$>Bn4p<EGVtk$A!!gFl=NzLcTsV;)4itwvy_36W^<JH_00k at CLo!41RW07O)oqO=V
zSp$3b4z#8*F0>nP2cm1AbG5lq(G2EM?qxr(4O$Zowp|YgdA2Q?LN|YZ9?s&_2R3s+
z5un_QA3^VX99wV+NAA<URqR5wmqO-0#5~j8I8BUp(|K1RDpS78Pj0*GaTce|SB)Ou
zyrW5KC4D~Mw8;%Yf6|WKRh%WxZ^fYCupB$Vnh|q`P`!7W#tBtotVy#%$ykiSRu+2v
zj4@>5ONRQS%h|}c7Z}5y?l2mdm at MQ4JTw9b()>iLVda8_#lnnLK%jKU$K2IjP>1z1
z0bD!L^+GDzWuA?}F^`A$w$QB~U3576EGHCFO{_d53t<;Ede^1H9OHx+v`OszQUVg3
zUno{6ZUp&kTcJzO&Zb?7H&;gGFc%o*L&sy!FX_(SEmu)lTN^qJ)AF1|*B8@&gk*YG
zOB*#mBo7MS7-8?FlnP|i$EQ+_SOtL=JyK8i)Sfn0HKc2v%{FUQOSr*)VPa85Nwq}=
zkwvYYh{5TvcCtl35-cRH$n8+M#C$Prh-63zkC9>Rx=>rP?fzKK*TmMg)D%OK2(8Q1
zSWvNJSzfA}m~Cn*CFoTd{JgLcGhQ`wiwdXAs~rc0v(mE8MQ5oy(5DEYf$_(oMLXxo
zosb#`*u3T<LYcZYHe9030yTy$)fKjqA#YM>nS5$_jI7p5+tfU9{ewg+?J6>>^bNg2
zN9!^E;lYhh?QMXK;IMY>7{|P48B}Udd)fE(<BH&~g31U|dw~magp?DmTJ}vGrP>Q^
zH5ccx*a=ws%1F!azlJr;<Uo^OCzu(*4*NPIUs~@~V~a*qlGNc7q1lk^>0i7&;w)S1
zN8#dJ;eHWbou($QLo7^rv?mR*su}D4Xs|dV?V8_hOP*%J_~95v<4bDn6#K)JM6bj`
zaDj+LsfZ<NFFF1mehm&BpOl?Qm*=+L1BYbBvfxc9qbaZkK;_rU`OCN>QQ at UmKi8mi
zKN!L8zxGB^eqwfiOQXLZ-URTyOn{H{ruFQ?^$wK1_6L0Lw<<xugg4dGOm=Gy=XI?f
z&xsL at a!k*~(VB4w18-o~7YErY{Wlc_cG9nQ$v;3_RpyPH#+FTYu{V-3LM)71EnZ at h
zFc6s(^j;4`KrZio(Oo5A`NfxEm+UuO?N_doyEGqWm&K!~wjL4JubsjrgLY|4@%N%)
zaKO&OBRQ28$m7$(LeA+hW=7+4>Ni~p%e$JdcEeHW at aittf;kKZ!ay at 0%U8zuh4{%W
zU2dLBN%h2%MHF5O7YKGQgL^*CN-%71&>pY!KNmb)js3jg$F)^LdwK^#>E{(A&Wky2
zuvgX0X6V0JVoCKLfs)|KmRp}E^UjgP;;k(BE^!Zn>_)X%ErItcR>f_5S(8U3+PHvx
zJc^DqJ<M$^>cYk)<KTxbF}eH7Cj7$yd#0|Ld8;8Ec+Wg)a1il;gj_MDRXG+Wb_P+9
zfU}O{)(mZBl;`O@?JNH at DE#zz+(TkoIP0*E>T!M^ub at 2!my|a|IAOGNaNm)mWSJgG
zKIx~biHPmG)oGM`jJ!BcQ+}R_dPV<?T>$Nch8(@TnNf`TJd%+7v&DP117NC_I*W|5
zCsm<xYPs~|Q+jJAB|%0KsSu<oowe`V2LB|pwqzL7x2L)Yz-4n5uVC&OFY2$GKUy(w
z5xgt6N at VFttf;7%&7>10dMv!+$NL8aoKVk3Z(^e*M6S95)yC-vzw{A29XcEwWv!D3
z_7uS~JEPaIREnmY*kCZt1Qkmkg}J(IL|GpiI_P9q*o7U)CS}(rZffT2$6kN;1wYgN
z16&<kV3!CY*~DJ)4zEv8=WVgQ?WdZ>N)b4gm`b7t#va2Iu?M=h#qf}2u)A_HKG_e~
z0ed1R6lQTVQ0&)qdBKD+kB>v%%{ZLZ5&eu+<wNDst20i*7o8xr4E3qgp2+ijGgDg_
z!m$Mj){dMrp5^jAHKr8x_- at W<OIsAMT^IR}%eM*hslGT~Cehk%kQF{X3z at ocm%4qL
z);a^)FGgl876F>E{{G26YcX5t<f9AQNsQ1z$eUa(|5v4maLtb#T^Rphn+*J&wuwK<
z`bK~~V-l4*Pa7RNMcsdCo463njq9m&D84OwUe#|=5mRbZ^ZWt>ZZ5*8d=9zXyV#nG
zAZNxc)ZXrRwy0`cj}2+0_NhZte3W&=_b#ZE@*`QB&@)ynLJC5Pr`$suT_F5jrAJ?{
zxyp7_tV1c)-Djy}gCtzl9|hzSqvvD6a8KG<R8F$*$s;Yb227`3zSN==&9T!xM(`$R
zT^72;J{`VVYVG at UL9BfTQiVPRz%Drf$g=0-tP~#OHWCMJe2)76I4!95Yy)Nbuk&};
zU+JA2?4hFX-6~ACj4W8BMSl3|wHZ~nt9rKh{ly)qd|$lwT&wQu3n8<I8}{A(we~zi
z^kN-{osLCYN(uzBPv*EyT~YGa1VkX-J~VRG?_|OG+F~>pt3j&K9mujqXUt}k)izwC
zRTBaDWp)s0lV at ZPu}~7pPT?q*Op_}C<3!?o#>GKvutb_rmL9<fUN#PnbcKg|wM<)1
z@>Vj9^tO5PR<x2|Deo)OTZ#$Sa2`AMslYzZC%*ecm|~Cfxye?NsE1Mtcb*lLrj>lQ
zC+>(%B2S$D&`pLI8`wiZ0TI4vp=`9G8vj<3StCJL?4>JBjm8QheeT$0!_|J?@MLFO
zDCD&MrDNCNIW$g9xH~eFYvCY6Cfml@!h=M>d{ZMs!`S`n(^xfmg}y9 at EU9kF9~=JJ
z#;ctwzF#<OigafD8QwoaiD?~-{tygWbMD5!F1+A{R_5sob37tc57 at h|Q=XA{UMdL_
zipL|+R_Zl at bqIdLkgg+MOvi4zR=6OKUN`6}NDBm|0j_B)fFg=m3zhY}l=ab2uYp2J
zTs;_|d~F+uHEvWg5eeY-biN36^#o4HO<`$!&g?AC4<qyB?GI#2sF}3A{9b<CXAlAJ
zTZvZGJ5VbCg41)!PBFUpNb25>V7A*$m8d%s^6s}ikcauaJymM;F}?jPP3?>nahF9;
znDGGYNHmHthag23xFsnw*);ha4DD-|58yf24DmS8d=n{5%4QPBDhXS^Cqa`TeDu8N
zuoqeX9R_8XS{OCR82x2xMy?!y=nX7xUnLe=P(hO!o049dwK_>YeXH*{#r_8T)!OSF
z?>lvZIh=l~FO^~(#VnD1#~P?T+?(SN`ziFy84oY8`2rYDHtt0Po4|6Mn$!?82=yX#
zSbpB7E)!+`9(VUIGM4_KjHG*Y4F at uAC3HxyPU`@w`Z9pi{=S=uO1B9FN8-C?8u}xT
zMIMQ#HzJ7K*kqS9>qtf`dE{&5RX2v*=ylMbWS$WnikxOXs&!|c(e8J2Sm8F&8|c6U
z5$`5zLaK*x<!j&8a at N$0HevLzzG;yL=N}SH08yF91%1}i+LFNnoos|-9PA*xDBvx2
zXbJYJqp0%}?ulG+ng$Z-nhB4Y&33DSg1;d16it^5Je_tU%+C+jtAZ^}2o<rnW+g!<
zQFLX2RkI4;#WBwyt8w2-a$fd5DtO=rN)IFsrgxSbnHk&AneFdoDqD;0XX6b*ZVAiw
zV;hvt-X@*)!rX50O{wBO;RFw at D7?%t(B_31vQ+<MbqjYp5xhX%s$)f|HO;!T<Ugzk
zS|tf6)cUF?o!yOpXv-y`*-n_(96jjN&Ub-P_ayafrBRMXR*&yRh at 9txFA_ocVS95A
zc~)tl74O@*K6RhV%6aXea>cG8C8VjIYoU`lcjuz+bkwj}L>+J5Vx-Y%Nx+KkIYlgm
zBBK;g0+%CicyPFpf_*hV+g5W2YP4Jnqf(1f6G(F$q*@FCQ;$QyWLAuFNvQS=78?;!
z*Js1N+ELvibpW{OswXce;lcWpM7bk0Ho$>5!wbRKiZgN4!^R+v-a}c0YQj4K^i;y3
zzFWZ>hiU>n$YnN0dq`G=txFz0qJT4S2f;aPDx`f}<R%}*E1ZyT`RQYJu?xE!9S5 at 5
zsVF+FCIO-uy`a_^%CL=2RWVn*_Gchi$DYsov<7RWhcEY>zKlywRCy0_F3?-$H0ZcX
zVUfiW^7P;#;vpv61?FijS~u)2=yW^boCV|*;j1p0E*-^pb7Wg&$}<@?O;+=`;zN3w
zqn{bSplKPM_%S)iBzrqlH$ipMG+aGo-Zf|214rz+EsXyfEfTy21sh))2AsXIN`L$q
z?Sac#QZ4{BPT?M3E?CTLvYFU%n!-diodT%?gNKXP;o2HEUSdG_4tcy}7?3MH)w#Y?
zIYL(;;P~%7ga0~=4VYYjCn2V}Kss(d?pp;vNa&NdxBtY5pWXzthGt{_i9OPjraXOB
zIUPDdH4#J42Cs~@<g*Hm%CsMqQ%A{4 at K<I<0t)a*^lexKFYGU9sT@!`6|>$5^D90m
z(hk_zSr}sC-0;YZ&f6xUy&lB5VAkv0m{lMe%~*|WXWF2JwWb%mP^k^zdl$AbU%DKc
zbNs4J$3I<zr;|GJ^~DTT?q1sqPh(8M1uRqVbi`F*0#!8~*&lpMU1R%?B3r%tVhu=j
z32gryM^qS>w&*=UP(oE9ap!sytI(V at l^P>}%&YsuI|@Jgs}RWF(M8 at VkKQYefS-JE
z?E!E+4BT3;1bKmkgnL5pPZJn`-}{rKhTnho4 at _|QNm}`1!%h;qj;Ikj+jayPi0y#a
z_xr9ef!dJesztc#`a5HdW4(tvDt6rG at B~}CH0q-&is|$PrBs#8Z?UD9cdPC|kKo$T
zO at wjnpJ$d=$8GG05V1rKbUcaft8eu72HSVeyq{f>{ZO(JY8WN*4#wYjRso;iIjka`
zsG%W_4Pt$~!}4Moih<mTPm#AIc&0VUF8$nI{5->#I>Y;u#27iEhVJHu%I9utP~Q)J
zZH+LC>T(h6>dEka%4c7S3)>8NQKINb(Y6y~zmw_vq;odfSfQt@;(kT}p?Ja(sV`(?
z-X!eXJ-1tLYN?Oz_YTDZ;f|_0Ab57l8s+#zw- at Jn{y6_K>e<MWx|wQvbv1H++tgkd
zl&d|v-GWGvR$b+5j{_!4EntdkUD);C-qT8S!&Tlo>Uu?pI-1DbwOwX>qWfv+ro#??
zQ^2EiR(?FLUoud^?Fprl=gUq9A``@jRPzd4KrYfuGji+}urEl)kgL0 at Oq=riZ%<)y
z6+b9XTAN?c`|d6SU44a=6K9zg_)v>mH#Wv&ljM3zj5LJ3$3Al6F$3KZUQPgq5>}CK
zQ{Csh`R`6p9YStKeOYN+&zf{WEk2TFk$rS+^NcJ7;wu0?i%5=~kWnW$)`T*9ElWD@
z3P+#{LKjG3t&f59c#20s&kJD4*bJXU1(Y;BE3{5VOLOCzhP+QV5pt6R!Ne|-q at QKu
z25*G*E0^m at C-?2?N)n1b4Ehi!zvMKpK%^Ev_`nVfgz8Ld8!LoA&2=G2;_)CBaIYyM
zxD}d#vv(Ufx>DfX1|4~76S-B%d)`=3qH%XwqoY`<YmD2l>g$L*No27W^`#_8NRkn)
z3bsrZn`FrmUu(?dWm9LnB9W7uXpXW?1QGYFa at a_WwN|vu{y5;;(_nJE;M|*!;!Qo>
z6&*3R2v8NbDb#sNPUwAU66zdNghYluFr}d7#hGyP{(N!Kv(>8JJG#Es?wjMpCf=_0
zJD8N^)=QkKva8b&0PVoe*GdOce`0N90JfHt?<veLL@@Qgg6|Qze8UOm`XT&sw06dB
zVVU#Eml|d?;f)#vnYK~a at B8d;8Yl9rt1S{%^@cFyp%fA6O-d7J0ddLrGW+o0F6VT*
z=9(-sSBh at 1r#)XjN_kI-#tzJiALE!Rt_Dzz;PSl&hHyyaSe?>kvTJh(mtrV*Bg%3%
zyX&+6wKzyt++tzJ?NHJwR(G~~j)gs4;lm>bw!Tg7yse8p at 2nXE-Al)+@`prGKc!<v
zBoMh*gV;lu)RKpG9tG(?3={q?_&ra$P_siS?tB`_muVwGa`<MU*{1+ at 9a|YJ+PB~u
z;N9<$=i5lwS2TDEzXAD8aQ$U!#y?On{(mF*eqy&jWh9k)LvwY7xJ}~+ at MIKBqOf0v
zNW8j@|0KAY?|`TqCB{kvx#ruEq(emi`hJ&G_u>uht|8xBJHynvV9T}Rp{cK*Yf>!`
ziRr92896k;8v1qVNJe3OP7i}PtNdumYWd5D*iH*{RE{V)Hx*M9$~k3POmuQ0EYx;9
zyT*h!0m!4d;~B5;xI`s46$JxOw9SEUVzOUXfp{vy<=F~fb{tegWd{jfHBcSO at hE9l
zqPo(C&x(NB`@P{f^KK;^2(C*GR^k-*@tpm?<t}sqxeJPpBR^En`o0rLB+jbEu39El
zKg7#6p_AtplG!OR0U|oTB_E*tVlxcfH!1EXDExwb|H9}6uteHS_)@kn4dRh!x!1Kd
zqk3Gk)M}UohJo&eUQgzt4 at -xu&9)k}#vq&FLnlqs3$}Z+k=@)oUO>_s_NK1L(zu0f
z8M$B{G%P at _KHBk;izKOw)yKLMno-z<aTD_S at T=~ZzENE<Pn>nKi?#>;M33cM6u(=;
z<mg#luvU%E$)D`2eeIF%>86R at 1v2HnaCtiP;}k-My^TxobS~*qK6#+EC*H7$8fr|=
z%E#*(R9Q`FSMPi&J~xXr4Fh at h4udk36=Zs<>)y*xoLw?jo#Yv}56L?8`?Yi1GJ(!k
zuWfQ$MoJBo<9 at uHq#R%WKsUgj5Nlu$S~?Xx)$*|818eJSHpHzB!vwp2Fm0tsjRLiG
zu?S;5X`j(L{NN16ogtVV<kBQDKdzr|Ei>@yt&dxggZpx>q)phfkLwci at P)BnaZGMB
z-X`}!*qk7CJ<gbBX|)r3MUe8>uABk^7~dw1+3|?Un!|6(mWkT0;(I77k&Wx3*Uikf
z+I(eTEDdwh^KWuZ94(eDt7?LkHe^vJG%bfwN{SGCuO{uK#u=GjDV6nm+7o|{GDV_N
z{OpuX3D+f$C^-3gvHil{8Gfb(@;v+89aEe%uAI!S!+#>IG2hD9Xo7>VjL&!0RAaW5
zkh!kQd3amAW5{^(W!<ON*0_`QBY at AxTJ>?A6JQcJWXUTKb9cJv<0Oyip*<*%a}Q?d
z4v+ABE3&RLr>4a(;Q64VEN7SXs|bIv^iyWaY{wndjK<`NF_#{fVix;{?o{DTQBFhM
z#ZPuDbx`*$0a6vrpO63s#()|pcOak+Nm(brynXx^vi!|$7LS&3Z+w7^zpd}P@|7G1
z-w(rYTlRcUU%BSrGv at xPs#m|S0YEQb$xizH at cnJee(UM0cfVzZ{bt^2CFfuJZY`dD
zU%Vo>2CTy0mt6VxEY&|U#?(#kK*y|KfjDGt_iYHO74&}pKhjzgw0F*-z1XGuMz!kP
z2wJePJ_vGJrHE=Z69-MsM64pYx^%OZoy1?*nBF(yQ;_<eW<&h;pVkLBt>9<J_wyN;
zAj~+X61fx>r&diGRqJ`JcsvcJf7U~dH8Tdv446Ca<{lo)0xNXH%%+Kg1$(CHE+g&Y
zSkg2KHwmTTQWX&;E*|G>!^sg0EG0yInrm}y+p)G at FQt*qz}wQmARg_vp$7_#!9F|M
znHkEajNj%=1RG&RB&AEB3obl-X$q4XWr at kPR2RIim6^<=rdde)+0SUgaUrkNqAkj7
z?76As4C_=}xx`Mr0IJIb>`x8`^KU`2cHd)0D}%FbbRb{?&~LbYCKV(ANd+;$g2Mii
z3w1xH3poErG=PUxcH<=nct`{Ql_884CO_9P9b at zxQx#X at F_iwjRj#6$;w-}Im(6_V
zF5W3i8#Ym3gH^B}R9v>W4;?hxEjCGS$4jA+$vFckg?^eDvcQ+YSKxuyc3-ye-^z98
zIY#GW+pTn~nAn{QJ`Rzu4-j`rC#>@ak%+(%`r{L&pS2<e8xcIQa(}`fzEM?7hZ+%~
z`H3RFr(mkR_B|%qWOd;I#MogQF|Is7WYv?X)?WVIRUo}}WL`@v^$q8)W)nuyhZojI
zI#E)+whw5^UeD9hE2M)3H#-jOja~K<i|KR_lrd^jIdT2d>##@lwzwo!l22Yv=6<pX
zXz}u-Cv!r8A#B<1<Wo3YbK{MiAFYpD()&V at WKI}fBd^2Lg~Z)O3n#!Ykel%^gmcs<
z3(_?1?7v}8pEi4Sc2Q!LQ<oxp*c{;|afSbswYmJA1Qi_u3{3!nbJTap>atEOm?~gb
zgF=>8jWNPnCU6AzN2gCS_n@{tnk03!k@*yB&N-PU7Yk}hj$^9xXW{~kaC?iw(n=#|
zo8`AvSwt!39(E>ASNR{SIc6AqDe>@qS=k7!?hh~a*mP;8Cr!=@aCk@|faZO+q at Iu$
z=wwgUFnOlsiqH79>e)JjR8E9x!H%Sf20Mgd`w#x{EX_~<*a3m}WE=u=irbFg9$!S2
zZ0{`*;V+|^C7&68AW##V8pUgfyu;7KQ8hzV`!z3F6T=OTYY}f1b)PO2;0#oivO}zO
z2(^eBMb;?&Fg<4!=&ztH3Hf5Vnz<zp!U`!XQ!C5Y$_4X+J}s>80QqqLyfnXGgJ#$f
zQ;E!ja8_J#cc2{kouei`Ep2r}2~)&uw2yvVmL<b`^sQI0)}$A6q}NW-zwi8pvHbpn
zUylBgGcS3buy_N*f&OD3{gy}d;5k$2b6ZL|g71&42BMS5*6`*%ZZ>s4U9$-jo~m2?
z{@i<C{Eag5KXmlIPkZlYRoCiUe6(l2Sx&X+D#{X~v!bjgv$Fgc%6NK13->x~;C8GL
zkPg&YcOV}i3%Z;3*ZxnE)UTiY+J}><FBDq)2q+}O4Iu8gtMEhS;MVW`9q7+YJx}eY
zc$M-ay&V3&3oWHo(;#KURiK=BBH5wmn->iN<2xyi=S0J;ZoE%YO$2UuN>}e)>tlvi
z@;uyN_F~a{RZ at 1uM8hH>s5>PxsQ2+Bd#vxTu|s+uTF|`>d_V2SJ?FKWXO*m93|<}<
zlATEOSUXwsb|SZUQcM(?0~bHUva53kn$a*gg`W^Qs1y3WPCBFE`|llCR(=dNU6Ep$
zqpFuzZz7Z$%H+|TT{%*2asjAVSWfKr2f#p$Qo6}?|6Ny+?XQ`uzv3LweLJ)Sm3rf<
zU#g-iUZR;*1XiNc)Gt6yn0p{Fif;4w8|r^{huzBq_q77Dc}AW9hGxqWV2~szsMohN
zk1>HMM$2Br1EgpxG7ye3g5%TGWY8kOpsOkc)YZcR-$e)CqrUsS-xzlPe?ERc4O$b&
z9T$4Rbu1Y9N_=4DMMsPSyk*nvNvY~BUUA0nci?XfwBLVlZ-4%uJW6msTu8rN#*`KO
zV9XvUdLrdNz2 at OoR8rKDDy1MU@WAfBA3dbUFJmxDMi{fF0xq96x$5CoQB~3w(St5Q
zEdG;2aBsH%rpblgtFUrUcN8w at 8tCeNl}hF~#2HT_WfkdRX*l{ZRB!a%{3p-h?^j9x
zo$v0l`d;GO0tr2U;~*A%f4sfUudb at AzmAr@s>@8|Br(PBXE!yuND~yhQbf4HPP#AP
zewB9!X at BvINM~i=Uh(kT&x1hl6`JvzxMI2k{i(zSIolgi=bNlFN_i&iS7dYdBIlrY
z<6YY at h%B8Tg}Qj>Pjaq)<H>ma&4q@$%lpb%ulwG$#GN6sHn=H*u|5QLYP}x3aUjxN
z0jW%scu?(;P{@+zs~}k(jXpGk{v`*zW5->kt(ofD5U_9g8GN1Wha5*FO|9FJ+|UP7
z at FYze4d{FHW&ergz<P~JA(yMybM#^Qz}#GHQd$6gtik%<G$gRoZY~h-Kt$QUDXrv?
zKlCysa{tmi{WY57Us~ZmbjbgCt?@6d at NZ@p=zmr#{2pKW`M=hGg<1VawBe88iT|sA
zHPWwDCI&cbyk6OgNp)FtE8+&-NM9F^6u0x+0L3`0JU$)^I}^#R<&S#YdJ08?ywUs%
zP&LFVn|l};Ox%Q;xQ#9YwbeEkk<XY|`*!8sHgHZ<gy!v#u8~MDCcRMq9b5Y&#`eGQ
zFLu)ZWACd2;@GnEo8T_No!}naJ$P`p;7;T25(usdBtUR?cS6v{-Q696L$LfhZ+CWI
z-p;<6`OUmpOaB2?b*rlD-a7a8z2}_o`^x=5uk|mlt-;xy8(??Huh}t2e?hGORZg!T
zu$6x&GxGO)Vae}b(VM9PN7w?DaeH>`IwuxSzbHXXGBw7FS4DyoA>BQMu!U%@0VJgW
z3+JLQUY6*cOQQK>IgqzgPB~i71-&H>D4t%uVMV%w;U?mPP#>R%>md)}AP)Cegv7X-
zRtY`MaN4bce6Rv(haF|a8c7)&?)D<9;)^E(NJHmW;{}JeS<>wrVA~WeASJ>_XbW^4
z;~Cdc*An2VS3d)VUZOfFgQ3ihS}-@;3T;S1C~ZoMUXekw$$<Lb_NKpaAKLnh&>`DH
zoS3c$a4XQB%Q)J%c4I~mdip3<mfe2s<I`t~@;e6EmxiyVe(a}!wR`F{Iky)xtIdft
zErAHKb;9!FLLk_aa at oHz2l&@n0sqWx`rnW-xcp$8ze+v+N9v9JrF#uEG$wlt<%SWA
zu3Nr0HTvQ&6xP}dnJ|l^uRt!7=sKwGA+hak-v9D!<<)1;^In(|?FEqalTM5y at q6iG
zX at NeTKK=w@<l5?xF`WS<z2R39JZ^$H-vIJK8J~+)f7Me|o2$Z)Bpwc)rRIdXHjya$
z<%^95(k)>^d<42MsFdbj at lSsPXwaQh8z)>C at Q_bXm_SD1m%G>zO(G*@Z*h}GBg8tw
z354<oDb6m+$S&xvE_O!7eU4L*B+*5aG(xq(fbjg+h|ZJ$pZ`C4#eZXY- at T@PGvm~M
z#WlZ4zxXi+?O#${{+R|(N1H2U7_Ws(Cz1Oh#(;OSHoXv)dqErJ#aZCZ<N7^Fu*<*g
zgbpCbM9ZJo)Sz6CL+wSoA8}86gVOLNVY$ZQ&*=4zOm3K{wgyWl&oBl|jXrGMhX`Lj
zsiDb$AukCni^S73K_89L_A%e{Yl^mhX`mye#E1MEMp3|@)E6uBZ;y5SY1sdr5Q_7^
z2R;7Ak??o(VE%}E{b<z_MfkNfGwRRy3<+ea#p%Lui$2EF$4bHCA%d}?;AP*=fzbKd
zchn`=>wj9r52hsW1}6^Qqxd~?{NiLv|IX7N0)|WmjC=$16r5kCe?9pQ%j5wAF{i%!
zCenPXzX1fnxJy_t))GH^1WeK2`5jZa19ldvf?LhZ<96i!<~wc^EPi)y6(jVWSRWaD
zE+qJ-QDFGo&u94A4*%!uK~n3~EIrGra&`q?WiV8RQf)DtB9izUpmWz+L1C(dgMG=^
z1L>hxg5b at h3)WUT2JzOt2t-Q=Zq6Oun&I1CxaIrJqU#a6$9i&t8e1aV;&QULtKooK
z!RmG`j&-*4g$2}p388!2mX%KJwn$S1hK<Clm1tXyt$V`N$J$+d-6ZA$J)b%nqoy+>
zhBzL32<B)hqV~%S<Z$pr0;A;)lpK7NAIjcv1Qzv-`n(+1-%qe}46&Uv#V@;F43ys{
zki!|SkCxEfyrU>>6j|LQ)F4|I(9mp~EZLqs6dZ8CeHiy(O8Gh>L6K(3I00KNS?8M7
zvhs+rf(P~`w|xV|tN5L&Em+{VB{jXk!H;U2J5J}@m{qZbhYT8dNz(H^3XDGaH-#ol
zEbmrZv4p!D%%ejDmcDzpnEvu<s*D-w^4S!r%tVE%MN`waJuIJy9kCj(K%SL94r$;0
z2R{sJlD`?!zK1=29M*_`7}9=0m;X4d{Wzrk5 at Y&tSX27>48IKTe?U9 at u(lifv7O6Z
zuuDDT#2HJ$q6Q%nrp;hcgYX^50kEjSD9qBIe&v7u|6ztim>+siKoaWmzMP3^na23_
z3uO+1XuN1gcM`Aha?3P~G3P;cY^k%Dua?ZibNB8f{#ec808(5+HPl1_r at Fn;ri}tH
ztHM!wsfD_4)=L#F-AL$YV7x;@ZM*&hT;?sLF#a!@XCC=oc3<(FW577f(Sz~*+~IUn
zH#%u2b36X9YkaA9;n%BaZ(UyUCGKWbc<YzwT6mJR)Jml(J<FqnDnoG^4Hvdk(n=#~
zOHv(UWHyJZ8ccalN+vR5lc4R~#Rz_*9pKdf(l<b&oc#%+2ylkb{|FrN`v#C1EqP%7
zI^^OqDN73vo{MImP_W!vi~jG at n*K{`zkg<V$Tn1CeLOs?vN+u=H#a#J2PTB9+{f*@
zIZnX|__J-2BZ!$@3An3gWz)bzN1b8j(#b}pI`^59u-TZaq<8 at l@(G;GWS%u?Bm2_^
zq!Jz|MX0xLYZPJm%5UmGo!3eWOWlrNp4q`rDzl_IB@(~uxoPh4bZyQe;M25?S76a+
z%?jQSjI<s*t{Fg_L3J|)+V?-l*L>GY5?Us<j`A*F>&7y-wxYH^X-MP~jhZ~q2B~Uf
zZif4{?D&POEbVHGC7E1_5 at w*Ir)jXuC*o6%^w8k;>hLxGsOFX_r5WxX_zRBoH30(I
zhLfS!)q8c0y{B6rSJllnFDW#{Ec54PkMD?bTkGy^&$3mQVsu at Kz2fT_$HXy1u*6h8
zOk>pthc+|_>YDhW7W+b`m%(~g^PetsoWEQ!7KxWrsR-Ai^t!7#+lmE7v-O4ZpP=4J
z2Kqq^vkBucu0_u;(~v2~^<<(;8o&Sw3;xWS>7V(U|F?hFU_88ysmI}HAL7UHg-COO
zIRVsyUC$GzkGwQbT1y8t?BNaU2S%?*uc2H8drH&@QlJx6_*n&7+ds2P#=J)vL`C9r
z>OB+}ziMvQeW;r34SLkkd9oU#obFCy*n9v+B77*bxVqg=zv9b(N6tXPf`%eFiC+zq
zX=&g6tRX6gNW~S`NA*kyzg8IYVgT-9NRWUAZ=PGjDyiMZYgMgZyHGIG()NzBA<9Gm
zjj-~TW^?q}l15Ww`1DhXks4>nLgQHg5B02?dQ(dyZgo8i<hXULF!35I?gPqv{BrxV
zq>*>?>l-8oCOsN+lHw!^Aa<l^T*~HmOw3P>$OhFncPtNw_LqY)uKB0m{RJe)AF+b{
zKYCB7r}OR3!AxY)CgcPr!kw2T3h23sF>7}N4OyCc<j;f{-a(8Yeg-)T(d`xw`_k?6
z8CFjyH5!@6n#aN-e%)%L1MIVNm$>*~44-C5^Y6CXZ#FD)8#sEj4_PlPh}Z;xM-fa&
z0%PIqi!y?>SJ~Tp*V<00HK^NEeoaflx9DK(r$)x_!*>3UzL-DMh4Tt)gXqP+FI8(Q
zr?KQ&_QiaQiH{WZX}L2wdGglf3W~+31%Bk{UR at uBYZWVNMn9Ml?`t^VJO<KAXl|LN
z#%MO$(ZDa;8Jy4+n0$=@(nqogZ%>k~MM4pQgSPqkI{(=w``4&y{Gs;r&#v%)_wSP)
zuTFc|iOZbWc*>f}Um_KSVlUwrdIuKe&Awx#Ca8tiK8XvAI_r+!Fj$SbuJYN1_)@Gz
z&kNsGmdYxcCjq;gk(^&VeBH!&+1i>rA<d5=5s*cnNGCjeXk2RZjKTt&10g#@$)END
z;>A9$ZfoiM?c;%~(3jLP;$pMIA~W=6pUL;Qvv)uP)IE(N9&%~LoY1oTqKaO22uiH?
z&TXXTavw_iFCvl0?4Lu3jrujIo=zw7U5AUmQ4H1T2O;dwMa#QGRJIGgnTZ7ZXXyU7
z&%FK{)DJBc#hTtbxfv}udt!3Kp4&PmlkoNR{!+vKU6tK&R5+oqKgR&d>V?Q9VY*1b
zy>JwkViA at w00lrq15qgvCsElI9-0BIh70gQi2qeYsUR<eFZ2~&wida)8d&NbRg_Mf
z29j3mA`hNDiZYIrA=+{DjzvIYrQl0iwtBX+7CM-2tAaGBmvjp8*|ZzA!n+R}q^&hk
zlLh>l0{y2kijvCk|3$&X{|4{q2PTC7?0INuE&i@}UeR?DqO~Q%AtID+Fp=gJ<YFpn
zPl>wA$$5E6sWk55L{r)tOHAJfg*9P}z3Cxqi(-1%k6|AAc{>6M69NJNEXRL;`w%o>
zFQk|sQ&N`R@@MqiU at jVanS`{PXR%;*LDbhS5m8PraFV1kWK2xEgo8hW3OQO|icSeg
zER``<V+)Qwg(suF>&&<%elwfgC=N+KuS>a9qJbWWp at syBgnsC=-)(N$+1J=wyJ6M0
zopGVD368xi97z0iZVp<S4Cw!gDCR%yJF6~T(}yN90=H%DYIHH(B58qHv;-v2$%~>V
z+ve*1E(pN+NufeFOTT2={`vsPuXp~TrJ6N$iHmJ1UJfqJxaWy1^?Q{Xmm at NOjtORP
zV&UuJE_jBj7Bq^Nafx6KYUz3S4fgyVb*f?df+H7rL&GMCXygv`$2nNY8AuN8&PR!I
zEWa5Vu+*@+H(mHA=sJMCfuqk?p6ra}?cC{VW9vMSAH`gKl3k)AhHjcaO3t*mFJqNu
zX-4Aw?ehA%5`HH?AFlaLv^?hn+d}xx#SYq>JFjK0j<_XOgfT=fnWJxGx3zndrciB*
z0QMFa2~Zuf;nmK0H=mV)=n*KK(WoVDjM1*lmNb?eWQTnQ1F_V8*RqlJPz03hQm^9@
zGL!WhSa=7KMj-Vv(*J^SR!s;6oR{=ErVAMJegyYE0gP|c;sxdv3O1HXT9+ZhKThgp
zaTb!9k^*fihgo{~jF)4F(^hmV8Yav>X@!fyc#l1MXVJTl=NY7W<gI2dFsL{H^s}Hc
zs2FgtRpyc2#k{+l=67|qglT;!EhX4=iDF9QQ%=)CZSvI(l*IeIK{)2?0>tRyONkf|
zu$Ge)E#wz5*?)3K9=LSoagl+%1b*siE;(zW+M~;Uzz9(ejHv&`(yUqeUQ<+Ez6BFd
zx5}gtDOaWfti6ToG@&Ih-0UG3T%5wUR<X1oi?U at as1h_0&C2$5sts{@h|dapMt!<c
zcR?;Jw-z_rjGW^3_;Lsi4=1wLvSz^AG?2b(d at v;qsuuy*RQgaS<FZ)vkswM(hKU2w
zBR^b1iUh6!U_Pk3V}Eor>C3wDvQ_|g!2s++?Z!{Kk4|QOuuuQWh<JPVx~DCoB%o0W
z$b4*C_bw}*n{>I;4muj;Nt#1EFEQ=-O}&DS`%ZoM*%_ze at boASI;w_1We`aFO?wf<
z^el>eHjUr|%}F?&yW at sMk9lhP-EPb#G*hs^kflomZcXlFnmr?t82##2^(e%Q;FL0`
zt8PZa63AG3`8GaP{Hg)TNM$!a&!;#Rk at h4h#6+jOswWAGeTyq}fw3mm9b_kxJPp=O
zxWqPAIhE;+;>ArkL_lodH?{;fkAj%F;wfeAyN!7e(8q^e^IUx#lKNd-T*Fn7FX`zM
zFuawX@#@1>82_k}X*k<m_F|pyE-txXLqSeuBGBy75A}e=tPw?U3dq10mkJRyLW&+O
z;dG#y*BXD&K7Xj9qa!9z%_=k9wx44QZ}??I at EhPA<i4Fq`9gP=n2!h1P=yh>=5}Nl
zQR`ci)Cn7J1#1^CqMYfZE4G0+jHS=U=WzQFeFZMoGl7iH5Outy%WY8 at HyiKbVjCI3
zOpW#|L&gWlKE!RARJjH7V0!TYO|mzZx{<aN at t&(*kC-kvVvhP)b2&4Ll0Y8^ftnDm
za5%Th9znw(|CUScJ-LMLL=w|zFAF<6$S1>fC)gHm#M-JZ1oqOf!1>qfFrY!ZQ0iF}
zp%1wyo^*3oFPISZN7DULFrD#SH}ormBqLOpM=WU- at g(5-Ks at BQUoMJ9Z_0Xf8rCh!
z$->PRkS8m!LX<s$c76`JCBd+raD%BCO<x0cVz^KBs3T45Q##@)Y@%&B87q`gt{6Cv
zK-z}WAUSd6#OZa5Ohg}n;%93uad?aF2dz36mj!LrwqRrj7Z}-r=6Bj8{GB!T*TduA
zGFCeIGM)y{ym6TY#xK(zEiajv8mU!jy at 9O<xEABvbur?fTP?CDDtpSXHhu%R`zg{#
z-NYd!K9bgJ*_t&OTjhJVLqK|+o)yJRv^sI}`YdNNzcU3g9J9pXC&ZNJZwQkJFX*<r
zp(QR`Y)4*L%s#*GR*P{usNVFhT<F1SolCa|FP7C?&P7g$8!;o;lUC;5Jbq|2zYhQ%
z=q<lPT+r8TXIxBjEK$NZgGTQ2I}QNB_;Y?wsF9(6Gvh73Zq4{=eMMpHam?zqO~PT-
zr(+2Ipy+&(U`2gw_udNF&KtbVhj6<`y5IuhIC0WVq;PFO*C}e4%{^}g$EHfd`wD$p
z)r%gdcmZ)oLDJLXq#}zXS49!`s+TFMO*D#*ylYWzGoC&luf{wqp?hB*oo8z-T=bTC
zbtiKsfyKMN8cf)%#~JrG2^S6Y9z#=COz$wSk>Ksk6NlHiDK7D6N!WCSOQ22#yW*op
z9CF-&>Z(JwC|)qVEXqKS<zu-l at q06`{?TKtHgUgW+5 at SKOBSILL}(IzPzv^$(;_7%
za!wyhjE}u2aM+c?dX<xPiK!%I`b3RmiV!AwE at qM(^^y6q7)<7HW&go8KN=UL9v2uh
zUFD*qRd!h{wc3<66%5W8X$@12ONxkjk3K9AgVkyM32H`L;-j5VEoyP27Vj+!`DF%5
zlFChR_S~_o9qScXiip2w3JfrcxqwM%e`IJnCC+sttPqDnm%zhvly{1jKKP1o7BN6j
z4Da3C>;YW4t0GhO{ZQ7nmWrWkr7?iDIGrO3ZxM*G!X?(IbCH3n4F)3pV6H#z{gP7t
zH<c%kk6TbOQ)N3j<`_^E;{r}c`u%rKLF^F2R at l{6zHIRWce08#0Swc6b=7YNY(eC4
z8m0GaS6-ocj|<bAVA=#}w?-YJP|&k#7a}T<=ILgIe*2C at BEp(m)p<*Fm*;eC(rae{
z!85*MSrR7qXr-1JZte at laO}^09L#9id)K0qVs0KzQA1cIR1)Hk=bi}RE8W;Q(gpm)
zUZt-^wR~Ti7^DK^9iKa*@D%X#uW>wh;`QPv at HW5(jvYZb9P*TCB*K at sSX>R3q?;*f
z$%`07q6#TVij)q=gSuSn&q$~UGHomI<R-f7&|sCCxqC+ at f`&Boab|H)rmy!bq!!$-
z21)r>iI&rYmD|E4Zj1_T;SA03NS)4Bu^-qJWlamDGd^sc+UU=fqToIR3N*v*wU5ZN
zOs6b`*?btYN?xjaZzK`z^<fJ-J8+(jyn;xII9*$hO{Zou-k2l>D%N;7WDUs<2k&dZ
zRS6#ZO>UBGG)OakK|OpBF84X191f9M!@)3HT$(uV at Ui=)fSCNuvziZ4nenp4s(i^T
zakZcEhFOJ4g6Sb#ybTR>*+hI3BZYN(>J1_KK+Csx8ZY3;1&V{MeZ=HPqq;-#EekCQ
z(G2ap;JyLWVTG4QUP6W+vM<EB<?HCe4T@?`b(uIeg1JFI%6S at ZXaSM)vJB7}3}5Ke
z)vY7FNpG?jv at 6xApE|NB;qV&2o&Z at pACSHcp_5>Jnue1GJ00q`>D#nZ8tAucR$<$=
zsdj4q;3s`Q9sl_0^zyNp2=<<`$vutIq8wvc7pmDp%0FQgMrZ{0I=^#0g4PAD6wHzE
zVyF&p>vf3=al7W_h%H at G_=dub*hY-SEIt6%##TxBW?-v+-1Rg{g7{-2hn_UERq|z7
z3h%=EGTX8bZlR1utb&Uh6s{!NzUifND+ at z(HL)qaX3@?xrw-}wiBo;Ch9dMt_3^Au
z7px)WKXlm^0H;;xpg)s496C)*=L8PZToS3(0&T32819>MWc5;>Qf$8M?Zw-`YtJ1u
zi+sgY>7nA%daquEM&6t_Tf!ub+v&B_fTf{0vlG<wTpLkNd{y&3Ry0F#B{>SumN0+X
zl*Brbtjy at +1WdMR@osN;2V$@Ppm8iDN`C&Uhi3JR_qy(FGAV{JLlaANTuSlzuzPa0
zOu<JAUD)$JeRVp&%pH^I!E?uq3+h_z<!4om6SiN_&GoBjE!UhEo*9@!fzxK96z|j?
zwrdN-a`MtGDp+&7&dDq(fEhsn(E#o~A(@V<xK#In!RF{=1yb8Yj`@7J&;C4n6Xo2w
zqh<MEQZe}GRCRdoh?S~-94<kTvux^Wu9rdWJ>oKtbQQ8)!CB2{z3mu>9o``}tAM4)
zR)GWFOI2@{c^KGP#f=rfHvn%^cM<uC_G<#s_W+RH2g|uvT`OXu-vC{S>NsawvP4};
z^!QDZm|pX`JHdd>G`>}@sVHjgx+(9jFzOKZ%54!|n>e<KXO-)Tm^V?Z{i-roH00EQ
z^6OG0Z_Wx;OIFbEGRRs|7?YqC0EzuUU)qIaq)^hrM;fXclFi};l#ihW$fJzt+OEf+
ze(3{C8JJ%IR~}$4QSa7KAGw5wz~TsZoL?S;Jl{N=f+0%;*+1<4lHT&ek-xV*XB^*;
zODWLn1C#HFJvy;)X5IU28}AI15-&xV-2Y+O7kK|U!^MA8=!3?+7?3I}D^n+wbA2+n
z5Vi>TyunTAsd8k)SaOIlyeyEon=5Kd4Y=ytE(J^6ZI_$but#{w5;5@|@v_xft0ek-
z6cJURASpH8YtqHhxFVTr!WvF8x8_P`PqM6C at +VV$B27+RW>4Rg6 at UdiWGuC1G7l7}
zTCA|tao`KZC43riqo$`KGJY8t<!6?_dO|>{iTbh-7OPMkl6HPCQ9aRYe0iScD3mN4
zu at ka=r2LaraCxw^tZciRU4B<JWURCqf{!pY<Ox>2IKb2 at jbyym16%fvB3b0#gKl;Q
zEGocLoT$#(<kQq{{zL at hLKXKL;4-;d9H7=#SvLu!sA~>33kK0S-GfN)!UI<%Dr>DJ
zLY|bGMaJGAy29-9 at IP{7gHNuisH=R6XmRCn#$M&!b?h{G=AJd)Gv7Z~dbBb36x*md
ztj{>!L-5iz9FPf<WD1kaeseT&Xn=K=&hT8`VMM>DXm1&RtY#oau)l+Qi~pGNeN5iE
z!;N}3CPYG!yOZ?PCdSGfMU_9y$zX|Z4w{^Hgj`kl=UEUCV?I{33ulY;a!3!XJp&4<
z at jDzj{8CA;4a0!`A;nTaiel3jCX}BeM at I}(aTbK%P4fYv+7^WuW3KODxpp at Lp{|Z|
z+EG{9j<}~GVd(8KwG;9E#XU`RWj$Ehp+3fFfLvz7fya!8IzfFm14W}tTSn)`)TU-Z
z3lDn at S0W&F^^^3mkDR6Ujh$5WC+h((IOWyUV?b>FL)@4jfc{lDK>JsYELP at wzC0`K
zNVodwj&+MsiOjwQf9bncREo<|T+;A)%5b=Nno0Z6OyPTIIk0MDswk*z2bK%_W|;dc
zK>(No3`GcktmH_m<$YEw^^<7 at mJx;6z!HTDsQP;te|C$U1KEE|0)kh)l!d#L6SStC
zo2E^&#w6uhi?!OqEP*i#%U;;^bg!=Uc=f!ynigvF0Zg_?lSgKel`N$w%?()!Ns|p`
z{Qab#h>HeuX=X;@3!(bRk*RenZ&L47_1t!G04%<;$~>`!2r2{T+>kZYhwM{@uhVQt
zHDwnV_(5vj`Ud3fxjE at +>cA1J&F|+Nk(Wbe+|z6S$o1Yc#m|;wbuGG~2xclmK;wFU
z at cF2nIImcIwH&pbRTewFPHL7lomVUnMe<ZbOdR0wi8P98G6x^@CVvvB0W<GKGr+y^
z&K{Sz@#?Br8zrj6Dq(33QP%6ElCm67BGc@#Fu}tQ+3kX<=pVSeOmD4uw5C_llL?-9
zVj at 8dnU=r4plrEQoG?6hO1pD<Ja&D22kst<lNS-l+LY0cQ`BmAjlJ|2<Z%)oax8CO
z%3%c;iI!eh#_Q}WP=Pbnk(h5 at IFr=*6yLFuaPffn{Jx|fJ<!`Aq0mk$!T^_}@>leA
zmUS2C7Z*}Nq?A(ay~A)L0x_7J5e8RDu02SduG`W{Ufzce38|aTMD!BjfI_$Y`Q^C?
zozVIYgxKcLyL|Fkr}@OIj`;^eo%b#6ND*}2U50PO+Ka(@d$xsHmh&BS``CqoD^2oh
zZ$<-=rStb(c}*+ptLmcRVwTnLmM*CiZl?BS0G%-%+L#*YR&t!^Opd%qBqxMN4|Lnv
z*_OB29oKao>i)-3^;q;bfdahhQJ4 at herv7d%1t^c1Gro7{fK1}Z&&YEqGZ_RxDh`l
z76opTAr-wYFah{KM}d8nojji9Px~pwlIp`l>Z#ep0J?`)%n}idQ`%&GlS}Dk(j1e~
zIq6qlxh|iHxL%&a?{JZR-Q6*(S4=H9S7z2+)#51oqQ^+?$g`_gJf%lmFRRB_&lniT
z;cjEI<9($0(|gLsgiHRE2KMAnz>w-6k(WQnl7p83|L&aqyPU-Tr29brzGC at rSWy2F
z at DJL^qJ1 at gx=twKi(9Z})l0J=pVv7_b)TbRDAymKuEbqSU*a9p%NMN7*JM)FlQFIJ
zMa78imp=A=z7IH3*3!$})R|;ut&}FW#lv+K+JQoogz;zmEy_~eEJtoIZm%zO5b>qt
zNp~u-kIr#SA$hK5YqO5jRNV(k*EvG#so4vX$+S+Y6ho`&-81=xV>7;7-?_u=hqzH+
zAL$H40|0;!RR-LF|KWkvA8ZCpaP=#JUa&v-SG<6~t=E6UeTcuH?5qCq55an3i5~Z*
znKsurV2wvL^3Xrq;nVc=B+gECAzjJxr&-W18TVi<tZyQGpLz+|lolxf+6Zq|I|dpy
z%O!M`Wo()k2xeTuE~?p4J<g_A57x6>MXw$iUf6>Zrk;Kg#%EV|n2hv0JvVnl<?in>
zCDBjd_ll(j=YG}+J2{3rj6JG+#Rs&CD?LtD3c0Qk-co5kf(53?X-Lefo09lVvsoa%
zoUd*yg0obyB)0D*$?EIH9NZ#9Cs%0>HNT5>_yiP0wO;lKSv2Ul$J|%f_ZeS0Lfrcc
zUOFz%6Iiq~kZaEHkh%%<T?$@6yc+KXvFR=frMPZbdK-YLE?guHZxd$bAN~Nt{2q1x
zX`FwE!TwPIXRN=- at b_PcRQ{WnW$KvNN-I{p*$Nyx$7O2h#?6TwYG=kafD%}B>eCG5
zdGMMOW9HFwpXBB_80Qs{{li`cr0RG1TY|?nFkS5nIc=BNTjYoun<4KW&c&P+g?HTK
z<U6aYaW}~cKVJ4-=kJFjzq#$t@}KSV(?0(5Zuhf){Olk9v-`(yNpZ&>!oZv#0xqcc
zxM0w6_oQXUY_?SYOuq?mQ2gSnu|KP?uRMUnKLgqGFTQyU0 at JFQqwEmtY{JB9wvu{Q
z8F-BdSQHTKw%u^u?tjG^5rU?K1ZQP&uZcicYhddoWt1Bbx!nL2%BXzFs!m-61U=Q!
zP2V#P_#9B{nR<bHoq>3vZuYL+GP#p??>dZ)dRZ5Xd<E)>WGm}=m#09~{=Du=H&HwH
zyrb(kK#L^e&ALCwZb^IDUf$HPc<*yCorAgg>?~@kaeg7;MNZ93P4iTvmv!$lpZ?{r
zV^OO|-)HjZEPoD~5+9+iCc#{1V9A&4c-s^>I-R{(wi}gN1++cw7ZF4c`(oq(QG;sZ
zH2aKL?hIsYx)RUeoI0v2zW2$Kw8k`sH4rn&+4(m~l9Od}wYe9LaubHovOcUZeh7f?
za#8=Wr5k;Wd(=Itsu-9J-qVWvaq>Uk5s=jHuXP^sdO0P0hkU49`G~Xzx`#R!#{Z9E
z%D*+4f7~n!UL0%0z3ljQ$$8fKuB}Se#kJxCf35cuRO1^(STS)YN!e2dgQlAgl=Qul
z72 at hw6olc8SqIWyYd4n!)kF;huS?|7u(&CnE_~O~t72clu*A<ff_``5C?n(_nDg+x
zML2}e_jq3pAYbl_)BC|7q6tU=Ho(&>D|&jBwun0f*#RGE#w;?KB?@1AMNQP^6#*gq
zbfqbVnqt$m$1SqR6GW3l!OxBsPcE^Bv=534+>^)Y5o?k=bR=Vgl?FnH99dEL at SA<s
zfg}pecZ^f_N+YRQ?ZEtpELbA1QJ8KlnH`nty1I~Uo!~PwQ>i7#_6X-50UxW{w$O`+
zQjrqUwy@)Xp7vPy3s_vCfbX4*OLh9<h?oN?x<|TnEi%Az3xF at QaUl>89o3y%lw=oL
zQJFYc1hd`fW>o_3RkC!KAL5B5sNbhT^r{O6R0hpdmKFiD>EBhKs+By_HB3Z}viMha
zeA0O`{=^MwqmFOY$LgW3)DD=p^y-zBzC|GY8;OKo+O7Lpcz;%hRP$B<a7+vBCP6Ai
z=?=>6lw(9Lh<haO&{%LTYoyCl{PIpqdqteFBNd3(eoJWZ2sH{*i<MMlefug}$?gjV
zj;-iwHTpp?)OzXMtA!Pv((ar-cDb?1ZGVO_O<#sjjT1F~g46nR3cMUk{_YGA2S>^a
z;O}Z`<9x2)bxpcq&<k}7IhvjcMp4s)SASjF>K`fkJX|YU_{0j;ski%ZKko#jv3&`5
z$(>)cx`s<ywt_Qu0B*iJYab?X^S*WM23RR+;(VeRpE**myNwhAMsv}%)&tyO38Y7C
zCX>xd;%<yal%|-JxVlOyV*KF+JHH|T7P2aj_+ at imy@#$nlQQ>X#H2T=r;e47ge?4=
zzn?}nUK57RcQ+X#v15kF2{xW&z;sRlqisfOz1C5#be3)O8`7yC-K~F*>*xm!s^3Ub
z{f>u9{z8MXSfN<=CXa|qVe+vZuZE4~4C7_&?Cugbd7D)lBXt)%D|;H{Ik`G?!XbK8
zCx7HlIAFJ+<VZz#!r4WvKraXSakt$}$RBDwp2$hA!SV%;G;;z at +7<*UHUAE-0Iv%;
zbDExRq6=T|a$j3VucW%g*FaqTu3=aj1WOddfqtqU!t4ur$VE;6*m|||a0q;`fV2(I
zEVQcQRclCo+#-!kMcPcbfK0ei%Cnlruc6XG%=w6U9vLW at aVCT=jI&!JwqA;)?-O$;
zLn6fIbu at A}yKp-_y7!Cn&W~OxFjv)n`fL;bZ9v2 at +EG7DJC8xD2RO5vmp*ZV-z`hu
zpCWax*Du5Y?8Ns$iWv;wGmfJaK5c43 at 1*S&5);PwbDkx2oA~_>33M&ZDi}UlJ+K5#
zk8tSfBUMd72GYpy0 at EkJtj@m&jxUxE2mCHL9vl#WWcxjEe9i7Z;u*H?{lIkSVBV1#
zi?$0gxhcbFKm6SYx?@D75(qpzfU(eUor at 1E(W~xKCgK;7RdvRsgh6Sm<3o93oW;Nb
zHYut)32{JF4kue0jsDCcmGM5pQ;@cC2E=CFdlr%|7&uIKI_~Y0b6IwaiA7nm#zj`G
zdcu%<KJ~6!6E>^5`5^W{YiAQhxOp*`-X5o$83G4~tSHfqJMmgZs-sOi)^XSb(;0&m
zy7P1!C)r+8W;&7^Q5RezP~1atrNe~nB_v6(^DEA1wTX)ZFVlL><zsf!lxNRiWI{kE
zn+UdHYnSPrX7gvXjLPeqizTwb7CozK@{X_o2R)*PsJd)R%F;zqO%uYxN8{0nv&SaH
z!hWkOU-E{!h@)|L-+69R$!NuKG6^VSs7R!Xd#lMS&q(~EqsL$eL+7(YofOO2<H&%|
zP|m$Ou$RS&%UIPR>pb~QZLMe(?%7QZOmT4&kVLHybb7L#i8C`m7owq~cLV<Al&L+e
ztLA`9*iy*n>)6_9K}CDj9qh8fsd!UcNP!Zhg;1$z_S_`Fj9bIm28<+K+NQbPr7iu+
z`{SZ{RI9Xf_6pSXBr_Qi!V?=4R23|EMyUyGQd?=Fexdcc7u!V(H|pcG<I=~Mh+R=Z
zlE_2t?xWGKnd?7UUZR(}QSKjdD(VcS9-rq~oKE0&aC+UU`Tc0e>K`#fexF$ed<Mkt
zvD;{a<0Iz3p at R642EuYo81MJkZPfC`0q!GRoDFsukZzbtvYXTcn87`)9(`&%3t0V6
z)B==6hz{mC%3-t*l1CQGnJCXX=-{#e=6L%cey0h at 1MOtHHy5S!FvC5#i+%&5TtW{Q
z9vLW*oyzXBZ||PJD?R at PVD8+!U)TnXH<!X55!)7DwWBrMDStVu(hz*1$2J61|3TyX
zAIJP8v*is$ofoRiJg0~l{3O1DK7SDF0b5yCRDH?FN+h8p`5{Ne`uRsrG}g{MM_wmk
z!o1duMa#MYR}O(!w>@l+ at 9ZeY7W)<h1^8m**K<!X$SrT7 at P%u!9pyi1zORp$A6Mn%
z;Su^!HWX)~91Tg2gyuCZ&=zv|Y&>UzP?{r~$3<H6DY3kL4nP<--xJU?X>%{er`3Aj
zgxu80%kD_t8wn at mj7<c>{i4!mSvY at ybKQhFjZ?@MQ`64oz55xW=J_7Tcw)SK-u>11
z@;=W_Q`;vC9cR(w)!xc<HA1J$AtA++rP{59C2<!YLkB8;P<1M3+rYqfH3*!S=6JOY
z&yQZ*P83#=4DX+|;(Jo2C*8gmlLsgbR$`8hm4`ShffPm+mNg8$?t#|xL(%+*4`k$@
z3^7|F4;iR7=V5S4h^5oh5U-uWCTEkw9Np<}2<Vsku(}!!nHlGVspNjk6`-msZAi{d
zXtD`S{nZyMX)W~r#VuWH_-+*8 at DW+6l!+OGn;i(um2#jVZMas<hb+#VowzOgF0yBY
zJ!S9%e<F3f`%%D=(&CN!u+9hS!2R2SA)|4SHBS^Jb=g|X)`2kL(o$-y`>W;YZENW_
zS6PwTJSM_AZ;9XYY}8}bZ{Qk7gI>~v=h5$q0&(Zr7Qlf;ebm{yk3d8G7VN9>l7h;(
z_<pB8(jAKP<r1r88{QnnZa&@;<&q*re>d6<eq!2ys5~%d3`hP)$rL2}5`v~8G^d!t
zqGkG!@d<HoCSP?j&2c_UO0E`sM<OIc#(hShlRqoHwdyF)g=cy#x3RWKe3psPl;zWM
z!$>YKNVKxDHVqKva20b24(}}63WcWC1Qm|x&$@^BpdZ=7zIj%Oe)73Li)Aigmt}TF
z%W&H#aAi1-B4I#p_zfKhl7e{kvc%-XC$K^iEH+r93#^XcO2%r3LT+^ciOM+(LjxfE
zX+w7o{WjgE{0`<xwx@=c{k;*(AV>F^gwE(@3<blWnz}rb6`Y_u{L3n(U%y2O=;6VF
z`b1chB-1o8FMXd<7<nwB*B$}0x{)X8oh;=xnYli|=a8u>Os*EiWGD_WwxGr(PQ_2?
zhKtj?@yS+GuJ85thrtYl!>TOUtF+=gZD->xais9iJkBTQfr*lQ`9>*zY}*oZevn%3
zHB!Z1YIN$@qtQ12`P+$*W~#>0q5LTNK^$?yrLSoQiZEkm-vB7QUfZ?&9F|_zg;r)~
zdVJowL>X1CWCXAjg_|bE2jPtcH;&`CyGs<;t{M!_&$R}P&4~i`k#)u|iuLHQWlbGT
zfaB8S*lu>})P<SI9|ZX{7dpGmNF^q^2<i!XEcs3C>_~zs&c at J7uLywI(74Yb?eg=n
zN{cOHt)}%&8yUB7)cG9xlu=Mb)(bk<tZ~c6%@fa@!-6{P*tgbSM+d83fEw9JY4;pp
zPlxjvijexO;YJ+dhK1<L3u-F&A1ST9zZU0b>bk%p>k;CcJh!Un4P+0oeyeIPHUDG>
zcRi7j6}Ofz<*- at S0l#Oz3#(%%1JqVZ%Bnp6`3B2~mSj#Y?fz<b@%VNp^>$h?4cpS2
z47wwv{*JG=XbCAmLWm)r-rz<^UeE}>Tzv|xZ}8%2I;HdunUCZr$y$vWU`fpqwL(=>
zU1N&En;_>%?*XIiEx&huuUNjQ`H0SI>SKu6 at +++Ei54_k&N=eFLwrCzFFC?<xo(@<
zndphvD<?AHdS(8er6VTk#$n<#&oXgZJFziuC|Ay-fU>wIVMPzecr;j86J>`R@<5L&
zbFEotp{^->{j6hKB#fduWq{Q<?>J+87GW8?rn#nZvU{`1!-G=e`5YfsSm+L&?;bzN
zbdz>=?w)ItT4Tr<LWt4vVE2dFYa`F(R^dQ!MBDHmfU|_5%9 at d0M})LQV(q)q at mJS+
zX at Gok9$N}d)x4Sd4KbV2ucZ^Uo&O0xrT_4s^TMk$D?8SR6j`Y?A&=}Pb3;&OB;+t(
z_-K|t_mIBA<Jjrs^M|tI32f+=0WD6RueVR5Q>Q=XhkP1v!TbhT(4Jh at u|3;vT8uiB
z;K6)Q>5Sd?41ATca3?)3M8i>%$=XPr27jO^xuzFg`p{ZdH<8M*EppE}S|fakmkpiN
z-L#odz=e*R9hp{)r+a#+!0~aj9X9m-WnF&}a;Ul5E^gt-g-{e<SHj-d0fUQ}S1xN-
z32$(A1sm;VCS5)*dA?xHHvsZph3=A766dKLcDf5jCt>^(V#A=u;bVE}eM$CukqY5b
z>yu8Gtiyyu)4o at z<P5$IBOI96uSgR*_iVz}Mh>rD8w=WU#?4Hua7 at i<ikaqh8l~if
z&~zCOwo{<KVgbiEPu^&nWHe4<4}}dSFIK$110KZmq)b)pMxN)t;^$?b){ahRDz>y0
z&Hi+=E#|M~N!%Gr2jtz2vRX&hSCA$6dKAX>eDI}X)}?^2G7tZGOeY_2bg;P}A%gdU
zTRpU4;@qGe?w-G7#h!GY1!t3U4A%!IH^+m@{HCNq$5z*!JRt-qCwj}Gy?JtNL~CU0
z7qc?&bIvwR_;<)-UP)4ySr=6{->FB~IpuZX@>>~2TOuIYKi5HWCkEwjXbr925p`pH
zQHma_PT at Y*6cyQLnSnjfIq4)s%TdhAv3OEcE-XOvB<3$o^9KLvt0c9Nn`J$@7HXfX
z at 8&7^YCC%G<C`xym67JDZY1N)U<Tuhwxd#FAO3;Ou)3{|&B*7rsh*0k{^~uiUE0Cw
zrWgvfUq+rGfft&3ZM>JrT%SEDL-1Cu`(RIXi8>#@?tKm4%L?Z<M(>KiM+wgW2q6GE
zPUcRj6NT!rN13?i{XEir+L*WWkpH02^q&b&(=Z!XPP&Mv5sWM^7H3OZGK3Fo_B2AP
zMi)u02@}+S<#d+H at 6RTMPV|Mo0njCX*!vf`lb_{3+vlf!{15FP?@}J>!I2vNTGV?S
zFq3ST(vQ2p at WB3f=;s+f+vDHN<-d)6K>RQ-b_ql7Up}}R7egM6=F at sNuVeWPP~9Dn
zq?B-0zop|0_;b$MpT{tNw#)yl)X|^s>*xFWX#+oP;HM4zw1J;C at V~<bAim8ZnA(~+
zIXjvf0>5wB8CfB4vXVY0{l3A^&#cVy9D(IIcwZU3$%?@8y$HO?g~0VM8$1X+-!}vW
z|Lx-M1%JAjlM{iH^Ec(+_y4tA#l^_k!`_rx8fa*4ioh&pXJhB6VsB_{%KXCA)za8h
zSyB{%S;NxA*@BdXotqVbS<2MX+`^fZlY<+9S=7?mNzv3%%noR8XKQNfObR|GVQJ%R
z>d5>;O!bASv7L!2^Gj1(bMVz1Jlt$7f`b2A&2O{cjsYkl;JTUuOaR~y#J2^27ytzU
z5g8F41sMq$4HX3)n*s+L6BC<(lnkGOor#N+jfs_&S42gES3q8nl~u|}T3%gK at 0A|6
zxEat?+eSr4PwV?lAW+fJu%BYn;o#6|@v-u0{mq|mp8 at D_PvW8bAt9ato}fcOqC<S^
z0+4{85gOu`&-ds3{(*P`2?Y%U3kQ#Y2tJ_}4e$g467mTYBs4S>6u8s}Tn>OjhsGdd
z5rKKCWC;7r0h2W#E)$Miw6YybdF+IO&B!qj9swH%7Z0D3ikgO&j-7*(i<^g6?1i|5
zq?ELbimIBrhNhObv5BdfxrL>ble3Gfo4bc+(CgrkH=$wS at d<C=B__T9kerpBlbe at c
zP*_w|T~k|E-_Y39(b?7A1M2PTAD at _<nx2`Rn_pYs*xcIQ+1=YeJv+a+yt=;mdi%Xz
z5CF)3sTTO}pRE@<xL!}7pdg`Ozt;=miQD&zqeDTHvA|%6D8U*!JblI*0Ea0Wms!~k
zPtK-%f at S15hJa1MzD9Zay=uSI?60d>;Qv?6{;gvFUaxro5+nrp<w2qYga8-GzryqW
zRfKgv&;RQv>wdP=&vyEsU;}?I0p*{~hW>LI(tq7C2>ST0+pEfg`H^BhP0Eri?xQ0U
z&BaK_mO6OSoqT!v(lY(tv3ofeH at m{w7fE$h at B4AOf<22(3|50uoiicq6ly0gmP9hV
z!fKJZyJY%UR2Xbof~lkCh)%WfZ8K4F^FbbPE>Y)a4V|>GP$Z&oWxitsQm1ltAI*IP
zhH6fm2cX71LXa~If+nB1w-?<84<@r6;5$pAdaKK_JWjr`hPW_J at A2n^4Lf|nnb0&G
zr`NkjP~|VEd%xsK=n$=t%lIaYk(v3iYx+7dp at I=(N!0jU__*=0R#Le-d_wW0HjBwP
zL|yG0z`w`dk42s1L}-odWbgAxIw_d%3mNChaQ-^Ip5Vb at G4#?=FTpRIG7+=&h8pax
zG7D-ocjDQJa^0G&?@SFR(LC|HPc|4lui7wYapW9H(%>Tt7H(WhfxH{?X*!kp9y;;L
z)GVMHoP9@!5W!Xpv?UF#+Hs0HovKw`HoB at ZVN&xnrxB6J%{bM}Q at w~j1{E<6YgVSM
zXm^B`Y;I^+l at Z%dlOt$FpIX;OJ4tnU?nN<#-tj3%5%hSnm_mh`lOF_s13VQaV6^1D
ztSjcPJAj at l9hAY#Y>F^Gdb|>#YaIzMS!;~P1=@XqVo=rsmJZ~+a9Nx?I!b$o^i at zm
z at ePu559C3MI&<(Lm}b!QjyZIC^u=J+XPXV<r%xPl6H>4HF0%(wih!;iL`;k?Mn26e
zLz!Y$^H4(w6YlWf7SybuEm+}*P92rolxfLQXxP7>`@An{tb5O??PY;3&Qv!%uAfxb
z8V!l7RXyw6<1{SHbD-X`q#--)JnN#xP|KbyhN%J<sDMtox#|#UFLm!T8%5BDIj^%M
z3*}mWZG^qRo;Zpl6{FH{hx&4AXPV)uH2#MM5)%VFUC48jRRHe}zft3jjcwG_<w!_v
z=or$mc}+v;Ta0f29O`XFg^YsiX*YMr8QT;CChhaXF)Bd476kPmp*<@+?vB77(scc)
zT27LK&Z4#zwxAPKxNNaw7&);&$!RffUK=oPk+Cvl|M)1$J#d<trDKO6CZo)}E2{8?
zbL|ud{j(ttFgXbsxeylx3&pArtoH2K68WiZBjG0E2P6ete(Xpl?kiZH>+B4iiy_|;
zwU*@hg+XQn`bN`*$kUpjUUI at fy3|jMm0J1(b!}<$tYS- at w%S-A-Fkb0fRZWa##8Dr
zm^8KAJN&#Y0TV#<r|f_mRea>MLasNZd9|l6T(1hzV1z1qUT6{)Qe5$DULHu{Er_tY
zJ*OCL>cb4j(*&zyA}dXCqyQOu;wjEYXasf9Bwk5^lmU-s87Da`B5QXhfd at x%$lX+D
zk%j?A?kc06Ud~1HAGZeFL+FWE2`F38JYt+2;py>gfQmfS<lMc4DqaCbpsvLFQhw3-
zGsFgC))cMG1$yQ?a&DpYT;-GKYR;UQxDh+glIq?L>Ff^ZCI1g2%S52*LQMhCJ at sx<
z(x~2WooxwOgh9+UERno|ueC-81%aM0l7k;NxaSqX=$;~t=~&dWjxbKL(CCd=eU=h5
z5LEWlw~D^*!gkg81~7U at ZP}8}BTBV?zhM>7XJ_O5Me%0gQC#**mfx<m+LV~LsInw|
zo{8T|KiaMC=s3p#P+Qtis*JJB5YU3da%hh#79&&gNME6oA7#`W4>vr=H2!3iY#5I5
z=pa%}w%hfzw)ah#j<i9J%kX*3bl%C(P^vFVow>7A=IfHXXwHhe_Ueh$%k13l>8{Rh
ze7`HTvaCl(9o<1gbpzHM+s)OBuL>{IQdKM611I+;^!3DC%#q}(AE=&1?nGh{$vf!=
zhf0EpFF)&MPQgH2EZ>x_5HPfz(z-NZ$CZu_9^pC=V3A3y^sp^n<b7^4Ue~cM2J^p8
z-}Xz(KfBX~VWGWHnGl at RzlopkKRq(8{q!lB!K2s`BB8&xchO6oGdFLge72`>{arj)
zgBXTSfQTC`DRREh&Ui_mG5h?~{UgaVbZxK0Rk4=QVz56h{}}{PkJCXnDJM*G{zuY%
zUtdO8=(^M$?w;@6s#x<Tar*d(F{k!ZRif@!eQW<7N|0WD+Ef(LQ0ZfUAFvpX0ZGG%
zx}h4 at Fp2aH6bgz%ydS>H#QrV+G;+b>oYmEceIWtA2$ecNj4(F^ijU`mMMd;<xQsT;
z9|fHLbN9uHS-1XrafD$V;fO7)2KCxR0?(g8vd-G5%H>GJc>ycg+EAccs&XWu%K`))
z+TKf?cHuuH2eY-#rS3~HY1&}g-z-y(NW4PD5<VKCnmE58r>71RvVZhit|Bmu3Kc47
zbR)VpMJS|31ad`l at YZ!}=_*32p9ywdgCv-9QSV?G4wc at v1<&0S(so;dl7Of>;Ohi>
zbAc7QW^0jDJl|qJS(Gsz4-d~y1z>a9`le{qC)23*Q)A+?S=f3Y(U-GJ8%Y0_Q!qCx
zU0IUnC(;?<@yz>@QV~#26^i641WA<a8Z<<09%#^oRz$Fsrea7|&aCH)EKq_caDkL>
zu4n1}K3vJ29k%9(6Q%<6QH|4cO<QXJ9OZ;jdat|n#^M_4j at v8D_cQ8dal(&)eTB8<
zX8OBUTK3tz*5|F+SS%q5&sjzWz+7Yx&=8we>R4aGju>shj0Ro{dq(R at -%U^G2!HWF
zcO}Rqih-Hb?8!cT<I8<_9tJ7u6EN$c$GwOFyHiniO=3~IW<e({0}d3SG1Pf-!po`k
zDa!XEK-W0Qz-n3SuD66|ug at fj)82LOi&Kr>tFRN!^|=vu at UlJ0?7dC9+>P_EEPw<c
zA-ImOIxRDwYdIG at Yig*&!6_zaZ3!l at RR8i-*{=gkiL3$x77Yw&dx&D|NgQ29CZ1p8
z>SVm7FLQ`htM26~=1fBwEji9=tgo13mun;#j$Ms at 16?T%Nj-TvAV<4VZ`#n*WV%?P
z(_<2sly~TQZ)sE83{;-q6xr@{KzKZZkIjioH8H`@%x~)6 at X?|sm19?|!F!|t?2tr>
zJMM8snR0fqyiss&AU$DqEb_Tc&!w)oqLuV=_2ydpAUC;eG80EpzD+a?ZxbTW{&~HL
zNJYPP!d%CgXlQAH>D0~|J??4;kG$e`hK1xl{L at n~;qh!+ih57<SoivoD{ZLGhnK(n
zurS*hIH at YU(2nVvX0^P=v8s-#Mxzc+u!-FvtV$R)=l3M8&GakKnH3?dM|~atB1&q9
zG8FRO8rnDntjs!d3VP$O31?g3h={#P;%!z8g4`cNrg9sY)#)S5FFZ$4=Dea5vFlPE
zHJA19BTAjF<dr(plite8=o^NoxC8JM*ABY-Zq*j|+HH}X?%0x%kDIk8oIyygTjys;
zkVH@=uDq}$i(8MCLtBhgU2O_v6%ct=&xil{G^_DssWS`vESU!vVtC44VHdvCz3gba
zM(1rZXF!sD?DK^f-O)O{p*>H~tn-oC*{yV5_=-|I%egIGqavX1Ga$XAj5&e<xu0Cz
zHSvsdvc&=}ppP5Cb-AZIHBIojX{&deAZ0s|RVWN89D+m_f0tj*!JInCeD<_Or2~7B
z31ypm9_O^12zKTRuS{ptDaXgwqp74gH;$>gl_fFkEAPlHVFAFtJa71PwT3J=#w!z5
z#T8vAO>MfEo0t5evjlDSY~KI?c6gwp_^D}RVgyGEPCe`9o4SxE<2{mkomm@;4|ES@
z)ut}FAH}H_tTGbK31o~51VgItxkH=MTKY4ddVpE?{AnLeW;mS7mY+`5 at kBjUcXeH8
zwhDuhUw#ca%<CXb#7<0KmFO%DEI-PO3j{d{G)kqWy|?r8Rx8!etDB&b!lzFu&WD~x
zw1|vWb>Su|PMdPRyB_;^iHajJ?;Xx69%vZQ!&0-E_K|MuA$-y5YQ0m#i_wfv5uU|X
z%Xmbuw8trJhiJC~f13B`-B#)~Y0Hy^2T%E6Vg{s-oqKAG_gbdxr`Zeo3!U`P;oDx0
zaZ(Dx1S^XO1JS!*lZVsS;f}cLQ8|{f2&)JK8UXUEJXa(iLQXjZNThJ69tSkXjpsY)
z3;cnNUqvf=87H8wA)_bZ_G;y97hXDtZ8S7A#@b3TZm>#ycHzFbonZgyxuBXXg~1nL
z{XS$TaGNz6ho4a0XX<EaxP`H%fFZL9d;e at vkCq9&I#}_!JlqI1*2lco_S30(U41b(
zNA|OvPU3E{2DDarht$oqn at ps+lx}qvy*>mn4|WI6zA{7q8YT2eHdKY4{Q6Vm*Yhuu
zGh at 3g30RXHCWE2@)I0)oNkKdHF&z%@MC8^!>zh37l1Q?)7nfyPzJ73fXA3VGfk~?7
z=Q1$pW!v-J3Q$PVsI|l*+pgH3sB0UVqL-~@@5tGJVaFLPIr$F>={w=eW#k$Y%-uO+
zs;AmD7&2+v4*{%4u^P4$2 at AQdow-k*fAN+B0-Y$(=Js*MU$_oj$vTlnUbgciO$pd_
z#kB>Sf0_^<NL)g5&*sZC;9)|ggDoHbVD3_=?^6YQzLyM)f4M(+ni!W#$o3oxBCX~8
zKy%(X%{<^<%KOw_t}Ca%2vZ309Ka2 at 1hp~+yYK;@U99Yl$peppeYkV>Df-bj*LnNN
z-DOGm?2pEMv<sLlWF8a(_QmQ)aGY^yPH##28->usT_0I0(5%GdSFH9hOA&ezZ3*7O
ztYWZ?tSzT3zN>7^J(!+<yS*spV(DDm((ZyDb#>88)UDBYD*hHHUMGhu=^2K)Wrlx?
zecW8kjahYqLerbBWRFSy7fi>oeByvARZ5xFt+yw<E*Bfg)vJwJF`a|)O{HBJ{Y+wL
z2zBeycAc2c4FmM+Q34lz9O&CViF`5DNnagO0~(y7T7uH$CwILiEh%${CQtRWbwq-;
z7hfpKpo)GRcGz3gc$SCPg6C}nSm-O-f;Gw$2kq%R@@PRvr|ogqMKPnbbaRD<z#*xg
z2vaCh7CO#!UDe|#wR7Y?#C at pix>m#;S9$CkIqw!yI>oAun$QLTy}TU#+2iJgO=wU>
zmqM&jH74x-{pD)jJuzJ%EnCW`u9vBIFs8VDIGiW0ypr9TyK43zTZ{qq+xs*}KEec~
zpdTcAC%;UNO$U}}p=e2&lCB2w?g$i>riUHb+HTY*PCpLi0V`Uk8pYp!1628 at HI%p?
z1HZ8A8I9=5dMQwuY8^AYJv664dtgfqi1#B@@}B<`K~yp`qwYEN|JZx$xVV}vUAS=w
z76|Tv4iF@`dkF6C7M#Xif(Jry2 at u>}f<th3cXxLufk5ugd*;r0$;>_XjGXztncw}R
z|5&@KyLQ*E+EumI^E at j)+4oIZz-LTB#m}ozGko4z`>#IOh)`K*3jZTKiI|maGB8q8
zy&TtegB#zzs{&fgfv5og35#`zRBqhxr2&Kpsy=FfV=`67FlcjzSIo+eGR at A)DmT7k
zkxYs11ITLUg)P#^c)dF{bk#Nc4F}G|U{X%a+cEZa_Gm`eUDvBj4_c3;5c6%B at dYNc
zBs)S0JYGj$_o+f^7+U2~)+YTdy}9h+M)*Eem<bx8F0G1++VWa04{=4j_)O~7B35}g
z^TU#3Yx=wd4k^p7Osh^Su>RTT*}<DQTPY9Jg`R{pl=9|v_P}n}VRRwY{PZV*-HZFk
zUWPylQ1u__cM(g&cHt=&VK;$}R<BQvIGi#1*zMIZ8=BLfqHkzn$-_yo9&lNTe2Ob)
z%LgF_qo$*M#+H*l-HyucH!iOb&*rtE8(i^yYX?+?XU|v*BUG%r6WMxiFOwVx_o;Tq
z93P<F-KxC5b(uA)`d9)2iPSz}n!ww;!uARVb$w{RrNb$)LG=S$_ICzab^1pEa#aY+
z74IYn2J)Hr>rv`sgH-N#Ys at rN1UgFs5%5o1Z)fyGKn}VDWzjqf4c8TSu$Y-5aOEK8
z%$+!x4DjWT{iPW|xU*rUdL-}7g(>(PhEy?q^?|&mzzl=Pu2`W^G($n~Ng*S`nlhUX
zvdlEJx0xomi+`_Am1GW<$U`;d1q at 6280&$C)n;v#xbBjMA+_WxhxY2lL=$~Ym;t0f
zCSPlT&P53t?DQ7K$bW+KVAxI*=p~N>PKG0r`90oVqwcLmQCoX1qO06{zgY`X8-SoP
z-uQ*eYvYCm5D?I_oT{gWPAIRvb87}L=Hr99;*sUui#vG3+;=8*?LjuY2Pa6{QpJAW
zZm at 2(&V3z5H3;iSrMJPLwsBUx)zQm4sY}cu%XPczAmmpPBY4Bi5R>&~!h90KpmFtN
zgQ#vHlJ(r|jD2{~l(iB<>AH)<Vv2C3-nSaT_Z-h6+T)c^w_}R>U$j(67=uvP64dX-
z$r5J(5kj%tIWc|9=;;^LWd2Wus{D_X0gOG0*}T=vJUtzSME!>sNj4MUjnk4uYA7>6
z@%=wShW at vHmj*}<g%K at +5{hVS5GmFqAp+7zM{s?o?Y1Eu;+;WX`|y2uW&F#&n!j`<
z=8Ke}VMLMOX}&=|&dc>LV}f|8xD$GE6FPZ8A`VWp+LHd6IK0%iC{M-!b<&Dwo{0<$
zBauT?gR<IJylEEIQi50|RR>yc>ckD8tik5Sic;_<`?3x*6FG|2r_CXz9 at h<?{NOY$
z)ach~@<^>eXiWfd(w at n89N8A}$b3hk_R<2OnA!J0A}xYhK*UWZdv+ujP>*P;K;{>4
zOb}}8-3zs6QS)hCj|227oeXVUPuV&>h8q3UAKtQ;?YiEkR$B*C!|*7NRo&~d$-JJT
zLcWpcHNM3d;_i?vpRkgtjx7{^hW`1L{i0#aWLiPdr98aZSTS5qPHj|>6|qr(OKool
zC)co?(sY=T at PyNQg?vr$me&DM5qhWo19pxGND*M#$}leq8(K$-Es`A^%PD#e$zV4!
z$+3=g7lAwR at tiDCP$q$&b!--mFkmgylpzmfW>wv5TKar0IKq3O;e8tS6ExYhj{XDs
zC+M&!C)0<yszljhfYFNkVU!XIH_~z?`Eqk7Pe8M98SV6L(QQXMh~L3So#Fl*O+a!v
z(}xT2RcZ33V%ODF)|yfbAYn<w_#Cvtl);>1zg_8Y=WDuI$edWyigsv7hS|qDMIQz9
zYqg;Z+YD{smbxbGj#77Q5*I!$Rq5Nx!XxBpW%|%8%(X#YbVl}6ACnG70^+m!C>Ikx
z+)7qecUtPX!H9l6JXO&zU-+|lt~(s;jh8A2;yEv41DRR)XW&zw3?=*7zfLp$CGKnU
ztJ`(3osgB&Y?i2=#{>CzOP)|e2c~7Kn*-VkrVt|emSuUChJ87zvqE`SCE?nJJ7rBr
zDMl`$a)nDpTLGFypf|2`V5Fz<3FRv#QaDkgixF~#5J)D!v0Cv at yXMtYiyH^BU}E+A
z<V7=$UL0t$$|E4q*#TN#9LlFTUBiW?&O;CkMv1;BopG(Z{MUBV_4F{3?DL3~E#X`w
ziYKhDC|^y$Uz%Bh=K-PKLtdsV^BX<$s<Lpd%E->RdCv-2fhT}c2&k*>v^&JX^SZC<
zTk5;bn8 at tg*kSZ_nn`z+P`jn>ntsfq5b5{PL{a`dLOnTV3W8WwL(CHrRXEd3Zt{NW
zuePn_zJkYB_NEhKE45a%vd>7 at 3?_EnBl7={PL0nnPvo>YykmV|tJ-J6zwnU?dtg}v
zd0+OnC&2pENu2Q3h&j&ND2D+03q#JH<zd<e;Gqu at 3X{&7tSI}sjPPjpVV1WuS+yD&
za<*QV?5%~b;|7{di!WLk0n at v#fI3~2??WKaVFyR-aTq=9_IS|?ay1e?YjRWX1ad6S
z>Ef>?Sbd;cUT6`W#gau0K@{bgKM@#*Rr^*1{(64}hFGik9;9jJ8LxTbv>zO)*1t37
zx5taK%A3U${L75}dqX4z`MSu2N<1Rq7H%@}v#$xCsk_CA)t$&orcIiDf=DpDXO_M^
zM1=dGAJMklLR*mDERz1PkNC6k2h0D at 7ygZ<PSYlk_*xxOdFD*oierDDE+2sdrXTd*
zJ!$m*{Hs9%o5sz+ at mb3I9?fC`5El4z;lHuT|M%Vh{UraR5AXl0o;1HoC>iCQ=T9%x
zk$*SpxvgI)Fzo_<l5{6|^5B#B;r<2?yC=%h1(XI6TMmwAeuBh$ei0e(b6kFc1Z9LD
z?)-m(!hu9Pe>VS64S0O%e^L!)Cde}>@E%D-KFjMhFk$+4Ei+5+;!AyRg1N`ywxsiF
z-j}dIVzfGeZ(EOyU#bXc|J_T49g2sntmr#|!4vf+^mrki6J(SM9+8|Y9>MhPtu6$F
zMzU9Kq5ggO6<Ms=D1)y`49e^49m9+aF+$-`)X|#{?z^)e#v6Wu(kU|lX%~Q at +(YgE
zAgXn8dsz!4^x6jWaRz at c|IMcTrN;8xHR|8&f2|G;p_K_F$*lDG*cC#svYO};sF#B5
zg3?`e$i&s=L8OHCq3Jnr3vi%E5BibuKjNwXzkl at i&)YZkgG2V$8)B0v`N4+`>8nio
z=(mI3$X<Gqv&FrCUWP#eRi!{;FeD%`n639&|6}WyzR=?<kFEa!<xC~j38hw<bsxkg
zNnR at G5IVw;h58RB>?wJh>j0DLnLOZ2Sq1WOetI<3%tzr(uVYv4q1e#xj?o{u#Qtpj
zAx-n=3;#_ at t(vpPmrIJLIaEu}s)CJ~BHJYWZ-`r(t8+ABeu8=j0B?+LJn1bFTi!n>
zpMW!gtemak-h0jiW9Zv~Y$e;tx6_b^<|FURcaBhbe-b at _HzGY}Uh$sEX?gg-W<LGM
z8iiKlVF+s!KpDY`ztcfdC6P|XnE3|DEXC~re)rll`T8elj=OsLRW84Ab<HK0L$|}U
z54R3&C%0}TUDV!;u19yqXE)0_(o-^8)p9_iq}qe0x~8&aBJWM7jSEP+90ArS(k|Sq
z8Z;Ah>N|z^cFS;9KK$LP^HI;;B-H4bc5Xqj&YZXDURb{7{IU#s0^io~XhArVN-x~U
zU2a=*))W)7>LAv;l(z$FQjrUk{ucF&_#HISjH0$?WyCr{PEM$?m5bWF6oE`}hO=r+
zc`{!h>@&KeImDj>_tmGBtV at SsZ0lA*e6|t~j!q#1M{2DXL*N70n)A=4*w1V~6$PxO
zCa;bno*+=LR?A5Tt|L=#G}hl~Z}8-tcY1u?*djuseWuVfrPpOBT~-%PtvfPEPY!=R
zyp9YtnXGTfxx)%QySG~^IqvBtb=O3EvdY|EM71yo!=sfx*E%e8vd|=xcc7-~T;Fa{
zK|ffpixm5mD)GrNkt0GamO7A$Xic;-ACG?pNTl>CyaLEQly+{lm(p-!Jz`U$J;f_V
zS8gs~TpuDGA|Kjoy(75J;(H#tY8o>WPF<#bkY6l=sUyu>zAT59VO7S<Q5K-Hd8L>h
zwJSuV3K#yRXut4AwZ7|<nxvNXr_)kdBq)uKDCn|cK)d_F-7PWdiOAxInNk{*_;rag
zrS#v1p*O9$R-K3(G~zS^vkcb>W!Nv2{guOyh->K}gq_N!nW-NTt}fHjDuTDhH`J#~
zkJDtEg4>6u4WAtQNKRDTA8v-ea@|O+)|}~7tEu;@bt-soZn=XYhPg@&27x$-k+}MH
z;C*;#Xy3<cHdpw5S?H{nS)fL{Mk<5md9UB~@p8zy=Hf+Hl~T8tggkfJTNXjgG3_Ls
z1GQ!HDaQrcx+8u60RxsdL_M*?Q$)}beSN%Wu at 2&s4Ac8J(v$4kOY at lnL{UDe?nE1*
zt3;tBlj>-G!5b%9o$S|g`PvX1XM3=T at Y~T0h0ryrm}n0pmm)g|uIw%GL1diES<qGl
z=zUb6vj0pp;=!T<#CIGM#C4={$WU^H{HDIjn;D6vx(0|ckf8HHxVMkj0o4;@8_He-
z-`qMvp`}y|dpBaFjqx%^D at jj*Hf~J~K=@=ydh|6Zk1(!bOn56aFj%|j?bRF(Qc2%5
zH%}T&(hUYzie1~`2QhUkhu2Xx=}mT5Iyj$cEQ#dKWxm9fA?P3OJco{HCCPSK_u+UM
z-CNdq-s_wRJ?QyCbDOoqejQ=z=!!7kMl=QQlXiQClphkAZzLiGHrC2%l(yOUK7)(3
zqB`=ue;){rf^#MLxMwX<PG3yP+yQ&5SdIOp8DE*19kG`W4V{h8$W`q at B#h;uY2v$T
z6Gs*%i_>4<Bu;r6i8nu7MSg<xoLg at BxhK-!Dyv}@<D3tErzMEzJn&&roRU#{5K{BL
z>iP+~d?s;-Y)?$6UOjyXRH<o~jC}{M$nz9wJ2ml>T+u)toE at tjT~`pHtprSqE^Wj(
z1(43xTW-QBNC=06Q8a!me@&J%{+6@^(!)&^da{GS6voZbd(6Q!#9rL#c%`J!{6VIQ
zgM+XJUgf)}1lUJFN!J^v#lRb{vE at wUDs};L0Iq^Fm_dZX06jwcLiLI#@C?CkwaKGk
zT0BoZsn6=;%L{B5?4D8IZluh%@?9)70Yj8}(Q53Xr6ui!C82Y+!JJv~4^%NdG~Q?P
z5fW3zF{;hD%-&hjfgYAS?_VpFe}@Nx>5BN{3fjspnkl{I)xrDfFQ&4iw>GI9gb}-^
z1l^4ccO}?N)Jq#VJoN|imv!fKWXWP*tqdBOkkZoXKV{~2+)jD#6e~F*AAapom#Kyd
zVfeIF2E~aG?ru+;>^Fa-I^z^%G<jlGVwLwg#D;PjoZj0vjAfX<8f{SsA at 5O{vZP;T
z@^*QLNx`rv7bUta at B!xQ4>Mt&Le0FqdA8Wh&Y5T0EvnI`bm}*^=mxDtpFoeb&Z-Vr
zq<%@rn?AJQ0$M-9fI at _V$p0}N0CvK<+;^O6z1zzq;ONJer;!Q<QY1kDsNfd~AaC;D
z{_?*DKlyddL<mr8qQAL!*8-L<2i26{?SH--?1Z(J?>JRoZZAIotz!eN1D>!bh$PUu
zxc4R0Us^Y{m~V=UfR at Xb+w49nWAC=MOKrVXbtGXuy}Y24C?GRgwFw*bvIONf8aSbT
z96K)6Gh))C<uT+W)GC9W#C at O}y&^<9qED6jo)Z?UAHLN0Run;{NB7caW{OuN$Lzd^
zB*SI1s_3h?^H9{mxxcc&8u#hWJ*@XRY}yYQ3p3RVO|v-F8!8r&Cq);@Pr1FYlhy>T
zZcpyt8$C$LmH6ija6C|tU2Y&OFz~kUGtqh1JA9QBZrwP`o&aQA_tnUec`n`Lpfog)
zJvpG#+AG<tGzY}bvK{uHeP?3x6<oltaM>y2kA*KUHh%yIBJ+_BHq>8i7$+F$)1S7+
z(X|@-m}&Zt9+_nyX{R*a9v65PX=zzt%yn2fRB%ZnQ#g`R6QS|R%CY(!*ooM)<C2g~
z7aN^_NiU0=Rt;DbY8f%+q(V3jPl4JIkhD8{Gq5Hlwe$4F)?k{c((?t(=5=IDIb<Ih
zM(%#vpohh}32?YuqgbBBXk&1N5Z)U{*o~LfA2~<7rXcE5r7L=#?0lN21e_ac8pa>B
z2W4FegFxsbtWeWq+6ViZB_BR~IsRf03`x at Ieo4{Y7az(G)q4_k)TKDVz~+`pm}F%#
zpdKuy$3I6QK1kyp%QY;P<pcxlHg0L3sSpfx%>{O^({qm*qRd!_P_URD2T*|w3-}vV
zP^mP&`rRp1Oxox-Yf;1g1et$)jmg!kj|PR8ji4f8?_BXM{J7U*&&B#9xm(n%8yB1$
z1w(RRPYug_dPrxy#99ia#w+^i+xvufccEZ2C@#ZLG<ZhNKGs77QxUtk`NeD8>8M4>
zH9;pXb5K%0V)Pri*U&MsBYGvyp823G?Cw1l*AUGL^Q=jOO7$E^RrdWOcD$=yEJq at g
zQyDW2i`&=-U%I&I@|psa+-32L_iC`vi>aTvdUPkD#uQyjxgRdnN0$kcQY at ywlNg5`
zp&;W!MevAofjy>&nzjbLC>qMX#yHxGR?h!Oe~N(e6(*U8RM)I5A<M%BE+9LeL#_g`
zTc=DGVbnp17D0ZXmx8=*$@zHwPU4IxQ0|f%<OhDjW!&aGqSV*33K6}%y_Fi^qmXi4
ztBYP4j&{R!`IG_$1jcU9UgM7|s&PPE3eDZSO4AA#dpuEB4N&{LwkqmFV~vUQ!#~U?
zIi`|*jW*X(_7 at G%iK8BT`O=9P|8p|RRqHPID1wZNjg8gioj3o!+$+8|hpJSG*1cm$
zQq39tWGX(c*7LagW3N7(j=Ng>S%kfC_bCBPtpn$IP0yMK+Ffv6i0e}~QPO0LP}0w)
z;cnX@$Qesx5>kTgl>h`eD(>!~i5^&9xQb*S+xalEfWj9_3Ph`Fbi+?-g;9*vkFgi(
ziL4v%<$9I>OPPK9Y$J^2uOqk%T`qQ+LflB?(U-I at iJmItk5R@*)_X#q4Ol8(E2e!n
zC%ut)IKRAA7)4E?Quv at ck=azMrk*nl>jS?U>EP$#uLc=8VsjpU2bKFN!D at NkBuKVj
zs~>JQZXRA1#H-@{O`P?fUA>eQ5E#;1=`~WIZyK+p3zkJ&%%2x^n5lVLUE-Uv*7DxM
zuVb6#v-A=tawPY?#g<*=o~}!Tzi0D3RQ1Jaj3J&aI~xDm<yFyi?Zn(}?Whc`l#3~?
zVCbQQeJ9>WzH at xBRdYv#ufY2A<vL)(RqJqFl{+oblEY8fEvY7c<gSH{na88a`r&-$
zPWF7fyDbjxjyK6Tw%t!7IrN4|9zoNh<bGaVeZ+;PQVbebzm5uIw81vWw{-Phb2*-G
zF{Y_0s;=g%;YapJF|Z4)Q~rGa-j5d!g}N3T4nzFOo$Y!zG*334*6kzMJ50w*g;A8%
z##+;FBrxNMps>uqn&gxUNC95v_r4hw6%A%|hZ~{8W91T*mbQgr&xH`cMA3X)e6DzS
zg+>{Z3L?)F9>2{soql`U|MjTzujE+4|Lt7#k3T0p%RG2yc3n9?k_ln1oqu6_I*+4>
zjL9g0y#NFeZ*^<$^K8ewO)Q*~)ST~%yy at jAd>m#HyJDp4`KfVU<8mtvv%$xh&l90o
zj>u}EhRzs@;KIb6k$m>9KB~4koSa+>rwsJ44?e2pLMe0w+cV81%8+m#SBsleo-S%y
z6${2EZciD0u3>}*+4F3sX4V%{!|Q)jT!whiRwuqBH)%}paiWdXB8#wb?|B$*jA@(i
zs?d_y>2spZWR88s+iK6UkAS at ZL~<MlIy{Yuw&&MpYlOnr*g4yP)XMLldAB=S^A_+%
z9NwpzOw>C6*x+Lcx6`^*nB-RPsPa=e)6HTLU8kxIQ0b2>7CrRw*kDU#P54sUs9?Q&
z_F^TjTzvm^Int!NkNb?8l%Nx*c&D8feR3)ariEmZONja)N=Hk=tjj&En!Hq!6d|YS
zSjm?|-bU?(`Htv_Ni0QMHNN_r(!^lUMk9~DXzh#Rl-$KVRa7Lk;8kp9iBz<~WT*)1
zY9)E)CbinB#+P>N*>j|3RY8ce=UCr;D|l=j!mpMU1c~S$Qan)uBXCN9x7fT81}@`5
zxyc1Hdo&cB&)zqa5C|m+#n_2u73IXCZ<PAy)|hQs<bdI^S)(he92ZulI-;E7nN;HX
zh8ip8^V|7#=R_ncd3NOFSTE5<lB+b+yd?;?chJ$cdRBu+wef2gYU3wu5+~hI8`Cwp
zr&pV5 at z2b;I}_ctdyV2Kpe1v{nbkOZB*(`cd#j3+P-M?}zD7$BZDl)5g^_Vt_R#5>
z__v8ChJz>};$8Kr%q};ivXH9Ui2mAezWgMtSF<w~p>{qzPk=D+dR9x_M5A75e;h7u
z+)f`RveObdak7DHFYgX9XHndAeeA~md|u?V3kS|RviK$$w+|9r{c5zka~EW8&)azF
zitvQTdqLWpa?x_W?jY6Sn`$gE{0;B<f^47;zm(ZKdV444_Y!vQ>AB~O>O9XHQUzhY
z<Y_L{Ol&ot5;qlPM{4&#e?rT_2g|B)?e$_$s+v^hEm_DHv)}s9y|Jf6A}EiN)0bP~
z-<Xc6i%MFfjJ_Q{P)}hW at cOQDDMG01_5Oh^$v8*vC#d~-b|d>CLopRgh?~&sRTk*R
zOE8fiq`bN|e0-YLRn1a?T7<+0<w;`Es1BNdVtvyYeg4Graht=9Xpy@&GvXL3LVd`6
zi?Te*1SR=;7&5Plvh*x!I?3n0BX5I+@$?5G5qLKN*vc_=HcQ}yqg(bQTar2JTAr5f
zJWV%+cHtFK8Q#*cIKst&DtunitH^ncvC at a-NW33M>8*lzi+Cj24pk`ErR~8mgZ-zA
zio$D4+*}G-QDlO>`$9_L?+K<dg9+>K>mMD5iibQNcmc`!FAaM4q{QZ<&?;81ITG8~
zsk?Vv6O`SfnN-cPuVARe%FKRnnHzdO?XAU-!fzvH6e9w7GB+Pi9G5KaUr8j%nZdFj
z53*EpA&2hxh;P^5YEO79>d at IcORW>*EU_+laudHsd{DQRX^pVh2|Eb4J5sIY<4~?Y
zt<;iYb<qqmj!cGCecoY3gvQ8-^aGNa84}vj41imeM&tA<>2ve&FDO1{qhSP!a-g9p
zrwteF-=b7%nn!9d>Qz3hzjmd>(fJbL1?Tvw3d+C4JYJ43>>+mRK6k*rSdqAhoUu(i
z{DW_BKE0Et^=-e5Y&Sjk_^=+Q$j(PyF_<kb0EL|9z7GUtUqu<)SrtK8WJr3CDaC>|
ziCf8F&nD6|3rGU4tEN|*B8*&Ipw?}Lcxik(5d0ANAUT=73H8rg2;6%L#cH<6<?Hm{
zq}vkdCmXr1UX{>Lr at x+lq|*E^PA)^-f5d6C)8QV|y(IsV4|ed3>PLv?mwR^^Aap=5
z at t+c)_?x?tBH6!^3kOeEfX3DC-Gzb1p8$=c0)D*e9PgQIfm_gDq9cse-(Dmhh%&u7
zM?6tkER4o>F6+C*C$G619}`4$pGFVVPei&(<9<njsn?L<L}4GvDC!=(k{O<EfCm7(
z-%pvIXP<kuDh<v%AFm{v=GqO at IyBK^fno#Jb}0jIG|k^eGria|qRWQYNjGv2r*#h&
zG;p;*(ywmTc<VZ#E8R~l-b*J=!6$T8Oz4Soywf%<Y1y%)sa>@`zvlc=^twN?qfVf|
zq5h?B7kP&VovpenKaaU^1iRJ(SbWSQQjE at h1KUF<YW!?MaWqMJqQ4-ZBpp*cY>|=b
z3hzLN4-2Y$*O?$7EU<t*$;`?i9-=X)6Wyu*ZjP{7ac)-*p+vs9B0 at Rpne6G-aZ+Is
zJgz7cid}M8k1eM)%X|}jFvBDot!7P65Q(RnWb>5ek1Cw at C8=U7{|0*_dr!IA)g=Lm
z*y^HhNm38P6^&&~>0v_1!~Aa>;deMMdvcsF`zU~axoAv;O))zT6H__qBt_5Um^c0^
z at f@$QIt}J<6UwLSqK7CdblNE{{>4fFD{}AQMl<Af*HJd;BgRKqkZbR1=ybd5+gnbr
zF0>Z=M3W~$u+-WwA26u&Ci1XH=e0ykA=p*OHPoNT(FJKrU**x8l<6)npbE4{&5?@}
zn4egVGp9S8gY30NFR^DyJ}HQsBCVCYJ&_xqXUSgH>Au1I&a6ePFX0gR!>^8O^DH7q
zjz6YAcr5`GFu%Qha-?P}Oo^Apu7Tyh3;J=8ImWtjn1o*Oz1d~>q``Wnv2z2TzdA>d
z#4cZ5g#Qzv=xJA1M&KKh=yf7VL4)?tI2(t(10AXm{KF&qtIxPB>ip~38}^*@9ajja
zrQzjQs3cax@*j7a9Src*?g+ZmSqgez)JG-T9SP#QxEr0m6G$ARaI;P&KF-fcNC`4o
zwU?DBa6+_Uy;q%3uc?YV!kIa|dD`<(h7yR9e#O<><v3ZTjiyQA_T|7C*UG at b(7^a>
z&%BRVRB!8dds_tUo8l0u7g7mXQ at mUr`TNm4CR>xdbR3v<Z)X+4XGhMz2m!*fw5SyF
z{KSdREy$ZICQ%0!tY{+qlV6gdW at AE;OtF8>-zVr!F4NkLKMhD_VM^pBLLef;r at z_-
zmCgslVpS>poks;3`~LOg3-M^go1CWEXr(&TqN>nyx6SZR&E(@+%4MXc-ZZyMjRS5%
zZEBYz8M_dZU_rZUO}L++ALIm{<#SdAbCRYJZYUZ4OrTiKHiTN~sj0d%`pfdxX~sRX
zQj~ZS_dy+ at P4bP<yKDaHu`!tj-;sTs`S&E0)svP-IQuyMhvyNj6r#wcE_`BT+quo-
zTWMNVUqkb2*Gi%GyO@<oLx}F-tN;iShS~X-V3WqTxxK#34Bnij?cQ*t->!t%YDxeo
zS-hrBvU@<&1`-Jj<HxLb`jO(@Xb4S?lkx~OtYM<t3+hcx;$2rq<$lx at wr?Q*0gJXs
z;B$ACIXY{tHj`G7hfkJ`X$-b^cTAx>#2%L=^VEC#Tt!VZ`*@c}!g4_X=25g<;;DYK
zqbp$yA2WAEj-!Qyyf}^B=yjfgU;yy4#s6)q{+nY)^Iy?#0}gX=|Fn<)$M4;-YQ`5`
zqfh#q>Z%va;orrE9)I6HXwtgu(X75ta`_1oY7&0<27nmCM&VPi6CPh0du;yK)$ld7
z at w9XBCOqJ1)sm%<7DFKG4jVbX-HKQX{`&hp#bWnc5Cm1!L5!xVlNPc;RqS!2;{AL-
zK`y?Rl-c7a at Oc!k6NgJ|9DP_87TaL$sju21zRM#hh?sbrECInan_s~-U at _Zp{M`mZ
zNB=o>azu=@HAbv#=*}VTKH=b3Jp=yf_yXs{07M|0J<Z0AB(GSCxO=FGi2bmYol)-i
z8w?j!H5oSzkZz3q<iX$l!~GcmLm|w1Waa){&&#(+OHacbx7O}}BUhZv4U5(Gsbm2K
zXQ*A5_QTLGAi;9RPtZHS3)#I3I1mPZzxKQRUs(q<)3VXdaC=w%6Et=<o#HTG65Gjs
zDnVJ`!X46J*+brm-QtzvoX-D)VAl+kos-S#v;85IPRFGU;_Xl!6s7O)76dJ-g#g1z
zRcaSbbNTRmVr_hNGBoLM+eswK9VOXlhnQ(3$HbMu!yt2!rXC at DTZvs9@B2sC2fXca
zXu4FA<#a-gtFqDXE at a=Ha<U1S!iY}iz-~yxXY0e&Fu#JY?=xcf*wG|L#*>WKJ*0~2
zj<#x>%A<7wIwmC(kUrRGbIKcwS;RYI$j;X?-kXaLJ2)l#fi;yinq#7b>^16QtpcGf
zn(S(8v;fM5=sHEkj7fYquCtYS{&yZ#)<I73Uix_6(-L3*6>RI1E_PcT30U at -nOsU*
z7R^>8^`L{g%O3^w0-N?z at NVp78y6NI+Aup)Nf{fU>`*F at BgOk`Hj*FkvNA*qAvl=k
zR7z6s*$rIqxeaH-zg{0G)BR8~b#TJM)Y8*TSg>T)ZdG_8aF}*hs=1k+_$tc*^LRqG
zw1UV!2MX%5$Fq?f=lR&>c;f2D_-)*en|f6CHUnw(${@EJEJS~WGvb`sx$1D_hJ#P|
zuElH2%rK+11`11%rxqmmlh(zQPOce|M1B#^0(dbdF;srM+D#1q3Y(4GQd1S0cY;M`
zB_OS8c|vsK^(t`^km9EnGv-o_q%b8}we{TN3#{e#L|v9aYnLESSzf|V2$y&vL|Fyl
z==cdbXV`1GIwF1Wqm?Yws!(nJ+dE`&lURplS`DLzf!g5X?OAPII_v9mEUN~s&<E&x
zn(amdo9nEsw(TMG1oy1LfSURrCB2;Mkr>+FoIPkYtgRY_iautFI^Bu1MlmBeQA8<q
zteZWbaQyluS|suM8F?`zxvU3d3XXQgLPym4y5Ll3aTA%=gmPn)<tYfAHI)&@tF~4*
zg++sOoxh4g*3BO)sB807OC-0;%?@tqYizKX6<9qX39L^xlI!)U-lWAUf6?=En~SMK
zt!?1`GeYLu at brl8@*gt91FmTjOcuy_$Kh{+o!^VYoSm<QLs7KoF70xAE^0o+-{-9}
zIdC`dG9tfFwfPjdB?m)1f)&Xkd((M6J;SWkVVbWefw90aN5+geqW!FOi0_A(emzlQ
z1-?;Dm|uP2T89zJQ}MP<Rjb(HoL`{Wj$HE^36>(3ZcR~JFB5%47(Tb1>93P^48Ck9
zE6AZM(Z(uINa at lTVSH2TNUFg6dD^@hc_DQhQLi%ngoBPZ-xs5K!jPW!G)Y*kLwLeO
zdDv^4d~?CV;8QG#x{-c4fzQ|oArxU%A)NiFe#cN%w>B`}6~7gQq#y#&X%T at -ob=Ry
z7c-)1>pB+r&2x at IA9|~OHAU|d-WCDr-oU3c_rsO&S!+$Q9#nDo=>Z*Ce$lV*BsQI3
zJybkNw4Barnh3FR>7LW3=DbGP*cBgHQ~nYxlkb`fc}wtOqSK!F9K~1bJBp$QRxLYy
zwHe^DL^YpLJ8xhu>qdZE7Ng;WDWFWt{T4iZyQ|sMv=uf0-G{wM$!^OXyN^bj*evBw
z`aY3ot4zsS!J6PjluG|Ac%&W*GJ*z&yk)T>b3^4b>Qo_4R|6cH;!T)T<xLb*@R`bF
z>Ic)`Vn>=PNq>$lu?GHo(!xU}Ap8ieUAfw``3cGx0$hlX%)f3!R84`?@TTT?%fUG5
zJxDdh!5uYVFqL#d!^vZIa=!C5&Fj};{=T34HdYcrd(_1vhYKyYsQaWhouogkBmQgv
zse=B2rKp<ow*%r$4G|hm%tA1|8CgDlDiZjehT$|j*8n;I{tEqW9sPkrkU&{gdfGt<
zd4Rp?T@=~k;D9v<X6DApZ+<_TgmwjE#KP at P*_rXX`c+>jkrx)!yn=d-eA8923r_w0
zWw|(Walx;ZwTN`C*87qWfGP$Fd|LvUk7=a+`NDssRJl%q{=|wNJblH$zFQWGxJt2w
z&vn0&1F}(2|7hcU6TRSVVKJ~(SerQ7icy)0_5EE`xLA|=zgT!B<0=Izt$`>Z2LO_K
z>U~!K*aA&t{#Ks%qWauodfH#3>3qvi1Mj=7Db1K~#M0&Wkv&1eOF%0BPrWGiXX7tI
z`Tv;G$D{I5vnrRnV1K<9iC5cS4I$RT{ZF5A4E6LE^0>RCqt*l74VEh%NmR;-BQ>7J
z^!@jtc6Gj~a<UM9Qf&1B7a|$dO(w|&gZen=vVJ+4l9OW^Qj$+31d#)SZ_PqH!Zui4
z+ac!fUXoK#B!z`oVnrl`pf-4Vx?Tc;H1cQIB>@+6Rk%uvg|tEG5gwdecj-iD;SS-M
z(KnrOHK~$>9(~6-p_23lAKn$_HK6%l9I4PvJkTZudKu~PGs^uy-1)AMRb}VepcDKS
zXItr6H#%Gv^1>|9DEXu=dG*%`Yiq0Zdbg5Oa5V-gAJUcFIVYQ3`|U}}TANe8XC?-;
zb=>+IdvQWvf9gi<?#uG}k&Td at 8hrpP5EIL5vnc6*5<0E*)Qf1(dW99E at 0m0Lg?>!(
zD2p>G&TM0E1(0J>m;x^R7aNz0k8x!qxTOffUN6~Ag*m{Q9h4q`-1i)&3|qKs2IoV2
zyzvq-WrQUs*@@we^X-Lym%<09me8t|+Nb!JV?@Rcy at +%O&D1auDIkR#3k{8&4KEpM
z<YKp>BSHq*bs_2oF)x#2ZFBUHL;V^3Y-=5-07qUO@!mUO`s6YT)#(F5iy@<*AZOm@
zK}R|SP-^E?82fR at 1BN&yrYPO`Ec~WEsE+LJI%^QoNvqpRtK-Ou2k+I3ci*j at dmETp
z!qH0{*;>tC(rA3+m5P+E#74+hEUCTha=FxOr3X$+_`iinRFWPA#B&6RJe%WRl^5<0
zQGO}XD(2wV6tl8d5S-7;K=@j)CRKv2H*qMM<>Co(2lp at W--LZKwY7xtpTJfedGjza
zbyXlxbw$fptK~c|w^i^RYcteoyVh|CdPb&>gIueqA+v#h%;{xR`z^ZA>s>gfGm+w2
zlX+yVg^!93uzq;8h`pSPokVb#Cr45)z*f+sfGlwO;VRRrqB<L1B<KdkyMqnkJr?>=
z4GfCY%gS3-hQQ)#w?j%Py{9EfUA%r~{Jr4{wV3vun>(d)6V)(g2NP=LF_PSgi|FM6
zi$-mDx8Yw$@QS<6oYInu_)@bVFg253Q)jbfQj at QC7FCTKYi><H*la>RJ7v&sBSk|I
z>6()fUEz&z5vl0mv6qm3nB7kd^P{bJyS)4?{<&|f33%0zk4IrrOwN0qmQO(84yC~M
z;`6&r^{i#RX!d*r at Tr_^%6_9RZFw9LzSW7>6#o3Q3Czw8{#}dg_xw+^?}S8qWEiak
zPPyay*+|%@NX?e6%|yL&T3Y3y<x08=Ty2!<Dp}g-p7!DsOG-Qoph^=~zWfQonHSET
z^UPq#34QGcX+!3f{DzNmFEL_^&W6%*z-#^!r2Pq4nFvP9>L+Ge&m?sPD(G`(@bM6=
zpWHjlhgDyqe*-5rO at tW=ol_d1oHwtA0|N&MzXxGDXOdR}V(fTbzM#9JEf&Gd!zmre
zd(PnqU3O#`jn_yJW9mvD>48qSaSq55dGINE3abUr=xX7|oz07*W{P({JFijS^kWM4
z5*ptz$lYh3&&f|68=!t$j7ZbpkxzEXX8*MXSu4o8T8z7Fa?4FwdH at ur(%Q|*Nd<5b
zT}q=PL+5}SH!lChDv7v9101XXm;cZ9Uo$WLh9P?FGzS)*zv_biz3cfuNx?%U<N#>!
zhe`mR6!H_4NnV14gxHA^$xJKoPZ*cx835xVqN)6u=*BNg at 0(agJ(%^z`a=5K*5~qJ
z at Ax&%O7rW96(J9>Tb&OEVIY~0yMK7r>@>ON0Ri%Gy>T&j*!yUFOu)&q4&L+;Z_~aw
zP}H2;PmC+F at h<EkPG<jVW at Q-TVM76zQtt0NivAO%1)URHz4H<FreeRgM)iQD2Ua!w
z*_Kjhc^jPsLU5jU;r`Qa4(fhdfsiF`*D+J+3 at 5rAiEc*mUd|Fc{pl)vs at k%$5QU03
z)o5~43|6ghajt!qy&<*6(}(m2qRA;gxdOexiu&$Zm5x_fI6WYk=>YwG%33SWY_sU4
zo<dzYH`cPBpyHSt3zu+gQARXdF<#}w#u!&au{ei9?GZaCa<T2jnydH8Td{(xP%*x#
zepNr at jO{$L5b3inUSM`ExIne)%jsDp=}nL-O?29dQ+y2+NyMcf<4z8}bN*qbU(1<y
z1{atNxAfuTmoKF-{x6#PzlN)f4C2zTJAoY*u*Y;I97+z(_sW(>jLmJHNYE~@&k-j@
z!WjC1j^uDjD4UFH*`J!%88n}aXxOt1ceVi$n`+rfx at tmV^D7;iB?jKz_YMnHe$0|-
zvHlq02?v7MU#d!86Qe8F)KBgtPEjyx^@GXZ!EI at 8z?xp*@2R{E*5PR9HWc=7KH|L|
zl#anvW|CL13uUlWtzy3&&Vb|-i}hDa1xee^zeJ<hfJ<oI+$menFNrI1SX<!X3F8%J
z%RWV;R9y}d)poZ<CpOc%Z~X}xOx;~NaKB$pA-?JgOG%{qY}Km)cE-nh%L#IK%AJ>T
z%h|s$XIYkUgN-X;Yn&kJ&2gnsce)zUjJq9CoVY5u;-i`8nXDJlIGUHE4`G0cjUcA3
zn5af>67^J53Z|xH-$ta5x;aFM)~J7$%DEmhYhn^_kiXxISKSO?BLmmS>7RZ)&4XQS
z7J4Pi=lx`lm&=VZBYjS1B!XSN?H!8IWj-q*ZHOH5g2tj)#oBY~zDQfQV>BKBXi=5g
z(=n}D`*Ldt%R|Q=4NWeiOU+*GwcMY{89;vF$DxsI#>W8^AT#Y_@{d!(7w?|;dRI3<
zB9g2PfN&v+iZw?hM#x1(-It9(k at 4+q`-N24l at 2T6`_$LGT}E#?qM3OjN+H>4GF5do
z!OP;feF3o>BK-lhH+B(nlB@&YuK4%~d$Fgv;_W}QT6(Nb^}k(Fq)l?QPB*hAmw0Oz
zD25NKYMr#!L?QWk$k>p`K5YYBPAbz05RBca at l)&oUZZ9x?uAxhga5H4o}U24i0&2O
zqz!cR6g>b)>P!GhT^k^&*HH+BS*k!5vMVZ5_eBhesEzdNhCzK at WJEP_duH^ih+TC$
zsj6eOB%g~H7yvf2=gNGECAq{!<Q#p~9ki_gzyhw98sM}xRK*zdon&Y6V`d31m&*?=
zQR=wWE#1GlHfQ-F23uqZFz<V+WfP4*X?o0xSVzs*$C`~=!IGd;q;-E$5bU)|51(JA
zey&q4nt@?23&MlW1vr?Rzo%E9PBAg}J_BYiz at b?O_Pjx6FtUY<b8RkQbY747WjSVn
z&tb*zEIqn;C7PK&PYT$=8gJrm?8WLmtd^CmDXiE0TRFK%0D>^6$ionluf^81h{P&0
zrEU5XG^N7Y1S2&zm)Jh^+!>D{dMHA=oC>=DNWQ4;YAEux`OawmogBZtM6aT!<PO3a
zHp{NNW895ATiJPOvIGr+K7JshC^|8Mv?GwU7`l2X8Mhql^0EnIS_Gd0C6DavMB at KI
zRR;AoonFU!nL>(KWAlv7kxcq%7!kQPBBV`<g|lbda+}_>_YoHrsD?3fKr`CA?-1Wk
z-BLq;N;FQcw^x_4j at B%Ek5ShPLP2X8E;9Eb0djI9&uV}bNjNquK^{iYf+d>NP!N{R
zv~zlkma9FE2Oo%RC9edK at OZiiK+MN@@52B4Qo9a5<`?~D{xi9qmZih{oZejTY7hOv
zhZbm><5$zMK+}=H^Mn4EZT~j!9)~1>X|=<v&AaQkAc00!-xSUzb`u}te?_JyScnBm
z2l1$S)#jlpww3(o!1DPJEYGYkxk)gDyG#}Glsyc>`?+Uc^^neVv4AjNXws|jS;y_0
zJjsu5Q}@?YgfUf&oMD{NVfMxgEC{T#GG~VhwGKFH)t)jW(5ayiyu|Wc#U*9%3e4pv
ztc!nB7YNDWPQD1qO+t9vi%14FV+KOM2o68v6)D!_Pq52tGsH>*&%9pcG(M>o?Crfu
zM?B81pK6rB&S|<I%1OR;AAXQBXg=#6cSVTm#c%DRnAeqC=VJXdWs_MI-p}raqqkfR
z>l?_2v at ed&iJga*#L7=6l^ud(u1`O8&Z+;sn<X{nRylG`n<2#7M%sIK#3HI_)4uH^
z1+mA(vxD<{G#k}v`WV%Cspc65);lfgF&N>7;gnM(6WcuBo*Bv#SC>x4q>wxHYJ4_Y
zEi?WxtnmU35D{}Znf0N=i6*XdeQrY0;y!^+mCKk;;rHnwhPbv#edh8FynULX_uM5X
z^J!`r3vIk!0E%1q5Y}Gftna7?s~)Ade4<*%P+CU)fW!HwG9wx<%a%;gp$fZg1h4Pl
zD*vkFl}CxU at SV!lB<?ec;xywVi|+n}7tEX^-U_Pp&pH!jqW7F at p6Y=0vpK>z<%?p%
z`a+`-a^wo;EXIgQ&arf4j|W_1rRYRo5BLe~GF|4SlZ&=Qk7!S8N`Rx0wK%ub2Z&JM
zsbKOriKe9JX%(kfzX5EEfn5g5PzfU2GIb>iGOV6Kc(3a8ddtcKg5-D%?3#wEaJpjz
zs%;cbz6!2F_Pow|t3>lC^XnOM at cDWZ2ca@ldz`c>nW3-vlNgKJfQOXy0jxmeuME<_
z?$w;Oj>tz;48KdGuC{UXs)TJqxv?Sm+MCj>RGSgjPe>kwJdvIk2E9H!^SbuEXVzh@
zDC8qEg8ZDd9B-QY=nP%ys}si$etZWu&frhSFcwD?yjMV&t&jbH-TOPfrT4-3#!rxN
zU{%p0GfFh&cd*y*=-|h;Jp8XO;E^!Y#vO>9uYKHd;1#oYY3Q?>icqayeYzZB`feuf
z_T5WcSr?GF(nBvV!z!FyfrWy3_oQ?*$GoZfGkpY<xo&%Ry9LTG<Ish(3nh2U#jamn
zJEiX;XwU?EWOLJ}Sot{AMRZ<|QPJM0Z>f7xAe@%ay!4gqkg1%Ye~+U&)`sh(FthI-
zbCqvd#m6CcCpSlr$@Y~i)?Tt!Z;c9M at A^ww;qAPu)|-lkJC)`%Oqt}sEx$B<S%g)Z
z<D6WL{kR8_`+7MNhd?6#L-&aG=pDtt1;xs8r^o at 9mH`_0u_~jT<f(no$ONmWfOuGR
z`xF`KO;Df7ZA at QbG@vsOeYw<}g!DN%wL#)W`$!<xYD^H at q^u^@!#q2JS+m?MTzp=<
zZIy_G&tmB>X$#?hbB8@<Gn$XWX?bwc8`VYQT{m at nk0$OswuDM`w?&Yw7Qup29PVE3
zmAN)+Y~dGXO=IFo{w0i&mH!PQHhBzt6UQ{b_&}y1al0D&z*a5-Qs%ZwD7!<d4mteX
z6H{f??J#kmG3qKOTw9xnSoLj+l28xe16-oWijg_8eFdt^@XzyXHL8!y<2;AI?>UA^
zHsm~5DdFbfq-cygqUb!&7qjY#{My<hyIlf++0bH*x-UQ5+xXy;^1NF`&1xaC>!!&#
zZ4RDM(5^{AmLdpHv=;@n_6{R$6!euOYJv**!kPxJFNR3=tUg!C)P-e-lJJ}zsIbYQ
zn`<_Pytt2+AwL6z19rv9rmL}_G>3<myO;E<0-k?#Cw~Q}ks0m70<5M{aXk-BuLLeR
zfz^iUk at +Y5$KyE8BeK at 7pc8dE^gn%29+3hk9&-dI{<+#eS07?{5V%Ua{h at b{folGn
z|9=+*Y~-M*Gqd7U0;%GJtDoW+9&(Sueo{lt`4)8*=DgE49fxcd@?CYnysp>R>tUUl
zi>s$rNQW=y62mM~S9=9q?q(1+ at g<J*zSwyr2V}0Gp{W;CRidke9k4G&eo+ah9-%MT
zo9{Sq at bQO8@%#YgE`4L#OI!G*ftXRFivvMIM>UT8Z$;AVwWo6yOrG_4+UZ1LZ4!83
zE5jb?#Obk}=pC_&RFfsTGKvOUW=TI+EGV!4-4Bll#Q$QC`mc1vBk0v*#f7R}C>p|+
zZ<k5;-47~kBDOh4n<_-HWM0att#+D}@opY#v^=p>rAH*x5`jF<PyAt5>)Pl?>PV*8
zc0QVhwAZT))*?gL&X8Vow=b*XFSZFDv~Ca|K!hq%C)%f{9eVz{>852yeex6ZfRXZo
zVh%npFO3Q3^^=%h8u3G+{g+L%@xmnNPu0zD;)e2E1Md_rUMMFbmkmCN at l%c^6d$%r
zg}7+z%#3 at R9{@BvX9Km~@cC6Sik~3Y8d3K%-!2)f2a4vpkKpnU$v_TNx at PymaRw)O
z1pF&DSr1gv0o}%i4`MZw(|c_asm7u{`lv08RKyRO at T%i%H#HSA!MZg$R(Sysx9qJX
zvQs(yO{bH-JPQK;%x2PtCM%O;t*`V6IRUeHh&1+vb>Cfgg$fQYY4 at zFJ15`2r5D9Q
z1`9YL!diin&w9WP5$#F#sg!AAX;SR$YmG6a3$UvnMVZbs+ECn$A`vu6Bd0?PJW5Ie
zW7B7wF3e9yEWXgUKR11XWuOeQm36=FqKqh=TR2d4PV}mEDb!kG5|b+H+ORZYe47={
z6!C64X^%S;Cy{R}y65_i&<-V1d{zT1AEn{LYsA&dB4@>encA{G7YI(gIf+ZhcJT<)
zAu~J{TBCzp0j(j6NKNC^7lxd=DTcR!6Y^1S!(XxocEAMkZrKXL_|S4|T_q_uM5xVt
zxh%Sj4QP~f7AkvIm5OMvFM+?O!x4B`N*9>>%JBTh!Q6|8NSEi`=)^o%g&YD4`Nmas
z<5o_ei5HAUXhgB)1pC#JJ=~RJ7njH9T_&vN_tj03(^tS$)H{>5oNV?L?>KV%vUkTc
z2lvOJhuc`HrHGESuklMPawTypSzEsS1WkJ%oOxfq0XQ^?dOy4m1g^fd+>#Rrv+n*4
zwItgAL3>+C&A+_!U^B}a)k<>%viqoQYZXz;XkR{0ijWf;VH0~Z2~I`E*XtCpyx1|u
ztC$716XnS=x-G5XWk5}hY1EfC<nFG?W;jR2?bgxtoZ_>gP8Xp(5H+?;yiyd5<N<#i
zo_-=nc5}_ at UlJBfOF5w&j*hNrK at iq1N&xEyeg{&|rvkZ*7-*ENi!)RcKX*);j7Hja
zOn7}Rs3<Co5;2}qT~@EXZ<ZPShafL@!sCR6kIa8be8PSldV1{h|4ViI2UcdhOJ6kD
z5Aq at A29fA|B0}D9#~%vJXI>UA>y#{wx3Mafy$l?o0YTY?Pvxxh5Qa=opjLUAMtKlb
zylb@*N=|jZB0 at 8NCt_&l?$}Z(w(W*HHb6B9KZ)PBc`<3rmEo1~pttQ%-`!+xSF)_J
zPcStcZ)NeCToWFh!tg~194F{3xM{7#{EL=+c|{AshbTM`$j7P3<V`CtC{E5zG@&9j
zochw3LY<{O=kk4=oA<nNN7NsqT4A0CwZWp7 at D*Q`NJ&q|U5l3()rT12oYkzMlXiaV
z1E1RU<PgIYjO;6Q7 at N{hxHhlLsIrd4V(pK{KkSC081gz?v3=pYIxf18GC=LnWZSBp
zx26pFfb848!wF7p5~Zn7hdeW9*(=+v;nruu8(deh`tj7cFm&@aW~E7kz$DMcFl%|f
z^MibO?YVJHR4e975H<=Y0tMM+`je5o#l44DqtQ}(C-i3=aWk;2LC*HbAZB#D5m^AR
z{Z!q8!-YQoTi}f>hIAhajzRpBJi-LOl+LRji#aV%>$^@()eH|~;*u(8`7yfwBYfJ>
z@(nJ|R+vx+xnNX?P~18_e><OKzqzJ*Pii^q3&0_VN5RK4iZU$Y4jDnPI6>Wzp--|5
z--8NEaeZFihJcT-rv|V_`8b5 at CZ9JqH8dqW?fr at pg%Z}ydIiJw_Mt<)>9jiobwZ5q
zs9V~$Q&7EI6pN|bl~~3?PuOc-u{4EQ*x6Tn8A`QBg_j6sf;<p`BSS}s{=UJSADnun
z(_2?F34RgOZSRv$7GaIfd!|!uH^c3fSF)^`)P%Dj!zf$9wvt-G1IN{VgbzRjXGfs{
z_bSxC9k2CgpX}e52!DclsXo#?syd+RWCm-#?V~8R%bBWVVFFP<%K-1>fFKGQX{V89
zE0?$vKo0d60^Jb+cgE%xdG9Ca8)n+ZAAz_ZU;>VNIKX at U14-^I>j4v$@WJoa`vErZ
z+aGW&fG!Om2B5e+frQu4N<Yj1G_1cU0PAT^1L&DAA6P-Z5eyw{4-&;^PQctb5pmOH
z)HYR=Na(Lb9VU&u45zES*T}|Nb{X=1f>tHH!~O_^{)2Dt4~SK}P?q<op4?ARE8zbp
z5O{nO1b<o~CQ2P-r!PM>O=(n1z0i0S8=3U}`-d33-kqpOu}M<N(cl04|NYm^$5n0q
zRu8iW0NPa#F965>T+1bf1}^!&3~4*#0(~U{$k!>2x=!xXQ?9F?W?HZDosR2}cjX7{
z?{)jf`|9`kkx`!V6|&o)^kuc>N)>8I*+3U&K&sH5T$1 at QdUlbX0!qU)x^o8?x_cA*
zio5cN)>v8H=d{VG3Q|tJy*=)J_ghjC_>JHXPdh at LU<SDESyT at VPPcL<U6{WG*ldST
zQZ`QF$kE;A_d=IyEq(JsJ~+rIn&Vjxz|30gR@=f`_2S)Ob;Nw8R0TvO-jkd8iCr62
zEq>nR*Y at MP2p&5H##6|=&Ao>hFjj)M7i3N=!BNC+GDXlhv-?lphNkXkZ%}aI_m&LM
zYrUzg^qc2<+nG&Gp*Zt08Ok at +eQZ%Dte%$T&!chd_mPPI3qAKYA1w(OI5GS)fmYLL
z7&5;c!|q!kf|F+mj)2e<mb7DbX0(DxAi{rc>F*l%f5)Q-g8cu1(GB(34ZOpaVj}@W
z!y=T+?O&BFAltt8p?oc;>jMo00sw^F<4O7pMfdwy{jID1i040=38as1_7CvIqql|F
zqj3!2>i;j#=fCDAe)sJDK1?72e``jAb^(aVe}jMdpV8HiJ)n=?^wVBVC3`Gp1fLWv
zoSDV1D+&u2pVLVafuOd1xc@@@0G!}|uTbAFD8+Bwjk26cy2E!8F4qGM9#+?pRu|dI
zOCORr`*!k+^#0RF-S4j9$7`O(En01MN4j~rRKaWyxn^f^iLFloA~PaY at c%!?0{Y|V
z(GJ^@jYN{*WM+s`d9+w{tcvOy(p&je5IWmGWYSZA+jtP67rvhYaLWOdK&<z<92yWJ
z>G0mI$+M`PM=Q#cF}5q711tL0<xCpXk)1_*Qh#k8wKlCtxJqK2w$^2=W%7~GX}s9=
zkmnC%tDDX~<F9^|$l5_8p6 at l+;+{KJYrP!oCZIiP#c*`=L+r(mdb4N<^9Wp0ZU2HS
z{-<+ho|`V+$)3O~!YF&TUdv;jdDE(9 at um3D<nxzSJ%NCZXwjRgqmK=WmC`ps<NTt`
z>Zx@<UOJ-Xh^rWXJq=ZZVgCs-c~!WC;)`pu4h2>jawoJ~|AIaU!leg?L`~+u_7;v9
zj$3PFbIQ@$yRewHBCb=w@;kyF&2QBgI(V>Cu_|d~vvGqs&);h6Xq6kVb)EAtl7(V=
zpq#=B5R_(@gm(itslV~w{9o*S1z1(t`u?F)5F{m)E~UGX66xjuD&5@(hY%E`5s>a~
z=}=Hwy7kcA-TmLp+_`t~*4*FB+~?l^9i9iy-ki19UTf{OSG?c*y<b at OKOYxwAX(q9
zs5lZiYcdi&dqnayPRz}Dqt8U2VedRM7Ldc7_n?K#09aW6;O_sXQTrxvcC$dnVnwDD
zPwT^0qXofQjj12|-cj<`5cVpDpM+}t!1wzf8E*f{gTnl|lUgC~5<7{t^ef>(y%^=v
zkVh2(np!h3O1BMe%l{8g?yxtE7i*|YqCIEL(aHLCRW;vC1-GchJ!)KR6G(aQPW%;M
z`4fWsOFq%R<I?;Ux8|2*^52jKkuUF_6FGfQggff|3$)@yBTG$6Jq>L_eWY^BMl%1Y
zks_Bp#mk=Uijk4#DgtkzX&uN;pLusZN)8~K?UFV8ZkA^c4%kH1Lgqf1z>Ven12B#D
zKjgcvWI()<>~y~xn9pVaocreKpN-4^_TuI#uQH20j6jnWI^PYDDVYnJ^II93R?)M3
zY`Y5<Gs}QQ at BQGt6{RagopS3gy;s!-LsH92qJ~Ih1^NCrw#Ne(5zBTQDAM~TgJdaW
zJzftLHOCyKs<5as+l~~{AGtYOR9*T?Idb?qkEKKmt6yqy-WAGyek56^=f$3r#lVnb
zc<*hH4~D(`uX=H=`#dJYadyrLG_f-2)q*$IN1^%&q-ns1@};D~voBK5?2xB at pFXOn
zf6x*~`z=&S<!<*NQwrB<BXg^8or0i9+va_t5idrQn6*5U!<hV_ZUUoE?YH`0P1^~f
z_GR5?G{eQA4{6j({<AmRPhM^RX`jE`%kF!N>+g21qTEeV|B$@^kDch<DJsaac?bI0
zF!nR~)}{;Gs;m-<BP3GrOh$Qt-9l>aB293s&wf?%e)Is!gKY5F5Pj3TdqTU-SV2iG
zy*vVC-s6e9AfL%eB9r>+`%;lS&~!M#3V|QZn=pX-A)@)pBH>*ffy>@|JSHbBLZ0fS
zJVMM%qXP6`zJ8l-oYHc9x}#bB$j~jiODe&JBn)w#yqM at Wc6oM6CO!I5p1Wk$){1?7
z2(|Q4!GrQ235TeLG_c8gc$Pbp@@#C6LsEvJzv at +GxGBR0xGvnFGT!^YDd_$y8=~JL
zE!$1|=Z!_A`On<p|Al?puPRoz?cs)`zP+VMV^w<R5auy5`GwSezIqIqVR^JiW{{Z%
z?P^=exh&`Bap<?UJ7EL*4naZz9i3#&k-~U?YwqYBx(A8aoUpe=^i;e8G2J;1yKr~+
z-cp;6rSYZ?_N5FYl+WQ{GWr^curQI#r}}bd+XlCz{piG(?3p-VJ^c%a3i?-%)&8;e
z!9P at OyB1mdPxv(g;7tmq&<i(h$g<5yqMn(0^oZ8Q%NXa|W384}IP68Y?|i%yl$^by
zc5}J at p8>*NJH*@o0&Z^Fe+!`ccL(gQ-DSTA;=Tvr{wTyxc7y+wmSC=Zg{oooJd7_v
z4RQlOEkc?#$~Jd6RbDyj>)CP5D984vOMEv^%Bz5s)2~aD<ua!|cvuYmIC%RK&AaYk
z4T!ds^+Kj39wi4XV>UG<_5sqi59s}^KCO at bGG(<8ZPUAc8z1TNRFy2)M2(~<+dOY|
zr1-f#Nizd{W*{-ZQ}SzHWkpk407fg72OJ)pBl@>`QcdC0BO<!;nzpIE=v{o9)sjg4
z2_I4<j;PV|XCfi(+^=9-(A at Zo=ve*QtWmn5hvBnI=jbCU1HI3Ls at u%G)1x}s=CzO9
z9P<S8^$JSK$;Zjbr``L!<I7de!JXz`yDDRt$0aZZ`nhc|vn1Wh{<54i*700ZEs0sY
zSUl!l`LYFU#6BYTe&iboHa5Q_ZfSk1d4N(HXIZ8W0Tl%*Ctu1Alm5>j|33zj|0v_y
zuYMfg)3m=EP&x4YY;O&>7IW11ci+(oE+#@$eyxWD?>Mi3*z&tAtrh>$f&ZKC;d<1(
zhW0^JhnkPi)r#z>1}oLV*jU@)S`damRQA|9Z{m3|m4Al-X3rHUZ0?|_NoE`4%`-8X
zJChx2JYTLrQxu`S93z0EoDqE02xEPeMk?MObu*DVRXT-toA7Y1CNz07sb|R^2KTdn
zV~^MZv&Z|!r7<9`5-6(6To8G%BJr`zTI}Y4ItYs>N737RSk_@*0V(Ww?DL2qX+=du
z5BQa7LOzP76ah&If&*tVhQpgT+|=gr(*qI(!r{y)gmVjp@<c9fTg{v!rBG>jOSEWx
zhT9mD7H~SZ5+u;L at 7Zxl-py@$;)Q at rC?nFhQBFi%QSPeCX at 8G3Oil`}gfuE&)>%cu
z`JSqTGz~}vFJ>eruiMxWp<NdxP#B0tt8jl9c$}ZFDRMch{BI04k5EoYrp}mj3(iug
zhAq<Q<=>KeOuU_YcHUGqZvrR!CobK81M>6VR7T_n)8Kf`6g}ba$McSaB;w-P+5+7X
z{3(o`Z=*zJbmRyyEqp^QRKIk_U%)Bsoq~06H9fH90^7cBXD@%;hsnKG<Cm7vNTMkj
zawK6E$<(=snCn6}*dr9wwPQ_Z_i6w{QQGPEE~^`MIa<zXfxhkum{N4qPwuAM&sgKN
zn6pQk*UdgMay&C=qd=k{D0qr$a=Msp&9{6S^R=G<iPXKVdd}AmiG5_9wEZxU;Wc3D
zepN4{Um#|iYfffbAv`vBrczu-?)`~i%~z)a77yqr&oygp_m*lt2sx=?HG3$s_0G10
zcpzsEQMu|^JfkvvhrP+$LMA$;+~=Nf$l*jAK at dSZ#ApJW7vhEC<3*VkNPEpS{p0sH
zZiAeK0P29bD6!T#b2>tJ(zFa9V%&7pIyG1(O$%GtXD0ONBmIjlQMU`XRTX7%;_Z56
za+mSvQT`&N2a=YP$=(F+b&BUaT{!{)XH9FpH2{i0UzoY^VYbvqxW&bg0{vys%-h}U
zuU=-uAmyR(WVsq~rLKN%5PF1-dHAuhp|igJi>m0du`;R5N2PCRd<XB>#nEbk$`zkD
zsVMb`<`7aQ=y{Q;aG(uZVAE2tO>~Ci2+s*^uw3Gj^!A}gAV^qe)t#`<qh}X(`5x&{
zNUEQ6ALZjk+d?-j$|I#iS=AR34tuLoh*3c at M9LOHI_F~naw`Ta)n{%neVFnuBJF<T
z=KQ0J{?#iATi6|3F^CvVZlLHFF0KAF9UbfVt`~GtEV*ndnsCO70t2*<@Hn|S5(qws
zXy1{S3d6LXNz#$ncL^ps88#P?J5umAE~_Xvaej~Io`po;A`gS%Mmn3Z!<l{&HFMTk
z^3^e at 0J4>Ye{df_xc#(3maW-GtyBW$2<Ls9JT;#7c=73zW>TP!gBue+OXxHpQevJv
z^u=i-3~%a!JMan2eXC*l{0J008gWzqGhmGW1SsX-Q3luE79B|oPAxm;&PYBl*TxwL
zth1+T`!SayuXR8{CgtmS2=x<ZwYlVHHW1X+bLE*^*5J|X`k=AbHrV6?&-~z4)*_Eb
zaI3s3;;ZANf-8r^=Xk=FXj|m1RoP+Ihg88ZHjI`ni&N#Vhh)mP!NhYr`6~Z1F7~hD
zXn&-~`Ewhq8TkUtK5T$IF)?}>8UYBZ0z}DB6v)~p;C~?5 at z<p0e at CzTpS_2gyBY1K
zetGcbIPo2_apeT!(z%dngEIw+A!EV_m%_K9b*Nj<0fMWQ&<+&TSI~`g$$!nstSi1C
zqk7EvG<fvLa_vjd<zspV4@$6v5>aOfT7B$;>}b8VApKl{vTJ<O`J1)=BGK-A!bWv~
z2Bre)hENhDlV;578O=teMScfs<BMSs=^RX1hzq>!2w;ZGd6vZR`em3@#Jx)@9$b$9
z2oU-I-~OSx2|WHP(<}@69q$f3IS^?^66hcWzNR*0L|`{EVoX)IlV=~UCeLTUeWyX;
z^CSB=Dptr>Ad4#y*5S&*nv$kg&D)7dkkz{v`9q=&6Hg(^<7dxqp at Q`C()<)~g&RTo
zIH!N{GegC{>(+5EX;RG6&Nh|;Zn4dXguugfemW2gZe#O^+kjW+Zf8i0fSHirLki#I
z$sg9*9O0{eQ6oaY7xfA~h?iL)7^In&qcQ%tm#VN2cJbjX38ik2P&mnJffCu%Uu6sX
zx0|~ELzn=+q}~jiLi-!ynfzl~rH}SadD$S1p36r}%Bx&V=K757IPHjEheP1_ZsXk9
zY{qO&Hnys)EEUcu5&xt=9BSv$v9yzd_R|YQ#YAPeRy$nj`|JS#cm!2Hc?82lo;2^K
z1iP at Fg+{k1%q2<0jFctZZ9j>!b8G6grB!BK2r`rgHI0g#IOK%-{gxnwDL$U^=jfwP
z8Np$9?mok2>Fw6O0{Og9)t^}d=M>+sc8YDH3sCX)o}yIN5lN~Ow}T3WuuteK1-3%b
zDx$Tg+XL~vq~}@I8FJGam4=uyqSVY^pygmJ at 7fRz%a at YHAXUhl^Xh=x_+6oM<fO<4
zNaGH<YrK6P$qKcVgviI$p at WN*%;yBgmq@~Q+5bbVTtBt%zyDM9!2uc{NwP&<RpnIT
zM~A at p(osVGx%*yB{|S~WA+ at 2@0gJfR8A_KX`dMa_4sH^ugZ$Z=1`+`4sJsFlKp$S9
zD?7$~fZSPeimp-uXY_S0;_@^SEFt-Lpb#5>K$eshx2v?BFqx#TD&_SX-Y6V;a9r!L
z9#p;T!Ly=h8a?`v{N-x4T79{C_+>XbIxM}9 at MH!_^Bn(aA6s!+HB63~q6>psb at ZZ`
z`>h>?nXmd7>7b>1Zb5Fg>IbIA+mlgD^KqHYqg)~3_z9aK*!Izn;Jgs!5beE%DN54n
zhtEZ_R~mJ`y2PEHPII$@$MfGUXrF(wOQBJcz_d_He(eb2XrNIUD&GIVlP*yeG03pU
z(&Nkwzq4}Ohh!~o*QdRzc&v8`=KES9t?c~GD9GQg-lh>9kNCodfkC<+h=b%jSTAGG
zG$xfcJF4&kk*qnd&PDKDH{KA&X&^mOj^Lmrqo6^!YoPiI*@{ttPwO7buoWLOZw&{H
zI;}7UU^znb_gIufK+f~Ts_~{T&RjBg=ij*be<O!>CN(>8w7Ix-7rc0wrz7d^viWE=
zZ+Af<pQ|gqjMyOIAX{EAl|KpBfAZ8sYjGl|IHIM&DI)?CK17O!n})v+$z0sF(=<nO
zZ6#BrKv&w*5$*AS+^2=0T+lk at Gh=dx#(XX5>Op=n$1E8SdsmCfPMcu6u|&C9WTr_k
zUN?qry`5YBneiVao2y3HVyOAdRUM^b_z^#cEqTe0loLJuP`~}wSwU`HzjoKkDkXFg
z3$80L!!}HEFb=e7R#<V)#pSHlzd2?0<-LJz1S`w2UQIH_xHxqx{^8TtR6~|J8r=x%
zby>=-gdz&It;j1q?)@{}57#fLhUf8*22QYZ#wfpOa*+!O5r-#W%F&jDv<A);KQUdD
z$#;1VHs5D_ at rKWfA{6PK6HN3Ri7R`Dqt4^K&$S3$&eVK$Z-#;s?cmT$PP|%08Y!Jq
zocO*lgnTF;DlgP(VRCe at X-(NcZ!o?0nIvOV#0#d?Wo1oyOx!X3IId^#Ok#6)@|1@#
zdZp>D;ioTQh)4po6^*MoMXWs|S0MEv$Jd#|)=UM{we&udvPE)8L?JfmAxOD}@)#33
z9 at z?m)<#^|U)xiSp20XgkLuwIF at a0@Cv44YCCY!yTlJB7try3g5zQVU{Fs6np>!0k
zK~d!jbc3sFLw4r?jbUrOp>$$we0|T^m6c(mr^^`W>!k|Js*1XwX%gc|d3PGx3MtDK
zh;i{`lr&)%sV{JCzc-+?RArbkkaQQE5PCMhf8Gsp8lCQNevV9G`nG-gNL5MlQlPS&
z0kKWFe1t<rCZ8~<gsHyKC(~1}f6j;R*`?zLVFY_Y#^HlPrb3C(?28g9f{wFSkyb3B
zwGwQRC+f1&Qka0C%FC)&$o at k>TI}uAxvCQsVPau36rnZU`p`YQ=lBq3%tv^pX2th-
zBnqdQNxinbvi{ANx~jlg{w0eX0^?D{?93D+y!2F4td&u at IMu-S&GT4RUcP|5aQiv?
zU_o(#b=+>x<U+JKs!_mGV$xXL<ti-3!`;s(X!qZ8ulcZOdXjD*6u(N1W8k52jPm7*
z6Cu9 at DU?^U4u1^If_|Z at 94x#S<;HK5S8{rrK@>o*3eI{bR(W64Ni+7sP?Q)lo%eY<
zrmAq5;t|}7YKP_Ni*Pse5=vzU+}>vogkIOGrW%xmn0Fvb2!E|PO at ch0t9bbO?!@MT
z&!e)S!vMRlNBX at BfuMsEnm}st2o;I24dE^r{bhQy?PLty$k{@{)zkT~_ddJbG$N}S
zqoqKQl^bqlzuuvSzH6kyq}*L&DUNOtlRQ8P0lg(u7=~gX=I72yBl01nk4gt83C_Ra
zUEVL<M5~{lHrVeiBnNz*URGTK#HQPjY5XgYA-FQ~B5Q!|Joot?4p$8QhT|bcX~Dyd
zP;5vaAlMT{0F*yt^x?z1vTSmd_Qv*}Z7+P$^;EShF-6_so?M6X<Uo_TAU%@|A<;UV
z9dK_^ztd5(=VM!~PcPxZvrI3=RLo)Ntl=*!cL*JUI?z_`TIxMU4@#Jk;Ke|p_9pSb
zU5bgj2tLeoB~34$G%XdO3nZ|FW4K+9XM}1WnIw=moYdg%IJ2Q`TE&#3t at -|S5xj=8
zL>r&fS)<iP4=qW^V&IH}d9~5UDvyWFRrpHvUfNo#*!p&RiGVj|&=OpzCmr-)o0L3m
zOnsQ+7JV<up;`qM-jmRGWgvO at IV50SsmiPM+vk13z<5?!{)Pa`Dy{E*zMB0iBT1G!
zwm5YNN9r at f>vz~4NnFohs-0U5k0;wU)ST=*@>WTzShBtvK(p<=t3wsP9;W9BJFx1w
zI){z9-l>W!m^8~$WC<ZSq~Z7EFsf<A{&wsu{vMnktG7#yVHj2#31b5u+I4L)Hg$4_
z4z6}`7JFF3a}8vOqA)jxs`2ni8WND0z?G*}e_$O|9x1oxUDK$mibiyq<LtW4BPy{p
zx7b0#ia^yH at ZjFIZlWvY+O6(6MkX6&ryjW_C=x%c4Fb&2hDq`D%jzpXXc#yrze9C#
z?k~P)xfvC!BmHUYTI>K&0WdMIYIN~2w|uHP#GcQ1ufkkAC6Z#1vGL9)?oZQ-&-jQs
zbJh!~Yu<(9(CV}klEXyGRYe(Bg&4ML;xPB75*9taq}$@Z<7qVPIaG>5%J4=L(NGuz
zcbnw^Zm<yS-?P}+gtuaz$1ZZnU!@*_$RZ)!t|TGowaq3R66dRpbolbFRdF_T>?}i}
zbdi-BU24*E)(skXA4Ht_(BeL|z$TB}V;~p<5EdSIHXXD0O|a_RN_IGoG;m2gX-&MV
zT5}Ga0+NdOP>-Hsx3I6h3zQ|*ng#^$Ru*>}DYA9<n{srM;mx{^lsLK*-itnffv)3v
z0orJvQZPn<IJAr$U>&-H at B$r<eMQ%9M9FXMa8yqEgA_d74k&qA!JN?3MVG>~MBJ!M
z8(&IeLO{y at v-e$gHRBunj2jM8eQf_8k2(&HZfZ?D?g~Dd at UQgOPFV87h^~e7|1~>4
z2G*OL{Tru$t<m*)$1=DzHI3s#hOR}H)Yk{o^@#Aha=fUH6H(1cw1dUi{9{e%d0XMT
zkwLaYm#P)wXd(nv(dyX8>2h@%d)DZz8KL2yES~8X8k+j54$PVhP(w!*2fIS&wb8=T
z$mJfFeCk1=2py<BUCQ20Oo(BXL6}T6iYRrxS6M?x6gd>W1q|^-OoF>-pR_XTxofJU
zPuib}zG^Cx>L6H_b>!WQrOwP|ycTBk8!^!i@>;cH+Zfx)uT-<q&}y?ZzuSVYkD6Yg
znd;q*7J6qg>U*`t!wKb8%fd0;$A^{StCdQ5-d4MevUkwueI&`ZU3q#RPo;VB2s{)U
zVk)eVd1H$h<LqAE0<U2*L(h#AgzegcC_rDC`8?lzxiTh>Dl;8Xd+KC$9whM?#06_R
z9_qG1n>KwvI1gAt4-Mu3Imw_g$=!OWI!OH<hTut`Tp8V-OoZ^*u-gH at a@xR_+E&wp
z=X at 3^4hfr2!`_0Nm%`lC6~$4!Lpd at wX5+!1$WHm41|)jJoA8tn*^*k{RpOIv$H=<$
zL()Eky%d}|s=}7w-RG#1bOS9g&W)B6G?Z<yFFO*6>(9#`dJ_gqx1%Fd&I#nLiOj+e
zq&n95=!j75QHpx&J8Thfw}Tu6T-LyVv7a=~^0Kf%Q&(sC at KpYr!QNf*Sc3>%419WC
zxB20AOGgIl+pBz*Vwz?|;0*>^MC?0Os7Z2CBn;_5%$jcMCXLd{yD!{0g5(g16!%nK
z2~9!~XQ!0tDr>1T at qE+1bs!p*4Z%meSPNxjBWX$&<zCy+Da09sBU39&no}8|3KZxc
z>*=LyClV2bSt_QfU{iQs9n%a|9k<=|fsZwK5&E_SWSfxuxpFxJ2`j5NUu(5?zSbkb
zdAnjp?Pb?}!)NJ>@IhEX?%NFRB7;SiTD!aFZHHqWaP6f_W+3J~lr``3ZgA;fT1oV#
zRP48+Og3&kWONDc#+AnWA!IGuG;hCax`+(~YyZuKmd*nK!4Vn%r(CwWZxY`D at wHzS
zI=@vwie70z-^_%bM$Owia1Fuw5Lzh*x-c&p<R?rsP1R%^ag{tTPhJ9C!bOfzmvd6k
zSJF`mzDaQ_qW6P%4c=N`gaO<sv-D1|c^JV(lB2%wIn!IpQ!j$#CTO|IPX=UILIVvw
zSM7~Q2myz<^3o#~9B;$-&q8_h?`f<XegfS3VU*1pc2VoEKt;e>FePsGBMzipNC7y_
zKMzJz`;_D>PQ~;CUWqHF_)IpzV7kL51yd=dYF7z at +Mqdjd8SbwYQg}^-<*`!HvhB>
z|2zk#Hrh9HHRYo63!w%8i;r_%>@!2O<{gFn)!tiqaBfUnebjDpyM%uhIs(L_0_|E7
zedcWqpY;#~zp-Y8e}@-Mjh;R=gqef8#{L)f4T=USV|jh;`*KdaDbqN#>c!oom+jg|
zG-SPn*8Nf#)@S<7$@}zIpalt`?Tq2H+FDuq6E!peU3?~zf<ag^3iMbKIljOZGylR&
zu-V8OZo7 at 5ZyTj$MgJ?&?9wcxhk3I3x at KBLPoa`}J_k-?1(W8bponHKL=cI<nzPjV
z>dN7Y*eoE at +8v7KZ%8)CFe^X+HufzHt*;YILoxU<qqNA<R*S6c&koS~FqcLubFeyJ
za|B~-Zk=(q0xB1a`mAkBual^)>jkZlyR|epP8{m8-K)tP!jDAm<`}$2fAKOrGJ!bR
zlfg3((KZI^nOiK4!{x?Q=p7=i??$6Z1`1jS85onSNh(^}L3iyD-tvA3s{V#170xb6
z>?73#r-O?F(|c?z9V3Sy*^R^5?M!ZK4)aA6)C$wMG)k;8NnKV`Kk)gR#QR>H{;tw8
z%c%<QR(ZIc!i4 at fE;tZ)N at q<={Cvb{ToOH>)irPu%sGzk+bh<NOY at 5H&q6*c)S-(=
zcEr!NUCvz#YiZ%|n-00~;vR(oQmJC>1&AW;#+2?39I=)uQ)DQnBaN9KGYw`<n!>&i
zvyc-T`(Q8>0s~je-wo<iz9D|lY5uK?lX>-!b<Tk4esf=feS`!7Sx+rJEnGzD_Q4mE
z(=H=gCh8&8O7J6lVj((^F<im{xr(#e-HOYAXEcNN_6jl)))!(mAK*OT-6u|h*$09S
zg61Ata1 at F-tVqOKKPM?1vWquaP<H}NM~u^g9N+}Z^<_${eVetqhe|hmmO6Ih$v2 at H
zr04c)U<U<6!C+H?!o@<${&n!1WLCB?=Lf at t(>v_~=7^VHX4^hZl7ru!moYWJ&+fud
zeRtcXcVVQ?EIaqBWbVqIW=~J)lRAwoIGBwvQ`qq(gV1L6Q<H(Dfl2O+*OW1rPGa|_
zXIK)O-F9?j%jqnwaj?)SrLZJZ;9wK)!UrojD0<6h-81=<WX?|r*bTL_HMug5p9hrx
z?;)yvM_<2j3g|KX4m>+7ZP6IKT at msxQkev9KFns7F?`)7cy_nCC|kG)PF}rmLh>hV
zR$c9?r*2)=4L!hs)ehbCK6<*n>`}wd1hD3%FeGuxK~ZmJJ<x#t8H>eb|KSTMGSBV{
zm^nhyiYj13&02G8d}ywjeK|6<aL=Q`sMUroXbYedxyW2%%a{jvP8?cOeV+R=l at J7|
zkf|4&VbxdSvq-RR-JuUUpwz2 at yn=G3rfca+=73L_C<DK6<r_RZy(8<0C_Zxqf`RCn
z-<|>jaJybAJTGe>OYq^{6s#Ci6#s#5q<6==+j!+wFWXbH6PM=;$)`p&Xvf6Sz|gL2
z{dJ=IA{mRE8FA*-cJ`5H;owT-N+Pa89;_E=8OaRf_&YQ;Vcb6q<azBv^k4D&ec<Dp
z=j;Hb{dcH{EIHtR?h8#62N_a83`#<jWPQmd0H!oQ<eT-O2d34l(n4W7?u;K(m5CR&
zcz63#R$YOTjV&y%KsJYD>q!F4v~Ws++15Fq_<fkVah5JMzHl~7V=8X4(qGfTubCgJ
zn-88>h)^}>Vn=`;*haX(tqJ2X2ySjPHyD<qQH`PR9qB8d%ZBzj3dLfTkE%}>=D2HM
zBD&&ZKqf at FPpjt5777d0!runiMn>z|b$LkhM{Wt<DyslXInfy#@nwY97+cLJcP at kA
zyw!lk>aX%U`aAwjY&S-}?_}_QwVxyGzl-hpom<z9Q$VEpcPs`nO{M>$&;yqUl^&;B
zA0e&6iv)d&_0brGpe3V=RgaH0Qe>h4>;~$^GBaDccrZLzV(xV7IPCZWL1nPmngdK>
zYie(V at 18=9_k6dMge#=FS9dmXwovlyVN+EV`K+)Xh0q2U=#sE^MjP at uQS!|M$Jl^N
z+dL6~Ri$9ef1Bv2>KQUn;4Q$)Lp)rvg<G~)63HGDp@}QCiYM4J(Ax@??UHV*G+X!!
z$KrS3o4|ahzTS0HTlBxiO8+k^>ix8u_^m!&i(7PL;sscUvWz1S(5^sbo>A?`@`{(8
zJ0ww`EF`oklj6a?C&og4&YtAkR3lXd+D|#tiS?c!h!OG$6Ode#9gi@@GzDytn at VKf
zMTnLv(W80mB<gm=klgAepc`0dNL->Rg0qWa^hnhij_5UUf@<9FijjQR4Zd4+{VwC#
z?=eQAe&+yx<McQ1f~6;<@u#B*kya!X6=h&X=(Pa?D#UrA(i3C{>dn$Ai3TYiGV^IT
zB9UNL$O<FiqRC at F2`euRFn~|PBYKBXO|lcN46FojarVTm(Pa1oaLibH)^UZ8sJ*Dt
z;*g(**<rdlf^bxrwZ-hoV&QY?4T9T0`HOs-R~h;X?aC^csKxMpdqI#@5dk7RHhPc9
z>1~nT7l6qEq^Qu#&)HXA_9a}Ry0Z>J at qjwB#{>pgQ2(8-leVYu`2J*?C>la9H}ReQ
zrGpfdzn}Q;WpeZXfAphY(ye)b_+#ymrm2HT`3umfn0D10Ys>u$Wzo7i$OD2UyKW!b
zw{0T5O7z3UK at JR^IfaE=N8Jnv;=2ZfG$|e0O2S_tW7yDT=)pYaVFy#@P++Qp*SzIP
zJW_;x$LyO8Yw-I at 9mRq|jA+=hHo!odecVvX8^Uu1LSIWh!F{0)1h{#B1>z_y#)Y&;
zxdK6hkoIs!rfeLma^l|ZWCuC~OniRCv`JiM1Nyvcwi)H&oYPI!7E!V?uLoLv6mbQr
z8b$r+ODNz{;9)FZHFPk60o_3RJhB_DAk_mq$DN-<S{>cGsDp9xM#ieHFvI%99MihR
zjSN7bYl~9xVzPQ&nHj?$I2EhWcp=qLs#DF%d~m<Ssv8|*EW{ge05R1E8N8zOI1j=a
z3sM)Gji)Ovr<<$P*-O<_6slMC)!%8czr432UX(slx8^RD?H)-=9h_#ki|9Ho)mEij
z9te(CuT31cgPKBBuw*?b1 at +mx9@&ylv*|}hwjw-;&t0X<DM~E(WEF!gVGsy5(kJ$E
zB;fbqUenMeAGAO$HqSA~v(q*$HoI?nyJ3^Sz(+J;+ILIY#cfn1QZvK@>B-xsyDVJY
zlzCoBoH^F at ZWr_c%knd4H5T=hdt=ZJN9O9cl!`twckYqY!X!kF;Zn607O%*X^yFG*
ze~A22T2kq}M*&1oX8P22(qaT1*8#iG>GpN`ZiJLcqi#Bcc3F0%lh{t}6m)B^u&tQe
zXG!O*N}%YQJ}9DmoAHc`a<j2xrExB at g({zjFCTo8tn*=TQx!)dfE~T2Gqs&(ewP43
z&&YvN?5HD3rO}d^&nQweKA_JuML-C*7MDJ2DpUsT)ee?H6ID}4-;$U^+U1kg-tNwa
zE{C~J?d%8|#|upK%$@HXD|mTU<&m%=KVl|&lOF)D&`e~t$iM3j6C!JL1p-u?44aX(
ztKOe6?jko=1~oUgc~^5O$lEHrB=Mw2$__pETLRN{$`I=_D!$Dncc$Pem{3-)+~H?l
zsg;bk(RDD**o{@gRYSMaz;KyX at Q&GZ^pKNvI+7`=s&c*WN6Pi~eO}~HC9Avz2tht|
zwJJv4Ir?q_mbj~Fd6}?u at bD{m<M6=`;(#My`$hp|6j>-z@%nh}$72Qbve`GurN^GD
z5Ng6hgp2W&8X`s{ik%z|65ZV?ovOhNru28cRs#=a)zOjRXx^XhB)$CzsA`3)oh>Jy
z-W{?7vN|vX;%;C9VIWcQ502oz>O52(@-Knvmfd>a^?YwGdZ at Bh!A7#XM_dH4w9t&N
z*rAg_axf}ZMV11^7&OP=?cL7Zn<?#5cW!N!$Yr{V+3ly;&r$6l%gaQj5a>8$c_a}|
z`DD_igFLkrnS#Vt^eYlgU{R?5?C`BxLejksW<T<%aS7gwb^WB+{DIZD%4E|zg{q3^
z-C0H40=%yA2sVGCebBsj;1W|;@C*ZI6n~YaHlFsrplSR0apBfo)6a(^J*G^$yOSf9
zd!GpTVv#>lAn_0rW4Z|yw<8s07n+XVPBfcrhxU>O$(U at sdzWzQQ>~9nI{*o<j=EJ$
zL<i$~oe?VDt8*GZAv{ra!*GlHTv5KAIJ{8r_8^L5p)Ibi-8K9fXub?@F34fiZ1UqN
znpq^o8Y-jDZ{Ug_Zhf)5icHTEzHA=|8m%5(tk~XL#aF{b_#(aF`oO7ZV at zaRa$+lv
z>0!lJYjWAg0|Vyf{?PYdW2_m1d`?I(iywCnF4ToKIcF^ntf{=ev*GsuGRjX3+l&?2
zBZUNiW~&)J^({9?tN5jr^~+1UfWk%yo$~RUSH#4&qX&y`%t$aLiXL}rj#h}+v5$eN
zI0x(HshXJ8KTXpT^0cx_w{eV&q5%lQZKx^plvobRbG47}TF3)p4XHv at Zew;I9N at r|
zBvA*MusxNvTCs&sdK5i9e^S%h=e|Ud{Mg3>{B-ah7c?;{yaXO!#+9HGJ922rzpX-n
z*YTj$*VVJKs0w?ka2G6ut|-+=QA%!%%b7nbqhtKIX3(KL$^Go*ZV)w|GM)=n00BV?
zTCIOs4#es~e3qCcgNzwXi1ZtTr|*2gBoZu*B(g?gfVVx;Id#cJ`q{&tGxDjjuCWDc
z!dBObq}bVF%}<BcL`{hH3#Rn32Tk6|1Bp30P1!CZQ1eQY+3Ip;i8B=Cdp4pwQ#clV
z0?F;yQq+HE8Su;g|HsV!OJ?>T(g5n at Kbaza`h-JMA9TE>w81nfV=%y4eBV!>-A~SG
zZ+C+d(`_6MF7U at IU}!T7Chkf`e~}1}{i>r)%P38bk^r+0f(iMWa*H0o1#XWr$3X%L
z(ZE`(c*<JQRK~R!gDEuJ(=(+>i?wdFu>PUh)KOVY#zf`uteRu_ER+$DJL<~-9s%g3
z!)F3L;BiME`?vBj at at@oZy7Za&r2e`y2CJp7b|j7V55O>4|FEK9=!MisQ4{Fj52nz
z<L#KskDCqqFQNdQf6Q|i8DQn+{Pa}tF+j!neSO>hY0Ng-UpbomTdpr?*r*d2pf4O-
zcM|RY_GGO_S_uYO<P*HD%te(s05Dcyp5ymkftnQ%6K~-0{Wrf>C3NHlgDa|UKYbT5
zX<&2)f6m7K2;HJr+`4l`nB*32?9JqgH&21g|44DOvHxg~|K;{DG7;LDd3fP50a-qw
zy&S8!0wrm^x<p&L0?pEgMCCSFo8FhP_AIcXdEwz>zgu4P#d9eYX(t84Kd|d&>hCV5
zz1HLYBgLN^^N;rUt~2~^^$*ZZVBa2Elzpou!xZ<!8FRJw&LK+Mm-p!`XGvbkpNk=u
z&?`_c6R_Pt*t-Jl;QSz6_1*veMjEv;Aco(#yp=|)X3V05C~Bz^@-t*|A0Awze=}a3
zBiN4#_3T}eT-umgup+8lD&n1+^rHC})<|$SomT+?#S|bG^vi~WBS#=e?K}`o^EX?t
z<Q;J-Xf_+xCecz5TZexxUNlP?-PaS=(Q1tBLwgIzg|aVa`4EaIAq%WrqrQ?98B)Cz
z^!J0J^}UdCQ&4DgX2Yq14FZPy{Z-%2W3Arel%5Hcnu}183=0eFg0UaReEQjo`exOG
zGsPVx95GIy8M~9!*I6jJBx&B4R?G+`>SJcCSqUHG_{lx<$&UguB9xI{v at rWBiZaAI
zj3w>wCFbat?T`=P9diMaRjTW3h{mj|qG2T8?JA}aIiweV!odBF!u6s^(k+W{z3C at k
z^$q<6wf>C^Suo!}maaa?+~=pKXSG+L{#~`izi+)#dp^4V%*N3iB&iRC|5an+AYz#P
z+_O75pVEn(sopk<2>3aPQ-PTNWpaQDKIis?aNoEXaX%+(1g#-A4<V9odkV_6KZWGJ
z^(nk55Q+vpc}DV_;*{$GmK_Kif+)ZJV{i$q3!+Q!yO2vbnqxo^68RDcLn9mvgrR|n
zJpW<v1}M;w>rgZjKqwloj!PWKXCWZY3xzx&QEYGpLj94DPX+{>!MfJOVukpTZHF#T
z?IRBYv2X~5KL4nd{;LY{xCU_YrXqo?--YZOT57GhdA#+Pks$)RB15%kqfm&6ZFp at M
za2w{+i!XfTFN0F8FPt!fqz*icPM4G_1`7+$JHeq$h6yFI)ktBiGLHLjfzgA_eh%hq
zA4I3VRF{M`G1?~hd$N?D5(g>Q13n>S(4z|o*QHNIFxA_m5mL&KZ(==hUQu_>T0|>_
zi1k8uuR!EXQ){{ugX}e1o9m4AiLsA at za?S2S@*!9hjHI8d}^*0Xr|`GiFddw>u6 at E
zOm|Q5J*$RqVs$UbIMWDFfIF-Wef7|CJuPuFNF$CjAf}z96Pu+?U`>?lgs8mX43X>d
zWjRyxAx+INhtz!KU`ka*ym|x$Wns-rEL!ey$m{ui5>tSxmLs0?Ah{4c)@Dm-NvSl(
zMlg?d<c~@2C2ru7En7lL{zhTMVxeYG3zIHG^a at n{Od8&A3I5KS<f{z_{1I#qIGOPD
z5Keu!fyX&SS$#xXq&54gw<5>PYd2HPph?Nb`b<6mnMHDsV4N9#zp;^q1i4#xn4>di
zp`^UThpPT#P<w*~6&^E)`xy^Sl21*1_V#&12W82W33LvxOYNi4p+$n_J*P0KwYGyo
zhEa)r_Msi!q`gP|cbEqJncxn`aSROfDM at Q)y;iMO at Z%C<u%Tv^wrz}N#PZhFP2 at Bw
zG+~mdg at Lo@j0$V$?BMvZVEm3wqTn&yJ+B-MWABk#&3zBfRin5ix$-!pvtCNnF5AZW
z(8us5ih#=H&%0pgjdwu!htL7Pd#_(>wXRn#FcqX28W=g~l5wWRlHM!gN&*Q8p{wTt
zRQMY&(N3bgY|>J5TvTPU$u4|txEeRbjKnSyT*?J4-1|XK8oJMBPE_))Og)kpyO7q}
z3%2GsiF|KU_d9?+CECKNVcxZvdr**gbyUN=EwDp?U<=Z2dpi0&>s+9};IQIzhdWI{
zHd^wL<N>u8*UcThE~$8^tb;h}8%Mjm6dO=tBX0h0MrR{#3xQJhg=d4Bt61>i4J^mm
z!lweedE30Tab?`;2)1$A_o|accGVgHX4d>2qzjKG0P79}Vx&mteSOzNP;_U}=lM~(
zXEWK7Oo}55yG%^qIRi&`*Bwe-cOo!g0nosTM}9R$bC8=k%&{SGYctze&jJxGvp&es
zPkKHfh*JPTp*DK1Iq6OkR0C~QO)00Q3duAqcPZP5u$6DWpvijr<gNJg^zjKZB)IkX
zYzgHsK_eOv#!{TeBZt$FQV4Ycdp8MV*QHcqMx7I?N)oK!e6m}VBU)SkfzSpTZs6<)
z7dkQ%dXtr1#vHwSVCN1&f3yoQk1hp5X=6I-MK^r=Qt4S)#&~*5bJ#1R%0D=-AK^Rm
zN`Ct~CheTqQW-HO4T?GqU6WpKt&%7+XA{db#rg(qJ{s+R7>RsBAySSlpXUA5UCnan
zG<65h7qJlG{g*PSPL48`;E!VA{)F(h2icrwL_)V#FI6JO#<X59VdWZ$8)$R#c}cRz
zXia=9p1lSCwIBk_*z;o7Pc{Dei8}e6trm4freKr`S>4OcMJ5b1A?gu%rlmR~=q3_<
zs_Ps at oOHdoEva9wHphFh9E}(6AGO&T`yjWXz!L{9Q4f~i;!|pPiVb~S$kZf*FuLXR
zxWK+ at evTqxM=h)3{i{#V`C88yCck<wcvGFuCop83BMXu=IJKC$*&c=FPEMV998sx*
zAT^hxswAAb#mnVY?xk~f4oh7Vn)3I9&!xADJ{e#~<OK4T=_j~jn2`at!AN(&Hi&-`
zn44Q>8rKtF&_Nt(P}z#|4X5-qsn~5q+g6km8NI{goYipcPRl|qankmnwAC@&m)=9z
zlJKbcc-gZ=%W9XOTiZ2CCWzUjKAYl~!r#gd|GJnVt0#o at CZ36tkg_ZSN&UmK_PplX
zIIyg3qgeuLQRQXZnS}*TwXN~Ccm;1Nrb%s0HJr7HZ at W9C7^j*#@2t8xaD_9_e_>Uv
z%_Y9=@u}P1ZS=71oZ8L#>t$0Yy*y3#RKj!T%{I?>ZF68xk}4UUyOZ4OvOd!#Rjl}Q
z5%QFKNf6ZT9fWya>(~2l#y<B$^JIx+N=nq8RTE<zvtRbr;$fdes*d`ISQVP%SW%+*
zN7Bj>FD2*)c0avs-kT;~z!V%-rcvJ!p7=5ZNh#55lT{v<H(~XX{!@?TEU*x<luF)x
zas}EXhU}y28aiSh=>qP?%4%o0#fKuOErese(B|j0mL!tIas9)N;PMZz<OiMwnt!8U
zjgEaCLfHey$-^VyXM7xaDZSosu!X;;l|C!W+i0$K>R)Qi)EamAnK~Tpa>kny8)pfg
z%niP>rYdXIEznFl+ngB;%tuC2nUzK??J)DtYv2tW3k8%fMYxg=S^xuAk$O{QEqYv+
z{W7n17D0c&M^h>l_?-$dkGatm9W`KRB#-Ys1!~Yf5ZzeCBY=1IR31Z9-tf7}h>b8C
z at c?t2Hb%a;cha{WbBUwoh<EG(`(N>FbD|YOKOtEYhrAPT+rFhRz%OfVI5WnenOc2j
zQ>BQ5hQ{*Fayl0d9?N%>B2J3YU=T8cUGYv&HClA8KM-4TT8=(xRwArs=-x29iK7(z
zQBCY(S6Dh3BSQOEaG1Q<#^ckXLWsL9=^JaKk;C_{cG7n1{H<iJ>Lzm}tfr at J=fQ$x
zS0FdY1-=TSqYUKM_~h4BACs3c4>{`J+~MsaUV;Oif14wFEJo3Hp!)v(4r019+#{v!
z=vO?JV=9)tFOm?XA%!lXPX?BT9{lxsqHNZGO}+nIxNq#e_C<}6)Keh9Z&>!Y_eorG
zGbv5Q&<ieiYeSqZ2fgP0 at +TjK1!S(*5~qEK7+J%I#SU3Lz4AVE2WUC<Q<E$jvkE*$
zZQLDjun|qlL#ab)B_q?7npU`RgoT<xR_YPeRw8i8kDEvL$0X_jQ-Rt5IFVcHgmr!5
zEP at AJG+{16s6E>RFNri>t14c2kTRSCz1PJcN{KB91m`hpKUl$0T}#r9qbT+KH{xg_
zey{J7G*Avq`cT&*hc%uo^SZ<zrhPW=4#E}nhMAwQLVr};{s+qdKupH?#&S6Q@@I>J
z9{|(um&4yLg at 066zA=*v{fmWAA at whV+_*-&s>*+4T+ABXrn%;`M5>Cx{4 at p<ds3t8
z)T;v_l(7{$yh4(6T_lf188HfvxzKpiUV@^0$svBhkr?M%QE(eNS}c^oo(yE1gy=p(
z=2x$pwh~9_6jPO?vb<~clx~dBPLdp}FYsHW>R`QcmKok%)vs|z-mh5Rdxv``HacgW
z`yVkBl@@cnF-!h-m at dx}i$}&%zg^v~e at +u(`zh at ymab&FNsOsAPT493RyrXZl^nBu
z8~6ND&=AXUG*()o(E1S>w14a!w6D3*2OoZO8ULgGK)$fhtnBpE>1OgNoZ?VSY4L;H
zd`%IA55pfaP78;EO4_WtN?(GoyTD02J-j=CU`rYGvX51jqtD8|IkenQ>W?>hVZea6
zM1vHUJ14+N^rn#aaCZRQNo2QTOYB}nU&-7^*8vJK=X+eS-O^fU;z05MoF&aA&~u_l
z-bNlVA^!yRHk*q1-JWz;Cw3QL`*Xj?$Zup(Vvmwx6vjn&+NePH*avKhJ+S_bUENuU
zkpX?_nIxreb$BCzzy}62bqHohZV$BkLr+vrfuDZdt&?|7j`Y<uNY&k7f3Ww=qq{9H
zPlNM&%L7FAqKVIozVI;eo*t#AoW|99ELM>0b3!XJ%QC*SJYcMPD~cpB&fTjYH(4w+
zaO?Gm#jBT_#RgTAp2KL?%=hi=_b`YAfJNQfp|h55vO9UiX6wkTFsFYsl^qfdD10zd
z49o3 at po9NtONRJ^9`Nto^|g_jyCwEy<AHFAi(qF#tH+!$XNi))>h$K86G%3}JJ4O8
zs&9x;6ZVBb<hD+;MXL?ZstGK~!&$j>D_FDJk}kf-G4qf?-xJie{V9 at V=XnNgB5BO+
z at muMarz@wU38o*>MmdOa%Q$zE=c-ST7Do4rnw}gRo8pZQ70p*a?`ijMIla>%lnHVU
zZ;wcEnb1L=c{@**noI8=pQ*9Je4>We0ZUrvmYmC<+*;iCi&*f|GU6aArC}z at 4}*(U
zfr~PLU#zq~B`fj4bm-$cagg1hsn%sS=2u5>9YQIkwYdX?Qx%DuubQyUY!z2DM}ZmX
zu_F#LfY<yGdHHV<K5_3#gfHp&jmr>YWE^l%0mQlMsJ7oBKED`R_&+GeP%(YSqra~5
zpG*3-Tme?8|7ZUI?x6U$o1-cI@#q1!XH(w9SEc|8cX0a2doO$6I`0H^WpU8`992|A
z(6n;SuQ%!b-1N<Ma~pHRFgf^ldFb#tR(fpU4!omKw<wHP=rwcXr$a+Za8Z}tJM7VI
zaxn at e=AucOHD4E}bEgyTR0$sRYihL_8X}aFzn&3(lPt`lMw at jVefZBr$nPN~6(bH~
zbwi~u7z2_Nqhy)VH{0*ejr)IiT7T<WeG&a!XhE)}hsk}@jHpM^L0w#RJn#V^{;HJR
z`e5Tr$UXq{z(6kfv;dbX<M09iU%k9WaR7hAHj`bB<dZAVHA;g3fI}Om{lbJv5 at lB)
zAs{R<sNo7klHNW70qh~yKo9;EXs#k#9AxBrxA*)Cv;tfJ3uNsSN}&n3KwJo2fk02M
zKp`WEKo6cb7Xt9xYb*$0B=11^|0u^F?eRzd_~U)~WBmAIJpDJ!F9=Mm{p$tiv6Pwy
ztkMj;S&cGvJdGV~Osi%a-z|53qb=$$T220OuiwP?6zS?4s-cyEy at Q?MbIa=^Ydtem
zPHw;}^ZJ0F|Dh5KGb#%+aIOR#vZAuE{&>iR%Jt&`4=T^~fuP_|7jv-z=YQj34rWx2
zKjp*4ipuq;e12J$KQ9j#aO)rL{j*zMpa1EW%8q&tt~Q1br7fQu8=^iGv$n9dQ?_}o
zZ}{+$p_8e;p^~I1>O*x?0|ygwPG)A*hf;>7#wHHrY}d!4rVjQBhIV4smNwQ_hE@*b
z+^7#FOf4J??H)c7Q+Z^lZ*5 at s@QI<7F>o;pHy0<Dpx~bx?&|B+CI~|WXgx!a0SNek
zxf%nBfiO_fZlR%I+(N%~8xsQyj}jjb2M3Rl{N7zk_6J;?Y!6sjc}0{Zcm?DHSy`p@
zq~+8!baZvN#f>ZtwJemuI-1v+z+m3Kjdur+9v`1xlaG~8^I!hCY6M{+!!W{Xz`@)H
z!D7L{VZmHAgUEm~BEbCcb6wu+9~f9TcmzZwWE501AVI}#5G)KF94tH>0s=fd at T~{%
zJqR8P0s9_{2;v>Z=ScT$aag^>Q;{h|OF!W%^>0(M>Dl?9pyJ^Z5Z<MtrlF;yXXoJL
z;^yHMdn7I)DJA__Sw&S%T|-k#- at wqw*u>P#-oeqy*~Qh(_obiztJeX65s`1BqGR60
z#-*iaWM*aO<mSCEE3c at ms;;U1+|=CC+ScCjWnge<cx3eJH|Wgl-2B4g((=mc&hFm+
z!Qs*I$?0{yU_fv`Rtxz1H|vE3)C(3K9u6Mqx?V7_&es*kf=9T=f`~1mi1gg{&V5#I
zWE|1()Y4BV6l_Y{xO#T|sCbm at GgLd*Rr{f4zpP?D|EHS$xnh5*7ZijJ2Ln7jI4qD5
zXg?014F7!V_P=zDT^gfpY|5X=dZ;2zDzK^t6IiMwp-pT+npSC^JkT%)g`A$%0BHS|
zGLKz;IPe<{sRS%rDS%kk#R1Y4h&cVs$odp+3Wy7&0NMEx5!eYWduY~v1^UOS1ky3h
z?+b0jHY{U8u0S3lz<!VR@>~3+*U=T|Xo&3GE+Z|}qzT#{dLwtCo0;a)rbC$z->*wv
zlyP0aY+Zr2a)gc-$i~<peWX{Q%TvH8AENSBaf85J6ARFA?gn at RfUV|i74wou@~~@a
zAE^NdGzQ=qb5T?{?h>TKep!Ww at e36ZUlyT~!I{c*K|VM+LXIJrUA#abMR6dmB31T<
z8?f6<Z2~(M=nQwKokX>y1=0up?f#MhZ1NY_<Ed%}7_;LRFXkhVC&o4g(MuJiXD-a9
z4h at 9%Ca*wOAUI$LJG;iENI|1U_jQ at J2y(_scCrODiZ`%H-En|iyEg~`b=ww%Ts{aj
z@!QaIz)=^vh{ZfV0*c=V?2wOZh05*$^gy8Lj>&|sK=_j7B7da%qb2 at F`vh+9%F~?<
zp$m`kE70;$`i<Agk at R&c`=PLgUv&a(b18T1Y2?sZLZmVe9TQ5zP_%zAj-n=k-?QVX
zOL4xfGh=|$hF6u()~xlSwkW{f818-t^*BByZ4<03p#aQ=9A8 at 6`k*maMrLM1fJL`o
z=3*2YMM3z)=2QOgT|fAQFxNF`#C*Iw!K&LkN~(g&j)(lNR`D8_NT!AMS>|{BCel~S
zG&1nY7-uZSBD!i?ogIkd$}qwc<u&7$C8;V?N@<1VY;sh~21#7VhbOfAJ9L+XtQPlL
zd3Cd->Fk-li1(6eQ4dqBI^S)u)+c*?Kq8?dJs$xbnJG-G#84H{HVna#=6Ak)*B>v{
znw{QlhRtUwV5symVJ3`zuE@<!I;V)eP;^isX-}fsTfE~IBR=Tu#Kp8E|0(34ME49W
zR^ScPDBL{LHLXjkv?Fw)+%HP1mz-3>zE{BSY2IBuGyQH$C39n=*5)cDT$Y4{Bsn|5
zcSrdL at l(oNA7_B=#QplGyR2G}(Tpq5DKSTtcFQ`NZQ(Zt_I8B&C6>oK$sh2QGOz{8
zLXv#4FS}k{x=#Us+zSA+(=jK^h%nm8NyoKMNdu;y^>)b82Vgiy>b(NB^xqu#icMbq
z-$%Ntnb|g(rVdI!<3yP7&PqIW5VkbnY^yu07!lplY6iYLq$sZVXFH*^jI=QErXOJa
zy~TC;Aq at y5j{r0S{<#<X)al_HU~0kjtTC)<J_0UKy8S)s`dgf<-Xgo?2O6_DKJ<e4
zz%$1Lm>w2rE?$g7mY1^oJkSn^mBj)7OnQ|_eH at P<j1dx%Hc>v`ZncqzqfZ8kti}j~
zQ54)ur#%e<7x^DD@;c?>rs=jg9v;JoC at GxL5He!01%+Jf$TH*yORSU?`0q}d=fBaI
zpAh&s#bF~c(ZtX}z(e|SIB?#0h)8DWT-7CyFdb}}vfuFpvngD at HeP3tOy*226=%)S
z8OLrGS1Gnf#m%>upA at N3P`7D*-O)i^$k9G`m3N}sKhYstQ8SIukOhS>)?XNOn1}B+
zl5Lv4h9yJq(I98ym3aI4 at YiP>6ojo1-p5QnzQ&4<t_aDIhp)aZJuYec#Ftp+-6&w=
zDwHTd6DVyEKqV2u==!<<jaouNQZc-}S8J)*Xcz#NOFC>{gjj8*2Bb-;Fq$}9Dac9p
z5+`7Vx)o<bry7Ddd`Z(6GVDZmABJUji)Q2*AKNrMa6icYQfM=;_Ms<kWOs6}=Zru8
zJV1+(o5H+^l?N_Mk|NYCsrrq6o}^{*goaKFyxQpC7u9rh0}6N_c at Zy`w&KUb!xi99
z8Ox)b;uLYaE-JZ%N+i-y`*y-Mz%7#4vCoPmBrtFxTF22bfZaDobc^!-j8zbbVAN><
zHUy=I_i(Yio(E9)Hnxc=D7H1XIo!Bk#I at 1JZ#%W0F=rt2=J7&6!@K}6GU)=i__D3)
zX)4$GD*!fMgF-Ga=o^$yQPzC`w<?kA?Y#8N)Coe>g@^X_IGCBSy>;$0cKNXgvhO}p
zUK_8tYSu4~TiW+$*#2$#TbQ2Zr at Np*$Qqy%4+8Q|g|x%T0zJ;8VIM|)EgGC4?*t^j
zhwzK(pK9z$wEbyy?xqi;s3loSOvXUIzL7zWB=&*W*3UC0+rOoGiGd`LDad`p!~tVe
z&ckBzk_z|u?A at 6sR+bralz>ECE=iu-^Ji&+bbv`irD5oP$r)Ed(UeIdxvZ}cn=#?x
z^y14Rl&5+VIBJ;Z)LNJT_z!Tk2!)R0u&oW)<G&FBFEK1CZQl0yNtN?$*E=+kRYyV9
z(p>20+5B^<K;&G#pL?O*c&YLa#3X at OJ#<2Ai*o?WP(aXknM-Y;HOEp(6IA7|$QX{(
z8}Hpn!;c{+fnkO=g{j#^?oL~{ZgnrpP+HGVWO^5wpj|MwFpyR at HJ76_z%^YIQn~p+
zb0P4Mor&0V?_qQ`k(`{IjqqG};9?3>u9=qVhmYCzxfgLWR7NKJ6 at K`Ub#*L_pvaBM
z53qq|V#-DWmv0zry+00aO|~wK8oZRCRENt_Id$k(k8Gkp<=BYVsT-esUqAYwhB6-(
zq`g1qodg5}bHGvTYR>p_H!JZX{ZMG~1Y%et6IuuOET4anU`wi>8_4fS at 2MSJ#dBVq
zFs8M-w;R>$?E=E~)DB@~&<&I>N0l`(Xi7U#yIWYCoV<Zz80pk|;Q6eTCCT;?^kMw-
zOs$jS%id@@E{iLW=0cD@;T%VyIB^$Gtk at afCCwDn)B3#5Be`?za&qHa?@W*<yQ!P=
zq4SuK`=UqQ!lvNnL|y6b0Z%LMPV(ahaeTeHioiRNcDLTk581#7JDYzXYJGwUm~ckR
zuV)ce&&Xv=1E326PZZd)$zuQ{9Hxe~)g|EZd|;w^1)0a2IykTg=IzOf%pqu~vRWYR
z|6}j1!?N7gK0uI?Mg*imx{>ad?rst3j+aJ!1qtaAknRrY4n^ti?(UE-=fS;o!=7{Y
zIp558&CDNjc_Hu3`^1WS-MxORFy!s8GVhGcj1&}SVc at 7o*mz(C4S?4ld>TPUyb;8;
zxpoKa`xJyGozm$=_hNwCZZo5QRkP=5b(Oo(U%l at Ri9Td5jX(&?@M7u}<+!Anx^a5}
z=q<~+D_tHl07=<NFD>T>gy9sB$daDBLIz$Fn0`qy_t#apus)kKp(nCUS4V(S`#jME
zSns6(K-XI4-VH3^p|lL7n7;Vmc?Q^U3jDhj*`~dNrj_Ut+q)+RWi05@=qVAPURf+5
zBa5^hpd3a>hpl?pT7Rs7?r43 at ck#lJ16?XbOb%{_H^J5(s4%F>i^hGeMr3xV**8h)
zI_KKgJ>JV#jh!dg(lWu4<Stz~w&U<&n1R at ro{9JCV>E4xo%Ss+m$f3!J*D#}+#zLl
zSpY_z?$ngo{<oACiU|s1on7NL{^OeK<R>RhC(&!)uR_a~NUdk4Y7L6ONKSc^AwE`M
zhbn%np2BurUu`pX7RJ>1p;eJpaoR$@E>pJ=pPuO|D7iQ+Nqfj}o$ImVR?sowNFf-e
zCn)YsxK-|pR~IHGHF2_oG<okT<X~B*X3H1%uf5$=F5a}6X0NInchxK*$>$Ig$(skA
zIZaBVmg?xd(6Nf_4ly(84o`q!uS#i?am?=a>kjJjFRJIt6-R%eqbI~yKL}mpu^WsV
z4aaNiX0WBkYQ?>~IXk2ruTgK7IYld0z+0FdQRn8cG(K{P3_IAlu!}1lSTp0~8l&Xu
z&6skMV|B%1Vr3hO+_EVgLZ+?Hb@&b{{P1{_Wi+ZEL=sicp>=$dc4+SG6t1nqR<Eed
z-)(h6aSV55?i~~Jgq_=5SArsXOh+0-h5h}(+Uhk}YOY~_r*LFChT6{6j4lOUw!9Ad
z<1scH<q2}cq~?^^Cw#R?`eqoL`mN-8_v4f7?su`cQ7taoH|VHm;ye6buVYU1l1-9V
zZ7z2bmO^T-X)B7HP~lsw&|6>&^ILF_p4T9xkG-uX07=o)X31ztX0a%QtbT84?&R5u
zw*cv{a{BDc?>$^9=HuG(3`k+aJ3G>(hnd1 at st_m}T{$<>+k1RIrhI3TNpbL;c4vkN
zKxYOO#&hc at 17^71V3VW+Yf27A+~T?F at Cd&t9H=JJ2KclO(JiDfqp^!txMP=cyQ{PM
zOw_FL{!dvtc3Fa;`rn0=Zxj{5tOa7oQ=w_6KZi;XlaZ0s6A4cUmC8-qIPCj0IZNM|
zj?e!7JYGSdA*^^31LgArdBWoX_E77=P5UP?+!1v4K|xdqDws<}@LNe{m0|1vMuEYl
zV*)O0+GNylk2Be`uE$mFs$)T at 3UJCDyax)i<{TW8nHTMjExwb+zHCDV=VG%ctG$x^
ziTOD(;#JW@@|7krMnT~nkDv`dU_(|ft8g?DRo2$Jf6T5cOOkO7wO|rHn>TrP-k;$q
zsUwf1Gpl13d~&vnC6P&0$m>qf|I(NApbckZc(g at jsQj#a9hWLelcUDTRnMIT4Hk6t
zpm3NyzTbDq8PM-aWVBok9i+3w!$phY;mhM`B#_2*Vp5NTZV!=6^i2#PdI=cMDHVIy
z2dF<F at Y1)R2pnMnBBv2>3zr<<1UMs>`i(Py*Xe<f$ZH_R(7JvJ({~N?3B30nd^V$(
z7U(k}a_=4o53jWwud$}nZvt1=p9Vymw^L6LlP?ef`8S6K*rK)kUjWG~WHEQSNOZ#i
zY^Pu7?)(pJP)9LVxck=om**cT+O8VWy2A$SSd-UR*Ej^HD-sJryvj(966aFfQa4TW
z-9?@T<TUh88zzYW5bWCEv5~%;P&cjny1_y^w}LRM5JOR$0P<I+<6ju`LgZ1It4*Mj
zd<~NcE0j4lD66in1QX6)xDDkyhLIxbmER|Utx42t6s^_GUg?SAo0h?*bsVD~5N{q|
zQQakIt}!`0I_h>6?*8#_S77L#A~vqdIH^UuT~|$5>A&+RpQ_J5tV6|O2{OSED6~+8
zZ(0_(WAfRgOf>*TUWTNIF3 at 9?bU>920wx|Tpv#<Z1i3 at 6-GLqODY#AYDHnjHCLyNg
zUo^QD-g%Ns<Lc7cnSzdDD+b>_Ke&OrQdB}es8x`@z2f{t0m`};;d=xM&tmm8`{+3@
zU)Ho)Nm+*@My34@^fodnCMe|Nc?}<DVIsqb)v-Lf))&T!QBL|LN%+f;?}NWxIu_!q
zWff6vt`|{?l;FzM8Cf}-V{IDQ$0$sf(Tyv~t?(6t`t9Kw)O>qKzc-&=G|YT^r)2bj
z=R5<0i&#8p3Hs&Bi)(6o#BhRZOp%`|I`Nl^9%eHZQFB5_O$D?)oZN476jiJt(LozV
zmwBgosuha%IV7aGOrz^o4{MQc)Ig1>!lg&w^#dF5UNsnq3EJGQ1=+ppQ(!INr!|)`
z4yf?Y0qiOmKX<uH1jGZUcERh9fu(R;;@?J9tQoVOcmJmJol}7$_}c}v04$&n8gyMp
zs;E^!jG>?6^ybnJ2sJ96Tqa*Y13|qxTVOeK(qS20(0G|Mp1dcCYu-fV3!tqDDiSUO
zRdnD(O at 10Q|2*>BQvb=4;&#m1Qysj8m7M)`mGI4;5w={sP=k433vF;8&)n4mz?OKQ
z))P!|0<>MAqOfT#aqk8au+G0JUKaue1n(YrAHn8^B#{4$$#|2f!p&$U5EFE6I)mW=
z4zCkGsi?a84z&I=b<<e at -6c%&D`1>2wWe-dfd<cG%w35RO^(ie?*)R05P+^;q$=CS
z@(2XFxMN{+z6K1;TV?P8#{I_h6>9>G(d;Xj6vvY!nMos_?j8j}qz|ufJ}5UeOED{K
z{^g2 at Vrp$(AWD*k=&{y&#;S3?5EfpdT!AAH*VCf6mAb?-&HLNi at 3&qwS%2dH-EL3r
z3N~+W)TS_+(G;x`Lr5yXN<u}>{xR17<Y!&P4g70AOW>!UH46Aycf|=S(K&=!)A7!e
zo3~VcHzH%n$2)L0e)J%|iS|>Yi_Q@?-?I9E&cR;kt`4+zQZ)ojar-vUJ|e#%?h2p0
zjf?!PXLB1?hCWZ3n3CV<7$#;Q?Q at c1^SLXjHKqlq50_+aA-lTLN6lnJJC~${ee1?%
zUdz$nYg;-l)LL08KA<sInu{JJbPjrsi1W-pVFv>83m+&_myFORoM at 8WbxJ&TWzBjU
z6!bmlsE;#iP#Z;(J|Oa+to6(z@}KUg=zYPY!Zvpfu_<u8!+7)7{2FkpFw__TM3*V^
zt?UW2WUH{xl$3ps7MwBp#EY*kR1+E10u at RkRz6H&C#J`ek)B#MxL%2~YECZMndy`n
znAqr>M_1;qG{;WX`L{|^Mo4bTyO|E{JRh?^CvI5G>(y9ufyjY&!scAUq^}rhn0!*1
zL>-2Y75o*#gBd<c8f=2Jh+{o3sf`_+q0q+1Ny%zqXJKFH>zTPx1?$cu8luEhXZH%O
zQnGC!V68$HeRK0<tG#~*U322Yi`W~50=w#L<1fpeV`S<=*QtzGWK9!w${m+PlN>L1
zXPT^85)23@`rN9kqKhJGr<=RrX`iA$KnqDp*nd;LJD_f%Xt~ppnSiw}sbQe;g>N5%
zs52|a>Jxp at NO0jd7N1Q6+s{O=9|st!pMY4UF=y(7sVJV6QZvBX3&JHBBsg5rSay`r
zjUb}}V&D0f3!}m+a1OCC_mhdJk5GIrsM5l2CC!6Be-Lo}uHJ0u9UsnJP)IeYu%Vt^
z4>oPBG#$xAz47a}`OCcmTr4V!rbEbKAReH14KZ?&T68OcfjyX?%)m!b>KjKyf`9jv
z{&vZxZygXYBM`r7$OHr>vK|np0-BLQoCe^s<o$!Ar_#Sv^Co~cdYBCr9jN6q{vIP?
zQ?5gXST14PlVCFSE)KnVu(3^9^kwX^27ljmzN?Yhs!nV8bu=ZIgQpD7`m*NpSCo%z
z*5AM3>IMyoIy#kfz$<L3`s4YEJ>yy$;@k`1(i2?qK<1{UuNTUs|AxkP^ulmK3Nix4
z%@EkS!5yw_&fS`vxpV0_D6H{1->chWACmL51?yEAqoU at L)=<dD$$%MJt*4L~3Ubq7
zu!1-Q;?~DRS7h93T``xI?(`q&3LrmIazcfEOdyQi5dFB_Bb5q7Y1%%3kH6ah?rB6~
z*5)X89*@Q}yqAIP7Z^~2AsQ;DKokey>V{GQ;ha?<8Y)f>&w30UXU2Se&$Eq={MvMg
zXmfD^sI-ASE#*xM@!Wh-47JvUzbqS32+&C!f3}$ka=BY at s)T{Ya7DZc1O$t}T at nqR
zhV|1i8?05+EO42iPzWhDltcZ?GIW>YJze@&faO3+K6mXV1Z25-G<#@SxLT-6TR<;J
zft>{wI|n}?08P`@_W_7A7F@=1Ue-JIH8 at mgE4ii*G0aXmCl%L;mRs|99e7T!Rk^h?
zbgu=LafKp&%?d at EkxUm{?c1Jr?P-GSLduyLKVD1XUaUhX%&H$Wiw*_V^_ePWPS?pT
z)-OA8^%3OtaPbsJ*0ETpR>$j>X`7|_-1Kl!NCdqN9<Y1cDYQ0Lp>xwW(zO260MJbG
zK%2};!0jDofXNUEm_oLrGZxSZiuEK3s@*o**V;E;SORCzKkGs7QI)27%esNfp$0Ky
zbQP at q6<84`0|QnWbor*A!^@BO^}n39m=B(X-iS7+-!zclaxl4xqE;)Ll3GdUrrK!?
zKf6jv!zIQ$Ip~fRc;-g^_Am4Hpky02UAc!2s3;#b(T|IY)Vtl29wml2H}X745AChh
zBViQiJB;j|DC?f&u<CVMD`M&8HjXxZl|&I>I;b)Jx_uLyD2Ep}$?E;u_|j{J?MB*a
z(VISm6Zem1=ZF3%&s_Js-0aR)<I{dX=>LE)(E(ds$6t!~fXlD5 at lLG;oOzFq_H at 13
zor<~Z+55k3CTV>LqDD;EfkuIKZIc<4);D2YbhRROjlm92SNcluOri%x^22Iu`&r6t
z=;M;o at 6T8l*3R{|pkLVZlnJz4vnXyg8FRk~2K+>u?IxzG^UM0ealF?(^=mw3dqD at f
zRpC!2d4E7q^X|m+_M|&auUWe- at h)YVg->XGiy(9APivP9S9=C^u?*R_B>t>spxty`
z+ at EemI}wGibA7<9dm_w=GTe)kl#BDqC4UxnXy=JgdHo?N2c6D&K}zXWcQsrUR8{VA
zk=JZ<??9lomUeSny<J}9*;^V3;($r=fQJ!OW4mcosyJMnP at Wx>2dSM~f}qB4Q6eI@
zrtxnR^1g^n@^)Yx5H%40^zF4IdnlPU0?Y)%wja5O0rvd-LC1z9#R+u$_(WQcmbrl0
zh$A8+t<CsVQ?m2iY+bEWn_TvOZb+(em4FF{)1tlIN-PGu2UEg;F_uvrErrLM!8si(
zZdd*Hbc7Z%-(esFUp|FP{nDqiROL3BnpFiG_tRf7F}LfXAB_%^2yeHJM_Shv-!<fY
zE5x4&q=nxU0zMQX(bWT>C|VJS+_o!A0P+^F$Oh0yk8PmixT#w>Hx0lhn{!8KC4f0c
z2^gd0_sNPfQFW4Svkt;mj(d+2zej1aDz?|bk-1~fO<Yu6L(_rx;cu&~iSALB1L7px
z_~G037c0?Oaad`CFDAL^flQDUHadHfUpFWJS)rC5kXvuB$^&9_8BG_E83miP8m)O!
zqd?5H)LiY6%&X{=3350XTvg=cRIY-8S5aLms;-Pyi?slVB}CksoxiQzPC8{aK2(xK
zJ_d|e01e_+mph_*Z7rAqqjhysj#&^N#VvgDt<>@nP?WAP2402)B5Y&jz`ODV?lo5J
z_Pbp0&##K!tCf!oG_b}Ex89c%ruRt;<A9-XCpJI?;9Ux+0X~9H=nW*0LnlbTPZq{e
zE$hCE;0wAhPIAki*jk(<TU2{ljh5{krZO$91#)#&y1%Iy9AyVo-qTCei{s=U5F)-G
z(jq7nB_FGy27p(Qfu+j{J~5w7s~IY*=}t`SCc^ju(T#W03^)$k!#&K{%Lg{^aV17V
zh;_n~5bXK=pxF8cRC_W5luAoJ(@8WTbmdXmPj$5M)Nh+?h44q2Xg%Qu`xn_5HhJ*F
z4?u$gg}8%|Fu7Lb>}}!LrWEB9USDjxPIuwC*t|&M*<gI$3TuY^DZ=O7_i_iyG0(}`
z&_`1n8yO-5bMZDd7y$+mGw_ERP`<<tP~rW at L|W5nkx}2)KneSq)2BACwVdjz#6-O|
z7RLvX(1mtwJv`)#Xyvuk-JvxmR3}%bX_<E+&O5w-Tui0-u$qt32zY4{_2Lq6Mg}&7
zog<)!A}H at qf%$BV at d>*y4!Ne`ce3zA<(K3$3G;?adj`4r!|KA4mX2i6&A^U^)}K!P
zpZgNXe=90&K-`1WX71A}@(YG4XVRE$U<(WIe&o(ghsO^HgT4v=@jAPvYhyQ)N~Q#N
zbps9V%H+JpGMJm_Q3<8TcsQrKb`eftoNdBP at 5U+&uxb<b%`ZZSU<*M7lFlC1mWAI4
zm8Q-Y1$*jv&XzcrGOb39<F6~$s!ozmz>(!Um+aS5rA&#_2A`G!hBE0}=sOSoR7o*J
zw+T><@Oz~8*9CD|0UtzQPm87zpV-*Wq}2$p%o%qc at oFC=)_LNzy{QoYI}=i~*|8?A
z{`0a{TGsXX-(35D6E+oqJTfoJWXqo14vj&w- at 7FJUXx&OZDJLB+T$?d&v+FS13umW
zycRZ at 2&rW`YO(cqog)Hkhg|?*2NB>U51(Mo85CDl%r&+98_Wb*PeSxE+a);kXrvX_
z^iJvP1jV at yJN7*i$Fr;sF3j+f+aO8(a+93sID#vLVc$XXJdmvVJAn%9Yb2zkY$(s9
z4 at 1R^JD{-sPYgD at ypnbpR+vj7=-#`f1(q48XK0)S(k|W?0v`rloG55Sc)Pc33pXX#
zZ24n}eB5N5_C at F-T9C}hvYEM4VES^~blfk7l{P9_WY?sPEDzUsCdui~!{Ztq^tiX}
z!;6x5MNJrTESDwAGmN8+ at W>-=&l_KIeV$LUYjLW8>4_>F%$uGP;nb at o3u5Pwg~Q~N
zb|#TK0TLA%5t)5gKCGb^7dF?A=xx-H?^5cb0>FXF`+=eus&T*aYB))NxfO1s3J88l
zz|fYIUKBXTI at Y^5iU9%^tWi;NzL>Q*{8Y7ZeP64}rXou7-eNoAyhPzcfnSXn`Wp9~
z-T%pW;p)7xxL|i1e!}JP{Al90M>E<T(4B<Tu%mF*E&6S#=4zY7<zra^11=h~7*2}o
zc%S6Wd-&*#lcMo*grjfB_lKDn#+S6cReNorUqbc>nXuOtOtNR1cpw)r^ek(C6oEsK
zIRAJE-(n$|5zAPfA8EhsaO`;Ax*B8e)4{dXDqpC;k6-g%7TLFuE%QUS#%EGB+N4x%
zF1_Zw&9AbUFUJ^<n~Jr~`Un!rv at 5<1mfB20VGu*L(V at Qhrd%(JxlD*SjDEAikbx9$
zsL_mGH-rNfbbQ66ZnD2 at L6Ci7)g8@&<-gKK^Y-$?p$G~~WaKgHWg+_Fcj20$-HIo1
z+P+98rf(6wvLS^&6EVshlMOgJ at D$Q<NH^AvS~pHXH;P4j7g$tC_X;g1T=%024UeuE
z38i0$s=C)vU%fY8b+?KSpSt`S{_e(3s{&=L-(Twj<JM_4*Zb+TTBKq2ZZ#c33^)Ds
zjK-eRYPsVnjRR-9Rj?xfu%?i-q{`(DF$xv6Wzw#^Ihn!HW}5s5!VjA(-z*fmQCm|K
zy>iv+yE-2S&ja at BK^||R$<6C+fqf=G1CLk at D0dKkyW~7!y7y;7wXz=&{7yt?z=^F_
z=9TN|5q$3^+DiOafZa at MfF<Y|3dC at 84l9z+zZU~`K^tHfs8)#rx|^_<FG!via4eE}
zP_K}{H*DfjxBILT{cd0ZMTc8hOSK&O^2BcYm8;vGCIz_jX{~jHNV`)lX)cDxTI;@t
zCn@=S__?nuB&`;KI)@D5kyZvqxuS~3-)kG9e#rp9(Mj#mcDzR_3iyO8FBk=^)XUOu
z*ZP-xZCYqVw at P~-YFkK?tRW^<L%~5+zNr`<1FUU$nI8~SmjY$S@?{?J&J&H at yggGl
zH!O+OOZ*M_*bLdcSXCtZQLWbslqbP6Czlwp^&MRq))LbhM2km!e)z{loi#J)k|v|s
z(Q~pf@<ZKF_R`iREM0ZL9!OFg0y|yI$J3NGFBs2p=moY0mu{7G<reyV()2aediH**
zX<9&O^Bor&@L^M+3nanIhJbtfNg7DKn@`;*{jcZ(k`d_?MKOErapD+K8B(uP*Jv0g
zK9N=FrUd0JL9g+Cp9(d1N-x}~)$u3T8T_`(oL^o-%GvRm6KB_BD|wLZnnfyE-Roqn
zGrR&Pfib!#Jd7pm;U;xl)+e^!g8i?qCp at mHK~qts-{W>POz=Zu$qYiWKE)`@>Anuh
zvXUBnNSq`&EXqS8Hjkx7KNR*5;vxY!HeqC^AzrYoqar&@9QzCT$CG(5KW*~<al~d4
zq}QPGO$C9FK(k2Y&>5NlO>TDK-g{ivY^8{CZN37-q$+5%zT_;b6`{@|>ni_pquNWR
zruWhb4&>rjh}hTWGrPG)+4YjnoIaUI%C?+O#k9lQAVM14P%Jz{<Qb)Jy6Z<X%Fmtn
z;?3SBoPHs2T?fJ<b4eH;%FT+MxS|>veQ_UOJvSF3O~8L^7umzF!v8!ZqVo`0c!a at 9
zuiNu`MP+ybIx1XJ%1Q2eS{XCV-%aC}KqU5_t?ZzDCYJ|(Sgt6lner!#LdM<`q#qjZ
zi&;&Tb$#trn3-vIwFsSQ{`PbngP at ytxqa9Lm#An$9(EWcgBMT?udCva^Uk36?ZpLU
zwMKU6_sTnVisrh!6fi31pV<SW4upKhG7b28v(skBMIFIdsWy(xpE1+nN!HSl2nBcL
zKQ$OfnD&qj3 at Pd$H|v;Bj%HNhDg)^CL3XJPXzxEbJawTYO*qPyMcy*4bu3(}S7P{t
zZx_zoevk at hN{7PC>~?7vq`XW-89S?}(=ZxqwQw!geACH-PfzW;#?TXX1xuFn_AMAU
z+u4z~l6$qzQbIq_!kFN>{##?hZxNs=j2fHb8pbjnDcXP$)+uBnsdvhQYd~RwJcAIm
z0Vsm`VJ{aBubaAsWWKrgpw#-$fDV+>pD`a at v?6C+z_Wq{Y}-GQ4z*9UhQ=pvEi}yB
z;=hZ6f2M^%b_9h5Rgc-nQ^lMuO%Pxu7vEC+UPclEM_hS&XA+itjNpA(@C`}M)U2q-
zrx%i_@#Wfr+1>t2Tyu=Z5KBOo{rL at +sOWB)Sk1dd#F~08<Yj4u>DlS)q!~d at of0T#
zO0t)i4vV#JtyTLyK8-0=5<_7jh7!0k-$LAqb-;SdwAdBHtAWz?^fYS<?{wm&hpm<N
zuM>2{nOh%2ISoGJyYS%Ka?7JgMmLYx#7oSIV8X%<&Py-G-gV`o+|PH2m-UXb5&m1T
z+f2){n$~ebq-&jQ`6h35l1So#lY$%{5Up3;yVIvCzh;La`6%3BHTf$tcEXsZGblhN
zKN7!7sHSGd7K$1Ih)g2-8 at GXY7C>bHAZK?eQ!L{OOd#?BkL(B35kU0aW(Dq3DVlNr
z^b#>oV+%!1f&H-YpY;q#fQ}I*x<}!{#1?8q0E?`{8JPPp at H$AP>D~p3RrLXvFX|(R
zI7}-&<zpYWf*N0RL$)=Y;l^H3I6kTE!KF&8=>;N&R1X at qmHSK&Ca15XomwZH;HJFb
z&*gRAiZ8{5N*Bwrx6ltv3d5U(*Va9bkUu}l|DfnW$5W^AE77L{#J$3@!U2$H*&h&T
z<b|7SY_#uptdDXt=Sr+YoJe^<NN at F3(A`cjoo~?bP=PWG$YdaOQWW4$pb}I2A9|_g
zTls%~Bqi^OnW)&Jt!R)bcaSN=SH6Ng4$ba#a(N|X;Dk-?&QBr;U9V{4O>O9B5#Nt$
zBtwSR;^T)7L!GI4g!(xo^3Tg#80S*0x5Snl0pJ1V1DX`0zVPJ*K{Mh)Lu``JG12~H
z at 6Nu^v<;D=$uCJ0`e%#UAU&GQ6NT>Lril=6frUaxk!&ln5DRd2*Ku~5_T3%Do6 at A;
zHTeECOh1OqB;gpFG>lu>s-SSkGP)N#%4$UFeXqoqUZGx4Lc&^+c?(9-3Fb^tz8;Dh
zmb36GBAKR8JJ&0?YUuFf<_aMFIyH at FWB)V6i!A+Th}S{5X2u<;sEPSA3kgit9i~(p
zKH;XyPuB|Q0OE<hUk7iqO+aRI5eRwSC23`m3wq3HDeul7a1QrhlbJ49#+Fl%d}k$v
z-uWE-pnEi}6uj`X_-Bm`4q#OU2;8Gs5n29I8>sr}{vU4w&5UoVO%7S8W$$yFlCQ1p
zs>LYJJ`;KqwSFvowQ{%U&e#PAN*4YKN}7$Dya$Tjv_`;NgFv9ZAI3Z%h=e|!0t!>#
z{eTdTD^%5%KSu%bd}HNA7Z at Xf6Y+~+Uo*fq317K&IdH1LhXkd!68;Co5taFfDqz%v
z?En)9#8p#8)bdqJ`E)q;`vGCz`?HiP$J&~t!n=p*<=ecgJdFqmU at sF{gy6h$Zl3Qa
z;80&X;5|J}Hz87Je3)M^)#iW<BX}Nv?n;(u5(ol(@BI$U`6 at 8y=GPde^iqHOqv_2^
z)ot1``3#QZ2Lu4hpDs9 at dYuoLlDvBY`zSUy6p=EC437D0K~gE&pHX8Ui-BsD2i}r_
z#;~vQh4UuC?M|mR4Zxm`{;Z4>6Ml-DK4qx at s)A6ud*xg}X;&{0m)Md5I(-{jV^)nT
z1OixXqfviK6~lbCyz!&`rdt?=-V{J&LEMV1-^mQ13b$X at VpI$msGrG=Kj`5;Lt6t5
zpfp3x<l!C72buf{D5Jd9pqhX)r$*D*a9cwRtQVu(fU-s*Y03J_3m*(c6(``oe-CZP
z^A$)7RM=cx5?xTxSly#?K8~Kr=24{;tp47K(tSX573lWq+U;j4z)(Toqq{-66oe72
zCHd02FiDV^4U1<vYj{2yvmCR~64{NTaX|ZC#VHl|)du(o3E+w*L;z9q4uSb5fT5+c
z4nv^Cq3Hrv6FlbwU~JwafI2??&N|G(qf1&zr0CJ;{Te)Jaok)|;w54fX1EnK(=^Xa
zE3aSXbdEWo&en*oUrzy%oMoWqQXNQvaQ;q#AlmW8z5%Y)7gZT{*wU4Q at jYQ=XL|``
z2bUkf5r=#mW6C}QNyY1p(q~l6AU8#>Fn(OJUM4$4al42^e_lCM%Do&%87&c^Vn*6}
zgoMcOt48<}TV%tOj)<$B<!&I}!)7$$Xwp6EFI|Km3qBUL1Wj(MjrNPNUb=J}Qcur|
zNuYqDp&(Gsa$xK7MPYoVPt<m7Tq_=t+T+(TsC at qn9l{;PoiJ3wY-c{m!GEhCh1~zB
zf)Sr!0D8p;XziaRHk(QDIdklV49U5o)@2W0pG`h+it3%lKkXYVo%%MW4l7x(GMH8+
zESx#gI$;P^jRRp)X<CAUF(#672_$7;_Wr2NA-eTCQX2j&?8!EB?#MMOej%2rrrJ9+
z?j^L=_>h#%I;K5SEMC1tdOHSu^aS9zKgxde<fNwxxknde)wX&2GlDRmLZGK47@^{@
z<*TsDpF;uy;CP4V#*6A4uEghr;6%FV0`az<;g9m3yB$+E%{(M3$sW)A$7|A;30sq2
zg_VRC5l6dU#(N^hJa-IYSj at C{O5wvk%`aD!scsQ}4g~g~elhOTT2JdjimI?;$?)`7
z84n<#@lAN=hlvaU<l5go&M#MxNyT|B%2*1RqWv#UZ_a?~i{OF#EvXY_4Ce=49&>*N
z*6$9aZdz!VJFZ87-n{`$zdvM70sKPSW+&7h5qmdYr+-vGh2DGf$mH#KWsmnJ%Ox$&
zYEX<YzMxh}FB<n%*%y26ivM`9+%zp#(c54jSl>c`c=)#)jh|(^fUli^1c08w4~XY2
zviC{V#|U!>>^W%xWgmYDGg_8!;6r-zrsEADlWrkb#w!j0M~&tK_E`kLcCc at 0Z)N=K
z-N5Ou&zOH(X24d4rYlz<XrKqA_Aa=nwEefcj&A3rr?fbFPIGvVAgs-K#S$X%tNHx0
z0aRowd_J{@3E7RX?&l#BLap{p&kLxys8xUR5XvYlNtO~sh#t>K&*6D{yFpJLJ{f=3
z*x98QVZ0i{Pc;^oS0se9o$-;9CKmmVVwZ;;EF4|ljrSl$;3uF3zN-oWO>th)S_d#N
zs2E>+>77Xmlsi*Kp2(A0%k4~^nqapw?IoNP*qn*&S`iF(B2z5FzUn$@hj)Oh6kIzf
zDhgou(!!h-Yk3m==nHkA+j26+v-ixBpB2YV2(R5oYN=8(3JNeqo&zcl3or{`3;+W~
z0#r^tz7f;{U%LYXm=eH^nEQvw!BBvqI_7b%YpfzqXBR>$Iz#kT`ur~GGboJOVe4r4
zB})rN2iD at FWrftX(+?(`e5Ek<&L`ic7iG2d at pQBVPxkCAvtd=o?Lu`3oldW4<-fT_
z|A0XG!XHnepQI8T$MH}Yf7zOsx*Z~Nh<B(YE|Ob|_I+7tUD>duH9c#3cDhtPZTxY#
zk+7{0^r35e+nb3N-Tv}A_qrXa&3WEn*i34F=dhg5 at 9J<iU9NJ9ho`vnX#H>vpSXeF
zTW2x5MxQz(V~r7$QuPYr8y+O<x8O$g%xu?+mKXC)vuKj_pjD%t7rCv3>LB5xxb|Q@
zDd)l43N6)`*4dt0{x)dU%V7n*#L3yqy%>lWS}{H~y*;t^yc9 at T?m{ea;<UOg)*!mO
zcky_<z$#;Bm)9qyLv|<)n>Qd$cq_CvN7!8J0aPXY9#Y)mC5j1PP&58d;i5a5^520L
zAyLl~{eaNT2ak;d%9=^p>>jE5yt%45_+O|$t-q<iieEXZ6og?#QA6i{scscUfWTR=
zz{NRWh75G5Z{9a)uom5!uZ3J6_nGiAHMT{ti-LC}9>VQYvhj)Y8f%aR at wDnn`HA at I
z1Q`;3bHqU2w#OQ1Nf)(@%ksguK>T#!AXE4q>MOqf+g|SEuNB${$PLqt6azjLdlM6*
zig>O<CulVW at 5YEd-womHsgd_HGBke$7f6H5!escRQY{@|>TXn>)dpv8w6z1>(=9-j
z8g0aa^RU=l1So=eHOaIkQH7gI<Mj&cbub0F2)jQZ#AXKt>;<8zc+uc;PqKBkoS9un
zFO{&+ro)<^DF~7XX3Vd>>swQk^RZ{_nRd$v=N(AXiSh?gE5Hf~fH-#s0bJsy#ps)s
zOZDr at Lm(J8cM3XlJUvMlEH6?^TGFl<v9fxx3y+dggyE`zwIWDKFb*Nd?8*ibsjau@
z5o^9Ms*V_lME8cT=8o*QWeOcFoY|N&8)3bi<FJ|F?TfT_-qUgH!`|v&n+%lY*`CZw
zbzj}R)QdT^YV8ROsafN5LvkOiEgm#WSV`P%uv-|&M_ji<ulpGH=yF5}6gj>x*vgG!
zZ;@YC{lrN at Cx?b2SO;nx4Mjj}`L#g0Jb0nbNLR|#iehf{a~{ez7e0q7HWX>olI{n^
z3??$g9F<_<9D=vlP=~4BjCDl!^dHT&!hpasO!lqC48C}n*<X|iRMB|eG7RQoxffo3
z;K!vYw$?ees>gMvpXU>h+#wakGc~?3VA2nhcXa1SQnihlal);`=mKT5;gMDg4J4xr
zCcYh5s#cxSED)eC5D}dGBX33r5#@Q>LroHCr764R)+`MV<ybsFFJ`9&mXJlaJRd4l
zLd;R46L;$U&am_y3)^5UC{)Ivf_X`@xTZ8<(B065M4`l&k_H0mT|x*fOTx$|RkfxQ
z3%vs}!yt9U?0}-N2)-W(z0)lyLZYuEe_w>4{*eg!P6+wKzzAE2&p5nEaBdL+46G63
zzx2uf at HZ^R9_kN>qLHSpZSeZX-156rUYfr4g4hU#q8bS1ms$ItycVjoQl92tcH!OM
z|Fw<yH{JSAlbW7V8?*io=y$&~<^SmS-4Xcvco=9e{44Ff`Ad7JMYBdzhCEjfZXH#_
zK|)pV$bljW0Al|40q_5Y at QKNrbu-sqC<=u4{}BYAOMK at lU|2Qz9?<xGu>JH8d`;n6
z|M86&_I_1|w2Er?F+uM`>W3(t+=!af^!<DEQpHX}pxKH&Na~MRmA^%_j(2kVD!&U4
zbK!k!zW2v%bON{N{C`5DYk+To`|;CGX2k?f*kgb^*p$HKe$#^ZT|)cMR@~-4fOr|g
zpHQbja^&_{0Q<nnqSpV*H~UrS27$M&7;ii)!KVx0=FmHzEAPMPkMjpe0DtZFgn|`R
z^Ex19GY*u{L0JM21<k;oETVgq<^3Ce&7`Q`&l3+i2}himen6A}1rM+jfGz%qyLFcW
zl;R(A|K}aQSSAql_6!AJTJyF6d(r@?*+T}{3GnAIomeH7G?rAKD`2V$LO?u&fJ%7)
zSe-u+-+wjx*E7WcBkAYp1*=sFS74glg`idZ^`>8^F{}{%ud&8|=4g?rbIhE4fqwwf
z7pHOull;dvquMO1r2!eS`+)a<PAQ-QellL_{}-3f|360mS;YKzW0ZT(qErFUHhzNB
z{t_e=7A96kk3t4#@m#vBY0;sfFXlZ2q|i$eHbEpkK;*{wf21V-m#{Ve+joNh6(kkM
zEy~nCqe|U at l44>(V7i5&0x+xoJx~?r{|Kn+AD(jued>RVmh}@_>(71(>w}EMY^)ss
zOe#w!BL_1BeR^RVOG8GLTRf}VFAx|-tpN-wGiwuK&Y!4TjK9#XZZBc_3lQt)w|_qM
z=iR^VV|;FAY;0t2WNlys(nernWoNW=v;pv~ZZWWQ|GJ-z?XS`P-6|C`D<crSq=UYt
znZeyQ{hK!Y1pE4X&y-!QUfEdw7k4u;{o58O*;wgY{}+$oxP=(|djmvl9PP~jJg+-r
z`fu9*6Y1>lx8I)``B#=^c8*5>&BN~S+V27V>tX-mLBD2<nClPFw13mepWpsBGtKeG
zOdGzkv@|llJJ)x(_jk(_#8t(G#c74?&Gaqh^zH3!oPYA)b0d&}y_v0pjXm)#BAe3P
zj*FSugB(Om_3eq77-jT-ePsRvY7L}K%*@P548Vc?{(bxTAAWT2 at H*EmFDU)R>-LUD
zx6}6*yZ*f3Uk<`;kA96L&=hMSYmnJ*`u<vA1pP#b1AyNcL6-U;Q$~=P3!{Ux4Womp
zy^#^4F~B&C#%4~yw?<Az){H-4;~1^YfXm&C>}~EWo;#B2_kjMM>bpbst0BZ(e}Lir
zyD7fI$N#XHS-Ad~VGtl5ERFuQw(m{;Z{p{&M_^)m#s~oa0bNF5e#XQos&C-vV1&TT
z!p3N12rLyNkQwMs at 9seH{a!<V at x@Ozk<+&_V*EEOBrI&>qWz4R9#~zh%uK`_%$&N6
zVwU<QAYyhlHdX+GPY7gii at XPX0f6`E+x`j9_mjMR&Fy!<%?ONt$RVNIz7hksDLWWh
zsS&fYATY|Bfo_N34~Rd2>i`HpKy(5yen!m1oIlz2FUI*v|H(Li0{sDvaWMJ=>JQ;h
ztUo4VE)G`KU%-ECob2qsasONrcDOAxRK_YSc0j!eIL5HRKWuDUSlDL>4+9vH!qa(?
z6fjyI8a#)!g(ii4ojK?Y9YKYFYc|3g<iEUX^!PEVsl(@tFy|p{gUR~%^2uS=2D2Or
zridxu*t%XE*2&ean7z6myFC*H*BTay4P&4^4+uesXTo^43Y96m1_(LwgB&XKx!TG@
z__%dd59ZTq<JqgNU+1h-dY_ at a{iHjg)0E{pO1}sB5Iq=f3r}0k_l(pT%DbU|K40 at -
zk_A;0GQuA&ivx{Bhf+yEMmIyh$5;00&2o#%2s``8h<ED}jahFu8(VxF8&5UKqC82)
zR%;wvBhxv*%E!3)Q5$UcxljG^W9M<QL at zFx4%VR7R}rDmM9^q?QJ7vMj6- at Qqg{!b
zLFIda71yP at 8sTqbT?py6Plr+7lAnn~oFEo|K6R-UD|(a`Mc8nji24RWJh#RjsWF}s
zk<fQ03{w6}MKO}Kr*1zAUop{~kJw=kybcWBJR#>>J2cUw8Czl(=qw>bJ98ma_xU&N
z?|i($-m|ZRD5jA;=f#HydA?jOB)tR`2fCm@>-lk3qo{q|+2+-F3i~P*xAO7no1pnu
z at 9b^Slor&QrxCBeh<gR7lA5(}ulq69m@@cWl0T#JCK7_0mYAHDwcvwno3EK)BYqof
z_{mpSqZ|4}cwgF09q!<n-`SI|$7CJ)rC-skTdyri#-2<IM&Lb7SWSkG)F+>Y{{gv|
zPGIvT at r<T1&_t8 at 5=KA(+nem;gB3$RJbi*`p^F{Q%X!7H)F*PyIA_ at WUzlIxfIH@J
z>nS(|G^8V_%H+Hq+-zXYv{4iLVNk<-;1*a(C|<!bd=-0*p4^Pe8D3^*HSJ`Ldiuy_
zO&m%Omf*|vm$7$ykP$`rJs6TVvR?V^%s63^EWO at 3AK}Q0AJTL@>5 at Fblc+sj4pb}E
z#WO2~+4Zt6-GnMmt{)eP<CAexk`jo5<V0cos{KJkPZ+JjRETyX at tse#cPF!sABR4o
z^_Rlxcb0aHgx}ItlG-BAAT`wtu~v=CCc3smx8)Q3rC02$GpE<;eUkh3mgXMWpniZO
zgs;c4q};$n)cy=P at k~0(`4OF>Q4wi8Ygl)1arj~ZRAn=JsUqbzSu7EWCXsLU!o#ST
zdFZPUx+`^T^8Daz=11Ae)Wn+7cKi&jTN1M)hFv`_MEr7Z+!5#6nigSbe!OgV=>F2m
zL<uTkWskuuMpx^ME?p^zEi|br<J%@2{n}gleVdlSs|@5nO(wUvs+hZ=2HH_cT9d7h
z())6G#^V|b7KeDMr$Of8Ez-;-`>{2J$s)_VlZ}T>&vXU at laK5g6SWQ!b>Z4J$?{s=
z#gk9`AXW^Q-Uri`(rB1!48p>e!y3uKPKcpBq#2$e^3dxbDy(<sOK1neiVi*{!jG1b
zhie)IXkT|0=33oOlIx?lnY;xagcbGHxT&3V<0zM9$@F%A{E!sQZP%>2q#O}B?GMke
zR(-}PZW+WkX&f9-{!#YPg4jELnQTn92YpQ5<qw=w$H=o?jQCqTb}BYH$8|;C$918-
zm=Mirrgb%pQ8xnVc2GZB>jW=;5Kb5*mt(E5C#K}<QJr_{pgf#m5Ma>Nkh~^1w+ at vi
zRJ+VHPnK7N6T>AV>&Gj4;4acAE%qs2kfA;|wd`}e{P*L{uZPpFjm1Z->&QdO>hgRw
z{WH^nK4pqK#m!!t4H#i!5mF3JYfsumcVCM_$4WEgXg-ahFQ998CL?nh95U?A2aR>k
zC((*$<k5v?Gmu&w8Y=3xR!Awr)#@~ui6l;4Q{)_H;i^@u57Xs;sKE^__2p7cTI-Ej
zyIv0B<Le0xr7!y6==#RHCF)uM-*SuIysPh&Dqr)EhKIq#*)|d8M3up4d}3lD!W~QP
zg`BK{d8i+SEKowK5-X at whgeyM!G@)phufcF+DH5pGa=1bLO;1q at QaI$Z3p+Mj<d)b
z@(X)4%WR}TE%b|5ftfe+W>gHejtoT(l<hSrRoN5*MH~p+Pb%;kB6LL6l?I30WLLv7
z-M^Bya>FjI5X_OsO)5`B5lVUt4ChEJGo+z~>pC(-WDL at mEyqf&#KR{#viJuRqDF|S
zhhNtxW@!eHdK*SgjhtgD5Lf#N)S)Z0_zsZ8H$KSB_wLFJBfV&8Oo*eAPsn*5 at KL;o
zyu&zu$!x=nql0|cI8vJ7X{3-QdBbvSln{lyghKuFN=!;Lto>ATXa6`%MF at Wwvl1Wk
zcbX5WfdH-*Lgo(1%HY-u4xjIj6c_~5G~?|zD4Puf=}bS8r|-;#c|7ILl=sY!c at n|X
zMFVUgtiz|C?cE`?mwlS~%ETmfN_Bi=r{Dl?%6x_)vaYNuBcrV5v%4ZW*fyu at sq_>d
zvV>Svneb>B>313~xbNO>-CtZAf4qib)mv~1wLHvIj{Z<5jm1#tfa&1YcE#r#i-X%z
zZz&HaDt-|C`8CAOrl5L?2vVMw-pzArY$w#$kX#OL9y%0#Tqmpd-Q}lUcUXlW_ZY&s
zns<o>^)xcCL4Z8f5j}dx>fdDMp7h41z}R{P%BJ}<+tTZ at k2XK`67o`pHi7qoCXp<|
zl7Sw9u6neMzcifl0mfj at o=&b4KX$hpKU}O+EKYn<tXAAj%vY?OLYOtUo~ilkdo!{~
zQ!7%hUe-kd{Rza??U!!r6zfmJ;C&y;JvNnK=964CDtR8NI-JfOlM<KWKhN%!2z?1J
z_sH~%B%3frpeOSKMj<>Q4k1)enSIzVW?mp at hpEiT=kp}<Di>&w?<h*Qt)O|}Paflw
zV3YN~^$xK3a3k4rk>O6NhzCC;QE3jHL^mO^$EwuHHkcrnhbhA*6e{J+#3E at 5>z at +z
zmNHS8G%nbjQHVtdk40K;mYNRD3E|y?z2ztSJm*45eVGQ)D~EnA#>2Tu!?eMyZMjg1
zl52xTn`hhBx}kET$Q!f$iKB at _{<RMWsEyy(EIugFvP5s$zFvH4r@%{{gx(h*q`2(k
zko}pu>>Ib^qlCz=`ReWK>8I9VJROOPy at O12)`tfEDt_@!3t9Tp!vXQU)f>js!=CXp
z{WxXBzFa$q+eoium};1mWI#a>PLX_L3={D?UMR27wsQ(AcgssRa}pJi3Med!R7(%h
zi~>4?Bhp+5G#;fXT&58bczAtpF&TKon?C*GAgVE&E1O7<>yUK at p7y$W-Zo3kik#Fj
zr8vy~%c}vYH}(5S>%1I&6svw0TIe|wb7Q6B=X5ik_7gAcTdo?TIh${CJ{e)LiF(kZ
zvwgqNx)GF39qji1%(V>R<IJw&ueVrM{)Sye|AEBtkW_0lb#EE{ac@%vE0;jwVOfKC
z;-?BjZauSX>tqnIH`g?C-^5hfE0l`UsVaEo&`H9~iWAlI8dX0yt5fxJriEg|sU=m{
z%F45n@;+A+(~v2V^kkKu0c!itSz+77kRYF2kKT%-BC)}qQZ{uD?vc at yXGEZ)0yq8<
zHSrHMerpp{CCJSxgY%I4IXf?^H8nilBAPP#l=l)0zFMSsA$}%$$nuy*LApu-&pbtB
zMEfm*(_3px_T^l4uw~#*!Wzxme$REu5816L{;hS6ZGCt0h8@*Dq6Bf?z{EOQl^SQ&
zGhmNmbs-z84ybIBm4>uqRc9e~T}SQFM>E=Ggmd8q?y}y3E&h<E)P_vF_za70yLy2$
zq5d;f0W<t1bz<8uNSyR2Da;;MFzj$zC9tbmj7^p+Y6XsFAdlge>uVLNrLR=TNNa}L
zlc_gLb*{bg=T(6tuV6SAu9*teM~vz8a%bp_MyJx`9b at Q|p-&~&BkPl(4{s^mqIG|?
zmj-2;@AhNgAc%Q(TcL>XT5ygu-kI|Qd$p at y8&u^m*ke1!O+#sPP<~X~LB-+CQ*L#C
zZ(3?fl`5~z8{us=#S at qF-H1b}bAOjmUeOKcB|dU{<r)i3BY`);PY at 0-?Vg+QMqMNA
zTh!K}B|+-?OI_utpMMS{{RT%bCGxr%W1r^rJZ6^n89=BW at gI!PA|DLA(9JwlH52|`
z(tx06<L)8!#>S(e)8HfG4vl=Beo-f>401=b^xo>Jnrg1j0FizXji&XH_%|5xLkGvK
z0EEQ at 6)N5aJykSun-=v>I{SmF<#<(l0R}Gw$5aHJj8ddGU4xHaEyOXD+RA?O>dBah
zS&8!Sf%k#YJtxCE^=Hmg6!)N?ZT5oYm~sEXr|mIvs*m^9Y0xF;apTv6+%w&Fu*Yi<
zDkHcdU%bZ9Z3c$_!KZ0Q<#)Q)`HnSibuWnOJhEIYws1dGwo*3jo~(4~?!H#vJ51Um
zKBZb-*}ZzPPOYIcF-3ZQco{9-g*eT2o&@A`<96#_6<WoNnok}QL|Q3QSSXF=HSF=U
zpHeSt85LfBsMu8=&5JT0sVIIK6=7o()u8opt3w;h9F at fb+bDD_d_LBKg{@Cbd1Dj$
zvM>aaa35lQqtPS<^&zRJuvBs+zxdOGl!)din?R<B>(Ttj_)sn{gA7T^W9?nL_lsX&
zyIo8aFTAQdSS)*eeK at R=iE at mAYdu|j(+Qlhrtd-X<)Yt#nbvflMMUTwo#Q}eJU<O9
zLNlkYgu~h=b$*=<9?W9(6k04R9TZ7Ml2Bq>Zo={`XSse<L&L;&P9`pvu7sCza?dC;
z7FIt$c2S+ at gS>$pIwL%O@#G464r4Zht0?@HS#^YgB7Pe-37p$}m`Te6tb?QDG50_|
zHsi*Ppp8CbX(#q^5Xc_H?L8=&TbLC?VWP!^Xg3iGh1&Ko`I=8EoPqHSUY!BS6LPy)
zDIh7cqQc%Qm#rInf&r at ycPf=?HOqY`_dBpX%Wo~7;RA}uuI=vra(6wJe`Bz>VHv}q
z-y^ql)B at h)G at N78wqv1c&pfK&9zUmy%_$_)P*%;-tmjkR6svNE;S}1VA2y7Y19%i8
zPd5?aw%8jE7r&tHPE<}-IZnl45^T%r1XgVmJRF95gIf*NWve%T!^rrOzUXT4!NkhL
z-2Uf-enQ6!RwSis`^4*lB5NPtGD;kIFhJls=*y6v9USl at K?$r%QA|>>C^j1}&k24b
zxrShWNt+{8RM<&P(8HwL{&dUpRo#I8W3xb2cxw=6z>x7$5Z!1w&(?f}09VrDicPPX
zBcJXW?We_bBzrsRj>WeGN(H0d(yScVHtg1cv*ZZuRx;%&3&$b*0}ll*$kH1}NZuM?
z#|lkZA1_%&AO|dcg(C at Z<Z;6<efOO^j=&0~cfmxzuQ;t*nlLAi`;*%OZ_QH^R!V1=
zqo4`&#KKxqUS_E$SXjBosSHx`ux-O9PLuul5ry#7(KuyxlPWE(qX%V776CoDEkNgK
zuU8GML3<sQJoU%UvliUvpdX+*`B_bK at Mf-R`)T7%Tihza=`7~?>Xe>9H6PmR>~tsQ
zjaZ^97Ih&vxwoMiXPBeGmhX<Smk>2!w7*opD(o^e9ocAYn-ojG#(u+E%BJ>NvGh`r
zI^Kf7h82HkEAsR38|E98tBJFhyhM+hh?82{EGFS1<tP%R784{#B<XTFN7&Ikkl<2G
z7s*#tN5%^233_`qwAo}(Iys>NV1(7$d$C19?dU`J)C*WI;y>aiS=xPk4V)GEI!898
zb3G%KE98Ny#OiC}T1S4F_t+-;o<lHM3Bw6CryD0HP6c at Z2|^{@x@?J at q;3V-j~H<k
zNka?_rJP?$-Rw%XdDK;n$|hKayeM;=N!wzNb82ZAJ}%Q!?{0EBFKFVcJSC|AO2~P=
zJX-0Yh+0bDb6n_b>BPr#G)qc*k|jz%rG1?*xL+O-8jc~l(hMP5{)q5{gMNMMXP0*a
z>ur`DUk*MT*L$u#Un-7f at _f?#`K2N6`^hD$!5$7I5Gvk!dS|GJQgko;$A-tSo{ifH
z7)dn>$g;M0+uql<4;>z*5a*jcdq}x}p&LM)P*81cHFB7 at vIdgD&|3r1O{^*q8k+Qf
zge7Rs7!DbY8UFB$QsyfiD0;+dwYz;$OkCqI%a3T5U_4+X)Ly)a`VH$o+R{YQzz7Cg
zC;t*A;X4->-BOw+=I!@O#?P at z$uZdKwJrREj+QJt9uYngwZkWTgky}f_7%`?eiO`=
z0rMM^;!hodY at +bRy0pLX$OoV}$I9CH at 5s4VBqC4BPs&elxtBzuZ)Zn*;Y2GE>#Occ
zTSM~cn{*uR@(*STPD*WHQu8Mq3>+rRni-6kNlpAflf#plxY%wTi0Qx`FEM~F9mUSw
z?H7kV3zs71k4`N3h#94<5jm(G+TsBRpG5#U2A1oowzYQs=B%!)E8gQe_R_5f at E|pt
z+O^?alhcMktE`==B=D7Iw$!2J_V;(5 at zF3|P3|1Fiyi at 9_@$%hj*K{{l;mqPMLtu#
zJ4-Gxh7!F)n+d+7%ggQ9SHX)SV$tw11;Q3V^OnJ^n~RniXC>cG-Y>%29R(i-6|U#e
zI`4n~y16Pgb!HkB$C*(V$DzC!8RQhKCc~a>y3I{gP3O;#{{(aG9hpH|T9e?!EBg!L
zS*a)<-t$8%T}f;zt!aB!qt_qbyw)fsdP0DubVSyi#{Y2WsnHW}Co(3Z`Up8(IZ2XI
zWzIpamue_5cw!R_6A|%cUEB+shbQN*A1j<YdaKll_6e at H1J^2#Lr>;()k~}_3Y{tS
z2pieUinCeveX1CqUECCvZS8B-BZEWoL%`pAZ`MM0=bZN?0~(Y%a}gHoxT(uBpYb8F
zEVHEv$qP9Ip$xoA&(b|gKSRR6VZfD|F}IhJ{hG=`Y+`S`Tn?QN%XxaFk)YV=!$)w&
zz4 at YO!^ik$Pu}W>DJxrXUug1T+2y)-l60fCRAV44$I2MTV8pQ&6zAZVXT7_ovhr1A
z<>uZ8g;-0~Cl3jdh7$)9M_?T5cMBgTTEDtXegEaX@(~w-BEc7u0LrPU4O^nc*?Bq8
z8fTJwSErri&S+Y<G)hnJv&2tYmpiRFAu4k;Z$yt#QdIK5v`kAh-=7m at J*Nl<wb=2?
zU~Kch7p)7G4Uju5;k at P~iZM=DU!wTfdP&R`K$Fe>#m_n^4|{bV(s+Du<D=i%Gu(CM
zuVyb<b9mOqPh2NNs|Y9ua#^ky<@{BYrO+r2?K$*D+c5f$8TV=~N2L1Vg2CMT-;%Yk
z3TXAJtqn9ME;<B`3+uN`Xgzp1+f?1-2!HJG2sG)Bc at L-7y}-qBwHhOi=BS*hO}h!H
zw7D5LFzt&D5huc_o1i1;O4XD0ryYl#bbQlF<ri`6qgALZ&xNsM$%a^7^_KdBSf6bn
zlUQK{yOMW>i!fDqGoy4${{c^41}eFHd#Aw!3mbpO%QdzEYGHdr`-rClaP^5!!FJJ{
zM71)k4tS9sDJ26nkBL at PdI{Dr&q10GHkw<vhM^agn}?x=6Hlg~0}@g-y6utk{8_B>
zA~>;XWvN?R`k#K990sW`8nn;{QtoJ1Z|%$pj9)b)Z at sXbST!M^`t)fQq^`T8M#pj8
z;<x=WA{+8xI9aiZ$Ci8Fb-v28v7xOd78M_7bK}k7%k@)V|G9L!x7iE4?8T-|a8J7U
z`aF6BXos&9-cSjAAnN>)o%ZH<X?#wb^B64r3ZAvI>Em<FR|S=(?ggX_hnH8<oj)r4
z{9?^}XivCI9>V5|Wo9v<cJ4`}eSX075(aN3c^gd{C_?p?@p-PV@<AXM8)CIUTXkqX
zPOr>bcPLbq<|T&*q*+ro*^h6|D7`SB1cR<ukmkJ0yC7~jKJ&r4+IsJLpJyl%F84P$
zFjSxggoD3Rl at _nuyg2U{bbQ{cKK~H at NAb{)gh3P!PIu813x_)F;ZD|Jy${!5h+(j$
z#Q*t}Ag(((t)Hm?StAF1LwyH*AR7PYAv_wgGQYy+OdK3+zr*Id0xm$Z#lpye_?3}~
znKd8fUR at I<v6&$sr8=AJGg(^^BU3X8H+v&xH#rppHwyzULrMXD1YQCC+XHs!UG#0~
zjej1?10n`e0(>MQN-|<3w->l at yIB1n#a(S{<3<qv?q4A&haFm5yDMo|D`G<u$04+#
zAs0%ZDMe??7dN)$ljSDqukSPR%Sp4LcUMv>$gmpC+s at 3+I_$u%7BItmUd)&4<hkFj
zSQ3m0?YF&(q<rkR at 2;-BGSBCav(i&N+ml at x{NPOs99}%-#iJ*Cx($)VWSZOzM>~Od
z>$e}ua+Uc0)6-M$Dd^?JM_*cNeW84%x}fN;UzTP1++D7}gTBg;+1-I{x$adq^~U+a
zpWXSgC;Yvl{XxnsUwWiC{g7|UemhH}IGAR#n|%n=u9TCkEAVtpI96$Frm2didrhmF
zg$-5s09^re9b=eW7x`o}&Wgds^-tc#L%uGzXM0}U)8Vn-AZb+`KV~m*%w#?29BscJ
z5UpdMtgTtUb6gGcZ|8%6zV13?!OnNbph>Q9E<Sx3;_zmmgs?ax>dNp|$wb*i=<kJ0
zggEvYB{BxAXSn+cXFgxSTBEG7=EW`YXmB4GjX!gb&|DK35*QIUBTx{?2&4o`0y%-|
zgGZxZ2vj5$ZcVQ<0u|koMirf)QICK<jN<L=Die1W{g+`$S65g69GJy|mK)I}!+gA1
z;OOph_?5}*zg+ at N#s at Q3n_^zA*U8w=<{4SEMh;2XIT<I at yjY}IZRu)-4u`bFBBW)2
z^@5M(tej_qsv4Zk%k5x3qt%_v)8)s0`?-rtt<ufBY&R0&lHzmT1d?7O0`UR-Nu%n+
z?=-4jtMFH^-y}tC!#<x4wu8!E|MMI$8dJvS#daF+vrqf^G)%uBL#kB052Aox=1g+M
zNs<rpFrMt11mHebK9vqC6$j%EA{uP3l#>dDLX5=l4`qJP^4{oqJ3*iKHXN$=+fTG}
zIXCRpj`a71xbs>eKEfe5#R|@(`qUXFRNSPJI6POjs%vc_+8{&y`vS!+rEsTSrM at Yx
z-Y7ZuGs=sGDgQ^ogefPR at _||MO4@^Pzt?pz#;=<{vT at lt8Vq(9CO#M0v?V+nwy;We
z4>dFdkvH|WxLAe}Iz#C3mRp?C)+n^!)Nvw4TtkL4ajY3H at kn%OHF$-xF*2);Q(8*x
z;tYB(I9+I&4y8q;(0$aDCt}Qi<80vIq!8}hBIV4 at 3hMQ$>ktCBF*2Kl2xEaCoDI5I
zYDb5$lDgL#bl`RL3WJ^wMhAIx^<{(CSjGK<i5bmxNEsRC1H{sV4o;ca(W?yivxt?6
zm=B~1RLtcW8#?&{Tc{<fF%PNXm?jSLf{@c0s{`%>@CLfcE0mHvZjcu`aWmHNoFv|W
z%}ppB)6JoEn at OH#IAN?+jx9QNd=Q{eGG54ws4cXvgR<F)8+e_335*Kd^<lWLNQYx{
zEKsnSUdYotmXUOF97LMi2OZk651bK?8{{b#a}gocm at SZJs9Uq{7s5#<PsUQZ`HULD
z;{hFxUX4=1at-p3flM!OoKA(<@E9H9rk$8WhvIo<q at YI7`rP2tShLzhIt=p*bi_Qq
z0`lk|-?}`3l}g>BbsXdc)P>7&5!b6x>>RzQo!qC;!F?r+R&*6^LkHx=42L>|9=|3X
z at mfxYeI{fvhp%4Qx1_TMDNni0*n5O!^8hYzeSq4 at eT9o-O)YoJB1H#Zfg6cE|NZQ*
z412BT-{g7eA*s9@&%azwa}PoAZqOSz^nN`)Js08V?0hsjwI?Dxk4M80QP-zRo`%Dr
f4hLVR_^pLj!F8DyWwpU8Bcv6rckj-B9<}}kk59z)
literal 0
HcmV?d00001
diff --git a/freebsd/contrib/ptpd/doc/PTPBASE-MIB.txt b/freebsd/contrib/ptpd/doc/PTPBASE-MIB.txt
new file mode 100644
index 00000000..43030e6a
--- /dev/null
+++ b/freebsd/contrib/ptpd/doc/PTPBASE-MIB.txt
@@ -0,0 +1,5710 @@
+PTPBASE-MIB DEFINITIONS ::= BEGIN
+IMPORTS
+	enterprises,
+	MODULE-IDENTITY,
+	OBJECT-TYPE,
+	NOTIFICATION-TYPE,
+	Counter32,
+	Counter64,
+	Gauge32,
+	Integer32,
+	Unsigned32
+		FROM SNMPv2-SMI
+	TruthValue,
+	DisplayString,
+	TEXTUAL-CONVENTION
+		FROM SNMPv2-TC
+	InterfaceIndexOrZero
+		FROM IF-MIB
+	InetAddress,
+	InetAddressType
+		FROM INET-ADDRESS-MIB
+	OBJECT-GROUP,
+	NOTIFICATION-GROUP,
+	MODULE-COMPLIANCE
+		FROM SNMPv2-CONF;
+ptpbaseMIB MODULE-IDENTITY
+	LAST-UPDATED "201510272300Z"	-- Oct 27, 2015 11:00:00 PM
+	ORGANIZATION "TICTOC Working Group, PTPd project"
+	CONTACT-INFO
+		"WG Email: tictoc at ietf.org
+		       Vinay Shankarkumar
+		       Cisco Systems,
+		       Email: vinays at cisco.com
+		       Laurent Montini,
+		       Cisco Systems,
+		       Email: lmontini at cisco.com
+		       Tim Frost,
+		       Symmetricom Inc.,
+		       Email: tfrost at symmetricom.com
+		       Greg Dowd,
+		       Symmetricom Inc.,
+		       Email: gdowd at symmetricom.com
+		Wojciech Owczarek
+		PTPd project,
+		Email: wojciech at owczarek.co.uk"
+	DESCRIPTION
+		"The MIB module for PTP version 2 (IEEE Std. 1588(TM)-2008)
+		       Overview of PTP version 2 (IEEE Std. 1588(TM)-2008)
+		       [IEEE 1588-2008] defines a protocol enabling precise
+		       synchronization of clocks in measurement and control systems
+		       implemented with packet-based networks, the Precision Time
+		       Protocol Version 2 (PTPv2).  This MIB does not address the
+		       earlier version IEEE Std. 1588(TM)-2002 (PTPv1).  The protocol
+		       is applicable to network elements communicating using IP.  The
+		       protocol enables heterogeneous systems that include clocks of
+		       various inherent precision, resolution, and stability to
+		       synchronize to a grandmaster clock.
+		       The protocol supports system-wide synchronization accuracy in
+		       the sub-microsecond range with minimal network and local clock
+		       computing resources. [IEEE 1588-2008] uses UDP/IP or
+		       Ethernet and can be adapted to other mappings. It includes
+		       formal mechanisms for message extensions, higher sampling rates,
+		       correction for asymmetry, a clock type to reduce error
+		       accumulation in large topologies, and specifications on how to
+		       incorporate the resulting additional data into the
+		       synchronization protocol. The [IEEE 1588-2008] defines
+		       conformance and management capability also.
+		       MIB description
+		       This MIB is to support the Precision Time Protocol version 2
+		       (PTPv2, hereafter designated as PTP) features of network element
+		       system devices, when using the default PTP profile described in
+		       [IEEE 1588-2008], or the Telecom Profile described in
+		       [G.8265.1], when running over the IP network layer.
+		This MIB is based on the TICTOC-PTPBASE-MIB from 2012, with
+		added enhancements such as GM address, Offset from Master as
+		string, Mean Path Delay as string, parent IP address, and a set
+		of PTP traps.
+		       It is envisioned this MIB will complement other managed objects
+		       to be defined to monitor, measure the performance of the PTP
+		       devices and telecom clocks.
+		       Some other PTP profiles have their own MIBs defined as part of
+		       the profile, and this MIB is not intended to replace those MIBs.
+		       Acronyms:
+		               ARB     Arbitrary Timescale
+		               E2E     End-to-End
+		               EUI     Extended Unique Identifier.
+		               GPS     Global Positioning System
+		               IANA    Internet Assigned Numbers Authority
+		               IP      Internet Protocol
+		               MAC     Media Access Control
+		                       according to [IEEE 802.3-2008]
+		               NIST    National Institute of Standards and Technology
+		               NTP     Network Time Protocol (see IETF [RFC 5905])
+		               OUI     Organizational Unique Identifier
+		                       (allocated by the IEEE)
+		               P2P     Peer-to-Peer
+		               PTP     Precision Time Protocol
+		               TAI     International Atomic Time
+		               TC      Transparent Clock
+		               UDP     User Datagram Protocol
+		               UTC     Coordinated Universal Time
+		       References:
+		       [IEEE 1588-2008] IEEE Standard for A Precision Clock
+		           Synchronization Protocol for Networked Measurement and
+		           Control Systems, IEEE Std. 1588(TM)-2008, 24 July 2008.
+		       [G.8265.1] Precision Time Protocol Telecom Profile for
+		           Frequency Synchronization, ITU-T Recommendation G.8265.1,
+		           October 2010.
+		       As defined in [IEEE 1588-2008]:
+		       Accuracy:
+		       The mean of the time or frequency error between the clock under
+		       test and a perfect reference clock, over an ensemble of
+		       measurements.  Stability is a measure of how the mean varies
+		       with respect to variables such as time, temperature, and so on,
+		       while the precision is a measure of the deviation of the error
+		       from the mean.
+		       Atomic process:
+		       A process is atomic if the values of all inputs to the process
+		       are not permitted to change until all of the results of the
+		       process are instantiated, and the outputs of the process are
+		       not visible to other processes until the processing of each
+		       output is complete.
+		       Boundary clock:
+		       A clock that has multiple Precision Time Protocol (PTP) ports in
+		       a domain and maintains the timescale used in the domain.  It
+		       may serve as the source of time, i.e., be a master clock, and
+		       may synchronize to another clock, i.e., be a slave clock.
+		       Boundary node clock:
+		       A clock that has multiple Precision Time Protocol(PTP) ports in
+		       differs from a boundary clock in that the clock roles can
+		       change.
+		       Clock:
+		       A node participating in the Precision Time Protocol (PTP) that
+		       is capable of providing a measurement of the passage of time
+		       since a defined epoch.
+		       Domain:
+		       A logical grouping of clocks that synchronize to each other
+		       using the protocol, but that are not necessarily synchronized
+		       to clocks in another domain.
+		       End-to-end transparent clock:
+		       A transparent clock that supports the use of the end-to-end
+		       delay measurement mechanism between slave clocks and the master
+		       clock.  Each node must measure the residence time of PTP event
+		       messages and accumulate it in Correction Field.
+		       Epoch:
+		       The origin of a timescale.
+		       Event:
+		       An abstraction of the mechanism by which signals or conditions
+		       are generated and represented.
+		       Foreign master:
+		       An ordinary or boundary clock sending Announce messages to
+		       another clock that is not the current master recognized by the
+		       other clock.
+		       Grandmaster clock:
+		       Within a domain, a clock that is the ultimate source of time
+		       for clock synchronization using the protocol.
+		       Holdover:
+		       A clock previously synchronized/syntonized to another clock
+		       (normally a primary reference or a master clock) but now
+		       free-running based on its own internal oscillator, whose
+		       frequency is being adjusted using data acquired while it had
+		       been synchronized/syntonized to the other clock.  It is said to
+		       be in holdover or in the holdover mode, as long as it is within
+		       its accuracy requirements.
+		       Link:
+		       A network segment between two Precision Time Protocol ports
+		       supporting the peer delay mechanism of this standard.  The peer
+		       delay mechanism is designed to measure the propagation time
+		       over such a link.
+		       Management node:
+		       A device that configures and monitors clocks.
+		       Master clock:
+		       In the context of a single Precision Time Protocol
+		       communication path, a clock that is the source of time to which
+		       all other clocks on that path synchronize.
+		       Message timestamp point:
+		       A point within a Precision Time Protocol event message serving
+		       as a reference point in the message.  A timestamp is defined by
+		       the instant a message timestamp point passes the reference
+		       plane of a clock.
+		       Multicast communication:
+		       A communication model in which each Precision Time Protocol
+		       message sent from any PTP port is capable of being received and
+		       processed by all PTP ports on the same PTP communication path.
+		       Node:
+		       A device that can issue or receive Precision Time Protocol
+		       communications on a network.
+		       One-step clock:
+		       A clock that provides time information using a single event
+		       message.
+		       On-pass support:
+		       Indicates that each node in the synchronization chain from
+		       master to slave can support IEEE-1588.
+		       Ordinary clock:
+		       A clock that has a single Precision Time Protocol port in a
+		       domain and maintains the timescale used in the domain.  It may
+		       serve as a source of time, i.e., be a master clock, or may
+		       synchronize to another clock, i.e., be a slave clock.
+		       Parent clock:
+		       The master clock to which a clock is synchronized.
+		       Peer-to-peer transparent clock:
+		       A transparent clock that, in addition to providing Precision
+		       Time Protocol event transit time information, also provides
+		       corrections for the propagation delay of the link connected to
+		       the port receiving the PTP event message.  In the presence of
+		       peer-to-peer transparent clocks, delay measurements between
+		       slave clocks and the master clock are performed using the
+		       peer-to-peer delay measurement mechanism.
+		       Phase change rate:
+		       The observed rate of change in the measured time with respect
+		       to the reference time.  The phase change rate is equal to the
+		       fractional frequency offset between the measured frequency and
+		       the reference frequency.
+		       PortNumber:
+		       An index identifying a specific Precision Time Protocol port on
+		       a PTP node.
+		       Primary reference:
+		       A source of time and or frequency that is traceable to
+		       international standards.
+		       Profile:
+		       The set of allowed Precision Time Protocol features applicable
+		       to a device.
+		       Precision Time Protocol communication:
+		       Information used in the operation of the protocol, transmitted
+		       in a PTP message over a PTP communication path.
+		       Precision Time Protocol communication path:
+		       The signaling path portion of a particular network enabling
+		       direct communication among ordinary and boundary clocks.
+		       Precision Time Protocol node:
+		       PTP ordinary, boundary, or transparent clock or a device that
+		       generates or parses PTP messages.
+		       Precision Time Protocol port:
+		       A logical access point of a clock for PTP communications to the
+		       communications network.
+		       Recognized standard time source:
+		       A recognized standard time source is a source external to
+		       Precision Time Protocol that provides time and/or frequency as
+		       appropriate that is traceable to the international standards
+		       laboratories maintaining clocks that form the basis for the
+		       International Atomic Time and Universal Coordinated Time
+		       timescales.  Examples of these are GPS, NTP, and NIST
+		       timeservers.
+		       Requestor:
+		       The port implementing the peer-to-peer delay mechanism that
+		       initiates the mechanism by sending a Pdelay_Req message.
+		       Responder:
+		       The port responding to the receipt of a Pdelay_Req message as
+		       part of the operation of the peer-to-peer delay mechanism.
+		       Synchronized clocks:
+		       Two clocks are synchronized to a specified uncertainty if they
+		       have the same epoch and their measurements of the time of a
+		       single event at an arbitrary time differ by no more than that
+		       uncertainty.
+		       Syntonized clocks:
+		       Two clocks are syntonized if the duration of the second is the
+		       same on both, which means the time as measured by each advances
+		       at the same rate. They may or may not share the same epoch.
+		       Timeout:
+		       A mechanism for terminating requested activity that, at least
+		       from the requester's perspective, does not complete within the
+		       specified time.
+		       Timescale:
+		       A linear measure of time from an epoch.
+		       Traceability:
+		       A property of the result of a measurement or the value of a
+		       standard whereby it can be related to stated references,
+		       usually national or international standards, through an
+		       unbroken chain of comparisons all having stated uncertainties.
+		       Translation device:
+		       A boundary clock or, in some cases, a transparent clock that
+		       translates the protocol messages between regions implementing
+		       different transport and messaging protocols, between different
+		       versions of [IEEE 1588-2008], or different PTP profiles.
+		       Transparent clock:
+		       A device that measures the time taken for a Precision Time
+		       Protocol event message to transit the device and provides this
+		       information to clocks receiving this PTP event message.
+		       Two-step clock:
+		       A clock that provides time information using the combination of
+		       an event message and a subsequent general message.
+		       The below table specifies the object formats of the various
+		       textual conventions used.
+		       Data type mapping   Textual Convention SYNTAX
+		       5.3.2 TimeInterval  ClockTimeInterval OCTET STRING(SIZE(1..255))
+		       5.3.3 Timestamp     ClockTimestamp    OCTET STRING(SIZE(6))
+		       5.3.4 ClockIdentity ClockIdentity     OCTET STRING(SIZE(1..255))
+		       5.3.5 PortIdentity  ClockPortNumber   INTEGER(1..65535)
+		       5.3.7 ClockQuality  ClockQualityClassType
+		       Simple master-slave hierarchy, section 6.6.2.4 [IEEE 1588-2008]:
+		                 |   Ordinary    |
+		                 |   Clock -1    |
+		                 | (GrandMaster) |
+		                 +-------M-------+
+		                         1
+		         +---------------S-----------------+
+		         |            Boundary             |
+		         |            Clock -1             |
+		         +-----M---------------------M-----+
+		               2                     3
+		         +-----S-----+  +------------S-------------+
+		         | Ordinary  |  |         Boundary         |
+		         | Clock -2  |  |         Clock -2         |
+		         +-----------+  +-----M--------------M-----+
+		                              4              5
+		                        +-----S-----+  +-----S-----+
+		                        | Ordinary  |  | Ordinary  |
+		                        | Clock -3  |  | Clock -4  |
+		         Grandmaster
+		         Boundary Clock(0-N)   Ordinary Clocks(0-N)
+		         Ordinary Clocks(0-N)
+		       Relationship cardinality:
+		          PTP system 1 : N PTP Clocks
+		          PTP Clock  1 : 1 Domain
+		          PTP Clock  1 : N PTP Ports
+		          PTP Ports  N : M Physical Ports (interface in IF-MIB)
+		       Transparent clock diagram, section 6.7.1.3 of [IEEE 1588-2008]:
+		                        |     Boundary clock - 1      |
+		                  +-- A --+                         B
+		       |  Ordinary clock      |                     |
+		       +----------------------+          |      End-to-end      |
+		       |  Ordinary clock 1-1  |----------|  transparent clock-  |
+		       +----------------------+          |        1 - 1         |
+		                                                    C
+		       |  Ordinary clock 1-2  |----------|  transparent clock-  |
+		       +----------------------+          |        1 - 2         |
+		       The MIB refers to the sections of [IEEE 1588-2008]."
+	-- revision log
+	-- ::= { mib-2 XXX }
+	-- 1.3.6.1.4.1.46649.1.1
+::= { enterprises 46649 1 1 }
+-- PTPd Private Enterprise Number (PEN)
+ClockDomainType ::= TEXTUAL-CONVENTION
+	DISPLAY-HINT "d"
+	STATUS  current
+	DESCRIPTION
+		"The Domain is identified by an integer, the domainNumber, in
+		the range of 0 to 255. An integer value that is used to assign
+		each PTP device to a particular domain. The following values
+		define the valid domains.
+		         Value       Definition
+		         0           Default domain
+		         1           Alternate domain 1
+		         2           Alternate domain 2
+		         3           Alternate domain 3
+		         4 - 127     User-defined domains
+		         128 - 255   Reserved"
+	REFERENCE
+		"Section 7.1 Domains, Table 2 of [IEEE 1588-2008]"
+	SYNTAX Unsigned32 (0..255)
+ClockIdentity ::= TEXTUAL-CONVENTION
+	STATUS  current
+	DESCRIPTION
+		"The clock Identity is an 8-octet array and will be presented in
+		the form of a character array. The value of the
+		ClockIdentity should be taken from the IEEE EUI-64 individual
+		assigned numbers as indicated in Section 7.5.2.2.2 of
+		[IEEE 1588-2008].  The EUI-64 address is divided into the
+		following fields:
+		     OUI bytes (0-2)
+		     Extension identifier bytes (3-7)
+		The clock identifier can be constructed from existing EUI-48
+		assignments and here is an abbreviated example extracted from
+		section 7.5.2.2.2 [IEEE 1588-2008].
+		     Company EUI-48 = 0xACDE4823456716
+		     EUI-64 = ACDE48FFFE23456716
+		It is important to note the IEEE Registration Authority has
+		deprecated the use of MAC-48 in any new design."
+	REFERENCE
+		"Section 7.5.2.2.1 of [IEEE 1588-2008]"
+	SYNTAX OCTET STRING (SIZE (1..255))
+ClockIntervalBase2 ::= TEXTUAL-CONVENTION
+	DISPLAY-HINT "d"
+	STATUS  current
+	DESCRIPTION
+		"The interval included in message types Announce, Sync,
+		Delay_Req, and Pdelay_Req as indicated in section 7.7.2.1 of
+		[IEEE 1588-2008].
+		The mean time interval between successive messages shall be
+		represented as the logarithm to the base 2 of this time
+		interval measured in seconds on the local clock of the device
+		sending the message. The values of these logarithmic attributes
+		shall be selected from integers in the range -128 to 127 subject
+		to further limits established in an applicable PTP profile."
+	REFERENCE
+		"Section 7.7.2.1 General interval specification of
+		[IEEE 1588-2008]"
+	SYNTAX Integer32 (-128..127)
+ClockMechanismType ::= TEXTUAL-CONVENTION
+	STATUS  current
+	DESCRIPTION
+		"The clock type based on whether End to End or peer to peer
+		mechanisms are used. The mechanism used to calculate the Mean
+		Path Delay as indicated in Table 9 of [IEEE 1588-2008].
+		Delay mechanism   Value(hex)  Specification
+		E2E                  01       The port is configured to use the
+		                              delay request-response mechanism.
+		P2P                  02       The port is configured to use the
+		                              peer delay mechanism.
+		DISABLED             FE       The port does not implement the
+		                              delay mechanism."
+	REFERENCE
+		"Sections 8.2.5.4.4, 6.6.4, 7.4.2 of [IEEE 1588-2008]."
+	SYNTAX INTEGER {
+			e2e(1),
+			p2p(2),
+			disabled(254) }
+ClockInstanceType ::= TEXTUAL-CONVENTION
+	DISPLAY-HINT "d"
+	STATUS  current
+	DESCRIPTION
+		"The instance of the Clock of a given clock type in a given
+		domain."
+ClockPortNumber ::= TEXTUAL-CONVENTION
+	DISPLAY-HINT "d"
+	STATUS  current
+	DESCRIPTION
+		"An index identifying a specific Precision Time Protocol (PTP)
+		port on a PTP node."
+	REFERENCE
+		"Sections 7.5.2.3 and 5.3.5 of [IEEE 1588-2008]"
+	SYNTAX Unsigned32 (0..65535)
+ClockPortState ::= TEXTUAL-CONVENTION
+	STATUS  current
+	DESCRIPTION
+		"This is the value of the current state of the protocol engine
+		associated with this port.
+		Port state      Value     Description
+		initializing      1       In this state a port initializes
+		                          its data sets, hardware, and
+		                          communication facilities.
+		faulty            2       The fault state of the protocol.
+		disabled          3       The port shall not place any
+		                          messages on its communication path.
+		listening         4       The port is waiting for the
+		                          announceReceiptTimeout to expire or
+		                          to receive an Announce message from
+		                          a master.
+		preMaster         5       The port shall behave in all respects
+		                          as though it were in the MASTER state
+		                          except that it shall not place any
+		                          except for Pdelay_Req, Pdelay_Resp,
+		                          Pdelay_Resp_Follow_Up, signaling, or
+		                          management messages.
+		master            6       The port is behaving as a master port.
+		passive           7       The port shall not place any messages
+		                          on its communication path except for
+		                          Pdelay_Req, Pdelay_Resp,
+		                          Pdelay_Resp_Follow_Up, or signaling
+		                          messages, or management messages that
+		                          are a required response to another
+		uncalibrated      8       The local port is preparing to
+		                          synchronize to the master port.
+		slave             9       The port is synchronizing to the
+		                          selected master port."
+	REFERENCE
+		"Section 8.2.5.3.1 portState and 9.2.5 of
+		[IEEE 1588-2008]"
+	SYNTAX INTEGER {
+			initializing(1),
+			faulty(2),
+			disabled(3),
+			listening(4),
+			preMaster(5),
+			master(6),
+			passive(7),
+			uncalibrated(8),
+			slave(9) }
+ClockProfileType ::= TEXTUAL-CONVENTION
+	STATUS  current
+	DESCRIPTION
+		"Clock Profile used. A profile is the set of allowed Precision
+		Time Protocol (PTP) features applicable to a device."
+	REFERENCE
+		"Section 3.1.30 and 19.3 PTP profiles of
+		[IEEE 1588-2008]"
+	SYNTAX INTEGER {
+			default(1),
+			telecom(2),
+			vendorspecific(3) }
+ClockQualityAccuracyType ::= TEXTUAL-CONVENTION
+	STATUS  current
+	DESCRIPTION
+		"The ClockQuality as specified in section 5.3.7, 7.6.2.5 and
+		Table 6 of [IEEE 1588-2008].
+		The following values are not represented in the enumerated
+		values.
+		         0x01-0x1F Reserved
+		         0x32-0x7F Reserved
+		It is important to note that section 7.1.1 RFC2578 allows for
+		gaps and enumerate values to start with zero when indicated by
+		the protocol."
+	REFERENCE
+		"Section 5.3.7, 7.6.2.5 and Table 6 of
+		[IEEE 1588-2008]"
+	SYNTAX INTEGER {
+			reserved00(1),       	-- 0
+			nanoSecond25(32),    	-- 0x20
+			nanoSecond100(33),   	-- 0x21
+			nanoSecond250(34),   	-- 0x22
+			microSec1(35),       	-- 0x23
+			microSec2dot5(36),   	-- 0x24
+			microSec10(37),      	-- 0x25
+			microSec25(38),      	-- 0x26
+			microSec100(39),     	-- 0x27
+			microSec250(40),     	-- 0x28
+			milliSec1(41),       	-- 0x29
+			milliSec2dot5(42),   	-- 0x2A
+			milliSec10(43),      	-- 0x2B
+			milliSec25(44),      	-- 0x2C
+			milliSec100(45),     	-- 0x2D
+			milliSec250(46),     	-- 0x2E
+			second1(47),         	-- 0x2F
+			second10(48),        	-- 0x30
+			secondGreater10(49), 	-- 0x31
+			unknown(254),        	-- 0xFE
+			reserved255(255)    	-- 0xFF
+ClockQualityClassType ::= TEXTUAL-CONVENTION
+	DISPLAY-HINT "d"
+	STATUS  current
+	DESCRIPTION
+		"The ClockQuality as specified in section 5.3.7, 7.6.2.4 and
+		Table 5 of [IEEE 1588-2008].
+		Value     Description
+		       0  Reserved to enable compatibility with future
+		          versions.
+		     1-5  Reserved
+		       6  Shall designate a clock that is synchronized
+		          to a primary reference time source.  The
+		          timescale distributed shall be PTP.  A
+		          clockClass 6 clock shall not be a slave to
+		          another clock in the domain.
+		       7  Shall designate a clock that has previously
+		          been designated as clockClass 6 but that has
+		          lost the ability to synchronize to a primary
+		          reference time source and is in holdover mode
+		          and within holdover specifications. The
+		          clockClass 7 clock shall not be a slave to
+		       8  Reserved.
+		    9-10  Reserved to enable compatibility with future
+		          versions.
+		   11-12  Reserved.
+		      13  Shall designate a clock that is synchronized
+		          to an application-specific source of time.
+		          The timescale distributed shall be ARB.  A
+		          clockClass 13 clock shall not be a slave to
+		      14  Shall designate a clock that has previously
+		          been designated as clockClass 13 but that
+		          has lost the ability to synchronize to an
+		          application-specific source of time and is
+		          in holdover mode and within holdover
+		          specifications. The timescale distributed
+		          shall be ARB.  A clockClass 14 clock shall
+		          not be a slave to another clock in the domain.
+		   15-51  Reserved.
+		      52  Degradation alternative A for a clock of
+		          clockClass 7 that is not within holdover
+		          specification.  A clock of clockClass 52
+		          shall not be a slave to another clock in
+		          the domain.
+		   53-57  Reserved.
+		      58  Degradation alternative A for a clock of
+		          clockClass 14 that is not within holdover
+		          specification. A clock of clockClass 58 shall
+		   59-67  Reserved.
+		  68-122  For use by alternate PTP profiles.
+		 123-127  Reserved.
+		 128-132  Reserved.
+		 133-170  For use by alternate PTP profiles.
+		 171-186  Reserved.
+		     187  Degradation alternative B for a clock of
+		          specification. A clock of clockClass 187 may
+		          be a slave to another clock in the domain.
+		 188-192  Reserved.
+		     193  Degradation alternative B for a clock of
+		          specification. A clock of clockClass 193 may
+		 194-215  Reserved.
+		 216-232  For use by alternate PTP profiles.
+		 233-247  Reserved.
+		     248  Default. This clockClass shall be used if
+		          none of the other clockClass definitions apply.
+		 249-250  Reserved.
+		     251  Reserved for version 1 compatibility; see Clause 18.
+		 252-254  Reserved.
+		     255  Shall be the clockClass of a slave-only clock; see
+		          9.2.2."
+	REFERENCE
+		"Section 5.3.7, 7.6.2.4 and Table 5 of
+		[IEEE 1588-2008]."
+ClockRoleType ::= TEXTUAL-CONVENTION
+	STATUS  current
+	DESCRIPTION
+		"The Clock Role. The protocol generates a Master Slave
+		relationship among the clocks in the system.
+		Clock Role      Value     Description
+		Master clock     1        A clock that is the source of
+		                          time to which all other clocks on
+		                          that path synchronize.
+		Slave clock      2        A clock which synchronizes to
+		                          another clock (master)."
+	SYNTAX INTEGER {
+			master(1),
+			slave(2) }
+ClockStateType ::= TEXTUAL-CONVENTION
+	STATUS  current
+	DESCRIPTION
+		"The clock state returned by PTP engine.
+		Clock State      Value   Description
+		Freerun state       1   Applies to a slave device that is not
+		                        locked to a master. This is the initial
+		                        state a slave starts out with when it
+		                        is not getting any PTP packets from the
+		                        master or because of some other input
+		                        error (erroneous packets, etc).
+		Holdover state      2  In this state the slave device is
+		                        locked to a master but communication
+		                        with the master is lost or the
+		                        timestamps in the ptp packets are
+		                        incorrect. But since the slave was
+		                        locked to the master, it can run with
+		                        the same accuracy for sometime. The
+		                        slave can continue to operate in this
+		                        state for some time. If communication
+		                        with the master is not restored for a
+		                        while, the device is moved to the
+		                        FREERUN state.
+		Acquiring state     3   The slave device is receiving packets
+		                        from a master and is trying to acquire
+		                        a lock.
+		Freq_locked state   4   Slave device is locked to the Master
+		                        with respect to frequency, but not phase
+		                        aligned
+		Phase_aligned state 5   Locked to the master with respect to
+		                        frequency and phase."
+	SYNTAX INTEGER {
+			freerun(1),
+			holdover(2),
+			acquiring(3),
+			frequencyLocked(4),
+			phaseAligned(5) }
+ClockTimeSourceType ::= TEXTUAL-CONVENTION
+	STATUS  current
+	DESCRIPTION
+		"The ClockQuality as specified in section 5.3.7, 7.6.2.6 and
+		Table 7 of [IEEE 1588-2008].
+		values.
+		0xF0-0xFE  For use by alternate PTP profiles
+		0xFF       Reserved
+		the protocol."
+	REFERENCE
+		"Section 5.3.7, 7.6.2.6 and Table 7 of
+	SYNTAX INTEGER {
+			atomicClock(16),        	-- 0x10
+			gps(32),                	-- 0x20
+			terrestrialRadio(48),   	-- 0x22
+			ptp(64),                	-- 0x40
+			ntp(80),                	-- 0x50
+			handSet(96),            	-- 0x60
+			other(144),             	-- 0x90
+			internalOsillator(160) 	-- 0xA0
+ClockTimeInterval ::= TEXTUAL-CONVENTION
+	STATUS  current
+	DESCRIPTION
+		"This textual convention corresponds to the TimeInterval
+		structure indicated in section 5.3.2 of [IEEE 1588-2008].
+		It will be presented in the form of a character array.
+		The TimeInterval type represents time intervals.
+		     struct TimeInterval
+		          Integer64 scaledNanoseconds;
+		The scaledNanoseconds member is the time interval expressed in
+		units of nanoseconds and multiplied by 2**16.
+		Positive or negative time intervals outside the maximum range
+		of this data type shall be encoded as the largest positive and
+		negative values of the data type, respectively.
+		For example, 2.5 ns is expressed as 0000 0000 0002 8000 in
+		Base16."
+	REFERENCE
+		"Section 5.3.2 and setion 7.7.2.1 Timer interval
+		specification of [IEEE 1588-2008]"
+ClockTxModeType ::= TEXTUAL-CONVENTION
+	STATUS  current
+	DESCRIPTION
+		"Transmission mode.
+		unicast. Using unicast communication channel.
+		multicast. Using Multicast communication channel.
+		multicast-mix. Using multicast-unicast communication channel"
+	SYNTAX INTEGER {
+			unicast(1),
+			multicast(2),
+			multicastmix(3) }
+ClockType ::= TEXTUAL-CONVENTION
+	STATUS  current
+	DESCRIPTION
+		"The clock types as defined in the MIB module description."
+	REFERENCE
+		"Section 6.5.1 of [IEEE 1588-2008]."
+	SYNTAX INTEGER {
+			ordinaryClock(1),
+			boundaryClock(2),
+			transparentClock(3),
+			boundaryNode(4) }
+PtpdAlarmType ::= TEXTUAL-CONVENTION
+	STATUS  current
+	DESCRIPTION
+		"Alarm identifier (type) as used by PTPd"
+	REFERENCE
+		"PTPd 2.3.2"
+	SYNTAX INTEGER {
+			portState(0),
+			ofmThreshold(1),
+			ofmSeconds(2),
+			clockStep(3),
+			noSync(4),
+			noDelay(5),
+			masterChange(6),
+			networkFault(7),
+			fastAdj(8),
+			timePropertiesChange(9),
+			domainMismatch(10) }
+PtpdAlarmState ::= TEXTUAL-CONVENTION
+	STATUS  current
+	DESCRIPTION
+		"Alarm state as used by PTPd"
+	REFERENCE
+		"PTPd 2.3.2"
+	SYNTAX INTEGER {
+			unset(0),
+			set(1),
+			cleared(2) }
+ptpbaseMIBNotifs OBJECT IDENTIFIER
+	-- 1.3.6.1.4.1.46649.1.1.0
+::= { ptpbaseMIB 0 }
+ptpBasePortUnexpectedState NOTIFICATION-TYPE
+	OBJECTS {
+		ptpbaseClockPortRunningState}
+	STATUS  current
+	DESCRIPTION
+		"Alarm: port has gone into a state other than expected in current configuration."
+	-- 1.3.6.1.4.1.46649.1.1.0.1
+::= { ptpbaseMIBNotifs 1 }
+ptpBasePortExpectedState NOTIFICATION-TYPE
+	OBJECTS {
+	STATUS  current
+	DESCRIPTION
+		"Alarm cleared: port has returned to expected state."
+	-- 1.3.6.1.4.1.46649.1.1.0.2
+::= { ptpbaseMIBNotifs 2 }
+ptpBaseSlaveOfmThresholdExceeded NOTIFICATION-TYPE
+	OBJECTS {
+		ptpbaseClockCurrentDSOffsetFromMaster,
+		ptpbaseClockCurrentDSOffsetFromMasterString,
+		ptpbaseClockCurrentDSOffsetFromMasterThresholdNs}
+	STATUS  current
+	DESCRIPTION
+		"Alarm: slave Offset From Master has exceeded defined threshold."
+	-- 1.3.6.1.4.1.46649.1.1.0.3
+::= { ptpbaseMIBNotifs 3 }
+ptpBaseSlaveOfmThresholdAcceptable NOTIFICATION-TYPE
+	OBJECTS {
+	STATUS  current
+	DESCRIPTION
+		"Alarm cleared: slave Offset From Master has returned to a value below threshold."
+	-- 1.3.6.1.4.1.46649.1.1.0.4
+::= { ptpbaseMIBNotifs 4 }
+ptpBaseSaveClockStep NOTIFICATION-TYPE
+	OBJECTS {
+		ptpbaseClockCurrentDSOffsetFromMasterString}
+	STATUS  current
+	DESCRIPTION
+		"Event: Clock has been stepped"
+	-- 1.3.6.1.4.1.46649.1.1.0.5
+::= { ptpbaseMIBNotifs 5 }
+ptpBaseSlaveNoSync NOTIFICATION-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Alarm: PTP slave stopped receiving Sync messages"
+	-- 1.3.6.1.4.1.46649.1.1.0.6
+::= { ptpbaseMIBNotifs 6 }
+ptpBaseSlaveReceivingSync NOTIFICATION-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Alarm cleared: PTP slave is receiving sync after loss of sync."
+	-- 1.3.6.1.4.1.46649.1.1.0.7
+::= { ptpbaseMIBNotifs 7 }
+ptpBaseSlaveNoDelay NOTIFICATION-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Alarm: PTP slave is not receiving Delay / pDelay response."
+	-- 1.3.6.1.4.1.46649.1.1.0.8
+::= { ptpbaseMIBNotifs 8 }
+ptpBaseSlaveReceivingDelay NOTIFICATION-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Alarm cleared: PTP slave is receiving Delay / pDelay response after loss of Delay / pDelay."
+	-- 1.3.6.1.4.1.46649.1.1.0.9
+::= { ptpbaseMIBNotifs 9 }
+ptpBaseBestMasterChange NOTIFICATION-TYPE
+	OBJECTS {
+		ptpbaseClockParentDSParentPortIdentity,
+		ptpbaseClockParentDSParentPortAddressType,
+		ptpbaseClockParentDSParentPortAddress,
+		ptpbaseClockParentDSGMClockIdentity,
+		ptpbaseClockParentDSGMClockPriority1,
+		ptpbaseClockParentDSGMClockPriority2,
+		ptpbaseClockParentDSGMClockQualityClass,
+		ptpbaseClockTimePropertiesDSCurrentUTCOffsetValid,
+		ptpbaseClockTimePropertiesDSCurrentUTCOffset,
+	STATUS  current
+	DESCRIPTION
+		"Event: PTP node has changed its Best Master (can be self)."
+	-- 1.3.6.1.4.1.46649.1.1.0.10
+::= { ptpbaseMIBNotifs 10 }
+ptpBasePortNetworkFault NOTIFICATION-TYPE
+	OBJECTS {
+		ptpbaseClockPortRunningInterfaceIndex}
+	STATUS  current
+	DESCRIPTION
+		"Alarm: a network fault has occured and PTP port is not usable."
+	-- 1.3.6.1.4.1.46649.1.1.0.11
+::= { ptpbaseMIBNotifs 11 }
+ptpBasePortNetworkFaultCleared NOTIFICATION-TYPE
+	OBJECTS {
+	STATUS  current
+	DESCRIPTION
+		"Alarm cleared: PTP port has recovered from a network fault."
+	-- 1.3.6.1.4.1.46649.1.1.0.12
+::= { ptpbaseMIBNotifs 12 }
+ptpBaseClockFreqAdjFast NOTIFICATION-TYPE
+	OBJECTS {
+		freqAdjCurrentValue,
+		freqAdjStatsPeriodSeconds,
+		freqAdjStatsMean,
+		freqAdjStatsStatsMedian,
+		freqAdjStatsStdDev}
+	STATUS  current
+	DESCRIPTION
+		"Alarm: PTP Slave clock frequency adjustment is changing rapidly."
+	-- 1.3.6.1.4.1.46649.1.1.0.13
+::= { ptpbaseMIBNotifs 13 }
+ptpBaseClockFreqAdjNormal NOTIFICATION-TYPE
+	OBJECTS {
+		freqAdjStatsMean,
+	STATUS  current
+	DESCRIPTION
+		"Alarm cleared: PTP Slave clock frequency adjustment has returned to stable levels."
+	-- 1.3.6.1.4.1.46649.1.1.0.14
+::= { ptpbaseMIBNotifs 14 }
+ptpBaseSlaveOffsetFromMasterSeconds NOTIFICATION-TYPE
+	OBJECTS {
+	STATUS  current
+	DESCRIPTION
+		"Alarm: PTP Slave Offset From Master has reached over 1 second."
+	-- 1.3.6.1.4.1.46649.1.1.0.15
+::= { ptpbaseMIBNotifs 15 }
+ptpBaseSlaveOffsetFromMasterSubSeconds NOTIFICATION-TYPE
+	OBJECTS {
+	STATUS  current
+	DESCRIPTION
+		"Alarm cleared: PTP Slave Offset From Master dropped below 1 second after a previous value of over 1 second."
+	-- 1.3.6.1.4.1.46649.1.1.0.16
+::= { ptpbaseMIBNotifs 16 }
+ptpBaseTimePropertiesChange NOTIFICATION-TYPE
+	OBJECTS {
+		ptpbaseClockTimePropertiesDSLeap59,
+		ptpbaseClockTimePropertiesDSLeap61,
+		ptpbaseClockTimePropertiesDSTimeTraceable,
+		ptpbaseClockTimePropertiesDSFreqTraceable,
+		ptpbaseClockTimePropertiesDSPTPTimescale,
+		ptpbaseClockTimePropertiesDSSource}
+	STATUS  current
+	DESCRIPTION
+		"Event: change in the Time Properties dataset."
+	-- 1.3.6.1.4.1.46649.1.1.0.17
+::= { ptpbaseMIBNotifs 17 }
+ptpBaseDomainMismatch NOTIFICATION-TYPE
+	OBJECTS {
+		ptpbaseClockDefaultDSDomainNumber,
+		ptpBaseClockPortDSLastMismatchedDomain }
+	STATUS  current
+	DESCRIPTION
+		"Alarm: no packets from configured PTP domain are being received."
+	-- 1.3.6.1.4.1.46649.1.1.0.18
+::= { ptpbaseMIBNotifs 18 }
+ptpBaseDomainMismatchCleared NOTIFICATION-TYPE
+	OBJECTS {
+		ptpbaseClockDefaultDSDomainNumber}
+	STATUS  current
+	DESCRIPTION
+		"Alarm cleared: Clock is receiving packets from configured PTP domain."
+	-- 1.3.6.1.4.1.46649.1.1.0.19
+::= { ptpbaseMIBNotifs 19 }
+ptpbaseMIBObjects OBJECT IDENTIFIER
+	-- 1.3.6.1.4.1.46649.1.1.1
+::= { ptpbaseMIB 1 }
+ptpbaseMIBSystemInfo OBJECT IDENTIFIER
+	-- 1.3.6.1.4.1.46649.1.1.1.1
+::= { ptpbaseMIBObjects 1 }
+ptpbaseMIBClockInfo OBJECT IDENTIFIER
+	-- 1.3.6.1.4.1.46649.1.1.1.2
+::= { ptpbaseMIBObjects 2 }
+ptpbaseSystemTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbaseSystemEntry
+	MAX-ACCESS not-accessible
+	STATUS  current
+	DESCRIPTION
+		"Table of count information about the PTP system for all
+		domains."
+	-- 1.3.6.1.4.1.46649.1.1.1.1.1
+::= { ptpbaseMIBSystemInfo 1 }
+ptpbaseSystemEntry OBJECT-TYPE
+	SYNTAX  PtpbaseSystemEntry
+	STATUS  current
+	DESCRIPTION
+		"An entry in the table, containing count information about a
+		single domain. New row entries are added when the PTP clock for
+		this domain is configured, while the unconfiguration of the PTP
+		clock removes it."
+	INDEX {
+		ptpDomainIndex,
+		ptpInstanceIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.1.1.1
+::= { ptpbaseSystemTable 1 }
+PtpbaseSystemEntry ::= SEQUENCE {
+	ptpDomainIndex           ClockDomainType,
+	ptpInstanceIndex         ClockInstanceType,
+	ptpDomainClockPortsTotal Gauge32 }
+ptpDomainIndex OBJECT-TYPE
+	SYNTAX  ClockDomainType
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the domain number used to create logical
+		group of PTP devices. The Clock Domain is a logical group of
+		clocks and devices that synchronize with each other using the
+		PTP protocol.
+		0           Default domain
+	-- 1.3.6.1.4.1.46649.1.1.1.1.1.1.1
+::= { ptpbaseSystemEntry 1 }
+ptpInstanceIndex OBJECT-TYPE
+	SYNTAX  ClockInstanceType
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the instance of the Clock for this
+		domain."
+	-- 1.3.6.1.4.1.46649.1.1.1.1.1.1.2
+::= { ptpbaseSystemEntry 2 }
+ptpDomainClockPortsTotal OBJECT-TYPE
+	SYNTAX  Gauge32
+	UNITS	"ptp ports"
+	MAX-ACCESS read-only
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the total number of clock ports
+		configured within a domain."
+	-- 1.3.6.1.4.1.46649.1.1.1.1.1.1.3
+::= { ptpbaseSystemEntry 3 }
+ptpbaseSystemDomainTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbaseSystemDomainEntry
+	STATUS  current
+	DESCRIPTION
+		"Table of information about the PTP system for all clock modes
+		-- ordinary, boundary or transparent."
+	-- 1.3.6.1.4.1.46649.1.1.1.1.2
+::= { ptpbaseMIBSystemInfo 2 }
+ptpbaseSystemDomainEntry OBJECT-TYPE
+	SYNTAX  PtpbaseSystemDomainEntry
+	STATUS  current
+	DESCRIPTION
+		"An entry in the table, containing information about a single
+		clock mode for the PTP system. A row entry gets added when PTP
+		clocks are configured on the router."
+	INDEX {
+		ptpbaseSystemDomainClockTypeIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.1.2.1
+::= { ptpbaseSystemDomainTable 1 }
+PtpbaseSystemDomainEntry ::= SEQUENCE {
+	ptpbaseSystemDomainClockTypeIndex ClockType,
+	ptpbaseSystemDomainTotals         Unsigned32 }
+ptpbaseSystemDomainClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the clock type as defined in the
+		Textual convention description."
+	-- 1.3.6.1.4.1.46649.1.1.1.1.2.1.1
+::= { ptpbaseSystemDomainEntry 1 }
+ptpbaseSystemDomainTotals OBJECT-TYPE
+	SYNTAX  Unsigned32
+	UNITS	"domains"
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the total number of PTP domains for this
+		particular clock type configured in this node."
+	-- 1.3.6.1.4.1.46649.1.1.1.1.2.1.2
+::= { ptpbaseSystemDomainEntry 2 }
+ptpbaseSystemProfile OBJECT-TYPE
+	SYNTAX  ClockProfileType
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the PTP Profile implemented on the
+		system."
+	REFERENCE
+		"Section 19.3 PTP profiles of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.1.3
+::= { ptpbaseMIBSystemInfo 3 }
+ptpbaseClockCurrentDSTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbaseClockCurrentDSEntry
+	STATUS  current
+	DESCRIPTION
+		"Table of information about the PTP clock Current Datasets for
+		all domains."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.1
+::= { ptpbaseMIBClockInfo 1 }
+ptpbaseClockCurrentDSEntry OBJECT-TYPE
+	SYNTAX  PtpbaseClockCurrentDSEntry
+	STATUS  current
+	DESCRIPTION
+		PTP clock Current Datasets for a domain."
+	REFERENCE
+		"1588 Version 2.0 Section 8.2.2 currentDS data set member
+		specifications of [IEEE 1588-2008]"
+	INDEX {
+		ptpbaseClockCurrentDSDomainIndex,
+		ptpbaseClockCurrentDSClockTypeIndex,
+		ptpbaseClockCurrentDSInstanceIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.1.1
+::= { ptpbaseClockCurrentDSTable 1 }
+PtpbaseClockCurrentDSEntry ::= SEQUENCE {
+	ptpbaseClockCurrentDSDomainIndex                 ClockDomainType,
+	ptpbaseClockCurrentDSClockTypeIndex              ClockType,
+	ptpbaseClockCurrentDSInstanceIndex               ClockInstanceType,
+	ptpbaseClockCurrentDSStepsRemoved                Unsigned32,
+	ptpbaseClockCurrentDSOffsetFromMaster            ClockTimeInterval,
+	ptpbaseClockCurrentDSMeanPathDelay               ClockTimeInterval,
+	ptpbaseClockCurrentDSOffsetFromMasterString      DisplayString,
+	ptpbaseClockCurrentDSMeanPathDelayString         DisplayString,
+	ptpbaseClockCurrentDSOffsetFromMasterThresholdNs Unsigned32 }
+ptpbaseClockCurrentDSDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		group of PTP devices."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.1.1.1
+::= { ptpbaseClockCurrentDSEntry 1 }
+ptpbaseClockCurrentDSClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.1.1.2
+::= { ptpbaseClockCurrentDSEntry 2 }
+ptpbaseClockCurrentDSInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the instance of the clock for this clock
+		type in the given domain."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.1.1.3
+::= { ptpbaseClockCurrentDSEntry 3 }
+ptpbaseClockCurrentDSStepsRemoved OBJECT-TYPE
+	SYNTAX  Unsigned32
+	UNITS	"Steps"
+	STATUS  current
+	DESCRIPTION
+		"The current clock dataset StepsRemoved value.
+		This object specifies the distance measured by the number of
+		Boundary clocks between the local clock and the Foreign master
+		as indicated in the stepsRemoved field of Announce messages."
+	REFERENCE
+		"1588 Version 2.0 Section 8.2.2.2 stepsRemoved"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.1.1.4
+::= { ptpbaseClockCurrentDSEntry 4 }
+ptpbaseClockCurrentDSOffsetFromMaster OBJECT-TYPE
+	SYNTAX  ClockTimeInterval
+	UNITS	"Time Interval"
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the current clock dataset ClockOffset
+		value. The value of the computation of the offset in time
+		between a slave and a master clock."
+	REFERENCE
+		"1588 Version 2.0 Section 8.2.2.3 of
+		[IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.1.1.5
+::= { ptpbaseClockCurrentDSEntry 5 }
+ptpbaseClockCurrentDSMeanPathDelay OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		MeanPathDelay value.
+		The mean path delay between a pair of ports as measure by the
+		delay request-response mechanism."
+	REFERENCE
+		"1588 Version 2.0 Section 8.2.2.4 mean path delay"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.1.1.6
+::= { ptpbaseClockCurrentDSEntry 6 }
+ptpbaseClockCurrentDSOffsetFromMasterString OBJECT-TYPE
+	SYNTAX  DisplayString (SIZE (1..64))
+	STATUS  current
+	DESCRIPTION
+		       between a slave and a master clock, as a text representation
+		of a floating point number."
+	REFERENCE
+		[IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.1.1.7
+::= { ptpbaseClockCurrentDSEntry 7 }
+ptpbaseClockCurrentDSMeanPathDelayString OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		       MeanPathDelay value, as a text representation
+	REFERENCE
+	-- 1.3.6.1.4.1.46649.1.1.1.2.1.1.8
+::= { ptpbaseClockCurrentDSEntry 8 }
+ptpbaseClockCurrentDSOffsetFromMasterThresholdNs OBJECT-TYPE
+	SYNTAX  Unsigned32
+	UNITS	"Nanoseconds"
+	STATUS  current
+	DESCRIPTION
+		"Offset from master alarm threshold value in nanoseconds (absolute value is checked against the threshold)."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.1.1.9
+::= { ptpbaseClockCurrentDSEntry 9 }
+ptpbaseClockParentDSTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbaseClockParentDSEntry
+	STATUS  current
+	DESCRIPTION
+		"Table of information about the PTP clock Parent Datasets for
+		all domains."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2
+::= { ptpbaseMIBClockInfo 2 }
+ptpbaseClockParentDSEntry OBJECT-TYPE
+	SYNTAX  PtpbaseClockParentDSEntry
+	STATUS  current
+	DESCRIPTION
+		PTP clock Parent Datasets for a domain."
+	REFERENCE
+		"Section 8.2.3 parentDS data set member specifications of
+		[IEEE 1588-2008]"
+	INDEX {
+		ptpbaseClockParentDSDomainIndex,
+		ptpbaseClockParentDSClockTypeIndex,
+		ptpbaseClockParentDSInstanceIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2.1
+::= { ptpbaseClockParentDSTable 1 }
+PtpbaseClockParentDSEntry ::= SEQUENCE {
+	ptpbaseClockParentDSDomainIndex            ClockDomainType,
+	ptpbaseClockParentDSClockTypeIndex         ClockType,
+	ptpbaseClockParentDSInstanceIndex          ClockInstanceType,
+	ptpbaseClockParentDSParentPortIdentity     OCTET STRING,
+	ptpbaseClockParentDSParentStats            TruthValue,
+	ptpbaseClockParentDSOffset                 ClockIntervalBase2,
+	ptpbaseClockParentDSClockPhChRate          Integer32,
+	ptpbaseClockParentDSGMClockIdentity        ClockIdentity,
+	ptpbaseClockParentDSGMClockPriority1       Unsigned32,
+	ptpbaseClockParentDSGMClockPriority2       Unsigned32,
+	ptpbaseClockParentDSGMClockQualityClass    ClockQualityClassType,
+	ptpbaseClockParentDSGMClockQualityAccuracy ClockQualityAccuracyType,
+	ptpbaseClockParentDSGMClockQualityOffset   Unsigned32,
+	ptpbaseClockParentDSParentPortAddressType  InetAddressType,
+	ptpbaseClockParentDSParentPortAddress      InetAddress }
+ptpbaseClockParentDSDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2.1.1
+::= { ptpbaseClockParentDSEntry 1 }
+ptpbaseClockParentDSClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2.1.2
+::= { ptpbaseClockParentDSEntry 2 }
+ptpbaseClockParentDSInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2.1.3
+::= { ptpbaseClockParentDSEntry 3 }
+ptpbaseClockParentDSParentPortIdentity OBJECT-TYPE
+	SYNTAX  OCTET STRING (SIZE (1..256))
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the value of portIdentity of the port on
+		the master that issues the Sync messages used in synchronizing
+		this clock."
+	REFERENCE
+		"Section 8.2.3.2 parentDS.parentPortIdentity of
+		[IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2.1.4
+::= { ptpbaseClockParentDSEntry 4 }
+ptpbaseClockParentDSParentStats OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the Parent Dataset ParentStats value.
+		This value indicates whether the values of ParentDSOffset
+		and ParentDSClockPhChRate have been measured and are valid.
+		A TRUE value shall indicate valid data."
+	REFERENCE
+		"Section 8.2.3.3 parentDS.parentStats of
+		[IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2.1.5
+::= { ptpbaseClockParentDSEntry 5 }
+ptpbaseClockParentDSOffset OBJECT-TYPE
+	SYNTAX  ClockIntervalBase2 (-128..127)
+	STATUS  current
+	DESCRIPTION
+		ParentOffsetScaledLogVariance value.
+		This value is the variance of the parent clocks phase as
+		measured by the local clock."
+	REFERENCE
+		"Section 8.2.3.4
+		parentDS.observedParentOffsetScaledLogVariance
+		[IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2.1.6
+::= { ptpbaseClockParentDSEntry 6 }
+ptpbaseClockParentDSClockPhChRate OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the clock's parent dataset
+		ParentClockPhaseChangeRate value.
+		This value is an estimate of the parent clocks phase change
+		rate as measured by the slave clock."
+	REFERENCE
+		"Section 8.2.3.5
+		parentDS.observedParentClockPhaseChangeRate of
+		[IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2.1.7
+::= { ptpbaseClockParentDSEntry 7 }
+ptpbaseClockParentDSGMClockIdentity OBJECT-TYPE
+	SYNTAX  ClockIdentity
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the parent dataset Grandmaster clock
+		identity."
+	REFERENCE
+		"Section 8.2.3.6 parentDS.grandmasterIdentity of
+		[IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2.1.8
+::= { ptpbaseClockParentDSEntry 8 }
+ptpbaseClockParentDSGMClockPriority1 OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		priority1."
+	REFERENCE
+		"Section 8.2.3.8 parentDS.grandmasterPriority1 of
+		[IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2.1.9
+::= { ptpbaseClockParentDSEntry 9 }
+ptpbaseClockParentDSGMClockPriority2 OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the parent dataset grandmaster clock
+		priority2."
+	REFERENCE
+		"Section 8.2.3.9 parentDS.grandmasterPriority2 of
+		[IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2.1.10
+::= { ptpbaseClockParentDSEntry 10 }
+ptpbaseClockParentDSGMClockQualityClass OBJECT-TYPE
+	SYNTAX  ClockQualityClassType (0..255)
+	STATUS  current
+	DESCRIPTION
+		quality class."
+	REFERENCE
+		"Section 8.2.3.7 parentDS.grandmasterClockQuality of
+		[IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2.1.11
+::= { ptpbaseClockParentDSEntry 11 }
+ptpbaseClockParentDSGMClockQualityAccuracy OBJECT-TYPE
+	SYNTAX  ClockQualityAccuracyType
+	STATUS  current
+	DESCRIPTION
+		quality accuracy."
+	REFERENCE
+		[IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2.1.12
+::= { ptpbaseClockParentDSEntry 12 }
+ptpbaseClockParentDSGMClockQualityOffset OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		quality offset."
+	REFERENCE
+		[IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2.1.13
+::= { ptpbaseClockParentDSEntry 13 }
+ptpbaseClockParentDSParentPortAddressType OBJECT-TYPE
+	SYNTAX  InetAddressType
+	STATUS  current
+	DESCRIPTION
+		"Parent port transport address type"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2.1.14
+::= { ptpbaseClockParentDSEntry 14 }
+ptpbaseClockParentDSParentPortAddress OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Parent port transport address, if available"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.2.1.15
+::= { ptpbaseClockParentDSEntry 15 }
+ptpbaseClockDefaultDSTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbaseClockDefaultDSEntry
+	STATUS  current
+	DESCRIPTION
+		"Table of information about the PTP clock Default Datasets for
+		all domains."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.3
+::= { ptpbaseMIBClockInfo 3 }
+ptpbaseClockDefaultDSEntry OBJECT-TYPE
+	SYNTAX  PtpbaseClockDefaultDSEntry
+	STATUS  current
+	DESCRIPTION
+		PTP clock Default Datasets for a domain."
+	INDEX {
+		ptpbaseClockDefaultDSDomainIndex,
+		ptpbaseClockDefaultDSClockTypeIndex,
+		ptpbaseClockDefaultDSInstanceIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.3.1
+::= { ptpbaseClockDefaultDSTable 1 }
+PtpbaseClockDefaultDSEntry ::= SEQUENCE {
+	ptpbaseClockDefaultDSDomainIndex     ClockDomainType,
+	ptpbaseClockDefaultDSClockTypeIndex  ClockType,
+	ptpbaseClockDefaultDSInstanceIndex   ClockInstanceType,
+	ptpbaseClockDefaultDSTwoStepFlag     TruthValue,
+	ptpbaseClockDefaultDSClockIdentity   ClockIdentity,
+	ptpbaseClockDefaultDSPriority1       Unsigned32,
+	ptpbaseClockDefaultDSPriority2       Unsigned32,
+	ptpbaseClockDefaultDSSlaveOnly       TruthValue,
+	ptpbaseClockDefaultDSQualityClass    ClockQualityClassType,
+	ptpbaseClockDefaultDSQualityAccuracy ClockQualityAccuracyType,
+	ptpbaseClockDefaultDSQualityOffset   Integer32,
+	ptpbaseClockDefaultDSDomainNumber    ClockDomainType }
+ptpbaseClockDefaultDSDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.3.1.1
+::= { ptpbaseClockDefaultDSEntry 1 }
+ptpbaseClockDefaultDSClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.3.1.2
+::= { ptpbaseClockDefaultDSEntry 2 }
+ptpbaseClockDefaultDSInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.3.1.3
+::= { ptpbaseClockDefaultDSEntry 3 }
+ptpbaseClockDefaultDSTwoStepFlag OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"This object specifies whether the Two Step process is used."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.3.1.4
+::= { ptpbaseClockDefaultDSEntry 4 }
+ptpbaseClockDefaultDSClockIdentity OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the default Datasets clock identity."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.3.1.5
+::= { ptpbaseClockDefaultDSEntry 5 }
+ptpbaseClockDefaultDSPriority1 OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the default Datasets clock Priority1."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.3.1.6
+::= { ptpbaseClockDefaultDSEntry 6 }
+ptpbaseClockDefaultDSPriority2 OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the default Datasets clock Priority2."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.3.1.7
+::= { ptpbaseClockDefaultDSEntry 7 }
+ptpbaseClockDefaultDSSlaveOnly OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"Whether the SlaveOnly flag is set."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.3.1.8
+::= { ptpbaseClockDefaultDSEntry 8 }
+ptpbaseClockDefaultDSQualityClass OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the default dataset Quality Class."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.3.1.9
+::= { ptpbaseClockDefaultDSEntry 9 }
+ptpbaseClockDefaultDSQualityAccuracy OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the default dataset Quality Accurarcy."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.3.1.10
+::= { ptpbaseClockDefaultDSEntry 10 }
+ptpbaseClockDefaultDSQualityOffset OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the default dataset Quality offset."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.3.1.11
+::= { ptpbaseClockDefaultDSEntry 11 }
+ptpbaseClockDefaultDSDomainNumber OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"The number of PTP domain the clock is part of."
+	REFERENCE
+		"IEEE 1588-2008 7.1, 8.2.1.1"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.3.1.12
+	::= { ptpbaseClockDefaultDSEntry 12 }
+ptpbaseClockRunningTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbaseClockRunningEntry
+	STATUS  current
+	DESCRIPTION
+		"Table of information about the PTP clock Running Datasets for
+		all domains."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.4
+::= { ptpbaseMIBClockInfo 4 }
+ptpbaseClockRunningEntry OBJECT-TYPE
+	SYNTAX  PtpbaseClockRunningEntry
+	STATUS  current
+	DESCRIPTION
+		PTP clock running Datasets for a domain."
+	INDEX {
+		ptpbaseClockRunningDomainIndex,
+		ptpbaseClockRunningClockTypeIndex,
+		ptpbaseClockRunningInstanceIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.4.1
+::= { ptpbaseClockRunningTable 1 }
+PtpbaseClockRunningEntry ::= SEQUENCE {
+	ptpbaseClockRunningDomainIndex     ClockDomainType,
+	ptpbaseClockRunningClockTypeIndex  ClockType,
+	ptpbaseClockRunningInstanceIndex   ClockInstanceType,
+	ptpbaseClockRunningState           ClockStateType,
+	ptpbaseClockRunningPacketsSent     Counter64,
+	ptpbaseClockRunningPacketsReceived Counter64 }
+ptpbaseClockRunningDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.4.1.1
+::= { ptpbaseClockRunningEntry 1 }
+ptpbaseClockRunningClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.4.1.2
+::= { ptpbaseClockRunningEntry 2 }
+ptpbaseClockRunningInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.4.1.3
+::= { ptpbaseClockRunningEntry 3 }
+ptpbaseClockRunningState OBJECT-TYPE
+	SYNTAX  ClockStateType
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the Clock state returned by PTP engine
+		which was described earlier.
+		Freerun state. Applies to a slave device that is not locked to
+		a master. This is the initial state a slave starts out with
+		when
+		it is not getting any PTP packets from the master or because of
+		some other input error (erroneous packets, etc).
+		Holdover state. In this state the slave device is locked to a
+		master but communication with the master is lost or the
+		timestamps in the ptp packets are incorrect. But since the
+		slave was locked to the master, it can run with the same
+		accuracy for
+		sometime. The slave can continue to operate in this state for
+		some time. If communication with the master is not restored for
+		a while, the device is moved to the FREERUN state.
+		Acquiring state. The slave device is receiving packets from a
+		master and is trying to acquire a lock.
+		Freq_locked state. Slave device is locked to the Master with
+		respect to frequency, but not phase aligned
+		Phase_aligned state. Locked to the master with respect to
+	-- 1.3.6.1.4.1.46649.1.1.1.2.4.1.4
+::= { ptpbaseClockRunningEntry 4 }
+ptpbaseClockRunningPacketsSent OBJECT-TYPE
+	SYNTAX  Counter64
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the total number of all packet Unicast
+		and multicast that have been sent out for this clock in this
+		domain for this type."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.4.1.5
+::= { ptpbaseClockRunningEntry 5 }
+ptpbaseClockRunningPacketsReceived OBJECT-TYPE
+	SYNTAX  Counter64
+	STATUS  current
+	DESCRIPTION
+		and multicast that have been received for this clock in this
+	-- 1.3.6.1.4.1.46649.1.1.1.2.4.1.6
+::= { ptpbaseClockRunningEntry 6 }
+ptpbaseClockTimePropertiesDSTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbaseClockTimePropertiesDSEntry
+	STATUS  current
+	DESCRIPTION
+		"Table of information about the PTP clock Timeproperties
+		Datasets for all domains."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.5
+::= { ptpbaseMIBClockInfo 5 }
+ptpbaseClockTimePropertiesDSEntry OBJECT-TYPE
+	SYNTAX  PtpbaseClockTimePropertiesDSEntry
+	STATUS  current
+	DESCRIPTION
+		PTP clock timeproperties Datasets for a domain."
+	REFERENCE
+		"Section 8.2.4 of [IEEE 1588-2008]"
+	INDEX {
+		ptpbaseClockTimePropertiesDSDomainIndex,
+		ptpbaseClockTimePropertiesDSClockTypeIndex,
+		ptpbaseClockTimePropertiesDSInstanceIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.5.1
+::= { ptpbaseClockTimePropertiesDSTable 1 }
+PtpbaseClockTimePropertiesDSEntry ::= SEQUENCE {
+	ptpbaseClockTimePropertiesDSDomainIndex           ClockDomainType,
+	ptpbaseClockTimePropertiesDSClockTypeIndex        ClockType,
+	ptpbaseClockTimePropertiesDSInstanceIndex         ClockInstanceType,
+	ptpbaseClockTimePropertiesDSCurrentUTCOffsetValid TruthValue,
+	ptpbaseClockTimePropertiesDSCurrentUTCOffset      Integer32,
+	ptpbaseClockTimePropertiesDSLeap59                TruthValue,
+	ptpbaseClockTimePropertiesDSLeap61                TruthValue,
+	ptpbaseClockTimePropertiesDSTimeTraceable         TruthValue,
+	ptpbaseClockTimePropertiesDSFreqTraceable         TruthValue,
+	ptpbaseClockTimePropertiesDSPTPTimescale          TruthValue,
+	ptpbaseClockTimePropertiesDSSource                ClockTimeSourceType }
+ptpbaseClockTimePropertiesDSDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.5.1.1
+::= { ptpbaseClockTimePropertiesDSEntry 1 }
+ptpbaseClockTimePropertiesDSClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.5.1.2
+::= { ptpbaseClockTimePropertiesDSEntry 2 }
+ptpbaseClockTimePropertiesDSInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.5.1.3
+::= { ptpbaseClockTimePropertiesDSEntry 3 }
+ptpbaseClockTimePropertiesDSCurrentUTCOffsetValid OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the timeproperties dataset value of
+		whether current UTC offset is valid."
+	REFERENCE
+		"Section 8.2.4.2 of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.5.1.4
+::= { ptpbaseClockTimePropertiesDSEntry 4 }
+ptpbaseClockTimePropertiesDSCurrentUTCOffset OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		current UTC offset.
+		In PTP systems whose epoch is the PTP epoch, the value of
+		timePropertiesDS.currentUtcOffset is the offset
+		between TAI and UTC; otherwise the value has no meaning. The
+		value shall be in units of seconds.
+		The initialization value shall be selected as follows:
+		a) If the timePropertiesDS.ptpTimescale (see 8.2.4.8) is TRUE,
+		the value is the value obtained from a
+		primary reference if the value is known at the time of
+		initialization, else.
+		b) The value shall be the current number of leap seconds (7.2.3)
+		when the node is designed."
+	REFERENCE
+		"Section 8.2.4.3 of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.5.1.5
+::= { ptpbaseClockTimePropertiesDSEntry 5 }
+ptpbaseClockTimePropertiesDSLeap59 OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the Leap59 value in the clock Current
+		Dataset."
+	REFERENCE
+		"Section 8.2.4.4 of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.5.1.6
+::= { ptpbaseClockTimePropertiesDSEntry 6 }
+ptpbaseClockTimePropertiesDSLeap61 OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the Leap61 value in the clock Current
+		Dataset."
+	REFERENCE
+		"Section 8.2.4.5 of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.5.1.7
+::= { ptpbaseClockTimePropertiesDSEntry 7 }
+ptpbaseClockTimePropertiesDSTimeTraceable OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the Timetraceable value in the clock
+		Current Dataset."
+	REFERENCE
+		"Section 8.2.4.6 of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.5.1.8
+::= { ptpbaseClockTimePropertiesDSEntry 8 }
+ptpbaseClockTimePropertiesDSFreqTraceable OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the Frequency Traceable value in the
+		clock Current Dataset."
+	REFERENCE
+		"Section 8.2.4.7 of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.5.1.9
+::= { ptpbaseClockTimePropertiesDSEntry 9 }
+ptpbaseClockTimePropertiesDSPTPTimescale OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the PTP Timescale value in the clock
+		Current Dataset."
+	REFERENCE
+		"Section 8.2.4.8 of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.5.1.10
+::= { ptpbaseClockTimePropertiesDSEntry 10 }
+ptpbaseClockTimePropertiesDSSource OBJECT-TYPE
+	SYNTAX  ClockTimeSourceType
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the Timesource value in the clock Current
+		Dataset."
+	REFERENCE
+		"Section 8.2.4.9 of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.5.1.11
+::= { ptpbaseClockTimePropertiesDSEntry 11 }
+ptpbaseClockTransDefaultDSTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbaseClockTransDefaultDSEntry
+	STATUS  current
+	DESCRIPTION
+		"Table of information about the PTP Transparent clock Default
+	-- 1.3.6.1.4.1.46649.1.1.1.2.6
+::= { ptpbaseMIBClockInfo 6 }
+ptpbaseClockTransDefaultDSEntry OBJECT-TYPE
+	SYNTAX  PtpbaseClockTransDefaultDSEntry
+	STATUS  current
+	DESCRIPTION
+		PTP Transparent clock Default Datasets for a domain."
+	REFERENCE
+		"Section 8.3.2 of [IEEE 1588-2008]"
+	INDEX {
+		ptpbaseClockTransDefaultDSDomainIndex,
+		ptpbaseClockTransDefaultDSInstanceIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.6.1
+::= { ptpbaseClockTransDefaultDSTable 1 }
+PtpbaseClockTransDefaultDSEntry ::= SEQUENCE {
+	ptpbaseClockTransDefaultDSDomainIndex   ClockDomainType,
+	ptpbaseClockTransDefaultDSInstanceIndex ClockInstanceType,
+	ptpbaseClockTransDefaultDSClockIdentity ClockIdentity,
+	ptpbaseClockTransDefaultDSNumOfPorts    Counter32,
+	ptpbaseClockTransDefaultDSDelay         ClockMechanismType,
+	ptpbaseClockTransDefaultDSPrimaryDomain Integer32 }
+ptpbaseClockTransDefaultDSDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.6.1.1
+::= { ptpbaseClockTransDefaultDSEntry 1 }
+ptpbaseClockTransDefaultDSInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.6.1.2
+::= { ptpbaseClockTransDefaultDSEntry 2 }
+ptpbaseClockTransDefaultDSClockIdentity OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the value of the clockIdentity attribute
+		of the local clock."
+	REFERENCE
+		"Section 8.3.2.2.1 of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.6.1.3
+::= { ptpbaseClockTransDefaultDSEntry 3 }
+ptpbaseClockTransDefaultDSNumOfPorts OBJECT-TYPE
+	SYNTAX  Counter32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the number of PTP ports of the device."
+	REFERENCE
+		"Section 8.3.2.2.2 of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.6.1.4
+::= { ptpbaseClockTransDefaultDSEntry 4 }
+ptpbaseClockTransDefaultDSDelay OBJECT-TYPE
+	SYNTAX  ClockMechanismType
+	STATUS  current
+	DESCRIPTION
+		"This object, if the transparent clock is an end-to-end
+		transparent clock, has the value shall be E2E; If the
+		transparent clock is a peer-to-peer transparent clock, the
+		value
+		shall be P2P."
+	REFERENCE
+		"Section 8.3.2.3.1 of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.6.1.5
+::= { ptpbaseClockTransDefaultDSEntry 5 }
+ptpbaseClockTransDefaultDSPrimaryDomain OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the value of the primary syntonization
+		domain. The initialization value shall be 0."
+	REFERENCE
+		"Section 8.3.2.3.2 of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.6.1.6
+::= { ptpbaseClockTransDefaultDSEntry 6 }
+ptpbaseClockPortTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbaseClockPortEntry
+	STATUS  current
+	DESCRIPTION
+		"Table of information about the clock ports for a particular
+		domain."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.7
+::= { ptpbaseMIBClockInfo 7 }
+ptpbaseClockPortEntry OBJECT-TYPE
+	SYNTAX  PtpbaseClockPortEntry
+	STATUS  current
+	DESCRIPTION
+		clock port."
+	INDEX {
+		ptpbaseClockPortDomainIndex,
+		ptpbaseClockPortClockTypeIndex,
+		ptpbaseClockPortClockInstanceIndex,
+		ptpbaseClockPortTablePortNumberIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.7.1
+::= { ptpbaseClockPortTable 1 }
+PtpbaseClockPortEntry ::= SEQUENCE {
+	ptpbaseClockPortDomainIndex            ClockDomainType,
+	ptpbaseClockPortClockTypeIndex         ClockType,
+	ptpbaseClockPortClockInstanceIndex     ClockInstanceType,
+	ptpbaseClockPortTablePortNumberIndex   ClockPortNumber,
+	ptpbaseClockPortName                   DisplayString,
+	ptpbaseClockPortRole                   ClockRoleType,
+	ptpbaseClockPortSyncOneStep            TruthValue,
+	ptpbaseClockPortCurrentPeerAddressType InetAddressType,
+	ptpbaseClockPortCurrentPeerAddress     InetAddress,
+	ptpbaseClockPortNumOfAssociatedPorts   Gauge32 }
+ptpbaseClockPortDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.7.1.1
+::= { ptpbaseClockPortEntry 1 }
+ptpbaseClockPortClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.7.1.2
+::= { ptpbaseClockPortEntry 2 }
+ptpbaseClockPortClockInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.7.1.3
+::= { ptpbaseClockPortEntry 3 }
+ptpbaseClockPortTablePortNumberIndex OBJECT-TYPE
+	SYNTAX  ClockPortNumber (1..65535)
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the PTP Portnumber for this port."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.7.1.4
+::= { ptpbaseClockPortEntry 4 }
+ptpbaseClockPortName OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the PTP clock port name configured on the
+		router."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.7.1.5
+::= { ptpbaseClockPortEntry 5 }
+ptpbaseClockPortRole OBJECT-TYPE
+	SYNTAX  ClockRoleType
+	STATUS  current
+	DESCRIPTION
+		"This object describes the current role (slave/master) of the
+		port."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.7.1.6
+::= { ptpbaseClockPortEntry 6 }
+ptpbaseClockPortSyncOneStep OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"This object specifies that one-step clock operation between
+		the PTP master and slave device is enabled."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.7.1.7
+::= { ptpbaseClockPortEntry 7 }
+ptpbaseClockPortCurrentPeerAddressType OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the current peer's network address used
+		for PTP communication. Based on the scenario and the setup
+		involved, the values might look like these -
+		Scenario                   Value
+		Single Master          master port
+		Multiple Masters       selected master port
+		Single Slave           slave port
+		Multiple Slaves        <empty>
+		(In relevant setups, information on available
+		slaves and available masters will be available through
+		ptpClockPortAssociateTable)"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.7.1.8
+::= { ptpbaseClockPortEntry 8 }
+ptpbaseClockPortCurrentPeerAddress OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		Scenario                   Value
+	-- 1.3.6.1.4.1.46649.1.1.1.2.7.1.9
+::= { ptpbaseClockPortEntry 9 }
+ptpbaseClockPortNumOfAssociatedPorts OBJECT-TYPE
+	SYNTAX  Gauge32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies -
+		For a master port - the number of PTP slave sessions (peers)
+		associated with this PTP port.
+		For a slave port - the number of masters available to this slave
+		port (might or might not be peered)."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.7.1.10
+::= { ptpbaseClockPortEntry 10 }
+ptpbaseClockPortDSTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbaseClockPortDSEntry
+	STATUS  current
+	DESCRIPTION
+		"Table of information about the clock ports dataset for a
+		particular domain."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8
+::= { ptpbaseMIBClockInfo 8 }
+ptpbaseClockPortDSEntry OBJECT-TYPE
+	SYNTAX  PtpbaseClockPortDSEntry
+	STATUS  current
+	DESCRIPTION
+		"An entry in the table, containing port dataset information for
+		a single clock port."
+	INDEX {
+		ptpbaseClockPortDSDomainIndex,
+		ptpbaseClockPortDSClockTypeIndex,
+		ptpbaseClockPortDSClockInstanceIndex,
+		ptpbaseClockPortDSPortNumberIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1
+::= { ptpbaseClockPortDSTable 1 }
+PtpbaseClockPortDSEntry ::= SEQUENCE {
+	ptpbaseClockPortDSDomainIndex          ClockDomainType,
+	ptpbaseClockPortDSClockTypeIndex       ClockType,
+	ptpbaseClockPortDSClockInstanceIndex   ClockInstanceType,
+	ptpbaseClockPortDSPortNumberIndex      ClockPortNumber,
+	ptpbaseClockPortDSName                 DisplayString,
+	ptpbaseClockPortDSPortIdentity         OCTET STRING,
+	ptpbaseClockPortDSAnnouncementInterval Integer32,
+	ptpbaseClockPortDSAnnounceRctTimeout   Integer32,
+	ptpbaseClockPortDSSyncInterval         Integer32,
+	ptpbaseClockPortDSMinDelayReqInterval  Integer32,
+	ptpbaseClockPortDSPeerDelayReqInterval Integer32,
+	ptpbaseClockPortDSDelayMech            ClockMechanismType,
+	ptpbaseClockPortDSPeerMeanPathDelay    ClockTimeInterval,
+	ptpbaseClockPortDSGrantDuration        Unsigned32,
+	ptpbaseClockPortDSPTPVersion           Integer32,
+	ptpBaseClockPortDSPeerMeanPathDelayString DisplayString,
+	ptpBaseClockPortDSLastMismatchedDomain Integer32
+ptpbaseClockPortDSDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.1
+::= { ptpbaseClockPortDSEntry 1 }
+ptpbaseClockPortDSClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.2
+::= { ptpbaseClockPortDSEntry 2 }
+ptpbaseClockPortDSClockInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.3
+::= { ptpbaseClockPortDSEntry 3 }
+ptpbaseClockPortDSPortNumberIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the PTP portnumber associated with this
+		PTP port."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.4
+::= { ptpbaseClockPortDSEntry 4 }
+ptpbaseClockPortDSName OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the PTP clock port name."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.5
+::= { ptpbaseClockPortDSEntry 5 }
+ptpbaseClockPortDSPortIdentity OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the PTP clock port Identity."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.6
+::= { ptpbaseClockPortDSEntry 6 }
+ptpbaseClockPortDSAnnouncementInterval OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the Announce message transmission
+		interval associated with this clock port."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.7
+::= { ptpbaseClockPortDSEntry 7 }
+ptpbaseClockPortDSAnnounceRctTimeout OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the Announce receipt timeout associated
+		with this clock port."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.8
+::= { ptpbaseClockPortDSEntry 8 }
+ptpbaseClockPortDSSyncInterval OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the Sync message transmission interval."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.9
+::= { ptpbaseClockPortDSEntry 9 }
+ptpbaseClockPortDSMinDelayReqInterval OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the Delay_Req message transmission
+		interval."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.10
+::= { ptpbaseClockPortDSEntry 10 }
+ptpbaseClockPortDSPeerDelayReqInterval OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the Pdelay_Req message transmission
+		interval."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.11
+::= { ptpbaseClockPortDSEntry 11 }
+ptpbaseClockPortDSDelayMech OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the delay mechanism used. If the clock
+		is an end-to-end clock, the value of the is e2e, else if the
+		clock is a peer to-peer clock, the value shall be p2p."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.12
+::= { ptpbaseClockPortDSEntry 12 }
+ptpbaseClockPortDSPeerMeanPathDelay OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the peer meanPathDelay."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.13
+::= { ptpbaseClockPortDSEntry 13 }
+ptpbaseClockPortDSGrantDuration OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the grant duration allocated by the
+		master."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.14
+::= { ptpbaseClockPortDSEntry 14 }
+ptpbaseClockPortDSPTPVersion OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the PTP version being used."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.15
+::= { ptpbaseClockPortDSEntry 15 }
+ptpBaseClockPortDSPeerMeanPathDelayString OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Current value of Peer Mean Path Delay, presented as text."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.16
+::= { ptpbaseClockPortDSEntry 16 }
+ptpBaseClockPortDSLastMismatchedDomain OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"PTP domain number of last mismatched domain (-1 = no mismatch)."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.8.1.17
+::= { ptpbaseClockPortDSEntry 17 }
+ptpbaseClockPortRunningTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbaseClockPortRunningEntry
+	STATUS  current
+	DESCRIPTION
+		"Table of information about the clock ports running dataset for
+		a particular domain."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.9
+::= { ptpbaseMIBClockInfo 9 }
+ptpbaseClockPortRunningEntry OBJECT-TYPE
+	SYNTAX  PtpbaseClockPortRunningEntry
+	STATUS  current
+	DESCRIPTION
+		"An entry in the table, containing runing dataset information
+		about a single clock port."
+	INDEX {
+		ptpbaseClockPortRunningDomainIndex,
+		ptpbaseClockPortRunningClockTypeIndex,
+		ptpbaseClockPortRunningClockInstanceIndex,
+		ptpbaseClockPortRunningPortNumberIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.9.1
+::= { ptpbaseClockPortRunningTable 1 }
+PtpbaseClockPortRunningEntry ::= SEQUENCE {
+	ptpbaseClockPortRunningDomainIndex        ClockDomainType,
+	ptpbaseClockPortRunningClockTypeIndex     ClockType,
+	ptpbaseClockPortRunningClockInstanceIndex ClockInstanceType,
+	ptpbaseClockPortRunningPortNumberIndex    ClockPortNumber,
+	ptpbaseClockPortRunningName               DisplayString,
+	ptpbaseClockPortRunningState              ClockPortState,
+	ptpbaseClockPortRunningRole               ClockRoleType,
+	ptpbaseClockPortRunningInterfaceIndex     InterfaceIndexOrZero,
+	ptpbaseClockPortRunningIPversion          Integer32,
+	ptpbaseClockPortRunningEncapsulationType  Integer32,
+	ptpbaseClockPortRunningTxMode             ClockTxModeType,
+	ptpbaseClockPortRunningRxMode             ClockTxModeType,
+	ptpbaseClockPortRunningPacketsReceived    Counter64,
+	ptpbaseClockPortRunningPacketsSent        Counter64 }
+ptpbaseClockPortRunningDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.9.1.1
+::= { ptpbaseClockPortRunningEntry 1 }
+ptpbaseClockPortRunningClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.9.1.2
+::= { ptpbaseClockPortRunningEntry 2 }
+ptpbaseClockPortRunningClockInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.9.1.3
+::= { ptpbaseClockPortRunningEntry 3 }
+ptpbaseClockPortRunningPortNumberIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		clock port."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.9.1.4
+::= { ptpbaseClockPortRunningEntry 4 }
+ptpbaseClockPortRunningName OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.9.1.5
+::= { ptpbaseClockPortRunningEntry 5 }
+ptpbaseClockPortRunningState OBJECT-TYPE
+	SYNTAX  ClockPortState
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the port state returned by PTP engine.
+		initializing - In this state a port initializes
+		faulty       - The fault state of the protocol.
+		disabled     - The port shall not place any
+		listening    - The port is waiting for the
+		               a master.
+		preMaster    - The port shall behave in all respects
+		master       - The port is behaving as a master port.
+		passive      - The port shall not place any
+		               that are a required response to
+		               another management message
+		uncalibrated - The local port is preparing to
+		slave        - The port is synchronizing to the
+	-- 1.3.6.1.4.1.46649.1.1.1.2.9.1.6
+::= { ptpbaseClockPortRunningEntry 6 }
+ptpbaseClockPortRunningRole OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the Clock Role."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.9.1.7
+::= { ptpbaseClockPortRunningEntry 7 }
+ptpbaseClockPortRunningInterfaceIndex OBJECT-TYPE
+	SYNTAX  InterfaceIndexOrZero
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the interface on the router being used by
+		the PTP Clock for PTP communication."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.9.1.8
+::= { ptpbaseClockPortRunningEntry 8 }
+ptpbaseClockPortRunningIPversion OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the IP version being used for PTP
+		communication (the mapping used)."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.9.1.9
+::= { ptpbaseClockPortRunningEntry 9 }
+ptpbaseClockPortRunningEncapsulationType OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the type of encapsulation if the
+		interface is adding extra layers (eg. VLAN, Pseudowire
+		encapsulation...) for the PTP messages."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.9.1.10
+::= { ptpbaseClockPortRunningEntry 10 }
+ptpbaseClockPortRunningTxMode OBJECT-TYPE
+	SYNTAX  ClockTxModeType
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the clock transmission mode as
+		unicast:       Using unicast communication channel.
+		multicast:     Using Multicast communication channel.
+		multicast-mix: Using multicast-unicast communication channel"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.9.1.11
+::= { ptpbaseClockPortRunningEntry 11 }
+ptpbaseClockPortRunningRxMode OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifie the clock receive mode as
+	-- 1.3.6.1.4.1.46649.1.1.1.2.9.1.12
+::= { ptpbaseClockPortRunningEntry 12 }
+ptpbaseClockPortRunningPacketsReceived OBJECT-TYPE
+	SYNTAX  Counter64
+	UNITS	"packets"
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the packets received on the clock port
+		(cummulative)."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.9.1.13
+::= { ptpbaseClockPortRunningEntry 13 }
+ptpbaseClockPortRunningPacketsSent OBJECT-TYPE
+	SYNTAX  Counter64
+	UNITS	"packets"
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the packets sent on the clock port
+		(cummulative)."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.9.1.14
+::= { ptpbaseClockPortRunningEntry 14 }
+ptpbaseClockPortTransDSTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbaseClockPortTransDSEntry
+	STATUS  current
+	DESCRIPTION
+		"Table of information about the Transparent clock ports running
+		dataset for a particular domain."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.10
+::= { ptpbaseMIBClockInfo 10 }
+ptpbaseClockPortTransDSEntry OBJECT-TYPE
+	SYNTAX  PtpbaseClockPortTransDSEntry
+	STATUS  current
+	DESCRIPTION
+		"An entry in the table, containing clock port Transparent
+		dataset information about a single clock port"
+	INDEX {
+		ptpbaseClockPortTransDSDomainIndex,
+		ptpbaseClockPortTransDSInstanceIndex,
+		ptpbaseClockPortTransDSPortNumberIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.10.1
+::= { ptpbaseClockPortTransDSTable 1 }
+PtpbaseClockPortTransDSEntry ::= SEQUENCE {
+	ptpbaseClockPortTransDSDomainIndex        ClockDomainType,
+	ptpbaseClockPortTransDSInstanceIndex      ClockInstanceType,
+	ptpbaseClockPortTransDSPortNumberIndex    ClockPortNumber,
+	ptpbaseClockPortTransDSPortIdentity       ClockIdentity,
+	ptpbaseClockPortTransDSlogMinPdelayReqInt Integer32,
+	ptpbaseClockPortTransDSFaultyFlag         TruthValue,
+	ptpbaseClockPortTransDSPeerMeanPathDelay  ClockTimeInterval }
+ptpbaseClockPortTransDSDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.10.1.1
+::= { ptpbaseClockPortTransDSEntry 1 }
+ptpbaseClockPortTransDSInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.10.1.2
+::= { ptpbaseClockPortTransDSEntry 2 }
+ptpbaseClockPortTransDSPortNumberIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the PTP port number associated with this
+		port."
+	REFERENCE
+		"Section 7.5.2 Port Identity [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.10.1.3
+::= { ptpbaseClockPortTransDSEntry 3 }
+ptpbaseClockPortTransDSPortIdentity OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the value of the PortIdentity
+		attribute of the local port."
+	REFERENCE
+		"Section 8.3.3.2.1 of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.10.1.4
+::= { ptpbaseClockPortTransDSEntry 4 }
+ptpbaseClockPortTransDSlogMinPdelayReqInt OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the value of the logarithm to the
+		base 2 of the minPdelayReqInterval."
+	REFERENCE
+		"Section 8.3.3.3.1 of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.10.1.5
+::= { ptpbaseClockPortTransDSEntry 5 }
+ptpbaseClockPortTransDSFaultyFlag OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the value TRUE if the port is faulty
+		and FALSE if the port is operating normally."
+	REFERENCE
+		"Section 8.3.3.3.2 of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.10.1.6
+::= { ptpbaseClockPortTransDSEntry 6 }
+ptpbaseClockPortTransDSPeerMeanPathDelay OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies, (if the delayMechanism used is P2P) the
+		value is the estimate of the current one-way propagation delay,
+		i.e., <meanPathDelay> on the link attached to this port
+		computed
+		using the peer delay mechanism. If the value of the
+		delayMechanism
+		used is E2E, then the value will be zero."
+	REFERENCE
+		"Section 8.3.3.3.3 of [IEEE 1588-2008]"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.10.1.7
+::= { ptpbaseClockPortTransDSEntry 7 }
+ptpbaseClockPortAssociateTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbaseClockPortAssociateEntry
+	STATUS  current
+	DESCRIPTION
+		"Table of information about a given port's associated ports.
+		For a master port - multiple slave ports which have established
+		sessions with the current master port.
+		For a slave port - the list of masters available for a given
+		slave port.
+		Session information (pkts, errors) to be displayed based on
+		availability and scenario."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.11
+::= { ptpbaseMIBClockInfo 11 }
+ptpbaseClockPortAssociateEntry OBJECT-TYPE
+	SYNTAX  PtpbaseClockPortAssociateEntry
+	STATUS  current
+	DESCRIPTION
+		associated port for the given clockport."
+	INDEX {
+		ptpClockPortCurrentDomainIndex,
+		ptpClockPortCurrentClockTypeIndex,
+		ptpClockPortCurrentClockInstanceIndex,
+		ptpClockPortCurrentPortNumberIndex,
+		ptpbaseClockPortAssociatePortIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.11.1
+::= { ptpbaseClockPortAssociateTable 1 }
+PtpbaseClockPortAssociateEntry ::= SEQUENCE {
+	ptpClockPortCurrentDomainIndex           ClockDomainType,
+	ptpClockPortCurrentClockTypeIndex        ClockType,
+	ptpClockPortCurrentClockInstanceIndex    ClockInstanceType,
+	ptpClockPortCurrentPortNumberIndex       ClockPortNumber,
+	ptpbaseClockPortAssociatePortIndex       Unsigned32,
+	ptpbaseClockPortAssociateAddressType     InetAddressType,
+	ptpbaseClockPortAssociateAddress         InetAddress,
+	ptpbaseClockPortAssociatePacketsSent     Counter64,
+	ptpbaseClockPortAssociatePacketsReceived Counter64,
+	ptpbaseClockPortAssociateInErrors        Counter64,
+	ptpbaseClockPortAssociateOutErrors       Counter64 }
+ptpClockPortCurrentDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the given port's domain number."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.11.1.1
+::= { ptpbaseClockPortAssociateEntry 1 }
+ptpClockPortCurrentClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the given port's clock type."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.11.1.2
+::= { ptpbaseClockPortAssociateEntry 2 }
+ptpClockPortCurrentClockInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.11.1.3
+::= { ptpbaseClockPortAssociateEntry 3 }
+ptpClockPortCurrentPortNumberIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the PTP Port Number for the given port."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.11.1.4
+::= { ptpbaseClockPortAssociateEntry 4 }
+ptpbaseClockPortAssociatePortIndex OBJECT-TYPE
+	SYNTAX  Unsigned32 (1..65535)
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the associated port's serial number in
+		the current port's context."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.11.1.5
+::= { ptpbaseClockPortAssociateEntry 5 }
+ptpbaseClockPortAssociateAddressType OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the peer port's network address type used
+		for PTP communication."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.11.1.6
+::= { ptpbaseClockPortAssociateEntry 6 }
+ptpbaseClockPortAssociateAddress OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the peer port's network address used for
+		PTP communication."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.11.1.7
+::= { ptpbaseClockPortAssociateEntry 7 }
+ptpbaseClockPortAssociatePacketsSent OBJECT-TYPE
+	SYNTAX  Counter64
+	UNITS	"packets"
+	STATUS  current
+	DESCRIPTION
+		"The number of packets sent to this peer port from the current
+		port."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.11.1.8
+::= { ptpbaseClockPortAssociateEntry 8 }
+ptpbaseClockPortAssociatePacketsReceived OBJECT-TYPE
+	SYNTAX  Counter64
+	UNITS	"packets"
+	STATUS  current
+	DESCRIPTION
+		"The number of packets received from this peer port by the
+		current port."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.11.1.9
+::= { ptpbaseClockPortAssociateEntry 9 }
+ptpbaseClockPortAssociateInErrors OBJECT-TYPE
+	SYNTAX  Counter64
+	UNITS	"packets"
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the input errors associated with the
+		peer port."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.11.1.10
+::= { ptpbaseClockPortAssociateEntry 10 }
+ptpbaseClockPortAssociateOutErrors OBJECT-TYPE
+	SYNTAX  Counter64
+	UNITS	"packets"
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the output errors associated with the
+		peer port."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.11.1.11
+::= { ptpbaseClockPortAssociateEntry 11 }
+ptpbasePtpPortMessageCountersTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbasePtpPortMessageCountersEntry
+	STATUS  current
+	DESCRIPTION
+		"Table describing counters for sent and received messages of different types for a given port."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12
+::= { ptpbaseMIBClockInfo 12 }
+ptpbasePtpPortMessageCountersEntry OBJECT-TYPE
+	SYNTAX  PtpbasePtpPortMessageCountersEntry
+	STATUS  current
+	DESCRIPTION
+		"An entry in a table describing counters for sent and received messages of different types for a given port."
+	INDEX {
+		ptpbasePortMessageCountersDomainIndex,
+		ptpbasePortMessageCountersClockTypeIndex,
+		ptpbasePortMessageCountersInstanceIndex,
+		ptpbasePortMessageCountersClockPortNumberIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1
+::= { ptpbasePtpPortMessageCountersTable 1 }
+PtpbasePtpPortMessageCountersEntry ::= SEQUENCE {
+	ptpbasePortMessageCountersDomainIndex          ClockDomainType,
+	ptpbasePortMessageCountersClockTypeIndex       ClockType,
+	ptpbasePortMessageCountersInstanceIndex        ClockInstanceType,
+	ptpbasePortMessageCountersClockPortNumberIndex ClockPortNumber,
+	ptpbasePortMessageCountersClearAll             TruthValue,
+	ptpbasePortMessageCountersClear                TruthValue,
+	totalMessagesSent                              Unsigned32,
+	totalMessagesReceived                          Unsigned32,
+	announceMessagesSent                           Unsigned32,
+	announceMessagesReceived                       Unsigned32,
+	syncMessagesSent                               Unsigned32,
+	syncMessagesReceived                           Unsigned32,
+	followUpMessagesSent                           Unsigned32,
+	followUpMessagesReceived                       Unsigned32,
+	delayReqMessagesSent                           Unsigned32,
+	delayReqMessagesReceived                       Unsigned32,
+	delayRespMessagesSent                          Unsigned32,
+	delayRespMessagesReceived                      Unsigned32,
+	pdelayReqMessagesSent                          Unsigned32,
+	pdelayReqMessagesReceived                      Unsigned32,
+	pdelayRespMessagesSent                         Unsigned32,
+	pdelayRespMessagesReceived                     Unsigned32,
+	pdelayRespFollowUpMessagesSent                 Unsigned32,
+	pdelayRespFollowUpMessagesReceived             Unsigned32,
+	signalingMessagesSent                          Unsigned32,
+	signalingMessagesReceived                      Unsigned32,
+	managementMessagesSent                         Unsigned32,
+	managementMessagesReceived                     Unsigned32,
+	discardedMessages                              Unsigned32,
+	unknownMessages                                Unsigned32 }
+ptpbasePortMessageCountersDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.1
+::= { ptpbasePtpPortMessageCountersEntry 1 }
+ptpbasePortMessageCountersClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.2
+::= { ptpbasePtpPortMessageCountersEntry 2 }
+ptpbasePortMessageCountersInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.3
+::= { ptpbasePtpPortMessageCountersEntry 3 }
+ptpbasePortMessageCountersClockPortNumberIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION ""
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.4
+::= { ptpbasePtpPortMessageCountersEntry 4 }
+ptpbasePortMessageCountersClearAll OBJECT-TYPE
+	SYNTAX  TruthValue
+	MAX-ACCESS read-write
+	STATUS  current
+	DESCRIPTION
+		"Handle allowing to clear all PTP counters"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.5
+::= { ptpbasePtpPortMessageCountersEntry 5 }
+ptpbasePortMessageCountersClear OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"Handle allowing to clear PTP message counters"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.6
+::= { ptpbasePtpPortMessageCountersEntry 6 }
+totalMessagesSent OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"total number of messages sent by PTP port"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.7
+::= { ptpbasePtpPortMessageCountersEntry 7 }
+totalMessagesReceived OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Total number of messages received by PTP port"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.8
+::= { ptpbasePtpPortMessageCountersEntry 8 }
+announceMessagesSent OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of sent Announce messages"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.9
+::= { ptpbasePtpPortMessageCountersEntry 9 }
+announceMessagesReceived OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of Announce messages received"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.10
+::= { ptpbasePtpPortMessageCountersEntry 10 }
+syncMessagesSent OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of sent Sync messages."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.11
+::= { ptpbasePtpPortMessageCountersEntry 11 }
+syncMessagesReceived OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of Sync messages sent"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.12
+::= { ptpbasePtpPortMessageCountersEntry 12 }
+followUpMessagesSent OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of FollowUp messages sent (two-step operation)"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.13
+::= { ptpbasePtpPortMessageCountersEntry 13 }
+followUpMessagesReceived OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of received FollowUp messages (two-step operation)"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.14
+::= { ptpbasePtpPortMessageCountersEntry 14 }
+delayReqMessagesSent OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of sent Delay Request messages"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.15
+::= { ptpbasePtpPortMessageCountersEntry 15 }
+delayReqMessagesReceived OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of Delay Request messages received"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.16
+::= { ptpbasePtpPortMessageCountersEntry 16 }
+delayRespMessagesSent OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of sent Delay Response messages"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.17
+::= { ptpbasePtpPortMessageCountersEntry 17 }
+delayRespMessagesReceived OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of Delay Response messages received"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.18
+::= { ptpbasePtpPortMessageCountersEntry 18 }
+pdelayReqMessagesSent OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of sent Peer Delay Request messages (P2P operation)"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.19
+::= { ptpbasePtpPortMessageCountersEntry 19 }
+pdelayReqMessagesReceived OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of Peer Delay Request messages received"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.20
+::= { ptpbasePtpPortMessageCountersEntry 20 }
+pdelayRespMessagesSent OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of sent Peer Delay Response messages"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.21
+::= { ptpbasePtpPortMessageCountersEntry 21 }
+pdelayRespMessagesReceived OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of Peer Delay Response messages received"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.22
+::= { ptpbasePtpPortMessageCountersEntry 22 }
+pdelayRespFollowUpMessagesSent OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of Peer Delay Response FollowUp messages sent (two-step operation)"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.23
+::= { ptpbasePtpPortMessageCountersEntry 23 }
+pdelayRespFollowUpMessagesReceived OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of received Peer Delay Response Follow-Up messages"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.24
+::= { ptpbasePtpPortMessageCountersEntry 24 }
+signalingMessagesSent OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of sent Signaling messages (unicast negotiation)"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.25
+::= { ptpbasePtpPortMessageCountersEntry 25 }
+signalingMessagesReceived OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of received Signaling messages (unicast negotiation)"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.26
+::= { ptpbasePtpPortMessageCountersEntry 26 }
+managementMessagesSent OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of sent Management messages"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.27
+::= { ptpbasePtpPortMessageCountersEntry 27 }
+managementMessagesReceived OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of Management messages received"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.28
+::= { ptpbasePtpPortMessageCountersEntry 28 }
+discardedMessages OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of discarded PTP messages"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.29
+::= { ptpbasePtpPortMessageCountersEntry 29 }
+unknownMessages OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of unknown type PTP messages received"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.12.1.30
+::= { ptpbasePtpPortMessageCountersEntry 30 }
+ptpbasePtpProtocolCountersTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbasePtpProtocolCountersEntry
+	STATUS  current
+	DESCRIPTION
+		"Table describing common PTP protocol counters."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.13
+::= { ptpbaseMIBClockInfo 13 }
+ptpbasePtpProtocolCountersEntry OBJECT-TYPE
+	SYNTAX  PtpbasePtpProtocolCountersEntry
+	STATUS  current
+	DESCRIPTION
+		"An entry in a table describing common PTP protocol counters."
+	INDEX {
+		ptpbaseProtocolCountersDomainIndex,
+		ptpbaseProtocolCountersClockTypeIndex,
+		ptpbaseProtocolCountersInstanceIndex,
+		ptpbaseProtocolCountersClockPortNumberIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.13.1
+::= { ptpbasePtpProtocolCountersTable 1 }
+PtpbasePtpProtocolCountersEntry ::= SEQUENCE {
+	ptpbaseProtocolCountersDomainIndex          ClockDomainType,
+	ptpbaseProtocolCountersClockTypeIndex       ClockType,
+	ptpbaseProtocolCountersInstanceIndex        ClockInstanceType,
+	ptpbaseProtocolCountersClockPortNumberIndex ClockPortNumber,
+	ptpbaseProtocolCountersClear                TruthValue,
+	foreignAdded                                Unsigned32,
+	foreignCount                                Unsigned32,
+	foreignRemoved                              Unsigned32,
+	foreignOverflows                            Unsigned32,
+	stateTransitions                            Unsigned32,
+	bestMasterChanges                           Unsigned32,
+	announceTimeouts                            Unsigned32 }
+ptpbaseProtocolCountersDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.13.1.1
+::= { ptpbasePtpProtocolCountersEntry 1 }
+ptpbaseProtocolCountersClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.13.1.2
+::= { ptpbasePtpProtocolCountersEntry 2 }
+ptpbaseProtocolCountersInstanceIndex OBJECT-TYPE
+	MAX-ACCESS not-accessible
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.13.1.3
+::= { ptpbasePtpProtocolCountersEntry 3 }
+ptpbaseProtocolCountersClockPortNumberIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION ""
+	-- 1.3.6.1.4.1.46649.1.1.1.2.13.1.4
+::= { ptpbasePtpProtocolCountersEntry 4 }
+ptpbaseProtocolCountersClear OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"Handle allowing to clear PTP protocol counters"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.13.1.5
+::= { ptpbasePtpProtocolCountersEntry 5 }
+foreignAdded OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of additions to Foreign Master Record"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.13.1.6
+::= { ptpbasePtpProtocolCountersEntry 6 }
+foreignCount OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Total number of foreign masters seen"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.13.1.7
+::= { ptpbasePtpProtocolCountersEntry 7 }
+foreignRemoved OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Total number of foreign masters removed because of inactivity"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.13.1.8
+::= { ptpbasePtpProtocolCountersEntry 8 }
+foreignOverflows OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of overwritten Foreign Master entries due to lack of space in the record"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.13.1.9
+::= { ptpbasePtpProtocolCountersEntry 9 }
+stateTransitions OBJECT-TYPE
+	SYNTAX  Unsigned32
+	MAX-ACCESS read-only
+	STATUS  current
+	DESCRIPTION
+		"Number of PTP protocol state transitions"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.13.1.10
+::= { ptpbasePtpProtocolCountersEntry 10 }
+bestMasterChanges OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of PTP best master changes"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.13.1.11
+::= { ptpbasePtpProtocolCountersEntry 11 }
+announceTimeouts OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of Announce Timeout events"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.13.1.12
+::= { ptpbasePtpProtocolCountersEntry 12 }
+ptpbasePtpErrorCountersTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbasePtpErrorCountersEntry
+	STATUS  current
+	DESCRIPTION
+		"Table describing common PTP protocol error counters."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.14
+::= { ptpbaseMIBClockInfo 14 }
+ptpbasePtpErrorCountersEntry OBJECT-TYPE
+	SYNTAX  PtpbasePtpErrorCountersEntry
+	STATUS  current
+	DESCRIPTION
+		"An entry in a table describing common PTP protocol error counters."
+	INDEX {
+		ptpbaseErrorCountersDomainIndex,
+		ptpbaseErrorCountersClockTypeIndex,
+		ptpbaseErrorCountersInstanceIndex,
+		ptpbaseErrorCountersClockPortNumberIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.14.1
+::= { ptpbasePtpErrorCountersTable 1 }
+PtpbasePtpErrorCountersEntry ::= SEQUENCE {
+	ptpbaseErrorCountersDomainIndex          ClockDomainType,
+	ptpbaseErrorCountersClockTypeIndex       ClockType,
+	ptpbaseErrorCountersInstanceIndex        ClockInstanceType,
+	ptpbaseErrorCountersClockPortNumberIndex ClockPortNumber,
+	ptpbaseErrorCountersClear                TruthValue,
+	messageRecvErrors                        Unsigned32,
+	messageSendErrors                        Unsigned32,
+	messageFormatErrors                      Unsigned32,
+	protocolErrors                           Unsigned32,
+	versionMismatchErrors                    Unsigned32,
+	domainMismatchErrors                     Unsigned32,
+	sequenceMismatchErrors                   Unsigned32,
+	delayMechanismMismatchErrors             Unsigned32 }
+ptpbaseErrorCountersDomainIndex OBJECT-TYPE
+	SYNTAX  ClockDomainType
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the domain number used to create logical
+	-- 1.3.6.1.4.1.46649.1.1.1.2.14.1.1
+::= { ptpbasePtpErrorCountersEntry 1 }
+ptpbaseErrorCountersClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the clock type as defined in the
+		Textual convention description."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.14.1.2
+::= { ptpbasePtpErrorCountersEntry 2 }
+ptpbaseErrorCountersInstanceIndex OBJECT-TYPE
+	SYNTAX  ClockInstanceType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.14.1.3
+::= { ptpbasePtpErrorCountersEntry 3 }
+ptpbaseErrorCountersClockPortNumberIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION ""
+	-- 1.3.6.1.4.1.46649.1.1.1.2.14.1.4
+::= { ptpbasePtpErrorCountersEntry 4 }
+ptpbaseErrorCountersClear OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"Handle allowing to clear PTP error counters"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.14.1.5
+::= { ptpbasePtpErrorCountersEntry 5 }
+messageRecvErrors OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of message receive errors"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.14.1.6
+::= { ptpbasePtpErrorCountersEntry 6 }
+messageSendErrors OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of message send errors"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.14.1.7
+::= { ptpbasePtpErrorCountersEntry 7 }
+messageFormatErrors OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of message format errors"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.14.1.8
+::= { ptpbasePtpErrorCountersEntry 8 }
+protocolErrors OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of PTP protocol errors - condition which should not happen"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.14.1.9
+::= { ptpbasePtpErrorCountersEntry 9 }
+versionMismatchErrors OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of messages with incorrect PTP version received"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.14.1.10
+::= { ptpbasePtpErrorCountersEntry 10 }
+domainMismatchErrors OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of messages received from different PTP domains than configured"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.14.1.11
+::= { ptpbasePtpErrorCountersEntry 11 }
+sequenceMismatchErrors OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of sequence mismatch errors observed"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.14.1.12
+::= { ptpbasePtpErrorCountersEntry 12 }
+delayMechanismMismatchErrors OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of delay mechanism mismatch errors - P2P messages seen when E2E operation used or vice versa"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.14.1.13
+::= { ptpbasePtpErrorCountersEntry 13 }
+ptpbasePtpUnicastNegotiationCountersTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbasePtpUnicastNegotiationCountersEntry
+	STATUS  current
+	DESCRIPTION
+		"Table describing PTP unicast negotiation counters."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.15
+::= { ptpbaseMIBClockInfo 15 }
+ptpbasePtpUnicastNegotiationCountersEntry OBJECT-TYPE
+	SYNTAX  PtpbasePtpUnicastNegotiationCountersEntry
+	STATUS  current
+	DESCRIPTION
+		"An entry in a table describing PTP unicast negotiation counters."
+	INDEX {
+		ptpbaseUnicastNegotiationCountersDomainIndex,
+		ptpbaseUnicastNegotiationCountersClockTypeIndex,
+		ptpbaseUnicastNegotiationCountersInstanceIndex,
+		ptpbaseUnicastNegotiationCountersClockPortNumberIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.15.1
+::= { ptpbasePtpUnicastNegotiationCountersTable 1 }
+PtpbasePtpUnicastNegotiationCountersEntry ::= SEQUENCE {
+	ptpbaseUnicastNegotiationCountersDomainIndex          ClockDomainType,
+	ptpbaseUnicastNegotiationCountersClockTypeIndex       ClockType,
+	ptpbaseUnicastNegotiationCountersInstanceIndex        ClockInstanceType,
+	ptpbaseUnicastNegotiationCountersClockPortNumberIndex ClockPortNumber,
+	ptpbaseUnicastNegotiationCountersClear                TruthValue,
+	unicastGrantsRequested                                Unsigned32,
+	unicastGrantsGranted                                  Unsigned32,
+	unicastGrantsDenied                                   Unsigned32,
+	unicastGrantsCancelSent                               Unsigned32,
+	unicastGrantsCancelReceived                           Unsigned32,
+	unicastGrantsCancelAckSent                            Unsigned32,
+	unicastGrantsCancelAckReceived                        Unsigned32 }
+ptpbaseUnicastNegotiationCountersDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		group of PTP devices."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.15.1.1
+::= { ptpbasePtpUnicastNegotiationCountersEntry 1 }
+ptpbaseUnicastNegotiationCountersClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.15.1.2
+::= { ptpbasePtpUnicastNegotiationCountersEntry 2 }
+ptpbaseUnicastNegotiationCountersInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"This object specifies the instance of the clock for this clock
+		type in the given domain."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.15.1.3
+::= { ptpbasePtpUnicastNegotiationCountersEntry 3 }
+ptpbaseUnicastNegotiationCountersClockPortNumberIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION ""
+	-- 1.3.6.1.4.1.46649.1.1.1.2.15.1.4
+::= { ptpbasePtpUnicastNegotiationCountersEntry 4 }
+ptpbaseUnicastNegotiationCountersClear OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"Handle allowing to clear PTP unicast negotiation counters"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.15.1.5
+::= { ptpbasePtpUnicastNegotiationCountersEntry 5 }
+unicastGrantsRequested OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of unicast grants requested by slave, or requested from master"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.15.1.6
+::= { ptpbasePtpUnicastNegotiationCountersEntry 6 }
+unicastGrantsGranted OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of unicast grants successfully granted to slaves (master), or received from master(s) (slave)"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.15.1.7
+::= { ptpbasePtpUnicastNegotiationCountersEntry 7 }
+unicastGrantsDenied OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of unicast grants denied to slaves (master), or denied by master(s) (slave)"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.15.1.8
+::= { ptpbasePtpUnicastNegotiationCountersEntry 8 }
+unicastGrantsCancelSent OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of unicast grants cancelations sent"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.15.1.9
+::= { ptpbasePtpUnicastNegotiationCountersEntry 9 }
+unicastGrantsCancelReceived OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of unicast grant cancellations received"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.15.1.10
+::= { ptpbasePtpUnicastNegotiationCountersEntry 10 }
+unicastGrantsCancelAckSent OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of sent acknowledgments to unicast grant cancellation"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.15.1.11
+::= { ptpbasePtpUnicastNegotiationCountersEntry 11 }
+unicastGrantsCancelAckReceived OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of received acknowledgments to unicast grant cancellation."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.15.1.12
+::= { ptpbasePtpUnicastNegotiationCountersEntry 12 }
+ptpbasePtpPerformanceCountersTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbasePtpPerformanceCountersEntry
+	STATUS  current
+	DESCRIPTION
+		"Table describing common PTP protocol message performance counters."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.16
+::= { ptpbaseMIBClockInfo 16 }
+ptpbasePtpPerformanceCountersEntry OBJECT-TYPE
+	SYNTAX  PtpbasePtpPerformanceCountersEntry
+	STATUS  current
+	DESCRIPTION
+		"An entry in a table describing common PTP protocol message performance counters."
+	INDEX {
+		ptpbasePerformanceCountersDomainIndex,
+		ptpbasePerformanceCountersClockTypeIndex,
+		ptpbasePerformanceCountersInstanceIndex,
+		ptpbasePerformanceCountersClockPortNumberIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.16.1
+::= { ptpbasePtpPerformanceCountersTable 1 }
+PtpbasePtpPerformanceCountersEntry ::= SEQUENCE {
+	ptpbasePerformanceCountersDomainIndex          ClockDomainType,
+	ptpbasePerformanceCountersClockTypeIndex       ClockType,
+	ptpbasePerformanceCountersInstanceIndex        ClockInstanceType,
+	ptpbasePerformanceCountersClockPortNumberIndex ClockPortNumber,
+	messageSendRate                                Unsigned32,
+	messageReceiveRate                             Unsigned32 }
+ptpbasePerformanceCountersDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.16.1.1
+::= { ptpbasePtpPerformanceCountersEntry 1 }
+ptpbasePerformanceCountersClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.16.1.2
+::= { ptpbasePtpPerformanceCountersEntry 2 }
+ptpbasePerformanceCountersInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.16.1.3
+::= { ptpbasePtpPerformanceCountersEntry 3 }
+ptpbasePerformanceCountersClockPortNumberIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION ""
+	-- 1.3.6.1.4.1.46649.1.1.1.2.16.1.4
+::= { ptpbasePtpPerformanceCountersEntry 4 }
+messageSendRate OBJECT-TYPE
+	SYNTAX  Unsigned32
+	UNITS	"Messages per second"
+	STATUS  current
+	DESCRIPTION
+		"Message transmission rate (messages per second)"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.16.1.5
+::= { ptpbasePtpPerformanceCountersEntry 5 }
+messageReceiveRate OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Message receive rate (messages per second)"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.16.1.6
+::= { ptpbasePtpPerformanceCountersEntry 6 }
+ptpbasePtpSecurityCountersTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbasePtpSecurityCountersEntry
+	STATUS  current
+	DESCRIPTION
+		"Table describing PTP message security (access control) counters."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.17
+::= { ptpbaseMIBClockInfo 17 }
+ptpbasePtpSecurityCountersEntry OBJECT-TYPE
+	SYNTAX  PtpbasePtpSecurityCountersEntry
+	STATUS  current
+	DESCRIPTION
+		"Entry in a table describing PTP message security (access control) counters."
+	INDEX {
+		ptpbaseSecurityCountersDomainIndex,
+		ptpbaseSecurityCountersClockTypeIndex,
+		ptpbaseSecurityCountersInstanceIndex,
+		ptpbaseSecurityCountersClockPortNumberIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.17.1
+::= { ptpbasePtpSecurityCountersTable 1 }
+PtpbasePtpSecurityCountersEntry ::= SEQUENCE {
+	ptpbaseSecurityCountersDomainIndex          ClockDomainType,
+	ptpbaseSecurityCountersClockTypeIndex       ClockType,
+	ptpbaseSecurityCountersInstanceIndex        ClockInstanceType,
+	ptpbaseSecurityCountersClockPortNumberIndex ClockPortNumber,
+	ptpbaseSecurityCountersClear                TruthValue,
+	aclTimingMessagesDiscarded                  Unsigned32,
+	aclManagementMessagesDiscarded              Unsigned32 }
+ptpbaseSecurityCountersDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.17.1.1
+::= { ptpbasePtpSecurityCountersEntry 1 }
+ptpbaseSecurityCountersClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.17.1.2
+::= { ptpbasePtpSecurityCountersEntry 2 }
+ptpbaseSecurityCountersInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.17.1.3
+::= { ptpbasePtpSecurityCountersEntry 3 }
+ptpbaseSecurityCountersClockPortNumberIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION ""
+	-- 1.3.6.1.4.1.46649.1.1.1.2.17.1.4
+::= { ptpbasePtpSecurityCountersEntry 4 }
+ptpbaseSecurityCountersClear OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"Handle allowing to clear PTP access control counters"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.17.1.5
+::= { ptpbasePtpSecurityCountersEntry 5 }
+aclTimingMessagesDiscarded OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of timing (non-management) messages discarded by access control (includes signaling messages)."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.17.1.6
+::= { ptpbasePtpSecurityCountersEntry 6 }
+aclManagementMessagesDiscarded OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of management messages discarded by access control"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.17.1.7
+::= { ptpbasePtpSecurityCountersEntry 7 }
+ptpbaseSlaveOfmStatisticsTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbaseSlaveOfmStatisticsEntry
+	STATUS  current
+	DESCRIPTION
+		"Table of statistics describing PTP slave Offset from Master."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18
+::= { ptpbaseMIBClockInfo 18 }
+ptpbaseSlaveOfmStatisticsEntry OBJECT-TYPE
+	SYNTAX  PtpbaseSlaveOfmStatisticsEntry
+	STATUS  current
+	DESCRIPTION
+		"An entry in a table of statistics describing PTP slave Offset from Master."
+	INDEX {
+		ptpbaseSlaveOfmStatisticsDomainIndex,
+		ptpbaseSlaveOfmStatisticsClockTypeIndex,
+		ptpbaseSlaveOfmStatisticsInstanceIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1
+::= { ptpbaseSlaveOfmStatisticsTable 1 }
+PtpbaseSlaveOfmStatisticsEntry ::= SEQUENCE {
+	ptpbaseSlaveOfmStatisticsDomainIndex    ClockDomainType,
+	ptpbaseSlaveOfmStatisticsClockTypeIndex ClockType,
+	ptpbaseSlaveOfmStatisticsInstanceIndex  ClockInstanceType,
+	ofmCurrentValue                         ClockTimeInterval,
+	ofmCurrentStringValue                   DisplayString,
+	ofmStatsPeriodSeconds                  Unsigned32,
+	ofmStatsValid                           TruthValue,
+	ofmStatsMin                             ClockTimeInterval,
+	ofmStatsMax                             ClockTimeInterval,
+	ofmStatsMean                            ClockTimeInterval,
+	ofmStatsStdDev                          ClockTimeInterval,
+	ofmStatsMedian                          ClockTimeInterval,
+	ofmStatsMinStringValue                  DisplayString,
+	ofmStatsMaxStringValue                  DisplayString,
+	ofmStatsMeanStringValue                 DisplayString,
+	ofmStatsStdDevStringValue               DisplayString,
+	ofmStatsMedianStringValue               DisplayString }
+ptpbaseSlaveOfmStatisticsDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.1
+::= { ptpbaseSlaveOfmStatisticsEntry 1 }
+ptpbaseSlaveOfmStatisticsClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.2
+::= { ptpbaseSlaveOfmStatisticsEntry 2 }
+ptpbaseSlaveOfmStatisticsInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.3
+::= { ptpbaseSlaveOfmStatisticsEntry 3 }
+ofmCurrentValue OBJECT-TYPE
+	SYNTAX  ClockTimeInterval
+	STATUS  current
+	DESCRIPTION
+		"Current value of Offset From Master."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.4
+::= { ptpbaseSlaveOfmStatisticsEntry 4 }
+ofmCurrentStringValue OBJECT-TYPE
+	SYNTAX  DisplayString (SIZE (1..64))
+	STATUS  current
+	DESCRIPTION
+		"Current value of Offset From Master, presented as text."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.5
+::= { ptpbaseSlaveOfmStatisticsEntry 5 }
+ofmStatsPeriodSeconds OBJECT-TYPE
+	SYNTAX  Unsigned32
+	UNITS	"Seconds"
+	STATUS  current
+	DESCRIPTION
+		"Update interval for Offset From Master statistics."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.6
+::= { ptpbaseSlaveOfmStatisticsEntry 6 }
+ofmStatsValid OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"Determines if current Offset From Master statistics are valid."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.7
+::= { ptpbaseSlaveOfmStatisticsEntry 7 }
+ofmStatsMin OBJECT-TYPE
+	UNITS	"Time Interval"
+	STATUS  current
+	DESCRIPTION
+		"Minimum Offset From Master in the last statistics update window."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.8
+::= { ptpbaseSlaveOfmStatisticsEntry 8 }
+ofmStatsMax OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Maximum Offset From Master in the last statistics update window."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.9
+::= { ptpbaseSlaveOfmStatisticsEntry 9 }
+ofmStatsMean OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Mean Offset From Master in the last statistics update window."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.10
+::= { ptpbaseSlaveOfmStatisticsEntry 10 }
+ofmStatsStdDev OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Standard deviation of Offset From Master in the last statistics update window."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.11
+::= { ptpbaseSlaveOfmStatisticsEntry 11 }
+ofmStatsMedian OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Median of Offset From Master in the last statistics update window."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.12
+::= { ptpbaseSlaveOfmStatisticsEntry 12 }
+ofmStatsMinStringValue OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Minimum Offset From Master in the last statistics update window, presented as textual value."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.13
+::= { ptpbaseSlaveOfmStatisticsEntry 13 }
+ofmStatsMaxStringValue OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Maximum Offset From Master in the last statistics update window, presented as textual value."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.14
+::= { ptpbaseSlaveOfmStatisticsEntry 14 }
+ofmStatsMeanStringValue OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Mean of Offset From Master in the last statistics update window, presented as textual value."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.15
+::= { ptpbaseSlaveOfmStatisticsEntry 15 }
+ofmStatsStdDevStringValue OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Standard deviation of Offset From Master in the last statistics update window, presented as textual value."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.16
+::= { ptpbaseSlaveOfmStatisticsEntry 16 }
+ofmStatsMedianStringValue OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Median of Offset From Master in the last statistics update window, presented as textual value."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.18.1.17
+::= { ptpbaseSlaveOfmStatisticsEntry 17 }
+ptpbaseSlaveMpdStatisticsTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbaseSlaveMpdStatisticsEntry
+	STATUS  current
+	DESCRIPTION
+		"Table of statistics describing PTP slave Mean Path Delay."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19
+::= { ptpbaseMIBClockInfo 19 }
+ptpbaseSlaveMpdStatisticsEntry OBJECT-TYPE
+	SYNTAX  PtpbaseSlaveMpdStatisticsEntry
+	STATUS  current
+	DESCRIPTION
+		"An entry in a table of statistics describing PTP slave Mean Path Delay."
+	INDEX {
+		ptpbaseSlaveMpdStatisticsDomainIndex,
+		ptpbaseSlaveMpdStatisticsClockTypeIndex,
+		ptpbaseSlaveMpdStatisticsInstanceIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1
+::= { ptpbaseSlaveMpdStatisticsTable 1 }
+PtpbaseSlaveMpdStatisticsEntry ::= SEQUENCE {
+	ptpbaseSlaveMpdStatisticsDomainIndex    ClockDomainType,
+	ptpbaseSlaveMpdStatisticsClockTypeIndex ClockType,
+	ptpbaseSlaveMpdStatisticsInstanceIndex  ClockInstanceType,
+	mpdCurrentValue                         ClockTimeInterval,
+	mpdCurrentStringValue                   DisplayString,
+	mpdStatsPeriodSeconds                  Integer32,
+	mpdStatsValid                           TruthValue,
+	mpdStatsMin                             ClockTimeInterval,
+	mpdStatsMax                             ClockTimeInterval,
+	mpdStatsMean                            ClockTimeInterval,
+	mpdStatsStdDev                          ClockTimeInterval,
+	mpdStatsMedian                          ClockTimeInterval,
+	mpdStatsMinStringValue                  DisplayString,
+	mpdStatsMaxStringValue                  DisplayString,
+	mpdStatsMeanStringValue                 DisplayString,
+	mpdStatsStdDevStringValue               DisplayString,
+	mpdStatsMedianStringValue               DisplayString }
+ptpbaseSlaveMpdStatisticsDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.1
+::= { ptpbaseSlaveMpdStatisticsEntry 1 }
+ptpbaseSlaveMpdStatisticsClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.2
+::= { ptpbaseSlaveMpdStatisticsEntry 2 }
+ptpbaseSlaveMpdStatisticsInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.3
+::= { ptpbaseSlaveMpdStatisticsEntry 3 }
+mpdCurrentValue OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Current value of Mean Path Delay."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.4
+::= { ptpbaseSlaveMpdStatisticsEntry 4 }
+mpdCurrentStringValue OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Current value of Mean Path Delay, presented as text."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.5
+::= { ptpbaseSlaveMpdStatisticsEntry 5 }
+mpdStatsPeriodSeconds OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"Update interval for Mean Path Delay statistics."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.6
+::= { ptpbaseSlaveMpdStatisticsEntry 6 }
+mpdStatsValid OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"Determines if current Mean Path Delay statistics are valid."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.7
+::= { ptpbaseSlaveMpdStatisticsEntry 7 }
+mpdStatsMin OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Minimum Mean Path Delay in the last statistics update window."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.8
+::= { ptpbaseSlaveMpdStatisticsEntry 8 }
+mpdStatsMax OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Maximum Mean Path Delay in the last statistics update window."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.9
+::= { ptpbaseSlaveMpdStatisticsEntry 9 }
+mpdStatsMean OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Mean of Mean Path Delay in the last statistics update window."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.10
+::= { ptpbaseSlaveMpdStatisticsEntry 10 }
+mpdStatsStdDev OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Standard Deviation of Mean Path Delay in the last statistics update window."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.11
+::= { ptpbaseSlaveMpdStatisticsEntry 11 }
+mpdStatsMedian OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Median of Mean Path Delay in the last statistics update window."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.12
+::= { ptpbaseSlaveMpdStatisticsEntry 12 }
+mpdStatsMinStringValue OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Minimum Mean Path Delay in the last statistics update window, presented as textual value."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.13
+::= { ptpbaseSlaveMpdStatisticsEntry 13 }
+mpdStatsMaxStringValue OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Maximum Mean Path Delay in the last statistics update window, presented as textual value."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.14
+::= { ptpbaseSlaveMpdStatisticsEntry 14 }
+mpdStatsMeanStringValue OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Mean of Mean Path Delay in the last statistics update window, presented as textual value."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.15
+::= { ptpbaseSlaveMpdStatisticsEntry 15 }
+mpdStatsStdDevStringValue OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Standard Deviation Path Delay in the last statistics update window, presented as textual value."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.16
+::= { ptpbaseSlaveMpdStatisticsEntry 16 }
+mpdStatsMedianStringValue OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Median of Mean Path Delay in the last statistics update window, presented as textual value."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.19.1.17
+::= { ptpbaseSlaveMpdStatisticsEntry 17 }
+ptpbaseSlaveFreqAdjStatisticsTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbaseSlaveFreqAdjStatisticsEntry
+	STATUS  current
+	DESCRIPTION
+		"Table of statistics describing PTP slave clock frequency adjustment."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.20
+::= { ptpbaseMIBClockInfo 20 }
+ptpbaseSlaveFreqAdjStatisticsEntry OBJECT-TYPE
+	SYNTAX  PtpbaseSlaveFreqAdjStatisticsEntry
+	STATUS  current
+	DESCRIPTION
+		"An entry in a table of statistics describing PTP slave clock frequency adjustment."
+	INDEX {
+		ptpbaseSlaveFreqAdjStatisticsDomainIndex,
+		ptpbaseSlaveFreqAdjStatisticsClockTypeIndex,
+		ptpbaseSlaveFreqAdjStatisticsInstanceIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.20.1
+::= { ptpbaseSlaveFreqAdjStatisticsTable 1 }
+PtpbaseSlaveFreqAdjStatisticsEntry ::= SEQUENCE {
+	ptpbaseSlaveFreqAdjStatisticsDomainIndex    ClockDomainType,
+	ptpbaseSlaveFreqAdjStatisticsClockTypeIndex ClockType,
+	ptpbaseSlaveFreqAdjStatisticsInstanceIndex  ClockInstanceType,
+	freqAdjCurrentValue                         Integer32,
+	freqAdjStatsPeriodSeconds                  Unsigned32,
+	freqAdjStatsValid                           TruthValue,
+	freqAdjStatsMin                             Integer32,
+	freqAdjStatsMax                             Integer32,
+	freqAdjStatsMean                            Integer32,
+	freqAdjStatsStdDev                          Integer32,
+	freqAdjStatsStatsMedian                     Integer32 }
+ptpbaseSlaveFreqAdjStatisticsDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.20.1.1
+::= { ptpbaseSlaveFreqAdjStatisticsEntry 1 }
+ptpbaseSlaveFreqAdjStatisticsClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.20.1.2
+::= { ptpbaseSlaveFreqAdjStatisticsEntry 2 }
+ptpbaseSlaveFreqAdjStatisticsInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.20.1.3
+::= { ptpbaseSlaveFreqAdjStatisticsEntry 3 }
+freqAdjCurrentValue OBJECT-TYPE
+	SYNTAX  Integer32
+	UNITS	"Parts per Billion / 10E-9"
+	STATUS  current
+	DESCRIPTION
+		"Current clock frequency adjustment value."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.20.1.4
+::= { ptpbaseSlaveFreqAdjStatisticsEntry 4 }
+freqAdjStatsPeriodSeconds OBJECT-TYPE
+	SYNTAX  Unsigned32
+	UNITS	"Seconds"
+	STATUS  current
+	DESCRIPTION
+		"Update interval for clock frequency adjustment statistics."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.20.1.5 --
+	::= { ptpbaseSlaveFreqAdjStatisticsEntry 5 }
+freqAdjStatsValid OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"Determines if current clock frequency adjustment statistics are valid."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.20.1.6 --
+	::= { ptpbaseSlaveFreqAdjStatisticsEntry 6 }
+freqAdjStatsMin OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"Minimum clock frequency adjustment in the last statistics update window."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.20.1.7 --
+	::= { ptpbaseSlaveFreqAdjStatisticsEntry 7 }
+freqAdjStatsMax OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"Maximum clock frequency adjustment in the last statistics update window."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.20.1.8 --
+	::= { ptpbaseSlaveFreqAdjStatisticsEntry 8 }
+freqAdjStatsMean OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"Mean clock frequency adjustment in the last statistics update window."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.20.1.9 --
+	::= { ptpbaseSlaveFreqAdjStatisticsEntry 9 }
+freqAdjStatsStdDev OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"Standard deviation of clock frequency adjustment in the last statistics update window."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.20.1.10 --
+	::= { ptpbaseSlaveFreqAdjStatisticsEntry 10 }
+freqAdjStatsStatsMedian OBJECT-TYPE
+	SYNTAX  Integer32
+	STATUS  current
+	DESCRIPTION
+		"Median of clock frequency adjustment in the last statistics update window."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.20.1.11 --
+	::= { ptpbaseSlaveFreqAdjStatisticsEntry 11 }
+ptpbasePtpdSpecificCountersTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbasePtpdSpecificCountersEntry
+	STATUS  current
+	DESCRIPTION
+		"Table describing PTPd-specific counters."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.21
+::= { ptpbaseMIBClockInfo 21 }
+ptpbasePtpdSpecificCountersEntry OBJECT-TYPE
+	SYNTAX  PtpbasePtpdSpecificCountersEntry
+	STATUS  current
+	DESCRIPTION
+		"An entry in a table describing PTPd-specific counters."
+	INDEX {
+		ptpbasePtpdSpecificCountersDomainIndex,
+		ptpbasePtpdSpecificCountersClockTypeIndex,
+		ptpbasePtpdSpecificCountersInstanceIndex,
+		ptpbasePtpdSpecificCountersClockPortNumberIndex }
+	-- 1.3.6.1.4.1.46649.1.1.1.2.21.1
+::= { ptpbasePtpdSpecificCountersTable 1 }
+PtpbasePtpdSpecificCountersEntry ::= SEQUENCE {
+	ptpbasePtpdSpecificCountersDomainIndex          ClockDomainType,
+	ptpbasePtpdSpecificCountersClockTypeIndex       ClockType,
+	ptpbasePtpdSpecificCountersInstanceIndex        ClockInstanceType,
+	ptpbasePtpdSpecificCountersClockPortNumberIndex ClockPortNumber,
+	ptpbasePtpdSpecificCountersClear                TruthValue,
+	consecutiveSequenceErrors                       Unsigned32,
+	ignoredAnnounce                                 Unsigned32,
+	delayMSOutliersFound                            Unsigned32,
+	delaySMOutliersFound                            Unsigned32,
+	maxDelayDrops                                   Unsigned32 }
+ptpbasePtpdSpecificCountersDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.21.1.1
+::= { ptpbasePtpdSpecificCountersEntry 1 }
+ptpbasePtpdSpecificCountersClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.21.1.2
+::= { ptpbasePtpdSpecificCountersEntry 2 }
+ptpbasePtpdSpecificCountersInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.21.1.3
+::= { ptpbasePtpdSpecificCountersEntry 3 }
+ptpbasePtpdSpecificCountersClockPortNumberIndex OBJECT-TYPE
+	SYNTAX  ClockPortNumber
+	STATUS  current
+	DESCRIPTION ""
+	-- 1.3.6.1.4.1.46649.1.1.1.2.21.1.4
+::= { ptpbasePtpdSpecificCountersEntry 4 }
+ptpbasePtpdSpecificCountersClear OBJECT-TYPE
+	SYNTAX  TruthValue
+	STATUS  current
+	DESCRIPTION
+		"Handle allowing to clear all PTPd-specific counters"
+	-- 1.3.6.1.4.1.46649.1.1.1.2.21.1.5
+::= { ptpbasePtpdSpecificCountersEntry 5 }
+consecutiveSequenceErrors OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of consecutive message sequence errors."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.21.1.6
+::= { ptpbasePtpdSpecificCountersEntry 6 }
+ignoredAnnounce OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of ignored Announce messages (BMCA disabled or UTC parameter preference)."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.21.1.7
+::= { ptpbasePtpdSpecificCountersEntry 7 }
+delayMSOutliersFound OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of DelayMS (Sync or FollowUp) outliers found."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.21.1.8
+::= { ptpbasePtpdSpecificCountersEntry 8 }
+delaySMOutliersFound OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of delaySM (Delay / pDelay response) outliers found."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.21.1.9
+::= { ptpbasePtpdSpecificCountersEntry 9 }
+maxDelayDrops OBJECT-TYPE
+	SYNTAX  Unsigned32
+	STATUS  current
+	DESCRIPTION
+		"Number of messages ignored because of maximum delay setting."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.21.1.10
+::= { ptpbasePtpdSpecificCountersEntry 10 }
+ptpbasePtpdSpecificDataTable OBJECT-TYPE
+	SYNTAX  SEQUENCE OF PtpbasePtpdSpecificDataEntry
+	STATUS  current
+	DESCRIPTION
+		"Table describing other PTPd-specific data."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.22
+::= { ptpbaseMIBClockInfo 22 }
+ptpbasePtpdSpecificDataEntry OBJECT-TYPE
+	SYNTAX  PtpbasePtpdSpecificDataEntry
+	STATUS  current
+	DESCRIPTION
+		"An entry in a table describing other PTPd-specific data."
+	INDEX {
+		ptpbasePtpdSpecificDataDomainIndex,
+		ptpbasePtpdSpecificDataClockTypeIndex,
+		ptpbasePtpdSpecificDataInstanceIndex}
+	-- 1.3.6.1.4.1.46649.1.1.1.2.22.1
+::= { ptpbasePtpdSpecificDataTable 1 }
+PtpbasePtpdSpecificDataEntry ::= SEQUENCE {
+	ptpbasePtpdSpecificDataDomainIndex          ClockDomainType,
+	ptpbasePtpdSpecificDataClockTypeIndex       ClockType,
+	ptpbasePtpdSpecificDataInstanceIndex        ClockInstanceType,
+	rawDelayMS                                  ClockTimeInterval,
+	rawDelayMSStringValue                       DisplayString,
+	rawDelaySM                                  ClockTimeInterval,
+	rawDelaySMStringValue                       DisplayString }
+ptpbasePtpdSpecificDataDomainIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.22.1.1
+::= { ptpbasePtpdSpecificDataEntry 1 }
+ptpbasePtpdSpecificDataClockTypeIndex OBJECT-TYPE
+	SYNTAX  ClockType
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.22.1.2
+::= { ptpbasePtpdSpecificDataEntry 2 }
+ptpbasePtpdSpecificDataInstanceIndex OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+	-- 1.3.6.1.4.1.46649.1.1.1.2.22.1.3
+::= { ptpbasePtpdSpecificDataEntry 3 }
+rawDelayMS OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Last raw (unfiltered) value of Master to Slave delay (Sync / FollowUp): T2 - T1."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.22.1.4
+::= { ptpbasePtpdSpecificDataEntry 4 }
+rawDelayMSStringValue OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Last raw (unfiltered) value of Master to Slave delay (Sync / FollowUp): T2 - T1, presented as text value."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.22.1.5
+::= { ptpbasePtpdSpecificDataEntry 5 }
+rawDelaySM OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Last raw (unfiltered) value of Slave to Master delay (Delay Request / Response): T4 - T3."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.22.1.6
+::= { ptpbasePtpdSpecificDataEntry 6 }
+rawDelaySMStringValue OBJECT-TYPE
+	STATUS  current
+	DESCRIPTION
+		"Last raw (unfiltered) value of Slave to Master delay (Delay Request / Response): T4 - T3, presented as text value."
+	-- 1.3.6.1.4.1.46649.1.1.1.2.22.1.7
+::= { ptpbasePtpdSpecificDataEntry 7 }
+ptpbaseMIBConformance OBJECT IDENTIFIER
+	-- 1.3.6.1.4.1.46649.1.1.2
+::= { ptpbaseMIB 2 }
+-- Conformance Information Definition
+ptpbaseMIBCompliances OBJECT IDENTIFIER
+	-- 1.3.6.1.4.1.46649.1.1.2.1
+::= { ptpbaseMIBConformance 1 }
+ptpbaseMIBGroups OBJECT IDENTIFIER
+	-- 1.3.6.1.4.1.46649.1.1.2.2
+::= { ptpbaseMIBConformance 2 }
+ptpbaseMIBCompliances1 MODULE-COMPLIANCE
+	STATUS  current
+	DESCRIPTION
+		"Compliance statement for agents that provide read-only support
+		for PTPBASE-MIB. Such devices can only be monitored using this
+		MIB module.
+		The Module is implemented with support for read-only. In other
+		words, only monitoring is available by implementing this
+		MODULE-COMPLIANCE."
+	MODULE
+	MANDATORY-GROUPS {
+			ptpbaseMIBSystemInfoGroup }
+	-- 1.3.6.1.4.1.46649.1.1.2.1.1
+::= { ptpbaseMIBCompliances 1 }
+ptpbaseMIBCompliances2 MODULE-COMPLIANCE
+	STATUS  current
+	DESCRIPTION
+		MIB module.
+	MODULE
+			ptpbaseMIBClockCurrentDSGroup,
+			ptpbaseMIBClockParentDSGroup,
+			ptpbaseMIBClockDefaultDSGroup,
+			ptpbaseMIBClockRunningGroup,
+			ptpbaseMIBClockTimepropertiesGroup }
+	-- 1.3.6.1.4.1.46649.1.1.2.1.2
+::= { ptpbaseMIBCompliances 2 }
+ptpbaseMIBCompliances3 MODULE-COMPLIANCE
+	STATUS  current
+	DESCRIPTION
+		MIB module.
+	MODULE
+			ptpbaseMIBClockPortGroup,
+			ptpbaseMIBClockPortDSGroup,
+			ptpbaseMIBClockPortRunningGroup,
+			ptpbaseMIBClockPortAssociateGroup }
+	-- 1.3.6.1.4.1.46649.1.1.2.1.3
+::= { ptpbaseMIBCompliances 3 }
+ptpbaseMIBCompliances4 MODULE-COMPLIANCE
+	STATUS  current
+	DESCRIPTION
+		MIB module.
+	MODULE
+			ptpbaseMIBClockTranparentDSGroup,
+			ptpbaseMIBClockPortTransDSGroup }
+	-- 1.3.6.1.4.1.46649.1.1.2.1.4
+::= { ptpbaseMIBCompliances 4 }
+ptpbaseMIBSystemInfoGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbaseSystemDomainTotals,
+		ptpDomainClockPortsTotal,
+		ptpbaseSystemProfile }
+	STATUS  current
+	DESCRIPTION
+		"Group which aggregates objects describing system-wide
+		information"
+	-- 1.3.6.1.4.1.46649.1.1.2.2.1
+::= { ptpbaseMIBGroups 1 }
+ptpbaseMIBClockCurrentDSGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbaseClockCurrentDSStepsRemoved,
+		ptpbaseClockCurrentDSOffsetFromMaster,
+		ptpbaseClockCurrentDSMeanPathDelay,
+		ptpbaseClockCurrentDSOffsetFromMasterString,
+		ptpbaseClockCurrentDSMeanPathDelayString,
+		ptpbaseClockCurrentDSOffsetFromMasterThresholdNs }
+	STATUS  current
+	DESCRIPTION
+		"Group which aggregates objects describing PTP Current Dataset
+		information"
+	-- 1.3.6.1.4.1.46649.1.1.2.2.2
+::= { ptpbaseMIBGroups 2 }
+ptpbaseMIBClockParentDSGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbaseClockParentDSParentPortIdentity,
+		ptpbaseClockParentDSParentStats,
+		ptpbaseClockParentDSOffset,
+		ptpbaseClockParentDSClockPhChRate,
+		ptpbaseClockParentDSGMClockIdentity,
+		ptpbaseClockParentDSGMClockPriority1,
+		ptpbaseClockParentDSGMClockPriority2,
+		ptpbaseClockParentDSGMClockQualityClass,
+		ptpbaseClockParentDSGMClockQualityAccuracy,
+		ptpbaseClockParentDSGMClockQualityOffset,
+		ptpbaseClockParentDSParentPortAddressType,
+		ptpbaseClockParentDSParentPortAddress }
+	STATUS  current
+	DESCRIPTION
+		"Group which aggregates objects describing PTP Parent Dataset
+		information"
+	-- 1.3.6.1.4.1.46649.1.1.2.2.3
+::= { ptpbaseMIBGroups 3 }
+ptpbaseMIBClockDefaultDSGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbaseClockDefaultDSTwoStepFlag,
+		ptpbaseClockDefaultDSClockIdentity,
+		ptpbaseClockDefaultDSPriority1,
+		ptpbaseClockDefaultDSPriority2,
+		ptpbaseClockDefaultDSSlaveOnly,
+		ptpbaseClockDefaultDSQualityClass,
+		ptpbaseClockDefaultDSQualityAccuracy,
+		ptpbaseClockDefaultDSQualityOffset,
+		ptpbaseClockDefaultDSDomainNumber }
+	STATUS  current
+	DESCRIPTION
+		"Group which aggregates objects describing PTP Default Dataset
+		information"
+	-- 1.3.6.1.4.1.46649.1.1.2.2.4
+::= { ptpbaseMIBGroups 4 }
+ptpbaseMIBClockRunningGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbaseClockRunningState,
+		ptpbaseClockRunningPacketsSent,
+		ptpbaseClockRunningPacketsReceived }
+	STATUS  current
+	DESCRIPTION
+		"Group which aggregates objects describing PTP running state
+		information"
+	-- 1.3.6.1.4.1.46649.1.1.2.2.5
+::= { ptpbaseMIBGroups 5 }
+ptpbaseMIBClockTimepropertiesGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbaseClockTimePropertiesDSCurrentUTCOffsetValid,
+		ptpbaseClockTimePropertiesDSCurrentUTCOffset,
+		ptpbaseClockTimePropertiesDSLeap59,
+		ptpbaseClockTimePropertiesDSLeap61,
+		ptpbaseClockTimePropertiesDSTimeTraceable,
+		ptpbaseClockTimePropertiesDSFreqTraceable,
+		ptpbaseClockTimePropertiesDSPTPTimescale,
+		ptpbaseClockTimePropertiesDSSource }
+	STATUS  current
+	DESCRIPTION
+		"Group which aggregates objects describing PTP Time Properties
+		information"
+	-- 1.3.6.1.4.1.46649.1.1.2.2.6
+::= { ptpbaseMIBGroups 6 }
+ptpbaseMIBClockTranparentDSGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbaseClockTransDefaultDSClockIdentity,
+		ptpbaseClockTransDefaultDSNumOfPorts,
+		ptpbaseClockTransDefaultDSDelay,
+		ptpbaseClockTransDefaultDSPrimaryDomain }
+	STATUS  current
+	DESCRIPTION
+		"Group which aggregates objects describing PTP Transparent
+		Dataset
+		information"
+	-- 1.3.6.1.4.1.46649.1.1.2.2.7
+::= { ptpbaseMIBGroups 7 }
+ptpbaseMIBClockPortGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbaseClockPortCurrentPeerAddress,
+		ptpbaseClockPortCurrentPeerAddressType,
+		ptpbaseClockPortName,
+		ptpbaseClockPortSyncOneStep,
+		ptpbaseClockPortNumOfAssociatedPorts,
+		ptpbaseClockPortRole }
+	STATUS  current
+	DESCRIPTION
+		"Group which aggregates objects describing information for a
+		given PTP Port."
+	-- 1.3.6.1.4.1.46649.1.1.2.2.8
+::= { ptpbaseMIBGroups 8 }
+ptpbaseMIBClockPortDSGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbaseClockPortDSName,
+		ptpbaseClockPortDSPortIdentity,
+		ptpbaseClockPortDSAnnouncementInterval,
+		ptpbaseClockPortDSAnnounceRctTimeout,
+		ptpbaseClockPortDSSyncInterval,
+		ptpbaseClockPortDSMinDelayReqInterval,
+		ptpbaseClockPortDSPeerDelayReqInterval,
+		ptpbaseClockPortDSDelayMech,
+		ptpbaseClockPortDSPeerMeanPathDelay,
+		ptpbaseClockPortDSGrantDuration,
+		ptpbaseClockPortDSPTPVersion,
+		ptpBaseClockPortDSPeerMeanPathDelayString,
+		ptpBaseClockPortDSLastMismatchedDomain }
+	STATUS  current
+	DESCRIPTION
+		"Group which aggregates objects describing PTP Port Dataset
+		information"
+	-- 1.3.6.1.4.1.46649.1.1.2.2.9
+::= { ptpbaseMIBGroups 9 }
+ptpbaseMIBClockPortRunningGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbaseClockPortRunningName,
+		ptpbaseClockPortRunningState,
+		ptpbaseClockPortRunningRole,
+		ptpbaseClockPortRunningInterfaceIndex,
+		ptpbaseClockPortRunningIPversion,
+		ptpbaseClockPortRunningEncapsulationType,
+		ptpbaseClockPortRunningTxMode,
+		ptpbaseClockPortRunningRxMode,
+		ptpbaseClockPortRunningPacketsReceived,
+		ptpbaseClockPortRunningPacketsSent }
+	STATUS  current
+	DESCRIPTION
+		"Group which aggregates objects describing PTP running interface
+		information"
+	-- 1.3.6.1.4.1.46649.1.1.2.2.10
+::= { ptpbaseMIBGroups 10 }
+ptpbaseMIBClockPortTransDSGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbaseClockPortTransDSPortIdentity,
+		ptpbaseClockPortTransDSlogMinPdelayReqInt,
+		ptpbaseClockPortTransDSFaultyFlag,
+		ptpbaseClockPortTransDSPeerMeanPathDelay }
+	STATUS  current
+	DESCRIPTION
+		"Group which aggregates objects describing PTP TransparentDS
+		Dataset
+		information"
+	-- 1.3.6.1.4.1.46649.1.1.2.2.11
+::= { ptpbaseMIBGroups 11 }
+ptpbaseMIBClockPortAssociateGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbaseClockPortAssociatePacketsSent,
+		ptpbaseClockPortAssociatePacketsReceived,
+		ptpbaseClockPortAssociateAddress,
+		ptpbaseClockPortAssociateAddressType,
+		ptpbaseClockPortAssociateInErrors,
+		ptpbaseClockPortAssociateOutErrors }
+	STATUS  current
+	DESCRIPTION
+		"Group which aggregates objects describing information on peer
+		PTP ports for a given PTP clock-port."
+	-- 1.3.6.1.4.1.46649.1.1.2.2.12
+::= { ptpbaseMIBGroups 12 }
+ptpbaseMIBPtpPortMessageCountersGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbasePortMessageCountersClearAll,
+		ptpbasePortMessageCountersClear,
+		announceMessagesSent,
+		announceMessagesReceived,
+		syncMessagesSent,
+		syncMessagesReceived,
+		followUpMessagesSent,
+		followUpMessagesReceived,
+		delayReqMessagesSent,
+		delayReqMessagesReceived,
+		delayRespMessagesSent,
+		delayRespMessagesReceived,
+		pdelayReqMessagesSent,
+		pdelayReqMessagesReceived,
+		pdelayRespMessagesSent,
+		pdelayRespMessagesReceived,
+		pdelayRespFollowUpMessagesSent,
+		pdelayRespFollowUpMessagesReceived,
+		signalingMessagesSent,
+		signalingMessagesReceived,
+		managementMessagesSent,
+		managementMessagesReceived,
+		discardedMessages,
+		unknownMessages,
+		totalMessagesSent,
+		totalMessagesReceived }
+	STATUS  current
+	DESCRIPTION
+		"A grouping of PTP port message counters."
+	-- 1.3.6.1.4.1.46649.1.1.2.2.13 ---- 1.3.6.1.4.1.46649.1.1.2.2.13
+::= { ptpbaseMIBGroups 13 }
+ptpbaseMIBPtpProtocolCountersGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbaseProtocolCountersClear,
+		foreignAdded,
+		foreignCount,
+		foreignRemoved,
+		foreignOverflows,
+		stateTransitions,
+		bestMasterChanges,
+		announceTimeouts }
+	STATUS  current
+	DESCRIPTION
+		"A grouping of PTP protocol counters."
+	-- 1.3.6.1.4.1.46649.1.1.2.2.14 ---- 1.3.6.1.4.1.46649.1.1.2.2.14
+::= { ptpbaseMIBGroups 14 }
+ptpbaseMIBPtpErrorCountersGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbaseErrorCountersClear,
+		messageRecvErrors,
+		messageSendErrors,
+		messageFormatErrors,
+		protocolErrors,
+		versionMismatchErrors,
+		domainMismatchErrors,
+		sequenceMismatchErrors,
+		delayMechanismMismatchErrors }
+	STATUS  current
+	DESCRIPTION
+		"A grouping of PTP protocol error counters."
+	-- 1.3.6.1.4.1.46649.1.1.2.2.15 ---- 1.3.6.1.4.1.46649.1.1.2.2.15
+::= { ptpbaseMIBGroups 15 }
+ptpbaseMIBPtpUnicastNegotiationCountersGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbaseUnicastNegotiationCountersClear,
+		unicastGrantsRequested,
+		unicastGrantsGranted,
+		unicastGrantsDenied,
+		unicastGrantsCancelSent,
+		unicastGrantsCancelReceived,
+		unicastGrantsCancelAckSent,
+		unicastGrantsCancelAckReceived }
+	STATUS  current
+	DESCRIPTION
+		"A grouping of PTP unicast negotiation counters."
+	-- 1.3.6.1.4.1.46649.1.1.2.2.16 ---- 1.3.6.1.4.1.46649.1.1.2.2.16
+::= { ptpbaseMIBGroups 16 }
+ptpbaseMIBPtpPerformanceCountersGroup OBJECT-GROUP
+	OBJECTS {
+		messageSendRate,
+		messageReceiveRate }
+	STATUS  current
+	DESCRIPTION
+		"A grouping of PTP message performance counters."
+	-- 1.3.6.1.4.1.46649.1.1.2.2.17 ---- 1.3.6.1.4.1.46649.1.1.2.2.17
+::= { ptpbaseMIBGroups 17 }
+ptpbaseMIBPtpSecurityCountersGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbaseSecurityCountersClear,
+		aclTimingMessagesDiscarded,
+		aclManagementMessagesDiscarded }
+	STATUS  current
+	DESCRIPTION
+		"A grouping of PTP security (access control) counters."
+	-- 1.3.6.1.4.1.46649.1.1.2.2.18 ---- 1.3.6.1.4.1.46649.1.1.2.2.18
+::= { ptpbaseMIBGroups 18 }
+ptpbaseMIBSlaveOfmStatisticsGroup OBJECT-GROUP
+	OBJECTS {
+		ofmCurrentValue,
+		ofmCurrentStringValue,
+		ofmStatsPeriodSeconds,
+		ofmStatsValid,
+		ofmStatsMin,
+		ofmStatsMax,
+		ofmStatsMean,
+		ofmStatsStdDev,
+		ofmStatsMedian,
+		ofmStatsMinStringValue,
+		ofmStatsMaxStringValue,
+		ofmStatsMeanStringValue,
+		ofmStatsStdDevStringValue,
+		ofmStatsMedianStringValue }
+	STATUS  current
+	DESCRIPTION
+		"A grouping of PTP slave Offset from Master statistics."
+	-- 1.3.6.1.4.1.46649.1.1.2.2.19
+::= { ptpbaseMIBGroups 19 }
+ptpbaseMIBSlaveMpdStatisticsGroup OBJECT-GROUP
+	OBJECTS {
+		mpdCurrentValue,
+		mpdCurrentStringValue,
+		mpdStatsPeriodSeconds,
+		mpdStatsValid,
+		mpdStatsMin,
+		mpdStatsMax,
+		mpdStatsMean,
+		mpdStatsStdDev,
+		mpdStatsMedian,
+		mpdStatsMinStringValue,
+		mpdStatsMaxStringValue,
+		mpdStatsMeanStringValue,
+		mpdStatsStdDevStringValue,
+		mpdStatsMedianStringValue }
+	STATUS  current
+	DESCRIPTION
+		"A grouping of PTP slave Mean Path Delay statistics."
+	-- 1.3.6.1.4.1.46649.1.1.2.2.20
+::= { ptpbaseMIBGroups 20 }
+ptpbaseMIBSlaveFreqAdjStatisticsGroup OBJECT-GROUP
+	OBJECTS {
+		freqAdjCurrentValue,
+		freqAdjStatsPeriodSeconds,
+		freqAdjStatsValid,
+		freqAdjStatsMin,
+		freqAdjStatsMax,
+		freqAdjStatsMean,
+		freqAdjStatsStdDev,
+		freqAdjStatsStatsMedian }
+	STATUS  current
+	DESCRIPTION
+		"A grouping of PTP slave clock frequency adjustment statistics."
+	-- 1.3.6.1.4.1.46649.1.1.2.2.21
+::= { ptpbaseMIBGroups 21 }
+ptpbaseMIBPtpdCountersGroup OBJECT-GROUP
+	OBJECTS {
+		ptpbasePtpdSpecificCountersClear,
+		consecutiveSequenceErrors,
+		ignoredAnnounce,
+		delayMSOutliersFound,
+		delaySMOutliersFound,
+		maxDelayDrops }
+	STATUS  current
+	DESCRIPTION
+		"A grouping of PTPd-specific counters."
+	-- 1.3.6.1.4.1.46649.1.1.2.2.22 ---- 1.3.6.1.4.1.46649.1.1.2.2.22
+::= { ptpbaseMIBGroups 22 }
+ptpbaseMIBPtpdSpecificDataGroup OBJECT-GROUP
+	OBJECTS {
+		rawDelayMS,
+		rawDelayMSStringValue,
+		rawDelaySM,
+		rawDelaySMStringValue }
+	STATUS  current
+	DESCRIPTION
+		"A grouping of PTPd-specific data."
+	-- 1.3.6.1.4.1.46649.1.1.2.2.23
+::= { ptpbaseMIBGroups 23 }
+ptpbaseMIBNotificationGroup NOTIFICATION-GROUP
+	NOTIFICATIONS {
+		ptpBasePortExpectedState,
+		ptpBasePortUnexpectedState,
+		ptpBaseSlaveOfmThresholdExceeded,
+		ptpBaseSlaveOfmThresholdAcceptable,
+		ptpBaseSaveClockStep,
+		ptpBaseSlaveNoSync,
+		ptpBaseSlaveReceivingSync,
+		ptpBaseSlaveNoDelay,
+		ptpBaseSlaveReceivingDelay,
+		ptpBaseBestMasterChange,
+		ptpBasePortNetworkFault,
+		ptpBasePortNetworkFaultCleared,
+		ptpBaseClockFreqAdjFast,
+		ptpBaseClockFreqAdjNormal,
+		ptpBaseSlaveOffsetFromMasterSeconds,
+		ptpBaseSlaveOffsetFromMasterSubSeconds,
+		ptpBaseTimePropertiesChange,
+		ptpBaseDomainMismatch,
+		ptpBaseDomainMismatchCleared}
+	STATUS  current
+	DESCRIPTION
+		"A grouping of notification objects defined in the PTPBASE-MIB MIB."
+	-- 1.3.6.1.4.1.46649.1.1.2.2.24
+::= { ptpbaseMIBGroups 24 }
+END
diff --git a/freebsd/contrib/ptpd/doc/draft-ietf-tictoc-ptp-mib-01.txt b/freebsd/contrib/ptpd/doc/draft-ietf-tictoc-ptp-mib-01.txt
new file mode 100644
index 00000000..f8389430
--- /dev/null
+++ b/freebsd/contrib/ptpd/doc/draft-ietf-tictoc-ptp-mib-01.txt
@@ -0,0 +1,3693 @@
+TICTOC Working Group                                 Vinay Shankarkumar
+INTERNET DRAFT                                          Laurent Montini
+Intended status: Standards Track                          Cisco Systems
+                                                              Tim Frost
+                                                              Greg Dowd
+                                                            Symmetricom
+Expires: August 6, 2012                                February 6, 2012
+                 Precision Time Protocol Version 2 (PTPv2)
+                        Management Information Base
+                     draft-ietf-tictoc-ptp-mib-01.txt
+Status of this Memo
+   This Internet-Draft is submitted to IETF in full conformance with the
+   provisions of BCP 78 and BCP 79.
+   Internet-Drafts are working documents of the Internet Engineering
+   Task Force (IETF), its areas, and its working groups.  Note that
+   other groups may also distribute working documents as Internet-
+   Drafts.
+   Internet-Drafts are draft documents valid for a maximum of six months
+   and may be updated, replaced, or obsoleted by other documents at any
+   time.  It is inappropriate to use Internet-Drafts as reference
+   material or to cite them other than as "work in progress."
+   The list of current Internet-Drafts can be accessed at
+   http://www.ietf.org/ietf/1id-abstracts.txt
+   The list of Internet-Draft Shadow Directories can be accessed at
+   http://www.ietf.org/shadow.html
+   This Internet-Draft will expire on August 6, 2012.
+Copyright Notice
+   Copyright (c) 2012 IETF Trust and the persons identified as the
+   document authors.  All rights reserved.
+   This document is subject to BCP 78 and the IETF Trust's Legal
+   Provisions Relating to IETF Documents
+   (http://trustee.ietf.org/license-info) in effect on the date of
+   publication of this document. Please review these documents
+Shankarkumar et al.     Expires August 6, 2012                 [Page 1]
+Internet-Draft      draft-ietf-tictoc-ptp-mib-01.txt   February 6, 2012
+   carefully, as they describe your rights and restrictions with respect
+   to this document.  Code Components extracted from this document must
+   include Simplified BSD License text as described in Section 4.e of
+   the Trust Legal Provisions and are provided without warranty as
+   described in the Simplified BSD License.
+Abstract
+   This memo defines a portion of the Management Information Base (MIB)
+   for use with network management protocols in TCP/IP-based internets.
+   In particular, it defines objects for managing networks using
+   Precision Time Protocol.
+   This memo specifies a MIB module in a manner that is both compliant
+   to the SNMPv2 SMI, and semantically identical to the peer SNMPv1
+   definitions.
+Table of Contents
+   1. Introduction...................................................2
+      1.1. Relationship to other Profiles and MIBs...................3
+      1.2. Change Log................................................3
+   2. The SNMP Management Framework..................................3
+   3. Overview.......................................................4
+   4. IETF PTP MIB Definition........................................5
+   5. Security Considerations.......................................63
+   6. IANA Considerations...........................................64
+   7. References....................................................64
+      7.1. Normative References.....................................64
+      7.2. Informative References...................................64
+   8. Acknowledgements..............................................66
+   9. Author's Addresses............................................66
+1. Introduction
+   for use with network management protocols in the Internet Community.
+   In particular, it describes managed objects used for managing PTP
+   devices including the ordinary clock, transparent clock, boundary
+   clocks.
+   This MIB is restricted to reading standard PTP data elements, as
+   described in [IEEE 1588-2008].  It is envisioned this MIB will
+   complement other managed objects to be defined to monitor, measure
+   the performance of the PTP devices and telecom clocks. Those objects
+   are considered out of scope for the current draft.
+Shankarkumar et al.     Expires August 6, 2012                 [Page 2]
+   Similarly, this MIB is read-only and not intended to provide the
+   ability to configure PTP clocks.  Since PTP clocks are often embedded
+   in other network elements such as routers, switches and gateways,
+   this ability is generally provided via the configuration interface
+   for the network element.
+1.1. Relationship to other Profiles and MIBs
+   This MIB is intended to be used with the default PTP profile
+   described in [IEEE 1588-2008], and the Telecom Profile described in
+   [G.8265.1], when running over the IP network layer.  As stated above,
+   it is envisioned this MIB will complement other managed objects to be
+   defined to monitor, measure the performance of the PTP devices and
+   telecom clocks.
+   Some other PTP profiles have their own MIBs defined as part of the
+   profile, and this MIB is not intended to replace those MIBs.
+1.2. Change Log
+   This section tracks changes made to the revisions of the Internet
+   Drafts of this document.  It will be *deleted* when the document is
+   published as an RFC.   This section tracks changes made to the
+   visions of the Internet Drafts of this document.  It will be
+   *deleted* when the document is published as an RFC.
+   draft-vinay-tictoc-ptp-mib
+   -00  Mar 11  Initial version; showed structure of MIB
+   -00  Jul 11  First full, syntactically correct and compileable MIB
+   -01  Jan 12  Revised following comments from Bert Wijnen:
+                - revised introduction to clarify the scope, and the
+                  relationship to other MIBs and profiles
+                - changed name to "ptpbase"
+                - corrected some data types
+                - corrected references and typos
+2. The SNMP Management Framework
+   The SNMP Management Framework presently consists of five major
+   components:
+   o  An overall architecture, described in STD62, [RFC 3411].
+   o  Mechanisms for describing and naming objects and events for the
+      purpose of management.  The first version of this Structure of
+Shankarkumar et al.     Expires August 6, 2012                 [Page 3]
+      Management Information (SMI) is called SMIv1 and described in
+      STD 16: [RFC 1155], [RFC 1212] and [RFC 1215].
+      The second version, called SMIv2, is described in STD 58:
+      [RFC 2578], [RFC 2579] and [RFC 2580].
+   o  Message protocols for transferring management information.  The
+      first version of the SNMP message protocol is called SNMPv1 and
+      described in STD 15 [RFC 1157].  A second version of the SNMP
+      message protocol, which is not an Internet standards track
+      protocol, is called SNMPv2c and described in [RFC 1901] and
+      [RFC 1906].  The third version of the message protocol is called
+      SNMPv3 and described in STD62: [RFC 3417], [RFC 3412] and [RFC
+      3414].
+   o  Protocol operations for accessing management information.  The
+      first set of protocol operations and associated PDU formats is
+      described in STD 15 [RFC 1157].  A second set of protocol
+      operations and associated PDU formats is described in STD 62
+      [RFC 3416].
+   o  A set of fundamental applications described in STD 62 [RFC 3413]
+      and the view-based access control mechanism described in STD 62
+      [RFC 3415].
+   Managed objects are accessed via a virtual information store, termed
+   the Management Information Base or MIB.  Objects in the MIB are
+   defined using the mechanisms defined in the SMI.
+   This memo specifies a MIB module that is compliant to the SMIv2.  A
+   MIB conforming to the SMIv1 can be produced through the appropriate
+   translations.  The resulting translated MIB must be semantically
+   equivalent, except where objects or events are omitted because no
+   translation is possible (e.g., use of Counter64).  Some machine
+   readable information in SMIv2 will be converted into textual
+   descriptions in SMIv1 during the translation process.  However, this
+   loss of machine readable information is not considered to change the
+   semantics of the MIB.
+3. Overview
+   The objects defined in this MIB are to be used when describing the
+   Precision Time Protocol (PTPv2).
+Shankarkumar et al.     Expires August 6, 2012                 [Page 4]
+4. IETF PTP MIB Definition
+PTPBASE-MIB DEFINITIONS ::= BEGIN
+IMPORTS
+    MODULE-IDENTITY,
+    OBJECT-TYPE,
+    Integer32,
+    Gauge32,
+    Unsigned32,
+    Counter32,
+    Counter64
+        FROM SNMPv2-SMI
+    OBJECT-GROUP,
+    MODULE-COMPLIANCE
+        FROM SNMPv2-CONF
+    TEXTUAL-CONVENTION,
+    TruthValue,
+    DisplayString
+        FROM SNMPv2-TC
+    InterfaceIndexOrZero
+        FROM IF-MIB
+    InetAddressType,
+    InetAddress
+        FROM INET-ADDRESS-MIB;
+ptpbaseMIB MODULE-IDENTITY
+    LAST-UPDATED    "201201230000Z"
+    ORGANIZATION    "TICTOC Working Group"
+    CONTACT-INFO
+          "WG Email: tictoc at ietf.org
+           Vinay Shankarkumar
+           Cisco Systems,
+           Email: vinays at cisco.com
+           Laurent Montini,
+           Cisco Systems,
+           Email: lmontini at cisco.com
+           Tim Frost,
+           Symmetricom Inc.,
+           Email: tfrost at symmetricom.com
+           Greg Dowd,
+           Symmetricom Inc.,
+           Email: gdowd at symmetricom.com"
+Shankarkumar et al.     Expires August 6, 2012                 [Page 5]
+    DESCRIPTION
+        "The MIB module for PTP version 2 (IEEE Std. 1588(TM)-2008)
+        Overview of PTP version 2 (IEEE Std. 1588(TM)-2008)
+        [IEEE 1588-2008] defines a protocol enabling precise
+        synchronization of clocks in measurement and control systems
+        implemented with packet-based networks, the Precision Time
+        Protocol Version 2 (PTPv2).  This MIB does not address the
+        earlier version IEEE Std. 1588(TM)-2002 (PTPv1).  The protocol
+        is applicable to network elements communicating using IP.  The
+        protocol enables heterogeneous systems that include clocks of
+        various inherent precision, resolution, and stability to
+        synchronize to a grandmaster clock.
+        The protocol supports system-wide synchronization accuracy in
+        the sub-microsecond range with minimal network and local clock
+        computing resources. [IEEE 1588-2008] uses UDP/IP or
+        Ethernet and can be adapted to other mappings. It includes
+        formal mechanisms for message extensions, higher sampling rates,
+        correction for asymmetry, a clock type to reduce error
+        accumulation in large topologies, and specifications on how to
+        incorporate the resulting additional data into the
+        synchronization protocol. The [IEEE 1588-2008] defines
+        conformance and management capability also.
+        MIB description
+        This MIB is to support the Precision Time Protocol version 2
+        (PTPv2, hereafter designated as PTP) features of network element
+        system devices, when using the default PTP profile described in
+        [IEEE 1588-2008], or the Telecom Profile described in
+        It is envisioned this MIB will complement other managed objects
+        to be defined to monitor, measure the performance of the PTP
+        devices and telecom clocks.
+        the profile, and this MIB is not intended to replace those MIBs.
+        Acronyms:
+                ARB     Arbitrary Timescale
+                E2E     End-to-End
+                EUI     Extended Unique Identifier.
+                GPS     Global Positioning System
+                IANA    Internet Assigned Numbers Authority
+                IP      Internet Protocol
+Shankarkumar et al.     Expires August 6, 2012                 [Page 6]
+                MAC     Media Access Control
+                        according to [IEEE 802.3-2008]
+                NIST    National Institute of Standards and Technology
+                NTP     Network Time Protocol (see IETF [RFC 5905])
+                OUI     Organizational Unique Identifier
+                        (allocated by the IEEE)
+                P2P     Peer-to-Peer
+                PTP     Precision Time Protocol
+                TAI     International Atomic Time
+                TC      Transparent Clock
+                UDP     User Datagram Protocol
+                UTC     Coordinated Universal Time
+        References:
+        [IEEE 1588-2008] IEEE Standard for A Precision Clock
+            Synchronization Protocol for Networked Measurement and
+            Control Systems, IEEE Std. 1588(TM)-2008, 24 July 2008.
+        [G.8265.1] Precision Time Protocol Telecom Profile for
+            Frequency Synchronization, ITU-T Recommendation G.8265.1,
+            October 2010.
+        As defined in [IEEE 1588-2008]:
+        Accuracy:
+        The mean of the time or frequency error between the clock under
+        test and a perfect reference clock, over an ensemble of
+        measurements.  Stability is a measure of how the mean varies
+        with respect to variables such as time, temperature, and so on,
+        while the precision is a measure of the deviation of the error
+        from the mean.
+        Atomic process:
+        A process is atomic if the values of all inputs to the process
+        are not permitted to change until all of the results of the
+        process are instantiated, and the outputs of the process are
+        not visible to other processes until the processing of each
+        output is complete.
+        Boundary clock:
+        A clock that has multiple Precision Time Protocol (PTP) ports in
+        a domain and maintains the timescale used in the domain.  It
+        may serve as the source of time, i.e., be a master clock, and
+        may synchronize to another clock, i.e., be a slave clock.
+        Boundary node clock:
+        A clock that has multiple Precision Time Protocol(PTP) ports in
+Shankarkumar et al.     Expires August 6, 2012                 [Page 7]
+        differs from a boundary clock in that the clock roles can
+        change.
+        Clock:
+        A node participating in the Precision Time Protocol (PTP) that
+        is capable of providing a measurement of the passage of time
+        since a defined epoch.
+        Domain:
+        A logical grouping of clocks that synchronize to each other
+        using the protocol, but that are not necessarily synchronized
+        to clocks in another domain.
+        End-to-end transparent clock:
+        A transparent clock that supports the use of the end-to-end
+        delay measurement mechanism between slave clocks and the master
+        clock.  Each node must measure the residence time of PTP event
+        messages and accumulate it in Correction Field.
+        Epoch:
+        The origin of a timescale.
+        Event:
+        An abstraction of the mechanism by which signals or conditions
+        are generated and represented.
+        Foreign master:
+        An ordinary or boundary clock sending Announce messages to
+        another clock that is not the current master recognized by the
+        other clock.
+        Grandmaster clock:
+        Within a domain, a clock that is the ultimate source of time
+        for clock synchronization using the protocol.
+        Holdover:
+        A clock previously synchronized/syntonized to another clock
+        (normally a primary reference or a master clock) but now
+        free-running based on its own internal oscillator, whose
+        frequency is being adjusted using data acquired while it had
+        been synchronized/syntonized to the other clock.  It is said to
+        be in holdover or in the holdover mode, as long as it is within
+        its accuracy requirements.
+        Link:
+        A network segment between two Precision Time Protocol ports
+        supporting the peer delay mechanism of this standard.  The peer
+        delay mechanism is designed to measure the propagation time
+        over such a link.
+Shankarkumar et al.     Expires August 6, 2012                 [Page 8]
+        Management node:
+        A device that configures and monitors clocks.
+        Master clock:
+        In the context of a single Precision Time Protocol
+        communication path, a clock that is the source of time to which
+        all other clocks on that path synchronize.
+        Message timestamp point:
+        A point within a Precision Time Protocol event message serving
+        as a reference point in the message.  A timestamp is defined by
+        the instant a message timestamp point passes the reference
+        plane of a clock.
+        Multicast communication:
+        A communication model in which each Precision Time Protocol
+        message sent from any PTP port is capable of being received and
+        processed by all PTP ports on the same PTP communication path.
+        Node:
+        A device that can issue or receive Precision Time Protocol
+        communications on a network.
+        One-step clock:
+        A clock that provides time information using a single event
+        message.
+        On-pass support:
+        Indicates that each node in the synchronization chain from
+        master to slave can support IEEE-1588.
+        Ordinary clock:
+        A clock that has a single Precision Time Protocol port in a
+        domain and maintains the timescale used in the domain.  It may
+        serve as a source of time, i.e., be a master clock, or may
+        synchronize to another clock, i.e., be a slave clock.
+        Parent clock:
+        The master clock to which a clock is synchronized.
+        Peer-to-peer transparent clock:
+        A transparent clock that, in addition to providing Precision
+        Time Protocol event transit time information, also provides
+        corrections for the propagation delay of the link connected to
+        the port receiving the PTP event message.  In the presence of
+        peer-to-peer transparent clocks, delay measurements between
+        slave clocks and the master clock are performed using the
+        peer-to-peer delay measurement mechanism.
+Shankarkumar et al.     Expires August 6, 2012                 [Page 9]
+        Phase change rate:
+        The observed rate of change in the measured time with respect
+        to the reference time.  The phase change rate is equal to the
+        fractional frequency offset between the measured frequency and
+        the reference frequency.
+        PortNumber:
+        An index identifying a specific Precision Time Protocol port on
+        a PTP node.
+        Primary reference:
+        A source of time and or frequency that is traceable to
+        international standards.
+        Profile:
+        The set of allowed Precision Time Protocol features applicable
+        to a device.
+        Precision Time Protocol communication:
+        Information used in the operation of the protocol, transmitted
+        in a PTP message over a PTP communication path.
+        Precision Time Protocol communication path:
+        The signaling path portion of a particular network enabling
+        direct communication among ordinary and boundary clocks.
+        Precision Time Protocol node:
+        PTP ordinary, boundary, or transparent clock or a device that
+        generates or parses PTP messages.
+        Precision Time Protocol port:
+        A logical access point of a clock for PTP communications to the
+        communications network.
+        Recognized standard time source:
+        A recognized standard time source is a source external to
+        Precision Time Protocol that provides time and/or frequency as
+        appropriate that is traceable to the international standards
+        laboratories maintaining clocks that form the basis for the
+        International Atomic Time and Universal Coordinated Time
+        timescales.  Examples of these are GPS, NTP, and NIST
+        timeservers.
+        Requestor:
+        The port implementing the peer-to-peer delay mechanism that
+        initiates the mechanism by sending a Pdelay_Req message.
+        Responder:
+Shankarkumar et al.     Expires August 6, 2012                [Page 10]
+        The port responding to the receipt of a Pdelay_Req message as
+        part of the operation of the peer-to-peer delay mechanism.
+        Synchronized clocks:
+        Two clocks are synchronized to a specified uncertainty if they
+        have the same epoch and their measurements of the time of a
+        single event at an arbitrary time differ by no more than that
+        uncertainty.
+        Syntonized clocks:
+        Two clocks are syntonized if the duration of the second is the
+        same on both, which means the time as measured by each advances
+        at the same rate. They may or may not share the same epoch.
+        Timeout:
+        A mechanism for terminating requested activity that, at least
+        from the requester's perspective, does not complete within the
+        specified time.
+        Timescale:
+        A linear measure of time from an epoch.
+        Traceability:
+        A property of the result of a measurement or the value of a
+        standard whereby it can be related to stated references,
+        usually national or international standards, through an
+        unbroken chain of comparisons all having stated uncertainties.
+        Translation device:
+        A boundary clock or, in some cases, a transparent clock that
+        translates the protocol messages between regions implementing
+        different transport and messaging protocols, between different
+        versions of [IEEE 1588-2008], or different PTP profiles.
+        Transparent clock:
+        A device that measures the time taken for a Precision Time
+        Protocol event message to transit the device and provides this
+        information to clocks receiving this PTP event message.
+        Two-step clock:
+        A clock that provides time information using the combination of
+        an event message and a subsequent general message.
+        The below table specifies the object formats of the various
+        textual conventions used.
+        Data type mapping   Textual Convention SYNTAX
+        5.3.2 TimeInterval  ClockTimeInterval OCTET STRING(SIZE(1..255))
+Shankarkumar et al.     Expires August 6, 2012                [Page 11]
+        5.3.3 Timestamp     ClockTimestamp    OCTET STRING(SIZE(6))
+        5.3.4 ClockIdentity ClockIdentity     OCTET STRING(SIZE(1..255))
+        5.3.5 PortIdentity  ClockPortNumber   INTEGER(1..65535)
+        5.3.7 ClockQuality  ClockQualityClassType
+        Simple master-slave hierarchy, section 6.6.2.4 [IEEE 1588-2008]:
+                  |   Ordinary    |
+                  |   Clock -1    |
+                  | (GrandMaster) |
+                  +-------M-------+
+                          1
+          +---------------S-----------------+
+          |            Boundary             |
+          |            Clock -1             |
+          +-----M---------------------M-----+
+                2                     3
+          +-----S-----+  +------------S-------------+
+          | Ordinary  |  |         Boundary         |
+          | Clock -2  |  |         Clock -2         |
+          +-----------+  +-----M--------------M-----+
+                               4              5
+                         +-----S-----+  +-----S-----+
+                         | Ordinary  |  | Ordinary  |
+                         | Clock -3  |  | Clock -4  |
+          Grandmaster
+          Boundary Clock(0-N)   Ordinary Clocks(0-N)
+          Ordinary Clocks(0-N)
+        Relationship cardinality:
+           PTP system 1 : N PTP Clocks
+           PTP Clock  1 : 1 Domain
+           PTP Clock  1 : N PTP Ports
+           PTP Ports  N : M Physical Ports (interface in IF-MIB)
+        Transparent clock diagram, section 6.7.1.3 of [IEEE 1588-2008]:
+Shankarkumar et al.     Expires August 6, 2012                [Page 12]
+                         |     Boundary clock - 1      |
+                   +-- A --+                         B
+        |  Ordinary clock      |                     |
+        +----------------------+          |      End-to-end      |
+        |  Ordinary clock 1-1  |----------|  transparent clock-  |
+        +----------------------+          |        1 - 1         |
+                                                     C
+        |  Ordinary clock 1-2  |----------|  transparent clock-  |
+        +----------------------+          |        1 - 2         |
+        The MIB refers to the sections of [IEEE 1588-2008]."
+      -- revision log
+      ::= { mib-2 XXX }_-- XXX to be assigned by IANA
+ClockDomainType ::= TEXTUAL-CONVENTION
+    DISPLAY-HINT    "d"
+    STATUS          current
+    DESCRIPTION
+        "The Domain is identified by an integer, the domainNumber, in
+        the range of 0 to 255. An integer value that is used to assign
+        each PTP device to a particular domain. The following values
+        define the valid domains.
+                 Value       Definition
+                 0           Default domain
+                 1           Alternate domain 1
+                 2           Alternate domain 2
+                 3           Alternate domain 3
+                 4 - 127     User-defined domains
+Shankarkumar et al.     Expires August 6, 2012                [Page 13]
+                 128 - 255   Reserved"
+    REFERENCE   "Section 7.1 Domains, Table 2 of [IEEE 1588-2008]"
+    SYNTAX      Unsigned32 (0..255)
+ClockIdentity ::= TEXTUAL-CONVENTION
+    STATUS          current
+    DESCRIPTION
+        "The clock Identity is an 8-octet array and will be presented in
+        the form of a character array. The value of the
+        ClockIdentity should be taken from the IEEE EUI-64 individual
+        assigned numbers as indicated in Section 7.5.2.2.2 of
+        [IEEE 1588-2008].  The EUI-64 address is divided into the
+        following fields:
+             OUI bytes (0-2)
+             Extension identifier bytes (3-7)
+        The clock identifier can be constructed from existing EUI-48
+        assignments and here is an abbreviated example extracted from
+        section 7.5.2.2.2 [IEEE 1588-2008].
+             Company EUI-48 = 0xACDE4823456716
+             EUI-64 = ACDE48FFFE23456716
+        It is important to note the IEEE Registration Authority has
+        deprecated the use of MAC-48 in any new design."
+    REFERENCE       "Section 7.5.2.2.1 of [IEEE 1588-2008]"
+    SYNTAX          OCTET STRING (SIZE (1..255))
+ClockIntervalBase2 ::= TEXTUAL-CONVENTION
+    DISPLAY-HINT    "d"
+    STATUS          current
+    DESCRIPTION
+        "The interval included in message types Announce, Sync,
+        Delay_Req, and Pdelay_Req as indicated in section 7.7.2.1 of
+        [IEEE 1588-2008].
+        The mean time interval between successive messages shall be
+        represented as the logarithm to the base 2 of this time
+        interval measured in seconds on the local clock of the device
+        sending the message. The values of these logarithmic attributes
+        shall be selected from integers in the range -128 to 127 subject
+        to further limits established in an applicable PTP profile."
+    REFERENCE   "Section 7.7.2.1 General interval specification of
+                [IEEE 1588-2008]"
+    SYNTAX      Integer32 (-128..127)
+Shankarkumar et al.     Expires August 6, 2012                [Page 14]
+ClockMechanismType ::= TEXTUAL-CONVENTION
+    STATUS          current
+    DESCRIPTION
+        "The clock type based on whether End to End or peer to peer
+        mechanisms are used. The mechanism used to calculate the Mean
+        Path Delay as indicated in Table 9 of [IEEE 1588-2008].
+        Delay mechanism   Value(hex)  Specification
+        E2E                  01       The port is configured to use the
+                                      delay request-response mechanism.
+        P2P                  02       The port is configured to use the
+                                      peer delay mechanism.
+        DISABLED             FE       The port does not implement the
+                                      delay mechanism."
+    REFERENCE   "Sections 8.2.5.4.4, 6.6.4, 7.4.2 of [IEEE 1588-2008]."
+    SYNTAX      INTEGER {
+                    e2e(1),
+                    p2p(2),
+                    disabled(254)
+ClockInstanceType ::= TEXTUAL-CONVENTION
+    DISPLAY-HINT    "d"
+    STATUS          current
+    DESCRIPTION
+        "The instance of the Clock of a given clock type in a given
+        domain."
+ClockPortNumber ::= TEXTUAL-CONVENTION
+    DISPLAY-HINT    "d"
+    STATUS          current
+    DESCRIPTION
+        "An index identifying a specific Precision Time Protocol (PTP)
+        port on a PTP node."
+    REFERENCE   "Sections 7.5.2.3 and 5.3.5 of [IEEE 1588-2008]"
+    SYNTAX      Unsigned32 (0..65535)
+ClockPortState ::= TEXTUAL-CONVENTION
+    STATUS          current
+    DESCRIPTION
+        "This is the value of the current state of the protocol engine
+        associated with this port.
+        Port state      Value     Description
+Shankarkumar et al.     Expires August 6, 2012                [Page 15]
+        initializing      1       In this state a port initializes
+                                  its data sets, hardware, and
+                                  communication facilities.
+        faulty            2       The fault state of the protocol.
+        disabled          3       The port shall not place any
+                                  messages on its communication path.
+        listening         4       The port is waiting for the
+                                  announceReceiptTimeout to expire or
+                                  to receive an Announce message from
+                                  a master.
+        preMaster         5       The port shall behave in all respects
+                                  as though it were in the MASTER state
+                                  except that it shall not place any
+                                  except for Pdelay_Req, Pdelay_Resp,
+                                  Pdelay_Resp_Follow_Up, signaling, or
+                                  management messages.
+        master            6       The port is behaving as a master port.
+        passive           7       The port shall not place any messages
+                                  on its communication path except for
+                                  Pdelay_Req, Pdelay_Resp,
+                                  Pdelay_Resp_Follow_Up, or signaling
+                                  messages, or management messages that
+                                  are a required response to another
+        uncalibrated      8       The local port is preparing to
+                                  synchronize to the master port.
+        slave             9       The port is synchronizing to the
+                                  selected master port."
+    REFERENCE       "Section 8.2.5.3.1 portState and 9.2.5 of
+                     [IEEE 1588-2008]"
+    SYNTAX          INTEGER  {
+                        initializing(1),
+                        faulty(2),
+                        disabled(3),
+                        listening(4),
+                        preMaster(5),
+                        master(6),
+                        passive(7),
+                        uncalibrated(8),
+                        slave(9)
+ClockProfileType ::= TEXTUAL-CONVENTION
+    STATUS          current
+    DESCRIPTION
+        "Clock Profile used. A profile is the set of allowed Precision
+        Time Protocol (PTP) features applicable to a device."
+Shankarkumar et al.     Expires August 6, 2012                [Page 16]
+    REFERENCE       "Section 3.1.30 and 19.3 PTP profiles of
+                     [IEEE 1588-2008]"
+    SYNTAX          INTEGER  {
+                        default(1),
+                        telecom(2),
+                        vendorspecific(3)
+ClockQualityAccuracyType ::= TEXTUAL-CONVENTION
+    STATUS          current
+    DESCRIPTION
+        "The ClockQuality as specified in section 5.3.7, 7.6.2.5 and
+        Table 6 of [IEEE 1588-2008].
+        The following values are not represented in the enumerated
+        values.
+                 0x01-0x1F Reserved
+                 0x32-0x7F Reserved
+        It is important to note that section 7.1.1 RFC2578 allows for
+        gaps and enumerate values to start with zero when indicated by
+        the protocol."
+    REFERENCE       "Section 5.3.7, 7.6.2.5 and Table 6 of
+                     [IEEE 1588-2008]"
+    SYNTAX          INTEGER  {
+                        reserved00(1),       -- 0
+                        nanoSecond25(32),    -- 0x20
+                        nanoSecond100(33),   -- 0x21
+                        nanoSecond250(34),   -- 0x22
+                        microSec1(35),       -- 0x23
+                        microSec2dot5(36),   -- 0x24
+                        microSec10(37),      -- 0x25
+                        microSec25(38),      -- 0x26
+                        microSec100(39),     -- 0x27
+                        microSec250(40),     -- 0x28
+                        milliSec1(41),       -- 0x29
+                        milliSec2dot5(42),   -- 0x2A
+                        milliSec10(43),      -- 0x2B
+                        milliSec25(44),      -- 0x2C
+                        milliSec100(45),     -- 0x2D
+                        milliSec250(46),     -- 0x2E
+                        second1(47),         -- 0x2F
+                        second10(48),        -- 0x30
+                        secondGreater10(49), -- 0x31
+                        unknown(254),        -- 0xFE
+                        reserved255(255)     -- 0xFF
+Shankarkumar et al.     Expires August 6, 2012                [Page 17]
+ClockQualityClassType ::= TEXTUAL-CONVENTION
+    DISPLAY-HINT    "d"
+    STATUS          current
+    DESCRIPTION
+        "The ClockQuality as specified in section 5.3.7, 7.6.2.4 and
+        Table 5 of [IEEE 1588-2008].
+        Value     Description
+               0  Reserved to enable compatibility with future
+                  versions.
+             1-5  Reserved
+               6  Shall designate a clock that is synchronized
+                  to a primary reference time source.  The
+                  timescale distributed shall be PTP.  A
+                  clockClass 6 clock shall not be a slave to
+                  another clock in the domain.
+               7  Shall designate a clock that has previously
+                  been designated as clockClass 6 but that has
+                  lost the ability to synchronize to a primary
+                  reference time source and is in holdover mode
+                  and within holdover specifications. The
+                  clockClass 7 clock shall not be a slave to
+               8  Reserved.
+            9-10  Reserved to enable compatibility with future
+                  versions.
+           11-12  Reserved.
+              13  Shall designate a clock that is synchronized
+                  to an application-specific source of time.
+                  The timescale distributed shall be ARB.  A
+                  clockClass 13 clock shall not be a slave to
+              14  Shall designate a clock that has previously
+                  been designated as clockClass 13 but that
+                  has lost the ability to synchronize to an
+                  application-specific source of time and is
+                  in holdover mode and within holdover
+                  specifications. The timescale distributed
+                  shall be ARB.  A clockClass 14 clock shall
+                  not be a slave to another clock in the domain.
+           15-51  Reserved.
+              52  Degradation alternative A for a clock of
+                  clockClass 7 that is not within holdover
+                  specification.  A clock of clockClass 52
+                  shall not be a slave to another clock in
+Shankarkumar et al.     Expires August 6, 2012                [Page 18]
+                  the domain.
+           53-57  Reserved.
+              58  Degradation alternative A for a clock of
+                  clockClass 14 that is not within holdover
+                  specification. A clock of clockClass 58 shall
+           59-67  Reserved.
+          68-122  For use by alternate PTP profiles.
+         123-127  Reserved.
+         128-132  Reserved.
+         133-170  For use by alternate PTP profiles.
+         171-186  Reserved.
+             187  Degradation alternative B for a clock of
+                  specification. A clock of clockClass 187 may
+                  be a slave to another clock in the domain.
+         188-192  Reserved.
+             193  Degradation alternative B for a clock of
+                  specification. A clock of clockClass 193 may
+         194-215  Reserved.
+         216-232  For use by alternate PTP profiles.
+         233-247  Reserved.
+             248  Default. This clockClass shall be used if
+                  none of the other clockClass definitions apply.
+         249-250  Reserved.
+             251  Reserved for version 1 compatibility; see Clause 18.
+         252-254  Reserved.
+             255  Shall be the clockClass of a slave-only clock; see
+                  9.2.2."
+    REFERENCE       "Section 5.3.7, 7.6.2.4 and Table 5 of
+                     [IEEE 1588-2008]."
+ClockRoleType ::= TEXTUAL-CONVENTION
+    STATUS          current
+    DESCRIPTION
+        "The Clock Role. The protocol generates a Master Slave
+        relationship among the clocks in the system.
+        Clock Role      Value     Description
+        Master clock     1        A clock that is the source of
+                                  time to which all other clocks on
+                                  that path synchronize.
+Shankarkumar et al.     Expires August 6, 2012                [Page 19]
+        Slave clock      2        A clock which synchronizes to
+                                  another clock (master)."
+    SYNTAX          INTEGER  {
+                        master(1),
+                        slave(2)
+ClockStateType ::= TEXTUAL-CONVENTION
+    STATUS          current
+    DESCRIPTION
+        "The clock state returned by PTP engine.
+        Clock State      Value   Description
+        Freerun state       1   Applies to a slave device that is not
+                                locked to a master. This is the initial
+                                state a slave starts out with when it
+                                is not getting any PTP packets from the
+                                master or because of some other input
+                                error (erroneous packets, etc).
+        Holdover state      2  In this state the slave device is
+                                locked to a master but communication
+                                with the master is lost or the
+                                timestamps in the ptp packets are
+                                incorrect. But since the slave was
+                                locked to the master, it can run with
+                                the same accuracy for sometime. The
+                                slave can continue to operate in this
+                                state for some time. If communication
+                                with the master is not restored for a
+                                while, the device is moved to the
+                                FREERUN state.
+        Acquiring state     3   The slave device is receiving packets
+                                from a master and is trying to acquire
+                                a lock.
+        Freq_locked state   4   Slave device is locked to the Master
+                                with respect to frequency, but not phase
+                                aligned
+        Phase_aligned state 5   Locked to the master with respect to
+                                frequency and phase."
+    SYNTAX          INTEGER  {
+                        freerun(1),
+                        holdover(2),
+                        acquiring(3),
+                        frequencyLocked(4),
+Shankarkumar et al.     Expires August 6, 2012                [Page 20]
+                        phaseAligned(5)
+ClockTimeSourceType ::= TEXTUAL-CONVENTION
+    STATUS          current
+    DESCRIPTION
+        "The ClockQuality as specified in section 5.3.7, 7.6.2.6 and
+        Table 7 of [IEEE 1588-2008].
+        values.
+        0xF0-0xFE  For use by alternate PTP profiles
+        0xFF       Reserved
+        the protocol."
+    REFERENCE       "Section 5.3.7, 7.6.2.6 and Table 7 of
+    SYNTAX          INTEGER  {
+                        atomicClock(16), -- 0x10
+                        gps(32), -- 0x20
+                        terrestrialRadio(48), -- 0x22
+                        ptp(64), -- 0x40
+                        ntp(80), -- 0x50
+                        handSet(96), -- 0x60
+                        other(144), -- 0x90
+                        internalOsillator(160) -- 0xA0
+ClockTimeInterval ::= TEXTUAL-CONVENTION
+    STATUS          current
+    DESCRIPTION
+        "This textual convention corresponds to the TimeInterval
+        structure indicated in section 5.3.2 of [IEEE 1588-2008].
+        It will be presented in the form of a character array.
+        The TimeInterval type represents time intervals.
+             struct TimeInterval
+                  Integer64 scaledNanoseconds;
+        The scaledNanoseconds member is the time interval expressed in
+        units of nanoseconds and multiplied by 2**16.
+Shankarkumar et al.     Expires August 6, 2012                [Page 21]
+        Positive or negative time intervals outside the maximum range
+        of this data type shall be encoded as the largest positive and
+        negative values of the data type, respectively.
+        For example, 2.5 ns is expressed as 0000 0000 0002 8000 in
+        Base16."
+    REFERENCE
+        "Section 5.3.2 and setion 7.7.2.1 Timer interval
+         specification of [IEEE 1588-2008]"
+ClockTxModeType ::= TEXTUAL-CONVENTION
+    STATUS          current
+    DESCRIPTION
+        "Transmission mode.
+        unicast. Using unicast communication channel.
+        multicast. Using Multicast communication channel.
+        multicast-mix. Using multicast-unicast communication channel"
+    SYNTAX          INTEGER  {
+                        unicast(1),
+                        multicast(2),
+                        multicastmix(3)
+ClockType ::= TEXTUAL-CONVENTION
+    STATUS          current
+    DESCRIPTION
+        "The clock types as defined in the MIB module description."
+    REFERENCE       "Section 6.5.1 of [IEEE 1588-2008]."
+    SYNTAX          INTEGER  {
+                        ordinaryClock(1),
+                        boundaryClock(2),
+                        transparentClock(3),
+                        boundaryNode(4)
+ptpbaseMIBNotifs  OBJECT IDENTIFIER
+    ::= { ptpbaseMIB 0 }
+ptpbaseMIBObjects  OBJECT IDENTIFIER
+    ::= { ptpbaseMIB 1 }
+    ::= { ptpbaseMIB 2 }
+Shankarkumar et al.     Expires August 6, 2012                [Page 22]
+ptpbaseMIBSystemInfo  OBJECT IDENTIFIER
+    ::= { ptpbaseMIBObjects 1 }
+    ::= { ptpbaseMIBConformance 1 }
+    ::= { ptpbaseMIBConformance 2 }
+    STATUS          current
+    DESCRIPTION
+        MIB module.
+    MODULE          -- this module
+    MANDATORY-GROUPS { ptpbaseMIBSystemInfoGroup }
+    ::= { ptpbaseMIBCompliances 1 }
+    STATUS          current
+    DESCRIPTION
+        MIB module.
+    ::= { ptpbaseMIBCompliances 2 }
+    STATUS          current
+    DESCRIPTION
+Shankarkumar et al.     Expires August 6, 2012                [Page 23]
+        MIB module.
+    ::= { ptpbaseMIBCompliances 3 }
+    STATUS          current
+    DESCRIPTION
+        MIB module.
+    ::= { ptpbaseMIBCompliances 4 }
+    OBJECTS         {
+    STATUS          current
+    DESCRIPTION
+        information"
+    ::= { ptpbaseMIBGroups 1 }
+    OBJECTS         {
+Shankarkumar et al.     Expires August 6, 2012                [Page 24]
+    STATUS          current
+    DESCRIPTION
+        information"
+    ::= { ptpbaseMIBGroups 2 }
+    OBJECTS         {
+    STATUS          current
+    DESCRIPTION
+        information"
+    ::= { ptpbaseMIBGroups 3 }
+    OBJECTS         {
+    STATUS          current
+    DESCRIPTION
+        information"
+    ::= { ptpbaseMIBGroups 4 }
+    OBJECTS         {
+Shankarkumar et al.     Expires August 6, 2012                [Page 25]
+    STATUS          current
+    DESCRIPTION
+        information"
+    ::= { ptpbaseMIBGroups 5 }
+    OBJECTS  {
+    STATUS          current
+    DESCRIPTION
+        information"
+    ::= { ptpbaseMIBGroups 6 }
+    OBJECTS         {
+    STATUS          current
+    DESCRIPTION
+        Dataset
+        information"
+    ::= { ptpbaseMIBGroups 7 }
+    OBJECTS         {
+    STATUS          current
+    DESCRIPTION
+Shankarkumar et al.     Expires August 6, 2012                [Page 26]
+        given PTP Port."
+    ::= { ptpbaseMIBGroups 8 }
+    OBJECTS         {
+    STATUS          current
+    DESCRIPTION
+        information"
+    ::= { ptpbaseMIBGroups 9 }
+    OBJECTS         {
+    STATUS          current
+    DESCRIPTION
+        information"
+    ::= { ptpbaseMIBGroups 10 }
+    OBJECTS         {
+Shankarkumar et al.     Expires August 6, 2012                [Page 27]
+    STATUS          current
+    DESCRIPTION
+        Dataset
+        information"
+    ::= { ptpbaseMIBGroups 11 }
+    OBJECTS         {
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseMIBGroups 12 }
+ptpbaseMIBClockInfo  OBJECT IDENTIFIER
+    ::= { ptpbaseMIBObjects 2 }
+ptpbaseSystemTable OBJECT-TYPE
+    SYNTAX          SEQUENCE OF PtpbaseSystemEntry
+    MAX-ACCESS      not-accessible
+    STATUS          current
+    DESCRIPTION
+        "Table of count information about the PTP system for all
+        domains."
+    ::= { ptpbaseMIBSystemInfo 1 }
+ptpbaseSystemEntry OBJECT-TYPE
+    SYNTAX          PtpbaseSystemEntry
+    STATUS          current
+    DESCRIPTION
+        "An entry in the table, containing count information about a
+        single domain. New row entries are added when the PTP clock for
+        this domain is configured, while the unconfiguration of the PTP
+        clock removes it."
+    INDEX           {
+                        ptpDomainIndex,
+                        ptpInstanceIndex
+    ::= { ptpbaseSystemTable 1 }
+Shankarkumar et al.     Expires August 6, 2012                [Page 28]
+PtpbaseSystemEntry ::= SEQUENCE {
+        ptpDomainIndex           ClockDomainType,
+        ptpInstanceIndex         ClockInstanceType,
+        ptpDomainClockPortsTotal Gauge32
+ptpDomainIndex OBJECT-TYPE
+    SYNTAX          ClockDomainType
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the domain number used to create logical
+        group of PTP devices. The Clock Domain is a logical group of
+        clocks and devices that synchronize with each other using the
+        PTP protocol.
+        0           Default domain
+    ::= { ptpbaseSystemEntry 1 }
+ptpInstanceIndex OBJECT-TYPE
+    SYNTAX          ClockInstanceType
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the instance of the Clock for this
+        domain."
+    ::= { ptpbaseSystemEntry 2 }
+ptpDomainClockPortsTotal OBJECT-TYPE
+    SYNTAX          Gauge32
+    UNITS           "ptp ports"
+    MAX-ACCESS      read-only
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the total number of clock ports
+        configured within a domain."
+    ::= { ptpbaseSystemEntry 3 }
+ptpbaseSystemDomainTable OBJECT-TYPE
+    SYNTAX          SEQUENCE OF PtpbaseSystemDomainEntry
+Shankarkumar et al.     Expires August 6, 2012                [Page 29]
+    STATUS          current
+    DESCRIPTION
+        "Table of information about the PTP system for all clock modes
+        -- ordinary, boundary or transparent."
+    ::= { ptpbaseMIBSystemInfo 2 }
+ptpbaseSystemDomainEntry OBJECT-TYPE
+    SYNTAX          PtpbaseSystemDomainEntry
+    STATUS          current
+    DESCRIPTION
+        "An entry in the table, containing information about a single
+        clock mode for the PTP system. A row entry gets added when PTP
+        clocks are configured on the router."
+    INDEX           { ptpbaseSystemDomainClockTypeIndex }
+    ::= { ptpbaseSystemDomainTable 1 }
+PtpbaseSystemDomainEntry ::= SEQUENCE {
+        ptpbaseSystemDomainClockTypeIndex ClockType,
+        ptpbaseSystemDomainTotals         Unsigned32
+ptpbaseSystemDomainClockTypeIndex OBJECT-TYPE
+    SYNTAX          ClockType
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the clock type as defined in the
+        Textual convention description."
+    ::= { ptpbaseSystemDomainEntry 1 }
+ptpbaseSystemDomainTotals OBJECT-TYPE
+    SYNTAX          Unsigned32
+    UNITS           "domains"
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the total number of PTP domains for this
+        particular clock type configured in this node."
+    ::= { ptpbaseSystemDomainEntry 2 }
+ptpbaseSystemProfile OBJECT-TYPE
+    SYNTAX          ClockProfileType
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the PTP Profile implemented on the
+Shankarkumar et al.     Expires August 6, 2012                [Page 30]
+        system."
+    REFERENCE       "Section 19.3 PTP profiles of [IEEE 1588-2008]"
+    ::= { ptpbaseMIBSystemInfo 3 }
+ptpbaseClockCurrentDSTable OBJECT-TYPE
+    SYNTAX          SEQUENCE OF PtpbaseClockCurrentDSEntry
+    STATUS          current
+    DESCRIPTION
+        "Table of information about the PTP clock Current Datasets for
+        all domains."
+    ::= { ptpbaseMIBClockInfo 1 }
+ptpbaseClockCurrentDSEntry OBJECT-TYPE
+    SYNTAX          PtpbaseClockCurrentDSEntry
+    STATUS          current
+    DESCRIPTION
+        PTP clock Current Datasets for a domain."
+    REFERENCE
+        "1588 Version 2.0 Section 8.2.2 currentDS data set member
+        specifications of [IEEE 1588-2008]"
+    INDEX           {
+                        ptpbaseClockCurrentDSDomainIndex,
+                        ptpbaseClockCurrentDSClockTypeIndex,
+                        ptpbaseClockCurrentDSInstanceIndex
+    ::= { ptpbaseClockCurrentDSTable 1 }
+PtpbaseClockCurrentDSEntry ::= SEQUENCE {
+        ptpbaseClockCurrentDSDomainIndex      ClockDomainType,
+        ptpbaseClockCurrentDSClockTypeIndex   ClockType,
+        ptpbaseClockCurrentDSInstanceIndex    ClockInstanceType,
+        ptpbaseClockCurrentDSStepsRemoved     Unsigned32,
+        ptpbaseClockCurrentDSOffsetFromMaster ClockTimeInterval,
+        ptpbaseClockCurrentDSMeanPathDelay    ClockTimeInterval
+ptpbaseClockCurrentDSDomainIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        group of PTP devices."
+    ::= { ptpbaseClockCurrentDSEntry 1 }
+ptpbaseClockCurrentDSClockTypeIndex OBJECT-TYPE
+Shankarkumar et al.     Expires August 6, 2012                [Page 31]
+    SYNTAX          ClockType
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockCurrentDSEntry 2 }
+ptpbaseClockCurrentDSInstanceIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the instance of the clock for this clock
+        type in the given domain."
+    ::= { ptpbaseClockCurrentDSEntry 3 }
+ptpbaseClockCurrentDSStepsRemoved OBJECT-TYPE
+    SYNTAX          Unsigned32
+    UNITS           "Steps"
+    STATUS          current
+    DESCRIPTION
+        "The current clock dataset StepsRemoved value.
+        This object specifies the distance measured by the number of
+        Boundary clocks between the local clock and the Foreign master
+        as indicated in the stepsRemoved field of Announce messages."
+    REFERENCE       "1588 Version 2.0 Section 8.2.2.2 stepsRemoved"
+    ::= { ptpbaseClockCurrentDSEntry 4 }
+ptpbaseClockCurrentDSOffsetFromMaster OBJECT-TYPE
+    SYNTAX          ClockTimeInterval
+    UNITS           "Time Interval"
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the current clock dataset ClockOffset
+        value. The value of the computation of the offset in time
+        between a slave and a master clock."
+    REFERENCE       "1588 Version 2.0 Section 8.2.2.3 of
+                     [IEEE 1588-2008]"
+    ::= { ptpbaseClockCurrentDSEntry 5 }
+ptpbaseClockCurrentDSMeanPathDelay OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+Shankarkumar et al.     Expires August 6, 2012                [Page 32]
+        MeanPathDelay value.
+        The mean path delay between a pair of ports as measure by the
+        delay request-response mechanism."
+    REFERENCE       "1588 Version 2.0 Section 8.2.2.4 mean path delay"
+    ::= { ptpbaseClockCurrentDSEntry 6 }
+ptpbaseClockParentDSTable OBJECT-TYPE
+    SYNTAX          SEQUENCE OF PtpbaseClockParentDSEntry
+    STATUS          current
+    DESCRIPTION
+        "Table of information about the PTP clock Parent Datasets for
+        all domains."
+    ::= { ptpbaseMIBClockInfo 2 }
+ptpbaseClockParentDSEntry OBJECT-TYPE
+    SYNTAX          PtpbaseClockParentDSEntry
+    STATUS          current
+    DESCRIPTION
+        PTP clock Parent Datasets for a domain."
+    REFERENCE
+        "Section 8.2.3 parentDS data set member specifications of
+        [IEEE 1588-2008]"
+    INDEX           {
+                        ptpbaseClockParentDSDomainIndex,
+                        ptpbaseClockParentDSClockTypeIndex,
+                        ptpbaseClockParentDSInstanceIndex
+    ::= { ptpbaseClockParentDSTable 1 }
+PtpbaseClockParentDSEntry ::= SEQUENCE {
+    ptpbaseClockParentDSDomainIndex            ClockDomainType,
+    ptpbaseClockParentDSClockTypeIndex         ClockType,
+    ptpbaseClockParentDSInstanceIndex          ClockInstanceType,
+    ptpbaseClockParentDSParentPortIdentity     OCTET STRING,
+    ptpbaseClockParentDSParentStats            TruthValue,
+    ptpbaseClockParentDSOffset                 ClockIntervalBase2,
+    ptpbaseClockParentDSClockPhChRate          Integer32,
+    ptpbaseClockParentDSGMClockIdentity        ClockIdentity,
+    ptpbaseClockParentDSGMClockPriority1       Unsigned32,
+    ptpbaseClockParentDSGMClockPriority2       Unsigned32,
+    ptpbaseClockParentDSGMClockQualityClass    ClockQualityClassType,
+    ptpbaseClockParentDSGMClockQualityAccuracy ClockQualityAccuracyType,
+Shankarkumar et al.     Expires August 6, 2012                [Page 33]
+    ptpbaseClockParentDSGMClockQualityOffset   Unsigned32
+ptpbaseClockParentDSDomainIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockParentDSEntry 1 }
+ptpbaseClockParentDSClockTypeIndex OBJECT-TYPE
+    SYNTAX          ClockType
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockParentDSEntry 2 }
+ptpbaseClockParentDSInstanceIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockParentDSEntry 3 }
+ptpbaseClockParentDSParentPortIdentity OBJECT-TYPE
+    SYNTAX          OCTET STRING(SIZE(1..256))
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the value of portIdentity of the port on
+        the master that issues the Sync messages used in synchronizing
+        this clock."
+    REFERENCE
+        "Section 8.2.3.2 parentDS.parentPortIdentity of
+         [IEEE 1588-2008]"
+    ::= { ptpbaseClockParentDSEntry 4 }
+ptpbaseClockParentDSParentStats OBJECT-TYPE
+    SYNTAX          TruthValue
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the Parent Dataset ParentStats value.
+Shankarkumar et al.     Expires August 6, 2012                [Page 34]
+        This value indicates whether the values of ParentDSOffset
+        and ParentDSClockPhChRate have been measured and are valid.
+        A TRUE value shall indicate valid data."
+    REFERENCE       "Section 8.2.3.3 parentDS.parentStats of
+                     [IEEE 1588-2008]"
+    ::= { ptpbaseClockParentDSEntry 5 }
+ptpbaseClockParentDSOffset OBJECT-TYPE
+    SYNTAX          ClockIntervalBase2 (-128..127)
+    STATUS          current
+    DESCRIPTION
+        ParentOffsetScaledLogVariance value.
+        This value is the variance of the parent clocks phase as
+        measured by the local clock."
+    REFERENCE
+        "Section 8.2.3.4
+        parentDS.observedParentOffsetScaledLogVariance
+        [IEEE 1588-2008]"
+    ::= { ptpbaseClockParentDSEntry 6 }
+ptpbaseClockParentDSClockPhChRate OBJECT-TYPE
+    SYNTAX          Integer32
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the clock's parent dataset
+        ParentClockPhaseChangeRate value.
+        This value is an estimate of the parent clocks phase change
+        rate as measured by the slave clock."
+    REFERENCE
+        "Section 8.2.3.5
+        parentDS.observedParentClockPhaseChangeRate of
+        [IEEE 1588-2008]"
+    ::= { ptpbaseClockParentDSEntry 7 }
+ptpbaseClockParentDSGMClockIdentity OBJECT-TYPE
+    SYNTAX          ClockIdentity
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the parent dataset Grandmaster clock
+        identity."
+    REFERENCE
+        "Section 8.2.3.6 parentDS.grandmasterIdentity of
+Shankarkumar et al.     Expires August 6, 2012                [Page 35]
+         [IEEE 1588-2008]"
+    ::= { ptpbaseClockParentDSEntry 8 }
+ptpbaseClockParentDSGMClockPriority1 OBJECT-TYPE
+    SYNTAX          Unsigned32
+    STATUS          current
+    DESCRIPTION
+        priority1."
+    REFERENCE
+        "Section 8.2.3.8 parentDS.grandmasterPriority1 of
+         [IEEE 1588-2008]"
+    ::= { ptpbaseClockParentDSEntry 9 }
+ptpbaseClockParentDSGMClockPriority2 OBJECT-TYPE
+    SYNTAX          Unsigned32
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the parent dataset grandmaster clock
+        priority2."
+    REFERENCE
+        "Section 8.2.3.9 parentDS.grandmasterPriority2 of
+         [IEEE 1588-2008]"
+    ::= { ptpbaseClockParentDSEntry 10 }
+ptpbaseClockParentDSGMClockQualityClass OBJECT-TYPE
+    SYNTAX          ClockQualityClassType (0..255)
+    STATUS          current
+    DESCRIPTION
+        quality class."
+    REFERENCE
+        "Section 8.2.3.7 parentDS.grandmasterClockQuality of
+         [IEEE 1588-2008]"
+    ::= { ptpbaseClockParentDSEntry 11 }
+ptpbaseClockParentDSGMClockQualityAccuracy OBJECT-TYPE
+    SYNTAX          ClockQualityAccuracyType
+    STATUS          current
+    DESCRIPTION
+        quality accuracy."
+    REFERENCE
+         [IEEE 1588-2008]"
+Shankarkumar et al.     Expires August 6, 2012                [Page 36]
+    ::= { ptpbaseClockParentDSEntry 12 }
+ptpbaseClockParentDSGMClockQualityOffset OBJECT-TYPE
+    SYNTAX          Unsigned32
+    STATUS          current
+    DESCRIPTION
+        quality offset."
+    REFERENCE
+         [IEEE 1588-2008]"
+    ::= { ptpbaseClockParentDSEntry 13 }
+ptpbaseClockDefaultDSTable OBJECT-TYPE
+    SYNTAX          SEQUENCE OF PtpbaseClockDefaultDSEntry
+    STATUS          current
+    DESCRIPTION
+        "Table of information about the PTP clock Default Datasets for
+        all domains."
+    ::= { ptpbaseMIBClockInfo 3 }
+ptpbaseClockDefaultDSEntry OBJECT-TYPE
+    SYNTAX          PtpbaseClockDefaultDSEntry
+    STATUS          current
+    DESCRIPTION
+        PTP clock Default Datasets for a domain."
+    INDEX           {
+                        ptpbaseClockDefaultDSDomainIndex,
+                        ptpbaseClockDefaultDSClockTypeIndex,
+                        ptpbaseClockDefaultDSInstanceIndex
+    ::= { ptpbaseClockDefaultDSTable 1 }
+PtpbaseClockDefaultDSEntry ::= SEQUENCE {
+        ptpbaseClockDefaultDSDomainIndex     ClockDomainType,
+        ptpbaseClockDefaultDSClockTypeIndex  ClockType,
+        ptpbaseClockDefaultDSInstanceIndex   ClockInstanceType,
+        ptpbaseClockDefaultDSTwoStepFlag     TruthValue,
+        ptpbaseClockDefaultDSClockIdentity   ClockIdentity,
+        ptpbaseClockDefaultDSPriority1       Unsigned32,
+        ptpbaseClockDefaultDSPriority2       Unsigned32,
+        ptpbaseClockDefaultDSSlaveOnly       TruthValue,
+        ptpbaseClockDefaultDSQualityClass    ClockQualityClassType,
+Shankarkumar et al.     Expires August 6, 2012                [Page 37]
+        ptpbaseClockDefaultDSQualityAccuracy ClockQualityAccuracyType,
+        ptpbaseClockDefaultDSQualityOffset   Integer32
+ptpbaseClockDefaultDSDomainIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockDefaultDSEntry 1 }
+ptpbaseClockDefaultDSClockTypeIndex OBJECT-TYPE
+    SYNTAX          ClockType
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockDefaultDSEntry 2 }
+ptpbaseClockDefaultDSInstanceIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockDefaultDSEntry 3 }
+ptpbaseClockDefaultDSTwoStepFlag OBJECT-TYPE
+    SYNTAX          TruthValue
+    STATUS          current
+    DESCRIPTION
+        "This object specifies whether the Two Step process is used."
+    ::= { ptpbaseClockDefaultDSEntry 4 }
+ptpbaseClockDefaultDSClockIdentity OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the default Datasets clock identity."
+    ::= { ptpbaseClockDefaultDSEntry 5 }
+ptpbaseClockDefaultDSPriority1 OBJECT-TYPE
+    SYNTAX          Unsigned32
+Shankarkumar et al.     Expires August 6, 2012                [Page 38]
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the default Datasets clock Priority1."
+    ::= { ptpbaseClockDefaultDSEntry 6 }
+ptpbaseClockDefaultDSPriority2 OBJECT-TYPE
+    SYNTAX          Unsigned32
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the default Datasets clock Priority2."
+    ::= { ptpbaseClockDefaultDSEntry 7 }
+ptpbaseClockDefaultDSSlaveOnly OBJECT-TYPE
+    SYNTAX          TruthValue
+    STATUS          current
+    DESCRIPTION
+        "Whether the SlaveOnly flag is set."
+    ::= { ptpbaseClockDefaultDSEntry 8 }
+ptpbaseClockDefaultDSQualityClass OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the default dataset Quality Class."
+    ::= { ptpbaseClockDefaultDSEntry 9 }
+ptpbaseClockDefaultDSQualityAccuracy OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the default dataset Quality Accurarcy."
+    ::= { ptpbaseClockDefaultDSEntry 10 }
+ptpbaseClockDefaultDSQualityOffset OBJECT-TYPE
+    SYNTAX          Integer32
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the default dataset Quality offset."
+    ::= { ptpbaseClockDefaultDSEntry 11 }
+ptpbaseClockRunningTable OBJECT-TYPE
+Shankarkumar et al.     Expires August 6, 2012                [Page 39]
+    SYNTAX          SEQUENCE OF PtpbaseClockRunningEntry
+    STATUS          current
+    DESCRIPTION
+        "Table of information about the PTP clock Running Datasets for
+        all domains."
+    ::= { ptpbaseMIBClockInfo 4 }
+ptpbaseClockRunningEntry OBJECT-TYPE
+    SYNTAX          PtpbaseClockRunningEntry
+    STATUS          current
+    DESCRIPTION
+        PTP clock running Datasets for a domain."
+    INDEX           {
+                        ptpbaseClockRunningDomainIndex,
+                        ptpbaseClockRunningClockTypeIndex,
+                        ptpbaseClockRunningInstanceIndex
+    ::= { ptpbaseClockRunningTable 1 }
+PtpbaseClockRunningEntry ::= SEQUENCE {
+        ptpbaseClockRunningDomainIndex     ClockDomainType,
+        ptpbaseClockRunningClockTypeIndex  ClockType,
+        ptpbaseClockRunningInstanceIndex   ClockInstanceType,
+        ptpbaseClockRunningState           ClockStateType,
+        ptpbaseClockRunningPacketsSent     Counter64,
+        ptpbaseClockRunningPacketsReceived Counter64
+ptpbaseClockRunningDomainIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockRunningEntry 1 }
+ptpbaseClockRunningClockTypeIndex OBJECT-TYPE
+    SYNTAX          ClockType
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockRunningEntry 2 }
+Shankarkumar et al.     Expires August 6, 2012                [Page 40]
+ptpbaseClockRunningInstanceIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockRunningEntry 3 }
+ptpbaseClockRunningState OBJECT-TYPE
+    SYNTAX          ClockStateType
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the Clock state returned by PTP engine
+        which was described earlier.
+        Freerun state. Applies to a slave device that is not locked to
+        a master. This is the initial state a slave starts out with
+        when
+        it is not getting any PTP packets from the master or because of
+        some other input error (erroneous packets, etc).
+        Holdover state. In this state the slave device is locked to a
+        master but communication with the master is lost or the
+        timestamps in the ptp packets are incorrect. But since the
+        slave was locked to the master, it can run with the same
+        accuracy for
+        sometime. The slave can continue to operate in this state for
+        some time. If communication with the master is not restored for
+        a while, the device is moved to the FREERUN state.
+        Acquiring state. The slave device is receiving packets from a
+        master and is trying to acquire a lock.
+        Freq_locked state. Slave device is locked to the Master with
+        respect to frequency, but not phase aligned
+        Phase_aligned state. Locked to the master with respect to
+    ::= { ptpbaseClockRunningEntry 4 }
+ptpbaseClockRunningPacketsSent OBJECT-TYPE
+    SYNTAX          Counter64
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the total number of all packet Unicast
+        and multicast that have been sent out for this clock in this
+Shankarkumar et al.     Expires August 6, 2012                [Page 41]
+        domain for this type."
+    ::= { ptpbaseClockRunningEntry 5 }
+ptpbaseClockRunningPacketsReceived OBJECT-TYPE
+    SYNTAX          Counter64
+    STATUS          current
+    DESCRIPTION
+        and multicast that have been received for this clock in this
+    ::= { ptpbaseClockRunningEntry 6 }
+ptpbaseClockTimePropertiesDSTable OBJECT-TYPE
+    SYNTAX          SEQUENCE OF PtpbaseClockTimePropertiesDSEntry
+    STATUS          current
+    DESCRIPTION
+        "Table of information about the PTP clock Timeproperties
+        Datasets for all domains."
+    ::= { ptpbaseMIBClockInfo 5 }
+ptpbaseClockTimePropertiesDSEntry OBJECT-TYPE
+    SYNTAX          PtpbaseClockTimePropertiesDSEntry
+    STATUS          current
+    DESCRIPTION
+        PTP clock timeproperties Datasets for a domain."
+    REFERENCE       "Section 8.2.4 of [IEEE 1588-2008]"
+    INDEX           {
+                        ptpbaseClockTimePropertiesDSDomainIndex,
+                        ptpbaseClockTimePropertiesDSClockTypeIndex,
+                        ptpbaseClockTimePropertiesDSInstanceIndex
+    ::= { ptpbaseClockTimePropertiesDSTable 1 }
+PtpbaseClockTimePropertiesDSEntry ::= SEQUENCE {
+  ptpbaseClockTimePropertiesDSDomainIndex           ClockDomainType,
+  ptpbaseClockTimePropertiesDSClockTypeIndex        ClockType,
+  ptpbaseClockTimePropertiesDSInstanceIndex         ClockInstanceType,
+  ptpbaseClockTimePropertiesDSCurrentUTCOffsetValid TruthValue,
+  ptpbaseClockTimePropertiesDSCurrentUTCOffset      Integer32,
+  ptpbaseClockTimePropertiesDSLeap59                TruthValue,
+  ptpbaseClockTimePropertiesDSLeap61                TruthValue,
+  ptpbaseClockTimePropertiesDSTimeTraceable         TruthValue,
+  ptpbaseClockTimePropertiesDSFreqTraceable         TruthValue,
+Shankarkumar et al.     Expires August 6, 2012                [Page 42]
+  ptpbaseClockTimePropertiesDSPTPTimescale          TruthValue,
+  ptpbaseClockTimePropertiesDSSource                ClockTimeSourceType
+ptpbaseClockTimePropertiesDSDomainIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockTimePropertiesDSEntry 1 }
+ptpbaseClockTimePropertiesDSClockTypeIndex OBJECT-TYPE
+    SYNTAX          ClockType
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockTimePropertiesDSEntry 2 }
+ptpbaseClockTimePropertiesDSInstanceIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockTimePropertiesDSEntry 3 }
+ptpbaseClockTimePropertiesDSCurrentUTCOffsetValid OBJECT-TYPE
+    SYNTAX          TruthValue
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the timeproperties dataset value of
+        whether current UTC offset is valid."
+    REFERENCE       "Section 8.2.4.2 of [IEEE 1588-2008]"
+    ::= { ptpbaseClockTimePropertiesDSEntry 4 }
+ptpbaseClockTimePropertiesDSCurrentUTCOffset OBJECT-TYPE
+    SYNTAX          Integer32
+    STATUS          current
+    DESCRIPTION
+        current UTC offset.
+Shankarkumar et al.     Expires August 6, 2012                [Page 43]
+        In PTP systems whose epoch is the PTP epoch, the value of
+        timePropertiesDS.currentUtcOffset is the offset
+        between TAI and UTC; otherwise the value has no meaning. The
+        value shall be in units of seconds.
+        The initialization value shall be selected as follows:
+        a) If the timePropertiesDS.ptpTimescale (see 8.2.4.8) is TRUE,
+        the value is the value obtained from a
+        primary reference if the value is known at the time of
+        initialization, else.
+        b) The value shall be the current number of leap seconds (7.2.3)
+        when the node is designed."
+    REFERENCE       "Section 8.2.4.3 of [IEEE 1588-2008]"
+    ::= { ptpbaseClockTimePropertiesDSEntry 5 }
+ptpbaseClockTimePropertiesDSLeap59 OBJECT-TYPE
+    SYNTAX          TruthValue
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the Leap59 value in the clock Current
+        Dataset."
+    REFERENCE       "Section 8.2.4.4 of [IEEE 1588-2008]"
+    ::= { ptpbaseClockTimePropertiesDSEntry 6 }
+ptpbaseClockTimePropertiesDSLeap61 OBJECT-TYPE
+    SYNTAX          TruthValue
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the Leap61 value in the clock Current
+        Dataset."
+    REFERENCE       "Section 8.2.4.5 of [IEEE 1588-2008]"
+    ::= { ptpbaseClockTimePropertiesDSEntry 7 }
+ptpbaseClockTimePropertiesDSTimeTraceable OBJECT-TYPE
+    SYNTAX          TruthValue
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the Timetraceable value in the clock
+        Current Dataset."
+    REFERENCE       "Section 8.2.4.6 of [IEEE 1588-2008]"
+    ::= { ptpbaseClockTimePropertiesDSEntry 8 }
+ptpbaseClockTimePropertiesDSFreqTraceable OBJECT-TYPE
+    SYNTAX          TruthValue
+    STATUS          current
+    DESCRIPTION
+Shankarkumar et al.     Expires August 6, 2012                [Page 44]
+        "This object specifies the Frequency Traceable value in the
+        clock Current Dataset."
+    REFERENCE       "Section 8.2.4.7 of [IEEE 1588-2008]"
+    ::= { ptpbaseClockTimePropertiesDSEntry 9 }
+ptpbaseClockTimePropertiesDSPTPTimescale OBJECT-TYPE
+    SYNTAX          TruthValue
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the PTP Timescale value in the clock
+        Current Dataset."
+    REFERENCE       "Section 8.2.4.8 of [IEEE 1588-2008]"
+    ::= { ptpbaseClockTimePropertiesDSEntry 10 }
+ptpbaseClockTimePropertiesDSSource OBJECT-TYPE
+    SYNTAX          ClockTimeSourceType
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the Timesource value in the clock Current
+        Dataset."
+    REFERENCE       "Section 8.2.4.9 of [IEEE 1588-2008]"
+    ::= { ptpbaseClockTimePropertiesDSEntry 11 }
+ptpbaseClockTransDefaultDSTable OBJECT-TYPE
+    SYNTAX          SEQUENCE OF PtpbaseClockTransDefaultDSEntry
+    STATUS          current
+    DESCRIPTION
+        "Table of information about the PTP Transparent clock Default
+    ::= { ptpbaseMIBClockInfo 6 }
+ptpbaseClockTransDefaultDSEntry OBJECT-TYPE
+    SYNTAX          PtpbaseClockTransDefaultDSEntry
+    STATUS          current
+    DESCRIPTION
+        PTP Transparent clock Default Datasets for a domain."
+    REFERENCE       "Section 8.3.2 of [IEEE 1588-2008]"
+    INDEX           {
+                        ptpbaseClockTransDefaultDSDomainIndex,
+                        ptpbaseClockTransDefaultDSInstanceIndex
+    ::= { ptpbaseClockTransDefaultDSTable 1 }
+Shankarkumar et al.     Expires August 6, 2012                [Page 45]
+PtpbaseClockTransDefaultDSEntry ::= SEQUENCE {
+        ptpbaseClockTransDefaultDSDomainIndex   ClockDomainType,
+        ptpbaseClockTransDefaultDSInstanceIndex ClockInstanceType,
+        ptpbaseClockTransDefaultDSClockIdentity ClockIdentity,
+        ptpbaseClockTransDefaultDSNumOfPorts    Counter32,
+        ptpbaseClockTransDefaultDSDelay         ClockMechanismType,
+        ptpbaseClockTransDefaultDSPrimaryDomain Integer32
+ptpbaseClockTransDefaultDSDomainIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockTransDefaultDSEntry 1 }
+ptpbaseClockTransDefaultDSInstanceIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockTransDefaultDSEntry 2 }
+ptpbaseClockTransDefaultDSClockIdentity OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the value of the clockIdentity attribute
+        of the local clock."
+    REFERENCE       "Section 8.3.2.2.1 of [IEEE 1588-2008]"
+    ::= { ptpbaseClockTransDefaultDSEntry 3 }
+ptpbaseClockTransDefaultDSNumOfPorts OBJECT-TYPE
+    SYNTAX          Counter32
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the number of PTP ports of the device."
+    REFERENCE       "Section 8.3.2.2.2 of [IEEE 1588-2008]"
+    ::= { ptpbaseClockTransDefaultDSEntry 4 }
+ptpbaseClockTransDefaultDSDelay OBJECT-TYPE
+    SYNTAX          ClockMechanismType
+Shankarkumar et al.     Expires August 6, 2012                [Page 46]
+    STATUS          current
+    DESCRIPTION
+        "This object, if the transparent clock is an end-to-end
+        transparent clock, has the value shall be E2E; If the
+        transparent clock is a peer-to-peer transparent clock, the
+        value
+        shall be P2P."
+    REFERENCE       "Section 8.3.2.3.1 of [IEEE 1588-2008]"
+    ::= { ptpbaseClockTransDefaultDSEntry 5 }
+ptpbaseClockTransDefaultDSPrimaryDomain OBJECT-TYPE
+    SYNTAX          Integer32
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the value of the primary syntonization
+        domain. The initialization value shall be 0."
+    REFERENCE       "Section 8.3.2.3.2 of [IEEE 1588-2008]"
+    ::= { ptpbaseClockTransDefaultDSEntry 6 }
+ptpbaseClockPortTable OBJECT-TYPE
+    SYNTAX          SEQUENCE OF PtpbaseClockPortEntry
+    STATUS          current
+    DESCRIPTION
+        "Table of information about the clock ports for a particular
+        domain."
+    ::= { ptpbaseMIBClockInfo 7 }
+ptpbaseClockPortEntry OBJECT-TYPE
+    SYNTAX          PtpbaseClockPortEntry
+    STATUS          current
+    DESCRIPTION
+        clock port."
+    INDEX           {
+                        ptpbaseClockPortDomainIndex,
+                        ptpbaseClockPortClockTypeIndex,
+                        ptpbaseClockPortClockInstanceIndex,
+                        ptpbaseClockPortTablePortNumberIndex
+    ::= { ptpbaseClockPortTable 1 }
+PtpbaseClockPortEntry ::= SEQUENCE {
+        ptpbaseClockPortDomainIndex            ClockDomainType,
+Shankarkumar et al.     Expires August 6, 2012                [Page 47]
+        ptpbaseClockPortClockTypeIndex         ClockType,
+        ptpbaseClockPortClockInstanceIndex     ClockInstanceType,
+        ptpbaseClockPortTablePortNumberIndex   ClockPortNumber,
+        ptpbaseClockPortName                   DisplayString,
+        ptpbaseClockPortRole                   ClockRoleType,
+        ptpbaseClockPortSyncOneStep            TruthValue,
+        ptpbaseClockPortCurrentPeerAddressType InetAddressType,
+        ptpbaseClockPortCurrentPeerAddress     InetAddress,
+        ptpbaseClockPortNumOfAssociatedPorts   Gauge32
+ptpbaseClockPortDomainIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockPortEntry 1 }
+ptpbaseClockPortClockTypeIndex OBJECT-TYPE
+    SYNTAX          ClockType
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockPortEntry 2 }
+ptpbaseClockPortClockInstanceIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockPortEntry 3 }
+ptpbaseClockPortTablePortNumberIndex OBJECT-TYPE
+    SYNTAX          ClockPortNumber (1..65535)
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the PTP Portnumber for this port."
+    ::= { ptpbaseClockPortEntry 4 }
+ptpbaseClockPortName OBJECT-TYPE
+    SYNTAX          DisplayString (SIZE  (1..64))
+Shankarkumar et al.     Expires August 6, 2012                [Page 48]
+Internet-Draft      draft-ietf-tictoc-ptp-mib-01.txt   February 6, 2012
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the PTP clock port name configured on the
+        router."
+    ::= { ptpbaseClockPortEntry 5 }
+ptpbaseClockPortRole OBJECT-TYPE
+    SYNTAX          ClockRoleType
+    STATUS          current
+    DESCRIPTION
+        "This object describes the current role (slave/master) of the
+        port."
+    ::= { ptpbaseClockPortEntry 6 }
+ptpbaseClockPortSyncOneStep OBJECT-TYPE
+    SYNTAX          TruthValue
+    STATUS          current
+    DESCRIPTION
+        "This object specifies that one-step clock operation between
+        the PTP master and slave device is enabled."
+    ::= { ptpbaseClockPortEntry 7 }
+ptpbaseClockPortCurrentPeerAddressType OBJECT-TYPE
+    SYNTAX          InetAddressType
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the current peer's network address used
+        for PTP communication. Based on the scenario and the setup
+        involved, the values might look like these -
+        Scenario                   Value
+        Single Master          master port
+        Multiple Masters       selected master port
+        Single Slave           slave port
+        Multiple Slaves        <empty>
+        (In relevant setups, information on available
+        slaves and available masters will be available through
+        ptpClockPortAssociateTable)"
+    ::= { ptpbaseClockPortEntry 8 }
+ptpbaseClockPortCurrentPeerAddress OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+Shankarkumar et al.     Expires August 6, 2012                [Page 49]
+        Scenario                   Value
+    ::= { ptpbaseClockPortEntry 9 }
+ptpbaseClockPortNumOfAssociatedPorts OBJECT-TYPE
+    SYNTAX          Gauge32
+    STATUS          current
+    DESCRIPTION
+        "This object specifies -
+        For a master port - the number of PTP slave sessions (peers)
+        associated with this PTP port.
+        For a slave port - the number of masters available to this slave
+        port (might or might not be peered)."
+    ::= { ptpbaseClockPortEntry 10 }
+ptpbaseClockPortDSTable OBJECT-TYPE
+    SYNTAX          SEQUENCE OF PtpbaseClockPortDSEntry
+    STATUS          current
+    DESCRIPTION
+        "Table of information about the clock ports dataset for a
+        particular domain."
+    ::= { ptpbaseMIBClockInfo 8 }
+ptpbaseClockPortDSEntry OBJECT-TYPE
+    SYNTAX          PtpbaseClockPortDSEntry
+    STATUS          current
+    DESCRIPTION
+        "An entry in the table, containing port dataset information for
+        a single clock port."
+    INDEX           {
+                        ptpbaseClockPortDSDomainIndex,
+                        ptpbaseClockPortDSClockTypeIndex,
+                        ptpbaseClockPortDSClockInstanceIndex,
+Shankarkumar et al.     Expires August 6, 2012                [Page 50]
+                        ptpbaseClockPortDSPortNumberIndex
+    ::= { ptpbaseClockPortDSTable 1 }
+PtpbaseClockPortDSEntry ::= SEQUENCE {
+        ptpbaseClockPortDSDomainIndex          ClockDomainType,
+        ptpbaseClockPortDSClockTypeIndex       ClockType,
+        ptpbaseClockPortDSClockInstanceIndex   ClockInstanceType,
+        ptpbaseClockPortDSPortNumberIndex      ClockPortNumber,
+        ptpbaseClockPortDSName                 DisplayString,
+        ptpbaseClockPortDSPortIdentity         OCTET STRING,
+        ptpbaseClockPortDSAnnouncementInterval Integer32,
+        ptpbaseClockPortDSAnnounceRctTimeout   Integer32,
+        ptpbaseClockPortDSSyncInterval         Integer32,
+        ptpbaseClockPortDSMinDelayReqInterval  Integer32,
+        ptpbaseClockPortDSPeerDelayReqInterval Integer32,
+        ptpbaseClockPortDSDelayMech            ClockMechanismType,
+        ptpbaseClockPortDSPeerMeanPathDelay    ClockTimeInterval,
+        ptpbaseClockPortDSGrantDuration        Unsigned32,
+        ptpbaseClockPortDSPTPVersion           Integer32
+ptpbaseClockPortDSDomainIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockPortDSEntry 1 }
+ptpbaseClockPortDSClockTypeIndex OBJECT-TYPE
+    SYNTAX          ClockType
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockPortDSEntry 2 }
+ptpbaseClockPortDSClockInstanceIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockPortDSEntry 3 }
+Shankarkumar et al.     Expires August 6, 2012                [Page 51]
+ptpbaseClockPortDSPortNumberIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the PTP portnumber associated with this
+        PTP port."
+    ::= { ptpbaseClockPortDSEntry 4 }
+ptpbaseClockPortDSName OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the PTP clock port name."
+    ::= { ptpbaseClockPortDSEntry 5 }
+ptpbaseClockPortDSPortIdentity OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the PTP clock port Identity."
+    ::= { ptpbaseClockPortDSEntry 6 }
+ptpbaseClockPortDSAnnouncementInterval OBJECT-TYPE
+    SYNTAX          Integer32
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the Announce message transmission
+        interval associated with this clock port."
+    ::= { ptpbaseClockPortDSEntry 7 }
+ptpbaseClockPortDSAnnounceRctTimeout OBJECT-TYPE
+    SYNTAX          Integer32
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the Announce receipt timeout associated
+        with this clock port."
+    ::= { ptpbaseClockPortDSEntry 8 }
+ptpbaseClockPortDSSyncInterval OBJECT-TYPE
+    SYNTAX          Integer32
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the Sync message transmission interval."
+Shankarkumar et al.     Expires August 6, 2012                [Page 52]
+    ::= { ptpbaseClockPortDSEntry 9 }
+ptpbaseClockPortDSMinDelayReqInterval OBJECT-TYPE
+    SYNTAX          Integer32
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the Delay_Req message transmission
+        interval."
+    ::= { ptpbaseClockPortDSEntry 10 }
+ptpbaseClockPortDSPeerDelayReqInterval OBJECT-TYPE
+    SYNTAX          Integer32
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the Pdelay_Req message transmission
+        interval."
+    ::= { ptpbaseClockPortDSEntry 11 }
+ptpbaseClockPortDSDelayMech OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the delay mechanism used. If the clock
+        is an end-to-end clock, the value of the is e2e, else if the
+        clock is a peer to-peer clock, the value shall be p2p."
+    ::= { ptpbaseClockPortDSEntry 12 }
+ptpbaseClockPortDSPeerMeanPathDelay OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the peer meanPathDelay."
+    ::= { ptpbaseClockPortDSEntry 13 }
+ptpbaseClockPortDSGrantDuration OBJECT-TYPE
+    SYNTAX          Unsigned32
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the grant duration allocated by the
+        master."
+    ::= { ptpbaseClockPortDSEntry 14 }
+ptpbaseClockPortDSPTPVersion OBJECT-TYPE
+    SYNTAX          Integer32
+Shankarkumar et al.     Expires August 6, 2012                [Page 53]
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the PTP version being used."
+    ::= { ptpbaseClockPortDSEntry 15 }
+ptpbaseClockPortRunningTable OBJECT-TYPE
+    SYNTAX          SEQUENCE OF PtpbaseClockPortRunningEntry
+    STATUS          current
+    DESCRIPTION
+        "Table of information about the clock ports running dataset for
+        a particular domain."
+    ::= { ptpbaseMIBClockInfo 9 }
+ptpbaseClockPortRunningEntry OBJECT-TYPE
+    SYNTAX          PtpbaseClockPortRunningEntry
+    STATUS          current
+    DESCRIPTION
+        "An entry in the table, containing runing dataset information
+        about a single clock port."
+    INDEX           {
+                        ptpbaseClockPortRunningDomainIndex,
+                        ptpbaseClockPortRunningClockTypeIndex,
+                        ptpbaseClockPortRunningClockInstanceIndex,
+                        ptpbaseClockPortRunningPortNumberIndex
+    ::= { ptpbaseClockPortRunningTable 1 }
+PtpbaseClockPortRunningEntry ::= SEQUENCE {
+        ptpbaseClockPortRunningDomainIndex        ClockDomainType,
+        ptpbaseClockPortRunningClockTypeIndex     ClockType,
+        ptpbaseClockPortRunningClockInstanceIndex ClockInstanceType,
+        ptpbaseClockPortRunningPortNumberIndex    ClockPortNumber,
+        ptpbaseClockPortRunningName               DisplayString,
+        ptpbaseClockPortRunningState              ClockPortState,
+        ptpbaseClockPortRunningRole               ClockRoleType,
+        ptpbaseClockPortRunningInterfaceIndex     InterfaceIndexOrZero,
+        ptpbaseClockPortRunningIPversion          Integer32,
+        ptpbaseClockPortRunningEncapsulationType  Integer32,
+        ptpbaseClockPortRunningTxMode             ClockTxModeType,
+        ptpbaseClockPortRunningRxMode             ClockTxModeType,
+        ptpbaseClockPortRunningPacketsReceived    Counter64,
+        ptpbaseClockPortRunningPacketsSent        Counter64
+Shankarkumar et al.     Expires August 6, 2012                [Page 54]
+ptpbaseClockPortRunningDomainIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockPortRunningEntry 1 }
+ptpbaseClockPortRunningClockTypeIndex OBJECT-TYPE
+    SYNTAX          ClockType
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockPortRunningEntry 2 }
+ptpbaseClockPortRunningClockInstanceIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockPortRunningEntry 3 }
+ptpbaseClockPortRunningPortNumberIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        clock port."
+    ::= { ptpbaseClockPortRunningEntry 4 }
+ptpbaseClockPortRunningName OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockPortRunningEntry 5 }
+ptpbaseClockPortRunningState OBJECT-TYPE
+    SYNTAX          ClockPortState
+    STATUS          current
+    DESCRIPTION
+Shankarkumar et al.     Expires August 6, 2012                [Page 55]
+        "This object specifies the port state returned by PTP engine.
+        initializing - In this state a port initializes
+        faulty       - The fault state of the protocol.
+        disabled     - The port shall not place any
+        listening    - The port is waiting for the
+                       a master.
+        preMaster    - The port shall behave in all respects
+        master       - The port is behaving as a master port.
+        passive      - The port shall not place any
+                       that are a required response to
+                       another management message
+        uncalibrated - The local port is preparing to
+        slave        - The port is synchronizing to the
+    ::= { ptpbaseClockPortRunningEntry 6 }
+ptpbaseClockPortRunningRole OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the Clock Role."
+    ::= { ptpbaseClockPortRunningEntry 7 }
+ptpbaseClockPortRunningInterfaceIndex OBJECT-TYPE
+    SYNTAX          InterfaceIndexOrZero
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the interface on the router being used by
+        the PTP Clock for PTP communication."
+    ::= { ptpbaseClockPortRunningEntry 8 }
+Shankarkumar et al.     Expires August 6, 2012                [Page 56]
+ptpbaseClockPortRunningIPversion OBJECT-TYPE
+    SYNTAX          Integer32
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the IP version being used for PTP
+        communication (the mapping used)."
+    ::= { ptpbaseClockPortRunningEntry 9 }
+ptpbaseClockPortRunningEncapsulationType OBJECT-TYPE
+    SYNTAX          Integer32
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the type of encapsulation if the
+        interface is adding extra layers (eg. VLAN, Pseudowire
+        encapsulation...) for the PTP messages."
+    ::= { ptpbaseClockPortRunningEntry 10 }
+ptpbaseClockPortRunningTxMode OBJECT-TYPE
+    SYNTAX          ClockTxModeType
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the clock transmission mode as
+        unicast:       Using unicast communication channel.
+        multicast:     Using Multicast communication channel.
+        multicast-mix: Using multicast-unicast communication channel"
+    ::= { ptpbaseClockPortRunningEntry 11 }
+ptpbaseClockPortRunningRxMode OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifie the clock receive mode as
+    ::= { ptpbaseClockPortRunningEntry 12 }
+ptpbaseClockPortRunningPacketsReceived OBJECT-TYPE
+    SYNTAX          Counter64
+    UNITS           "packets"
+    STATUS          current
+Shankarkumar et al.     Expires August 6, 2012                [Page 57]
+    DESCRIPTION
+        "This object specifies the packets received on the clock port
+        (cummulative)."
+    ::= { ptpbaseClockPortRunningEntry 13 }
+ptpbaseClockPortRunningPacketsSent OBJECT-TYPE
+    SYNTAX          Counter64
+    UNITS           "packets"
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the packets sent on the clock port
+        (cummulative)."
+    ::= { ptpbaseClockPortRunningEntry 14 }
+ptpbaseClockPortTransDSTable OBJECT-TYPE
+    SYNTAX          SEQUENCE OF PtpbaseClockPortTransDSEntry
+    STATUS          current
+    DESCRIPTION
+        "Table of information about the Transparent clock ports running
+        dataset for a particular domain."
+    ::= { ptpbaseMIBClockInfo 10 }
+ptpbaseClockPortTransDSEntry OBJECT-TYPE
+    SYNTAX          PtpbaseClockPortTransDSEntry
+    STATUS          current
+    DESCRIPTION
+        "An entry in the table, containing clock port Transparent
+        dataset information about a single clock port"
+    INDEX           {
+                        ptpbaseClockPortTransDSDomainIndex,
+                        ptpbaseClockPortTransDSInstanceIndex,
+                        ptpbaseClockPortTransDSPortNumberIndex
+    ::= { ptpbaseClockPortTransDSTable 1 }
+PtpbaseClockPortTransDSEntry ::= SEQUENCE {
+        ptpbaseClockPortTransDSDomainIndex        ClockDomainType,
+        ptpbaseClockPortTransDSInstanceIndex      ClockInstanceType,
+        ptpbaseClockPortTransDSPortNumberIndex    ClockPortNumber,
+        ptpbaseClockPortTransDSPortIdentity       ClockIdentity,
+        ptpbaseClockPortTransDSlogMinPdelayReqInt Integer32,
+        ptpbaseClockPortTransDSFaultyFlag         TruthValue,
+        ptpbaseClockPortTransDSPeerMeanPathDelay  ClockTimeInterval
+Shankarkumar et al.     Expires August 6, 2012                [Page 58]
+ptpbaseClockPortTransDSDomainIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockPortTransDSEntry 1 }
+ptpbaseClockPortTransDSInstanceIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockPortTransDSEntry 2 }
+ptpbaseClockPortTransDSPortNumberIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the PTP port number associated with this
+        port."
+    REFERENCE       "Section 7.5.2 Port Identity [IEEE 1588-2008]"
+    ::= { ptpbaseClockPortTransDSEntry 3 }
+ptpbaseClockPortTransDSPortIdentity OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the value of the PortIdentity
+        attribute of the local port."
+    REFERENCE       "Section 8.3.3.2.1 of [IEEE 1588-2008]"
+    ::= { ptpbaseClockPortTransDSEntry 4 }
+ptpbaseClockPortTransDSlogMinPdelayReqInt OBJECT-TYPE
+    SYNTAX          Integer32
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the value of the logarithm to the
+        base 2 of the minPdelayReqInterval."
+    REFERENCE       "Section 8.3.3.3.1 of [IEEE 1588-2008]"
+    ::= { ptpbaseClockPortTransDSEntry 5 }
+Shankarkumar et al.     Expires August 6, 2012                [Page 59]
+ptpbaseClockPortTransDSFaultyFlag OBJECT-TYPE
+    SYNTAX          TruthValue
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the value TRUE if the port is faulty
+        and FALSE if the port is operating normally."
+    REFERENCE       "Section 8.3.3.3.2 of [IEEE 1588-2008]"
+    ::= { ptpbaseClockPortTransDSEntry 6 }
+ptpbaseClockPortTransDSPeerMeanPathDelay OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies, (if the delayMechanism used is P2P) the
+        value is the estimate of the current one-way propagation delay,
+        i.e., <meanPathDelay> on the link attached to this port
+        computed
+        using the peer delay mechanism. If the value of the
+        delayMechanism
+        used is E2E, then the value will be zero."
+    REFERENCE       "Section 8.3.3.3.3 of [IEEE 1588-2008]"
+    ::= { ptpbaseClockPortTransDSEntry 7 }
+ptpbaseClockPortAssociateTable OBJECT-TYPE
+    SYNTAX          SEQUENCE OF PtpbaseClockPortAssociateEntry
+    STATUS          current
+    DESCRIPTION
+        "Table of information about a given port's associated ports.
+        For a master port - multiple slave ports which have established
+        sessions with the current master port.
+        For a slave port - the list of masters available for a given
+        slave port.
+        Session information (pkts, errors) to be displayed based on
+        availability and scenario."
+    ::= { ptpbaseMIBClockInfo 11 }
+ptpbaseClockPortAssociateEntry OBJECT-TYPE
+    SYNTAX          PtpbaseClockPortAssociateEntry
+    STATUS          current
+    DESCRIPTION
+Shankarkumar et al.     Expires August 6, 2012                [Page 60]
+        associated port for the given clockport."
+    INDEX           {
+                        ptpClockPortCurrentDomainIndex,
+                        ptpClockPortCurrentClockTypeIndex,
+                        ptpClockPortCurrentClockInstanceIndex,
+                        ptpClockPortCurrentPortNumberIndex,
+                        ptpbaseClockPortAssociatePortIndex
+    ::= { ptpbaseClockPortAssociateTable 1 }
+PtpbaseClockPortAssociateEntry ::= SEQUENCE {
+        ptpClockPortCurrentDomainIndex           ClockDomainType,
+        ptpClockPortCurrentClockTypeIndex        ClockType,
+        ptpClockPortCurrentClockInstanceIndex    ClockInstanceType,
+        ptpClockPortCurrentPortNumberIndex       ClockPortNumber,
+        ptpbaseClockPortAssociatePortIndex       Unsigned32,
+        ptpbaseClockPortAssociateAddressType     InetAddressType,
+        ptpbaseClockPortAssociateAddress         InetAddress,
+        ptpbaseClockPortAssociatePacketsSent     Counter64,
+        ptpbaseClockPortAssociatePacketsReceived Counter64,
+        ptpbaseClockPortAssociateInErrors        Counter64,
+        ptpbaseClockPortAssociateOutErrors       Counter64
+ptpClockPortCurrentDomainIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the given port's domain number."
+    ::= { ptpbaseClockPortAssociateEntry 1 }
+ptpClockPortCurrentClockTypeIndex OBJECT-TYPE
+    SYNTAX          ClockType
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the given port's clock type."
+    ::= { ptpbaseClockPortAssociateEntry 2 }
+ptpClockPortCurrentClockInstanceIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+    ::= { ptpbaseClockPortAssociateEntry 3 }
+Shankarkumar et al.     Expires August 6, 2012                [Page 61]
+ptpClockPortCurrentPortNumberIndex OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the PTP Port Number for the given port."
+    ::= { ptpbaseClockPortAssociateEntry 4 }
+ptpbaseClockPortAssociatePortIndex OBJECT-TYPE
+    SYNTAX          Unsigned32 (1..65535)
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the associated port's serial number in
+        the current port's context."
+    ::= { ptpbaseClockPortAssociateEntry 5 }
+ptpbaseClockPortAssociateAddressType OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the peer port's network address type used
+        for PTP communication."
+    ::= { ptpbaseClockPortAssociateEntry 6 }
+ptpbaseClockPortAssociateAddress OBJECT-TYPE
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the peer port's network address used for
+        PTP communication."
+    ::= { ptpbaseClockPortAssociateEntry 7 }
+ptpbaseClockPortAssociatePacketsSent OBJECT-TYPE
+    SYNTAX          Counter64
+    UNITS           "packets"
+    STATUS          current
+    DESCRIPTION
+        "The number of packets sent to this peer port from the current
+        port."
+    ::= { ptpbaseClockPortAssociateEntry 8 }
+ptpbaseClockPortAssociatePacketsReceived OBJECT-TYPE
+    SYNTAX          Counter64
+    UNITS           "packets"
+Shankarkumar et al.     Expires August 6, 2012                [Page 62]
+    STATUS          current
+    DESCRIPTION
+        "The number of packets received from this peer port by the
+        current port."
+    ::= { ptpbaseClockPortAssociateEntry 9 }
+ptpbaseClockPortAssociateInErrors OBJECT-TYPE
+    SYNTAX          Counter64
+    UNITS           "packets"
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the input errors associated with the
+        peer port."
+    ::= { ptpbaseClockPortAssociateEntry 10 }
+ptpbaseClockPortAssociateOutErrors OBJECT-TYPE
+    SYNTAX          Counter64
+    UNITS           "packets"
+    STATUS          current
+    DESCRIPTION
+        "This object specifies the output errors associated with the
+        peer port."
+    ::= { ptpbaseClockPortAssociateEntry 11 }
+END
+5. Security Considerations
+   This MIB contains readable objects whose values provide information
+   related to PTP objects. While unauthorized access to the readable
+   objects is relatively innocuous, unauthorized access to the write-
+   able objects could cause a denial of service, or could cause
+   unauthorized creation and/or manipulation of tunnels. Hence, the
+   support for SET operations in a non-secure environment without proper
+   protection can have a negative effect on network operations.
+   SNMPv1 by itself is such an insecure environment.  Even if the
+   network itself is secure (for example by using IPSec), even then,
+   there is no control as to who on the secure network is allowed to
+   access and SET (change/create/delete) the objects in this MIB.
+   It is recommended that the implementers consider the security
+   features as provided by the SNMPv3 framework.  Specifically, the use
+   of the User-based Security Model [RFC 3414] and the View-based Access
+   Control Model [RFC 3415] is recommended.
+Shankarkumar et al.     Expires August 6, 2012                [Page 63]
+   It is then a customer/user responsibility to ensure that the SNMP
+   entity giving access to this MIB, is properly configured to give
+   access to those objects only to those principals (users) that have
+   legitimate rights to access them.
+6. IANA Considerations
+   To be added.
+7. References
+7.1. Normative References
+   [IEEE 1588-2008] "IEEE Standard for A Precision Clock Synchronization
+   Protocol for Networked Measurement and Control Systems", IEEE Std.
+   1588(TM)-2008, 24 July 2008
+7.2. Informative References
+   [RFC 1155] Rose, M., and K. McCloghrie, "Structure and Identification
+   of Management Information for TCP/IP-based Internets", STD 16, RFC
+   1155, Performance Systems International, Hughes LAN Systems, May 1990
+   [RFC 1157] Case, J., Fedor, M., Schoffstall, M., and J. Davin,
+   "Simple Network Management Protocol", STD 15, RFC 1157, SNMP
+   Research, Performance Systems International, Performance Systems
+   International, MIT Laboratory for Computer Science, May 1990.
+   [RFC 1212] Rose, M., and K. McCloghrie, "Concise MIB Definitions",
+   STD 16, RFC 1212, Performance Systems International, Hughes LAN
+   Systems, March 1991
+   [RFC 1215] M. Rose, "A Convention for Defining Traps for use with the
+   SNMP", RFC 1215, Performance Systems International, March 1991
+   [RFC 1901]  SNMPv2 Working Group, Case, J., McCloghrie, K., Rose, M.,
+   and S. Waldbusser, "Introduction to Community-based SNMPv2", RFC
+   1901, SNMP Research, Inc., Cisco Systems, Inc., Dover Beach
+   Consulting, Inc., International Network Services, January 1996.
+   [RFC 1906] SNMPv2 Working Group, Case, J., McCloghrie, K., Rose, M.,
+   and S. Waldbusser, "Transport Mappings for Version 2 of the Simple
+   Network Management Protocol (SNMPv2)", RFC 1906, SNMP Research, Inc.,
+   Cisco Systems, Inc., Dover Beach Consulting, Inc., International
+   Network Services, January 1996.
+   [RFC 2578] McCloghrie, K., Perkins, D., and J. Schoenwaelder,
+   "Structure of Management Information Version 2 (SMIv2)", STD 58, RFC
+   2578, April 1999.
+Shankarkumar et al.     Expires August 6, 2012                [Page 64]
+   [RFC 2579] McCloghrie, K., Perkins, D., and J. Schoenwaelder,
+   "Textual Conventions for SMIv2", STD 58, RFC 2579, April 1999.
+   [RFC 2580] McCloghrie, K., Perkins, D., and J. Schoenwaelder,
+   "Conformance Statements for SMIv2", STD 58, RFC 2580, April 1999.
+   [RFC 3411] Harrington, D., Presuhn, R., and B. Wijnen, "An
+   Architecture for Describing Simple Network Management Protocol (SNMP)
+   Management Frameworks", STD 62, RFC 3411, Enterasys Networks, BMC
+   Software, Inc., Lucent Technologies, December 2002
+   [RFC 3412] Case, J., Harrington D., Presuhn R., and B. Wijnen,
+   "Message Processing and Dispatching for the Simple Network Management
+   Protocol (SNMP)", STD 62, RFC 3412, SNMP Research, Inc., Enterasys
+   Networks, BMC Software, Inc., Lucent Technologies, December 2002.
+   [RFC 3413] Levi, D., Meyer, P., and B. Stewart, "Simple Network
+   Management Protocol (SNMP) Applications", STD 62, RFC 3413, Nortel
+   Networks, Secure Computing Corporation, December 2002.
+   [RFC 3414] Blumenthal, U., and B. Wijnen, "User-based Security Model
+   (USM) for version 3 of the Simple Network Management Protocol
+   (SNMPv3)", STD 62, RFC 3414, Lucent Technologies, December 2002.
+   [RFC 3415] Wijnen, B., Presuhn, R., and K. McCloghrie, "View-based
+   Access Control Model (VACM) for the Simple Network Management
+   Protocol (SNMP)", STD 62, RFC 3415, Lucent Technologies, BMC
+   Software, Inc., Cisco Systems, Inc., December 2002.
+   [RFC 3416] Presuhn, R. (Ed.), "Version 2 of the Protocol Operations
+   for the Simple Network Management Protocol (SNMP)", STD 62, RFC 3416,
+   BMC Software, Inc., December 2002.
+   [RFC 3417] Presuhn, R. (Ed.), "Transport Mappings for the Simple
+   Network Management Protocol (SNMP)", STD 62, RFC 3417, BMC Software,
+   Inc., December 2002.
+   [RFC 5905] David L. Mills, " Network Time Protocol Version 4:
+   Protocol and Algorithms Specification", RFC 5905, University of
+   Delaware, June 2010.
+   [IEEE 802.3-2008] "IEEE Standard for Information technology -
+   Telecommunications and information exchange between systems - Local
+   and Metropolitan area networks - Specific requirements Part 3:
+   Carrier sense multiple access with Collision Detection (CSMA/CD)
+   Access Method and Physical Layer Specifications", IEEE Std. 802.3 -
+   2008, 26 December 2008
+   [G.8265.1] "Precision time protocol telecom profile for frequency
+Shankarkumar et al.     Expires August 6, 2012                [Page 65]
+   synchronization", ITU-T Recommendation G.8265.1, October 2010.
+8. Acknowledgements
+   Thanks to John Linton and Danny Lee for valuable comments.
+9. Author's Addresses
+   Vinay Shankarkumar
+   Cisco Systems,
+   7025-4 Kit Creek Road,
+   Research Triangle Park,
+   NC 27560,
+   USA.
+   Email: vinays at cisco.com
+   Laurent Montini,
+   Cisco Systems,
+   11, rue Camille Desmoulins,
+   92782 Issy-les-Moulineaux,
+   France.
+   Email: lmontini at cisco.com
+   Tim Frost,
+   Symmetricom Inc.,
+   2300 Orchard Parkway,
+   San Jose,
+   CA 95131,
+   USA.
+   Email: tfrost at symmetricom.com
+   Greg Dowd,
+   Symmetricom Inc.,
+   San Jose,
+   CA 95131,
+   USA.
+   Email: gdowd at symmetricom.com
+Shankarkumar et al.     Expires August 6, 2012                [Page 66]
diff --git a/freebsd/contrib/ptpd/doc/index.html b/freebsd/contrib/ptpd/doc/index.html
new file mode 100644
index 00000000..3e367d24
--- /dev/null
+++ b/freebsd/contrib/ptpd/doc/index.html
@@ -0,0 +1,125 @@
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml">
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
+<title>PTPd - Precision Time Protocol daemon</title>
+<link href="stylesheet.css" rel="stylesheet" type="text/css" />
+</head>
+<body>
+<!-- begin header -->
+<table width="100%" border="0" cellpadding="4" cellspacing="0" class="info_table">
+<tr>
+<td>
+<center><p class="info_text">
+Last site update: 22 November 2013 | Latest PTPd version: <a class="info_text" href="http://sourceforge.net/projects/ptpd/files/ptpd/2.3.0/ptpd-2.3.0.tar.gz/download">2.3.0</a>
+| PTPd is hosted by
+<a href="http://sourceforge.net"><img src="http://sflogo.sourceforge.net/sflogo.php?group_id=139814&type=2" width="125" height="37" border="0" alt="SourceForge.net Logo" align="absmiddle"/></a>
+</p>
+</center>
+</td>
+</tr>
+</table>
+<table width="100%" border="0" cellpadding="20" cellspacing="0">
+<tr>
+<td>
+<center><font class="title_text">PTPd</font></center>
+</td>
+</tr>
+</table>
+<!-- end header -->
+<table width="100%" border="0" cellpadding="0" cellspacing="0">
+<tr>
+<td valign="top">
+<!-- begin sidebar -->
+<table border="0" cellpadding="0" cellspacing="0" class="sidebar_table">
+<tr>
+<td class="sidebar_heading">PTPd</td>
+</tr>
+<tr>
+<td><a class="sidebar_link" href="http://sourceforge.net/projects/ptpd/">Project Page</a></td>
+</tr>
+<tr>
+<td><a class="sidebar_link" href="http://sourceforge.net/project/showfiles.php?group_id=139814">Download</a></td>
+</tr>
+<tr>
+<td><a class="sidebar_link" href="http://sourceforge.net/p/ptpd/code/">Browse Source</a></td>
+</tr>
+<tr>
+<td><a class="sidebar_link" href="https://sourceforge.net/p/ptpd/wiki/Home/">Wiki</a></td>
+</tr>
+<tr><td> </td></tr>
+<tr>
+<td class="sidebar_heading">Related Projects</td>
+</tr>
+<tr>
+<td><a class="sidebar_link" href="http://ieee1588.nist.gov/">IEEE 1588</a></td>
+</tr>
+<tr>
+<td><a class="sidebar_link" href="http://www.ntp.org/">NTP</a></td>
+</tr>
+</table>
+<!-- end sidebar -->
+</td>
+<td class="vline"></td>
+<td valign="top">
+<!-- begin body -->
+<table border="0" cellpadding="0" cellspacing="0" class="content_table">
+<tr><td>
+<p> The PTP daemon (PTPd) implements the Precision Time protocol (PTP)
+as defined by the relevant IEEE 1588 standard. PTP Version 2 implements
+IEEE-1588-2008.  PTP was developed to provide very precise time
+coordination of LAN connected computers. </p>
+<p>Documentation is now being added to the
+project <a href="https://sourceforge.net/p/ptpd/wiki/Home/">Wiki </a>.</p>
+<p> PTPd is a complete implementation of the IEEE 1588 specification
+for a standard (non-boundary) clock. PTPd has been tested with and is
+known to work properly with other IEEE 1588 implementations. The
+source code for PTPd is freely available under a BSD-style
+license. Thanks to contributions from users, PTPd is becoming an
+increasingly portable, interoperable, and stable IEEE 1588
+implementation. </p>
+<p> PTPd can run on most 32-bit or 64-bit, little- or big-endian processors. It
+does not require an FPU, so it is great for embedded processors. PTPd
+currently runs on Linux, uClinux, FreeBSD, and NetBSD. It should also
+be easy to port to other platforms. </p>
+<p>PTPd is free. Everyone is welcome to use and contribute to PTPd. </p>
+<p>The PTPd project would like to thank the following for their kind
+    donations of equipment and time:
+    <dl>
+      <dt><a href="http://www.meinbergglobal.com/english" >Meinberg Corp </a>
+      <dd>Donation of an m600 PTPv2 GPS Grandmaster Clock
+      <dt><a href="https://ssl.sentex.ca/" >Sentex Data Communications</a>
+      <dd>Hosting the FreeBSD Network Test Cluster
+      <dt><a href="http://www.freebsdfoundation.org/" >The FreeBSD Foundation </a>
+      <dd>Providing testing resources for the PTPd Project
+    </dl>
+</td></tr></table>
+<p>PTPd version 1 implements IEEE-1588-2002 and is considered a legacy
+protocol. <a
+href="http://sourceforge.net/projects/ptpd/files/ptpd/1.1.0/ptpd-1.1.0.tar.gz/download">1.1.0</a>
+<!-- end body -->
+</td>
+</tr></table>
+</body>
+</html>
diff --git a/freebsd/contrib/ptpd/doc/ptpd-2.3.0-migration-guide.html b/freebsd/contrib/ptpd/doc/ptpd-2.3.0-migration-guide.html
index 00000000..d1dfea21
--- /dev/null
+++ b/freebsd/contrib/ptpd/doc/ptpd-2.3.0-migration-guide.html
@@ -0,0 +1,243 @@
+<?xml version="1.0" encoding="utf-8"?>
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
+    "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
+<head>
+<meta name="generator" content="HTML Tidy for Linux (vers 25 March 2009), see www.w3.org" />
+<meta http-equiv="Content-Type" content="application/xhtml+xml; charset=us-ascii" />
+<title xml:lang="en-US" lang="en-US">PTPd</title>
+<style type="text/css">
+/*<![CDATA[*/
+ th {text-align: left;}
+ table {border-collapse:collapse;}
+ table, th, td, tr {border: 1px solid black;}
+ td.c1 {font-family: monospace;}
+ td.c2 {font-family: monospace;}
+</style>
+</head>
+<body>
+<h1>PTPd 2.2.x → 2.3.0 migration guide</h1>
+<table>
+<tr>
+<th>Old option (2.2.2)</th>
+<th>New option (2.3.0)</th>
+<th>Meaning</th>
+</tr>
+<tr>
+<td class="c1">-H</td>
+<td class="c2">-H --long-help</td>
+<td class="c3">show detailed help page</td>
+</tr>
+<tr>
+<td class="c1">-g</td>
+<td class="c2">-s --slaveonly</td>
+<td class="c3">run as slave only</td>
+</tr>
+<tr>
+<td class="c1">-G</td>
+<td class="c2">-M --masteronly</td>
+<td class="c3">Master, passive when not best GM</td>
+</tr>
+<tr>
+<td class="c1">-W</td>
+<td class="c2">-m --masterslave</td>
+<td class="c3">Master, slave when not best GM</td>
+</tr>
+<tr>
+<td class="c1">-b NAME</td>
+<td class="c2">-i --interface</td>
+<td class="c3">Interface to use</td>
+</tr>
+<tr>
+<td class="c1">-c</td>
+<td class="c2">-C --foreground</td>
+<td class="c3">Don't run in background</td>
+</tr>
+<tr>
+<td class="c1">-C</td>
+<td class="c2">-V --verbose</td>
+<td class="c3">Run in verbose foreground mode</td>
+</tr>
+<tr>
+<td class="c1">-f FILE</td>
+<td class="c2">-f --log-file<br />
+-S --statistics-file</td>
+<td class="c3">Log file Statistics file</td>
+</tr>
+<tr>
+<td class="c1">-S</td>
+<td class="c2">--global:use_syslog=N</td>
+<td class="c3">DON'T send messages to syslog</td>
+</tr>
+<tr>
+<td class="c1">-T NUM</td>
+<td class="c2">--ptpengine:multicast_ttl</td>
+<td class="c3">set multicast time to live</td>
+</tr>
+<tr>
+<td class="c1">-D</td>
+<td class="c2">(always in .csv format)</td>
+<td class="c3">display stats in .csv format</td>
+</tr>
+<tr>
+<td class="c1">-P</td>
+<td class="c2"> </td>
+<td class="c3">display each received packet in detail</td>
+</tr>
+<tr>
+<td class="c1">-R FILE</td>
+<td class="c2">--global:quality_file</td>
+<td class="c3">record data about sync packets in a seperate file</td>
+</tr>
+<tr>
+<td class="c1">-x</td>
+<td class="c2">(no alternative)</td>
+<td class="c3">do not reset the clock if off by more than one second</td>
+</tr>
+<tr>
+<td class="c1">-O NUM</td>
+<td class="c2">--servo:max_offset<br />
+see also ptpengine:sync_outlier_filter_*</td>
+<td class="c3">do not reset the clock if offset is more than NUMBER nanoseconds</td>
+</tr>
+<tr>
+<td class="c1">-t</td>
+<td class="c2">-n --noadjust</td>
+<td class="c3">Do not adjust the clock</td>
+</tr>
+<tr>
+<td class="c1">-M NUM</td>
+<td class="c2">setup by ptpengine:delay_outlier_filter_* options</td>
+<td class="c3">do not accept delay values of more than NUMBER nanoseconds</td>
+</tr>
+<tr>
+<td class="c1">-a NUM,NUM</td>
+<td class="c2">--servo:kp --servo:ki</td>
+<td class="c3">specify clock servo Proportional and Integral components → converted from attenuations to gains</td>
+</tr>
+<tr>
+<td class="c1">-w NUM</td>
+<td class="c2">--servo:delayfilter_stiffness</td>
+<td class="c3">specify one way delay filter stiffness</td>
+</tr>
+<tr>
+<td class="c1">-u</td>
+<td class="c2">-u --unicast</td>
+<td class="c3">Unicast mode</td>
+</tr>
+<tr>
+<td class="c1">-U</td>
+<td class="c2">-y --hybrid</td>
+<td class="c3">Hybrid mode</td>
+</tr>
+<tr>
+<td class="c1">-e</td>
+<td class="c2">--ptpengine:transport=ethernet</td>
+<td class="c3">run in ethernet mode</td>
+</tr>
+<tr>
+<td class="c1">-h</td>
+<td class="c2">-E --e2e</td>
+<td class="c3">run in End to End mode</td>
+</tr>
+<tr>
+<td class="c1">-z</td>
+<td class="c2">-P --p2p</td>
+<td class="c3">run in Peer-delay mode</td>
+</tr>
+<tr>
+<td class="c1">-l NUM,NUM</td>
+<td class="c2">--ptpengine:inbound_latency<br />
+--ptpengine:outbound_latency</td>
+<td class="c3">inbound, outbound latency in nsec.</td>
+</tr>
+<tr>
+<td class="c1">-o NUM</td>
+<td class="c2">--ptpengine:utc_offset</td>
+<td class="c3">current UTC offset</td>
+</tr>
+<tr>
+<td class="c1">-i NUM</td>
+<td class="c2">-d --domain</td>
+<td class="c3">PTP domain number (between 0-3)</td>
+</tr>
+<tr>
+<td class="c1">-n NUM</td>
+<td class="c2">--ptpengine:log_announce_interval</td>
+<td class="c3">announce interval</td>
+</tr>
+<tr>
+<td class="c1">-N NUM</td>
+<td class="c2">--ptpengine:announce_receipt_timeout</td>
+<td class="c3">announce receipt timeout</td>
+</tr>
+<tr>
+<td class="c1">-y NUM</td>
+<td class="c2">--ptpengine:log_sync_interval</td>
+<td class="c3">sync interval</td>
+</tr>
+<tr>
+<td class="c1">-m NUM</td>
+<td class="c2">--ptpengine:foreignrecord_capacity</td>
+<td class="c3">max number of foreign master records</td>
+</tr>
+<tr>
+<td class="c1">-v NUM</td>
+<td class="c2">--ptpengine:ptp_allan_variance</td>
+<td class="c3">Master mode: specify system clock Allen variance</td>
+</tr>
+<tr>
+<td class="c1">-r NUM</td>
+<td class="c2">--ptpengine:ptp_clock_accuracy</td>
+<td class="c3">Master mode: specify system clock accuracy</td>
+</tr>
+<tr>
+<td class="c1">-s NUM</td>
+<td class="c2">--ptpengine:clock_class</td>
+<td class="c3">Master mode: specify system clock class</td>
+</tr>
+<tr>
+<td class="c1">-p NUM</td>
+<td class="c2">--ptpengine:priority1</td>
+<td class="c3">Master mode: specify priority1 attribute</td>
+</tr>
+<tr>
+<td class="c1">-q NUM</td>
+<td class="c2">--ptpengine:priority2</td>
+<td class="c3">Master mode: specify priority2 attribute</td>
+</tr>
+<tr>
+<td class="c1">-Y 0[,0]</td>
+<td class="c2">-a --delay-override<br />
+-r --delay-interval</td>
+<td class="c3">Initial and Master_Overide delayreq intervals</td>
+</tr>
+<tr>
+<td class="c1">-B</td>
+<td class="c2">-D<DD...> --debug</td>
+<td class="c3">Enable debug messages</td>
+</tr>
+<tr>
+<td class="c1">-j</td>
+<td class="c2">--ptpengine:igmp_refresh=N</td>
+<td class="c3">Do not refresh the IGMP Multicast menbership at each protol reset</td>
+</tr>
+<tr>
+<td class="c1">-L</td>
+<td class="c2">-L --ignore-lock<br />
+see --ptpengine:pid_as_clock_idendity<br />
+see --auto-lock
+</td>
+<td class="c3">Allow multiple instances</td>
+</tr>
+<tr>
+<td class="c1">-V 0</td>
+<td class="c2">--global:status_update_interval<br />
+--global:statistics_log_interval</td>
+<td class="c3">Seconds between log messages</td>
+</tr>
+</table>
+</body>
+</html>
diff --git a/freebsd/contrib/ptpd/doc/ptpd_2005_1588_conference_paper.pdf b/freebsd/contrib/ptpd/doc/ptpd_2005_1588_conference_paper.pdf
index 0000000000000000000000000000000000000000..3d4f80dd4e00f98bb6ca2a50744a79c39b5c1f3a
GIT binary patch
literal 323600
zcmb at t1y~&05-y6nYw*EcW^jVLyA#~q-61$6NFYFPcL?rIu;37!;2K<mgbT^eIs5Fr
z&pYpZ_sx7gU0qA6daYWuYW}XKR1_6w1TwK9Q?74}O(7$IxBx5wdm}4eUS>%hE_Mz8
zh>Js)S=Q3d)X>S&%hUt_WEKN(a<Z|rGs^;4L984sEX?u%4rT=aE09_Bi38&1X65Hc
zHnlT(>IE6__YX3Hhm)z<Pe~vyWCWH!K0pq at PYPi7n+F84f&R*4c~<GK^+2G%)dRAz
z0RL8xosI3UJP?SB<!?MrPS(HixL7#<%422W{99XAAlu*cV`FFin_PA-uD{9P1hW5~
z$Ii|ESGk;A?0=KX4P^W4{Q_B7L4TDC1hRAdwLc(`ljU#qK-`?%f06qnf%C~Yo<IMZ
zBOnJC+h50pgB8g7R~eifY=0XoP7Y4izs?&c2RG<%Z8<@}Ki#j3lcA-JsS`57lZC20
zStNj+gIUqZ)a|F~ae<hX?d at FvpeN-4%FI%BX7&KklY-B*s17fu8Ia2q#KCQ9%4Wg=
zG+_mD0YNOL?5ynU#+=4LkP$yG3&+#Mu(7Zia<hX##%xC1Ko$_U;Zqe8E)Y9An-Rb6
zlWik7yBIpT{IX&eWCTh|F$HmCgg;w4G6L(9%73gQSyMZ67YhK0g`HX4(#FNqiCNsn
z(8W~L)Y#s{^l24=Ky1t^03a&|Kfkk!lc}NY(+XKIGB7ZJ$-zb{LqbwcK?*{G0}OOR
zV3``O&W(3=j<*YGY+HmX5M9sWA|cT$qy^Bd!A-lqtodBbI&8DEtU`;=r_-j)R#5J(
zYh3-gc*A7?l+|TM1TYnZOn%3P|6&e={{rA69sz?z9w-<dxOEE+V1(~=GC-$<0S}Ep
zYLdNsp#bTrfLE*8rkSW!!7^&lID8hLpJe({glbqWNssB6 at gTYb#A}#5cJg5jlnczI
z?-BaM61uGDAI at 5}#0Qa=5-^7k=meuq;&w(xcyb1R+}R&);phDP at -m8s=BCbo=UIQ6
zBvnrbQ)UrE7egC+bLQs~SwkaJo2TNZh4EA at XX;{T@>B`{JuNbT^1s~->yz>SG1?;b
zb}puNF3viv&z?*f!1~h^0Bq0mp$uUA*%9E`5j<c0lnQt@;peNL4Rn7g at htpF1E;61
zek-SJ at A5Ql0G1~;Oe_tB?LBm!`{V$E0G!+)U1kv{dxyU<l}(-PU7d`d?(o^x|3l^H
z>t914VsB&bq~c&`Z2Dx=BF-Fu=k at bkms$MjW}bMeszAWAUwIxORS<yn*J!A!vH_kw
z%TF!`;MoEEY^3O9Z>(bKqQm^;+L={NJzR8|#XMXjRGzhe>P$if2w?qr$NW#9-;Vlc
zpTE at kISJ2_nZ@j$Ow`iOoLR%tPRP#L@?Y1&hR&uxYlzA#$}5P|t6JKcI?J27E8E)|
z+9|5YsXke{le3G6g`v~ajWf#{{y~FSS(#N_ja;6mS=Gta^k1SxO`VOMEFE0zpX&d*
zQ4LEI7Yk<{(6g`m<IDA=B<HgadKv-Np9lMsFJk9ldzztNyyr9Msm4$KbJ_nmp6fmz
zzk2y4hx2JS;o#u>dHke-KmhyGuJcSkA3tStasQ+_p31oXpr6a0>phvoQ|o8yx%77{
z?kAJ`P5;vM_wTb*wx`l(UH^Q3mh)Tx-+De at Khw{n at Vo5y`L|xr<-d79b^2orp8NiF
zhwML1<@c!m_w(;jes1}z^>e at fH(&Ojlly<u!#}tE_r3kQ{E7GMtpD&hKNrgXcl-W}
zVKWNb+nD at U>jts||EG1c|8jKyVBP=L{F(Y?_rI<G-{bz9`hEU$tLNE%w!PnW_DugO
zXMM6!mOs|czbx^|PM$6FxyDax{a5Wj_xX!{miAodd7OWr|7D*~{AZi{dHo0dyi%X*
z{ciWKHcxu|uJ>H_tm&^+`cE_XcRl`z^V|>cDJc2#WIqq`(`4%~ONod)`zjLv+s|!4
z_h07lyiWgO4*&K+KmG30UTylcqMt=7|6~Y1dv`{54lV%WQ|R}!pZ^lfsr$23-q6;R
z`M<kE8$<J_J>Y4hcQLh92Ry|oB8Co<rk3UwE&z_F2uAY{nuS@&+4y<S;o=4|KP&W1
zGlGB|%u-LAqNTBrow?2P7WC|V#SLvOZ9HjynkeAO`2v1=U)rB#Do=rgi?Ic>yuFjH
zq0LX0#xH4XEG&Oo70(9pr(yWlKEbRa1TZtSaW-XEQ2c{Xkpr+Wv4EKE9sX4!2LS%5
zuV**<tFJ#I9^g}e^$#J>zr!5Kh%)s>yG3y{-&u{%8`V``UNKd^jWEWto1iL6sTZ6G
zL$0e&R?L%82E9YI^lxz1l8y|{Vh#bfW at a@vA6 at czcxVgkx4dlD)17sNfY}dAjBrg8
zjP|dt{y1X^Uq8(eqh!?3+ at 9iOL6sC?XmyK?@Cj$%3|r)(RT(DdmRzU+93&ugHq at KK
zBuz6Zx&u#I0S_333w$4HxN=kM`)$o^x6o}vg0rD9D9rHn-I`$mb at Ys*ULM at 5j_ihD
zp82!ZTM at pNiJrywm)*-p#pf+FQ|jOS#Peuoit)X82WOzr9<&~-v^97bWudKejja*8
zTUl(hvJHD6KkJ~nH#9UDR9C-t&$S;QhALWr^%-3vK7npAZvj3%pn2I-6 at NP$uQ{a5
z{w!0(P&pk_=`>~YJt1s5)DTuA*M!y(!i9?yRXvuO-^IfxS0bk<Bnm4+-&x(RG23%^
zJ#xzjGaTu5+azGfr}t+=yC8u+7H*})A(0O8167Uv>j8`0BMTL}BHx<BT-O3t_5p=3
zGgT{(cgv>;IX-bHK`|&ok#)fOcK}mt*bE;wYLcl}8SQ)bUG5cMUv(|o5+t5!2OYoa
zy1Ub$hV39 at iBYlDb4t#vi8`H8u&r at z51!3Eh-=vJ4*~Y1Jw`GInr=sH`g(giE39;!
zD%7+GeJC0aaYFYhr&7S}5Iex|J#k{Yqv`*uM0l`<EAagk5O&gTkE*|<@Cy9U2Wuy8
z1q1QKKL=yD at H5K@JX3Lrij-cSwa at o2!$=j$<p?$?o at Oo>&B%r2Y`C_zIA{Aauw at 1p
z0 at cZ6&aa7^%|bh}SL&T$6c|=nPRru!NU{$-T~EyWt|mqd5$$?rNv at eYgBQrzdgQA_
zgO1SZ_CmKYN#HQo&6?4yA`N`CLqA=x+;%AP8z&<fHx-=idQJ^&!^vNL7y#fQnC;`8
zclw!PDaPZYFn;1x`XEE-5EW}58-sQHo&byK1e%r`3HT|FaSZEPjV!2lg4yORS&UN0
z#gI0=A7wuL{Ks?o>8rJwblfTP*mLrvs%Fuvm-Ch&dJTvEmr4lrDys<WqqgKlU9UK+
zPc_Cz(R?6J%?(02vq?<XLSCFvXpEs3SQKarr8XdbTnuRqatiP*?|7+zfuM`AxcUt<
zL0WE!eUT&9TIq3>--Y-}Wl><=!~hFl!SsbZt}{hMf)nl4)V&~u%twVHLGm0#e`X2j
zW<|PGTqT_7SBO7wmAY(7g=GfiiV`EjmX#KYZD^1@;Y7To-eP-|8L1<%fBSA8T6GPe
z^NxJg7ozt15i0<J9EOWnOmZ}idA2T-JV9}j(+6fE)k%gWon}a`s at pJO5SYkP8#1Z+
z#b+MIJ2Qyb8%qzbqk at mL+eEmhDzl~j8guL@#z!Zs7=@TZvnYu)X2&69#b%NYjr(>u
z`|BBJh>yHMmRH012TB(312VQ at cVucoC9I$uCT*3Y>0Zx|->TLp80A*9px4HMnB=xa
z)aAwHbul*A>4><iW@&J(-{$E|%JL}uoeo2rVQ+~kI1N9ZIJ9TGQ4K4A+7#H)U&LS%
z;Nu~GSR)~G;gOc4mR7wVS|H8pfno6$K-lUA-M-uDgC4$mO&hx;3*K?X>#jP&NOVZ;
zAxj%wBhYB4Am?rP(x9E;b^g*B$OLSMWkEc9LyfvMEHp%lL<up=r}sy|#VM)JDv6a*
zp_>o at LP+0_R~5)UBNg%;$!V$agW)O^>Lq22^d#?E;W+M%MgTaNx=f$NKm33C`KRVT
zeJzNS`+xY_*XnZ4OB_gT$CaIN-$YB=HF!8vik&6-h%Vo40<4?#W?JIK-yJr0w4;J;
z*|A=+Wqb<&M7#}yRXp6$y_;f^UZ)tOv$`XaF%>yHKPqi<=Ahf?E*s;JK5yh;q7ldU
zUrJ31%i<Zwr|3}TB;H-;d2B4A`}WG_UEfGOzAc8i8Rer<F4d^xn6A%f?-<g%wujcc
zCR<kNV!k6~sAQ!efyA at OAtw@Z_PY1FWOxoIjk7=CfzpmeLi{9 at HMOgl6Rz=`z-6D0
z`Ii2V$Q>k)H+>wZE47 at hw?Ui2P*!xzGt-aXg$#mB1O4|y4d~>Q0W%qd%RaXk5tG#w
z*%hA;*KfN}>)+6`#!RE&ekh0~axjG29H^CVE3e8J&G~L-x2U7 at DgV3Kp7rfRIScnj
zd5K)ptmHOygA?mK1XBhY4jqf;w4B(^A+dNdxoDhogwyIoOool=k=`aw)EIU9H2LmQ
znkKLrJJS5cSSQRWxb(?Y;6-vXR?Rs%i5uc<TB2SOZVP9|tz9jR-6hFpWmma~w5PJA
z^zy?xq1HCyNx}fD=)^o$iU$?OuBr2Vx3Pc5Ev$B0o~Mh at 3vY=7G$x*=8=<*H_=QE7
z4To!C$##LZz(y8&DG{GLDy*-WE!5O+l)8p^0TSpu!<KJ0?@QRn<QjM!8#9)w#wnP_
z4YZK=sVd>HK7{d9-FRHssX at INb|L+!jtEgq2A06FLA-*dsg!`9`1Zwnhn2zanygVA
z9ReImSNnWw#|C7`ot&$xDc>3BvEEI&Y|zQPDFD(PoWeWor&`9QXwCQ*UXN+$xELY5
zgsSAcgH`ix;EiB|mZ9DTD$io`c`-RaqH(b^?YvY&EF03JhGak;opMn%qL_?R>Qkrc
zdpXS*w`5{or$j0zs<Soe(=j^~@u7Bp>9yM{>h>Ux<3daBB3>{KMP*!~>QZEjj~S|K
zyM#wz)JAr;x3kp|QzVN8NT#JFu~}yU-kzEY-C>~<!>fxQy&NSzF$D))p-Dx|NYb(r
zPY+SeduMeTy*?9?T$*T=Z96CajwSBRw2`5+wARLxr;{w at hm58`G1m7Uy(o2MT^zXs
zRu>h->?`oOnIAP5fyvMOok at 1wB!%UV^eHiLC}1J1&`PeYlZbOz7%4j|2!^d at E6h5u
z2P at AaZ}8 at Y%ESI7ML#jOe5VwDw2(US<*IYT?t|pahSoH5HQ-Z%{;XCV69Xr6`bda#
z2pj0p=w42Op3wJ>Z!T0t-E74A{1ea2C6QC39znK9 at kaLasp3$uDr^CYaRZ7I48ITn
zUE#K3%9b9uL>DzWDW1CugKI?Mw?c5d*4OQViUem{0LdpoKOjgSQ%j|%a_k|$(cy8h
zd{R5&glBP+m1S?HqSzRH+9{{A>X;BSzd;nz<(@HtT<@iCt%$p)RR7lM?ueMSxuX%?
zDqV0l4!x>idnMvb(A@(-u(YN?RS;P;(@9fPx at 5=W+a)d4xZNMeNz|U52g|MIk3(dZ
zlicO9 at liKLA9mtv)Pcbfa#rqvImPgq(;Y`FGy1f&j#kI`RdTg;VZ4R8XWmvYKox!B
zi(HZ}YO at uq-fOAZOHe1v-Esl~3WLIk5bh!Xp;S(=i&!mnM=HcrEi!Zqy{-O~Zvmo-
zN)3);Ic#TWY at qrjs=qNpI?vp~hpo;S$)4~CH&r!ek+dJ^24L$AmE8Z}M1Mj;e{rHu
zX!hSRx<3c3 at 6-qF7P(%u at 6dWs1WKaSAv)8saOV|5uy2FXA;~A|@k7`sxI^zQ&h6z7
zbNDY}lkcxDb2&0eY~qqa>gZHHbdba|jDU1X<Q`-5n{4UpxcTl&`wikjjCI=AJ}3K~
zVGo{o-kh`v(_T*I0;L1d<x-KgO<!0ZZTST#aNQ&1YI63+X}_1v6*8uV`oeUik{w<Q
zsus^UhGxF%_#wtt$7!l<>0r9Hvnhwz>OKZ~OEtAWGDirNJ{X8GN>M?jd?mV=k_Vo8
z5YljR+%4a>%bfONg3xSw|A!i5e+KW-d<Up*<)s_Hq$C!bw>eDzfY<=dUF+Qd|8V}g
z=@&h^_FK;bua0DVhWvd at ukY30bHw3B3hMY}S15M3kiX4pGmRG!2EAJ5`2^PIUW$*4
zy^bJ6g5s$6kfk?Ta7T%=2URCfLny2EW%9??>fMCg2C8DHXjsArzSQ)GFJr7|vqeh~
zhPB$<b-jmPPH1lB=9#@L>7<uO?!^f$ua>s75 at e2&r6E0CEwfS6W=%ki9yZ#vge1vg
zO~Uhxg>Un)bkwZt=FgXzi4U$Mu1YeuaTw^Zz8%tBtCe#Kd41z4>#uH(>RT^lW)J;3
zed{%4qbK$CI=72-5l@?m4Y54k(n%+kx^%4f+$96K- at NNXkaOXNdO4cPUG`^_l>!{t
z1oy#xjp}oYEJQSNkZ6d=?qHW*j0q!4R7{m0;Xo(4*##B<_L1EZD%TJ7$<ztTZ!dP2
zQ{Wc|Wv8|JT}f5<(A1>ym$hL at Lrhj7*-2-sIPIe~(ur}uDTELi1a+dr$-vT&VC4Ah
z88B at I7s=U~TE<~I^L-WX;5Cx06n;|(cIRN<VM8ic=`>$?jB$wYvCv{yMZpkf93jo>
zk*T4x<E3k|A-Q1 at I3frl6>8QN{J|t8E!>-i&**AkTkK0s*}k#KN4#eB{k4Vc8^<{s
z3m!puOqTko##9(;NQw_FI<||$>iRr4M2MPB@#e++m3kv;b(+2f%BW>5#juP_*?sC@
zM-G at egiHow<ip%71SzLZxz){nXCR33_DSMRgDT$P#umu{HDE3K74B~Hf*yqJ&=n*N
z_-)ltzIgcSIC~ci!;jsf!TzDS!btrRrW6=#(8Qu(&U#i&w^frwxFr)lX5U{VU5t_&
zS*Mg%mvR%H7)PP#XCkjkOL2jt6B3HT>_Rm<iBYNs%o~{rqO9|MK23TN2SkC$7ih}Z
zbu`8-zTNkR!x4e at gXe?a|Nea;LWP-C54{axB=q=5s^@!WgOJ|?9t3pChQp?@f at Vx%
zK;`)P)D&j at 7^vJzhaYfAz at PaQNrIMqB+VS@Y=|QhZcfnDqgCT%`)tH0|MAp95mO-O
z<T`+zZg-CvPY5xcp^C50ERcN4OnZ7opkx?qei$r~hm>k~itrS1{DdNg4VVNwunxAi
zesX^TD_Q)Vck=NCjeoU|Ovkk-JQnVVX<X(b5IY9F966A?e|FD(#h6X&q%b!BoAthc
zeG+1={;_Q4-o}<VsyU=VXkLA<`h#fNTmp(uK*ZTg&lnn>n~)iIQN$pcH&BohFg*%j
z5r>tz!Amob5J+IA0ja(J<n{gymH!KU{eJ=U{uK!O1xNgMC=B$!p|Iztdr#2He}%$+
z!;il}pXaMzaM({!=^2pv%kf<AH}5}zqGy=v=kW(P_WSx50QKDSulmoh)i2&JVC?z#
zXOB-%)^m+t<^S3DFPZ-d-ToPZeWrhvK2v`NWPj`W49-0tzgs;+VZWfe|Aa7qj at O^S
znr95?FPPOYh>DH-4~Po*^mywD8w0Wa38MP%6ZsRO;^z7TqT&QHak4#OTx|bWNEIXS
z>7m#EKUmezM>l`juAi*z|9QKPRv)(85Jzjhqra7e!0E}p;T4yM at BoJuXZU8C4k;2t
zA<kCpKx2PK at O@p?9o2Ra6 at aTVWuvaqVb%D<345wr)KOWj_QxLGn{_U|$>unHG2w$_
zjjs^ywQ?=C1QI<-N3({+`CSj&`Vw-SY_Luo3_+)!;WYQY4_iYF<TVTkk$4VWT%SIN
zn^uIQ)~76FqvBecK-^0APw*VPO~@T=jxgYHO+dtjzJt3k`eZgV{4Mc}5Kx|kFBp!{
z&w~2KZ3$&V#X|NSwCh(*EAJA^lK%8`vr*Gm1?FjE0M?K^{0PWzb9Hhf-^k&GT*<F|
z36ds2Rby`F(&~a=r)NzfZJbnSK-KmO4tQ#TQ~n~!L6*$^mi!FKd~$}+VQm=<=A6-n
zIFwzV$ow#(jTRy!GCIo;uxjvN%?VENusk=qA=0CF!R<@~lEQNf$63c`b)eVDa!A(g
zy)UN{w(&a-!=-%V9hEHON5(mc2Htl?4DO^_(>4{P65Gu7Vj-6~`C*vd&W6GhOP+u_
zX|8&;Qt{*usf7p_eNk)hOt2b)i7Sea`e0*n<yVx59|EZqBndso5mn(uD2|<*hofA^
z+^IfLFWn^K$&+uFb;%TQIw;u at _^L8^#_2;`-HxGVP2pO+_4Oto4UWWH3D!m*w;hN&
zw{8?HRqxo_+tL3aQA_gWAPuagExME-)?&3a@<I9G#f0u5)yp$=HQGqk>lat845#PW
z3G*eHKq^Aq at d#lJr6lUaqc1uTnnz?~HSUP%cX?5h#{;&NLkY0gv&q)MlG#Ec$tW^V
zB>=0<-Eb at CDR3>xz4KMPM4{oum^21CZ$!`eg$ZeuY`BG`;=Uro at fXPeyu8Zm+h)EG
zU@(<u7rGPiS{(7+!!VyB`pr!oWjrbA176`XI`^^8&WzoHMWvsPx~+UvdK;WUcrK-h
z=wxunm*mcOcr{=j`qAGT%)a<8-G9?qn(%S|Dk%5bp`zUfx|FjfEulm}DX{l#EG<SQ
z1RvCUSlENXQV!`Gkvz69-kH}*hrzcf4Dej8PB}4QRYq!K)U{OoWQ7am$y?olU!*pN
zbuLczjV56kXt8&!8%OHW(j-WVudcGc3f*zf!7f(nUT>u0Z)k`~e^Rl~{4DRqv;Jc<
zQjND%J77EOZC-u|+~HpLBw1s90<3!<Ztf9adDmf+hp>ojX4x)zLpoVK=;T0r`XZP^
zSI_O^Dei at FRdb6c61ldFZ(!9sPwm0 at ui46`4#6Kfddk;KGB>>v2h9}5T~r<<%p)js
z>@ME$#$1|kySLNA))D1sF|}e)z9?SDZ1TWP6pI)2jOfn1TrV$3XWnaSRMnds8uDK)
zBQuHM_PZ&xH;Fe>YN;6=+)^1%Y^d?d;Y7F&^kCBGCut2pPYn<OoA{z_h}V;REd at 0b
zGHLiR%jmO-n+o}Hw(CNyGC>fLFDkU5b*Lk`TpV+qg4?;6QBCcIdy<$zl3>DT{O~av
zLky-HCclsLxL!yX2k=VL7xYx$4Xf$8-y5SK3xyY+6XPGfHFU*te=v0_)0Kx-SA7^`
zZu?xiYwW?8(2GGU2gWTo9mRb;0>_70+YgVa-Y&^bl^-5;%@<!>_z3j^jJW81?LY0|
z&rkCH(-i`NtpCFmzEhWbyU2mocBgS734uLq9|7)VB at c}N6=T=JN5hfsdQjJpRE_u;
z_hV%=%w)JlI+da`6>BhM?E~jq<61{x<dvx_by#{yYsFS>wYs;~y9udCZ|)+2#jom8
zVd5`t6oNNhY(zgVKuz#hL|e?>?3hxfTRm!PLAqITzEz$^zGvq-bF+<>auFw3G`aGx
ztW{K-)~ZJpvvFIrRbq#7TF>lh4p%Vspxpvnj3+d}6f;Y&FZi^&a9z6psb0pWnVHU#
z9+e<_+z&QbMe9A$3%kuJK<KjZUZ3MI3_U at er4Kn>Y0O)^!}xhGHfz})H-QXnGB-^`
zFywBq at iLU^<Cd{}*!KZnQQS1=S(72<h*h`HR`(S9!#qBw(Ge4t`Y8mX<RG1S^5n%Y
zy|aWybwY}z!8WMZ8c3?q@<zu`$LLmgVd_6PpYG#Q62yo`1%6BCJxcJ|nQcLDj38=<
z)bbe0j8J~IPDI=UQ34I9T`0yXF$n>$yef9z&_&d63M11i-7b{0EPn6b1 at oRgmJ~W!
zcg#pKjYkJlu8%o3y5UXm?C1#LSh(%`a3Y8_8CLt<ZZTdlKgO4L?h{(QWem643^@T}
zxMuAYk}Fc>Hm{*f!InZ_Vb*rS5r}~0a1ojqgl#k9*|GXHX-pMF+!I@|drGGaf7dCd
zFkvMpNKG~qi(?jBE2f#$#L9VzJz*?H?J1b!P5Y*m1m2EP^*bhWCY0uoNyN6QwBJI%
z`TWIR(_#%RT at b}$2w6Bl!1XmEC8C<YlzK*@kiU98DXvxp?mV`2A^6#AXxEVj5}81>
zl2_v~$c88YXVN!>NQTP1+-aGr*e>r{TpPY-hHRwlDj_X~IhMmxpohx`W{dwA$wVCU
z3Y7M!$=1Mz;Gm&^LKuouP^CGkYCX=7z|5oK+`d}Yx*+;MV7!=1r_)644Ey5>FW at b?
z>54=5ybO499G1dXtxAC5yZ#tq>)4WfhVM{rn7fkYw!vHH8%|rK62uGvOCyY}7z~YK
z8?raVsU7NNZrMph;pCISW&%Z;fJ)?7O%<*`>Wvt=QP at jvXMk-*M at iHCYvdtIZu)EN
zR_GSP>@ZG*OvmY_I%vU|Z3PloMLhyDG_*3g-m%0!iENJs5wc{Mx<mHk=HGL%?w9JN
z0=^#Ff?g2%lWIB;E>zC(Qjn|`93#fxygeIxKZ&}24WdK!gekSNbJfej-25{Ck+M4q
zD$M0!+z(BYb52r}fhE{!>KyAX@?wb5Rq0K05tmga4#|Y at +Yi|fTp1jQmnzGEugP9E
zqmqb0qNltz9?`al(^%@j3lWJQjayW22-0OFTdzW<F>-q#eQ at lRRRVH@PkS`*J1jbz
z!};Zpm)WiT_9h~!_P&8{!cj!yS~)@(s_Lh9WJ1-OmYIU-#w;VViEXhd!ORgH+^DNl
z7p;zvsUR^9kuAY>X3L}I%Npf|HEgyhyuUO~p#Ons04B0ykN!{Y>5s>+Pst{~p9BIq
z|5v1z_9yoQ1C&w1qQu!{EPREZN9U!vlQmbZQO@`>$qn+^KeewZT6-Tt$5#aAb8UWh
z;9ns>c*|O;ONr!n+Os8YE|2wPZ!*e at lQl<gvg4R_PxaxNfpuZ7F|*@U#zAXP&}<TR
zEwD;ZdqLF`Faz79s6G9*Tv4xrC-FeKVz#`*h3c(sM>Gj9w*Dfp!e7IAKywZ;iBGto
z&89C)I$fk^a$TDHFi%l`|7{JoJT}N4nj^I};2O2YlUI3EVhFVHT~e-c8%156H{7_z
zrUg<#9O%~KhUT47F~b|Cf116_L4Dfv at M)czSQ{Eu4<&bwwsA}kN+frinB>EOZw^84
zO|ps69LLz6H$RpC`HQFsp*aVXZh2336+QQntZj8%Cspx!31#MdK}l%kN#$l~DRVu5
zY_+HEVJls&#A);t6%MnPkea>~|J-t0$qx7}PGkrZ6BetoXt_Uj9vgFAovEW%<eVI+
zLQm}dUbkm|)I~!MQ6sVzi-NoWTO}neCc`#G9Hn(p2hnncPh_B<S4SKKMi0FGX
z?LOXDAj0xJ4uvpEM%}$hfAF5wLU-}|I_q2Jsk)$h!&7)DWR-{wok}u4@`}co7#Bl$
zXFNWMAHqwxh60dEp;cr#1w|@2a(geak3;^sk at j4X!UUWuz?zgG5xkZf+txocTsvO$
zYlb#J^Nr(sFiDD75#7(jV52ar)^Enk;K*z<>yL8FGj8z%-IS8eauJwe-i#q<8UVUI
z_gfn4&1~zNRfuyArCtfzA|wS>M=;q$(pKXH@}fv&_=eERunEe0hM=HrN*6&uI%);P
zHX;!$)|)qBBf~MAOwcz)nu!v__JB_NY31+ocXMKXd_fe$*kom{>SN4|AK)N*@iOiq
zS)YU+V^ctqY0=YUS-n+=s~`;yHY?oIpm|7$UR2|Jz$4!#^kY7Vn7pgdl?6j-Y&=g6
zHp%`aRZ~VGK`htYH4Ckh)Ab;fmd?N}igObkm>1l3p~W!ti4YuV_fnhOD=m0~rW60<
z(soE^8Q<5WG8&t2S#XaG4VJWCF864Bb{&hNue-+8%ZgLmNy~DfPV_dZ)6fbT)&5kw
z!UaQ(-v5f*Z^Rr`xfRo&A52(%;abqiuDv%xU6svx-8N#ysD#^}QBbrIl;`HCS;V at v
z3hns8p~CF*Ewk$(bZezO-awx9N17-XM!#`%{PpX0Xa>-$qB!y&kqM!8vdrKQIl at U1
z6{(W)5lE|p)rGgZ2t3?Xc&22ZP=h`7vYZ8GGJC7%nKq0&vo|DiDl*J-h{S8Xh3?G;
zfNKUe<XeZH!#s679dMnor`TO at L*k1S2|e~+WXE5`mnpe~kFXiSF8iJNzg=#nrB-h7
zN(L+IC15xpb8Ux8QZZQm0o`=kH;vST$r(4J7D&*O7LmIe?HPOx-Ju!|1 at RH$)&#A`
zvcbCFxB)9{<Hxv7D)0<fp1)4C+EYYouNlZMQ>QsmYUA-%!Z6V4h&B^%s|Jtubph=B
zB>lG(+y!z4PD^R;D{C(7M|c)6K^8lMe{yX9kTvpe>_p1sDOtnP#gkEz`9JdG<o+o?
z?q6AOPpNP$e`I=?7(OL+JpEaA)_G0 at 1}HzJBHF9jSw5$U0@!~h`u#iG;%Cm{e};hn
zoM8HA at Y>}Gyx!n?3IXXoD1dR|c~{`u<DF@@-xl*ws~M=R2IBjbF>a1`W^#JpB!GP!
zFk-A!ce-=l at O>4ACTmpxXmc`U7tclOV^(kf!T<1VDJ2(D!HnR2Z+`mwBSJ<MHq;8T
zb!&5cja35|C97*QVnHL}%^b8soYte+s~swBWHEmE$yO?7bXiI%QgIQr9ixl6SnQhP
z&~4C%db~xuWMm<&S9lur?n*eYh_B$?h)S<%vEHRL3t9D))YFNTr=Wy2>3pux323Xb
zhhmwlAn5B0(k+`8n~L_%ZB%1jLvekm=)id3XJ%7}gV&^`_&84nRp*O?$TwyFCbP*v
zg|-+of-h|&<ji@%bIm7h(bF!2$JwZ<W>_#q9vLETu~2+dbg`F^{89M?3b_<57nR8f
z&R#KoImkNYaK5qIFQ{8c@~9 at ss+gi(`C37Dk>s{s>(-LZoG$1yar5~%r`KN?5-h(^
zg5X7_=EUqrLXy&~&MmHOkb|%>QeNn7N at 3>`PGMb!DsxL;@O_{jzH-Tsx4ZKWwvvPx
z9;8FPmzv_K&|<lbt$lmMEFv6NxzP%DDd&|E{MMdOA{->mK{WX_gUhbVOz}Nf8S};&
z=A6Bw8Epv)7b!l!!>tjr!~VS7IVbGyiV4hPg<Q2qdOIu}GWILgTwHU@#IdU=3Z{~=
ztJxpm at yg#GPxE^y`DcHCjtSrBdub=84Y|vd-X<A;u*~Ie77(#X8ymt8^s5EG)L!7)
z8OznVs}|J1{l?@Nw94;oLSH7th*_?^K{h9K_}252;=m!|rKETbrHJ*Wn-A!GYnM*u
zkw_a76M2(0mD at Bl$r5I8Yn?yBXM<)%VU_ at c9GtB`LrZKCOu45NQN<h=tOu=-sSq;4
zt<1zH%Wb|5Eku2z*1%={fT=B2i67HlDY3Y55s4Rm+>IB~tk&0x<a6ny_m5?ADnSfL
zRE!g2oE38X=E<)p1H1|d_)_R{a_F{>h_T~)NQPs<2+O6xRx<)0+m#41rI6`cVZ at yM
zHy<b*aG=0~ZLbd{&+6ni6}?a0a-wqTUw;40RI~hDjf035d6VuCsinjRckY at k|6PLf
z at G$h~PU#nQwp}|xp-m1Pu|>5Dqm^630D5Kw at P>R#HIr9{VqHulji~@W@$8FMYqP11
zIqK*Orm1zGibUP=M8+E>E;D>r%8ewnp-$Ti1LjQFu&QfmRz!V6W*=ahk~_(*X3s^*
zqBA7w-b!bkEVlre0-=6$+Kd)5{-vB|ZbpqeKFmHi4qB;G4rmB%3UXs{>7Z6xrY)Kh
z+9mMNWa8xzj_ at Gf-Ve<ED4#hGJJ at rd7J(B!SH-WFX7c<mGG6nRM2O8CCh8=ArdWi$
z6la?K%Ge*Uc(1!7_NHB?mj8WiI`G3vrVx6*DYyPQb5JjElKv%@<#*sci^zmA+Yjl8
zu>RPsYl*=_?Mb-29HO0&hFy!7L(2MiqKHeal4wHf*O~iZ6`v7aQiW)6_(gUOno)pL
zl`BIdhFIfuO~e-*Q>D+IjnSpMKrrsWD)y;QOtt7)T$F4UQlOGXW0 at vxkT*1y6(6Ii
zXXw*h at tx~0F`svUL4w`7$9(!HFZ}mJGa%@HB|kg^ftws?tz#M&aZu_A#SLc=)#11&
z5K_^C4e5j?5gSTw49FCHkdKn>?xj-Fxn+l9OvG_HCAUg5E|-plxh%{zud&oRjv%n<
z@|{Xji87S)i<`gk!<Q`9ACMFksPGN*eh!I~z8GO;@8L={I||L%4&2nA>DR3S!0 at O#
zYU?=~hn1eQIX0e8jOR}COy?xg$@WqNBMH<*SDAh?AP(A76~Mz6uSSj6hXrkm1m{EQ
zBmp+%?k9#YUuJa1i{@mQu_{~3U$Tz$dleKM5jdxYLuv&#I1u`%F0A6In4 at 5R7e%Sb
z$RIIg3LwnI7mCjL3_{NpMQZX$l1h#ssS at g6GcrN{v at Qj~hHkeu)|Ts)syLx~Z`@%p
zfTEv0H)7y^8)0azN`dphP=}G$*}N5Q5fiG at bH|?)ZR}WFjEg+cK1L_)D_>|C3vMK?
zzVs$F7z%dzyuy)w|CU<s_I+W+mRcjF7J~UHo_1{6j}>1HHN3!!6KMuIo#4})7I2eT
zZ0O0m4Tt2<vLv6@;{1Z4G?|J#sB8onfmOMT^{8E2dm*@#akx;iu4T%39vaJWDcdOA
zuk))st>0@?nL+Yxr=9t1UR$u0QzO^eRqB{%ZWk44W7QO~NUN?%qQbJ`@5UUB_y8HU
zlrQ8TQ)c`JZxv2^ZpX6xOYW{pWTHBXKb(P>Yb%p$q at D5c2YnxTvxAT{h*~0e3eO}w
z4B)xs)S52k>LIpK91aAdHp at 2T>}{yEXW at B}HrQ38?n6Ur-|*e5l~1V(yx at 5YhzOZ_
zm~YCjxAQzfRA*m=+z>Zg&qrO6vdd&7AlcYpqKT2mt~z4ZNoQI!X%{FOw;0czm>Vsy
zxLYOJACv)vK;0M2P+ZGIQ93GAA5Mt-(Ntv;!BWt{xDY2yrpEZkh0QusT^XU*x#fha
z8n+c$*Uh|@COPtV8`YkEykwhJ4>MXBJ}!p`VyIRO<MQh=?&C#OG5kmvdL*MyQZ+tc
z15PQN!1H%6F*zv4`AQmfCWOvA6|GPBzWQWsG%ijN9G|$h5Oy8+u*63x1#bl=YG?wU
zMEj*IAtr3JqteM7zD945)6R8i$1#?Y$Hy=I<yd#^P2}Qo3Xg2UbQHk~q!=+yQ1}%@
z=*qAdwdD&j&)agPV!iMIs%xpGm2UF5M&vz|D|%5%Pp`(EBwdKQX7Y}6G<xVZ38s)6
zOm{O<JA3|C_QDSCoJwKg;iw!J+8-D}a1eg_oSBYciR*?Y$KqE^QN5s+l@}v8Q~E-d
z at 9e2qO<t#%+Js)=Y_u%05h+XdZTclkMy>qFFR398;#NY&y0;_T9x48GghJgSW@~$I
znL)-obLE4mS>eWf3XR75e$()5=(1@^#V&y15ks~oklDh=qgbMS8xb8T9#-_NP{^Tq
z3!vSZ%cy{>h4T|La)pQ9xgz~*@1t*Dvr+fH*p5S=4~%wD%L>YHr4i}NTxawWwKd8t
zh^=8X6}w%CJ>_aKM9Mb)le>D(JpPYJ4aCm*kFNsB16Y}bo?j5MdwNsjDJFEYG&WV1
z5dL!nmzLzIs^X5*?{7bt5t~@mV~ng5Pz4jqZetin1f>Kg1qY5HEI9`)BnpisCi=Q0
z5%k5 at MO;BFovFgO9OaAe{v_lj%l<A`EzazlbX+cpbb0fFsbiAkYwm0J<KyM8ZP)4N
zU|H1pC3Q0_h+r{avc{yN`*5(ajPl^YAQ1o%=wKkvawf)?q_C^;pJb}Em*DTCGW1|$
zE!)UshdNnK9wQiM_mIH^@wi}V-qks!y>zT7;oOzI!b|haPoxS}!aO*Ia;#_jXqC~n
z<Fn1Z(2EeG9#}(bo-Ulra%!2TF^iYTMPAJ1K2w}{$)(>npFdQjv~j<LRjM>(1unQp
z)gna8+&_<M-po%e6Lby%HsCVz^3^R0!8>G_seFo=X7M&{HM`EGE#hPvHq~fK+Jn+}
zFu^P$RF&`cu#@w&a}z8Hz>_=9)3^#2j6C9k#j?A)g#Ae-UWVLOe&|pvSQ(v4_}r8s
zbdP9nE3l)%hY;X_Q#o?mP(R5C7F`L|dA6<dVfYS=<+Pos{btnnrofYy^M#9Hd;8_(
zCBIevQorgr=WQlRhv0GRSij5Chcg4mAyCT4p at 5X9)T at dTj{T3?>9Q5QuLX$K^@(oI
zJw426hu?YS<GdZ{DU>Z&TRZ$hHx1)jhofTssDkNlI;X%UFx%K at TnSz|2V2E-26onf
z2(~o|rd*5sHE`vEF)<z%bi)31ZRLJx4F2|7WsQF-SG_znD#2vSz$v%g&Ts5O3j!hw
zf@&3<-T*Z%@Fg0AKN>{05L-CxAb at By0HO+OK!|%BjIRimF^kA0khqH22BOE{<qOD`
zE<Xpf=-{_q at Fx-u#6Iv9fjR~lvcX{nFuc%}05~!sq;NznA(UA9P3Z3;Ml=|aVanMI
zMPPJ+s<AjAVa9QUBG~<~&}^b{yWQ(?rClf&lx8SjXgML&tmCZrED%$M#5S-kUF}sb
z-UO<w5_-Uw1zE3BHDc<)qITt;@ZYfbK=7mL2UD+woiIS4;de_AqLY$|Q%LeChrc8B
z%ER6hhlx`%5pY7{j(R0T6(=!(_%7T at 2?;xA%>pAeYG?w#7W+^vY(jU}@Pf??I$hX&
zd=?6(D``~>j$9Hx3XV>gFFT4wa!%?d+#%E<hDFXpngZjyC^+zSvM2*U9qmIzTW@(U
zWba0=Om9oC7Dj}L*cq8v?4%SZK5$xWL3lypHrgeHP0mZcAdYC@$0n2$sg}$U05$$P
zR)A8U>MMCiP8ChXI~HjkF(J#m3#Csq{WQ3=Q|~lXIn)GWvbGiJiw>tr_x<+q_HFku
z at ng0{5%Wzar)#%rNf(YSGN%eGn0E=Asda^!a|rehc1b4RPIcr67_z*ui?$Fa?djC)
zpBv%oyGcD=iniW1reaq~u1kqYCgNzZxk{EYYz7%8%cRJC7TPA=7TYGr3EBD-Uu9CJ
z{sr!U<^aYzX~Z;YZqEj}<$YV2?;GDtk at ZH$b#4TC>K({Y+EHDmZr5$;MyDf$qZijm
z?x_-+ at E*!~(3N4=IxA52pVEwpEi%kk4ET+HM0}?pS!+4Xzo+vfc?3N2Jm!a_i$#Y_
z8pZVaMGfPOG1xNXGA1T1C&4mQYPHvPm#vr6m2+su=q!H}FXt;~Ek7u4(8~PiXVOyx
z-w?OxvPf9lWQn-wwO}^SvFK;u-R1UWbcJa`-n^mj=-o28ce`(`Z^%QyL*W%FVIxW$
zid7hR*cjoD$P{CsCN{_G^iO7lwnPbpF>hWHQWNTP!>2i=^Q570Ejt$QM5Pa>!KNwj
zj5TsK<~7weesgWwlXk>zNouik<2$(hEVr6;Tt8&HblBdh48UfCze2EUVO`2yvR;x{
zuJl6V>m^Pk*5PZvc+D5gJIp7+%k0&q*QIAwS+4iK6 at DdqMf+Ikm_WFhMO>45i9YRY
z?Jn=u<tF-$_saE@@nU(^`^$Bmeyo1t*W|B^=o0T3_R)wieRq!cn6F7rJMcT<B;hO&
zxiC&_vox|m4mzuu!Hq(eLZw0SFc0Kh6q+Qh0yje8GLljQ-lUwpypExb8uy+wq--3u
zj29c at xQ1PZp;f_#{;0U28llJV9UX#If=vcCUCVHVa9X`@!UrW8swvJM1_qyOP;1&^
znsZ`wB62r<;@XJUh|cJ$kN3 at G)J(r0)}1T{l@=8 at aab?qC)a+tUgve^jj)Xlc?W4l
z%5QSXQb^J^^1K<MlG0KOu`VK3)QK|gGUo9j@$V@!<+BS-3XuwZ682L{6!?;03MmV1
zWn0?DU9;WRJa{DE7ud^oB#;gi4c>@Q0a?kNDbAU-a>|m*YUY=|t$*X2S8z6RzIC$O
zYTm(jR at erfN1nOu@D0BmJ|4?_wb^1ZpK}iV1$sY-JS4BXwL3keCTauMUYl1JOLbb!
z#W%u0swduAru at A+<3nDu76U!MsxZwU^SsJgFoP}!-G?U=d`fgCe?P!EOhT7~4H*eL
z1ZUcDrl%#U<v;JM_S!0UU&vGSyTNzzI#Ir|AN6F#M&5ljLl;A+^!{Z-l{{Ib*3xVe
zb%eJ0S1xtFt|FI|>F+CKIJGd<Yl_XpGjqObA<i%r^BJwK38>&kAAL&vRNOq!9M`;a
z>3JE3KZm>!iWrj-V~u~zPRaIAfM=V;nQ7x_V`-nFjZ<SIK|ig%;8i`+R9<82<+*;Q
zdpLbHbS2<=<9gxl(?RCn_ffuObSvFmgQ{X_(ez9Haq~wypP8$fU8~Fe2zGGm`ZCYu
z^4%Xf{gvibJ7IdB$GFyF)?r_MG*;Lwi|RXkt-tKOT)3R&6t$h389TDy?`Q$qZmfaZ
zWO=XN$@P60MTSAK`zpI^v&75&?p6UT4_xO*a$^cbN^Ht~szvI|2jLHuX at qGJY1io{
z>600P85NmCnNgXyS(aII*%I0HIaE1GxiGnIx!ZZ_dHwlZ`NakJ1yKbLg?5FjMao6J
z#hk^(C4?n!OCd^KOZUoNm5rB+mN!-~R%BP=R7O>SRk>E}e>C{`rCO%CyN0W#qL#8Y
ztq!v;vL3wNv;L&PqG7dBt8t=9x~aSQWpiB%Q%hkhY3qkJ?6$Y<2<@-iA3MA{E;}7M
zzjc{+ZFK8*FZO8mO!q4Fj`qp)4SW*+)YC82-!Z^9&^pL7*fhj7)G*93T>qK<bKMC0
zNZlyMX#E)HSmQYNc=H7BMEj(`WY?7F)Te2w>ERjqnTaoIU*=|C&92Uw%<azG%%3i}
zE!-^zEI}_tE~70ctq`u{e5L(bxyrHHwkEpvd0l0Fal?4yVAFZ?e(Uu%@^;b=$xiVu
zXt#Awd~bYTXMgL!;o$CD=pp)H+7ZoB?XlqT=M&A7ty8Dd$Ft~jyz{~fwu|md#mki|
z+pD|l$Q!(yqVHVa`)@UFckbNpVegY4Xdjw?$oyD(w0(R|?z(<`euwZ6!RF7`)&3*c
zWa9v_{L`c1KOW6Iy`jp=#liLG7;{?PQxkI*rz7EYRm8VQG>17lnSc)i?ZX8$Xs at f_
ztl)uyv9WCM)#_5BuZjZTG|LdkhR76DtF)E6u$8I;25Jn-8A~IB#>x1#c+hQ1kK3*~
z8kX)xIGw+6n~xr+HGw at v%20b?sARklZ5k+i^Gv;5Jzy5wlMswW(hxQ1V6~GhdMpV&
ztCZTIyAUQ5RA3GY$vUrhxterd555GCZO875+I}UF9pgDI00kC at LG+%G-E7JqBR~*N
zFkcoa>f_#`!{H&A&|b2@!Hei at P!0$@z>z?lpx5EGl=%|Qa at TI=$7_N<$ETO-g)(8l
zRO(;IZL`FCAcRlSeqO<tlGwl_RJV#nBmu}&d4!kqRtSb~fwL@#knNmmwem0CgTQzt
z!DvdPDURzmQP@;Iw%~g-ut6)94N?xJnp6z=lm|#|NcX0qzp&;*5u!m{gUI=u21QK?
zZ2+Y-`Ys#|?ISV@={qPvf5{(^VX7qw@(^#1Igmvmz*mE~Iw6F=IVIVI`|ZBXy6}it
zJzpu|@Zy+!e_2hLs!OKc0 at cSgXd14f-ImvLg?P#{d5RpQFvH2q1B2}sg-L3#7XC&t
zN!XT*KO9ilOq1Ma4qKhOp~NE~1Q31D>=tG6XEg<?zNZ-|W%8*M6mQ!|*~S8~rC{zp
z+6``3jSG?n_Zas}<OVYQz~M*;fpKUOj-<>Rwft~9p-6I!ZMVX|a^bp*;O?&A-&_cb
z$8LnbIG;t*4!O^uUR4vQjz#Cw(2YYcC?grjF}<bkrtW6=cn2RI`FJyeP8)!G*w=n%
zmnI2y^dUDFXlcUgjJ}6-YSVP at X&MrH)ENffHZm+X>Lx!Bs`Ex*Bt1 at d{7WwOmE6H<
zZv|@@fjd6`Bd at 9y+6R|w*2_JeY|Ky8BAhrF1tVmMB4T+jGq(iB5$in0bEpyxeSsY%
zqwbee?@_$`5t$ZBylI$f9506;Ke|$vk;o3FE?3svA%yjVJ)l#ZXugWh3K=by^Q6;B
zOsu}t=CM|j>j~q%-As7%&X$Pz{r16qtz8~vuDg4?!dnvKy!vnD?-M%meSpj!WQ!(?
z>)sEaLrv;yJMUcrCo=T)RMp&UED~FCDLyz?)_*EG5wCU>U&)=1ny at RC-=w=_XQ4uc
zzB;zYZIqQKDKJ%qty7?9O;MEX6axA=!xM+CI!J?P(=L|=9%`dF3zq#=r?~DP;f#=K
zR7(!S0QEnRdnu1M67C9bwpkM%8&bFhTezX=())Jc6z#B50S4Jfr1<1mXHZu-I1v#M
z+d3 at 9;AS?Xn@$WjyrC3|lGzNwp%})kC8L?<sD0rp{aiTYkzgCcYrSv~_$n`6W at a+>
zv)0M7<Gr04E46-avc)sQJUpye<K4cI;YbX$Qp3xrcMn(R*RJ`vY$P?+uCenb?`W#+
z+NFNh-le1fZ~-x81Mu$F%uRfM=>H&Q*k(P3-9y at tRS`jC+}l+~hG9xrIk)FL(773x
zr2fX^{z9_JzEb;pLRv*ZvUT*hwBHWJE3v!LpkdLDMPG?DFWV8y+z(Ih5P*NQu6yr0
zNPv5wp6S)BqlrN8N|jq_N!fNwP`GwMH8RVY6eT)B1#RD8Tl+Po^vje{1`9{EXJ;{J
zJ(56KtQ4WrVImi+w5S7}a0cBRT{iOx_vhl4c^E<bl1zcl`da?ZX at H*gSbHyd7Xm9i
zxIz at qCPzj}%J`%g406pIpDYC?KF5H44Fuha8b!9I3HKVwFbHhONNhsAFBMD>b&y=z
zAt;__Si+=27(~s7{+XREQ2dx^BUUU=pp-*3(E~`q5a4tycLGw>>sF;eJK-|g=tzbz
z+h8+;(#pNVh3pGhfF84E7CUY%cqHqWS<{jGO21)AOOt2SYqB+?5+#1E at 1RJ{B;)!C
zT`0v)FSKN7g!xWa#7-IyWoDYDU;XOkl5dGXoPBE-yT!f7>e}L$D>nwbz^v#6C6(oI
ziY=}KZXe&G#jFS7^LIAi7c*<U3N;4$aEw$0q3 at y|jO`F;f=U6y6OQklTF#-IZ(wKN
zhJn2`LWtSH7aB_+mf5b!HGYlpE*I-%8M*JgEWbu)3`Wk;EB>*x97rkWp?wnRMxW5w
zk(k2W?tJH%?9-N4An<W)`0f`>nT)a-kL*e`XbYd+*|C+2hH1|?{Yi5=tR|(Gwn|&U
z!+-*ex$BTp1Zy>uLv5j%@}pQcgf9i08?jvFb#!jkEajnGom&<QHs8<ar0y*nkD;2z
zJ4LeQSlQdjM@%12y7`oaZz5x_Sg=I#c(80I<ZyU9^#nO*XTG|`f9G7!NTGp0uZHAp
z?|v|%SSIiSx3>tVkSK;l=E753wPA2AOCW;GI7|H%cjK6<ap#^)fwpK7R;lJ9mBG%z
zS)9)jWBDDjP)1$L6v4N!z3+a71;Z*_!X5ZANy1v>x at hqPUG>HKxnzegcnN;gGf2yC
zi-yr~nQU5z#YBllygrJcFPua)lW(v)pqt&SbZ>RGRNYP{E~7lMs1U<cbH8W#nuo3E
zLKrDcxhnye6RhY0(4}pS;q2Zfnb2=hJ1n!m`nH^V|LF73>mTUYnimQ!au(y=k7}XW
z))?@DS5}o+pG1g}pUi(&%j#=In%N!r^2dqThfQZndV7gCvJY*2U8H4`siPUd)kd}k
zRlX$YyNv4DV$BF#9f4foDFaUVx~6Nou<Tm%xMFrS8M_Y)FH&_4iPYweiw1bFQsupJ
z7nkz+i4}>C<r6b-m@~e;eWRlJ((${R;M7(ZfdfMRz|kZV%a;q^teBTS=pNwPneKO3
zzkWsW96Yl_$nw_><5W%=ImAyKocCJm97*8VY=74t*}K9>nZ@{J%PQ<LgPLBIuFR;;
z$h*w%8wL6;9WQ)CPtxM2yLc?JvEf8N$4BtxzS2Z2m!R2PqYh_(VMk91cn<8;k2PH>
z-)n@*e9+6$c`KBUd~WD3O^H!wZu?K?Ex(!OB}a?1-8hbBC4Vy}5C%!on)JSk`6zoY
ziLat`bRis7ZRQe3Kq(WKUlG1&(qy@&yh)~ww){c(2v2({Y4*6|>+$UOowS|r{A1i>
z&KYCZ4-bALQ)4s85Bdh+0bF2)T_++{oM1vUfw~qDj^DF-c~_N^P2o5-9Pj|tR^iM&
zUN at nz!oc^Cz7jaGIIfY5n2X=W3_b?qk*J40d>Lx5lT%v1 at 8gIF*ze|0XR2q(YD9%b
zR+{@NS{G0xbQ4ddOqLoxHbrp_7_C!*i2WkKEumDBIlVlrt>BW at +C!4o#<dteuAyX&
zk99Gg*-yq*ztb|PgSDwE8Om%dGyENE5rMqWz>AMY%22MM7LL=DPM2o)TeSvfsRb5Q
z{?!zfW;%Is!P{}$jqi2`QLet)jqOPg_{)0Yr;#GFr)&nLPp>t4N?i5~?@-pH(f4rD
zDEl!ftiC5?a&%F5j4vJExRO?SVN*)=pnbQ2$Nv3>(;_DUm3FUwySMA2cHMb-F1GFZ
zk}>|g;+xf(a(CuT!e|z`MryizMe9Q^R9`k7bsGmh9es5a%H+Eh_-pn^xD0ka#%;hO
zh8=5E at a6oEBi;bw)e51`ICIaFy75QFJ8d5^Ka%jcJ_b*Hzx7o`DzLDToev(C?;xZz
zHr4W7n#AmDc@~|&9(3vOAS>Tm2V#>@50ERymsYW8%n=u<=65sTP+~a{2%7PS1@`PH
zT7bbXx5Ka=Fh1<z{2u^0K*qoOXR at x@MMhrWcMYv*^eA6hTVCaj5Lo|U<oTvbBlBO5
z*)zEVhKYuZ)t0?gx|(fQ?qhB})4bNV@=#2-i at 3?F)g5=Qvku4Mth^Zq7!8Fdv=h6N
z*W1fn8NTbA6cO>bYt5Y6!IMW(?(`D^Wr``UW;8E>ugrId@~)u0-9ctjROrQf9D5m0
z0OM{3&1!nOLD at 2ND96NlGzfO4$g=jTT$%g8^u1ioxK0(PT(>%nq>%jF-AZ%xL|#pt
zL%!hBuIR$$1wzbq+h_S at BOuPzL=$ywF5Ir?M-A$X-|(nf!nV3~zYT+blDl^FMnzu*
zikR{C(|oyWN=NCQ01qt#!R++{%&@*<a#Wb;(qH_u(4rFOdx3_Ceq_LaYybcT2Kt5~
z`sqRNGl0q+Q4@$0{I at qk{+1gdzwxsFm`44aR%>)lQR9`CiNr>;m`I%hVa0EJsd at _M
z!SRZ|90xPc9j(^R=~1MYwA(9fN8RehO_vg;+$Ki7JNj;=)&P&*ZE4mZw;!SpkEh61
zPiobz7(`}B#N#JRjQEwa5_scq^&$_gTcliEG7r}udDeV0^2e<DkgF;q`hQIt9CLCz
zF!eidnefO1Q?b<&^T<;;(VJh3vkhIbhImKF&R7xE`@^=E5$Gt=%nkQjNmk;A+!BS&
zGByrwLVjwbeZp{|1*U0EY9!FZFYE@>qnz4CrT{%kBloE4no;jgcCQXl`&GAH|Bs<*
z7g~I!ar+wY`_HqHz6pha=1o)m$e}j$LK?+`n?rxZc>bvHG9o`;C?vj$!cR;IYQE`0
z7%$iD$hmxB{|@!i%7o1%Ag)kkC!*p6KwLKWtK1QAe)?bV^2-FnUbIvd6cw-l%yLX}
zHpCmfFX{ZkcI&V{yl1}h3JGG0dUZp>*o-}XoN!%{yNJ96@)RA&@R^s-Bhi33yNo_F
z(lh>0Qa<`^L0Ri;0j2rs;FG_Q)2`hGX at xl%>oSqgc(%%_werFz0p?4Z6jBgwtyIhM
z7NzYalVp_1(m{NISV7X+SZlWkrPPxt%<+eYlXgeOLd>spSGaMnBO7!sukFF|q?@RJ
zMB8nz#2h(hzB{<FXDWS6qD~dd*QHdvC}<5$2qZo(8&KR=X$#NOYS<zyJ+j+-wnMvt
zT}dpJnlqk|v*t`J!K5iZWM7YmD=x)rDO_|P^VbtR4RCtpz&k%8(*u9o>$88C?RKGd
z$nCvOU6{&XzT~@|t1RCfkI6lc&2A^kUU1y2k-}E53w)bzc82(@IjcGW<e`ZW7F7^X
zg&SA#-GJ{O at Rr1gFB~fZI at O%GaX|iK%v=ix#gNcZL*qn|^!@2CL4uMP?E4`II0{<*
zr<MdL4J@|eAk}`Hhys_QWT!DDs~SizunJYDWv6a%K_GU~a7i!(2+pzMTEgfsCX5C1
zhlRrkFem693Eelt*ifG at EEsyWfu4h59O%g%vW7w9nDadZm>x_A2EYJ;I#=zz*drq&
zKNCAADuf*n<{J_i^?BNe;=y6Q1kQ=MwrzcaYLlho`}kPT1CklBL>0?7l$KtpJ2n?B
zug%1eR2hZ at nPY$Ed5-Z8NBJ8m1xQO8m3a~K(v^ko?<zJ;R<3F&RyDCMa+t_QP9aQR
zG*Ffgl}<$;@#;^6+ik#BhX=*Kv*Y(Aw>|G1U<P at ZKdm*sSUl!eIeMWlBDx)Ys!NAA
z*OmTEDfm8qQ%qA#?{1&NCN+^+N8NMNW}~S8_TM$BT5 at zt#i^Wj{EIL~>$WD7j`fG?
ze$qKpiI=_9O3T<cnKxE~JD{1%3PlnMPi4IRHG<Wb)t7?F94n at u=?o5aO};zVct5^p
zHpb}{hxFoHsqeb84;o|DUv~(2h>ZXbVfX3eFdz?M1a%qAE4>T?AE+|VNl3K{?*3s+
zk-7-<usz`%f|EZdk{uQVE(dT6vX%ZYK$}1d_R|5i0nG&i at zYEu3sNY@mlYzCsH=Zi
z1k=xd9&eyNKwcQF<>XA*NVBk{ZKTmX2^LhU^(MNtmA1$gAe{d58wgqPXqFdy=W*w&
z4YSn8@`_oX>D&`gTr6mbj}0+6r00(oG$<p=5kLSmB!l33vfkD&^n9wvwx#=*QXl*J
z2(DVSTIN^uWJe(l;a>HZz4flHYir=>x{%gBeD}b<zUn5^iwfUd+wrH_h<D*w%5>t+
zl;@9q+}GI*v(aPSst!AO&u at kX%s?sVzDu-Tu^O&-6?cj8Ua)kPp|hEXdma3-jC1DJ
zZNFIDtM*MDZ-z}b<vcnww!tx$`(%xa-cuvI=~l&Jtgv&cWS~fzo6Pu|>nZ`S=}g1#
z_y6bI8?i4D#mJ2-i!4nLTPUgIMu^y##88P^5)7ebO0}V>@+9_A%ZznA5v0S7md4T%
zo-%_fYBwdc)Y75GXdg4U|Gc^F%+t<&pL6ba&iVfHzu)(N=l#yPRCmP4xhd;bHve5f
zS at DfW|BjCe*f_DNZ^X9#Uv<11<m<90BQmkow^QO=8;_Pf{qB>C=NFD_w60=J#)kNW
zgX?xx>^#`%+7{27nN#QAp6vbTL|%iag4XTR0;g{;Ea^Kv at ov5I$45;an7Lu>uCY(s
zf3>y}%W|vwh5TXLJV11NSqdAle{Z+rVc3uVdLzcE24XAa(6+^1Z2`09&+#i00;+cz
zQzlPA5?tn)z0j8`?VO>qKM7)tslIA2=GF%x+?wkZXa<-Y+-`Ea<Lk{a6XEtvFxPcM
zI{)dX4G6<ZY(OhKlr}hwO7zASyo~->fu1;pov4GEasn3INWoTwNeC46CYY<a2A45{
zYI6(M5s7qMlLowx2l;4>&gL%n=~!U)(kqZ389T5~CdnYg(N0q_63v;Hm`VgA(wsDx
zc(e|;q?IX08m(_o9}y_PGBm&h95>I%v=u*AN at cd(MJTdSY$aGlW+J*^H_l5stqjbx
zFV)zMNgTCVf~C?_ncMiYCDg<Myn_W~ybG1;MV)MKq&9}*C8}u-ufB=P(oovyBokqJ
zm^D0GibpD19o0_qh(<4r!Xj*9HZI^MzL%QPUe-w&aYi24m&h%hpHj0hhs?Kd><8E@
zZKRC~R>90xFj`{>uPs3d=l>9=C0(+lQV!`7JKopbG%`WvHrFr;nPj+u-+4FjSmNo!
z8FWkiy4AvZ-ERAQE+ZU+wK$D4<Z+F8{~k{yinyWPRt095*=lb2Yb6AoFaX2Z17@&S
z{E at 4A7@y)F@>JEJ=PB!mJ<EP*mNU2E=t1uN=sk${F6JujLIrVwQPvk1qv#}kWuT0g
zC9+Z~<g#2=4i&1Vs(ae2Pv|eL4z_I)d8fu`!Fk;nhFq?|+syWI#=8|qa7=<ETw)o~
z1&;qgbx|qAW_3zk)ARHa>zVzY at 4D|>-&0crC#$R{^DrITnT7A9F*&rB3G$kJP3BA0
zN4k!#r`@`}epwIJS$ct9q5rBsx29QT))l*#onx0db9|G1XH2?zm$?u)$SVRdNI*x{
z&p1}oMDoigreQYbq6mvwFUzqJWsLhEj^RA6;_qAmNGLhyarWP^>gLH}VvT$thvbMH
zlN<6wHB?I?Qgu+>RkBJ|<JCN3g*vS+s5`p3epMIfImCLsM_;yJS(dTe5@~j^UFtaD
zjC7_sM+bcN?Edqp=ULCM`QU5n`?YVS?~w1d8ER&de;8uf!)IeYS*~FXmJr)niF<Gq
zpW&jP>myNOv*MeGo7E7*RqHN2r5BMQ1BfBSFd0td$Y{wW3S^GFBZcy=ERy&ASk2f<
zWSi_EK9+sNd8v|b<eofIEMlcu&0#7+#i`DWG+Fgj{nS8WyqZGft7&QmSEy8dsP?K0
zx}gr!u{uXj)ob()eORB<|FV=7W5rort)bR<tI#@Sov|)iPwf!fW9QoI?Zb{{js(XL
z#{|b}$4<u`$1|tH+21+ZIoo;8X#&EiR)1mKyYcg1oa2<dW;e3lP*r>`n&^Ccz6 at c;
z9BQzhq!;Ti>~Zo?yX1-#={!BrY}TpjiJl at u)j?^gL+nI74hvzVOx;kA)om+C2CKUg
zX)TkF)fAnq9DZFrYXw<__8mZ7M5202D%BBPs0+;}NVL~WmAzh_fy=tC8ls9%^?bF8
zgFaVzsu-D8g8dYE%=<R`4d%O>S|CySoV6aev|IgC9?D9p#!2aIwNkIB&QeCjeJ(9<
zU#22o-ba$`m#b0%k*&H^`lwo5Ew8FA9R)b4L*<+fL{>FN30FbVUp-Vq^a00d_7|Z_
ze1Tb_C7!kO-=B}~gyXP6MNrc`RFkvP7EQ2<djHsWpjxr*OLj5qY?F at R`(->vsuM`$
zvvG^a#CvFqeXPL+h*zsI+su(M)cp+Vr$U8HK%CU1S_YF_0sBQ`)sk8`inBhU{vW66
zr^^HUR$P3tDiLW_Us-5*s7%?^-(q46M)GJamOFOaXVFiB0n6oE&no{CudwHQ&H0<6
zEBOt_CM$-lT~y|&9I at 7y#=e+Dh9^YfEpqP0=e)m_M&(^;CNRQ0_NYGWiN}y<Rw0>d
zH_#NCVvI7I%m|FfAhVVFJHzZk2h6v#)KELxN}$FblTX=?{wBrL?KE7W9)(F0+#`07
ze>ZzSimZ#&&hBQRIgcRbqa`ymnqBlJ-_9Q}Z)v&`?R<Szxk=Ue>`+x0U`kDh1R~c=
zqVgU<iPNU`%s~sggtd#L9zzBvb?^34*Di^jJ9X^PKA|07x#C`ojfswG9T^cG*2>*7
z)D_a=SIwI>eW6Kk<3<e|)UQ{!PVHJX18W309k!*FAjacP&31Xiv%OZhJ1s4?`q-Vr
z6FEOSk?nQyRO&B%ysm7&o9maJN%S1|f1XJ{dM5qPQ|h_8qHAo7%j0%=Po}tC6*7E4
zChbKj?kt!0zTeL9+e`g+ZQ7xs9N_Xa$xU&2CEMlkrq0MM@?@v*cI7n#likT<17l-Q
z9$1rRO<LYycYe79cN4#%f<1}l3IVlA%G=bP;_<%VPN`<#)nT5TG2Z?IGCe8HLPN7+
zW4x05s(Z8-?jGK{(S8>s`={|blD$s<G_JhrXi)4bkEtwLSWyq7v!iQ`agWIvk at +9i
zs|GfT>j=-j-P^kmjL$#(`3$*ZIa~h2{FI+F#ayuOVlWLcHs;QCnlqRPaGOx^6VXP&
zDB>qaXiM5g1QCQ#n<CtXwMkl=O30`}D6ME(RR$%YZAwC0+5{p5tss)O- at Ls&&Ic{D
zD&q6JnR)Zxym>Qk_Dr=S&U at rlVBdOk{5L+HaEHa>`E{{fnOdKkj7(VPXEvGK<u?yE
z#WJ-4{u_^D4O0Z8iDVQTzl;zzHv6%c*b$GJ$_{Mk=X3Cx?9;6=A}mR)_nQwHi;T6&
z^$A=|QPQO4TLXPXMd1PKLn?~+lPxhLU at r6-@s9f9-a<+)-+E$V*gtWkrmC{nn`ei$
zcT8?-Fgho5uqLgOBRQQ%jmy(<RoEkAG19^GulB=}n1M6R<3DTWQF8S>OvAsp0xPo<
z_p#1=s4kK8)<EuMd(##48vf)>!u=bcelk+hk&@^^?@i(%XGuEIpm)Y*MTJ>j&I#hK
z!;QknTFK9 at s@&2qOk;!B4}$Q~6Nqg`yrvq#4+Qvn_w<Kp6&SO-DQ5G2TIK7baCJr8
z6baT0I-0R7Skvuj(&h;RdHfdoHPKkpQ<DCl>m64RSzBW&<NkwsjjeBNHX57SV*W at n
zk&10&%LvZa&r9o4BgIxA;HDNtq!t at Uz2$8&7T~`t7&Rj65)CLd_-Gc?#Z;e&+auvq
z<x<Gs_Vmik#76U4T2Pny-`Vf>Ac3Vs at kdQ>qQU+f9~B5Zpi#f|8Cywm$1HUwv!-Gs
zKYs*2!oAT+6%K19qOqkdnH)7j7sX?hOhyfVG?_?t^jqDl48PY%4yZ9TmfR3YIM?5A
zo!sLyqc6vCh_y-$Qd`iXUPIa4)EicIH at C$GyhQ%pEwMhKh`Pk0c<)r`Vgr7>&r&K_
z%0g!R%%H!aD*A*+&i4(3iMpj$lLE=F?pH|4JdRAE)&0Vjc^#R6OtWQSDdT_qQq;A?
zGIKx{R=i4n01&wY!x38PrO!7Fmw2Tl^Pis7LrO7^gadqGtM#-4KQn{CSM_7mpoegZ
zuTv9rEx<I$_h~Ou5c8h_-we7>gouBdE&)CRDuHIe53B-Wz*69Opb2wL;9I<g19dO8
zyT3vmuCwHIwbB$|3C4!@5tVBjDS&YU^Vn~eI*H0Lo&sH&dlKfJwJx(B^QOpot+3lj
z-O$&9e;CMj?<F5-E>Hk at 5!N}%K7%%@r}?bbHH^2wkHr{&4jP58^`J{3Uxx7lAO|*I
z6d`Lh#(5YoKy30b9t}ibcZ+Q>KL<W`LSG18 at LcSh1M1_sShGyMp!k#n_@=r*y;=(u
zLO(_V=jJmzXJY@^r+<Se`<DsZKMD3#-0|%$h%Bs8XUV(To;vG6agH{qhpp=v8+su{
z814%+8Rz>12x*-((LKrfD|}q+dW&X*_W%<lc+G>fQ at uf9=qmJAkvE-GD`r43+qx~j
zNt5&-J%;ll-c$<T<D7fQg{hd=EbTjKvUZt at Fb*?3M1M}l39-T5H-gq7?pHlzeTp^e
z7+7ZjI1T&p*uR=%!1u1S4)<X073iJ=HX=tR0^_0IBXbxwY>#~&<vr|sAg|0pfO8L+
z=^%AK4jy(O<9|$I955c33-G?L0zU^H2foL1u<kg_pA0`<;GE&y<ow{=kok{%k~z!w
zxDm189J6cYhvI444HN>E_))Smg>uZ5^}_eaK65Sb+MHXQGY*Bm#Lj!=8lRJMDuWuX
zO1ZbJLC&oVTE at B0R1M2Bl!-x_!#Qim+M&{i2-hRmghL&FxISf#fT~?oz_H_dcc>GK
zG(Ai~=$5+PqsO!vv{F5T{BOtj3DCKS&mmcZ*R=1`$6^Nw_aIf`F1dDJ%cA=k?jdD8
z)*D1DOSE(JnxsQwiZ-OUTs_tmSC4qXhBMBj*-!>;9aBc8?!T4)FA(QlJ at hoje{&64
zmNrDM;H>2SyD}Z{I~4Lhpc^RnR4DsBT}r=u1$mJ-H-KlgFn+&=X|6U%3$?Mb?t+l7
zz}nSX7tM#AieG9ksVnG+-a}tdhj5SBOPr?{8N5E|hIAff=iJ at 7B&n0H_n=$@IS!RI
z6|(*y>nddZQPyP08n!8gxHs_oEc*k=w>i(r*K}UKP9^HijQq^X(~SI_4?AymUS`lS
zOjErj$Ej1;jN at Lz=a=tetE?ya&Oz7b%+IE2`(xBEj#(ebclaE&Idu)p0D{o}BK3~o
z9maig&)jRZ>(5#3>JqCR=lrR at 3-r2mLX=v)>7E*-nW?v|$myjVC)YVDPWRCuEla&;
zLGGv8QS at -Tj~2-O`4^htx-Q?gnbKdbL$1MUynChS<NvU3Yx(qy`Vx_fx at 0+Wq=|K!
zhsLUZ!kfE<HmQfK->LiL8x&E8DXvzahGC1CO>hY+cGXiOY)G!hb3j?f{_7g at liz{{
z at VG1IUFN&jZ&MCX>bi>es1<XL$+HIKJHDT$avY at XX7m-T<*uN7O;AN at PEgu>4c`kg
z9(V&YVv*|2wY;XjT;^=9w3%hy_T*ED;d+DSVE>@ptAT1fAu4gTT36+FMLs>Qo~7w(
z13iLqk<9yD=uu_pmksETfcg<IjNJ6vyzJGITDN4s-zNL{Xje6 at l;0Dq(`m9^M$;IY
z0bPQs)Hkrsv&gI47{6&*^84WTl*fBR9!-6p at OOfc_3~TTy+c)8W9)<MH|);=<lDRS
z2=_$y5yWs5*Px;x-o>dtm=9inemeu-Ny&<BsszM))GBo?^r1K<j*C-P7k>w;@6%K2
z4{(3SDWJBYf1g2boR1#91hM)J#nfM8JO%PYz!rS_ZK7N)mpau;m^Tx;4X`_hHI6{f
z*a at 49pl{Lw^_R3x9mMy+CH_XBfVLU*NuZwUlpj-<xJ6z19Q5S**6VV8#wP2_5=YQC
zFQsf#kiI&&m(N at AZFdiUrLUQOvXA%hkJsRJr5)yI8s!pM7lEKnhnvJ+>H!Xm_c8ZN
zv{gB3om37|RJjZsOyMWgAZahqgc_TzJP%CMX4B7r?HE^ro&t{BJRJZ&0Cr&Q)1W7G
z{8V6wMaXAR$PNMffnPbgOz>X!l4ru at vrdlS-$t(ilp8q1jgdOJ=XRQd{pM&3tdk7&
z3VH~jZ=*u at 7AjOrA)gGpEZ*hAJNGtCy`Mk#gYqs-moc;vevmUhD7bdHKmWhhdr;th
zw*gN|AFkp(mN`UYl=Id_&{pL<`u1kLr2zOU at C8mhoqK}(yHcKYf5;V5$@*uuJe$wH
z*Zc9}1U;1rClAv3 at Cwy3w1t=tWb>YPsFtChf$q%Ry!NB}pbg(B2iPa%VCmhwzKlv4
zVk&$sVw-<)U#+oG9anhf&fUAaEZ4g%h6o!oHtPi&FR at ulOki8zB__lV#imdmu9T%b
zg2Y2Mg*K{c$D}PSq at i{L4FnqOP~1kfT`zYrSspExswPU5fGbsPRjFWFs{W{|IuEF5
zZQO5W?=@x#a-61rs?~SCIp at r4=g!PIgEI$=>Q`{D0-~;LuOnUp^6Uc28N^~>)V~OK
zJ}_oo9}(-yj-~we_p!fA`uD;74D~WlhkW)jDFLqnM{OS6-`0I`&z at hI+V7*fxJ&+$
zR_E at SxO+BmRvy&n{}XU_-Ui+T-uPdSMG5vQ-~(iix|A%}79sasL-1T3eut2uOz>31
z1)RL00hE7(@<yNt<=0_53f>RKRWo!4_7TJp20o!?A%7=iKY%{&G^E-N-vXXV^)Y;b
zkbnQ)!k$$7p%;M1;X`INbOv}0_!&@+Hg-SXhrSE^OXw?7eGQ>Jd>!}>Pz4-G at zC>t
z at Vha_??gWG5%17Xl^^u}__%DnGa@$M_lB4VFa212&zr;k{^POzmiP#k>tM}a8#A8=
zy>aeg>>u}7AeRn^oKob`BA0a_e-`=UD2sR76OyM|{n+dkF;L{rB7b!(M9!Rg=M{~4
z4=%Uk#@M at +en?ILJ|NrT?Wl7bZ=K7CO<vroH}U^Y3CP$c;u?VYUXlLaj$9IT!0$rO
z0pGM^ntiw4cgKzs(>`r|qA~Il#MH2bSQ;K=x3Snlg+O{No+!qP-Jdv?KOjbrjnn_F
zZpV2W<K?CI<pJa9<MlUDJw5N3u%4Ee*m^qd^QZ4UJD<rSS))ihcN2wpTd2KvbANjd
z>F0R#yxDJrX2jGnz&%iam{kaz#C=f$<N$u)McAHo4Uw>`n}nhF0%u|SJ9xA3f!pXo
zTyD2UhM|80x=(#q)?H^|^LYC?ecy`wT;_*ZGkFiTiusdbU at 71SP6IpbZ!O-Q82hiv
zMMA_oSFIblsa^)sa=>wU5!nTFL-#`Wo+qnE`q=fv^5tP82`+kAvRP0VJ|`Sz*39tF
z*>$Ch%q1L#Yv%N9>A7kyTV at p=S)3{)=FJaZi%w!!$v*&vU1is>=(1I!;NkFKREL4G
zXK_<g!bv;(BZ&hFG1wmx`E$Z;m)JY-zs=qvn`N`NOnpii9lpt4Cw{`&S=MWLdJ`E_
z!X&yIA%&7Y$bMh|7z9*O&wfIhffk?#P>C0k1I0j%u&_?niFtOQy%(|=s0UgAm8 at nz
zg?+n_>@~KH%tqT6*kLja{9SfP at +oi@_$2JJz^_6V+-B*=!NPycvcC*{I{2u?M_|te
zzXV<I4=nww*w&)m9*f)AZgUp*MQ6dE3zPs1rNby4#?l>zMj$EsCfgxLIt>nkccvK2
z)nw)c<Tq+cJTxQRjwNlv(l=q{ny_+BM1`x-uG5&RGoLl0P9y3xqD~`LrG)Lqc)LZi
z0O<pA0fu$ojdd6HIAkBtFYVugYz5kd#-71C7GhQh*fz6(W0P%7JZgl?F0iMu)CPMx
zF(W73a#wRt5*rbmVX;@#-6FkP67I>ux+Rg7lVa4`9?f8z$kzb{SK}s<4}1nF2UNDn
z%rEBW*^^|aix?TaS!rg?YO_NvDX0EREKF*VNps?7^GO613VAF-OE<V1+<V>3=gxJP
zxD9u$+fmP&Sqo#F6|*u{!(z;l9O*NiOBRBR721-8t)6yI+|%dj_c-EOpVqGpXoH#~
zS1ZvBtybHhHE4UaR;^ugw`#3UWrL@|v)99Xo?K6f$MDp89NbCUqx;xK{7nMs0~&x<
zK*buzV9#Yw0Wo}y7?$EG*a;+o<^%ds9soO_c~Q at cdR|z)uzF!7kit_7YycW8uQuwj
z+lcyu!UN!0z%pRXz}gN#4vG>`2~CHlL(@^KUm3y-eUQ08Ex at F00Kl$+w0$L(e*>UN
z|Ddd6`wY=m88W^!x37 at K3u${HZ7rlmq%0aXW<&V>{#YOuj1|N>)cQbuu)d(aL#+wa
z1ZxUvI at Gd2S+K02tV1mh6bFk7iaS&u;6Yx%JJgoyp6W~0SE|)mb$xYnH7muZOPEC^
zVac<Df_u#wS>aM|bg9yVzY~LO1Fiv#aL8hy45$ZGr3aEL-LQ7U+D&SJ7~nvQZgIUp
za?2;|ZPF)7!mr%pXZYh?=8}aq(MnvoF`x}#=(`L4E?GNO>XG(1<bbr-SoPbbokQAf
z7%sRvdCk?~_|=gzAO<u54swO9CD#D-49S58pa)P{9e!)sTBRGmE~Sfw41K{gPNq*M
zg!repd{Lh=8GArSa24{Xln10NlQQ4PsMK#&>c6Pezg?-%ML{VbQ8*4unP+&S`kAO+
z6V(f&I(mDE<Plw&CZ#4M{hO3eN*OXT^Yq(!`UiRXdwKdRdHSwA{j+(Z-AtTaUCETv
zBP4xE%1SBc7#^;_!S%IVFXehvrza>zC(ERqC1tjd^!+p5axZaTpzo7%^hC`_Ax|nq
z5*;xkQP3STvH~=0MoxhKWkwG1i}W^?A&uTL^KbCzH2NW}P=)@1#qZGy(g_{}Zw3FD
zL}(Cv%8WcG>i-Dsk3m04X1hfFS4pjG*G4O({S~X-56#d<jC$M*eGQ`?BOy8J5i at iH
z)<b6K0O&<Cv;)*)2E_!onUQ%sI)!c}`HHB!i3AlflWJ?kC(!c_ at QPI9<z`5<Di;GJ
z>0 at SK0cft6<wY7GwQ at La2IQa2ApzONOcIcj&L%<08PqE$uanu5U1s1p^rD>!-r)a?
zTo8Yp+ at xOf1po6z{J%9&|3oXyPX6n2V!2FyC6uJWv;1=40{>NhlCCj%UnuE<<5DQ8
z&|ZETiyTK?g`VX-p{=|-AiW&{c=4&*BJ=t2KplTM2;Jn*g)WL|ke&F)Yv5iV`W&y0
zbn?f8NeZ_S!C=NDz9jHv{wU0gle8ky$rt1&#Z*erN9S2S4<pVA$f<mx^t`f&IO$i6
zkaLf7qjQaOrE{rsp>w`7*O}v->CANbT|QTaYqD#S%jMEss!MSZS7vf#z$hX(g_)X9
zkfsW$%Cb)p5<=Yi3Uw(sJMpQkN~v14jK=*{q-yoDcxh2p(mC?^_~N3fxU2Sy>rPYp
zz4g%I%KjuJtJh(J3e&#qxc{+r=Ln_6`wnIcZrpcp{d!sz at 7qMGHs;1}t-}A9w6ZSl
z2>gfjstsx?JHzMPo80it4J08U2_!cpECetlkbneo^9dNf1a~D=6hu^HDzG8$qPXa~
zYQ<XD?JQ+FJGIkwQFKQWu?o5sN4wqDnGT(H?T;O2yZxB{*p}IL%Gep#VBd2=U8nx(
zOmFV{k at G$|@0)X;bMCnwB~t8hDP0*g(#nAE1*&URo1a}u^EWT0HaZb(Ymc7ShN4#D
zJl2MS(b_iMruI2%h#K(w=BPnpLhW;SFE!+ECGB{xFZ2|KIBF1J$Vm)=%^;4z5Qk?3
zSc3oqnsR<$jN?{7w{blI0ex- at pdBlH<v|MQtA!YVQ8_42=qr!PAu!;>N at wZc>?{T0
zbfL5K6eM(}A)uJi2#_Kpfy5j}0K|+AA$;Lk*kD{KCxnbb9wQD3c`$y4d1(a$ELg=*
z34k&GKd)ZT{{Y4_-S at Zk_<IfhE`z at pq$_%S&rW6Zz*e0uw(UL%=%Tc#YirL=V!L~z
z_YJ+i=r)5-7whhMLAZy6yA8e=>hW)AkM;1qzRTTwx8Kn13(ZW8d4td8I`%Y|ckBh7
zjgij0B-d2%1>qnGPmx?fk}F7ZP4QDgu3)PN2V2@>3CI)jZd$Q3RB{rmhc2}~<WaDL
zHNxVk(ktIkUl$>GY$cmR(G-IxnhHWf#qMG^3Bl?lp)_btUkxeWsM4#i<8!Ma7Mi67
z4>BXAzt8vd4u`|TL?RJ0=;4S`Xd8w_t8WWN1M555qt2+)ALYAzAxx$tvU+*jd3N5p
z;G_neW6qP#)6PpyaU>Fg=8So6fupu?1Kb#Qk~_^^;usRx)P9wBp60&d=m at Y055wj6
z2{|KR;U-^)BVlqONDu~DNoS6jz3pxe^}uNt!^ylDWr7$$Y#?nQVsr=e??C<x at -Gk(
zIt2RrAn$|BkQTa_F7_+?d?aJYOg0 at QZJn`{TPtS4c5h#?Z5=Dt-?U<#ZmSaPWtT0<
zoel?YjIM*e3-TGrmmm*8#I%*R3Y|w*SQ`qXuo*-72)+yx6*doJGdP$G_i)&3Mnnj~
zVFmzd#?SK};cx`OP{4$M0g%udCO?Z1`wR$sum&NqhMbm>1U1Gee1p0P$5aV5e;J8I
zv((KiG)j^X=cgE{5*YD3#3 at AM0+fjR@n)nnvk#ncXA`^RY>YdR3w-tws8Wkws+Sr;
zVT}kq($Tjb at nZBf(ur=tpw~VACDSABhpbX~<t#;R?B@;epJ-~DnM#>vr;SrZ)0R2r
zYRVitXS`Z8XGwV{fu^WgI-i%pqXiz%n97wSy2h>!BxMAWW^w4Mh!!Dh05<&)pS?Cv
zSV+M+fX2!B6*Uj-6)h#0E#XV3l3D6=KGh?s$bBfUNK<(>bSTYGd}I8<BKx3o2n=$$
zSSNfI<BO~l%p$vpr5Tl#M2?o2_p?7QwJ5zK{GixfX0(`$M&49mDl$5atVwUmQYaNF
z1<j-wwMJX1U5ng#HCkM02Cu3ByiBQFi#Tzv7H21er%42_e2rC$T_#YD;<Z{-{Sqiy
zdWIJ37*L8-wHD<hfI?3<wr5jV_|!XyI&mk)2CTO#<TA#<nM~znc6%1b$YoiIEQQVL
zu$PzRo3K^!d|V;`o`l7NkMctF{YNh!efQj+=C_(#jt6Yb3Td7^*TPv#b at X)YiN^E8
z^~ai<kJVZX#U-4jB+p{ei~ApTir at d@)Ww?{KkVy^ZLE0x*715rPDWYdm79&W`0kDm
zcf at XVobB(s_)57waA&60=BU5?QP2hq2tNL!_-o)oDXK>GFn1;t{31xPLCmBjs*`n!
zG__9UW at -xu)bQ$K8}RH^Ga at SvlD8O{qKsI+C at rI`fVbsag5LbCk}geGL6^0+deAyt
z{h2N$CDokC)L7jGnv_(kkYQ$V1JBiHWHmJ!T2xe0Y*{10HccT at WUk3{CnlCoB5D%&
zHA}C*QV}rFiL=xgpUl=SC=_gRDXf at TY?(oR6Z11Tyw>1PkO~!0zqqDx<p#5|vQuaA
zAwE-;Yr>|3UFEp^MpbMecQBWNV_`9`_Bpqx22^9Jld99IOR9O*g6a>duT)7Y)jD{R
z9-7e;GMbx~IvW?4I?4Si8*lRW`u^I;E-jM#0W2=E##rE_YjH`i8CjJW<Y<~eO~TYC
zWMzL<YQdeb%!hy(uMT0ooM9-50;byT$YKZs@&yeva1b&$>^6Zq5=E9kg?ytOtjRza
zq{uW8G&t~UksP1d*cRO#`fjbiOJ+2l`F88{w$V?9KDd4HA8WWbw(fsz;?(Tecr-^*
zu>9uezK~~Qi2L<h+pAw68IQOkbe~b;TE0ELvn^P!K5-<pYxm31y(9lTxbtxJg^s|9
z9lL(K<xd~|_U)29wK%zIVpHAbk+r2Gan+Tneg3KL{-0RM;c>(AI%-t>J(P*o@`efN
zSt)fS<(QO8noN|UNt_9%%cR6}X<Q3~nFF#7o5?2Cxfpi}qX#2bY7rKT+>~#k%30(f
z0|Sd7hoVM*(EIj#*!p1KkDBz^>-H}X7#p^q!sDM}JAS;o(D(P{iI0DOY5eRDp at tHu
z;T55VN<ObZRG3gFrXjf$ipYf1Xkro+pkpiy&(O>PdHb3FE&_LEmcz=-kh4fqZntN^
zpu+|=*?aQ6<%NImJKd;P1xLl(3WM9<S$^%_^4(>;+vxur?*I5+bbN|baEfZ72cd#i
z^d)~nzTt5Cx9oFi^Vu_jYpn~}cLJYhe;P<|h^x{n(${8JnaUmZfUPw_re!(SDRav_
zGH;Q($X~6l_BW}U{9Dvp{3FV+ChQ%l`;PL6=CJoz-K26t^R9QY?!0nJ^MUt5{aw>t
zhi-knw^C$nC=1v{+2;H_Z5AuaO-e=icB?4KEXsA2jB at a%ag8@*lr at h^5SmQACojvr
zmp^I0=W^*9EDZ|{ziALP9B$jSR~Ql}8;{4A;;`>7EybOG0S0HSQdqE0Tw%_JI{(9T
zwa2z~mGSeP`||a at _VwGoPVCt6BM--qG>%heUUHH?Sdw<>TD0{s6E{pv2BVp?Zekl%
zlBuIqYMX#oI%sK9pcPw-`l79y2o*|!Rr{lrKtdCsM&O~s2$a!LN*kAR9e0o@=YBc9
zy4UCYzTe|SfPzLlw$iGpw$!6i>)S`tMw^%ZQ?AQ*r`oj7A2qx7tKCw0jsyP2x at wz)
zHL+H{t!ZU<tv}kmYi&!i at 72Dj*W1(4 at Hn;y6ICIvJtlLHHT8tt)wPL+hN at i0W2wH^
zJ<+Jw- at Bc)ty(!4qHkIjJ-RZmtUnyB3AKC7jw++0yUyFx*wY+IuXrU=-{!H$61!WL
z)g{(DOtEUU%_7?jYL())`{Py7#xbqCLuennh5Z?l&@^$!ah&n#d?Fi1KF-I-r4ckD
z at j2SrG*vu>1f~w@=~bffrVe3RA*7>~$UJpHl2DEV?#FbJW;tzS>MlY~2f8_4(yY|Y
z<>>3?d^mv#J-*z)oDTzjR^GV8nEahAb at E~s#TSaEVwQU1k__EhEM}J|6f*l;{pJ?4
z-|jbKXUPa3uY)@!c^~|9J^Z7jtS=d~^=vPlfVa_m$cZ+Px=nbK^QwapojLV}%7}mj
zmQ{2XbiqPoiEUTxHTH2kV=q7>J;Evj3RYCt;qRACI=gl;OWS0jXi39TOHdN$t*xoD
zTm@<$0ld@@+lTU^AV?vLt+~A~)jc#>I?+ at +xz1`3ZDM;%^XiudhR$f;ZUc<tjo3+@
zsFV0GH|}{ZHO7H<Og+so2%BIX<X{SB;0Ewi{FCR=II9UYRpYG2<@f>}%Svmd+pqz1
zi}$hfp!VdiKP<usx<avukZMGDi6J6sZxu;r>wpN;;wce}Z^}zF$d5)M+S-~Ep-28r
zR{|(bx?-`et}Ep+7AM+snTJK(L3z)h^+ZJ6`!z!;DmWUT2F%znreB--l!OXULu@`K
z!Q_}1nHgrD;h8!3A%34Nz{r`K+FLb~p?=bt+09jwO+<?jxT9oW2On|!|MN8WE`1j2
zeRzwx$PFVC3ZmJwTXnty at Mk&Bu3ZcUcL5Y)5#1<E!kC0};hFG!m<^k?Y2yGIL1SnV
z&CuAVhGxM_x3+ at j!jq<K{$FbsDso6O)fxx}g0(@+V_*RDLa4gRQ{}B<cxzY*Nnw}j
zR59;o&4Z|hcMpQiNGpd-t04FWp-M*wi^)ESR6QL&jY^H>zsAN1Yto{boYP^p;j%Qe
znVe-iOqn&mE4L8t-MeFR?(kO*eeG9+S0=u6byYf_+To2Qg6W3#m90-C at sV55zrJhw
z=cQABEnPV9;ZN_DZk;)>b at U{pZykCm;eUKX=`h9UHYFTScg%qf5*u;lTr;kD7mHlP
zg<nBmMcCM7h3BD*rsx@(fSGcwqji7+{BNYd^T<JG5PVFGpeR_xz==8;GiVm>(%XB8
z#b{KBxiz7TDO1Xf!YZnB76+kN+1yBGt%<TWQ%2XU5hjg3S$F`SL?RU>wT4>EHiyG$
z_qTT7R&4{c_1}hGzcur03FnqO^g_rT>Slj=^#1PA<z5^LVNdgG_;+tL`n)w-A2!i7
zo}g>=!Z3M5a7k&WtNQVzi_k&U2F2 at eGzb}?M|elziEj(LS+~Wx+4V);4)YGnVd*=@
zZ<$X at Cym#*YtHvvA2>g7&HL`L_ndY+cvzLIva1f&>2V37Q*ue3r1}|kk8{!|xKxat
zZdF!!1EXS&cWFW|SXmmqhKVQ=o7_1rf>>Z$h-~8AlPYLo3#+pXO`EXq9AMd7fPKV(
z_&@Yp2dpF3F)M2=fIzH-F3OF3#5e9^a=sZK_NjAlkMhg_gxCh~2p+?e_%gnZZ{ojW
z9ad{*VgLX7xtLk%=<HfbE0ad7g~e<>)47;G!{Zg7-FR_Qgv;V}5u<E=Q>0iixboow
zo0e|*(N1-rN<ZIZ%<MLCJFglkB_ThWrHE+<wg at o(R)m&PnGmRWAGJ0t_?J<aV@?b_
zn1`+4JF at +`>2OHBe(2cm6TQdpb->^Y&#ZO>SGpg9Zg~5hiQ_NlFa6 at zQ$s`FJzu)L
z+|(S^l#sIgX^Q7ESaS*KAI_hZ)1nryGjh61T%}(v_0_W1MQCVP-awMM<n`oy@~&P$
zN$3*C0<Xp14PFY)#;(O~25yFa8~aP`pF?twuAu;X&(+tPPyrXu-AF*9z$DKzoXG)>
z0!*LxkVrh~DZq+zCPPF091J5H67e62w2oqcr^*;mB+s3eK`y`)osW)3 at l<psilcP?
z{D3e<*IvLM5<N-6O!6m5oTR$fagkUrTd`Gb(FEt#rvR1FS<sA)4n=xqrP32w80}oh
zE?Cm>B at If&;@+ at cVfk8rz#sI7{4CFfjN!1Jic6f04uV&qm0zkG1icvJ6N6A=@Mvmd
z%2ZBfjT7{z%&}3Fk3_7gvgS~n9A&Wl6_cWArK~>XtWC)m(0HgJD-5 at v+4a3=x at UKe
zzxa*PM|(aW_p5I6mz|-;Z3hGHn#ebw^z~0aF_Ako%=Yd%@P+=(ZyjmA at cQYAAFQnN
zH0iibUOMtZf8TOXeV14Nxn2E3W5+cO_ffW9qUh?80sV&5I}D(pRR*FkM1e*b>;e^B
zU__1wR+bEil?^N}8z`%)iAB)a1VN``Sb>*ysKx+>IXH}XB*8Q>aKMW?p4V}#EVFaa
zL;0eEZA219g at I}26oZ)p+$ApPEYnMY9M!9Ng;97SfS?-xk3;!P8KDd%5H0^?TBHDV
zrsFhuXlI?p(Tq85E)!;VEW%cfJBp%EMH{7QBtHuFfH^=j3AE4)FqbYITfBl_-hQkU
zggg67--d1D%o`8(;-iZLntlz^et(r)gZ$wAFV*EA6vcVQ@%P;ycei)9?A{&s`)==+
zWAD5JIq*2F$i$UoG!|46t3V48u at M9_3Puo=dLdX8w9vG%$uPB-Mr+i`6vQG at YsMM1
z#+Z(6r&XJ2hcHYdZOLD>6HUNAyLVB;&Aab=@7>(IJkR(2Jl{ut_5_8^)xvh+0DVAn
zz<Y!`>ea at HxVVwr=&ux;J#BP{r<dq+^?BYU-(!-2$pD7}nBz at mi`8b=WkTg8l~9 at d
zB9vUpFS^_wQtO~-*!{(*-!EDwfFusmB125^6e6ZX5nR~>eg?Vm>fa=^Nkzx_zo6p)
zmIHMGA^;cU!5B{@MJy^mA~SxOPx1us%$mS&;u$q!)3tzkzE+8jD(&gV-JvRIpuR$x
zUR_=e4dFt{n-pkdwiUM$t^RJ at O?3M;KpX`$z?o-js$@emwbT54VHds2OV?I|$<m5i
zO7+v4r#x0#yo!^?WXHON#%jzA9jxqmVRuL8&b)vt6fIl3XXJSQE0-`um!BC69X~YQ
zJeCM8-LS-y!;6I at 2loA?c(In?6m?cXE=E9|4zvh;B}eu!ZTj|%ZswjeBWW}w?jk#>
zPTN5{Riay at p~--AkyAtZH-nW0c8vLhI2h!>oE;r?AX+geqa2GNxU!NX*=%s3h#Vp0
zNL?funT${oXDaUS5wh?Wza`%yTLvvji`L={Kd~rZf#IA^dlVHF0Cb3I?QAQA5kHCL
zd4tBSA=D58KXN at 1WA=Ik51}zhY*1nXKnUJlkHidEW$T0W*kktBqbwsl(AOSCfrg3<
zY|S9GUvpjYD5gSlc2Nv#teKA^4)7<B^_+UQIeYNO{kIzS-|F9T`3=l{(L8_4yn0n^
zP37T3UBODaQDWEs^7n_gP7a?ra;9b!d&lte3sv*a^=_#9v^09+t+NmPa0|*GO_L|#
z78uZ#i->wOIcjk~Lyte2lyhL=)M1*8Fr`Rl>)0fF6MsnD#dnEG7D9>*7_l--5;O&l
z at +Y#3Br-{oph%XMSI6lotbs{0g+b=y`0cTz0UMk~dV;u*Na8cuh$x<tsR}Ad(bOg4
zpU9YwJFm!C#r2$0L38-ooRmN9&FH$C7BBNE{i>#i?$J<b;X;LMg*bu(2m305jnjty
zK-^g<*@fR+=x at pYPRvV}2OnOhuDSE-3;;s3AN1A-dUK*6is4Rqq8ei+=8Hu_J7b+$
z2}8n|a3$Q`QX<$FJMB2>Iwg%7&$})Je;c}{zh=0 at +O$ZIH7wy`LN?a!l2|FD3?IR-
zvj;Oyqm1RK7?+_kyk^m6{Jl_3tO+&Y?L<ScDbyI-hxdota`(pur~x{mP3XE!-R6PJ
z0oz;DG2Ks1$IL^vUj^R}y&oH=#&k1=e;H>oW<oPd!djLI6{BVNTTAHYbjaumQR;)Y
zt6p3~FIFZC>s`qJ*BMa0GV)=~1B-bSm*a#SuZt(+lW{5 at xC9@Na0eoA2lV-N**<6|
z?asmp{COHIianoGp)xx?mvZQe;IYzmfykHSM1?GqjnY{qkq&?z*Lv%5Zf2w&<(Z)(
zW>HWg1;vi%*cR8LsA+LZ>S?Vj^-+OMi;}hAla at _uv!{BWkg_KgrM0do-=a~bbhX5X
z->JQI`oxVLXNQ-S|83;Tj!hl7V6WV^ZCfH<P_&`q=qo$AgR6<NJ;_ZyADn9~Ki+(3
z-L{s2k2<#O{_e<McXX}a-rlypura#u*{YLuuMKrpKEJF981w?%g!e!bb`-)!Ikqo!
zkG_+2FGMv`9dwtjlW8~ZWjieG{(jx-7CoaI2ouY7bjTrw95g9N6w=ZYcq?*X`FyAX
zDjSeVW}?zg37j($l=NiKz^EhV?RLaE6au+0cLAAsv)@db$MMTRqp%!Kgh at GE7fyyJ
z!&De63=`pNvi<`-p?5C&hM$>D8JhVN^;e|f#Lq#hRPL+RQq5Pyovkw&gS_Mk27*3T
ztVdo>X`6Jg@*4!`olNk^Vx*^$q$EnM3HEqVk$Gu~{7chjh5$NYB|)hSsc72KJ^9D*
z&kqdT+P3fdsrEPias8dkM9f^;v9|h$)hjpW{lFs;dvNxzU;g`rbN#3L&VD(y(D7Om
zaj|>dmQVL4kN>%SQ!Zp-_|Y^TB!_`Vc2qh-I>)gjd)bDfL1z-0KN)F_0CY~ak}^{`
zXiZuP>m at 8f-S`tmDSFJQ-dk-cacvG>l9H67D9cl8Eat6TnFk{`y0TQ6$zk;^jCo6G
zYE`OKrXMYw#pC1%oF{;`%5G7*VrnS5&RxwSjI7&Y<r(9c!>F7qbDUf!`vlox087RA
z7=kHs^TnL#6B8mS-f%m!n>y9Rt(}MV04yk4F%PGV^3!Ub)KuY?ZycD67pa0*8q>#h
z7e2+V^x<D>XkoNkgJjMuC at w21Z5SX&<kZ>ahYxeJ1}ZEplgSjv3Rdmj+%N+Fjf6j;
zYRKI{KrPxoqS20%p)q<rwV5KQ%Varxfh0pv6wsrDyu27%jRYbp;E_bP(IldgMnlsC
z!DD<I<9saRBqkB&u^*GThS5?KNunBE)k{hqN>tbOzgn<m>JqJ}ZOJK_F9CZuUs8|{
zs8(MRwe-sml|k-)aqdMp0FMwoOgAGB@)3>^Lgl>~`vgMpBB-j!>%&l6GcS`<$PPmb
zLr+f0b{*jnNKWUmd691yPGACK9Y^R;bcJ#)KEC~NG^*SQes=cr|KMoqkMHWedX<M!
zknfh=x(tqEdA-2+DnyNyv+ypH%kB0!yc!YOpmS1OnMU)g3e`C$Po2+&Q``PvYTG5G
zw(aWnIjcI!KjSThEN6fpU&ei#Tg9&t){E6#CBHGVN@(I5_(q|PPf)!XeOxc!Yd$O-
z@(poA{M)7>;UagD|DEfi at DX>Dzu~<pe8S!3|IOX!?+XvOFZc)E2SP5xmAMHYR8I&J
z@(O~7$<VtQo5$|9=?JY`XEkNIt^X&xYG9i<&+vVB_TAZu?K{W6clMpncV}NX$98gd
z0$!F}C?HBllddF#2n%SSOara4L;34i!qgH#s)CA!fT^q%L!*_YcB7#NHnvt%B|2#n
zf-zt}Fm0qT$i%jcN-(?oz6-QW_0RkH-jglsectDNo_DL at VPcFBiNsmP#}2cAWjt<o
z6+dUPxZuNaL5v>5u-U>@!KB$pGakYp2+*{Hj#R;Y)8T>N!H>C3wu)y@^a?<z;&)7U
z%yjp;@45;1k7FD5TKo%hu)jkbvZT{!Fu^B`Gti{gI>+6!PISEJPKWeyxZ&y{jF|?^
zFTWhenH|6Cq&nftvZnf at 2Pi{NDp8g!_@#V%M|%e_Kw$O)(WL<=-m3k3W&A78)%*Ly
zMi=;#3@*<rK3lu>%slPeQ+L2emwJ<8hEi2eD7)Xb^1;E~&)8MfmX=bhfD2b at e?$%;
zj$yVb=!*nQ$L8WY%<LdGDD1&@3ww-1-0R5-S4rOD{+|3K(>NE~p4?^}ZaZWgQ{FZ%
zbC;8sHK(mm#XmXWS>IkjT at i`r&}shFAIur1l!75F<l0PGgMp9c7AOnUJ=_&=Nx5p=
zP$`=NR972A_(`7g2>~Ub`LpS^h02oLH^B1nVDbRYG8j|n2ZPG$!f;`%@J4~=vRqpq
zMlcko2wFH}BXL3q3cbc|<*;(apkf8H&{r73hltho)#Pewb#^m3!j165!X{-Txm|mi
z+{Nz_CXBJd$C;~{+sb_<yn^<KyhDmJA|H at sL%|4J3d`%FLd2WrrVJt-*YbHspjitB
z19)0Pow5%)an$yOymib+$JmMPo*cS7 at x&tQG<`7twN(+|6tWRK(r?qnxv5rkgISpO
zn$QvA7!22KgbgK~E;fhRK+Fc9%{*_aDYB^v?@u*)JSe(cFvejodl<am6GNAtBl8MB
z1LrXbTLVH+6ZEHNbiH%wH0+%koI%CX6U$FwtwhT$-a4jN=uBrP>d^AE)nMgWIfZW)
zEm3f2puxe;T7F%(1hprVleLflD2@;FI7ucHDDy at _3ndJYp;`?f3kieBfmVY^^34Xw
z+S3N6M&kx1v=Mm&I$fqy?|e*Z(E<SFwpaq?av3X^KDSF46ksrGj7V9^8*Lr!c@}Ac
zoR^>yqr4hG>O1R}DE8r!fOMH6e){U7HDlLq)W(c{H5g4UHSi at r8ai;~JGGb8Rr6lk
z|MZ8a*Y<5HO`aY2aH4BDkH06(U-`<qQ~heYTqZVtS4ycN<^3(szv-c<?(Z$#ay;<h
z1^(#P-q)7d>==}ZC7=Dp?t!yf0k}EeA!I-X&kz~$faj2K)N|B(((}HzffnGuhYQ?G
z{;h#miM at f>i341PI72uZ3AYW8E+$qG_6*Ii3J=!=`y|c-a2l%;Po0b%wrddrRPk$*
zto|+om at 3gTIpO-D3wKqCjG6H{@CpV1Xk#kx06;*$zpy}LyIGv&OxS>q&R7U|LShIH
zS?v*eQe8V_DX(5EFP(-P-Mw-N+S?LR;L=QSW~zJo&I}wm$nl=D;EnltvXN4`L_;E=
zlDwk at YxKiFhwUxE8FaNEmjoX7NM*RWHOW at dalg-tFz5)9HaUi at tXDyv2_e^EJ1>e|
zQ*Vx6-LZN4;L9Ix6Q8f&JyU<@)ZUYz`{(;7=6HD@*I?gJH-39^PyOPxYW-jPO2>VZ
z$M2v1 at 2|nKGm8UFd=|M98LH$qIGqB}9TMh>2EHM>i}^nDJI215+3Xu<4mKU~pX1L(
zFEVt9_4=X$LHWTrw_Ct9niP2q?nol<lH{Ni7B#oqg@?630HY(Fy<RYDNwZ$lYxh<^
z`}0XuL+_I^;$l~K-jqR12E+0j@^zVzrJ%*epvA_ZRqh}(D~$|fBWWc`4kgJW at ih-I
zKwPX at 5xUp1e$N8s3(C!VM6n1bc>Ij&O9-CG0O0&EL|JhF at J-=?N9EtS6GMzCmW=-=
zM$G2*GZZN$Vbw7>D<LmrV?YT+5Cb%5UB3E3<%9Z*e;6IO3EJwvxjQ(bc1R<{#?e?x
z-CI9<p?>4+#pfbm5eR}XSP(_MJ_qW-d$8gLXg9mf{QAh2$Pcn_g(}%I+3R_FAUsSC
zQ={~#V~iZ5Cg=%=LlOC?6jw!Fmt@*R1)(LkTXgU=g-R)*3?<>XNb*#K;c*~C{}DB?
zV|p5EVOsE(Dt-Y<MM{Sabu7x?j6|Zeqe9bUrJEY1aExN8UW$OfHD&f$zqL7CN$Fxs
z27YxTSBXJKbB!nXXZ!NQaP1 at V7-K=jSg0 at -R7_k|ET|MKsaQ}cM{?IsfpN=BBbY3#
zAZLoxGsVBvAY8 at iPR0W44pek_)GcX;qY at fBWM!G at I~emH9Xvb{oN$B{0V^Q}7_6K~
zLZV2l4~{Lw6PP1r2iq3_A}+yCpaSM>O6Evab-TS^@2_8Cw7F9w-^_OPXfHmvoz3d8
zAg3(L+WelR-)Pg;+40&<IlZZ_4Mk+F-ZPjC#xh+y>J>G}m_tNqr=Y3z-*4#idk~@$
zL{x-`wtzW5(K1yam>ufcc8AU3d^bZJ)KBXl=~svg`Yqcn=L6dVr(@VYOpZc~$LwR|
z1jLx8oQ^p-B{eoyLBe#=JQWrBpcE$|s3_BH=SjDvor1_GBw0^sPP)+s4K$Ep`GYN(
zoWL|j!!?AonoK6}K#)%AS_NwcSaTLGgTrtK+((ik1$rs)3u~#IG}D;dLeg!4=C+V@
z$AzecWYkJVEhM8y(qAIojOEAg6-(CE2+{jT at pJI3wb9xd^@r%y9-R<EIN_jr0v16A
zK}_Sa%)-474mQL8m at YlS58ekyKke^zsVYb=T=1#O8B1kbYp1iz5+RpUgiS&G(<O5Y
z*L at 3ucKfLp>iOO!YJFh66!wNxwKcY#*f{&SereST4dJyIs?FO_ZE~P!F8d$hRRi0^
zb;sX(XFKPw^Z6sbce#-Bont$R6Z>#3rb!%fAq3O0m29QZtj!>5#^?$n$@ogq)<|o|
zU~EHLp-Q!8XlpA~qg%>XUDkoOwUtmo%cPC26BC(4Hwr~Vl(k)llfCyG8mLxH_T9a^
zdybUf|NsAexNOT(NKRDMArXr*ie#<qy6g^q2oK3S8usCR at +6*=-A(Cj?p<yUXH!+Z
z*`e%S+l#j8tj)uH$6d^F%Xv~4{JtKbRg0QTe~vKyfk%h~Tw!%De7aG>Sa;MlazdT%
zgh{o=Ly at mxAlEo3$Thm(-y7H$K)%4r0HWOaSYS3_3)pBi0)#*>9%TetKp$CdSFSe>
zeQ`C8h!MJGiS*CJMfyH|cgx_OxmpoIBy*NdvQn|CU1WilR!O|2RC6q8Mv at gGAFE5$
zCmIr*!$XXSPxH6Kh${LklCCD;jgpfX5!!(>;b?;Hn9u~u)`B{7YCOskmSi(Ztp^n{
zQpE_h*kvX2Q#;Y3Rni<<=_fvf$r>44nnxwJ#r7^K`>N5CGo at X_2i_lBvA0X@`V#WW
z_bdo~V|w?@_A}$F*B{>h=I2H?-xUlh9Fe$H2fw)W?2G^W?M!ihJO;nJzEg|G&Df at y
zfyHe%fBoT+XMgwb8eCr)Z6=kcYWED8)E>CKoCsgeTNE at 9E6jdyj8-IO7G`f+0lG9<
z at 0+YdW{_;Kg7k3^>a2D;n-{$>d&y!0qqB{ARhLMT<N|Uuk|Rxy6!4I<lN_Do$dQcc
z?f|v5sScE?b|KK2X36p_36$@>$4)R!C8>BeNw0rR78e>x#Tp*UAIwkXr}MU8exlmS
z_L3zc9p~0`T~(?z-Bgv7ruV4IVogV?;?kl)RZ+Ak5soG;+M+5QT9hCVt*uoScXYVj
zE|h9&s;*Y}Ku|}P4ln31q8s{<eo&v%r*(&3KoP4-%&*HA^IRkk^F1-WrPo|%B6DKd
zz<Heff_P(ukU>ry9${oq%FU-V at +ninEmumSSAP=Hz%@VHtPMyXe0un`&!&U9pTOtP
zHo^l*!$3<Jc at rXNG>p=##=UX5w1>S~So+l*MUXeBhk!_o+*|PR4P|1G#IC`c`{!8#
zJ~Q*sZJhDQZQCekG!wJ5gLIAxeq(Lcm<nsGbu_E4Mb-xVgIQixkfvi*323^kDo~3$
zRmHDG1Aao(JeCpd8kwhEBHQRsW!*W%kMYwyH_JnV at 8#F=+*-cKPw^aYquY4afqY^1
zqoee<WHDncU<P0yGNg at Z(;8=Jz1ljBD{503qD8rfRD#ho8T#RoIj&{|U9JK>$36qs
zTa`dNJ_Q{Cl|dT2gHP%D=96sAe9i3NI6pxs3f{HadjfE6aBT<;N<-2Uo}c at QF?#?*
zBWA@=6<-Ew0fQ)vtHrR4ATmN$2=#_wsKB|7$#q`mg6hKT$L#+miyKEN9&}-86q9P*
z=`?tY{~`Yq{+GP{6n}xAC8(h}m at Zo(22+^fR~5TJT>o@!tbi6C(WZY&libCAW=i^p
ziF=&G=<3z};m#b3XP<aSu}X1ysyx;0(Ct#(ayuY8mSa3OLgLhLa2`2AW;)}tTTFHf
z-7^e8-2Lp9uWXdH#z=EQs#VeqPkVxaSbBK;<oEk?3uU$8f$Wl1+{7oC>V&WUOfc<6
zlU8A;a8f`U0elQ>MLUIU#%Rl<*;B3)UVamR0b5Usv|tw9hrWu&&~9rV8n=#kj|wN6
zPjvsu`&Pyqa6?W&4rI at K5A4cJfJ5-0@P`cVCdmgNyGM1_cpE?rrk$P6mCn834fAbq
z-Sj!#vfF?ysM%U#_4Ygue}<m3j-%tQ$t7pOc`yb4h|Y0Wz!i86{>ydEbKQ%>&0*8b
z80IQC4xaQL$m}<rFF7dFT3Xtt*W_w?mR5pF0|^G;5;!a?*n#=_xRPj3AW9#l*V)M*
zkXnaXA=0IsVzoNF6^etZtfr?`rB2gxT^&l!ZnG(NA5&dbRT5gX-E33ZAppAI4UsU?
z1wa9vwpJNt$S_O*y=Ira#{gZXt<4LO$L(@fR0u=DDFF%b3R^`*I4mE+x%T$Dx<p4?
zTYY`}Py$Pm!(mS#JD>ZJO)!kKZOjgb?9g67cUd0G+v`PRUO4H6-U9l!)tL4%N9AK$
z;A0Bm(}~#AZk!W)Hq$i|OM700Ibt0LpbTh3-e#?csTwJf&ZI0V62<Nm%ga(uod1+>
z2txg7f))8fa_kaP$#06Ukqf3*3`C;wMWWF3a>q>{A!HJF!0<@-{gyM`+|-p`($sD1
z at 9R%?KX||8%HpuM(-jG|W(u>@$Hi7l6j~wCy2C;%AWsgnyW(My-W6XWmom*0H_%68
zEb(|S9F_>tkU=ox3HX00-Je|q7SX-znSd%B6=)FN*!hb!rJZff!IqguHZrNw$=j%D
zNh;l_;?P!DzgTI=sPKB@@(rI4A4At>d^`Jy*-u~`H{tJRR@~tRbzEk4Yj9>DxDkpE
z)YV8);x5CT%R;Y^sjDY`{$(<C5in^fA`oE&M4+XwL0?1L(Vob7<b}v95f9W0 at CR12
zFqpj$Jy?SX*K?X4UZnUtbeF1#S~Q|YfB`JPfqzu{MN}O{98bn>BPyWRtaSK)1zxAq
z#ahM1p1N48xF)oL{(19VW~&=FXmFxI_hLUKE2^&}L|>uAX?G^r%J`hbvW%3q9niM?
z=kLv{W0fqzuHU#OB6>34e(1;F+5op#%<PNZ71_c)LgQ-;Hdv!K58bO)hEiM0T;#Y;
zP%+?X>yi&c0q~L_d+U7lz6P675$J#&={~#}Zor$;qxdQKbox#F7kmj`!Co(hF3Djm
zGq^0y8hOlxjRcMxoCDhpN#c^Ap4_#AHmMc2$Sp=^W at Tmrcob~Iqw*GG57>>LFvh`C
z#tYzi<6veob4EIii<$G%+juH-Rl1BX%hQ<;z{k>uMr=8}TUwU>GVGI9r at t=kkl(<s
z8|Uyj;~o5tArPi;YI;QdFW*%I+r)Lp-~XK*+evJn&vyKA{yN{;KHKs665A=40KSS9
z$N~#mBff at 35mQC?(Ijr56owiKYk*Cq)7HV51gvYjAdqOGK%h*d)2OC(Q=@6p(lUuw
z+NN%;2a{O$LE`MabJ9UI&63~y`_4Mq at BjP%KKP&zR}2;*KFKPGtdXq*gF&cGN8myJ
z0D^$uPw8W+n)j%FpPKjQAy0n0FBk~;u+3^kNL5p^Rs9n227$a1kHv(O!m9$+;`fCn
z;ke!joq*{h?5s29bP+B%-eHI|=_PeetJ%sY6<QG0$=69k=ZCvtpvXwOv at xraHPex{
zl98r`|G$2UDEu&);0hgBKF at ku%g|U@&F^<<ewNda)vx&`=B6(AG at t6x$arQ^<Glfh
zfC<K2-anPppab0F2=2KJ%<|bgd}57Sm({gWo5#`jFpR>- at CO*puanwBi8cAzNp+pr
zHv4ze_L&`fqM1aZ7^^ZnHp<~t;_eNT at p0zRr#BAW{T9)=xj)YRg(R|7C<SloeTO*U
z4g+AlzjPP_7simnIrk#>PWMrK6VG9bJ09m)>Tu%%b+~bc_Eq%IzKR^@0*vEa+{1Bk
zGNCW(&eR!bw%GvlK`UotjDECo54&73R%LaTVF{hR?jp@$7i<PCF4ECskEaQ{>1?^A
zry-Vxlj--<IPLb(M|cH6jl*P|qyfYI8xbr{!&tMC3j*?%7Z;|s;WB8uhpSn`c98l{
z)GwDCy{^^98f`|L2Aa`g3%j^OMHNcVvW*LHX(%I&>qnpGHlvN)Ao>coi~Av*f;Zp-
z_cr_+xLX)#^4frgvoK5`aT(#c@$(U`jLCmEPuQG9$PX_PQ0XC!mgnX--q<b%G~!Wd
zIjuW6jcemH%zDW?ppob^eXd0#kC|$0|GePQu<lymd`kMpi=qlu7y_!|eXdgcEXtCU
z`gs^)mQcjNG{urM^9-NtC%~dW>RHkg?lG^Lu`rGWsN6kh`rOP<KLyU&huYmXgwe{m
z56nBwUq!8mN3ZD}N4RmzspeCx=}CCXG6n}Mre#*Uj2N%nWb-eMGI<6ghGk-m%IJ)l
z=?&BV2Fs;bSP$c{YcXq!*|5_VwP9Ot=*wG;23D%8YpdDe>?gD!HnChYtYIhc&O}Qx
zm~<x{t*#v6!Jh+<g;Z^3QnAhU90V{~IIA~@d?vEodsx}MWPpjXxL736^?@!QIV=}T
zy(8yhQ%PI{E9|T9s()1fu)gp2*Zy(w at q^EO{rt6m9ekXG-og5B>u=Y$!E>+}mi_9r
z-m&re)%xq_4?qSUgiWUp5K5wqZOR&%r5$!&Mhf|>-|a5tmF at l!ekAk_c}RI7WO>Se
zNxCB6;BSQ9lbQl4R*{ohLQD0?s<JWlSZYWaRa)Lc5DcY5eWBk4Zt&)D8Gb3f>w8an
zH#IGPBsGO}F)UjhluF|e<t>6ph}J8JC>(3ggypi>FJe)&cr$Wan-^OxRt^Q(pc>SJ
zLqT(}SD`IfS}q|4bmdhApHL>1DTPtm!4OC=q!0{&gt*gTOq;{F=rHuraXhC?z?0{N
zEn7e1qvq$WvU(XAh9r~wGjD9Q4MrYfYs5U|D>dRVxrTz0riP at nFXT_i$+Rz704YS4
zR3KA;1TPlQeDn71MZE(g8bk>Fh&`rwB-TS(7)3xyn+(BT!vIyGO2;w#KNyydMkhH7
z4~-0|HX|$)3Gc=&@KPwbx;Xm=(Ps}&^cntk at i))k_(ezc!O|DQ+m5W<KTueMch|R%
zMu|QzijFW}qgCIzU9U_zRx~&NXmtINJ~!#SNOHqA(s>ybG1kvXetKL9<Iu+9z<o1$
zUA&%SdZnM_us`Zk9+emy*b>Ra3bY;u at u0LDcH<|aPsDb_cP0+OSnO!-G at MRcN?y&)
zN#3T|e)zVuKXpuc8D7G#NN01`a?|Rq++5Dip*9F&PA1*$=vKPbN2SN|%^52Wg}@u-
zokAQXWFC?H=OD>1%7+9|$L$G8ievC#4AL1K!<J0?WedfGkN#W>YguD?#KJspIcdQb
z#GeTjC*V7}vr`U-L)htXkoaQd1nNcCm*}QH)L%lvSpoMGF~-6LwhQ#Gp{}VermJW*
z5M?#a!D=AN8gKI&i1Hd2y#}JZ$4gr-8 at 7DGbQy4BE7d!d;cS+oDc?X-ejZKpqFt-8
z1WuJ|K1<zsAjsAhoH%e=&_8dzvtz7z&(AwlKgC<FBO*o<IWb>=jtE(lczXefk{atQ
z0Ll_Pfq^)v5=>PMslSX8#DBL^|9$(MN0X^P_ZUP?%G(!MO=X>gnxVnSMCP+uK>!14
z{||~5>er!j9*hKw=56)w*Gq+%J;H{Pt4ana4bupJo&NRVAD;&QBZmfOmbgQ<pItw(
zuX`)rg#qe2?uTai)b>3S$@=bR*SF&D!T2*zpK#M$J39A)$xK*#5niVUxEI>N2~OO?
zAg4)2X>+z8`mxQ`Jps%0sjfv`L54SN_HPbs4sPa~%yzQ_WhT2#BP}EL5yuYaP-G}N
zlpj(LTAythvyVCUJIAu)rtt#H*$eify%a8li{TQnZa8O(MPku(I#*Z<OL5tx2Goce
zRfQ$RC8d at 2m6?H-wf1%F+Vt9NI0{kB7osJ;YrsDc7zl3Y+*H_9+*I1swebN5)6$Z5
zxA1APCDz at OR=cZQ)qPMpYB`$!fjXX_l;6y}m7VOq-R=2;brFvSF at F}`0Sr$Az!fyX
z^y&7}v5pWQ9*pvl$dxd?QVbmPWC+Gu9iG-!N47QNFePoq)+E9#ao%zVBg!5dJ_C9r
zUId6HAvpn}&gNa$T==F7Vy?5Un=ZyRfyXXI&qT5;nP~cj=m`a`DYuk4LaF+SlCHc%
zJ}^j$DJmgalX4Z7BMp{=zXA73B|A)Hu6n07OH*i7%V!&!XYeJpr1LS;(a4t{-}w*S
zRT>+`b;oCB=brWM?9A@$G3%L~UC*&zo0+wD!DC!JZ9+ at 16HIFf+hhTWBPJ&05Tzh$
zKuuCe8mU}u6RK83ZOYL!!7&g+q9$#Gs;E>V?HAM!t*I!XN>PbQqf)Tl_uiUAt-7Oq
z at 6DS-yYKyf7bxi)AdSFL4Hq|qF=EoWO&%jVme9hrW5p;WQyDaj2Tu9ca62Z1TS~SF
zs5KfXHk%TlSJtIr&6g03qNc8up!z}W*I-UvEv##JN?cunITZ)oj%~(}`wa`Js84!P
zzuk)>TQZ2p3Ui1;o=(8rsS${4p|{P`Od-~;5%n^+ttQK=R_3<1LD`)<FZ450s=fZ?
z at V?T5zy9LeJ%4|9entNvlWt^8Gc#~z!{~u|o%Zxk4)sp{e8Y~8WX9lu5|{QKU9o%V
zg7%)#b<Z4LdgM<W)vdYsM+XnAdTyv~U5oa?)|dJZ{=S;lU0C at GfF_?pn*3?dIfM at p
zLybe)2tGoLG>&MjYjhh+jF+kJtH-IIstkcQY6{Gfc at DB?fk_oGoe-m}F+sc^$Q)k6
zf at Gvyih|emVQ*q2HbFQ+hUE~?afs45#B*FespusQ@?!)(foY<)Qah at V+Ihmkl$pN;
z0%So2 at t*?TKAu|xLZ=AK>a7|iJPi=6P=zmeONds$0++6eUG*r6b_NTCD)`>JbPY-D
zR2Ps;@k8-Lm{x!q$^{GVLE*o62)abDEi(CP)DmR<ss8tX6LhD332otzS2~r&j3rXN
z)4%F(>YR7y);$YIh9mNZC-DVvRfU;JY7DIE9Q at gHm<Q}`vs>|??aeizKIm7n6^HJm
zd+8lf(kz&ETcOQfSXgMkW-~?Gw~0P)tFSYA#D35Imqm9)fJ6~SUf0#Mk#E*j+$hMp
znlcI?5(1qfOs9cs2HD`#({R<m;2H`JXaHBR2or+HacmIw*#Ou})?*14#EKvmk3;Q2
zIz+>V;p|x?NE!4?AMLJ+9=^#t>Yef?J<`*2XftzYGjnJ&b9qVHE#n(yTt?a at N8mMC
zgV*G=d+R~&fH?zg(i6Z6q2y7jA!CFlA+C{h)dOYE(j8;-SO8tiaQIl>C>R7CHEpvg
zl554pm=!Lz;sS4oW-I0hCUmnn0xEd88DbP*5!(zQi{E$taT at 841+?bjKoCdxn^mCD
zNBCrWUn#Nl#>GEg^KuIxZzmR4`kT^?z26yr{&$Z9#i4A|d_><o^@odBUOn>7!G99c
z=o6+{ZQ3$5w&dcL#aqu at Cd}Qr7ElKgNCR&`bP>{NK1%Dv7(qPJKX6*XHL+nL^yjxD
zI-xKTU?kjb$?q1YE?s&bcgvm%5}|0|3M=?06dbvU6mk>e?bQnETU^u!&*lo1e at J)q
zn?~q-@?7ej%qinGL!C&!o_Uu#OP^yvj6Fu5U`{5EDbx>`{n7o>5oNzYtxv2;ZY6i{
zdkktwS(fZG*3#=4YB at 8=F6UQ71`||Z^kMy>Wz<(_DrZ#4j>H$S$0C$T7a50j5{^Ov
zi)nbqD&vwtjnVK=1z9X&<ai~cG%F#6X at GxGjQ|~ISUo~O{ME#%3l}Z`ms<m@?fYsF
z$0%IIq6txrMp$sOp43!*VrFj;Qy4nOG7NA-ao`3hnuY~jRg&N=sYij$!U%@u?j-T#
z$DR@>`<0stsa*FGL832lDseMG<r1qBn-Y5xWMYE&<ZRCPo-y)b3X(@HeXDl0hNWhc
zZr5I_t{tFHp+O0#2((52+YSQS*j#(?L5>DE>MfA+IX)%%(LnM^m|jJnWn~}O#>;1A
zpLb+9dwDGC-%DGAzz5+8ngPpGz#$3QpcrYW4me&H0=r7RvB<0zr)_hZw8ive3y9_w
z9dqzOJa9V~QempsY%t1e at 9ZKE48`>VWt!ZarnaZ={v{OK+S*tZ04YEwQfIC(qo4x)
zkXEm~vmD-0wBj*PeL+<637g1ro=OT5A+VSW$}s77qe8r2ifN8+V8SfVF+A_lJ|jg^
zvL6Ot6&51PRY1Q7_F2#e*TG;eS9KS2gX92rjH4~O#I^`d*pZz~QEhhY@?6 at _RJ<?I
zk1{>NBDJ3$U<TMhejq%M8Swhc>*+Pj24Ofetd6vABe&7pm~H%aVP|+}X1h9?-JbiJ
z`#kv)`(k#VyU%-}e2{rXI3yoRy^?uZJ?wnfJ?tH4PjV-PlbPe{iR{V7W9~RJ&c4l0
zWKMg(_HMJcg}aTnbBl-Fwcc>~1&-`cH)tF6ueOqFnYHXN7wX}9^+isPOAe~b+@)Tq
zkLhEFgb>MKJg`|=#cj?O^)llN+-%i1V$%Fh)#I|H5Ua1ODzS`!3#@NTu<SwIccH?E
zrH>2?Ed3TPn`JqU&jR12X)HzqAjp}xDm!jbb)+zOi>+Cz?Uy at Le`03SxGM0uiJ6T-
z++&$sSP=3mxLeI+vl_?q5FH6M3nsE|Bg^JJH|}|EnPwPxCF_;JX<3$R#{uCIBLtpj
zS%#bcBl@*6*t55SY8g^YC+Y&L)vI{rJ>~u7(30}X@~ZMCbTV1KS!T=E*^jv|3+kDS
zaGuCv8T{XY5QO`}m%^d&vCjDu#M9$-pnX=maWySoO^H*tP)I3FUAv!4P*+FZ-pFVj
zc at GBc=tEfi|6qK$WyDAq3l2u?f*8GrPr(0x{Gn at u0F672($KBJCg*`hPf0>Ix&elg
zK|GP4h2tzD>+*mgDciPHKOUN##c83+j8?y(#Y at xQa;ASX{oAJLXIjJYh4b;xQq_(Y
zT)5)oK#G&oX}L&<O&yh1oWzNiM#cIZK(JLQJa^}v(CWKCB-iaqTBd1w`NFO#hS<Ah
zd7C9SNGuJeitW3nbmEh5cu9wiAXG;&jCvEGx;xY|t0*y&NvQzSr|HgljtRjnS}_Bg
zLt5z$!XnZv&0^i)14|IejCl7xz{MRgydlk5o%nX_>jotO3Z4uiQQsBgzWDi|^dH8n
zHnyqj44-rEm%oUwZ{m;GPJDfxYdg8I?@b&hzK)5nn^4FCA%jAJHIS(k22~*m8!B{N
z%^DVEY#KkRt(%ZQtI9yCR0dI&Hj@@<?bK>QLK8^ak1{4r`?Y9H%BHoN&E9hzD%Sm(
z<#XP9&pp0=&pGe&zRzP-m<kPyAH))Ur_sy4v&yt~HuDqZ$BC=>s(3wqUAdmPnz^p8
zBv#aw<okuC@<-x_kq_mM%+<<0>7M+l`(Y(2>7pzta)*}A>iTBUkPLY+-k&nGt!R^k
zDssiB+^Mj?$>6VNzNw$r7Ib!4+wa*QXPk-FL|~{~84C}mc&R0eJF+jt-;TeXWj7G0
zu;Gf;=}Tsb55===M5S913G-nG-HJ%EkfboQA-G}aCOob|V_8|pnYgTriceIeGQt_D
z%!@*V56keDR3;4|EEgjthuH|%Dup7gNrk>uABYq(iYO{L(}HmZGN(krHYDpUvaDz0
zKE&D`R?I>H0*HiLTX~*ye65Vj8p0qkWo+Q*@D!fLH}EQcfFEKPUM8Pe-Vu4Xd{}1W
zUZh-6h_Xz6y<}B>_!wC0lOTnlggu56?d{Cc5JEPRnl>Qyf5GR;-U}bV5Sj!QeG_&D
zfI*>zXNLDJ>9|wThZxX0lwlu>AJ$IlQx&RxpayElMw$0W>R5qvg#cg)ag#})7+TF9
zGZAu|S!juE0W)a?==kbVz*N!!S{WbQ445romfU7Yl<32UmRmA24#`wx$t=K2ZhFmB
z!$?p`!N?7xHO$a|m)Flf$nNb`Am}jA2cY@=13>nG>!lb>YwqV`0~kM1iJO}nvl=5*
z5-=k;apoHbYVQ}L{)kgB{!;&QM(W>QkLA>%>227m|Kp`MpC_j#28}y^?`rmVv)k~W
z%#Qv8yU5?_<BNx&Mq{^AZ4L%~Tk&)CH;O60+{LIWCx-WZ1;2skFFy}=Og5 at +t$&Pr
z`qO^D==Wh5@&?C`QQS8J?yuXr;@%>Muw*mzYvsIU91I<7oiNz$;48s1$up at 7!G#px
z%C+(Y8GgZ^mW>I6<2YDF+E3Uxl5vNSPIaW!tYJKjE#u30pKzdkUwXng#h(&RrB8KD
z8&zE8=Y+X*wX14e?s^NqMXnehwB2iaV94kBd0{@yV1Yz%LlDN2awLY**$8S#!}d^H
zq`e~<3I;*uwm|p`4hMyYl1jr}I+P6RX~A%$g;X-c#YBuyEY?n?WH7M&=(9yCG2mj|
zmNE3g^4dyJu^dif%Sageg{>stkyCURq)mA_Wu&asL~1%!O<hb0sb%u!EuDg<Ra~Fc
z!k{rq;n0TCcoH`>5zsczZcssXqx at jW+yIdF1VkFwjpVafOcqlFLdz~YGcyQ82cE?g
z3hyC~rcnR_PSZ+5yATaw59Ni_(18BA$D}bz1D8 at lyShLX`hp^*VfjC`2c*g!{D*M(
z at UBw*y=Zb*cWsp_)cW_H(!bP_BqQzm&doT2U8T1EeyBCsy<e@>>hC<3tGGf6hkFw)
zRqgKXI9MOUKRuX at cDK?fyH-C=rnnc8fX-PV%ZZWTWLPfA5K-Wh5OvOAFw9WGVC9(x
zZ(u0%OAO>iMrNj&D#KQpiwwEKU}m1<Z(uw at rU-!|<Xpx*x8lD$0C{YDeTM4360n0=
zSp4{w7e**U*inO%sg>+Ap?iwszPKM6nW}HY%k}$MsUH{c&QC9apJVl7gt7gcvpOv2
z6(^Z;V(^p~k{F2`n<R`>c4F!-#^eUiHJqi!Y6oXInVaUS99!isa^wn!xp at P<iwFWg
ze~Eig96bYJX}dbPqv0laHZD?6C!cV&;pxm|Gq{<DHU at rf13&L`FaE2(lRpfeo at V{{
zSKJB2ph2r;n!CdhgTr2UaF6j4Oy=-1t}Q|7L6=x=nK*C7FMZP3q8&9z^m=Ww at dvr)
z#OXgCPjDydKSSW>=%Y1efq578qRq@`g9li0*`lZ at TNFY5h>%qsZa3MZdg!Q%Jh?`0
zmB^l4fKGw?`-`GzU#wex3ay+yH)jgA6*5`6U$PT^lFgxZwzJ#l^H@%JsmE$-qrDFv
zd6pmDwc6<<kB5CNghTdd$es}r)pnuO%_4oRyat?ZQZjX#mT&7dddzpV+gOJiJ5{f)
zexhj~h<9)I7 at 8KbPP(Jt%@JvLKbGW}SuJ04F1Z*<lU_xy=Dve2xG&`SHYrdP%hfXL
zjBe+)^IPOC%J!mFUTAZ;ngkgsqj=0U>K at IH4Gb4YH$Uq>>OSwBbIrNE&jel%kXZRp
znM^rysIQdm%=E1Q4fh}q6ep+YNxMxCU3<8g7lGpvN_3|@jBK0J9 at bL=JpbP6belUv
zhe9Vqj2?O|L_*(!bVgTfl&lhgWlv|S8IsAvzAZCPTRzsEUCrRkl!|hjJf6Nj*!X|L
z3GjPzEBGktKq~#mCKIVKwW?lJSxbGWlB$YTkxo)q$S?%FA0jzs`j_!ht39HdJ%ZI_
z%EE+D6&O*#4+T6SU}1P at _(Vt>7isLyYCG1}*EF%F(LgTMv<(t2{&Nzt;W~twxHeN>
zn+0m2`OF3;^+t}n$#^hixHUMd1}cZoSX=Xh(FE5#Q0OlZ-sx~T2p?Buh46W|DI;H7
za}-I<-q at xnRuY4p8ASz0pN#W;ZYe58agzdFkuODQ>H{Yr{Xqv`t*fi++_`g*K_Qdk
znOQ_xNLjM$w}xgRt1kAyO0$$Qh_+d3G6&=)$_8jgl__&|1B;N|W)NDGMtj(8y5J}W
z($u=Zy1+WYI!*Kiy09PCsX~!VD9L;uB?ORW6N<q5gDs7*{#<V`5DfTzEr9?{%>#Zq
zp7K$807N3!OSXQ$qkr?ESK2#&``2f8m(?WEld68>^4amhsN at QIMUTHUeWa&|f7HEm
zWN%^n+)KXJZyz7-8F_hc$HEas=`Ln_`!ahkcE+C4&euPFeX!*}R9Am&6W1Mo at 9uo>
zY at hA(uZtc3y2IG{;Uo?vff(p=EGc2>Sh9uCq}0U%)b5W?jYEe<)e0lVP at pZ@s-dnb
z0y^4lAdM6VkZRN1l>%c#%DSne)ezalet|Nj8cawm%f8>|w5XQu-g|fVeDA&c{Cdo_
zs_kIst2DnV+)&7^-2}{^zdwIdoUpw at bh4O!SYiG<aT_vNLoV9_DhWA|y&(Yb-?*Eq
z2s6CIE68&dpLgN&sv4>yl3 at 4azQG%??C at A1NFph_(;O5SX$Ri6U(d{Nx8yv%o+)b=
zfwZuFSV-Yu^+bfffPUBq`^Igybc%#PM&$mGfat~H+&hD9sQl|3UQ*R`%F6`-h+oFq
z<ih(V at pZUA*`cNBG5M at K&Tb{ZhdNyOWk&kj;&$nK;$G=(@r1&<7+s+RYFw-R at jz#&
zN+nW6Cz?q=AIXvgYJ36I{-jN`-BxuF_Qk5Ixq4kgu2Gj%g438wBreTmxSF9_c1^jM
z3)p{dRjaFz`t_rnNJt*;T0oq+{O}AP>2SNZDtCA0zw|DrMs3&-oh)sLaf4PnLQxV9
zIn}5Ft%PJ6H0+E-NlcCyq~iNXLa6N81%L;PLwXn-qyRHL7+ at 7_q0=v7HL0auFM at 8_
z0w(FoJ+Hs~;hXzU^uD#hV}zphZt8Db`mNl?Lx;Auw$=*&nfUZ~cYat}u|gbwV{NsT
z9Ga`0`_n^9FaK)nmyrNi%^JW^H at JsM@19a5`k8+S)v}71kX6Kp%soKXQyx1jm_w#u
z!jg<5p3E31{uzHj=!eRcv*;+XB_c>X$af~+eqn|KW%2?d#Fs=F-B#b&LX!CPs$7rR
zgs6YL)Mx9H*Rz4hK$Jag+iok7l6eL;j#I`o`K!&ooOaO-q5kNmWFb_DZVwGd_xWD&
zk9tQ#Z_{JK$>eGJ9=*gah5xDCjNUTt(2y*2`yTV{PwY2J$=M|H8uS<Q)5L%y0fIqd
z1O>Pma8WQzra(;1G|XNT=QU~`F~`iZIb}|pv!=^@Dt5y|J(u*9oyBm65y)X-wfS-|
zNvC-=q0%1pfGVh2jWiRB6vz-6C1a#arimRd2;}&->fO~sZ#6w!O{>pS)$+~Cl*pQF
z$j!1P+vJW#9TUR$2?y42aotRQxHwnL-z;)iWistEGes`lH+>5fbM(cw#J0u6S7V^Z
z#X;akTU#4#gJgiPAt2c(kVFgRBA|O`{W+Va<tT<84VAI{j#d#ongNIvVe6AzB($~=
zjy0&)@Q{gW7pQ2P*qyqz`;C84dS>s>mo%)5d!5PTm$p9q^`j%3zqY)EJ~942m2X_5
z?gQ)6*>rGwBHq3E=&}19O*>%ro%1&(8z at wQGzyO{U at M)q5LtC{h=WS00E~l;7%`m-
zmhLoAmb{23Lq(t&{Asv)&*G3YLfFHIzAOHP#L%dr6-)R~x-`FKcMJXg07=1zYiJO8
z;y~rf!a)}j#&yUSWe!fr7 at x`4H+;~G7*0{duF;_wwPJ;s5KB1WZ=5>UFkM2yf)NI=
zG$fA)&H~;sjBHaKe}+#^?w93k6IZp#Ohw!><w at 9$;$ZUm$@UpgHV`=A#staEmrr+f
zwPcYZU(PhO6tXW!FWB};rR>RUIm at hUDJzhyULVZ#+xnIDnS+e2Wz@(ncXT;6I9`)}
zQhy}N%GueBU>L+O-vzWg!37^#W%L+N8c#W%F`hRLlf%YwHo-2|JJX84MqTZT`#XcN
z8hv#%9_vg%H>cDP<g1owpbZTP(U~AlQ#CMP_<{w!q at UEqgg&YZ`t7=28OD0Lwy6cn
zb6u at +M^neniatWhm>bSRD#jmVWDv(0lt+#0BhennWOX_tDK)9IQfH8i1gBb-GHAW6
zfeRz8NMgPX5f1n+(&1tr{2AQ2V#Gc$;?@VsSh3?OTe8*LBz%rx;ZjGb`{4Aw_jmMw
zLRM#7)Z6GW^+==hf3r>Usx8 at pM>dW<v+?OQ58wab1KPFjXNR~@-oJjdE9y-ae?zZz
z4&{2jdHKp80nuLtz3damNPxt|7Z(s+tLWf&ss|uQ+`Mpe!E^_kEkX^D27wR_POwm1
zE3smEy<VshXC&oiglSA*cpG~&uCDMLlg`h7#Ct&H$~k0%w8ZJ;!hi`H5QM18=kpxa
zV8_|X@&hxD1xw at z$dPDpbrLIssJv0ZmspDt!WuK!7!wIAKyW<5B=!U8P3e>*;;R@;
z4VjomI0piWILs5PFk65<&K3&T-NGfeI}!h)g=Z$G(8co?^7+g|e5^21gu4~?Z3^YX
z1yTrnB-+A86k=L5r(4ln0!QWO=x$LGXb}kxvDy}Xxv##dB_fCI1O6xVO;wMFHdZq#
z+GS=}R9o;X@`&(~yjR_)?TP(ZI1w86|3UcJ^NDsx__yfy6<9$Tg4vDO-(#0OvkaV$
zxxOoicI1f+Jn3F$Un6wcdlKt~_4dueurT5u3IE7{%zn&qUKzKKIW7r*7pB!aj({@7
zC}C4fC}N3gHwue3#$@)Q6d=ud5Qpmb<$RlhJA;RVH-b_y82P<K;R{ZIfk+rp{a9SH
z*7|a|#!o~jei3$6(Q6|)k4~S}cj^apQNI%iloZ;mj4DF2azMGEh?-(4FcW1=nO0=w
zxH~A35yX|)VELNemb=$261V0y+~Ta8x^X0SSW9<DykjA`z!qTLToGeSF%QKI<a`Z{
zW*8xr8TP^_f~@^)5VAIIbHRDQdT?W#Cv9z{n5P{BXJkSJp*YAl2l(TOe1b4|n=_eH
zt;U=S4h0>jHpeOjYQ(8Xr4^~%TWC2dEk~tg=Pk=^&jqz`E^K&nE;zUpd?BR|4i5U|
zD$GI4s}>y0hYpr9!M#8Z<WK0<t$QEe)0hZedF`#+pPqgF;@n>PQ=1mvvaD~nu=472
z&u#fmVC2t~etes<-yUBvu(-|I1$n545b=52OC%#G3+zrca=&V{&~_RvBz7c2HMdL^
zcO6x*O?|M|w=5qL)a~Qc=O*Qr(Vpz!Ne*RkDqcm1r_OVpMo#%;g=E`j%KvA&T4UR`
zt}w4CQ4*~O^{`CYv?SW39+qj#wkXSwMD!zGD#x*tIB^oqiIEl<+F`J4AlZ-~i`T5%
zx&pJ1p)Fhtae!eNu>EN2DveSsjW-wtI>1e^AHlF8Z8ik`6%RpI7{gXOJLgI+BAGmg
zhxcCb(&szh`Gob{=9aKkC8c$2r#FO;@w<V-caN5CGj2MEfvHAwf>U56TY^v^5)Kha
zXkSeq<F7^?MI(*F_1|cJ?Q&`Ddld8#Pw?}bo7lG^9QVHwS*c%%vZL&%<6!VL_BDs)
z9W&|FF3BaXWL>qb+OG;%JvTJFz(Jil+jcf-l5DPW$abZLltb1EYcs;Fq1DjckSXL*
z)CQ8A5{Qs$OL#q;&B_aq;1zQ8{bdlm71Q<_X-ig!U^wFm;&pq3D{ePYFj?Q9n at dyM
z-(R)4T-7RF)EWUvPM2H+Q~a!}=vsH(cX6&@`-d#YTB{w at Y&9t-wjgz>vK<8T#q8rn
zV4)n4(az#vZU>Ytya>uaUNz<qMAiDJ8i-3w%&$nK#yUtf3>?rTdHj%RJ at v8<>6Xzw
zt$GhgK&k<0$5d^YK>5}8)RXIyy8qbD!$f>IxVCok=EBP-`_rL at o_shQ?J%S#?4h0O
zOD*k+5+6NhI(=~P^^eYvYT1x3f6wRZ`p$#lgOGmAzTGkQ at 6eMEFfTBt*td;Wy at 9E>
zqbnJf(S(BOLfeI7CZ>(+;Eui#G3R<G3-i6_qs79qdD(Kg;m6{#{`38p4=j)WWb)01
zH^r67iutys+)x%jNq;iFUbtU)RCrowYK+wP2)aKLE?9nR%V%;;On}YE`6ebf;`In_
zm(x+l+wDG|-)>t{iC3*W`>gB*9#Zk&;dkWF8g<^f+^YJndRJxD3b}goWO50_77R6<
zIM%x=zboIBS-CccT9_ikSVJu3N#1~H-hfcP9ifw-@)LiB*bLvija;&U<AG&tI=3=H
zMk;KV;RxpW&LEizE(J}&JEp%d9Dr+r8H8IrXAK at 9N7~!n6CbfD;JXl<`<MwfWrT$k
znNKaJR#R+BM1D;<5E3c9uY+BhCeye#C!iIaKbHkRbv`TO5OAIvyc2*lt%l<yPIIuK
zF})lolksAFJ$^rKj=OLq-1 at 4FkO${qh8GJ){CuR4Dj0=p at Xjp-oGR5h(goM at TVrHQ
zz)53WkpOWAih+Aj>?_Z{G(0#j;K0TpK%X&CG2JnID>;(uO0iR{X^JHbE3hUOUuCd4
zO)ad-;?HB7jLt3GBm45{!iVGspzHYeUKf+eZG;8X@~y=k>TD$!9}CHaZF-Sh#Oj}1
z5FSJC27*@Ds*%FZ7f2B~VQUdp?<^P`4}*av%J<~YWfSnk;#XVHlqE5uey&1f5rOA{
z<`yar9t17?QN&#wpXooK=u&foNGwscyQ`-w-NkZ4(aC6s+7>;bPD?}@2uaMiJ`rJt
zNiM?dv*aXZN}G_Fqsi$A85PGQay&L8krOk`{Y@~uX at EJ@m5-3|yq+;kBN3?M`^|$A
zIox?fVvZ$_M3 at 5&BN9UyL>Nrs<L#X&+Q0d<0r2rd7H5&{7AUnDe1`xzstew}4oHai
zyi`A(B2j2Su?hh1U?s2u54F}b6o;K>1O3uFD68}|h^b63okdz;0HrTI9g7m~`75~A
zr%!KQyFB-&q>JS&tULMr?8a|KzttX=Q&REMeY5kg{OW&yd~LkWqg&6WlYOK<|I%oB
z>d?6ZJ-h$uO!dEXr~Lb#^gI6`hZDa%^|KAb!r2=dc?);2xb%TP+UNH~tY+3?cNUK>
zym)1%J0ptfu>HkwSGe_z>8BSiUY!|UytsOL`0F3_oK#cF{!0hbfq)rEpK(HQ`ZuV#
zjA^;Xjm=pDfh+JHo)RH1DtIk6;)MuejbZ|vM+Q}Rq6?E$j3QfxF%Xs0dQ2m-+2Jr9
zm+2a^CgK`e<=KDB7zJm$j5oABjDhpSa8pvI>uCg3*bom?>xDywBMwK5Ndxh^b;AyG
z^$Zj9G`E|rkk*}@s0D#_pFDx2tm#48v<e#^cMBWIYGe}x;>L5@@MPMHkksiJeleDY
zMR7?_jHmR=Q_AHjE%PD`i8LhAkSJz*iA=*X4a+nv!)~6^Y6H%fWxN5-*SGMVre%9;
ztW8O~=5J!t1-k$lx#^*}f+TJ-I<rQb&S&SKZ+5Hh=u)<nHQ&gtXYXg(BuA#QbJ-$>
zj4X-R#6-wbVcmwOMN5QY`4&DA67sEbA{4E#E~BGWk97>CL;5I*#4-%sCA3u at kH7~-
z#a`mc4W799BEQPt<IOx4DOF=+r6a6OX>(dpGcRc+&2&Q}z*yS4c3(4VbG_F=9SYmn
zP-17fQ?<a$h(y at Spr@~o3PXJPv{d*TC5w$yo1&5>C=siz(b|mk44|b1y|Bp45-46t
zq-f-0gduWupvKj`K-N?oa#ku0A==%W*$aYVBop(m4jnEw`CNR;*xg at mbn|R at G}ZM=
zzP at j4w|`%&Uv!5X>pNY<Yx%{_xr+x*eB1cl?jL3%qNFIXsBoB!zICQEJ-I8L=?E)|
zkI$Z9_f^#+18w;roUDMCI;O?+LKQK$83l--8PnP8r0MRIMa*Pb#LSj`B5MZ*p|u>G
zM>O&6r~>geIG=uiqwP*{ui}IA&vFfJkM`j9;3h>|qyh+Nn3U(`OF+Xd^MK(wj&QV-
z#g6<IF2J>LKIjG?KvCbE6&_ZlBqUk&43L1DncTn}+e3mgLNOrIGp<t}AFnw>LsiEJ
z_V#ke4URC}HO_=T$}kbR#p=WDZ5tBKwA+<dC&h!)glX at jc)*=i at gO4bDSjYws|q2d
z^*IbwH6}d!!_D00EY%}5C<IFinNx~NNx7yxRV)!@N--IDQjjpayVKNW`>R$<Rc)(E
zt<e!|OanlC`4(p)<ONv7f<uvzJn9HKd?naQAH%dbtUfPavJ-nBa`4)Sj>d53boRRr
zhcoC at L?hWJVyrRKpDu}HN+fe)Q7nnq#HXS~Tx(tXHH8B{_7-9QsCTQ{rULWA)`S`u
z=$7CEsXj{<A=kTWZ71-E at 0+})X&u|k>qOhYKwI13zz_e=cG-ruk(_aSXJzf$tC4os
zlC^rVwJS at uB#&<;CzfT!y3;Cg<XkKzZerP1iyL2?Hif>#Hnbch<=hV?P)ees9ED3E
z`Bd&(bGclqqm(ltn0{zVO5aN<M|-4sGZ#v(9M?qdGqX}&jtXh_+1Z(qwDX_;^Lv70
zrPjWEX1GU;g!+>n<a3^-Hwq&oQ?2M at V<8Vh4i#$Xl{ZF>pd4T2_?<7e%IKW)9H=&h
zuD5;OmGrVA$g9)!dw7K!Gz;4D{GcPxKU-c~pSHFo+U(YwJ1sT at g8OU;1b<^gbULJm
z4$(Owm7sdXNoW9kO8LXTQMmN>jWl)ZKi+7|l8}xt$rjWuSAP;hLJ$%9q>H(%n_LF_
zv&bB2kheT<4O}FG0T&y at p+L(`;s|vo6GkZ!NlpjpUlMBGP|rv(Y^1R0Zz7N7RyYoe
z at XhiCFY-3g39B$-FS9k1b(locLa at HJYP*<fyP0a^y52C5Y at ik6qVd3R7zXWPG<QCR
ziV->(mq*BNqjb&5p@)pb3RQ)oSmBVe|0~nCst;lH0k$AN6^r&hyCmEQUtxONUau=)
zka?A%R4>VMOdHH3mHvoF9vJGE^?nrbgem2qPW=LD0t%SV2&Ns;^2NXVGrCEVLV<uh
zHhy*S3rl0sP*{B>8ZiA&)pL&B9wCL6@#w4fKHM9N?Q)BYLyNETKm0L?G6f+{<+v^k
zzL#^n-_{QavGgBgM*~v{sO*T?5n8AM{PYNHaGPm_1{Sd)VIpDbsEr3*%qRs03?|F}
zrk{$->~MnF;RKU9DV+d<mZh*J1*v-1u%v~ClI)8pvi|~TVVKK;_If86EllLN;UH!|
z4TB`F_Fy-Yx8omgO9HGA*(Pm>cuY1oH!12qgArtN3tSWQ30s%5w=VUh_vE~u=X(VO
z!TU!&Z%7SS1D}`QRL}Rmsb9#yBT4ySK6FeurXJJ3p`27t>gV~Mdy#FO-{|?CXUnlA
z-{J4b+v-QX-9 at z+DC(0&F<+L~rEkmKX?{d8hK%8KeiBV8VxLk&N0fP^E2b=>MfsNU
zvEqDLJ)mFfxhDNna%w$(MIX at h{rp~8aH+D_9l`^0#G?yG9ks5b&bl(M&U=NRJTMT^
zkMdn at +fPpfn5L29kP=yVMyD~tr(kbLLNI|be07^{FryoI=(m`UQ)p&B4#B6)$4xUo
z`IKuI)=-|g0SSm9jmD5BY}FJQ at oKNvs|58>BxnMvBnBnECn8Z&NyH`+=~6Z_G0mkp
z7x+%x(0vBt4IS7pgLof8JTf>#_oA)@FH4FNka8TSHPL;m62QN9xg-IU9}EU0R|aoj
z{sBfe at dub+#haMNX-&HjK!K2+M|nUSE}l+vrea<)H_e--bIwE?X2ayomC1Y)z4}h{
zr{7{*du at FgHa5`ZA!YqPG<>)W#PbAm3iMX75Tt*Z7DXT&rBFEIF$2W&UFG_j?smXI
zhd?_6DBDQcw2x=#z3ZY_hv&1tzP7f^Ew7_x_TtvKH7Hiz;}qC7KB!mpBvfAT8L&Wj
zNjcBcJmt!}=t<4X_Nm7{VK}`F?n1 at dk!&4-b*Qvv$&L>vve7<45JfMmX=uiopv4NJ
z`A4(4D)%f{9lmoAcSncO*(2X9-Mjat!Av~(QfuFEINADF(5$x1a;(oKdyG)uh>8^F
z*+;8?nC`{cH^3VPZ%+NC^`}$Ov`31^QJ+`ajZU;~)+Ylf9#>sj^mC5A7iPk0j5^JW
zKv*(3O&@x_!&e&M1>-9p7LbUTXCUSoh<OIW6tk&qKya5;7`TH_n1U8H3<&=IE**oN
zzXWsWhL6a3!5~~-A9Dy_A2d)4*hLEo)TtN<tr?W9XR3yTmr;_>$8rq}<2Vs9&_Qgo
zAeKbvkFuc$+vddr8+tI-{Lg`Z5%!49IX`b`o7w}-p;3A%mdEMY+LNCeN7`lg at rgMN
zS=yYoqOEET?ILs(aVjDn97L&zkcjyb?vgj+n}(kx3KECnZrq**Gi=FDjW;lw!)OJs
z;s(BmA7CfG?0*JZY<w>ko`T9UT0_+B7^ghXCLLv*3XadTibXTz(F38Rid5&>|CSae
z2N;Jqtn)KAJ+mw#WE?-^79GE9XA!N=s?EAZ*Gf~_(yFyersMY+x}bFVXp1G&HO>&$
zi;U&UonGZmFWO>7X|Hl=ro{S{m{3YgD5Z*zep{t8uF}abmCghZd};-0--<-1sSq}t
zu;C;J3uw7$Lr$T?;QIHLi;m0n(~05wuBFqiIiB6;=^Qzg&7rb6RD<R~Hiwa6iL$wK
z&7Q*;p>x3XUo98yYVhs*k3gd^kKqrdckMqwfy$VfuUWKDx`qzdPS#$lIcf{S%m8OV
zn7>$HXw)SZMx7#Mj_owfXv at n0R*yI7tCP^45Z7~ITk3EGy%TocVpRfpqWl6(53{>O
zr#N3*5CdZ~DpR~_bg?u-1S)gF+DNX%u1f5xRDu6-mx<pnmf$&k!nOtrXfFu<&F<!M
zOBI^qX=A0cgCO{X-K|vWOYM!LJ~=Az%h?D10>}RIjbf3SGN|{Gdv<>5eXhK7o7)ec
zG<-5Ux8Dr~f`LF_(tg#$R{ywov;L9au>lgVuK;cmH)_<8(QTw6fhPax%3v-P8H2!b
z4OUW-nS+CBDxx(Vo+~kuie#D&_mx;F6)8hty%eh at s-^izZMr*^t6KR~vYQi!W)>Fd
z!VHaK$t4P1PI0C at mI-K59q3b0<I#+PR*g#rZ!}TXl5;7O#3wU3w3 at q=<8!plUtKK4
zD;2#uSLHXVjVjMol`3C_eSOvEAFr+~)tmh1A!of7XrklaXGq#6Qm8{9c>JM#DjcG0
z3Y(n1itJrw35+2RJY255_X(@L07rd;aV)!sV#9G9?MEJY&@<EzmY@`f4W-;NLBOPS
z1o;9O)UVk`f1m2pY`fUq$t4MJ3`jZJQy+QKEDGZPuY7i+x#PVrd~Nr_>An+ZXJ1~6
z`rXpRi>-opDym6c;lx7r>lL2w+f#0hRq`%pboB5<_UH at 2vDwyCaaV|OZbC*r!rwnG
z504x__Ui0xZO`e}cNPr49*=8EOr1kNST(Ke0T*e_e$j+R$Vx|`ZOj at N&9(kVcKOFP
zah`Gf-n+~B{3GY{ugm!y`_A!?^Vvxp+i}1IH3y*ul0nk3mIMf-2(?;a%MU~ujFN~I
z)^42|?T<2P6)<gdQ>QLL8Y^@w%i0dD+ETKqn$-PK?T<<mEAFJJ(#BfCp69h4s2cfR
zzkc8M-n?gjp6~O0Lc4k*$z-JW5wiDed&3WV7>4@~C|QYJRkAWwvM%a}3$&F)uaZDX
z=)_NnXwnj?B#BfHM5+g(lEm8-4JQ;2#<|jvC+K`YRS7yD+i6^`Fj0DQlx`HITSP4t
zx3H*jwi*W6s#!GJsfnD0+UCMLET)xBcA=0s3$!vT6q~O>LX_cZgDZtINpG^~(Art5
zCHXw$#9OyyFvx(&=dJO5`XQr$V1uf$DjR$A3Pv%0HNqnW+NTF7)b{r#MVdWDsuUts
z4N+lnNTEZDh(n4}?q;HNWt0v?>132XD2`eUxv)@7aD`=+yYHFOnk!w+xp{ajbfy*R
zOwrD-E8E$!SjPD8Di4>(%ai4~a#IISY}%iNPYY#Xp}bsX7s_ND1{TX)R8*{(_X_8=
zeQlN%OAfS&R!ka5M6Fl?1j6o26wK^~u2^AHE0ZXe=o2Rs39najwJ1r)oJbZ#;uR;w
z^WqJW7q75y*b%D~O=fj#*c!JcEq>OTvlc9lv1E(2FpoPS;H~j)2z5x?G|C~y at 6_HK
zt`q~hQdtdU8pwV%%n5ud%(b+VCP8h|8et4kJT?U{W{iLbz)1c=0N1 at BMCAR0_e?;E
z4F2f*gNF=7au+tP^akvbi{G&A=u>V912One!K*jou=?iUqw7zs9NVdfTa!sM?HwXV
zpPo9k5*<^b5NVqakgr_aqG6n|Ale^tS0T>4OqBK1Bdrx|Aa!&eYUgS-o$Pi)tMM2+
zIEfuQfP*|;#<!$Ix13^XnUV6lM8O5$)!@{L^SDmKn<L1S#s?{JL61xwoJ{Q-PkjJ(
zc|PXx=rII~rXqw3auNL}u(AE1e>OyZs{Bg%J$c9ZcJzIx;Qxn<Y;iuQ><pbI&pV&<
zz8`VucCpOs{eazhom>ySqp`M5wu+6 at _<8)%bKw7n07afGV>`@`^OO7>zrYLpEsqV8
zw&y&QIQ_ByK{dBs{$x70tvZIDZg3&9V{l>k;a!(Jv8|VMe(RTajl98l?k+MsT>9Nb
zOo9C)zhN}4$nZ>%E8diEM(+Cv*<rN)Kmbt>iTYDgnoYH)T`3{$^9BtjN;HEgPUxu)
z=mnZ(gG4xJLhcrW2{%DgD?nENAZ-xzn?N1uAF+K$*dxMm*Kz5%{~O8?^+>BYHVTCh
z6hF4JRrXaPaE0JYzvQmqPNRTm5%>%WLZZz~m%Dp<TG|956!asLkU3ap`Q*W;Zp_>`
z{>0ON+EG5Z@%*XBPJVSWH-GNi^WXez_TqP6J$d`+hQ4zr{;=}Fg||L=ejJL9ySG;c
zxYvO-lc}(6b=It28&$RF%Ho?#K$Ki+Aj}w?6`&d%FcfOeKwN*>@M~0e4TPwf8apnN
z^YfCRy$;&if+YvokIt0TGb%Vts=^FaVTJ&mps?WFs#I`kO3v4Wc5zX at 4#JwJ#5Sb$
zDpS1s*<}Q==t3q{?7CdN>)>>h+W^(bfKkf<0v_sPJ3`Hx0jn~CWHKZy!C~BZ8ax30
z(tUDG8A(ksK|Ggh;<=PVs!zIlk=Ba5Ro*Q>=i|?`liv2e-of_W?N9oiY(Fd>^Brq{
zM!e{_Dc*KAclC~xM!OGn^L8)Ei(JO?2f$W^&$I==T$u^Rj1QSHW)thrWjMZ5?jd**
z)`4dVt5UI`yXIW%xNFum at 8Vn^8EoJRdBTnu#&CQx&d$aO6PM!)@x}OZyeU4u?#;n^
zF|%H#syJQ6f~E?OHSKGu$aO{JBpLk=CECcB9nE5 at JMBq#rOJ+?LGsPel$<>VDY!cg
zhFL`ygmP+njF}n(1i4fxgiZ%JbWje>hJh(5Ywi_DO*O#;3skNf9hPY6%`XgnXV28L
zldlZ)WQr}7!4)IC#tekyL`+SQZm0CM9S0tGc#l2Ol}~b&>AxO(?9emsRev}W@^-A;
z+*^vJQbchV4siQNyHsgr<&}xVx{>XVU;WF}cGV9oGn-Zhcm`OGGCA^Ion<Xer7|5-
z at GT?|M~qN}iG($Y4^4zbeTYPT2#o%nYAJO7dl`|Invh at -h?N~t!5i}@QmSB$`rQtx
z#tk3?&bwN-2TQp{N^A|9#Yh$<G?GOQBUxln^J=k2WsY=E%WbIUa0hF5%y#@FbD at Lp
z(z at b(*|oVL+1Bj%P<Bgh#5=5w#)jj&viouq at _uc9d?I^7p3-JwQ}LPHY3+Ntm%J}(
zFU4Mr{~&uV_cP^X?dPqp=B_H&-~@lm-O7EM%NiYrQ-?Dz1kMJ|1{XUVI|8Ill&qM;
zY$H}oFcT5g8`HUjW)Xa>L at KH}9D)>yFuE=wc6ml8bA%lyvt*udM8u~cAEgU&XgI|F
zHgqHOuMiiKaWvH5-akW?I5#!Dt$HUnhUpoD2zgvz?Yo0K`YZL^tR^#omSjuXU@`${
zQcA)gX3#Qf?4ivDJp}mH=9p<zK(fkOk+OzL2tvqE|GkE*u?LC>;Pr3^)zZL9F|alo
zRChnS_4J=f at U6;tdR_Tj=7GM+3qL;GyN8?q^zo5mYbqtXD`0&O4gLF%H%ZDcT9bG3
z<QI^yul?@oVu=Cg+YETU24rQ(<vLfHEY(OsZ}FMboSLdme3Y!uRla(|*Xj*Ns-qhD
z5HUT7^y$>X>a^me3yI9BO8D0Royw#EJ88(AFlS88%s5mJ2V%8^6>b&k+b_6M`R(fs
zC)&vG3EVCX_f9xxoU9WzPz5+C6-pniVDXIqqe2Otf6^ipJFnrKu4k=#W)k*i at _kE7
zW2+uAVoyN%<}I>Cug%)tQ at q2@l6_gCqsq~G at l3)rjScCTxruSPv%a7q6JDKl5@$vB
z5YH&bF%GB*_X)%nh|sBLNtW>?bzL{etTAV>j3GmXxM(aJO~$zO^4BR`t2N&Ahf~v(
zEV(*e9rM*{xeC(|Jn*>F;O`)DhS1zW>I7cuRaf25HHx&lqa$BBd~D5@?qp(T$RFzH
z3N&wgU?ulZTiDgqoX~XBMMB*CyYKe5|DW&bk8R_s<M-}-_WiJZzij7z*v>h&b9Q{O
zlQ?d0RhBC>{khU25N!rtvSpJf43q}OhSq}lgN=%b23iTS0In(_6(O-MtgW{xTRKHB
z)P+`}E#r?egrcfQ^%zs>A5>}izGtV~{vq;v-*@-!-g~+CdEd|H<7^m<<R8Af<3R_+
zTP8;Q)YOSj#<73{ygYVqmA(Ra8T1Wz at ZyvSUdkR;XEf6B{v#dlH<B!qbAtH3lakic
zkA#VI2=_~a0nU+9KDEH2Z?otL7O~k9LZ~lbJe5RKNtDdmCYm&-P1;mNYIM0)0}WJy
z2%!dKI*K6zx^Lz3ihQ}vr1#M=l#(3I*B48wMV9Ux477(a)Lkt4D*Fsev)R7DmLz&C
z`OPGq%&H>7EBwGSF<K<4JY;fV;$j>X2gfN7br^HG9hX5v)oQrN%geP<d0DMO2P_Ih
zC(pZvORH+p6RU1ctm={R;6uIh^6?BS1caQBpDa(8>t(-GZX(-z4$|d?(1q}FW;y$p
z^wrE?-Rr*V>Fb$)x}rMj*4(f6A9jzTqx4ax9<7^os~$hnf3z5qkVFd%AN0os_pP2k
zrnxv1i>UEf!pK|h96u+_+sD$!GNM`t<=ma_p7KQb>HO2~v*A<e7t1%8>+xWo8%$D*
zbP{!=5~5KP6&9$)ViTF3(x)elMJs7`n at Bco_;R?@Sd8J$9#zexL!wV|NMMub4^*+#
zH%L+Vqnh6_486&0^&+tn{;>4hDnjbT)VryFrI=KciFo3)geIkFX;xySCfeW`j%gIT
zImEdQ2TeNDPTgT_XTYJISCLH(A^W9W>xW}^YvvX)M{BiD?_ao=LbdT~33TPcJp at hA
z2CY at -2kOGMX;p4ZE?j{s6~L!uLSiHo5}ykf3*p1^^0-dPH*d9SGe~aTYPH*>*#^<e
zMVk)|Q-yJo)8n~(w=FCFK(~^LBY&QY!x2u#sX&g6qxHm&y%)^I-wE87Z!33lzS=mN
zq2Q>(O{0Mtbc1P#FN9{Jv*xTd8=vd>X}ZxL1bJLQ2Qd}EV`3>?%KXrs&&<1QZ5)ec
zC1)E|K4(;sCsb)D7FdV{p=x3$VF=YC+;U0bt3f%bj)rYqfrMPJsw5cI42XgSt(tC!
zAcV78)z!83SZaGLNrfp?m_n_(wu;|*-;*SGOsX<+2<8dl0p9o25X=*TXQ1c`DOBPA
z{lT{xC+SK_cbKdz*45R{TSP^rl`>XUAgX#Z!~$R?hJ7kMo9cb)OIyEScTfD}!s3&k
ze<Bs_3Z+u<Up_jv?~%KI>+hd`X2b5XBCA2>#k+4E`^wJ#Pvr8&ZBr)?&m{#DZF~Ml
zpRJBPJiD>F at 8Hk6q_7S-EOPJP^d{eV%0g?M9F|RZD&(+)hZB?-)G>PnqZ(p0($ol%
zX`q`3;c1xph*`kjB8cD7M9!6B5nmHo3l#DLldWA^DYce69Ci)Ve(B at +$><7V8j6uR
z`jIy5$BmbXoLX-fSkFapYg$C2WTEJR2-*=rWI7L^2y=@TVu?9mIZSgbVL=ua_#PPo
zuaxi~H2!;zSP3l=|B(L*msYSRT)R}OEy*kLat#QEtQ at x0dW8zX0yYP$6KH~_M-y|(
zobg8VjabvTVFVfpbi_n^f_p*}!HLj+bk?s&bw_7nQQa^ZgsX^k0x{8n&T5$fnnwO$
z1ur^wG5RjiSdT}nw<)oSZhEc_<XJ2wPABLDg^<t3W+HnvRM!xt$=YdcNxP)|UGr;`
z@!uR-w+3tYv~QAYw?I3zAWv+fM%Pv`b;>R1T17yg6j5h`10eQ^=AS8GFqWffg=ngg
zGErQ;6(wES0K7SZc3!<&&ZQnuoOFFlaev>BN50YDmG_;$`{%7|za4)dpL=wwJTXOo
zITbswz4vj<jP$)#W{o*cW$A$qs$!0Z(Zh9QxoGF`rF~xy*~yN>T=g_!EKTyDsmAeh
z>N?!ibuS8yTW9ctYG&PfhV`spw8OeT;fBQk2WR*Uww|0om97<5U`N{${$?A8D+Lmk
zt`$D2qxJ<nZjzhk7)}svQ4eRbT`+2UNU@`d1&kd;K!t46hp$W`u}lHqGgXf3wF&ZU
zKQX3uFRb<hf;|=ML)?WM1beFL^meeP;2J7<1ujUngn>8;AS6Nz^xz6+)CzL2tFRr+
z52qd9usG7a(ca#@-DXWr+k>5FYELrjq&Wv|4kWoPwwO(DO*H0d0+r1ICE@=kEQo?A
zrfjVJ!_;YnBs7g0=pyo=CcWroRm04v>RxSDqw7$e)))*ry8}A_UGJOU{kTp8DgyWc
z`Y4RI(KZlUc;)w%8c>I9#U&*!nQ=;1EIAPe8z*l9wg3-MBS4H0OWDPyE9*D}-4>{%
zI_QKer@~B0saUrYzWZMPw+ at Z%KIq0rwxiACqlK^Ssy at UVU%S%S7FW^-->iRX{P{YX
z+dO2U?Am;N?}i8Iz-LD2EMQatjJ5!yHhsR0(X%{HnW{hXI^aoxVnd;sf4oFN3Tw4)
z-W)9fBa~nRI#?Oh1>WL#z9$9miIEuI--zZ{i2qYmKTYny`L;>J#^bCMKK!Xf$Cj?G
z$k)iW^6KY={rVRT26Egx3u2`Qv(O{aO2mkmX}(8DDYlx?ZNoM<@>OA at TGcDYMsp{(
zgWn>I>0`zY^8ojAZjS$j`GVEx`89Ql`xSrEIBA};Ugys6XN9x+IpbCHHEXHoihf(T
zt=}>G8$80Z{BCG+n8d<hJ0|n(xNTcII!-&L)9t7zBzm3^AC`I!Q8Q?Uo at Ni(-($b8
z9PQyZa>K%~UbTMjUrN1W27VwM(VsJz5p}yxYkDN9QI?&gR6$9?DR|a%dDF0U!x-R&
z2+s?aX=Zp1T3o=-`g|NnGED{9MEOla)SC$CX+l7<kP#ZfS>dw43Ws?MgIM<br4!sM
z+ at Ij|9_EcF&DW4c*%S}!mDFJ#uiHqFxG+?~;aspn at k{?>yV_#oxXSRHy?8ErnKOHv
znO*Phtas<;*`0Cr7LR4LgIdyrG>WO3K!R4O)D{wi)Y>8>sjzGbQ9BRF61249B^3|k
z0kuuyG;y%1x{{Id639y<8mTG|ZfQjfCJHDLvBQ66?2-brI_E#<%x&kK^L_vKfn8cc
z?_I$|Xm%)=4Y-QLD}1_LA;c<U3yki)KH-b}ru3-{dtSPiUng-&S`Vy=zt;)7&INL6
zE^14D!vbBkj_}H(HDnY}?UOr-z~A~7ngV_E4yWW2Js_{ou0mvMpqIfcfJ)&YcwE|L
z6p$%UP>_*`m^gAIUC9PQBAo`+po6UFRI&r$fKU}_ny%>rdV5eevme|Nnb=SpS?x at 9
zaBJDzx|TD_LNok|swvfxt$|Qtw3uZ1n5ssE(w+x at 4M)2UW*I<B;^A8KGN7d%zOjuK
ztx^(_q52YGUW(NuCSs`N0e*mN^Ip$!L>F(~gk$9q%v_^1$excA-jfD>OX1hxlK>!0
zP)iycp$z}wXX>a<om7z;J82*z7CgOPZ&WIFgFpwklDw<e at AdIVeg9>G?>hWhEnH05
zWRni|IyoH-rl9JIeat?=zG#20es0`X?;CM)!KHM^zwUaW+^*QR`CPXs%jH59+YwGH
zYIV)k4vFW*^U`^ZiK)A5yY++Aljs1wk9nfDM?YX3Fz4x6JS+TEoj2yqS^Jmx6>_n<
zjIXKJjQ8y8>UHBo^+V&PU8bTDdLSDSS(VmVW5Dc)kKxCJiRe at GVd*LJY-|C~OK0V?
z)p>PZo3+I`_GNKS3n$nk=oCIBL;w at 8nyShn8c=~np at fxcrKC`1y+rX`vc#9=QmG7}
zT4W3zlIgVPNoq}DXojV0rjapC19pR|k1%Y8VOUTna<;~)8IDt{wc3azXCz5BwW=(M
z9N>?Gby!As07NBpXR(ZUf%Gty1Z at IY5aV)LQK%3ZL{uFv0gy_|=zEk(G3eJGZ+P%$
zYc(ULJm8<_z*Akkyh1&1R+kXtWxawkA)_~B^sf8|`D0+cpVb_Icj2nSs|drQ6DY>w
zZFL!8N~5xX at VLi0$28<=vsy?4fpnRj)*a at z0CNW96sJ%Inl(0zkU?@k+-kf*6JjV#
zm}u5Sl!;Bn^vnz9ih0wd&1V{4sHXLMR)12?uWzn_>6zTdHVoxq08UG5d5}`15U>-d
z=ZT)`jT4DAzWoc@>w(V#^am`E1QuX+=zw{2#QJ~4 at V_;UnQ>;^CyYtd2d0=J7NTzv
zuF!BM-Xq3j5n`I~M9~!=2^kVLE{U#6Le}qH%m&m!j(|A^0^-mKPXx5FLnPaMR1F6_
zl0dVNhF5>rmh{{>y1ciPVQ#*k(Op#ern&Wd^OLQAs9U#-qvOCQk<wtfzWI0b=G?fL
z46ABb#MMl8^Dg>VS4o#bs+u_Q;4h(ln^(i3eXRu1j0K7c{}~u&G<<hkGsZPeYHN`O
z1&?xoXD&C=I5Y~4D^#N-1VrOFgk at Iz$~U-#Y`nSD*EqD0SV%4ibJ|?{R_vB|Tfg06
zd0XSuSS>!qos50jqzA`r{%AL1_o6-A6GpY3;kHM{_Qek3gTkKDKJ7_kf7=^7EFV at U
z#!k{Ru^Bug%;aXoSLt*3oN!)R)=J4Jk9mQwmvLDr*G<k8oiPrN9b%7mC&nV%N}&e-
z`^+dBB_Hxb2RXLZmbeIIlW!>5#iDE5W9|;2IZm%fzQkv=m7pfy^eYXpDduu|yWQbp
z at pud52TjXbyVGuU)YL-G5s=UUS(=L%r{#$fDmm&4)tPFjx==+`S+#Aq)wpY#dTRn^
zd%A-<(I~CTG+pbcnNCNI=X8Cf70<L<aaehYjf*W^m1CohCUN0-o9^&~Xs`?`;n-vu
zAb|@4$;x)5ff|icsmR4aV!rc24&`ih2_+X58OelK<GAC=7vw+58*+pUkZde3hq_dY
zqS1FRb!;8 at V3BH})^g~5%B99a2No+g0Gif6`|J1C at ut<cCfC8w1la5EWLuD$euc;T
zL`eC at hCnZATXV_j0BEFvq?9}DNO$mBpUm-^KhY_- at AP2=`(6B_JJ6yTJf0k%OXBhA
z)m0K!nN=DB1EWU(fm8iHN!63oB!KT46$4ChZVar+Rn`@iQmO~-&lVwOiAiM#g<ird
z;GRTAp+lmV7L&cGmx}dh392q>jS(pV(KLASw2dpgt13K6_<y{_yEFkZ?=~S^Nx+GO
zKjQHzS5rt4U`!zQfn at YW!lhIYgg`PB5-x at b5TJ-&%Eg#>1t at hd>!t%%$OR!qQeoE3
zL(fZR-7b at LjggFNLJ^pp%lZ$?xuz#T$+}Ha;LRd=I}~#JMd3f(^5uj2uRi+H37>|1
z{gM;K-Gq2{^b4KN<-}~I(<Gz1PN>Q66I;5Q=$rz2+pJV$xv%cuJEWoRuG+3c(`!%f
zb+;xOa at u?O=Z`lUTOZU4+R>G_zW$A`05J`UQWFmyKmKe!TLfB?hNjMMEuGmFuGKP0
zQS7g-ep`_AP^}it6i+>T at crF@mH5`4 at I7FrW@u=enLwRd!(r;Qj`Sip28kHa3?U}L
zZwjOt@|z*jZ2HaS(vF$1)~!46>p3_2JCwD}6eZT8iWwpFQWG_)6wpKUCGrkFlW9>@
zyY+?W`KZ4NzR>3e;;(j%T)_LE{?@xx;o*Hsez-y9f#^9r3dfOx_Zt?&_DWi>nxS;t
z&OO)tar7qxA(oA%7 at 5hlRwl2pwNx#yS)-_%>J*+x9cPboC*<$spDi4(pJvW*XXI1)
z9~4g4&vIww*QwXp*YdxxmZ_WVPX?->Ni3^AJj@|qsmny(*PGk&USkwFpC1|KGH^lN
zvV3804Z|(Nc{ai^b%-)34W_y+ at pVENN%*(AQ+11cTNLv$Q456y4t>mRaG__o7rDQ2
zVQ#v|9%PTPVRjmfZPF`Rw|E8d$~h(UZ}zJ_rmgFYf9F2Hulq25TnvVb!RFxyHW<SI
zgKq+)<N;xMLWY~94W)UE2AV`uwr(^lNw#z}?fOSlWr8&gRkUU4l*A)j{^-_J>ZVPr
zrf$llKBkWDQI%+$STt?1*>|qpCXt$H+BB_y_~PHapAYvOf8Te0=X+E<wLM6}!9<V=
zx}r_zJagEk2Kup5?^{TYFQk`}OPER1{XHYyzk at _ydLfVvCv+q9@L{+kbK{eSmU|}Z
z+sT=X)6fvOS1GR7;(9w9Yif=*Dtaf|LaOzoYa!oqghHNoer7E+R0fFOS6gg!Wll6-
z_;mZamWZdd)>M9<cSYuVlE)=0QRHw<Sxrx-k^H@`w#aA}uvjnlh>2TcQ^&i5{-{&x
z9GYP+s`XVC*@En?!@Rl=+3O(Zv~ZDuE9Pdn8DT~|$IWwvGYS!ugF-{|01Qe44z`q2
zM4NO!w?TS`dtEBbv9gx1ij$QXk+-bn$>(`8!0+H0K4K~8mdF8#Y?mI97%9S-Ad$u(
zso!Ws&UU!1*xJHPSzh5N2lG7fYK=U9$y9FUL`m|poSkJk*357cv51O5e}x<12_F$G
z1 at d-@ND;!Aq#rPyAOgp9YC)FN&!AcL0|JQ%ny_DBg_5w6P}VD~VyQRBfFX>_seCh=
zLi(4+`<52^<>XByz*2HS#y`v>>4~_0`%p)!CIWl6V~<@cCh{Vdxqr<)^w19z0c_Ir
zxGyfht{E}Pvk|;;l&}H{l19IIovqUR@|!7VD_3i$;`NlhmD^uL#gnO`R<77V#XqDR
zC`!8cUFq(ii4k##u$~z4R8rPdwRjxF(?|mzJ8Zsno!OCjV`tn}%GDOIkbaKz?_R6O
zX5z~H-pl%3RgG&hzFTip1uI5DugRymt;`%KFs7B6SY9e&9a0 at zBek(H>5$E6lsN}S
zEJBlGo~=o7UoaAAGNPze%5dr=nI%kwXoLYGlM2F;o(QIN%PFC!c<^mnIWJPTCNVLG
z7nkB#952O*m9}4a5~4cUYpU at q6jn9sl;@E1oIk`pIa0spt>;#(+F=hC93KwWKTJ0E
ztbK?%bL8vlHf_t!V^4|YPw#-`Wmvtu$bN+%W2&JWjVXjKm<9l!rZ8G!e_}GhLiUj;
zclHJtvf>JJ9@&n$B{?3W^Vcmeup9OHz54vG!4aJA(kx8ELp;_-I!V1fDMmf^0q0<1
z{1~v%s!2#CBH`dK86E=>%#-wG_6f$t@$-!FqUXIAbbj?M<$_7LZ!wvT1*FQx#4^9G
z+|7?=UL- at f?(z-tDraRxT(|5BFz8_uKnYJqx%+z2lkfG*H|czw?TL9f>p$M&s>rLW
zfq^b|6m8fGP6)vfJcuB2#fq;~t*taz&9z!(O0jC at 6eujPVboFbslG`ci}jaZlS<oW
z(XLk{Q57deR-|J_uI+-I*j at GEd2-;QXVbQ9Z0uW1<4)o&7ZwwJxSRO7;}B=l49Rv2
zG<-!Hoeq00qWM04n5-IHXEF*xu&AzMO-t9lDdsaHn%QhI2c2~teV<yn=P19ou6|d0
zl^{wT!AQ at 6&AZN5SGNs!x<yfL4>a^nY~FpI?qtpjgoSGW+!;Wd_cu&7ATb#~OLs3x
z_wEWiLf%JTmB3cb1K5f(1WX13oXi{Snveq4O<g3b@}$hl=#I;Lo8l^UUnPF<z%NJ#
zWH<D-ANrOSvsnS;AL~1t>yFUSmaL_PSyNk@$<>E^r53YfDk`<scB+Ba?mdI;{N6xk
ztR_|=NrlFEDC(}B*mP*8Ms at um>iQR5*Y#SN(S^B>myLEv37TEkl5dj~Rhh(?hI(F<
zKSs-Ra`AQ&%WV?X(MF3Snt7@!KT<BI>WxufiP<8Wi%O`9{<f~YL+$KHxFc2_Q?n{I
zx~s=^6_I(FYwSjN4P!?bPG}vcOHbFI3(tpN3;!`(a9BL3d{vxMxMG*P1_&p441P;-
z%CC9NkSfwF=7xm3Z6HLXkQ$l{u_2v~vslTz!nH{b)iLQ{9n>z#6=}GWh}5W?$#imJ
z5rg#N0)D7fck*wX+IP2kIm+?(7=LsmVKNIQr_<?=_qD9tdyG7|wa;X-2u{U{v~2F)
zH<h{OZ%uX}=?sQ=AksUrb at z9?{?JH!l_(etoq@=zgGfxeYX>r`xYd|T>)?iFd)z?W
zVCNW%R9;r*z+dutX)-7>3r${cWo3=IB*>V-?F;L}g6e7dl6TholJ{jVr;pf-^hK59
zofwEE$yTnGxv`l at 2|~eUw^yBCepmC#a=~V`nvPVcL{j&wGwRP(PE{RFyVFRAonEZs
zZ(XAAq3~zTE=UEN2W({4_Oguun`}F2V{Kuqcmh~-Vwn>SQ!!0NYcw1U>#mK4vBg at H
z<LL7Q9Sr1Jtc11InkAJFU0Oql|KZt2idmypyOW*-UBG9Q{)@SO`RJB4?uxcRu&Jc{
zth&B&XnM{Y=(c-p=hr?s_oJ1u;pC{NKEA5Kd;h}^uqV<Nwrz?XX1<?ZJ=it%+Y!iJ
zhyFDfjO1J at 3%(6;6`=500K+Z-BZC-5Tmmpv1DFQ^EO7wQ0wBE)Am0KgIu2mR_w0WI
zP;k8X8B7e7h(Bdf^32^RD*>qJ1n|rQRQUnCxJLE20cz&}{J#MR;##3C0Fj>pG`x$Y
zI=<WdIe-?_sdYMwcs)R(7C`$Vz{;ZlJqCc at w*l7u3SfOahlMN#rtbiL--PdNMg4{*
z0fsjK>}Ujd0Bs-b2iSw_eYOeU5%kNWsLMh0#bI3ku^RxB+W@|dKA6IJ$6f+>@&Lf}
zPXL}C19<i{z^M$tH%<Y}qVCUcxEp8We***ez!U!my!pw(3-&C|B6rSW&_DYDz})nI
zh8LgDBab}t$m4&7bA~+f$Rm$D^2j5PJo3mRk390oBab{jX#fTY(8~@im6&oUU`%u%
zJN#c=>_?ITjCePL1q2Y`pX63MY*R at TJ#kEuZ7>i42 at rG(2rMMd2Q6%tkBD#r0h}1e
z;kyVu;&J>I+b??WIT2gzRtO1gvw)z20tpEUkkBq5s8*EpAj(LoXc1Hh%$e~J3Sc2b
zG+^t^oH=uUb7!t*VpxEMScFD;U5q7IiY7E;8J1%OTCkFmV)a&GHCnL-Yw;u2VLjT=
zjyO8di7s?w10{aKMr^{*=)o`8j4fog@!M|o6X-)fc48L>up4`@7fB3a2r2AC8pFt7
z1p9FS2XP38aRk5OsMT~nYlXLQ2mjz-qFZxGRHS7t+8_P>_8v1nEBz?`W822vh;rwI
zJFyvCnY%;G)KUD7KX4Z3ae-Nw!c%FKCTW%x(o(5F at 8D|g+E(;3&sy4{^xru5A?eEW
z`+x4dV0lfxa;9>6>hjbj{x42lob{os{iH+;_h;l@&*;?S2}f_e{aN$a;#xFCMl6mJ
z7cH(MK4oz|3Xw~?nxgv5zpnkk;u>^D>n)C8esq(?wdDIOjuMwGt|Pu`G2 at 9o(m1B=
z=jPqu$vw&4RLC*2qwEFO`DKtdI0+9Wexa2T?BK{J)~!R{H4;LmK>avT!tl-<Ep^O9
zCaf=yTzN(&AUD9i>aUA6+rvt3x2W5&z0 at eMPg7@%F@#1dO?v at 99}{e|^x>jtIAJ|2
zOd1)FoJ0FJP5e5#Eax=m;{-X6+4}O830cLMTzU;nEIJb5Sj&Xg>IhdYtP!oRD at OZE
zvK^xDoLQlcQ0pmL4NUBLYb~BRIj(ZfsFLfF$ty{EB`+i;J3N2f^PSN3N-|y;jZ4A_
zolgjLXk#+$70Q|kWS~U7uAZLGb~fE{=`9o_?T+QcK+-Bu{)EaV22+DW{p&MsQ3Zo)
zGVK+eQffGvnJsS!AtQ#mCK=z!s-okc5HI(?L5r`(+#poG%8FZ(kfI~Ql5#?6l}u8G
za=ExTrL3qzpeFMai+|^Zkl^u8nJcZI*W<ggs20V$l1MRzB<IuS2$yMD7sYI~zqb50
zTGrg_>MHd~D05bi_Hwk7Pmk(qblfgiqnNX at nW;v#i at 1*#T|Qp4|7rx)m|AUijx$#t
zy}&%$>dxR9-$4_+Cn9`jb?|+Ic at JZaygjOKJ>GB6yZ78Z7TfZop}E0aSy!f89_aqw
zquXm=hOhowfQI=T>O0HaX>SA=0QAK;PzntSWo~41baG{3Z4G5^WN%_>4K*<!Fd%PY
zYCJqIOl59obZ8(kGcq+WFGgu>bY*fcMr>hpWkh9TZ)9aJOl59obZ9XkGcYkZHa<Rc
zbaG{3Z4C-YiPTnkTocz8zLSKomt7G84qIgja3{*X3WB0Q5W*rTCBy(hAZZdrfhviJ
z3l$In3spfxw(>*;s}%)Y5d^D<JPX#^f`BV1uZT~UPFULNd$0ZPy}r4>`OTbj&pC7M
zobP=10t5h{0MY;vxULBBS~>J+hY;7a1E7^d53r;u3(SWB&|Z)0f>@h{=qR;Egv<2+
zNMDcQMaN$$*TEwgqyj+3qT{wkg*)!K3_yS~07zC0o4N7ZFr6I$BwoP%tz&S7>agk<
z0467K*)S$vxaE}Ff;L?4!oO!6$7L~r3?Ko(D8XfFJaY?A5m7#Y`yayX(FA5ZyKPB-
z8~_P;e&h}wpUvyH%_{@IeF6X_HQWZ78ImW^O2MD%VCK>iK(Q8=ENhyvD&vhJB26d}
zYenFy^#laLK7tBlnb{eFloWswWH~c3LPEqg1cX%L5B(tZcN$8mZW;wR&I~$;1OmVX
zaexhk`0Xqi5Pd%$N%`R-!DoHdw;5STf9A{fXikY({Q?vdB)1VkdG(@B+t0=8D91Ml
zKGE3l;22c=HBW?urz1LoErvQ|VjxLQZ9x#5&k5i}C!h>|qCklHvV}=p{w8c8)Q}j+
zt9>+YKt;V0SQZ!+n$Aub{N~AtXQKf^W;~CR5RC?~`I|W`HtNsi3bAF7HfwF>OGmxE
zmb-a*dok9b%iY~Q{1_f9sHic^#LfnN{~J(up`x7)w8Cg`<_cY?2$w+&+R&C-*;(0z
z{`D6iD*pXHN2CBzv=9I9dk7*CxNCuq#H3QqEku-4<kJ=MXH^t~djjq!_O&iGJ>4}X
z8 at 6opNzRn4!tGw|&~G{h$9A7O+`P-^*=Hfjg4iuLKh>DL9x`U~RY-UNY0^AWB}7DN
z`!w&Keu(A0c6F(A>+^Zl^**bgymZk2TTtOPy+d&s&8t@)jIA%XzBeIjez)H4O9BxG
z^aqe2;(0LxKXOiK$yME^qMW7Q-c_e&7B;k^Uw+GxvTdUk(tO>Y)(y9(_wC8^?)7C3
z*Ok5Vbn;s!U(5>{%QD@*@YZ8i(^ihOz~W at S@!p?bR9AIw=#Xnumd(CZS8H5wb*o8w
z?t|&`(Qd2CbCmm=nB#{69v`?Pa2cOGOi!-~yfdl7VnH#90L8>jB}4*3ASlZu$FJu`
z9-yDUI_dtSy5`~kM-bzfrO|BP2eI|9ATF8DPwrpxn_HRue_WXZw3{`cG1&Zg0m_X+
z69sIPDMVw0LY~0h(lRM2$zn6^EWn*DSloC^K94C$6k^yCXe4nas_Fjm>Y*6X{}9Jw
zL<!(}If58LKyxy4*R#_VM3%Oh7V}}+Sq+_%%p9kNCAsP9cF%U+GRY-JttunZ_YKi2
zMry<FST1VW|LV+<l>K_Qo=o at oj!e|%hn!=X4`hv*Xm;?j{I0wxXmIUqG#YXX>>k_s
znmm|UNWn&lN?qQE3{4+sYiEl`PYzf3^r=@o%I<E7xy%fy;&+Y1RrK#Hxh(X%J#FHY
z%WEzeUlYX)4v1ZAJnc)~x>$F3H!$2nli4X#>HRG$88zQHJx^=VdUJKDNYrYY|89G@
z{jMDK-gb+`*Tb6zoT?%k-H>W}by%f~K31%%@m6qDSDZ;Qd+JH>j?Z4~XOX|gbPG9M
z=(InZx)PgdrDLLVP;>^ml4Wp4my(jk;fVtV!g(1Y8HSRg;5Fg01ibf)BGFh1giK+g
z0LtP;(NV*j0KgTJSCr%gC3TjM$XJDBjC&w>XlM$J=K~Xv1(ZLkHdK>DF(N5Ixp^0&
z43w8Bl}IEaf!zFWSipRg&WfOF_WW$9<X at -otnNbe&dUZbvON{Q)$(Z^O-)82O*1Al
zw}DnTa^ReU26;(}Gl2}s^m5bH<gR`3*fsc?l+jRatx9awV~3kh494<IHn;|k9uGKt
z!`j}CEh7+=(K>5unp&hBr#+ru8R{{-bBlFCw&LAS+I^GD<zfqP7Er}^v4768fD*U_
zG94XvtK4xOV?F=D^+OWiVP?=|wh{E*xxB4>PIQb=f^rnI!#mQ4!{T!V+$bUH&gJtg
zFkMKQHP(24hRbIPIot$H4=$c<49(x>B at BQrPZY**`5fWaxvdGqAhen5Y8u37OR+ie
ze~{6iHE9*$;w9dI!)sq{<Klx`!r{}>s(nVEj8ElzA3HmBxD<6xU0eEPX?6r{(;c^s
zTVK{}Ze{emes(B>l3ko0Rd;Pua->1Gj^jfmBzLIbYLj_XQBlmtg}3dgO$uj1KEC8R
zDCcZjK&>*it9<UY!>un}si7z?kXa*6JsM%2<o%?uexpN?9|e;!R4=X?+;65i;PeGc
zJt9PkU94l{zw1rKa30~h_T8pHkGef+P4>?jdA=tmE0W`dzO|a|1+vC^AUG$2W7Duk
zRoXFVI_zCpl$=a?rzj|R_-lvo1)?NU&sgJ$wEU@)9oxGrwD{{C+b)dA9Mgw&<ejZ`
zXp-8_ALg305{iyPQK<y|2uV}~MF-QA!*272Is79AYqzPN_Q{&Qd6fU(ub=o&Fiw=z
zFn>tCdEe+kO{*8 at 5X1XPDx>QoXvIh5Z#qlu-<{oRKcM$|B=`XJOv%a{k;4;zZ+CDA
zt+HltrVQg<THC81N~L~}?Q<$t=EXKlsnRt$%@eoX`&2?v`qRji+Ui9&%xsLz8`(!y
z_Zlg&j=f<}-s-h>YmEBWB)HS0C&dfLA4kV2t{uDh%D?5};8i$*VzRq+@=dgS?&%PY
zze;;VtPlIgsqb$Dzhry0_%pt)CmO3x=X8(AWN$ln at Y+{4)c)lD%A~%{CE#|f%cV~1
zy^ofwR$9es$M#zN*hL}rS9*|cgf6vB at S!M1o|P;8{O&!5i)RNVu$<ScYQO71VsS-h
z3C;?w_}Spp+}R*jzL4Gw9#*S#-FGdjY#jJY&;rDH0H+1p`OV%6!|(&_tO!NrnEVXE
zlgPhNU+(cxZEYN%o1t+pBVjTc(copzpqR*I+=h at 0Qi{olIdY$PNg7j8nm$M=*NhHw
zqJ*iDOC1rX$>pRAhjKZHE{M)auJ0bYI9)#PfA9Ng|Fid6&sux0wb$?YKF_lX=ITON
z1;`2;VyjT at v~Yhg<}$(W$N*BpPSI7O+kNSQ!9nzoD?@#6W#8MTFme8Bn>avqX&Z{m
zEp#yMgF!<W_P3GEL26*XrirAGCSr>;$vcX6=@18`^v^Dkl<FpR4+d_+IZQs_49;Dh
zYk=vis5K69yQ!~YVN9FLUBn&oa?W_eH?d_E9Fh&s$T5goN01-|&NMd*wq+?@DeUO9
zQ#a)`2$ItJDHDMmBWYWniL{OvxNa)Z^=@X-EVvY^owULY`_9yKV5iLidPRHH)9aTd
zvYq(hn-xgER3vapkC!?)sW{5=^jJNTBzmxAqkfHDYG!o-=Di5c(Hoz1UvuJUMtaGm
zE>y_D$NJ{U`8W18dMaTq>Pcl%;fki`llk|bn;@8E<)n8;L*>P`(E*xLd!aO=h at iPG
z=SA)1-axJA(2!o6Kb!_c23YH1Q20eQbOZQ5)V>v8;XejqWRNR9l%HrQm<d23i}@x-
z3L%e>!+TaLU2oPKt;+E@^ltE;PQ9f524Kyn334!m#99=@1#$o^Rml+ZWeEk;8jxPh
zVW7|jga`l!Z{LEM)sFrQ^TV^*w`?OLuW&kt)-<?RDArU|dcn9>KN)$vuhhu;mqX5M
z-hg4EA$^@iPo=JA>y5|AdoML_^(r2V>2ek`dAqLt;qAcVacD~~`Vo44(HZT;uH;R2
z(l>@5(vl(~`a0Jys2x3f3gJdQ!&N42VONjlCvcQG_EBCu%Jd#0gQP+&IpEMke-0RT
z(J7WQGxf?Ap+mVQR-*xs3&j>SH)YG+24)`RX~uP^IOe(5Y9xge<n32lpeC}b<LnE#
z*Y-shtu7QGZ`-^qC?6r9T}(6)w-&-}yH9G6XMKi8)e?5qZv1_i at E5UjPft|zO`w<&
zZ#Tn{y`^-D>H)Atq(PXyTY?#iCMrvY2rvERKTAYd;`}Jk5Ymqb7!VBrz`#J?P)I*L
z5Pk+=xg%@>aoqp)Mu^{YBlve-_FvPeU(#!gE-7fd)iM#^Y8n%%Qz+p5&XKGmF`uOJ
zdUNefJ@&L%Ib}rQ-%#!=+Kjr^iEUYlopPNR^=j|EmsSlto8Qr-L2Nrl9Uf1SshZTP
zT{8&J6pzPDmKt&RbK)4|aP?w$t$X-9bTS*=A9>MiJN#sJUC2$95&gd>4Ng0{9+~<B
zxQ>11j^ypMKtA&jO!O4gplw3etj9eN1ZS>^>iKEcn+TC8{OldKdr6jJ$6ONyP14r(
zt^!V4q+P;rkvXz)L2|_3-6!l0!@YvsN+bc at N+XZR>Y7pWXS>$<sr{zgrvK;Aj58&k
zZ``)t>+!1`I4z;b->h+}A3oG7vXn-#p=RJ8F<v|>jI_|tmkNn*qVO|Q0-EkRW5+9W
z+jFm9IlM=`jGwR_55yG-?Kngn7l_MYeUm#}=Fk5RUVfcm*a?@af*=FtfN8Et?&f%-
z4<(&X*nXYBkMCKmyg~vP!d~5wuweQDA7;3&&|QSy0(y!LX!yd*7m;Xyn_ESl9qAr_
zDj^p=U0B{SS4e8QIr#i<_>4<eVR}(+=Ef}eOSX-&YK@%Wxu4mJM)?$&YYW+;qFHHo
z=_C<hvT_hpC|a0wG1kg8LMiQR3S<1K;iT<}u at JKxT|8ITZFs%T^$p!9wp1he&uH7-
zeB_DKX8VI0x~DS6#A{Vi99<Icbzw_rf<LaWd_dt4-v*kmRlh?}c4EKRT)TFCFdtVY
zxnMjYYsH*cflOC;8hkq*s<0BHC4bdz%vX>5!q4%oJ^S*AbT at Rm$NTU;o81EKkoyN6
zJCXb#j>P=lwHEJFWAZMea at ue*R~!y%qy($i`cD^_UckL<%C1Tvutjhn7FA$ig&W8F
zVZiqfcuOF~mW~w$o@#E~I3V{aW^RBIMB(63gX4se^uy_|fD<H;s1HM6Pz1R8&n<C+
z6tLWi237lMB7(3IAv1$4U0aWTjgqfCFEe$AMF3)#4VNH<071EyEDHz~!hi%qd?Dcw
zEW{DKM}qh5kYKQn1_=V6t-<FY2orpA1Fd1;IL2ZR7NQ5yfdCMItIksUAoj?}$S=gs
zj0y?%3!{bjM}3(#BG^y}4a+>U(7LOaTV=9x{16A_aYQ0B7N=tIp48kU`M~<B#jV*G
zyei!gD}DN}e2+2q at hD#-B|j+%qjFDNeulEZZJxJnlE1dTMAgKq*nT1hJ_XzIx}LOp
zsB9|wglB&u)OItfDm);5-j>sw-1 at 3xfDzzs_M*o4YRQ-nfAmUkM0A_TxlSGSLTAQH
zrJ%={Z8428J^Q_nn^Z?;pK{AfpNk^@+jrljYU!yRymPs2nAc(SmR*e|?VFC({;YF>
zkCD07LdiTdnLk#FKBAcy7z)Q0oy&apTSQ=Qc5ezYYpjHNp(7~NCHdh(!{hkwxfsW{
zO#JIhWwebKpESg(zia2RVOs$<%=YuiAqi}l5!hw0sPu9Wd<2z6PJ*hHck>Nn2-St9
zh8+lJVjX>%k-=dBgw+6gNw!iS2WVp{K|VSJZ9sF$fcrd?5eO=jNec`SO4P+SEP~<V
zyNEY}K0sU=t>x&1-AXaHplqd3J+S6vveh=Km8G`O6+oQ+^BXW3vFJe0;Jv9%H|yuf
zeR2xfU+CNeP*^T#@lOp=D5&R877>E9Fh?K&1VbW$u!*R*^D8}{>$Yj``nAm4t}cS5
zR;8Bp4L#YC at I&ag{pHhMRkf}4OkHREhNtsS?CL7-GCax9?KSOxnT~iBjit;a?oD~s
z=k2!9dN^2QtV`8?FZ<QqP`_C)1wC|)(j!{U@~UL5Fg{2qTWjcK>h4wx?UQ!O+PUjj
z^G8**wDBg$Ok?h|3uBudVp-4EJL|nL!fe^8P=XS4OqC84OR<va9nzk=<1Dk&lvBkn
zpX{5M1~kQT0~F^y|HE~)K-Y9;;cx%{IrkEe65^&9xp5^zlEx!mp`?-<A>#c=43(%y
zf+4g_sW#eFV<p~8kr~gi;*}0JS{jdzu*wXosJAJhr5+t>jCPrY`_Gr#dFb44opbj&
zXa8q^|Ni&+_BmSzeADSlh`;OZ^r(au-%pKmuRl`u<cH5LoLexe;hKt)^mT3G53Jc)
zvExAJtDC%UWlSr)HO2SI@!a6n`K>yn2F=)3P}*-s!kv2Oj*Xr+C}Z8Yo#UQ#_-1t_
zmgZFT5BvSrd4T8+vII6@|ITjD!-${%^?Hm~!D1`r(6+^1Z2_|j=LVDsHL7>%Q>RQt
zBHZSwy}+L$?VaJWFA-vlslIA2;?@^o+?wj;Xabn)+-`8Y?eD`eli=}BG}m+kI{)$C
z8xVmNScevPAZ>97mFR;_cm)Hn9KCQ7J5U$1<TxyNkc=&ekT59fjf<;Uf=d`lwYiCF
zh(a2!N-*!^MIIWVi at C#n8s?il^a|of#&+zL$ubymv{O}#L^JYYQwbNM%n5UmM{96X
zT9|UA()ted(GvMsieOB{G4qs6TkvCLv&@k at 2uBu*t$3@*OhQ-e!Z}H!m5y2V#hSY?
znWHv}ODav3xrIMjLQTxadzeqgJ5i}#(n<DuYGWi`rkZB+>RY%Z4WzA3G%Za}Q^K>G
z at lZvpBiczG(ddoQScnbG#(CVpk5WrI$QmglPRo7!BDtmUQ))KmlKCc%{Rn%ct+Z7x
z<zlv6XoaD?wiu<1|1nNUnq*3)9Mq+D8-EYe(1e&<T*KDLAj5V1&bxs}(uO{apquMA
ztY+35cDrZqa)x8E8mDlYJgzeDKjN{pCa$Y at RK6K*wwRlNS_wmE48#cbfSK$Sf8eSf
z!sqzAJW)02dD1#;&$b_!Wz20PdXjs8dJpEki at 8cWQ9+#NEbEJ#v*;}SWROgd#j-*w
z<dR%c4i&DZsk_>zkL$0kj<#(Qc&A2a#<(5~M-Eru9cFtO=eq at maa2MiQeruy^Bn(^
z>Z+27jq0Sjs^{s&)>Hcf|26;j{wJmgPF7hj=3xf5F$+IPBXVdZ6XkXJmdux^Pjp>f
zPkVF+{fZu<GxdDET>nLXX-&7vtjl(9JKHXEX8Wi3Pn$IJK64>(kXK8 at ARe7qKjT?V
zlgKZRn2tGk7e!dadRd0`DC4{j;3&@F3jW3wfP|BCE~Ed3RX0x-5he1G9F)UyRIbZU
z)lkieDAiH*P)RC9O;GcQ<?56=uWsw6`Zb-e=Mro6ZhgsuWm(2<N2J=t_GZU%XOuJ5
zIi|)JPwzcz{Vem at RX_ZV{lE6F at E`QwGQ-R)@{d3)d-xm_l4S{Nu$0)wO5BYj_yQLK
zTpx-On-w1_9#%sPSFMNilHNqR3?zmU!({}KEn_5y$d|eDo)pOYvQRz at U=`<9DqCeY
z at u}=3&PkPgCwJwcVi7CNYK~AXRh;U=nI@@Ts=pdUOi)vaJT+a-<O*$8AFDm;yl$W)
zbga(S({zd6t`F(6`k$7vVyrl;n>EauU=>&=t<%;;>xms^d+i*1t$oPR#1Zcp>X_(Q
z<=El4?Re^RI0rb#IOjOeI!%oTs at 0!4?_GHQ7w0%BuiFi+H&qp%i%^|s7s^m(%%O(p
z$$F9g${sHdv|BDqk<QhV%toD}9_y(xOdXKsI?PVc<FNon%G7oBNZqnRWQe*WQPxuV
zR87 at M$`R1jGggRIVBZGR1th4qrBWT%1-ig|h6H=9RM~6QX}GOxssXC_R2Qn19Q38i
zRmI4#;>5jUbY$Q5HX7UL*jC53opfy5?%1|%+qP|Y%#NLkb at My_GtPPMecwCo$NQzm
zs<~Iy#Cq1=t47Ud&P$3hlkL`ZJEonjWiN~BSxqYkCC?@PL;tEg%d9v)RoI7$Gh!3v
zO|u2KCu8ipLt)YhzII}Cq_qNeX+4$9%D+l3MTtNZ&TU!Cf at 4)jl=0Le5M_{-W!u*r
z!=J>;;k67}O-%-u at 5jf-+<R`cYINlmx)tMC7NNhYinjUhu4`4T-wJf5xHj^Po_*FJ
z3YQ#6Z`Rr*jdwwt26b0<y_ys%8Ahj)>z6*9&q{@YWkj-;3N$;$=yE>_;w|OqaHq>+
z%fCj;UM(C6dePZ)tE5CUmeqcIr)VhscxX+-j8x#!j5dkUdBg%>VCc7hSZVy#J5YJd
zvcu|S?1<livaT~6TbDJ-89}c6D8GmdH+IuT+a^E0@|uBEFIV11HzhVpo5WvE<-MhJ
zoR%VWxP(XtQHq*34a5qE#<Xtv<!hFaeG(?btpwj#SnXzcq41LRaZ;-&vn4lda;6Xz
zwEwd{`@M7H?U%7m-tR{S*eT8+27>AIe8!6c_UGR|x$e at -$>!JBr4zCdGe)5m0|Jd}
zL6S(0Q^wTSK1p0Qmb2O{jnW#O5*M7#5{9u?^seU_bHz at jF?jnM_sKL@#edSiOIH?X
ziitJdupqjIvc9P-l1J;oxv*OPA#C&M#yDFk*P$shg)bd!X+jxt<E7HD)iX|+jQ|vt
zjHnWLHn<bNwWDhAvC9{~FN_|~z_hjdo~BF8-hLgYKR24~`|=j&bmDXjkF<5;w_b}h
zjOq}PK$y<yrd^CXzg>Y}0Q|a1^;h%p at MnN+?abvGHYhY~Yw1l)<>J|C(pzb2(UT4(
zu`$qa0`KxPS*+&o+Iign?w|bx7H;o?{tLr;7ME08PqB9HIiILK-B(J|wPxfE3SsJ&
zm>CpmHZt-|ddfPBNx;MFO)mne9ft;W;6(b8<<D at ndA64KM+aX?qbaWdf5cdH75^M7
zlb30*w2`^eXerio(>T}aF?#L`@9wBy5-WIC&!!;qbJ%0KPs{;tZ>_b{6(iu*Ad^3r
z$d%S?(l;%4-M%CZ_E86}glJ at Bvt7=~FC3^98l4~65-p0@$1$j-$VLQ75UQDKz(yTs
zVO?2B3|+`V)ItR-DX4{t%EkgU45=wVV%z8byEqr0dA<sA?(y_g=F`!1rh6ksdfUvb
zHB<Yf9lmXhi6!VeJN_tk36vP>I3=48I+3;Itr2}a2|jZ&-k-VI<6Y*pQY|A9^#t{6
zb^^v9*j9<>sBLKjMUs;(5U((>gP<#+%9ytlT1H}h+PlpAG&m6+u$1lA=i!nDUq$g5
z6A`-C>fBY`Mvh8>^PK5{tQOh0<EK29nkg}r1Nc~xaR?>8%>+3^a9I{VzciRr6Dp4l
zu|J2=)zh=vVqK0%9>R-Se>l=_WO~e5Jtww8KiPTR-Aas4Bn_bhw#o4wQ;JaGJ<P0A
zQZr3VvIws{HYvTT61`kZhEseDuyMM4kb+`!gsjy at tSXV-1^jAV<$cps{TVwmjo7YB
zReJbf)RISK<MpTW3b9(VShr%xZE_gmMk(fN!$;C{_5oko*U#@`>zYbfUj$25*4|2y
z^Glof_u>iR%GQ~h;`S{*wwkHfR4pLD?9GJ4&0_**bXKwTKwl5~OJP;gECoxuh3R?(
zO5Vh_u|e|5(nP-83pC8AIMY at Zf~iwqGd``5(6nR`{FWZ5(T_XNWdgfI(XZ9=Yf=fb
z(~4$HR+Hj)_hL6Bn>g9Zdv&U`8JZi3;|e6s3OuUg#!ENiiQ$J6K9!!ydr#Qoz^o-B
z2{^>i$FFbIN}gV(fMpJZdew4KOIXc6R+OEYo`VxtDUW~rQpb8bSyw2~6mr!uud^X^
ztovf0G^D_#HO8WHu>kDKqPaI?FFpPY3av|)ii9uAA25>Xqw!Qt9eRJ5YDrMzELv!3
zP2OYmB3 at V2O%cWhBGe`jfrwr8IfQ7s0Ba?ChP6q?pH5^tM8#p^1He6X%Mk1Sx#@zt
zl{H37Cop?xdZnf(n*OJ8*NeI(gh%|4J>br{P{>~_I&fYv%0P5}1nS^Jeq?=-0?bDl
zeeCY=kY~DQ_P)WYXUAiet at FzIj3XhB$jKHsRDKR5_kZkKxY8#Wa$t1IJ(-Sj8fzNx
z?@K1!ZR$28w&qs-ebL68uE_|@f5suY6RmJg at O`(BHhZpGfsbnKixtK6g}@H3h0l{F
z)Qh<FB7|hqLnE?c9Wi3e`A)JKc4I;E-@<F at f5(0P1MLm$*6&nrhfo%KY&fm>kg%_W
zu$y^?@?cr54D^8sos~Izkrn=7miq}`aG^(T{YCmm?Y7<SNx;}3noDbY`Ef}DG2*^S
zkk@)^=#M at 6ub{mi5heScSpT>c$;8dX>fV7-(O1a|h-+YSshbQ)i&Brsfw|;PUGZ&a
z#q2a_(PkGluR!w7007ubq?;17SFF<&5k`rDZe-JS5!Jd1^$^F at 4blfE9>oxZ>kgP^
zY at 6Ow+ynGVnVEhz@Gjg1h5i?H4De3p0^4R_`)Zyi at SiZ;bTAn|pV%pbKXts1?paTD
z*Zy5hkiav%`YC}+9~^E={@+K@@Y_BxeT2TZ9)x!|H<ag}v;7?hjJ`1MZsATLPKoz{
zPQpk0calf6I|pJzAx={@=>%bB7VN)(ly}9)XV4}X)K*}3NZzKJ`>dR79cDPtUJbdg
zlX1M{X3F6#PtYChGy=1<u$q#ba?7z(%qY<Vl?OSkM%VKfLZMbkR)d7`eB1a;qWvm#
zl4k1<JYCCBBUyN51W!^<uIEwLWi<11L_b~i-_cHRhmPZ_`f=8uPUH<Cp`Qp<c7L}2
z-We-+!@43e;a$NIp^a?52ZR&}8&<Ftop{8$$X+AUui1~Jv*1kRRU1u=Eq%1!eSz;6
zYzxmCzO#FeH8c@<z?+dh?IdIQ?c~Qj0dEPUmujzFpDMm?O^!!)wS)822H(E1$~ZL%
zYUV{Jx?lu(ajw)XbeQ8`D8DOuit5OTYx4rYU7()Ax`#wP()-T?Z6%Hse$Q-WN+)o=
zco0mm#vT09P$D{iYN!!fAuyH=sWQk^4D$r-oo(Qc^U56MddZlXWG`3m&W_L3aL<U(
zz1KgUo|%N>3bCkYJ>+nK$-LdPdVat2woZH?-QhfW&3aj5vGI+19cDZSeL=`A{asq)
zpDuv(np?V!+%?!{ca`p0jj#%<8rt#atdG-oe;wRok&8&GYTH>JexYhfOZ5bx7?bFe
z6S3gUA|b7Gtr7QD{u_;V^Q!Qr!S^$m{EYqY2AlNjq{|qqda!FPnD;xuiVj_Dj*=dc
zqCzUIcnnLU-2EKKL#&$<#v=Jc+=G@&u2&%O8N=|h;}U~4a$|T$9&xvShQ6>PZw}}L
z)8kGt5&sLFIaq9`<F-kU=c>*GuoU3jEq0yZIE}~ZSI at zl1@@@mx~-UAzvh+W#3ER7
z=@D4*^y*DF;ekIp1Idr_ZS7I3j+F7N>14LX>dqV<7)C&A8N?gpU)^Zsb7+P7ZBw1p
z9dvg<kw=VaSu_B1B$(;iHD5frK##3}ALLBDkHK-#>b^lu+Hx!Y!zc6NxbT5mlc<+M
z{kVXtMloY%4(<d+xx6RXB}ZI$Yxvn_GGPa at x3Ip8{cwKi3EGzeN`t=Ff2&h at oOOh6
z%xCZuSD;5HZ?uh~BbG3vunhto{Pw5RLqE?A2tW(#`L~p+u at V{Kb|G82RWahQg at blh
zOUE<!FYnwOh2GdVZaLs)ypK0pj{_dS&2ZRqEmg at U%t3h^0Z7a4h8^l(%l4&m-Tp3(
zIh*gIF;xy=9wTypv?07Rk1BifT+Rr45NmGOLBN})^W?u-^tJC{9Yc6$j>~xzvyIzH
z=ge#xdMO+MJ?>;CnE`<1{tvJ12)oX=XBzKmK%#e7tZx at YEzKo^_#$QMSO*-K4c8{^
zqavccdRJ__UP1MQ!g-QoT)~9Ou09NZiI}9Pzv+^C^BpmRPGw0h$OdB#5HCD#t2-Bv
z7tlrDx|x7{+l`Vx(GTKWK_YIj3rL^S6Q+L8E%_YiEwgOw{@y at cP|8;O5G at iH$JtBe
zzz at r&mldiI4|rZMdz(U#rytb6qzQ9DI%##E_Od-gOL)g}AqCq7n2q6Vf(VYH5MgU{
zu4cb#AMk&)?b!4!E`)wV#spy=^KXF*R+DUdSWh>W9TiXyidPS+{BaK9S4@)G7J*~1
za>Hjj-Rx20^@Cs+hv2O7z<8iDUzeB*oDJ|1=vvpYPK8n1jF9W2uI}3&=v<6l66gi0
zW8I<dc5{*xrXjW$oiWZ5Zrl<5t`4|cP1CGkFPQNq$UdnDW88|`!89b(zUH9A2gcJf
zKJKzg=xqD()s{|5rcR0g5m8pqw2)8=Ijx~v)z%h^z<nAy)Lj_!)>z at xO&VDLZ`?!(
zWwfR=^}1hmq at o3QiD`d-=1&TbM;UQnHX)hex?~{->_3Mdr1A9$qVBuSY{L at u6_q~_
zxE{ZGA3t%#dS103zawy`+-Y5pde9f{AdX-t(1Ws$nb9W_-%#5x?RTDUY|>w8-P0(Y
zf7JYZOz4e at Xn&I3d}F(*=Bb$eqS)PVhjfE=yZ7C~AXBgOgN)-mQ*4mY3fpvo?{{%I
z(Gh}J>`!#~xjTt-A^yTnX$J)J%LlZjaQ8#snl;c>pJ0S at ppRk+?(jP30&;F7`&D@>
zU#suFoGs)h(%tpWciW8${%7JkTs~vdKr_Ep|6JhWGNa~u?-TC+-k=`h<rTsS;Z=V-
zQ1rfdG(;arBp-^`=j<_Yd`H9&<rjsg*x2uOjU>jmpsr!JHw&@DPg|T-Py9c$T*E`_
zvLKz_*TZgk&SIPhj6OKTLE4+-50i*vf3#P at zch{!TsO3}@{+kXti=r5IzU8hY8=+K
zfRCjsJ#_^jKlPiev@<%|6%)jx`azDdxZ at bw9@IEtnI+<Qp2_m;PyxHQgge3axz$R1
z*@e=FW8QeqHTJPrGf%H;5&SV4<yhpi@$ND^q~K5rBsVO)q3jG6C7%Ej%N;%#RyTX1
z;F~0H5R2t0{nFavI;M+CPUVY(jLMH)-gbMKcOPwgP;d_~jvWF0oVS{tFk_M!(TRG!
z8i93a{pES}_j3hP%y-nam;F2EI*8c?tPb&TZ)yTk&ajsfqydQj2F0451443cUNm6N
z)334a1FuW+xvv^P$kwVgC_LATuvOSYVYHh5hh at bBzuQ*S=jXlfRQe{Q*3h#gQ61V1
zNU1;GO6Lz(dBBI-Ut*&DoXQor9c6mZLdQNvccL|DXF*qC*IbIqP|vl8p$3zF2^8&{
zHe(Wcem6Oes3@%d+{SY$igaNPxYelg^aZD7N-9R!T%9Cp(xVwz-AFlowQ+u+U>%cH
zhSLUB;_KU80p(Et28=o-r2$EtH<EBrnD9D&Qb#jLE&6)bJ>Sr7S+;RYJDk at dLTs<d
zZo#gg#>T2q0DyFX99+^FBL+>%gXqoAM<3{yB;Fge1xSX!tpJ&=1Ogg}%D at 1ZI^@V&
z%&YB~P#%IggmOd12il{JP{Zn)Dif at Wo^j|n+KuZP(RgVe)^1|mELbmuj(uf00pxd%
z_~IuFpnSKGoWP$K^_|JNpP%93xUNdHdyBlaUS~w+D*U^WF%BgNrc|f`S5!GST(p4V
zBYca_qcb)x*tG;>N#*?5?YQewnwzyp9lX+dSh?NM6szG8b~ub$Ao^llMEWQ;(xP7)
z#1M<VYQ&$PfL3Wz*f at Mb9R0K>oita2Sm8$y?}bm<u^)M|<`?c$Mtou}em1Ok96#1l
zhV~^Gy!?41%VX-yP!}5mrk_}j!RnFvEyz1XFHBFjvh3y1R;I(Fs?bO*wOFEUNcBL`
ztfO%xf8Jo_q5WDDBWaDxHIq-oLqL%{kd;EUQp~irRG at m$H562gmdQY+&lDGe8au8>
zqN{OP;eO&sA5Ficbrj25meazsGMtWbP#qhniWp9#<J`3RlS&IDs%kF%qp59O+d-|i
za at Hi$s#`O6r54`2#kyJ|(tKI7TDA6aUbBg9daa=OPqL<3w^eMUyY^ZQvD%QzWrG8^
zP2`mk&i9>e0dxtJ&M$&9raxyo2iVXJhf!vjxeiqVWEvEZzlqo)=tMFT&B0z}tG-o-
zBC%HvVd?L&Sh at 9}?jrK;cLUV+qmD&=k)ib?4zvI)Nq8~;bk14ifhrI)ACd{D3?i-R
z0aTqeE~R!1unLj^KpexI#6WgQ?jK7%0vs*6@!3q4(!H>tz=#LNYar>?vL8jh7`fN~
zZk|y)uAQv3Qmgb*`K;)w_|19&`!?vl_q%yc?Sy`c##*gC_RSsNPA!wBlZIYJw_MpM
z*(F&vxeBxPrvVxoIN9tS>=k2)8Cc}je6bWeJ_W=Yj5a9dUR<yMW*Mk*F-`)FPTlYR
zb<qkxOnu?#pY`1Wj*Ao*)e96-1GSsSW^OlfM&kh$=A12?m~$`;O<T~urBQOp9mTu|
zYxI{Yre2v%P7;*}gAi&Yt?k%eKCGm0Lw+88Vl{QmhuD58M4Z16ok6K9`+e!ODxLRs
z%AFeoL~{9q6U&vLiMAyX<d+I%hOp-x+F;z3CqNZLil?HBlFwTw9`usVcc at p7^YRYk
zDRD!Kr^4F`Uen8T(U<QFximea4v}=yiHpfeKQfc#rLn?_j!#;h0EkY2CntcK6Cj)O
z_1ICQ`};`aLZ%~?8V4|;nk>%3b8z^Ot*QO%!MIw;#Va_^O%?B0l9VpAfH>18y*1?S
z?;{{JkHRYS!c&eU>HG&uRM0hQ4rVS6nG5(e6`5;@eqloy-vW>l?-?jwIu~o6P7Oem
z^~p_%N4NoUgMA()75Ugz5;Lz2`$9e=2=qyqatwQ3m1wS7m6|O2P-)yojP8Q~cx*y>
zp?Bkx0I!`Rlh}i<2#f6kosf~#eYe?o9tLW~&Tr at 83b!R{j|kh6c#pu8EM7ZMGI!^8
z6Ro&oA|bR)jzCBNNDi_Su!u+95kJIRuHmtJ-4Qj0$+IyAJ|E^WhwC|FyG-_<8>bkD
z?rlV>HZgzVyyxb_?)Q(&p0UZ@@aqlTSNp$GXqr0T=;fj=n%vO%lRo7BP4&iju60aw
zj_&sam4w7i1(6JXyje^;<S<0{NO6U1x%rt3XnETmuC#@pJ{a|8eMjea4!nlfMjIsL
zz8SLG)g^EXPz&LDcJxgcz=O_j90ThadNS$3JQ9`EOgY)TcS<y*6g4kApv{fMH+wt$
z)$_|sS3}|gKojrh-Rd3a9qnE0UGDAgox{74W0Gqi at 9Kt!FP>pkU=%R8H-}px?0_Wh
z;n>EnC~$*bVudf5L0v>Wi7zSvRew&il)t+XE^mr1HC%y${iGTfu}pTm9}rRG{d|8b
z3Xbj|{(!NXT>|ht&mT_ykd#ub9Rxuy at lJQRPCTDMmV$l4n?l>HyWV|$Xd>S3j90cE
zi`mf(K2ED^Ah*3wmLXBfg_Vc(%uQ=@b3YXpsiuOx`Y1t<dYAp?)pn}jY^<n+>^SxA
z`~2eG3e{e)rC4>ra!f3-oe%rn%vHZt<0dD35x~nz+xjSLG#sw9bFNz5RE&}V1Fk>{
zhQePWB|O1~v?PZq71<<b;`=A}LjW|0`qt=OsFFJRF29<N=lD6nRuP<<z_-LR;kfJC
zedqhdbCz at UxTQChCTX32Q`MFt`0mN(ulAdOKLM4FVhl~R^-)3tp-8)Pc(!Vc8AVWb
z_Ds^MxiK|tUOZV)UUeLmxp4!!q^IVBz09<AiBX2mg39k-arRy{QVaFARhJU}>IXu8
zB|JhKCRLXcBmp7!bMQYt&Fi9v2AI^{NXGTGz{^o%0~?rsQf7}H5IXP2N<YP3br{{+
za+*X;@;IobxMOxsx>rs1Q{8Y%L1hhnHE<R_37XP8Hd~UN4>c&&SAohj_c|Douk$%2
z-OD{>*x$5t7 at e7$h)HZ%=tXj-|7K0u!|QZJbQNv8R4)-uwys|)FUp!~$Zlw4<W|zv
z(3CmmOF2KcYF~(af at +}*C>E_L-sIin+|xyAcO+JmJJgh-8`o|RS4hF3cM)RIlp{Eu
zKsOom=t5NT{`fl|N&+iCk$MpRd2;Wa$~w^8Or&6I7Zu&Y4-U23H`W(szjujNBg+u#
ztp<3ZczyfXsOF^xcC`J6l8iE=+GOSPn=J;WSq<h<i=NDeNN?jyw7UH at Y$jz>X=Acc
zUM`a!erf(frz0g=qi&}qHK^G%qlHlwnX+w}Y_RP$?6sks!-{iM;J)3Zuge0z$D#PD
zG0~yF&9MAK4)uPn0V}-`JlvNNpjl%c1om at IHr1SLp%^)l`gz^tnTa3|(hsu^k`jpP
z1LULD&()tF7~32D!_|)fh-RPwp$v4*oQ{Mk1$AGXqJms4gfI2|ow|s3D>>M#gNb`3
zc}0Q=roGE<_BEb?uM0~@?CZx3_wIKm3cnii<s!K4vz+w?Y1 at E&uYo?)?93Z=5E#_S
z%l2?E=rGV2JRsJ7KA)@bcDeyYePKd at 1XVQ|D`@xBu$|p%kyq8*W*Oe3Ys!n`iSuWf
zONAQR#F}dA+Arne2VNof==qemd_8|XqGa!sm3oaw^ayfd-+EguqxekK&lb_QJaOCn
z4c?`ljU62E(H2YR$V$6SsZ#)v!zKKbJc`BjdE=PnoM$;e>DA&R>(g6ju`qtx6Mep%
zn;meq{JZ9S3r9^JOON@}(i|t5PgG-;Z(6R=>B3HCC-3Q$OlR3;)1#^4o#~-2pWhr4
z^E||~Vj{4j!aT&XuUUr3TV-AekxFKG)&G at g^+ywP2KI_#MnQGMUuE at DJATUxChU;{
zhwVAW)9xkV*t3f`ABC at OAK}#*0R?B?rN&~{`<t5agXzq~`ExB|b_ybo(9qk%)hC at +
z;uQ^V24s()cjU$_4s3wU%+An1q#4>b<Gj|0Z*WGECKJjzT at GfCGZ=t1#2!!ek3l-?
zA^weUAYc$MC?vu at 3aksQ{}~GS{ag00!6pt`$>fO&%4N(&@V0R8aF{|XU4!0Rhm^wK
zx>~EbW3Mg0&w$#eUpnpzBJ(T#Ohq;KF2QW&gFQ6^K7FgKClub_6PTPK at E*!~Z(WuO
zyGa0bVf at u!X%Ws5KgRMc8p=V&PgU|Hm=$N00*`=a%^akRmV$nI;5=p++pC|Y at k7y(
zTt50 at S*&V)7Zbl(DsLWfFyMw-n{Levxn&mt?MX>mL7plTmeZeMT-qJiKn*(vk>&F5
ziNIyeNMw^UilZPa1<s6q=8u1fJgc~Y)=D%ru+ne-yr(#*<0>l;smiGmRUTmcfjb-P
zfhj+2p*?flBz!bk$RD)1cn2*SY?u>RR#W9Y63eE})4VIQfgajB5y^}&%YKA|FT=BC
z{*xu6Ma^pJKG?$~&dhrDlf6iX7?YmmjLyK}rQdyOgO`Vg#qTHQnE06sp8_}Ace%F#
zhwLNh(hMvdg2`)nG%KeV?xU<M^QpD_gJ7>)pUZ_lgS`a+3_aUr1+y8unY+=e-jC_b
znfi=#PTA54tNTsR2Ydh64g8({NOvD|50AKwdzGsto#R6|^FWRkBlRmr+B+X9uS0$3
z*x at Z<#+c~wL4G3k`ru)V(S0AYuilq_s}E?e>Uyp%-XB)00cue>BPT%KYrfbDuJG~)
z`n{S9i`8dTCmJGE3UWu+s&myAp}kz<^{Vj3f`jnJS%pvI0|Ae_BjNf7Jt9TD=srNL
zp~QBSn=FtdW_oUH)*qZrWTdrKsoPt>RmP;RyB`09ZeQAoQ8qyfJNS-sUlM=<d0yvA
z{~u{VO#h(;DZAU7(2LpGI*XV%897?mJKKHJg1+B=GlWc-2>-<&Qv8=dNXX7ji;k6z
zgOHAyft`?vfq{XLk%56-=U-Rl3~Ws3MdW_T$%@e^TiBR5$(gt++SwS`{!)@v{)cB|
z=0wOwujFiEqe{rZL@#V$FJWR~X6{VL#>z&o{_imZy`YnkiLEms2PY%_Klc1Hrek7c
zqnC6xu(mJ~v^BFfA^c`9{bQejjfJ&4<-c?hek&vVmo}<@T~qqzKsg(k)63a8+89{>
zOQiNc+E^GE`1t-qj$-~#6x6g>8Q8VhSeSKm=>HQDdLaWRlYeymzdNSnV(9!&0EHz*
z{+amCN57qu6j5?_`gT>)*3|Bsc_r^?Y~pBPYep$){Oyp1vpW^NqKTQsH^a)EQt+Fm
zWkN--<YI4cZDR9}zuyM_%i{m82O;Y}%cV#!qV`X~|5pcC{^P*E*<Js{>VM~U{jY2;
z<zMx-K at 4zP_vrYZ9Yjbf>_jQ&19Q46Z5zV-a}s3XGMLYA<jC5~{VneorBBvAm)l%s
zBscPR6{AoiT(WJ?$!G&%i7vlj=TwKgX*8ypfaDK-w1{W2nej71ZfjYziEVC};2zq!
zfP3S`8f>M;D%<!`7HWy!ccXp^f!n}h!yl}=V(}eD^}*gE;<oq^O6gs%>mHyK2_ at JH
znOCewT`J6-e%%MMVn5J@<825jr=}EN;>~t>EiQ&?h9?X=x-llusfW()fDtrkB0SRc
z0jVxnW&9s8&ibF={AWe~8`FP<_}`Fb{l7z+iS2)Z^#23PbV7F4#{U5{Gt0jb&B)C5
z{~M&)|5rr(m+mM04aaXdIT8K?a>f4v^)CZ66Z&5Uj{m at n>7Vc@(kt3Ie^UUz_mr%O
zv4z1uTb$ur&c?_@$j-^6Loe)TXaBzm6-}J%TpW!|oCyDg%l~eu|K3%E?X2w_mFx|S
zOuq3i?8HXM{4aI?hW58iS(%BD`QN4~vk|iVWB9j~${d7 at 9RCczXZ~`uGg2~f)}sF<
zB1W%l;^wSFFY4wjuJn(=-`^mv^vzXd|DU=4HQ~Qo`rkW(g at uis@&98_6sc{*Y>Xj$
z=hmL2(q{BY9A)ntt%Msv+UpyekotEc;x>@YCrG5rMyq~Cee5eQQ(3Y+n%^TqA-yT8
zY^ms^D%E~IN*k|yULF74s{G5u7OzorRbY=lLS955CYd(17%chYo)kXZ(D&)Ac~<r^
zn4G2O>MD#uW~!kFcKXiQ%m|gXcXN8*D<{>$7H0itM6kxEC=|)BnZcmp>?=Nv)#{DB
zEQ}T>+qwDmX9cm*5pdXzXh9)VJ8HNotJlL87{l}Im(+Xp-@<WgGw(`l+17UxMhuZ|
zt6p#m?iSoKS_bKlCvpBED at Is%Ga|X_i~JKU&^|h!+0LXP3_m9$g*eeB8oYpmsh#vi
z6*o|QZE^UB$rvjMjU1Nu7{;JBdJQs9p9GWC6&agtT~lNa+&|b+ryMUH@$BrzP_}U^
z{3+xExNo$#n8$Oju<m)yc&1>q0b_9WWT+U%sRne7`Id*Chn{p*>RDA5UFVuukAw%8
zW7rG9(GkP+{j}sd+VCZuTa|V6YnS6%LmFdWj?X)dR+A=!;|2o~mv8r3m-Xs%(9#|r
z3!RMDI&q8R$)zMtp17OaE+le3j#mUbKSM6cc3D$o6ADSqoP5-M{D|O|9{o?W2=YIH
z3SH)$DZb3+*sta<$2`ZCA%B(UC1=dg?$rZS(TjHR;B<PLt}ReB)ZABy!wg$`@SP4U
z2H`A84RVB{XMevedKyYz9``*nM>Cy^_sC57pv^P-;7^@6Yy+ILa{>CMyXURV_eYH`
z0KebUb{T6g-O!G2f3C#}L9`j9#|6dM-F!ee4^*RyUPB_sXR2lgZ2yEybPEEs<1og%
zuGYrNdG$L`H6zSgd}$I9xbY1+vWPjVf+W3&t_61aA)i9<mv9BvBcH_?1Plw+ZXsyZ
zw-VLjX&vg(d0zt3dhu^B&zuA#nYyv;VO2UPnJ9Ihycn)B*GiJrt~qv3Be9^k+y<mh
zhA8Wqu#oKPj;2`YDWG(-+^bYO?B at bkAQses!GDBTST2x|cpEoo4`e)Ly&4v#7RpFh
zJ{{If%|iz!#A%FI7o_I+{I&_<QQ6_?vkURdF7q9#vbiC9Q!BY*T)RdVO>=optA{tm
zO834tMO3dSgQ`lh%=2Ey3jN)!8b78SxJUv=r4oPb>w0{iRmiEc=>Cz6<@CEw`JK!-
z)pE4ux=tuQsmt2`JOX1>)FIipAi!DO7Pm^Gnf at 2WAs2<!2aFzq$v6Q%xJAY9{ZpB0
zQLC+dj~a$*8oJERbHfncYJVDQyyB6S3)!h&_lj`(&fgW`ZG6O8Ll#ogic=z at v+g2u
znnJP%$*vNWh-fOoItif0Ka8S#cDl<sofOH-$VOVkq&TASMdkR}uSH`&H9+*+bz&XJ
zq7YZh4`{odj@%cB=7qS*PBIaA$ml0@=Q<z6y6A%GOH;IKJ|MoNIHwa)Z5i^FM$Ui_
zvYE4M8u~F!&>n|+gkKS~{vHiWcKEn{V1r6=SP$P;9k&RI%ywnkHX3RqEs86P(z3N?
z at kG%Ft9&^6QgJ0{m-%_H&%{9TfAL$n<%3hpmms-KGvYcOCarW8``!`2OoS!Q&YkQ!
zYwX#ZNU%@duHOa#ytd9;%%#8)lu06E$a5q`BA4Y#rHW{Mq0mfc1KOqzN(p0_9Sp=^
zm_;y3>33>Jlvvv|VwVwevw^~xMH$r$7ep-4{Smp at uf-ZG&*-4a!LpN<ow<HdWE8dG
zuu|jz$rkKpC_-##Pz(K}60U=Lq4ek9wm95rYS^jQOYmo3_5;Megp<RT0|%jSnoDut
zqi~M~)*bXhKIEA}XG<|u=Xm|$?Sv|gLX*e|V;oU=jp at 3AS4ok<fLPw+gR=9Jdb9vP
zFu=ErNf?!6dBWvg#*oJft)!;k&p$~DI)|Z9?r<GqhS5rIxL-VntNBrZ59Jz1x}*={
ze-yFtW=R*OfiQnhlf4DvFpm}!{6mUsu{jn2!${nzjHl$1vX|q5S&%Z2<cpI#UM55~
zk+R^(I>Ad)KiC7Dh)rscw$SO&YA|KFy4AWMKfzMYbNyzD+<hlh1Xp%9Jy2L+3qoPI
zoC39u4ZZ|#R2-MhY{zkZT at tILNsJSJycTjz>V7j=`Y#7S3I#vRp=85wz$HDvrdnLi
z)&Ji7CtRCccHB>DD3V3*mei&x8YlGrxF<wSDypCiIImT`T`jmx7^rlb7CmWLc9@(s
z{S7R_57+CdL6^~CI}+aHI^|t<Ur|Vb*}J8ogs5_Q!U at Fv5IcXkFA}6_uLxiCyIFs)
zBiv}{F<<1^9IjRbx`~hEqT;r at C9n@nyIdr>tm`1-;LfbMh20D}0elRXQ{3~*EWF*V
zrFRxRW4{zBEn=V>8k*baCd3MnO-&qyIXs-wI>UWwa4dq&IS at WJ!q5(OqTG}+j#>2T
zR!vpQny}(s9NMU|R;)8Rjdn#DYz1&uy?WO!4h;?iwS8;xiLb&2M14rxF(f*sKUVpJ
z^{5Z-w%d;sPhsVY#-6^YElKNWDGr}WFw^CChCfpj7wFnEqAGvmI>0l{m4mxcX)xlc
zoM>UsqyRD|bOu*jV0xsv_i_}u5^-0f4sAZZB8q93)iVafa`bpZ at ila78E1b_H~I~v
zU?flFbNQL1WflXv=@q~)YPVU``ng3 at I+SWDRJb`UUAx_0w^gi=;&acZ$*&-v0`I#4
zss_5`N>{bm?$CpBagvToc}gIY#=qsM0I(tNK7sCik60bex_TxQUCV!{-(ES at Xb_kE
zPtR;#hFi~|v at uV_(vUqclPrB{vi7A}rI+3grwqBAsNsz3aZQp-Sy66Oxde1iuwZq`
zo~TL-;UqxG(=$k at dTq9ig+whL!L}8ttr-If9<aT at nzT#xXJqqYlJuzHaH5o^O6+9@
z;vzhlleZhje5<+?vS_};b4vc#%K%ZFZP-99dWrEQLp=MB@`2KWN&Jp@^nO+ut#YC4
zgPUYBv at rPw^bv~ra2+GKVY8#xKqw^D$x4uI7hyGi2(KJ#V!Y}l6fhmT%xSSvqEgvC
z6f!l{=*iHce((ecDDNHTtJVV&#pr9MowE67v>|J9l7)wR5n6!PXIMX|;PcIgmbGso
zYPI{vUSaA&gR&tId{n5Pp=b4hB|Y!eHB0d%62TA at 7ufipt93hcCXWCS4Z=GZ;Ai%`
zKSI~J=ozE<n^y^{9BLxI-~Em9nbgQ<!GX}U8`eU5uz-i_r!lmg^nv6Mg;tJBscu;6
zhwr*Y0`sSq`6VziPe(||qun_gGk at BKits!z?=4Y9onW?;#mSSQKxPwxKYwy8&EVFv
zX;h3hWm1~0uMIuE$Z?-#-5l3!8D2D*-kcopZ-2ZkMAFSg4v%L|Wf7Lm$&#n8Br=%I
zj^g!L?H0HzDBc98ilOtK(Uw at prwk*WQg?OfmT$X?IGCb~S9JMqJFxvt_G}3<juunP
zQeHwx%o&KL6()L65p7atqPaK4K%;~T2PiVj5ho<L_o$Ng7bF*<dwet4jtk}1Z+nx}
zCT-8hkUx at j75)Aq?-)10Tpfadas);ilV at _kW>}6lnJcEsuCLfl9R at 0?lxCFB!X{di
zK6ZBEA7^zOsl>7?oEYr!J-=SAzAZ<eLJI4F=qa}}Uo^|*-07cN-kqon4KFP8kmrAN
z%{7O_Q0%o%1c|O*m at K+pj$dT318m8jUQ4v})2zLagYbvhB*QN&1s8cyZ<T=b+L^SS
zg4ZN~m3K0FuYSvJ3B<)WaHmW0w>}r%By^m#W6`WAn&c^DfOE}9t(SOCF0ofytseHr
zUB#*v-iwpCdbR+Cgtb$@Y0JZ$2Y(7Gm$G_p73FKG-G>+#uj@^)dUW7X-)Is)K7cJv
zt*YKb^}Vn%Bn%2aerD$@D|Zf~n7FPC$YerpEw1f}LIz0=&gvU6Q{Xv<C(sEu=<sYO
z`et~_J{?qxguH|%v5^M-eR3IA!AK7ihz!g<TKvK|z5E-3hYr3cwi^vp9<PG;gZrN7
zc-F2n31HEa_ffW+fZ8N~R*j}gBE0MjUES|jf{YnwRCm+CkX%rRhBYQ6efU~WFc%rF
z6{s3J&z-d(yWrJHHdl&41_VG;k%#6VUnP019*Amlj;!W`Z*E%JbZCpQH7_=%hOPm4
zS!*2}EvkAx5i4Vq;;U(9+)R4HJ+f{GG>gfXN&HpadK`o>1SuS?Ln_%tG3pun at ewWP
zbcWlgb7xV;2yhFaj?h*Lx0;6Ja^VLkQ4k7quvBf;S75oFn2zSJ%0tfYmmxQ}*}bWm
z4V at bKl9@d8)k(0r`kKKH0!#VDB{q(O>X7g at 4?{hDh>O8Pa4C=+ at VG6#pdSV9p at ui)
z4YN$CH})UsYvZ0E#6@)ZEoX>C<2SNfo2QTsy_}Fp%C+a;+k|Fwv`p@*qJ0ub`FBBK
z1n=u_grw7%@OxOgMx(qT<5jcfjJyD&ab(+!lT;8&P{T>R=rUCa_20hhpg#*sfT6Z>
zFdG8Wt-DNlINUXE+piS2Fhh!eU|X_;+{9ET0Wl8reMo-7X`<AT?oP+Z$s^rr_<`?G
z=&0w4<fltzXwkYSJfLDDbQ%nRzG|K}91e>p`fGX9F(Y&&A4a30-17of)Q_~ANAYS7
zA={ixE#ifc-c`Z)O)S9kX9v_zvRM>Tv?X%WgBpw6Tzi>7F^8E`@O~dEQn;Lg<KgjO
zFxnz^47J=x31XS9zcuSR%<!lhRP(>roRWL>RNt+koDXx)e5Y*C%<w$<orpzBsa4Q~
zsZR{AAWzqqk at JONc757fZT$Km{Q*ao!I>6q6mwh^C4xxb%7ucB+=|$ea%i}wHn&{e
z)G}4zti2eYiiJclZ!kUk15bHVgcdS%Fu5%!7j=X&=U%B40m=WP7$pm*<%sY3rIh}O
zrV$T&or@$-=U(T+zA#x6czH0J6tsIuI)O=Bs{2pwF*<{|ZGXIUhTRZGFR^Lq<lvgI
zb9m5>q#91ifzZwPqZy<0I at fKpWvk7l0F*4ktbP_)6nmC?!0QmWOy`-OHtz29tWcw)
zVi^Ze9C}cwKs0A1mQ+7-uDWIpe&sWwQZh7d1MbsD&{ubhsEMhQ%7bnpQlqG}QOG1r
za1e#))}L+2r%J>GGJ}?JKIBaU?21)`A`~&h?}SN-xWQ<{4AQxr!dqe1^bUu0A&xRz
zO;m5|GO+HF at j`|Lmb-;U+tNmB(UMt-J at 7Lr;v3%VZh*~3gpdmt>fYS*$6CwWbLYsU
zLxeR%0Q=VGUpUiE+GP0r5+Cm>@Ds6kwN~2j1}pzMDptq at k!s&M8S|h#U*t0*@WrNO
zfr1cVT;sF|$T-!YF3B?Vq>HpyJQBS<zoj9v;wNSIBPtZ8!{Qo(@v?-#s#VGw)>c3i
z>?m0dR3q~!nPnrGs2RR_Eyv-^Y<gHKmRbF-pD&wZmAYK at O1?gT<}g-WhL(puo_TvU
ztlU|PDGkCZglAhoyiN}J!Mus9pdHcdO^3vnph~m`p|VA*WLjOhE#g8%gd>u9FBcsX
z9JH3FkC~vkP|w24F|tfcgfDUVo*Geo1ibn%-rlPB?_ciEa+>Yn-q)CB3P#l<_U4cW
z%<hy>NYChbZ$NVSei0=IZ}6w<b7JBNL3Iza`5mt`)QmbfMN$|6Q}T}8S>4d7Vm(Sb
za-#<SuhUb)Uxqv&Fyioq*c0-X&IW-mc(7arEqE~6x8mg3EH6{BV_nAI)XsdtbE#il
z%pdaz%jU8wtB)M2h?nCG`^mu4$N?6Te0NGY+4-ka`Nbte<_P-ca#lS%p2UHV!TY><
zOlzeB5A1v|fT+mB`wI=R3L!EdBV$S0hSaK+sG~3h*mlmi6YmfNXIe?G-C0zz?|((?
zs2*B)v1?gG<lXjFu~?Xz*DsyXm?GE~e0y)hYZ9y?MichKOK6%kVK#0$Qcc6rJ;GgV
zdy4mp{CGf^s<_uXi1u8Vl-tW8-FD|y7u@{$xYFr&e2Sk`q|t`~IZE$UgNOokQ+TtP
z3MGbV`y?_02`iCV=zIK}69$w1c#DrHt3h3WLm{L9?oP>)o_tcGXFW2cKBnem&R)q}
zqg|(NnH_`CRjJ1UxLQWkLRO6~{lC2z7l*E~(O4md3Y=|eU_-3*lqcQN=qJ~R2|-cG
zXs5yCM1Ed|m_Deicaw`kQFDQjhV6t|=R&MhW5j at 9Kfy9&_(ji$#vh`t0)fPZE3?gn
z;EryQHKovBwq7kh2k7T$)oSYbqZ+UC%h-VqnkUVe8|?)dsunkonP8E^%gK3X6Q_Js
zt4#XXjBaEf7i#>3yJ=wJv`w>$j_QI^C2}e8&m+zQI>4NqvHXl<g5YFtZUw>w5Wu2I
zF}sp96wIIchZ&hFoQL6%B4v79d46GGSWN2RYplZJxSJ0=szw)mJEYiGeh4gR;7mS;
zxdgv_yzuH4e2(R)JxnZG{~Q6nu4Gkaz5Q5sRAnGtxz0mt-Tc at dVgu~qZ9L*v{cx9$
z9I|NYV5rgh#9?wwcPv5?7-nw2BqP|^USgMFJFtmN_^<7X{IZ4^*dc|2H!(<pRV_Df
zVbBVsWLG~x)>2<+((D4S{K41D7%Qq(Lq3tzkJS_vMmu`-TkVGA3b<l~zl_i4-)TPC
zEuzHNVg{(BX3T5TOss>ps`9WVSjM&2kBip|Huk{owOuHfb7GjiSKFNR2)3mm_)bY4
zEsGRuW{5As{i=-bj8u-rEaI1m`?VgWL-`6q#rU{n&^KvC3!y)qa&!B1JeA_}ir^wZ
zrZ%fbha;{U(RZ#+uq^B$5jnWK#st31(#gu#rDti_e2C`ER(dsTmJE=2dBPPF(OXGt
z?qBve at pDWhUw>+vSMtPxH2rED2V%?@5IO05Ra02ao=<nI<~b3S2_8UM;xg>4Nc7$E
zs!I#hS<7>d>yMZ at M&+y-Y(fpS@=<8gCEqBp{@8Idv<T)v<bAk;;5mH@`l{hOWiDzT
zM$bKT{C*;~AR|4>pUqMD&rD_(zntkF^XUhQX{cZ?x78sMJ*-I$G3nms=iInsdW5cT
z#Vl028;lFp-|36SE4Fb;yD0$C6ZgY1aXcVciK7nej%h$>VDEfCJ?Zb6v*puG(C8v4
z!8~f-)fq0o4}3^(X;NZbOi*M&24IU(#i{n;WgW_h?KfpYf^Cw68uj at gE^+wq-3WN^
z1#r*9vPL`BynCM3O^HQ(3T;=vq%|Bm@=rF;GGd8?C>iPLMaE1+!t3)#Unv)xBN-z3
zknf2&r_PZ_!TrsL!;6Ex%0-FySE7jTgm~SHd%~6Zm8pGNlhm&Mcp?}#pX%e#Cr+0Y
zUJx%c$yeNLQ7&i{N2$GEJ!03p&mwt^Tt~1*V-bJ7=&e^8x5sb7Y(Jp86yeHt)Pe3L
zR-21YxmkEFF=9+YW)x7$HHyMZ%EtN(>Rouj!sPvUJB%Ef5HfJ5*XtQlB#A<3CN;zU
zdn7uyNXB`o$GUwdr3B4q-jSCO`rs%&;}zYRc!a^d&1W5QaF3jyac at fxdwXK~ICw0-
z%AVTmS;(KA?50Xj{MUtkxP`CknuCW}0FvnVbuj(J;c1;G90>O?cjXBi{#dXF at 008+
zSNTdeVqGIXm+OHW*9}sh=e6E<HlP<>ynDai1qHh!-eiZFpq6s<LfnA3_B%=B>P2~R
z%b`fuRoiw2>eI5 at n@93P7{AL^mO-3(y5jOh0$l_jJ3B==m<x0H?F at E%m#yFX?FPW1
z(kb_X-x`gTsj=Tlm>xIwIXXpMoLn~e3T{ulAQpF12X63)n7GQK46^a6 at j;}uxFd_7
zg-J*o0jTK{Q=VLtP3~bo at U8bLF%KTvfBi1;Ib>hSZ?04aGI?y^O-h%aNufG`E+6_+
z9+ch0M?X3xSKP6J#kRIq_3cA2beso~%b(UkbCp}pU~AHGbUysY;FA|6U%dCuk;>le
z@)56)<4VPiQxEXMN_)CBhw12IU5DP)@AFXEa|&yrk<`!0A`~lkuKK^mA-fMNG!7!0
zO}M#8vXfcdOh-)O2CyoA-kK}*JZpoYljW`}bX}Q@$J({kCaS1)yz%C(JU+{D`)T`!
zoS!G&4}++|hQ)>WF&i1rgCf(!)Es10nc0_ at oGLL)zY9^>bo;J<6ZB98?pOYGEIBsn
zwOk_>Hv1#`DO6wlhP3txzTB4y!pv658rKWrAZF=$K-io0AWUh1oR6$WHrw;NM#1yN
zmH+3^AH9#4Mf8LeQ{RF@?Sn9j$J>O4uff<{<J;L at _hwQLn~Un*^rW(8y5*%0A4ad&
z;3DS_8 at KuLQ8o5}btBmp9lOTEtWOEAfSUwm;k1=Bp*RwDHs_y5dKq-=p=79Nd%}*t
zhBwb`UpjpWAQ5<R at 6J$~$L5d!C~a)tW5#rE0`V6X*_vQA;ZN|v7rq=sUI27zf1m6&
z)m)WL?jH5cpfV?Rw`lVj{C3?B75uymwiz^-jKxun@=Qj-a_cg)pY`nxS1n-qsUhf0
z3ENK>tA0m)SN)EUpL$moXmK%#SCPU)U6rZj5W99g<4Ozhb7qEIr&o0A=Wv+XiIo4{
zEqDlC^vEQd1>2?HO0Hr{>YjNr&df?8+_pu6e#osq5AVI-p8Dy{A4E|Ar#0X$M;o4=
z(q`>US==4osRk#Fz;%ET^X<Jx`}+rb(@058w%9 at fvT{j_6SLM9T}UiHKix7(r9vd`
zL?%|z?$O;*0#8F<YnA`2Uy9%lII(MIPQ)qr&r;YWg-$a*9(XS_bN1%8XWIy|zqKws
zuTgjiJpAD-)0_f?i}4+|m)NBSSusHX|9K7!z25-)n2+8psiEn6el7x<odEi#!DZc`
z8^RCBoQ%*@Fzv0Ss}l<n&Gy7({w}q!o^@<B&A>&Ef_qfgkBh6TwiFB{vb6NB0<PIc
zF<2 at Jk|9E~DeNSTK>L8w(T(CB!D7rFteaT)*+<gzE4LsS=RXd=b6!3mC-Ac<(mPNO
z7Ujz4dB(Kw?WD0jdu^fe^iEGwi<7ZR2r{VHXufOQb%)qIG~~S#AG1^VdSzVM?xIZq
zdbZyw^*5ro9|<Q$J-em6ghlSE66n;<MKf<SL9SI|Gt90x*F-0YvsPzcorXJ#-pF1{
zCwy*>F at V2UkEtdQKiB!@7IbpiyLpXq_>UguK@;#_{<Hzoy(x3*f)XL>JS^*+3l*t~
z{zoH~?!UIh?0q`PK<wO4Qv?w0INO!8N5y}i at OC7e<sY!ub@>6U@@podZF;|^6ZYX<
zH}D+kfcy8B3RX=-gTEfPJbT3CO`KN5TG#pKc){o#5zpN*5BG8^&<m*KL3cbQ{1gba
zShw_NJRHkQ4u9gcR9G-#b4xM6%~<na<Q}e`)_=xr)1kpDopv$9y+dhtcl8=b+T;OD
zlYie)r?#w at S6sP<{;lYcvTT?d*s@=*>49Q7?(xj4oVt6YDBimTsCcw2{4QunDnN at V
zjvT9gUvHS_tO;6*1-Y_>mKl)i#^7ZQ&x|wN1E15|89RWrd%C?JwyTYCXzMVQ=R{al
z^BsP>zCAAmw&8By!^t|jN!=s(!VTSkZL8ZGa3Aw#3Y at fMJYw<czTu?LLPTxIM6$aF
zxw3V2 at V>nVf86Vq>_T#>iTkbsDo=A))36>a at 30q$b+oOYjmh9!=N2iHO_*_geTjNJ
zIY7am7lM)Vn0QCLB96Tw_5+IUXN1ckfagebqePZbT<s~nVNup7ldT^+59kPZ4G>&n
zKWD)Y+`tMt7=gOJKW(qgE5TzP%69WPKwR7>-}!h*RN#g{(j$VV$2)mqTe3C0^<{Hp
z<vug!<j>Q8X7s5319+>MxDz^mNJMM^>Zj%t#De#Op(z*SB1zKxOE>{Ow`A=L^8AWl
zAlwZi$^C3+Fen|l`KlmCB^63^6zAl|ueY1O0J{7PsRAiUPz4H81Xv<0e_ at Vki6|pd
zW3hmAq$W_Ih{*^{X{gPh+OZQ{5-KQ=a3&V!3t^}TzwD?WeYEfuCPlB03GN~n5x6Xs
zA;k>8qIzOd3m*Wi@(<v)!@~g}^m4-f at wh`8LsUBSA4Unq_KhM)C%u!Z at o6X|3Qd07
zr)p##qGIw;M~%VAZc7Q6^UQhd?mlvbxSMp&0`r&cqLfVrP4r5kf99DCT`bx-60vUi
zr~^2dQ2<b;3K4`&;DR8@;KLo1`Vzl at 4k@9W1^o=GK}b=f>fl%`fKjT6KmW!dZ&)t2
zf&6W#(F#W at 9F+kfl~vxNC;FLuB~ue8_jpWBdN?;6f|Tfl!LK$)AWL8*#A8=i;vW~U
zwkpytbOELF6Z%$WJ;P2Y>XdR1Mut&MxEP*DkRSU2Zp`%L&vC at Eh)M`bg5d!JFJvxv
z2I{_$8Z?*$wN*0`Q^tY{+PI=zO(mC*;*E|83QFN=MQU7}joMz+pM`QDlEU+(05XPD
zN!fKwA?uT4BI?7&W~kd0*Eb^Ltd#;@RPOzzAK8&e+$C2RL*P2v1Hyi*790U!`bu;o
zB0-p1C?{*OjHNsZE0KtF$zUSc$_=tmRAxqCAN1uc3rI*xCvKu)O8c-+P>eG!fFfRF
zvXozGahTNQ;YUGkTe(RfL at TTNd5(KP#atm$5drEl7ZWj{)uC|<Nyb4n9-Ic{wf1se
z4%sja`<Ze#jpZZ~QkbVhCDFflGfK)LmQ~9OR(>mf_sMICFydA~pZk4A-9X2r5~c-E
zuGI2Vnbtz6*ly)n&Y5%6coUm+y`+mqZT at 0eU&3E5Q+ZP_)Vp+v&TqzJ`>~qBdE51S
zxg5pvz@}L-^Ilo5*|#;KlD9|2<N>(au~N-^S?5DU$?uFaL#hivW?V6}lxXE&Z{*C>
z1I;d+U?Wa8^uR_WQ8o6s#%{R40AT_XCyPCX9_dt*(PS;iZN7txfQ>vOjA%lw$J}KT
z7Z`d&NQ-qQ<Sq~($d0o+foN4#b<H`D!m|S_z at N5CUqcU)u6L%xAs_Y*O{5w#s3I&t
zsv(Y~e}TS-unz*pMZG_+3`CV5Q%~ZJ{z5GfX7=chUj|kxflcL{E-XIVhPT%)fJiOW
zsv{(Y0%n%?drx7Kjb at +(Ib<191KM!X$o{p+uh;_UkdOeYUeUg<pIX1H*`xN7mef)r
z82M)*5KgXzCq95(6j{0kMIy%fz(~y8eEXT;v66JO1_$EGJAzM8_})GSx8GiMOM~MH
zQgK*t|Lt)_;0HYYdes-Hf^q%-1zkX*zer)S7KaChlv)H?4y27+H_&}Z90oq-3<*T4
zs1F2q at MyAKZZMiXQt&9K>P^+ at 1<24u0m*VU_+NDu+7jniJpEGDoe?A^0Z3lzG1w~p
zZJT*|-$+>(q-rwzl5Q=?GC=QeKf!HUdu%gAk-||O*Xq%mj$75}aL1+6j+X+G$*g<v
zj!UH#gVUkbErhQp;arF?ki at b*Nuc93rimwtb0?Kpz4s&CKq?<BhY?slM~$RuY?6Ui
zjm48A^MGU)&mkuk4_4geFOVXi9FAkZ#cggK0BO6$S^<(d=y^5qNKS&c-hd3o`_?3o
zMq1svZKTYOwcU!oRd4;%b#$np5vDVyBJq>_KFed5^nQ-kgOW6r;7lQ5qQ3>XZ!_Mh
zOlCY>y5LH+#=t=2cHJ>}Kyu$Pzy)fXdQ3v8(mX?+3I;VLk>?UfnK9c?Z|#|f5G7fs
zJ)8kTZ4120kdyr29*|<uQhMfv?RF$^X8&?Z3&}I|B~}6KrfKp*$$YzvSWFpi?iC9T
zNH00mB!IF<s9FGNKMFgOG$j^4kkv*M2q4oHLnMTNDTc|+`NWmz?&4~7PjW at O-ni;r
zhg})(om at Tdy<K5%Y+QtI{9LF{gk8#S5?t<YqP!*CTzcEM`S#9oIpN*s^2Qs~<(4<G
zOF!>(m!jSaFO9ulUaEUfz2)G2_m+%z=37?Yy-($NgTKY;L%^xuGbfx9KeL3ZfKMAP
z6EE`!=c%t5<!eUyno+)Hl&=}(YexB+QNCuB|KE)A at 3;KMfB$~}=Uc at k3RI=Snehg1
zOD=CnN_qSF1H%kIL;T8a_BnKJozFjCmVX?Z%1eJMs;)`fecI>y$9^22{`3idh0Alz
z7Li4c(N8}W5ql=4M0TAzspWi-k_G9~xrxlC$Zn2|rix#?Bi(wyl(t5suzKNNKdVyL
zUb1Tu1UaQppx at Nw$Y at m%Y0LyjLbfPv-9)l%<1AuBTWbk2L>Gv3mI9EyiXkjO`MY!#
ze_MidY3Q=PE3(Qqq%wdwGwH at q;ywhZQXA4Mmm*yq1X6O>UYzwC<S1)*UUv9+M?58~
zNra0?DvD&gM3*|2NbYG!NmY=l{xu4r%mKrJD*iDadT~fw)ivl5hV-P2f;bwI)_8n_
zK03-{A81J3kF&s(+ at m*Ha}^v$aqa%N6vDKg7f-lUj=_N%Eb7D!AdpsT3^I@;4xU6n
zRc7iTSCpBNV>*GP8Z!=Qn)X;QRsd-wN9F*@HIfSox5kJB1R|NbBn47svT_~+$fHH7
zQ#xgvQw~MiTBsNRqjo`Z&xW-1s52n!LAMksa&yLVrEJSscS at QFXM<bzMDjx#h)CtB
zc*JjfGQIm?4tqJP2%V!p-j<HbS=vFo6)2GA<K`&;9Akszo=qftAc8cq6JY?Q at 0bLn
zeOt^eQH4#o$7BL2xrKb=&sr@~f_-f6NE`gszUs`vZd;k}<U8%~@DoTgW*LWpQ1S!M
zfu!clms%*CaJ;6ZUKk=h+-nL*&t6kfcZ{@N!fTV+7(JFRGd3S34kXF2a%6x=i%LNt
z*Qh3?N3{vRn<CvURI|b%rfR_vQ at -G=sbjd1DQLK~scZ<0DRBs%sr3!8EBZ}>i~dcN
zH-?)`Zyq<{-e4{#ya`?2c%!=9@@97F=MC>t)O+HkvG>hOb?>dG8czE?1#?>TDYDbX
zPa&RGe`@uN1E-$P$Z%@jhKi#KFJlMCo=B6=Yb9J;hL-fke=>q?1ZnGYf&)@Zyot=Y
zR0K>sn~`}UafwV>oQ80;{K6?~GKPp4Hp|lC9N}(Fn!$68IL$GB>7$jNWV{NSK5M78
z$%7y|+EL;X-2>dgBrCf%-3Bte)fFuO1>|1Zxn9=DK6njHNrXAm>1~hB9OO9jSo4Sr
zX7?KvR1`YdBPt67ct%BD9e;o8)Lk%*z7;xx_Y$%VnkTA|JOvEFiw}gA$^W_N<2RGH
z)Q>F6dOwkBw?B^UlxaOnSAVt7_mBOQf`9geNa90qyx=+pi%*eKzMc3m?WSo>9<331
zt`e^o)Cm8t3zc2C(ZU-Om0cH>ZAm<Snh0w|9*g2WB<R?>kuKwVamriEw~okjl`sIT
z;)_FQJISNop>T-^DA4r<3tihSA}_1dC%*O&V90ZoS~nn*g~L3mRJsR3b$5jJ=1 at Yr
zg6r@&E%jx*eb*aMKj_KO-#cppc4M``CckNe>$YMwMG6NB*n8*+nH#WcQ%W`t&az<Z
z<N;*jc}cra|6n)DQm_jyqbn3yN&)V<)NaV2xPY-+sF%Ar#bLdrDbu1{b7!$9{~`=6
zUz;m14{`c2<Rc&&?~m66#7_`4uvO_M(~lvVfmO>v=t?G!=zJYwbNr`GK~U$L0<)>_
zy{o<X_t=O^J-0Q)x9mw{J|K~@VJaGNUr-HLTeF(S(j=*ii9aKSsVXgS2_tBdB$MDn
zZH_0rHcv7;#M6*pgC&&SAPHwE3n at uCIGbTK!Ho0s2fvvpvpGfZ$(K(-IA9PNRSFMC
zhkry0BLEv+Sv8f+fXxfi9$P{%F^VKb7;Ko-5Sq2CUDCC=03)^NnSX)VN;)ErCXHdI
z-o#$0Ag(~K8QL?mIECI&vUV=g_t-3mZYvz=tSRXx+6Y*rFc+hobPUo3GC%@pd;q|S
zER|s8PA4VicpI)^*BDj5*k#EVQWzY8x8D1j8mGS2<Ab%$<`~MzN(TA*lm&>7{@yk4
zopUG5!r_Uj1GRJpnf871?ydctshN7I!~)=v)G+SBiFI<WRJ$rY>Eza?+E}5J)2{kJ
z-QcC_wKWRcw$LvSm2GiM8aI(>MjAq{E2^btYuHLzV#>4`?7XrqP=vJAFKSl1PPN-s
zTIb;_#<W2|V%0 at 5g;C9}aV)(x`sCyHfp?ay&l-ifly9kfoOT_0rrd%Z%%(c_@|RNk
zZsoU|axl+j<>v^Q-X;}IgID>~g3XtJkT7fTmUu!$c#N&u44eYp=ZdUbNPQ1qz-~=h
zwnP)bwr&|MLZg+>3O)^JTe{@rYnJo9)#996e$TCFB=}b4cF7_&rn$6cwdiJX!Ly}p
z3@&CBl<o`i(DXE^G(Kla5D>j}lo<52s4z>!N)<-qTz55v85Y+h$kHM_nOQP3zobqV
z^qwEdbOeE*F7VK1G~MdNvMsYVe0o`prpy8CvTC5=y_XY}@)d~8$mDK2G_h;8BRq6$
zV3G}ubkf|&bL-e!SghYWGK$irr>4cqd58yiInUwA$;#1c6kKDQAUqh^vt6OA8h>XD
zL@!Q^bo*^_)+o|}^%mnkN_%_FgA^Jlx09A{v-wUD)oN*>ctqN<zW{tID&k5ey<$~#
z>>4TwLvyG-hN7aD=HrX4(zs;;Y^ZLv*V2iv+4KNJKWHZLGppUL2l+sQHkLHFZ4CKh
zOqBy_D(z|aw7y29ENcN(zo=U!hixU;-R2EPG<qL`<hFi`U{&ug$lT*xR`SM{13OLi
zoQ0<6B<m%rGmMtqC291Q{a)vZZ}#StH3NFJMlpohEL^m8LALPd7exzAnv>eoxLTTC
zzR2_<Zn9aE7JHcb^@m;SwiSxp;5_N4FAnw#4dEWmpHoGPy|rRv9bYPfh<E5ZHds-T
zV0M#9J9)fUlSTVIyCbX&*vZtR*<_A3s2_BhpD`-hhAc6$i!PWZyqMHXe}*oY-K3nf
z4R+JEXo&JN+oWHurTvOn>D@&y0G at -ZT4-uxW#BPe*8 at 3=G{V0H{N%gliD<K`FGvx=
zgWc7ZPD^{Lil^=KdEMQH1NorIbPH3u8SH5iZB>s%TIRPM(f{MST9R$aQRKW=kt=A^
z2avR$w3^+V^!^70xD%ncFRf<>4um8=j&n${6P2BPtn<k5SRx;bU8G!)`n$RSf}Z7H
zAPCJBA;01`WUpdAniy8eK<43&wF!z?sf6gi!Paum<wvnWnd*g!K6=iJqHs88Toy5m
znAwRPRe0d3t(O#aFpEAzlp{!R<{`VEn`aWa=d&0Zk+v+f(?brQMWVdwS+jF8#qA;x
zWb18Xm+XglCv`>#Wmt?{J7DM9zA`Atqj-Vjn?eAIyU%^|j!Tmy(&bfe2 at -i?Z?v04
zp7!iAadj7$TnRYN;MONat}(qWh7S{YNu<kDYE?<(a7}q6xVyZ`Ba%g4 at _0O;A&+!<
z&Gqug_+slfk93XLdU>SFV~v+b#x482c%(mL6~IP`x-9EjRr&CXM|x;%>t*53IWLdg
zvBK<|N4m!LetG1R9Pr3r*~1B4^v>s_A&-nR$s3bLp4d?L%_HNMTwij$o%R5GvZ?D`
z<dN}mvyTO7WzxtK6HIR&>9Op^BI7srtz?mp{IJMNlPoeaan8#k^ZVmwk#Pa?%E=lO
zlZPc<B?%VECqDlp0%Vbl(8VI37?MR^QBM~6D+>vrXC`T=?(>6AbC?#VYHj}YfB#7v
zNl^d)ZFWLqmVhF|j%bG~(oUESI>8yzv)H{YdSx)e;fSWlSG3jN`BkfFpCR??uz6ML
z%9q}?ymIrqEgFYP7V~+B42#({BAoY`X!Ghv;x*RNM?T5@;8B`2^)GyZnK(E?nY76}
z6>{&1J4sFTECYYVun!dN98Ir9zy(>lWZ;?=65$9BEh}j>gjPHE*{|5W)8X)Flm;oa
z?7o0+bZ{eZSx%eM{6K?-wRlWCk_|hvSeK6uE`kgj015LP9(J#JIoHRhfp-?_Yw at Ok
zGc4K{Sx9-<VudZl?Vu`W%*tO?%6AD~9 at +YbmAoI#4>Sgwox%057JVL&jlu7$>Q*>=
zB>x}mThyRG^pX)8v;MJ=>huA5h>^ngswsm-UdeL%$}7h5 at atL8>Ke}TqDoXe#3<y&
zZ~mc}k7kn at 1yfQduZ`PCFr|?Dw2LW)X4F)*G??6wqOwEQe(#r|S=~Msr=N!@X|UsQ
zbEUKx{o+db4aPsXQpkmz!GuB<W)NH{@1^@=F{IcQ<SrLg%9qdeP$kXx&4(%}g7`9}
z44ukDl~Nx4p-Q)$!1OAL82!p%FeSgUSF&G2oH)#=-_Qigm*(fv_%1s1mnOJFiYbjC
z+?t#&#5v;XsfYl(CRj?!G1*+!U^6bah5ywiJu*73F+b9w*hk2L978(ff&W+2^oaEf
zmq<qBazb9n3Xi1Nl;NTBF_1xnAt}$sBhBcLtTr_MPsnY-LT5b7a<Rx~%1V#WY-lo2
zE-yTME}^WSP=y8_BREycI3qgumV-Q$$NA*TSEW4lPtBXbSJNkMrZ$*EoU6*4&dzgG
zCX;wzF@#B6Da)BmqS7NkCv&)A&^vR8$LAVx<<JM?wkwC0>%yBN^MJ2U4%GvETc|h5
zU=lUuH8;<sgAHD)!$4WA8gt!cX)M)5_*e5r)A`K#H-+Z)elDLsHIg#`8Xb84aUz~K
zQ#|e*UOk3&d_%P!8<gEOy(33WaBlLl4A*>Q1T at g}GElmwU>$!pp>a~_xB!B`JMOm^
zg1;A&BZvLa1P*(nAF4kN<)|IJpwmOL>f#D)%C6T1qiOr+1v_r{8pJ4E_ at n`OCR?tM
zriw7~{=%Dpu3Yly<#7XGf}#a at zZrH=G!UmZ<*#D<lc{JE8uQ1y92J at Jl$7nDj8=|}
z)C`=m;%zSTBEf1x>MXl0v=_k_4d!^di#|d_9*el$Ivskp)9??kv}nOdLyo;hPZFk*
zBNzuu?q#7`vtXwzZSWC7k0HRCU~_ts!uUNs!S<1-3_6rX$4ZNl at 0{MDluwGmyx@=-
zpH3k0Majs!d?4FIV+En%BZzD~;3yGuAx^!J?<nImS=mt(nHVCW{q<y8@}YnK&!w2X
z-?iY7(U9pq2$UNKF3v7ZUW(e_bfX8yU+gV;K7rBpqJy4JSYvT;pyoCbr7;Pm`n-up
zEL*G&0%LS@*2a8fcr?zUv{0_0`Ay`0kAl|2K-(?=@2r-=iHS_{RjsOP)(|HKmd4w8
z2sL8V2rF<aku=3s{eSACLAMhj1|HTXWu~w510mm`c`agq;R^_^O#<&3l`k7a9cFj|
zXj{h at j-g}@YsA@|ZbD;x)9K%UypBNTB&!rV=8%3UJqC*)7t%`}XpCPdbrs^w8UD|$
zI9+M6IyJG5#oP1d({T)CGIQd(yzA{_(8AymQAt_YUWvFf#|1O8aK=gs<2hSw>50Nx
z4PT6<g at rWnjVSX>`hkTU{m65bM`=JgPwo?mJA-Eqe6f)!#PUU;+AQx0xQ(1;oe*!&
z)8~WWR~B>AW8HP*XUzT}IyD;}i`domf)eEC?;JIOa|B2)+kZZqoboOk=|*gQA#0b<
zAPHa8L9~pEZEeDS)S4UWdE{`2UtbI9g#C!O%flYjhr=_AP at 8At#DId3qsnn5mL?Q4
zS?f<~PMaUi at UTJC1(!fe`1J!mT%HVGYm2v#gL at tAX<;>casrNQu9D$#I1^!kvGjgn
zCgSHAy+S!UFR{~L);zP180?%5HQ+YBI0ZSD*w*5NjT00!D>PN?wCF6FDCxYj!NXWq
zuBj2pNbQL;Ob_18;*Svu4->Z7frmm|LAxT5d$J>|B8I(V7YS$AvqBnCATo~>A8u%k
zh_(+Gh^h(7^HfbxA%{g&%sXHrWbR|eGVM9yF~e}}#!0>fau<@nKI<7|_h;i7b8wnW
z6t-wh6RlR*7pIO`j(H6SkM%mA at iB9UdM!ME90t9!WCmI9uA-7P-kD~T;N^0g>~P*%
z2R%xo-k3koEcvBTBds|35vg&jfQ?a<f$bBG#%Llor>Js*mA|ysv0YtnXMZe|JY})&
zgiLC+s??(6RjIQh=c at Z7i&XqeGs}ZH9R?3+Mc5w{DE>yAP=iH6e`K%;3$svwgfNnx
z59Q9-bRiI&)lY{uMPyo`1{b5&nDJ8-wDL7K+e1(T${x?%DY8c_TUJ%H?iPMQUkNn#
zSiq>zq=(@D81KG97Uj?K_9c^qAS+S5^?;Ao5N+3R2<jPWF$P8&deCc_BTtEMlC=A^
z at LUr?!BwMsjnHrO5GBSYoeBUTgl50Ivdlq`Nn}_Pv%zy&wfajFox7-k*S~3ka6p5l
z?B6uyRbl;8bDs{cKQ%LB{nf}me?cZ`DY-MHy&|>y=1de=OvpX=H6hIe6R2!}o;5`*
zkJS8{nZMRJ0hx`UtfVzrXr5sy+GD5yn~%&InI8jwP$@0`yQ-vAnC^oT(zAIbl$eo-
zjdDPAq51ivuz#}HxAz!2CZZO_Zk}CxG(R7WSsZ0fV>oMr6ozb^#h|9H(FTi|^w)@J
zGtnhvLwGyk$$T8(2w;c#;goaRFdsc6X9Ufas|+F*7VCe>)=swQ at _6eb!$D^MSZMLR
zM8K7p0h%fFI1`#4dzZ(mal8W&_roX#8H8(CCxi7{n&{g>O(V%$L-O2hM3aSktx;fO
zyoVN;SQ^MEo at spQD<hiQ<g)Pavlwkdo~VP<D*Ux<0Nd5e?!SCjOOhlz3cO06;F&%M
zr1O-`u6i@~Uku=mGNQWQtkRqm3dGmh>>c*PTROAru-WG${DN(d0pwrca4@!Rw}At{
z4P%5cz9R=RergvpU>x6d!pJEE at j6`f_R{ixgG7_ZRBk6VdcroZ!Xx>=^P6^R$XS*{
zNEQbt^2|8 at li3<qD*xuF#9ZV?CJ0Z>>fMxyx-N!m&Ul{iVkm|ns4wkYVtc2C(A~0G
zf$ZZG1v*J<;uT+iyemuJe9scQrvHXytSk9W3EEZ=4S#)L##I+^JtpSsS8Bvgh9GF3
zXz1}8QTJ_7E)2tbUF_ at mzj8!rKK<n8ROA&37<(>B{(Jltq&f>X3<kvGON~)`oByH&
z_vn9>e1=nL{VBm{hNS$w1>YvKPNwc}Vc^dZT4I|tSz!C=cE6Fnk`IPAdycNpiL0;}
zj+&`FKPJbw;`|`(j`8$~x#QKT at yvqC3?1mt+qJrT(p~EZeYDB1|NbY>$Q^-XN#>;N
zuCrlWGz*TKph=F4M4{^#NZDmcj+e2~ZCtS0hc!WCEPI`3O6C<T$)dOKUk{e#lHF=|
z?Rmn4vp!hT1Cu3P$>ksxOnCiOa+Bj~{Y^qn<kt2j{~{@^a_gUx&(}-qPswFT4 at t75
z#AtQ1F!=&mQc5_xf+Ypsz{!%r_e=`1q#F&gB*$bR!I1(LKi%~O=_EA^Hb_lifxgxZ
zm(tMPUngu8%L3j-0<3J>hrH_`Lk@{tM~a>OAw^#g_g<RxBePKvO8V{ByIX(1B$B2?
zOU6B2M&iM|L(g_WtNf3iZObzg<*~9+I_0Zs!0uwP>CVTA;;nUqm+X|+H-sFgjF5l0
z9>K;7;}JN|jy4vKLtX9%@d3%{0R@;4Q~dn;n8+D at A91JneP*2~H`ERE)8`ZA$TFfF
zT}Hk`0gbNXM{ppKXqO2wAsTEvhH?(BLK|0SXP<dOjRW{R9+eR1$JFQljbDShunT=Y
zAf&Tpf}dmsr+o#VfhoxfvU4wpa>WIQ$+jw28Y$m7uxU)z!FVMX=vY2+KmXsPspo9^
zh;8yZxgApa-hVxvz8KeM5Wcc%jBD=ynIpTC4*R_`S;#{Yjb`rl;r_vH92 at 6(OjEbb
zC5x36UBclwoFf*U?2xMh$72rZ(C375H(1#<oMad|`P|f)B;BYzCj*T}WE!8`5nvP*
zAc%H~Chd|je at F&bv at S4Xl8?4bediNgI2z}>8{WCrESRyi!VKTEYO!O`H~q-##GLxM
z!LiKRBg>iWhp`p~JdB3E;J{3NNan_cORMP!aKi^y6Kcr9iNzCB at XTCr!sHDNon=#p
zf(jHGFVF?&pM~61D?e>+n0nw@?k}iNhYc6ltc(zT(+(Uvx%+Kq$Piq3_N)Mth&Fzr
zcXWYK89_WxDNrE%M4!MQGmed1`=;q2IW~pagMDcW at FY7wy^Ip_ at xwG-LdH4q4Yi^d
zt31`XhjpAdq%BF1!q?|qj9|bOpA+-2!*^zkkW23hpB_qBpy+0fJq)ODTD>Z3OR}(;
zh0d8jB*sl6k{~{UaKzM3E7;OeI$<VzwjxbOC(YZi8dMS(o;m#^LDS%s%sS-~W+<KT
zHb<ATo>xV9?H3j)@0Vnj1|vEY8p>sI^vdk|YG;qIUArFR$7Qk|`Vz?Cl|~C&Y)esC
zhTCp!4ue6h+6DdC8bXIn)9awFPd=X#fg_DgZ5x8S*~CmMfsTHv_tEcHwwU)s_~MjM
zt^%>Kg%Q~?eVqD~<0Ogkd+wRvDVgmf`F=^Z7cC^i&@s1$HBr9AQxbQr#*S$ttcW1^
zD^HLvTIAKt%EO?5OJ`Om_+%c~WNn%ro_P)SqD}=Rb6&x`cl5~zQ{3299!$|CqrXqI
zvF`ku+aF_tkAP8OE$9Et11g+E8G{d=GN at 3JH4G<qzdbiE)Z0IyKt6mLZak|J2PR at Z
zN|Gl&Vlk2NY8hyD-QXuBtLkS_VM`SULf4SXBl}Xt+Ocd#t|Y->zF!h)i1uKYkv)J(
z{gzDLF$TV()L at gy4K!efLX;`fMcFn66QtTm4zq9&+2y+L;wMav8A5)U6&3k0FNVfq
z+piNsUs^PtaP8p@<4~g)r)`}XgA<Bqv9)T`ist%Az8{hx@<Pd(=h5b4FC^8+Ge%?A
zKb5wVR|GT4XSDs8EHiugbM};LJ|~V5r*qx?jq{D|DY606DF|{#ob#=9WQlMtoSP+!
zE6LutbDdgIaD$5d2(cbcD{2^%K;*peU~#;A)iV>_OFpT8za%jWai-sz+DP~!DF+ at d
z*0Xojl(N at uMIx+X>B1r_+$%9+5 at jK8w5uVoB3O4O4hvni+Epi+3L=<cSDcWuUU*t*
zlw{1#UVv}p3=4d4WAHrohFVuP6P)t^LuaPv3q!-$0_((H)Uapf_%~+1eVuH3!@Hy5
zL=e575yD)uf7U5JWf?W)IQ&G`H={FN5?{{Rxmu9uEfu4dkn;vh{LXK6ov$<RuYZR{
zr{ykzh>o;qGvguoeo0iLX*p&*R>ot;d_ at GA6)xcrpP6~vXEo?@@RG#bTsoMIOOzWV
zn8)^JhD>W&>)SJudkFZJOO7#yD^47b15X5Z-RBOuGw}`Qzm*j{u{cUkX8TFHj~ELz
zqB7FXXnXFh#@tOd71-ov=2!Z&vLYnk4 at nGD_%rqo<dzM|?}FcY#0_>SU#9G1C#NVD
zPW^?KERKBTTlHdiXZQX%;Su3pryF>bKU+nh&1Y4aGedL-nfAh4Pyr>0iTMi`fGj3`
zjZYM(W^;8Tj3WS9V2j;Y at b2E{#dx>Ke4Wt48w3&C1`C2T(*KK`I(DF&-?>&jVVkA!
zEC7VZcqW*|Z%T at GBh`vjuZ}$8o~2`#-Q3Mg7%zBYH^6p2nBlVLiG4?e2}*1!pVfQ$
zlHQixS(Gr5B`Wj2;p>lAW%29A0GQ_9ND8b`xbsTBUy|X37Lqxk)!hq$v(N%Zu{+MC
zA?{ddt9qhDyPE1;#xuonCVb#1Bgd*A42>Cu^*GT5-)I)!aJeO%EmO+{7A)H($u|Rc
z7_sMm;GJxb8k9&7tH9wh#}UQAx#>E#Lxrsn#M+rQ#Ns+5nrUK76TKGO<Rdx{%#LS|
z=!$_4G-l8y$FhtX3s)>3;pvx!1JS4g<B`DhY&3>@!hO$AW@~m_CM+7YqgeBshT!G=
z4m@!I!i`?}^+^C}*$2KqY4fM#uW6&;Cy$%k)ygCdNhK0-va>Lr{^~+gn!+E!M)UPX
zg=pZBS9&gne{`PL30a4q1fG*I9i=haK-hy#M-XF=aJ=LN#|;4_Nb<xR*e0XCk*f<V
zE90&yiN!3VF7V!5_ at t>^42|HH&l88)K7-$cr~2WI<*GreB>H{$8lPBe{`wi7Bq!E$
z<H)Ch3aAgNaRuK`K`dbjS(PWV?c{LIq5~1ImI;y0h~5zRzzz)};J6!}%8Yi&zyXO_
z=x|QHEO>z9oCp)O1BE4<zQKv;{D~)SuzfCu2HH`b=$>zQ#*8F!JYLRp0kX!e3>x4#
z8-C#EPL6eTdb3j_=?o>`FG&Xth+8J!-eZ0`o`=2HVAkNnIIF_Y#;zDNARjV-4cPJq
zU_5nZ at _kM;gQYFg!Ut%%6Ewgj`aim>B)g6nhh4=d$kQzHJbAryHhup^69lAR<)l|O
z_$8IZ0R-z3k<MH(OB0dq2Sx!@?Kl=pOnJbeN#iG)ik30}ml!0i(Y9hdJ|u<+zF02a
zUE1UKaLg8G4aRGTHrqUoT3yr(74S&yh}#p6>)B`SGdi7*niK&rWQ|$&iM+*P|8VBS
zA*(_r!L6s*i>^1@>JLkKY8TTlW7um&+f64_7RzZk6anz0e4Vo=3b1e9QT6$G!|$Ju
zN)51Ekg#9sE|BtQhcPh4N&o#%u9-3R)u&DfOPTFS_zz2q9xqE}nY9J4kL=}%L5#rV
zR0P=~)Q|Wi<z8S&=ERk-Nm$s>hNVg_To19EFbW!Yh<Zz at +R)up4?9=jwpV8at`FUT
z9WnUL=Zc<vfiJhjOG2aSQvG_X_gv5=hh|+b3{lAq$KqKJaX at 2cl}&sKta{asY1Asc
z at XXZ3z)oyK+Gd?^xc3`+K9rd=H(hnQoKJab8q<AMM$f9`QO74vyixVc_m5 at Q`pSt&
z&x}vt>_V1fRboBNN7q-KHByRFq)8!6-qKdPia{w;9-09;(uD_4AT>iW+=p!`f~_1O
znbh6s2%i^oLsQ|N6?F-N;P&9$lUMNL?4plmzvyb{pd&`>ysDfeTiO82_sfD at ki}#f
zN<{f;FiCunHHR<VyXuJ9c<;uC&Az at qr9k}h%vrFjcv!BrvGj#@qs1c!s2}k(;mRDT
zn<w;}BW?3e4TKfAi_)s|gl_%{@Jx}JIiejyD%^&@@KSNS+3L+r5~GjI?7>mrd`nv@
zDMoc~2|Z_?tRigZ_2Wpv#T~t9#2Dh1GSyQKzZK(Ks!hhsdG{)+ at X8a*I)!eMhVINH
zD`ac)`NDhO9kQSWCYCnIevWT+iO+fRTMa(7B+^FWXy{d~U#xd8d#&JkeLu4X>gjN<
z9SLV#??;M0iR39oF=C$FX7^pc(o-uu#s0j0js3&mQjT>V`f=4hPT`u9^T&c#BX_MO
zi<k9U^S({C%^A}onpwf9=D6X*(!jxiQ}6|@L7c#N{wM~D`<)vyU&3IZ<iG`*Jn)8N
z<|LH~W5*1awbzOqB!JN<0;99$iOje;vsI=ALTHW at WqFC3(9k~tnQ+(QskgsriNl{3
z&^9d{DHXWpwVa8MYeALZ<#w(yxB<ZeT#XxQ>3k_NN|+mx&F+fujqAuxTwTs()rY0|
z)FnJu^ucg|VV-!fvp+0z at yuR%i|lYXaq%0==J|#mzA-r97KOJu{zo4Jw%YU#Gv3PN
zDl7bk<*nl7RXe6>$D(U&GsLs&0OtW?@(Nz3HZ*<IH=T?6uOSU*Zpi=Z8Vau?G!@cv
zG69gZHFe($&wUd at mX*g3%GkirL3twNePC0TvWJJk(SdOvq;Z9aC$4Zau#fYC#C0(l
zdg1z3>4AZ94ERw7ix#KbQ~gvZbYh$RVx^P&V?_jRY at NVlLCq$nUP84FSyY^GNZ!(h
zs++KPZCHHuqWpzn*bmD at q~N;ElpK}ev72zhoNaMWt?<Fvy1wF&)Ocy at 7b|^sf328f
z=>$3x3Ohe>GPHNaPZ`=ye8&r}cD#QqQya2ukV3;nN=z|ut*T!i?c#?yw4yM=Ynzht
zWW<K(hDAh|Ed;pp8{T<hYp486<E>g5Dowt-qUiuHo*-F=a at T^!6qseJZWLgVn2!^T
z4W*y8`}O4e<@<$ak}tYMG(|{}B;@(;;cA6-_q*m#TFM&N^8K)cEZW!7NF-3!6U8rB
zh3kAa8xRc7gv<fnu5V-~0HrN8im4q7xduz;iW~@l)5C$;dXz|>6vF0Y`8%SUIHQhk
zurJ0A<3M;<;4JmSM94Vyrls}ccGQ|Hx^H#d{lXBu+;J?sc&-?IUAhIHbzbh|4h%q<
z2BtfelQ+aRnKq3h%Y<g1%4XL)nY(><`oWd`dmYaf=0E+2!XpL87f!5!IZiw+-k$k@
z8VmuDc&JLjp}>{D?>6*JH{N0!<L~`&k8ZKK!^9+>*_X^w8Z%@FH>TLq9lW1+O??9;
zlNoV3!Q?kav5UE*zkbhgAy1?y&#Tnqp;~lFNYzQ*lXxg)^r$TY#q`>*<@;d?V&|v@
zi}wfB8x?dm9Htq>QQ~d7cGVeOrGU2aX)h>+SN}Pl`7GF7xG+bMkNiZx at luBxim-D<
zjlaMUK8bIZG*h3A%K-N&@1oU%XOwk{@FHWgm2<~X?@$sQIC!ZaRP`n%OniS{sac%<
z^$aIV%0)fANZCx2#jGjoWW|_TFu0*t)*Lu5-CZ;6r~aH$(HDJN%8)`D3}3IJ?ZXP`
z?UZdyBWql-QgeMU<hFLmGAa|zBn{cYEHgfts2}!B)dQ|ttd=TWS49evb at jws2k7Tj
zwR%4C1?S)OIo83#1+L>Us{D*gHlx*}{hqwGj8*$}IA7tc at s9N)z at FjcCazI(A47|$
zX&k6s7MH|3Yu?|^5o$$KKY@!@g!>F8xh&r=3xWqMzih+- at butJ&=LMooRDh3>KHw%
zCWcu}D!rW at qp62LX#}2C7^NL}De_fS69aBr3KdsC%Cjr+1eZH%<u_)E#LtTPO9<H=
zXlVFpRP<q4U3WkyTu?)DFnAS?YksqlJ5Dyh^8K)Yyt*vAa(Hw|hQO(43p-lgqn+4q
zor>?@@iO1>Y4CXH{xp2LX0G{K(S{@gN)yqPGmFtRJ-FaeNP*>xRqeto{HFCXjMnmZ
z(0VdhXS|D4pHoTV3fWyj_on!Yc^ji;%Pv;5+#V}1adAiMUknaewjVE<6oL)<HPc!n
z)DySs*Jt80HpA^|h(EGCRQCF4=;b`MceTQLf~7eO^B8c^Fo8zGG+h_dH7T$jD{g;h
zZS|_|;7uE<xm1R#PYPj{`gMy{ulW7fyIA%y^{6kEcu{zHMfzb_n0_^JlzVT|o@^`5
zi6FBRQSo0AryB!Yz$xvxm06$wtpLdbA33^s02!E=JBrQ63P at uWL>9V9;G?9N at 6a2f
z0!XC5EGcK3f8a&hK9-a;EL02e+W%?!u&3SO^KT2AY#3bK|1ZPYBd7ku^87Y;{bd2=
zy8p1OOmJZKvdKrgi;FmWq=o!78eLy1t2`PP@$Ay^?@*whTCS*?b}Gi$C5 at e|ytShp
z79N%16|Yw`NQ8g1i at 9SKf328XxD&5=dhof`Zfe?_ at 7Vj?iYaDl$>nUY)3&KKe<XGm
z#BM>_QcOJuz+-`jah1Tmp0?E!*P>~UrMV;QMdg9g47~bhvI^MVv)6`3ua6a|>Ge1u
z7*>Mfd?NU3`r{IzK&7I1Nnt&MJC0>^?#L6sDClG78_CwD9eE3+X#KjEJXCz1 at gZxy
z^RXb^aQ4ejj}OR`_X;21^NR0S$g}<m&NV<vBoy!FC>Gd?Mz3+M$lndA8*mm4HK?BZ
zCSq<l3Ysgh^Kn2S4ShZkP8*M5aF;uV at rED#2~1j0(;+1830bmBpRlVYxx-w=U|+nV
zDxo|cA<Re2vR*6J){5<Nlc at 6JXjSY$HObF;$My9i4!>16hphf at C)q*KA3^&k4Of#;
z;vNecG^_Ms=@pj;R+d0^0(X9R^0g+F5srk)04~BA5{p-#q!`*!ho-Tzb45`busMhY
z+0XW-tW0M9AKO)uElCc-uJTWi&l6zI)7z~3Z`&XdL)G7<NE5aJ3lUq`XB%;Jr-O};
zD=<8C&DRPkg%ASp;MKVYNx=>QQ%-p<=qwzIc6M;%5p--iG`2Hwe6kr8ffU})Kpn$|
z!-^i8c-(^Sfv5T9F<$x7>^r|$9vQqXGlsyxd^9l+B^KquKySygc)5-RgK+P};`Qp3
z4x$WSbF82mN<D2#-FT-^Ka(#RDby2ge<Vmxy!$JKdLq6bE9B!sjh0m-m_2e&1X%J(
zBZZnPwBsJpy8;X8NvG38s&z1&f?E97a!ZHnJO5fBCt=Y^t(-6VoDJlj?K2KfHXpMB
z)H><k5yCDHv7P~Y^ZyC*s{x#})v+9Dw9dJ6bb3VR%~J?g_~0Q0NpP#AumJmlL&GB&
z91nW3^La&+1I8S55Tnj=zRdm at DDvgX>lQ%<&s*#>=uz)2kip`R(smI}m7{n6DVoda
zU_9Y!wf;eaDLZ!0_VA#_9qsm&_sin>u4y5!2Z!t^Jdk$lz~(3>XumK_eADA<2di<9
zNKoJ|)Ez<(StYx%Vo~ZxV+}knsXyp3w%=pt!M%ihXq$tZ-Z;YHIji03C$t{Exko~2
zLZz>Cm?Z|YBOFC%6sT at 5EMwB6ESB^TGXe09Lk4z))@{&Zu}QRzZwi$`H(;B1{A1M~
zd#`J}!bPj|&%~ox(3GKCRAfk2tG0$XIUB|r&gGZI$Fm|zYy{>IsfsN(`<RWzZ)_4L
z9X1tKPE~OTj)PlkQ*{zaOjUsg at j#8qqHLVkt(3&MHcNywDcEE141wX%*_diYlOkGV
z%h}MqGt}nA=93jewqGn6Ud#5bbkZX%--o4NZOU(|7_7s+$*L%`O*XUosPhw(kD- at B
zW(xBu5I<vcuPE4%FPkJ`n^(R_!iyO$+V%);@?b(1$@!%?Q&eBzQB$P}@O~vYXpS<2
z4wIcSOX!A+M|xA$o0y`X|9KT=bLE=N*4H*(hbkqcp-NUsO0BAxY at ThwqdSt^20R*A
zw{pSpFO(TxBRIlSb9f4aeDT+NwF&YxLlJ>HHTz*9k>Uf&;f?|`4zROf^`=}N6wt9R
zBz0H3leRd|qB8mgd0Fx2|I6tucb&xNul0tA5B#0VgCoM<2}ymv=ivg9;%QQUUY2a|
zf!idl&cvx!?)EWrE(0-JF6dN)79wkp99Ij6$2d=@zg7qvj0KAxJhhsf(<82k7Bq83
z+dM?ia`auzptBrdId?r||IJUdW`9{aQ$3Tk&L*4jTsQ_NuD<IO;+2k(3rv`ghEr{~
z3nMm-^@kPnkO)5jI17WrBA8?G44x|%TU5x6CthfK4~r<ixfV-yB7c)(p>CnatP-Ds
zLrqpZ^4AOw8 at f9ztjo<n`82+oj(fAPqHiKnw)n0L8CK;N9AAjmgm)<PnA|mbZ6*T*
z(*zEk&%Tog#)pk at kipz*dgw1Kc9jGz${nC&gW{0xCUy-6+ at i#PXuLQCm24ZpV;RMB
z9SZE!b7htg<@M;SbgAZXzXfVj$0?FCu3m6rz2~c2OopOXob*{Ka+b{C7q#*yRI`IG
zl-*%3Am^E9Rju*f(dECeaFV?(YHXc`!jx5-p~{XJ%{I=-6&~$4s;cy{I&R9I;#%)*
zxA9t`r5O- at p>*0*nS&y{U4^<T#p?xiRP at Ut<-iGZEhjTUoOu;??K#O2YE*aRy0%%B
zRS|om=M8e5^N3?2TaCJi(@*4=bMI)2&l9)qG3EyLP0d;PS{z!VGBP()`FNONJid@#
zaJU{U{x8Z`w-=V=-)IzPFcb~}6W#objuiPjYx at kBoGUErFosR?{zkMV-zIo|<_b0r
zQ+!~EUl<Op`D4ZUu(Lpyu8%rdANN`xQL^pG{}=CpmvUoe!=xoOB*gPNFV%jv#GBo;
z!0R^)h0VeY_M4%67|~xW&%NRGk0sdpMEPyee2Ia<y at E?ShnmHPeJrE16C$c!Izb%R
z^ilwohfN`~GgGZbt$c}c0?sz4Mvt!8wP%ZvRLhBzf==pHFU;bY^R+ at scT8fQs!N?p
z*<`w*eyr80P+m6KOIvxMh`rSPUuFHxQs3t><E(ye7p1Nrx$yUa;}s=h7q^gsft4LN
zchxMnjCYD$1&u|#Q>`n;tJERou?KDj($JGb;-myS4T!NJRoaOfGcd7YtWs^7c<R0|
zJY>pi#TC7zKKpEHS9a+AX_JT8am{@a;glvj at tFNm!|)g~FU$8~i6=X0=^d=$O>$c|
zDm}rm_9&Jy9$fc&sKvNQ>C26)@(V^aqN)Dx6(<4GsU|J)VmRBb1oUE#h6FUu4chmO
zbLtrMD9aisf(}ZyiJUJs24`b9hhU>0Z8OIhB<H}zO9zZfn7;nr!nt$)AUPcHrd9Ae
zyW^6dtEwr8o_O@~c-H+lw{$i)%m!yu3InvugW1wGb+}=8iamRs8O_fJQnT1DeH*KE
zUl<N;?8l1p5=s;>tTu3J^9sB;EUJ8cByef{hi{d4`0uYf<$L#&GO0uV0p=Nw;hToZ
zWAD&?fgAAz4zZ3<#~vO->7Zfff<7pQPT>V^wWT0XA%yq6Vh6o5l9}HiccWNUdWf*X
z;IQ~fO^SAi{0PHxIzaZvOA@|4AL}>EqbJpO{<XB6c3 at dlkZoXZUC^w3 at G?rpX~MH?
zpI7xpJjS(0hU;#Oi02sZ1;gegqmhvE==7MALOa+j at a8o_d{)k5|3Qbl2(m0RX3JoW
znGE<REfU+%@_kvBbz0_zR}gOCk(1By3GzP}L+7lWj|GG2%;=m-JFK*ULt-9m{l?*8
z*|?u8x^s_c;A+WAc`6j7YL-=4EXd|y%l5k>@K3n<rbAgYUV7jp#G}BP|KNi&v17c_
z;IFU<X4}9HJfcA3P<hDH`7wv)v9Th=Q{b5@;&l3*aAAEEG}cRwhyt0Kfk|k=h!Hor
zF&y0dvEoFU8)l=9TsS|-IGt>jMUcH2&oFSu7m#oHK!aQc&BpM3l+C}E-^wPW^Ru*0
zv at Wmdv{WGx&xXSfMr&eli0k0&K}vDi!Sx6(L|;M#Cpi1 at zx2-SP(yPwogmI*8PRbf
z<;z)h34 at Uza9z=-Aqqa-QKKP8^ZThLPDSdfs-CFxkV|<YN7!Vd9wJzUnctL*wc=cv
zRW6DUbnE=0T=|6|8vlW-;h`8~_RLETKGt(siF-__K|NfZbqLG%WeL at l*b%B8g=WF`
z0pkn-Ha7`II5=K$9wOwR1=-=AtYd3z%;(racY&Qa<lw=WYvSHckBSujx6c1N{P*e?
z{x2_C9E26Y)W}wJkHB+{XC#jW^>Qqs1`pOrhKZIJVQZ729Q3dum*xAiOsK*5>c+`~
z&;w^zOJ>8lCLfaVn_b9+p#}3EICq!Lo63a|nZ>%R6 at BoVSrXBi$mr05$D-t83oWS8
zc#+%|TJV7vwBW<CL$u@<2C31p2VbsTCE*|{Z8%hRt0JyQ;2KYAi;LQLtbi;8TPBnS
z@?5hbrF_q0A+lB0LEulUS8Sh!kL*mAxj_)7rQ<81i~@HYqy0~JwPeeYtH61$!Yk;b
zFQE1KbdRnlz5l at jBFIwu`pqgRNhv`Pz`>~{QqZUfSffY{y!6b&s-Sr3cpzM}Uw_ZR
zA~KLzRYE%2!EmL((geOg1{pfh4qmCM(6!%Qm9<}o3qyY-+d0#-(z?~%`QJae#%n;I
z&zfIp>0}>;{<17BOA};ThG8d(5{4|QUvo1h at P6kIYkT(nfhWI_9`;)+`w7|Hq0Hr&
z#{$d1Cvtdnyek82aL1J-0q45f3&-PXH?X0#dqt!)j?AcpyfTZ?tm=Gx6{-<<u?xyl
ze&OTUh#j!3tUrkrI9tFtkvSI8!w#8fQI_G%P@=$FdC9|;X3cuW+E3*1P%vKiOuQzU
zp~4-qz;`&xgiTS`AD?JP-h*40<%}02JkTZ}K=z9}d7F5H;W0AcjK<2{4GcKS#$Y0z
z)p!l6zkh9CtwJ!uhzCdpZQj|*^IfBQ2O~#>%>ll#mOdCeW+g6Hj7~h^%SH*Co#8o~
z*R)B_2nC6x;j_9~1(Z9&^7XQa^A8rCv<wD$QAsz*-x{1JYP@*o8On5+R3z=nr=ADD
zol`5c8qWrr*fD-%J|Tm<WFg3X0`DyGJ5w|9LzFq#3x{k4rm#(gPOQ~mL3WGbo}D{3
zY0%~c{c_KxZoPV|6Wh>>o$J8C!8T)79qJFDf+#gONbzE^4P010Hx~@7A6tPd8WZcM
zz_)F&==7EGJXk(f>4MSHl{6A$WK+3t(5-Z#EY?A^!_Fk at d0=DTIZHuNT%(^tz6 at 3a
z%EHuL5bO82|CWOLrVIMo(sWuN8|~>rZyC9}&=@O=*OsC3`6`==;hsYCBz}$GEk`+w
z&ayP7ew+i#+Ao7XuQktkSkAWBn)h|GW{NY#n;5ry=tnlnp(6XSe7!6thnCv)-SXLW
zBG%>)Jauqz9)_>WaGd<}wdcEqoBsU^BZb`u`wZf>^E$W;?gHyC3x>(WiTW{)P55`5
z8iS(C3(Kr2cPCsr06Xv=HPwtrt*{v8tSG;MC5IHBt2RC%GP$G0%CMYVk-xL1iTusK
z*zUMNd3-Gpo*sR?!<?l8bB+_VCUKwW6djMl`z6Y%6z}Pa>tT6(=sKAm_-6RTruKZd
z_%&tFl9J#S6U#40O$vNA?zN4l_Fhko(KIZ)xsfHkVPuUqrf~WGwIG8O2XMxf&KnG_
z*H!MFKR$%A?DuZmwdinB4lK-ZAS~kd#(-(9=#8FLYftzs=7~WMORtF|S>=|6nPlz4
zIAPj+Fn090t`+XZ1uRJme`5z$D6a%VV6o_ at 0{4 at t(aw0`i30vuVrMFeTjuJ2w0t68
zyZ&U+nUzc8zy5zLwTo{3X83%&_I$T!dirfy3)5dqzxgYpflrKA53T7hy2`Y0;%J#+
z3XcoP6 at JrCEG8^{VueD54o1>3L5H*I6C<<QEghH2E+KHk(6i11Ya-Rxf^3)a0AQk7
zH&SXPa?4#u#vK8_Y=e;@i$8A?mrlM|{Y+H at o>9U4*!&*rv3$KO(lH>)f&ed0fD&vA
z|Lf+&mt`~jEej*$K}66YH0P at UBg<px-1tVu)+fMdI^ge<ILDfF_~MK>Hbc;`0xBz6
z$pf!5AB-Kc&uhiw!FZqJbC693{oL?AjwHyoVR(#j$v$S{x#7HS${kbnv3y+?Pugj;
zjL9%q9?}jL2w#47Db3)$tx;>@pL_?kCODce)dyoo=Kr(8{ZBGVHulXGhQ5;W|3nCz
z^;|F-5+r)w8|zVSfF-IdNbnTRj*#y>(Nc~{ijCAhhHJNJA7zgKo^?yVTXd|~ilfwz
zw$pWe;||eA(*G>w*?<?jL($~N&GvI@!_9w$r*Tj7VE>|JvVj28GUKA6go;Fbgw4UO
zd++rrL5{O%uyE!}bvzh5`X1K`PX}cSK=0b3ccuKV^!J)fLdy8arn{0B&-nT6VMzal
z^2NLVf`vB;%NNH7oV*X_hgA~YI8P|tBfXmS*?Iec_Is>P1CtYmoCmYLU*lTg0{}0P
z!`Wo at wW^gdb{a0eZ08C#V5?&US-8L)i|g0j06A{d<KGNVZK^Hb41Px)G?b66;j79<
z&khG4dhR?^OxKIR?ufOYZ=|EHE{v|cZjty at 3GEC9;N!_vZFh>A$CEX<WAfScg{Czr
zT@(N<LI$3XVzO!ZlE+;>W$4|N$B1?I%UwP*z1s-4*fFY1O*-<M*I%E;Z4L=nBZ0E_
z`+WRkAZJ5kAb1v>56osPtBD7QwNw`(6B2?GG^NHUR?&(}VqrCr#SJnjsSOKuF^r#B
zEbmd~v15u|qU at O}Yyihd+}Z90{)r)P+$)r2HQv1wZ>wi??qJolkR*-4hE-L^3&*^G
z4P{x8PfEd$TA!D!c00Oi<qimhqH}jF?4`19X>`+&gVyUCN5&&Ocqr1M4@*4RvG?8S
zs=cd6NBGnRi%oo^;_WVM2*+g+eQ_e(-m#~ZVB)Js@&97E50V^;EI43PAqbu0624U=
z(2~B$2BqMKjDs`0f%fNJ{DO{2lCV$=e8DHN2V=*eu+ at q_IfHfhvNfC_EI#gkzDvS~
zNgA$51<>p(@XA>c)yMF48`wBTj7voti75KWPDZ#hYxm^68y7Ge21V%%zEdB3d*-u3
zj93vZ>(s$z6|F at j8;tLU?@soZ-ZZf2oQET&)>$#VLuYh05Ghx|b=hh33)ffOTW!Da
z;FVrNb#u_$!P8&Tg(yL)vRGt3A)>k<lD5H-&6d(;abh*D7}$ZTp)5m at HSFNE)U9o{
zZwv7|f?K4QgENK`<;hv==!<fCjfk^jU%`Y6&r!NimTusg at ug@f{hJLZw$iG at iHM@m
zYd}KE4+?HzK6~nG#TM?EH)UepDT){!mE&JfrgIGGw~Qb>Kcm=KdnP-NVe at t(McF;>
z-~R6(U*Zi$&LnPet at NO-?j5~5i-xb4LC2uQ{5gNJ?0n9>>$^o<=O!)FNm-V_LB_;A
zp+_gt2&aWX>V$;_QKl0M_D6f3I5RQt<(U?i>57wBup*|rz=t<jlN-*$h8PDEbHnB*
zj?*!42-44V;OrmE*Jb&*=i}t>mh^H&!tb<Z9;9bxC{`-+YW}VPA4bQtUl#Z8)@Rq(
zw{viI=*cU}(Oir>${&L*O^Xw)Nm^o13EcAx at AKM8Jo`vIvS5d0iKZn+g22)f?gprN
zG4HM>!ecp%gykdw>>*9>mU#A)c&Kv68Y3-H_!4J4yoKxih4o17pykNMia5JTj;i^M
zhKTo5x9UYJ!#CO_X}ny;J8V4=?^d#?79?2$_n9~}4m_<LV=potzU&P<LgynIXX6TO
z<5D3E^RaxrEW7uL*i at 1g4v&r_saX+QN~%`G_CStBN0<>aJT(TgeCmE6eREmTo6HyS
z!W>v8^GC~@Hkg8p(BUWBnHTncx*K<tMGnq94XoITc$ks{MG9LmOu>;6{G?6#!SN)m
zq(~uglv|qO8A+cYqDkUCK}^ejDj&MRZR0bdy9r#57#mnxJ)<4u%i8ee3Cc!xG_XV!
z`O{@E8q#n^BP$k!*9;pb6Y>B`K()VrY*$Nm9XklzidT at MANs5(C$sBG_CI(ORZ^>+
zH?rZP7J>qb5xo5_YiK?{3q5MTuHZ`e33KxMr3sw6Z1IK_!yhtJwZwX%$%%0pXp0rJ
zgOSGi2pNr6A`X!MKL&%1_j~|E+g?|U*!3PKMo`_y$w$UBcp@|<IonxZ=L;_PQJ*_p
zMt9+f at S<cVp7wRTbh%*E=ou3EjCkiUP#n$&6shY9#qv0zSRW_f*-&g(`H`Q{_!+dl
zkZXvBhFcdKGp^{i-JCoynT<iG<{HndDAF8z#cdF!xQ`FcyzBeuc>VIgp*!tzQ1UA`
zThr0#;tPCs^l#iTn9b6woJxx)a$;^upF~J`ULlbOMp`d}Ij{38mI>Z)0$u4sCdzl*
z`_Ao^2N0;%oS_i34T)*luUK30c@!RqT=Nf20klG9YOoiEtl*+?{^ki&a8d4%t6+ at b
z=<--Yh?+Vvcwkh1a$vkbp8P<sN_cKMU>gx~s%^aV5My3bq<!i4&$;PmIOcMqI5?D>
za0Cq+cY`Bz*h1<;o3U+e%@alsmi7Nppw4EMhF|$t<F%KIG|~6nCi<t#tEk+Q9Pj!n
zJ1!oYRNvvbN8)Y>5vX~01OyvA>9SbH6B#jd#H3Z^Ljc<~r7HNaB&H&}c1g8#S=T2J
zfS?bpN|=N11BKq(>o}UvOEUm2$eqZ>#A%hh8m*K}8XC*0g%%d3+Ngm!mzT<u{KGZO
znO6y*<MJ at cg;!3s=d_wmtWGatB()a1Q^<gm%O&+A;{<qPeOVYQIEJ)~fpc8hWIqRe
zDBxc%uO%7Z at zABt&>=j(BbZ6=g64B+X4LH`zPgO8Vb=KQ%o<$usrL=l?R9V{Xc7-p
zg1hT{5n+JLz|3TqMJ33BwoooRlsW4}stim($w9I*A7-t+<khBN6q;x|Bfgo6YO*uo
zMIBuP2VQgmxi%&E20Cc}yA&EZ_+`-%N_ at eXuifevdpv@zQG~p0XrmXdx11H*H~5*I
zQTdQk*_5GSA85R_tGC6VMS8&hqg&ecyH6FQ5|->V5(2d!SsCm7vhZS1gH>?N^emDY
z1hY_MlNDHvSG2+tRX*btzyEpHF8zKc()h|?oc$|d1 at sd8`v*3b4nsj-{0>cCuV%U&
z!9Nsvjx%APnbDgs6Y=~<;hRD$ul}nMerd2;F<WJ2-IVIf#0zgTu%lU;`#NL@(rxnN
zjS(Aj0MByGW-HzduGaY|)|M)RurNGb4k8NKx7UyhBQRIM#5G;p#6%%L){;5_ESF<m
zN7?E?8;Y~hplZV$00ZQtI!{9<xc;FNw6MrpCW19vR%{NhcFh=X3){T|&bZvF=^0rk
z7^ubN5VD3rL94%H&&56=P3&}#8|5*1B8G&^B9yo_vBpxCSD9drwbtd$#B-lI0dBJ4
z&X;b=%UG2pZlB7It`wM?$VP2yaP{kCJ9u`}fvo}G`@A%kne)TE5JbqOZsNjEjFnZ`
z0!dRZF?tyt9P-+i_R>V9`AIX$^tv6UwVzdW#T-o_G06%<?nmZ{EV at Sv58ag934y6z
z1H=n7de_9s01YihCnVZ_7C8$vr5w%Y(&Wu_ at s%WvDam<?3Gu6ggsr6g(WOrm)k9JP
zDN12fgXB9nkA=8aQE(3 at T<auE3~w-DE6F0j&MuOKkSea`Z5_S9<*WsA0et8&`ITK)
zn5Jj|MokC+0+24buDMS<ZR*vP9Jl3eTqvGWWHZ`OIT1CsI89=u0g8&I;@s~pCXG;(
zixx6t;8G#iT4iHmiA>GKlAW1tVzM5G2Jbi(+ePR4B8WQQ(IZwzY-9HXDXQ8|G^|Zw
zaKYw}+o9Pufh4N6ASPoBa%)G{o9B92w4xL90Shju^E7lS7VXEig8s}*?0?oB+w(PD
zF{g3L7uw3n(qeGEHKTP+4t5?VQ{z3;+5!8c5qZTj28DUqzE++e?vNxnXpw+i!HU0w
z`UU9?`E$$FOM?oFR5&&l*`tqc%2^8vf5v4blX>ZiMEaSG7HM#=TIrFwCH4F=sDn3T
zZK$OFSWK1<q?lWkZ5^u{#ntQ)TQqyFkW!d_Mk~xMI3B+?Le_+WCZg*M6cKD{QZ5Hs
zf=A(@{i=J<t1 at WX3>(O~%a(XWG<wL|YB!>twG}>kE?RU`)Z&Sh71#c@*iLk~k3`6a
zz7LRL_@%KqcqVBd+-zssU7jZUQ1n<6J{MU2)%**W!T$7oHMe%~Bh8{0jb21ohS$Mb
zU2bFVw23b-s6f0k at dG6mJ4`e?GGjT1T^1hgWxA5Gb)~cJ=(kD;#2k(MwUB%3FS%Md
z8Kx$6=Bq_UD;p8+2%6)NoExN(S=SiuLdGX!7pqe%=YM4vJn{L}J0CIK(6<m3qipSD
zmk!w4*=3a|YFA=@Ye85>oL6rqT!u0xku;x|CgVJ0)k?y`f&Em^US;n`MK{gNjjC2Y
zGiU_%CyHH>bcGzXS+sIVF1)f2ez2{x?Mz<Uj22i!Lk=W+UW*-Bo1l8owy4II(gGn~
z1Et^5G(pDQOk6Ix1-Xni4|y^@SRZ*}rFAr)mj<JTn!!Vb-{?iXcG9V)XFUsSl_K##
zp7c6qRJ?N?nUU#A2Q9Fi@<tY$r)|eF=e?Y&8+W9sRc?~eJKH6rdG76WYlimM*ke&m
zfz-yos6O&4Kw_%<)us$zjjIK%xLcbawSHOn!OZi<Yz2WryX{p6rYbr!TN~Nv;J0ii
zvN!gb8<Pez<Xak!i7AZmmAay;qvvYd=}D)HDO;s#C=k~xwIeHAv%M at V&C~lLdwa~}
zxg*)=WU%%qM|PoEcw(1puN%nsvpDoS89ci-798|uOj8H$-#=jjo;Ge?;5<jzQ>T9v
zM;4GO$``W6dX0t%CZ%dv446|b&Gk45Id3L`$IM@=3%g;@t(4S)zt7ATo1;-UOD?-y
zhEDXl%b|sZ)r(lnsDhh$Ox$%Fq@){yNQ_^K8#o*6#|cx5nd`EODJuMkv#o7k)IA%2
zS96^-ADTi%#KSMl)U-gz__b;!kfS5GgDgcO&vr#@M at n}*Q5Mle5s}O*N7_%Gg(x5R
zi!3y;A#6=2&n~MsKAM^53kwd*%v_fs#~Y at g?F4q(sV9X4vIPzkDTs~^8b39$_ob<>
zizfgal8snUODO%kOIMW9gpMp(k*MX!JYgbb+oGkaZ}N`9YAm&HwCGtSO~Hj%<URx!
zy(-t8&pM9g^U|32UussC#+2i#?l}nipuuR4smhO9H+Pid>O{TOucr(szk{<a)^50k
z2}_f~G4*iISXK`n%vde5D1=GN^r{`0SfW=IqY|>ZSxx*xFZLtHF<b!?!G_h<=-nlc
zHTQ|9O})F)CZG>CTPd>1y{f2$_{<7uiAb4EWN&U{^q~!65DB)~AfwkB;a<x|MlDs9
z%tlfQJukc=>jU}JEd$;Ne8`PA2BePctz_)pwl$*;wSsXCa=$}+nr)wosaFvsRkW*_
z-el{@JTOvwS<I>v^9BtF?K~Y_q;xT|`Eby?ms~8=un!2{{#DPI`E~`;ok4kHHd}H}
z-Ws=2Yb`cqlhpxC`))e0-x??FYT#o87X0?y%FE{MPYleOK-lUUKJyJOQqdAtk^ktf
zmMlqD9X5Zf=oR$gV}9%DY1aOy&$0wTRMj2jkrM*2Wm|68<%SR-KP=d^dYn}u`~J&<
z4}ZR&#KT>Qc at EyE({djMd1^09_uBMa5xAn+Iz~gO7~wi$3y!;GfPt`-Sg^P}As6cS
z8{f~-f3Vzd6L`WAjtq6faYt2l9HrDThqyY}5#11-0T}FboY4CZPVo@!kj3HwgJY`W
z1nKU$`1n-U@>uR2snBAJPjK1-VsL_s#zt6;4tf6mT!tqYZ_j^To0hk}FM56+104@>
zuq|<mS&0_|F_1O>j!Z!fSEFpZB?=?nk-4Jb_rhbHm&&rgxjNk)jmPoqIdDxUy0V}=
z19uc8$IZwG)Bla?41{TnSVRtlLKOf;y{VGi!jDI{<)^zSKK+$Yn{q006pZn(doz>x
z1ZUTK2};{*jmKuRJ1b<la=>+NPV1WmrRrpb!BNbcjOTmrjUo!#lT>c0^vjwn78rg(
z{3H0t<1UFl6kqrK;*KfiQ?+jFOkYP7$kG}wF*2E6I#r at U_k#I*Lm`z11hRoY<Y14n
z0kP!&O=Dp{acI!w1~!nB7R}q;(8yWDhDW5zZ{$H~S~7M}lfx at x1w@NbcX3Kyxq at rw
zS3cob?W+D2#bfcaF$v-7l`EFwgYgX4K+^LmdC^ibpOOf%Fy^{t#B&dNe5i4doQZ#1
zoY(yR+cA56uXGJ{4MtC`sQf~etAI7d`AxRvb6K93zuEe%iJ;D+adXXlEc8wp&zkTS
z3x{6bgS(DLmTzWMVKfo0SdGN0q3RG+{%>7T&YO9QQO;eJM(p1B;VLcpujY|7s|pRN
zw{kyahIblG3Bvd;p}~0PT{4t!+b^{I^i&j)0cnoX$O8CvSrFmy at W3Ebf3<j#V*{Rk
z&-}ZEU;g|!E6$%@FHmcq^N;16Hqkv^28&W617M3%>>OMH2Pz35JMx6=<rlz$*;qg-
zG`j_^nJ;ea$!@VhOQiM0guoLDYOG`KPeaQ`+|Uavda~nbGjMO^g^fM=vZQ!|e<6CD
z>pS#hT%Zxxv3Fz$bhjh~K3)l2{x13;L52|i3pdV?A7S`hh7*r(zQ5PF>||HQcTt38
zq4TYeV~LA|b0t;b?8<Kpwq;yBgonp5(LFh2g^PCh{laxUkEMm*Y$2K)4jk<;Md$RR
z(uuHoX#y1-&qT^*BPVvR&GL_bnhQ!q*w3yc4TL29Sr5J)O3P1gk<XZ5-hAGcL*L~Y
zxypZ7_O~@R{$inDxeKcNH-kd;Z24w*BL2Q_ykV8U{YhMk278N!g;0(AnaA=xs&5ZJ
zhMk6yw+q6PSr(GYaZCJPHOwtTQE3nh5d2JhLy*>#rgkS$Gc3$%Vg at qOaWOHcjTbi7
z;meYt8Sn);F$7H<S(%wtcj|G88od{|lH3KF!5=y2l+X8u)R-_Cn!$0N+>t;%xM3($
zZ9kjYU%bt8Md(4tjVI2Kx5ayf=@A|M=!q-V)bY(yqCPJw23#wW$`u^KyCijSNJPi`
zjS+V$h6Sk`hM+y-yDJP7gJa7oL3 at 2I^i;x^9G9Yp>%?5PWA=_nUs%F5-pMPgPe#Re
zJVrSfJ5UPjSU#8KdHI{HpVzKV&4A0Nax7$PU(cFguU-?P68=*d2UP<+Y^;Q{as`Ta
z)IF$%2rJt}>e|pE`J8);ac+}cp$5MnyxIC#Mp4F?3L!Vt-~r1ZH{_ud;Ty85+F%5l
zI$=@9ZO_p1(^nilhD4&j)X({PS*&%*+z~jN^bJlnkmYDBWV>5B)LKjwEpY2pIMD-y
zsVFCU+*#pO0qypD!TUJc!*zz2`w;&77XB8LwsXq|PpPbJvA?Bp2ftwFOrGHZSVKE_
z3*T8NoOw&Mo_4*1_}~AYmp&`#iT#D`tLKdE&3%jQ?S0F4Jmg(;&MQLO;$)-1oRx=|
z285CL$#w>WHo0MB&NdcO)k0>ScLmgd(AV=nMA5w+RXx8BaL?JguHa>Tj^~CO-oe?H
z2K974;H5Y>9l>zswkZP_1|^oJ8o~0SnE&v}mh=68oBDrE`Kasr$IUSy;07e|c6-~Q
zy~6M>l4mjbVnA9Ensvwq%ZHXk5`}_voQ*!|y#-GD8-vbtOCk+>Odykr$U>?*nzIOT
z$Q*Jx|7~M`JqNZ$jQ4ZBWqCaI`QSOG(!pLhcWu~)G=`p(%Wnqfho(JDv%gzP%#xqT
zgowls!?VXVLn^;oo};zt7ej9IZLnaPD~%l?IxNdUv$XwQqx)m_gi9I!gpv>cmwGTa
zto&ZF))3wiCe(-t3UJa3 at e7J*dQC-GlVHkCJ8q&y<!(NJ+PcXHOBpx$+%iO#ARln4
z5BVJToo&HAHyr+ed%#Nh5h&Em=APrCa?O8p+aJ$?(<m?QE%%IF+;iOQ;@*Sv_S7~g
zytwh|zgixa_^w^qzgZr#Estvd)pGADWBzKnsoz at v56foYV<82XtFQS`a8Vmx6!hz=
zZUzP6+0q||Ij*W=;vgckUJKgTBvqWP-y94kJQNI~%!h)9T!(_+=tc^<er&9w5G!9V
zOGZvO9ue8XQPOc6%=$5T^Ae+C1OiudoQ?9Lf$}XY--xlpM=UF^6*eR$P at x^yqA%8|
z9U+~zyl|XMw<vVik{mf{Km$gBES8Z$kHtT-wl3l|im`ztbaq at T%DCe+bPZ8%HQplR
zXSArom$rE at eUs|CR=96wzP<p#&n}trcIIrl!;A%16^{ObWj1ZtmOA-GOY;w9l?ASi
zCo~QyI8)DVT9Fr@*%r at 8l{-3xy}xS>UaHGcbMcHGWObY<?fTe`8vJDFb_Bfe1ED|Q
zN8=Sn-IS<0bS%0y^MomeB#Mj0K at NsQ1(V_gk8WedD4P(%b?4VM*kVSmAsIKxxs+Kd
z`eA8OHR-%_E>xe>h)d!I=y+}@lu%0?t&3G5Ri4nYq~&NQ4^(I}SB%N3kt+$f%nlZx
z=DJpRETt at RCSB@OF`JuEt;(Y8q^@wBs`8tcZkw_)V50ocQ0F&GmtKwVYf6RdS`+1@
zHkCJiO|2N6BuxrN6fHb-tL(WGe)RfU(W{~%%C#zGkv2(9?%yP>JHTzeu-SJ1wp8sf
zMYQy(vP6zS at hkszYF33niUckSV4q@T(T-_k4T2so)h)vV at I>JkPj+UF7im`vHOG_`
z at upN*J7C7#T1E;qrS}{Pu&UVTn?xsF6~A5bn~Kcc6hbJs7GrOG)k%Oxf!r>~@_AW$
z$JLST65#L>Fh6UVIq6#y7gRVNc$aASpw&~vHLf*z1?4f^>5k9B=rIkU;^4YOBoD4i
zbmIb+OSCh7p!Iw(H;gh~E2i4p3RYk$)sd=Q&6ALp3{N|*O*mNMzAN-yQ9*6N!EO0m
zmJ)i8mYRlIoW)mi=ZYRr$Ap^IB)e`tPaExj_!3i_?RslFm^*U67F3qD=(5CJ|F6^(
zu{v3oN%$&R>oKk4g{Nihpv5C&fB1oVWu+g%EEbu;CKbt$F at D3O0%wed^?I=4waT?Z
zg)Ryn<5hOu<{%1RCt7+`_Ra0+6*o-vY`DnJ;3Tcde$6jgvWf{m%FzH-Gw!|f9?DVC
zQsxh1bUIxz6QNl?m>aZyFG!}EYRs-(Lwnw?AM&+L<)3cI?ChHG at PvOq9z}sT)KE&)
z_Agq}67S&e;nxx`qXi9bO(Ky<GyYF^m1NhJgRpt6;;-Nzceq(kO_Tjk3n6iv<kct<
z&s^IeK=zYL?qNrpUP)vwNALW*&jsNy|4MS^@597&qkk9k*Pe2qgn`Vev4V2DYfRpF
z^p+m&^;YoP at 3B8x?w3k>eX^`|WHF88-<I at R_n7`+xpz;m-<BScep?1Y2+Zp17gQs!
z87Nb0YBBO0FSRO+LPWku64xsio%5y`Lpd+S+5 at jtxK}dPNtMh~?5!3&_=R)Ug+-8j
zW5fzjNZ5#*TH#qqsV1R)$ic1-TrduRr&M%H2ga9{uV2g#woiXVEoKUr{-!0gOg@^z
zQuK^MC>>8Nz~707n?Av(2rPvvZlb&#OVq6Z)cZhOOjVh`3WR2xCH}Wf3Llak7EDpc
zdlPp=^MRH8+aT8A?5%&a+^lo2V;?P)fwYX>KU$t%mj?V{xvL<(K3S^mAC?jQ{WztS
zfEAF at -%9+E05hs`gf!km)BheOAPSh6DH!n*xL24^=2!k?FG3cNnaPe1f>e1l;icbM
zQ$J`%>Up!9?HUl at w2aH}6^5}=;etplgcNl*ai3L~S8>ZV>1M2GQqhQ&!zvj*m(~~Q
z+4$YXss!=Gh;gj_)u`Pt7Y}WiZjNKBW8xS;Fw|4~-14C1Vv1WhD1TdSR;Jf)i?hku
zP0OsBkAr(J)5~TA+<L8 at k#|k at jl*E{n|l$fd1FPhkJpO3i<|P1r<B9c4hr`;`aQ}y
zQ|{QR9G)Z~F(4!;xwiA+`(+up;T%+|A(LC+)in*N1SayM7)KGflrYw-1uuH6Obm~H
zYelVS=kWn=quX9v_ at hB{frr3wu8%|B7}uZ&EjSE4c1lBS$vq(OmJZcY8=gP+8KwNL
zTU^@kx at WG)IOG>HQuh`a%REHJIuH5I20do&ul%INb=2af#!W`yAx66&ru;-NYL;+x
zT(4t2?iG-6n0q~cw>lo~J#_5j`yRKs9w%^I=6%3~_nmHwp~~U|TSCILgJgqUe95Q6
z;hCmH9Tq+aMxBo<w#V;?fPP1bM2tk~E6k>+VkLt!>ZZ&-vk-6Ac_?z!S&*6iclXzv
zx-27g!NU^4bf|3MsTQ~r_r`3vMO|`Wk~m&l at kjFoR#P- at DD+s(ROS{d=E}CrJ!dAA
z651`vp%pV``!h(`=+Q^JFg=>iohz!^V>}Ayk_zK!fX9+Na0>*E<E0mgVQ4s>$>Xu)
zF^%^a5vvu0Ct|a>$5cDZSS_j~L=&|gn0vICFgLE}+GEaF%3S-IeYD(3ye-kx11pK#
zwy8vVuiB=m<VNG=n`+J=JssD~p~<0+b+u~Xax^P-_o7joIdt8-`Xh()>UYeL>*hIL
zIh>T3j}@k42Y(!o<k6Btzutgcpy`Y{a8!0q=dJa$+ at XYuS|2U<>`kxV7QRhsX;sq~
zw8P29(EQcWm$ay5c<ivdSDk(J`RLvAuQtu*j%Ve1EI^91f>dHt#eCQLluL&hH8sJ#
zND-S#$4Ig&Uwe}hSsy3xc0IRW<9kOt<Ox)jr9Do#Bk<2VpcAauiqj-9a2Ri4MK#AG
zouuKy6uLT`XE^SB<5tt**#kpSSdVfX9TbheXc*(`vV1)(J1F+HfQtcJz=^^EF2swq
z?v{=BPDclwv0|e#93S*W;KAPy`ywp<seYo20oN2>+;V~;jw?$F7H|X>l$14217IC8
zMy)VCdK~*+fkqR!@lYktz_w^Ef+zPVXp4?FQi5Y+Z^yw?T$61P7T$A%1p$c{?19%S
zQjn?)C7NPD?hvy3f$dy7gyqgx{R?UO+i>UaGFa!Sy727Wv^SlSEfJP#${#P@&Q$&u
z at igVn<k5Ol0(Y#a=x~uh-n_Q at N}x-9RK%6Q;@?`2^b`;3c_py0dp=goI5!e#fh{?s
z_5E;%f|=?#CJ#<Mi0cwd*%U9!70cmoO3bkj7JrQDp_*QwER9VOXDK{fkkD}q8{ng}
z8>u$f6mh%F+gas`tq2CuBVKl4MzksiT;Vxc!sJrl496H+A1VcBU{dXHgSJSMIh3H0
zWZjhxZIc#RA3d;FR8b(<7TwbF4lKF8*W-jJ+Wxu&`oQxJou!9QqANPCDtmIGi-};-
z{&P3DP1X6plWp-w3uIgLA=d7qLR&OGDIZmJTbe&3X|X6?w at h5$aT7*;IgT at TOegN`
zmco6a=Q|GV23!NSE&A;thgSK?!u7np!`1 at F90V>5xKE3yDku&lb%ZDmj8qxM$BpR`
zPl(5g-f|%9z;zAXV#p(-)tQngCx`J4c;GdfLY|g`PXlijUeO`T<N&EBuMtnljxowZ
zHDd$nhj<kAxY_a=Mvr*sncjE6C;|jVJ at A-9TZ7(YM&x4URGWY9eD5fOfB$(}mZ$6M
zW!cIPz8-ipKQ=WmM%On?bzh1&veh?@9z#`L_L4`RU0qHjIl_Zq2)P<v at w%DzsOYG{
z67|U_Y;eRb%;4>@UMto$Jjnq&*=dhF#>{?R#hRhvNz&xCO46+6L|03^Eu#%t;wcav
zN>sF^#>!J<FF5&8^&e|Iwgz~-TH>DT!tcnKa@>}%VmpeuFdwVPS0Cy>jP{hw7?ocL
zIfj08u|$KfZGKXzICMW6YIl0$F$Rjn`fNp;<L`l|YUACk-mM7({rg2s405g+TNQ*S
zD`?e8|8_`{APex$iaJLtCP}a-OQ<OwOCmsu6X_V-qlTIpe7XX6=4UK^vCORVQP|(k
z5sk2y<9+Of*GiAHP<-M6%4kIM1wQ=Zuq3z9p>J`!u>T`taV<67JA*|XkSjbiCXe-G
zjc*~n<iR|$Y<igXh^hV~LI1|g at lG_=COr|~FAFFB=0hp^Yzy4>e9aRNY|)g8g7L7K
zn*RuB(F2L$;GcRgs9U{1!VOC0)Y~Fkbg~#pq~|h*H!8{SPR$u7hcrOJe$k>ad0V!!
z9<Ni!tO^g`<Ta|oHzeg2Ifzh%mhoSBsvdI?54d?@IxJ1bT(S5213@@!Q5DK^y3Vj8
z*fpoxd_f3x#XiSeM8<LD8DioZNgmYZD- at O_yD|D(tT~6*UW4UQ#4GHkK{@C#3k$4(
zk+^rQ*C3_Gs4B5TkKhhUFcg>v(o7|plqlM at 9%h)4a<(ldXQ>UKewbobkn{6!#Z+UM
z$qC_gk`pp)Z81}bN1yNyHoddNQ at 2cM&yan7s4i_fh)<Oata+#-vEO$Uhcrt%soh%6
z61!^QDX^D1M-B%Mw%y}Iq&n-h;%FFHC1;98^VrF%rqRoZw$;5HLn))gg}XI*&;kM5
zqFOe6UzV<vfj`)!>aAra=1C!3<#VK}W8~r at shXo-`Bn3Ews-Pqy%ux{^(x}!%c~?)
zQ<o=G%Vx?$k3R4o8UC~^d9Z$*MUx(NrE<TTfFzu{MDJX{&W|Hc(K4GrYC_~ZuGu-`
z2802^!0H-V3cHb)LrvqP$}GzFOck2h3V{U6AOm{QOkB#ZN~KC}`)M_qS;BYI4 at UnO
z3o$BY35CR0K+Jcy^c4PJx8s)2R4{Sk0ZLdR+HNR%798B{_}@bu6?mx3g>lZ~U3<S)
z3^h;+RWNp|@lScQrWPAw3S?6UjcU2^?oA%F;PF<)?7ipzScbQ_ub0;k%P2t^TH<N;
z+j4tdQT=4e-EXg-mK~9PS}<bHA7W{i#9JAy87b+B8O--kOTolz=tyEx24pUn&S8w?
zYB{_*@zVJFkL at bSj%^2FTX`$^#~p6glWDU5=|@Q1CaF;!QQ&LSiYpeoi_{qJaB7mC
z8Tk=;Bg_OzDv=s>2^(?Kt at _H8>Q(VR%)zcpBEjKI9XMJVWEw;A{U@=%BiWl58B3=5
zIY{>E;oX<y`z49R5m?jwU`#k}U9*_f6p~Gig+g%5hPI-+07uCOB{5ly!{<fwaBM1o
zfn~$-)HgeOrc2gQ7>pW6tglCrHh22E at K?OGmHyJ`$@uU-$JX^tPHUIM{c%r>H^*B=
z7flgZoMMtgz at JK%$rOG_u%uD4#DOc~;dl<M7>oBBC)>@`sXbcjBzK9IB-JD?qg|NZ
znGuuJ at CYa+%O);I-nx3$&IZz$U|DByW5OLvBlRVK6|C*t6A0%owH7vS<b($PXiE|1
zkV6hc{Q9}D;-zs-4UbQ28t;r3hi0?%(x!S0<VR{_vOVCqy!y<2M#g3ixfRs_$<o~9
zp;o)-0Yg>zsM2;`TFj^ph9*aKD^qE at F04?Uw}vG>7%Z>8wZ+z&u9UO)rbgAaxm2I3
zSG?lu&%0RpzGu~QUHvB{MT85IZ%VqJ7q1`8rr<updJM)ZzJ#?^F_ at vS4ntNJVI2vn
zZhJld9~w5nk{$OXV;qz&;n;Ht*stSS#dM4(6j1_DT3X~DP`pXwRow?d|0ubKQ(AqJ
zfH_f8m7i_!+g-e`4?aeb?`Py|r&#jf<)<QxkA(B;jpfd_!WpW7=oEvSW#G{FfECSe
zq%E*m_rRAQK_6CS at k|4xhSlj!!QD}qaX%qx*cr->MGm;)BEWtDVE6`b;#eQ0-UkjP
zUaP<xV>)mpM#P0_VYXfx9Z$d|oYVm~bmxMy=(4DVlIGq4jx2QyO8UerX2vC{-kmn0
zYITsCf0T^Kj;Gac35we!8F2Im$!#UKew5_bZ>wJte+69qmTa#MVtQ(MpA0<t?zx)Y
zJy8FU6#8~-V(TNYHJ&)u9gRte_d8&sPDfAu*++h0RerKpUTGbEpcjVX)Nx at Y2zuA0
zfeaF^#8p at 7omX<n;WN822QjAr=O)~Zc&9<8F(luA5}V1sNVVMKdo(5c!qp`Cen>Ep
zPDs+~ujICJNmb4t9egGI(YYabWQ1(~O40~d_Q1DwmBLR*6yFk+;BhtKHUp1tdB#`h
z_lOt9bq|HQRnOf5$6_fA3vaM<Jv6+*UL_yUY+s(G!C*Yg9HG$mxb6%b3nz+qY#EfL
zaK)Y0e at daTjj%JmGe|TfTL!z#(AYzja>k9Tlj*Y4LXufF&op9iG+wHO_v<*iR6nfH
zzWC0$Rm11 at 6CoX2_jvvv+ZiC^GAw&bmA)M+^k}SJ!<8C+FfbA73PwF;L5VZ2#w^17
z?Uw|DDV~+-z at 8GNhMJzlW;(O!RkhHdnsDbWkVlE>mvx>RJ3N|aM)bpzey6k2lbx4Z
zgT8KH-;S-maYjoL#Iy1ny)*6SUi`*n&RI(f^tY=|`6V|Enw%TY5LUR#d1=&h_bEDt
zu#GI7nXONir5S at oEnHoj`ep`rNigF7sT1L!j1-<wGQ6wvKpRSk#WrV)ID!p)UI`(|
z_n-a{J)=1VTsgtfGFl7vb2p<_N$NZRAajs-sP?=H>?yg7u!fEg0&k2coQKT^iHExC
z)4^lzuGg>wy=JBBbYtH4GNki(5?|>vf;j}f_!EM%_a*tJMD=sr%y%7cU`y2 at jFbSb
zQ5`PX#;#C&7X at Cb@#wC=#V$+>Tl=LkZ0egkaMps at k4u`$1<kI3+R$Jl_1oa$hvH!(
zrsQ@!sI+|$JY1Nke3FzELknM~pcTF~8A>~PiTY7b=a^arHX-1t;fZgA^KK|_?)FkR
zJ!4-L4_)%|CcH+8*AOB&q~Y7g6?EJnTFpBPm>AwWT7Rbh5+k|XwJwU%OoF}CJsMu-
zSfyJ}z~G5dWORi~ibfn*mgA{;gk=br5yH at rfz_nAR2W^Oe(@81h(z0xMbhx_-SR#y
z?CAqs`i<#|U7s4$`;U%17I>_wS5#ThQzs at 4a2xaPSPwkUmPJbTW_;S_JSuTZKXG!(
z){y}kIhiNV4EBK9HsYo9A2q+RHK|8 at gS%TykG2E1!2&X?a at F7^Y%zLs at c=t?RfIdJ
zKt|(|%=JtORNZ7iG0dVWJ3qQ-*N{6pV|S&VEY{A^tE6cn{3E|Qa{&Q$LrxrG+FR9_
zt=F?Uv%R*i9MNcQ{6e#JVOoI9JT*!at_;`C9<WW$UQ at TUt)!8L3T`OCXZ8%JJORn~
zLsFA`BgnZ%6{Vt`tI(OMs$<Jj&s3{WJ=7|!7`8m&v|rvy4a at ek7_lXqGRQh3V%cu!
z at iWxm7X0h1bcmoSPj*nAXo+AMj+<I!HA1Ve5W56S7S54DR2b5x*b7fx>ea2@%?Whz
z=arivNz_>yb!`r{A3|fI#107DGcowp)~H^mhH{~PnN0S&GA+(Hs$&LlCt=u!Rm<;}
zt7unYe>+2YBto~b!9DP5*%(q{o0*n-<=C`XXFuo_?vPub+Ct5(l2u>Ta)I^ec3v7|
z%A!9qCYHv1we>0nr#T>s2deiwHeVPw-5c3H*E;k=N!5l0rrF_k?Ni>DfNQR3GoI#>
zG9(G_xfiD<7MP*qecFX_Q>;e)rGZM~d^v%$wSyPZq8>H-=su2<o<{xLc*z@*M7Lm<
z^v%#d3zB8rHoqk;UQLOOPlC%Pefm+7pT3OV0%YJCZ@~tC4 at d{B2re)KH&@exO%}7z
zsg{I1QqJYdj&(;NSAb3hvFJ`0WB*~s<`*)ld*z)lN3SIWfj{TMN{!q?pb^QlbOLeH
zTGM+bQ_DIrreE(W3|~M3Po1#SB2!om{8v&3uj)<g&2KP+SoNy*NXhq0g2oWok}s^l
zO$D~tX&_0CfmYVhe6=Q_DFbV<vr=Ud;|5L#i*#(J_hNK7o|b#tkj2WvFVxuUUJmiH
zQrdG_bV=2+mKv82(Lo(s(JpvoFmv~_6$(q$W|-ZM_Z(NZqs3OP7!&v*sm?hlSwpOG
z$04&&p>*Dg4GoQ^>Cj%)YQV1I9d@(Gc<Ie5>6=;VL&M{tj4bH<9mGJsx|-EiTa8BT
zcvboaPrfj+;w)LD#LoK16PQV8r|}I9UeFh1#T299rA(6=NdSB_hchXfkGlTQaM$d0
z?<#PexL2#`sy%YG`}fT5g>Lb{{qpTI{}~?ZH&gwQgxqvu<HR*IDEH*4eO>E{?k(<A
z3j-uaOgcXoC}4$azBNX+<ii5%BF|WL<w`kw_ob2~Z=GxYdzLI7@%86fQT(;L8<5ZV
z#Y??=pM43wUxH~Vh~#wvmMX_VsU16$3m7HkkV}<I*5U~fL*SUU-P3#qo<<ASwF_+X
z#8IeV(K|Xjf#XpRF_)@}I;H^0?hyN4V603SNl_leFsQ1@)Tj|yKHCD at n0iH(MUPqC
zV-^Ii)Yz*%@bHN3w2%a)7dYNIV)|K3!4cTFRN<?Yk~wv&nBC*QWyEXogkAF+r_mx7
zw|Hp}e6Uo(F~M0JbE$$eC0LB!8ax2K<_@=cN6Bbh5-wE_Nu3PniOKUn-PMw1L8=1h
zZxy|QJ_;(jo|@MF#}9}g(_2+Nx+l13BA)=J7b`w`6#omBs*ofbP47`Sk-MPd(GXG4
z>ddW at Nt0>hk{D|`3*9lSp0r^0=UMzh5_9IrBE}a~?7=u8nMJQgJH#E~Itw=p6m=vG
z-!)>X%A}!2EL9OczDluFg(P@`lJ5_Rp(n>J9k=erAPel+f<%j*ARu<CFqBtpmP6mf
z458Kqpt#F9rLiWlAz)_w2G*Ah*rE{;FwMO&&5ri%xZ?t2mZ(nvFk%HA1vcP06Vl|0
zuL~B8RO%};K-&DkjV66i)h9C at Y*deA<PHLzJvS?Akb3|pvSjK3*2;<;!(1TH7ex)P
zh69~=TCrP<M5tnf?+9!du~J3&SoBZHn&A^VkVS?9jHUB}U5XS8Y<V`4%=qfPp}!Z%
zau-pZ38FH*pyf8?u%UE>Y#W$QCij(wcMo8_vqfuz$b7*k2Ri^iar(_62u!Y1efbV5
zccYmc-kxy2g5}f;36>$v2|w^8?~e?o=g#Tu6Y!O1&*E2RDs<6{<%9HI90xqEG`%#&
z;3r}=a4dZ4nujN<m+Y8f95+Eq_3Ruko=172Bpd%DAI`=HdPC`Te>Fd_Ac=`NO&FWC
zvl8ndPt}1zg=P8wTwo!aFlZex=k8_D7M8owE#%gd4SMp4!1SwrYLpE*|M&Tru<53W
z(Jmy4*cIj2!3~J^OrHO`;=i&Nd|x^9Tk=QJ6bHN)D-Xq|=|5%>EkS3Q+&ldDELx(*
z-qDdpbk`JSRsAiK4n1RC8s4v~bqoY~DQ*zVVi6?R&}A^~*x1kdz>5)hCE7bQ4sbTm
z$TqTsR-P`>WmIhjy=bAs4bA$4@$A0$hlVoKO%EI;#BYpQ3Q2w8Xd at 5&^D{P}0pqx_
zJgFt)WpFM8-?w049KX)|mb{0o<I}30_m-q3Ntu&LoRM5}0*|v3uZ{PclZK{bW=k at k
zs4X$*W+lB9{>pU381rgaW=5<B2^YRFword&GjK_)RDm1xXO{Z%Aa`I{JW-O<jU|9|
zy(P233KXZ~dGOMWuPnhk_9{Epp(F$6b}!hq6?kiZFisp at mxhtk;)Vsxmu*}0W*>)E
z!T+7#JlXa<%mSuuByY=AG$jisWFupv=O!lI$Kb|@HL`cU+ at 6dbKk&Rx)KFL6v-4k)
zpsqW+eoK&Vxl2j&a;P05QqTom_r+G1Ahx}@=Xh=4%*^h8a-l?v+lkryV^03c1DF=0
z!{NXvM$86woFC3di#zVly9sXp1n@}2<CEQF`($Gm3pj3=7tR<Lj<#fVqRkKQ?99!-
zBtc{HL!y1>y+^Q^ND`c5twBim9k8rZUUqlKWU%B+e<!!Z*hl&DK}q(Y!wEkq5hpsQ
z1)Ft31pYSJ^ya#p;ojzQTcmk%?7KDAB#92hr^Yp7cRBwui-V6NCz{|u%#Cl3_$v|e
zNAh^{$+X`Rrdp(<mrbh<F)|-Z5-Y3QCNb2*wiPWxgmXd6TiMuL0 at 959lhn{7Pud4=
zHBf2xDe1Xlyc)61Oy;X3o^|33o){d`Mr at Cc<sboL?+V-xZkW1wq9n&D{5vJWa(pE^
zD9JlUIbC4IVi;E$v0Kf+mI{Zdu?(*1%^nQb2)kuza8|Vjh&@kp6reA4(1wv3Yx5PJ
zV=wl2jb0}x>54lSmzgY)z>OtSpTN)+H3gGUL2!LojLk&1)f)sFFsKh)KWI>!++<Yg
zr8BWEjfvoHE-M30v%?}k)Snv$PAUwpXPQX4e3_QMa0)`;rJ>$Wl<R|^QTdVx?-v2q
zfiTMg4~-{1wQ+ccf*NMOd6*}Yqx5>7pg3U6PV6L{W8=-Miu0`i(xJiaO-Y6axO1}&
zj4&v_Q5s{j0U0wzi(o5owkcs<9uCv<ps at MMNXD=K-4ekJ6-T!HknD_Bcn|Tn$-((a
zH!K!0fxwJ0A at Pm~dT6+F4rbJn2jfKRa%s4;_>dg6!=0PMIVd?CZd`xh{)#a53rj2a
zm!z}MVNsJoIzmcWr8GV`vi-myE^C_%*HILkNiE5zDPfg$qejQ0h2J3Khg%jB+3c_`
zk>{3$fblQ!C~{ecrO|NbX6svm8#w%XWGlXtm6(2c$zL)FKbt|$;u32gXN{gSv&5ro
zV2P(WZlEm9M09gH$$i1wVGt*<nCc`doe&p{bsmfZ($9xRBl$OEE~lYU at 3Nv@%fGEU
z*pUm5TwQpeF=;W*xnzj_hosu)d+MjehiR|9 at 3g#UkNGWmPnApmlGNAVQ$Hmm-TWz$
zEX5dt at XXj{5;B at 5bZb|nZEJ9A=e8G9RN at UsM(h6!#E!uwa1BG2P<zcW^$E3_eHLTO
z1u{9vLvQQBOpd1~3e$(U6Yp9u%cwosh9{nJdUa8x*Wo-8Rr~dk#3A|qmDZSreDY&A
z=4ig(yaoA{U_AG{lAZ0xai45Q2F#p^)#ocuOfC*R7B8t$dgfx2cocb^I?>S!bW3W)
zBAL07b-r`%0_Ap|s9upPq+{VII2%sz!rAH*t<Our{^jwVp!&$bknNJSprEmYIi93=
z$%->?rEDZkd1A05_Jt3Ofmdf<IsEie2%z7R0gO$={d(*Z&+(iXcd&fh9Qv2wjovHS
z8&)-r)#u==jU3Q847sEqMlW8zxSB=u6qub}1+j1m`?Btl8hgLvMq(Ks(eu at E^(%VI
zd97c;ac-IN5x#{P?p4r-%p|ce-h(sXa;C?XnnV8dbY(yjZDYUeaBfK+Uxu~wFTqP{
z?=8P2bLD>Lb~Kj9%F=ba6i-8GyXBKZPcP at _<|t**m~`K1z>5JmtxjwPpfpa|wHAV0
za}isydD`L*6KKf6H_%wkXXOe=rR(e*2?q+I3d9C(*qlLkt3*1C8F_+}7i`=~>Gvyk
z&OWz>F{Zntq&G`$&BYUyisMA$6}`=zcV9fxA74KSFga0sx;cl4m87V?imvlWzCR?x
zosjr&<A}FutfuHw-O^nl;mF^d$pXvZmg5swVCA;Q=ZEC55k=KF9-BQNrX|Od8>L~0
zbjdpGO${2m_Sl0Pj_wD4<y$fSlt$-_<~PJxsGY3l`0&8uKDei)f(h^uO}rcW#{qqW
zMC6fte at LcoO4bIE1^YUj0}9C(j`h^|CA?H7i7xh)d<Vm*@a8EZ#EKT)Qv1-L4I?+A
z<D^Dck&=#65=W{Wc#mfp(xN9ty?7quiIRY@;|6v$B;&DK0#4-w`=V`Sgs;Mm_`Q(f
zT35|Pc!U+<VMKILrK^{tp1lEn+T_((74KZP$Fq0#BRIp at Fh-U`=kV$+B9_Czovm=;
zQf1{UT3gtCsu?3oYV`|NM568oGhAnXXbfS)KPWJ%ZfxaCb`Vi0H1?ck>z}(~;~8H+
z--Xg2nUU`}q%lz1#rcomX{eWEM_%YNlAf~xx%xFwtq$%<9)mMeg9^Ek1gz#MIl8Mp
z4OgRO2PRXFm|-<$SN1;apCM^A3_-)*?ip~s%@z8iyiEnItch;wSmwUFsY|-9x0^a{
zj9~b{*Rb}{O&`hQNJ-QF5Inu}y5+Zo-88<d<L#zl*Rr>p#!LRseYIrQlB2-6S8-SH
zjy?#X_4w4x?m^d}w_gE)GL`n-K=tw9I!N^4BM6F|-PCQBdUsRcVeNQRJv!j|>UvP4
zTf-{=S6CzNJzrgBuUs#L`M&eYV>}Lg^`U3xF&WX;U&j#IHHO-22nCkC#D`GeF6m;H
zu<leMB~e#3y3sXbI?f?8r_c_Q&N;QaNm-a9F<?+9&OsCsDU`${3f!|}#3Xv*YZARA
z*PI7Q+3fF^WQYD<^;2 at qot;5{C%ISAtH1Gm@?P;%a!sL!B&N{7Wacr3I at Z@Qg at z#K
z(n7cH0WYS|&P+O{&<F%W6H}<;HD7xQ1zcnI{+6*W*_dMrb-Z#a^%>K1;T}peIi@`n
zJV~x0)YEIP=sTVEljYme9NTgTb-Z`9z2Y%~K2q9~yuRuStr}FbzW)CF&xaJSK-dZ5
z^T&|%H})ZlV+*PPFp4*|P;-esKU}K~xxUsQOndE(eQ(#UNvQBzJI`nlMx1%=P4xM(
zPbS{?+H0Tp{)A;9Z=iMmd;Q;-^!G=3`JacWFOd7``!>8I39D+(e3X1WBn_SK3#$w)
zvmFvCC5WG&F-K3G5%yw48M^mDdcBi)MYLEoV<dPdnRt^mBr9rLoYm&mNh_NE5YUJ>
z87es3NwxP8H+*BCPCT65a3Eem8=>R<)c=ROeO{UTfUz)m_g=JdZ0f2T8;Mdb#aVXm
z8VJh!M1H;QmrEb__00UYTW}_#IElkX(F?;E?@(TwQ}T64yo5&nfJSs5b`J?^dmPXs
z3tgk)WFM%Qa=wXk at wbv1DHnI~gnuiUk%VEx<Vlf(mjSqno_Jp$L_jcC%ofRQ*zNn0
z_(M>MMmGvg`X%vnkK`Vs<#c$f^q^6vq()!&MY=R~(7E>6+y=$`6x3k0anO96jHg`M
zLvk(pVN=*S at Ob0FE=-oNa^UIK5SVcrRDjCbFpz`3z`6!*&To8!IkHkj1A?U2yguIk
z80eeEV<*Dsc+7cWU*XJS9vTv)&hhfL2;8Ic;>>syE-A`W;|TQh%1bSu8!rrRND!b)
zvcRF`#SK_!hx7Y5f<@i)o=0d5Wte(8uU(>bz^^`JxEUfBrs1X5Lqmf!#tsrtjYqE5
zasfSqz!di_oX<q4W8Kgq=|4YCf#mnL0?X3Glb90&Y#4{+ixT0Qf}{&8#|+OoNd~mh
z(yw#JMySwZ!T8fwhQHAZRxiv2bIpeajRf||6-L+2&`I5HXtpxNG&F=;&XO5+rDz((
z*m`n&Gl$D9`3i~TGc3$mDGa`34mYEt$J{yV%q{v<T+*pvz0x7fJTT2{_E0FPV2vqj
z$_-U^IvEvYFyY2z!nMkrKdkzUw~0q6>#RX3i43bT!41o)@u!5Q)Rc^>p;Nj$6qG<R
zFP#|!&oPLZ$QG11HjTUDQc=ZrVy_%T at 6=zI3&ulZ1fMA(cRZ!%k$XiF17%`jhaCao
zik1$YmS<)Rr|ny=IS&ooT62Z0G>ak9nG1Aqi?MnrjC_7#O5C}i%RWM8zR2{P2!mAC
z2^DTieR<UBX9%O at Dq2;kXIN8m1Q8PL{f&ePCMhvn=~K)nTH&#E#{k&plp{)ztZ|eu
zZ819q)_}cb8bppmAZz9cD-^N<R at 6C%vt~hKNFcGoAewSV|0VqkxC$eLmX- at vqg5iQ
z(U}$={TnmZxuQRO?AMO|`CEcjLmm<Y5?Pj}Mx-ZUn><$5HofKhR)62&s<fogbtS*g
zc{#Tx;UDz=Ojmev0c*7jb3sq%Y>k>#%Oakjz?x5lwHT6_bxVvI&h5i0bch=x^Sk8=
zN^ajgvyT~xde~1E0D;Ma20$|9paH-`4;ld6i=H$9k|GBU&=E84)#QOUKS>&(f{JB_
z272=9Hw^$T>p=q)Q|`KH0HDf211@~gfJ>4zAT~H?KpgR)0gy;JXh2- at d_(91b39(z
z2;zBbpy9Q4(E#=C_Mido+wA*61Kj(1(|`>x8gK|CzmJ0k1b)x}+_{Yh4RFakXn?!g
zZW;hM>_G$E?0L`t7+Kog<UN at 6K?5Ke%^n&If6 at RQSsE@H;0aR?8sL7Dn+80SG_6`E
z4+xEU@&K3An+N!g{ony{;)4hHt=ho at bkmz`^B!$`@BnwjsQ^FO!2{fr>*N8RPxasd
z?)iGtfTvMG0~G$4cYQ0^uq+Tyj0B~>{`*%@1?06eWV0B4zHiCu at c&3swCXzns`{Ks
z4*MI7x at 49MMr7J=3F=HcmONqJ>g(4%zmn!m5A<>OlpI$DsTuX1#MYm}fyb+3doQ`q
zf1btahw0B>$9?{m+^2cDU-C|JoQBBid&zbFkF&lqc4LA~b??^}_9F?9OfDI=BT?oG
zNl^|w)>jO<sw1%Yr~!=gbKr^I-o05nxoP1GX-L$$0(((P_!%SRET=+^65$&ZZ!VZ8
zgFFDYMM~>YrpEAw<r62WhGPp(3{9VhaOsw$xkR~fNpw|Aqze>HdSe+n at F=n3l5{wg
zw<sv}j)kxZq2(}9;8}2%F33?0jagP;QJPh>2KE_~hKtkV?z4}EhLae_D~8MFg=a%w
z(4v&x3O!sL8+1;eBHUoG)k88T_vlhNeU=v2UTX%fy#|JEt{5flEc at x;X@<nvy5qc7
z;hCix&DNE-w8C5U#(<BWjwqP`bzYc`Fqwx&C5ew6m=KmnNY4dDc<rV1wdv#)o6+~G
zG$JPp=BrCGL$r>Fx3wqsi7pqUq%7u`PT^zei${c45X8Q7Y~|yrEd#!or7JuI+QoM<
zM;f7pSvwZ>ElvP#41ZO-Fg@%4of_7ZkFib0B6qOfGMc^dC2#_RL&BAn-SkHZ;PfZa
z0^<E4Vc(a1^tVFm4cYR2NI>0V2-19$PPAv>nIUVWh$x9W(VRU1N at 2{@d!$b=eO{PD
zPOqniMT3qVbjGAsDigJm<@;<Gsn()uIrg_0mn?c<n33s!OC+BCA`5c|`dr}Cp=K1<
zUQv67u}{vdok8h)=$(`GaOob_8f#{WXKcvpEP&Q;%M;U89ZtP9GzviM+39Q at yo03W
zaDPf>)ag55tv;~_kSnbIh-eD>U;tN{^hDz=Yo_lGXIr#$L>YGqmv>S-;z>+D)P5)+
zygUC1hw}LtOR~pXC2ydiVVXD8C-z6p6_lXlq^GA3lK#y15z6!^b*I>5mX?;GX_jR}
zA4%z$X4A}DgKqF0#^I)RIGT=Z!K*Jn`yF3D!ayG8Pl{&tXw&L at XMZEz@!@pPxuzUv
z=Sp7+r^eB<O}Dz|%$Z5JI5y(v$}qt3NI|VJ1KkQGAD^e71(urOm6anPedj62r?ZT9
zw6Y#}u9{DY60dw5Gm9`j95Arsq^suKV`f_{355z`tnzMLTryfu5AMqaYmIDp5_Yy|
zkXcj0?i<taHQJ#8$7!}qFZ1r&Y^j|o;m#NCQAI<;R#u at YftO~p$w93B=~<RA95SB0
z({feD&#Pu^A>5)Y;zcsy*GxxPm=VKbWaXk+`Pnh`+p>p78M%QsT{z0}&UL$5GdLU;
zy)k6oI={KFXYR}uThco<)R=N>5%YB-N~9}(iOkx$gClo^a4Yn#7+f&dcxWt3X4n~=
zD%?SBySimpwnk6(#g15nFXwn{e1DAeZiwH91Wj>n#+}UUhoA)+_~KkznTz8e!fbs5
zkmg(y?%2kT?H%(S?bx<$+s2M<+qSi1+qP}b-2J})zp8tyQkCcQNlqiFq$*FRyTZ85
z{v!D56J0A_nIx#wi{5mOHA1PVoVs9B>W9_onhA}hMSOF+FNtoZBal}7U4ep*+8=Kq
zj6WPe^5{=-D`)_01Q&l;hjm4xNh{6kvNarG{dts<QZH+qUl%HMnQh)EypRsVLqVPj
zUg1X<Kn>)A4+r}sDZ7K4W=Jg_vvSGgS*MXQZ962)Sq at JQ0z6QqRL-K~e~ij5COGUD
ze;zj_psIY%u=@<~lkX}{&8Zv&IL9?>5~2K*Q2BwD3mi_4j=8FmpHR$8jSZZlwH&Gj
z)NHUBR!V at n$AC*ehrK&`5%zQWAsD^_n)oS at NqwrAy&4VsbiZSz=9y*ACx`6mx513r
z1zv+0_E=Gy1b&_tGG6Q}M at jW~E}V1~j#0GV3dl!9<jld~hsxqjhrCfe-oa1hgs7o5
zsL?7Ydb4yk)szuuDR>B3su-1ojHw at 572t^~9s)zsW6svQG^Xz8vh$sY$%)K84Ql0*
z9FUU^GHW8AVdQA+*bWKa`Oqa2gl(T<4WtiIyk{iAA?2;Nvn<q>srng!@G*hXP(ia*
z8<0JiTw+Jd0saJx$$(a3^u9D?)!GzQ%K`MlBMW{l{xP~A1L#t7Fm|yG#c9Bh@<2F9
zE%ERU4MPmWuyY>3czBd&tY;@ITnc<y+zlFXCE)G3bi?8 at SIlQ7gYog}H#N^RrTtyP
z?tz?%F6#891th{9xzV$1XxL}DRB$0pHk27w{F^k>rJCko&WZQnPMy<>mMdYC7XEnN
z7Wd#Tu^db_`pZ+56}6V8Dk>|pjhg**118D`Ewl0Qbm3Lh_0Hnc=@RX)@+ at V<dCpFB
zfb^fUS`u-15z|II)1%DEc&W8_eq<C5vu7UbzfnCz$@ZxZ8|Blsg)0GAsYK_QqS6Tw
z`O;0l&n3pkjUS^XfaMXvq|YC~C}5~oI~7oWCNuGeA>!7l-J8?#a7 at Zu*p?=$a~zy~
zl`CHv^NXWZ!m-zjWrnLC07teRPI at F+rX3j5IT&t8%boi-mrsyuix@<9ar_WFQ=m2e
zG5%$<MB at Y|z3G#y#`joE8huy4!ATtW>QykRWj$*~isxKWS1vKBYmQb_a1$@j)N+-}
zItC+{^w<<$ZY)Y$GYBtC=Ac;-InCf{U97sKT(C=-q%g<U5htno`zA3wlw}c59gEY+
zguD at KrFNmLeGzF{z^jc_>bF)Z+cG_F!lO|7aRnaktRpowZNkqQo0pJYmdqvWiH$Ym
z^px3kC%Y3`TnJf at E49K_ylcM5KZ4Ow`Zp{0>sQfQJNan7ZxxmP00{JFMyHPB4t5Eb
z at 3!^U_-!ZW#@&smvvu#fr0{tKWa}Au_Ef=`47)`e-<Dnahp)}YtLc|#9;#;HkJ_mC
zpHt1y at o1vHA#^b@^$uGUq52<apK%LvZ(yXzh&AF^IqnA$+1L2FnC-`;plUn4J+9xa
z>y=(3l8^pRiW(~P-_7gF@;@%G^0eB@@t5kc^afWby1$yEx?k#i*?aBgttwtD73N&(
zM^90~Ac5s$ay}12<Tw4`Tbhxz>Ii3qhIS&tC|8YE{HR at G0-tB`V_a?x>w8ZkI;h}Q
z>aF)|5K%wbAKw|<--xV!<qY8iTkZ#D_lBQH8;u~)2ikD_5=!`}efM^{aY?r=ygyxs
z%l{ZWtOr^S8`pK!Mf}Dq_(X<`OZ-%1dE0&LjPkh-u}3jph?#wW!iYIWMtJETV#}d-
zGP~Ia_j%VvnUn5pw(5=lZIm2~W`;5TNww;iwD)-{?2G%L8}qZ=P}56{A!BIvt8(vj
z5fSliK4hQgOvZ&JV3>QuyP+cb^T84468}<c;qv(_zYmQKFF|QZ4#?Un0$)8G^6>zd
zZdh|N>V064KuB%dT$zYB*)`do_i=MpM`5VgYw$hw2+|gY8*&$+xHSd`$rt_8!kn*;
zGfG1|26)dcbn1E5F at OWaUP_&;{UiUIeD?J=1&LWFN>u`R^4YhCV;-96A{!d`ld%8J
z&J=NamhtdVF~Fn*JtuE3M{QhTO$Z3y`yKj)tNl+ at OgkZ6EtK&k&4^jQ0Y%>_e@#4J
zlqiRH_nB`Oia17JonaSE6f|B~JIS8npo<hhOSHi;dB2o74noW?fup!tnJ=4%+D~GC
z=WOVwUi@!h?Cpo1gYqDf`2}-lBxSL%FYXna;yC)`N&W4&-<KUv8hFZo#L?H2<GS<H
zktO3UtIGhZJ-_~F at FAz&QKH=X4<qIP<Lt+Gw at eCb$#ake_|Ey#48U<Hj!M+P)#_N|
zl9BAu4n}XOp3xc;NYfMOVBvN2`n>H=j}UmmSbs#mGlgYp0bY^8_*cf!hXF;M`J*&B
zT$4GsUtVkPh58|(vinaB47HPDuO-smPJv7m1lNDE3$|hVGr^lm1RH%Xf{WmxMxUk~
z+=H{#44A}C*Xa5-o8n4hKKxkfv=KC^6l%2)JxthtC(^f%V4~d8Y(@IJz?C7jn^mqt
zBwVkVv1vBri&8X5d2pQiINo6Ra=NLBpi9fUw&A{e10Kzw=W at UTCj<dyRgwLuB2$OX
zHqH8RIGuKL&nfs>aVbi-N!hS?xQvQ+kLHa<%qe`7F6CSdKvrr`EDg`qMCx)`)Nmyv
z6tRha**FrsQZzWwKUBU#8cN}F#9vsyPGWdQ_f$VmQ7cSfW)E at M7We_e-fB(jlZ2Wx
zY;UYIZv=0Gc<rTjzljJ|i=LUv)O7ve`MQ#!cLM|HGMZuhKj|u??+CcBMRXeP4{k0!
zng<Jz4*6eyrkKv|pQ|65eQ?O^zL at bG#P3L>XKYntmzbSp+gzRU1jR-{RS(S2e(}89
zcrnVZ-pT7KI$?cu6NEi*jAFs$I@^>{9rr0KH%L_9z!EPH?VTmY9(foP`fWdU{w&j5
z=Q{u47sQTF{P``IVO=6hH!L)|a5m}XK2G)2N<94R at 8)D&Q?`$RZ`v4y-(9yurCXFd
z720%xt$conjN%+u)Wi5dJPBmTER)jOuD7Pn0M-}H0m7bIKvtYAKxcVVfJ1qE<SJI)
zN4T-z&)gLFTc_z7G4C-+LNI@@(ouo%&sxKxOVC=d=B1Wh5<@!TFY3mha<?_J<JJWo
zzR+3JNyvg*a}w7}Qvg5nZH=@`)aT1#B#m%p%aNfsF%&ymK>=ifH&k_5mJ$Xg#Gg4O
z at B(M4Jy(rbLDW6tW3X+ouQ*0$uhd`5yhV^-afP?KVJu+3l4}JD1buz47c(tZ(#~EJ
zPVeJr;P<}(H4RHiz=FZn#k(Ih^GGE*-to{q5`imUJscF&g36=Evg2x3`2Bv!A_+cF
z`(s-ywjJAk5O{04*^7haew$W55sQ(6;n%kaNrVRJT9Kh<SkO6z8xYUhZA3}9%M29u
zelCx&_S?o;E{(UB_UlQiY_o$1^IAAs{_X>Vr1zEuze=j6G!1v#mVSc8V=8k7p+_4D
z0!qt*t3u?3=n`YoN^)EQa(DS|<n&tVCs6Ts+!Z`vqAUv4MDze7ur(|cS%jTTk1y(q
zOcM_$%)Et$fbl(9P1E at dlkYxZTxA%UN5L@~r1gsb4LENqT%OkZA<+yoU-&%>O%P|+
zwedJ&am$3a0>cH`zRY-|JDL5J4P;-&Dv*Z!rzz`+X^9`p3=u+r8Wc1h?GBTh-JvNO
z<0l%)cSVPV2WqhXiFZ%F=uaY2O!Q6r5ImP{f)NQ`;v^GGs?g83)oYHKdV5J+3YUwQ
z!RzilgPz853Q|f#kHc58q~w~NSpbmd!rORJB>jNxDQlUn!&N>d^h}vr+gTfi+4v9V
zV-3p6hoBSc8Q+6VHefy`Btm&>DbB<q+7({*+u1Y(M0m7pcZ=(M&q6!ISfUQ%Ky<it
z<#-jt5)rz?^D?U<Yim0hZs%^RUW~65i}0m6XXRVcGtw4qu)8K&pvik-CdMwIIn#ru
z)POMLA|`P7!Km+E7Pei8qO1pqw<c0SAmSR#d{yXbrAv+1J_#;CZCDF;U4-;tEely=
z?J*vt{9vtN`=JDcT-}YiSIwM+>941hlf|JA&X*h%tpMD=pGGznMebVSpb)B0ybmMP
z`{Tc@)h at bM9WTZvxvK72K_YM<+UaJUTU|reIA?7ciQV$#$Z|F$IA8`8B!|9PAPix5
zd7y>;Nkq65N at -OLB9RzO{XJvJJUuc}$yJxjZVCCbfrT5;cPx5i=*o)tI!_u;T=s_k
z at W%|D7qS!BSVT?Xp;0olsoQ}}z|2~ZiU|e*S9(Pk)6e#HHAjqwDNHwun--UuP-nk~
zmg$H~9hi3g!UQWbAvDc5j@<G2dKycOzA{2|LqZloz*;tMJqkB^;?bW)DGrxcB6vNp
zj0wlWmY^>VuITdS{sd__E9HWLhcUJ>a&&Sq*0+ZLi);-n;8_S62><T6x#^{hZA_ia
z2mx$NO!Ok=R!+ta^deUJPR2sUhPFn=|D9$eWMpPzW#Zxa?<z22VT~!?c1o(~f2KX(
z*>rz9C0GfpiSF>wL0hpA1>MB`(O`Rj3X)D0fXcmQbUEs}uo3%7l_yk8Q1Bb8DJ#Wk
z49%L$LbEX|T3O=?qAa6ajP|i0JwT~se<!kFk2l)6+?NV%ugw&dCv)hQ;Q8q5s_i-3
z^SVv<xZ4i|2v#2sWTwO0^gMkkzw5Z}z!j4>4gX1``P$PRO7Bq~$e6|3EOGNW#veFw
z8Km^-&&bxU=(IEfC>S}=SoG!Q^9|qgC^amQ1p#E~JVb-eQPp-yHi%ja=DQ|uDEQ$x
z$RiLs-2FIYh$w+a<HvyV1O;$-qxbv#R`Y#_2at-sFR=BBr&*zyqdkP)rD*9i{!MVh
zbb1>*-?~HN?q}R5r0A^8N0WKI&q43S$nsFM4KP&6OgB5_TB8G6fE+T-d~uNu5qx8>
zp9VTy`Jix7Ikpn(>RYpJc?x4FXh%5&=(6a}U_NL$4bM}K$9Ih`R5$_}-pm$svIV`l
zDg!RW3|-zKM&s=ty&Xo at LLUhZ|GC_BRoT+qfV&id at igA45B;OLN9N^SPD<6p`8E9}
zoqfm8pX&@CauIyk5LAU!M*2WJ%$iHG=GaU#@Pe4y6Ky*a$zRuN1(*o>E4(;`Pu};5
zV?4nOg}Xj*>e$Bbokau~Z}tvBZk{&`t!mjrZrJ^>n9+ZPC%Pa~c3^MlAp8>0bb~VI
z5M=wPF{gLj)Em)LB7fM>i>zYIm~q*4bIl}w2~^#=N4iofQ}P7n&E#;?s#Vyv0_lcW
zj!=Ia_m}0oEM;FUB-2rwlXLE8T)zrg%@0LC!JjWzS!*`DT`eioPR<sOjG;%tkH0bn
z(rPR8sP&vrwF at _~?w*y8&ETQKj$<SyC8J at 0H~E$GHI#-mvoz3cU;i-tw2^F3Ggu3k
z%kPf4N%hmwq^xG91d-pQ{J^y$)N7$#2p)4ue7kUN->sZKKKuBMHO9X}0G*?P#_hO^
zSYhZwU9J?OZnGQNlab+>TDk+hzL!i5l01G{nJ^Cm-<ikNpLT89DTTjv(d2GcaIr`g
zd6B7r4sIdH6XC9oAHGUc^T$SB-^T-SO%2Du)HzUkFLtxDd2^SgFd7}aq4}y&mdY*2
zQh{}oeSNho>JjmXrF8dFpe#*^ucC6xk2bTdEp@}lhse%qF)%D;J|L<S`8X{nZPgej
z7zppY<AZK_d(YPXSMOY-K=^o7o{?n3U<Z5j(g}1`T#16xj=@&ec!BYzROI7oTU~1m
z^ZECN99|2#Q@?{<Cn+G_EIO$%ex<5Z&|03RrG$N~E04yavE>}VHZ&&OC!ftAhiXG;
zb$ei>2CYe#UZA8>hp+_W<tTZNmKhY;)PK~sY0fO!x-Xukg5%j|KK8kTUyXcky<vi<
zI#GA%r;aT at HJ5n*;12TGk&!>!P9>L^M$dEGj`F9!T!1NzWUU<EPU2?;Cy=!~H#Y(8
zBzWNXOy-powsUUmNanTSkgTj8n`$*HDL$%mF)ij)2X{a7{ww=~V+3@|GMf{5v?1}(
z+*@p at XZ8L`azcgeV?sM=wVIPnijzD+5=4lRtw=Tc#GB}s7DakKCw^--l`|aQ$<d3D
z2Z;sN9AV5l`@TKo`MPF0hheL3t8=zrm`gfTie at BhU#LO6<sXd-nic~xa#)S at amOfl
zpLhz4BbDk{s_OofgR!R_26Oy;Pv+|T3$W;rWim4fYC}eCx|_rCw?jt+6(IpOuJ!U7
zhgiUZfrwO$R`MiRi`B%3GCtgJc}W53UOT4al|Ue&-x!UO7BcfgY_I)5p8#ctl`v!o
z1QdEBoO_=<WAU`bX1<7rX)aioI+!5te5vyYb~%o0>c*L at RC2P=om-?=X7cE-4J{`)
zw(68YD|v%r;j&Xs@$nX~4g%Y7?j4!k#4$lqGESQcRpEk?`l`6aF!DO=B31<p^Q(<W
z{3qm7P4pnOn+E2A^8w3&m{8R))zEL^uY?!NJ<oxN0bOKzq-oS`G8t4~@egpm<B-&D
z!L}S!Uy%>0TZ(~}u;Wl$WM3(-1h?cDl07V=WSumc*ZcKX>|5nM=snlaZSrn`k0oyF
zl2G@(=g=BdS=1g$Zs&+E;5|?`@rD-($yc8}q@)Wntezdhf(2yDFwR>U at v~zW9!am@
z7nWP<0eaLJ<ec=9%ZLG6lpcO=8881A?puz%ezV<6YhFoQGJH}VF<hc63IxRpZ&Jkg
zOfsx@%1l+w%0=M})UHRVJ8?c}U7${66 at _6y*{DRpHP)Vw#+#YD`35(Qv-kEm=)IT8
z>;4y5_&%=ecWeqWa)m0V3R^adQ+6U?l!2T?V!-L}SD5u>KNq!Lh_&5o^vhfwf6n#u
zZUlrII3DC;Dp?IJ#q%~+Q$h0z+F(x~4(l`Jwii(DP$C|KyrfN=N!+RJW}E0!;1Pb@
zjZiM4uC0R}4XNatRq+7kK%wgRv{&tlJ=}wTTXZ}GeiJZWW)5{yJ#n%)GQpqHY-*jk
zgHVn8A6>?PN27%L*N4(O6W{wY+Kw_)uZh;yTEowi<>CZfUht<KuAu=`@hgVEUCp24
zy%G<CNE>vhK*t<>8fOkbSx;4F-?Id5m**n8-{4DybXz9J9>})*eyV|Xf!ATD>vf>@
zAnJ?hpYYpW>whUJiWc at ujP&o4?O8AWZNh9}q1X!9%%@72RKB5wrP`68-1WD9PxINO
zhK1##M=K;J5iofrwS+Smt&_`~DN{yR=qi2sL?d;wSO~rq`vAnO%Le_?8|uDuG)X`d
z1WsR+5Pf>0;n=bfOftxPiC?cmh)Y`<h1P5zYJNr74{D2c9_Hs2j*r^g;Wm!l9jSXe
zz?=Ci&HS*4&(U=RECG<a+nb5-UUImMvQCw_vi1UL4;@-TP`6Zsj86Z0x%9MFra3$h
z at 4K+qehIF84z<{wFZD;vxhy7PffvO7JErcCn^1;I1w-|pcC at 4K;9IgpM1wc{;+|g0
z_3t11>zFwMFUpa_j9)w3UaFo}ipyBv(KU`)1MXV5>x^t{E>{MKo)E`)w*IZX(1gv2
z%cL15zx#4Gl4n#J6N**HPz>85%9HybPGOK^e$@F7b;*D*Htry08+I0inP23TpL4Q`
zX%>Z9%b9MsJr_D}TFCo+P5qkQe${#Qf!aWgCbl`>U-N2rN$N&?*mWct;|Gfot7ZJ@
ziK&5XZS{>HL}5T1P)%*<h{z~D?7~d7H~Agt_WRO36#IAnHaJhe<38o^$|lZ=x=j|U
z6XUDvQng5ALkH=@(}G~46W(H4(4=S3CUp=LQ6(p2YJaOve}j$)f- at zT^QX+YPRF+W
z0KT^_C*)VK;XM$KFAkw+<Ydv?3lG;m9nQNH!TgOH0m(G+5y at 9?tJT1hG1#Hs8;P}5
z&hzTMq}6xRn?}{IoJZKuo*j<&(yUqyyg6eRzfp{|&b}ekiR{L%gw;k0M2vd|-r?+5
zF-EGRyx>)Q%aIF)O^oUFJjp0c#QmlI)<*`LhYz6rrDu4|>0Zo)b%%?r7_@{u?j7&q
zFJZFm8U{S?KQCIQ(}-9#!cw{sn7ri;JT5WHlrao8(0;=d>KiVMUCwo^?7kNC>$db6
z+X)n9-%fRpRqQo6RXrnDY1CY4Tg&y`T4CK_mZ>y`?V~A9muv^sXPpftY1t=kewW{4
z05R<T>mx~%8X0m$E1&RJfs=2sAMY$*-Q?!@qi2MeH8-Y_zqpzi5#zZ;XfaT*pC6>s
z*Zl@(7zCXWyx^30S(+Ij#G(*rr_5+p`QFv0zT!<xytX1=sOQJ620*fKqLg1SXMeka
zA`4~mZ3u1fbr#$gdQsVq#oaBoW*NKYZyeWku-0nvA%V}|g)!X_rmd<8linU;^kJAG
zCGTda at abw{D*aO1YA(ZF#$%=ps}8dXchEFE(sP1t{zCh7ZQLokQewfk#t^(!Y at +UN
zVaGp&4K%kic=W$M!vFBt6gZE3l3!Wy!S2xlpr$-|K}fw6J>zBmuvH|1e}NA&w!!{e
z)gZgLu{sQo?GkXw1fTBm{`~Ix3i;Uq3JK~75(4508UhN62g&v1gnPEKZr^Ii$N3Xp
ze7Hz)PQ*O$A at U*fq4Oc%NrjWbxRCL*lZ8$@mQEt2aC{E^wA at L$oo+MMMxv!~eGc!m
znuW+V5il}6GCevyE_z7x+Uh02L!Fbre3$B_gP%e_f^jH$XZ#xOrQA)fn_ at cxIMlqe
zevS50%~tDHrqY=I1(UH(W}nsK>+Spf#$u18+Eaf*p`ewx7tP|cp&?+d1onA3>(jDR
zb9R$&AUhS_rZttuY~B>ywBF}z-Ke8TEuOC8e2L;i7Tq^bW#eoZDzUGq^ri@|9o0J7
zlFL?|EU+G`{@VaKxf*Rf$70^s9E(#4oF{Zxn?zaJK8HT~F%LqN=`cF&N3&$b8d{_E
z9yDZU6vQ{{9^ODl=rfWi5(N^BfN-WrCVwa5_#TI^IKzyTK`8b&EbiJuDPL)LE$>>)
zb;<ZcMz)@JpyLj*3HyGwsM;!)r9UQ!;^GFvzTiZR_}~wTQZNzdfp9S*D#&Rxq{<ux
zIUBgLfy$XL6yn%Zp9Vd+UL*`wdRuEUl1$`@!D9K9bfzDHGsme;8`DtF%&c*wWi2d=
zw-6bN3RG{PK7x8FjoqH_PghYHKj_&K at yNzBAsfaaAnIlDSKP1hk?P&b*X&4BP at kP;
zGKZki=weXKGAHC^_KoNurb_L9vK`siV at nwn{7s%kDs50*gBR@{qw2V*3KYV^BrG2q
z1^T5(fbBc>m^XP2m(8v6=w6u_sSJ7x<<XN+udpepseEFke90(8Dt#`muOKGK at nPc7
zntI&J(~pvsqF&xuDOUQm^BD>2E4sU~FQov?e`~w|(_zP-b%;e~5Z?NE5<u6QH<gYm
zF&Gd>MvZF0K-^g9 at wyX#xDw6Uq0oh#dnslm*kD=6J~Uk0(#DY{g{@3IFk8<}hf^1?
zSBY6-WfooGb&H7lGY0WR+}c{U6nKrL*z1Q6bbb9mx}siQgc)<1R=JxBsX|>QzCgl=
z|8AO$CkKTQlXt?3JV-`}38yJ%5Uh9fFv4J_{0FLpv&gMU;%W<f5NcvL^r8WgAw#jo
z&zE|ZB at 9S>B#$mx<yk7drsX{a!rhLYHz?Ve()SO23CfES0D|K~vcAW-Qq8<9K_!@_
z<RuK1ud|w&Io929`R(0kdg$4U%?ZoIAXJWLJplItK3F?1)<82AbMHmZ4ee-1qL1Io
z{$Ad0GVdTIfut*ro*Wb-`Xqq_3EB}B$uA)RT=^^bZK!=s!qZq<uuHdcPugF^t9jjI
zVO6NEI4>A*TbM`A7h<L2scmhD%JE!*$ivZov+6wVVx`&TDS6XG!uxgE76;hUx;dB@
z9}G*H`owboEJobV{#!PHfbL-O_Uci2cd==a%aixpX|sE&jh8U1MiaKh`b_P;p~U=f
zHe_q9 at 6qsU^sIYK_T2*AZK7TFF1<zrUFTl;7FM^(qI=A_x%hUFg}V$Sghv&vUlj7~
zRBYm+AsGW2)z?nP9wq5GNOM6d&;mK6Sfw%m1hss+ByA4TD{Zes##7XwnW^{8QRi)+
z5{^f#pHM9bQbx?ZisvDdDD;)(c^nYkAM`!{b`*h2C%sJv+5GZK>9zo1&Kxg at ac7T-
z(Dlm=mQ=a#R0D^9lv`Fax3#h;7Yb5M|KLamG+T9i-F01v4)EL_RUpvYUeQ&kX?|?c
z%WQuixbkv-^_^>H6`q`3izA!U(>e!_qh8{L&0*+tRb64n&<}Uc1f}yR%7HcPtQ+a-
z=%j*X_ic3Q>AMq&m8*5vnza{m_?N)A^fM-5l%Vz({$$b1|5LaNw3}@qqFiEN6DN|c
zxv;k(jkj4f*jD<_X6;ZY1(e6__nL=RU2g0sP`=0}5kOTtpDFLp(a%XC6wEGD3x#FD
zM~^E94$GP=EGKc}ERkbYs$$Y;Hc1%`2QUJK<Cenqp?45_^k~YxSAn4|$Cxfc4iN&Q
zeY5g-SY_~k>0<AVDI<!4{xnpk8HF{KfGXICU;b2<4Gp`}sd*n~aQ0-i^xRz8J1W>I
z{sqilQyLRS=+Ooa^&=@A$4s81fN*9(DFHQVqmfIm6T6dS)i-|b{`lQwwPBy^o22W^
zFoS*i<^AoVf&NK*isv2IcaMt;b2xRupG91}R$U#$@O))WdbF at SEDv2n-!h_6dQn2Y
zgCAo>6f#LolFMAFQYg!%CW{ZH_>yg+`1c%o0L(ehm;Tz=*jFkWbeR9 at eYXpbT^|d}
zxa;%QJx|T&mSfNHvuE~r&->_&&v(6T*W=N`1mYIEFJpKH`FQK?;0zNtD&F1O*DpDS
zy>SG)%^nVqmydVew=c9%y1(h{xj&@EhI>i{g*y?@1>n)c+ThTB<Oejm4b4&>#N)Ol
zlm84bvI>hV*caL_GX^<58I7kT&bAnyj4zGwK)$VZqRQ<Ma_b=16Dg6xnmxQyAgpN+
zq9)cZ3_Bi+SRBBiB%bXT(*grnTxB}uN0gfBQNmGa1f1-s%}_z5gN;hL3B`dhFiE!>
z2*$!c65qaJg1;z at 9r28~M at GEniU3d+fROlsgv6JHpjrCB@a<ktcwg^+uFI5~5b{8r
zaH at o!yyo%@!%XS@?z$$_BRaVVHUy>?a$+m#&zyQZiQ_umAnA3 at o+3kZOy(XTu|MBw
z1!Y&sS<YUpm!pweySeX-FXA>hzEmHV^ez8Du3%<XYufy%tEhD}I5FLp?DqJ|*;rV&
z<*ge;tx_0S+$(=@g at CD8_SIKR8SHpIS(4>}RpWq9N}YVNM-s<sSy<GwDWos$<wLs6
zEyRS<`P)6p9vbdxbp3{(&QA)|E{GN~Hjdm5>XNix`U_MT-V|@x4+dw_2bNQkT at S2x
zv^*5T!ZFWrAT7Wjw3I)0L9b!{J676i#aM$Cpc5JU!yXr)ZOD5|6t*vHej(sXV&6D&
zk-KWGo48r~C{jni1z_I*Yyj8?Y&`e70{grAy8;CThqC*g<gJ>B57yZ?PO14BEg#*M
z-G*b=4Q=a-Ak#NB-p>}*TaM-%|FTzB<`tcuSGYd)cWQ@>nY<2#dhQK&_ab?ET at Iiw
zA1cQ2=Yf>eBQckYl++FKHt7-d0tHr-4#*!9-l#MFmwNgtZb3PS4L51H$Ora~kLglc
zAf$y!LmR^eHZSS}w73ziNg^161GH369l;e^0^vz1<Fyh$q!L!?P~?qPiQCPZL(L$o
zycwb#yxHq|8=mv#o_CF}K?TZg%3b*>PcOfb#(*oEEH#!c!Nat&FXXVk?OEapHr}YG
z_8&{guiw`kqjbOXT~3OYNJQDY?d}&&QYqL^EV=DgJl-KLVhvP*9zlT?iBvlQ2Wxz%
zKwXBJ at T-;L!F6Sxey3m$Jif2rj2yv2Wf0Zn0t|NQOG+ZYseOmIsAE*{Y1Nj?1?zFt
zdi-uK&u>1iL8qV9WEOvYa~8tFc9iH<d5-CCYHy>?B%<F}(x>v-Hzt)@164E5>T9;S
zI99_UibeQCwyTpa&51qmk+z$YwiBWt@}<sUv9-m^H2cwJX>gvWoZ#7oxjH#TZ{K?O
zB}n2whoh<e?UJg&oJMF+C2oz7pyuS&TwH@~ExeGHXUuO|j2eEKfbVJ{Y)L--&c&~;
zAkT>!QLJY|gBdD(uTmRR at QXAx&_aJp=nu2VPKZH&&N;z{*EeN``-U1zOVRi5;Vg6Q
zxB&5&n3>TvJYV`~qOPYRU~Lo%Z8VCkhzZ(-Obw%MSbDn60n9X=f(qA>5!=%c>J4}S
zZWu<h(m%QISlYKy!E9zmdpLqaZ)cYtE*)YBhW0O0<*C at I)V>RDG&AraoYW!t9ZgY_
zP0eA}RaZ9bLgjXNSL{U!x@?}lqE)u~fvdrTUB$(YlAF!fyp5i&oNIOZ%bcUD$sTs|
z)yFQ^Ym3ie6Xl0l+aF`91RoFH74en`va*VtKBVWe7z=VSOFlb6nyRqLF~7P<ihR$O
zu3>*Xc1)8eAKGO3SJvkq=XrQQ)sF>%s8v;D2e_7H3%IJtmgExhBE%8U-d2|~OKU9}
zSV%$N8;l6wmmL=pI+j=7(eb&cTDCQ92vHmG=b|%e`@}Z0lKBT77C5NM3D!a_D;MR*
zr!2mH38|>L8OOq^p9CB7ljWCM$pmpEo%@dmge$`<9fMHjI-KwDH8_GS*e!0O>60Gp
z5Yx~|#7;--T~^vuHL)a9&?)isb;B~RsJ at z+7<qUY8Ch5qs`x8a%gQQO+tL$oxg1T@
z85)N+mE1X=&m)~fX at pUnv(qRJ>nlX{t4t1R7~mcS?{HGNlFdNbi%=kivJ_MzK@~ZJ
zB4ucHYfVs4!o~_EHq%XkU80~=I)}BNvTImtCo9OHKt=B#5yQx9Vtyw7rhH`0dlvJX
zOCc4OYl at nkAwuDAjN)g)lOp6rwd*&*?ldPI4{pzmnvJiFieq_u)<6kYpygd3T#?hp
zNGKGxjK8|28<TQ%i5eh at n2<iXCcXN;-jrsk6P29U8=*3Xewu3f&73E`X~%AQOW0PR
z;Y<fZLIsHtw#Q#)%rLGA0rRVkTOGA_(G7uc)oQ6C`|I=z^lN5I_X~!L`uk_seP2D{
zRi#$77V*o)`E{1h<4F;0?qiLpAic_$e0HT*tE{9-w-)8jLr2Z$%|(r_`#vZbGNnLt
zbpuZfh?y-qYcn{OhN6$A@@towsQlg9LHX5sC);)Bl_vgJl9B3uu+}OmJbW&vOAB84
zjj2sKd8an-2qFKEHm|Bk(L80j&U$sW$^5{UUO)D%VsQ|iHaK&R8L5g?7uO#kzyk+U
zeF=i*1=Za>{q0v{T%s{OA9pU22TMs++o|0TBg~LJ)^%3>Ut^2bNs~3)K{@%di6FGR
zW7eXR$swz#d2QTk(fKlN`Rg^x_dsP$++usBAv~x1!bwNHsS~zP1Aya+O!0>Sb{RDL
zOyXv&$yhMq%3wN_Ur9Xv118A&tlq at MW)g4^g;XOOpvvmqd;traF;fZTc8HEdbW)qj
zz4WCEn<l1L9}X(8+Jr7=HsG!}t&aMZsRdU7XL8_YTPG%0OwP}LOg0v at 114DlI-p46
z+Nl|3rTl@(iLIHGHC7xzph0afX<#haCy^mzN$MQzV1jlJRCfzQNrQ)GQ^JY!=_X^t
zg(7-K3;u`){9qwy2&L=`>gOR_A|&Ql_71?7H(-Rtut8EnCUVc|cS^nEaY at G!7-m1Q
zT0vW9`>^w!;LEu*1yOh66c+7lSeYUGLskg?2LqR6RyaCNER|EFpw3;CWWmymb#c*S
zw_3)zsr)S1qP#*`86c#*9P0ruYF$=<adno=SuR<$rXcEEri6askC6F^_^v#&CWI8!
z^Y at -2MMsnG6jLuVC@QRdlrx}JQ;-&tHULMbPd6$NzerA;Y_7u?OvwJ_CU-KZyE7QE
zlHal<c*zm4<BLRJ|8{9qu2e`{^sw+;$Gn~4&fM|7HPNY!d^v0AJ&bqklu{>dJmc6m
zYb7ofELoGR8X%Y3b!SfWK}fFarQ?b1(l^zxxEO9XI4D5|=k5)s>mZvA)5Bn_;PD;E
ziFoxZD30{+Pku+sbbHfP at _XL-*`*YoipQ)vuJ$u4!#pmq8=w%fw_?$Ewy}|EP<?&P
zWQz^n>+tb|MdKVxsx^6X15wa(nw?iycJ102sIF at Gz4~v1dfC*1d%(qvfk239q5eM2
z%CmkUCM}oCEm1SspQ;9$TU<e+zC+PK>BFf`A}oN>8Z(=??dW_{^0LWWjt;Gx{qlk~
z{tSZjVLO2VR=}vNg-u+HNe1)1Pk{>J#n+ko`lwOxT$(-?{dzWBfK!=P*3b8=++RoT
z%}kc7-B#khGVOu;K?;m11S4#wpTQ4+dCU)TJPyR1tBTtZc)j^7<@VL!eu5FW;8+t5
zsbA9=7W1R=D!`hOW0#6F-mM=$8X1RlVjj0wH6#)$$<9Z};tttiaJ7Y^9T7 at RQ<V*g
zGoX`M&$829na8u9$~GT=133LM9y)-R56)r)%sUk=X~K`NQm^(NPd!8EyhLRMf}W+f
z_utPSr(1~jV3)8L2i{;_Y5xGZzAJA2|A=AM|3wTdx!W1ji`d#Y2^l*YI+)uz+5TmQ
z{|^6>#Kug7{}9Lu|BeL&Y~3_znb-+wnOGSJ+5Q4{23GBVr)2c4jp>DC<YYy~s0D4E
z9nAkjE}J?MGPBYvIvHE55VA7<3&j2bg8Fu1#^$DGPK2y%O!R91#Vky0^!$#7#x_ob
z?0--D$C`gIEfWWTUffCF%G{9O#?;D~kl{bp>06syxl{gEo17xmzf#4&<hPTd8NH0H
zgSEcZzarKDXkuYt;Nkh7tT@~Ma$fMSqkpwH60-m6=fAO#(>FDym(zFnM?2F$aZ;dH
zuyy)NmH$;OZER$&|4$$o{>s at HnFs+KOxpB<4z_mxk5Iwb at oy*$jU5RA|E%%9wf{5x
z4<|2ZYh~-8Xs2&z{Fk5?bY%M*uKyhRujPMbN=i(G%*_AD{z5iF7RLWVMg~Ggj{k|7
z2$}ws^YGBiIoKL18arvy%L$3lD;c{vY10e4If*L%WBuRdL=_ncng46e|F-8J*Z;2^
z0Y(4|2kZYQN#OrX3+Pl`kKb=b_Fh)qiL2DGcc(}Nn4(a)4APZ|D7&w0LLz{RYuSqh
z6_U#G^y_BMZ~6se$2_ToS(b}{&79ac5jYWaey)2LHt+9ER}8K%{#1$6u>K*B`MVD0
zmO at uN6|77p3?ZK7_rU(%<z{Myhf$hblyi%pUTUdw7u4ce=MBnX4G&$iJ^q1ldIiY1
zaNgn>eFT}f2zUg9eew^|@2QOFFD7`HngoJ<(=81i<<0fcQN&x{6XS(u6S;XAh{eL<
zyz=J)PJoS!vV~Q%i*1AX+1RPP%HU8;*Q6Qwqn#7=Wa$TD1%Z8}@$ZI|!@*+)^qgI9
zDjrvF=Jch=f*f$H31>^P9Mp$&i_gM0R4-iDPoTj~qhQ6w=-v&!_&VUFa$(;@<FXUg
zFD3~mtbr}pGj?oU!N;Kx<}_EUPqh29*%*`$Y~Qq6?Q~qB!d?E$;RDScc|o#q5t9jq
z+8QX~fs7Zp3%jD`sF;P}tx>13>8?Pm3!xsBeAfpOn7Y!9Fob)FlNY13D6Qm`k={#o
z%Dk#u)DN43;mSo<THn!cnCu}wA&Km)a{j{dYPN%gjzo;D(nw$49Uv&E4}utyJ2|j2
zSJECPwedRHuZXEI*0AnwMVr>hz>!xIHMy>57Zbfjk%11JQ^%XoJGF5l$Oc9`lDlAj
zpJj_PW!Ct6r}S_NuKILO_W4nXgl|PqKt7+MiK5ydUWLZ}7UF`1>4M&xg at p`+!K05m
z$w^S4<<W;ekdRmXf+C_xex}G)+D!npDdn8g-~6)c^Ix)Z<&NUc2fuC?@^*o}_O at M`
z3nywiM9{cH6RkSu>J4Xm?TE4Z8Cuv#?84RhIdF)7R0Dk^?xBH0?>$gtdy&B^s1s|d
z6XT87QEQQ~p%`#+_kUN{34%bmzm41&80E!Beip<@2UiK1Bb_M}%xPQjUsR%nsi^~o
zMaR<Pq<{hQ^T1>!);R-<Me}z|vIqcUeMx;)d18gOv^GFGHZY%;TfHVIt`D@)it(V^
zBAiw3X;={&+he}5byMdvRjDaRoymt~Tk{N|V^-t<<}y+{SUM_SxhQpW7b%5)g9hJ(
zr?8Io!1At2yg)`FL&+SUDL&Q}^a3r_xApj9V^wgKy(^JFfT(R882^x*g&{T8T|n+v
zszqn|s)UaH{e1+Iq0Ky^Rt2kHT%5LAr~LD#aQNJYN=+FNJ*pLLn=&oQF`CU0KPNOu
zs)q?n_2Es`H|2Xebd}#wly+Am<I|-cq%6tq at MC$LKxJ3Ex&8CyM(&cJqk~3s%g=;|
zLqaOYbv1IKYMb{p`p#c_p*N&Jf&xS$IqkpeQps=zB_x#jkqd8{Xyjjk#vS8NprF8~
z!t(k0j!bx?Dm7b6%cxUBdV^^4Vza2<yOIg|2leF;ZCXkBq)hjpD4`N{=s}~^IAhcT
z_R7y-x)y#qrDqprEOKFSHmtX;%Clln11x0CD+J2%6kHU#ixkG6QJhonJ9%_|c&Z*=
zF6<KaP~ua()}vf1SzpqfwiQB+mf{l_wcnOKOL9xxq>Um;Fi-zvVX(1A60l{t#A&U;
zTRm%zE&_gQ4RfsmH<Cv6gtZvo#x}7w++4|+<?P(skPT^zR2m=Kr2Fagv8WrG8}zAn
zb~^vOrxNVoiSA&{2pL+J(<VAF>`gt6US=Vr5N^%~ro_d2*GACxB0upt(zWYwYS{MR
z|JJKs(9oTyNx829bCvBreyk9mcs1t5Go+W3ywMyj*I!oc`n%;SWY^8EphCdNSt)Vh
zls$L#xG>oI7gfqVv*68nJY&!Iob)L}b6KqLdNhn?bz2Hq^D^Vr%!<&H*>UOsy1*XF
zH8CddbA+nf+<josHnkhb;T_mpS4*>W;HEmK^Y9bM7|vNwq{dYkp^P18 at tqsu6#XU+
zGjz~CBwE5q!j>1i1j&!(Yyv&N$c6(xjR&p~mA27Ypg at Mlu9&0367xJKYywI^3p$kz
ztICK1OE$L9;%Iy;D<v{218Zn?0p)64?V*3Yt_noiSbR%VJ*gvwNL0F~z_BTlX^_Y9
zDg`jAX`Hb{Po<AKGlLIKSd#+8%tB)e<Tw9 at c@bjkICIv!4pPHm5Xm<I)Vj#vnO+NQ
zxCr>-1oje0|Mm?&83ay5aW=sA<Z|SW8~V=BSci|%RII~%=m367N2fKn1I2ABm(&c=
z7UXCYx`8n<BTSnRA9&uGIt2X2sC)O at C8W1uD&;Ju1+S#;AzJfmb##gXzqFeKBE?e@
zj5Z|``nQC;q_DzVFo~?Qtr?$i0>C#o&J<Z$mviA6{uvQON+>EcFMcGEbHp}6ai5P6
zSRtNLQgs?XEz!h6B;V*a<@mXLy#t?%0shq!Djo2?G&7-FGfH=M at CYO7`OR7`gFMDB
z<;4C--DpgCu`#SUaU)mOuo1KAK2p@;EOB#cYu52l0e&+y<igOnOyqc~TTfPixLyF#
zNGD<c-X1F}fKL9Rw1t|~imqiPuO|4rLB%iKt+|I(7N}q{SW%i%lusC!##)Kwmx*M{
zDWNqV8jj4JMwW1mm4ITtojzbwpN`B#Z!^PmX3*=`>EC*a@=vasI&JEcfh>{M?xpP%
z#ciG at n($4cEFzhq*755}*z0FTFTnvp`kfWQk8OKly)?FboG$!Q%n?Y$HVcP{Av!$4
zVeI7Iajb)xBKHwQ#Wyn`tp8L1wKG7)cB*FqK30j#%Cr1qD{rKF{6ve*2|$sAym6~K
z(>9bbF(QW(c&#-u$R_q;tlP~yZrNSylBnuVQT?;!C#0F^m$sbfr?ln2V5#7P<OVFP
zI!1>2n2H3<B8QG=HLNzrQQ2u#Lc}Ca1}PsBj2oEg`VHnk_uf(a{9Q{<=Kx0sb=t-B
z^bX7~Gf3H;e`A6Svo8rMjmk00n|}2|edfcu%X<G3ES;HQPVv(zHfb#=4XrS`O3pd=
z(-U-A4vA|%fAa>AFEOoB9$U;-s>Cg6_|84&g>%xzuH4sm`Otft&{O>*F2ASl>IYW4
zesw(5$@0(WI at AYJ{*W+vSd5Ip9-{S9VJyfx74hhJNDz5K#4>>^1CLk!E8TL<&Mq8B
zXV;kfneETb>CoAjm$%YVw9<xffyV?73`q8SjE{Gua at LHfRjcIkVc|>?lQx`|i1$HW
zUG`G at -TAgaUq9Dc^#kT>qmOV`DjNZASl!el<FfB>{Ce%ri#)uZBmIE#2gu<Vt26bF
z3$@O7friQ}hiKUoCk~1I+`>BP-NzeZ at 1{35M`jq{y!)VPN&!^yoD_P)76j^sO`8)H
zX78d8CYN(;IJai25EoX2SrXHZzq9xyrK1hb0GD%fp5?1xo5jIi+MdwyUwp>b1ycTL
zWPY4Jiqb*b2H^?VMmvQZC2Rr~Br?`{%m+`#AG%;_Gw*$|bl-sByN85eIo5sKy1U9B
zD)FjPM$D+YfK;(=l^&TMZI0BQuip+%aUbW24Sf-JeTy&jn_4%lQl+AkPYssF9`j8V
z at b{m~A)a~q_-z%my2V7&yajnPJ at c`472TKp_sR52H^c}vmM`@C#>se^)gZH2hn%9c
z*dZnI9N*ib6bpPy6*ZnMB){ifpkhDqqUmWx^NN7i^>-m$;<H8e5bA^mVFEyjGmiwT
zSTaCxg=+yZNj^8)S*D1N{m-eQEM&bJ#ED~3J|zfsU at 2z{^te+BGM8k15 at 0#Y{bK$~
zihT3X4++ldpyV>nUiBm&NG#6yxE(vlwbE3}P&vg=v<JN}5`oU8gF2_#0K{+x`}}%j
zz)RkJ(!G^Wr*_-ieh7yzLYlp*=0p*dVyLUO`r{oHvVa0u`O_RkUEOI?!5OBnaJV(E
zHb-VOs`GEbl=&#^J`+GT)8V}cwaaK0-6Q$+hjDQsaY}wW6J>P$INvFYa%hWHZ#F{G
zZO>TX)pk63LnFc-b{-!7X=2)|U=Je2`|s1vL7#73?1>0l&hY!GplNy8tyT$)*N*Nx
zcv-uh$KQ3QVK!sM)Sg{z#@!&<mmg)O?KsGeB*cHa#cY$~*m4&7WpEE4ec{zEQRn=~
zYo{h-S(b^(j{;=b4i;0N=S-icc$G?52bnejbedyBh;<{vvW~fVupBtmJusNyuZjYV
za7elfR*k#1ji&BqbRH41|8TjA_yt|gUfGw05u`yXQqFFr->t~tl#h9~9;XZ`R05z@
zKEg!IJexW&1r!VafLpov`6aLgC34tBS7k42!nTQj_8~iE`i2&PO+=J1eDGbMm)(Ji
zOUkBhsU=qXZAgrGv~Kc6kbLJH-$tpF*azcbSo|Ew5<GA92`8S^72JUX=&%B+Jv!!h
zQf0pWM#8vy8TzOg;BpH)#$p8e!`FwjJ^Pg(<FxDIZG5$>cAOKxlog!Yh at b3;)OI-S
zZ-FKm7T1)YtwJ(Y{XdJCYhp(VGOaj|7aCs8!>k&MZOj~Y?ax+x>WS?iG6mc27P{Jc
z>czho2&@@K68HShgWv73d&jqUIy!EF9w{%u(ul8Cc+RVyWp7_BdiXAAjjA9z9XMs$
zFGv6}D)8)|9hEduM2Okhz=E%N^VW8m&a3o@(~83l_)OYB!|EN-ca&T`Xs^mLwI}s4
zViiUEmk(tW-Jrm-l|<fv_z=H_Xtca^=56?4Wlg1A*O((Zl+T|L-vSA+zqv0nKVV-^
z?MLQnB at Q>|>t4I2T#LMSg#KR2U(z-Nvf3CfLK at 7VKF&(Gx_LeF#~eK}n36F9HXU%>
zqbZee?XM(`PqtehE%^D3xL!L;p&>SxBbgsW(x!PMFJMK=%zEl$aU5qJxH&<#_E0fw
z$VS*}fEo*(5+TS9EL7P?G91}9u02r{{Ui5lw|42|AiT6a+#5MuVDr;HeO6^gb4Pv~
z&$2P~F2>WlXf2HqjmdMCH6qLFUPy!>)Owre2<Z}c{931=L62 at n574E19eT2ze0mV0
z8?$XZHymfJ!YV?QP`QXGoR`_*KXoqLu<$w}wv}^yE(0!nF&Sjoqc|XS&3+l((6Q#B
zT-l2{;x9o*KJKA{^D2QgpfYu*L&eJ|cHcw at G1}`0bXSc%R~xEj(26vT)mu<&hDhfs
zXV-6IuBPrZgpMP&&EZK$EyHUDNvK!qmr*6If6kscDK;89rDOBJxle3yPPLhQ8(z7t
zTSx93)GIk}4iMBn|45#@H7-(JbD~Y3q@=*wbWjOYvAMB8a-&gQ;}>DtG#HnOp*`O!
zJg|L{^>p at e%G|~C7j|yHSda+g)9w^T!MTpZ5%q+32|+2)-uGeGs*Gp44XbalhO#u<
zHd+Ls_!t&z!9JnYu2Ms;h2xZW&B>fG4ig)%+RsA9&EwRRN&=Ff!Zutla1V_EY+WPv
z?x=Vl#z&O4KE{urF<0_UIWk*L2=~Rz-wTk4&whtkLAZJmWMaS#7%A8YZ_sav?Sn4g
zzHd7C2P1Qa7#Z0_dKWU`*_A5sjnv=Ty03IsZvz_KaiG_78l+dSZ9$cb^`t)YY5e#q
z?9b*=U9%f9)xhEn1EX1ze*|-+M>Y%EaHegC1=mTKj#nF!@8AB`6O4Hh#VyIa%8Q}d
z^<AuE#rFv0^L-?0_|V3r{6x0=m3xFy_sV#mt!v)KUaN3xcE$fI<X~*kKAd~~G>AN<
z{*z$@DX$Iju?Y5>LwsJS5-E>+*M{Q~n}6vk1dqE#uyFl=W8Bg at 4}Ut*a at u9%yeUWv
z9a6~bN|4Tp5%-7p8Lc`ewL{6Za at nr!#zU|yn{QFZew*1h_sh7}c-iv)y;3(P##)Iv
z+G-%jtBUmMLv$Xj+*U$pQ5MsmGU`AjNH__<Gl<d8Noj&a$(H>Ro)g5A)ek|svB|UV
zf1WwPmt5qX`BdPQ=yUfTJ3X8r at CBhI>L|XBDZ`e1r7dW81Hj1TINPlmoX~%(fXp?t
z!Zulj5JqLD?z=W9Q!hCF%IJ|G{MAC>Ko1-fqgSBcDFZn3;6mWw{>^o4Tb>|w5k_sg
zvg#D;WUb}OCFUfB??eRHbTgpN_~3CW!rkY!<$9zNv=9AO+D$n=<otB-06C(H-5R*3
z)2mA1Axg(l_(MPGC)lzd(bM}n5$BlMN`%_n)xKlWy at 1Rt8~^a*El9M|r-nd{!}n!&
z%faE3NEJ%`BC4c#I4+SYF1n%7r^YoqK6>%n)%$Q<>p1}Rou51!%`Wd&7!KEMxB=TH
zK6--74T2bhef0r^2yw8E@|OdaN!_4gF?6Ue%;`Wv$;X&-Yi+!ED*4`2rg4QyrN`dp
zwEg^478AWEa7wY3#K=(yR1sE5-#xWnl?rJL!1XP5;1QxiiL3%Z&pZtn&iG!)Af0!#
z9BazrESYY2<Fd6*ZJ at Zc`kE57duGlcAob_#xeAo7Av3y<fm;0Kb_QPgM3nXb7nez}
zw#FTxV9w~{+SmX at G*03CM(zFt$9v%7)iEHrbRj<1HCpTYM04w0YD3YoXCHgYJAzPL
zcVp6G9&Z%)Jw-obi>cXfQ-gA#E^VJ+-T<p+Vs4XzlGmP5__FuF;DlA-(ky92&vtKy
zK|>*?MX$nqGvxB;jW4jk91?4h(=DZgZ at B)>2kB1(E*&DR$NTqW$jUS4;o(P_Yk-g9
z;ieXVo(1xJhnze+5JSpzZvlLRXo0yVh%2S>otZvZl0FA5uN}4~2)Lr_?gm!vGife_
zM79}caMC-C2;8a!XZY`ve!awfV}r!tongqM^FI4{Wy)3jcJc^v>j5{z_n6)>NU_E)
zyXR3}p!)6}F1zLLYxmT{$L<C+`TlX&9jEps&hqyWK9x~J&KvdepL?J~{Ji!AEs$vo
z*-ku&iLah>YTcv%!P-5=h!O<|8gARRZQHhO+kM-%ZFk?cZQHhO+ueI-GV?IWCYwz5
zvEEK4mBKl7zTXjzM5c-9tFc_|MuE9DEp|HBLxY>mFG1R+ at f}+JOjrFzHsdzI{8=5Z
zAF#65S1b6!t}BjClk<`+cIx%yWEwxeom<{!)a=%Y+K#Ok*g5d%_e6$Su5EBe_`%NC
zl$y_7?)E1^PFM5k<*vu_<Dg*8?R9d~v`@G`6=M3^@5r%CB!rC3Fmc}J at eeuVWyr}4
zPcQC-_NiY}+GH$lJ8bCdH;VZ>>=3ysm2PXhO at jnNTL4Y8rtC;mAFlut;K{Ra#Fs}o
zR}VpiVc)j?FN$b6g;ZAswPS77NjJYq{cLudI@;$zxyOl+B8X;a+VjfONz}CW_CEaG
zv;w%g+!nLCC4JwW+PfBiL9CsewR%8S^Tyjv at 52wKhiR8nZ{wC%-xTXZ9#0^;XnFT+
zMawMh*Q&g{U*|WDco!|rve(<?!~8oAE&ir=cDB!2{-~Vq>&MgP>Z(uYb?a)JJj<zI
zu~(trllA&Ub#3fXI(?tFmyg#*>f2--|Dt^@|IDwikLQk_-tYZWEDbcOsufk4TG!9M
zWv9It*5XCRO{1j|n)YVexYBDa?C$K~uu+7iluC1)lpEQvyEwly9{c<JW|iEi&DMtw
z at M!1mqc2XY+aJy5P)N7jx^PfX0W=bu=JjZ7 at Woi!(8biz`%e7c(AUX3CAT-dza6+L
z*)&u;xQuQI-i&LPHs5QTPg*Z(shdx%t(&cFwmEXogS>BdGVhNKi!L%P{9QlimV8hg
zU{zOd`mX2D$oTqM9KWl`vyF*wRW_}Hm at F}8=2+ag&=o8yAaGpkDj=tZ1^Ewr-E`un
zc&YHSe(!HWu$zygX*qbnv%Os;9Xxq{nfwory=hNbo12qe1`^rO`I4qHK3St)xdK15
z%{=l?_2_(Ao<#P{Yy3TY*RAjNc<P?V^Mq at k|G4Z-dGSDFUYv3*?;;~6Gy1d^uH8s4
zZQfJ1TS-bX at 4MaKpIK+s=a<WC;mnkM?4M7=&Tk*j(o2($S+xiZ#c2+I&Fmgy0873;
z8vhVRe;(>Dx2(LbMO9NkhEa&K3tn#!?B$GKYXla-7eR(m0t&^G?kC*Bvr9 at lMTRhn
zvVj@;yY8NmKY2P312_Ywp|!AFq|LK$@{U!JOR_4xpi^Y{uhmI7Rs6iy+`K4B;}dgn
zOvG%sFgbW1S@`gwJ7s at 4H5Hbct{W%Ht6*~Uh{rwDLvt^?!eqgPNA(2wucy6a6 at MmM
zF0fen_?T}@H^ozG-4uu}PqSo|oV>K;JZ`f~Fkf3eX=luj<=9nFFS^G7yWd8<n|!^h
ziW?5K(vV%giVMstg;y*1DN*_EjKztbtR#*NoX?^gwR85g($PaaeFQMpI73%p6@$bM
zY$y>KQxUNZE7n%7aF~_UQyP^&eX0r`3svfQwqU}tvVZxON~-ir&aTieaw8%!;P|kS
z2#~G#L_|bRho-wF+(cP^n%lZfCxSK=k)zshwm0RR_|n1^Ccnqfi*oSdmep!CmfPA9
zGRpRkHpoVC37LpuL}a$s5z&6kNV$iqqC0ZAUgs-=+{{1{Y*&$|fzYBWxJu-vkJ*y!
zV44l=lu8&!xoNR2|ITH$QI#AaP at 69C++KbxIDpzN-1IyMC&&Tf-#fmJ^A)kxZ}t!G
zD=dci=yir3xb3!R=D8&GX;e4JfQ}@RrJdD?Ts8=4nxj*6GAmk*sNsIL>wd4Fhf1Xy
z_a#{+=$PoM_DPs8vpxh*stcKqK&s;2fG+z$9gAwFr7GBSZ9U^W=N9(fEU3E3_-!S%
z>S>g#JN#WLjbIHPsM at 4*8kSLioToiZ*{q^5_hoL85FcYtI2SuSZ{X4LbZNVn1i9d{
z{7ihLbx*XVJA;OzO7$)X3?#cmqf?X#+&89gVhPRcu7|~CmE*2yn89lD<bN7A)p at t9
zXb at BN=?1<qH>)!B-JYFj31`!u*7P&6Gvk8unw#7%q$zY%tg1*s(dCbK7U%2NF*q{d
z7UE;r1iyV9oE<7_A6`4 at X45y`hqo8tcJk@@3~Wt3Frmfq*vP61fF^Jd+rCDuJQ12K
zMU=iur`4r;QmKrkepZEJz4A%wz!2~bXeLEWoiuWCmNr?!RZuaX_GxRp$LmCAn8DWQ
zX58Fr+QEC?D*U~QEz7qZoB>4+1FxdqHtsJrqj?vmwONET?g*~XtT5)0&B2>;VS}R9
zUq|y>c79%DB+iq8bH{~ke{@l-H166-b`0=e)=k}^Yye9V=6)XQ;v2|@u_bPxFY$t`
zjxoL;t{O(`IMERtU%D56#s99q`TlH0EW`y+b8$$?#K at 2;0U_?NV{Ye-p}%<t)+F!E
zjPo}2xf2*wTkz5Sen%LYhF&?xa^oEae3u)Kvf66jx+li7fLv9CH6`y*k+X3=b(KgP
zsEQ+B1{Hf7nR-zbQ9ljRCfb5BpoJlBk}=pEt)IYYaZIQNA-WabC|RT)Y_0oX`y at G&
z&Mxqr<ogW=cNO(@D;b>aEOdm5wgax3B&y-vP|x!+0J*rk?mr{JMfH;vdmIj*Ew8|@
zL?)#RT2|3N^FJn<tRZ>Q;d-{}nBe72j?)<HySNd+g}Hjx!e`KeGwiyhJJF2P1sEF0
zUWG5cWIN%E(1vdG2_Egp>l!`(5N)1yP at 1Gco@u>PP1~PxrCRb8fUm~I(9fBV4Vi_Y
z#lCE~eVo7i{nGQx^U$7O9A8^IfZRN-Q6fY{Yt%DE at 80fqi|5d`=$UOP7Ly<5ua=pu
zgXc}J!{>iP9qX=f(0j-J(^IY_9)aRFfc2$n-{T9N=fdBks_!dC6LqK}8p7JexXOq>
z*3CVGd1 at mu8*-j8>TQKFbLj!g&qkLT4i~*&5@(<fk|{4{cw6<Z!{@61561K$`YYEJ
zCMGpkvN7*gez_CmajULLZ+RvWNgT2hsmPyD)<J{8Ue>I)j^?_uS~(<37Cnb)>tyB=
zi&OcxBgf#TQj#^-bYipc2LI9$;qN)?)Xw(ir%_IO at j~@jJt(t}f2E&3g!Ub%kMcvA
z_MlB(wL{9nteOxaGtJIcOG7 at b(kpM+et|Vo%ibj~P6$>7hT&P at zlf#NOI2R+NCl}4
zc5w%c{j0+QMqveMLS0DhnnGfi4fS~=M><V-md;w&Yo{L18!j^KQ>+guk0*_)!4$XA
zFOkg&@bXEZedNovc$KKfVJK)Nf|{3+zMuc_6uGs-P!Av=*W-S#`i^jbVbj`+*JB2l
zn*9{pyQX}7Fhtfb3iTXtx6Yg^)CJ_SdlAR$ojFp~AiPR^pF6qGNDp2m==?aGr9xM@
zo;U(Aa~fJx at Bq{7=UW(i<7zq6D>?bfR;b;g=`}^I7W{a;@iyX0hw%$fwv<?RzU`an
ziz$Q#j)nQ3mg-m9p<x?owC>!s_0v7t?C=m4R&-QV7mK)rr+5{r$tl at Pba;$SBV*%+
z*ymQ(!jN^Laib>OGYb)-OA9j}>=~z>Lf^L`gC%b at Rkdy5ETZ%TQfOOT<7H+SUWFa0
zcvd7&F|gACuGWkGoydXk=Qu at vjRNz+JUE&YGIsl#C_+2RboO5ip2?@gr*g2KF(%AL
zzPfPrpn5w|V=A4_y*qmZ2B*DBPp$8uYTAOlcn749m?MQv)Ps}N7KB=e at XJ@?Cscu)
zlY**u#}pq>U at r3{>m;%ecM%T_E#(n1zmh(y>8j(~06ia?$cvhf0hz;=cvw(XX(eS$
zry4%&^hrWiq-bOEswnCLc)-*$NfQ at UB3|JEG|QM2DUH&K`dR??Y^XE%80{*Zfz%XQ
zHKs;zvt1V`?FBDiX4l2nv+ho&cZFt!&o34^HMHHSRDi#JhF?^sS=qOE)VL-%^?1;x
zm^-d-ne2S_p%>(ckk)cB%I}>Utr&wwm0=Z+-c2mMfPom(WttKiR>@JloZ(?5Ecw2g
zCZpWwd at RlbC+^~eQ+2PpPzr}eBV^tD-yw;yc<7zKa|RqHMXkXcGR&ISU;a_xx)dVV
zJb{<{RO#Wz&Y_Lm8h^In{apNA00%I<hf>8f;u6l^>wQY1#WlXTBZ&%qu*xLQ_=D4=
z6Nx$DL|$DYxdLSR_g*n<+s}}nm_}_*exm**V{!e9s at BgTA^i2p<2?!M<XanD7FL~4
zy3judR*N!jV((~K#X~!=8zwl<aWd**d7t5LpjNAy4^Da6<qY)ibFs at SGs<qOqCWch
zKFQ(snA4cSn9H0Iec;7Y`=`6fUhyW8GXDW<eDipudv!6q&z;?=D3z&hjns)(2TS|`
zuO+$Pg+9Csr<aIHek at iLlUzj?C!NB7m6C)ja?x;K5PYX`{Dv#GuTS`M%PpBy{%CX_
z&gBB2Xo{KObzY<>A=i-!pkdvrt%?SO*;)>b at I@a|Atw0 at 7aq9&D*>h>Rq_<(7*of$
zL9CZ(rc}iqnhXXf_-g~?jYvjN1FjRzRS4#la{_(f7^Hg1CXz*~sbbdESTltZ<0&|~
zy(&80MZI#H99M59RBuO?h+0d+N2D-EeEB$cN|z2B(4LS{Enn?p1^EbTt#q<~;w`0o
ziO52&Y!~akb8(f2_tfN7<$5X1BYD*%pxQe(Lrr^1-RZrUH(X*xFWK8>vxa4{cC|Gv
z`e=<72{WuaiZ+sGq0}QK;KFOfZE0APAvu_g^h96Y8_Budi1k8TG6rS(c7Huy;{Z)1
z9?l+&y6_P?F>tS%oFabo>u+|npU!%@PwQ8MYg2%5D?yVww-^$Do6fi*Y{gct!(7$R
zV5<2%P7!AmRDr-{iwfr%2i$bmg_>0 at 9{!}8jl&{k2-BkQPgR-R6Pvr)o at H<oHuUhV
zbE<xjb2|U at _dsvI4FvMyxBXkvdtPbufimm6vz$y&=Yj2eA;*4XVUxmWs>dtEzv4?w
z#jc$uHeo&p0)nX*gIT`Cn^4AHHHC$pwt4Tvt2SQ;{*3I|bn9%IAe9(ksv#zN+9NK<
zo4Xy$YM=db$;+E!ZHW70hD-A3EX?NFbRjl#sTX!O!uV0?lZwJyz7yq=*7S_44Z!=$
z<b)M<y(m=`Ft+1qV7um-SyL}Sz>Jr1-<SDzQqd2^z;SxD#p^+#8~qenJ-9*W<6U$E
zStfSBy=C^(F&rlHf_-r5v3oRlF@$<M5a~0>cObbsgxC~*J3~y;+pnHHg1#~)uPmTu
zXaJA*{&});TiA8xcVF`^CBUn*r>l%}RJp&-q+ffd-}~eB>$Y8e+Vj<$x9YJmysGK@
zdz+{4_wRdTl6?2bc%S$4<9T(IKs)U<XHxJkA<)6E7UR5juONimnYy*2{O+;h8(0~u
z|Ho$<7E at ys_2lO*sdWl=082o=D*CHMGwx)!<qgM1Z`~_I3+ZgPhNIN0P{_<U4s^wk
z`DJjW5rUig$NUr4c()?{Q_KywHQ34n)<<hEFfFpmxSRTl1<80<cTKnpGdHevmOPWA
zYET9jU!mU23V{9PCj$7*g}r99c at CZaa!v~b?qN7}cx5fkP1ICRMGq{~(lN%TgWApM
zz@`g1?UWgkHA8lg+^hChhBR$^gsKY0?d_eVkH+q7ab=zc>%j3CiZaG=#pI=otUY&u
z<U at sM)gF9=E)Gd~cPz!FGW$~;ZV&oBh#9?t<eS(!k!9C`Zvibk4(rrhZG^YL2J&BE
zY`2SfLeE3(a<xg6_1Qka`f2xAuGp{A(Y)^wNyc1X at 11@`pZBKd-WNF5V&qVK=lN at K
zp;h~5#uN45{uXa01C?6+alRMdS3?z&hPY~dc;&a9wWNUN)Z3R7*ZK4f-P}Vp%A2Y1
z$dhmlz+PNKEYi+cq(!X4!T8Qn+;f;&?FDaOa+28j{>-OnUhMjJd;J}DWf(56Hq1xS
zxspm<kDEa590g;vqlUayju?B^!zc9N86*5zYxi*2xp-5Nn(5`^yfMRGZFAWFm_ZQ}
ztJ!qaurHP|f?3os4|6@?YCuX5e#48S!eBjB|1r+1Ev(}d=5Ydwold7e8CF}FK0hm;
z*5Z9I6{YmtUyiu8YE9`oHS7d`S}Gk!O#@s5Iy11j8E4IIldT+m2D1L?M2Yc$aT)IG
zV97enL8MxXrk;~=-M~JyHirMX**#d(vT7RRTXC&aaM15*Y#?0r+4^Dx{G1yaTbA{l
z>qyYQ{`r=uMp`e0;vW52_rcF?4BYeyUHy~nZLed=U;vi4gbKp`(%x6&%+m;Gi^sSb
z!?-a=MSn^6Mi!{5HkX^7VwN#RQRkSW1H69Rdk|Z*Rsrx$QL~nv{4n(w<fPcK5%jY^
z2fB-~g~$YViv2Ue6s!u>m3skKu<+j|1&CAGSTR{IXC>5o{AjIUrxYSS$^5S0TFxH!
z(9d$KWyNOIb$KnwR>Ui3kXDcz9cvjEPxgbonSEVmPsW46Ol`=zTgq#HG*zUlfN}g7
z+7e5~u!=}_{GeNCnX%*!(|siHyJD;M0)W-X%yict!(!nQBnLeDk(I$|aIX@%@rBXK
zU at CyB3!NYKtp<&cJxiuk$0ATn8{&9OnP%!m7Ab3{ATe8kd3~UdveRlR!llSf^A$9|
z- at E;ZVZOE7L8#&1&|Egy=!2ij<2?I%cp2Bj#|uTC&Vs~At8=!MwjKji;ysM6m#^>a
zeG`A{dOpav3p?fAVWo0=fmwJlSr2FVLZGlXuPUM4E6`~nfIK0_1jRd{`SS4{UxpoA
zA$S5qlFc-7QV7eKS76K5e^KqUsW>m2`MzZPza<7$+WW7UGIo|^lt14f=ULj~-bW+8
zLp2B4JuhAbM_^QjL9rlrb@<VI9q5Od^a$dOe+BZs_Zxftyhd`l06ag!;;}s96inx~
z8t8>!QND0`>do;A2syxABxe*`Ou(u%Hp7A6O!2PpXy#aO7YNMfNCDuO{D(JB6mR=h
zIs>1NB`(3>Ebkb_nj7 at CDF8J!YgU%+ef9uqkmyG^oinw|KFE!I_-5RWKwwyZV#+-T
zz+Vdt0shpxGJiya2UW$z<*Q(8y~I3+6eN2eUU4oAcdwt^g7$0%BFi&nh+?IO*%`0G
zL31G7jiV;uUb^XZ9G2o<2}gZhe?4 at catC1n+7O$1+%M7eqbyH1n*C}%N|efX3UwJ&
z(mB6qX9^=1n$6-x0oR!a>sk~04Oz8k0el90*t{yXin~(?NUbE|4QSPjF5cZRXz&O6
ztkg~RW|fWif+qmG*W{u)Idc((PW#<HdW+4*n?B=M49ly>xtXnIQdTlbpVX%L^?XMG
zQf~2B#l|neZNbw)U3Hjua at _4>o-OpRgzUHh=!BTv2(#6)&>i})TF1RaRCuvF?`T3`
zz*I?MexA at u<$sAsXf*|bw3wgKfV?G69YU!c3w>_qVYMn4Vp7pp;k=BPE{{n}u>xKG
z=~{=kDyimd2i at D5FWDM3K2ji-+l*%)jaTaa^|i7F`C8C;^>fbYe+L_8-3joLoWZjh
z9;Pp!W?XXFom5zm=*zr^e at Tteh+E9etUPjxu2)KHf-Ug`{8Kyz8;^xmCthP?!7w4E
z$nCY4&KZHzCSNx1N^}2{^xR#KKmT&JzV)~|zJWjcM<B*Wx+4M^B&h8B%f`;%`up}r
z21C{nfmzNVxF<OOesRn`tUS4<*3sTQ&NA&cTKnEga3*6IipDV!mtmnF$V=nWRL+k6
z%En*|e;n-@>OR^h4DA{AKJA&dzxNrZHUxby$V-ic;S!r6#n}E7a~XB&jD`8*B%!;|
z1W=O;FoW}eU2(E5uU9xsq>pE0<8+#K$NUcOIWwTSKT93wH0IwMD^_(L540x^Tv0xt
z(@nh?m^7bdDO&t{Nn*-vmo|1Wx3WF(l38{+?S_UhEx;3KXglDEwBDr)kD8U+n3QgT
zCg2m$Vwq%+CW7q^?-}qKxbTmK4Vgn{3v^pn$p`(h>H>DVW613XstXN}5&SDC=P(-#
z2|7GaPSQ2-FrACDNCIvmttLOsFa54|<aBO=5eU$dckPaveXSL6Z71HIO;VqJPd`uX
z-SR&&bvu2M*s`#fswH>A9$yhpkG}Q}>;9nSmr at 6K#~*Sw8uq=SCq696ehu$s1<Jj-
zW{qc}rmNzkgsU7w+TO%N_(WfZN_o%v?W-M#eS2ZBvisQ9tt+>7V!{eL=HeuWguv6j
zfw$Vi6rG`$EEYWYd2$>6vs3=l2Pb3g>K`zfL1aqwHBVkeZA=$WQQU0v>y3WDzXj)J
z*c9~_$L4z5o^2`!VV}|l<*WXeylf6h>1_8`B<%b(te8K_es)fBBC|aynIfO0##zbe
zkYddb^@i$LI7?4a%HCOQJ_o5CIWd38blm1c#t3;3+C6uK70U=|*qatbA~_MOLrrVd
z>=)|tMc4n|df%*|)-BRyAO`Z<4)ns5C+ at RW8C_6rHn>P|L0a`gVHer^QwVF+ at GsU7
zW^m})UW<JogP8yILN~++<-k>^8iPFEU~~)tI;sPHumrL-U1ML~5RbbMF5)8TI{X7@
zs{+#y>W;<^tPLTiIcz(l48jk_G_GEGydM at KLuKh-qO{5{82M`^udR%sFFSOw5rS6p
zbQ?eTz-*Zy!xl_`-aB%414!m#1Eb6^MfX~yT;MHEVoZhf4cx|`aN{?b at D1`2A4fnO
zyHa$9m=k<p>)GoN8U)8sUL+#z3mmt|ebC4!`Q2^o+i<L6F%-)g6z_G8G>8*avI>$h
zN{D^Y%c-|Fj?Uq!ZAFHlFBTIQQ?EtJfv+uG`Ug%<WE3_<Z}zO?YZ?LcJxJ5d681s@
zydZ?Zk<4S4C21R(r?mVjsiA?k8kP|H!Gf&Kn=Q8>=(^xFV5nFTL6^-zH|9FVtq%Tn
zcIWgC at l^P{#x09(9 at 6UY8rG92OT8@iM~;};5!UPR=*e+ek~VCa!)q16-S>tCtFlFn
zq52>y?ul7vg<FYu0omQ&3_ghY)-}$MQrBq{ysUQ;1$L?p96C=sG*pW&n&RSzfnoB}
zvykD;V(UB*L@*7nt0kHl92K4<9zHIHX1gBt4S*g<q3ns}g^Cp+zw1Dh^7gx5WJ)pC
zsYB-HB&1Xle^0)vSn>j<>kwyeA*fymabj}3xF)fYMO8;hK1@|6qPqndT%I<j2*5)I
z?02l>CJ(VUMb|)=AgW!RD>91=d&7tl^~s&-D~I at 9yK^3}pYuQ^pcKMYx`%zppfx!0
zcebb?Y9cSRx&Bir9>twOx{d|=kiDO^h=0>i{%*d>X!jeL5+jP=BMnN-3AcJWi;Zb!
z&dAv2EGz>Xa)(!1M`(~7cfavl{CdQW1diFCgA_8(3J+rfHukzdF=TboaS%++ at GZxm
zK)ay?_pg(aN;jjl;K*SpbMUZ8MV9udNknK?bcaC#%t%rEWKQOW+kygxr}h#~4N4g~
z=UL}xz2#KKwfkzetvV`+Nybe>F(?}6*GXn$T>KOSyH*WN8$)%87-lGg!ThdEy2cmf
zPE!)a1%+6V%EAc}!~3A4G>x?=%#fa-{$OC at IM=6pW)0ay<;)TbDHP_d%)Kyn!chsx
z(*BNAa6YB(Z%V#j=<P4FjaetL$`)dk<?a#*uT)m{KwDW!3UkX=?Z8jGazfAcBYGf}
z(Lhc1-hb>p&G11#saTR6gM1Coh~kB8z<v}rs!iKob_FxEixCdx^swU2lDF>V1d1Jp
zu;wWiQ^TW^L!<Yv5UQ}`O33;$nmGJGp1U^UiJXy4M#l;PBAvYvJJJV|a(fBiSVbWe
z&RMgMuZZ}0C$n-CcN{B2g?e74ruJq9Vz9TEXtK=@0)t(9N!T^E6^HLzGjc?l)$D^5
zIVJI=(0HW|*s2LwTfxTlE)Y<~VYT2BZ>mZ51uNkqKJUmbV<qN>R#kYZ8?$3*jYswV
z#B44w=6SGO?T2pp^3 at rvvQ0T;Se`6lpW~-E9W?exH0iSH at R}e at tLtr}5I2KkBe@$+
zkBKlTeJMMLDN$g-T@|(4;{^FJeM?f{ADQp}{=GKf+MxzZD4R}Gar{JmCw;eMeWWS+
zj!9mvK0~G^)r2_t9L}@&LH8(Dj+lsQ6>)kV05AguO#@O{pVW*O^9|01j%k_JtcxL<
zx$!5W at z^E7^t>uj;1i4WkeEQ?ejWG}!UV+6rVmU9g`0ig4vDnTBq`CK(G>gTr*Xb^
zbkw_KtzQW{%9+jUode6ef27<$?;BQryr2O;>OVfJcNQNcOVg^hy*(M`=@e@}p+*<A
zl3t at 6pEu}DnPtm=zLo at l>~JbHH<tL94H!%*or|Qc^zM9go;XEtQ<ETyh~=|>rE)J0
z4l1 at p>9Ks;PHK3fsGH~+_tcc&rfN&+AC7V&1cd5su8~p=NaS%Qb&VYIzTTdUQT>SR
zyP=ZZqaO&%(TQ6AM56WV7%T0_xCy<=-hLtquhGS=^}WG<1_1@=K+-|&`ITzqKc(Y;
z-;o0BjcK*I)SQm)At;SOf6BK3ih_=i?&xRw5hWbi%J``jT58y5mREPQE^(Jk`Gfs~
zX`D$KtyMhoP3fJ4^7rwWCUKYK1}J(k!TZ>{elz)AP$q{oZub^`Nkv~?`;+ft7VCjT
zmOX~@**aKXvdoBF6Kx2e@>P<=jTrh_a5dzlVAqBbJi%$U1gdj>Tkx~R4)2;GOQyGG
zO at J>P0nKmz*0ggbJZujK at 1n4-T(?R2H_o(bNrrw>sK#fHVhCq<DpB)`p%6TZa2wN1
zS^_%28nc5&utXc_<dneF!=NP!35yUDGa`69JAs}F&ol&;YTm*ZhUpVizR)kC&ymTy
zQv)cGsvd(a0tFJn98Nh_Xg!?q%!Yq%)9UF<#u>>L|2bfQ|Iu5i>Y8|e<tS@@sy<Kr
zTIWkkxV{#fCC!tlcqU`vBbJm_n$T8f#EoHb?4z2Ou4J_cpupnI<##geRzD!?O|0IJ
z^tgO$4?Vgw(5;jqKvH&h_YkjXUQv66l;lK8>h9NFOU9WGTAn$Astbbps&>ADRI}NF
znUPt#fNTqUBh^Cj;^><dx9(P0udC-yp+Qx}r;CPMvc=I)rqWQ#E61)LmNjsSexM_2
zf>|apIF3_DJr<~}N1Ovq*9zNI2hsgLCX#z1GW4t*porymzV(vD5n_<%ciR4(__1e#
zM5{XEh99R%E739MyiguS2s4u-v6dl4AN1Vnw_rB=gu~V{?+-csu&D_}x0&f35fBvu
z{J(Bh@<QEF0g)X|b;DrHLw!TAisAGh9bNT>4!7p}pdYQOTE6aOk?;IHbt*kQ@;|sW
zJ|;d*hgW0oTFkZ1c|hk#4d6<x`+`Xur4CjQhZsytzO*h~D!<UaPQuc*5YMx)?2S`H
z4Jd-$us~W3#x{9VG!QZ_bbMOW#g?XBsy(X;gIQX80t=#y*JNEr44~q4kwZ at XhR*{P
zG0$+GNM1N~H8fwGA4HRne^ZH|TZyr^CA?VWL9A#QN70Q-uV;WBU(zPw0PG*~$63pd
zD?<icLElp4fv(EBBAdCE<81}j5gGtRK5O0bUOor<I)0J#NGD^A#qVxv`w$(PER2Zz
z4ujJi#NQaeMc?*b0D<sHqt^hy{m0^acTzM}3D$+hE(s27pHnL)Cbo7d8Jh7rs-OyE
z{Iu_R=4<sqH>mICd$IIhnL&pr at M=*?8{hiqzVX8)3Uj4jrfOdQjbRwr^!)ZIIn{&K
z@{I-_9=#SS#aq=Tw?-qf;*EroQ3Tf<!Z19p%KpGvY*uQJ6pk#tPUu&D>LEWV<xWM+
zJyLXYAKRr_$&g5pec%_gKWa<bKtjG1XJ2w$9B^SU(1HJ|Vc~6(tXcY(i-@?m1qYlo
zb0xR4U^R9GWqVQmGJUX8HgW9@?e{~qSV~rJ0F%$L9Qdy}y$iwgHG-+CN8-QT*!4f?
z;0GBAZta~K^Oq7_L5vM)JU<r0)M@~)68JS|5XwPEP+4gZ$DF=Z_!*!=J at p&xZr7b^
zM)_jlnYhr64%$#Cj!@bFgEE-S+Z at ExvrTOI>r)RTLB4TA#W^YNGmWA#ndu?mZ$e at -
z{c3u}1|ujm#@zU3Io$eB%2kriUbnZ?Ad!S(paW(hskeX^L<IX<lDu=~a}U0bM!6-!
zs54dPq91V2^|&L9P0XN+DBUoR+C?$!eIVz$;yT8*#H%(R+rz9)KV?mwJ%70c4r;A#
zAGkmPBTXN5wW;ILO^4dn6}`k49{aTh%Mxl#QY+zCQE|*s3yAAY#VAR#L9al9Tj23`
z6m50YTmeb{AV@!`C2bd`dR;vMI}#2lfW>St1JS0&Cxe=6&o{pWNck`_E2G-^vb61n
zF{XE?);}9j%d}<-pW!DTx!nAdxv#zPFgTUYcLe7eG=NJl0byc#@tjj{*+gTeP|c0U
z;|Z{?evm?@ZyqiG?PWU9 at wgtXm9)#J>}<~Dj2(#xp~#6b+g!9kkxx5aPoFV{xwfeo
zdC_9m`rV(1x;O?VE8^}m^&0ed6Sglx=P*_gx_IEBhIiOJAatW`{89>jpj~+PfOIM<
z8ZBEw at 5&qIR<5mA;PbR!+)xsmVu%Ev5yWs^9b_M0R14fX(6-p7)y(zVtB?xt!`jD|
zS9FUQ;ushJUYyZKCS<Rl-G86W$+l&8Ep=c|G*py0LinbCW1{rJMi*MhJQ+E7cgWKy
zv2>}PA}Qzjf|k^e2%m|26`iNDs_O2<k$l2n$-t|eAF9{PgM81Vw}Q)45{`!~)3sK&
zbK=qSHR6|t^L210>UDkXJt}uP{k^}ZhcXa!4 at uiWp{Ak&CQ)Qf5R?(&gUC+ehA5&u
zFD3BQ<wa at J6KHU85lv};Ek}aOT^A(nom#{sW at VN)zpw;Vj#-^LL<L2#De!r`A2b0*
z3{>YYwb=c0xUWo{kzxDEA%bmYd{Jn@`jUi}bwPzA1?%eqz8^r?y3kR;EVQ(-rRRq*
zs@<t;iR3unZJNuO{T55-5fNte)*5FSn at QO}AAqhL-w9hv5TF~-C6(SKY1?76TK7K2
zY*|mY)YBWuGdiyKN&vtkx^2UipYN_vdcO|}Y*V3gK!9qCd8>aNF-%oU)}EloPSa;<
z(Zeb;GSW~?(u)C(7}|h at Vz-Nh(8S=HWB}9VMcoX2r$i4kJ+&+D>v+9!NDo2K>g?uZ
zu<M0chtPyp5zQBFAr1%o*9R`ltS7?{jm#+ZW+kEU$M<Yj<m8+cw7e<CK62`t#7Q?b
z&DyJ6|A>IBcP}%^m#qSCbY_%5Qq~U><iVLf|E#0RkJK)0=(>7<Em|ZgUjae?%b6n#
zna)ifbBo6 at SDOHrP|hg=Wa~ooTJRZ+3x!E^K{+3|BgiRi`S5|(KOTUf=O82)N<jR$
zV#kQxR&23Z%Zzf+wa2Y6YRhwQr3|e8Sws$3VF;=kJbQHToYO7+<({|vAZ$;KLvnLz
z=2uV{fb3%D;vrTp9`(@Sb%`OLAsAUB=hR>j|6{QX72#{BLJe`VLXJkJe+>^LXYOwe
z|ArK)4?X+J$uZNc9~pfmyQiJ#w2rh}g?ZZ9b at M8iX)mf<(H{w_M2MI>9e654I81Fy
zx6(Z<zNf?IX({y at aMAaMg7-80tvx87jPI=&6p_viMiymvglIS`>{5LyTSPD<wO*XH
zg<n}9z7_G(qNdyW!DrK=w4rtKVoC`~m*8P3;5MUwIvZB`Jsy5ZBWD at jY6L`cb>y64
zOwSsL5`P4P=j;jAXNPoI4)gKmfWN`oVIZb#ib;|M<AtJzN1e<fX_QOd;ct>F>#C1%
zobXKo;z0jjW<`xKkmET at jlLMyj!a8cs|S;Mxd>0)U4Gmenb#|5*yO_0jR2ItzGLu>
zp8FK#g0CQ8P;*?Q*4?U<U}OsB9=pFP8$Y)b16MQH5AOytVtIa_i~6~F><RvtKYGKh
z3L7 at chpT@2qQ7TwN}<uDV;5JR&#){uIv;I&0JoG<**_lrUdVY$u1GLl+Vk;Vxi$n^
zRHMi$34MLJ;%EMwe5YRQZnYn<P=TI_HS|h$l&p^ukrcjl18mYwd?_SCuQ~pngZ`UE
z?8nSlFaB5#dDZ^VMUyz+CBY at g2-pR%3 at exLU3%l`&n+DCp`RCf2H%Am6^J?(e?%;p
z=gy!~e}`peV^pd0WlbJl=WEpEJTx?L`&zX-a|s>F(>1ApO4%WFsDP~Ps&E6OiTbmA
z)6MVK8;*K6K^&O>g(*0DHF!2$nU5m>Y(^r)=IakKRW#x6dZ}ukwO at UP_nb&G9YgQ0
zvYg|3Ri>a9WrLnaA>n`<#kNL1te|&a*5WuR-P+UdjP}9S5Stk|wk!)muJ)g_h+sFi
z3CXR-LDwpd^2|<1yP8^3nt#4#^+XY1zcGla7n7G85zf%}D^Xni?eDOyz;S3<HY_h<
z!jj##wpS~L3#jL<;Lm-vY;I1%1*NA8HkLzqIo`g<d^W)sGykI{Iz4wbb`y&3NJtfu
zSVkO-2fU1#TAvxdk&kaNr`4HXqMew9C`@nVP>LK|$R?jQNWuOgff8VVmF3;=t?_W2
zs-kLmb>MN&VMq{zp2nQHL+=m1L<dP}Bjb8Y*`ev?t0e($Wagxh9nTFNrZq5I7C}%5
zRv$xGHK;e)4%g6~HE>}_=W$o;+v^AG`Zv-d0GL*Q1jq^okz#U>@ab=Fm^`|eXl{x6
zfJMP)Iryt+W4;W+30LVa_ctoVKu|N#J)en_!OKe}G?==~)~k4AJp;vHL>dEmJJ0Sq
zhiE)|@+uLAl)s_H0$<EJ%sok_rGiueuZA|Ule3fU6Yl%3u=t-SR2)*mJDQW|j at 5eG
z0tBZ;fNogYRy&D$J~F0U8BlbzR(p^sA0-Un#h9rl<2IUW#7I%r7p<*<w+j3`8F1oa
zQ=2};5ySI^H!4)Vr$sT0co!K8#xH8t6~#vLONQZ**>4QrRe5Ht#Kfw|7`1C3vE5+G
z*<?9aED_M0X9Cqr(&X!0PgtI5MSctsi1SkP%QH8q+h#QaM-gJH1*Sc#0MdW?V4<U{
z&;%%u<Cq;#xrN;*&C|)W#Vz4Ym7kh!<xV#%Px4NnKk4yColKCbS<WPP0_yL}1 at Y1?
zGYQpwo3=*GZ(>0e3tO1Y`UDJJQ%;qyw;)YtaII#8^HauKoomhJ$?lf at t}$%b*PMxq
zefTC~|9XO at I-erar6}qgV%+Ds)I^}+o=(vpsawF@>;I4u^`qtuu7zzZEsXLU;97{C
z$PtnK=GN52zO!KuVn4I#qC*aiUqXe at ROs_Zjgc-kAjkCymMoLe_JZI7x5cg7fOM*y
zuaxGfa)`G&Rd0%By?J-)6h`BMgHd-Whrfblr{uk{xTk{O=e+m&VLc*HN!lt0IW^3W
z%1<kEJCq_V39;GbeE+&VHrr3H at ZZ;)^4;(9^VZ5=Al*1kSfDXwwm35cYW96rnW^iC
z1_V!1)GO5NYiF=?OdJ%Ne;e_s{(AdH4NlB7M3zal^b}z7BXpE7_;~E`li!M_V8VRm
z-C1d>Aw&HA^d6>hG$y17HLXb0bseXxL>#47r_%tox_>=)?qJl=qs9*PV0hyB;ISL^
zETGhwAmuP}yLVy*J<>+636QOp0z%iS7LU+{a4O1m at X9H{*AS_`Ml*vdBSniuaCg13
z$Z5fK at s}&pO=CwB=j)vGUnEAD8tGk1>KKu2(Y?e1^*&Ov_rO*-V3Qc*W!HCA5Qw}+
zb(un-CmC`H#QCMP$=+(hhqHwJGl?{@9$AgP1P;TE^Jg&~nRIY;OTtwxf#UBJ5sAf*
zR#{f21iR(EL0$Bx;$5JvMP2$r#tvcocmKMCbs6M<4?)4z)g#~$ai5Ot^Nqt<`BOB0
zqsax4XYV>Uf)LZdV9gW)j89(Pu<p!_i^^OZHvfzCD{uZE1&vUd*N_~%P;E3r>dKh|
z?6w+<%HUTg+4$s$0)Fknm?8-U=2XG5OA%rAVOkz(J_D~W8fQFr{V~!!rBRCuxe;VT
zRf4Oz+3-K%JzUeA4L;6<Vu$k<Iz+3rG%K at vCSa7bQs0m4qy|SS74QB~Pt#KHS5>qL
zV>{PPD`T!`TNjD_a`%v at ur>9Vu)$Eg5l(g}Fy~OJ35)!k6PnFtJPj}3i(`&}yR4As
ze$YOKK`<fIjr6kUE;HHAJ2Bu<nHy*?#!j*b5jh?yq1}yfZYNbRvsC<?rJwjVLlQg=
zJ^1{5ZEg+w^)*}E9g{_=P061JwCTL_d;ECp(&TYo%!LqcZElJ)aD at HlFE)kCAq6(e
ziQ#<llkncMJiO+Uh}!}BcprC9fLO67VEq$7Maz&%0Kd!R<4#!+?zIa=&u at WvExJH}
z>hz3Mtay at -Dd+zBX;OR1a3rUk#N}?Ri+zpcP#^uXaEI+^3-)4!?|`TK*AM2CvOmo#
z%CF=BEd><`6hjSf&<s;a5VMRrm!KNKEyZc&9D{MY{}3z&0EiZU*Z-SS^B>B|e`6{C
zMYS;gmxA&iZq5I9tL2}p@;|Va|2+Qh0sL>YmjA8F@}Fn<KUfx4b~Xmi{|C!bq%NI=
z-HO=rsJ_SXXKH>AwumZi%~7f*5`JZe1h?%-p+q);DXjAO#QX^T^l}s?tW$}qe5r!v
z4J$^h7u);!m3_q<1I at 2nyQ`zqc_g!Qd%)H9R3?mH^L?hZ07G93pUc5pr|ZK`!i<?g
z-aK^L5pZNCt8 at A<vs+vgS^DvIZB&Z1Z3SUQ^mTSr`)4kut-(wSbu-fErr9QZ)}ycH
z=EBzNrm2PS<F(Ura|>gZY5!@H&N>^b_zqTT%k#A9d4G={mkmB>I`ZwUt1x|Vzs-vG
zkHw9bUb^4QsVPZBVC%_`B_y}7 at ycd(89}ReJoWSjjv0HzmY$ty4{U9oyKU<2t#2^A
zLxZ!))@u~1<`!vlo3k3tPWH^Huk(6d?1>Xon!e{_!czV}p?rTKPd#nXild6ZQRZ?3
z0^UtMp%9t7QtoP+iM6z`fccxLU$pXgqPaaFJI*@MqUGE0dnq!N8db96!+m*~3)My#
ztsg8me5bj&{nNA^s(Mg0Yfv&3+nt%M7m`8P at 23jetd)OnCZMT9eM59MYm(`ZS(13z
zv^$91SQwC{vvFaKnWIRoDo$v}S9B!`Vb1~b!VR^Y$WzVtxy_epGXaQv2+S^UX`$&r
z&^Zhs$8~o3pzn?ClWvB{n3gksJ5|IjuB?V)RKxFnGFP=O+3bnY%XLYzJdFG(CsdL?
zeK_Lqw&cx=(RS^SNorlb=#M4bck9VRIF1%Erq!eOB7yYGCH!|@?@_%qr8DX2N@{v;
z<=)yHWxr$?c};bz32pWl9)#*Udc##*D@^hW)G-paxOX$7pU^sCyx$g%Ssjvrz5Ki!
zbRp6^2YNZrkp%>atyZ^nV4c=amv)7?`HJ`O&W)+6yNlaZ6IBtKcTnH{?#34ZBIy1?
z)+&yh^bXlVkT;x#PTBR&*A{%9oY0~$u#EKBj at vYRtzT$K*y5oSyz@<w*&ay3QNi-z
z&tI(Q@`sQfWf5!b5i&=;MammP8qt1V$@Y7}gmoSrxrVK4m~3 at PS-vK|EJ=Wz-}CcV
za8yPem?Glyn~?k`=qR?&sCj4W^Q*yTzQi3roD at w(2^Z*p!BnAeXKDKb<7FlFCY%-}
z$!-<AS6;}B;`nm>&+XWbyVG2#8>jQ;FTA5dRj+e!=3Ei=yDM_KjqUc|Z^JI~NKg<q
zr at L_+`NNpIN%cUJ#<H7(H3xi6U%MA<-SjBBId}O6F1?u!E*z3%?Ev!J*njt1MNK-R
ztsnxB at v5+K*A(yk{&<$^M_c0V`=*(OGds_UjodXviY>$Mgs^k+0=!h*(kWMyg9&k!
zDZN=+yrZc0HdQY`Ie2`N;$X{Cd|{5<F#Z-QBjFXl;dN7+EWO9zxJ3#5^?KYw-W!+t
zQ#R+?r5&A_%W3;VwBl1mOj*BF|KyV`-(@#d;p<M%oa!Ajk|>Uz0R~JUjeCQGhfS)G
z<Udy}?<nO8o3X;dQ5ApXb4 at O{vJx&Ez2&C76_zS(o^5PbM$Loir<bxyh00iWqgUTi
z)Oq>GW;BBB8WziQ=)vw#3@&Q&Ox<WZPrpC(Ai`=-EY(Zd)#upJ-HIY#=j>iD7U_Xj
zR5G|Ltiy5XDwE=8r85(?0lQ at i8a;ea0w1V5*uEsr<w&|CuzYc_d*bChE%Nn#GrhXk
z-gl?=Z-yay<n}ncs(7)32iemnVPW at ZfH81QMTdWCFx6lf2^sNw`+o=8|B6p4zCI1P
zM9VAb-B+RmV=`xtyt<E0_a|7A3Uf=%m|rOI6lAU3U;kEqvu~F{Tm8a&*<!%o`Q%@P
ztq5j~=1(6!aZF*2TVClX*>6bNXC?=q=`#h+KaEnG;o936JDrVZTaHlQ^Z)rxv;45k
z<<5*f+sTaj8<5C)ekKm<D?*WgKU6>e)swN{lDVL7r8wLD-P#$#`Xt_ahom>Lj(y8$
z9OT%tKz_&z20Zg^M9vS@>s81Pwd?(gEb<+`Tnh#}fc_Ysmvn-Ea{W1DL+ECo8}ZfF
zN8LT`N`ylubhbC7AUID<4?!RM#m_``)gPa)A;dkrhXMJhErzDv!B)ySn-$_7n2nAY
zKjxM52<CClC2c2JpmDEPRV}|Kuu6&f;2-rUQ&u2=gV^9uln7%W3j~~LF9f7IIwyQ&
z1{gT_nGFHw?XM@#4FbcUhv<BoeY&aID$M}72qe-oA$~9dlX$H`Wb1{Gd2)49r*@1M
z7<Ogz=3sON-Kd?0DOOpr^w&4qMx#E~&=tm*7TM&*;@X at 4&jej)8x6xT#Z~S$)&`s}
z7Xu*};SrH<1=O&ucaA`N&B(j2*?T}W!FEpe2&s*yI+Jl(UrWRJS=jQ7;mwjVae>J*
zw=Ul1j2N08u<)fy+CYcc)<~MUJ*e7jE|g24k!P+wH#@(zsuKV;>8gAEvC8F;IVl5;
zWV8$$l-t?RM6k+{3hel#hYi3;MdZIfH71t($+~4B>m4A at OeGmi>jzgMrD{Ssc5C&v
z68F4ZGt)7HPAbxoh|IO?h_E507+js0C$cg~I}~tA0g$bM2FpWh7-BMbk^V|mV%bt=
zQDn(w1exXjqi|G_=cVX4B$uERl~@HUN>Hc=SZ+yKkIasmn+I~04TSa*Y2>V?LYTs~
z(=9})IZWAT+<<&cmjheSvX*FL*J(WyNZQRsgedqJ<rTPRQv~K?<lqJoQGDoqrn#u+
z<J3Mv!a|n7E1zgD`de)sgTy%5PW{7EHSN)Otfz?wmomg-*`v-3F}p%W6$5VAzd0=U
zN0M+ at jOy2wgz+F3EaH#dHSc+yfu1E1piXcFAAk)+WgrsO3G1MbmcvONqj4Vq$2{BP
z62a#b697jNxX0Kq!IR6V7cOgz#~K0AwCw&e5?&UjM>7FLk28t10{!(BE|UTzM`6=V
zb;y3Dj)4;h`;*=upHmkX99%9|YS{*emM*_Q$qP_Um%*!461L^402F at -5T6NaIgxr)
z|0+<aRQt&gLzOBwIuLqFv>@)<<(T2GC!zP3Q>=op5Hr$>uU;PnWD+?AXzz%k9dzc<
zXA1 at 6BN>zHU)V<(Z8#8hm?Ml~gZm}X*)Gt?_5RW4Ci71w0Uae#*CAeb$dzl6n;0U=
zd~|frKzz1C9EdzD7DI$7nopVmIpUd(+J3)dA2cS^tde-KO&tyc))I&@O(vWo)R^>F
z((;i|qNA1NwaPT!#e;}M#J5`6q0))#6<I8RSS~VoNtNXdX?6}uNTCW5>Ve9itW#C@
z`~eyW<(vt)?a_HJ>o2*ua*YzJgjJPzqe;f-TFPqrb1qg%-ggGx5(#Q{R~E)~Bb_+{
zS~+S>FqH}9WI)x^P1YznmX`8)uN2)<KvKH=J*8dwzm^N5DFc~5({9b#=E;?HYD$5&
zUsc9Z>DPHbt>}_(30vNcC at -8Xg8pkh1=Jj(z0}I}Rb=A|s1umY?zGo<BP(2~uJV+T
zEAR()uA`kge=8&~kJose+(`u$+6vUsUQkJZW6t)lP$@)&wrHLq1e97-t?X_sjK2c<
zXDAC&#eHBn9M1Y!#ji9fVB47@<11;5LmbZ*;gUHfk8AAZT`P3ibWDe{I|tP`OW8d=
z*?7l1eGR4V-7u3;-?-9kb8y?6 at ruIB9#}SW^_A;h!wdrj$2#R!q2bzn8G!#i0JjZA
z+oK0g#u<m at Q4;jqA6hg}kl at TZM??258_Xxq8_Z|<y)Fa+HT~E$-9bOnNsIRLZ7pmx
zV4MJr{jjiLea;xW!WxmD@#7G)8$qrWx*UWGU2QeN(TaWSwVJzqXfQL2sM^3diV~qK
zK&Z^3Pz+dw15%uHT at YHt#EOfT71fKlFwR3sQ_Lu`%Pdm$Ev_Kr3gnm)JJt+qT}zn4
zgsEUd#K2I at WWeitHh6-R`!K*iI&+PEjM(mv#M}mVmr=G*O9tmt7=a<wv;#Y|2tUUe
zzq{H>S&&S&Lu1wt5$ppT0yZ&QL?iMS2~rWRsYZpR4_i~xF3)lS56|7!ahG34-^Vn+
zc%bO0p=ZqS;8C2#ZBx)wQ3cmRtI}gi(&;2kSzN>$MH9|MB>_ZZSm<dX3O4wj>#G|e
z3vQz@;u&HEaL!WxUQkd2jUco^X)JA%Qg_M}^Jb-Mv%I;3WcAESp}=WM1h=a&J&bqx
z`IR1=QUd3GuLn6y3Si_iIkaRmIlSmJZ*LFJ<lu)8h!5V}<GX_$2hVc6HQq~{%?2kk
z#6~Ha)J=0vnc_{KF<6e=83mMFrUf1p(~x9}C0L}};lx^Q$O8M`<d!Pf#Pe|Aih}f#
zSL8DONk{8siQ0v=`7>CB(iZyur)-<R6C!JnM~LtK-0<z|Ww_E~;3+S2wA<z}fhX3Q
zGVaJxIQLotFD%|(`|%Aiv#I6GanK>wejYeoUL1)l at svjC9-!J2C2o+|u*}^7ksAv9
z)$TZC8?Sp&G0iRwtXpZvb9A1NH)1a|^JAXdztN@}`RpR6Q>GhOqjt~H!k9O(wDQ!Z
zKWLD3P3dmWOlez*r>~GN5<EceF at fXP-ht}*$0FBwEwhyV-*xWMcdQe80;nVYfN(7S
zF!b<zjB!YTXYy{RuEOJP-;OkDNcA{?+2sdgCVuCyw-UPtNG?*Vz+(rot9<Xj|FSTt
z*G=4Y497?NJ%$^`J1c(cKVga69hCL- at ysl**Us!1_O;Z`z~gdb!|8H!#pz^DhIgl)
zQAi}P4rCf%6plcF8am53g;W(lefNjGNKPp*dPj^W<KcV*xd$FHuK{KbXAfuVrp`^s
z!fjwn_;${}cauzG<-PIzw<9)#EKhVvDSKq#EVKsE5XFbbIt>VrrIvyDEbKIF|8W!F
zeo-?->J5w-MxJ3N6*;=`lns~NwAR{>EvLfdfp)Ta{FOC*6~{FNq`r;8(y2}~6Q~BY
zk%sM)pmaL)=duoNAQkk}Qt++_+d=gYP4M!5)fE(GEW}t%U;k?jd$NiEyK<bB%Te()
zaz^Z7_A&y3WUsYvhwwJeAh>kWWlYhefUrW(1=E<#SP~Wc6w0RU`LV52H`;q~8!=om
zcDoOD#VV?IjBkX5gIfTF-pm@;AziSn7bUm)iR?Q~b?Wy_f{8?sZy7MU{L=YoRN$Wv
z69psO!txoo3<FlUta at I-?@q(M$uxXW_FqYKyV_^IuTNHuiG#icWx{qWa>2eHmk|?<
z>}(?t5DYu!+*XK4M9$tz+nPs42*dkZykHE+m%oJ!^=D?sA=aO&U~zT#ZXcP*NAK;k
zaaRqeR})gBSrPAaO78cb1bOXd?Uyk*k@)ajrd0AR^4Lx2awRND!j9GV&y)MVd=n7C
z4yQk*Ob at e4KE;SI&b$i{J65hmh+Ui;31WL^bPdU3cikgG(5aaf1X-&QI^l(#GA_Y!
zUYr*Y<|(`+GXw=>Fc<h+&0S?x+hT)ro_w_1grZqTh+nGz2Y5h-zxJF2dF1{~UZl1>
za+upzM*>$IokeORpxlo(!jI~Bv=NS)M;f6XFFVo*x0>xrBP`eQNF&rUYT&Je{xX==
zM;aZ&mPRPv)VsSkx}lDBq!GBJd6(KK;MGQZeS6ZsuJwo`)Vw?%al{9&qlO&z)n8~f
zA93VSMJ3wmh?T~UIszwJd(;ssRXgG+%Ge>;E^}KR?J^ho2syFp(MKqv+xyf<I1M#7
z^bzjjP32d%JOZgE?=E%Sp1cjWC*Li*C*M8)>_miVc(wVyhQ?5V7Rd;aXn=lyz*$1A
zG*1mz_WrP`hZRCgdUg`5M+?nLLr)SfPH4hG3O9GhhDuW}z|Z>Xu`U4%Sr6D+3?{`>
zjK>XS=F)a++^)O(+?qliw=lr1<a5#6R0R+tz+Pkf;O!cxH_#``Gr9B&<w(&h40t2H
z?zk-Kcm0aw0qirj%aO($$7LH)(M(ksIM40<bCk)Noa%{eoIMjx%h!*B!Nzh72#XDU
z?Jq^pOlOr6rC=5snzgToBB}m>dMGM|-IssAhHO<N&|5~~Ad%|Q-*eQd%rF>dILhg`
zj>adwMKDVDeAn0L at wFz~9Dm<~ZQqBJ14w>dt-tUDO$OH?VvxRW9{T6!XrGbgIvfo)
zt9T2RrIBeK#NF2CyPQ|RB)<&hN-9-;U0Hk_su}WXW0U^r^mk^mgbwq4ab?bZ{-_z-
z;P+0I^<ej(;-%TU8OI?*7YW1X8c>Bzh5~)y22<-z=&cTmxHeJp9p=*Zd?N$KA`}qR
z+2UL at jzblLgu^+bz{r5V$2f%HmghIQW$8LSWeEeVj!}d9n1|f3DsNXY4;3dsG}t6q
zt}s}~@cHc!&O^re(hAf=hmRzqXvp-D=R7)@8<Nw>VL@~Ce at s8TBaw(YrN94=lGqIm
z3E<Qnf)yNfKVIa!3v>M}yUK`vvqwTr>bf(TwkQ70uR{JW0aV6|=I)3~p at 5R%my at u2
zdBvZhTo9-f7ol`VWO<L-6bEP}+}i4ad}IqA#QI!4J}z(x<UfC&88+zHrNev2Iz~7^
z%MbLM_pa^7;4C7P|4}Oli(n0>RGY`}p#ja`4Ink0N>or&ARtP(utf-VJmE%XvIWc$
zuyP=uUah?AJHB#6UqY*{U_<VgJ5IJNvSlaTFYf6nT?v!Dx_*nD{TMzpbQ#P`1z?h^
zo7Wj0SLA4m^Lv-8r;{0%A9ljdxUQE4{&-B5d%bXm<kx7?MZ+QfzHE~wPIvO)_Cvq3
zF8Dl#Rjslc<H6m}@%W%2I`?~ZKX91nPzUio7QTa#xsC>O8<^$<bvToVR|`qsPl57P
zA9hWfQO^hCk7AG-Gj(|0bX5mWVTZlgDHaY at icT?^UW{%raacyIqfk!2fmSucxuH!J
zBaQ;oeW#3CjobIdBeN$x&dS%YyrRyzYrb3#rbs_A-f@&kbQg!H#`KYU^?|0VY(r)b
z!q-X{h(I2ta#v>DL at tD0H(q=vKq6$sz1;0*)}#W~65o|cFw`@<P86iiTVz+Pm#PBS
zI$^4D7P}_Gy_CDz7;bXG*;6k%&m7(=@4LUR0m8eB0Q%et<83{1k;5+TmLhr4O`H!H
z3Yh3Wo&w01=X{r)4s*uGopdk}J!>*_zm0u3{nYo(=0WEr2QN`apL)}r&#%4m%=JII
zt0YU79E9!r6m^1n;n|$$Z>#RVZ9q(s-G7x2rNaZp62fRK%{5QDllCA~K9ha-2=$oz
z^|#T!7(~g5)!ptkSe=ioO`1Yav3S9cjOz>M4uEjZdF2w0m;|u*>f$sRkbI-y?iYvs
zu}n3IhOsNj*^Y7pvdjx|xO<PJAF0WDCr4;D{}#r-#_UJJVZ!n3h0&{nocqw>`@v2{
zK1z6oP3{13F7#`#ozREOek~OTqx%3^F4l0}8AeM7e7q4ss0Xzxx4&20L9CJ$)AFfr
zRFZZK;Bk`Di?v4Alr|Ihj^ZO+c~{EPD|jZTuyfLXWV6)v{{dW6oAAkO^9^*Ze<qz}
zlg?q<(ew!0M4tEwb4Yzei2SUU|7SL(C^+W}>Dby3%YH6KPky_HyBWgdjguT<vp%r^
z6E{miBYGFdR9YX9ti7!3x_Yswd2m!IGH{sI<m>-tJRv9GT+_zz<H?t%9?UT0|J^~a
zZ7W&V_aaZ|Fyl&*d+Q%Dw?ia7fC1V12hg<-`}v31g{<NpBK9c^$SDHwDH>Z7Y3XB*
z1bh-la+XAL8iGLNG!D3vaimV;NP3wj|Mv7Qzlt=!2<_$*aXTZ(vrxC<XWAnTlXbRi
zXqs9{Yh9J`1X&Y^97SSqB0P=6eYUSOHHo;Z5o8i<lh~SOhShzI?!s&n3RZXCK-1!E
zB!)7=+DJTlb{~IAKHS`VW=Pykdzk(ob2DmhSR0skO^F(^cI_#nNtO6HF2k~0o at 1Nn
ztH%*!8!d~;k$65X>s#aJo`~fO7VAr8#5OX9(~-EDGeturr9=-N?IQ_T-{<1ph})?#
z{7xcpJeXjAx#iI%CRh^PE;fN{YS<GLAFf7Ev3tZg_q1y95vR{DH$D=R at fMtq<g#6`
zqF5h^hxO2-)!5C?3(<O$7`G$#N8_(_KeFq-cOXANOmgKF=rK1^B^|KDt2!V(xL>&D
zc3YbckE4m82$2V~vHrhbzhz~0gm6JxFLRa(<Gc-2rTC!FDz#G)UKyN_jxkk(71CKu
z1;h(sRuj=azp(08njzgMA^GBlBt~jc5xDTQKiJ0g3w^9aOnAi+X)2*=a73Exo64>6
zV_oV-T+j7K-zc|xIQ-vCQET#~y}eKxEr at gy60bSF+!;x{hgk@<MuIri;s0yJ&HHJs
zS?lfYNRZyGN#M(sc&-+FBQZEF7>N-ojKqA#ov4iv?&Y{I{11;L$b7(RVv;0Y?${Q-
z at Ix3YFmeoGqL=U*ZAzc0v30kwN`jD4uXrVm?aIU~)p*3FfWR(k{D3gUFkwx^a7?->
zYb3=o=`kp{45zH7Ni)&S_dM9dV=hWsip;I|9D)pcl0M=&;7f5%dYwj}ecElKRfcuS
zdVzWRtSEdzCo}O|5Ev*F32e*gD2Zm?5f)0fY5q={K#4^lyd$p%L&vT~Gj18dMbq4c
zZ7UjEL;ESD(|3X7&2zupOl4ee)Df~W!whg#xrSS++yy)pc8ORSQqK_~j<JgCLLw}F
z5O*t7I4e!&0wT?QO}}`n&+Aa8XwynDdZ0i=7Nsw5jZ6Q`zaSUPDPIv at d*`YWWO04b
z|04O-;u^buL42+J>Jy1B?c)?buTxyGeIP@$3WqrTejcKHr0tH<ZfQ0>j+PZbX*C^)
zhINWztqp4cF^M5%mOyfv`+cR2%xN6RX at Jye9EoYx08_*?0Yv+3NSP*((mqeo^w;Yy
zh$;xjWF at Q$BC$8IP>?BoKz9Y<sP`KRGNlPPRY4e8mr_CIG2%3R;L|>oit<O#-)X!?
z%##AbAvi4rgpqS*3JAxP at -eAO$0S~kLOM8X=cIIS+{dWWAqb^%a5&mc<tVZ7OdzHl
zGJ)}@Du*n2dsPnIQ%mKL{jZhM5$6l(U}Vuu>EL+mox%`F4e6N2UXG7A+7^a%$UTl#
zwL@;+EP`rBRElZGM=fCu&|OxSBc>g)YD?*m+E}wn2P2y(r9-Oa6k#X_GwG0{KjSq*
zI;M~gEtgfLL(`ecq0i0r?Up#tl?YjVS<R?$#0nuCu?G{5>D{~Of}FxUhAD at hbCeNB
zA8jayWXjew<<L~#RF0B-RgRC#P~}+9_p^d>`R4m(qVZoenX8%Sj7uztQiQ~`k|H=B
zb{eAyMj*9H5ghF{gCbV5hCL{P5jra=VzClGg#eZ)cT$FY!7bsT*ND4zas+eVqbwF2
zvBaFU<OpHMdy*yAu$DcTf{|&*5~kpA?U78e<R&Un2yk{X1;@BTV~P at w*wZm{t4tv?
zSeK(rp-bM%6tX9)U1bW{^=!!$ddf-^oEW;v6C9pZ8pz0O at WhgyXO<D7tCTz;m)U#e
z3AujbH|2>a7vqVKg2ET4XC{6NVmzTWvXdyJLS8(<+kCD!hzljNXR<&!nDK;^%%#_e
zyHE0jluT=tCnTB6H-QU8zivbkalKGS$chXz7*oU=!4$CzV+!5nNgmL1yn4))ZK{uW
zT;UcnWo2qaAvb7LqC`=$uSD^28z72lvY0oN2uOfmTJMDfCad0fk-&`p8vn1^k_09%
z+Fm3ejoc_Cu)bU6fW@=T7YD5G{p{C>b7$dzW!-vmz~-X4g#$LX<FjzUjx#t1Y$n-}
z9Ka#9!U3BPbzUT}c~i5H0LP;j63BSOrhqsJ at SJxS5|B0biv)I9ACLeaV;85X$2>0<
zSk}}z4RGp8FA%v+7Fg`@iWQaXTD!1-+$OzPV4B1^3wXUa3%n}|U+k5s_$`RDzzkLZ
z3rv12_eBFsQ;;;kMMJ$j@;sT-03W at b*N8)_(7-Y$nl!Mr$4(m9TJcE(9 at i^%gsjdm
zgVTVoku>1Da2k+ZW`iK{pnUZBqP>VhGI0tIaIUOWod-CZqZJ;={DTMH_W>S|&L=yD
zUq!|pf&3I?Xh#X88)*%#h0D1F4fY|A|1g^)AI<j0?asDm)2@!#k9AywG at c8@dO3sm
zVj2yOfmL}9%fMXIR<XDHH0)v+)gIgv?;HbYVw-cL&1hOo++@%Dq8v{Lke~k~NbTol
z8j<cN+*$x(`V1*<Es!vMm$&s)(-%NYV at R1MkeG&~Rhng*0Ad<L$~1xGG)IZLOyfXU
zP($i8juZ>ZQ#Um?@$3tt(!y~O7Kxm5AuNn|!QubaD1=3JPE>`3q-I(Q3-QEHUaQ38
z_Ik}E?{dCI9P1rbSxA<eRauBv+dGwoWAKnE3&(y4Qx-;szt5!u=B88 at j+c1~Qx-vP
zPi5g)_hiD7;fO8mma-zB at 0qe93!YhJMRs&Y%8KlHo|F|m<Epa4dAQbusjQHkrRYjz
zHgtvLeN!31yB{-kMJ}_Ssw;B+hf-IfSWH(w$_ZZ-Tl$-Tsfw)m^i&n8kGZR=Fhb-O
za-m|1WRzo>s7S$>i1>(eT$Z*K%&wxM$@ER&`r242DiPQFbcC$L9y1^+DzQe0O6<Z!
zMR!>|rkvxXgy4&|i|lA3R*H(G%Bs{vMUzP>Dw%xMl=oezq!3Hl?7^5YpX0-X(zb3f
zFEJ62gttjf6Wm7GVVoxRw*mN at o}Dbg#B|q-B at Q=Hr?3R;3nkS{eD+HW7@<=Ju)Mfh
zXrZ#WyeNXzW%WW4tS;vkinx4$`=W@;2RKO)EH!Htinx4~_M!+z_AL~_v9^xR5gCuz
z6j^f#mf(1`!V<jZtM`;WZ7L+eyB?#Egr71=!kYmniOa2JF_ at 9qBneLavtJ`xFC4*F
zX+58F1mFE$g(JLHoFm at Vge9JqnfNV;v&1p4;4H!QVQspz#Ifh&EO9tzyO2O0%xQuv
z=C(3|OJ-4_2`-suyl8^cIeiyM-s-K;gva$p9U&_-%-}TPYa~thE}SN$u8YCcb0lrx
z9BZ}Lh+)zMn&4bnr8-S;Hfa}{$ozvR-uEFy(H}0l7CiCG0Cy24Na(c^@zzt2J!~N^
z1&JrlBAus%<3Tpic?!}xMrh|r^e at -djVxIX!}2}FoM1|hGUxf}pZljv0F>#Dy1=KF
zAt?azI~3j>&eQQMqOfqDC$gO<=14Ovitk>l#Klco)snu;d2*X8UY<?coK+43))RQ;
z*OQ!VZ0Grv9vIJ(lXF+U9_<FU)!UKl(Qag0y;8j3^|5+4aHfgKGtG&dX{z5k=<J#1
z1kN-Od8Rp$Gfnf<fU3_lC$Np at jy%(x$Tgl$%HAaJoqr?H6ykNQC$R084K)RkKH{Cm
z?=u+KMFmi{VT($sezit9q5^zvB at m7HEwV@E=+B7dGu5Lhz^vy{6-27dqbk5Ho|?<_
zk9`EG3L-r&t8*sc=toolXFQ at LDvX4SfT#ekbdBeW>)Dec5*5y1{fLT|v`1CAr(s7`
zxa+!(s_2yCQ58gTkS|mPnF|93$+)TAqJl`x`C~*X{iup+xgJ$v^+!Ica=S&U^4(AR
z$13Hk!xWLKs72~g6*dUpq+3-GDRWy#Q_J*gHs6y;RoFDMKO?+pdOND3rkRhbD4p%7
z3Y(^E?VAsNOS&T~+DtP at Rqh&FRqigND%$0>mOMwlDx-5W8y_Re97k1{tNw at zOBl2Y
zQF+r3QTZ+hMWv<VSFZbPpYGEe-z(o<>G4R;*R=jVkt02AYl3IAIekTbs5_4PD6j5#
zq=gxW?f}=CkM02HIUe1)k)u19qxGvh&nna%>>})Z=#K9?*}S at gQ-sT<?l>+F0sTC=
zIKuOl9V(AG{UEJ}q)*^*eMBCTK9R%q!x^H#Tz>**nut8poXDAGy8gbK+4xMNz%$1V
z+$q}Mkw50xfulMRd1u*?M|Gz8%~)?QVN~mHFP+HgC6DxKx1Suh`S=*e+hIgMc_f!{
z`)PWGd%ykUc*bRjemarUPZMXm?Zid;Z70Vc&4f)x3$vLV&w6{wq24E_mrgEDFMVYP
zz0`1<|M-RVF~};k0g4oX-#0J>aoZm_QEWihbZAY{bTm}{-|l-d^VWkzLur-*x$`?c
zyu*rWU)WZT;Sm_l-`tAeDq0Lxv;H at yso{LGd7w;qEY}>t29M(s+lVY<at}0at~1{b
zhd_g``V0RY$j7>NGEMP0bAz1A$2lB179zQNU^%lR0ICF)B>mg><ERv&WFT*F5p1;|
zYdS}RW|B_X{Xz4<W>dp=pnBWm-{1$Pl(Sc^<tg`5b2zyYB`Mqr5ADrElzJ4iF(;=R
zfPcTb;}<#O1J=-s)7!;Qs=X`Vu%~Di93``P)ebol(~5TIP7CW79i=EU8 at 4jE_Z{f|
z8sxu~r^K~JSK5|UO>Xd$?1zl+wFLA{VCyyyWc{Q3@%i);n}vRdb1w}}Db_{{`Yp&)
z8*3jBuRnI;4isZ=rML!zeMuEyMPes)Ol56=(0o$6IsMEzbd?>05&rT^U^&-jo=y1o
z!BBnOTFBiS=u-jugniK_t at r~Q+3N}PIr)7F&dz(=A!FtyBo_ at IyogKPwj_)WOXuZE
zNswj{`DlR`(^K(?w8dut%hV72xrbNa_XZ|8`1il_mnTr?9RVsJrA?YXtPl3VX>!}e
z)_2}(PafQbLn`rwb+gnC6w~*mR2KG?t{B|YK5Z?Lc^11Am1?YU4?n0;VyO|8Tik1}
zx3YM6Svm0M?F<$At5ts0Jqg0o at nC@3f)ucE4~)iJSx{_;Hb_7<3%0xqFcc_W-OWc1
z(|REM at IzOf*Nwib5>-x}(M}x&iR~vR9t2>V{0dJz$PA(*b}4osZ#-X+_dDD@{w#jL
z_6U27Ml~JhLT-v}K at xe%n)a0<@2hAsY#)gp8g7|on&2 at UDmrFn9b{B#$<k7 at vxRZ5
znIQ}58ATOn>Jh%j9QL);@hZn0rr~CRxwhp%oSVirpvWZI`#nRi0jt_^S(G{y8QqGd
zC8-oHY|QElOWCa+0dzCXfRZ#NvB_FwA at +h)GfkDvTe`lR at tk~t0Hz?>8fi;5bZ<*i
znv<9?H5DOuv2Ka(36h#gxauB`92Mlrx~cJc4~n+vy(tQ}X!>OJg?JTR2E?V1ahb~c
zNSZv-0t3R)^lI`r13w)mfYi$607vXvrzrF%IAhiDvLr;d2y0P_O4aD9jBeD(B?g)c
zDBF_C3H&0^p#%F5&Hzv~K$9KFG2Mu}oA+>;hoaG~>MA#_*5=DS9sJV8J*BC+AibPz
z2o}PZhIHkESJ3w~7pVm==|bmJqB-fhvO1ZX12|OA#gozLq7~)PXo3LqHgwUss2sh5
z{%k=c!3I{t&^24pOEe-@)t4Y=WHr|VIegUqexG$+^1%5;Og(MZOR+mSIvpFGnJ at Hg
zl+BUCc|{tPH79vZ9yfS<(HY!=`!9-TN^6&2i^ff{b4x)dCJz-AL`jh2W`91I=`9)6
z1-W4pfUN%A)ZyLJq6f*H9*}pQLToCZXcE~r-eMSk6!q&69nNbXyFaAbV;3D4Q+M-{
z`fE-zuSsM%E(aWtW0-{&HyN-qjr5WM)d6$9-y2!hVJXU!R<;^>th`yic9#~Jrqdzw
z)LO~5GBNA^*vpb8p*Ce)yK;g{s-$ymf1MUmgtP~bQ<8uVQc1>Ak2P44H7Or$=$68@
z&~W4f#W3aloYRay=VRS4dEM*<Ym2}lZB9y;@1^U7)>N+2KX?(%Kr-xYM)Bi)r(Q7I
z96dB$pARY5ZNfKPXSk^f)I5;1VC{D;FVWVr5%t&HW2s;>luckh?%(k;rcl?w{_5da
zd7bgd-7*$^XLHL~Q}s>$H`n-{##K#kmHmue!*;V!a`&Mg=!afqOR at rENWq5+(o0CD
zpw$tQoE2y--XhU!I!lTB*HSnYzVGh$7Uh=Sx29Hukjt#D2*|8ji*mA+Y-p)ox2;)G
zTuw~~!s0S3edV~@;hV=${i+O at Qe^Q&O3KkF+r4%DdrB%&6ky3#X10P+Yo!L<sd=}P
z<|-S<VH4YvGX*)k^G2QTGrp%K29C+)BwhBh_PTJeqWk4ron-H_da%$o*IliL+#dG~
zN*gbXtn2`ixURjf^y>82!4x$FJyq2=HEwmrT`%*`Cv*RZ%NvYVA2e(vbAto#llPxw
zK6x_+6HW%sgtHK4cJg>m$085kU%ST{e1II-o!!TKy6*g-WX(pHHG870n%~mk=t0sp
z_j=U2)>I~w#_JLbs{i5|^Lq+b#=rZ$Xg>SCXr0-@>hrP>_GT}fIlp8yX!Q7R9X#HU
zMR26J3mk<!R$j}KXX8ba%nI_Pat!f(8>Pty1|YAY!?t2L1KkPBRJOVUwdi3rbu<~2
zF$ZDk@&DE0tfgGt?d0nR&JP(LzR9KgP;QZ-!<Dd%7CIa)ROQ at yR|`RKzgkc{kYnr4
zZ2xY+NAxDTZGmNqE1v<FPj8T<<?D?3Qc;hRq<7f|Q+Z&g<UDliXHT;0X+&mB%An1a
zXt6>T^TevGZ3-qMe2>B#2P*XuLj?8 at 0Y0GyWW6KT1DAB*jPl?`!)xBj)ab01Z%v~U
zHwO(5r2Zf8*F1%?#5Km2{Z6bfVptd^e0oP1AzpOTJyk!u_R%}w#JceC at W6y5dmv5D
zo=f~ekFx at 9cQ|L<HOrcQjG;G_cGIORe5Z_bm84b$tn<2bO>QNQT at Q?g8~1zhS+o>n
zXcs^`|M{*6Ep9w?2Iv#CNaHe2;P(db0y6bvf|#EG@>?~c>Ond5xy54 at 0_9LtwXMwm
zbXQ4&Eh!GWN*w{rU^q{0v+lobOEM8e{@<%i`2peCatJsiv$q8Fs}%)Yhm{=xNCKV%
zYxBm9X|v}5wVE at Ye1tz+Dm$G5G+651^qS2Zu9}ni2)xq!1vx=oIoB2Hu%(~Rr7a>L
zCO7n=V)gXO+^0vI1Y!klg0|HckDIq$D`*OSeupZf$Gy`Bx7`0YpfUYJpdFX412^DE
zYE0yQHl7f;1g;6o2^Dbk4{Y<EU?G4@&wTdA=yN_V!s+wuc9jC;KX*4B?^@objR$He
zL44oeo5I#7k<EO|@^sa0<Pv7W)TbxIut9$V`plqi(_>2|wOq%yv+XU0rIYgTIG2zR
zz#_zH5BWhQ=<GCLyxA9-xNvK7Kk$TbdR1SXRRL)&H=Z#Pi%8Z)e7j?wBvdmf<Nlq?
z0HV9K!EF6%TpH2Px8l8W>PxX*Z#3Oc_m`mSFtatt+1?M4hY$7{>g?U{5`Ab>zn7|E
zFy!GqleD&-0jfF3tSG!=sO|L(nYD*QAY?U_TSWp;5Vn+jziZbTib1t;dWvjm<z222
zqk1Fn{cb5;Hsi9qUZ>bi%bKc(EM-(^BpSGafEf)<yNYbKmVPzecdZ$qC4`-htwS+#
z&up{&oXfF^n0aH31Y-8Z5|a1KR?pEOCPits3c0hUN<d4pTF+tCw&iINcQuwlYIL=p
zuy{7L9_!M&SB{y=>I at ex!n+Hp;CwzwPp(Z;M;Ei4Yq88s(xj>a8=l;^dPZ}R!dX%3
z+2CpG8T>=KEK?WdfX<QiSejsV11*_oG>kywyym8$#LUHE*7iUV at iy<@SKDv%2)~oG
zpeLTLS5iAt9NCSk@*8&d(<3FABORF?y5{3qz=tYlK9o&r>^<`~$!12uMruAvc9TLk
zwv1sDPp*AD at Q<K<$iWH<xHw)OprqiSUt9{G at euox)~5rLs=R_$GU)`XpmDU$usNA`
zC9|2dlC+&@7Ao&~dX$>BR^nc&#ziA+xpJ%*ChxBI?|lxz&B1J4-vVn-TCL;5$yio?
z%#(vOy}oubmdSh$+U*yk2~xi54M!PwH;Tn_iVvY(!;RvuTp<GP)4ZIGI2Ix|aa+Nv
zUbdTJV#AZYt_S~I7!CF34)Gs?4D;)~6;qVO+}bOE>oYW4zIPI?u)eRea4F7vJPQ`G
zVD1|Zk)&7PUKRG9<}2>fzO1IVRjr|{sn%y&zeNko9>_q>zTe-$(9%@nEVg|61YL at 7
zNjlRq^cwqygKOy}Xxh~D>9E>G9JhROYOOI0$Qe$<$<yi4ug5>T)aDfV?-ul$)yR~G
z9{-%RV2Pie2NTK>m|^elttZrsqUiyPXGS|x6N0LNNp<&ejgbUn4ak96n|^oH)gs>n
zoS<Q6pOWU+f+gFSqg=@NeO3&K^a2^$XPaAvvne^aj2rSLH^Eg{IA>8zsP^Bl-?e1o
zvfHzR;!``j5O>rN7$|aXu+R(?{~HwqD#n{ydRg&)k4Qa|TDdp<gd|uG9QRjA+mgJu
z{*=u1Te9L?#CXK?FGx#`dRkBo5)SQ<V4MOQ+Em~cw}6}JckXEr at bT!|F`EF#*6$#x
zzz(*VSQobK>qN{cmkt<rz=q}oOr8NrosyK^Xj0sn(khkOexQ_IYd=^Yh41eZ^We5q
z?MfeQKQ{*Y7bG=Ll=Ncp51#!Pb|fbjgXH4xk`vSS)-Ors#?K$w^1}=oq&;^ArR4Lq
zRoY)Ag``%Jje4n-Jt(+sB&}Yty at Yq>oT4$Kl60V(@c;`Ocr;>Csl>W5#^->8f&drc
zHKjr0g2EG(N}?tF=mlm~sNJPxUp>tj`exqPTw1A>e-2a(Wj at f;D&e&(FOUpFVoJ+B
z^`tXH0;Amp2BB73vSU^Bn8_2X>rGq!!60IJ1ClGU-zX}wo7+-!v6vdh$Zl<XA?Zs6
zptcAJmO5Z_y}bGDcmuixUQIzjf35nG!=CtC6Bi at 4-5-n_&av~Ja1oopZk at PgR_?5_
zm}7i1w5gL`-h3e}nf1l+$P?)!L7&zO%Fo5BbJ0;$haauD?jT!i{v$2z%C4|uu21?c
z?p*f?vY)CI0KTeIFBG-37$rNEXvPDhD3EafjWwu0k}~py!n0>jtdOGEWJU)uOUaKU
zn*zED&hCV55jyf2p0#?S<2qla;)l+r3^?)h2g?u0)BD8CXcco}Z^E_ClQSdZNwXGL
zKPuHT%dSjKv-Zjw*qOVe#VKL#5{<g^MN?JnO1!$NY?X1MmzBDgqBpX8AR}m}_fLkv
z6ZJabta0KZ*LqWLSmOj^WWYghiL2VnFyY%OPH>MofWcUTkXLLyuOw_5tZvWU3ss2B
zbIb};1z`#~_L0P at xsbG#RTy&u*t)+p7`T>tSE+~2exE4PwJ4gvHnU21UMLx6>q`G!
zRiv}D7bBOmfL=*6g?&#24J3*$4h7B6C+avJcj<6OOsbd--$>9QnIlUwh7It_vhV3Q
z&HJaQ9mB&uCuWvCt*%@zse#SBa3nbk9h<5DO_DMF`6J3dRJEPj9}K$$a9>1D#$~UT
zt*6M0n;8Q(Ru=B&iQW2JmI!gb>lQiD=I6j^CUA<fDrbQv6Y@?fwY^_wK*jXc!F%_Q
zbFgtZPxv~+PG4vvyYl1yJg^xsxIO(H`=Ii4KUik(Q at 1>Uxtcihc4UpMv?4q?<Z7%T
zm*-E8T!Bzcf^62C6Fn06N;TQvDK_v-5ZryuL2sJ#SA{h#DA$QuPmMO>?upZ#Eh09q
zZ?uSvJ<}MtPW6SI+1bRh*o%3f<S?kM3!A0|S3L at fvaI0)#z?XegAQESi=3H~E7`G@
z%)d$E*7EgBGMmfPsa^q-iC0dkoqCNby^P5n*ma at 0ET1zCEA8>FZj>~2F_{^fB9g;{
zv6&2iezE0wX%P2vo*j95wEV8~z|2WyR6KARf at IPK^nSXq>J#eSVfywD)*f>Nm;VOG
z<X<E&;ro at MBz*4LkzT^*7;5t-e2|ngieW$wxkLEkjWyOy_(C#Ae+ggUb`d<_at#jL
zm~nDlCxTVyH%RybSM!_jg?%gYjD#<+hEWo}gI~gTNl5tk!h8uIzR~O+=hR}ogpXQY
z>jdn`*>Pq=jO#i-C%pET at CDv|T!b&2S$)2Q56<59621#3;kzYZM#S|ce86kpgfG;#
zF>b;KNm4-iYO?np#usp8N+;uk;nQBm7kCZ3<^lrxGC(=P`u?0~87?wD_orHu at gZqi
zdl?^GXX|Brzfv{rS}(u*k8iBfZ^nmPtG%p`ua1}X;j6Z9)`t)-ds!bW*%zl{(C4o-
zS-oE;rYiifKKRpa(g%NM&`J7WNM<5Q-!H>7U>0xR112R`&7;MP|06-umZYCE;9P<I
z;x}~#f$Htf>5v2o`JCt@*BlcbJ71jVhPTXmbc}`M)(Zyv76!6hSe4X}94d{evZ|&I
zf)Ia+$3^pir)t^xg{q|!9*k7KaqIQm at J~Nn;79Fm60*(qOEQ9Fytaxp5+_k`aV$ve
zY;Y^Rl}ki5;+C54>3M at 4mxNK?s>xBy(2dgPga2g=4 at c#R!0et(*-bnSX_`H6v}_uj
zK>>3!8pS at iW+O|<H9o!x$nmlM$98ojS(e<eeV?LEph(9w=a?gO%&uAs>HZNS0H*mh
zink(P8XAy9`i$){q&@Wx%GvbhBBfVQoz;vOA8wnAEEY6^W|Vu4>CxE;T+ at QWbZyA<
z86LCvl>T5zuCblSSW))drU)D>PS_#OhX at y@6+G5rc$6!n$L76bYwF&y;+;k-!F$Um
zLg$PeaYJ!r&v=P+8CiS0M0&W<>SjfQD>y|@-NEtsQJDzMTe}{)63+ at y55zXxsXOhM
zsYa`sT(L?Eq$nFJW~5pbGF)b~rbuU-_EcUK|G^0 at Q!Xp;UfZ^E-3Jlmbo(dVTIr*o
z!tv2QR*>p#c)MJKe^1RP*W^{BER8F2;2DkZl|}uwB7my{a*(nSSLF9$10%+!^A_2$
zJK&g|{Pm1L`uPk=L?#FFt70#z?jx}6V7HjV5h$zL(5gcFRvX8H*IOlfA8b^rz}kfN
z<a6_zn$~10%cI4yE~ZYor*-7t+%Tem_KFewEwSS_Zv}Cn&DgQB_*q)IV|7(^21v{g
z((j^20W|TlENyDVR1H^Fp!r4}V9jEONVsc8){3!TPfPNQ{&bAW_VMt5tM);heOJ70
zW-eP1M5Sk4Q-cmCiA at g!zb(w#xTs5p at 1)t1Sv_gP4A=XqhiydvKW6FC;LhX`8oaL<
zpgbQ#Ji^;f6A;$gmK8n at ofNem0irnYa6!c5H`q!fv1^5`NOQ}QZ3rl<9a%d%9~pOr
zZFvYdFFJ|XFMR*~{qJAhJ at SW{_j(^S>#Jnc!53anp3eXL?Q4Im`17j}nOF0DG=}(A
zyc}cGKNNS*Ry4QDQ}X9m$HQwL#Xa>dDd05yUGvwk^o0+u7^Z>w&+hHhljCjJ*WjIj
z#zkMuydM at W0e$~-75)rqu+zNyy>NdhC@*iukZkgR<Xr&bl9>4-vdV`K6zGmtN!cMH
zB~}SPh#Y|~uO at jqT&<Dy!8>pe!=rXkEa>4bPlqF9a}wpIqsk!yATDB*wKiGPzu{V)
zl#4TZmzoud%_;aJ8lSU|VmN5HS*NY4!wpebq}^Peixl2;Vd{$i#Zm6!pd%7#IuAd;
zYm?{{2V!xs at o;t-SAZq*^320ik|)ClC`FmpR*sn0EMMwU%B)u^@H#~j=!;+HY9xU<
z!;@y}x|}J4ufaH?$Xk!kT)1NOi1Iu?|2=NnE1}0xbuXSJJca2FqB3OISg&X^lCTxc
zQHkA4o_Z}%tc_x>OUp-;&{|A!AAtu5Rs at zl)`mk9dNNJTEx@%H)Jd-#dU<E83fW^4
ziv*Vgw=hO{8WGkc_DrF04xWvO)}bmG%y*joRNe2NWe65)zEiFYFO)w=c3=HI7ls01
zjszDmf`wIv8Lc}I#ML7*=n*h<14*bRUp)Ls!2z!n7ZsPt=iuOa^6la5_cy9*X!9Hp
zG43ex;p&PF?S>NeME1a1;&SWSErxHP at j4xkR2N56hG*t(wTn}vVE at 8L9r{02C*YAs
zR1CE|6a~Pa|DvOvRF8KprIZxWW_aHDf`qL_Il}y=V at i42hi7&=qfH*BRVzi}WrtBB
z!&sP<^FL|xf}@>;n0Jk)gqq3LhA;;hI;ZL<RJeGh>-V2mk+d6hT3we32kYe7>e&d7
z{ulK0L87Lf{&*r$fEf2T2;Pj%0>p|!Adg1e>b{)+8AVt&AL%5lDc at D#(N at n??e}Q!
zijgnfjEPM<XF!cTc96|HEqG{-o!@2TKqAE)z+0n7Oaoe at DTK+wvikKS;$Rf!2)Fqr
zVJlR at sJ?nD*u~Y}3PwHkQ^CtSeK{4p{I>E`aQ6p9lq at Q^>ovGb)J2=OL38<-<Nd$7
zof7W;6wKo(VONyCP6_vX<^f9BMOnT}*cBEEl(36^lvBbkjxwJTh9Uxs5_WOsdP?|+
zJFt%eC5+txRn#yq8&3_xnCP at s%QupZca=V$5_Uym_fiRWJU{a((G$mA!mcQ#+!FS*
z5S~%Pp0ke<_VCSeOL)T}YWNc_Tt4f^0Jw^z{eql|7!Zi=r6P7kUhNbyFtN?)k1xB3
zfr&NW|7-M9#l*yVs+ghMxAT9k^OW%;o~+g2UbRHv?G*AkJqr0;u0p11{ZuMVf9e>X
zJ#|jM=P6{wCEyo at yvU(WA at 8V0A%8~w_e1x41%14<T=K)p_ku&p_lmy`6Ys^zQ~zY*
z`7rT<jspmLjsF3K7{E&?zOTZW$S6_(`!2UmQej}Aoy=rYN|!)XMe4u-dn3;wY0MOp
z+X at b7IxA%phujLcT9;*zZQSnM>^Xl>0#$^xQq^rN^N!~nt(i!8my=+}ty2sNvYnUW
z`)4#BLgXRDqfJAN2D!pL{H6k=+7&Hx0H>;$7rZ>Yqj!k_TMXbq1*wLQ12f*Z+%b%c
zcBEiE<^J~eWLcXFM^Q;}_?|@-1k4q+b9t+>)n<D|9I81-MfFi^9CT<r08l0KD1fYs
zZT6US^u>vMB}JP<|3}t<u2<BgoAv!)(JHW;n at b5Pho?D7Va-HLbXPMCz9vg+a1GnG
zrLHVYv|vwVWmbY#{X=eib$l}qZG0*cbMFwGJyrxZHP<ak%&1teRI?*0IJ4dVJC*?a
zB8$W9Lo8+vP8ii|#^tNXztZy+%LevUm=ZgSK!i~O%1GEdECe#Yo!9xC$|l%I<n9A9
z>*a;y`JJ*vFfK%v!rXzUn|>7liM}sDmes#Li{<4b1W|qXh$~i^hmfFQ%zg+7%H768
zNRTGS%Vs1f at VX8qaWT*SP!gowA-pL`6!;!LrvYqAa{sUB7q$08NzguKeJBYOsUAuK
zV`e{;1l_2XhmxRK`P*+(68N_2p(JRWd$^I306|s{2LT?fzhc|QY(;AMP!hy`wnItS
zm9{Zc2+E$gpd{!kwH!)96Y4`ra7^uok_19d95;eCCD{lHN`l?1Y)XQ=^x6taLiF~-
zK`^DpBW_3caC{*oMPYm2lmxC?J(L8exA{;KLbe at B5-s)dMJ;zzlKY>mfV=IG2AqCa
z>b|@m3PRH^L3xuVh38lZ(r$-Deh$ZIpARJgq)IuI1b{1TQ<9J_CAq&zNr=aGC<zX?
z_D~XBUhHrXnwGzQME#{C!+U9YD2e2UlI#VClI#_ilDH<VAC#nhQj+04zrU0u6qk|=
zd2lF+%QIa{;^H`r!3A3{BN<DCI2Z}UbQ#G23SUOTvtLGn%gbdX6X89K#HG?+M&gQ=
zFC&>r6FC?O;?!P75{mDi!FU+SzzhgR(&P_k0l2cv1BF4q?h at x3YTz9d!Eeak%Um2w
z2Gv1vjj*r8a}|6Riat2@>b&;xbvs}C!B_5YPcr%d#6-H1r>^dMX71Qo;}C2;VkLHC
zUAxN&y3)H&N11S>E6q!EWkw=Lj^#UZZRtM>-Nn566%|G;4 at I3Cu}wG?H6nc&82j56
zcs>Su8Ei!Z9D}yfu}tx>gNz1>G@{21noKd36UGo at BHQ~v>9kZib0<b7?&4b(IkrYc
zPiF|b<-qADTDX|q@`cY<fJ_nrL!K at sJQv+<bB1YM|A7RMJPZ;TGapYR3J~M|_Gq>l
zn;F%-6g6AHifY}LGe?XfEE|t>64s({1s-j6pxZqfWoa|`SrfR5NX`tb)h_btvtx at Q
zukHO^Mh+-a%<(s=r+Cl;TbxKcq%bXi{RsI>i*6RSBC0rO(XQg4MYoEB7VRnyTC}S;
zXwj+SO^c$6H!X at X-6QZ+@uo%h|B9xCGTyZ4l=1)Qu5vV4a~qcX6m<mc%Q at x<^EvC6
z`2K+jfRt42anub;rC;I#f+35%j6)WA8HX%7WgN1|%Q$3_mvP9VQ^p~Syo^Kkco`oU
zzI_ZR<B&yO$03VO9fvIPI(Av)WgN2TlyS%+FXNC!UZ&y4Q^p~SqKsV at MIB2P-7<Dr
z6lHu<gmwI#F;^D7DHH}4vdbbb<d8+DkV6)EA%`sTN<D9hLJnDU*Qrdrl0&(iN)Bb?
zl^nXqOZkB(YBH#p&#zU?ar!Cd__`N!=pwIH*F~q6Ll at m;>LM at Z&_%bHT^B_$hg-dv
zzuo at oqTMV**CUMF at F=6R<w&Em=P#-lq{}wRVNLi;8)er<VsqOuYj*O67=eKb3x=*U
zdS#<Y&?5$sJs_?jSZc62Mn5xTl49#xPMAV9Cpz-xUhXoc%B<fuGA`1NpNjrlp)@uW
zB-y+AO;dg0c6t_W)I0bsDhuA}>>C9kF*s6lHs?biW~oEg)H;HLi`NUq=BvKz6}5n0
zZ+fK^hrT-};W4VZufEkM8!9y$t~QppU%wo5G-I$pGTVaH5!z4>|71v+GS9Bi=C=XE
zO53L8Q}-Q{IIDg2Bv=|FH5oWT`DeAe9`3YX7k1JPezzNMS3aJcL*iu at J&?`h!c_ch
z8LCa1JbM+TP+jcV1N at Dws2<tMj}`eIStH0_dyWY`33-;`55Q?Ig=Y!&@%&PTy3!fS
z$ClgYyHwt$%PcBS(}j~ESH0;PY$8xLE`wwCr|FtuYdf2+#Vq%Eny$f`+S7Cy^?aJH
zL8M6#ti#)M?>d_<ehqr|rVE(L({%AU3rjRzgC(`obdgW}>A80GWf>nm*Wk?g^jtiA
zKP?y8GxO=ONSE1PIN~Z{$m4Weu$V?%c3cutemX8VXhg#WrS#Kp5#TtP{TAWx?etqu
zj^n~ep6IucJl=1Sc{xYF#iwR|`YjW;od%10 at BaCfEVtjj*&_oetet*~ht6{PElwZf
z>9<VQdit%C>3K_#ZS>o_&W;zq_KwKY_tS6r^>!L8 at 76DTLMDSnSlOdrTdLRRbjy}H
zpMHyUYWehAWPU5rZynu!dzaa7nTz%GTO2;?({J%{2>Ea;uJ-xm^{3tTgr%q5hT*o`
zyCvG~-SbyeKTNwlbkK7mV>ulF&UWaa=gf9+=m3VY4jlltedqviw1*C0n7afW077MW
z`~x03c-BD&gyqly4{Hw{@N?tP0bp;34gl-Ebik|ELkE0XKXibHuX^bKc;rI|bW=Wb
z5N<ql07DNp0LbmIK~L5+=EDXs1R3D}x^u7rU}+B<zyPJ at Y(Q8}1qD285C&%hz}$lk
zfLeao0ESr(8{poh_Rp_eIc)HiJYlHiumO%kayuLF^z^U+3_Tq-;C0g1TL2FmJnN`O
z{klcH>hy;V^!39Ax?6wYi5LwQ(LN3v0PcC%0NIh}!v at Tzb=ZK3zpArApu+~wGT1<=
zc-VlMm>)La$Hl62E3fwX<@Hy5*KTjyV1qDh%KM*x;EOPz88&hO-(ZYajDxJ|{_xi5
z9d7u!hDB}pqx2dy^fL62P1r<R;5<V$`%p2n3?(hB_pTr3LfFtj4W^J9Vd#arep}&W
zecnlO>o#*U1Zit^$H-HlJ&Ki`-P&L)nGo6pAxeU6%t)_&3_rj9 at dHPrmEcFFPb@pk
zMbPG32FvLm7%Eh at 8Hy>wAt?`tlr{O-c;M<R0Bf at l{AQTOlcQ2x^MgoHii1G5yQuTW
zav`np$EL&#)}-6+U9>&%G`ooro at MYB>XK4KCN0ZU_B(FIMEvO at Txec}0c2$M(9yli
z)tDi0v93Tg`y%dL+kt#$_eAjZwH5bjbB#F#;b$5o7E9C2gs)@pH5boD2p2yv$%&7_
z&LLC)_L_o4u)13sy1pBJXu#ZH2KIfpl?aW`(AfHUQ3tcPMnD&1l&ZtzAu9*+>8+M`
zy?acAhQ}nUC7EZkhYU}#Y|F|v<nMRx=_RA`;TSgmC_Be7{LnCD=#BZclfpW|i1=EO
zpUcwc$M85Oeo&rN*csOSW<h20oOO6caZE~2<TOuTC6dO!-mu)Jg50_JeF{0v##DFZ
zvMz7LS*(Jrh6hH0|NI+UEMn7NSMmOXx3x$^6C*2=bO5fTtQ(mrKMp-DY`65Oo#mf4
zVaXzo()e1t8iTdP**3G4df39CxahFS;xT94C~x{Yh!O;;)vC0 at G%7YKkhW-I+MXM?
z$KAcQ?H at NR)b?VZ;M<@sw`gWD_x^@9Oiq;OF9vhz@{@Vufp8<YharQN?ANLnC_sKn
zgx9ECaks7Yg57p=hD|iYcZu<u?{3LCZ1Z86DF#X_*NcL5davzWFHIabJ7bWV7Z>{`
zLcUdvwJ_w&he4M8&K91X+kN++YcOU&0wV+T^Nwn<_zy3}wES+#t2c3dtnQUw?^6W%
za<64BTPW7 at AJeNr6O~E~ew*=e`f0??=0WErj+e%w_$mHAM_XX#)^2?okz|B2<GU%%
zdGB%{pE<sko%r{bPdx7y#{u}P=qk`|$D_De{`~SdtK2kzyJ<`WVPZlMeS at QZVBj3a
zgj*kjCAp^ns=F;CB$M<YCtDI4MAn4Q4X*TtWSW+)cNywyIkOMI>W!oHrro_L-px)m
zIQ-Yc9`(S@)IA1!w2tdVd{@nLIDNS%hIW at Kwj5SXyqR`Si{T6<BFKk&2KaK%BbXIV
z at m`LBhMUWDL*nkd^eIe?^sm}y%c}mNo3%0I|I|c;42KDYJpLD2LiDBW&9%ZY6ehm0
zO`E>MMI`D5Pnr5bUJTMM^+0*XQ;zH5N8?wU^$gA~Pb^*^7h3w<uzSqHF^O(B at pqs_
zY4G%G7z*k>1i~;(Z_q4xe7w8lnvA)!UF>x7E7*(a__dywAY`yPdJk>i?)cd~nMJ#!
zC>^WmoL_~4+L at Tr%A@*^!FX|@|GVL;{$p5FFF*g<$nJM?IEFaG4fl*=h%=19jDOd2
z$hE{NVY$a#%ROhSIXvftCFYp0yyt}FPBNBP=Da(({GlaBEGXu$C59PTQdcUX(oKz8
zmvvoR2&WG_nrC1^`Nlv49DE2#3tXCVS0l}9(M$tN+e&B*HTsIKg{g*@@S#a#4KJQW
z(U at z1)fF|^0M~M*$KQ`TVzl|~Aj~#7Sq&whWjNeeU$9o;U5L{SE#Ag3-T<c=E%?JD
zhWC4lb6BJ)HR1rb6dk=2r!_x!%E`$xeC=n)a3a>61Dt&-l^8-M?WC%OLIs}QTrulh
z9MjHg!Mvjr#wP|Iexs>rO6%$t3KK>i-BMw~Ov87Ka<E?BJY8bPEJ_ZHJ;1wrb7VV$
zGxL%}!Qca2T|&eCFHY{=$HIgIR(LS{5P$CMgIkv|j^#%d at 3)wK_|75UVg3Q`@BG7u
zN5q%Hv!0QMj at Spv58gIoy?L-4_9Cbmh#BJ(R^gk>Z&fEU+rP8aAGJmKnuEB<dzuCz
z9^!qVx8jF-2hHuHkAChb#A|NPfTYjLv&sm?`wl<4#`1V-2OOpNC(q+9J)n7ru3o2Y
z6DAj^+Wx-kZ&s*rgr5HYMxvYz?obvGRIdff9T+Py7Xgpz!vhB+Sc2%5|3V?wXq0ny
z-5s+LETu>!U^oJ9Js-jW7O5RdGRuA_$q0=?I0hu((zUJ$36_>bYZ#G$yAN!+=@;=1
z=LNG&w_r*F*1)SViFk-wH7LQdoqRDV5qr=uD!o_=_O+mE6T8U7xTJ3iYhL25ydaAI
zqVGdzdgePa(G|rBaqFQeW~fpg=Z5ZprTP#SJJJ+oPCncM>OweIk9a8MT9gybhdPW-
zzq3le*z<bg&tuW}q%6_Ug82zJ`{bwrir1`O`$;=`zJmNdECf5Vrmkm)WlfG5tb5k@
zH~!0ZwPeYW!oa;x;S=;rK>W at zNAR}${@V%tm1VE$DT)*zL_{F(C at rV2LW{@G2!Bdt
zTu)RHeNJTteNW{a{-DZL=!;5MsUDf%OuCQX`J|GKmN%Cc!ZiMB+^tddT_wewitxiK
zi>)uK&*KobXk at JzCMXaVMmFcI4KY^#LO^iJo&1$O327<<gSPHJk^Bn%YlZzpaxVYs
zZzOEm$1W<Ond`oAB%lc0#qQ^G7v(E)JiRm37Qg90*j5FK+jJmIEAfN%Wm*G?EQXXc
zfn*+>HG9dD$C1pVNX_F&<e5X+BJ%_iCfbmaCy-*IiIx3z#S0=*g7`isrG#VmvMMFS
zZlI@>AnyI7ln}dtU8MxbJU69;wh^ca1+l!QwEU48^gCW7Xs41ORBj6;A-=hkN`m;N
zj?k?dLb}k<5X5co)DXmdjH)4w+>{W6qn(tH5*y(ZL?nb07?FyE at RX-l36Vv$ln~y)
zoT(wP!O##O^HORE;vq)R6e6k`8baG{kdMGgiES_q;gcM*iU_Ic3=xTLF%kLbC!Iri
zFFVW;6A_-ZrG{{GOsX0JWZjz@!tJt)Ld3>GLwM`Yc#WXbQbVL)X4McWXG)0NITyNJ
z;@p=bCLx}{6eMN{1&KA7f{^=o6A04lT_i;IIm!qe*W>QTDrIw;gh(k*N=TI2B;?~T
zL_+5C^~~U27{|VFMf_JC=WO=;j6*Dl&;-YKCQTq7_I5Iw0OFc^?2FYXX#%m at _n-+N
zch97W2~~ay2~1Y;qz(Q8{&3&d2!5jmPk;g+6J_HGAY7T?2`0(2lPM6Zfe*F-Lbfwu
z3&eAcWDCUpNF4rwKN5s35bH4-Ta?&(t02M_oWU%Qu!T%{DqHZPtbe<GF{mY5$Tllk
zpfdL)S0LQ8xXCDOaK&T;L}f(7GwLQ+ at Nt^GG_K$lFpd+hh?X&~_-HEqV)v}XPeF_;
zq)Aqi1-HnHE3nMxxLYLcnMKJ2v9aI^?wNC6BhK2%72GqeRj%M-PG5xfh?;jJi-_xi
zb`y+dU8Wg~En<#fi&%xRg{*QX7sx(dhI6`S%@L2woK?!&)X0KQ(C9?SB5G}9 at o^eT
z7G%<xCzOa10b#4X5CNfV<3$7%X8YI|lUgAH!o2N81nlcZA%gkUDi2H~q!$mMNuTu^
zu at 4m<nBm@?2XOl56du4uGImlPSg{S~0bD*qlm`&sR(Js2LHk7n3#+0+1c*m3M3Axf
zO(IGJY@$~o0-kfdh+xHAsM{BPm8YldbHA8in!$4_U?C{?+>4t`F!AUsZ&N<6xe62T
zdEOTjkV&00fdF+tiof at aGr_y7^oupK6h8%VCZJ#jWdg#5IWH=hGJjG5y5{zB(S2u0
z1yg#oj at Wk=Dwy#!bt+hL*^&w{a_&L}9 at isP#HqkDI2HIDNd>+NrvhGO8U>EW&5N&J
zv=>=$C3fKg)XG}bxd7E1t#E-?+qvL<9?AvmfYLeq2r|z2UEXnl9BE`l`nFfD^a5t+
zN`=Im!(AXP$7s44xSnOV1_#UWddzrrjcF>;J$u?0j?Au;B8L at V(Xd%G$G%M$F|0sK
zXT|(VG5iOIw6vl_dI_oNyeP-3p~&}N^^w=;Lg%mv%9mRp at d7lYyxanb7vLGVw67On
zAd$zAk|&VJbJ;La%@auEF{I=PB=cZ2cXi3*NW4f5sd*eJFH+=g^3I8yUl36k#6 at 2?
za at tjW0pdM(Z2W9D^@Ue&_r>%D$T=<b<wBmHJY9~*>GiaM%tNmc+iau=4B~6 at VFGjM
z>sc!W2C=e{2 at GQ2hY1Xj;kT3p1~ILh0)u$k6T<|Ck<(LP5X+)WUotc<N<h?wKR2%=
z>cSIls_Mc^IwRGE7fn0WMK(FBx}Xr}tW=lFR<_7Xls4q$vKP8#1gz<xlovkEzN@@&
z3+$Wn5)EVW^3hWIMR}$EBw*sgb3Q%Ag&Txc6&E1)`iqjZWr}jdwnAIDV at ykY#NMt>
z(>i8VZINR7BD6!=n5iuh*Yi}wv?Vf_w!|EvEwKvI7FlI^a`HZQDv5s4R#6`*#7u4B
zQdyUpwn#B=YKzy}q~(1UqAV9ILjCvqO*%f_q<5KZ%tK5>iNf8IQw7}A-Y=>^r|-fP
zsI1vWWr{8QR+(bs_U^(IkeZvU&+%R_T>x at -8Gv28a7eFWZ7-U@WuCpz1RvcgG=a76
z^P&kp%w1>#zjGFvz({*rI8Ct1okA0wYZacz*c&SmWeUWz6{f(PFB{5>TDK4d>;EW3
z;oD52a9`j=0d1l3-i*p7QK0tEdW~qk at B|Li?4R=l&VS9q6W%Y*6Yq}FDV~;<_$i1p
z#kO~YGX)xC^cPcXyF$(s$YrlbB?8}AQU&*KD<jY|^A at T=&phKr6(}e9DztdBw?Y*j
z*ArF5slqcjRrnl96}}3m3U2K3-jsbLb?83kY_Ac+<VmRlwX#lisz5dGDpcXscCL7z
z2a`pA+E;JC(}niuK~wJHyAp91%E%fv5n6#`(!GIqI2w- at Lro|nt?K|Wq4(knnTzil
zpRVOH6Iu{8p`7D6=2WnFoker73FUY`<^Yz at x~@G!;X*k+!+Z)_iR0U<FNtEf3H_)J
zd(hq<>|qtJmWX>kN7Ab$;-0VL5ca5^FOkS&NXZjO<QZsM7Te4dNaQi3<OwA55URs$
zop}Or59&zC6G(c{j(LgdwXX<Ei^MlwD96*^IU+5LtUW_pI6kd~ws5Ql!nLIj^wRF3
zEgYxA<VbvZo;8rOR~doKbA+^T+)d3?To at Vigt%}_=3*P^7rqM>7e<y{Sr!+L_X=&{
z at YuUbwM7s!6s#>A-zPn2jr9gsgtbL77(cSM=#;aFi!5r-5EohYxFIgO&0WNWk+ye;
z3zzQBP>!svYYQWzwbzKJuMihK&0EApI$*aDm+Tl7m(QNkFK+K2U8abNi}uI}agh!g
zyNC-T{kV(N5wy~G=FVJPq-)M9BhWQw`dM7GYfcdtEhmMzNY`|iz+K{cq>8AxWCj(N
zoWsQ>SE1sft4x<E`&cP9x(}NBHKLy#;v%(LMO)+ujb2$>ve>FEpT{BELQmM1G@|r2
zqMhKGy?a!FfV7tW^}8UUK;+thiV{4t)raK=;o7~*4-mQ|<cH%iTF4K_%{H&{QxTIN
z&Os~Xr_3Vq!;4t6$`2O(7+r|`@FvXciu at q%g at FE)QiT3|6h{PT;#tB~O`;AY2;Y!G
z)PV%y?}qp4i|_-9Jcg7!fkd7IA$~2#fykmjN#a1}ps(HDNgN6BF{Gw(q=?U%IOAK}
ziAT|@?G#9~6Od(3KWQn%bkflvbgyA81*G+zEp_lVTq|1&@v-Y+EmaU}DdezgEFC42
ztn4VnuYTe++T&9C3Go@(P6%&nwVk3A(M})5;dWXR9ro|aEAn^czx|`Xfc)maU$_v$
z=nGc~ochDSV)_NJ8W#Y-<_oaw2 at C17zhz%v?A;Ktz5nxzZ&TO7hyO;%jJEJgH3CuD
zXanS-<R1_57oK~-OL1w1K&Ak~nt(OBVp>6XO~b8&iK&5OahD)Yo(YEu0iXs3J{DT;
zZc`sNWuP9?<l@~U>U4Fq0$dDD&gZqdItwHp8jda7Y~b~yHQw?+TNMtuTVZe4^az7t
z<DXgnrKR<3O+xlj9Cpzy0ABBbuf$g9$Am{7yNWUGEP3H<Dw+=8 at Mr8PrtbP_HR`kJ
zXa~4$#3osdaC~fOWG$#6ZBM=f_^tp6IdEmz(<Fdp-x~m*sRq_)ntq5<2~m>(oi)*T
zdhr$Ks9!s7 at n`_7cle;VzqC1Kdxf2v4W4=lE|+J>!AaSsG%>$%xTe!mGat$!OzD+l
z2iUY(>V=Xc;w4FUU at bpfg?=MOG;MA<nubfP+4i*NIl7iBoyEq7&x;qBVHYP`fT>-6
z>`pB0%iWHiUtc<WPVze=%ktyv(wB51lzps5_5bld-PMvT*^0yFy^31F3%<szry_ck
zz5i)jk~xR0TW^#hCkKo_vdFVGiaXwpThLi*tjw;%7mI6m9gZP?!Js=8&oPuxOZ-|v
z+h7jto-~tX-)C}?+QLeIL;4+Yh at 8ku0gGG6xwtZEuJZ07z{O*Y8(M7W?D#4;=IQt)
zL#Mv_XB5HO+Y2WYx5y{4O|I at 3wE+hgS7tO={_I^wrJ-zQ)u&dMN@#69kXhra?ERl~
z9cU0W(_XdY>Z-4+v4GMq5E<e`hK+GBl6xR_=_p#eWDCaFn2fRy9c-Ri at T!|ElzcGP
z)>*r-A{N*#VpMi6Urjj}#w_uHgA8;!qw+HLAeYaXn7gq{9z>~_Pz6!GR`Zn^&=-#?
zJCE|DD$<Toa6h#djzv5!*sR{Q88;dFe<@0waV2>PQAl4Z8+_`5!P%z&=jJ^r=^51Y
zJfnu}e_+6ak111J%E+8W?r?Zh%)4Ckl5ms%SIx~ko6fS7R!RP!S$iIVcnBUT>No7o
z?*R~xBGZ6yMSbxs%c%Iy7N+vC#d_wGwh`9BapAnjiqT~mRo-Ng0&vf+<!qJ+;@pB+
z4XtZ+S5Oa93MLs at kX5f3%D~BEcuSlQs%Qm}Voj|SaA>SXkLL2B{%%@5R(<6_yrKH7
z23F2JE?0T&O=-dhEufKGZYomOCAXmRIUveNZc<Oz(y}}`A*yP*iVFiT<#fZlnqnkU
z+_{>sFqFWVCoQYj78#*uJz26zQo^Jl2HVV?71cPcx{7mF9%i*akjq!M`+x8IWsnGa
ztI3PWd?lS59RIra)ZA)M7>d<Hlrprw704{totrDJv*&no1<If;!n2XZyBHVCEci&z
zXX#naRU&OaNkNdu{Po37chaEIqo6D9Z1K1#81y~f5dPrLg{P%HIv at Nn=!>Vco-L20
zdiHz`+T;4<he4nG_ch_w*6(d)_}m8bEmop%ehg^uH2A9|7l`)@BJVGgEX;r=CK2>S
zXyAr;wU)zE3;nt3;f{rZ2nfXmDnSV^)NV2fCJnHQF<rZjF3pU}2DEWzg*G2vMaT&?
zhRhFon_KvE<I<J_V|m(R7<)YiN|p88?M#DJ=(DE95|*=NpTKCgKpG%yenye&^Bi0!
z%-(M}4#OsHrp=(DRw3KtV0II9d at 8oa*BE9BU72jJt(GqNv=ID#7ZD7fKdXv`mcn|C
zP+}-FsCLZ8Ff=C at E)1xEW$D=kepn$Q_i5oxyvRKR9UO>U9uf2UKnaHR^?&t*o3k!g
zd&?5*ETYh_h at D3irW^|w(5h(rbo}>!E`#&w5(bnm3})QEw)}vZXyD{Pp=h)ItG4fR
zYc?t_B;%s_16Wgt^)5plT}3HWOc(DDRFsgg^M8n9{Y`=XrT~ur{xc^xAFLSF&I!~W
zpmB!55{6RyBX*Z at qFivaeu>{Ov@$g<1&d%~oPy(9%TY_`V<rspF6K|5u{oVquI at Xh
z7kv*gq`z6%>(#UVLMhH#@Bb-0`L%@E&{^H*d9rAExXX&k!>p2ZR at d%pkMrKuc3XN#
z6la{r7aXPC6lf%7K+GA0v9e;!1T~Lv96QDSIn}$BgOw6hDXCPEIa(5bE({kxcZPo$
zGRtr9RvS_wy}t%TJ~OlQN?E3~?U6!(e?v;LlS|7YFuP&Mq#WgGFuhCm7<qf{?Yep9
zoFW6RHqt=1y!)n<<4ZB2-l=21{}%~Heoa<r8B{+hmml6==?}N&y5V>jH4Sal=aq^}
z+di*UgruKGs%OO1#9W;5{EqkUyA3 at Gvb_Q#@tf7nht`7~1FwOzDB%M3N=7qOdBEYO
z8sRg|$tK`0*Xp%d>=3VjeyW at 8>v$xxJ~5sg(o`=6 at KVBeV88!!Sny-bsjba-Z8`Ly
z;BZ<~Ct?J{vrO5Lqw|QZQPS7J&`m^=+i7I`aVDRoL%vjFHI**da27N~f1ngD8twg`
zb&juHbq at Lhl<OEt8Hp63C{Fl-_%*#Waj~9-PIV5~o1d2iZpLq$>)XK+;QZ6y&7OA#
z(kr4>b$|-|mL{h>5LGb#a_Z;*y at t(F_}m7nT1Wup1*`&?1$3rRM!ju&h7`(c*N1}O
z{LJT{58Y-aTjos#t+WSn^;qlvzgt4-Lr4g2e&%P*<)g5^kPVeO`?O?`Tgg5xL;sh}
zwl0V(u3f&M_1s+s1 at 1>A`F`AYU<H+l&kMI+RK7=^O}cWIE0t0h29u#l)p*m*7y)q~
z?s;f+_4Wh?T$ms8#T&)C1g)Q9UTQ28llF|`D*LT{LA at R8^*`D*8A9swP=u9KSj#i1
zjmtS+S-<MTyvSK?d9$kOGU|e at LteP%Sx&=WV}7eikDfA#N#ROO$Dsx};7$CIvMAu(
z>ml5PI*_q^{_i89svSKTDA^N|ZOhO!-doGFSb@#8yp62y+Vy{hIDlH5ge3;ZQIqNU
zD=&35GCSock5_vvT}96&R~S;!rPB2t5{s@=2LqxwQYR-=jg0GmY3$gI;YkUO&C3+a
zP@;#yKwv50;TS6CD<v3WLAlX;D7{eH6Po|E7`62$ERg8-FP7;vydV8A`1&%0CW`4n
zY=kish$s(Mv>8GSOT`QeOW#`2px*+IU`OEI^#8Q;MIK;72e43pBPqa(DpXh>?6$8J
zGeRsU at JIk|AWdLCqF|{eOY5E2if>GAHF*VfDd@!R`@uSNjs3O44sM=q>xgRSi`nH?
zExDp7v^$vo#@^4xjwQ1ZUiSHS!%6A;&7T&P#^*<|d{{ux<Lj${j^#ScOaHr}+DgkN
z<yr7*TnWz)Z86-1ch=ibvg6Y{#Ddj;+0wwH5%)bFtS{#LTCgxLvE>$alLv!>kSi(;
z#Ri?Utf)A<>&)RJuQ7CHegUj4+WJ~h*Uk-kUQ1ZbPD_<nrK%)13od?H9r!iktl=rD
z3WH7K0%tktRdnO#^?X6go7V3XDy=bOL2)(8wO6KfGcd5&YWyxNbT(RX<2swo3tV|N
z2K^*1P2Pf7t4=ap$C*9gwJUMk<H7i11>enUMYQ{p_qz__&XSBX=gu!G_Y68HlR at 5F
zUaT9=e1Y5+o9&l2P<0me8;($xnzcMa^E?Wo&R=q}U9}b0F#jq(r+B$nP>*p3XQ(J)
zc!sXA8B}`FDp$;+L?Zk*ZW-LyQuoLeE<Af;)lS)-_ZXZhvV3Gw1{X;e(N=UpvcQW4
z9kG4VlPPag3FO;~C2$hD9;`?Vv#%AF>1x%8R~POaX)KzV7TycfRy)j|Wp<Tn-fMd{
z!Or4E6pw|)OSFpTj*5c|`cR-y7 at 59o)VexX%p?z#1h2WqSBW4H^;)qcEU`n@@#><6
zGEUu2CLC0_6#F{lBm?t(DNgSdYJfu#^WSmN#}eTk?Cym(k@^-Y8`yZ+=pYQBz_SXw
zdM+&8ljbqh0=Kc=9t>Q|+qL*2wB@>2l=L;uXu{31OEuoZQZmh>s{wZUy>`3sOo?_|
zW>wm^DQOE4#*Q<y_MB1YiTRQjXU3$Hhw;U}VX>KA>60rwJKr*N8um|Lhh>!ZwZgLV
z6*xadK*4oeGzwQp(6#<%P)a{PlKi2c{r_xNJCbBM4)gmIb%G9kD2cMiA7_qG5o=Z7
z-(7-$UMj0A(n;{?OM)bHQr|M_GKAUyJr^HhS*m%_lVX-HsEpTerR~lUyPx<d!Y?RF
z^!YY`wFC>8NW}#o$EYq0_sbJ;Lix$n*C2*(&qR15`EmhQr-MSo4pJ<oJib at Uug)30
z%G+y+ru)IX_C9I5NQl*41R;gSR`)%Gut86w1YM3Fx#L?Ln30wlaLJ*^LRWpI<>_Gt
zn#7lVb-~ru<X`y}|K at lbG3&|Dme`iCn`ZPru047v*7o#b;3|sLIy8eCD^62(jwtE{
zy%}-i3dT+gOW_&=Tg01WlQk1{`ohlf$MA3+?~(bF0jm1l5{tCSn at -k=Ie98-Fc3|L
z8nx?~o&$zNNT0m;REKK2J<jEfri(hMTzzMBN`2waj9(q=ZA9~REdb?lwiuc*y3Vk2
zz*NUVo+j3%P<J?CRW6ww3Rp$llX(Y6{?v0QS{`2pE6e!F at Cd(eWKH3>mYzwE at LOnZ
zJgtNuEah}$oc}aC3BOpwRbC|g!ZL>l3gNew<oO|Vyb7-df*Da!mtP}TwIAUZxJrsh
z_{IHPd`saMm`#bo?}3l-yDTaEa)J5r2tRDmk0@(8R6pe%!Y>bbJt}YwHIUOFqHEXr
zHeyxfK&2y)pO^3pXV#@tWbgDO>LdIvEa7)qQurlSaUBd#bJi&dzc_ar<Kq&3u&nm+
zC_mg(98cvJc!<;X#AmjTNBITz(XI}Gh`y8{UD0g6jp&M3D!;X!%$4#3Yq~6XG00Ey
zDwW?iuIgg`(s_S!4KMa_DL>3|<_>cUtI`=xI2*ks^@kW9?UwCz$-mNe8TI*%CvJ9)
zm`ZS|KX{W1O8mjyOX3CM5BJ!_DgM6Qi>(H_`1O$cb6K90$BS(IY(U4O#bmMUfm^Lc
zg!Pg_@}hKDdRcEHZ0NO9iO1Ha<IGsyw1?#gm-w})a=^RLfxT7D*hf%9f_hc+nfbU&
z%#caz!7!Q2o?BGCJ;Q<ajz>Qe)>}1n$fW+GWu!!Yx2)@?v8h#J$%Rd!1xq`xxFuid
zAyMe7KIw@%re-vye~X>c|5B+<dlZ`w{>%s-m6{_0vvST9+rZ-}r(v4WRWNqrh_2Vs
z6bBCODr3j;>K*Uw%iiJ9YxTB6EeJ-s>D`60LZ3$cUJ|2`Z2_4nQ3Sdro?Wd&4v7vg
zC4;9XaP_Noc*~Y}wT`e11 at eq&dg1JJY5l#W8IIHIqlc}KUeoj%88=1?Ju{AFoEclM
zHOLOEcwGE2)Lmi9GZjhCJ_pa(8CIktZ(;q2qnRVvLQmS^-u{-D at XVdM;kl-_1!M<&
zTb1hd_|{8To#KeyOjH at f>X1vfh!8hdVNyKJl>^WMz*60K-~qQS#<zZsxnHj$;PR at T
zxYsUk)f6{h_BMi=4+Qtby=%)u0JM1KrR9JsJ`aC`jpFICSdy6w5D#D4L8LuLvh@=6
z49<A<whT`FxVm57^6HQ9i{4nR(e)JU(d)V&;;RK4V=?qbn~e+H$(Aj_(I{bS8CND?
zH)czVlKYhwGv-t3d^fF&u#CjB><545jHUcJBbLM)OB7C^6>Vw8u9S0VTZt#dTt~t2
z&>e-}yK*)xomp&safCC6(L{i&Ne=d*8C2nr?;NnsBg%<g^~qd^s^fls;HKl2%nnJF
zyeOp}!+FAFmPbLP%Li{^dKq+TH(1u;4ac9DE$56`IAiPH^GODsVg7w6J{FLxOO{dS
z|54U;j_~F=<=~9!u5&fL4@)0%PSOPFp3ctCK^u06CtxiO-WX!5#5PHiZ4c&*nJxJ>
zVjMh4nwy%SE1F-VQ at rOw1Fv8!bOLI{L?T10K`20)#R!jc17eMdJ{2%pc;)<&x;6|I
zX$k|r;`Ie!QNsh~c?5Itf)iffed&AL3_W7;YrZQ{uboTJsFWxWom;O6{RKTAaF=1{
z=Yj_!?iC^%Yv(oizR06MFQg#^CQg<|q4>ec8^1O`*F^oB5RC?}Y@^pKm<}gZZU)8v
z2`5hNKCpU767-D;qV0s0v)9yc8{E!wHOtSTaYL|Nu=c6ZGPKA>KwAlWA~Z)JTaBX!
z`fM1+%I_2D5pd2t+3JZ_*Jv+|23PdCl}8atNyy<ohumUZe3$fMN at l>8PB#tTO-`SE
z-QP*ISZ*gBHdKW+V??$3ip)U2o`f at Efd*ki7ZYEsHC?@bWWV6|-V<g9!;Psxz>vY=
zB}n^~hE7B4gLEXsK1o(y#<HnCl!^UIUS at Wlei-jQ)&p~RGrPZ+-8FkAl;7<Hc~`o!
zN6SGVCRcB6H>@JigEOc|iM-j$xm#f<&9ydj0r{3GO*U>2C_+k5o(NA-(;4ALXwD2L
zv6n9nN7YECD+?!yJsVSaSEWT|3{vC55Cu0Q$l>q;;AR%}Lx{1Iq#4m!l;WVzfp`fR
zM<2sV_KeB$fCM;dB5TjmQJmj<j04#+B?ptNu{Tasah0+SEdfJGN36!#W!0Bo2<gUQ
zukVPEma|N=xp~sIPtvN)TF-*fH-}GV{9VMeu19Q75r}X_U5{Qc>tp!34QrvxT~q!t
zXv#5!zaw?7MQQlD4YQB;DSsI_<$u3+q=vDjpd$Ub4YlLN;{JON|8AiBkVJq>u|gl&
zPgAn&r7)<mOb}&9jpzEIr~~!NkNb?aLC)5i-=|pCOTv99+K>@Dysuh4KLU_rk$5fP
zDLJijtZyZKG`@|*W16lgmlyP`V2{BgZEAi`(BiyUI;)@mPIhDGP8<v1v+485m0R8+
zQ4TJdmWks^uCF!?aAnpxE|&fn+_y%V07_<iIys?8GvsPjVQ)zZ_?`#BOCca9XP*pD
zSHgL=nvLi3Tsy0S=bI6C(2W3j<F at bbyJ{|AWSEwk6*&}!-swzink3`uH7 at -?v at +-L
zV_4D40f|PmXsl)XD*hXFka2Hu%YEd*%0mP!rYbt^@PKvF8ThHR8F6ngs%<e&v|($C
z$~Mz&zR3QaY+n*t-X@*6s_1P-{vO$s!(X}f`91kEAJIsklAq~_?tTnk7_gQC6QwZ>
zp>ngAJqF9i>op~G@~-b|?4f9Mr{UT)&yg>^w1jZ~^I){Z at M)lvJ5eJ8j&V{YBNAfR
zwpg6Qmy7Y1a8I!#E9 at TXYr&qVumStB7q`N9_Qt(%_IQ1cxHKk^M;+SGklcEqO$F|q
zG+$9c0 at _K&oukLezI=6Vs6rm4#U=q)=TXYe*=yf50-cx4gO&t5C1>^*q!T$@h7mUc
zl<JM}<W^h6(rDhB_s3D6Hk7bS>$kIb71e5lDx5^2F_N~A6A9Ca&ByhfGjT~gZ at Vh^
zW;BP9@@r+ZMGdHrccSEA->*ymxeYyto57bdm^fCgJoL)?k7Es`#K33kdX(6{F9Ap<
z%-82&Lf4yRq(iGj#2QOfXlLt;{dq+67kDBiT~5w)F|4#}UC-x94lbwqw{*3SSM|r4
z`&IpMrR!sxRV6u{A+o`mzTAsUFFjpHPp<59-#iWFQ9nxj{`=?OU$qoTU}!~%kXoHD
zR9U`$W!dQ;@k$CFdJJh6NfMcNEMH-XmJzJGETd%h{%k?hiL*z=oj>4Hp&9}fMfPV4
z9(%BOiou^P#Zji(!qd)ww1kiTPj|U1S+3hqG at q}SFPIWZycj!oazmG+>vGio|I`}*
zbwse$Q8(6+NQ!uEkOt||OWsMp;tO;jMC6qqEAyoki?6^7OcIxXZ-hg7IFV at 0@5Ggl
z6P!Z&59DgOJ38l>uLRkOB9+A3$~$SfxvMpP1Ni={FXBS(opib1ve{orkH!dMA=O^N
zFkQe^)f<7pr}zS&c`p5dT-p~A;#YEojB=7Q#CJl|CFxuw)Yc0 at yoG>v;^W(QfZ}cW
z&cM82uLS8mWD)aZeId=ug#&`P;TM3v#<GZ_A-)i5(IdZp{q^gfR~RQ|PkO&&RDB1n
z`}uqxa`DEBE6!=xzX+yXk`rnVQ!iW7ls6&(X)$f}nQ!}u7sJ<M#^Vb0z5O07(ci{%
zKFMkRDr?BREEm_D8{5dutyptPKAixcl2f9l0l)gn at fj$tv<@<Tc5nc>=;w-qSSVFL
zch6tPoa-}PRRWO3l<4v2CgU3Yl3H#iYi5+Sx%lQ7A<e?n7#X?cyA~P+fH*gsGX_$M
z-!Uq+v70?6%nb~Qy~#xgObQEu9~RqK<EytL06&tS%$p2MFZJ&I5th+9xLrNL<aB;+
zHRF!1o=;Debt%!1p^;ns-rZYnj_ at so1W7X<m!bRb5om5+VNUPnxmS9V^5B-fj}gQV
z?q_ky%ImW%AE(~ehsW=v`8y$DJae!7>@K<@i}Ue*d9pYd2?j|<VwzrrBTn<vIYz!u
zykP$p;T7%HP0mke{h0B1C)$6%=2&lQnCsU0cJXZKMaqaV$<@d5%5BDsvVl$!KxTQi
zmM)*mZQdbr^?dq5MT(40A736o at M#*2Zx_poO-mPNicOxG-Wk|7H6OQ;X=Is$l7X!w
z6V?Zj$cmm$7<~cMr*L6D&hCO9{XSA|1qAEL&~UJ;pvYg3p2xh1^XUYr6*G?F^(HC_
zevj~2RqI;eGc126jd<yilA1ZTngh%}@9NPgL5q9Po^QK0{9H?#d5cWX at 9v<r9EU$;
z=27Xob9NQk{CUiLS~K7G3huhk6d%1x0Imo{9W7tl2Yl_oq6=-Wd;{y18{oe2soSCn
zzILD_^_6cRU-|E6==Ga7%MtemJzAT2Y}pC&_J-ewt<=PIc?+4Jj>Hn42UtDDhc}o_
zbNz{IG4JLXq1XMmXLtnC at SkNx8O7T34$u)=KSWD}zYjCliZSFJvLEJMa-!bND at 0yo
zxeo at OcA0mE%h=2{bS!{+*nG}{8OG?jv}C0vZuzi`1gx<(t>1;>V4d}2#^cxE55RZX
z`kghdNLQt%cpQM&=J-ChJi7g0y{EY%N7j9>Qap$2)o?%_#%EKQ`7(1D)Y8<<YQLO3
z*^KM=3gII|k1L9rzs&sVKKI{eTkpDwEL%(Y=lt!VHAdd3ck_s}>`yM8ZZq21%*StF
z?k|{abr?4W&8-1UuY~FQfsdTGKJZY8wXgNE$Kr~GtdujIFDrEfpY37QQxf>?q`!Dc
z8I4;rP4(d;sQYV)tT{9<QQHz}o*^E at w`>ZBJqh>snSqg%-c3JMKXTH9Kj6zBP+g8u
z&&fH^7ib5B6PH&8VyM+MCNFP<cCWj}IWRC?{ge9tdjRf%IJfCC-vLXkidWn*ezF+m
zpuC6B3wU0U)!kpf+U0rW0C$l(j{dbD-4}hn#lue|kFI?jN8euY8 at YamphLgDe*g84
zfByPc_Y6=_Q!iBizJCAbSG%qyKfFtO18B`cP~YV1moQS at Cmw{- at Vbj((0kSmkhT&E
z{sA5Zy4w;>aRUfDo*QT}-f1B|p;{r{GYddXxC&|6FL#3Axyr%~jxXnL4cDh!i1+IP
z;6JI$xNI)Vbf1XIGac$qM<Lxi^9~03g%m<4p7kY;WZsD&Y2+Yt)Z?J*X}O(lF$wGh
zJ+9M1T<>gTptz5D5Yw{GfQ~61#ykbh)(;}}k%3NX2bol^XW%ky9K>oE4E|GZ5I|;K
zSRi5LAY6SupgGz&h&RnjT=nb(3Z>gYRO((nE6_oN%3gHE#9E1udzDNs_fF_8Qx0OI
z>_w2I+7D6#gS;rugRs at DP^UW|goF;_b!aF2=Qs_cA(Z<fREMSqk(wo>G51u$HQqsL
z_7R%mWd|{;*9F%YAH<96Mi}x%+Cj=Hj1DpEAf)Fr-oST)Hdd1cL}%S;pjgd=NUcOn
zf7&GnVWNY~TCJE-c-ld%R%M23>Yak<DEH-~iPAx&)xCV=H~`f=@_thrfD0tygIKMM
z-V&)Fq}CL4 at 77MjHH|>#EL#cYyfF at 9HEU#GA~=9j-3qQTIf&GXiw1ku!ssox_BD`M
zYp_5^)I0*QR`>ETkq#oYDhnFh at f9f|b^@VQdngFiL=so^WiNGY+7D85LgAY^4<e&%
zr9G5zC0q-&x<ag5!8h{&R_nC70MvtMjZ;PEt#ulNYn at i~;(h?gr-N86(~9O?^GIED
z*R9a5TRVu<I<0Vx*+ICrLy%ePw4tTfGlLkFy$o|o6&)a23$>xiR~Z7rv+jj1Ukf!z
zRUrWLs#~G$AJ4!ywNM+{e$6BhsoDk7G(U=##j8x;_FOt9ZS?!b#kN(T(}qJ<_T0Aa
zKSNB36<bza4%=rl;$oAHV$Z%E*GI=yk8fM&wm!z7KBU;PDskHA>TML8xfOfbzCQYS
z*J7LO>!X)nRBWZ~Iw13#wPH)#*GCg)eX&vc;kG0cb$BN;1jIuixI)hCB({A3ntG(k
zPQ>=DIwqgi`5+v1_#r;{^@9){z at iL41YJGK@J^KZ2f}>>fv at H`h>TVU6qp`>FFVL2
zDFjY4I*9eU723SCgUFmekjpp-8vn3^uu38LuhBt>`$25BLeTm9Jcx?E5_B~3Ikh)v
zfk?NVNVw}E at My@Oo$v`}WZgsH(WyTW9Dfmudj1e7x2O&~(bfxrJm3Rxl=JTd!YlWN
zT!<{)0EJH4zzmu60niFj+&7^1YL5{C+OU5+iA1S?2z)X5AUwt^LCj5BWQL4-2+BcJ
z|D9Oqs1NDzZRn_-XjK0<LL4#DAupmI>_o0s2;{|>2chT+Z{%va$ZS#w1P9YWboN4^
zIK~@*kI`xqNNBHzK!HTo?}Vd`ypcu=%t-nVfFubmwt=|Mj}3=MZ}|rB6<1$GLz+DV
z+A*ZrP9$2+Lm*Hh!QMz0S|rN#4raHV42a3-Mc)ZB4|*qwg?xJmG)&01ok%o`H!>`|
zGN5XrZ|#Ib(d}eTDFmt}I at NcAib8V{i<<Bd2%XS)JJGm}H^O+<34$Wp*-j)>-$Niv
zg?=EH_C+`v+)gI7LZDQ29>kiy5)|B#-hot#4!08tW%v;2rBH@%1nOZC)*TQ;RP?-^
z5S`CBA#{CZTg1>eb^>vQ+^a-UE#Ap!;R=G}I&47?+zI3^df*#DpR=|IH$KSZQ3wJ9
zUGbd|jYVt}07)!%5WVCFa$Rxj1l@)<SqZO|Zvw5>+bcoS7g>bRIV-Vgg+RRx`GK@<
zi>Oi|5Ol2{M7X^Y2$lcSUG7?zq&O7y^DF8LW&x5wvd15%&0b^GthTED-<_jJL<Uq`
zD^nXT5JHcGhT{dHqIM7&>mWAe0~r#I7l^*b2T>jyL15?`Kzr&`V0GIFG at q=4h{*>+
zE1Ho&1ri;E*EmQ-${zrKD7-EhVm-*xwGn*GkPifrP-ITp2yUeHg9yKaHp{l9Pk?Cc
za|bH&2B4BhIvg=#bdW{;1Hq%y$wbkZc97Y0BdBvcUkUD%r3fn@#KzbNI>YQA2(?vY
znQa6ekJc+e6izKNqr`j@^zqII5g8vymIi>>`?jHg#w$RM*eIfNZ3N=4$w5}smp3Ak
zD<f)j9Atg~y{Gq3i$o8Citt7h)giSmh(W182}(7(@;gBXDx&D353(Rh<p2{({f!`4
z!-gJ3lYZLbrRK$^d?+rc(?$nj?ym${G`NVOWxo^7_tS!2?Rt<U^8;!5 at L32eH1VBG
zFGnu~rJ<!CAb3~*K>F%Mq}f5tyZ8%1smk}oLa^!lKt{d`Ky>gcLI0E}CktxVgKHzp
z%h)U7l<y1rm+Y0GpQknlk+nV$;ruQrV%Gz&q&F(UUNm0_G)PKf5Vi4vjFh_y*-UQ$
zT1RyUl=>53xvF>}$mrCT7#nSUAiU at xE%hGAWO*YvxTKhSke;#(XK$`fUI>)KIKW8t
z1R`FJUkF4>mbVAtCL4h)PPqbtbG-r?x`T}M%Z5UiJRDNbRnaRM+4pY(?Vm0DL5S8y
zC{)%?cot9>S8t$=u at QW#@<BSwMi3-z9R#&;Bkf;G2cRtb$P?u78$o$B;e$w at 2WeTJ
zZ-OU9R at w&{t#4$7hTjQ|eJ|7lod;pogS58qg^IQMK|0Y!I37Ja8M5yMKXp9_U0@*|
zUciWF+D at d=LE4m!^mruhr0c#iQd<r{eLM+NlrB05)AlRqGqZIN5k1JUFgm=RWbnQf
z?yAW_Xzp8~PYgQ<pP<RU6|SoDLHh0ssPRSXAj9^R(Q0Qu2#<X)XhY?L2+xD`w(kWw
zG3_9Ow!QEQT1E#U+4jQw%KAJA3gbZ<ZF}J at H(NhQpZi|Wbwds^bl(e#k at X;ZEaP2k
z>m)*SkY at W<5W%tzGWxz1<n;-Nx4U87&7MdgyeAS!8~av}scHx5+m8rWv&TCK)Y3+v
z1ouP&p*@iZs!r at 6GWtQ<o=F7l#e9&_wyPnis6CTFC^G4<FP8=W<`sW2>5tzI;;G_6
z=nKPESH!Rz?!is(dx$@SI6 at n5_<A?B+mD}L0NvkW9<j&{7YF{(Wf$S(rnGM}rZ3m4
z-{ZP+d?A)$#tYI{N04H=3xHf*QQ%;9%H46~%kob_ipA^;45*j*@k-NTFY_;fNm6Gq
z%Jd^tcR$+74 at XYK(MOI-uMhR7q1#x-6%yN>&F-e2d->D!r at L|1=F1oNz|t at kALM4w
zUz_D@)S#*sG0ZUxZw`K%B&((ufP9K^7t~&TEEji$3)8z+O!u1YU_n>-(TKxTybwG9
zs+gr)aKtvE-nBL}04z;7!UJGrHFW2uUswb55ngm*7AA+&xu&}r)2F|BzsED$VD<<f
zbJ<^;<(0Blsf{ZivrNR5dfH2UnB{b@(fR2y&MU_S#nWYA%MT}nS%#P7bc#~yfD*8*
zjK?%(&WzS{m226I=30N{w@;T!ZqEF6S+^O}2lI2h8P%^f%vNU?&5Ljm9=mH?o6cO_
zbLwGouZX(<NkoC)Zp4s99^1&xhScIYd1O*&ICYdHztJ?HGU|e7#ir#2=P_GmNy`gq
zO>?%FzKHCRIXE+mlrv?mS5}O?0U8A;5}YgPya~8znM87hgRDx?xZc^)B$T;_*=6SJ
z3$zwzky*71;}INHxq1Z;X^y*u_E?kbyxvu>w}_kVDj!f9(V0j1#S5UDRc*pCWu_a2
zzsLQ0s;|$;vgu#yd-p46tI*CFw at H@MH8cKM#eaVN^QGt&R}sj<j%GXi4Sqd=h1hxg
z<PT6kxd0rFuz4(+;MWsqwC%@F{s8%tf4&Sc%d=#TVc7>rm7@?hq9;iAvHMFiGu>a_
zN9=A(b47UjD<d0=dZgfuxw7{AJebroNFB#?XvvHu_TgD!Cb70%A<914Fex+1n=`Bo
zGNc_o(?WQs5F9yKt#Tep%vwA+!{u<sZ6Ysn@@3-P6{D#;DHonuXFZBz@}vY)V`Z-K
zC2_1F>o#M0Be{WETu=Tw9JH!VOH2ol+8q7bt&u%p5T#jhv&!3?YqyZU;r={KxHEqW
zQR0s7X{ppj&1e94$wEH5vwK*b!aZ5;)68!k_8hlfKgPY8m#jR7k|z-WQTlV{I5c0F
zgl~SBO)aM<aA9CE-mAHEw}|ag{LKqtB};6r)mq>In5}->Rjx3oI*Cr<-*IJ43zJ65
z0oNRPSyD>I;;vRo57#$-S5^v*HGSynDP+-<4BtyM#q{q~`+4SGq@%adyW&SS>XaM&
z@(F9zwWy0~!#~l<ZU7xG+fOL8$hL+_-9_l$eb+dLq?U9iS{wu~h at 9d%4{MbVrOYPP
z>mx7y>6eMAkoD%3sj8dj>186-Cg=1EK%V>foEbcGhN<%zsOC>iy93pv8dpW4AS$*<
z#p5+9PK`sQbFWA>H?PoB_6#!D^_3+^OPH%nubB_CM<2XFk6rxNCiUeUW-FZ%0uUgY
zNq8=nqxJCX#3ioV?J?bxJ^;Sae_hwmEzW+uY#Y^Ku9mOp^=_8Vp1T<W at L_i}NMEg*
zu2Ps%Wqw9e_Op%**Z44huw at SopNm{pxO^zzqllfdIATTCb6H%zXI%6LALgqc^v&cv
z^Ea3pvB9fa9GbF6PP!w+x$iYfc#Rmfl678-ju_9lqO7!iMKAmYu3FqIrRJ)|Ke9yO
z%Ckv2$S<3G_*T4&(nWfkF<VQb*0`0J^SbK(y_!|U&1hD8$5oCiqpW|MBa}@}FF+%w
zw`u|zbzWwp#psnG*>XI8{bb{6Sez%P+l=YF=5w5`A8UGrYwasrt&$r$;o(#AUb_1{
z?o6#Nyl3Gln_7laDS(c*O+;3T)OLMItCDJ23p!P7QH1Fz*|}C-m{tL9 at gdT+q)UAE
z?3b1IrMK-aoEg)L`|aQ;^p#sK{o`a=HZC<i+I*TEZ-58z;^n`tC#|B*`08QUstVPv
zC+djE(RzvXyuDd3v3`X$k8OOEvh-J?yQt;Prs;pX`XNPWFZWM*T7EgMb=!~jqyPBp
z-~ajg8|!*;sz3j2KmPaCTf5(39n$RgSMQ37C^z}_H6`L-T9%#PUrR&2UjPyYMHGql
z4ZJI^r#<6+ at Bp|Kbck=z+lZKc5`+qF`$-l;cLV;w*htT(!;_$ywr%0gs5WCGo?o(&
z<%RJH6uod?2Ak`)%<!k$HfNw%EZT^x#tjf|e{O`4O8bu_lJ7}8#O6Va_Twz{uFX3`
zBeb5xBFJ{)qWM9{+mRha*R~F!3~o0J^@V622bnpA!$g0dy4l9^u;B)!&DOg9w7ppT
zpYD3el4Qk!06KrG=oQrABMGsNUcwvq{-<pws0>6BqbhEAx<>$xOlipD?K4KH?v}<n
z&fBBcsy&Ud=hN7I9%IKz?P)yhygy25ku)|r?k_lKyr!|%nZ{GcF<w>g95bnZ#^^6b
zOXG3gp0RVLvHE#?iE~d2x<f4Y5;3`i_4pM1)8&FOJPF?QIxaEIkHXx~eu?&W$;`KL
zyzG97izUG#xPB4#3rpC)9l~N|^%6^C1~|WjH8#tvk_07G`z36UPU$#|<`*gW=1a^*
z62akYm#D}k(_0c2ntF+AeioK*j;9Q4=&@yVO)_vm$t6}>65LTQka)vRnQeR#)^E!E
z(@ih&I4^(1P{pNP5@*c^P$=qKjNxN}#v6ISoO%NLp`O9xE&PH0r at zO&w+%x)3D(x_
z5{pCnBdCqmFVRw;f;FD9WyV4N5w<seiC0U48H$qn5>ee^aoB&vBfMu(n at J{O`}iWI
zjx8c~iMyOKkUd+wWY`PvmY|RlR)?0w`bdJdB1*<78b#wJRW?j*Ct%5E9(xp$ACTw;
zv|uZgwq?Y-@)0C}s3xaq)RUJqTX$v?c!8*2;!$Qkg4hsmHxrp{8IfW>;?Y`Vv8XpM
z>An^LtLuJ=MiD<{Miu%kc>5&g+!09Pcb(!=lc1%H$aKnx!t at fwuc5F%vr8g0AA;P{
z+ZQRLZIN-oEHeq>&2`ORVJ4R?BZ}8Y5PIS$IK?8by at dS)1zG4CYm~E7<`_wkhpIkA
zBE0(+HoK=_W8fgjGVV(@^tzS-8I=7|5<_`AWFkF at KE<Q$TOw>WlSDUq2vQXa-djZa
zmN7jEvKG6fB!+_bmQrFJCL&nvm#EfDrq8D!5n0STnmR!Z%;IKA5X_2PGNgSGbOIsR
z7hW&1I+Gx)>39mR^|?i+UNXBRL4F?Xi!`lU;_G|>=}qP(=Hn at -PnAp2xMiDOqSlk(
zwJYt5^r2fsF7V+=a7<Nu3gTC{EkiX4cE;?NSg&6MyCVdVeO!Q?cF7d`B4ynd-_#|8
zw|)Yq*6IuJm0I0mb0)#|=zfU~`yx0HL$K|uTq4>o at mZgOiIp|!I2PKxWY{>RA{54<
za*D+QzoeHDf?eV561`#Sd<yo9#WGZUHpeC2H3>>^oQyAtLxwPFI{_g=^H|+qfTM7>
z5QL&QPEHZiOJ?a`M0MR6*-`2x!xJDV)^Ad)ZZWka*c4MQ(cWLeN- at TkiRgU_q9bZ<
z7Dw2AOY1z9TEjL${LV5^b5B8dM1_3`w&osNsmB;mvd=UYe1q4xN8?JFJVy>ekW{&3
z%=Q$VzfD4rF8c*$GYP^aPnM at hbb%CQxlJ;8kQ{<^+1eK=(a=$1c0Yg}!D^di^zjrN
zJ7vu`+KZu=7_03eh?{&<pMto*h4m%DY<@~dcfn%&5ERttwJ2UR3G%1(ON`a+5Ts2O
z+o!bXwJ557$()u1X_LkFAqWa;TbxJ9A&8r`UNT}fULw&*wT_*^YMaEGB|+O^@)U%d
z=$k0YYMW&8JUIlN$e3S5rEc*$k|2Vz+$OOpU!;~em^wmeZ<pveL6A6EZXbf|7tIqz
zWL)B|Nsu_>m3&Ey=7}=mJoyOzca5$4Q}DMQr;4C4VZlwJEEq{9GyGF}G)hgdRakJ7
zc)kRC&-^K<A<-vM1}pF(c&AuzlW5%eB{J5u<6vN{Pa-V1NqqVjDSb^lj?HeDj3G&I
z#Ixf57WS^wwisjmM-*2x#3xZ!-KW&(j3|?J_z;wF#`+{K?J4-~afm2(gy-?#q4I(j
zO;A&8X>Rr;$|8IS;vh at zLol-|Z9s&PJ_&cu0mz at MxKELyTLurALl8k3>64iCr{Ey5
zHN^;}tinlHLK94emZxZ2GmK2iQk=wj#vFoOG5Z%;)dw(oJ-`rWSc!iFj#O=1j3>+?
z2&4 at 3NrZ*?DQz`3kjX-P2ofnneUdTfQ&0w0cVkGTti(x-XUtQ2kK^BvQW^7;C at XQ2
z{iq9iytV|y)OL$A<Ud7XH4Q11mHC9hBj*LBt?9$IVdhU_8IVy~mLGzG?XpFf`IAg$
z{- at N{f*4vE7V0F<Lj4e&*{kCiNUeH-G50?OHwZy!W#vwyrcWt<R`Z2#QP>EaAgtRj
z=&N~vILr1S$g=DMehYrvRM|4v861Lr#IpSqt+vH at C_SaD)Q=rr*efJa_6iR{R9G1w
zGFjW7(n=hOc$GWzZ4zhq at Q@KTo`MX_{q>Z-A~|I6EPDv<=j)du6|>8DiimGfb{bD9
z>l{LHDNG3u!K|zh3=tlsPpQ3cadsmQkqBTA6xLXr2ecJJ{{mj}>Kg`=#Z&qMY+yDp
zzoA9S%%UsKL5w}lQ;KPl8mX6p&zMi1Qdgw<5qwYGpgfOX&}%ydWy4p3IYj#3zhW!!
z8*r at 5kwMin?8jh+7>j-b&OE=Rt&;sC7JW~aZX*d^k~X(E^VU=3hN3MAHb|9A>d+)T
z`ot`4<~!povb6!Q!`MSUMb at eQBQ=`cEV>HFA$1+KKY}B79ixY!5j+Lqam;>6*YqsJ
z(pl{i1hGp>PtQW&wNfvsmY;><*YuL+f1fpw173nED}IU81gPHQ7VZ6#GBpXJgN{pD
z&5uGTxuHu-g4HVh5;47`wEQRpa-Wyf^hf9kM{Sp&z$8I7?0QL`=~3ufr_M{X)k})!
zXCdH<T+&KfnvUpf<B}e4+kgLIR^}<rUJ~{Ae*|Y<=M*ZRPGDvMR2--nPM)h6a<Wh<
z3VT`3Z~xD~|F9J(Yc9Pve$02D!-1D2>Wcpi<8r2e&&N~N$BuK86=vTWGmMMb;Ow=;
z8;oINC&Vv?O??cxJ>v4e(DCZVU(Xn_f#S{g??7Q$mzT0;Lh&!Yi_7|4HGU_XG!6}m
zvVN$pX<-M;d0+#&wqnd#4A_VL%Q+nDk0)=9w{VZp2w|kGf7sUi8F8^Pxy3$j{9N|u
zz3VwdfLNFR1^hhzF&jCIMu|UGcCQ%nRF11{y+gCa)%@}?#INJmE^WPqYfiWsB%sz2
zYd_ZK)nak^vc_=wo|E-)>oJ2ov|^~SxDqqChHLHX`SIFj7`DFF-hUpoR<o_kW39Wa
zL8-A(gh7!%qpoXZ>d&vnP-T5=wuTHhoI$M8+E;tRCEkBRS+l0x^7t;YhBn69rR#Er
z(fA?0 at 9*n(kFu74lgFLYKEt at Y*KvMcZGTyu)|}L_?{0Ig0qaaWeXjSf?;lg`95M*3
z%QuL{2AH~kY*~N3XQuD3Ui#V(9qmJ`=-Nx`-L7MgP(#=H?s;zQv%c849)GLrvs&l6
zc$W3#(%0+P*XuQ7#n8>|H=?gK=u`G96H_k#r at P#dYw2wuoNE<Yfr~GIMC{y&Lzko9
z<w$q`sk;Hp8FD;|Bz(g&4-!B(vfO5zfM^tyUfH0dXLb7Ru3Bzmi!jOM;)rYY7tubV
zi=Z`ma$F57b4TK`nkP$d(S)c3-b6IQnulpC!0 at x27C#>NtZPdm%KFgzGS4Q%>D4tg
znxVF=K3Q?MIinG%X8ZeoH15B?{`-aYUR$OqTRDwsA0O~@1C}%6{J|sqEYBEwjAYsF
z7vN_H<_dHF;u*&e at Qy3{Q}qV)X9pq23lm0v#4RL5&_o%II1t5wF}(I@@vs4EY6v$M
zVH=S-wfXYCqHDJ`W4W|U9mpNR8EK`%BeMvX`0D8g=ShwW2z5qj!z?pg?XoOAmYZg!
z%l8U9=1mK`v4t)uTg*z}Z)bX>5%<oHr!((8Yk-M#K$yLDslQn7pU4;2GVjakZaaSK
zdo;5%M|A=4AAdI1agQu+-jU=U#@%aKx#cx`wa;e+p$k%d7h8VGTpo at US4}0K=A9oS
zAq+lWZZ!`Z4w|1bK2dx(N8J0et^D!uJ*E`-&13oUzUL2*>#SRb>@Qo`V(}FgBn^MN
zF0rg0x&mE&f6?4zC+5|5HCp`Ti(F>aG;?9buh|Fr8CU64KkZSXQdm)OVlA$Z5}7!n
zAGYCpw62yWc?2^ZM~NbtEqk2#d8;?_D7wF%Rp^CD4ZWMa7pC?30Y6-^MjnOHa~dX>
zsyo2A)7JJA<FwOHP_E3&d+tx=ix~eMp9b*f%b)?ib5}?B034z>E^A?^ke`ryMAs=Y
z7ZCQIrp9>6*3w3HZ{1eihQ%p+xW-kptep?Q-Q!ucMEY_d^t;EqP@(wjCYf&eu$i at C
z)!%K2_?8u<7DDT~W%uXf1N=O9!#4<rU$aplwf_)w$xbpk9uVY1G46gNY_UCp!b4Qo
z$ZBWq02H~p0X{+8q(-k0hBHmw@^S@`d0ZbO?!J(62zyFQZU72%#oZO3im;@k9B2kM
zsAciyY_N<=+^wKzSoA9|xfP*gzb)7DEGlXPpOuz_<`-epmA at YGF5|Ld>dVDup8WJL
zo&6KW#;kT<S8soQJM&$Yd>L_ at 0Wi~7Vh4CiE1Xst^A3@!D|h_ at 6ds1z4_fzd_82E9
ze!g7Or8GaoVNnt~eRa<PR=nTyjC+XW5I-a9si|lt{LnH#q3=s?ZNFafy5J14$y3MY
z*}m(Nvra|#K$xb0M-TxGVjfV026f`^`gQhknk7}L=JAxCy*!Sud!0rt at U3Mp74?n%
zTt<?6o{0|(+ at Tp&YnG>@niA-TM=kQKEV27rNkwAi{_FB4bOUMrnWk}ioq5VPkE^Y%
z%=$RJ<sVWl2ifV{+iUo^Wmj7E9DA!5plB at TJ0euGPw2~+jr%(GLF4e)&9DtAB&BBJ
z^mNK~M&{HAJGN^JRV<cYz^d&zPdW0t=V&@J(Tau!j;Q{14X4pcbk$E7UpkNL&1C;|
z9k$<{iMT!eJ_ExpKhB5_xcp5pHLmaSUGRW~-~RLO|M>bBDzu<33g#_^HWzL;Zg9o_
zF5mz8s-<{?@~2m}Rd^aChkVG-m$LQsZz)j1&L#BwD4Ywp^HE3=K?)+wi4;hwW at B#B
zcVI|rb0CfKg2YFa#c#?IC)fo%UJBgim`)}wBS9+wg+O}0%Yk{};wwW|YlRY{;s_{y
zB+Z)`_Q$h_1Wngp{wC-X$Pp5 at 4H7)U959=Hd{3(KHmGGE5-{wcn%hoVL4%An)$iM?
zn^q~&mq|Fc9e^pIPB<8nuon3vZiqTTeoQ+ErAwXA)(5fP4gv!?xi_f35$^}9Hs(Rh
z6O2UMQILqXoph#+IVrBPBx}xtpd|f#Z-TNj-lw>+3!?o1PzYU4s%a9s*PUQ9R)3Ji
zChQsHNzlb*{s2ldyb<a`tm)N~xSDTd;;j3FP at +&!kgS?yvDt0}UYOSJAd{^D1Qq1O
zkgwxGl+EcT0|s%$vsn5;+^ZhMXtg&|F*EU5)3rE=>*+?CyQ7oPJiGzgSb`oM=^(;+
zV<WICw0tiF&0txQK?yyGu}^PAe9$?-oXbfQ-_n8q>U<CtIS7uA(-~WF?MZ|N_#pH>
z8^|e%(ljN>qOIEqPLGD=Ad~a1H)7vFL3(O^5Itg42DOgHz*dqm^+7lj?WBbj04bVa
zTHOI1hn>Ln9tK*Q?~HI>)dvx(+d+Kzd?j`HW{Jccco6rc8^L+ld?n2X(IAs1Z6in_
zn&X2g=c8BBi#Iqy8OQ?+ug;xVo3Et$BuRpLr|me18?>8f@$vJWL;(ZPbKfzPs6K$m
zd;=(JYe|g0U?XtJbg&0mUaU8P?+zf+6U?y=f)rT#Alil#$e$Bvo%RPoM}H857GRel
zY`&igp=GfiWYOkr1Y!zNCTZQ0DE-n#ps)OjgK)BZBdAf2E&Tcx`$)FMixb~V+}(xL
zSz-V<$kYSi9L-({x=9;Jlm>nyu%VQfg9zp2m5gvaASUe~I9q!FTDW&o!X`}^9Gwp`
ziyVZWv%eCw)?!J7nzRx4j`jdU)-MG6l4Mb&HUewH4sZ~kL0<^eAe<abXRGx=lrpsu
zq{LdkkQQzagrm$!j52kT1=HhS`u_y}Lo~@6^&k~eYY#H1T(4w=wOp`Dq7NdRbT$I7
z)Y~h8XA1j?|2P*Oz=|CNcIvSPnL%{}k>MN9PiAL0h-y2Ca?E>)Yv~ya)$SlR=RuIc
zRbC04Vt8SYMg7|dlE6F1PUdq-f);KW9i*~1A4DmMH$jgpLtY8T&6Nai`yfV1+z1>Q
zCGnN?aNQu2{&XXFD*fp}l#=*D at XT=L6j^T|I}tk8gBUgOm5k~8PQO7-JjkMl-3Z)I
z8NZMch8|>66E}jqSoJ})+8be6hQ)`YEEL9r3<~2xjJENW)NuXq$(_#kAbgz-KwO5s
z5{|eDl+O18jk5 at C?hb^?`39N~1&xCdyT?Ij!49yfq%Q<j;Fh6rx}&xpWYP$41X)2N
z{7OcVBucg22>j!G04eL0pp<=XATbK=MvxSg*n=#Z<&D4*(kz3B4-O<sMcoJ-VP6j-
zQ-2{YJ*~hH)^UPCJ>9{w`UcSAB+d?YkcRpolX7~K3iHSI at k*MH79{Eid=umV9rZ!v
z6`(2ms6k+C9veXl&`%#^QB7Y- at 6!p!1UAKk%-RkDlPGTh2E)e at 0-=^}1g4R#;~+!j
z7cw+~(O=&HCX!0JgSlSg(qg}1DeIFcRdgdr2a{I<eO)7o&|e?K=&v^dTS*yxC3Q%W
zMazAYhK!))KFFl7z7Pn4k0-6cTT*HdqBP+ffw!b7d?igS$)MaG#JqLf1m04{D}l4=
z2`1I{2C$a>jFp!B4Rjw*T7$3j*0K|!vL3|Ncq8!aCcfzn#*$wBAl%^%AS)=WuSBXQ
zne^%#!RSG+eh{UwZUin;+ApNcnS{b|0BdU}9p9(=O7KXZa!3}v`bKa-bmj+93fU`x
zZa6`jQCANlwB`pf(^rCR@^Pni6d`r>AdAgpBj_2l=C7ptxI;31e{O=zpt2rBo4yj9
z_41AH=-o8y2N8<vL5vOMm5kwSspA<m>j(KC-DR#MNsa?iy}qKppp6%J$g8h1;@V0*
zHd6KftK;rKWHK_D)<QL2Fe6Cfa!g9|jo at C`U5_Mr3jyh?-3Y`)Eic5z2_O?R?vw^S
z#O8V<t-Y?9)apl)tMacwFET at Kgg)5`)aJo%I)~ex&37Xxp=`A`Vr&jaQZ(w2EUNd7
zAS&2yZ)CnM5kQP(-FQQHq<X)R!DhP==u9 at -BdHg#cyR!zOltQXH1^teP!u~(rpn2a
zKx0z5-^id&KN3rR;}Dr_zBkgT+ at Hh{5p#VYsap_Z`@NCHX1fsx&D4%0E4Q3XD))^b
zCguwmDkmqBHR=?D&{SCO#Mp5U1ijC91LesUyn{yBz5 at l#yIr%2jX`y?``*Y<X?YT;
z&SEEGOXbW-r*7W}bSS&;jj%<YK&uvDQLStQI+VTlMyA=3Kz}T?20Sa2?Kd(g+mFOF
zzZ9G=vjN{oXKC38lqhxkk@)2RH1^*eEVkb#fDrBZ1fay`MFw^KMxaC4eUGI0xB}8y
zY&HTRN at 0H^#_oF{UG39}KK=v{qU95*eFT{l`y0Xk*pF{yu(lisR7+8TM+eIk`!~`*
zfaW&TDckc78m0aTB%eD#7M1=+Fu$-l9|%fyZb2rS^OHb$DHV3mDfN#edmchKX7=VA
zv2I6FCA&yahp7H<q_H<2Nm(n%WVb#L{Ozi<5c-uv!Ho<K1xM0+D8Rgv*}re3vmzZx
zmMSH|^>R!&67#7A#5gA0$YM`FlI&t0vuUNQJ&+`A?PPLrI1*?<5u}FVYbQg+?2VxN
zjHNUh$YzcbM^ar>gBXX41DP5!NT6`329BhS8Kkjv9!YXt3o<!@9LUgM1Ts<5>lx%;
zcYri47GO|R97%D>I3c?^xEzRS+Pf3)^#Gl-%{yqCEAPZyfK8+XwaJliV%-U<qm3ZO
zihLx+Wzd7562F4lN)QVEcYw%F^$uFMJ4nSpjLf4hIuIz7xn4-N9Y6~Y?;smN%H0UM
zW4(SgDY%ZLu5lyi#I|0DmHa}|EH?rb(Ao<rsox0ng_r&b<;v;tNUAFRUtf$rTyB+w
z8Q*^h*cl0?)=d7#1Uf1MO<XZe!<P{<Df{mmTKVrUfQ%HbQZt#)%kp0{=V4lUnp!>(
z5Zm)P{5e}2ObQm6i>n!G{&MCeOpY_!3kvRLc5G40FQCN<!b`@~msXr(wb;o*hzlT`
zxiReo2dp}$mFnhNaZZ%iD*b4 at merO_2qxW99x|(5&K4CmU(VQ at GErh_W&bUYq19+7
z0v&piW;~y{?j{SgFBhPW*0(vH(af?eWm$+3UrlL6P^UiLYm?a!*>r!EWi2*7Q*p4&
zz3-pGq)X=)Urk-)m(u**BkOsY{_Rn9<t>(v8du)y*q?i(!A$O<*{^T8H{<2z&gb-{
zjiXCWRtbw^O<&F)=?B;IHvD;pE at QPx?!MJWgq9Ttl3)bYe at _9bP;@h!d7%1PN^KFy
z@&1|>KE3+ptNGDwJWMUeK)F9ptH!T~%((S(xp-y2$vot=+5PP)yy9kfOh(p}M{{}{
zPj~l<IG#0PZTaefYN&Mf*c!NN`qK>*#&B<sxSZ}@zp`%2bK8U3*6`&lgaTRl*Zs>V
zh)UL#BO{7Cpq2or)N-FMFTDODfvI$hV6YL{Dd+a&xxE-UPjfW$)fcd(tyqtuh35*5
zC|M~&r%r#Khhn9eR|e&m_q&P-XRWJpU{eBF_b?cE9K>dMTuYdKi`Jgc>7aO>$(Mck
zR&%=YH7ab;<GOq=&2xP(- at m{9`I=}OSNeNJNAK?W0e*Ji9dP@}8;GA=fbr4xmpb^_
zL6d;oe)0zVC;xmcf2Ny9(*Ah>UWTTp36*B^6*PASuWLqHa=650u17m6UNiurp)>}{
zf=B&>RAew~_NSwpFUNf1fmHdpN0eo~dtCuqxp+ytDf|&WD at Ba4k93+>xj{SB;<+N>
z%jDw~8Em+W&Fpje@(WCyk0y+Ydh4%N<*V>cyt`Ki5WIZe;(2Y_SkWom)bgafbbxcs
zcus8tb13ofb}a|6_&Cl-E6VCD#m$JE9`_w(xJv}d0bZsT3k(F5f68RE>?ZW2|GF37
zS=aTeLSQf|x}p-NqUonDYk$6S{1*FP^qHHiBflA1RTUZE_U9brv at bYnGy9mn`~pUQ
z<zHb{8MUpg_%BvM&zFQluBSFwRqswM>gZ@!EO at 2t?))C9!`x<A6|ccLm++T`j2XJM
zIXnYKk^4p{EH+bJ;>e-Um>~?}OEbw~&xHH^nt at 76cG5@HS5D4u5AeeUV}xS{1?pm`
zv>h}h=k}AT!h3tivhYS*4z{mqAMIE3?xM;N7CR!Y6xNk5sFE<vu58f_H)w_xLEQO#
z%!qiCxw at OC8oMkS8wZweSaq~#U>V+Z3p@;2_I%tmS?IT@<1q8^FEbxt*6JY+7s6_h
zYAtE4U76RGukLXx30)cH2yKSTqqX)D(J||J(BTiQtKf|KG<kczHq450N;AZ4@)y??
z0d;Mox$JI8Q*QGrs!e7Mg`a&ftC07v%G;8_V0XiIugeQlmsfaukLO;>(~^^-wUyyM
zwB~VcQ$CJxpi<g{LrdqnPWxv!Gdir?9dclBM>+fUO*Nl8vPc1>A<R}|M6u at q!gTNV
z=VN%k#)Q)4;2g at qBrADY<@&bVa?K3wX at rMDh3hT;BZPC^URqVRwKiS#zG{opwtCMU
z*S+5JMEm2?bJSp&xq7gtk^L at L1k!A}Jiklq4CBP at rYSe_cf!BF{`23j|NTFG|NWIy
z3gw$6Wd3~RJdvdKAU|K-Al~YCOP-}zGCMvx9^~gn3fzV1HBIS;6S?Y6$wLWrCbd#^
zp!g%s%8?Y!wj|hct{+H~Br3INkUA5pXcG9M^do^RoH|9tn^*flvP4g5uHsJwft7TM
zMi2H6q;#F4HME%gLS}sjbs;~?6zIyoGpW*xrA=?H2SUB3Q?+PBM`Bs0vgDQdNGRk;
zIMAKIP~Z_%4XbC8m(E~K?eIiU4*f at lt})JlqY4QsC5M^=G0A$8 at r#1>1UP*VOypMo
zKq$IMAe>e`5-M+<Kq7d3Aby=JpX_w+0R3u}Ad3p`NH_?Q6xGTTLB^<o7geY6fz+Wh
zbZmp8(}7Ss%^*hkb0ik_S|>Ag-#<(CI1*||<w}PKS)`66Pk-_7Li|psx!MTQKY*H)
z86APka(y5ZJu!f$-4kfF1fjM(k%8m;36QaDbw@(M1Tr*M9zo6{K%etS5bHxH7*yN+
z11T*BVZ%KUcq8cy19cL@=uB#FL8QzN1dcB~2-U at zGzr}@Q2+D%KvG*l2DQO~AUnJZ
z4MZ#_yCb0%bJ9609tet;cbH-7z$cQ`;GI}nA4n?!7G>c(KqdA5G7#C+Fh`P;1(~It
z$UxQhRxt*eM)^RB_X>~!jd>#TSA at z$Em|jlxb-RpVyF*i(!34e3yA~ZfuLV`jR$G0
zy+ at LJfVs*EP`T>cxD&eW9iVl3{RS8uRu812pXrovP)XwhNnUwDdb1<J7+{M2$)U3z
z2?x#*#8|-(1Tm0u5QN<kG_RV7-paZ4ouIDR>_MjF-#dYOz1|_4{-wLjktDfcDC+kq
z<^&3E*lhW7WGZAyA#3LTu08-}70G5<Rd~rvZdg8ANX+j<Ft$%3wSOQzve}<se(v4|
zKmjPb^7m8r+z${#V5?^{*aD5_rf&%*BbDJSOU>7*y0!<X-rA7M at aoT-<=eOcH>teM
z7%rYK-p`}S^0(o3Fir9)6<5}AE%|jq!hu<P&W`I}EG?3wA7Dr;@v@|8F_*<o;21R5
zV(x<uuytQrtffb1>q~F>wAHy$bRc14hn@(Ah1q>AIHoFLjvm83;ZNWnFR=kPU9q}Z
z^KG^qJt!yB5|77xY;C+vq*RhQe1a-5`S5fFvsr%JvjvT~^%(9V+rfbA`O>_9fk_%W
zkscQ3v6Ltz4y158K+Yu;7hGBncVU<3GV<e|>)Zh}C)W{&KIU*YV>owNpQpFMgkSlU
zcv78{<(1B_v&NM-o+kVXW*;;+W;uMcHn$$nhvai;RX3^R#*655FUsL1GM9s%ppv9N
zrs+~YyfruD)227i?~mMj^l@%-?w#ai#&Gls>+ at oLzO7--bMK^i5$?t at yT-LC=hs`I
z)vR at T+ye@Q7kIZ5K4cNcHr?6%Hou<HU>VivZ%Sd-G#~`#4fAwP%NuTCie!YRV at uH-
ztv%=EmO;olFO7^@t1~QGUV*m(88{K)V=lA%1+)}#9(0dCkjxm3`{j~mL7sb=NC-qZ
z`T<@){bioX3xXuPW2UY;y{BtFN9qh`i=f1sMSnac!p-vJ57*rQrNy~O_+EX|O&&~|
zd5m5*pXVi-n|PZe%-C|Nt<Er{nQ6UC at Vsp~oHFFsH2%-me_s%r<;en>*}bQ!FYt2(
zY+gi`SH6My$^&rVh|}ex34X4CNcLC0fqdn^FSHe7WL5Eu^lJqrDzbXZt0&0Qu28^k
z%DgN5s=ewGM1~)qMXwv@<(^`=!~DL~7~X3>RpA^yD7_XL0v1m<gEPXi$3=$^w$v`}
z@^BY#e at dR2ZxiN|az at L+YBT7e(9FXwqm*$Niz$)87GQ7>H(?M8TYfsSABAL$!Q2y|
ztMTV!J|7edYq5(oV|a<sOn`mqeBL#VNFwy;i8bhvIXOzUTQjwK)eLibj?D9(saQs&
zQi~)Tulwkh6N&#HH7%lfRorq}GGc6G2=p_kQof0~CpUA?&DQ5u=gV%^@Ui%K4zIW?
z&bjk>^gS>O_WUxvnpqBi0Q+shth2tj(T6SR-#ioM%~y-(sSw-|*v&F#9#wigVW!F!
zE9WP0O5AjBnS)#F^R{TJ8H>x3bbsw}NHTSn49!E7I&~UTdhjEh;;P@#_Rkr95s_X>
zUr9d#Qkh=hrw<UB_YxA`JO_^zc;VSz!OpDi-!Ph&L6%^dHP(UFtF%|#|5|~+8`Ctl
z8$iv7ZpdHJbZo5wIQrfTc)h~2w0{GyS)NxeAT!jl^abQcm%VtGD!FuN{aE_)il0dN
z5qb{Ay8QU__dmY=Y90UriqwVp{k#15_p6pNwMP#z{Ob!b8ye{$Kff3;fh~;!-yXgk
z?;a7-4?xT^M1Ea>dx5MrM at d`&+zvPS2DQLJn`{KTMFLrgxTanKazfci&1$(49DLb6
zTygQ+`fJ7UA^WZbQ*G<Ru~gnagUNOKO!J;-8`B`|=GnDcgSd#;0LlZLcqK>_Wq*l6
zu&;#SEPN2_Z6j#kq;5n}U1TFDaBUpK)y_hCi4wFEmF+tnDu%W-cb9DKAiNJj)nq-0
zjqP|k4nzAvv~An!Uf2%6wttvW3i%);`&1Hga3_Q6K~(p%P$XbIi10oa>R1^E;jzs%
zO7yHd at osM?M%%d$6c^)zc!66<YMq^gW4IJ=0X!+&K`3JQO^~M>9c1u0i07e|&~JSl
zKtwl!>`>((O#4(4P0voKw}aUJ8AW=~gXrLm;A)f(;>mR(R1o|1Alp|U&P&&W3^~WR
z?q3PY80AbZGLneZjd)$RgD}fRAS4POgvL0CY1;_oT&o9B+ULU6m>fhpZA6fq#zDC5
zb1Bl*0fyQ^ED8V$fpHM1ZKi{0WX2ca5_)+jkyGBFh7jEeksQQqn~I at vdOwIp)Vv86
ze*%|PPDb=Fm2ox72jR%LZ$i=Q?u1G`h(!*56X*!hgJ|97LKUO&fs~LmPT1N;Q0nHs
z-h|jT0-0XqAY<@BRJXar#cI0}T#436B5vNGhD_cGciBjbwrwXA$$TY7`&76;y94CE
z2{e-Xo49I}gGix`Q2g5oMRNa6u-y^?ASmhW0E6@(8rl9$P~#&US0W)fZlrPeDHL3*
z^&lJt;7xGDst2LQ2eBvsC+QG)esCZP_2ANUBkCQ_LeLRG-|R$C6YivI_>Mwhcw4X$
zvau0JjNYyU`G)EwLk?iYHsZaT97Iqz?!-OM33N#t2Vrg-fiSt+?$2oxD$7nxWFwF%
zm99iW-X~Ginw7u_tQ|zoArn-~OMqNtJqQ<Gi8r8wu7o|b6AbM;uvYJ&w>Vz(6yE&p
zL`*jVrQ_Yqg*@G+6PB?Nh at aX&kTGZyqIwWh+X&=PlMkdsFXcp;Hv)lF#+9ImvrZzT
zZ3J$j^#e&yGVjW41<+6=H_)R5BpF5ru|7T!Z|a;t0!uqctmPX(sjPW4&|Sk0!YUs~
zkG{7d(V!VR2ywp>)by at Fpw1!%tz?WlplPb;)h^tEV7|%+5uz(8QSzO at v8*42d;LI=
zFM>dM%K-?&78wnGA(I%Y at 168wLEu-Y$2(C--5bGu<!7J(p?x>ND92YYdhQ#M?>Xy2
z;5#-ZA>oZ6d)4uQ5b-1fHT+I$l}Xg<MzFnRSAw;RO(Ll43#lk-p4qOXjXDXt-&_a|
zvc%pi{6X76=mY3HCNNKS7lLbTvGWQKG&zVu4BW}kaP*3h^qjsCsqF(PBX^FJK{o(j
zt#txY-3StzC%-F!vYKQt9mGn%5=2wavp{-x0dXbGcoGlT1wi at MJ3(-hPQtDz76KRa
zgm@*RO+dZh0BV at lNlfZSpq5=?TnUXni4I*!g99pmAhpmW;-X_A5S=bMz7wc54&CO2
z(Q&K<k{V+8PFiR(C&Q)4M$FUVg+NP$>okaLv>;c|sZAm-O%?*#-ERQNqV@@xZ6lE3
zo;No_E<~<m2u)(1B^Lr6-r5IJx=iBNumCuhi<1k1qBEUDx at -ikm(T}Nc>;EA@&*v<
zo;_CJmGzqq5z*QN)^sHuZJ5iFD`_E$oM at qqK(>#55cWEMArL+xidu(kcU`g(BK<%{
zh$1Iuyb;KD*C88G&ute1vBu$S9ZJ5|gGijuo4|2gcU%ee3AphJ(7k!%vjTF_aRbHL
zBsS_s(9Ve+M5}BBy4_X9g+SWUn1sC%S_qW8w>=wi@%IJ;GTl|hm9&s#|I=OW*plNo
z5cS_G-V*o)0lWQn+MF|1%_*yD|L#NpkdjoZtV~={6iNJoBx9 at xQJn{YQuo~4$&&U;
z at Efvi;Mv0#N`{SK!;}mMnQTL^q<2eVy!dPcAwYp}5Iu(=enlT-6?r8n;l)e%K*q86
zA7uK>AA)+oi_Jj>JNrS at E5#cbp)Ch0VV4J4Ya9ecn0@>pGV4wzT&(sWlU at 3il+dUk
z#=gA~biXnlL`ORaT&xeUsvQJvf363aHs6RKfYmG9gf3ynJ;>md<REnV2B59jUJtUE
z<r{&nYx6-w&QC#Amih-$LyUv4!yUku9t1*`eexhW=Rx35>kqQ}@hL%<XCFL>l;c|h
zNjl^~hK^T)u!_3 at h_UN!1QL{&gM%zy1~vl0$tHIYVIFS;YO;<8nX^5}V`6B>_9QCj
zr=SbjvktPx_ycLnvrXVXZ4V+RfC^-TI>@l~AlBzWaP43_I*8V~6U2F&4<LGc3N@%U
zd5|gRTM%odKgbyML3G(cAjPV_5>%kxlPrqljlg~EHU|+;$Pa<`rvyI8q~JY>vAJvn
z{!@7nZRfY3tK2y|S>^l|R8+SInd|%(bQD|1LB<>pqIP@>qWat at z>?#@a4~3Q{ekqj
z>Vn9a2Y~~%KgewDK}-$+Z<#)b_HzuB^O_H`>i(&JzPK$GZ*)dOi2Nq-#75UElaT?S
z3{>_`?3X6j0&}5PU_YhC`>2*bzF=3 at DcBP-ga=^p^1vox&hjyR_+r$3p6iO|6M+xY
zizg??M=+dc6|)N#3DdO>mxeglOoNp2;Q at FbZQuU(a<ig^adzJcOei{EjM2vw1z085
z=8J(jeW$a<(~ia-TV>${7|;j2;f*-B5yw>HTXXo*ncV?|lcUu#*=eF((X8<@cjCjx
zjISBCPSc-5efGJV6+VgK2~a9E#T%?q{N>3sp-91}eYC4?04Y9PD6naoPtMu}YsInf
zKF}O+OCA96DHZo{X)#=F<*|&IoK=w#pz(2=e&{2I)AZre*Zw at B4QBIzFxG|qShzH2
zS31<y8<&cf3bT)RS89y)+gt9N=8DH%+?*wLT_KDjxMmEmjjfTO2S8(pXbcm#y@=J=
z$v~NmSkC!p_nk<OrOy=`pX)Y#cpGDXUaaTa=4KxH5DPC at jdNt?(+d)__bR*DT87&N
zs(1*vc&AzXZA&i{$;o4I!8bgoBN)y1S>u1d-5XhBk>45_hG_Qmj-b|RF<5(~(CU$Z
z5<xBQu4*+iqK5;RS&=jD-H{15ButA0>Q^YtmFelTNy+3!-?&ZG0+ASf0j<82DOtDZ
zTgJv!wsI*Nk69 at hXr7HIscPR>$);Ja%0XQNP~DZQ#mlwy&#8nNM>xmlIeine)#dpm
z77Ohy^KWK}<r-PBt!EAVe$?+DUq8PTH;>Hz9wi-{l6r$*J5Vq2pEsU%zHkAYHDY?3
zGQh7L at H~%K{srQdpI?TY7|}~uhkoy%3h$2!X*Kl;;_M(1zG<%X6Z?nV-Ds$L9UvQu
zFi4<!SIn<$2#{$to|>*0K4!#gMe|eMqB7)$n|8(L<Zug3z;H({Sjh-Oj$zF(uWI8V
zWvrW-?~_k0^K;=eHq&Yh4tsf3py>uKe?GBSz2zd)2TKnyP?@cGzR;ZF?>65=m_EFC
zQU<`TG at lRiBU+wy>q;|Rck<(GEf(5 at 3q$pCGXke*o_CgDogNo-KrE(JKf-vK`HjP_
zVTsImSz0Vir+dfC18z{m53J>`XvVIa?a!^|%QPvS!;~0a;j1{&frWdd#q1TkzD=Be
z48F{To=&r7yR5YOu&wYLi(saUKMq+Se#13h!LopwTyc;^virK_N*vS<hE$8%+xz9M
z85NdyO?qoZ{M+y|TB)yerUTdtU7jt82)+c9`}&h^Kc4yLDajssmwV4hm3f0-9I#fp
z#WkdL)V#5SffXOGbVN`+=dhW+NPGLJFJq>R6c^CHIcX*jRR1 at uWqP+_nk74L@x-KH
zjQ&P(VJuGJpv7$ZnC7kc2AN>P12UFpG*$LEHA-W<<J4xhtqepsavXumHY%Uz*g{60
zGPdLnL~#!S$jBr?z#Bs_OqR{t#M(VQH?R<d78)*g?jK`s{YXE6XeK;4pRTX%T&acD
zee6Db)HrDRgKwuBid%l2U?h)R%hm1$v(ij~Jx-Gc5X18-VbxD!WzUs3n3<J+^cdZn
zWYgu-(pL7+>W4n(ZTg`%9iQi{@Z)|N at iNyoHLn|%U4l=?)fL)iQfFkeT)@jM+j2CC
zRXn(2kLtplpGrMj5aV1&%DRfse}s92R*%|Z-Vi at FRSV4&YJ&E_O{ONC(PL(w5rc}4
zZ^5f0&PZ?5M{6q7d~TYOv-|m%yI-ZdTCx1NyR&5$@p`bC=GTTBpu+YTUa}EH;1!J=
z>Q=8TiN3=e=GxlTwIZozzfB)LGO6-;zh1UDmywf89;;=7Lnhp(x-KtlhweU8ONZB}
zJ!#kK{tgv at Uv_;)R>(1Rq0ZT|sIDjnwSQs at bEfQ^n%nLgqi1y=%o=)UXoR)Y+YFcK
z2k;an!g|j3Ib&A)^g++^uTeZMMP2IJO_r9(_DgY3FFiePw1Pb0>=EXgb*fx9)b1<S
zyo;40Q3dC1hQr$Nyrmk<w`+;XR)hm}d$z^l6+B%qWVf0}=FhM4UB2u0KY#uG^&diP
zK7amOzW?`C3nWp^ui<!qf7Pma?m>Qi2^@j+9wn;J at 2{nZrS5=91}VdvSK9!3Bb)0e
z9WAjDM3Qd+ at +j=y*&1u%EkqB(R%Qob7;@U?<&gxkRohM~)D9{w32&7om|688=)=B&
z=GQqAoG$wAP9Wn}eGnU*r+S2vK(k5TNyCi<C6A;cFi3d29S1>A at 0=NGwfMeT_ae6w
ztWd{;m^f(S8*Qvn>mb>6aJJgi3DTGnX(Nj6pia745~D=e2>y+}la6n28eTDK0<V}G
z!5L7hfXv#Hc-`6vJiw}a5Vm>}-bP3eAuQAz;SGl~LkIZvh(y>cHZns?9)uEwq?#r%
zhWbWW1h{n^oFrJR>>ogF(N4h9?JYO<t;kP%kjVu0iqw;s&VyLglY_XHVl^1P?*YO4
zuoo{gucQ=@?13m->p`T>gS045uI)6*pbUK_;V1y>yN#q|QQLtQ`mLkFHYcbCl)ncN
zb_9?%<1JJ-wv2;JN=PVQtuu*H(r$!(Se#Jg266HKLJ);L_Jp2Cfp?I_Ch$t)OYklW
z>Sha at FYhiAd%`u2_tAsQ!Y}h0Hj?m4@=mJy%oE<$2T&BA&U=gB1?sGEUp<IxT9EG7
z6l6R6(O-$;KoU&U;0<(Y);D|fmS9l0A4DmK^}5>BIS~Kz4`lj{mt;vl2%3?9>y4n|
zCSm&j8$fNX*dn^i(g&Hm?7b3d>>$SM-w0I^*Ee0b1yRb-SJEZ+sVKnqAd70_g-{~J
zKGC at -h7K~R#FYxhqfv0fWtDg(Wmu9yIdBj)dnL$3 at 6S~#deHg<sjDYh6p|Zhp&nmI
zLnRtXge_+y2q$|7EqXS9-!fiE#YIw+7%T5aa4KwEuVl0Y$`bT{y2~b8vK58G{T#&`
zK`nn!a2z#+T&r67=HIQo!H77Jaa;HDX&e;<wjaR9&-ex)8={4SXa;zZu-AdC=-``=
zJ^g|7=IOhkANb-+MA#4iCVKqQ66CN(JqYC3`VL04bO7qkC*gnlE5Y1z!QSfuw1v+6
z2Id-<EH>FhSegF at Jcc_);pkq8t^EU$X!**EAcZKa*jLh~*9GOZ?1gMzwJ(GLbJr--
zL<<or;6%<4C*6af%<PeYv26Vfc%8yGs55-;B(mA9AB072IT at h~l$B8m;q&Sn;dKw^
zuu>PmN7$3FL+B4gLMrI-m)e8y^4ct9kMWf-W&JK0n_~gu7v)LLtaDx at q=B)yuMCWW
z_XDQCd%l7e8iW<^Bmf07tdO<$SHj}vHOwfdq!4kRKZ!p{9|R(iJ^d>gA#OmF<>o;s
zSa%_NN+OiY<11kq*Gm at VcOr-K`$4GrwGi{t at g|2a4*7x1c`ng565#`=fTbr9zO}Rv
zVUPYoP-$Af#MreTgfGTXh$q?yK%BB6C$go^c at YU|M-gqSkTqr at hYk5bAXkfR(-Ofm
zgRS-}X(1Uww68=UPS-4Cot_BfDH~}bvaOKQo@))fDW^ywYV#Y}lr7r{^eM%BBAa6V
zK at eg#%0w2^Jds1`{vZ&bY>SC75D$QW+WCQWm&+tNG!eW%_9|pINd)RrMj at 2L37nn@
zq~y{<^yH-=9Oo=#YhDWf^>2WJ@?5ZdH&1fdzdoenUQvoCVwB<!f)s1L5M{%95WFSS
z3fVocg{sMhm57{K$eDR9JQnsT#Mq4<1PxDiA=~5!GPFBEM`kxlWbIzaIVTb5jH!i~
zu0$Yvx)h=-uZ3`(0`^E`Af>hzvf3)-$V>#`vQbC@=mpCP*=HvL%`{gbOY>4tNWB*#
zs{pgS6cp0fUkP7O^Acs-co1kLiq1qfMdyP+%&~7IvON8s<gC0Ff_0=2W0!c4<9p47
z7wbW0^GwWSc`f>o?nN>a7WPc?cZYYlOxRwZWO{SYWUu6}DK1(v`D at DA$z5}~cFV*h
zFST86W}+jxYwCacE`SpHNgzw+E<|({!l%KLK$fgth+6WOG=J at 6!bj7SK!h|YWXULm
zFTW>&=IEyoTghQE{q33wAG}Wjsi~uootJ{bkW+}57IMb=f$)-(Kv&+>`Vea)5oio4
zV5=npiP5!?wN at eL%tRnDW-r9jXBHGjvqDsMA_$hPLiR{YE$E5e3z2gQIWw;XfvCF>
z>&Y1l@?p(F_Q`8OK8#by+WDlA4{aABB88Zx*ev`vdLg><S_sb3LiWragZ@(~Wc5+V
zNk7^Mj#(i#(o!2 at Z?8hMC5LUu1sR2`{9&ktUWu$-h?NaOEzDVnYVy~HTBu-4UJ9YH
zUC7Eg0djU;3euqULTskcc-ON+wCA-T4VDzLPVyJ!cFrV!BAh}_OR?c=Nme0hX)Qh!
z$0%f{4Ju-jGYMo(E#zok3fiF0LTu%w5Svqgj^r<eY|DuRvRhsXN<d~IV!e>!QV4;3
z2SN1YlS2qhDP(I}${+-KFJ#Fn<m5y$2!XK+v0SMQQXp4q5S6?Zbeo<+b}rQhDUdS>
zM9y=q|Nf%Ks438?A$0zwZR}Cr%J~!}V3k3)KUk6eq<EO|h=uPOYc#b0cKG`jfGfC3
z-8MNscl>%`MVL$NZTfT`<1>6DhBxjRoZjxYQS~wT#DkY>ca9GBa&8O-?QP;9xJo|z
z1v-j_|M<8`5yfx&Ibh-f`}Eer5fh1ut(e3(G^}r&cVw!!wm2sh02L10PCu~RxZvsk
zxYOL)xcR^7M2%mw2*BE5u_LQS*2CmEeDY#9r&PkZ86h7>xkpw%Ox((t{sQ73qf~*h
zy8m{u{KMRR#bj19*y<}QTN5m6zAaY>H1$rl`|AUjGV~hb{L3S=EKfSlu1iMP;trfF
zZ#2;;V2V31%!qt{4#zEniOloJ+k2 at 9ru&!D&|^O(O!g(1((N9r$8<UCo_lkANsNnz
zNo7qJo^vnO^*F>QFZ~If2rzM9xg7~p%;K8HbT)fGi{0;U at x%D5fu^~+#>e#Ov+Hxb
z at 4H#In%<AU;(II>Uo8 at F-m~!NACoOHreA>S?Bna6wa2foW4hjZ+-BT}4%c~5BgV}S
z+Hb_0yh3~(&A#-GF~92Oij+AsCVOMzJr_?<e`+!bJY-|bO$mt at _yf&z=6FbN!qE*3
z*^Z17y|sY#CGyil`pV|H9#&JmlcTJh;gw*|C>$C)S at Nn__wKA1Ud_KXM^qt+BC_2e
zj5AsQs8f&piQkScZ-<0+Gh}~;?<>`xR-RwFqZrD(`M2!u#5`SP$8>96V;+_J_pkr`
zLV54E5U`Y^v&1>w{`0gCLjC74zuGbXn(#1QypQh%`11s+mVQy~_yM+Pw?46^^P3+V
z4W2)NCY!|`(Lg4i5H#gR1CFNo^3Y+V0s8GA3SYq-5}!Y~<rW_amsw0-<K7!|JD3`G
zN|syxu;Go|KAXxfa;4#~@wpUv4e3VHMvRJIBx9?*X^uCFF=t}Bp+3IN<DKL8uLoe?
z;;(%($Mp)oE>SPVW_(?H0Dc at -C5kO&3amNbme1`?Kf}y}SZO!+sov5YxdpIyRPyOQ
zUMIfY@$z$X-b#FZ*l$hXaXn-``obLU#c|KU&InU1Mil{$#ct)N(B|Iw6q4rRg(s1>
z6{n{7{tO?xKVI(Bek?v7(-DgnfUj1+ZE=*zgMZA{ZwLY)ME*6p+Pey_G0oe8qUsy9
z%`L<p-tj85xGmgDzjd|gy$u=);fU{CU%7)y;#VtDg>S<M*@*Gc-EI7p-`wS1vR6gh
zC%mW at 7u_OFbjU3g9>VQ)+_Ua?$wJRdcF<3y_ryF?-{22tm_#T#%Hp42r(tLN2|BiH
zkDp-1zG~wQ+P!$odVKV`EO&BdXzyDA{{3}EJnh~k;SE9)IM{K2J1!oqcT`arVa|E0
zT;uHq2o=d%t^Z)x>|GIMH%(qi%Rs!ralP-W^%ggHAj|ywu^Y5qE<V=1aCbHB_e!Gl
z!?YFScKpX@?#KOpo&JJ9)gA63%HMN$#6k}+*DWQuuzwufMcHIwj_}V!p2O-UH{F at Q
z0PX%9mE<h=Y28|}Y3fyV+w&D*X&M)ak8d<Bm~+bW{0pna#|3VL*)+xnbjFeYoY%&E
zE3jXR6nlhe_X4p5(OkFScD>UzV#m79wOYiE;uq%Fc7MHMFY*#%>eJWJ8+r4S>U^8w
z7aN~(IQ5Fa-Q20`Zf1sKLQZ(bLkciT7VX)VJxw|H>o368L-W>yCT{ACOV4MPPv2Lh
zOpl?Q80LG|;~k^ZD>!33qfL(OK|1qxRiqnF+VpL at W9Aso@pi{2f(S3`mb>-}x33Ya
zM+~nhU<krsE4%RwQ=x46v-ygBM6=y4HEwv?yv00r!PQ@>z)i1brcep!XP6o)t`gfO
z9i;!KyKI`{xN$Ii*RSYfcU4B!`~XN^_alcr>|vu at lEXwA+1ipNuV%7#{{6lnd#rx3
zPPtraKGRK*00F!lbJbpc&40SJz}!7n>ef!f2-Ys8#>q-y3s<i~?;u$KFw_w}OQyc`
z at vHUlaqLI*T0e-PZ5P=(HWr4CE9>=KrtR8`^J(W&$Ln at 6#86xNHtet0mfwGeBXk50
z8#F(xV^rgIaMC7k8_t_KCJa#%FzarZH#c3!!;9m{o1&L7_jWO at d5eLLbhRSY7d8?m
z^+KXGTt{P<W&dkzvi~&Xwx8P0;Lh~B`wJZG!eiohHMNc+vQDdI7{2}Kum8OHIRPVa
zR@`J2?Rhm%!!OtIuj}-16V|n7Rkt3kqC(Ih$>ke)zELZCY07Kpt?N_2zgo_;QEa;G
zQ4?h5g;9mkIdI~vg3DHw?ID3%zyM69VAJTe)r3=6W53QOYyM#nxWOuU#iVQO!~_9A
z?pIL*IKn20YQkmB?4V7d0>O9C=T>@*#Bmj?D-J>EB%^u8PDb}e>qO>Y%XTx1<13iL
z^7^HwkL{w0S?t~th9y&@v6Ec-EOG5!)rcjtk<djaiX at I}pEsgON(VvvIH4}X{blqT
zBN+lMbrQQTL&O0wvArYO6F(Kykt`c&*6Km>I&33btwHPv&YP8ulDcv-(uUF^B9>7g
zJ#Zn}v1try8MCaduQ&z7G7*7JXwea?;RSyX9s~HvIuwy+_nRGoE9&?v2H8lpBd{aV
z8$1CuAzVW5Nk*(As3X0R?+9XM$xkFp=mfQKBh~8cjv$|7b;K at Tdou1cOf;uGu|jV3
zqTr0KVIy6p5@{x~cO-OC!=!i89f4o0 at _^)?ct%PfkVgF>BDE07s0HGPUG<o>HU0@%
zV~=Q-+iiXCpp;5PyTW0jB1G&Gn;el89cetxb|F$z;JOjJj_wJ9Wy*v|v8(Mn5tI#x
zMJ6<hgsuUY<l^6HCe^=7u=q~mkO4$W3q(+2tx^%`?S4lx3Y|J4IXluXpF1Ms(nq9=
z&>carT5+T#`7S|fto^tPYP>07B5IeR9YOaI2eM@!k!CGpM<DZ69O+8yoha^ZIXYsM
zXa~?lf+r%yk=DqRMpVk=NVQzskz at kkyC9aZfs!i`M6aqN8Z!~}N==T)8XRe<5i!kN
z9jSqBp%F at UL|Y_+=IC|-WuR=U4Pi~BU!REB)n`YLy<MFXDfAJlsHr(7n#dHo!&<}<
zlP*k}#P1T+{nUFO`dRnj9+;%s6NrnReS1>+QGO?;_>v<gt at Z>hK01)4I#R9v?}#aM
zairhucEoOw!4b{8t#K)3B2gV_)&SlK^i<|GgVap6pvz)uj+8(St56T3j!0u$kPj(3
zl8XavWmC`-?j6LYlEa`jW6X}IvMId{ZY-%f(h6IGoCxAb6$%Z+aBR^Lj$TDs)#`|@
z<gJF5m&K7>lOrwCCLqm|G)GD!TMcR=sUup*UC{g?Bu7NTpODn at Mp|t|ATVNaq^c5u
zoLI9XB}XC%Rt=75U|Y}=QXI)m9BGMdLH(8Jh%*H}k((o0_ogClU?GYlqKOC;#Tp&S
z*@0Rr5y*$2juc^2h*nFEXbMCi{)z*#R!3T9QwUAXj?~DepdK_hqOB2uR!G$mDQpW`
zA!J9gL`Q04TM!GeIZ~8%8Xy){bwt_mxN@#FIwBr4Ayc at OrdAxOiDDBV?MiZ_1fCh<
zKpc=t{=(&Ujm43y;z(QB6tqDOj_~;kkOsjM6?PXw)5H-;$&psr6r{o09I2UXMTDlR
zBPCL3BD8@<M|34y5!xU%M{+5SG|r?5B_P?6(%2THKypBpO+g88Zh=S^M;d2RgcOL;
z5$6lUrd3BuVpEW9MI6z<ONJ8Qvka1(11*xN1l2}`+DKi=RDux5$q}XM854v66>1|Q
z)sfcN7K8v5Y9o~sDM1N@;7H+pCB%j+HHb#G1(l}R5#dS=(m0b6o=S712DSw)z at -{Q
z8{2{yNYN4MV=+SuaH$5#*}qdOnaa=td~`tyXHte1aAV~{ouSdVP=g4UE088^38CRa
z4O00PXf&;k6t2 at 5ZJ+Bjh`4#s_G54)bD;*QoJbjMKdB?7ur2g`F4Q1Ok|zp6Lz2gc
zaHR%mT&V?ppCpfwN|GlELQ@?moJfMc&nE>$xKa!HK38gxT%sc!EJ5GrLJd+lj|6?6
z6%UBA;t}+HF4Q1gaRC~4BthHfIt@}ejRc`##RF1U at hBu27itjYJW{lMmOLPt3pGgN
zLapfgEO|f*OCCkv=SmHtoJoql&yoj3xKe|-iP86?CzTbCqVIF11}U6LcnYj|@Wj<Y
z(f7GfgJf1bAdMA|LXvTz2B}=A3;Mn|psaWb+CJB55aB#3X#1>qKr+{9kjizspzX8d
z0Vynb3PQtm8bmpf3N#r at 9uQ&41Jbxq7sQ6!JV<59Q_%Q16d;8&si5(*<N*<uJOz!P
zOEpO51O%xpc`7=8a-eXju4w!$c|epUPepLJRD%d-5(xMGir8?a2B}=BD<m099*{zk
z=ck*$+}%LsqlvHhH=bgZUVLyrfzi89H}kaI{rlzsMb}mo-ve4GvUIxp+x83Al5vs`
zC=wA#2yTrS8GCo%pAe9{FE>BWKRzv3<ow}wT6E603t~P`KQ2hQ`E9|hZ9e^HLDijq
zKP`yb{L%;a3zX6PM}MCFg&E3x>gfFWwZoSMmUTXlkEQ`1F*^o--zGd>y6Lfi?X&5Z
zxxbXh_hUV=|Mtt$f4Q|)VV33ByMNpqcH2xcw%K=Rn;VXRZfH<QJ4YP4C(`gl#v$4~
z at wyz)`scUl@^O1S+bZ&W0vX_VnT~I#>C+Ny4c8A&)BX0i{qVS8VfyX&F}fUo8{_8%
z<pGoSy?uGQ&OMzk$IH|C@^pWE-gdWJ`?kBW_A=HUvTkcXzStaPK0g0(emZZ<E#L5T
ze)=$;uJ2)E^Yiri?RAXrZG1YPpSIsWV2Nq|;oC%~>2>?%bog at oV|v&IeHx4(pPnx#
z>@%$Mbbovq%U}QR^tEl>ijehn|8|=G`?T2ZPhae)==@+VM|h9t={PM1a}k`1Fwd_K
z<ITtIgNNz#6;EyMN3P8;V}h4U|9QN0#GzC;eE9b|(d&5S<9O$#fBj*z3+H!w|NHZ9
zhKt4ZI_c}nE%GDJ`(0iSA9fkXCR4Zu=kDVPvF&I0h$SKj599CK!y>cg-RbLRJiX%o
zOAo}$c>8Jl1`WFJ0VdB&xq2jT8_8oMNS+Ti*P~7IhO<?!ufdJF&2>gx+W^-&9>y<^
z;}5+0*uU+wd?${F-4;W*#_{p#D`JK7V5j229w$Tvf9ycXY+2LKxxj2QGs^+xZpK;v
zVLJ9##z)8L^5yl=tzva8qe`t;zpm+ORff^?5qm(2%%7J-chPD3ALG at s<2Z5zf2B?a
z1+=t$i6Y_C0QSOrFfi~mya&&PO%)}2xTH){E%$HC7d!GrQQgvvFA}RN>zSDmk>#r&
z$`!>g_jre7p!R<6>DNuYWtOh~&UX+VijNA94R3)M8~Rs*0W7nL12 at P&(5 at S`t2&na
zL0JGiE2{}U26_&h(m2NCj?Ll7F4F1$Im>@nHGbU4$v(mrpDUMhp-POeLG^uPoc`{R
zdpKuI$6#M~gt3IGz}TkeFGf}<G(uJ~BxFs1tlapzaurU35Jcn^bcwzNity)AOn`A`
z>FA}S=GAJtEjg~^UH1I at 6ZFzIj&@*SzRQWwWE&jiuf)mlw4Pq7moCOrtUKYph1s!z
z01pMxUV0U>XqaE6pm;|VSTC_h4#*aylk^*W?T5k7EA)gu=)W%YAP*=?IM?kaaCKdG
ze#8~>U}R4HeYMURI${d=6 at 4G^T~M%_Iq%lj8UYyG#v1stO*(I*`PO&-2|-xlJ(A!|
zuagGD*sO?0xzW*`eaqpCcqk{oe=@h|`tSV`Dmuq}L)xYF<tr^$a2h9qk_iI{;c~B?
z?VIGSwAQ#>F1d+nl6=cH$W4SM9IGoLPjxYm$Shqe at h4rEwN5L^T?mFzcKr3Xe<;;_
zU2WjnEO_LZ$Pxy1uUzIgc6c6CgD=5z2We at z<bhXbXbU^G{lyRC!k{|K*VNbblY5bd
z^{qlWO|#s at FDKvUiYT7d%D;lWZ&xG~N(N~XSFxy_BzS}ka at S~<1BrnHZA%)XYJ2&t
z at PJwHO&V_W!>fGiFa_XQK3Vi2;qCN at pV7Snz(v1A<jYEJ=_!6$5tN^#LuZt{8*+HE
z^~=^ya``{S%{ErgT}6oaUKfR|>0fnZsI-d`UUi8xG1E*9;t2czYSRSUCV8<)Fq6gD
zGgI8Bjbwo|ILM!<o>VYoN4kem9kOkh)@K<ztys1?@jz;hU)!GV6_H^f2P`89d4 at oz
zcP}Jp;^0668S;if;v$WSe~$*fBriBk`BxBVM|AJ{`N{>#oCTR0g@=hUonuS^juOiO
zKDvs*b|ADzBry+WBuywT7T4l+KVV6wJetL~zz9$(D<(ljh+GgNqo_J}Q_}+0U||v<
zj!@e!kTAA&BXbl~&)D<n5VNb0A)Vw+`QJuZL&xACVlQo7p?7mt1iaaY>@v|BCwiAp
zmKntjY7~qb$dyK$0s at A+c&aGBxr~({QEX9XrNA8Nl4l9$87)mHIoBP4C*dq8b at Ecq
zSuC1Af!LW{#QVNS9!|6QQF-^3W^lwu=vP`Wa1)`J0^8RFbEp7#jJDg$NV}4>kMXU8
zW5a!iu9QKte({wo`v+gdv;C;bJW at f6GsvO?>FoF+#)pO!S)xb*&qqlPM+TptKkvVf
z0)Gh?I1GM?o|>{uNA#&Bs<p3^KMzYQccdK#<N>Om!r%=kdXfQZ4&YcY;eDJpZVk7o
zir0F;O+oss+mb+buj|p1$U^)5xJdSlD-ue?5oactX*lF+F_v5fKwbnw7!D|*M)~Z-
zK!gb?NK#Ndm5>9K>Nq_lRD;Mg)L`Xh6(QYRbfR9FuG%RLt}-qSI>S$rp8T*JKvY0#
zfjZliim_y2>+&=z3z?Z|M2&TM!jr%-yKL{c;zoalsYwHZBGQSfLxDu(Oui6nn9{W3
zw3ME+Hf1#o$Jr&eL1#*q#byhEQ`H-2^7BnUN%N&S%wqZ4MDSDgbp at 5<o(*hcl#FS-
zby>d2bHdfXSfRqViPLn}h8&}7PP7Z<FP;NQ2?Aq<k#Y#_0`3|c?%^!uVo};7khCDd
zO${mm0$Fr0IG{!?4P^A(?+m!JINvR>E>7*3yWD^q6(1Hy9CNA2AQA?oRHfz2f}efM
zu~exg{1v>&r&;;^707w>M?ju#W6i-{aJpVm!Nwk}2koPPn3;rf&74~ViteSzq}I5;
zAeq!4L$_u at H<PcvE!Elc^sBsls0}l#`HIvq!*l&WbtC<E)f*=-fCHXF at E^t5g58;5
zH=1kC96{}jWDNazE=T~)jM_<{gIy2U20lKy3)f+~Bz0D7cXTJVJj=kyy4^M&9U(bA
zEH#IRh0{!ZiQ%ELmQq^-mqer=8|I15SWy1ml_!yhC;2Xgo5pedVjUC~oiZf9(L4>0
zzkWaOT22BVe_aT`1Okxq<$<pxzAX(&LRfHZ<>*^xI(joB6Y1eMY83^gvssbaM`1UC
zN>IL0uZY@&13jW=L5hr;6D08)-GUQI18uQ0SjyWcF|d5TX at 1YEJmT17E>QGwz#Y&3
zz6YzC;c;PA2(fXzC53ub!y^QMBJ`el%-zrkDO|OELrCusSgbmoS@@YYmRv%QNG!+)
z^m|+ELF{ES4wyLg91EGmLSa<ijPpiX9A&&89&+k6m@?&pP8&DJ%cN8&0%bTgD%<bl
z%xf9PX%xIRI!dv2d-$b}Q2iT+#$9{JPcKSc{<_Ik$8xFNrBSiRDX1Y?D+(acS~ANk
zsEjy{ZnSn}du>f1ieeC%!eqU3kSEO(KDax!ZQC|KW81cE+qP}nw(XrA+t$v^&HMe`
zU0lTd(@~w>mHAY5byh`Jbw21+kY9&X5y1+h|B^K7=dhB|{q#Q7_kJD;1iwv2o}*~7
zIHsi)45&PrN%DaO<`45Z<j{9flHVwC;t5e!`THW|fjS<KFh(#E{c at h9zce1sWQ3qz
z>jgI|IX>JYfG;FWo@(N^Ng&>@H|I4Er|m*@IDA+W)&- at jVTEz~yXn7q#n>(DZ^1#+
z?ZB4MZ6h*AT<Dq;Kw>BTS#+PbGM)%cWx9M at Uj+DeI9Av%T4roc@@f=1wZW5Jf8FUf
zO}ap%Osj(mkD!*aOi=?g at sx|lTRD~<^1k3Oe&R2#Z{QpghW0~5weyNCY4E5|bgphv
zj}kP{nD)!5di{*YAHL-S{EikPvP*}Ph_4W6YSWEg><sM?GHxuh&wmr6Ay#7%6)f!7
zQX$$c*O7A1M)xI&63}FqwNVn=!#n)QCuF~OeivBW74TP0uEH%WT2(L+j{It`EV+0;
zqdIE6Q=FXPqJmB7lKHNGRY-9*2Gh%{ZdsNtrqfIjMrUqd403QSDOlQ!y$f(@1_M!`
z6xYG(psRIE{hokqErcRzZ1~B{$MNnOFdOilkh)VWC>TP+BFqo-$w2Lw+IJRqrczae
zN{4VN6niein|wB+Lr}667vY8+5)pV1RX52DdYUj#h&nI-wdZZG1Y9145k at NWzUkc#
zJw)1yeH&Wgz}kQSr>W39<z|KuhfC=gYs%~ujP7%TSVVCLYYhCi+XcU6Nao*pwoUuC
zPK$6lQmEhFOLRx))-aH@|N1 at 2_WK%Jio~Tl0|OaNY3A_Rw4!Nmhpezv4S5-UuzvYT
z{*zRgnEOIX&(f2#)qt{LbQo%>skpLvpfuJc`KQ`1It>4!-MP#Hg6e^_PyfesZsj)=
zD%$7G`F&yMk?qc59g;6-sw#WyoCuDLKT|VQ{K6^q<8IK760pRlIzgfzl0aLD&@7gg
z^j*K?R9!<E6!ancpZ<7Y{4<n37)ImOHrZ3(Ah{ouWm~f|d%k{nFazzmIUqh|&&d?q
z!hA<w{Jp|Hsia^;-AgVMmR at 0O>2<*8$<O9Sk0<E9FPpJ!RkU}fINcp2EW#3daxU&5
zB}%@bBu(9tg2sffkOG2z+|4~ZKzlEAw6o)>doA?O-{|5_qYwe}A&@2%g#xY at d8r^7
zc^Z6?JDDdkXmYTHp`w;Wd}=4V&1h)oW5(FGOh(s*cBuqmMCrOj3(oOj+)bygh)C**
zYZ&>ejhO5R)RhNyL-&AadP3qBT(}8Ym=A-nd0g#U$p|eR#M;W!AtU4fq{x<$AkBTC
z>9SdDq0ni(dT&;CRSfP|v6VU+v+7rSwGaZVj|T1yifT1h5O{uu<?9zR<kK3x{GNL+
zeI|k%=&4BB`_UVxll$cR-+^SgCZcJRH#zmcamaz>b9)o?)qlRkJX)^UVsRE;yhZpy
zQ5fzc)e_>8V#uwGT^R+U`}=44<c+8H!^v8@#h<-JdpT5GDlH^i8PxmhJF~V|(mJ!9
z>VIQG9fuxkpjG8?_|%+QWXgB!;h at fDD|jH(2>&B4q#8iPAQ+{v%M>hKzW){>lb<xu
zA>I~)NqshFtV#(07E=+B-7MU}RNpK>(|FhchkWXKQL-vT at jY&T?<v_I3g2#KHG(Xe
zIEaEt*ZLg@&eKJ2ME!<el5HC{i<VLjQs}C_!7x-j3U at jj7GrOrKt)re=}on%AdNd;
zV}i*%7S0OphUI-`(17j2d(48t+E?Z`?-S8Xr;0w}8><n(MRSY0vrC0L6|~LwYF=B2
z0=vnN_6-SIkY3hB_FBx}2lYeTDDaRom%)Tow!DOSrfZ`CW9Q60O)GVkdhE0keae$$
zpClRslm>rjgn624i?LE?lp%Car5;wd20UnsONESHizT8&5gS0%$Nu~lJ)#;|7Fn>u
z5D=@i91~-BSJl#Orl at ct)@D(V)mc%je`S0Go=LjgZXFj73Qz}-{%O2kKf}N!1^6SF
zMiOj9jAO9#JXM+H5$Z8~`bRL`ka)B&mE`P#73mf`NqN6@%GZ$a4)?=lmIO@(5K?5%
z($%$(iu|RTYCe2CzaAR!NW&*9S&CSz2 at MTZiuEs0KYTwtK1I59$kox`#Crq|n6Z0i
zYn5Xr5^)_-`B!k|d;sOea(dQnz_l7^S36Lkb$8KyvP?2f2FcpAl5%1;KeZ0JG*8Nv
z>2;vzRc!Fg5M>f*$n1xAuoyoKrrEQExstCK^dR`}ptSezwhjmWY at K%~Bi6V9P8ZO}
zi(Z5$WIYNkuhYt*@nU$g((fjy!VF&xktE0zpX2N2=hat-%*Dn|GD-DiBa3ayRLgy;
zv66+1^q73K)mxBL$oD^5a>Gqy4?)0_=%x*=&fP8<{^jSEJbeuCzF+H%XFz!`PL|#c
zu{o?ZH_FEslH2xPz8EQph(bA0n0B5jt?dA5WEntene)#=nda*qVoYT#7Yj`=p096v
zQpRO)3I2gr=6R!^=E=w~`BGJz3MceRj2s~AQG-lm==UjX&XOC8?UxQLyLU;~fHJRS
zoUCou(V_ju71H*~-j`(!oZGZox)~>$nKlkd>J{=#e5|7DMK-qdpOm7j^n;J=C0k1s
zprB0 at N$-KQ5Xh`K{D`<Ovg*KjxIAUC at QP4#09Z`F8Ic=uh5h>hmaTaupx5)Mwt!>Y
zeS_lUq;qz;1 at kom`(fpyTipxZO^C02@>{x2fEzh~>A_X_NVTC6k^I)dCvGW at Z1l1w
z8H<t~1{`-tpTv{wt6 at DG>8_UWV;tz|9|<*VQ#oZb=c}(R`3UB=w8xQSBbHgD3ej=7
zhVIH6*i0t!n*8=V?@&KJ`|)HHl~><g5k=N`4StPx<?IVLm%PZ|;uoB}H;?C3-6kt*
znaYCtSLb5=^4#jPux#eU*%3I7`2nun8Kgj8$=YtKo1h8wYI>njU8pP+OELsjr;wq}
zHD$UsHG|W`bW8qWs;1lc03pK;TE@<iI9mEaG at u4RYkE)R#7p%H+G0Hqw0ru>OuPth
z?;)4_X$RaSvtu=Tk-A6kF^pQvARuR<ZA(z#22eLq(wP4W1F<=Nm&3d4A(*z=EnedA
z+K-*YeS&bn-Sv}qZfo|7bF<XFfL;7lh*T`?#s_;Nil=@+z-ESye0O)d1+C%<njSPZ
ziAzXr*>R<Ho!-#?A4Dd>J=`lm+hc}b=$g0!s#=VC`M2vYp61n7ghe?$bA{8-D6WW?
z1jL|5#JnHw7scVL`bb>LfRm*QgWx>*I8tCQUUfOqj1AjI<N6?{mZ%Gc13b1L9$455
zZwlAs`An26v<#t3)m)Ezc_eTv_wdSR^_N!kNCAp&4N0gF6dh@{sM;%=1-7G$kEu;|
zkuimHm;4CF-9K{j9O=nwJ|UBd@>q&YcB0N;HT=_2p^=<&1nVh*SjLJbTsYZ^+%5&I
z^!NjtyuWf<sLe3rtQK5tl=?7g;8I>Ubz+_k$!1vxbQE7afG+};V5vbj_}>l#*!RiP
zI{)M|EAQyEz;=(`CHQCj`h4m%?y8BL>?DP*^)j6oQM at CUL2>^!0;<{J>J+*>3zJ-B
zy+)WynU8pS9Ki+R$3Glgo7~<+J(PEPYCa%%;)T;#1c33 at I!7Qps`kr3sg4U?Fq{3I
zAOOw(=ju%|>cdDVzGiz?LqwU9ecBn~4j{|Xpe+fa4XO4<k$9#U;#_6J*L_J9L8Gcn
z^3mTTnM#)g=$h3fwz0o@#1JRqi-n~allqoa1<^5hT&?Dsa!8rz)3%%$wgQzO3_AzR
z9wUR2F)DLnmvUykmyc^%6cK&E#nilwj*klm)gMb+_g#DmM8s6X_MjUuJI|r{2)TOh
zYMY0{+!pk5hKP<z(44Xg_mDXwzCZ&8bWc^wg5+*9Iv5I9JK|eBQ~$b(H3w at IcnoRe
z>K<A3POaIG(g{i4h_8zb++ukJTGFgXstQ4VbGusXrljO!Pf%oN8HgCo=chly9NW43
zj*e;9Q}Gm9jW|cZ36sjP*0&_VDWKyJ^UumQ_wDDaRK8_^64nAhdr{|a4$Bjde}D1>
za@`^~8dd}&fe6V%DnMYuF&PY7hx&tF6dnygnOvu4M_L*9^T^et*1xYHJHDC>biPda
zg>Nq6#i?(oBVm}ITX(v?_Wt}RP6J_t at 3t>Y4RZtyhn4Cz$gjTcpc{lQ57evNN~h8O
z+UL#gQ(FZ$iBBP~U=w^9Vw=;=`QjupYPG_U0VU8-c28XwzE9M?xKK1Q-Lz~isK1(d
zQI^(o3Uw1)#q;|{)U4zCxh?Pd23feS!6$ClDn^#6O!&*eh);#}DsXzibGI?u8nj+y
zBb#&~i$wuN=dEIJlRVb8anPIbP!TiBm;6fgD-W%Z47SLHtT9s11(Tp4M3x>%4#T3W
zM3TNG%MhN~#G5#@dgzG;?jNU#Hn&h(`%jkMEeuL at D_>O}OWEP#x{)Zj^AUnN5+~{)
zRSZC=@(65NTN(6VB8RCT2=v4NS7&5)N}(%ht|KbtgLA;<xp4`Fi=Fd6n)8_T3T_<6
zYU1d!4-t1H6(p1qn6gCrrJLBNV^F)|H35u7AC7dHnPu>(E-16lIE8qN?j!fGs8^wT
zYVz7|Xgn!KUc-Dm&syZ3m3*o at rHMkyd5~wZtNl$9C~X3~<<)$0bX~93v$QUJs11e{
z4*J=Vi+)G>u=7pVLD*~ZWYEhQ1k!s`3~g3$7BRDFbgo7r5NV1!2&rnDbXB*ja)FCo
z_dt8TC72WX at F7-qP+6iHrkK(0y+a}o^IZhnCSfYvvPd`c1#50f>5SzP*ipw=<$Y4L
zVdm6AwKj6%MJaFwF<7+Io?Gl#Tc<Y0^lGXl_17H}5x+X2nt$rlP}J?6n^j8 at kyZ>A
z?&=BZ;n9?`r3e)d*9$F2g;urgijdmnje!n~>{=4CuD at RcqDHbH`;mfM5GY?tx<)CP
zdNj|A$$BUZB=!>uQ}hyB6!9Vo at 8qU#phB at D7o{@L*@<rC<(MZ;!4(k&CedH&S!HQ+
z6(_$D^DHyQ0IBghn+!W_JsEb!=Nn@^nIq}B4LDcMNN at kHF>Bj7A+(o6FC-pEgqVWi
z+<Zh-ItSJTZlu!Zn@?4HR at C8k;Wf(OlHQ<_>=>aT5V?cHQ?|B&T|1H+FAK=2BR*V>
zf;!n8!|SOg`+*GAZd;9Xrf#7T`%SfYW3~H1?iHdKuTXVTn}~BnddM7_C!2K(aGvpD
zhHK?a<`vv0cF}6U_!TXP>^vq}c}oj2MfIaLxK%QI%UiYDs=vP at 2|pPa=wY)d7^K-k
z#EPsS(0{$A{Mm(qg)*@<c5-$!F|dLCDcKoX!ZI=uFcAC{czEcA?QES*Y at MA57+HQ~
ziuB4J_9pc524?>q9DgnlFtPqmu4w0M;A}#`KrdrrY+)c|=dQ)@BWL^3#Lmg2Loe)T
zXaD~bDw;Uixi}h`{3vJsPYEC2{|n&1^Zy5cwVk7qy at 8R*e`uW82$=t8kdKdE^at9H
zOj((Ufcby*e~N4bER6rdqpZxxK)}fP|CE^snEogKsV47eXQX7}tVJ&m5T#c(ad+0C
z7jbtMQ~D48k2*0WMgnH`{{!d$1L(ij{~tioCbnkI<^+rkEX<s2^r9Bl&L)oZqSimP
z0VYOv#y=}K|F<)tez=R%r0j at 05XWxbQFvPY72tQ`tjGlYLD>Wtz#P}NgGN(rt|k|w
zHFeE;eZIWex2zB21 at -%h{HhI6qeh564tDsN?^$fV9NXU9-Nqn^-QuuC#U>#~^sFJN
zL at grfi{ep`=(FPT$Yid|2!tn`{r(EXLpi$j6&zmMFjF-4eE2jScrMFY8ZuZ%le+nB
zUv`uHaEukJa?^iL-Co$gK6h?UD8P^LAKZL7bBwLV{Gn?QY27`1cHNNqNUOoVx at CpS
zhBMB4gj>6^bK|$c$Ucr7;8!o%$VFQC>suwp%wywb$nmcecLMj_+8xfv?(qJV1K0NO
z&eLOqiA_ at d?-^ms%T^B72*Wm<8j|%@V*{>mf3{bfd~HQ+XdLoJUg?G-UL5(flY9B0
zl(p{;SeH7TcheB|>Acp9^W*jHo(|9M-DxON%BPa0LCajl*$glKQoj=mhALo4F&Ih;
zlDffxG*tpk?cSZ&`l>wCuI}!|``d?lFCg#18*+yD>%m~K8?5zNuTOO1(`6HjfGH<X
z0L9C*H)LmgQCk7Q0bM^$D%qV+n_u5!z#PFVe9*!fdaXlGOGmtkoQxD0m8X`3Bo}iQ
zzQSR1CpK+(e-6czY-z84I|Jct*C#p~GxuQb>hXsSOM?0Hk5D1$Z}X--$>*fFg{?hj
zEbaw3S;e&MWgZh6q<D!cus%1S4^Q!m{jIcDr>+vPeGx<)M;~4>glA5+1hi#4D5R+q
zk6?+*dX?~lYn$&J9%H0pIRZw731 at CTKGQb~qBJpnc=(I?UfI_~1gt;z3cHt43Ql^g
z<~8t}X<;Tgd#W*#NLPQx1BJqam33`i<EbKXa8tZ{D|Exh%o#23-}v~0o#P2{5vsk4
zrPfhG{VdzxT_X1OPKimw9{8Z}hrXvWhC}DHLF^)X%4+7=r4hQ~93s~{cJdBj%5J~8
z0SQoiHYSo<XG>^ztV8XvSr5$lQFt;6{@F=~d>kJm at GEb81WC#_?yaOLSr`FYoCjr}
zPZim2pjmYlwS2{qUQnQ9Bw&fB>5)oEng1MwTES;n%#dbENS_Ob)230*E$DU+zgX4o
z36dkXNl~)fXq>xV<2z0x>2=DGIghD-HEeanZ_=Tp%HP|*fxB3gw~c%R<(=~%km0@!
z_1);zE!{ch1`6*1^`FasmH`jwbF|cbaivQn_;hHN8_?;}625C21Iv;EA3Fad{)-Hr
z42pj~52u!4mr$e!^#Ho%w)6 at qCCG;p4>dM{o at Gyd$W5lMbIo&7l3P;qBKY7y$Oo=m
z9wJ5)4j<v?BjW(ACRLu^+tr8oNA^St&s*A%{I#!d8%~0Ip=S;{B*sI0H1;He7x3_v
zY}y%@=tsf{BNKL!*Wf0BdTZx~E&4CdPZ}a at E1AMlEUc0sK_Xa!S5cxiY{tmj$NN27
z7e9~x6L{+bS+fsWkA4Ds67ntM-#s=deEOp}Tc#0MNpqbrJ$7suOiPEKWDy*w?yRU0
ze~jgTnC*r6c^+FHd*AIs;qvE;-$0J}RQb<O!6Uw{M|E7hO{gCp$_=A)%ka6%&{c{X
zg#x-MC3D;&j%<&Og`t|qHY`aDJn{0~Q~GCR1|eBaeAyok=|)onQ}$<LdvjTK6H?m1
z;|R%mF at BnyX5N<nqOu7CG!Ltn?}+ZhLYPR6Pq#m$ApD97r_bWKU at C@$&LKGN(UL&J
z+{2>WnmN|!Z^GRU^Io;Mj9$OTFpX{JGQPK!neYCf*b3&b`5NF1H=r7dhRFMeE9A30
zL9k_x9*z<ZZ14%DJo at nDM_)WScx>onh6uR|F7`hN_1#E<$Ywy`nCT>{$kW=i=}GT*
zSZa~eWXI1;LLm|lfy)y_zT2Q#qeRa^iqR at N%8Z_)Dw?|9%D+e~I8yMJN=?ST(Q|YP
z4I01-n0FyC{+T6b6PLQ^EVkTh)Q8r`7N+PeOc^hhjgoe;?!A`0=kw<n`6xD at NZ?u^
z7m*63Jx|OAB}lE{qtt9i5NYxvm}K=*5uboYD9e2K*_g9vp3X<vYLA<Vs at M#Zi+6=a
zKRy+Gc*S(P+|tj~mQI>zIT6d~&%A5ib!Lm=Ezx}BL>o26i>jm8ED)XQlgQKBK5UJT
zf@@r34QE8knNJW~8(;nOCboQk)J%{4Lr1o4EJ5lagL6Z;1lrN6<vlCEMXn)1;OZmq
zT<k|acatLdk3BmIu*qlOdKf8Yr~<Ey%TsMw;w~3?l^gBUEmcXGjo%{F?3X8Im~L)7
zJr2lI*5aU(b)C?jqFNyz;ev~v*Ad!FhhaW|pzIrRHwy^lz=^Z>+(8Z%buSIXKz9uc
zL*^h~7eBxsg_|2E!}ulJ$VVxe9 at okgau^b5KGRhUGQB4?5lL5}DX!f?k~%r+NhktV
zdv5APH311)=>DKxO_Bro%jzTlbk{1LEsh?cM#hLc=^S7C#7D6uzI>G~JfT(NEwFo9
zTmrZ_`ywzA?Qeu>5Hp1<4wkndz-t+*;%mQ1FoJL5&IrZG8n&d~EhN4}vL?T9OmxOM
z?-1xinCh*|<8B7<cF)Tzykda^-4^O7%NQxRrz#&ySLA5jTI}Dwgx7wHbY0N>8BJ8N
zMbs}JRenrePIdlReO+L=5S?9HP#Iosv7$*+UW at P~cg~jy3ih^@JAqm0Fs2o=g_?{E
zF%~YdMlKTbW~>24s+br+sG}ynAf!4X_Uxq?a~B`tqx{Gr*>{>$8Tt~dDNK6jk75;h
z0W(ultwE51H`{b(;!Ex(uQI%pRa0;d(zu$A%A&?%2&+OK?^L_}B6RLbJ1- at m*pnn#
zE*)Z=rX!y+UGA0N&5wD{%U8v1UTSI(SeI}3mr$3wxN?ugd_jyE9fycQP2N}LrTAa&
zh8qRnbd?A}ncBQGBJE$m#n|%eQ8)c>i>kC$;>@>kF{&9TDo${cGc2l!NI}zWsLDu=
zct_Y7RNRXs$6yXPn+L@^0QV|UwrI<|QjxJYsEU^kr4ayshUWYT*(Y=|<acuJAufxW
zb5x+Jf(vTca`OtbcoggZ1fw>d^K&Q;H0ULj`JR-H**Hh4@*45^#AejxwTR_Dh|Gwy
z!%&r;;x0XbreGW9?jKl);~rbKZ1UcJU*ug1sZE}sGBr?MyA!C(ivfC)E%-I4Gc^0n
z<E+X(X;X5+n3a)8cbbCC<o5H`7Cm$3rQu4XYw{Bu1X5Q}lk5Y5`G=6WldsyP at rr*t
zg(hp`E%C=}5xb=;qemt;e$2YQvF<0BL=6w}nyt#`{Ehj_JuT`ebg?SuAhdWFt?<&6
zCoYk}4v%a^=08@{nvKFuO&4j7YmB_V4uDwuYk`VN7<<FEMecH)8;?X?tU2W1RvUM2
zL*vl8f<*<N*sJ{7?ja{{Uy>L>lN+p9N?!(+aU^Z|<G>jd2V<KDWAKK?nVHDQc-cHf
zT*Z^ohDJ+JRNkPGQ@#qg^o4oQ#<!)))6cNy#)(#K_5%Ap(F8<y4Wz_*ai+k>zY at d`
zcE(#{K!igwtCgNPl}`LkPtXv-r_Ryapyr%t!!!*dz+D@%xC`b at F^MbYC~2qbPyg8T
z?Fy;la~1s$VW at yg#l!=#%HwbdP><ELO2tDU5^DAoNismqlYd!AR)&XhU!5}-nYUQ7
z3QXNP%b)RShKeOeLrBypQNK%nA^NBm8xcysL&Vqi;?}$YOdx*C{#Mk<lS#GBH2c{f
zPi)>&+3{+QiDxi?xadNt7!FiC=+Nx+5YD(oqf<$6HxMcoETi*ard#auXD)_oV_!V}
zx|r1al20=jQm2Zx8TIU#N!A3!+!QnZ3NjmjEKV&($(L|4*7EkO4yS2awBgDrz9s{n
zhC{FcWmuXhr>ttGc1XZG6S}?p>x{Ks)rR_8bIkSf0tj#x^88mKVK&_SgKy2Q*&U{^
zrnh=@m78)A6H${_hzdt;>4~T_*q6&s5~8mcFL^2UebtOIal|DUtVf>L=Kl9)R%LG7
z^kI=mxOoA at Sv2Tb0hstTdU-QM&0txOV>}e3*X8fbUiiTnw<7SfQ*5EabJUtcQ&MsG
z!4}WV0#w*W%JQ}%yPh~AR3h`<3?Z{@^A6@=g&963Az8#lOhy3Z at 5K_L=2kdJ^W_;S
zGR;-ico3WSU!I$2;1jprhFg9^$SrXn8VNKI;g<f+P6FANRU;5Hv>v~CVdHJ-X28Y;
zsirx)e$g@$vDn}l2N(2UAaK=`{eD6tL at i|6x=+YA5dsjV{E~Qns2Rn~HxV8Flj?zb
zc24ct4N-wGRe(i+%9gDbOhV!B$t;tK<gwCG#C^%_`A)uI at Ui3kNJeFJIoir05Cq%|
zff%$x&a~~`A{coH12$U?5T9LYE3DA~+P9R-N{G$2rcx{(IylJxRe=zoXyxxL3Xrt>
ztw>l{1`tPAFr6drr7=fDVnZqLz$R#UfIn<P>QKp75cM}M_EgV9%@@065)7_~Rt~z&
zpMfXSge%7NwpGQIGl7iHMZ`a9KB^+pKm|I?LUH~+;BeYj*jst~p6+Ud{pgrjdK(7{
znO-?W?y}t$Ls~|!<P>T`hpbND5Sxm&XcdcOg0odGAjm-^M2&|!K-+xmTDXgs4U3}`
znBu~v9#*3L>2c1 at cBUS-W`s*)bS#|`G;h^jWlcYRp{W8j=Xwt*2Nw at K7Si_gKfcJ6
z>t-evqPmoeI?Ojggs5Ti{&9<z4f#%}=|W7<1P>Tz4)`^<01-$ftpFGC{P;*=Gdm0P
zBIeS<9K=KpX?wSg3LT(hb8oNv4^Xj?JC#P7Jc|#);hEX60%!#{a7-8E!Y{>QReR4b
zOdqu7>2QJky&@ADz$+%94!SEELJA>MC9GBcyN&W+bHwK|1qb<1dR0&Ptw6m59G-t&
zNpi}g=IfPlsie_mIS7wpy6J1}dDuQ)NX#Eg9phMgsU6Pv6$s^UaPfce=G&V>$lOIN
zQ*zlxgt@%Au7Q1#dw9mk at FzgIP=%UB#M5#RL$RsktePO8b44#)0#gqFk1hK}BI05b
zC_mmT7|l}2!HtB|GvjU~nq9?YBD#<jp1Oq~KL4#5a$t=A(;uU)>k7;fnN;x!b%L!#
zCP=5e!~3q2Fvsmn%kVvrB}N3Ewqj{Sjidwvokc(cmZRd7A(kbBkAv4BQrH%|dW;39
zyl=l3fk;lE0S6`{D|os2Bb7W?5n;~mAR>GC3n!vR-PNP1u26x6aQL)Rq>p7;D!goE
zsD%$J)DvLlD-KP$rQ)?^xZ^~lF(?yV at XDM*iVW_mxUjO2 at w2CzPtw1CB7nWNPw@&0
zLPEnkpXrrkXG$H~jb|a&m&HlM{TcuF`_r7?zYjk?H^^_&?}Dz--pR8`R7~;#JJ)-i
zVK2=2 at 0qFcwWW96(Hm*QP;K&ols%2l3nF4r<9w42x^~p$lWp?C!h`O=7Q&}c1tKB&
zos~^obZ=10#f9cB0WeYSmUQVSU<|cwZiEmxvZBil(Ie!A=M<yBjpbZPa>mfnv>*WG
zXc~iT`3b`zS^}o~e%UQitc<F2a at WnZj^tgmh~8qBzv6S&%Jw37*cB7uivut1_HMmM
zI&&1TOQPrXL>#+Mnw|jVBUi_?Y`v3n`M7<cg?SxF&A|%I1$5`bO5dbN+E)O;equqJ
z0C{iPQlPYaZ{XCFh>+!`5w`{$gumVq!TtG3dGxReAp^SCmp2k_fpjQt1JnuH+ba|t
zz$9M`2DrxOn;s=*_$zTtCwK}IUXH|<AO`@&FFj8(L;iK}II#SWUuFY7!wdiR0h-^D
z`Ku7X7R0c3jjWJT#O`FqAnSpFIvDuV=JrngT*$yea`f=x!cb=Pn6}pSc{Qda7;!l=
z$OADd6B$oQG;FLxWK7HuiAp|1)I~=-zJ!gv!x5x*XI2UK{s8U|<4S>3xXCwNs{V<b
zHVM&yRBtAcH*?x90T$4V?pKf>J~F9rS8TosawjT|kt<aC{H)-1m$YyQzW&SKEB%z?
zcqgKKef23-WO}t~5#{m;C;sEwpZd_Xfve^ideS|NVE0yRg#mIS<Vq>B+U{k)WOTTe
zKBvT#Ub8UISc$6Vy43=p7fbrLM?>dvNn3>k9~|ib+sg!zhYFntX$`%$(27-_D3W}c
zkmp37(|j46)Hyb*{%}Y-St9vZPsDk~ZoupXXau}q?Xp|49{NIX at es(FR9L?gU4E}H
z3pw!<lqM_Y7djs{B&p8)F7wW&>;l|?j-xrEpM6-{r(qE;pe7d?gO~NVD;0BXPO_6m
zRT~~5BB_C#mw=0hz@|`shx4)T+ir6WRE*O!<Im(y0;2^jBub?kyjAq`B#&fZU_SSD
zAs=b5LgY-Sm};Bjoc*Z=nNWZG*~bV!vGCi6nh|`$*KtsCjrZI3cnj>`pW+72RTzFU
zC39NwLhNwnA1n4-wBo20^*BQ;9g-xJ#_g^<5?dxu`N_aP;m(GAE~W5|rtD8{<An^G
zMwUxjkTajVYu(Q%(cJ|wM~z(oD$Y9ADB={4!;Rf0{;A=<_v?%(zG-agT#)OZfB`QM
z37(>?awVBr5X%Qh%GSk<xIjtCcI7(E??orq2(oY>w-faD)ac5fHukJmDNe^y+!eco
z@{3?QrQpLysDfvkA5#W*h>Icw8C$DoKVhz!D5s$i;us%MQQX3dv6BF|7uRUZg+DT8
zXOM!HxR{IYb&Hkrr&Tmt$h6}BQg^Ldz{G(N%Qx&lw*lR85LSW2s#@Ami6nrx^3piP
z#_`F8Mk!^`I3su(tW1%TphM{Z&#B*u9|fMp-5QXZHQ`eJ!!7~oL at Y%~x0T1|$SDKA
zD?r7a?W32-Gx5Un23G|uhuGo5>GbnkkAFqj;<UuXSeuye#{JCLN~;IWK1`G0sGfEG
z-`C}RQEN~)?3Qs`EQ5LnIYVW5P;=$4QUfgCG5?#Gu`2fy3vi)%7rX&vOYvL%kn*u!
zp|+Mm9%-?7i-mlDQuj`Hdn<26P->V=BQBEm2aJ~r<+rxj!#>n|Ncpl)ToL=Kl1TkN
zM<Lu$4bp1;UesliNUY{S`1 at bBSM^(Jj)`pjRL&^3?-6%VFb<-UMl;n1Hk%y1J%auc
z1joWAP||&ENN!xXLWG{q_29-X)l6d_9)Zn;4kU#zmC7&-LCDW>01;FIFEMwxAc2Y{
z=R)`<YK;LumtMrPf(;JDgo29}lyYGhMet2rZ$h{bN1vxTdMpRdFf1YFu<+xmJJ&3$
zINiaCCItOpVqp+PBq82WK=>fWc?xbb+^@PR)yEh~QOEOHP>Qxrzf*LDpxo32f$Sav
zFb9MXd-Dr^qU7Hdr^#^&_U8DWo|oSb%7+x|3etnHgHdk1K1nj9<`_va<w0ZDzIR#H
zjRAD6o8g^z&0b&?6ryb~Azz*Nj?ka2zw(%SU0H~KpD9=muJ2!RyDg8&bE!9G`4`p^
z-dZ>OibF2e?kok8SUL+$j(jPy!3Op6-4vQtVfZVIGMHP#5l(HWb|wHjaB%`6- at yYY
z$j3$lSD<LpV?kgCAx8HZ#~s)*PAX7+HXuINzp at N;899Ku^KH;DpA_(vVJm<sO}fl4
zi4upmNl%zRIZqzGm2&0<rqb|>@jrY$MOIK3ip1NGWXOBOU$_t at j&oWL;^3WTe at u%p
z$6v{m;oyYXlv9lC&5~Ho_w@*$8fc*XNvtP`eL*lvK=HXj#v%-_fes(PYTa1FHb0?;
ztpKj)7WS`i@`3Z<LNssIZR<!#j^wP<UfVE<(yQoiSCBl5W`}~erUA4<x{xb`3Fq*K
zg9YJvymKN>vulub<px<Ys&;M|+jhKRqRZP^<!e^uv)yBJJI+ddhAHuE>@s2&g~po9
zbSOq(Ht$U+1weJY9??i3*Z9Z%c(K1mFZEyn8~tOVaghu~bimk}gBZf+BZ4TU_ATcG
zPztwRP6#3OMtAcx)pn1M&0w1$!tC{wgGHZakDUtC!gDGL%%Qpsd^XqY8zy5jVy_LN
z;0oY%6ArvcinE#=h`n_p_d%JmQ|m)6{Df_S$Tms?){fd2?w#_`GJEt>7i-aV*e(kd
zV$DJl=+D;$F2n*V{5tH-&|**XP(&m4C?yiB8syzFH9J-Bzmty(RFVQb?-4>UzomY<
zzr=iF(5;PBo^ZgyO?4|m$kSPN8|uXpnO%|o33nAOz(9DXt~X917VK3f^V*etxaxe5
z!Zu1ibg+UpWpwG<wlQEa2M6#S&A?Z;7`Q}%Ril8Z+wG+fU32!p`e6vHfU(f)We)nA
z<i%)32xTy#v*0g6kUx1?n5#h@*N$T at FWb+V6TcW`aPb@{_Tp1YxYJ4*^IwUc!qt`e
ztpH7Ni5*P&E4|aD9;&?{cZ63xsvpdxt!m&35Jl%@r)9aVZrkOk3T<vR-rqsffR*<P
ze!s8Jy6>-=NUsgl7v86BRu%8e%-u`5d&qrmnA7h)hWcdGQ9CpRrR%7CuwJ{8z2_UQ
zZ`k?4<$r{va9Q#shCv+}szaX>+X1m4q8-#cX#+oV7I=$Osl-fxJ=O-9QZQ9E9Dz>Q
zVgg`=Oldhm*%LzYOs60AKK$@%+cvNQQQHikEu#>_vf0-zl8&r at 42WLTKX{g4(>Ovu
zW-q?Ou{XygpkzYOv2{Wd8x7l28j at Evi$+Cc7*2!A-I671I^LkkGN>eA24Kx3Vy|({
z=iVb&@oosJg=GnBudzXX=2p|(pLw{Hmu at TrjsLe~n?PxW{*m?v*a~rHs$o(|WO)6i
zapjk7+@*4Z)8JYj+yk472?1?{Ol}hh#x|G~aMk%ENd{3eUrG*$6!674a)6vkpQ?YV
zN`;pn=~%ADE5T^COnqs{kZ8k1Cxd(Kf9S;K_TxJ^qN!wp5}siDLshKr!$(o+&ajfJ
zXR!gJ^%E!s|6D%3P*M<q)pinPN>9DSMK@;HGR(ji>wXYX5w<2R7hnG>b_=6Xfqk=N
z%gFMN$xPR`&>Zi<2Sjr5!|M9oT31NqyaHJvrH_MI3D?W>3PinUqG=fIrYBf8Dg);j
zwoV}1b?;JBvSn1divZN+9({2YUZy5pWM4Zc<TIKPM-y&;p at 7d6c@(kn01V(5UBPQG
z^bdHfg){_vqOk at NNzV~($EYoq2TPK!Vq)>Eg;6BM^DeO{8qWk<R-Bf_$3zBwdN{)e
z1KJM(q_|}*^E_GZ1u3{}8cg|~J_QBdSO)Mbn>N8z-o%EE^H6{ATv*JoHK7Ngxje)v
zrcODcf-rz+i17;Rvt_ohd3muy+)sUx%(i*t(Ky8<o)OBzK1JOSLcl$@%a`jE;0?85
zy>NbdvML>$f%5AXq-a#xx!^_b`{lPOv!F5qRzUXx#GR}Zuu41n$+uvM3An>M;ybxB
zFs(tSX`OjKDM)1rm$@yXF-utWkR)Q3>dDL2xzFtD=0YS0<`(OK?BmdF%;ZslOWSj~
z?{ZP_KV{t0tmXZ9ol-qF5}02dlxzi186L_Mg)P3YN9Ce`?CzOVS1~cU4^d*za3SNQ
zW#ksQ5{(Fn<~S^|I|(1QS`;ER#~=9Pfm}Gv!EaDC>&6rJS4!YDPQNB+guCPw9TAND
zt-5|jL;S4X#%y89F<-PzF_rCm+wg_7rn7B?kXtQua0T^+%oqFxE3s_oR_h_bKSsij
zdgeG<$?<U?13SaQ%TM+u at Cxg~aqm(&29liD;BYu2f>P?Wb++l|kO7(Q=D9<5Q`elt
zqUfhhw&39yP~Cnk!+<|%-FmzLgG}DW01N;WtCu<YGb7G0fg?wzaeR>k<x$lRSfY}e
zuryvK=_c0lwS>(u=-&M`As%qH-e$z%xG_=fI-{=a@{|Jt at SOi10o2%%J$;}qi3Mi3
zw{8KoJW*`m*069kZ)oCD1c2Xym at CKgaRPusHhfJ8rC<@4DLf3DQfHePJ{Wj9A_xQI
zi;Y)^aLuJ at Mg*pC7ygRb<Jvsu!nO{GhCa6W84~%f76g}{HmI<}2k|T?;r8M7j(wxC
z+ at WyXczdz53rVfZGv5_Hw)VYdUpo^}d}5*RSQm(94{U%?g4_(=@)r+ro&>#7e(}=Q
z2CNq4m(17x0G?66xARTXfWoG_k^i)!ZYnB)svtPSctpsRg5>oIZvzuv+b4k18t>rx
znWcEThYJm`Wd^PKg5Y)vyJm#Xx)dJWfo<V;$N~(;xP}C^5holDx#kz>=^Iy*rd~Tn
zr%)v$;WVXwGWY&;*I9Zz!(WWc)ZFIixu2|vLH;vwo`L`a(Z4_OIQ>rlcAg~=<x=eD
zl^by78AgbQugNPy5t>PeL<guruWs1+A<rrgQQ#Ruh!+vhq8*yoMyz^{r|%(5#xt>U
zh9g37x&8P2CpQGC!HlQN9KDez!Tu74p^mCi%QXjo4#KH`zFvVJXWz9Hb%4ez;tsCI
z8xz54c5+}}*$HV3-kHb!YOzJ0jF%Z9vuePZM4e+?<QZOx*AvSjEJS!yX$(?@A&tJk
z2!7<EqL7!u(<Gh3TB$!dC#Vf~=E`Iwf&%Rc%0Bgm|HXR~&@v*z0g>VOcTFf8w_`CZ
zhyv$9P(Pm(r~Y)|9GQ0STfHvzFNY)X|1vbN*Du-jP6*R=O#n at hLSO#k#OU%TiZQl%
zWH1$dKHfQ at M%(Z<-(*7=@@L&yt0w<hD5uzA4JR<A%%lZ2%05RAnK$i~H$jD(-+--z
zD5P4!uEf89Zs{!9I|Wl3miM3aOYp3$*atdSZt+5tFWc4tHOZPqxU6nzpGKiXNln3C
zraED$wqp>Po~z`33ZaVia^Fxe&^7*`11|9v{_NXsS$jpPVCnt&`WP6n(Fscx*3vLJ
zPD?c=ko at 8sL={->*&~8V4#+)S${hzK?)al0nVy}4_ at lL~GojZoGJVjcK?HTq0WR87
z?QA2Gwh|3S)=r+(hb-<9y__h#)6Mlq2O2z*TgKp!R0RTMc5J<%N?>i?19c_Gz+7MG
zy at D0->4_{SoHV+OKo<IsUh-7TtRBId!2Ia#!c|;g)Z)$jNP_d#3)o7I0HzkxA9YYc
zE!+8#`IA9UT9udUM=FBvu$Afn&JTJexrD|mbJ`HWCd(Jp<gFj5IU#4R3$tXiLn<5;
zN^L)u>Eg!G%MB6xrqNVD6p|*b<wY0{-=2V;a*mJLvGRykW`<E)I*AlMCT--a2+H;U
zfvJFq;3cnl`$x`HUP_o&vO1#i798|zNla`^(L$+&<ZP&yEUJ44RMMPlNcdz_f+#Hb
z233N{;Mvj3ld6FgeWR%)S|iA}8F0Y#@?PghyJ9ON4%fM+(<-CJhgD%Km;9a6(bCB%
z#1R|NF^yDC4?*HJk!~~ijc(s%0L6N~4Az1LVxqE at 2OaVTN*-FlLZO#$TuTe;HjO>W
zxdc_KtPyg5?C=hx@=s_cjFt+XK+*--bp(Ym1mY7+MR7?%E<xzyOpUbibkTjY`5;-y
z!_5&)EowdAlGCoOoK=W>%Ji}}oha1tMN8RXzyL`Nd%1FZM%MMCThSzszIu at H&NN7~
z<skj^I9loC+rjV2whtXT^Zo03a<?F8AvBZMchTDl-E&1hepC?WSx!yrpL?grXiNjd
zzHR>%zg`c1n#Bo-%B(rrG?Afpzq%*PrUDI!bpLdnm_cf@{=3b0oVi}3Ph((4j`VJs
za1&y^HJC7a6X^#xQxr9j=}z2-#R)44pY+r#%a#3D_#MMl{5J!fpWi4wYt^0WrUm22
z(^THs4SYP7>_UinEX_@##&F**8AkaKbPv`jg}~k7RXOLWpHN2FMpu{8zmoCj(Ifs`
z^694o_#p9riLZO8AXFYaCi~m=S>@m$0q%SvWnZmhHd5adTZ+WV1M{tuf<x at Q5U=(;
z+S@))&#_*jV!uG0-{98DMLcIUEm;F~%@*^QgQ%8E96h>pke*^<8cz);Tc41SDPTzB
zed##F7=z}JWt0!3BnRxnn%%AEh7R81+l^+&+NLS at sTni<r7O9HhpQ27LrnsQXK;oF
z*)Y<K6bMy at EMBLA=bt#ncgP8)V*HA3w3t`Vy)qh9Pd*O1uX+UOCf=faH@(r86i`qM
zmk0Zb+n77qMxR~G9v1M!EWXE9Vp|m!oZJc~eq+8-+cm4h!yZSZm*(MLH%u^a$#F+q
zGf1QH5;I2rdCzeDe!b0Jh5Z;h;{m|CnHz<QIv&bp2&j6>Ap{>0aLh2>GP(O7qxm#2
zk?8qmhUMwz^5e!LtL%Lm2zeho%ov>BH!P!Z(q-)5yHkqj0LRjgig9EUB_CV>YEInq
z5onc$&Vaw&- at LJA&t42T_<0o6iu35F732uXZ{ZpZ3mPXB4x>Gj;1>3H{(abgd2>iF
zE98QgBSD;C at uEk{jvv{7dUI#v)g1)NCBHC~61Z&$q|xwIznX*-Gq=?xg>D`IyHf5R
zBDI(0nvCw at bihZ$4Q&qvZ&>i;&feL*dkZKf-@>B<bF~tXC)Tbt at 3Ls`$Q(M;+T-|c
zd?WGp$*ju$dwU=ElUrxwy<YE$3upamFRAt$UQOhCL`5NcmyY%ySTZhRSd>v2R~yLk
zQOyP;^w~5k4-3W$3wu1+`)B{j at rS3Ep_}l^^`D%k3r{xO2_`En`H1@*4Qgo7puNS)
znQ#TTh?bFIBxb`PKV}X&Rm0xv{p2fOrDR~--GN^i{6yN?L2V at U)phNLt~8;Fy7<<$
z=SzT}u2U}FO+B?T;A9wI at sup=Yw+|<>D{+mj^FTlX*0_mhVPhOfz>kNdG{!F<86 at c
z at uaH*!$Gd-W1nNmUuX!k)gqN|CmK#I0yo*d=>=Gq-hBY3Ipy(FZ|GsuYDY@*7WVtI
z6{f99RW2u83<T&;kXn&>*D3qX7DY3gE2dj%j!4wUb!oxM*(A%sEQ>49!I@=drr7Py
z2oFouq-SuALk#C#mmM=DY$JwjI<47=p4OJK1ZCcss_kbm;m$gh>gZ8Z$)u;ILHa>3
z8CtWZ9$y`Y-&)~2hTzveiO&6z(db#1HcC$2(?{fk+q6YtqMpN7?!ovDv+RzajU;*j
zUDJ at LA;v8CI()-vm=sQIqq=ti0ja at gdI8U04Ih)hqA;)?i~<dB9j6j1DmLZdQxc7b
zG?J-JipV}J&Lom^g$&wd5YnDzB4-fv)&o!zX;8T+B4v;SKA}Y3<vWsJ2`UuznFV^t
zz~$qWj*)XT`D7S*NQi@#jj^FT0=P5kJwj3lavdN><oC)t{$!ql$QFTzV0gKFf{sJG
zv4uIMO_1fltmP0BurTdEGU2Rd4p;dSMp#mDU5jo;Wa*W;c`^1=PE$-QJ}S1K>lw*o
z2-^Y~qr4DOEWvHD67etwfL2J&P^my;H88eda5_9t$#)X!Qxa-SAJF7O?g3Ik;rT{v
z|6IZ<#k*zkBxTCT=zQsU#OMw1<-2gzd8TH_P%JE0Ve&edt(o~oot*6E4Fusd*gM0W
z%6l9Iw!<dVP(mv>$W_8{6N42>p}|VYUj|!y{p-wVmr@}zDRP6o1BuL7Q_&4ou43|9
z7xk5FN%bby%y6))9&N&-p;p8rW*oSDV?mCOw64)gJgJ>4nwG(+MmY^v_WIfTPR?X&
zlcd&MmzZU*Jlok;d&sNN!lShVgzsTa#LTL_*~EjbLjjCqV(@r_Oe5g`-RR`K+{Rsv
z*%hr5MEX&t*xg?_l-e-K!J^*aM|A|e?!3-?><uyVrNZ%^wi(^eTE}ILnH4P at M7y=d
zsh4_Hv);g)^l-GU8<In>BL^|}Oof9{<_+4(jfJyng{^Mr_n(E{;{2_WL8drZwu5<n
zks%_3S#+!*t9k>Ew0lz8y1wu{qURa6wP-mYaADVVhGXyjF!KUBb||vaj!u1F8%XuB
zkkd-gL6BaRMy^hFpBUI1+vm{_di~R~SUoTJYN{IxiYC;r79(?-hlacwq<&Sj7$mof
zv--L<tDLnuj^zthJrdScm0_eh)|QC9yat)jVh0&fh!3zb-;}j2HsE046vl{vQML3@
z+5N;g3RD(0&-&Zsbg*I7O3cYMh4?3q)gp;F8R5&yVl+e2_dui}*dO+ag$&)e>&Nye
zPvsKwo<UEMS_NY#mzqf5KYBe|HzR at MvtQRxVVd&FuVH!PpZdJG=$3}A>-={-JlVFn
zb*>B@`Oh!xY6r5?AN&m1Ro at G`bX|@(>==J9C`~tzUtv10RW7vsjgv;q&D>G(vB4Ih
z5HKC^_^Yw)R1)EF at F5b9ts2Fj^{ic8d>;5_4GGut`r9^VO#`QHOJkqz4USXJ+}Ayi
z4)FPKY#pATpse9|PH0^|H5OrGyDRYLcS9|8<fG|X_uAs`NI5XLzx;=WKS#<SZW4zE
z<&^xIrR+Iq<88DF>F0dGpScHbZuq`xEKIso=i5q~Gk4Qy_e{O{9dd0WpE#^G<dv78
zpgut-KVFwUK}*LSwlB)LbZ_iY!pE-aKF`Z;_JAln{<Z0SAHxZK96WcF*mV$GOo>Bo
z8Gkr*;<gf+ZKI`25?9djp6uMvGmtOc0smoSQTxOPksLc&%Ns)-H=1(jx<=r_&pVlk
z^$PK-WrzCSSUwI48A!gg at RVCNW?gWo>N44ksC#SEE9p76`GmVQ0v-R|P|8q?{+5<^
zo&V?V;J`Ib%==G)N8A?vo+ihaOW4}kUB%}IemRDu_b0nNr?2<tW84}y&S>n`*xDR_
z8^q4?FEc0Kiditt+QAJq-4{<X4$oG(HrFcp`Cam92>V|PP_6V`HT-`6^lhKyu6)xi
z8C;_6=-sq-0uYxcTCn%_K7QxUeN~w5Izf-t1jKc+dG6M}v7fz`29Nap>1}bj?b*w_
zncaG!;gKGyiWy*Whz;LM+JxNSmh``kr7|yu8n?M_1k!);+rhf$z>Oxl=fDZ4+D!_p
zU>H5R(G;2KuRNuws<-!+yJ<yd<?5a`0|izAwfE<`^12qC(J!Y2ucXrE2J1U<RbTt-
zsxB&~0>;x%*jI%SPpE(xqYO*9jC|hp1Tep`t<Eo^`V9wl!(O~85#nMpraO?htF~Is
zNnX0kf20Xmk}b!mB-Yr9_!N>x{cuCh&Y6$qxhn9<Pw=^KMpu%%HqPU at Tx~@M-b^U-
zLE)YO4ttvDJPED|>MOw`7G4Rs*(T0r2n+3p^UOjC4Y{hO-ZZw6L1%o|2=TIdTyU|A
z!>i=$qxIzZ7^}TJYr^9$f8Kozev=HuyR(5D{LUb#0 at 2gTTq{x9yxe4zA_TQ{5e`sp
zyJ$S<N0y=kJhv;toJvJ9il{n_68}r(*!cED=mT?j+PYJVy0eRUKs9h>T+fY=njxO(
z5w{k6c3HK!oHG(`+jn=U9&I1UXgzD(b%uM2Z~i%2ixbRJ30?3=v@=ceU2^ysElD7e
zMJTq!F0r$wpbRj2n>j%nz}ZAY&jbPKBXS0NYE-T{ydT%57AKJKN3IMHR*yOaj^DP7
zTL+0k*+BD{i!mLiFu*jWxFYp4`0HZu(t=1r&xFW%?7hpMi=jdPaiC*+B3xog%zVD0
zv}lFa*Kl~(q?<2J5Z)RTQm?cDqRe*CUXoe}KM2;&F)gAUC5eHZ8De{ssrD!ZbEe+c
z+(B6sFPMyM+9d!$3f0d82I_Gq(no}9<x!wS3J{8_5>JH07Q7nVvWgK|B1|P4mlTu4
z2;W9S(ycTQ<sPyNUTKymg(he=si&S7N4pmxG=mdG_$ovq)c{_oglc<=nGcue64?P%
zU9fTL;musN<LGIyMhrtDfb0R7n~sPkV(Jsv1IrHvj}gr2Ri|3f$d>e^XcY&(_+#fd
z<|VPQL*~^$E^d=L9(>6OwS)3Yg(GV0QA;20Gm2vKFGSbqm+LL?zk{dvnTeTVon_tj
zh_ZJ=X{tmf&@x*g8f+GEGFIIiv41Yvq_vP&R)@)2Osy(Ib4ng_D1FZjtw!&YkoYO@
zl#sFQ%yv<zr6{=<_p6(y8>5_V3?u$%rAMK-?n>)q+CovPp5a!fgHlr$QXD52!scH4
z8w3 at h#HtO^)D(8aBp|_!u2*f`U{JF*YLPR44{uGVb5e3)b2w!?)K}qLoMB^bJyg_c
z$A|#KA7f61cJwvB%#m5Y4mgL^PRv{h)~r2u8{o-p`fLS+Fn(F4aqq9hdbAMh&N?D*
z#+sA)rK|axSf{UKvqfKDy$3dF7;s2fiFC52%V3*cn}}4Bte99o>6^l1kJ?vp+NF08
zuhPw^=r+0*k7!h^XRwj7qp~LXS#Z%szi1{Wia_ZU$BUf)Q&y`T6&X2L+-j1jLZ||V
z!yY{kcnF=?VR^buIF%MQTHo_dzTB-OgUcE4_EA9=8`N*yDlIkb{;(K(w^nj9X#Kwc
zi$HY0K5m%DD;uVGPU-1nX9I^Fqn at iht9V)1eeYJy7;m+U?wySH>y^G<cC!t#n<ry@
z&R1in{CRf+#tn{{GmtMXJ7&qHJ<2gM7_+VBuwx9r+Vh54cy4~GD^;ANHY=&kN`3Sw
zrp-%o^b98dtTrdB&C7E145oN6$`<6S6JJ~u&^nlC!d4Mgg7Kw^yYi?Gh82t35l0DN
zSP%yXU|ta0Tw7sEEl7D`MlHyl(}Lt|`Tg)uMrVae9of1n%oeYSJXDdP_;xt=5Jhyv
zwXVvhkvZoT(b-p>6wa+3MqKJ2@;$~cTob8i;a)MV$Px={P(V?oMQ%Vxj2WcFLGDM8
z5(l{fQ7Rs#;)_+3807{;sd$w8k)*~+_HB}qCMju>q9xh4Sphj_DO*E&uyWH$AqA2;
z75RJ at DNK<{6sc2 at 4>ZFIaXLd!ngvnRfin at HUl0=krUl8_D4?81=roX7nNCl6;X-7q
z%Z at ReeONwMC*vKj_OM}!KbXbO8>aZ~VKz+u?%_Ag{nL)IK3~64+4|1h?skmv{39xR
zRPl<k7qLDlJv-C-p!5n#-_Z3^O#V^n)tUTb*Gn<&S8RG|rg~G?Ys(ig#!pQ at swXLZ
zlhSiAi(ht({#ognRexrsUsn2Nq2E(oxsZ8;%J?1POI4V at TL$M;3t at I!h3V{-zubYM
zcAzsJ6T;aP){J)q>^6+`Z|rf$Gyle3Hcau2+=0Oq&&UZenEU4qQ$8y at d@{yc?V{rc
zb9>q`izn?)>Fwkb0qi!+{YA%5X8vWvwBE~!A^1Y3_+IJj<r4s$H%$3qLfH*tJeW`$
zrg*D8?-=95LdH*Z<s!xi at F=JVmFIC1Fe!5q%VA{g82w>nZJ2HlM%Iq8fjaZ}Wy7>S
zH-Q(%c&k0^nEB@&qkmCycII|3)(>X(wBzX?&!#61tijywHjMQE#|?A;vSIQ!vSA04
zzma+ZhcEJljQs$dH%#lT)N?TTTiL#ov0f|tbuh(qvVVbje?HZfix?GfvV#Znh}vFu
zjPblu*sC4zO5x7bA-*Z7nf!xNG{_DH_R20gcw<i+rg%{)990KLrDs$f9F?9?b#PSr
zMWt_29h#J$N$H*B1Q<+uuJ)|ri-{3)*IO~gTkSrtO!ekR`XXP*R8M)F!hbM6G3DVl
z%-6>a^LW}`HjMY1&U$0kn7WJ@{ec7Hr at C?xPlbT9%8-TKJj{m4-!z3aQ$<E9Iv5pL
z?6xVqFy^;%M}Xaq=Z<Xbal<@c*)YX(O>xcS at 5ByF=KgudSdVY|E{y)ZcQoUq{H2~j
z=^11P1G^1#|F~i9U%to}GOdqFufe##t37O(?sv849kck-o_c>Prua$qbCMGVIPI7{
zf&9vaOc}E3=&W`u_Z`6uS?y3(JJgw;$gE~aXNp(U4ivQmMJZg=1X1>UN<{}_eqg_0
z?w>YH{zguO$>?vSK7;xC<X0wtTU&Q!%m))itnbY2amOs4wwDd__|oobqpXbaIbU1<
zuwlx#+Vh67U$d`?SpLE24-;#{e0|z5#S3CTp6belOc6rck%i}s+Succ|HpW_>^QC)
zVR+w9p``?j6;Y&k*(O1NlT8w|fh>Y7e7fx(2QB-=c28$Ed8_k&DPF`X7CA{Uz(^mf
z_>=ruWXmMqHF*1(SA}&joHH&+M}ryDeA{5mH_Y(JIDNwmHf#e7I{=X}Zdt)wb|C7w
zY%uEEU?*p)r&)j3VC?ULpPVt at u>y9i!0WheaQ4qlrN4=@9<cf$ubHzxa8cliseTz3
zrT>XBUzFv%@m4>;y1`V>vHnFpySc3A#HswB%Z3&6v)&x*n={d~EzbF}toMzxpOX12
z%lhBqq`zq}?w=~_d*hs6$7O at 5o^CMeEgZ5ETvRn;>ZmKkRl}`RMjeg9om3$v!;M78
zg$t-c><iZq?He&CS5Z|Vm10p-BT>${*2%>bZ4oJ5w57*YR98rJ|3}nSh{<kTYE093
zE*sWXx~*`luz8xi=?u5z4bxB_RfV*#sSu?EgKf1uLQPFbQmJhlrrW at yE2EA|&9rb6
zV&B=D#xYCHw2l*|TWy}CH>o5{m9%U<8ahnG9949Jh1H6dUP98Zv?U--c0a&1V;*%W
zT?&YMx_Da{qVhs3ZNnVZWi9El()6e*#1&OhQzKC((dV+kueh+hC|ToeWr(__wAIiP
z-H5shVIp=8XvbOCjOlh<8cg$TgK_3=R1L<-y3rK+k+Ytd#;L(MA6QbojY(Y7 at qrzS
zyQ05{>*t*F>-fUhvi!o2Dn5^*#aWN?nmJbuuxc>XGsXCkQC~(s8DqW-esZSyy2W{X
z$^4GI={>U+ze2?vSIlw69FL4MRLtSTIe%deFKh=E=HOCRa3gM*UQyA|v2;|k3f8P*
zHFH=qhc&BcT{yZi<{RdpVg4HCpD9l~ux&BXE8{l!iF$$k4>lMU89tb&jaAL$#9MYF
zBo?EI?BWf<Ip;f8!H)S&c}33abIgCoD%`OOccuUHRQjJd&j+~hJ8?eIz_!7tC(3%>
zIDeIuEo-yKGM8*;I-|%qW4MEgc;eh2?jROdtUr&N2IGoTJnO?9)#BVA?kE<Qg&y2d
z4W|8Fi?bfwNJan1n6ILrjB)*S+%_2Xm*6jF%wL$Fk!ikZFs?^4KO<wlX8vjBua5pP
zruoQgV8`OX;U`+S0cPX<#2X<po^W9AUq0c$w!!GPWqw&!uXS8CnEcHuTGnO{!$v4~
zfX5x%0mmxZMaLPVo at 0(Xwj+*Jv at 3T&PGv=Jy!|?8#FqwVePG+-Z9dRZG&t`Vuxc>P
zFZ at i5<ISaiiBYeP7ZnYx8%+DV24lV~Z-m5{FUuPtG3{?#O!Sb~%&4cBpNjddn4hY=
zF&c40e?cY2{AHXPjQy8Uwm9oWru}t`b3K;vXV$U?c5FmfC~7}+&3ObpE)7OKxNI6s
z^~$&zMT2pNjDI1HL`FTs95-x7Y;>G4>RYxWmhFgTJ7R;MoN;{1{Itw(7yRUm`7Zj)
znC9DJd{_FZrqa)iw|rpLVv=tfoaa-;Md{zhS)cM6ShBce{dI%$egV4%WBy$FyKx?G
zj(##my*f_)eP%5ya_%9S<Fc%1VAWupv1AU*vZ9q at 4y*Ex0hSF$Jylll#w6|<O!dn6
z!W>_i;|p_iDJvY<HW>AE at DJmOw;M?5cq1@|LUlAux|;^m;Y=ZCqP?7Rf5YrH%x=T%
zHRYA9tbeH(^Wg$gR6jAvM_vPK7S~MAH5m1sf2kPr;X-OKmUD{d?S>1g#asVn at -H>x
z&$Oat4Xmi*#zcX~O at s4{7ZDuijCvwC%sGEn1M8acvwfMpgPckJ9310}^Qq&u#oNz-
zDlUV6oKar}zc`~`GWwU-FPWbz`o$RaRPc*4&DRa4`L39MWQ;GtPtG{s#94nSD>O0f
zkGwYXZHvixWn32(y)mvw2fsPfeA8f at uVH>0wjYN1ZHoGRW-V)AT~w4|6>iv$M8**;
zbKJ5Ws^i6-k~rT%z?Q{r5qH7Sinlwk5myaH{W at +Moae8n((#QqJz&}3thdEUf8F5h
zAFyjM%`f9{V^xURa9`D!=L#QKWz>~YMHH^K3UQfmkx}J{B$<8|MWo5}qf5gbMxz07
zpem|r%;Q#3Qz2C*(dVas#{S;0#eX+UP`J}1{8KvTy4&&Tuid5W=cliz$X}9- at iLSD
zx|(3PX_~vm*G1M)Tp|CB{INnc5&D<({}rjHQ7E(*lKl8D)4;WadL%Nx-9P<izZX*{
zy8Y=%k5X9KP4Ew1XV+;9`z!PUAA;cZetnuk at cwdnf|DnN?Dj8D{Z357{vXh?7$-Y1
zE-<xj|NEyM<V=%}IX0yDs8+L&_B)-MQip!0a+8rJHqB96O8>V#r%pk2%IN~W^?dqV
z38-omUFC$y!E_f5n}KS6jWW(ZE>VqEz(=R|0AA<0Gw{&|doaPhJSB%<&C2*bf9v%$
z>;xP>nCEU;CiuYXg`PajW*${PN02id-(IHNlmJ(s>s6r;+ZLbj_x&Hk#?5i#%m{_#
z!o1*BO4tSeF$YojhLCAm0xAin6*dKS;1edeKd*x?vHm#B at Oj#IKV60$tfhZV4gZRd
zFT)Q0QuN(D3>*gW<L%O5P%g8tMd6(P^n&5Y)^8^I@%}XIpx~GObh-}${@TO1W)%Hn
znEVhzj=JwY{7Zk|mY7y3KxPgLjBm4nj~9sfA6+_DrXR}>(|2Jv1<csOKEhP&Rx~gv
zFl94A#z}R5I1hg0w{d`@)OTi3;K(>YN7;A38{j*;zrv(O+h0QHTZH2c$n|f>%ZpzI
zxVJyvA3^F%H|So3<S8caLav+E0k%{3al}iEbz!YL_<EYn(m~TC7nh5itZ53t*}1$J
zw>d15!yQOMLBUwCD)6R%`v at c7j(0yNy at NIC-gNh`q51mRJqF<y`qj at x^oK|2)xBI}
z{1)<Gqt+!wBV8|De1W|TtI+*tY=~J&F?Eg5{d-Ws7}rme at A2!sI}C7$`jhutrLItY
z&~zJw at D-7Yju;clOKj!roQR9RT|eH29h^)*wtu`2 at CUvB4yNe-@p%o;^?ZrJkN9|m
zoa6mVh#oGl;dy?<$G!VJKa$$k5lS$<{OX??3{ZY;htuPD>tGTw`ZoBJ#b)w2ZX#q=
zX-DIsS>mdsa;ZLH!XJ<0eeCvwKQbUF!^zR04)^>WT2=o`Y`tFYDew{=DftlK2B!~3
zKD at v*&-cgq<=$OS-Q(-gZ^WN}f<3=HZrAsBSj3MkH*s=8D;FpC>Q`g@`S6bw4vR at X
z8K|XW7rit65o!fKr~4E-KhB4DUu1zU-%`@;ExioOmiZE9_j780Ief&odpd(qzFszu
z0=d`J^SJvweD at 8n$M?hc*!Dx$Q!NQ=(!x&XcfXs#K=900r|9q9`!zOvdSUSJbh^Zb
z<Ne-!E0W(own+CH-#!L^(cjLOx5&XA|8fq8^Ouw#yWh at mspvk9_ZqrF4Wu5&?tZ*|
zyEZn89t~k+Dx%lxaqw68y}Mi=;bQ7ep`8463-lh^;{V@=P at qr_;pJP*INn13+p#-c
zLpxN-0_XVfbHpT+#1EJ5YiPd4=8xFrKde{FZXL-D-RmoQc at 2y&y53dm%mhIeL4uiG
zW}}g=9*Jxvl05?Q^*Q8WRo9hTb{2sF>yk~@gFHNB$<-3LH4Df5_!V~q`S`=<+l792
zw7yqCc%}4nQuX=tUIv}xmE(#Atyd<xoT1BgbU8s6$yWs8>tFqgl8}Zz9L)b3$3P1-
zD7zVC&Omm3<}PT{eqb2tFi{i0M6xZHKx-}0Cz-OeQ;n<izFAiTBP%K&uAWYp&k7%r
z5M=(iwzGl8Y|rk{Ewu!eM at lyWp>~*@?89f=G|pGbyi$`ZEzkG2-Aw;nB8)&ea=FW9
zb6Me6={VF5h!mrlpfZeofVJPHi6()FQ<$lQ)_UB-_^ZZ<IU#dSczXoHMJm~bo*$3P
zU!P7__s{p}V6VoEx0PhM2q>kk!=h2+aMEGfUvuxTRr+f<G)zi`TrClORFfA8Wkm%7
z>JZTG50A^8tU+T at Ki+b+OGJr{6;qdxG``tlCl&6&<p(u7Nj8gE-8`S9nZHYNHu*%?
zlL1zhMglwZ?3a_YCTu4p9)-k2je+K)R108?)~Mf~A1;4aM{9TjBayCz8`I&6j{hV<
zsfTpY)5F7e$O^-c>y>-XJjz_g9k-OOkJ_Jq(Ly8BoK$mX+(ACkcvg$&Mk$g)*@Z at z
z#w~yV#*yDllFqNc&X`H}NV at 1s%@0auCam`5TOEFobFEh1j~oeZlxS{96x!h0;q+yB
zzLbm at M`4mc$JZHsx%{#?8z%lFfBoS<Hf8;K;3AilA0&qna0zTE;$rK6S!}<@uTT8(
z<upc=JG1Sdo`3yt#I$^C1J2W6J>68`Z;qYeb|#3_J5vYY&6Dnuba;?kA;Q`lPsAQp
zCYu3BFL(TLe`P<6!vubWC4awMK1=&Dw-W}Q>u&$}#!-jD%V$9O!^ifGy!lScc5ubL
z6ze1Ze!Vq?^0NN;=?lsn)96V<)efddQW31XuatiKVK`ii{*S`5y5I+GMsz(fUt-W~
zbwv5bzJgV&9Q{(mrU6rv7pcEHT}NY<zA;bBdr0fhmDq2{uqs6(rrI|(uo6<>J|1+k
z2 at +RQxhyU3xEu@KYQ4f^UpZOqv<b+h<ONppXp;BT!XH{{8rO&&zUu$Cclu6nd`K{~
zO+%~Nr_U$)+FPn0;mw?vN9Xwa;Tfa-mCjRHo_k(Fyx(isW`6qRLSCSVX7wR0&sU!>
zLWP_6ONs%1+w$omu6TW68tIycGfj$KH7MZqJx%x8G%Y33NX*)M8uJ<&yrVKT<yh;U
zV)HQtimmCg9$Z<|u4Xt54XQO#Q-#BKHJg`d5*~OVizZ;59QQPvSJxCYP#;u-H)GjR
zOg>aJyhxHRi%%IT-O+4LrpYS^w-nW2nYgE!y}D+EIK|_d;;v?RbxmzYq*)aB5yOsR
z at -YqmdWJY-m9VSXyoP3^Gh-b^?ORRvN)dzK*@<s1{(a$u2wQei28)b_t*lz=>vHw!
z!Y%Ue=Rf=fb at FGZ{vovj%70l<C}JF!j}ns-idG7mG4>p)hgpS_C00g0=2qTOZH|*w
z%9>sWqA2bi)o`4xTGhBatQGS+s?BkzfOj?W9&vt0Gu$>+Jw{CZqAHT`UCriZ8lc7(
z4MIRaKmqQmHou`N{+Jv~1&^B&_f?alsWMWMf?7p?48Yi)YH}P_h%AUwRanc%UDfP3
zR3q#lg at P0AtA^uHwH2iuRaK4|oVKf)9J?w5oGa at 9G?c@>YIEFFJ<}OWg}SflZYi{5
zNN2eH`QmTitt#y~?^IPn_iNMHK3#;2jGsp~;kYi<*($*in0kE_Zl#Sa1wE^jzsKnF
z=}aTQ7n$_XYNS-NQl1ZOxl;R7NP at A^zN|szj5CW|3*{QTdVr{6QcXimitMvfnp&fZ
z$q$kClKAO+t at a(SosjU?^GFgAaR7xB?ii~Y_)6j~fpVxkacbTiVqy1;0JX^IRJ>&g
zD(96aUUT1~H<g;WX4be!G|pv-t9hu#3vyIc*7w*t*p@|QjAr9da!+JB(<4O6B}bKA
zZYpPVM+T}jYGP%iN)42Oq%E?P>ETM5ERg0ktDH1cNTzLBgJnBvw!v?O2EmS<^70x^
zbg1iVfKh|$iqQbV!1%;duFi9d+yUc~o}%Wa2Ep at C8oBLOA{$_QIJ2mY9<>-?s%<a;
zllu`2F(KIz(<IN??3(J_vaNulwl?j7vtm%=p?C-!xAIWMbA-#4w{W?Ov=1)L-(BjU
zwI~HEJD+-_D+|r9ZJ8rqU&*}0_dEUn#7QXwm+6d?Of_ at Tu-Z6jSP3TuFluy&n8ZmI
z8!{q|Di={m!s<ligoBD)ouUMqEGfaVtH1<u(UCKQUg**6JLU-WC`Ts|NwOAVs;w!g
zobj3wSyI(ydXy5+EE*<zU7^Sd^|)597 at MXM8Xss8^&S-!;#3X-9GM0pPbC1N2U-a4
zVIEoNPi`uNEOO?}rSs6EcvWB!P=jKjkx6QkC9-C2au6hnyhfEJ_uNn-kK%9RL|zps
z at Rm_1UaCFN!3U?ZYsEZ-Mxa=wo)D%QIsLa<r@&HXV11~Q1(KC{2B%>{G7Gm5f?>K-
z;2t>{Kny=FgykGhv={c6 at zrG^T*9O1det{Q<Ep6+3M)IKV;Jy+AY7`QN#oXUMcLp|
z<C#TE!B&U{mu7qPz<JMmSIebu#ZKAI<N>e7TuV>e{1d5f?10HC_gnA`09 at jkN+m#j
z;;p2Eb(tPP2zs*cE*oT-&9x=&(VE4&X}*)Ly~R2i;^tfk5n+@>L>Su at 9T+r&XGGG!
zGKD;y#3-#e+LXc}lOiBy?>CBoT-G{MglJmcC<1cxX`_e)I<)Ub5zzQtH;PDXt%Cp{
zm$=FFXdzD)V8AtQ6am at CI#UERp at oeik__yAqX@`(?eWg$QC7E6gvcds6al#!3XCE|
zQzwp)I<wd)M-16;HOZPW at y}`F2;H$w93h8nVdDt7M2;Ir=q3Hk5fTXRHj;q6%8=D5
zV1#y%garTWyS!KjMMyG3m?=U4(aJ^<6MmE;&hW(bmDW1EhNuLg;HVox2sE^x41$0r
zlwRIJEs}v+%YWQx5QKmwrpW?ead9IEiBWPhK}Z~pGO8sqrn(WtB=<y8Hi8)bMi66%
zK at j5%Mi6?&xRt-$!updDMB=nKTZB?Jf{;k1G82U4P9bds(L-(gFegIkq0f~vpCV&6
zMLH7U3YveQ#$r{P&9Y2J_JsqJac^?{UEvJF(#|+nwka7Hwbt`=$x9 at iS=46f@|jZ~
z#Z<>&S=ppY<XgojZqd>#OZK`)*Tl?sfvc3|!ND!80jzyG?xota_+_vp8AxPAj at BYX
zw$U=>GYd8itWdcE5g;$BKD at 3<IMJRvIKQJ at 3g><y9zA7={h<&@7{wRMPpKrWggiZ5
zj5p7&#$mdBV3LA6(@0*4U`xD=#)ckm?}I|f_q=8ohioD9d9vt1M(`W+7!8kWb^Z0$
zr- at 99;(0yGN*8-gbd8+W-g`D9<;2%pZ+OwQo_R-ry5RNLZDP9)#*Ga-e7l9 at gy>rf
z=Y6(6%=`T*mex*Be5)BY^YoIl68pbB4>AT`^w#-#V5<3fFs!!c!LZ`<pkY0nHe(R1
zy4=uU99d<MY2f3ga?;_d0S-y!Vq*!03~8)bd6m~HWV{Jg_K6<FzDq-<N0oM;Wddf8
zp?zK{NvAiF4F~BsGbj{sQx$9GYO(f?v967pwOLR5FY8s3Bu5UzzEUrk5VcWyk0a*P
z{r~F_1e8mAeDkRSEGk8D1s5&a>YUg}0^8MV8~PsJpc7ay at ygZMIx#tbXFYd-Xh719
z-yHIbwf(^Ktopem&Bb|YLady;5`SZaoC7VN5#?Li&QUBA1<3=Y5S#j9c%o5Kl2(bj
z&B%Elw`U1?px7<RP<7gXq0CUyg4R#y8p>&+ at b>4KKvq9L^N9yQHQyO_B(<FU==sTI
z%%7Y%xT02lV=tP~Nib~4s`Q+mMW}?C_EPYs<EDghUC^(D88U&v%q=BNoG*L_lM=9a
z``llMvY3x6JSUP!vQn<oq`@Swdchb6Qrkwq{)YqhNm#~d<<~q%3ti+HYTVDb(8-?3
z_9F_M{x!Kx20Q%shvi^gNd~3wY>>k*!PhN_Qn52!`lN3>xjGmCZJEM3S<q6fsfX^>
zR7{P7ud?a1#x9yP7)?oS`j)s|^NaPk>id#CMMKn9OpQD2W*e!C^KCK&y)VuCcN;pc
zpycZ}=Y0LG=I%So@!8xZdN%h<>u&Cs7MuIb))af^KMdVN;4AmVjxvc;X2b&|C@=^&
zH%^dnNG2CdM_>akkUuP>`g?PQilx<JYK#^6TShLi4V at O)d*ZQf%oDj}Jv25ZIB-KZ
zh>pDYMeH*;5dn)yp0|SK25y7TSWetKt#U at XW6tc9;CA4NCKkBoj0-&ZaNFk&jF at oL
z-u$GeXI74~CvN8k3OreTV(^N<^W2c04}Xlyq?&>PS`DMYB76q-T^~Nu5<Ax}IAW$?
zX0Rg9F_C;`i at rQ7OwU$S#HA6 at n#42x6rXlpvCS3kff@;;s!^lM>bd*pM?&$yn){t$
z6d<Zg8A88cKY~r!HUrxp$4ZkUKpK%TOID at l?sowzV^)7 at Y*c!Fp(|sy?zl3h%KHju
z-7YKl13$uf1Zau(2cj}sdt9+|q|+!Gfni3Yu!3b$niAjFg?Xa+d}&mhN?W;VGmXdC
z@^-F_u%fdZkN5WvoX_}|+zi!(m<N^kLyxalu0iQLr<?C~NxmMExO=%IbFpaZBA*$Z
zFEruvzH-gXiWv!erBQ~e%t+*RdSJyn&d}WQNsT1nt)`yUMCF>xOJY^<R(er)dRH7K
zi5!|lwv)=ay}@wqhIG6k$=7fG`AVOO*GCGWwS1>!nIyh6l9I?|(GRW?%u_ljw!f3N
zx>~yjGW*P|y6;Rs+sa)Fm{K-g8f!~qP3^V3vJVY0TP*RW9jy))%dj_g8FeI)^YyXS
z1qOZK6{mQvJ+QD%3>oFM6FWz1S9JmNL>u#^!FmhaCx^N53*gK=QHoJwTWcCI#(es|
z^NUraF!r;?>;s2je0(X=b_V(w{(lloz&*rntl3L~xY8ru?dW7^Ba_7~n)5v;uv72Z
zx6kT)Xxv_2gMs9Hh(Xd19hqvz82-Rs`92%=z~E&~Cyu0}4dM&U)b2a)P_tm)MCeUz
zVAJe<&yz<sYT`Wdml_BPHF8;i!wV;nqS)dSr*&H at G-YS)!jCHZ^|uJtwj3%?f+f+D
zU|m`_!Me0au(a*0U?P!Z-?wCg(37}Vq(<Nw`(&<92tnZ84{`69e;duQY2~uSy_mKm
z{y(}7ER4SpObjoq3W+>vD|aD5?Lwoz6kM=uEh_q2tJf~HdEwyhW2i+KluKn83Q8Ba
zoh=o8FR)3!ZQ~Q!pgV?EK=*S&-zz1-oY}JFle*@O<yD?Il3{G}Xam5uOjqLnmBExz
zc*Fv;+kC`I*spDkxHXfTR-?o=XAzdq#I;_2736_pw<P1#X+!Npaij&JV-b23(*pVC
zntPI`PXGK&CZ5Qp?Ui0f0?Nze=zREO^5n$99rN6}7tM$&VzvyKm9D$q1*m+P_EPYs
z^Xp!0af92HFLJ)ZnG`Q=Y%hF=GbKm>Tc7I-$e7~y9g$IGZyDuGxw>i7V3M~*eazQ`
zsc)m-8t}qa&K3r1>4Vmq{N#xDCgZp~oi_UCXDogl-emNpMN at c@t0*~<t7x+F=Zver
zUlJ3ki8fb$N|Jys4y)8qpp!>uW2}nOJmbwMnVn=~D8*L}`j$O7!^Axb-Plz{MvXlg
zsG23vb1VSIgVf*g21u4sV@(FGOb(PB%BW;^H;l2yTJMb-wa~4(7d`Ol4!0z!H@?uD
zl7Uy)QoB6dVQodfify#^$c`9O4=lD(>q{f2b$+3fm{oPOeO$$kSg<&OTQr)OyINxA
z^YkJ8hNT71s-}Q;V at 4Kn!E+_&oHtt3*I_GLR!<V3TKc1l$D`zx)91qtYd$o>Z-bAR
zgM^|9_j#z`kfb^(#uP5SK5#r at p4c3T!aXaYZXA=d4(o|-P&yQG7;8!wG89~#HFYSB
zb>^23z7m^h_WkjBre9s-L^6{)c8p04W7T94BaoU4tDVpn7KslLl))mI%S2eNTK)A~
z^?v;&0y0ZfW3;>n0Xd=v0lBp<0&;7SfXw*x`pkllSWbu|sSyOrov??cz!UwugPM8b
zt<DE>Ha_?=h;%@YE&$jT4{ZHCs%vqz;whPMIu_X=1i;>i!I2K;2`m#&jU92$FKjg1
zl`CRm<Jbair^d+DcIChW&OQ<tWCXafs6zsZn9tCOX^juf at d_ruha>bn;WY&yND1Yc
z>g|E)TOE)D#5Zy2iES=j3E!98MUGK5C3EnhVDZ3x at B}tX;ATrFqEsLNlZK~O at 5E(4
zd`nE<*0vrR*d2*$dTQpN&MVy&@X>gO=R at x#s>xa3NyQUu?jLD(B(0q+aXy^^E>5$3
z%wwj}6JvHJ&5~K^yZd3lN}APQ8hbQ-VJK;~?l``~)<`25Q4G;EvcKRRP)Z^N3O~sY
z)M)JeaYc*Y^9&jhdFM3B7xT0^p9Pw9Fi$j}FO6zbnahZxM`hktIeTZwBXJAELswU2
z-8&e`M6g8ks<inN5vjR1r2pdL at 0TP_eUbas_EW%I@<HCED7Ty#ffeTNhZVD#lw2o7
z+%iUI+2HqJAN6;>K1xU|oe`=|*4`U&UuSn%mHNJ+QPnx(w-eV&=T)}1kYuvgNNOr{
zg?J#u53IKEknDT{KEQyLWY9HtQ})ZD6J~5*AZajik4MM@`vYsCQTsX?SCSYVQM;O%
zCLOjgCSDnIO&LnnCDuLYh&iuN6u#VpDSat8w37oKm7`?d4CfxSs$bmRWcln`yz0Cg
zIbJqzEMJuU&<O7>eIU^w>cgb&PW6ff1}Q0A>U!YN>nA)%LIxRlFus$}H|O0If6ze)
zFnWQf5~6h85Y>_ywYFaw!?y07Pq0P}^iAeqSC*cv964kWgsOd1d0w~zH4TP!?WeV?
zF#1&HvmMUKmB=(WP^`axE8njy>6V<1)$^TrnQ+^pookpz(j>t-*OFir_0-u8qcUe#
zMJpgz-gg%U at ho>&<_Wj)(m?afFLY9T9q at 8^r!CH(HOWltpnr?Mack$qkzh#h3&g&3
z!)feIHtoXdC{sIu+5#K{+|~Gj#U#gkX`E4Dg;dh4D{bnbl7&IvE-q<yB~rS+PqnJE
z74*jDwfa(ce6g2IuPGrZ|9?pxBPC%=vzG*6Wl>;}l+Iw<cM{{~YJ2~&Ud1?;<u)+y
zQ_KZ+AWEVr#m*cUF!l%yI52twN4~yER_RHvvEFDg!F2IUdJ<JEmiWXOJdTo)p0YZw
z5j)2roVZ3<7ni@|jkiyj7-3tRMP9hseh=&j>cm%|{V~HgcN^2bFJ8dUs$e6ym{#ZF
zBF)gnUW|x4!3ezDte_0re%5K(mIC&_ZDtnYr at lV_D(^2i)b0Hly1oB1>UjTW6ukfP
z^?bA9tnzyM^@_x)1J_`MIG588Ew5!wtOZukeM7i1k64tVV~yVCIL;W@@^}3y9G at Z-
zJ85X>lBkuLD3p~DEhwz at J-`5~(G6fRSzAX-G>?b~RWXXtaVfwxnxJnFb}WU}uzxWM
zFZLhj$bJ=GO5&ZkKhf9Bh*T`8nG;m&jU%fRcSedqn!}6?iIyb%rY7!l&uDp!Fe8iN
zp0G4bC_zIBp%CV2HbhL(m`AONN9r9D3y29tP9*Os{6s97MmFvdJ1Dwuu0<tDybH&V
z!xe8U(P+Q12{T6j&M!o2DjnF-6KAgoc0{v at Z`8##*2F%f;mSq1ugo0}21v#Xc at 40}
z`ID3}e4!o6DEEN-%a=#)v0eDSPefe5X)>`wr-RtvaEYWN<R*F^4|_z7bh2Lc!5A;v
z&xpvv+O%b!xZqfgd9sQ+j7QqZbcg5sb{C)Y^Hml|<5uEj`h6 at -e<&CdKIZlaw!lU^
z9-$-BSEWZFRiqu05Ogl>ky#`?-Yzf+?YcF#*Xv%rK+Ai?G>i~ICn&6u`bfW!2`$a3
zrlZe`w)(<0cR$*ZH8Dc+BHcu9BhpaF)y88JNRC3A(3ob!$u(C5#*Cg6KO<VlH at Xhm
z2Cn$@)oNH{7GrB}r83f)y+K^LW_vK!(DoWI@(RP;A(tI+b=&7!pm6EvtHnSsc;JKE
z+74?+RF(I^BA76BtDu$G+IxbG!t9_}lJeM6pSB_GmDv5eum<<^GK9;sGq1kC-(aRV
z0q!I?%M-}<Rs}WH=Jr-y_Yyfn4Le>1PS^%}%NYBcib$<Ev!t-^?uFvK`&&<wc8{3s
zcXbSA5gkz;j>=>|4bZ4O+d%E^HTyP9-I(_LUD^J&v);I|AD&2UD1kn)V&TO%GG`6r
zj3&GPVNbHaH6t#7W9(1V4)%uogD(VoRqjo-d_~bGrVa7BW36xcmMRyn54TRFvyyc}
z)I;)e(@K4Lyr@))A^8e^$WOjWLN^JiV3`=%<X9MO2DZWWxIfd)M=j`7l76}+%~G8v
z at ujnWl~>drie#zVPiW>l>+264<q5&1&@09h)|sWv)8xihLbS4FwCRe-Rxx}L9})_e
z?fwKpHuq!ld%#;wM1)1@{Vibau+OVth4vWk$VYx;?f0i89!g#Cv<9BLZ!~UV4Gd6e
zI0)Z0Hh>$Oum7Sr>KJ at e_~rsHfwE~FVt7TYO}1$nsS^{7Bl>v3Q8%A=#Fml2HSy|X
z>xc!-m1S3P?-^jl)L9eqp;Zo~vYMRVqjlnUF=(aQ!1B72)ZOjn1}fX}<OVlv3ANh3
zhK3!hwf%q`7_+EkVUF^n11+ac?5VZgJ3F_nf)S=IF_mvsBBr3}^{W*eK at 0FAjxO<;
z+!ID5wb(Bw@$iPxU)b5t89Rc`>?;^>Ys4}Whtb81qDWg&+{+r3Ou at y>s)=nJT_U$2
zTz!m$z0h!wdf|3?l at t74g0z~f#712j$&Bbx`vt25BL>qNZ?(YMU^u$2r%XS;*X>u9
z at +3uizObT}muoGi&9cQKx?L`ul{9(Ua32XrQUp!#Gbi+hB?`t%-mo(#X=(YI**GQ`
zYxRt%0(n3)a;{;$FpoHi@$8yrYNV;iO;5S77Z7XrL at fKAuaKqVS2`v?fl6p)Z>kC|
zU9-Gnli*S6i>3MB7{|u0_lOw=n+wduCj5kS&RDHu6ER?=3Clg^^WosIeV-q%2!Ds9
z)hxZ0mN~KT2;rF-_(GuKDpzHq3$VpI&2dvCJ|0(CBJ?*&!x6(Km3r_p`-5?)qI!+k
z*YDVnhE_ni&SLRIk?Y8`ld_Q6m~eBH=V~Y?^%3Z1I^~IgwK@>7sazCuR$8K&Jrp(l
z+#hwI#v?Tjvid`bJgU`i6d5GZ9-##|_1LpXsTAtF=eu$f`82Ud2P}#HJ{Vqa%Qss8
zydw|sdo><*L_(ej#4fRsi#=i0!OoNgGGgJ*W}!JEzLUMhDG_*d;0EvIkttAWb!***
zd#ol~xgFKDQH&0U)~;WN;#Upoj&O8P at jg4pFKnkrZH)GlDqk0%C>y0>H|`nx#QvQ;
zfm_9G&5*;u_Ug_fUS25hE?BcOC(>?=q;du$uG$G{G0Of#g#w$6XH$?|4Fen7mij1J
z9+FBav+>wl+44c=SanOIUTFo!H3Xs02)`&Zil^ZsS+IC2#NBrk=*V*(@<bo`#wAS9
ztofT=J5tLg2TN422b(zOfE2|p5r~{8SE%T%U8e#jT~>RI7=sHm@@4V^4`15e0tr);
zThtdmw~2^XugQ<ILYSd-eZyM=?9;OeXB~IZ*YRI*iaCB9e-@{ldVY at _Y|<i2vp`_h
z+;=$?iV-Y0dG;;7 at IJ)9@))Z?fy4O5?Rd at xj#^4I`i!uHTJ*;e4^*a4TH-<fjeYpI
zie$FA^7lyz#%=h at T3`1SJ*d4#bTYputKwls6JeZS4coS4gnKC3mneyYePNE at I4msY
zqZUWFlK8;d_q#ZwD<a`xbBomPNJ}1~_Xp$HtF&tb3i*-iNYnOx=m4W<Z;#0An9;Y*
z7?{x(8ur+vTN6u|Ja<zkWz;ef{i6S$h at g|lR<`YaB7IW6hB0DnM=h%|x;~BWL<(id
zgPAgGuMx(Qh=)kvrQ0<j0r52?d1jj!OtNOvzHx1fGZ3NEjTJT*aVunMN6(Bs at FgfY
zJ_s-`z1v(oiWro-6)~I!-=_n((xKEoIHM at l3BtY_$UFw|Rbo+g|M?K-NR2mY at qfP+
z-?bIj;Xt3iK1%-a```ZIfBoJ6`ge3}zl8t(`0&2%HzhxQ^G at vPwJ6yWa$5oevqS!B
zNniQv4oN<#zCM2c_~(bWHQw5vI0SRkjuVuYBH at 8v>J$08BHl5jF;eMZEo8#6C_Qgt
zOW{gaAt?hMnRHd1BgUp!^cu%nm4up{u_NX!;VUDCkIYcb{0LQYa1&#a`FVRDX*3fx
zSQ`i76SRlbbF4a#71_B6`1L(C`7D~nQ+|@;sa&h$|LAi_>GVYFt-CV}(Ji|X;G->N
zcSZwfM|P+82e!>5u46Gdvg;TghN3#7-`Fj?9<efCBla^gW!D)~$YjW_2gKHqUB{J5
zp0fL3%I<|zc4I#ED`hu6&~MfC9jqcpbz_Hgo~fyMhFf&wkbS-e)G9}GBPkSqif*Kl
zqMD)`cyA&^H`3nLCAuEyb>5=u5u>}M#QH&0|2RN_jg8co2*-z8y(Krs^l>CN4rfPV
z1CL_2<VL>u%*2SDU`npz#u}vLdV~*~R9uH9^C<3xskl#siW>`T8uo;pM5g4%rSplF
zk{hgAmkE7%_(*Otw_YP8FYA%q$oDO{aU*LS#f at 4bEmLvdwUs_+dICVycm@8-0A$Z2
z1(G=)P17W&=a6Q)^@N2kMi#d1Ih<JHf23DCu3f>6%(aTU0R#Q-X6(#?0mDmhW=Mgf
z+5WIt)t at Uso?xIrkGy@(Ve?b00!MUn#Ja;RX4o~tpp6GSpgx}y9&hI>69n7>J>|rM
z;PZ)+HGzG^iJTO5V8XV&TvTF at XT}8K4N|IO=^N^pw4)jln!WKG)(M$o at Lo0NWAox;
zBe_mU>VnQ7Q at QICnNtdqtSRMzwlq;af7z9w{Cf1e*j$V#Y_apKD|AUK%@z<#z*Kgo
zY0u2OO<`dl`xSO5XO27NgPudxT*qb>n%UQhAq|1c!k!w8QFgzG<ucLWLz*OJ<!Mpf
zN~7t&|56k8<6+NUU7|{ev^KWjQYBK~rJDkb0uAYQuj{k}i#@*D!xNF)a{`Id5^iBG
zVN%xogIqoc+%C0NlRvlG!?{$xKT?q8Yk20*BO{Mz1m3_NdADH;n{iD|hTDsa9La!f
zv0Hrc2Naq&C+%u1nE5XzSkG~y&92=KYu0V?w3WGkwd6Ccm4KdgTkzjjRM#C<M519R
z-0ouO#ble9N-uh17zJc<vIBb#)@osWyS-Ff$y#{C$Xn(+`FpO{I+FI-zQW?s&N3#w
ze2QH_)hL|B2Jb#~5wM6c(2Eyjd*@a4#746e6*BPN2lsbI?`ANsMgBUGi^#Z5*02aM
zTUC{Zq~gFOpS}r7^W8 at LL@M8nbv-4iF*xTdGln90I|M%-<!IVR7AN|~@mimIUFPLC
zua}D<Gg&*cRW(b|CvLYW29~ZhQ;7Y`zQt^!O5hOZ1wIblo-d5hWPE at jc)v9UZEEk*
zbcb#62EEw(bKShUD at o#IAo<F(X&?ua#4LM&U-rI&54~lvyTg**vl1^VnhZ~4Qw2>n
z&}6nq&}0KmR-48>K{h^zB^y}sQ;2e?g-T^0$@A;PQribfHjre|h5$^fN0J6fHjrQj
z6eRiBBFT>(BpJ^WAcG^v`*&$g5iO%9NHQW6W(Nnx9oFT<e8M61>qN<RF&a5Z1Yogb
zWYNgfgC)b>v?AaPELl+wJ<tkYA(m`l$>sBqV!ujn>kl5WVuVuamj^ug^U!1*(FO{d
zjN4sS40EJ at Y+m2;dqNo&Nj8w=O_6p9hq^3SvQ=eREcvm;l8;9$8E+7M086%dn4MTM
zs-D<J!IGn>4+lPtc(Bm6zS}2I622i=vfD#^L_8Tav5iYJPSnX(4xaqmcwyxJ^CNqU
z6mwFP{NG;^5ITA9!1~v(A1VI$=U at NsfBnt>`Zw0J7vX<CKU#8d_Ko%z- at c9&)5rC3
zEoVWXEXOr+k8SYlb$P&Ek)J>Q`Qsn%t}$`{jTU$^B at I&T at hXt^d^|rNk8er;96h;n
zUZ#6sC$+~28$Hi{=ouIQ&zMbnlqdSeE}sI}+~w$~r6;y$dMEwlJJ`m{0h1r$0UHWJ
z>>&pSj=+O=JHmR`!mf>W^Mb%`dGn2bom9a3`CDRsMyl)xIclJmlXTbCK;ijp1%xMT
zi1W5E=VUuk0m0Lkvd!}~x}5q3c6w|);M=+P=frZQrXIE$cHVGYnEL4hC3y9s!Cr}<
zgaW$uRzR- at 3W#s0pRIuS4WU8WQB}1Fh&iL=a)iE#dn7wHFV48{iJ|ohJcGTYkSKwW
z*)#>gegKJHf=dVg*QNye^5}O-9>-tW?Q<j$VlMqSe$pYr23pEgi@@a^b~Ek8v0t%S
zj1H_TfLP3NY$hSw{5nxL?U_tM6TDCXMZXLcv+;>7%LX5KJ5;xt1Y&BSI8*BJ5Kv}n
zpRIx7rQ$-?*oD1o9rj(lwiiIDaiTmO5m$XA593(sA)Y|0XvZ)+tJKP&2x3d!4I39R
z?N2rOdoe&SYT8x8KjK~X%{?yB`}KGzgJ9QOK3fKbZDM{LkPLo6riX;Ub};^IAq0Es
zcM2hRtnbB*ZUx0 at 0vlLdZUUl=-PfOAr}5Vwo$I4t`7SD<mVNjaSAL7x at CBAg9H4~4
zHZjv)^h721#9YE`gY|+Cg56bL(&zBZ^4UTtY$XL!=-Qinz8-IlFgxcj=@V^m*-{Qg
zOp-g;4H0#32g-O$_B!QIWFiYaqf(wXyYlDebyEO%(z547k>aBqib{%gP!2`)msWmU
z^!86KpWoYw56tpgf5`zc#OByagdtcVj8F|lkfVOK8iHLOihZxODRx}^(MPaX5)#q0
zCPshCndX*cEMIQxv*plh-*RT at 5y+wY2I`^vjje}n5Y$5ql6GOS+SNZiU&?xa2btW0
zDDor<PC*oz6zzl{I*Fzp`mGQI2yec|Vp0yl(?gtWITRix3vvjy5I4Aun^S6uK{yTB
zD;^{xgA3VH3Lg;rE|!l_>R%`N+H0ePJ at tX9^J{W%%)&2N;};- at u1z`g+K at who;LIl
z-#<TB4 at CqTRp_CJQ1FeU#2waEKYSvI;qgQd)_%|$S<y<N9*Q&?NyTb>Vr-Hz_(ZSV
z)??^_TnHG{L-4ejKUe)Yd-GPAfACQKL?|Wy<{5>pOF<N8w2f+JiqcTCtEe@#V>1Cm
zl5w9{8V5)s#F1=sCMICU=G&48cFVjUB++YA5?v1^QM}<OB3PU0Q4vMq6FVozd6f0R
zy4{Hv4bi*r3Dkt02tfq9il0yrMNw=+(~J{Iy$M0|`+)s_1ra{u?eq$w>pFsHyB<Mw
zU0;HzIP0+S-w8rZ!QLK>aL*Ew2qWBMX<Uqez4`@-n*IIjf`r?p)(aAD*L6VwcJCK7
z_{5xF2lmVdM%3c%)gO>>N7<+akf<ei^8txt3nU&pKq8)R7bM)yX``npA{+IBL_}y8
z0^$zk1qt_PBkTiZ)r%2G(q?$X2=^p$gun=-b&QJ<k at oyx1ZuVH#R$}@_7 at Q<$XWh_
zM~Hw>MA)_mZQ5RpK=^50jKJ+`y$Im;5RI%iV-JX&6bmBUZktw*UBsbA3y5%gZjK9x
zcx*w$@dzUDhTVvbpU?mcBM^kvRbT{S><?u+op?YZdbd3%P!zi$;r7&m6iC!0y&#Z4
zl{WntvY!cy&5YR+xr1`~6`n3mvl8drdsV!sM~^x at RlcXTFmu(_jG_An8eaiYgYQQ{
zaFZD};f*#Q;PT!l>d{j`bJ)!!;R@%}Nz2qA_7NwtG~fzk*tVC9;^Fbkm?OMls0~)w
zJ#lQLoe)LgvJKG}QSyl~c&|F^v3ZY~?KuJD%6h{JyA*vRb5?-^41&LF4rkA=S<BGr
z?clGQf5eo+=At8?_4tR#fre`{L9b8QX{J3hlePqhedJvjt+o~?paC|3G9}mI`98jW
zX62Eo74}jGwo!Jgh=nu9o-ys-!Gyf+sY^A^D)i?sweUP1HY_PDKvZSOd<ImO9~DCO
zQ at BM>f#$*IPb)Nq|F(wbVSb-TiA)U~8i^DpWzBz$uDc-Y*XRmS9sXWx&!*-1e{4;c
zs<nO|*>gM|N<v26R;WF|eF`_6j%qTd!@g807{C8-QwkyAaJi76U5!;+-jN&IbDZdv
z>~DlMZCgBT%g(Rnx<cGB+SWXUd{<j6vH47JE3}vj^OM{y#b^&Ljb8M?>{K`@SsYk}
z^;)sTEkGg0vg}V-<!HCeSDKOnEW7s6VUMRy9>^TNv_B!HG3S0 at HqJsXnNjC?FpRfk
zr{`7m#KyD~l`^l#LlaM4?~ZUT*6Y`atZ_*;S;?h&Y*n?^Cq~@!wolNT?{4B3()#YN
z>nTay(K*vAGlsG_^Fuh~QI?^-WbBrW=CwZex-85)#vU<;o*CMwRV~x>iQ6*53DvXb
ztRVZBed|e&Pw>p2`vxD2ZqGNI-1n>}7=-s-W7wuPkD13U$~Jk4Zu$K^qz<~4X{!7@
z7%Y$HPRyA9OM12ASaKslzfbWlFbn=awmcaEggL at Mj?iOh9bJDjG9p=gy^tle(J!*d
zDl$Kjk%L~MpY4EeIIdvT-$HiSp6t<S5IgEXuD{*F4=t+^z}&fIgOUxW)lTu-L0Wcs
z;3vg`Y%UcWn1g^v>j!f~PyKC0UA(Gih~YA0HXPcKs~E>Dz=>DIFxOggpYsyVw+*8J
zEzLBBV{sg63$SR$qe8_is#I}&VekbR8U|;|5``shQ3olUXYNG^Iv%%{F0GV+aMK#s
z3iGolrGOI+w<?{Uc_xciqpV);7ZZ_c;P}>!^IF<5HGUu at j>$2dp&M$>eZ&`fQYB5U
zuakvRiq4qCIb~``s at xHNTJ6%MxVPu&;T(8w+$*3<`3B5hz_Y5lXHzV?rncevk^WOf
zovYq(><D%ZLC at zsi_I6e&#6k<HG;jFfNdza!n_jIz1k51*Xwy&oPNC>l|q*dR&AxI
zgHxLdJJE?l1+=;0u0bX1?usL;^06f7A{<zZxHhjOx|^p4IgvGQ8eTAJ7Cp1Xf>B!}
z at 08OA)3sfc>OLs-rdR|zt+y3h14>Iw#+*p&5ZLrXk$Rj-$;H%6;~={-mE*zjHWo(@
zpC?gS9Dm0Ews^gjSSbjVAOFJK(b9TbQQF%Jaw_*1kfrS$;E6}e{q;3s;MTuBECi`+
zyG^pcZ-~%LrXGQQ{QOA%<NGha*{@&i*Pjq(_O8EQA8jO4hyC@<^p at 4aL<T%2YXelN
zVHz3wyxyxuw(B{4fB*R1%{9a#6Y5wb@(h!lT;c(Vnk4be(p57q at eI!-iiZ0J_?1`^
zZ`k!k^DglQGA>8ejO?Q3)Rf_w>-Cg+OA>Dw$rRNmC7xL_JAx}bgGCC_6`tX$rX-1H
zmgW*%63=k&<ad{N16;@|lq7&f{nRBMu$<x&@8BZ|E(;_cV5_eq@%)pb-#N~qUPs~K
z)Qu(M3J;eYENdw|b4=(OS9oySy7b#|>tS27<T<Yu$;<61JOomoq`*V$MftAquG|4}
zd`Ts4Sm|qWg~j`~Cx_T7^OPK?j>5w!$xbft4A$~c%emDdAKd$*BTtyExv(l<LPDN=
z8F2(9jQGU$-G!fEMmu(Wcitd<cfN7--8qExogebiZ at 5Js0lB{Bem~DWa#mid5|C7Q
z at S{|VE4<@pDZDR{__r*yjNFX!ZWek>hlRp)vCw0BW1*Gg4~h{iv at 0*F>SS8^(=A1r
zFzt!st!%WH12+vp?h?aYy1g0!0FQkohT%2VojS|nHm}jZaOvt>NN~eVvq7KQpiVlG
zn+Bs3?s{XpzLp1Wjn8{0hV1qCpGjhCM^W>F<n$9RW){4{JLH3T>sj6w^sN`nLMKi2
zwluY&4yN~N+`&oF4l%f+ at J!T!2-T*hnmGcK51mi96w at I2A1vAab61m)dMs5^9m5bU
zJu8dB4!E2KsR-$w>tH!-Ukk#+*2@<CHzmZ=h!E~2d4O)Us(Dz#*@)@Jh2s2JEXv>u
zykSdEHHS+q+R}(DnNqRZP+TvFcTXZ7X7<#rZ!5}VBBnu{M9rl|R8~x}(EEsz&NKwC
z`tkwKO0kL<mmP=2i4<^4iVCJ4wv6`-MW(7HIBIHAdGp}rrOpM3%TtODgJVG6jf1fP
z{cOFhNJTTlW;m9n3iLg?zb_SGXMmz9EvJRRc9b0f3(NE(!W)K?VDTHQp_<}QL9e}y
z7Y```;O;lCu5vK%9gNQv=G&b0hUHjkSaZ_`PG5EgK3`o$)$<#!9BXfjp0kXL7b!61
z1-qu*X=`d#ahaisn at TvEc;@Uliw!$fHg27(*pDmP;m at I9?t{5w&1*qKAJZBynU#dr
zA|qWS`{`(0SCq~TcZTX(oov)?#ZP7NI2PtC=M}K1Vj%|GZNB(XdcL3FZ3e4ATP=(o
z`y>RzJ-;MKh~QXJGcnpVd?{MWDLj)}zG&F)F?2?y`F$_eCypa^Wz&)XXF!<0kz=z`
zv>t4eYk&Rs4_`CwPUW=qpO;1I9atlz>-V)p9Y?>LC3gyB*YAeQq8xVpZn$+~>36dX
zjkS>P23Mnc!3Vcr`p9>~(B03|Hu%)#yWx at 97bM@!GP?x5m&UfFk`&s+d+ at l@?>ku?
zYXE_MH=HZu<@z0%;gsStLussUm+!#xiOctckK(&5knezn<(J|Mk{XilI8$dAaQ%)`
zi`QJg`z at L2((h&oUUU6!xL#f1@$1timUrl9g#~Jt*U|3?q#Bb1Jc7?dxqiR0$K}m?
zGI4#~^)0;~i|coMbErf!&(JsTDgBO9)=R(}-ofa#UiW%rnB6?Bw-rtOvsI-`eO(IP
zof(Hv%9Pg;@DGe@$sqZDwoAUB4;=Y^P9XX2Cp>zcS2${(cizuaI3N<1E*i>5iT6dt
ze8l^4vc&tBFgQExP#v}>duTSaj`G}<wOcgDTCM at Mp{W6UY?!Z|!Gs%fQ*#Cv<RT`p
z#Aw^(mc|fZY{(w=d&Te+oJ<eHY_$-1LpxgIJCj*})oRz=4$IITrq*Y=25Qk^-Qwyj
zOd?$)K2Vw at aeRPe0Fmk^68)DFcNkM-?$1{hf`&IAB#F{W{Rbz>^Rc3fO$zAH at M-ON
zXvgl7*zOfmkm}wYz4*d;E#DCq>NUsewX-uaI~R59_{PdABangNAv!5Vr_}V6%hZnA
zxPy)=8Zt#Ei1q{Ns6O8pl*t!lFty>-;s`;sD~B{L&Xa6tY1IpjJ+)e0R!>(Ei!Y{D
zT1>6HtIkuCI>q35MrzS%aQu~@K7_E1a-J4(rS+jw=&s4tbwn+!uA)wK;8uC<%^i0E
zD)UlP7+I2!B~_lORC;J_-l^;eYxua17;2}lXzCL^b4MTC(OP8h5}ghf(7Nc<-B8O-
zuZVNL=+%o}^a?Qp*N{x1ueqU1I?klj(kzk21MSunj*lVU$NK2u_$)SV5tqf~j5ChM
zV%c36xG=9g^L$&;+rHkAU9euCK%&-jf+r{~_t)33fnERluw+YR+clE?eM=VVnM^za
z{rLHj{KxlSezRY{+OIz$%j{i$zdm}-KD~akI~(s$OM}ZqqW^qMBSWCqdzI-S(?THd
z?;pQ^^t4>(c$r!swS{Tg{p+!OUKXnr`%lYAQ`u=x5^6-vLAY$vT+i?-ELqgse8q67
zN}5}agBXjG)NR2az^^8aQVTl%`pO<U#oSjr at N-JLm9>4vR8R8J((sbn<NELh at aO+|
z=hK4cj$}S_u7zP}*5O<WOV>8cwZJWFmT3-45wrPV3k#H<2HT#Kcj6dZf!l?#!6cyv
zKr51Ij`R$+z#;cI*uqjrJ%tBcx=szJ9vp-1ZNXs6H;|Gr*zz0CAj2I?iGqQPr)2NK
z-0Jrj`C#5-DUrCs9I;<9*aFs=m3*>w*A{l{#0AirG1=ajlkJ;D&o#J$t{t=dT~Fc)
zGo4ZQlZL`ry2N%*Ka(vm=DugL#hsFbvJ*vyx(|*Vism|)J4V}YD;R%{w!k7~A8g%A
zDpC45%g;X8e#uZ>ih<-<%N6}t#2Eb<YaPF0sPzvj4%BiUIK~Y_t>56v1xETAVY#6w
zdtyaWgY#N8H+BiBG$NVE<W3a0L*tRBGW@#J53fv!Dc<3qMp|Pd3+FR@{k$w3X&p<)
zdSfxH36~Qs47*BWLU(1Wxk35v^<ubGVotQMH1>K-w1A_;3=6bYe>lh}J82rgQ_I7~
zr`;3Q(wKzBffj~dDNCAHgms}%(VKWm5p$r0Wi^tV2i5S-j1>l2$12IfPeAL|R}8d{
z=@HDc2gdkt8Q=z>BwZG-FKqCfX8l0_BfZ*jB}s0eKd0ym>>&RiTizN1ggwGQGK6`C
z<mmchFoKoYy%=lpjMrqbDw+HQgWBP+&AQ7$G78_|6=R$AC<x4w=g2bN0uK8X(_oj-
zbkD)DC^NreoAo440cNX8^Qvq+2av0Bz%V`viAUslHo>nq4fYj3lxH|^&1i4lliRF&
znQ4J-)+;4oyw>YpLAShG*1Rn2sLpS;s&Xl>v&}M?uUKYX-1`;V>@CN&Lc at Lb`2g41
zb3&}M#|5slbTPI#-Qiki{gQLv&wGx7Rg^Xnp9?L+DE2WJr5s%1O+E`Ps<7>|@_f05
zjN9BZ at cc>57PP~|Yz-pdc2<+8&ugz!_rn at oxDM>gpdVKztbf~h%ayT>ep at W(?Hm-v
z<-9~2h?&a{pwrXK!3bUwH?FsA5tn_)t?_vkF?AY(??-O8UP$7$PUGRBU>h;<JJj{a
zyh9T at goWm*qja9iy~)CTQ~{H*8ed4kDjd*|R?g=U=+UPpQGW7Lv`yJzKi%)K*Do}g
zgBz~Q`k at K_2r4Wa4Wa5CiG7WtGK$41WCd)@%R&(bYh?zV at Hs__6i!vy>dZMK+<D7O
zE;Wvz#**wEYF~&dY&=4c&^RdJLuXlLy^uWO0d-M`2MkfT`OPBf3&~lSO#<<e(jqCN
z1uzlRdtoV$LHTa4zq;jM(wIZ{mUC3kmJ_OL%Q>pIEvK5K38F2h!kzJGeqNeq%Q1~O
z4cDJUju}gi$$g5fa>+4G6HRKeC{aJ&M#hKpeqBq>rO}dOnkxF?OOBr+_#5(Kl-IT7
zz;RIoUvliSX;Stjr{-&^`Edn9OU_4de95WBSndgr-D~3v{6{U3OQC#J6v9+5%64O_
z&!KfN71$<nIz(YdJCF)96~FhFH^Bi>|M1Q?sDfpr@@CO=kb^34MU_fW1+L6`K-Gb1
z98i5^f$AkUVdWG)4H42&+l{KQ-2I>`T+I1kCN8nsjjA}i)yqN*Az&503fKj!xQ<|R
zMPu%DVAbPZFIYt;OSxec5gTtH3SeyQ7aD=6?>*~7)62MF6*ldls_NqbP3Ic<hE<@U
z7RRt)jD at SX_r77($$CGq>PM9WtCuWTeKdkqd?Bw>fZ(|MhE;s}fU1|(#W0^jd_eUn
z-LSB*XjnU_0!(+iLDjkE!Bl^-9!&jcFQ+lp#+(Quc007()<iN*A}p>4+Bl3bQ21T1
zQ~Lz%L1uoqeVf!InmgHtH(W!u2Zl22tvY&svnV~NGzV at HYXN;{>{n6`c4lX6`K*CV
z*|N1GTcMei6M4k~s+vt2yxK3_3r^<V$Ub{xp2r{>Zfz}N#Jx-4`QXL5W(>WF(H*tb
z^u`v^#HxkRt2#Ltj$8%JmqyP;*Stqfp6Z9JJE-f`StbV+D2lY8YGzXCDm3gPzR({^
zNsIa5C!?~1v(}+IC6QiQDE-(?7=#-5GD?(-SS$k#&Lc$U3wMR;R+F&T&EiW{ydMo~
z_N*PsMdLf$KaN8MkUg?jGqY9PVI#Myl$unx`J+IlN+=9^)i5T)HGxtV09dq#e3+WJ
z0Zyv(`(EtN{arI5+sCrS&fZKIfi^`sHJgp&(O=h^_-FuX7EzN+S}MdwdGo51?O~d_
z=#mpRle^Mg5GIqyiUKKmgFuN}+mlwlD+t4dTK4N<2qyQEucu at 2X-C<byu=^cYO>#R
zDTemHRjVn=WmC>u5$trQ8nCk-6Ov+b75740o7j|Gt*y|Ac(=??HpL{@TYmP|OM?vs
zVrTOu9Z?0#7&Y=~5|91%@VY-R#!Ct~SJkxx){^JR!gkGs6V_)&SQfUIcUWX=PZ4jx
zo##=|*{a?sOGCl$d8!A~?4y|Y!pP&Jyh2k_6vss}P#W4V2t)9)(~AcG?H)M*z1Hhq
z4++D~Yksp}Tv}DV3>|RlB|K2Qv?>q#n|zX)M3Cytuk(e$_3AmpSaQ!ggY})|Lsx~D
zrW>>nX`M?w&n*H$vejR!5nPZzg<1GA$9|n4n}ct1T;X4SiQPm&$d?<~hG;GMGBlO3
zbH3cbmlZrPq=q_Bk-8sX9So&2rv`e{u1xgc7?CRQ<@{#QRQ1l68~C!=!_*70e>z`o
zV4Pxg^_In#FWLFBzt28&zKjEEBzNnLwyE*q1Q##5j4Q12$h`D!w*~6xLTUu%b&+KR
zaWNTAmJ#G&7lZaqM4e>0fh at l+uH3+t#VW{*8<=tVg+|O6e&qR~=|!+buIwAG#*%j<
zibLdiF??Cvw?5(OIloy<^@5XSllOXK%WbgpgDtng0E;XiQCv9`qRMzZYOuK&{7zIE
z9&FZ-lVv1yT~s)V at Zcb-_QpXZgdcFO+`yHIdg98+$O=p%obO2=oh*O!7W(Z!-?EiQ
z*~W~L{r#4V7SCjC0 at 9DKZ^?iB at wdO*uix$0zcHvS1^;_}vpHvtzh1vFJrlipRK`Wf
zT0%847+bxqM$Q(4Vpe~A`^UH5w|I=X-<`K#nq=I-zSgIz^j*U+puD?}V~<IuB&4Vn
z^uslx)xHawJQc+O6zib!U9jsf821y<`-0ZNh&fvtMM||TnJ?{}1BGB$h$R*OO)QHe
zI+3QBrj at G7<O at xp3Fdf-8Vr|a;wJt9ma=Ep<eG at vtUS1&Wpw%Dln=_o-y`w at Bdz;+
zt9+g at +56Ip2v!vV%8Sg*BL}(2zYtyOWkv=D{q45OF at +4tPRz*4gpmy3K>`F2qT@(`
zeD0YRZ3Q*+8{I?=*PjnjL$sPWUZOk%NHtH{uLq(Su&ueac6*bpru9Z>8kSSYS%bJz
zUR{8;!>7493B9=B#a=2Cp5Zi7;2UK^I3AgGB=l{GAy|u#bDfdL(hfi&NL^fRP_8WN
zLCAz6#T4Zyi?*8Xx3EO+{<P<hKQ-)6%x~-Mn%PfSZP at Ko3))Hn31jQa=pmDNTQE8o
zogSd0w+9%2F+~AkZ_LBNwUTX`JT4h8WHxCS7_2oxCz{>lSp*BkC%$RAF5mlbi>k{m
zP>e at 55M$q7nu)pSUr=WwzBr at 4Em!cOGwHq*!pTN?3|?!b_Q<@(?w3Ka;iFz^%VpB_
z;cFfPHKv9>4JNB<!tRK*44H at Gep-+Wh#_aWzuKetNrkq9T_Vb=Fw9=_UbM=7Mpi2G
z-ek}o9>#!-`iOjC?)+x3gJe(MFKM7Pwuz4x<<VnY6l0Y6>$5s_tI4sC1@%i6JRc3~
zwWvGiQXWLTz5e}Bk*^*Fn}m7=;BJnus~DK-^;R4f3zbh;lu8+0?6D+hW}-TxJ><k>
z{RIL{)%bleC)dNaHKi~czs=TeW?~b)E*qx*{ioX?G-t2)x-?)&h^gf}MIATFyJ#S>
zH~M#t5X1vwNt!XBRwh?IuDi&-_uz at y4IHBg*(11=0DT~+*TcH_&@sg1Uiq}GCi5{l
zKbkki5cW=HbpY21_r2(ay);1K_LyP-W(XiOIV-su$<Pc&qycLoD<Zkx^0TX58e|!w
z1C#|$M<lhvoN;M~G88tZE4*&&fiT{Zg`QW{8$Ag$Jxw4Ohhd(uK8(}C&ZRdjY`Caf
z5|{?^m<5}SXISc&7^YwJ6b~ZwQA<3cY72?#IvVHSUL5S{mFYy!gpna2GB>-%4hFr+
zE6}{w>tfG7=M}TxEb10fuBw@?BTmf-C$eg$6*<}8<hWR9?9(&9&KJOf_H~Bkk-X_~
z0=cIbr5xhrx2Uf}%>0_=JO{zds$0cL``%uWPAyGyFiZ^e;CTH=1p&f(s%fh+Xh(XM
zLxopn at -+_{MQi$K1REoY4^)fERm_5JU=<Loqy9`Dxn9Xw_MP{1Ed!K0U0`rZmzR|>
zTv3}&@HBG70+?P9#-18a*!7kzdomBXH9l{G%He#(zOQ9(k{iJTwd?*r-BpfcS#AUU
zK1E+(CJ1gIZFw>jp_n67XbeS_AvwCf0AzxXuUd*Wx)Ps{3)akr8x;0$_X^%12jdM?
zsJS4h>gm>t!8gnSU~XLC6RYD3Nq#Z$h47BqK~&H(R5CCj45N!`Se(kr|FH<C_zFSy
zwp1z-nVM at jj9S#BJ#I4D8Pc`a!EhKg02ZW&y$8X6GiA`s5N;CM<ugJHny-&9?`s#X
zEsi)A5?tRwSj9b{Ry4%UiRr=#X(Idp!X?{XCgRf&Gj*R8!oCrnwisaY^<Wu{%F5n^
z#y$b(B)sa&Ywlk^Y_ylUt(J at Z`_0Ds)?(@G=;P~0i9i1M%irv;zuI5_^m%RX{LjxH
zEhu^W`J0VlBb!S0A~vj!>GLs}TCt$G;yNGx57YDEA3y&7!|E at lqYISfblwWX2ueGa
z&&Ohnqo~pnH1uU at 3%t78!ySjXaMo<i;>IgD|6>v7`~ekA$}2H8j9T~qg&(v98r=t0
zbRXM>2R0ZTAIu=jaZ4O9b;knjSg+Py950 at zd80k>feV_}jO1;wQq>;VwL#*K<2)KZ
zZ-ci;H#pgx-z?JfSmKn@&qL!DLV~!I_lo%!q6Zh(p>$OPrfdRtjF%5Gba*PHqEkxQ
zFT6_24``Woc;E%x2k<H&p-(h+MGDB$c!qQ&fYgAU%1r9*s=%M$^UkHEe={~Yy-}Pm
z_)7Fx;-%CsULq0m1{@SPas&!<7rC;|c(J~5k3M!=R>uj=r>-#@X>i@}E^WAt`HF at O
zrzL#&4m=|oE_M(6h)1j-?75(EpnD$!Zk-$UMqiBvOYc2a%*9ItQk*AcAJ@)!LsX9a
z7kO^$q`h!H`mspev0~AUD^jxkjxbpJ;QE&8iZ1|*&9J-!_wfp)+N4D&L)y_2UQn#?
z9E2Be2iIKmLcy~NE;$x1T~%KAc~)99T1o>!_Si1q*5Eno$NWMR3P%(VK~j6aA9&cR
z2jgLN*4K(sxdGB;G5V!u at dg?5J0QPi$Unbhf8i%1(^8qUbM40sg86y*$+f6no~+S=
zA5Xty at e!rQYIM3Qch{%o^JN)3=fK?Kn`H>}+}wCg!?w;i14dri%ui>a$r~#g_mnW2
z(Dw_=kXL=q5OaYy=y&gEOc)AAzjyjicjb!BTY@&uNHM%av1c1EEcL{ImeSa9D+H1k
zPT)28u$o<=<Ebt_pY}LHHXu*H>QxxE;3#1EF(<I$Z0M%r!XJ0UX48ArWWcVd&QN7{
zRAITJY9eE#WxBR~Sw at 6WgPzBrrHJiat{!Qu^Gr at J{9s4rj-%SSci&ynIPSQDi(&`h
z#$nwic{SJf4lyygehd<Go`{I8kYgML8=P*>cHP04Yt<JX<9#RN(A+a-cM#D*!m$HO
z&#2?~$~%XcG~7BSySQ*7eu7BD6-1}Do$SC#?aNTsI2Mo;eu5*(x0hzYtb+A9&_cI5
zUEZ1e_+2Gu=Io%$v-gV~xMTE%`#3#~ma3C23VTYOWDEKeDk_KOt_aUcwgAnuDqvfB
z at RjZ`eBOq(B|TNXTZ;5!iEG5zGR$tHIK)$p?@%OFm3F<<(sbW1HyP08>*bc%`Nbgb
z-{hFJqBM4%5rV;sCoi?Iq6<l8!S8ME><kSnT1D$<0$k$^>kSbv;LBMse12~P*&Bva
zcCDezzQW?A<CYOovyXh<8jcp!;$w$38Jzc3!-exVNQ63HtuK7YaT=Vb$A(T^)XNMT
zsB0y|<qYuY)70u?^9sG9fY3&4B$jnBz9>ts6*d(oN^-$fYjVRr>0I>z?S~d{`l%II
z at x?5-w46pgY|_WICnkQVOvCKded6c7@`&EC<xo;#KrQU_8*W&1l=pt6r;!qkf#?e-
z)^KDER-eNoEg1PS2=ORs?ckI)_X;Pmi2amGNr59zFPywnPsvbt$I)KcC*;Lj{9P3@
z(%XsSsVF8DrCZi14JOD+<%8JtvZ=q|sWy{VmM%<?$yv4Ho at P<jICH9P(svvxH4p6z
z*Q!)HEyLLdISa2TXDlcpJl8eMB7hf(QOLz>kSN3-c7QK8kEp1m*>a9F#RocZZGOLS
z#UTjRKEB4Y%(AcPr&bPZ;Y)~*gml{EhLyB+0&nDKt#U9`OL<nHsni%}`HfX)l#Y?;
zl7t+4h at 5(k0GoxnLU{{O5b_v at wsE`qn0vu~#*w;dp-^!N75L}(mX at +ZPNhJ0OeS`x
zI#a34W7L`sgnPGazv^7Z>lF)@pnPY;28-=rjQn7!GK~jC1UmwU+g?oLmBXzJrX1cO
z!Ub%^vgg4RVA5VI*g3OJW*v<qohEh|9qT7goOFER)yHYQXb^>>aZGd=nGE*E?{#Oe
zdWElhrGS$hCwv5c_N?HmIY4FwJ at TfU!9pnNw>Ec&6LZYClOU%&Je~pbXEB26EC2lu
zE?L#R)gv%p*GI5?UX~G_{k*>V)$)AB1bsFpoxYZ&<=KWG{bI;({=C<yX%-CU(fYBF
zr$<vTTClSBdG~h<iQQO%N}Crp5^$&pET&re{C3&z7LDOeHL%~77P`rI9wX}%w>3q@
zyS3jVmL|d$vSA4Doa2R8%M^#jxK|ywn|?8*Oa5dfS?#UjBn5sGuM{)P3|X^r<A$*}
zyA&4miQ)-y=sReZg7<Z|l+`X`V~m<zEb(aB=h7k*U#y0=tl3d+fo9LrX%m(#9iLW?
zn~;=5asubTZ`TT87xEn_VawndIp;z^`5pA0T7JhD95P-*%bqz>fz at yWPmGacu#G%n
zHF$EcQ;MJHu4f;N>Ltc2rs!)$H0Qv0x0XemQz$I<3Z1Ek_J$`E!H6d0o<<LHWvV;a
z-JMqU?7kR&gsN42;n9=krbTnCMVorU-+9I!+1Q%mS%u-Qot_&E?~|k?e4VedqrM(X
zEXj8=k1Mt3p2|HD|FL*v)^-$!-Kxr!5IacrjmMF$G_)jmN=FTOG at QHg@Sxq9)k=9=
zi3=v<{i=_vuPqyq>-4oq5?EN(H4IwEQ(dbDpT4ooSG6s7Nhgb_ftABe6~E7t^)};B
z8<345b#7z0ZiF<Np5yaH+1Nu$3JI(zvog2$!5LF|tq}KL?7)a^;w>j+yoI79N98T~
zMHjrw>x(swcXoYB*!|Gfg+mNn6}?<fkf=tUx<CPkZ~Wb3LULRXFBGWZjTO4k1SVof
z>cc5Y%QaV53!d<F?OzQ~20YF at q;0pv(b5 at D%E;Ck?n5&(oNHV)zMSON7p`)bxH}?C
zT<8a^Zv(HMJ4Zq=GQV?0I_v>Yu8r0=eIgPg9qN+Tic*QGj at Fnw;}j&^GKM|^%Y(OH
z at Jb&h*xvkL0k6h{>+p(}93sU_J`#$$a?HoiuP~r|D at uMjrx+QUC=9hO*pm%}Z_Fa>
zs4-AA?BMM9LQZk5>GznX_v9*ZBL~`FxE-#UmePd-)-%MY03$vN at OVb7hN0zvT>)!F
ztD2E9z%1XYuN5WQl3^;cr8vPS4E;Z0=>yd?3U(M9xbsd&?$(V3n_Hqhr{#Bl;r7;%
z;TQ@>nQ&a;5d*F+>s$)1A55|$ft#WymAJBn>P#YuV9gMcpnH2TIJrl~9o9mZ(uO;@
zOyZdxd(8jRT`k#_>?m;FtMCfyNC^Gb<Ed-^(*`0?Dz9IS?BF6Lg5bBVR<nFOTrceP
z?CL%Ka=Oa<e}wl;HyWPu2|1}-;Y=lS0mn at 0>cQV+?ycb&42{Vy-n#G;r-<McrQAhh
zoLx0>TkBOtMr?u at g7K=!8??c3H9yhl%H6mk4Q5x-ug`4D4D8G<&kbZ?jUj3>TYOK&
zDR0=pLmxhu&CN4O;lsHJgx&_L7R%j(*Lu-z+nleQ1Z&_fWV-KyYeysEC>Yse(+7!G
zof6weXuQk|4I#p_yu=>`bA_|caZ?s~Uf9kc*C0W8Ytf<{kBtD&4I8t at gx`F;k*lU`
zw&TR-(T{-Z>!KG$c8>7w(~|2-8>nh?byk>mMdcm0?<<lk#wONMSx16KM~$6MfDNr3
z$`xpwwQAvpG2Zxtqc+8D7Uu%5`6v*dXmHz^e!Uol9|t)pi2Z2jV?F93Fgx9lmqrm@
z(5^;jU#Lm1v1x){oy|?`7ryA2f<eB<sC%5?UuZ8knF)1Xj&u|I<>+ at P?n!lf-)=dn
z)+6BD;xF6s-V3*V|88T3eY3ncwY_eWbae-=lY62kmSJye-`6+FpCq*)j}}=xys8<V
zdIH>WV33DC+XW_tD)MU7Obp?bos1|O7dTTQ;AI at l@=@B6{9F>V`)n&-R^O6XSSSf%
z3E#?=EQL4?i{|D6ZgyI5L2Z~LbmF5T{gi}sFFw&Hu2g9+-1{jal%%)vhE at 1Y{=Oyi
zA-cE+y)j`bXi at 9>I+LN}kye#SCRI!ln>>mO1necg{R_#@OETs?Gyj(W?7SH4oejHI
zUIWR`OEQhzkc at coEor`%Y$xy29k%j05ANK at 9?2A*h(M{a8x5%i<J4x1v&VSt-rYDc
zImfKP!W(+D55p_J;R~Dz8fUGkIMDVrof%fiO=fqTP{o8$B2JDm!OPwUe?RVn;O7>U
z+DK_I^p;d_N|azs(eu=>!V8h(A$O;A3HN~6=gV2s3$#1)RKKW08p}vvq5m15#5$8t
zDUqG^61cX?sZbE$or_`=`Hgyn_6-V5)=$4X@%PO&7yNvZFZrlG`0p8m2ukXTxZ5hw
z^4N}aGM#MGVY^SbZ at f;KNXbwn<cdJr6vjHU6j)nU;Td+=<c6G|-q{Vx;_eU*Hr#V}
z=mQ6Y8%^_hXZyH{S)lR;$4O5;lAlY`|9sTUUxMdMi3azUG(K*$_HpV{0yp2^{w;Y<
z`M@<lB(mg4FyRohlhBK!XC$=oQjXY~2e|m at f~oWPwcx-UtiBa~UG)Q>=0*XMg)_S2
z%?bNrnD=q*&VGBC7~6-l?v at N=gyZR5S3F4#`n=*lTd}DgO_zvM$Rt)e9CptRgFZVs
zUix4^z$S1s{N=c^tsQt;d2sAb$BFH8m)ju2G}O8vZ1TnQ#&zRFN<2rYQGjv6ZVaR~
zZCd<Y1iufT!vyUqZ1j>U)}CTOb%_sTE?EN_WengtuXhU<8keY5savCZe*2x4Anxfs
zU_%`(PWbi+JDU}bCpJFl%&*Vr;Tt8s at x(JF7}4XaJ)muK0c8WnNE=r2o6=$B5Lz|w
zcml%{rLRlFPM#Z9;N}%IJ|R5OWz&cWZ`1p$tqW_6_&AXg4Nv$Dc;{@&Z%E*^lQTXa
zIE%^<#HRyS)fX=v<K;u at O9P(p8`|Y6V<GixrwMRWx?cC!XC#nq8Usl%z&!Q$lGrzk
z7dn?nu;RZYs*{pD^;<Hfen?h$%&_k^GAw~5 at bu~0a4my5gG?Wh+Kzp9blhsdt at t_i
z2JPk-#f`?qFUOvJf!7G^`J5OhdX<;PP-;vG9KFY}HlCQiD7w`a#h?G-4DN9M#+ at Bj
zmf({4B=Qm%cQhKF8lteX^hLXQV-cS4A=-VnwL_zT39IcF_Q9AZD9MP}Z?*kHl97E*
zeM-QPpI at B$2_BhU<I(ziN$#8as{fEY7UikmlH}1N0gntXy?A7QYk%=*Fw>GpBPOZC
zqrt>HJhFdOFCN+7-7c1l at bb+gpKta{!{hYu$U5BC7mrLL`^6(W)7Hf!yR*y15^KBj
zMWYc7 at mA>CE*iNp>qR3Us at g>(!=+y|dT`R{kz_!8wA=rXWMH3DpOS}0Z_0p1J_rb!
zqP^sANP0orn-$?VNkeJwQJM{J6nl+EI&A_6ZZ%!Kgq^g8!k**m4l8Q<-9Of!HrGp|
zv&%^xfn!2<%-X(;o%lwJ?reC%NaYQQ`^s;mWUK}a!8g6;#W&d1vRf}^i%B}H(1vgB
z!gmBq4Ue7=pXfnF;hLfB0JXz)(%99~RT@}Yi{D!~U(J=!7iG_ at i~4n<-}_C06(<IR
zlXwoz6O^p*l-~dw_u at Cgw^qwn<q4VWlen^Rx|4x$D)gHS>UYwyO}@IY%J70&7jT#K
z6FajfOfY01O*%bW_BxmhDfOkHlSwhjkcdq`p0fBZRPY7`zF{HQJDV;ay(46BgBK9P
z8*bY at U=>7aF6I4$v%nN2m`Nr*9p%7q<;+Tk+4cBD%U3C_u27&&Izg`o!fRXBrC@%|
zIiV{2zB#REvIYIdV~x=DL5qsM at T$q+l*|sc^aZ|olE;l?u&-YHM#qU!Sq?Z9^+_u?
zINWud=u at LH_;9TkeUt}WsE?Z#B&`clx8MR<Aj9GiEUoecV-p1Q*m6jYXIn5Ua4E{@
z*EN{h&=8KiGm_ at Pqa|NbqKgD!32Vx4ZWcjqNhV>PEE~~YIs9+FO1NN1zM>B{e!d$c
zZmtjMsb|43*Xpg|;p0lO5F9NSyNhJNrJ;z`0ZLT9tKovXLBtF at s?Bhy#<N7z7{0em
zYDN1o$=YyebN3A2A^DjVutT4jV1gDk#|+)^du`7%MzH|D9%>Tp^`%koMQSruo<(Y#
zvG`=$BQ!b<oYABb8%J8kD<ys6&RH^f5aHck2^vP^8au)$)u)WbGuWkB*8H9QDr<&w
zUT6z`8lB(h$`jdQoHXuvZav*eb>TV&4;+b7fs0k)0cIObDu0+;C90a^K}QXGT7kRI
zYKCPq5lYS2G%S>YS9 at VN&E37gHp=#IlD*~9VDvq8W<XKk#xEFK$e(1FDsZo$&&^Q2
zYO=^!@cxp;`$)i9-K=Diw`R?U9j&AGt)1Z$*67#|4VSFvO5WD5H$z5QFNL#Uu7Hg@
z?nbS2Z?ibADxpzW3WrY&AMZkb`V7SBX~b?|lCI1aJk?Yx)2%xz+_l7714}L;3YWJ(
zIZlRx7bzYXBk*cCuq!MV>mc~%rp939 at eFm?5u#d!2S#Piddqc;5C`oN4OyxEb<Mkm
zW$u4SI5(d&Z|u{&(krDw(#-w0<T;bh{Vz#=`8o9|G5d>tNW5J*RJa4- at Pz`8*L43x
zPBqz~QBOt$YMhT3)hij$q0M1g_%T`iVCc8JfEtZ6zK|a`r9d;Q5D~Alf*y(Yj##lw
z(*Gejd&wmk-v13N`=SpFfzi^m!52OTK%sf*HY^<)(ll_bU>>JzGk-6zvzb5e(ZW{B
z6Sz>rT?RKgamRw{pJ=qP!X_Cw?n?ylJg at rx<(=5J#tJUq9!rV)xrJft|EyQLj%B$G
z%;zia59~s3k+Cxe28{iLfj2N_4A>6*`(}})$LYQeZ(wxLU|sP at BB^50i94PR-idW|
zy*j$ty^TjJG<~l1v7)S(I^4{B>KbBa*!U>-7B=_F>BereTyiP&m|e-p*;h>RYjwUI
zHdApVB+(hN=C2xij6oeS<Y7x+rwZgetodtxV_RTLzHH-oFB`KcZJ=Xda)j)IVamPp
zj1iZ at E`w_FFeW|{(H+<|$Ht1z6<H%SgO3Jwc+AlsD at 64Ag1F#}IW{~j-C21G^%W(t
zn|gN at e~@vFPLD$2GBBv1gecgg>1A7-hSDRD6G>q{KO^T^K8rO9*hKHFucZcmI<jQd
z%#jsC>dHJaZMG`)!Ejrdr<(nB&g2=5DA}FO&LkU`17_FD4v$W;y;e-hy at KaCp%+PT
zI_aT>*@mEp&H8No!m_)pJr**g#tQB+N1QUGc3lq<r;t_Caf(4{t%>*0$i9xXN1~WZ
zEn<Tlx;V={V#ld-F_~HeiR>2d|0YsXh}24t*5db;g&x&oWi(sDqqac>ArE`9*BnF;
zEB^u|r*IEH6+}y>N1K#2 at yQ-Cw;)nDbBp?`WpI5+X+tLOo%r_o0nMz>URI=P?9d>L
z=h8(K&J!wBUzfB-jqsam#oz}fON2_BfkJ|X>KzNR3uM2A<gjPs9sSl5x^yxQ#aE!(
zJWk!sT0%)rY1~0LQOx3x49H}tyRdNM3#_qOB9fewc1_tSVnI(wVS0(xhvGz_ik=k+
ztx%izJYaTg&{nxfu1t0$Z}Lv5-KONeQW?PPQ7coT+GdJO3M&}w&J9?8nRJlXl*RKY
z2bz$;o_emR%zT8kX(c;Q$DbGlP<x4o%O?WWgS at 0N`Gi&?V+w0tzMj{(L&lwv$Q%wS
zIw%l!Oy!EkjyauOjy?7k3u!z=oZ9%PaZg<{kFM$>PbQ7}ORH-uuf;yEB`^LNAzOqO
z?{Z0p9jS6LR%*9&P at i;SPKe};pukjCw%clXBg&!jS~dLd{s5VnUiN2qE|!~rfB(m~
zD#cYrYt<(R>mk{8!wrf2xDZRBtL2PF`o`WKB_!=TWcd_pobxSke9n^DeNBbnZEun7
zwGn$#BM|u&Gs|b-_z)P at 6dkai1|HBGWIHXSTVnkz&A!s!0hbREjH1)mbSq=m^q-L9
zwUHI8u3jl`fa60%s?WF-+4U`QyomIiU4DgtNT{h#$nAC3%p6RLDM8*Km)AnnVjL23
zT0NuiKO>hHk<r&0X`Z7u$no09&ZmG`%Ufi5^=6Oyk%`~G{qvhW{8Z2n at RokD6*`kq
zIjrwLzvUPHe*4p3?5X|Ppugj}Sp@#`vbToC?ez;Pv6xuFW6LhgH}vBPjqY=AHZgAO
z`xQh-qX{tcR}dY`v`OeIWVtP5m>}|q*6d>AJ+%GqRp3=XrrKxw0y>TxGRa<iBy2Vu
z+Dmy4ZO0Auyp*!7ucf_*F2 at B8jH&+lZquXn+PBbgydeg#PoKBGf|lcg1l`@Ajg7CP
zzD17Pf;w0 at 4^CRpitnJ?aj!B$^kH^ZZ?$ib%WXqCo%I1>PAc!A%W**%N7ch;%|+*Y
z4;{w??Mw@%o$&><9DB8P*B{^d?b~1f=L_`~_{9tDHvj1r|DWHw#Xt8)WH;1vw^{&`
zZpSy!aje7M$FmMUecpC7$5uXFD~|0wyH~$A*dIdR=L0dX7i at M(QygwVKQ!o8C=DQe
zMvpAUNU&$BZZ{1NnPHFW4j75L1Jl$TY#%1fmKt_1#|{s?lY4~-SD0l-DRHD(Vh8Ka
z(WHmv3T6>?yBmYSt`aA%n(2TkC!!P{9XboQG=_pbQm6+RYl~>%&7Y~;9+&15?QMs^
zI!Lrkx7lXPEZj31P0D?r3fDB6;IUhnmTI^2P`6vjjFW00#RglC8wOn1xn7YCJ3KP9
z`Cd_7Q9BoUs4SV>QZlpMJljSWe$Q1c_%E-I^%NeGK315prP_B`ArTo!6E6^No(1y+
zPublbL;Uv|KX(t at xfN{IOR0|)qUHJkDn__LSrs$Z5hB)*wQ<CH*>^e at GLpW|7m$N{
z55rdx$01OCaj3~MNA3AF^4NBG)Z8B{a$j{D=}eU`ue23wiHDL>WM{=bYVMhf?|(pq
z{2_`nfmkaP|Dh#9H!bZ|hnDs#&{9QT$Cze6C%f>^2htE#*x(AY1@&omx3juJji+qL
zKwj`=JY};nI>GLsGqaVy5AmQ`U&txGVYAGudONRSgTT!0a_sP!vprU*6|&nXU{mHv
z;)`>71shUoteF0L?K#e*Zh~oHT4uQ1I#OK1)D!HH;|RI*urXv<7&Na9W^rJ~`q|=l
zRPSY`D6NfHV+WVO#<<&YcW&TuH}y7T9|=1Q(+Tm-2AVf}<nSmpyWM7|2dKmVrxFX2
zwB~jh^9pO&5!O=WT4AXgVOP;e<%}(m;z%|a9S9!8u9j*4^Xp?hg at b@I9~Bme`RJ;T
zhzzO%he|V!t-+Z%W{ybU0eig&kL9sD7aPG9s26FE71}GmP*^X at J$Aj6xJizD7M(og
zyzD!n3xUKtAFzkf^R<Oqhg;W(Ls-?-I21a(7iEoW^(os9j|!f?R+Kzgw+xj=9hW&7
zZf)^U(ujnt at Q)96+~ariQSS<#b>j$Q8yj at G|HrudufJhYPj<LR9xue1!t7DXVG6Tn
zlA9 at j=r~Maww8XF!Zd&4?_>%?%8<hpW;eNb!0g$M9UfZ8wZgbCwZjx<mnJt;7y@!9
zQ<&9r*-T;PNGsxv%V)}mDPWVDoGHwfA~#b2kwX<`YLZPAm&wZ72&n at 8qaUj99rdOP
zoKowd3S45eLlu6-a#IDuQ1amlvlH~zVuBsm%@qj!<M&+jFa=Us>&+A>2Y(;I6uVl;
z6d&p-HgI}71xA28;ng9BCr}%;-#lSRo$HlnU(s3E&H~q^$P=iR)~^*-Ex8?@K$v>I
zc><vn-8^BYo%ry?w(o2%#Cc+WfIP9c*gUZhL7wnKw!;Fr2748G0vE0FSOHDEc><y8
z^X3WUk9F-lae_ad=4OedGwr7M7FA^?qQj>qL;NnFaEjZ=ho&C#X|b>_-I!;T(U44`
zsaHNsqNQiXFq!nn3Q=Y(wNQa!p1C1o3c#64Octd_0!w|`O_wxX$ZWA9Gv#Phu?2g9
z>@k3E7`iZ&W(!+~+l{>fHkD={j}?WiQAT_rY5;<7so9i5h-D56n!^qaZ?SK2Pwiz*
z4*o!FMOyipl1ZoP2xp+TNV8}4Ba&3}13_L%{ax3Z&I0nsiK&cL&%_SiXPlUoajjTU
z7N2f?7Gn+8u4|s7xX9ivFn$Iv3WtnkuXk|}rhZT{X^nYqHNK&;QlFzjTbx=i&O61p
zIPsKktUyj;1>TCsJB6OY`;44)iny6IrZ=IU>iYWl%KmTj!bB~U$Gkx3o)`A2GcW8_
zF)vt?Lx-N`5udw|-l43FVo(|rO;6oM)53Q$r8df_IMQ5dqx)yKyN1W)?=ymCh at k7w
z7+cXhV!gJo(C}$S=fP3#1(Rk9)ggmlTWupHjSc-Jp|^?KqlM at w7*B9uU9GBu`6jXz
z9#!K=+2_XWY5_se-8|8|445N6**z-7^~`M}uB3EFvh!UipW=3%$}QvfT$V at mYv6ut
z(c<P9;gC|;y(r@(HIS-Dzrp-3>(!DhS+2sia#zsdA2wc3Mf50Z|I>$%d_GyPXEn-z
z#K#x}h<1lHC0dtyDKbl#oFR_fc#uWjKK*2^qn1Lm at x}`&@sepj-&o>_Ilj?FP0g<p
z8-uT&#7+(z+ at Y0b$8GduEhAP;ey#m{7DS<C)|bKRIzNS$r5pAI7e!vV%zXtuT7AgR
zTprD;^XL9Tz@^yZj-D%pn6eNjc4dUPIqjoUT{7*fjoSiI*!%z`*XOzxi=F%?J*dph
ziF~5%D-$FDK~yRuiS6sXCd{)Y*o86}{mvd~>r#AfMbE at gF;tKxdmu;vFW-`LwxFfh
z>7v`IS>~L5jZJ4dc}MbL$i3^tR6t6E?#wV&d7aN&B1pyQh5AaQR^480Wp<9}$t0{K
zxS09xK6GM1&F7EkeEwE<_n3HXy}G+p&+dL%-QE4NVt2>X3-^3R=di55TQh-F$S4-a
zn%Pq}P@(uvWosN<0H7Jh6AQ@=dFFh;?B)M!pCuQ39vZ|EJ1 at E|#2g3VqTezP<i_=|
z*cjuGvnha=@q^9|ADY%_;TQn}oTAdHO?eDDg%aio!x+OefQFD~r57#RABZyVDDB*V
zDdRIqaf%rkjQ+P=S+kcWND2T58T2CLajwYN2QlKNnoi*kP$zl~F5y64|KTfZ%H~Z6
zK=MPu9v#oeSaOiF at dzzthPI(7E{n+4q at 3#wvblK08cq2&lu3A5IxU90HV~XIO!0)z
z{e?1Wf}fQxj4(2-($DOlxT77+w8}_$bAra at SH|vs+0twY(D-;+Z0q{M7HGEaxIoif
zUND2`&h&CT<Yz{YX6ZnFU}XW`SA?@BpXft)tNbh{OlKGLmtQhZ^fg}=txf?~k=g`u
z_n~O#@(3qDk{{7uUov0uFB#fkbVqc$cc<T{)3*z4F#4Ti4xR95J`WAkMa@)g*4jvX
z2A^0Y^MT=ZJ;SqMSY~0-q8JNpb<(+Ac>-VNFx(1CjoRg{b+X>U<amq1H06acGp04O
zCcrb$PDbZT9b|BX at 3Eg<>52z6pFbk>$*76n2Z;J))Ot3IEc<e{t0Xljd=9sap(#SK
z2Oi*Fn_+GtfVOLLwS7bV>@9aOU{+OoS@@=f*QyPdeP(HrRcDcd8Rwd0ESBEivhB00
z9gPpax4Xzv8ACUm;_<T&7B-45pH>?wBQD7jR9ujGqT75~u- at Vei`yH>P0Ho$Yo%~}
zwe$k}8s(&ui2UFe%M@)Go#3nWBxkwO+?R&B+4>KSH8GqjY)FBeG8{JNG0C*fWVrdb
z#m6isJ(+q8WCg6vhs7P@=}aQW17`LiBvZY(VHStHuwz7$c5>ZYo?2IL4HlmKLa*xf
zyz_JlFLn}N2~Vp8<G$y~1B#kB5Af0gDWL^OVaB^~0?lE{iIvm2XIgZDvrNg468rU+
zNS2kF`_Y4B9o2(m-BuULx~)jExb|2n(H*vyoTHh>B?tdN-l5M$Dw2TjG&}TtL@$8G
zlAU1rswuBBwI=a at XV9<$#6W;1moY31A+_u!T8fUSrO4XLU`eb)3yZ$i&w^XZ=8cm}
z5IRMA#O)Q0H$zcQg9W0X89LB6pU_<U?%)+=oh!!n42yHUwTw!*y6a1B{VZzG#PABB
zu*(mO*N~$GbS3|9?VRZGint~UV(=B7B6q<``X2J^Q*rW6P4c6Vk?NG&y0%S;JW%Sb
z$xMNHhHR!p(t)+764y~r;bhs|cmWp3w%X4(oOlBJ*c)KE&Bd8%2OfhDpM*~i9NZxu
z82h8s5BEm6nEcAnUGIV at z+l2Y46t$L`F?M>dBY7D1)teWikB|>CBL(IG~UL~`9K1u
zw(E)nR2lMV5p%Zbl1)Nz(>|KjCDXpzxGfNbeL%}xxjs199udgKI%|z5PU!th<}1XT
zDnmJ9^8E+7iax7w?vjh$LxW?SA-#NSl79kBxsrxO<~i`XhdN^uy6Ty4m6~lFfR+f~
zNu3~rXA&u0C)QFC9d<IAILitc$=S2$N>zuSrDYImrG-xxYM-1b7|L15Y;Txkos~|C
z7c-?WjJvjneD{W1(~P5VFjJ`TyrQxjSv}mrx3YiOM(+=F#Grb}VjIf!vB1D)cjtgE
zZK)@pP_ZL+Yy;pHT`ra`nRwnV^X~j$X;b+em4NIVZ0EvioQ$0g9Yz3FL5n?&xhUh&
z#YgTL&psbv at cFQaz!@L0jq|-rz5;Dhm`KKy9LvW`F7uqACf=#s%to1=BEC2|?dCY7
z!-NNs(NX&gFKwx)>fs!95MgEVox8HzxG at euATfG!DOh(RQs%9ZHx|u>I!^9&zKD}-
zW7pq4#aXUm{q;xre*P8(sX at mA$4?3()suo;RyPH?tVls-)~?mSM|}79O9SGNa(Ie!
z#Zt6z6=LW34$TZ=42?}5SYQOWXr{RJw-en1%NRZp)EY6zCJROoaxIk2Z<!|+8ves#
zBg^<gPA&hZIGy6o5sHR_fC4Nf<ZgU~7s_MMscGkgfob6tD5;PqpoVvX-a?+d0{opP
zK!obZ at TZu8Av=A_h^!8zCdxe{6EbSD_Pm-`ddkiF<y1>eX?!Pmyw&y(MrppXra1k)
z0=+L3Ng=SIjuZzf^a?Cx2DYKSUKWw8NqJ_RBA1Id_}I#}p?8H#br26jPR}-fz5&G(
zj;ek^jGAa$y0kMcz0u7a at 3^8J#9*+)jg9sP#JJqb$lVWfF`qz;kC(-^{`dkALl^1^
zH8w^%!E|DP(#QIcpXodrM_0eT5KU>?<BDincAh~efVv<0NRY0<SK0DQ=7Em>_ONJ`
zGMY+8Y7 at qTQyj4zEWWmwo)diklKG5(xk3y^*W&j at LxLlShBR&s2w+_O`=!CL51C)<
ze`pA&K at M!0>6Vp{@=}(@A!=+Uf%q~GdCWA;!|YfPSQ&U=Zyp${iKjDf)3^%^fy-@(
zJvz37idGMcrsffAW~1ENU?FQkX}J at jBW@auMu_j+GLL+<hKHu-fX4 at zw=p)a7*#EE
z=>!;2W>yQywnyd-%hP;f11pVM*s(ZRnaQ(*TnsfdJ3PBK!f$kjrkDV0BHl(HO24vE
z_|4+V=j=2Y+Wyu-G#W9oVQTiHpG(v6Xw`KyA8p>P91okftWaQoyeuMkt`D>n<+Qgh
z`?dJc*+&|<<hNAYNe(rUzQtrX;gFpIpTqWvY?pQ}0GA4lC6{Ws^ARvi|5iy&zwkl?
zk><vWI-AWd+-SV9!Od|nX*pyA#oB24CeE{rA*;*QZ9370Dx<n^&o30MtG!+2`s<GZ
z{$x>iayk{y at 6>pu#;S;?Th&k!$=9`HzQwxAb%`I<jBZO-O|HD}MhxOv?#9d$tJ=%L
zw;Zh`o|=+3!>`T})H-QoGlmyK{VA`DgdNQ`Ed|b$Rjaz<G<TCzNLA)oPAxSBGSSeh
z`9l_wwE41V>Jno)nPue{P&%TLg-Gk#xOS}<kTUdxU##j9 at xo55wx;Z?%z6|@An9|n
z^8ceD+x{>|y}mTaDg!d3-^#`adKVM!i_h^rNu>20$O>7T4~sj<E0JR&FC&}2xUslG
z*NU;!nTz*_9IqUQ-X9I?1T{}|*1<c^D8qWF)K|`=*@#D?G5O8|jbcO({L-Q)gUp$>
zD6c|>wEo9>wc}cr+rYe6aW^mneMvEP=D>h4OX$q#4kq&UO|nWlI?wHij2FCH1f?U9
zRIxZ4lQPSe7MSKb%d;x+^~k>epC$k=b!PxP+GFw|gX#P4IpHyRZ&|u0fFP$BS$gPm
z`{eM}<9j_`Bb&c?5Ywg2RB+oca&X-=@zvlN35(?ea_j?H>`{oVV9(lRkF3J4u)?Ap
z1s-$Y0eKw-mU3n{o=XKD9_7R~F#KtLQ?fcp9kZroNasK~5^DvXGvTr`zO6WfJ|&qR
zuEgeg;lXzFSf+8vbt(_6qjJc_j*BB`6zxchDfVnDR=9xdz~#cY_|kfLpjTlB6!}!a
zH^vTCD33fvLumTqDTfjF#J!z#bnMx6lZ^>{v at k)6J(;hzaH!fhi4GpTlM+KMBsMa;
zwSyUoK3^X3sl)~E-H2<&H$o-gs=+>4nZyzH8xJV`%hK{i`wk3N?ZkCu5x5TKiZTsl
zkwVE&A&phj5{IG;Ja?IivCImtF+>u>9Yr{E7GXXYN?j{Lsnrrktt8oIh4?;ex7jK1
z7 at NniLGS3xW7>JK- at iU#bpORF3GoIZF`qMyPfW-oHu30sKB>j4&XhEPC9A}rImRNl
zM8`}j80!Ptfrn;odQDnAI94d1?c>pimmwjBL)F%J7v<%9GK09*=dsrXJ#DtQU|S|r
ztcv_B5q<%$p_YB7R#Dr1j1SI;DiXlOM;sW}#-X>zit&jXXyQ;g`H8v%WgXnJ^4VK<
z>^x*X$p_blZ#<S_+XMWT?=c{5Rm$QmYHi2z1D1w-YCadgX91pBseatq8Cv5W!{E{A
zA-Y%r426w at aj`Pz<*_SZ=0gkI3+j$k<FR77BiJhslf|tlp}SCdv5p7TJrC$^bJb%(
z=}v)VuFhStMpGuP?5TLwJ0p!uP*U^wMQoh1$g67mQYNDH<uMB|h}px*4rFEQ!fHH)
zro(PXGi&{QvG4g#%@5lCx<gCMcFN1n2*|PcQGz-HE9<c(Y*W~#l2W8*^wF5GAik4L
zCgiDO8Nk)JU{#W}vqqQZm#z<aJ8t&iSP`PCzdU5pLlUZi-J=0wK_*}&WqT-pC;Jxz
ztdos%rh0Qr8w+=c+0k)t$XMva#QJL25=s&ey;bZvCK6y>UpNBG6|~f#o4`~ZYk#AG
zi>J<WDv)oGa~zxb3_{CGk}(Y;Gy)-;L*X&!X2^a;78tp(p_hjzOO+fdNG2ccs9ewn
z9_h$??sD;_6!YYlg2IZa>r07ki>p~y2;XVNA#~xQqwP}y$7qxVLt at Xs?OOq}UaY at 7
zMBW=HxoNahFnu3^6;mdU*kAZbCoKN*#6Hgsnq$-R4OcyrpTHr!>X at 8iml%s{Ecsk=
zE$+GI<q=`nb&EKy0<3GNQzp7e3V;)7%~9}cE|MmsC&z3x9QkokC&=+CDdEDxUK;9E
zFq=X}w8T=j1jmaV*(WjsOVeYKijfhQaI?K~7OdW19)rc-D)6L??_yk`9S5IH(_>N0
zXn$j~y#f{&H3J?>)*PWy;v2TJtXwgu?3Jf#iq5zSR_xXq7&o`lFOPUx4{=ARwgxQ1
z1#=)LGO%E5(IFp%9$y&ftdX#VEqr*~>B;WweArWeNyyvrON$qe^DtJ)*5Su87D>zi
zctD503jh{nW2zO0vqsUoR^Go#J(v;G{_;@1ivno#kx<`pFhPhV`-Pkk2j||nbma<I
zD0^dvU5=gKpom5Dj57#$&#JPv*2Q|e8XsPa`n`G4Bf}kH91Yy4RU-dbQ6?#7CSh1d
zIS(PeURk`nKfl%BzZhPN|NU0{)LOhQ1AYJbt>lkC{`L?5^>_dEujt+0IRE|m<{jKK
zRX at Lt;olo6!XJ|hL=CNeOtVI$*6lT`lgSFf^T)S;e)B*xYk#2?)HVD-2zv5_8%Alz
z^5e32-$ZG;rBTn$c*c(FqykRt#m9j%W<3w2TNV{>qlfGgi*E0Dw#kALuGp5CW`3ka
z at ezqmnI9oh3J)QmMT10kOQ)hJ!B=q+4yDoV0?)Z_O|qi_!;i1w$w_GyzrqtB52sIt
zGylujVO<{VdDHI-eRQ*L7&yiS`>tpM{bAqbZG!ES?CX}Q^<iJfkTc}g6|F~a_H~Pv
z_43%0WhTMPrm&pJzHX^%5BoZ9Wb|a;3zL11h3p$UkjIjJ;~V29Uq6JE`jBrNvg$*v
zd5xQU<DR6_?a*31+#6vb{gZnmlqA>W-oX0|l5lmqxz{bDt($w at qLjO2TEEAfzcL)2
zjf1oo7srQtyO}q9hCIw0chiSy1544Hc_Un$J>jwA3+8p$O>X9O3kRJfUWY*vhj=ec
z;yo4;Z)~tDvEvhiwM^!XoTv0A^G03SrASXD9_G#3ZI?%+L?7mjc;CDm88LZ?H=Yyg
zGKu&7yi)NjzYr=jTJg^`Z1$6alnIF}M$7oB*Q{*KX^D&SUWRk~b6vRE8W9WMs|)Wj
z6Zbp_aIEmPQ!fwi#}g}7%yf<i^-YCJbxY&O&|}ncTno>=F6f7|#Rc0kJGN|lb`{|#
zSTbcFN(AjYraBxFr8;Eb8nqsbi_2zodf4Cwnvts0P91;G*mjE0r7Jzg;+q=w!WHa%
zS&D5BJmeVf5^k}+?>#wdh2;k<TQf9auz_c>#7au+eCmGlEkM%)X+Q}u5`7(vNDQ-=
zhj6H<Dv6b^Lw3nf@*>tVb$ymD19R0Wuf+%IYW^oHc^(T2_Zd_=_XOn)RN<nyTyxj0
zk~K=J=`s5{C4q#?t3>=dbzB}1C^qDdGTbWL$O54>9~vHy%4VHkx7sgsO+ at a0%8}(Q
zS?lMTE04twQX-zq`E8eCON=_520C-RaMd;8Z`og51SBC^ih;ltC1Kvd4AkB%9fr;$
z0s?D)FjiR8$HR(OFg+w;gNSG=Gwg;=SrNP$cv8m~Bj!{YG8!wy!159Gz$(a>#FKZt
znBUPlS1c;@R<S24!n$6FbMC>Rm~!pJGg;hSsWhf;e_5z<Z)ka73gvh`xFBfK*1iBp
zEr_#a5bbISPf(v0VIIu-@~DmCJc1N?Y$VQ6nQ2*jLeS4sDgHX@`h2Y=e515?bv+hW
z?WhhscBwc-<HS4KKBWvcrj-tJ(|NDgy&e%}nS$ftk*P(V9kN;)Kk<|c&wxx0Dxwnl
z=fY1mVez*s_Bk8)o0xiiL4QBl#1XvSc5+zZc<XVA196Ah?B&q6)Se8}0M at m$S&Z*e
z^z+0yj(FpJ34i-mDfEtLcFSTqsG7qvz^0*^EmSj7o~qeGHIt3;RxOmr=ZIzt(R?MN
z9i72+S!iZ`c`R0bYGw<~Obr3eZ2b(XshKSlG0v2l`NGu9$3o2<JAf-wGUq3Df|Z9_
z28;4gTB-W7B-&}E6wPtZp)ZeC?XY!3rC<Y!=7^+0tEOlUyhVm2T%Bh`C$$jG*n*<j
zLNvF}rIGz6bF5!lj!2H9wEnV$Z2nxTIb7I_QZ>ir9+4bS$~+ji2j_1O1{j*zLNh;l
z2?>#c=%i at 2e&U;=`N9;<$3oE at J5WcYXtsW29z}B`y at 2sjG-pmPNqkE2Frw{&Z+k>a
zutSPw$3kU7*&I2s%}z5tx}um<Hh+0x@#_BkR)hJ>XNKZ`zm?$W;-&K+(yJWDl4A$@
zeTsJh3Arz}JQ)InIYN6vxA84q|1%hoOFc;A2xCl>FRO~lB^Uwg^ZO(CA3uKk!~Xi+
z{`w0G+t}vcua6Q8qHVAJQc87%`MzBS*B12Gan)E|Xnfx;yV3x~`SJ0mxvenLqyI(_
zN@%}IH{{~40*8;=^L2S_S9)W at 6D#qqg65hX)E>oc`=0s>H2Cuap4N-DDNob|Um$;G
zbEBi9nx0sm8oGZKM3G^jGyEew(3^rt3}QMV_Q0Km4>A<9bD^COp4lZH+VQ!QLHp}1
zIbWWxxy2o2QHeoPY{??`yp|}!6SFM_Jl*b|iY1ERsY5A8H<_Jtc`eBUJ6txNuuWa-
zb;2T+4N(L;E?D**SOU;MFbky;K!g}2g4^a2MYji{h%d-{$oUCDLRdj%^$CbNgXEfo
z<ne2SxouvYVV at ICi`K!`>><%aRfN=rE*Qp+K&pp86C3-osfun7R1s~-peD1tjw(Xf
zsUFW4J>o%7Ma;J794=&bnIdy_uKFyn;(>8A5$oBu%|yi6A1Cr+LA|+MgfpqFmT4+y
zQRXDnAd24GRM+Z+WXd8xlk)ZuS$Zh1C5!y6Vn)5N5vxQ9b&&_QHUZ|@>~wX7U-eQ!
zjAO)nofy6!mo9=`CC#Xd*jIbi`bD(Ps(Sst7%&)Bt+o6d_ at Zs_c4*)C<)Jcyonv|}
zW#qPG1+@`8We^CVjbOJZ;)f0~yZi6bMsUok1r7oj!F9 at p9N1iQ8<HXxVSSwFQzx36
zGxLQMM<o_RJF?B>9bW8zvIvMHx2MReiz9e4ukDJ|OrJ(+BiL0nrZ#d<Pp_qo+ at 9<U
zr{<SUGJ1QUkldEw8Tv+PT)k9C9 at OCO0+JzWRTPNETXNe|A$ca^Leb=zY4a$eliI}x
z;0a at 1Cz3=U6_Qs|9E1wVJ78%4`$bpBP$9kd6rbqnt;ytoK4OO~al#m8Vq!{KLALx_
z@&<Og827o>V%&c5OESS8p*-F&i#UGTEz_4uV?ARTuceS~`_wavc0wVYH&7y-Z%87Y
zASjU-B-_}>9 at n@O5ufmIuM?qZzgK0d(56Q6Tu!bNXr!HLN~E_^5GTO&SWhY>c&g+I
z6_R_DE=;bO0$vCtm|glQX<+TiweQg at 5#(rI<**T$&w?2b3H5QJ4izlY?wW))^}y&{
zAW%rKXW=J$e%f=cC#H}b3W;x^4T;20^w*I{9)u>gE2t8=8%E$0e!VS`{Gz2^Co~ko
zZRADEg%ZhAIY}{m1;AdEqq$i#H#a2`JTdVLlt}QDPD)2XWQ2}4{0GkxL>`LR=kc_}
zd{86#8SSMQdEd~~@fcXMvl^Nr2_B!G>%`DZ1eo^UJOt{~1IvLaY`!hJD}kkwZksCU
zc&L*64M!xwT(plO$?NW_lOl;#y%2Bp;=x38?|lL_;R$FY*jY at 48p(??7eG}%5!9T}
zNbfWDUp0~iQf!QGjdWaFBQ4jZk&f%3k&^L`*?vwHa-gm`Fkzk{(l3}W&kSwD1k6zn
zPUL8GXWTepo+NR`L5dPQLIJaDJ-ERqdVd^PQ%;$atikGy6Xr<^x?CE8(3FD{mo1#w
z9^r()p&XnrJB9_KT|v#34^DWH^PqrVBi%S*o)RAi(#RVokf_D>2ovTBwH}y2YFpbd
z;faqoOrTt2-Y|i3<$8lc22+dw=-HrvP{i(*2c24Om_YPl9GJl6ay}qnb`z%*Odw$w
zj_eE*CCn^~ViP40m-d#UgxM>>juMwGl-M4j1m3WEG3y(eVZj7~aBve$AjW!er`?Mi
zC%k*hbpl112Pe$#+LOYG93&ou6R6UnAx-u*WWJyAw3HKM%(r{0$W05Z8=lvC)F#e3
zYE0Jr=x&p-+h2vZ8->5LIdm8LiE*^~M2Pb`ktMId6r<ZkAQDNb%#- at kgvC!pNkUKb
zGNDR`9$225`O4JWZUophusx-u5JV!~aSiA}vR%pF?HWCAo7d=ZUMDQQdS at 0yC+$Tv
z^Cy$5rQcaQO=1=D$c(AzxEx{Xcd?EIjfMLzgmvi_$M$^DBRbntQ>JOxFx?(P#jI&B
zB&pubtWn%J$}}8{=WBcX%;KBv`L>d(4O3g)B1X<MThg?Hi*j=JsBTp_u~4Mn>f^pW
z>{_x}0BP1+`Ak=D&Lotqt84pUaYCZbX}cX*?D1%iq6?i9A&>?+pGGDHv{NWxxz38A
z`+-&!qMH1^)*4U(#?Q7VbYy;A8fbeg6mh7gP;((;CwLf<pM*5irbQaHN=9_ag-RHY
zg?40D7_KMbyL3g(qJ@)opU37CbIj|+{54jcXl~}f7pB27Pn(TKPvD8#xMael-LySw
z)B|0?53j^D8p at hAA9=G?;gYhRn3*G<B40ThOE7bP*b-)!Cpyqf-(6my^$oF(+Se1k
za3H++7PTr0DB~^FkYimV^#z|i5pGhsQ+t-hu%(tCC!&uG;8Q6Yn#mGX at 4hxxf1QR|
zlH%D?{6rYfCOe+sl*K+;IoK^`6_WE?(uy)Qp&*54U7()hb+1FnhV!O#Vp3`DH%w^+
zeB$(sz(NJBF)GOXuunm&XbE}IdV|eI?bkOvV|;)?SW*k`J=N))dt4)Jo7dogpA%9(
zvocYc0rauT87qgeHobX>^E~Wz2?K$$IEXzHy*>rRN6W|>>x&+KsDUw>87m*@KnJtK
zC>sMTkP at AS5e+PGvquyv6gOL`%jEeQ>iv5jyr8c^vr|{*(t3a#!akY!M99J`d at uND
z^9sH!3UmQI38DzLfG*KW5`3-d{1oKw4>Z<)q6P>liXEn?kh01P=HPcqv?E3Zm!4(Y
z%93a-Pgt4-Dgn at FcFAJwkx^N(3b{uMtVGuy&sc at quKs2|u{<DeZWClGE7!E5Gnt5a
zYS1hJ5zNkA%QY#+u-4%ELdZmwm8nrKii&&Zc%u$-*X|RbsC<JfHM4teI|f#xil{g>
zHCqhQae0|0H0G*aUfiC)*M&~(jxPQ+XIj;s?7!4hUD>{JaEG3 at t=g>_oUBz;%VriP
zH?6;uSWUfed!$}7gb{xmLv^fF;~cJSFV6r&Le#=V0FYlowOx6pK7-V4ev4Q{n4-o?
zuu8l^3wI^Hv1Q8zte%FHZ=gl7!+4ySO<E$b!D1k`=eqKc^5TtZFt%r?mo-;!5w4Pc
z<a}7S`-I`;g0sA<vLxAHI3sXgx+7O~ak6YaQNnnfNagW at 7}DbtXx4HCv5I0r#{7CO
z8!+~N9}$~wT0;c;_Y3OOgAs06pWh$B|M>CSANJSp_SawFY1RaPzdlL}HUstbi>-PK
z%$3%0*#faX{yHve9oIkKw+ko(YWw5kPj~0V9l4ITN1V at WqLec}Si&eVKJ!#fk25~A
zdk|Oya~qIWT*5Qf?Dj%?XM7E97tiQ40OhgyM34D#g8Yk&uNmSbO)D9nc_R0lcb%C@
zjL`|7*;xxpjL$qptlSx&*|l<cJ6JUUBgavU4<7ASXMC^+Tge&UWs4wO9%p>8OMY#}
z=id|<_qwBcEy9PW3ung(A1>KQ=S27{FQhple8}6l=-kfihF<f;-mepZkh=&Uim6YM
z at 1g#}e<ysqTSWNY`iW1FMBg2 at JWlw$LxfwAVNzl(!iOk1LeAFA%;{jvzSTw{-21{M
z at 0S^`7ocGlqudSCRtV}CL5tJ9%Rbdy%h{{2-ypiTzp?1v4nlO#gS^Nbt`XboqI<Y!
ztdA3MX{xF`Wid(;K4elf#tGlfv<Tl at E&eMQ4a=Wl-wj5`wZUk)E-*T-2N;c at l#ra@
zVC2Tej99CDxhJU^s^tXcR6n9;%q~(ziQr+LDkdN8Q?T2-n#1hT#{WsLc4W(L8<@{3
z&IY97{}Ve?;3}7v at XCqnO<*V9zR~FB=UhpVYl3;e1rJF8Y;@o4Gpuy|QVV9Msv#C>
z7paBZrdDXMI>j?{&BdPI_MB at 0JvJo@BWk5xfC<=Q%ZsiRNu#XmP+ at RT4RokqBW{})
z*Mb#Lr#`?m5b?|mP4T(0#~qiD+OD2&H2M8fc?YZ3B+aUE)g~@vH(>tuQ_qFvAD- at d
zm#fOGAD*m14%t9YjcVk`vvrB9IM at bL_zhe6npeO|uuV0Zz40N8))YU7r~<~;$QCFn
zjVxStAYI=cv~}}uPEGofxyKMmO_Vh_gwS?IRy{d)5c=*`-1zLxn_m&BGh#H_K>!^}
zQB}s4wm5hAwd+t#=Jmu}^4V+5g2&d at D;|X%4t~T(Opa`^-W>Kz(G!_&mZF<Yp4|4Y
zMYCvlg!5d#2 at X=c at 0N`f#bABBB3xqlEMi4QsC)jg0(IyiVlT7Ta6%fl*<68f!SdA1
zPgad&w1IEI-i%?LX+dm8Li~*40gZMWY1_Q_!hJ at FT>BTg+v-C!G8Zh(HaZhEs-9Ju
zFFU5S#qxx?BKVY%Q8$}r*ShvheS5y?5%=ie{GMytHB7goKr!pJ+s$KEH#4Ga7%i&j
z+%{K?eg&)sfQsWWqdJko5gj8Xz+8j&2-=mHyG?bkN=(Yu^FP(fZF|_b)G$EOtgmuS
z2Uhv6%zj<<2%6IYfdeXZ?xtYL`$v;3PP`&=r0sJX$rRMiuu>CBJXmb^XgZ at h{k|6;
zsZEN+^bIR|L^oy3;ymmD{^y?_BWiJ|*7k_Z!<MXcIzNW+W7B!_MDbdu^8=)MJe$s&
zT`FzTd2_TSbf^D53TcdU^)W3e$Hszb$UI&Vr75Dh*&;`V*t~gq6~7OR7+t(*(w>b+
z7M-8LUV=0Udd}>aSu>~eu(?2N-W;j$ojaR{-B|%=^Or6DcX|A!z!s+*YYWj1v3VS-
zavp%b;?ydr(|Nxo0aJ9|JcKvVd9(919!_e{xEO}&>58yo&Gc+Kk78;>iO-_}+Oz5W
z?ibPdkB;JkJoBr^j>qXdHf?&Rk%vHU9XgLw=8MmpJr}S$DzAGTMrJn;;}ubQzrHZJ
z)gknr&2<R%OnNq-KjylY9Afi(x!C;PV6pjq0wu^#c-TAdaM(R>J+I%9gVnQ4Qd3Kc
z%X=C*NSw>>G>glB6v9DbE(&66q8Dd^_o&satG?-xvc>;q`kcbXz)7>$HhBMEz94nU
z4#1e%F$odOJ&k&K- at 1u-V=+s%@b~6DXeKgZb`@IAv=)@Yn~ua4nz_yQix?2RK~sEW
zc*03xDwSwIHwmV#RmCTv?fyQeq0c}ZDCG_KT+q4zeDVY%3*a3M61zyYa-_tsh$=h@
zKt;3nkdIX>W)<7^V;h^)5O;>LZF`Bj_VIwaxvhy?D=Rl6-)?TJawF;?0S?S=;!Dn~
za7wR~K at Mjys$U2xOjVNP6riBk$7HH%e+Q(_4@|rVvqL#YAPf!(xKap|8f)WN%_RY&
zHEZ?jNWyW}CFs at 8nRJ{SG%6a8(?U732In8~o<^u#OIJh^WDZAZq^xs6JV~v3*?~!%
zdSM;I`{NC&|D+e^a9MkKMrKE*%q%sYGR;-lmFC=*%w<|j6<3OSRE;YV;RZJ!0#(2T
zdiVlW&qPi)$fDNq0$G3e0@=X+Dn!)0fuWW~8r5Es7O257=jts9)TE#JM6BWG(C3B8
zd6#BzMH at U&jC?Y^@}<wq=B0b=uZXH=$1hmgVtnm^e$Ce at R%PszF+ZQR1IqsUN5r6;
zc9~%RehF6Z9*o<=`uh1J_#eOj?eF&2Z}!)}z|!oT|9yVc7`+<5lwwIO&{~(v2812u
z`?#!s>^|d;!XI;h+5Z0HA3tgUThoBgXssHo4P)M(@5^J4#u7|V3tcT5AJ|0%s>n{0
zc!%!#@)c1aoIJv?vuj>j<HBAD862%{kFD0OLF%g6kiK{6O{eJd8Vr6;am!$L_M1%F
z$+$c0(dPA<Pd at 1R{zHbot$?0PHa7Jx98L0vdKaEr1*X>HuuEL>X1bk{aLxrUJRvLb
zHqB}@<Qhld!Y-GM6-E(5KM`S)txE91Uh<ZL7oObmeuJ=6)w#!IF2Q?yAb9x!J{bsJ
zZgIp7R}6IvR2UD*Nd}(a*JyFuyv9&BF~SltpCx!<=B1zF%2Z7pbx^#X{Y)FL^|q;a
zZx0kNZ3)^YleePc#VvYh+w)CNVnLyJne3x at Vb9W^qj+(zFw?UXFYMG8Vk#43Y?~`u
znXd at 803|PMVRTy^Bi71PN2QvA_oGd9D`Az(T}IUH5p>iecin!L*!3NQXh_Ygc>P)2
z$8T`;1FL<cEf=I#UlBp$4#d{;SjDbFSsg`O at 7;gLQI^*IxYL(EPtYr-?XRS6joHe0
z1liBaL#gYwh%KZp?4hyjN*9iqMLY4BVzFlG&r-UuQ>Go+5QPJfN*88JN7=$2quyv_
z at Ev-;BC6w-lrGFn^rFy(qh_*|6d2GJwVt%Qh%$vPJT46-bYaiPdO_&At*4n-Z+j3T
zyAZl=vl`I3mq|@=IiPag45Dl6`-wxo3e at lmc}Gq>@}eDyHm|r;u4kbw++;*73l;N~
z*2OvDsa}W^k$QZV%Jo8a;bw^{^~ijB#jm+~g);ZEo47~pM<M=vc_4FrS8f7j2s3wH
zw4`;)$N*?mZ<mGUIbQc#1kBrI^ee(v)^>dX{gR%ea+%F%iCj15e3r_+?RBl?q0ZeO
zpv*lxNamg+Q0DT8(sp_161U9tYxenysB!hI at -%5v=rWOFBdtFt(G<F$r65E=ARI09
z(><i&)_=iS4m?u`kAoO42)@BHVaLh*Cq38x>te)U8xefus)jwO(q8ofaNH5Nvg#FS
z$FT$%cK~$o*fn*JC_$7tzwJ5K3VNC+$-h9jEKW<X#j0 at Ef*{J<b?nhN5Qg_e-=h>Z
zuTf at yMQFBmW+7>y;2|?U7S^K`#)ri*h$wS#gQ7udKXlEcxJ#2n(=z$iFy%A;)MJek
zoyy at TJ%4zD6vDKjq!^8(7<ss=UK(tIUhB4%uhy>!B^Y0JtCqu;7~iWTMP-p!ezViO
zV~4ydLJ!D%^N7A0F>4P2L*m5587d)fMixDkbOGLK#RG|G-S~<K`od`0i!#JaLMbXr
zD+`{gN1!GBRE_ri!v0_3<K0kS!socQ at L8@)_#D?u_+;bbnj;cE8OLeQC49DL3m@}{
z-MH>CvsZCh*;NWey2m_4<TWWGt^UCXH#^4pT)OA-NcWg0i-@@H at m+*~O{Zw=QRyBW
zTs*;bk6ku&+OB(Ye5stTD;-<+d?d(qPfqs2Pm1hr6Z_zQ at K!RbY_v#?A!xPmB3>$J
zg(r^<tr-~K544)y%8jgOOFaRHR&VTsr4?;C<BhGr%#dCYWyFK67<p<}VJptt^TAe}
zR(S2$dfCF(?Gd*67uo?=?BOZg;EGesdcYOC$9SL<_ZZ~{SKPGZE5cGA>qb{3M({3l
zMJ@%Oj;=`c92;Fd^Z7<s^MsUcbTv<IFDwOpE9Fl;8%uGNI6gczwHsX#Qx3S|a_yjL
zbp(qyx}q3TlPiKLCcJtrZgfQ{#5WyXfvPbbbiHh$>-Gp;@r5`Jx*{^o8(mTMgRS0J
z7v0>gxUqFN?~1Urgm|#k{!g>q*ou<O1Fd*b>P&~$j~C{I#wydq79sZV>ZS&hc>-%T
zglEu;*m(E>_(rDNjW+ at B`SJy&(=*EOfRuF+oCAO}w~Ynhf$<fQ>i^iTb|gz~9O%DO
zybFwiAMj_(lc5O39HC=nD7p=;qw6mcnXF><D#n<XXs}596PsD*z)AcilYvHFs}8Y5
zA#h8to(J?Otf>QA(kdf7)13oxg$A%T&UgeTbTtc&rY*=i at k;H&w7cxS9vV|i2fi=@
z57A!aF;6UU%sKFGcfOX^X6u2odh{(xYiqEQvAO|{O~t3oP~k)HNx|j?g_ajJsFqgX
zs-{>~>TdZan9>+m8<i(EgRR>WY1KnR8Q^gAfOV6AzB5LYmc9o6QD+~_pfgQn)?mx4
zo_$|R<#kDzxc44X^;Mo3G0$+Tnq=GYsF at K<C5J|?<;se%G=EEyp+UVBTGe2VHZU$8
zz0?NW-QDg^JZ>hfR6p%vk*;5i8^d&SGLoradR8o#oSx>RxwrSRH(nBdiQf!d(o`}Q
z;zd*2ik9Y*I%(`|Jkhe2EHp*OT}xM9Ixxe3ST8&;to#x+NiqOf%R1?TOIpbfjXtH(
z15UAtGK&tZ!I4ss-d3ZY<4KD+YjIpH2DnSgWT!`i0IuR<D0_#d09&a#U?Sor^OLq1
zfK|r>YneSH8O;W`v0$d|sGad at W1lF4ow*jix?SCjMyi3%EVJ3&&_Jotj^S{7_8Jxj
zmf8-D>?JB99*#mR)j=)mM46fnVdu^lpN)CGzh at Lr^xVJY*p at g!SB9ueGhd-a)XIKk
zo0?EF?8v*Xhv&9k7axP=H9s`Q<NQ=(vT`TPet{B3JSc$&9r%tWC1{K5eSZNnX&iT8
zh0_&Gm$gHqB#(j*6YRp&&!rw3?u5;|o1A3CWA0#fwVBo#8oC)zJn=T-&oE<IxrRG}
z1NzJWi#|hA=|0eB1AUhFK%X7=D*m8)wfNY at pAF>2j%c(^ICi)|pYub(l=wlP4fI)5
zg7n$iwUq{aHjrbcVbJFTi#}fx(dYOA%Q5IP?x;J&LnmxeGW4o?uxD7Ikt+5KJMGi}
zd%k-%-10uSGaNY?kKoSm^X3|zu=4xj&Ia!MKB%*SI`{WMlnq3={Hx?5%6LZ}-z2T5
zd67CpM*}IiGfdM~7|hs>&ud+n-eTLoHHHcz5w7_l&j#{L_Xc^kzTF$#`G%s-TOj6)
z<2wzbKKe!W#GLVh#da6m8S$J4Gu~-<cSGdu*$oj8Y6NvQP-m8gs52rmcV}wRC)VI2
zgFAmKFO=NhuZ*s at dVVMW_ak|Nj^r5$^zrpd@#E*Ozx%J>{MTO?+1``?dB0lsp5P_;
z!~E&Rf_LAd8MOWL7PZ`BNBTNNX!u|`KVN^mT3h}+HAe3#Ux&nErux^~P?kO=B<2f5
z-ZA5lHd439H3AKZNOr+caXjQk17T<&_N>*OBGDVD!@S%EECp<*fGp%}UFuUys3A^n
z#9mr6VVSI}Ny_39D^<Bk4O8bVXmJPDxIZLqHEI;*|L~Fru8G+`S*&=3_S3;nrhGJf
zy!pViqNn-LFqPm!LA0sW(XX)WraZ~jMxkGF(Ic at 21P)ls6^YJI)=?Bob^`Pyps9%w
zf%2DRGP7KpZY+9rMPtSr=grl^swa1Y8^*!i;5ZZc1HW|K)v$7II<W`a!lDr=N!*>Z
zo!IgY&X$zHV63d!T#3O<qrENDiLuyvC#E%Cv8GanceGx1E8ZEy9I`|+ih6OO*^?Q*
z>Q2dC?Cw@@R1>+wEJiSy;KpGCLE2N58Lw5RR^E_TyDIhL|7!OW)7;CvW>yyV9Txu3
z*49&3cj!xBMlm_2si at Z#xOR2T6*r-I43R?LWLx(h5}g)pvIXu3#)-^&-3s30Onnr~
zisMn#BFMj7(qw%_OK at CeE~xSad+>N3*b)#ueqdbVC9bHCl?#t(%<b3}@kS%IPTW<&
z7Ogt$Y==VeWmM$^0^ykaog<Qt>O=D%H4o=AsiGWjn2SkYg0vogM=b(vn6}OE|CW4G
zBJw>-m!p+s$WpgJM60qX!RTrll2ovZnaK(Df;=!*ekiO>y$4^JG~n1`V$vv*Ca;<D
zT0S{bRAvqG0IaTGO5<@!n6yRpiP6Kaikew_^Hy=Owqudh{8GvB at OdNz!#y7f;=V}Z
zp;0Pv^y6?Q8O$QVfV;b1F~a*(bEYZHPs4(5ci-WR{+s@>j8v+a at O66e{r5kiL%MM+
zOqax;f~M(srJc)#So>__gzF%u8b>(5c*kr3*K%ArYVwkLYod*1#otGtch~NlTwQ(L
zC8azR>Xbqc*ed^AW|4j$oFyeugB{pkw1}sMUCTPKrY35FcZWCu_(cw!6=2P1NIJa&
zW*B%eDOMd1tR?P{<mfYwjRiAxM^ZgBbvFOjVCzC##;X-hbTV2=vb5$lqov(EsZr+5
zI&aTjEVQHN*`d*5&ar!T#xkpW8t>q3q{8EUr;CrHJm23Fig#3PCOgG$iL+B>2n)Ms
zzM^Hi#>#$X)BGtj6y|Q~;k%oUYs-t2Sr3i6=J5q2P16;3(x_QvC5;t5vOe%OY)g;}
z>wSO0D+7c6y2BaIKEOwe;1GP|!NS6f`aXDC7+MYubh50}m8Xn&%pFk?xtRTztMSGY
zZ!7+c%<QIZ$A=FB<h7b8nJKtiCoPNY#5=&vObns~uHqO)H9LbJM*!vsjh^cfkm)ae
zhRm0Wb%qRVPT$PLRWt{r0VkX&F$-E5q0o$1jQYfD?E_7%ycji1UDJY}_!U|N8>tc=
zp{gBvR7xBUGqM6^<O|b`ZV!c)%iXu9QlJM5rhb`Z7u|RuZ?@41^+JtR4|V2fz=s)|
z6q6Z2AnyXL&HpO##PQQSWx0Kml)}4~e@{9ZOF8pxy({A<(_kv0f$1-81ytA$#_|)e
z&zm_>e~H_642zN6zqGD`&K)?_h{z=o+r<~MD!K9w at DtJw+i9}6XRgesbCuamZ>Qqj
z7I*UA8hKFz%?&Z&4D`uowxcq4hiakG39SnrC5E#5`<2oCmX~w#e?NS_uaP_}fj+)o
zDSrI?^>_dEoB#R?liLmb=l!a|(Chn$nO|p{d}puBOZ0h*T867Y;;w`LBDxR$eEspN
zwZ at EeUSSg#cwP9?P%p{nLo!E`BuME)Qm01)gvJdAj$OlX^?07R#|CgpFzx~)g}?@#
z>BJY&*<oGLfr at Z~r?vRIVRnPq={y)QFju&ErBN{Wgke0;JpF-#N&(x{fz^1z8>nlP
z;1PjG4UDe0 at yG2w3O-Lkt|J8Co&B2xzqTZ9Nwy7*M`Zpv&8}y~6ojNvV_- at io*JM7
zz)=ZdIo1gH)@wd+p|6n*C+;cl6Ox!eH}E7bjo!wD0M0 at 0;+=&#uqK_ALCS&S4!V8g
zk2BR4Q}UU6*fw#hh0Cj3pCcdryWtN?!dmnu#~4i!_ezXqK#5`@I1{gWvs(u?Z^z at 2
zh!(XQ$1!`sfS4u?ecC5#ZuW?W52&$Z`3h_i52VipKf;8$>Y?C-z44P~#Mu7ggO=s0
zRw+TP0{6)iSXP0@;uF)jeA`392)ntF>=x7G#M|sG@&C&RjVV9&+Ic0tns=(#PJK*D
z;8g1omuKWY9<gj*$&6)edXj`A1~rg}bOhgk6-<su)R>cYwMjctUk`lSwIwYXHKIB!
zGCJ<4^c|we6L~NJ)}STKY;=8=eFJS3re&p<hei|!KEPUOT{pB{T}w~+AKBHCY*~uK
zwvsETz!(gyC!=fhMz#MzV at u{h=IDle4?llo85w3i6~-0ogTI_iOJUYpluEimVkW&E
z<+JIyT<KTrm#g1k{ElK{{n^9&_He#S+3W%qb#Pm{NLbp!Gs3Yhs!*633AJ0kWnqHi
zw<zj&lkkaWJb1PB)aD2#4!k6AZJ;Ieggvyb^xW{49bXJyb3`NYK at 6^RmEc?IjV<aR
zqXmms1U3L34VM at bp0Hdn8(!*E at loT(joE=`^)eYOnQ)xN|BCIJ0`?1E#0kUC9k`!6
zjw6PKJC?BA@!T4+r^S4-eJni!=u#B#4pr!SQP)L`TWyZh!zXs_<qn|h#|KW8C!Skg
zS5!isz``D_23%L>j7xU6G_L3!U*wSp){0?_^dE`31)|A!3m25t9<06Ix7rrtp3$>6
zc5M%-u>!BtUpL%ZXRsJOoEr<{DLyn2e*vW73*g>xh*A_(`@>K?$!LK#!4g|M)Je&)
zWv$GD71o%x4PSK1geYLglET8g1#C;>iVy+enf_oG0hdg0Uk(<}gs)d^lnIE&JW^y;
zSS)2i1+0KN$H7;!!|-z(WUlm8`O{LQ9ZOszdew at a9j?G3WgclbkX1#lm&c&fA3U_(
zFOT__-s~ujM$#X(qBvG&Rg4NT_^mHuj)k;P at V}5pY7|~rDtse=WkD$R=-9xQuVDE3
zlL?X>x at +~ZJNX3D at 227Y+ZL_ph|_!Q#$xEPKK(c at N4Yttj;&+HrzJKV@<6ALOIi$9
z>W~uC<;uoI(X at w8Ny9yo4>9kc+cGFVT15#NU at bEtzITyv{@)$jP?0vFJ*RQI*67;N
z at dZk{?gYRWb6|z>gq5-At>eyy1u<N13 at 6o?_~MN-k7x~EqO2!s3;kCYeBcM;d-V)*
zH&^6?G7L_tk>=sW?F)88ZyU69^myrn$QMyPI0u^h3s<g)d}9*BE1n5Sx5i6V8J{%q
zOZH2;cq(X~kru055oGH6AEh*8&@FZfgXu9j at EBm3oVpf0okFrOUxwzmIpdmM*vdl?
zO-`GA;qO)R%r<eWA`}i8&ZZPAyrrC0H9FsM4Gs~&_F$)syNzh at KX!mCIY_88ggZY;
zNC&>}hFf#F83$THu!iOWJj>Pp)%!M{e8d#uqqycm at z0q;6#<_}%338MCzW#k2ccAH
z-vS at 9Dq+fRY~VvHE15aESjmGoSP?09zAbF)Jr%kWhVsa<XsMthTTJUb^CGkyG~`qY
z1`T6kSB_*uD$^LXHafyRH0yo1lyMg8q!3~KDt4IU1MRtDj=?lmjtyjlN>ZB4<C(3k
zbmm;g^dtPB5-&TLGneS|Mbtq(MBTEG`WcrDTWABdTgfEW2V2v_ys%6Gn|H&Wi$uJ@
zAZ6uf+L$x7Vh&WMsdDlZ217 at -gR+?T>6m6GTnI+}gXr#nqK}o>-!rFgArwhqzqWGG
zzD3!8|Km5ay1)9a(H at DAt6=%LEVjKbv|!cWmTwia^xK$%`uZd--!@$Imm$~udw<jS
zxPtE7wH*tUdJw~w1)IZY@$qkrf7ar7*k|CW{lQ*3$?JHv at AY2yPs@xshZDhiEj#Ky
zoa~*oH(GGt5rUPL8U~hc7r<uvV5783%NAd?-G2JZkUsgB#k9+BN~jcgPP|&SWlJJ1
z)7{<OqHB<@@I|Grh|$pZ7<rfJtUq at K%uC#CY^1Zqs!4bdJ6i%9R(NN0Y=-)<K&@r{
zsKJu;<D$s1Q1zM2gR|}H^@Wg%d<SJu?mQ#AU5rt2hr4&}JNEfue}(AXyZoI!2eBG>
z>HIqC_LTHIV=8>91C%O$rhA`s7&T0ccbJUliy-O1c=;%kI61k%6 at 6a@LVqo|q7Nij
zaM6nFhHrsqsZVaL;2dNC;+Kq?_)A6___tHl75?T2Y&=?$n|c at UgkiXAqvJZmd!;FL
z9}}j}!EO~6|EA{j$4o99K$qbV&o#&&T+)A8-(DepF<D<u_%rmyDrW^PBG?m(*gdtr
zQO<oSM@=?n_TZdbi3?if{jlE`y-imIhu$JhU}0_7Fmz5Ms4xv-{b6rN^RBpU8Fcyd
z{<3i&STP3vZzXHa;?UhFNkOi1rYlWEHHgpgSx^=tvPupV2*@;Ha<79ks`7jxWpD?G
z!N~$z)LI at g-hx8e9T1mf(3{{{I&ucZEqm)%5kte=c(wTy^(IE{SR+?GM<M2w|9i1h
zCKtpDCA#s#7kz?y46$R{v6<3xwb$7~Fnrwox8cix^rlZhso$0!Lohodsw{hLjQEkA
z8B*(ao!5V6z2J^(Sx=q2T%oEIx&kcj{Vg1^QYeKw^J`bkcdNshw!nYposk$RQKvj#
zlu8^r$g9|RM$Q}t&uH)8u;q80^TPGcAzH at 5mhRJVgK{Eha7!;q!X?VyUCAl4+vVyv
z7AWG1!k;53pYe(Mn7fhI6b9j*Z4okOwAQ)9-l^he?6FRbP3vJ93^K}k#EfxcInomr
z+xJ*(wHmlH=vILBYqlc{LM>7h8<fgk8(9O)GOpwKq69l_%%N-!93j~T&0we<719ef
z(1jXnyi*?;v%2ubu)7%>C#1yw?)KF2po-shD at M=Z%+?p;bIw343Y+;X5?BVfsl=UU
zjDM6E6+8H33F)^wqtltJ6?d?S+#HHK_you^8}?|Ktk^)gLE<X%bfEoky2>UTF(s21
z*!xW;ufUl)nY_SlFn3$R-%Q-=e+`dfIeEV$xOQ4g5B{_8*vArfrdQw{n>ijH at n=%*
zDxTT7LsPg-&P+!~az`=NR;j=KthKDa&f4<$qy8kM)I1q6VwV{%jVx4PUel?5;}s<Q
zWz-_web~M%b;~NdWGV%r1lB4PggtOSqH}ubY|B6}#M5E9lE%ZFX9y9T=_G$X*q-Rv
zaViJP#{Kk&IfcbXhp6|775nCB{5Y|$B>A~;sN7<HOPrz)wlk`xMI{-g!f$n?n0K$1
zREuih!9JA)qgPzs$o+m|xwaq4rF9+)njODb=?C0F)ShOy&V)5_>1Oia?^$V?B;#J-
zI7p9ugwk`8D`X)2YD~+D at Ha&-b3u at p-OlRsMXA>YY<6+PVa~-n<P<Y_#}|JonU-eB
z7wdC_pP-MQ_7zwq at T6a{U!HzraSPV9134uHs~iL6OT4VUBjWOAvL5WGU0JofYAI>O
z57`_$I5I|UN%Xbf*BKHM&>2)WHfFLltjOxy*X&r)n2F7a$1!`QN(Yt{G?jZQlcFr_
zpcC?bd6p5AM2a5E&tsW2C$!-$_OZn9LQAAp&DY{BwGe+ZmEhz#ICT~5uvqtAP3}*h
zmy#LM!_<325QF++XMC=pCH<8<xFo<C_<z*Y64A*$?#iMOe6hrS9f9cB@>XRqnFRT^
zm`brhMg9`s4u<9DvG{d<?gahIfCRmgxNSzo)Ro)7^7B~w_Bt#UFTO1vXSWQ!l*;OS
z&xh5XiDO%O&51(;o1rgh<XqoOeP){A at V;xXQ_FZ9Qh-U^Ch%!xKFe)`P;iZg1+vDc
z&^E424wo`mQ56!mM4&dNZ18 at O`1j{O7%m_8txSYTjTF5t63qz~Xq9%J8n+PqKi+=1
z4gY7mTGDh$Rp7i=aaK^DqM%Oi8tx8yTDAXa0}<ro)ISVTQ-uHmjsr^<eMQ{h8C~UF
z%UYy4lq44V|Huo=bw*jTG*MxBK#v>>LqUMAaG=i5FEciAFhCFb*^CL2_}?eh!tnh!
z_lk})wEqcx%9^?}=spaL+I2FSd<ko6-rGge3t6jE%Q7c&ac2l!g)!gv1eQ at Xc<~N>
zvZ6+3cO1ORimJFk)5>=>>}Z^5Mk*f5*(dWo{{URfoR{VMWwEtidH2auyIkLx{AC$@
z-yHq5>yu@#*Wn)wwP$3M-WJ(%S)gzVvyae^Q!5tH at Y7;gF>A+Rwcfaw%B`}oLk%mm
zgAUgJ!t2^W%c2fTogSD+-UN$2J~f!{FB7M_&qhBFi)T+vE*hG-Ctkr=mDG4sywdbI
zH7pV=a*KEu4y=(Jjz`?z at t!x19qa+uig-Kz8S_Hm<=r>VjOhwHPDrn~MKD at t@-J`M
zp4i`UEO*?NsHuq?@Z^~%kz}6_y!pL}=64GvCT?FFcZ`DSc&*wY3znFR0yo2s7-H^s
z4-Pe9neng3iXI6b|8y3Gua9BJG07b<KjNM}RL3J;nzww%4`;MI<BsTUiE%a#)kI?h
z%29fv;yHO{Q{2*ow_5Y{uE6j_)BRX6vW4IemUu)#jWbdughl1>7W6i~Z^K^rJ_8o7
z+Ubdrc at kJ-mdG<Cv5^6B3ov=(mrViB9FJ!J<KcMdy<(DdDLgM%#S!JIuDk<01yB1O
zD_0(|K*sqCqwxj at a!S1|no9CJEwc5aC3>yWf?c01+RtAWOP at K80mtzMTpfvfn3$8v
zzAzFv4iOi)XKMRHCcgIt4|vNAUE!820**spB#w|f9^ndN?9eW+6*jqICCm<#KkVGF
z23`?i`2Gi51eS$8s_;%WOvf`b6Bz#(tU<LRG)rP#yf**H^)Vd<UK5w>4X(1#zYiQ$
zn>%Q!c=#>*_-MJ~TDyK*z>n`=jQLI$`Fguo{X8tsKk4otEzcWa*C$J{=(d1Gj`zG-
zWZC$iEHY+VvB=B%=nobd6Z2+~H-d2U#Ue}Tc5}p!-uhyZAKuPu#hH4u$d5ktL$Js#
za$YR*En`1e6kL!8M?CiHMWP7)dM(g79wZ7f><5V)lei#}<E9T1-MC0}TPhsk)$`GE
zhqZS7w%jCo69y!5mn=a`bSM3!MPrza_R<i1w+s~Gk%iguK}nNrqb at BPaEz32^cMEf
z{C<`_TEq63-#FIqud()Pg|el!4xHjV at KNqqf+Knc&hf$>bBuc6LBHOX83~Yoz^zpe
z&X{aJ-M9m(;ugg%=D?Y&;f$UPjfy$y-Sp<3 at Qh6s|491qoD8<K^3=?zwQT+_%G38=
z0JvV*pM-Z>c&}TAU`LJ}Db>~stJMi*vBeb&O>%9XA-Kcd+#o#Sr0VfYQQI{{e<Jg{
zOs-ebvoAinvBGq0SRE-LT3%uf$;N_X$Pq}v?NQzrCO=w#t(c1$u at tczavjNNZxrty
zvcxf;un_B0?RG&j9q(aAFN9wmAK(=cblmAB-NF-$N<jU~H!O>uPRZlAQ?Qa at DcItS
zQSSnyB5QF=-fH4i{f2Pdq29p)_iSl|jzqIVu`-J;)omC`WrJAE%)-`-!DUeeTXcgA
z%IKTmhtsO4nqtT7tOgWBWATy)9FF>4@#hNJj6ZxUr?Wobk1{HE=Z2*#bC=bwZDiu+
zz|v|11uZBX(WOMrcY8ED at NUBR_ifB=tPnx&EB{b<N-?G^=sqVqSyrTAQZk4|u&?4+
zLzUa0!!G52SdTbd^i%c6*z`dMsN0$x%1!rd;f|fp6%jm6BO7>9SL`cyW#EXIHnKSI
zQQZ)lXM0HXYTZ at AWP^}s85T3k;;L*uZrKO!>=7XASt3#3PvTSuei2024Pz}{b?1UU
z?w45e8^7M_mZ|-<qCdx|!&JG)sN<2vCHq0VlvfOq^TZ(uutQk`vb4qzDtQp#GhX?b
zcc>Y5=AGue3t7H`t(}D}o~e(*=D6fSkF;}a$}?2BV^{g^aMa<<lOp at VGm{ECF3YGL
zoU4G=VawWlMbpdh4TI5BMpsYZYz&SwZ_~4<f-~@s#ud?1ul^p681hsAZaGIDD;WPs
z9!n?_xEEcN!QAv46MWDsPmc0ci$%tx_d_0^%L3L;*3T(}f32dge{d?IVW(&-tgks9
zI&M|aCwbfdyeVRBzZP8cWmFHxgCp*m<(bavm?!u<SPJJLe!L4AI=nqnK3Pr%ZqdnX
zSqQ4H=}fp#ypBgBjte=Knn4DFI=)Iz<^u5y<A%7O<2?@R7v3t~_i*S+-pCi_XO;wk
zs)~sB&h^%rvxh5Kiu8e8(AVle554PH*7<0;bTjw-#@iDFPH8#vg=U&B%e|+Z``dD#
zT)Tc-{Qgb;vPeeW at tn*eVr4&px(v%gR`u|_V`N=B2v{G~$e5_YLKY~NQ!%H~3Apvb
zSU>6yTrsHg8!7Un6{r>oy8k?e(906aJRceb_M_pNOdggQmBd1$gKIex21aq9AaKJ_
zEC}J_P!tO?{VXPt at QrhHb-wLvkT3Kg&TMR_ at b|0+B1(8b&oLIyl)+1OTuKZ-P%+|l
zJ?r0J&dGtxyo*0p{X8t;=A261(#@DS;STTX=h4?4>$F!lbd7$-YlSdZ(|?P4XQaA`
z4L(8c=Mj+ucSlYvtjDz>MQq$M>Ox>v*!;EQY}`R-mO8i82sUtp8MQ>b?tx9~3|Q{e
zT3`JG_SV$T3+sWOdcz%OcDjW`i5uvlpSmh<3C9TgOjqF1m?W5n(z7+o4*0&&F+9`8
zyfAiTxqGbGo1P1S=h1DghS}WU;qHf**ttL&m1TBM$DASuTe at 4QRVFqJsy6!zZ(G~|
z%k9a{c>cEBY5C?V`0KKF!DFEaf6`LID(1j%SVl!YBJKF#fs!i6l at sICdq#eF7vqh?
zxehzkV5$Mf<AJdub@^k(64t5?yoJ^6D0duTsN-LONzZ)H1CKpw2Q4$Yc>V!rXgDg)
zm?SW!&bY-cO5+wbaOP?_V;qEjS)EY=dr!D#Pq^j;F~fC&9cLj)jw=W#gqCS_Fqy?{
z#2s_uyWm!C84H>tNf4N`?hIl3z-o0yS!{7diO$V41fqjk;szd(16N!MLboCQHo?A*
zxx-3JyJhj&jhWxE<8-pKqSpqbv_#!nrHUw=S7^}l=OL|wA^c^nF#aH#XatW+Tdv at p
zP4ymWxLkrZ+`5H~2u!6FiaB<KDqVC#&lPfj*Tf%&U`*9rJl`BCR8nAsWzp4YBrbkI
zjxGLTk9wEY*bz!H-+61y<k)y=&hV9-dqp^RQ=Me at JYQ6xv-q+pY8gwao9G=6Xnj;H
zVNeBE)&>=n!QbSH%j5b#>DO5edW~7U-r+<u=M{Xekj>!3DLHs#d7zRXl~x8rj#m*{
z=12?vdSIF?<`5%^Ic$Qz8Cj(I$%5pOq?X!fpkdjIsf`tr@=E!K!c&SZWs#U!;t!m>
za-2%`)XcMrU)10m1Z>r_56clp-hQh57<!R`3A!J$;d0X at 8^W>kDH|eoEchGPAmI0v
zx3jvPfeeFh>ISYnyF*CC|NZ};{vX}dlH*2lME5#HElFTnsLZVV!CTufyz!=Ywij%6
zNzDO=9Fy!3<{G|>@8=isBCE1m8VFEV1T!P!|01Nj4<r8ZD{4j#GM=H(o`3nY8}`pX
ze|pjd6V7^)8bE)1{<Hn!Ww-UilWbS03h*IEob-JB^dz6q<@wvEfA0Qz+C!7w*Uv*4
z{<V83amD|6_v;?F!|q at EJ<<+RpVIDd(O+Jbz)dKpS1YdSsh2Ay^m2aLI}D5>2M?#+
zXTAK7FJJC6PYr*g3ik))UBBwJ+rcj0_YT*F{lB084ue;_q<e{7V$vwa&~k at RBcvZK
zpY#}lS7`V1+dS;k?(MWksN`+=qfbxzbQ11f95CG9lzaU)JoYHW-J3WD&fuMae~dZr
zi<or%0(ZEb+Ng(KH}Bj?y{O!G{hvROf4$rX3b<10O;qJ+<FrR74UM{{Gu&LGfd+!p
zav93i^xOUkXp47|{JYEk2|WU)!nF`}upiYq-{d>*PLDSpI$e;C{FI;nC!ele{X9I|
zF}({9s338{@M`z>qsH0ZAo=pnA0MadWw`SD3mgw+9;-k!-rarC=lC|<?AnFakA1+^
zZnOc~EhD7beYy{@7InCr54ZF0!{I(WPG8A+;~%8p=eW~fj57~!@BDh<A2IG`tP72n
zPY6F<UhP|@91o9qm2-FuKa2Vi>Obb&U`I{REVbcb at wGRn4<oiBHOJS{!g&8Cju4qe
zmHH1q-}z at oYSc!Er_=88)eft!{Jx)%>1k)bT>9f*PRD~W9?BTLX(qJyZu9-u`S^g&
z#%n*$!~J~t&A$J8|Dyn*eKJ6`SWQx?xPyP}>u{ErerBSn<30=H`Her%w^@uiusrBp
zs0wd43lYqht4V!BS(=i#DiK&OASq8T?{*NG$gew#?Wa!uyT<kbuhrcTV#RKRu?N_w
zHa*_N+sM4 at 19~2DFQdMXvwqxA#aU8V()(pT9^UWzIcsS`*I6?34Fz=K50AZ+ny9Mf
zazeM6c9+)^<sS4JvQE$bq2IIV7y%rnBMS>T+CJyS<g6ab>Qa40oq}-R9|t>dp8vF7
zyv<*({Jg0G&SNga5H+rq8JhymQdzv=cR!(#AUPic@@{w`Pt=&tr(aGNRMV?AB_yFl
zoITHk_Yn{i(}HuO#o at f4;2$rI24Ay&U5>x+r4bFs>uoR1<R)bZ8;$}+up906G92LK
zpjZ%9o!9w(yb1OpV)~P+_3MqqZ{nSacUAcNU7qGcpMMaOkNEYM=TBh*h+uB<F<@9o
zSQ*2VbwF;MbH|Ytp>Yys6XA>)bA*nV<9$Rnpa%*af>*kD8RCTF5;++|iO|wFg-#gL
zvC&}E=I^m4z0o*H*H6Cc5J%MmBPU;RM16CZWHGb%j=5vowr$(CZF9%gj&0lKj at e_|
zw)M?>pZk9IkA6<4x{|6?Cnq^|QooXVm*MJ=w1nfRFfTr`EXo;D7LqGEAH`N3X<EcT
z$m+cZU>YljV at Ot7&=)2n*9IgOkVDXCCnKMV!6pgG9xb9s{8K9~B?2jS5PL+}3i#;+
zz{zLX*aw-*t!YERDC{Tthk*$L_h3qrOk_)fs|lK1rAG_E7W_o2WG$1+n|;A^S|-eQ
zZC-4O3qbEOM$zq5B-^4`;V2_M&5)E|q-Uw7Aap0+(N>ogQspXB^$2Pw$%!cu-Hk~?
zY7UlH$5MMaS`T67;uhp)T)^T at a5EEI5>Iv{BfblMp7oLS!fBjq$O1H$i;h4XnvC%R
z3`uC6S at t#2GT4=BGLdOPl+46bX0{u<cU{C!{!W7ZRfXOY&dAV>u+(yr*5Q|f35z(_
z0!Xu#O9|EeH8$`Ox}yzD&cY}&Z-JCjV>l|G`Aab`x{(z>U4TSp)*#RfNQ9xSCAuFr
z&lz1c(mVa$sw-404=Z7@#fldN{ym4ev%g*iv8M#L^x at ECWkow>ze_VEpA%lqC}|KN
za71A1_m?^GJQJUTu(SD95~;m`jbE~$!O{=L+|rNeUupB}DYf-AGU-RjbHtvpo_Fq&
z!}7ZTH~QOFYn$<@FFwxTR#?vI=dfi=5DT^7HR&Zh|IwfjI~r!%D;83GR=nTf$u)}W
zWgN$4@!=fAFxFf(*l`RPQEMxuCDd#nlU?)bmeMtb76-h2;d7P88pm-gvBkoExr0+!
zsZc4Ld`K)d59&0i+&|@f;UCKT at 0`0BJbBf)cyu0AE$;f=^7}f=pwa;-+#G0LR}U(e
zwH?d-p8=#0S2{qA&7&&!a}B4?fyU(GL0wCp+b!>z|EW?I1t*W)y?5#~aHB%%;!$C5
zccYSgcB9gKb%PQE^5ukE08Jj&MNskLbAh0`-zKOM;~Q3%fsI?h<|VrD2#T1Dq$aY+
z&K6#w<?{1!3$JjqL1 at -oLQu8XCajp_Ex<AsRk>Atv=mgyzt=z$DgKGyMx9<DtQam7
zUJ$DdU(2PS4P2!UuRvlCA7^ofDT2=ClCVwh5URjHBXkZ~7}g|I{cI<wP-qrbdHe!b
zZ1&<7vDKVKXr4e4Uib>`OO`tM5!EWFvRELja;6a)=l1w>`n*+eVFLlxgVmJFrQ$3)
z+4xd^IQ=a_(PI!SB2q?X612AYx0jRJ`2+lqn>VW*oL7;Gl%!lZKwiJf8|CMyTL8;C
zk|0;wqa9JU*j!!LuDPn%oEzbOTw!OIG8ao&?AQ+T+nAOe0C^T#S<sJES%VIvRKbV@
zd?76<i6(WLGCSbd*YRRx5n+S+lvw=F*{0BZ at C6&h-olkLY<gCAe1Yzbnab~wpvd$j
zWrhr{VFel_PV7<{v?-<x+_SR0`QV-m%K4^Yd0Vc#0|%erj78e`e76uhWf$;=O`vks
zoN%r``9T=8D}C6mccCUmVI-uy^vp`~<nqhaS>-Fg(P8zwdlU=7ylw1JD#vDzDs7-t
zJP9>950g at T41a=9tQxZogR#^9HY at yrX&;(z^i?$nijnb-bxEYEG*!?7mm!8BjLBjN
zQZ;^fsIE0FU*2~|^=YYyt<kb}P+OeE`m4T~NT(ExF;^bLF`d4Fqs4U|@Rx(qgRqem
z4Hk*`5n;s1AzXP8Iq^CuRspqD5~eFz*d3T&(S$~-9xMoFRU|Snu!r&&Xa+IZi&bKm
zjifP%(CnNlw#f-_cEqA-!Jn)W*$`u{W+-bVW>c+0D06m+`Fgj19D?pWM%i$Nvs)DM
zP6P2B%*C+(3JPVu=$N5nO#WoMBBmJ!EnpOI{cR>xmOsOh&WQcZC0|88yl_-7u5q-K
z+X$8!E3^hC4KGb_e0IZ_?@?G1N4dnIH$iy*RlvLHS*+V)a?C>J#U%_jgKaC)gi~nf
zh-rk-w%3UqZhZkJF^y4GMQMDW9ra+>OliI`XU#JfU}vfUmX~j~-TjB42o3Lyz|bfs
zb&mbEDoA4c5KMpXNTjai%A%!lEN at ATqR`Y(ZO1Zact|HKuAbw`TNcUW=2Oo&%dU1T
zO${yfigky?^3t{z2=`yd(w{7jy5?qZ9LaUlYM at J?<q0HWmddvMBGc}<X0e5Mwaq0g
z0Meyt^%&Dxv0pXN2zP4 at Yo0CrTs64KL;bc at wDZ?Ae`Ylqs_pBh8ZpjsM>Uz`_0OFY
zWX)as_h@~Kq;4ygr}_A~Nao5%O7-xGU8N=Yni?_ES;xX?)Yh|f%n8bU$6)vzshi6p
z+$QahW{+*OtdgN}t#qtN&8FCZVlkrJkB$Wiqog`IRxx+!DW`!HtYn1cVzKSAPbFfl
zg*rOM0#hgKwXma&5at%vlW!Mw*$lT*=#BB#z;}vB{`0Y>#&63%R15QCxUT;y#lfH}
zZfdY_;tPf^iKm4Y0r#U=QA<{j;~Bfk<+_^tv%Dt!CQ~=<&Z;rwMW?E)P57$!RT}9+
zR09gEUxIjos>r5nH5HhA*yp+1$!}#?-Ws|0s;mz at 6~iDMkE0p814jCq`?tp*MOEpf
z7*h$XRZ+y&cG*Q$o@&8WxAYt{5}L+tKrj-T`>h(E<5-R6mi~VH7sS?+>RHYosdb8h
zdk_4j=8Afy-^IsI{P%;V4c}md_NCvXguS0Lud7w9-<<rF=TH3TZ0Gaec<}G~H>Zy8
z`dLov`thUk at AuxRp6j_(WVGwK6VYuCmj0O0>tB8$5SR9$li at Nl!IK^B at D{b<DT6 at l
zv_(+P^?WX*)-)G5j-JG5u#BEQ89}>kIjnU?dnKgexVdB*{}=$~Ia?gO#yLB-VXQp0
zxwG<D(ASHvV0EEeSThnx44~UIB(90bR;MEe*)_zTqiGWPG7Q?f5rHHb;~ashE%mt^
zwen<jJ<P~*^v2&JwK!dKD=)f-3ah|4&4OoKf1bGXy)hyGjun}^Y#2GEHPap}8!jcw
zw0N3&A<FWC@`0<Hl0DVq8@*LgtmVMNPDUSx2gnTKVntANHa^95iz{h**pTf!M at Vp0
zM_tp3WW==)PndLSQnW?jK at D?!Cqv((kj!{qY~#lz2GpU}S%4)e48O4e(Q5%)2E9_j
zl(~f3EgL7k#m)qFAKwE-VMJ(cY9<aWEkd_7M2qabt#mXF&oQH_o?e2*gsWmMZBaX-
zp0qM5-CPt4=;3C+;*Si+#v{%|f at 7)QlKpLSDp0vSYEFj^T at Bm17Ac|_vpNw^I&dLZ
z-HHjes|Th&D>uor4k at MIP{f1fP#-zz$tZGWf!Qv~_@|dP?q)Mw-DDopZ-!*fe&**V
zt;6OdBTB?w`^VAovbt0qwt?UQIyWvL0Q^AT$bkjcQ`rG;=D^H(7x}1Jd7x<~QY{!?
z0D&q3Gn8$C01JhDM9z%uDR(>Fn>1SGy5cc`;q=v$XX<6R&|pLH5E6qu+rB6;f$DqR
zl^1%Lw{rT2oD<7(hS~~2vUj_JsEQAU+?r?O1h(JO7^K2rN9`m9wx8qq5T)HeNMTTf
zrC#=l_|xL6x{Dr=@gws19W=)C3%z*XOUvdPB7>d0rg(o_^|`|=q{40=n73=EBJ_!|
zKA5wbLjNH8Q8I(0nXKoo3yIyKPbx4ep3v{4CxHa~xE0Mu35?eF74ZQPEPXKK^kpv;
z8I|FrLW8*;=%boHf&J)jiVPe^ywGHH^#>FwZAE-$%^K!5^UO~iz+^VEg7b!{KF`s@
zyY0Zkyt1)=KhS`jZ=^y$%Tl(W=!>qRQePhEk8+m!K=(DHNNL76K>JT~;=Os}N|sG+
zD6VVTrRqIx=5e>9sSi4 at NV7V;hf$f}X~g<OFC?1r^gz0p;yra_O5Gbs`5vBr?w3gG
z-rQ?LwzTK7bdF#t<<_ZfyD9v=`j1xV&#vY>-};?AF>z9dmOdkiF>!OG*!am4mOe>z
z^81A at oIiv^7Cz|Y(p%h_{}4-W1v|2O#82-Yc%{&vc%f70pUZS|dfbH^-?nOZ@~&4Y
zHhjFIJXS}Q1HJPvt1&hlmElCcvDI~hlDH at 3Y8nFHM>hL+TXv#^8E?t{U9ypFl-+60
z-VSAz+xi+CP8RGx0tgdr=WE)?+M#+B+!}UyR|Cpo&?YjOoAZ54qj5TL!x4~50xs7K
z*`G!oi<EL#7-8smwTxwVWY0BV=TeT{OR-)El9L;b-I!RGQ8<*KSEh~b*Hq*z&k-?C
z>%Z#@@<f+ZC`sS78!$-*I+3S$g73?Nq{`A9Se12GtGOahmd0O0R9e%`8r(ho-M`S*
z%NZFg9r#pbhOqOVL#su;oxNOa&wq29N_rg)L?#FbpDhbH#{OOCK-=+^J!nDa?28Z=
zIn}YCO;N955TQxJ_i72TMW|p-WY?%G)C<4>lTm!@i+ at zdYLqNailq}!WfLY`rDGi8
zZO1$xN7I7dB8^<R7CPdL&myIie%s?vzQ8c=QZ2bpJJ?sv1&jTdeogbi6t~ffG}R;4
zMJx}br1SQ-S=@-v8EQC&(2?E+HR){mc at obfBU$NmnxmLc|0iGDGB*>sbbJicJCoLL
zeMM{Mgl2eSLLa*9hGfdq%T1q|GOGs*qQ-kw-f~9HV}xG5IpP29xSrXyzG=Czr5It?
zx$!~WQ=!IiMG2?T_*vm5i=EkH4CXJh?ykXenQ#r=3Djd?zs(HZo9QYJJjwi%opAa|
zjD5f@<Ge-oyl#18gK!{>Gmi~=_Ohq<$*LU$4+;!j-@(+P#VhxQ*$m!Wbr-I5dda6M
zzV2Uo(Ry{?79tghhB}`P5fGcGO<j96UF9SmCe^Z66QT~~T~(dIyjt#T4&0T6wPV;l
z&T}|wH90`}{JF&{?t?1FRW6MV{WH5?c0*B&gUHEkFYwfXX}%smF2^%ZMyK4)h60hI
z^A9n{UG0b%hRebXbgJu%kSVWBR(^UGLYg0x;M<LCXCcvDTfz8b;BK+D;GNhAG0X%|
zOL6b=hF~09%}N9+nS03T0tWVy!IUb`fOgjUmf1ccb{&E7jX52GB-Y<vP*L7G!-k7>
z!4%@NniWCXJs4bxbB1IN#?^y9r<*sI-*tPVya`>cKpx6Bff&f}_H1ZhUmhPqcHTqY
zHx<5{p`t~6f!Kllydsgli?p><6pZJKc8z at -4~O9OH8a2hG<<o)7o0Z%Xi^irnXfKl
zD^WjAJe+%D_MzmO(iQdrv#7L={pd|ZtQd<<b4SrAbB-t>hM}Jqh7Cm681Yw at tFKgU
zD)x}G%Ws|>vV)SQ{%8`y_|z}~)m7n<$Ufn_e{nVNnz98xrg7!U?xxJVs=(12h{2|o
ziY*Rm8dK$V*)hWO>I`LUEDG4O84yFYmKp^DBX>X`b?ik3E;e?P1G!?rg2=Bn at z!gW
znC4C~BXP09pF3gk0`4$arK7=!2Nvqeo8MAQDt+z@#_r7BU~HxlBzF+c5eKmf&wjrH
z-j3a|ez9PKP~|S@!2dZi7R1kMudBe%!(7j#Uy$j4{30k{PqV<UN|&fS*E9sKs)De#
zS~<tBvLrY#lC>=x4{Ek1U#fx7VAek9&j4rjt}kKp{m-}L9u4J^Yon>H`jMb!I|L2*
zq?bDg8{XlY&VnT0ezQT3QwSS0zZUI0+WAC_cQOQSx7TbX4<uW&nXkNR?I;cWCRbvm
z%K+`xqb+<EQz`nbkJB08n1Wu1#ue1hzA2{~bXzp*VLS`z_kv5WKWwDkQcaelz36sW
ziEl(D5Qy9!9j209hr~121KZBtrn6)_OtDaH*q*<xGNFFiVc4wXREK~0 at qmL9xAX6&
zD|&n%BEkUkMCIT`TdnBAt=AQ;uHT}OO2tSaC3TMgThdF!NIGqhO6WfLs7G%Q5?_qj
zmB_Xk$Ny5@|EaGiIC-X3UkZ~Ewh*K2Np1Kz{c^3VIObuAHk6;N*%-!5ttepzopA$a
zW$6e#yw8bb_baz~X%?Y9gya;kY(t$oF}6I@%k+Y*$tp*DpSXB#DY45ZK&QCN?X`Xh
zI$ViEC|^tP%tf72F82goZs;yl#&!sYX#(Lp68ToJvSRRWrch1H`(HhkQbs?OV&Afz
ztAntYi&fQ140G+yAW@!a2$U|)U<x2qTUxldB|PX{L+SHxEkLwF&GC}+`oqDyc4FZx
zaz&`}5Ze6P#2wO>J{g3H{X^Kj*+jjeu+Ou0fVzyB at IhN%cH%vk4Ix0u^OC(`H!|r3
z3}{KX*JUW8-<<n5T)OJwSrHgZ%RP#|WD}a&k^Gc0^>xP!`ZTMr(3`I%PIiKs>Cz9L
z9UPHg!TlcA&4KHqV?b^4Up^+ixIBLHH90OYfA4)<;!Ru<;RF!p;Nr%2TI^#D7KxBT
zP`-GRvineUu6N{zpA>loIwqq&@t%c^_BMAPc8nN<PzxgVP#`=tV4bry9J!A8`{&F*
z0COolsPq<$i at o|8GLEKUpCyi!{`@`8)^I#HQvomc*|{0YJowvCC-usm-QeT1Jo-*}
ztlz at KTxF-p$b%p at cN^;Ri)Oq}YiTm`QvTTrq?OEnT-%*R9-A!~8<(+Z)OHb^<&N%5
zV#T#=VoCMkg!OdZL$x{ljkZ`7=2-)UHiR7tfB?(dIDeW7JqK*yx8Ev<4QAess&8$d
z9GA{z34%W7WAy0Wyh6qumx(!@Xi9#zuxj9PDn at xWA~g at 52fYcsthFFcLbSh~jv=g6
zu`G<kI0EkerX}Nbiwu$QWRTNbuL<+6d2DP<PQG3PAX9nkHy2GWU`Utnt2f2ikn<Rs
zWst+K6YZt5Fdj3K$+#80#fm8_!uD|#yfIEJpstg3hH5}VGt3YG8T&zF-5 at tEy@Q$!
zGD?jvW7G0>x`gmktE(1_?Qx5-$cgXy6g_p|&-KnDcp}A^b}0d{mb!$?U`GYncG5=_
zTy at TX*NPS4E0VJ8p{x2~a&MOnNF%gM1%mf4&@_=H-5_=O?LZ;1{F$;zX+0;J73jh}
zk;9U+^RQ)MC9X+ef6+N1G?8nFvu><4#9fh8-|sCmBhUf@$&^Np73%>CU?vPhP#eQ(
zaou=&Ie}tJNU7pN7Biv0^7`_H2ls9z2~}#?cq&OYAgNxdAn5b?DSebO>;Hy`f0+<N
zbuS6I>XOs^@f1Sb8;*b6w9LQwuBkf##mKJ1h+*7JL~A^`r8Xh at E3k*n9Acs~1SJ-p
zxSvZjanVK2+Wbp#eo%{!MorMWe6NS}VmXCTV?#1Ty#{Qj+=oyMqL0$JuGj7tc0zt#
z`5!Xc*Qr{0nu#?re->{zK((Elt3Hh$$I-imK`I`CKm+QrwQvJAgc5BP+*;6>$SaaY
zICL_Jfw)a|2inrFZ65<glnl`}n&?du8l3i{Or`y%BSF0VAeVx_h7~v`ySTFCnek47
z7#(~}g5785gGAkyk?OC*XzmNH1_7;h3ssN}i|kBvQGQvlt)aoyG6v>0!`NGAFSPj>
zhCLdT`oKgM8B?A{O{e-6Yb4^~;f{}YPzRYcW3H3L- at l{ssE&iHl_s?#)-p at KU`jJA
zH2}>c0r?&xA-=GpwW at DSV}eWt%mRFSqESi670MtdALv+wXrButo<3E4tYX at 4MP~K@
zqkmo6w-}~r{_{MkrHiG*Subtlk?dSnqEZ8wu?tCD7 at -N}1c%B86$cmcAT8Z&Ikh_b
zEG0!_m?tst;o}L0gb_GA2_a?u0b8VK?_n$NV6VDQIMm$rDda`8HrO?kGUfDPW{r2G
zw1fSzWz<#@UG5TVIJ`2kJ-jkwUwRGvn{3UD`sBft22GcIJ9AcI<oWFoC{^<(d_wrE
z2nmIUvy&L{=QhHoY8wg2sxM^e6hT|-=v!sWAC0Z!ja7a2n9H!J{u_JfUZc(je(jd^
z>T at Wqbqe+b{~jvZOvEF5zdKp?B;ho36%m~FDKH+06#_E+0aaoTXkyrRG~qodV at A^&
zFa8vypw<m(+LMAaCp=6%Ap5%!RY0jD(Cv>yZ>d!olr+pLviR}YFuo~Nyz2%^n?0{F
zPGpHrQ~VZ8moP&x3k(G(MeFvsI!6rDpQb`ANL__YQPt4*Uz(K453U7?(vd`5<E+b`
z5Z2bahu#faF!w!#+d28FwuV1|)GvOPS_bKqR6!S_c|`tho+)Ul#{M2yGc2~<a0?eY
z<%Fq`T}w-v{!!`@gEM+M5!%x-VBB^l)oNNUHChws^0z}kJ!nfF<G&R=Ewku{(Wy?x
zsM?(4NztAXoOwXIb`zsinr)jFhiAH7I&{MvU?*=HA1hmV6)qMoY}ai?^~jeDo{1g2
z6VB%PochJxMi>&aGr?Yy!99<J7%hQhVT6Kxrq}!zakyR;(fX`WD1iU7F4!gA?(o2f
zv^qF2xl~mIu09tnE=P7|AF>#;b%7OKEk|@WFzncq3Oy%WQKbtW<T;u)ia%+yZD_Gb
z3|T}%QcVn$Yi{%vLviQy?q0y(7$w`7a@>Y<)T&- at 7dwlJj9VY}FlxGHDkv$sVm>qW
z at Xi0hYw;Cc$L!zEAIlD+nPCY!!J&~COIp}<U;^O6PaxBEE=P2{f|+~L9pl=(ZyZY8
z52A<PCbP_l3SLRv%OnmmTI5XN0J7026OVAG3>Ei&UUG(o+FUfeE#PDvUx|^EPH{($
zQ0#wXlF|GB%#N at l-Hbd>#M9b;cRD8e35V at snvbI**c)UP0>DciTJ3b;BhH?JaNx(~
z*YJfwqTBDTM$s3_MQ?NrD4Q&G-te&tJZ(mUd{PIc;4h$46&4VH^q~-1LdQ?bxRW?t
zwf09>12(eOT at Y(Be&E<^frnpXzo;^UPEJ|~92w4c932d<C($5Gpt+rT4;a0);!Q}j
z)`+#fRY59ShdT*yG#!e{LV4J5sw+<4a^S%jG$EpFg;RV*Fcxm#x(}pSx*Tk_5muIC
zzA_kLg^7vfWad(k`kOzde2svjW~oNX{CF|h_#bI2mzp?s7BoQIX@}0N7&k9DAAK$5
z-kVoY{ZzvtQP&WJo4Iwb9@@CwGP4Xe)q^Kl+c#g|GmU3d<H%}#myIjy<9Hw{7LiTi
z^T#$oy^*mNk{OpgitWX#IKs3#_hm3 at IeHU$3Bx;jt;Wv>2 at d5Gl7lc0{O(ar2dLrN
zFGF?<<luPo1@|!`4X^G%_b&^34_f97&ZsM|Va3!k)dL)SY-i4j)4j#pxO{7Mh4r*n
zt4HJI_e?}{gx`yGStbr<*QrIPLbtMog+Ghze1kU<t)c)%RHb)ojz+(GoF-E at yh=r_
zB5V2S)Cn*4VI(cHK?jU(L^5AWoYo>}x}2PR#&3fpu0Yp#b+=+9o96GsBG|8e+T}b3
zRxPOqIXVAWt2tl)@xm{V_o at Po@$e->K+|KsP7>N5bl96q7<Bl-pNb-8d at z5C!eAp0
zt%F>1SMmxsY}2bnruE?O`Lnag>k-D}@nOR92Q0IHyHmHpbCzkP91|C<+V*L5=Qjm2
zlCVEW6j^wFuOkVj{~~E7Q#Vhqv_1X(c*Ucacp0LEKd=|6Fu&L5n~dn>sacWD(H$y>
zmt~eP_m>ObLd1G%ly6+61sBG-s at kSnzx6+B=#pb65#?_hLiLN$I;XT-=w at n%JUX8|
z7(D{!-!6455Hv{_iss?Ai6ob at Aohg@s(f;~cx4T!ztbC7EjZC6SvmNVx?W3%1-z$I
zhp9$Z(<XFs%-*&}pI4Mi3 at Lwh;ByCfLt7DYa0BEWiG2XXZy`<6gB0sTXxax~g2MG9
zNY5PXIRfN`^gCSu?!RZM)K$4g;O*T2=9Dr5#n3z2DA=r$BdDT!0Aa7y^x#XGs!a5$
zcY=Bfz2<hlg4(f4^o*sPg+(YbTPlP>9fZtR?iJHWig9bdLyhVKcn%!IA5dd+xGWE-
zai1Ju at vR<z*et0<@c_DBGC`E^dTq*O*4HG+Iby|*kXcC5X9rqR3 at O^nndY4MWQk)q
zB2JQU*UV#Fi|q{LmMZd+TFbGa<vpa%)?I?XKH$i=$ViRW4dx53CZhOx53wG at I=<q`
zy1|#+!**4B6Q>(M*3*DilsUvdO?PFvKcM(i+g^hNoHPm3k8)X=b!`&3LfyhB+Q%nS
z&5^IDqyy8;`e8J&8T=oD#$|gdd%<c>&n0HuMb{a%_&M`<NE<3F!rX2wImUtODf{Cr
zw%lVb8cnY}dJ*jW5VJBXkNfr0SL8X#47MtIJ+BjTByPQB2eo{WwbDm7*w4>6<U7{8
znqwWjT^)z!5!{c96IvscmHJh<3>Fp%qsz%Y*`_(87e!|NfeSj+bYJ1(8gD=qyAU^t
z+vt)*K{RtFae2{R8{<k$Itf)}1Qg~O$nICCpG?G6N<D0oXnCIDY<D-7p5SRAS*HTG
zCw!enG|L@#cR&!;qOjuYHtE>x3nxhHU4(B>Nbtz>;*aiQk5<2q(1))X1UMXn&7%5=
zrWke))}lw9=lf`7y!ZlAzY&SI=)M#4K7(0aY?4;k3nCv0HaG^r;w)7kAvvn!#F61_
zRiox=a9Ij|Ss*G_|HI1Q{1myS3u>YS1kajd)g6XcDU=NbFdCgH29*^P&7Zh<)nsCt
zB&s^oNXMw}mD&;QRX9(QMCd3M0RBn0c`8hrACS}hKJj|tLactIXTBNrxd6Bkkyv~e
z>TPUdH^f;yk<byJ=au`>&&I2z?pzjY|C2v~JxovIdrxni=@`Mnnnu2?8kG-gz>)=p
z-&FhbjlWbnxw&}%B3U0hF^6rwGPX$COWX_sK#aBdMEgc>Vrz8;bz;2Xou)?R*HSvQ
zr9Dv^cWT^s__t{^cC_hMX at +jlwJgsMk*)sZC7$9PbE}u#7`ma{UAr>U(1!~}vrmz^
z`((8_zWV2o=*WrDG0ql?TSxc!ufNHDDm5s9)qlO;g1qPqN#nqY0fFnoy65JhwmavG
zb&PH5Qu<1Nw8Dk7K4=hD*r at v&hoMeJk=Ry<@L)-41`|BkyT?r-f%l(*uF*g^COF9m
zj<vdl<ind0b97B2zt1FtLx^hs<lygnO^Z$6)emLkP(`7f=ql~HNAnm4=XSC*C^g{%
zDR)m&>pz+#;2645m9zW*tRtl^L8AX+SlR^6y23iM^_QJa1BuD5n`sX|d9U9`(vcoF
zKY<YA&A5*;RsUwtm`RHS3T?uV%ct7%mi6cAGms788~IgO^e(=FP<TGeZynCL#5hRP
z5JOoB`eU4(b<L>&PF+)RTn~+P=bTIvQVCvD+Ou5H(+Y)np~lEPN)27>V+q~omdYD?
zZboQ)?we0V)6A#9s^W2Z2X^i{H0IQ?_7%9Zo}kED&MSqHTVz@}6Wg8oD_68hjgj!Y
z)oFQ&#|1!?HKAgp#{GJI4b8ns64`mEidmDt86-~Cu97KU87H2Yj>#S|P+7T=Kom;;
zaMk`A;{6##?!6-Q<I495T{Mb%=h}-G!lw1P1l8Y<ex^&$iDEQIb#hvzr$N at 9Xx-~H
zfXgL0$uQq`!ZI$`!YVR3wDRl^YKCp8$6nnc#;b<4a_asdiHA2jpbM=CQ4fWF%h*41
zQl&!M{s3=rd%63f*&l4#?K1pKIWjX}CfCX{!@tea^yZkw)%cAEU-*6h`wIY{1k5k-
z@|=1UxRG$>`gr~f|53`z&LsQx at s9sJ@Rs{>&Yu^I at wyH1lhVkZ15@<3{0244e$3aG
zqISr>{}&aJ8kGNc87?Iq^_ZFA1tM-cxPmx+AJ(R;3dvdt<PcT`H4?VlABXzG`=Ue5
ztU3)fsgo#xAdsi5Qm}KiZl_ZNBp2Oa6j9fn&?P;Jpc<>@qL{Ym=(Q$)X<=D-g5ly}
z?c5+0x<Y`9(rHX}wR&(V(jv+c#imH|oAT7}BGx$*RG)JN?mCU$(lSkc at P&91+3LUy
zW)+B~=@IxySsa02!@-^o10B(-U%PlSE2=>Py<sqa<DQ$ge(OPoj!wa+7)q%~6kqM7
zYvs+36pMs}s^}~lah+%^oeGl3JsPIW_BWWM@@hqhWxnQj9OdtNDP=mRr{P=nC1a>X
zTFU*C8rbH0j9=5OG{FieD_2??dg-_N4X^Ot?p3ez5Y^m?!<6Z!RNds8gj8Lr<|&M$
zbsDw_%B0*mbE=)9&6QNXC&2_pR3c678U<*4<=#<tzLFno-YPKQ!%BtAP|g?&OsK at f
z44p)Cwvy-wZw at 6@n5gLF!+GVzrB!wBszD<WXGkkVK_B=hgVHk`XGu{8j_Rcby&&c$
zf~S8rTkbD<PcW%_MvAMiHBt>!W!o<J>GU9g)};z!!87{NHR{Z6RlaeIwkFm$rD=!S
zAzPAqw#lV0Ou2}?E8Y3b at 8RW5_j`s5n3d5upIh=ygmTMzhyI;_N5?*ZV;RO0?(SKu
zA>&DYIRxU=#?4|)tMvzFvi?DUXZ$hb_Zw-uJL<VMy(Ww;?vChJ6_{&2pQ2BbnWn#`
zhf`++nK`r1zb?{E#XEHCjQ4Zo({OW%(jthAh8?Z1nscFQn${TdRjYx<DkfYte!$j{
zQcoUjw<Tw9G8aGv_sjfIdLk&SPt4(ZIG_ktJb5@~XKRrbB$edHsTHI;QINdm&H_Im
zO?$BgP%|R1J6C6E#$O80E+fyxnhwIQ#_nwSlUfo*&^9z#<+{BFN;~;UW}{m{e03NR
z%KA%SmeAd!wOMS0uC2inE#5<)NxNcyK=g_8Kz6$IAp}8g$t)kGa3 at _9u`k;`*r5O`
zyok%_IRp7n2RPz&2|G|3t`%)yz}Nbk3xE>WSJny_4t(ylHH#8LVR6{wK-k73nKwJ6
z7#Vg&(dk8;(Rx%(5}!8TmA6mu(RoArB``;!(D-$YE30{9fAt&#)9>7!3QEK*w?yZ*
z0qKWz%@61v3jzJI-2!9TNM_S&5HXK)Zy at dOuhimWkJi2vTeFK3u(_mBxFcT=2V6f0
z6po=cnHpX(`hy_Z=drIzp)_gj!>lzR(5BmWqY+^*;xuRU5{OLf*moibEMfKLSMvgw
zE!J98ME*K+s_X!u%~+_N!U$zQoC22}+ne~o35}P83eO2a^0?~~w6x%bZyvJ`@L(F$
zl|#j$dld}!z!)CKMx8*}Yf}h!qLr;j--Nc%1ZPh%LCq?^$AAV*1Z4b1=K^^XXhz&4
z%Gq0Cg(pI?cE24GPYr=1)pJjnqD!q3cpo-iUVtIAF}#UwsS=Q0lE8pI;cA;@`th-x
zfQIARYk(WAm6WmvoAe=tTeqWXSZs%;m5lhp5Q6$VV24}60BxKIpG%g&L0V>(Z2^{c
z1(fF_J4W;ojHZ9QP|CC-p3|vX5b0brO*4d7(!JBPbBbN#&hsdbZm~2yaJ=Xh7Kkrm
zqs0p#5n!9xYmr2{8rqHYIwsQQ3k&vxLj>w82HrNB7Tf-LNUemvNq0OLkdh^1$iLIs
z;o at 4$f#<?TX7PVfk_7^d{d*MKczP502VxBw%JYLF+H^<K-GY1w)LMd5R$L|F#|PEL
z4BLZ16ue0zflKjbf3ono!b&f42C$fi84}-&*)gl$IN_m?*tS1mnOb8VV)mn<02_h8
zg-n(@i`h|0WN`$P<C^HVKFefdEXkc5(t)9A6~Hr at 62lx$K*D4{SL>EOD8AhWLU4-G
z4t{=jrCO)#Q^5wiCmG+HePef?VU&ZWgwHcOe?Pu<sGtCYSlWx2qw3BnYlGevPz4vc
zsLh7dmJ)+rsu0x_7FHZ_1`#~SE0pM$d**G-z{~>AK>FqxpOiJG5_rt!BM)4VN_ayd
zRidqL&<eUR9XN{?>-;V%q%8Fm5ZtQ~*%08WK09+k<TBFA45tyvzcbZ`D%i$lg-xoR
zSrr(!Lf|?u!Yk9)cP{EF!JMscM34!AYsNT6qZp(nmZ&;Olinm-^C6H4jcxy1+mSI5
zeKLq+O#`VH!{xmej;CpfIIF&j`FQTUbOmDgi7`uDwg5BB`23Xx72+f(@u-VXA~B+4
zp=_NdqZY`pQzq;o=mOC_bsB)7#02HK%P}8q!XspwgO3b~?gV)9vIp}b!(S9`SZuZe
zB~N;@Bt{ifX|N1Hh?*WTUK=4;^CcK8*k=^ME{81`Kso){!L2a~{0)e(;gi+s7(eNo
z^u&up%n}I(D<W>nVN=RavJwe@$fC5~3{j~S5rr6c<(R8&ash>yWpuE0Baj)Pu`$<%
z0m~N8N(g2 at JGqEC6?(m(Hlh|>xe7d~qczQYPB22S)w}Bo1l(A-Sm@^>W#d&(hd((=
zFb_CLC2J(rfLzD{Km;E|9~czQ7X>vS1oz}dUNGtBYW|@^a=KGZrcXZsj;A3D#6|3x
ze*l_u^aydEDY+r_q=wFm5n7{a{y0s?AQW|jGeI|3EFU@}6$x*se4=_gARLt;ctZ_1
zQ4As%Snq1|pa^OZ3Z}(V;Shs&P!D|Y0!exijER<Uh@{q=iJ%ju18?GSa)-}=BSe>o
z>>IP5&-sW10zkS#>_w_oA<8=hU1WOUs5(MoPY9ZvO9MZZYrUrNspD-b?Nv3*I~I)G
z5TL;bmunE5iz at 9`nPps7J4|V0=}o6d!g~<~%?K;!s9Sc3TGYdP*#+y^VXW=x0#j at M
zGIIbPJxWfSeg&o~Z9+4O&sU1X^_>!}jn4OlT>;Mf*b(%dwFc#+SnMo>%CqRCaz)p=
z7taWEPbvp0ahCaNY61H?Wq`K$fCI2PRm)m07l`~)DOM~&cH2=lLC_EnE|*HOOoCr5
z3?0^9bZ~Q91ycIqCy~|t#5^0 at D2q!vNoavP&m9uacL_R4e#C!O2~+~b#Y$qt;GeMZ
zJ0^|Y5W0F*X5(tk(Sh at mwsRRjb2@V11&%A1ev%FF)2 at vODJAPcSQW2XP@%Zw+`_2l
zam<P(ZwW8^LIfjtqs}BO6}zMNTN8MFA0+qr5^zPw)>XuM&?4yGn!6!vMlL%-fzk`Q
z#0`Ea7I!;!oq0{e1k8(`fX$8<a0-9y2p>CSSDx%#^LWW03O$xF&+WquIP{#scg5>=
z*(t^dMN7b^JVV$J1}jjts8h9USK8^F+;5#r(&=hg|BOh&Wq}#!->A5Krle_c)J#Md
zSr$7vKOF|X*WFY`b>FqFWlgD}zJ88~iFGXYEuX{u5Gp&7ef7K4fDDluia`*8Fto5H
zJVp{}RqRC#Wrj_fJ0-}jJUk=lKw1xMS{87b8Eh-as+kFcTf at Qyr57unYwVe#3PwQH
zrE+cFbBhSi5h1UXI!BKbPm4dxD?16q5`Pn8oiZnw4AbkpMo*+d5lM9)%T=N3raIt@
zg1$rwet<4Mi*l-qcru$xm=~Yg^sJt9?zHxzVavc`P|;8f+2KRby)?F_es2o5*bknF
zl&RHd${lg1991wJ?-U|Y)!XQ%S3UVH+tQ>;3aJS3SMypl^!?kq_`P+BbPb%AQ$o$F
zvOrvRs?zE~-a7^XUyMbCou1douh)ULXdYf<CXTr(#5 at vTm8(KO9N~fc<P)w1fvib+
z%>7sJ5#(Ro9 at Vj7!lb=&cc}0dEQyi7T!UDU-K%ZbY8~*ji;GqSx*P~-ZnZ-A;039I
zW!8kX1xmMf*B7U|vlA8L?fy;dPMCU-g3ksKaDm+f9i7VWWd-cpL_+7PxHIAiZb&i8
zol(PgFtb-Rkmnth|FkYtPMCNfyqtb!mEl}Pyff5*oKnb!Y4INFdU at Sj2~{rJEMkte
zOHtIx?kWWBO+_8FnkxK|V8=d)r88ylyTHn_RLCow$o7n8Hv)?SG+e<_Dhu%idhwnf
zC8~XF_t{a%gIP^RX3#@;!Ouh-uv<aRpwf%g%}@V|u*!`3su&Zb*r at dI_bq3-INVSP
zM%PAYsZhFodQ%eZwb#;v5k4q-eM>0r23L~wO~}b#Fyt!`vhGpYRNg$h8N2!`q^dWP
zfEx@>rOGvp*{?@<bvg|bRZq<#-c=4;>up#9;r+p5>xFULR-p5Ch6)lUv8!`Q&%$a>
zkS&cM1Y0B=j$YD@?Wihy3YM?miD-WsBV;UuuR^=zx(0HJNY65LOP##s^b`2DPMbyM
z0wdV!5bI1x+$<{+Vi^^wXYY$<C}29Yn~ch?ihAb*YA6ke3!bxOS%puAV^pCk4`;{=
ze^XR*f9O}m1i^Z;;=dj^XS*&LeR{aF8xyNgP&vsfW61Bea#0YG=x7|!x>n)(aB_j#
z!P6Ij7*7cyOrtG*@-QYSM~5kVYUF^_Pg63i3b?Uk${>n_wq{o0DybdNQzP`?dYHjD
z(g~~sL?@+|F%*==TOW&Na<#G!W>C)qp`BIiiP<}05?Tz#2jUl$m=#i{Rx15?1lhb~
z;Z at 50u^cj*398b~n`M*7nn)ld<(sV at 9)ixs>rltEY&K0FTdCe6<{E3qn>!&Jdl0y4
zXHUAs3h!^`oLyk55uSyFO}&dr%YCAP{j`jTalfdOvre at _+}bNFBbCBmFH|Z&7c#S#
zS02})Fi&TpGDbLi-2-+=M=5+N_7L>FW4whc+mOxPa^ozu2*oP&3+4!Yk_~Hx+w|s}
z-1X90GW9%X1t>ehyWOZ(s8QuD_KPzbDF?+XA?;82QC5+=MA^y12mZdVVG7<jsdA+t
znBYU^b`ap~1s=qL4TRJ+jvO}JGpU58auVrdOFiDVf9Ab>mBtjY3*Eh+=!sm^s63?T
zY;vaLJ at jnzn@U`l&IAL(vs2ZId(0$!v*pgtZRV;~%js=zqw5)Dt{ihLuN)bc<Ujv9
z5L~h#uvJm{>=iS=JXKKoW#`;YpRN93Pv#t2_jxF|R$2My*V#f`@?6e{3Ox`E+AsaH
zM0VLd&2+&o);eQ`%&5#{+{+Y;SJk(Nt82%%JgfTexKb~iy6dqg8-9O#pYraaV^x at E
z3;e{^)RQL at 94LifqVCnYsfVu{+56u!Iboj0=#-qLKFwqpS41QFXZuyYd77<4u8YJ!
z-KoxW`SBK9rIrCyxAEXnLh5?`^eWg2Ql+G+&&*%Tm at W~G2)fsLx^oKo3w9rEM2IWw
zc7OJ|{7<E*NWntIdx-8KkUtYhwN)qWDfgJ^LbleNs!+eH&|OcAutn1IdqB5 at Hy-X*
zUPU7|z-1vIx-3+RK8(O+uM$yqk-0V#`t&q9a#rw0DO|fvdA7EDj&E&5{ma6R!;s5A
z2lu>D`q8>nn at ZSp1)G@#`uF0q9w{q?Wo<TeHUg^H15ACtJC#pPr%)FAJHl}Ik3nsP
zo734o-KfSyafA at WRH&|k3AR!yqKPk9*sX2GyCZ)BV$OVUN0^9u)CEVVTYD;mj$U;)
zJCSYu5OE_}X_rJ3(e)2BQ>ULl+38Y%qjqB+T6NsIt-CoSxFe`S?hB>pPo~eu!b4MY
zW~R^8%32rY9w*P2pomi$3A?>N5L=xuYCXWw9q9xy9Mvr<VCngw+^Dh)rG~n<JxJe(
zX$gN~>Nt0)SEdl6X7yQVazhC=!vg9)DiDYx&my|>nZ#J29rJxS3+(RI30+{^^;(ZG
zD(WK-J+dj~1Oo=4B$R+8sV-U3_UX%_5pxg!=GdtYHx+AZC(FtEy2j_km+g>N+zwf(
z>ap%qzx#D%CNgFuoU-Lyoe13JyyS6NKfriTori;1*22t2s5ooGFrH>Z&!a7JY_{lK
zE(*V%Eb6`b7&J#d=%LNd&X+Ecc%3gDq2|=C$YYmJ|J=Wxz7zBgIZ|*r0kz5>Feil1
zLn-9KeFEYXlNdtH`Hn81yK+a{Vj*JKy3zQUV<hP^JsH>ei%0E%8DpB4=w0_AO+BgM
zI}?nFxX<AT^BSS4Wk-LpsTptD>VEqxNMAqxLFz*~fYiNSRKD>@Y85dDaKCl;8Lu?;
z<2uc=ULFSh{rQ)`Ot(MBlkzpbo6kU?+QtNRZyuKvFFMwNoKNCmz5hSxkuS1|>wWJO
zy|kTfvMB=i-FJ{vRMyeA33-UUh$M6!0^TATshAEufm^_^Q|nfJj)mtNSY%Dl57ZeN
z1>VW=r`Nz;lCQP+^*%t~n;QuQA(?43&LSSYLeLL$yYWcldnWA1qtKdT^Fnc0{gu7I
zZ~Xc1x3krAJgxP;UnkqOyZ2DUtd0BTI_Dae-nqvo1=9Yf)N8_h*?rr1C4f^;rgp}4
z<~H+|H+$q|!x>Nh7UQ3|T$fZWPqewdb=RMQzXG$i0R`K`cfZn7)Mwe<eE?n!`^wc{
z4kB at j(sRhS<a$FQKJsUTuyN-(@mo^;hw_J{Bxj)>>wdD(^6&1FSQYN?ua;ZwHK%X;
z`}+9)zJ2O_dSE&dH`nMN2BXMc=vuk_d`O?SBelK%^n3gD{kP^8clK|u*TskI!lr5j
z5+;4#fkxYoD&U4}V-E41hndQu!>~e%@?J$Kq%bG&xs213aG0e+gt}qGl9*B?$JE7>
zpz(=P*i74#>UE%Fv+gN}0EER=1jRI|fv?3m5GW_{N^0>+DU!SLwzx{bqLjw}!^ow{
zZA|+A8O;=?jS&8qQQFpM1PS%0kdj(fFJpCRJ?-d0s_-Mr+mt4C4RHB?oRXJrF^*_K
z0*d1rbU(jop+5vEN9GGlX$nedQmHDn at 4$&rh6E-x%8YB$E!MJ}{hwwT at f)sEj4l$C
z)Dn~v#cUre@|2-)l%`;mrs*m_;A6xoWkNrVsufH#l>>9ima6}c+Uh^H(AwGMWTyC!
zHqw|A#Yc-zr^y0gNezKX4Kfvn)(`t|R4B#Khf2dv<!=4=?*Av^sQF2=02o(k99n6d
zi4p_oj7wT2kK#w^pN5hvv$F;NS8ck*nyu;o>pirV3zhh}@_#Jf{bOud1bK5t$p1?4
zz4ZC%{QpX~YCgY$W<m-{+UFW~O!r*ulqLoc7FFdH(Il=ZV4YS`1{D1KKR<?2tx2Ai
zLjSL=S<^aa;$i-4h~efD#xSa%(!|8P1_z=#Mmn<(RMKW`@+ofcJE!5e;sG_mIaVkv
zhCae+`zGLO2X&2By}_E+M7=CYUJK|RnGo<VB4Lh<dl`srGC$E at zH%N~{3J1e<j#bB
z=kQRLY1O$dW;*ZpXUH=S_UG0EZ@?2(q79D9?AF0!4_46!vq(@vZP<&C at 5gcBlh0vH
z5By0jMnh~&3j*NuA6P;UWSQwUz$WHWhibLhU1^hn)ORjW<Tk)JKHh+P%k4?h4W5ne
z&vi*h7LdM#^aU&RYLHrAN<>Saec9$}xma++3XU-tHdA8 at jY5%fANwX#)3QN`A_ows
zt7g5{ao4}^3zBtP*oJjFvwKFh>;RzpDQy(ApS($zrZpt6w&?U^wHU^Asnxh{(^%S~
zb7+A$C{$6GVgW1K at O<Y?2T=*rS?QS~nU^gPtKL!r+RGnF<G0&cvl)Za(o7wbN2tbE
zLG>&_IGwsL$3)r!Q%znfnl(19{Rxn+RL2EGL7B`&4ltX)fZOaEOMK`ONSs at Q%qlXC
z;qwzeY^T+!4i1tY3?&@~#Ay%(#;+iV(anm+UAvYGXx*r^RI<Bsf-qk!1^MV=eK{7%
zHx<%GNO)naIF*(9l2eYmKA*QmPMxr;Zu>jC%j>FcF^yv25uQYUa%eEC+xt8`9k0Cn
zDrffI2kAUGjDf#siXBEru=AlHBrF&f&-B<9#+SPAK5@&~dfq835AA_)BP*@G)?}!<
z-V6zQ$Md^$0J<~(1B}N|)#VlUFqK`ibK9Szvk<|x8($KWouC6`z@&gij}a7=X2)*A
zVrtnejAk?Tc%c#Ka1Ha^tV_M>>Lh9WZxD4Jx<t`=Xzfs&p<J+v+S#{y3Nv8il9H23
zq%6p~?ZI{Bcd$nYkuMCfqZ~P_*osjDQHzpZ0!gJes}uH!iIkDCH)v+u?9y1-+n3_O
zPM`GCNe9tyPsWKN13OOjYfT%=ZBr|@ru-QysLRACM=7tOLi at Are;d=)CncHss~PN_
zoF9wDKahA>gecVz;Cdy5(8(7$ug^M>RcY-Ls5_vv^$;z`2CY?;szm@!0Ygdc3L|ts
z)2AigHU#pJ#IC%kn6JjvYN_*!4sqE at i->NixwaR{KCT0;EmI4rV&i=miTb_JE$+<X
z`$J1*<_vUc6|R${W8 at 2-F*)Y-?9Z;=L66$+w?C<1Jy&_aNFVQDUOwX<$$+<y+k}%i
ze!oxLueaY{Z^+z~2m9BVvW0;De&QT4uyVk$vp3_<q0N9sSCkM#_kPh3O!(m#S)LaP
z5OUO4r=mV<trP+dD<Y-3lK$bHf|zUQwHK%mH>#wRgwxwV4#AaOy1*D?qP0rfhWDNA
zW4(qzgtZ_DFTkJj$d58 at H^N3)wp(3M?BfG at H|P3&>iSIH#_q6{12&#E(g|qjFamve
zptscxS&9*#gK2~=&?Ig_p)1%^05T=W&294S1Q8^si4-&#Wta>M74SKS6{m?7G#G7|
z4ouB<$2`+$Gian1csZJmzQjPJ7LXEckPfv#&EoFrX=#dJ4XMJy564Y5=Kn7=F(n;w
zKobd+6e|FnMw<z6KOZIt&SAktX at iXHEjWdP@blRTl#ZZN`w`B6haYHGv**Pa=RbkF
zbp>zzf#fq^!v<VA^fv!ct2exZ2$!%W3T4lKW8vAt9f(Fv1 at O>MWPq#z+N(M9Hb?Dk
z;n3i%;hqr(jsQ$7u(x=7l8Vltt0wdj0_NWE5r$^lRG)zoxrd=_euR0vg!NerE$-6|
z1*wufyU(a=jh@!lm`B=?X}KkmGj3wV;ieg_fU5}kOr=CrVYZOIe9m3ll3#Q61~T|r
zFN`6*qy^b`k;IJ0p#02ZdP<nd_iLy0HNmpc(b|E$CLwF4>bioEU3ChsCaFShVHdYK
zK^IJ&o}vQdK9M2vs6`HkvQHM77mSY>8bV12ToH;lSq80)yiG>VOk(;0K&M(xwru3&
z_Id#!x00kn`Qsk}d!#}7_^)pIDqZ55=INBc$|_h&BvCdvinDeM$a8p}mAT2ED<SGT
zS at M3#zFDxgv7(ZX1`C)!VNM?MIY^v2!d*KSy9=XwV(aopqkn}+z`8CPU-3Mes{x}h
zRbBnXIz_ybJtsOGPL)&Sx!yR at ieU?M`fWLfz+~M9sujIeUQxID)Z170x3A95Lex=w
z{KoX|qg!AhLjSpha9KLVXu+kY2nkLQ&RZe0`Shs&Z)te|sqMexCS5HIvpL(`WwZ$e
zS_`gSEsV}vigHgXT7*zk2ZHXJYvwqf8VaQtmZ>_R_DmE0zbynB<(BG$zh>qA46l<k
zWN at 9oSNgF0ko{=LN1&oUa=%Cp8OT549-PFNXhve{^eaz(m+jriuHBhX2+c}c*cXgo
zNUy5{4-$Kt$~7sXTYPblK>El;8_%t~0NY?HN|N_6Ye{GS>ZF~6s<XDQLf%N^0{V%!
zIRpKaf<x?p at wSvDALaW@M>ZIfoR-UG;P=%$F at 5wYl6y%YT!dl*vORL=Qu#?w)?6$F
zI6bbDLWnbzRSldLW>yW9Gfh+tgcYe^ks%%Z)ug;1-tFx at Jtx!s8fj+1n*6KtQJhr9
z(@bg{lrrNl70}TgrS0mQ>8nceFK_HgRnoqcb+TjvyiRvjDCL~;bgBRwZ>0faDnX(X
zWIHOs-gXVrlbWBpoI_QV$PY<XNF<1?qQH|xBR?*NblHSo^8Ck|iszCE1g)!BQK04F
zjmjh*{b^zzFlT=GO{D{qhQNa7L7;&u;@C6 at CUGBK|8jW2fO5w{0~e&Pn}j50DFPQJ
z3<C(#H>kmYFBr|BgX`{fPFK}}u=>FQ{fWT>uLr;aul|AtW)<3^K|0N~<e>Uiqd at +p
zUT(>KR{Q+npX at mcdS?1k0v6DSeGZ&+#{9L;^}_UPZiEcNTp*QA3iQFEB<feVZcr-m
zFW`1`p+3MWJ+ at Dt?s3qc{GEN&kw5N;48JcU{&=D~5f})4vl;ajnXJJNQw{!!;KCmK
zwc<u&-uFQ(MTPmx+tx^6O^@};5xlR(suwnm>?09qC0TKg>DT&_J_m>yEHGTa>pQnh
zfT7MUUh4r8*bP<fTb09 at FXf-xgG_j^w<%SHKI>t|8 at 0vHp;y19)kh8}1MNv^V3e^|
zJS2l$Uj=-4iA6!*9CBx*oeNXm|Hsrj2S(Ox-NP{^PA0Z(+qO9|I=0P;or#T!ZQHil
zu{}v9GhaXVx%c;e|5TqoRlTcf*IKI%x^~gep1`qFaZ-an at FFJ}S8B<ix6gQ9<k^>&
zqlG}dAdv-MlgW^D5iFm&#6Kj8D7`b3!=xiX;PT8tLdc#_p_;!l!|z`H@}v$A_r0yl
zlGmmY_e}cdW2h&98IhHM{u|oVx38e|a(||#E>=l<*adq;PJ5K^te?1HFs)&Fq+#&5
zVN}~WX%2Vd_ at 6W5X$|wYzP<m;Ol#nh+n26(vS4s^u6B~FR?`S|u6C1T at KmjKvtR&}
z5?di^D<B*k>Kq(eoA{|*SMvGk%|j}nkKIJ-iW2xfWnc~)T8vhcyqx7)Lf<#9m}#MQ
zt>Rz~|MvK)N-Drg2Y|b@!^OOj){Fhp37 at j%sWI=Lp79k}V#Lo%8~N>v@|UETjIRNf
z(p2H9Kuv~W#~08J)Omt#A?vP*3aDdj!Q_0RSN5Pc0U_HTRxYO(Q1{EXVM_Cp<-Bl_
zg4S;Bed`=>aS-6PLt$r74O50C7{g0?NVy~)#Ju#8f(kG+JtM4)#YGsyhGmx$)a8QI
z=TP at osqi*01el;0o=S6R at HSP6eQXB-E-4D_*_EUiZfiyenNG^OGE at L6OZZHZO#YYl
zNp{Q*q)d{$)qLo^FG&S$9ehzxj6oh^6y^g4Nq0>pH_WwA`(&=FBxDDxk-~G|t{bVM
zpmr#u{A)6EkHGUUqoHat1p&}DmTu7`<X^0z6fK`KEp~u;IarG)2<~&OY|C(EXumN?
z(M(aO&~AwIX}|<W_$bhxa%_d^&0TBJIMly?hn}%8Dn#S?C_)R^9W{yuH-36LjaYPL
z4H_8h{ACIjs%nn{%fg2_C=wIUi36b7_zp36C-?Qt1O3(+E&H-iWNjAo6!#=bJ~&__
z4;8g$10KT5+lCs>ScEp4lq94Y9m at Dt6cy*J@=*jVZ|Ey(l4m4 at weLdv7;O-o)@3 at x
zFRHmO7c2?}aFMn7P~iNOqF_;gIFflJhTWqddLdxRj at Rzm`>j6Yi2Gb0J}mPNl at O4I
zEb+l at Am3>H)iqx`!b!xd2m?=**+YTpjLx<@MApn}0?(gj4JyL@&~3QHKUk+YArKLY
zf~Y?s{n9>zeUT>*{^`%se~1BP2MZ3qaZrMl&b|x_;WGJ9{R^2D%-RQSzL^ajJo7Ck
z=#`2If&~9~qijodP7;hNPYf#PTx}AL<=HhV2zSQ~EvV3Q?K?OI?8R`<+lOesSYIA2
zc)7B-0bpePJ8F<gVas>$_Scq3aCu65He)L$cfpJP;Y~@fcPBfspk+yaRImh at A`vh<
z at xdpfjBCszB55$Y%eNRXza^VR+#paq-4O6!ZH}fvIW9toI-BYfLGBHQNDdX0Pzqni
zN-!~UvckYRW*$k5cQv3Px{V3I9c6cnVjr5uYsb(?IN9L9%Td*_<H4?632gSEO=gim
z!U44}ajnZTi*MX=k7|70LjhUesBIdw<z4?|S0x^Y`nBE>71|D46uja}T(I}B#^uYn
zs4fEun$!>L>sGr+C*<i59%xv$&veLJcR1KT&j|h at p13=|4*LEk3eh3(pkLMn{&{~&
z5dQnvcfS^RP#5?+7^6_(&ufAa<k24PEl+wa4$_X~kwK>^hn+q#XM9?1<S|n;C|%*-
ztP*Ni#BA7>Y*<Wdh at Zt&{y*VZAZgiSFQYf at h%qgtHzS2&`i#P?jkREk2c_;`o&SF&
zb={1Qb<U%8Zi;lyCw1E6Z+EoY@#MPQ3_)52tqKwS`}1<n=x^vXMBR0=S-~?946s!f
zc6$2+_veypPM|H#78=nw!I?ONj3;<UfjvO;04d?>S_oBK+i&SBZw7-lNq|2fp|#WZ
z34f;7rm?TZjJU(?>~hm=Q)fQg-)#pjSxRuse`L1%1UJP<OF6>(&!52aH+_we?YnA3
zr-yR6pq;)XHqk3}9jbnIyK&V_FkgRu3y3Rw@`Q;n+6Fbs{%Y3}xQy3|vZ4N_Nk6Tt
z9d)XL_NN({OcsknJ6a55ZSkLzQ0w-}i}30&^QrJG-xWRRFpTFM8x&9zb~-1a8eZix
zMOp>v4p=iuS|=>h;NNFv*hIN3P|_!%Hr#LjnW57xLd*}VXfY^Ut04s1DlqnGyMSK|
z(hbzlpgLyRbf{(EK`N%oN`(=yy!<(k3)w#D$EK1=@}iVR0<A_>1+{T}_BO73zL!T9
zG;2X8s$_WDWJ(+#q|h?RCfaCS96SkCk$IvQVc)Cz`VXY`*#<ye9`HP16ZOn&+|LWu
z3?XRFu at c1<I$F)HY}KU%FnLx&P4-rX5w{gC4OX{L4RA{k9S5zij!c5DyL+5~3Cxt?
z9fMsd;RNws2lB(vIh3KpW)Y5b8A#1OJAsK`2+c+FVmTM!?xaAnxgZ~cNilA{9E(Wv
zc^hW1WphG+ at 8V_OFu@t$euu=lHJ5-#?#~MgX6dn<K0pn!4tWy;yRTs&gjiQ4h61<S
z2>Tr#M9?6N+Aq+~Ct3i`z`@{U3J-yKEBzC*y?O@&!Y3W1X|KXIY9tpUG<U^CH_SIQ
z{hTL5!D=G%!|p!XzSob&U?0^nSvZug?GumY@!+Y`yrA~&!F|}Gz)<9evjip6N`SM!
ziOn?Bz&xK0fPH|m_P3%UCNeVF+?N&NLby!J(I>(jO*U(7m9julq_N|QbZEo;ZjYG?
z`tvc~rTChXXEEba9nK61gXbZLh%;_V4HJ7-h7cTFQ7(vzQ_g|~ITU}$7+?5k(GTTy
z(X@}OHw%U+S|yCwPol}i3Ksgq{)5d}jq4d!zSNKntaZjC9URrsgYG*R#Q`@wL_N}%
zrGSH0?Ks~Y$VhKENcl0M(f-93WyJljAE+?E)XM=dwgqexV?4d?2}heK2*`wmBIx#-
zhDeC^nKu#RZ3$>7kPt!qBSg*jSed>A5Nc#8Bta0Y-Uq1tTou8pEGhT`O2<$l1Jw@<
zXVs7;h9{6<6Xw)l{kw5+`yP3qWhpi)<WP`T_`^Y6Q6fQCN$>bp8Aqf+Imzx2E_d!^
zV2$RGVHn2Sp0ucmnSF3xj)!DmEsusuJWOCLVLBg%VB;L_L}2}93|(L%Et`+t;6V)e
zZ(v}$dD&p~*A%;ZfW%!Q2m<5p+QwZ*ln^38FK?(M-+#!1HCvE^5y+L*q)#w{laMP=
zg5_kK5`f)}qXNNn#^<Hkg6yg??|8uOrZytM9%i0VMLaYk!6F6e(L|I$=A-s?_i at y_
zdl;Lbf(R2z>&l-|!Tu!N&`s1_MFjii4`R!RFN=Wg at f+b#pU}Dyda-qn-$`{#N~}Cl
zISvm4m-`EK7IXD|S%OH^vcZdtlfj6f!wJg;=@<|<KDCHn<wgDyH<EP)j%L$*Xt!NF
z+uXWVQGnH?2lQdOxpr#T`{<&;)MLjRAQmWZ4`4%52)*+Cz~wxnw}XikWP*uQxBF7B
zzRPZSizdg;E8 at 5byqCo8;1N;g2M&N^m|45_#|zQyCn1^z1 at 1PBuU2nHO8)(r;fs`T
z&nrxrYdZ}5{rgk-^AhFr^47B_p>@9R)^SEcPCLDFxvU2HbH16i?c80#{e0eny>!oW
z%K78%Wli6<(xye!M)j at 4{JjE;GN=M(g>ULNI(Hy_R^ht{drX}fjBh}PC}XRoNxK3g
z^iT`zs-Tdc_TpNyE>@hUzR3voq-*a`J>fgb&n*9lTEwB(LN^VYL!&jpWs8TQknA1~
zG|S7%cU#sP(g1zU`=#DRo^wLPkA*@@za*-7?~?_K0TT{`*<JmJ>{wW?KVh&8;>`RF
zCxCce?}4_G1Fxs;;>)C&MK at -Y{Xutp6Xhe|FmYZ8=dX7$^&+1QXXzkklw2ccx*5kI
zJVInD+ux{2?Q`+sK0{rlrn30j5!w5AQeg3BQ!9 at uaj4Tp`nan;ZVIuOv0;L4ii1N>
z+24JW0!1+f3?PZh!UO}o5q!M|gBb1DAchL(Bg#uQ&fbG^$dJ-y<2x(_r|;?)4k%eS
z`b5kX;;UhAw#XUXO=b>~%!uvcwG-N_?~I8+>xm1-Nrn*XXd-oOy%>^dlJFQwk#H{=
zJ#v#CIGvQD*s{r20kN?SZhr>>E1tB$@LsY~2{1+CJ at 445BgEYD0vU_s3~WQi#Z*|3
z+UCW;SNDE3e23lNd50^<Uf{2Txb~vTo>9ICa;B&cBlJ#l>rvbtdJ!a at rQoj83&TVa
z#ky4X2<xTO-ftY~((%xYTd+zN;zWw}$y*Ex#<D;IgK2`^#RDTfHAS6DE>;hV;P4PW
zja7)y8V8 at 4GK-0bH@6|cf@&<Xcp4ypj%DmtP^s`oaO?_zHE&@BVF8`zt6Whcn%~+z
zc)P8V(+7~|S`nk{L&bv?5o=P33a4c}f>p3gK&X5`)0k`qn)*Nv-G;*eJkVn$4KPma
zV8I_YvJ8gR&)6Yn7rbXteOHcP&V{`w&q}?T!}>KTdy!p<K3UuJVkT=jjA!i)*h!zx
zJEuZQC+pMolN+&atADeQ1yOn3-rBW8vgnj<$g1^B)g|MA1CJ%9vTCum)yO#|6m*CB
zgWi9PsOLB}3Mt!+s2Lv3D3*teUy=D|*AlREhyX>Q(VCxuGV;6p7-I->rtLPJ>^j^|
z9U+hk!6Y$CT`F;OeB+26`+eoRHuOmplt)pVFwr^N)TKT|l7?mx^uo8Zjl%~)#5yw)
zf8IDutk*XOUZsu|LoPbAKrlZ>G@?Dmb5~h9HoWq-616EDTY0*0D#6wgH3Mn3VrBl8
z^{?w8Q5^f9;NeaDON&<g(b3iM at 2VQnQGi$W56#sKX;s?1l=z}AezcXJk~DPs!SMxb
z<FYNYIi1!OM>KT&5{1R(h;=!1wdGgqhQ@{E<CX@((Q@|%0;%+LO;8r?MUC?sywQ_n
zZ5Da-bO~I<k`@!BywTCIE1tTpdO#UEh})kfU%X^1KSgEehH?{18X0*l!sO}bqeP{}
zHb|`k_ZtP-yj<^+G(7H&NzygKnEEKv!Ye`Fwb*NjWi1BsCTy50x}|_WG%R)fDAGzZ
z5{epQg`m<XIifV2DzVsRq0 at 3JW@btlZ=6}FMUx5atPiv0C!)pU3mVU~WJN6+PJi!0
zr|GFJcNC~~AEGmrBg(rl*Om${{Bo)~NF7JWkdp$L(6tc^nY`x<p}V6jA9R7Qyv7Kb
zbjp at i!6kZ=a}l+`Iv_9qdf7)_j`-O9wq`2YmdEz+<<LpcqCM`l4(Ne&aF#Bw>J9OW
zhK|`XpwIijG&-2+#~F*ZhE}(ky`+UETMCVVsyAbuhKANeF_EN&*HRcgT@^oX$mITl
zx=4BspYR%>1?%b3W^#gSOecX3i|=B>_E*$TJJ>b=;gipDs^)X0w4$!!T0j-86`YXG
zq?MeY&E%p8ZZT%X5o&8~8JViSl3?VG(y_RT^^8I%v?fk1>qg+&vXbaZpI)UpU=7u9
zj%<X%Qyb;F{^jhVFea4NFX;S|2{YqVVb3KSm43*i8gL1NVz^$!Z(Airq>qZWnsNVd
z{3XH9Os=1ksM~=pD}+_wSc5cNnyx&Sh at tL#DLIGC+mK2Q#?F4W(k8cHb4~k+U`c=B
z$V>;c1M3$mk9uwO?QQkC0mAlkn)Tx050v)5I=uXg#+`$#kO`QGXV2TYDTgYvPFeSO
z>=^KM3q>>5M8A+R8R{HMzq at c0HCkvA*~Em{mr<K^>VzBl4Q|9i6C=7caaIg)HSUxu
zwxRCX$ft5_Lb|?~;@Jqa4aczVN(xCn6LLH*=;gBMn!$9`m-F7_u$4OypqFkN0dnKQ
zF- at tyU`+>e at fm;h$?j)A={(gFfLzeKVP?f at Tmik$5M+5Ba~&ZMp%fLuYe?!DjXZZS
z@}=^brzOG<!Er at AUeThUwGyF)%$&hS?o>pg+-v|-A3|5)89s<TV5}XBjnC(KR&Ynp
zkQQ=UT- at rO)FWpXYd^4><WcAg7c{X2NP@>>+nl!COE1$K8R007VTTkN9*s-rGR+Vp
z_(UKV-4a+;qm29Nm0J8L?{7p64|Z`-Lc#m_sn>67-TCw^F8Qv8zNh$t7T0D6SUUtp
zj_PxjR8jS{0tB?R(teXdhLgod9qyR9*VwLe#IIgXF)r4ws&88b8gK4|?dliq>H#iG
zdlriRb{_G0ek9?`0iq<~#x4M3y~wjxSDn2iYka+f-=wCxgr$`0oFlq|uVUTmcTBMj
z^`vmm7UEfkLkFOL!qleD+=q>?dbzmmuO6Z^;Eyr1VfFMnsh)tI6F>L!e(n_gY_+1L
zT5!Xx!U{QLa0RQQ*^O9tz3uWcN$RMz`Bo{(boB=8@>zj+-mRX#g}9 at 22-f4z4@Ipy
zqiIBL8e}*d=u!z)vNccuT`}ui;WPfg>6ALKgqO+|WNQrZJ0xgiKb%}w8huO+|7Jc3
ziSY`%rNh!6H59!U(h@>W4la;9Pelsul}%?`D<d;@*6wH-w<+yhC?h!*ynDUGsJJoB
zP}XPktLy;Zon3~r;H2NF!u2SjZ8sg(HLy^}$Ls8lbGjki8C;<Gc?XqP#}?;i@*|>a
z6KSgn6S-$#h^RUqo`}rF<bDwarA>kPI$eJ<>#vz;nPXiYR?Gw36u}T9*`>*bA^&V&
zW6sXfWtF6(=<oWob}ia)747{XGPH=K4js5$2^wtD7l`ki`*W`0p=d4o&1!- at jCUfP
z70q$Nzo}Afhq3t at Ov7LPw2U_1lyD{J;_G@^M>UdT>-2GC%w2BLwT)D!6J6$wpYrW7
z-o5wEPR-e&A2qn)%<`?8JPH30H35`%24_RdXJYqdS90+9EW>+4teBc^Fjl=`H<@Ug
z)e2?N7Y?78KxPvgHLIFI8{_+|7l)7Op#KE?33rYmR#SG=!E;K-B`O==9{S?AepF-R
z`||g!Hkm at +<EvL1pJ*lw%(=jxPkPJw2Q!|Nc39EXD;<X5S5vo~%7ZPs3Tt=UD at kR>
zKGZGfM<Ag)CO+I_i9 at OAm{r;aD5US;+(5Pj{P$xc<?hjUfAstf3(UA_bS71k!Sxge
zhAdvf_^u(<iusZFNtMZqZj<gL+pl6nT-tu3Ot{<;vk6jGGvl>(6!{DoSLTp3sFss-
zaU%$f?}urEF8ila`1$h^X&HYmWud07Ttjw#0)y!?X5@*Y?_`(MV-Q+0!m27)UXJyq
z_fCjUrPpbQk&4Ck0H|iPm3JZa3MV0><|as7(>XCx%)2=F+*u-K>vYoWv2AvoG<zxB
zJj5(uLK1FBs!H)mU`ZBXF1B#S>m(9KLBpx~uy=rs8_q%7JNOGmdt<%Uv{AR&RaSY2
z^c?PLu6%9sUP<p0D7cQth<D>7yV)ZHe>FphzaOay)i&MEN*<zee&D)!UJdzQeSRtq
za?}aQ4ZR at 27>4@{NiwkH at 5NE}b*6T2fx at Y|9j|I)jhFW$Ygt~V;}BJgex6Fi;XO6*
zTQKV?oDcZ{iN`rl$mFUFvha&N at eMT2bEc``T6th=zGC4sWx9<RKTAs?x~R8vD&5!@
zV40)LJ_J;j;$9-)wUXX$1b%)ida@~)SQA+&ix;LA=0UUSqv?}tw?<$)ute|d@#0fK
z^@v@`j~3~DHNtF!Bb)~#^$s5Tg6uFKlXY?Bs<i`@v5|XwKx`%-k0Xy^1Za5KHt=y+
zIxkC%V>F*BH7h20f8#|LYn6fsk7xpZ8K11)OE<D^S)XL$eKuos{Q$t}3+M}45GvTR
z?~+VR306oHEli#nKI{fCp$=@8!I&)&Dql!ECv13&=TIAd!El~@ktgPwEPEMo+2HRg
zOkeUrH5L02{LwOa0xq%i?#^;zn2!QM`)e~x>iJ|CJ6H<C%wbLXMt%+{ZyE++GjobJ
z>mg25!RA!TQ^UOm)jF*pz>ahQC{P=UUE<6SV3C6t>-f~Pa0|&1HpwzKCB(B*a^&lk
z#e(zI#b3Kkg3fAhf~T{e3!P?9TGfRQh%^Z8j*po{(3fE>uYWCMe>1gf1y&t(6fU2s
zIVDoZrvTY$7q8z^AAw=Jzo9a-l)M&Rw|;AWJA#D4{dtfs<-5Hc^+Z4RU4Xke-;I1x
zERXfOKalm)JcXJt|7%1gijXMtCZBz+L^&5c6v2(Jx)da(KHtVqh$M5|PGe7xGz@@y
zo(N+OPu4shlh+V5 at vnl3!*I%3Au~Q`yh*#o;ceZ=K^o7>l&Nd9(4b<WiA73o)WlN?
zZly79&>yH|{u)}*5EgrcM%eYIrO+!*O8I5aA at P1-_wkOmj&?&lJLMoUQj>GA`F^Jq
z%|nu+q_=8w<sUy}^y4APCcomxvC+v0^M42e=JPoVvglEeDDxm`l`@QfhE!-}pziHQ
z&gNd`cLrZ at J6UFrU>j<?yuSb9s|s at rm)bj(_<|j%%`e-Ej0CnqGYy%)lu(^fx+eS3
znapdC@#`{%Ok!;SA9k}@+>F<}35kAUX(xd=l)#af1GuR+bvrkzlhnbr6HOp%jFcP6
z*nnJ39?A?WQ~h-sxt$bu7v94EZgjtQ4bH(?td{*(S*W?fNcIdGPUc5Laso2YHOdea
z58#@)Q!##1+e}5A3ph*5nlHnF%p7~Wo~85McRHb(I{(y|r9J4`7%tYo&OjnO)@+$4
z+%{#ydjrsMj~$meoTnY?ZjX^W9|fUAk+gT!uIWUxQnlied)~c?#F$YMvs_*XeIzVN
zEWeRS5_*w8!gyFmvxU$QX&;7HtOf|*a}*w7GJ81Z`K-AtW>NmG#eU{Esuu5~4g(SI
z_~2D%=yM#Wc*yJQq3u_Y<cmoWW+#<+<5!db37iKbT#^cvnM-93n?NwCZ;%%+H;Mls
zY2el6a$Fxp*f&SR>^-BSyq&?XjlI-pY{jEY%2e7Q`8aSI@;)M9_zsaC!u3QiAIS97
zhAU1nlyB;#x=_VdUib6$U5YhFsaW=t0T-&*Nq(#p%|YB0H3#ul1(&fAt}#@E>VOd;
zEtpE(x>ngeu~LZv$GI_zmeA3INjy2mq)dI5&aGOZoY~1 at AQJ7Jpl)**driQDX|p2+
z+3Nizyi|AVGqhE8mQ4uHg99(*y4j`TZj@|eID_ at ac;x~rmJ}|egW^DB_xQ?vwK<zC
zt?+M?h?M*IA7^)FU&nu$d8YeMsHy{1Ze^LGh1X=)e|AGcIm3lmuI<dhB3?82xuB1q
zTqMF1Uuv8?9Pz%1nn%Jdfvd%Y!2|@D#HG#d&S!)`bt0?G$2(+RRvScmkY}elP at jI^
zDx@)pB8xz02{4Xt%NQUUlR7X7AfuwhNT2<Y7B1Z>1NeI5A4fwPd*UI??bUb%QFOPa
zGI5cEM?nA1(6s6_#EoHo)^1;?5R at Naz0N;rgB at 9(GLV&z??b~N|1EKm;xG*{xwA*f
zmEdqq>#y+^j!|{Wy(9c*g*DcA`<@v5EZ$b`->eP9qqV at lDSW$?rSyYIt29uzoI{t_
zMKsRyCN;3JCF?o{coG7A^;GBFFd8}QCR3TGiKo3(#^cw?OYejV=S0CD at CVhKn{x`9
z(qRx(<0x9CjIx^tIS)x`#&>yF5G|UVkelkth^Ds(iYCJ(lbFW}<j<1TZbQO|Y)WBO
z=L<XrcF>h2-5;>l?5z}O>Qd02iKSGrLS&862y;=J+T>fU=1LB;C*SG=l>(dwB^ype
zVf1Bi_J1ZPR0oh9AfakOnl;@|4AbRbCZR<ZeiS>?^~2DKbujbhjjIr*n$HCBe^+h#
z``)E=o?f8jO8ge8XZVowdw)2U-0)4az?Z{7a5L&}!BeKFl9MirnSmW1Z(Cob`P)n%
zyVf$GoSqZtmkcS<O?_cm|3GCesXm!*CaFMP6GJ+y_2-fI-p1=5P4wlj>!7T2uKA=K
z6I)hyi9|d8ybxL<PsI(gPW3LKYJD-V1k8GLx5s>BFf#(THz^STYy&12Z~H#3vW#Nz
zE8zo7-J~>MO_&%q;<Au+sGroK(E;t#qrqCFS#W9Kg?Vm|+gHxXlwiJX-d%Oe+}gZz
z<+ABSh>F7!VyFC47K2)`1aH at gb|+>w+R!sgdcZ`s9qA>NW7yiKIal1|1OmC%3XuNx
z`ZU6%zEu$^`FwNlA#UQHmA^*Ms=$l(*Lu#%ovEu^-BAmMm`}Jhf_ZM at +P;`diV$+_
zm0)_w*Dc8xajlngj*A$`kya5=nd<D?1O-c{+-Vq$uo}jWB_M`bBhnm_#pP;-Qn8G0
z%^)4h)*S68%H=Ux&N&x_sEYpB>kna7GR9p(ydlHIY&MlULYxK8l6vVO>m!Ghk%m0(
z%nRr{CoJ((?j}DqqSo`$hf#_JEt_f3d_ZpTN5D(eRwU#RLh2|ig=s at Nnjq|v_Iz&h
zVOgDt>+a|mJWd=0e!vi5)Mj0}nDNB12!d;(?@lV`Da9G+N?1Vnk_6juC3yY|sJER8
zlV5=U#*xo6E&vbfpDd<g2*|d7Nd at ElqS6TUN7^%!Vk7BD#BJ~A8Ag~h(JVQ8jmGO9
zmkb!P6}>Ixed*W-B9wG4F8|haV{mULGmR^4rut8Z#R~3}fLsF&FR7{k<*Q#@8 at 5Xl
zZF8B=*!sIKBKmSSpURs%mae<c*3|s{ybJhioa>cbU3eFblJ#CcZ5AcAIxUY&tMpnt
z8Z~RN@)@R9?`q9#)&~scA`NMB(3Gw5p=Z~cURGb4OFK3H`t)3|HY+QxSGZlQom?MW
zHM)Prm1C=q=}zbQi^k at 5$@*|A?5|NlX63Wz^HU^3p=F$Bd~Ml0j)=rutSo_H%Ay!i
zK=BV5d7OaMcqpR4c$jo0Q=mx#`imEpKpuQTtW~Cl1}L)MJtAEgqGox1PoYynY$81F
z6CAD=aPJ$vZ)_qgu2&-b9IwplSaFyj=qFZ#O}EL?m~4YYa|L4KD&eyV)+xT`VG82~
z(&PP2S$2mpg8!?kHR~S0WE?{&W(v>KYJj)JJ`|e>jjI8RTRAIam1h-!Ym#C$Pinrc
zev_1Lm638MF)El8Og)7}dXMNTMr6J(N+sYzXDBd~Q$NOTSUCQhYN=!Y<)^gVIxzDr
z$!eeW at g@ey`k#U at c|Nt}%B6Atwl=}s_TUSyNrIIMsd>4W``%}cZ%LS9UKEixOkV5F
zjT8|%P!tAa|GbgzK9NfVOIhSF$|(mDV~&N|?jEr+6j9SEXHs~FRgB6U)Vx90fMNk6
z%By<?F9FDetL?Xqp`8DEr5#qhG7;^?3kFjxg0303_dLx)ZY~BRC<c?q$m#pSLj9k5
z2A6ItVg%*Zk23E-UU!Kw$fP$1xl%Md@$F6Gn7Wt(yZwQ=@1$h+<B(I4x2JW63N=&s
z^JNPzQ^Y)X_0v1<gZm+<-z-dk<nD^>bY_GI)eAH%6atTV3+qP|0wBY~f{YftJ1(W6
z?PIcDAz{+93#UG!MAQeWgP<gd=;gOpPM9>jZ%#isznRe3%iX`$4rupyxY-|Y24vho
z<yg^=59yA6SD?cAfJT$#Of at Y==8%~f3gj&C;GendSC7Y{`yg*8-sSLLJQ|Yx$N1e-
zQ=Whk;(rRkCtOKBzM1};age!}rJO4|2*QlgKJIzd(f$AGd_9rJgJwm>tRDu86Vu)J
zk%J=(8M2E*iU#LHPQO*F>?!h3EvQ~4jxO1zC~zR$LZatUvcGyWC*IMRBw)O{>26>#
z&w)9xir{C2Iz811e6jz2(5zc<?PchbHfrXCj!bFi43SW6>973q-%2Z9J^G2raeS3P
z{*p3E-&0J}ekD0eLSqXqkanMZJ>@0(Z#O5b!+uhMF?^9ZBq2!7o#PJ<lZ3YgxlQ^$
zCyy=^GzQAbN`p%ljsX!YGG3|mAaBnq-c+#u=NMj~F}Y at to&Db?6AAJ*j>*Ih_9>^6
zxKaH+aH}}gpcej<m8(uJUPjk-=(^?%g4b^#0j`%`?<r^$NKx4CNHB;hHbFTcZiS7p
zA0&Ny at 3`doAC4RQ;)mOKsQ-&E=UHMukct1Yq;~T29^@RWK at i5q`EN)5kDg^3eTp}r
zo|1+VkwVTT<6jzF{Yx1tfy<OoYTN(E&*{ULf6yxmvmzQ%NzTr9{r~vs#GTsXv2q%3
z8>WR~?ldL|L$pDueu#S#CNSO~s^B%bLs={a at +@whig`fFd3E>ac at jF8H<b?%q#>h8
zSRhvYOSg(Q`s<2jv<DJM6t;sTJ4S>56P_E#+xsUO_-p|T!3RVEt6L at z>HovAVCk0|
zD;a!}7;2Jx2_E3?!<C8B`r*GC!jl%*Y4(rsh>wSz{+9CohY28x!Q|1>FE)MW{nw#+
z_i0uruKyFOAHTcua4r8QR;8A6L?>a&EP27OnRjly(L(IgaJ~W<|2SV+zC1CBSXsl6
z)I2~)^=)E&&Qka at 3xh9vLa~WUC>i#CsR)BD_?LCVq~hc6I1n>I;|C|u<;Q++&G%o-
zdd~r_oY6tT;T+;yYrv&{AO|}jxCXc5Dmu8-yD at t7Zyq|)xyf7t2uL6_fe^%QiAxRQ
z+Zdd;$e?=f{kEP63wkaHXR*Un{CfGy;Ue?o<mM2f2^WbC{YFCnsR=@v-)jAI>K}9p
zkQ^i}c?aww{6`g_@&Z;<PGf at qo6!RhGD7 at M21q*eA1m1Zi&~e*>i=Wsp3kHm$!H<O
z51ay38v3nd403Ccd3<sT2vJ9Ki>>E#<bSJ7cv5swzxr=Go6JvyZlV9v)5AO_`mMub
z+<rzF0HiBw{GT-G!fTcsE`(;nIr+LpFGQum!Z1dq{iK!Z+ll|_*z+#(x*3$&97v#s
z&n_RjDjqI~paj{(s8FBEmEQgcjQ!iSI}YBsyJe^#NpM+$F!9DmZ|cN)8k0B-FCb0c
zlDY**6z|R_WW74CX68^~;6YOy5Byxmgdpd?$HCHCjhbGTF#o!?m|FS;Crb6#>p6Ou
z=OLMGl>oJ`bf?vZ_>Y{~+~4qvFND4dtK2|K=S}q+=bwzH0`~d4GW>IY_KaSmRF4Jc
z45^Q9nzu4J7xP>$`L5YM>=T5pqd1<T4CC1Ym+}Ccb~Qeaz$U*>!oc*RT*_Ypd8hUX
zMQ^SIyeKjiE~`w<?ii(2#`34i{P{KK-B5WluIIKdJ{YoJyr<?7T3S?IhDkLPbk%0D
z9=SV|TfSF2VtwWYz+^XXIcyqkHrX&UJFYcb=~n*~%nm4MuEvuWR*^HT)o9M?n%19t
z1X|aXUjO*A`95stXnJdsuOa-tW3EJO-hM%yTD3xHaW35(s<`RzZgZLa_uZD~0=347
zcnc<k2rAC)O{`-#dWF9_faEYwvC5~mE=%@!xqN~n|9yJ8O;B6<W6j at mDvc5STcvg1
z;)Q*>-Ds(18p3|X0I6m^&(i&q>8tma;JJq0Q2v=ZhU-f<j`z+B&igQckFPW1DT<Y;
z{pfcyhtZ?YCNDP-`{MN!J^RaFSRntn$7>LqbobetqJNbia^TO7^iL^=cgl|}E!ykn
zv&&TvNB>)z>s&twsjlEOjfzXrF8b`Y=cv5Vl=7F9CY!Dd6QHSb$wqbdJN`tp(P+_2
zCpD`t+00M2+x;c*4!etSw;WG_$-vIp-XHGOjQaZKOh9#!OmHFh3;VK~s-5Z1=5dO~
z^VM6cGz%Ly{h3MoHO+-pYPF5jM1932>UV>-olovkrqifG-(g*-8!G}eR{dE^-%WZ&
zU$Kea)AX$yy#>8z?m39zP*=a2P0y>WGcFB}&CRJo(A8^p0zaqQMeRq~#?Oabx6_$D
zYi}F&yy49s^P98Lw6B)|v5W4}HC^>nADf7Hx_wepo3%TECXR%;7Vcef4up0!j-L}1
z;SDFvNn9rnLhsE)?}EPitKYYlSDv{z^R*B9s6Rfc|C)7OByq$j8u$LpK(I^u1Kq$5
ztK=6pW6%^#ZnP)Dt?aYspvVGAE+{L)ttg==lbXU>&(o?XVLFl(CRk<CKv8P>vc%5S
z*oS}Cskt1Z&>EW-Wx~%8=PfGy10eS!oiQPfd-_ce49>S26 at qrXAepkdrb(XkSq^t0
z at h5^+A6(B!9s_3sY(lA=ryaT!vfzeXy5HISqdI5(875AcE$cV#30p+opW6y*EdgoS
z8%#2XkT5W9uM!RWx+n8JD7YTBmV at +qSPAypxz43iN1h%{^hfnaP^I5ifoOvUzwoCG
zzHC*I)#}iA=m`~Ry9A8HXA}{=^j9(aG)!sxGXm_tJrz}}bcxl3;f|={9$hMF?!7-}
z@)4+B@@I~*Lv>WplDvQE@|?{0J!~wCS#4DHjq+D_G^NcPlaD~sR<304Adzkoe+uu~
z2_{sbB~!#|I-{U?k4!LU<GB$@&)Gh1d3=SgadvJEDYv8vzj2;+|8Uj)bW_ka`bR!Z
zVI!{fgDy&<dCv9geBGP^)Ur>hn|I@*7aV8PX&$VN<y1NMa;NRDfO<=h+oO<VMd+r!
z{?(dlpx(kYLr=fuXL}sJU2Y}Ez-k=b7IbSf%6dGtgT19a_WD(*-41*!QS at O!4L-$7
zc<bzM!schxFj#vo=4%9nw;RZ|8?}ya^aci(!Py(xk7x%c3;Cb>*OS`&*W`igr0<yv
zPf)wRmpPGlue8#l!Mq-A9}dBJnxy-(2A}ICa)f&f=@~eh3?nbKvf$6B0dxFtMKiy_
zoW_*;OR2%Fh)KY}d4!AlP_5F97r>l7WVw>SmLFqbUFO8+qDL{`!sSXOrUe@)PV#gx
zT!}ZpP861Iil+mK=Wy+&Q@&gbVR#mbpUoeFvoy>^V0z}Nvf}6`Ql#ASt~Kk-Zz8E@
z+idy_ET3e38aB8{<D1;hkUxg4jAJ6DHxE$55)!L^rtqRI$B9pQ+4+%U2Go}4sQsAw
z?zMJ;JKiLi6Sr=Wn*G&B+$6?4y4{e^VS^8Xx;y1 at y@3))?794Ie)W++FgiT%x&3SQ
z@;=h})zgcrkiB^Jb*W(hj%jRGV&5t|1jD~3V**!mh{$fE%JU{DplxX^9+QHrz*{#M
z%m<S^G+bkVwTG;Rtlnz*t^s=J<Y+<V;68ZtMBB-fRExT)b3M7o$N5sqf*uVvo3#-#
z)i1otm;`KX_jPzbX|pbBz*P66^nThQOhqL&T#tTB!y!XL0{+LQ9e6}}1WNVQgu9Eh
zSD7_;S1q-MN?xE(t*JNmsHZ^fE5_m;^Bii4cdAkd0ca&}uen5e_Y$4ix36|XlEPd}
z2^smAf|_WC{OXvB6KgIyfTWO5L=3au>mJuJ%cEK$zENy7O!vI|LqPt==t#ZCm`?>+
zpyUp7e5+ at xJeD_sWuw5=Msl&MwAFQ7$fkICPs;e36<hzpzAbZHg^Y at iQV}N4M+|IN
z at 84gu#~nI{)v~pqZ4vJbD4+fy<H+#Z<T at _7_Hy`1tp`4OL5&qy{g^Q{MPv7!3a?gW
z?C~+16Hq+04c|$eDf=$CF=xPTGA1|dd9_~R>>h6EAt#{QAwGdyn>@Hn0D<j6^LV9l
zPgtfvUpZBPMkW7KU%m7Ci>a at Ga>nN&+n)>8hbDwRK_;~PvG)eA4f7r(%wF>|N-K7~
z!UoDKp(c4tFKoS4t`0Q#f~)mt@<!UuPkJ?)OFb1-`!@coj&)7jqX^M$#5Hw8OaxDW
zJd=L4F2haG=`yhEPZ8C3ce#gDsKn_79#@BK#+~^40sM^1jD?y&c3ATAS%GYNF at mg~
zNy_3GBIaECc)pjGf{mVa_M>N{!I6aRX<r)rz7qAY4R&dzq$w^c23^|o^WVU2mG+_R
z+Q6g|HmezSo)bRmQA#Y2t6=7FpqCbvC(THo#1|hH*OG$TdfQk8OO)dweJX2mwOp&p
z$GVLacXge6BKwjasH+Hn3=hWo50PWd!Fj>*metj at srb!qySH_gGE>n5Al)w!`S9<x
z`{~ByyBH|ihGaZ at 2t|bWa~YaO^zWvh?5Kt#&Jic^S#0PH3c-gYlGXGbrb3({ww+HO
z5mpxb;<MZq^DjTHaBI3PXZX}7zg at R$ookR_{^Y8=ny1NJP--Qb-s=RcLXbX?nTo3~
z*oKF*X~#zGs~=-uZ?n==Pxi;l)-J>mntxef2r51D{;|bR+1+n`_R|u)zQn+|KWs<R
z(8IqLDnYa~$TZ<6-75`hZ8>knu;UyLoYm@#xU1MV62ej&kFrUYvzW6PaW$v-*m+vv
ziSLHfKf;j(Iwio at G)YHKO-YY%yAmhf#o=YR`|82glw>1j;<793iXvp${6kRbWNF@`
z)3D(OjY0 at Zhn8e>O9ve&BFAdIi=WyjJ7ml6;L|$Q3)w&O{MndNbV|P6#cw1ihA<zs
zh?RSo?`zSm7rF}~4ya>FZqbcYk?q)vXSGuI^#p(M{pfV%Tn*U3p2;;YN`I?Pdlg}4
zPk^hklw7GkZ6QB&FKa-vvszl;PPnF4y!c^Yva~XaZMnSDy!ms{ERY at LvT^LMHns<Q
z at XSm5BiLCI;%V#vQ;6o;6qVUe$g4NPJSq3PgAO+e&(D=6d*dMK at T?6MH{V$%sW;`h
zOShShgCVm7ul(bjVC^cG5Ih+L+89+Zp4H+%91zwXl|kD{<k*lF6D4qKXFn{NuTaBx
ze0=S$0BT0`Dwco3U!HYMS!2BvwQP`lv(j@%5fRo$&(H|-c%QvlImD5D(O)(x*hSHJ
zWmS5iy~iQ-BdNLuEI#51{cj8x0CSORR2}P?Ee|cpKs1edIJYPwpDlfAPdkrsEW*XU
zeuu`dR_3<{xd!eMuUXFso&?%|A9+ at _zdu2A_?D;qyh9MY5`3+)?aGoHIOJz|4{>?Q
zd}bZ^+83~$S993{Vc&l}%f<2wu^vKT?=EpmdKAx+zP`&8a^x_+0yaEc#2%|j0`kf2
zW^A<Si#II268Nv-V~@Fqd|lQUIMb17cz(D3E`>L`;7Gcckv$rVXqwjoCv7SNmG%ii
z)J2c85+CD)RGdAC52Us7oIDEl-d)PZ%l5y*v{bJm#!`jo4E(k>N1JBktD5&CWzBU~
z&{A>pSwwGlAIC{(8diCeV9JhqTFzpkXkKi-E)1lH(@U?mqKe~Lo9<m-JwkSMy$8uX
zB$Um at A$kh5ux0D8j^lNchKbOZh<a42*kx|l#j+F<QdAN!n^fj7b9gIIsKL#DS`OaH
z<~Nei22)dl$)7e|+FgOM at 8VKqCO(VI_=j%tD_qxMvcdaSA+@=y16{tmlTbRhpWFdy
z=+yO*x+oD89Gs-D)XSDE{ul{JiwC5Rcn*tQMxEZKTgjO5ln>-gej*`JM7?uJ>wi+L
zTrDt>WFwIXsk}OU^{-K>G-33zqeSUyKeFZL6fG%m0l4z~Ge1bjyRTqs`2|}XBs0v8
zTg!UW&ydy}5N5OMAUfxrOpV4TJ<Va-YXpFMSXh)wNZEVOV5R1{P*kz%_BI`;{JBjy
z^r_Z;`}*;w`|Z?$Ub-#d^AGrI-{1Q>;^WKwm$ks&D>W&ezaNbsHS-_BpT0syIv(81
zcSrAk7PMc9UYaHvyLh#quJMKix;7k{Q<!#9mkp+<(hlC2LIA<d32o<mibEC!X-*sE
zw1sJMO*Uwry1(_kEK9De9(OzTUEccs%z1WDOf(*fxCLmd;-6U!NTV|p*QDP~`#jzJ
z`FZUU6-&arP%M`V0r3Q`UBJp)M<TiW8bq{`4J-Yt;4HrWM}8SsdRy>swud7Qo*jsR
zu3yj;SA#)xKW=;dTm=<EnvnMZw(^8ppg7?zqsf)IoiODOKb*rbI~}XuvKl&XBYgV{
z->R1fgkFtW-d{}fZtF(6>BB4@{T_~fWo`3esW=qA`{IWFe)7i;yT)W<veO_aBt3tL
zE1MC~jw=nDge$L`#riWpi*k4;#og{0M_e80FVAtJq~g_b_1N907fV-4m6e528nOS<
z6@=lujO*xR($*GNx!k)&^Go!jwY$wn{Y7<MY2w(Gw!LgqsQk#;dW&R0{<Q_YGp8di
z_%HL$Sif(}&A8^-dK>(AxxF6`=*j+x@^#F83X>o9%jV2?5`XwA>~<fs?e-w at v3JOR
zN!StzeY+6)5?p?SKM;!cPIdo4f_l(Pz1Tq=NrIl<L-IR=a>343T1 at tJTA!qeu|pV0
zl(Kf<n%KxoDTa)J>pQ?4_OMYYYalg)-TY<AQEKNxmqe{hQt;yuLq_gHs%iGRRb`F9
zzY8u%VQ#pTt)~|5B45T5$y~0EKEx*un}hZN;^2?3B>F4!e5BJ3+(y6C4mV+<9{e)-
z#$BVqP;ZifeV5+nC+#D2&6ZXYaZMjuOL#^RY)F$bj93z at Uj`RNu>&(0s^OV72l>iZ
z*{>)|;QmB7?y?+4s=W%)!xs;6sVHSepI8gdl6G}6he*&DO+6%qFvuKr9i-xNY`;VV
z8^4Yl$_n*FqypIk#4b5u(5j5gM?Yed;|!4=%q8}P>;5KlGXtbvz$;R*fy|tr4l*(=
z+UDQTpBH);BKM0`QUkb6_#Y$G%E7|Pc#?46tYjt<@dJx)-c2abYw7^Yd4LBKFOp&b
z7_oB(Hk>zd)hHDb(yDHf<@gne%_(|0RjYB;25k=ZkHliPnFtv5k}eX{ei)b3!<X1<
zSu(1v-~yMh1HAEtvO1Y%^r&S=4tJ=Kc<RdeiEC(5#uFLy<t!^8Qb_S={8_Au0Ap0^
zgH$uSG312eOgpK;im-AGG6$Jee7W>4axiF}42`4^DseER=)^ZPCJOGf$A~bz6;8En
z<lU}uFHxEfB5-jR=~;rLNJ_TKEm$!o^^C6F=wWEJFT0Q~@LXiZGTWAQ00TkQpK81F
z^EHlH0H%tM1c_{_Mskq>$weh|KviA2^diKJLmf?aS5%3GPfnt(a|A-1X(633IeoGW
z?Xof)<(g at gj7-FzSc*j~0Lv3f*wv9Z(1mRgE3#)ixc%J<w6k1X$e&od7YTMTACdC*
zb?QYrEnzgITsGK}G(U0+^8G=MWDm0Nb+{bWgc4}HtISzI2CPEuC9^;2ZmL2u#B=eU
z%sOaCDB5H|V*?-QR{|79>{^!0I+=`C6 at S!(V@$;g2{`|-LuFuyE-aeZoX2IXof}#B
z?`7<;XnB@%AjUlUmW0X%bPlRq?MM=AvzE6c04>Uid49r*BlVuH9cCRbCz0C}QAZSU
z13o87NtR<HFc(zTsR|mrcvP6&<glnBIGVN&;L%x6Vtm!FH2xs~Q%z#Ld~0Ps8iW~c
zOv4O!E0crAE%Z at Cz96$5Vhr#WrRfA6xR|E6N%gRrV>(!VxJrrRG)B`m^pM_?cW83Z
zul*I}Yu9vxF6|~wB at Etw`h=FDU at CbjxZ*3`z+r;hb9rWeASz at xNUVyRJd0JpWrAB^
zdq)V_J`?~<$5`>AM>Rv^`PC}HNn%?g+?R71sn#K4yOH{alH>MJW-imBEIX^^p- at sI
zVoB&7u)9gwG%N(ioFa*qIukVy0`Yw)+Os0-p$)%Vr9LA1IOa at PLAEc$?gg<=4(&fM
z^z;-Ym^pFAPZ_Gd<7m&1$iK(38MJfZF~^|1&(#I~wOMNT{0i(L&FYi=osQ9(fP9D7
z9!K!zjB$%;_k<DoeG32w_ at MvfrXm?0l94zbvv0v!XjyuxVc4=Vu3;l0r*p)p4Vng2
z{Mgo_`JJI^lNc;isp{^Wf(`W}o9SW4p?%d4A}=#(Z15gHj<S>YXzj}uU`f${ZhP@$
z2G5j?wg(7p<t}G6ix(qna^AAg*gX2u^{TW*X-Y7}^cN;?UYBQ3ed+qadFA)|fq~|Z
z)O0hmEgJG{KQ}pEZqY{Yw@}FD(XvjBO|3&5XaURR9OtwwT9ref46%}lTYZR@!@w3g
zkuQ*_hBkPytsQz%oypj%G6D0bt}@}T??>y&_dSFC2S~j|$DYyXo>9c~>Fq*^!DT%C
z?h6BWa>TMVl$k|9%*>3#_(@J8(1uq`t8}=`CgJPQPAa>eZIT<Mr5k;-Jc>Rg-2{Jj
z25URapkc9EZEeyDUVLTd>yf&?nmxWr^2)kd_y$F9Qrh7r`K7kps%_~G<HLbBBxvnf
zUj})1Ob$}_S|9PS^aowu7gd7EcML7MPyR!@!SpE7g70a!%#YJy9w}QdxbNv{V?ouN
z_lkO>7*lKIkl2@$5aW}qKq<TWMb;??zeuxDGBw{=8WZub#T#p*b2~GOr46hu8or}S
zTY-V*$ne!Uc&TkOwZrMgT26lg-YciYoNHDHrI_>L#f!IKRf at 4Ll2f9OU*0g4_q$t=
z*zD#3-(8Y~s7}kJCg&O3dC07pFKrW&Wqn2p<)$cVT5~6_okDeXq%wwSap?fX)^G5N
z(!POM`sD{_h|pOxGen9mqm{FRzaKHl1W(76C3?N4**U<gEzKDoDwfA^2jlOZCpk^M
zO&Aj$F8q!L6%VAek5x$zEcZ-4K%xDXGY3dJp{<fMt>)SNg)Zz!C at rek&#o;K`0zDW
zJ#oGN0`zkWxhJix<5+AHOhbiok5uglYaD8>)$JVG+~Tpf?CVT@(V4kwS)M>=(n%9c
zU0sm;zv6o=OntLsKlEI~Yi<>in~{8IN?vWa)x&R3d}1{%=-e#coTq#0(8SL%x>mLK
zY%kh;xf_Ws^A&MKUx}z|b=J=IY_g~4wqxfeI_A3b6o at _-TBqYC=$YaYtK2^3D)ef#
z$tHIGx&p&*hOy$YRkewwyK+L`EZuQ{VWZ#iMzmRMK()8hm9t8F6QX}=K>mYx^~;pH
z=Ln;AZM1%^A!u*YA^O>-X<vL8LZSChlJbbd3tZa)=3^N at W<go`!!D1mHoxnO62^+k
zS~N`XH?NV%5bnH}?#t!tt?2tE;lD<2Mc<Y1o6`raRZCE5oK-bu7-w;n8%N_ub-0ZS
z?YV?JZk(F!!xW~VZPq!37xZS~L@(*+W|t2eFEV7*r9eR@;0vvsotvHXXB5BLpx~3@
zb6P<~1${nB!~HeUL3_|`t=~15IquF|G1xeJK?t$h<__BuG<t1k&0%<Jkuta(6>;er
zGwbG>g42mpb5}iSo&Gp>>zXU~59~IT>T6V{MO*$sre0$ILPKuV?AO86q{A*?0D3o#
zpvhLwxn~O1G7{|}i8>bBjCc9a$Dr*0{MFLpVYy`o1 at 3eC^hYJ*R*P at gbJ|7P%l!1p
zTr2>sXXKX&z-6m86j$JrcuO-GD1!*mcZlr<5SO{lwEg(I2F_NY*5U6GBq?hrE5 at bE
zN~mULwxLB^g0b?Z?V3K>#1KGEP_+&2FU&#22L;6 at w>&7C2rJfA=JG^R^P at Zax?M&J
z*)QHH^)#5Xi2=1X*ALM8)S7}K`DGi0p-w!nv3AO|xFM%?AK^;i81o41%qz_NV<@VF
z`6-U#)@R=}bs#SRqXmPJ52%LMP|)y%B|jJSOlUo4;qQL}@yia%({*KQT-oME0AcH@
z4o0glu-DbbA+mjrVs>xuZFw8>={NGe)t{%&9J-2*K69w2qt;~|sIel;Iysfs$c;^M
zE3@;t>dyrqn-WW5r7JlHZh`xl>CN6qDLs$G&s|Dnj$@LTlIoaEXNQ`M+IzVjXJbT%
zfG?o~3{x4_4Ls?m{qR~!j at P8xA$m49G<Ew$dmNS)x863UBxO~G4(+Y=+a(+ at wwJPI
zf;x$(cBIS>nR?O@=@^QqVh}RCZV8F56c<V{yT{H&Hm&gJ8hqbvK%0i0+Y#g=GcgAg
zTJxJ<9*9EH+^h>+GTSt6W>Cm6LLPYnsL~Y~BhaYKT<gJ42u6WQFihw}LmY9`5&UM2
zuH(KWHzM_}=6D!(&(4F1;CqO#uP7Dg%Sw>*Sy-uTK$!Y%Q9d=UU$pd$<>$Z6(M-)`
zT7XcX0CU at pZ$+cu)UD_FUmGt&L^u1sDksJxycO|+_3Gmxaj=*C0v^U8U!ienDT)sG
zmQTz?d*=R>!qbOnMCnaTgNX at 0nI@OWadZ_t=467 at S_y;R$Xmw?(KE(1CGp~Pf~n#T
z1+C-27y#z5 at S^!Cck}wU=Q3oP%!^*AE}AAYD*^dBqC5fPSADY$w=2O`9?*ar9H$I(
z%yS?n{^B9|L?A<tn_rV&NuoE0CA-{al#h at L<zHNecW3hI*I_$q7~c}Dz?=+kQ<Bwf
zD324D6cyeDycRw0{e>;GRiGYfX$v`GZDyN3QyU*oH~#;}+gkv~u`Fq$mL*xt%p=Jb
zGcz+Yg9RgIuviu|Gc%*b%#0Q at GqWsN7QC^~J@?+-fB&}|??tRSW~RC-J2N}$tL_ec
z*;U3t7`|Tu?KZgg?NS3qPcIUvi4t*7<8ZIs&9rhO^BP=0PxK3smU)(3>Z<#dEh&>9
z!tH(0!5N=U-!UO!Om|N+8ap^}JVCH7xQVjUt$IK^Zdr!W!{-HJek_i&*AHpH!yphX
zH8$$34jf1NSba_PAu>5C4=t`PG7NpE&kTk_Dd!j_49)@W%a>s{VXBPn3}_YDFjrJk
zNk*4B{vAK^N;w=mrO{6$7OIOszmkt#&r|u4rDJ{MP}r!r5*?KCnT<s>ws0ne>xf)T
zEy}$o{{E9THpPIJ3vdCc%|20dYFK}dWqMTRT5-}50LotYqNe<eb=ad`_4X^rO+}}!
zjJ!kGH>K$0v#do%2?kM0d7uuuu+p&<DcXo#+8TqQlt&26LMfO--p_;r(82}RLt`iD
zVxRJvA#|3vFXl4TLT>aYygamC=2NhUTz;A`fO6C2X#B>%Sv$bG!y>m#NJve3<4VwJ
zbxaFMbh?a7j`id~D(Sms6|3$&VnH5QVljDPs#g%r3*wd at AIx#HFfojACn3zjLw<f#
zacMDa^g<~^{MG+05SHn4F%cNHv(7s1$B{kz;cpZ#Ig0aB;k6<KTqpxxLVeD8H62tZ
zt#y4KGLy<`h>3F?g)tn{F^<zw)Eq{b!*)D=@iHH?bRD#nhP~ETVb`V{8PbT8<4JHG
zPVX}oK=16l(_}y%f5N;MK!Nt%RcV$dMhyjj(p3?9%Y%9cZswhfBlV3Cnx#db8k*;e
zM)h`VX(>%@Hy%+gz9i$F=SxX4JRI at PUMO4zan*w6z1zTrRR&_0l>eE;oo1nv3^E5P
zyDesI(R)>Grd7-9be|03`#|oIfm(>fGdaAlFAHDhg^fMBCU3q8RJ?E~NC2D}65y7<
z1oikCwg&I?_ouHGxpD`-)_cj=4qkbiCB56S5;t=F6qIOf>`2g2!2dn7P!6?|hrz8{
ze at 2)P4kuIBeA+Eg?5gM!nWbT{4s<|6ox;NoM at 7i%MTv?5u(&-WvJ{6=_X?7!IgEPj
zW3K7t66x^I`rT#g*er4UaRfn+q&S;#HkfBuHe{w>s-Z$I!mDg;clLQrd!w{_j1t!L
zaH)?brS_khhT68lxln;@2sx=eUOc&DbgTNT?Dn3RgY*vd7cregX*FcvLJOz at e3hR$
za-0|h1lqZ)+cGk(z*d?f7D<mDLVH$LAYWk(n#Yq~)oOhu{9dno_%D#1bq`}*HvK<m
zjqAAyUWjLYAa#NC{AT`xQArIk^`)EIt~XC1Fc4BxL&LZqMRLtR_g5>ab#%u4eQLPb
zzR9WZwB>VW?)0MIxr`zdD`LY0)~8{<owRBs%4O=b>gM}r57^4g<<tz4r_P at nVkC$C
zlly~w55$&C2g{;oI?Qn<eR<^cwn(x47c)BbBP at m9$~t?ewLgo9D;?GIBk8nU%x%iy
zuk<I}S|%^k!WRhAa-8YN-|WxAzQwz}Ym=#iu1WXR;oSQCjSN*>>oC<*w_vg`yuoeK
zQtGWYIBxLT)_OVT_Fhv()2wrefO&UD$7d#^Z?PKp9U6;lX!ec^XFB(iY at eKa4)FFT
z?GOw(#<<mD%&%^&(TaL(xX8WRUSMuJNt~Se(zwy|`;5h6s*9<p2zSP8hs-ogU41B(
zr?wxjWxn&uvsfD&5ZAH3$!dtFoF?x4r at U|J^zk~x_@!w`-|a`<NP6ochhRoNnf-|Q
z<wx&`q{RY>F8ix-%sGC*$upNp4_tZXw)J{a at 2YIvk)U`DLC0Oo%u56`@lZ_}+u_wi
z=|gVIukWB$XK|qp1t;=MupWk~eG68%+hDd=ys`33^v43}co@`Z&r7&g<v|m<_BL;j
zn`nuk4?JOE79wfMjBtE+Ef(2`4QIe9pvDD~vtKb@$^E#u&#U!0uyKMfz1eyVS2&Xm
z+r69GmoZ5gf^P3V!mHOn`yLT`;V^_XIwyQFEmyx4 at O_UDEp$(+8;&g+cSJTaIo5;O
zzij9f96y5?77xq3wsbiT_nag5*HTuRm|})`ZI4%#JlW|-oncs<!fiN+XZ=B9Wa8!5
zGT>bVoQg3e at K!hhvlM0X>oXi|i>zm^5}o60FAQZPR;OQiX?5hQME9-Lv1pumF+17&
zTZu;cCVH+5-&nT{1_#DvYhT|%OYUGh46TGP7}XCa?6dRgU%iTuFm<zFI#`W}dGm8s
zNa&JyA*D&#?@VvDdk|#xAf`Wi2OI4LUAQNMIzzTLhy%wwlP8+(j=Y}ZTS|D%K5=zc
zjo!zvs>o}qT-*>X??1H;8?<jP-Rwl_;979EH!p4Pn`RAj>|rq}d5agBB0oZTK<55X
z{{f=C49#3fEqPtO`OFIM$~>{Nbkr?8e<Dk+vtcto)z#!)<CBNK;_r9Fv)=ujAm~4;
z6oDs0_r5-bF)NuEov$Q~Kw=;)w4vhVr<rw3i^H6f`L_=TvXLzoOq|B1!bLRqwU1lD
zzlx9918X4H<p*-|M+e9WHupTwN(h>U%6Hy6HJ%kuFxf at 7ewe8nQws|2_V0~5$?Y-0
zqA=00#bc54xH)u(joi1A(#XtWs*~$8 at w_k_Q4&W>9a*qoqscjugVV*ANV$!!sA*Mr
ziOsNZUtL!pq+t^^;G*TL&-Qc>J{pE0l(QN7v<fLo&xfYJU{>)D_|Du9yfr!AWM5c_
z*X{=Sw#e0B#e at L_Q6n-r?RH2h94p_8cXom~Ihs7)HKLnMM{oH&vVG1xH7SJ2z;}s8
z<Wv(pI8Vy;RddhQ&^-SYw4}Xq9SQgetuoD{02g_d&=Si^SPd>)P5V4<FnUUzZKjd4
z<4;qA0?w8HmHE48Z*wXJk?xs&uWX at jkAzT`H9b=4R+f5^&A4Z>YU-~Z5<;f7gFp^x
z2A$IIb|IxRu_Eel*xl*t-hg!!EObou8l{Bjm_bc?*Dsb273voS(aYIDKs4HGn$*go
z<!FJrTBGUrq8QEf4HDMk{!oZnXim0G_$FeXOy<g~<LMyK6Ih)VX2c%yaENr+E|)&8
zLoL+l?i3=9enbXA^0-equUs=b7T+{REyi%)3Zi(RWa70UCT7N06_O~twoJDaZvqJg
z7Kj*smpt?_!{XB9*zsOg1r4n&4rU0~1n&`eisD(m8i at ou|4rHqaOY&q+j=>Cv*Q+q
z8{|q`NC2N2PS`{eoQ3i*q`=F~*jgj5P at PLG{uxS|bHuABkXueCp;NVyMs2j>?jE;U
z8FJpTUHRb2H4;*+%VDfd{7p=ZZ<`sV{Dl^^aesX5JP-rz^)%z6Esx9bS5?caQPpnu
z3C$=z(IgYrm^&a|tO}>49FoAU#U3W)o&?AiR4Rr*pyNJ6v}?hd*5Wb7bg-Z?^aJOM
zlUKOFsYu%Nmn!O-hW%BuAjHmf<0%z<0rC(?=U#1~E)&a&&QPe74UTr$0axn-ccB<D
z5`K+I(CU(l2N%avvF_w!XbwqHWkj at TgyU?--T_uarNXc6bmnx146kDx8rrw5Y7sK(
z_G$klY1M_ at utN>D2V){$ro~dgVn5`U<B(yS>NN5nRx+)ZwTNxTW)aC~v27{INjEES
zekR=Wackt2Az^TCDqkX<hnJv<1PaLLx`kD*BqL^1qNMU8(&gmS_F2-Rj=*biGx(O^
zU$(81nI-)lKP#<p5~rVq!XeydbhAfHo;$sb&M^P5${u!96efr3v-6v%9FVdPmm+fk
z(>3s`MMBu<a=~0b<i2FjbTg#TB0$JsF{_k=q{bg!NhN|^-dZBT-zvzbHcF5f3SGI(
zC34Vy7!DTGKj&a%ryPEM*s|{*V#m1{Asp~T#&kDU7*6EfyaKI at K(Y;+A<!Wbj7v#f
z95$m$-A3RJ$8}D!ZEw3c*bdCRtT(ZxT*Vls6ep9r6XhbMAgFADkJQ at dP$Y97VENd+
zgAk7!^=%(PY;JHvdXZS4(he*ULw;kCjK9aUp6drW7awdEGB22z>WY~wkoHsx3_nIS
z^*w$t0oaD7-hvHPycoLLu9iP-HEFkD#YY1H>hkXz*U)yt`cXcZbiw&b!sN%%NX0R2
zIi_ZK!8+CoMx-ba%|7WGcOrXJ7XitNALEn_0%V*T1zWz&I-7~iIDNUPxLTr+R2_0{
zhGoheV}&Q@@s4j3_2(Ix9$dRV)oCFStdovW#xUu2l>5l7xD9Au3SH&f*T8*=IOFPw
zu}PGT at 3wkQ!1{<X5R2M^Qfr@?Nr~%)U&-XDRb#bIWPeB)ps)R!sGlhIap60BMlnK6
zV}dE0p$F$SZ&r7H=UT-}O5F<L$Xo5eht5c45`t%$PvnQnr+3zq7Lhli`sXS0SPu65
zk+15TB%ldN&$GxK#BccOHr+OF!`9TYAG%MrTY|>5-j@?Bvp{?&T27AHQhZN3%QEXy
zSh8lx`80%N!}_er)letP-9wsqL;=O_G(Ck9&u1LgBdg0I3~{JHl at jMgfnE`NJtti8
zg_6Yp>(WW?D;&={RHn=D*(x(DTHmJ1sqdQBYEKvG!%)-0Wk}cdzP28+>}<4i9=?>g
zN?C3fCgWhPeS`M#FyIBbbn3%Ht6I~0k4;oT<I?Dou_U|Z=pT>H-vkF}JY=a^3O=iU
zW5CuaNRtPxjT!f)KxYgXGBCwW+bpGHAkjg&g_54*#&yq=<F!^f4|HSMRY>7avEpFh
zO<g9Mk(@Op1Kq#eD6c$b$iFVHK&%};DYK!to7ksPN#Bg-=^*0rQGR67ZIZ>f^*kV5
z`|#WeL3SVYs`+ at 7YGtR~7^7~=oswDI34^y*AP<XW!#vs(&{tESjeWT7w%%_7{8(Vy
z$jXmQF<f~mZ}ncGr}6!^VIk*Kq;>$m=XSoAqi*@C3{!fjoxWw6fS_8Nv8&+(6cOC_
ztA48(@gZ_9UPgMcOpm~^vd16>Vt at zF>7-BOk%%i-ux;T3R9$m~^}O*)9_|;<X1)RL
zNl0ovcS41HE4w*5nHyZ`AFkiG?D${=OnHbJf}XTnpm>Ld#j5P*jNsy%pi#jjCce4x
zxyuEvo%%nwS)EUcH8qAm42l0}p$YFBW#-*mXeNZu4U#*^kK~!A)J`ZJ^9RkJnkRs%
zS-*u>$22)PlwBJk8L4@=AN^gVtg;EZUhd;UbVBN$;>1t3bt~_)#Y=<yt3^~B2+Ja#
zmiIx=%)C6!qi1NXE<qF at lUI!y=?cYw+wer4#NmSZ>}vp7dRu{f>^3D|Rqn|=dCo_V
zRa{|2A$t=Q<gl+ at KTkc^9{t1Le$ffm7he(*zdYa5zQ#v)y*-Y-J<Yzo9+ECJUSDqp
zf9;N+^nc;)I!@ik;o{Bi;MJcxY+}np`RZBCRww%QbYQ)NX9Tb-$iCj}A3AW!j+xX{
zvWE1+2jl!YPQ03gl^J<RNz3{`7~EQH991wAFG$AX!SwkWp2$JS+lweTui5Z)=pMCF
z*Z|_N)z#=;gA23 at 5~{-eDQoouhvkOqi#S|ckXw#&%~RT*xASmhin+*q1`lGx+U<MX
zk$eJ&Lu@%Wer*GhXkJoqO<H!*U_-SY=uIat2d=%vY89)Rm;rxxnb1A%iE_F~I|(hS
zLF0z@&V4G37;f>Krz6v4HKqwNfGE)Ieh7j$C)IkZd91H<66uM#EW at PbI&*L+;Y0l(
z*TybQXKw|b1AjSz%K#t4-J>B5c{z~@Cri_{;(5-h(rqZ=_q>4CAYI%KHfqZzYZ$cc
zHgsHlGuS+i%7a=Ta+ug=@mYDY?|AB{y{$f!u#v3v{n)C?!yldJ%4uXfKB?>wl3vWk
zwjPbT1mY0|=gJRbehB#`e~(d%)giIuy>a2(y2sMPtJRxdCTXq@@ZBT`bK6sh*c3Bs
zfGm-r04<G*C<;y<7g!Q|@I!<o(~MkOMSv+_iUK7BQ#1gEGv1$j&!6a5g>crbkCUuW
z5}!Acwdk0+hYr!6>^s?Wa;MdOc$*H5OU24l>5wqe)+oY7 at muU*O{4+<s&JeW*WU7?
ze1Wa^rGox34N_boWS_7Se2ffdZc+qxOcT364-C at qZiHuaXR@Fd)Or{r*j_+J`6^GB
zt6-Dv^zf?r3nZtDU~S~q`Kjj at cu226rfnj3ycSvP5y|L7o}AC#K8DWr!_00OA;k`?
zLVQVJ80Jvum4rXpdC(mBI6sn+?=3TYPAV?=L7$_|xYX$hb58G`ls9P8MmW{z?H0%)
zkVMLtqq>lcjA7(QA`T+ujv6gL*mG<+5@%f at SY(ZJZds1oc?1 at y2zdn^dR+|qL7MF!
zd1u^=(>{HwudW_x?(%EYHI}f=U82Iwo!-BngFHXw-5=sPZv|AJyqVLlel!<Cht4)5
zAGPgx8(`B86w$UkSPywwyp;*_ at li_!-7z#>$M>%vYbZW2s)8nG=oCNp))UK*i;}?1
zgX at hP_HOA?{4Vh#g0^=~p>X|zSeGYhR=S0{#-k9RIJG9yu($$~>pMn4S|2E{jy{Nn
zO!4rr0rT_q`4vzvN`=)Qc$5%Z30 at 0#S~Bu|tfT7a*7ug!RW4XDF8k0X!%U^gV(L9{
zHEzAYil`LdrWtqx4}slebx08p;gLa(sY)fu!_OUAw8YmFNZ4I#ooTR(cw?UCRSvcA
z84k4^{58mFOs<?Rm5Hbiih&;ceoPz7q-OyShV1~AE!RQt`_p5ABZ`xbuBGo1erf at J
zw($i=>boC!^Z9(V%COL5hxM)=M`1g@$%Vkd%`AKf%O{~lC7;54S?w)B&$X#5ark<Y
zjlw6wEu<ab&4Xw at MlIA6El-uR)P)j3D{8iwL{`>8#ZTnA8y`0OatFQYFLWs$GD@(i
zfypbWvJX8s5 at d3+NeVxZcg!BEo8s3*2;<6^-E5t=VEH3JLAZ27<)~S2P{7%fj%wy*
z%I_t9;PK;;xmhWnm3DWD47dSi1vD!+6&S?>eJQxm&5l`B5au0lqJ`vI%Eumz7v}{x
zg2bc;fb|llkS(fH(m^U0axDDyp*Ub!5#@!6itcQ)e2|uS+Y}<=;zB=g^W83x2hulg
zQ;1Q5hT4$g=wX9VzF$>EEdb(IW&#6SKg1F5T~0{6K8ja2M9dMQ#G2AaFg2d#8HOwe
z-B>PX^!*`(ISU;W-tHJXplo)YPqKO%MbrjrG5Qjabz!}k1V$d^!1VD>*qwphq5c=n
zM@}{glII-0coqTF at ufyo&S{8v`LWY4VGJcwDHNPv1sBwAfstY;ScXnpdXLe<SDYB(
z6=>LmrMk!y@^>}+y8<cX+0hiiyOn(BW*9Xh{1mKBCMwe$rr_8JWaG*UW at NQPfy<1o
zr#?r$B8al8c_maAKca**U~n5)!z;8?$S4ufEmsvi;zS3zKFHt<rc2|wos=2)F~26$
zLmy&66v}rI#Of~TXd+6(MD<idB*p|mqmc#pI?z$)*^3^Ho{>}4R7$EFTg&!W7!B{$
zA4s8CQwl9~lqfla7Zz8BfKeLmU})Y}?!yTYFSh3S%-|PB#O^;s8t^5yl9;?F9b24N
z6<t$|C4*Y5kCv{9H6x)(JAOa<Q-+0EY7VUZT^3U;wYR8QZ-TlAI|1U7Zj5`CNFCH%
zmV=-ci-;3k-}hiR!|||sH=3~8s({9)9Oz`DHBm#DU53Jana~ttQ73fpnr7C*uzKT=
zvtG4Z$kJjd7J>ZO7X}uht^+CLPIwEQ*b(@mqVjO(PYZJ*6*TY@$jQ!9DSV<Vfi<Z~
zR}f38=@7~+hs at hlqE`74rI%Gl<_4nha>#u44wPu~Y9DTvD??x~jS*E)GP|Fh4V;CL
z`CydG%fpJTreq+<YHclpAZd$=q!tYTL(Tx|UM!mtH}%l`l+NW$6wDwu?64F8na#L|
zKyX#~)EG69Lk!h+!QC)d>~nIKucA8vBp0qK^TkzFuuR at K^D?<ZYd@|dnqwqfAV%%&
z^+LJIL}qgWiWo<J*}Zp|uZH%wNkBm%#4`Bg{zIT9ntIol1inE_&Dd)y at B-zwAqmcK
z7z!ik7aCm%H<e*X7y}?Iy`=ezpjL~BSz<eJw0vO=DV;Av{L^DI$$>OVk>IV1YAdq)
zr+#<4Sq*O5 at 2^5FRl{6WWz~Ue^sfOY^dSe37!m!N;@8FX^6BXKPR?*lhlS9}Gff!R
z?RMGC&6qhP2O22h%QOX*?eh`HSv;(aT0U2U-RuH81H5ylMWO03lC6T*;UU6dDd?i(
z at 94_U=t8XXL#8`QD~cNu?zb=u#wU0v4E->c3A(Hji8gy%^GQAwK)V=>v`KwoY5W-2
z{4?u|;N3=vp$@bhV^eLlqfG(aL%uv#KXRm0lp;z#ADzs#gvM7A0~!*8pRp1Y&HTz6
zFIgeQpUfEV3wvKQpK($NR0jxDRlRG=e+ezuyd-E<ha8X#!SHyCHq#H~50y3NmzlhF
z%0lWa$+rW>Q_@`K>t9>1a=2EWR-;saU&)#&#L}@5c$d_-1*a}c(c)BMrwW^#@7~D=
z?9oB at 4F?l6BzUVX6Ijw=fkudNW(u?;U~|C at -4L51u#sd<Q+`=hA8z{2Xj~()-`~Xc
z-0!S6^r)TWv|mI9f)GHb8}kJgrGs6fmrX*4^`NjB-9UleML(rC^;>fQfJUD^(%2XG
z^4VE6{HNd9E1H4TP$NmvqikR(hnQM-o0${#MKxn>NQ$8-&msFf{eg5TmdGUrqi$G=
zi)gcmbmy|rftHSPNytEvg!XtvJTk_$&p6iz!iJvws*G%}I|IqJE(+X at EYK@^xV5nH
zBa&<0&q_t~X?oG|c1;Qx^aOkAmI<DYp>o<*=26#_No5rbBNYs~jiJj%>=?R)xn1Jq
z(Tf*>@N#9KwQPWk0CX4K^9JMYP<^03<#vPyDpfDirAw at aI>u}vRU?jxmbIlk<xVQ)
zj)<#rO;UsuEL3!_=_!J!Q*TKp=BsSsaj*8YzR#W%^r1g;5J`V)=JUn(hce8Y&SjB>
z<4_Huu%&mGRFvX%`F9Xn2GYK$YJMcG_eFWyVMj at Vw8f!PRc)1_6~*AWW=6}RaRL}M
zZSZkb>_r8yk(JFTyfq;d7CHy-Vw3n|4|>W>2rDYrdDgk;Wh&3P<qGzT%xV%FUFOSa
zCHqIX2wQeV^U1~fT_LU+&U)7uY|F6MaA at H+Rc;?E!!|ZmwMqn7li+F_Kg<Yys#zeP
z5wu<$i6u~>=)j*GMh`8UgCdQ~?+llblF!pIG3TYMlDH%*Us*H=D`+Iq`H))$eXnl&
zE7woE9ncCG4zR);+!Wm`8eiVZJ)eZQoaH1a$xZj)GG{UMN7f<yWc?+KzU!jFGDWI=
z+-svrz2I8jZ;UHwQ`G53Uj!a&B-C4#vRCpuGdoo&hA2lk{#%Yav#L at D!15(qg~vI+
zjP|ne<Cs`sR%hxH7RndOYnh|&@Q_A*Q6={<S0DP**N?pcmB$w<C-OrBAW&gq)I?&K
zPj^-ttzsv#EN-eidb-V6=%K7D^}n)FywY)54VMqnpv%800zE at EGD91j&{E+>L$D*u
zj8VHv#xVj#f*b_da8;*gL(h)aRK>M}2?kU(WVgdiY!aptP)35pKG{(2Y`^7?KE^n%
z5 at do<SLT(uE-!lbV)LS}`lz~#A={L2rLnm{pt{qyDkSE0L!9|)!uBTaYo6Ps_05JY
z`QZ`0G*z;K7=saJ(OG<Y(Ys;@OBp{F>NJG<5pE|H7c_e5o|p!T$5w?pO(LX7c<5+q
z^kUZSNlq7afiBPDiF-e-#dT8 at 0yy<zF3hG`<O}3UNxV!nRV&&+Z#h<&bq?sMKDob>
zx(O5{BAaOnRh at nodE#(W{*=-B(B?+;Tt$`pd;-xcfvR9>uFo-5YnOK!$X04gGMJCY
zM7SPvy|yld?uK9SD|Av9*~L?NT2=I-IEu4yxVem~^~od)hlPssEWdm{8P4z7{*6Bo
z!HfhihR)cb)2av5og%klpBf{iZtlM~BFdc|OmLQk4H?AD^@pF>HX>3fPlvEIFl%L`
zP_1#CBjx?r)BQB`Xc5*~enfeVRAx@)^fNSNmXU<<wW!xC=A_J!rA*3;$%<-ZJiQXM
zB6h$w+F+vrd3fQ{kMp3xC-kOx6x3h5ofbQ-sz;XzF3hF!_lY^Dwn6-3?A&NI at EF^i
zC@<AzYo<N62bI|t(kr`N1?sZVt8B;}ztoQ?z;u1lCB5*K>v`|g=8g)FdX_jeq1wKD
zz9jqFMe02s at i8vx3(99w{w}xM4S3qIpHXmXmY10 at Xe&3n$cXPzR_2Bzi2*`RD#&?>
zOlrdsF^%$)h$kx9J}FSqSHpyPfyDiIc`6#%LOf2j+hTDw*$EsX9%3OofPj+_1za&$
z^Ar^hrU(ohp;cUmxSB3XBV_p_;tgcY?J0mrFxgO;*))uS7E8Kpg at kx(B}1hh9P^Js
zoM2Y~()G4$2-FR7wuM%>Ev6<qMR7yWz>h9K!w)=Tl0fABk-By+5_EEP at v-5$-W121
z`qOr`0E{FQT705zlieF+m&;rU;>#mqzBv}^vW6<s2{_FJ6!1V4zW^nekUjR=VUemB
zzQGCxW8;b|^YIaJSo1RI9%g;+Qwe>OOfRQsVI97S9h})frxfh)3ipttB-80L_Al at i
z8?Vh_!XLAZ6s-cxI5;sYlSYE)NkpWL0=M at 75c0hfUT#(UAHcdSBGLf0n7uN{bS(OO
zs)}FNzsm;c-ClU6QBKx+R4iuHiHXk>oATEqB6nm7dGZbCT at m_am%YN!4((*|^vhbG
zU{8mA!-OGyA<4x8&LI$98^;IuIR;4Zs5d8J-0W+b1eQY{b|Rj0P_46iz27<J5g|{(
zhzpFaeJo(BA-TCj0cx?pAZ-VCU^L88f#vcDQph8Znl{*#X;zwve+}Q)@<xT&K6mG)
z4(W3}5aaESbPvH>@9zZ{N6t<PwtHE_8W6;k<*Nh*PUlWo%ll|tXH0l4Irww)x*zZW
z|D-8Yc-1~8NZ9(RMK;YN?Ou;INq)g1X14cTji$9x%@TC1YQRy5m9b(@q!x<)niqX5
z2SiPx2OTNqWpk`3sYue-_avA+f(Y)TJJPHDVUIiU8s9#@iwqO4h!M=)4c0^+9&QO{
zpbOZ_Z9To at j6@gXp}`xJ6rSAxR;DdTX)CH3Yn^(=s+B)+uu$I7aOtKB@%3cPMX;nM
z1wZP|R%r02$+X%;-qXO?P>6}6B)Q^+uIy{DV5wo>)C6ra81D&|n_s4dIO!Zy8|GDd
ztgky0U5gIM&$mhw&wVGp3Mkl%Fxra{ic;$3(JsSy$S}i*Pi at jNHC?tSt&@2r%zO~l
zSF6NEYFc}+e!qjs3lUw`(K_Z=+~1g87m*>IYLF67LBE1JBSW0Up<7}JOmibfFd?;!
z4VLi<Fe?g#RwNc;G5ru20S{}+T;1?lbdR*tEHb?Tv&K9+T;S{F>&i>(rlcY`-BxxR
z6T#XXt}EjTa_v&r*=XL%*HvDY)*#z=j|jvk-Ygw&pc!p`SP%6G^E!d!Cj`t5yxKo7
z==CB+zkFZs+9xW8{i5Ps38#6im7M37)>siP|NRHT!-E2A1I_mV{@~LQ at E2%~o84<Q
zmACV^HQsNHqs@&*;*38W294JdDh~!L2skzLXjcRwjr7Z*bdmP8KjqFldrl_|)fg%F
z(yXNqoFCsfwyW${KJL+FWh0rs*~};LukH6>xTh*ZZVmu*cnQNVFHV+supV~iJDVd(
z2!HOBg)bHx*@KI6Q0_~!zN3C*iaJ_<QQ|GJFA{qE`R&et&*+gYAo!9U at AZpoX#rJN
zbQ!LWx!IIJ{m#>u#vpHe1F*98jSU-BsF!f{EgsINX;j20yZ87G7Hvg4H-$|35#nL&
zzc!cWc~`>1J?v{PyPHMU6SL(L(f5B|g^BS+^Hz1XS7|LN)IgCFq<u4_`*Hbe{SEw`
z(84+~ECMXh#@Nxx0cc>204muUS|Bj80vG_G0uK+pu&s>~(8kFTz{n1&Q=(UKvjfsA
z7?}S4asV{|n10JD(JR?H88`s}4D_-<V{-!`TUTucP(2$X6M&tQNta&O!Pf5os8j+v
z+B!QJ0YS>yek<YQ`=<lH_y2al%GN>I&cF!x+Z#tV0P`P%e0=m`AlE>3Dk at 9>X68Rm
zsHm_3SQ!6OMX%ssYorWx(xz7s5u;ZDx;p97i at G|AEC2QrbeOm at BY^qOIq`x1{%QDk
z&0mIPfHtO1W&k!87SKO(&8?h(4)kJHpkqaVMxZGJ`1t-2GFXYw2=&#df?*V|%j)5w
zel2WN3cBcxnnmuU4jXfeg(M#D9OCjYYg`M-BZu#%XI+nP_)P^z=~fMMq8lWnB&2c~
zk5|Rt#R%3X9)6`G{qo9-SRt~J!5;_>+m7y<;fSnNDg-8&FrK+K|Gb*sFSD;FSF6IY
z`D~O?=H-Z1{<1H2NVW9lfJWw)psra3t3em0bp9rQCo9KIYBck{=}nn`K^e=q6>$rZ
z7a}*5X<efj(I`f=C2J18oII<kY<t-r_RF`9fq3CaZkkM6bJa}Drw--&DJm at VX*qpA
zhA62>C_4|dkKbMj$Tm1RROQtWXbQ93mu~uN{l1>R!58(s*ej`SAYLJ?#$xw<iSSPw
zs>4MZU6_!Jyd9A%^B;*<J at n3yjFKdc_uapyD!y~rAs7ptBb1{N7Pg2MOc8-uf-6$H
z0vlXW<6WrdaDL{#DjJ*#VMTmVEpcsaqneb*0NTf02NtiC0>*o2fhsx0Xpc1~hf|Q8
z61<R<t$S8(v$HLhCxjCs7$Zezg|eYtdFbh4b3~h^5Yc|Gvixj-_L&FQ;OR158rScZ
zS-PxP$-(H{IAf8w1?Vk;DS{dt5mA{ot)11Tsp%>)r}}<&#cggu$=Fa?>KDWeHC4a#
zCJ5;GHNL^o1Zh-xoOUX+W+kk%iphdiQQna_Z12UN>?eieu8&z(U)Q$sQjV(Ry`<{6
z3bd4fJzR7XlbArm4-m at nE+vt-b-U6I2hIC1KvTyYtOHC0j;dcr^x6)0sxgm~m at M3L
z#jd}=2CTXSCCBPqoE}3XE&IBE5E=@TCr$dCmp59M3}*f%4lGqXfQSpaMT!VZ32z2<
zqi at P(98*aOj^cBeF<%$;`8ztQ$3)h0WOdYazMISL^846;C at 2QDX$yM-S)`B06sB|M
z<a#!bA2`A-WLY?CpR<Y{yAT*)iYbN{(c5v`g at PqJ>KG;r=(mZoun_i9M0=7CSn5MD
za5WQ?qU&y0DH(0id#&=fhfOaPuk7nt1Y8QAH};lnd3diOPrfxI+A4QYNDmTPzgtc_
zV$aJG79nJpr1E_a8<kQI=kjjYGUSXA;aE|*xx&#WlU85?zVI`j{qskZ{*adUk(z~A
zBpoJ>{bl8g?NAqqb+e=%@->?}K8d24`?}wE!1%5MTJ?xk(OpxaL!pZLRVttY;5DGk
z*_KT%J`mz#ysF`j=hh71TkU%&x!eRwf$!;5Bsx|{Rer-0Hi)c#)No at BbMlWiGfc6X
zCGtyo=hvk at KLPu!>v$r+K-)g`-F183z2#~jFCF7UoS~z29uhKXN`<4>5E}2i?GyeZ
zluu$`<f4aNAJ6;*Z#3AI-D#}&v<JstA3zSo$hnT6p at K^YnYz477t4W=W#PfOjV|+G
zA0?-4LyI1SD-xgdO;7|(%r>uGzw=YmZPiSAN7LQt3+3no#uutk54-Duaidp-4c1E~
z>xnM8o)G8umVO(e=&z?zm@{g$J%lpHAv&Bcggn47{Utntm#mnYth{<9fGld$*`l?x
z3|-rFpgTcYY!nh|ml-NMGI`t5$38&RXYra<{#kQOa-W%VvghuRlU8S4K%l13t9K at V
z02a#FdpHqY0GVp1n<nlj0F at _CiemuZ(ab7f<)XAI)Jex4ooJDT{9KPOCi>Qjd>kh7
z{G#TA_7=pskp8eyj7vA<I8Q5}SP3?K4-pnjg{Tt|?BJ<qSyMCER)vw1VmK_tihpqu
zCE$n@`5iJCqig^6G1WyT`<*d&_&x%XE)tdCjmsTj_o3Kpp#VMSly9DOFDJRE6wF~p
z at 3O!6WbC^kZZ5ibVmNJAmL6&BE(k3BY8_ik_f$&&SY+p+VE?o%QlpJmxLzs=<{t47
zp1tQ7%%UP&t2w9i7bVnrfBBy}(s at c8huS%7ioa?EebQoPZu<yso0Y!9%?dpT%xg_X
zX|r5$Y%}ga);2d0+K0o+d|iZ<a*o{C=NxjsNVQZKlU=slZd2tLd;O`5?qfsr_MruM
zCr|Vy)O`~umd!sx(^@){{T2<ETQlBL<LS>EX5fYaxAwxP)bxc5xsvi8+=P15{#;%^
z-(*KtVwUzXJ+pIt^S#ykfV^<&bqB^%=p87+IWP=jYRe4yfa$N#!Q0<CsJ$@8V~q_B
z&Yt=7ndSBH&7e|e^ekHDZe)f at p)yEjv4fj`@!V8fWilp2=sCNQ7sn at BK<~Si5PaY+
zM7|PhXMl_wDug)$ZZR^x_#nKsoG2;QEptYX{G_8~^E5=@Ro>rOVZKU5Tw)TUQb{*S
zD0AqpVgwh1Z6Lhqe$|$WvnJp at z|cI7Qb*52&S4^arlkLdK(GgXHnRpTm|sU`?aOYO
zArq*FG=Iqa^~W%PdzmWl%I>g>-l52HPq+m)zIh6?ppARNeJBOx2k at -`bz69NVm8*e
z%MP83cv>{-STlpnl*wl}0VD(OH&VX&rY6+1OjX#^3EncJe)3O^BKWuWIfy0r9yND*
z33hkhGy~C4msJj at bYQn}iZvwFvOg9B$=gbew1OV{BB1l1Wg)c9kLm7- at jiR`x5B;s
z%JO#g0b<t&jLz<O^^XvT;A-w?+rP^IY&0XGPUzF(eeiV=B6-(#;d(3c77M?(1Ve0E
z!t!RiO?wF**D&qR4j&_eM at -%+yoXdTYQ2wi$;7=$gdMGjq{|#BQlb at HkKj(ETh2U3
z;KM&oDXW~&pO9gm&>s`1-n(btozQ!a67Cahu-UstA=u0`m$Cm;K50&+{#EoP at -=p`
z(+i;!oL^v$@FXfq&Wdcz4VDSTu8G4UD2_E*v{1eIBGf2WO7Ye8SD?lsxjqlMHn+no
z$DByig?patR+N5@{*9fA>hj>0sujs{-Mh?eN>%waCdFH*q&1Qbe;uC(L at 5W+vgE7<
zEl4M1CA?yW);kU19sN*qibcMBtVP5=6|tBp`&$nD7WsN&9xcB at -=MqZIdL{*oGDer
zIR^)Y*~9*RFyZtxg;yN&NOo%e970SzbsKE$V+EkLB|)mkcf7;M9Om^Q+=X_#ExP0f
zp at RK{mCLE2hJ`)DhD#UJX>t=y4zOr at LVATxtmFM=Chz&%S<Tj#AP&^Q2K;;NLpmNC
zZay63miK9v#W=kxg4m_zI0cSpp4yLOq<3axUmksMICg0v5S$>&kU|i<ojJVHLVqe~
zk(Q`D!JT6(!hPJwVCUnoyL!*PRUE)+o3rtjBUql+?IqH5NqXP+o at GV~W at HT2>4`g1
z09 at hW)tc_^tcM3{w3ZetOt}oMmzx+eU3B=|I2b3ZK%4Uz^qz|QNw)FA#QpTF3go`f
zM@`tmq4ON9QEHj=<!>0r%y9_x*;dPMa(79vv1u|?X)F*Jx2XZ#??Y5fi^X5 at r;*K4
zbH-mrnZwCVr*@RcKe?;mP6Zx&54^xa#~DoQ)OakL$BxtHJ!lkubv$X{8VFC`^a~XK
zHIvU9qX1nVK^4^#7H{ZQ7(v4t?b??!S<Bd;<vX2g>_mYh%2Wl9Km^bbwvmQ&Nm>x;
zbYey>Gr`b6qrs_4p7PVBfK<xMrhNFy@}@siZrx%{8u~iQ<EKg at yf)$$|A}jwD^53Q
zVWaFG4jNvvAG!M-KzCffqK?1iYmHZ{heQ}jyvn&h#N=la2Ih4yx^{SQ#9Sct=E^8{
z`Fa9ZEoTxR)>`=25~1Yd{uDocnpKjY#{Fc-whjwP`Utixd(?0p*8VZbGrpc3pDujQ
zh!s<pXzIBtfF~cKBZ?=11{JNl#Om~2P*{t|Jsz3uY&YiX=@nGj!D2bC*OoMjgi!!(
z&UBc9;kg==9%@(ZB7dPN at BAz3VI3i%Us-n}&BPU%S8)5E>$Z2L#C<=zM4{qp`o+XS
zb|{ScRC8caEgi9JNBrb$`k9CR!ZGIx)cPQ5**4kwgcHJ{*q<Wgh!sfPU0aIOSMPx7
zu~D+VnrmUX2ZS4t;uAB-ELs`m)Ariz`XNHklLNbRHOw1>clvWOsF}&<i@`fs{1$8{
zAQl`d-ae)*oMBihna5aED7nc_5wxOIYTHIv94j}hjApp)9=f+dZ@)t(ZA8b%wK}w%
zNP)<>2umzKhmPa#E$`UF56LB6eV!;X-Q^P?(Gi47Ld{xy*cR?0f~l$3#VokRtZge_
zi~KJ3Ecsya5+D{I8%m^S=GGb4ZPlD34d9M;s|517KPI<njh)y8=;HI_(0Mx$`*JHV
z%!5x0Y8;Ah5KK{T>3r~6=#VN&@r{qIoLNDpgMEzQ@>C}1UtAk~S%DmTT#7Fo&kKx4
zNF}<5(npA<i-=emUX-2(n$hf^8ltaRP at kXeqpc(~&}l(zQjRlBwNk^yR6c=86<469
zE11q#1*f1=0y9OS<@_<v79*S|iUeXjtI?<i<>BVnn at X4|5zO93EufO&bx>%&D{Y+g
zXZ at m>4x-Gb(Mmw@!11CRt}eB=u{0<cU_?;ld349y$K^AZ|M~5>!d>mDYaD;}TCL3!
z7zoYYt1^$$HJb9Nv?5Lp;zwfB&DSB@>Tx*Kg0krj1UF_oWxYmaL_Y1rs<OVhmfBvm
zWx1M2Xt4q~V8PyehVQ^bAh0P3C<;cMu<v&JyoQcr at V$u4p)Vi;l6-u|O#!A}>Lqkm
zu|ZU-sNTg#dv>PMi*;t6p`kJzR#R#MII`Yo<l+kf7Usi*4>_ZqO4Vhc&56$B56AfF
zRjOvxN6Cmd+pHx=Vor$bqPhIw4acdnGvU*%wAo>RHP3weF+M22SaZ(8k1LP3sz*P-
zVBpY+7jD|fq7vBo^Gg(AS6E-IW#K_04Qa;|rB#iCO_>rgcs&Ly$%iKG%Z8DSzS5D^
z6Rsh-b5sIui+pN at wF!02j)K|2W<>=gdNFQzoFmOSJE<NL6fp%vq%K8R2a+scJU=7#
z(0=(207l2Xk4~|c0W0mnGJ_^|SBQ|D*zbuWrocAU!@<MQh=MF$K;hJhx;s at eL#M2k
zB7>qzu%Zu%#gdYEUw(F4-El?|-4*l8k&Xnd*O(R#b!rvqZP7Ok2}P>}x%eX_znx)*
zRTE%hE(5!>!Lm$!(HIM&+Wc7h(5k`WrJ0KAK_eN(7}xF9o$r@!l}02IgC6?+?0S^m
z4m5i&9gOOM`!WLpnw1vhpBODM3L%6o5CyiRJ8Vt1nG5^x^+t{3YjX7b``cNOD2!uK
zq#~6(Nb4MMx?+|OlW?cSy_z83#j$fieJ1be+A4o+uF2~z<`z3>i!}&p?#$(q?{God
zv)Gv3G&R`BHjO}N;#XRP&mz7v at eF_hJk9RvFO4gb;n)4ptBWvNp7Kf+M)pXp98XV@
zEml9UtL|r1x!t7LS^v<O5Yu$7DHo5w*=5Qpi*t4LxZru6)G9=;^m=fxd!=MZIP!VZ
z1=a$8CUoeIeL%4IuI~`h!V`zVFUP?s={Wn9)5o)oSst at HNr?^B4u(61K?Bv!Lp@^|
z+e>{cr|%gfQ|1X*=4 at an={d!=!2BogjKo0f62%W+QhO7w!OyX*O_o%7;kA-d?`FPc
zP%wVm6!_xEDZTqMRq`uor4}KuYd1aEED`R)soR}aK1`w1KluhZ{%Ud|u)eO0iTx?I
zv0-l1$q$hM3H=q$2|;4$z-V*&9*?aW%w}?7JS30{*<y+oeXS|BGwBm(Lc;DsCtSZ?
z!IP2hOM)K0byJZH<!e}khw4-(`=(mDJc$wU&vYu{bK^_bMwUQ#+Gw}IXoQdY!!mDJ
zBxsPhI9Tu<IazU`D(;+%(#eM1i6iM^hVRXiUoXFD(K&rmO#h)>dUGDG=3E~nrtHvt
z!7rZ!&%ctME~Bz<x*980{#}e3nuK>y9IiM>)Np(C>)Z^5uIZ|xMdUcIo1`PX{#Z?U
zD0!*Sey%cwL6wY&%~&Db^lXid_2G)m(mQSInngGnhUpp8!v5h9ho~R>@K~s&@Fw3O
z^vY7&@h-G39_^h$FUaBPrp5)^wL)xYk!e8iP3^&G$Pb*vz8}f<DNnI8NW8A2b+s?j
zx%hrRdy`rHcvKYc!gQxJz_H`(DvcU%5okqXb`!eKSSTH!b4)wN*SqOn>WLPYLcYZU
z!@E4pC6rCL^}2g at eztqIZSsQxH9!qOejA2IXE&#T;mRe~P~i3S!_IHKEq%h|pau(`
z#hWJ;9{l||3K(xHPoE(%Mq- at Oi*haZWwN`be%#tc3I6Pumc0YVK-uNu*I(PgGg{$D
zk>8dB6dZ7gehM$s;H*>;(Wajx>3?uACU7l7iH`ORk&F{_n0f~#D}2>ssy#^y{2`wp
zX!|N%BT20NwT-E1?)q0|U3sXyHsR&+nECTZr7zhvX-;pNQ$MfYDOu#b1&{N&WMnIk
zd at tQQRJnDOat&Kc+$@xs#-$)|T(~%=vOTD;z|a36r|<RcTxekn!bbGCR$6u`OSU7;
zH8^7ut>1e`Pt!Z_D4%(DgVhHe(HVNUI$5Qn{oZq+e6hB_dhPR6w(FTAbj_PlMub|;
zg}k^ASclvu%x>d|@Aj4LH%-=ZqJyxx)8;7ix{9<l)nP8IIB8k3qzg$_sHq)x*^Y1H
z;gz4O2QUQO7lItKyg_LyPF?cFupyrie`1%Vb>=w}2a<1a#2pS>%N;)ZdT}aaO*V++
ziZS+=Dd%;>P<kB=O$j{!Rh@^Yvni#S8F;uwR$hXquZm;cg1- at OFL13tBOYG88^j{V
zQZVk6>Z{GOy~n7bzdJZB>G%+H%(tJ1MJ$s`iQFIK7s8r6jGK*b+cyE(WvGnvKJa=n
z4XJVhs6-wuMkei!8XOO`9hC<2Hsx_>1-=j~8rxUk09to5`)TJIdpNSVm>V_0iE~8M
z36>;TAUElO)fiJEY)yfz3wnP~eBFS%S+gGYHh0v*8aZPO$<dbfl$j;zYnpCcPco|Y
z^V_EtMi}uCjT(Mjg#J#1K4i61Ei?I7)A4jx=8H=BXPRj0)I=Cftb at xLugdZcg9)<P
z)if|-Q6?rYy?h8t*oTl0HIh9fj8~Ywdr5uImyURD18wwk8FlTU%8uE!jp&tlF at euE
zory1_Yb{X=aYa-G1{*Fd{+<QC!p|S47!=k)%V3kDHXN9I>Z)ZMlZ;C20%l;Kkn{16
z-|KiMU<53b=i#0N%kAc$5X<_HNSagfjnY2)MJrR$iZz(@R5#ZfqHriv at VCRcdD3{<
zypz7S)GXVOsHf80wU(YY{JK6Ye(Gszqmj?Tl=3#lWSy@}N6~4P9rboY=<?kv`EwpF
zos%m;eU|*#dy_;G2DTe&nWFsueo94L(ML^bXZ_Ne at _35E_n{pI2|FlAo{C|7TC*_x
zI>#}eBVh*QAZN=*Ir$>oA=7eVLt{@Fu=-eh4 at G)ObU8JJt8jJRD&c?e?5y)dT)nkw
zGty0<Bn+?G?^?VoHU@|b545Jgsp>gPn+pp*cFM<&F$fC}BYoUZ98@!P-<BA155ERP
znVF%6J>h$G^GUgM+2*s5((1h<H~xOGm$80XERHyZ*JgAHVbQjCcbe70-(h#gL^V-E
zzr~N{R9GD;`3$Xpr&Rw!`0>o9I;ZM0HbNMgKX}_Lud^KS3_yP2L6LeV*=47Zn*3nL
zN)KSAr|W?xvLk)1a-SDfLl0ZFQ*CD$8&#*%^=pG+=rex1Di8|I65F&0MvTCaAX*52
zqilbeuMm+ at K6--HmtB9P)34N`0vF;_&h(C-p89<(cK$tGOC$WbRaj`$Ko>U|GWh3T
zuQ*?fk1V-Qs_RM9J`|@=tWa!+QuynPIXT`VsZZcFYV1F0(axC^-K$Iv(B>HPk!I5*
zmcSMo^Hg3OGg7+`S-)?qlP7C8TxQ^s*tF-j13zLVbBB5FCJb@#9JTcn6%C{frLd-T
z7NmLrcX4*qi;)r~U{*zr{&ZXU7_l55upvxTjS;M(W`jKqnJ3}b`*CIa at S_)PGhd_x
z-W)K00f^AIwsf>sIaa2)PHTJ9QE^cKYz{TK*RvAiusAdk<JT{9s9SKWnU7u)qoObu
zqguk5GU37)OdCbncQS{qCiOJFeJQe6LhKjtFl#c15S_q|Be><+`D}}H5sxQ9_JcG+
zW+BR750;oHm at 1SG{{@^^91N-!-3u-cNrk**t~)|L2lpwtTy`^^F at Bx*mo7iEq$HXW
zm<_qb!6ak6&5^}o$y}sw_v(b13BBBI^FBi=Ed=}}>76)o5aj5KsgusdZJBX_YSZ8d
zSma)+hTaK1cDrhQG)+9(Mocs1iv0k~fNo^i1KEIF!KYHoN`HXqSOH)6{+(}WYUDMN
zM&xefTm6Opy!1fHC7pRDng3SMoQ=rZC^gLHydTp8{^~?fR5;q4r8B4A4_<l1<WAja
z;OwR-B!oI&PZ{HEtz0)G;D%-{s->AHv4#UdorVZo at kX2`PJhGhd5)bj^)XOoIj*lr
z)6tFv+p1}G>yVV*7EjVdo|-0Ii}mZ3o>repA^lJv)<_|afJqBs at 8XzpLJR(T45P?8
zl)IMoEhM*_7#Z^Fjs(_Ki%%mb*Nrv-;0N84C%D&Ow<^Q#{@2~ypSOoL`JTbfRgZuE
zmqZiCKk1e~#L{m{hhEeMM6j6Kn9{48+X&h?n*VcO$iNZ!M?yqSL0(*fS{TG0ng6C`
z%pDw^gv|^b04xmjG6w%BGcqyID?1xH{U)qb9GrpwG#~<WG;%PvbFy^+{KZ|Vn;Scs
zIcl>pfCwwl=YMzm%i`a*|7HL0n!kMdk5Yem_#b3-|Bb`q{QneGK?idKD_NC)izYME
zzeSUg?Z1sC6BEd=5~$n$gp-N=cjx}s8#9Qo`>UOml at 0KJ`!M`z`C9`k2h0CO+usuZ
z{VxmK at 7Vln`)&DeKbiix&j9%A_ivwm%l`J36$A{B<iCZP>37p#RN;RCtv~Ff&~M6<
zmW_!6K+DVyvcv#V!pOkLp!=s)&cGT-|0n9SLbg`Mze8_jVCo0}g<aVRXsrfdWagk3
zHn5Wbnwy$A0oWNi=r#UPW at Tih7j!iG&A)Oou+slV^zSk)6C)$Nq?3V_xsjlasnu^f
z_V;)ZGq5(da-;ZTit<m5GKlVVGBTr=vvsgGu=-P_{tqh*4F5tB({C>IKb_+LV0iw=
zbNc7t{10&Y9}Lbv0sbGr>7N}40^GlM+rPT`zbpN%;V(J%e*l;L4<OhWe+S{e-hNyA
z3#7lLe((K;%5T}fH2$vnUE<*21X1Dt((||E-$(t?@$b<3J&^uW-2Zje`qN$ifEF7o
z2wETt{vXg{VEfO|`ae;{@xKo$mj3{%-x2!j<m8;K9YJ{lOuq-V(!Zbo?~1=fl<7tO
z4Uhkxm*5NnJR7~Vxv`@*^B>M1 at YnaBR06>7ajpaar62tH`E#Au{a5mW<G<<rSE|83
z7=KV7viv0~3v at CtHgGcd=ao-GR_0&CKM%hvC at sMf=manXnws12l3%uUkps+)dCApT
zWf^4cgn?$}67CK_Wp_ChBX>*C5^UuBe6T$H2A~`ZAg!x`9j(cqv;s!}X!!Dy2rJ2m
zk?`{&!1B0qxmw#<gKPs_t*vYvxm<b4{~W^wD*vvgCkOlyakAtk*N{~JIN91-S(<}V
zG3Yqy7-<=qX#ge;plgeZt%D_ik&cc0w at wFR6D}nYv43a;?eUVEIXT&J(bK!QxX`&U
z)7d(h(lc^$a?&#}(K9j8f+T1i-E5o;Txo3_NkInxcw(;c&%<mS>HauHXJl(lZ>~Yl
zNXJ0`PfLG;)!fzw at Y}M1p{=tMFS)a`xiJ?9s|kZ4Cle>F3DAI<mW9!Tf!2_d)sU8h
ziG!6BXvo0^WMTT-p54Fs`5z2|8bB7AL6HEJxIn2M#?D4S2VQbPBL`bU11ErpxucW0
zl at -tdz(&Uapa4Bd7~8ryQj+uW(Es-5-~9VKIR94l|I1}izy8-T0yX><Bmk(yB at D{9
z0p*f_KD^|h!OKd^$Uw`)p~A?@#mK?M$VSV+!o|P<3d7%`whk(wUgjlNQ2z7m!b)ds
zWd%?JIyn9gF)Q8gh=D|9K at UzQZvUOu|CJ!f%KpEH!P@#aj1BB$Ww}IbjhwAP_b*A2
ze?Y{*h{=SBfyso{*q9Xr5fc**S_5WQP>c+L|4;i?)Y>)-gx>@C4}K|*A3962Y|CK{
z6t=yM6<XL!VHn%#%tY-e3M>2d`_8GIM#)+XrBJXQf_*;SNvD(jed3apMWI-hmwx!#
zD_0i7h}*5v-Hs at Wu+kL`ZiB_+7;;%G*YwpyI_GVRFKuqI1R>H8$%Tiuwz^t%`|VQO
z-G#1c|15QWe|O<OoR`%)-)ifxzSc<BO|!P%_r{doxp#GQ^`p(($_Vd6*%Z5E)%D|o
zb at sx&4_p<LMvd9IxvqZq{#L(=#+XWL$3&+>CWelu_CqJb+kzq-4sRped2i4rC!>Nq
zg=-4es0fTwp0aBS*Qf}LQl7HweT56;rKdco6u<EQfY6*M9~b)~Y5-C~ql-^V0=b+C
z#bd5IeCq?>1}F>%fB}GdUh9TH)#4?%^k}Uyi~phIfU3efs<1fC6mEN}a2o{S<<|a$
zu^vhVd(!w|s`Y#Z=Bn^JG%tx`RHxGuYH2EC5Kn5}{UD1KXsRPiiKjl5aUo<3o_rvS
z7>{wJ=Ex+SD>$;43fmo7;`-%M2?_FhpeI$7f_ytNnK|<iEaB;~EMiVy=t&7G{?uN?
zSw?>*IFxbbjwRxpCr5f|LZ>r_eHG(JJ}{4Cy at WYqj=0L)xI{by_i%k=!i_2EB~I)i
wi=^vAh?LHW`Y~IR*C3{V)*r*``fr6KLSoG}HaB*cSD5#Fc6Rpp+n4$5A8HbI;{X5v
literal 0
HcmV?d00001
diff --git a/freebsd/contrib/ptpd/m4/version.m4 b/freebsd/contrib/ptpd/m4/version.m4
new file mode 100644
index 00000000..929a2833
--- /dev/null
+++ b/freebsd/contrib/ptpd/m4/version.m4
@@ -0,0 +1,4 @@
+m4_define([PTPD_URL],[http://ptpd.sourceforge.net])
+m4_define([RELEASE_DATE],[October, 2015])
+m4_define([VERSION_NUMBER],[2.3.2])
diff --git a/freebsd/contrib/ptpd/packagebuild/rpm-rh/README.RH b/freebsd/contrib/ptpd/packagebuild/rpm-rh/README.RH
index 00000000..ca29ae3c
--- /dev/null
+++ b/freebsd/contrib/ptpd/packagebuild/rpm-rh/README.RH
@@ -0,0 +1,44 @@
+====================== Building PTPd RPMs ===================
+- The rpmbuild.sh included in this directory should perform
+  a full RPM build for RHEL systems (and CentOS and probably FC).
+  This was used to build the RPMs starting with 2.3.0 RC2.
+  The script was successfully used to build under RHEL 5.5,
+  5.8, 6.2, 6.5, 7.0 but should build on any RHEL5+ system, CentOS,
+  Fedora and other distributions following the RH package
+  naming (-devel suffixes etc.), using systemd when available,
+  otherwise using system V init scripts. The spec file is easy
+  to modify to suit your distribution. The rpmbuild.sh script
+  by default builds both the full build and the slave-only build.
+  To build a slave-only build, the macro build_slaveonly should be set
+  to 1 (as in rpmbuild --define "build_slaveonly 1").
+  The ptpd package is the full PTP implementation,
+  whereas the ptpd-slaveonly is built with --enable-slave-only,
+  so is a version incapable of running as PTP master.
+- The rpmbuild.sh script calls "make dist" to generate
+  the tarball used for building the RPMs. If you are
+  building from svn, make sure you run autotools
+  (autoreconf) before trying to build RPMs. Follow the
+  README.repocheckout file in the main source directory
+  if in doubt.
+- rpmbuild.sh will create a temporary build directory,
+  build to it, move the rpm files to the current directory
+  and finally clean up by removing the build directory.
+  What is left is the RPMs in current directory and
+  nothing else.
+- The number of dependencies can be minimised mainly by
+  building ptpd without SNMP support (--disable-snmp).
+Wojciech Owczarek <wojciech%at%owczarek.co.uk>
+2013-2015, PTPd project, http://ptpd.sf.net
+Please report init script and / or spec file
+bugs and modifications to the ptpd-devel mailing list
+on SourceForge, or use the SourceForge ptpd forums.
diff --git a/freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.conf b/freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.conf
index 00000000..39297e64
--- /dev/null
+++ b/freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.conf
@@ -0,0 +1,62 @@
+; This is a recommended configuration for a PTPv2 slave
+; For a full list of options run ptpd2 -H or see the documentation and man pages
+; interface has to be specified
+ptpengine:interface=
+; PTP domain
+ptpengine:domain=0
+; available presets are slaveonly, masteronly and masterslave (full IEEE 1588 implementation)
+ptpengine:preset=slaveonly
+; multicast for both sync and delay requests - use hybrid for unicast delay requests
+ptpengine:ip_mode=multicast
+; when enabled, instead of sockets, libpcap is used to receive (sniff) and send (inject) packets.
+; on low latency hardware such as 10GE NICs this can provide results close to hardware-assisted PTP
+ptpengine:use_libpcap=n
+; go into panic mode for 10 minutes instead of resetting the clock
+ptpengine:panic_mode=y
+ptpengine:panic_mode_duration=10
+; uncomment this to enable outlier filters
+ptpengine:sync_outlier_filter_enable=y
+ptpengine:delay_outlier_filter_enable=y
+; store observed drift in a file
+clock:drift_handling=file
+; update online statistics every 5 seconds
+global:statistics_update_interval=30
+; wait 5 statistics intervals for one-way delay to stabilise
+ptpengine:calibration_delay=5
+; log file, event log only. if timing statistics are needed, see statistics_file
+global:log_file=/var/log/ptpd2.log
+; log file up to 5M
+global:log_file_max_size=5000
+; rotate logs up to 5 files
+global:log_file_max_files=5
+; status file providing an overview of ptpd's operation and statistics
+global:log_status=y
+; required if ip_mode is set to hybrid
+;ptpengine:log_delayreq_interval=0
+; uncomment this to log a timing log like in previous ptpd versions
+;global:statistics_file=/var/log/ptpd2.stats
+; on multi-core systems it is recommended to bind ptpd to a single core
+;global:cpuaffinity_cpucore=0
+; use DSCP 46 for expedited forwarding over ipv4 networks
+ptpengine:ip_dscp=46
+; always keep a new line in the end
diff --git a/freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.init b/freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.init
index 00000000..6442d71d
--- /dev/null
+++ b/freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.init
@@ -0,0 +1,205 @@
+#!/bin/bash
+# ptpd:         Precision Time protocol server (IEEE 1588)
+# chkconfig: 2345 59 73
+# description:      The PTP daemon (PTPd) implements the Precision Time
+#           protocol (PTP) as defined by the IEEE 1588 standard.
+#           PTP was developed to provide very precise time
+#           coordination of LAN connected computers.
+DAEMON=/usr/sbin/ptpd2
+prog=PTPd
+RETVAL=0
+PATH=/sbin:/usr/local/bin:$PATH
+DAEMON_DESC="IEEE 1588 Precision Time Protocol (v2) daemon"
+. /etc/init.d/functions
+if test -e /etc/sysconfig/__SERVICENAME__ ; then
+    . /etc/sysconfig/__SERVICENAME__
+    PTPD_OPTIONS="--global:lock_file=$PTPD_PID_FILE --global:status_file=$PTPD_STATUS_FILE -c $PTPD_CONFIG_FILE $PTPD_EXTRA_OPTIONS"
+fi
+start() {
+	status -p $PTPD_PID_FILE $DAEMON > /dev/null 2>&1
+	RETVAL=$?
+	if [ "$RETVAL" -eq "0" ]
+	then
+		echo "$prog already running (PID `cat $PTPD_PID_FILE`)."
+		exit 0
+	fi
+	echo -n "Starting $DAEMON_DESC..."
+		$DAEMON $PTPD_OPTIONS
+		sleep 1
+		RETVAL=$?
+	then
+		echo_success
+	else
+		echo_failure
+	fi
+	echo
+checkstatus() {
+	RETVAL=$?
+	then
+	        if test -e $PTPD_PID_FILE ; then
+			echo "$prog is running (PID `cat $PTPD_PID_FILE`)."
+		fi
+	else
+			echo "$prog is not running."
+			RETVAL=3
+	fi
+	exit $RETVAL
+showinfo() {
+	RETVAL=$?
+	then
+			taskset -pc `cat $PTPD_PID_FILE`
+			if test -e $PTPD_STATUS_FILE; then
+				cat $PTPD_STATUS_FILE
+			fi
+		fi
+	else
+			RETVAL=3
+	fi
+	exit $RETVAL
+checkconfig() {
+	$DAEMON -k $PTPD_OPTIONS
+	RETVAL=$?
+stop() {
+	RETVAL=$?
+   if [ "$RETVAL" -ne "0" ]
+   then
+   	echo "$prog not running."
+	else
+		killproc -p $PTPD_PID_FILE $DAEMON
+		RETVAL=$?
+		then
+			echo "Stopping $DAEMON_DESC...`echo_success`"
+		else
+			echo "Stopping $DAEMON_DESC...`echo_failure`"
+		fi
+	fi
+reload() {
+	    checkconfig
+	    if [ "$RETVAL" -ne "0" ]; then
+		echo "Reloading $prog: `echo_failure`"
+		exit $RETVAL
+	    fi
+		echo -n $"Reloading $prog: "
+	    killproc -p $PTPD_PID_FILE $DAEMON -HUP
+	    RETVAL=$?
+	    echo
+help() {
+        echo $"Usage: $0 {start|stop|restart|reload|checkconfig|condrestart|status|info}"
+        exit 1
+if [ -z "$1" ]
+then
+    help
+fi
+case "$1" in
+    start)
+    start
+    RETVAL=$?
+    status)
+    checkstatus
+    RETVAL=$?
+    info)
+    showinfo
+    RETVAL=$?
+    restart)
+    stop
+	 sleep 1
+    start
+    RETVAL=$?
+    reload)
+    reload
+    RETVAL=$?
+    stop)
+    stop
+	 exit 0
+    checkconfig)
+    checkconfig
+    RETVAL=$?
+    condrestart)
+        if [ -f PID_FILE ]; then
+            stop
+            start
+            RETVAL=$?
+        fi
+	echo $"Usage: $0 {start|stop|restart|reload|checkconfig|condrestart|status}"
+	RETVAL=3
+esac
+exit $RETVAL
diff --git a/freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.service b/freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.service
index 00000000..9bac32bc
--- /dev/null
+++ b/freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.service
@@ -0,0 +1,17 @@
+[Unit]
+Description=Precision Time Protocol Daemon
+After=syslog.target ntpdate.service sntp.service ntp.service chronyd.service network.target
+[Service]
+Type=forking
+EnvironmentFile=-/etc/sysconfig/__SERVICENAME__
+ExecStart=/usr/sbin/ptpd2 \
+    --global:lock_file=${PTPD_PID_FILE} \
+    --global:status_file=${PTPD_STATUS_FILE} \
+    -c ${PTPD_CONFIG_FILE} \
+    ${PTPD_EXTRA_OPTIONS}
+ExecReload=/bin/kill -HUP $MAINPID
+[Install]
+WantedBy=multi-user.target
diff --git a/freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.spec b/freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.spec
index 00000000..635c43c0
--- /dev/null
+++ b/freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.spec
@@ -0,0 +1,241 @@
+# (c) 2014-2015:  Wojciech Owczarek, PTPd project
+%if %{?build_slaveonly:1}%{!?build_slaveonly:0}
+%define slaveonly_build %{build_slaveonly}
+%else
+%define slaveonly_build 0
+%endif
+%define _use_internal_dependency_generator 0
+# RHEL5.5 and older don't have the /etc/rpm/macros.dist macros
+%if %{?dist:1}%{!?dist:0}
+%define distver %{dist}
+%else
+%define distver %(/usr/lib/rpm/redhat/dist.sh --dist)
+%endif
+%define servicename ptpd%{?servicesuffix}
+%if %{slaveonly_build} == 1
+Name: ptpd-slaveonly
+Summary: Synchronises system time using the Precision Time Protocol (PTP) implementing the IEEE 1588-2008 (PTP v 2) standard. Slave-only version.
+%else
+Name: ptpd
+Summary: Synchronises system time using the Precision Time Protocol (PTP) implementing the IEEE 1588-2008 (PTP v 2) standard. Full version with master and slave support.
+%endif
+Version: 2.3.2
+Release: 1%{distver}%{?gittag}
+License: distributable
+Group: System Environment/Daemons
+Vendor: PTPd project team
+Source0: ptpd-2.3.2.tar.gz
+Source2: ptpd.sysconfig
+Source3: ptpd.conf
+URL: http://ptpd.sf.net
+Conflicts: ptpd
+%else
+Conflicts: ptpd-slaveonly
+%endif
+Requires(pre): /sbin/chkconfig
+Requires(pre): /bin/awk sed grep
+BuildRequires: libpcap-devel net-snmp-devel openssl-devel zlib-devel redhat-rpm-config
+Requires: libpcap net-snmp openssl zlib
+# systemd
+%if %{?_unitdir:1}%{!?_unitdir:0}
+Source1: ptpd.service
+Requires: systemd
+BuildRequires: systemd
+%else
+Source1: ptpd.init
+%endif
+BuildRoot: %{_tmppath}/%{name}-root
+%description
+The PTP daemon (PTPd) implements the Precision Time
+protocol (PTP) as defined by the IEEE 1588 standard.
+PTP was developed to provide very precise time
+coordination of LAN connected computers.
+Install the ptpd package if you need tools for keeping your system's
+time synchronised via the PTP protocol or serving PTP time.
+%prep
+%setup -n ptpd-2.3.2
+%build
+./configure --enable-slave-only --with-max-unicast-destinations=512
+%else
+./configure --with-max-unicast-destinations=512
+%endif
+make
+find . -type f | xargs chmod 644
+find . -type d | xargs chmod 755
+%install
+rm -rf $RPM_BUILD_ROOT
+mkdir -p $RPM_BUILD_ROOT%{_mandir}/man{5,8}
+mkdir -p $RPM_BUILD_ROOT%{_sbindir}
+mkdir -p $RPM_BUILD_ROOT%{_datadir}/ptpd
+mkdir -p $RPM_BUILD_ROOT%{_datadir}/snmp/mibs
+install -m 755 src/ptpd2 $RPM_BUILD_ROOT%{_sbindir}
+install -m 644 src/ptpd2.8 $RPM_BUILD_ROOT%{_mandir}/man8/ptpd2.8
+install -m 644 src/ptpd2.conf.5 $RPM_BUILD_ROOT%{_mandir}/man5/ptpd2.conf.5
+install -m 644 doc/PTPBASE-MIB.txt $RPM_BUILD_ROOT%{_datadir}/snmp/mibs/PTPBASE-MIB.txt
+install -m 644 src/leap-seconds.list $RPM_BUILD_ROOT%{_datadir}/ptpd/leap-seconds.list
+install -m 644 src/ptpd2.conf.minimal $RPM_BUILD_ROOT%{_datadir}/ptpd/ptpd2.conf.minimal
+install -m 644 src/ptpd2.conf.default-full $RPM_BUILD_ROOT%{_datadir}/ptpd/ptpd2.conf.default-full
+install -m 644 src/templates.conf $RPM_BUILD_ROOT%{_datadir}/ptpd/templates.conf
+{ cd $RPM_BUILD_ROOT
+  mkdir -p .%{_unitdir}
+  install -m644 $RPM_SOURCE_DIR/ptpd.service .%{_unitdir}/%{servicename}.service
+  sed -i 's#/etc/sysconfig/__SERVICENAME__#/etc/sysconfig/%{servicename}#' .%{_unitdir}/%{servicename}.service
+%else
+  mkdir -p .%{_initrddir}
+  install -m755 $RPM_SOURCE_DIR/ptpd.init .%{_initrddir}/%{servicename}
+  sed -i 's#/etc/sysconfig/__SERVICENAME__#/etc/sysconfig/%{servicename}#' .%{_initrddir}/%{servicename}
+%endif
+  mkdir -p .%{_sysconfdir}/sysconfig
+  install -m644 %{SOURCE2} .%{_sysconfdir}/sysconfig/%{servicename}
+  install -m644 %{SOURCE3} .%{_sysconfdir}/ptpd2.conf
+%clean
+%pre
+%post
+/usr/bin/systemctl enable %{servicename} >/dev/null 2>&1
+%else
+/sbin/chkconfig --add %{servicename}
+%endif
+echo
+echo -e "**** PTPd - Running post-install checks...\n"
+grep -q : /etc/ethers >/dev/null 2>&1 || echo -e "Consider populating /etc/ethers with the MAC to host mappings of the GMs:\nexample:\t aa:bb:cc:dd:ee:ff gm-1.my.domain.net\n"
+for candidate in ntp chrony; do
+echo -e "\n*** Checking ${candidate}d status...\n"
+rpm -q $candidate >/dev/null 2>&1
+if [ $? -ne 0 ]; then
+    echo "** ${candidate}d not installed."
+else
+    echo -e "** ${candidate}d is installed.\n"
+/usr/bin/systemctl status ${candidate}d | grep Loaded | grep enabled >/dev/null 2>&1
+%else
+chkconfig --level `runlevel | awk '{print $2;}'` ${candidate}d >/dev/null 2>&1
+%endif
+if [ $? == 0 ]; then
+    echo "** ${candidate}d enabled in current runlevel - consider disabling unless:"
+    echo "- you're running a PTP master with NTP reference"
+    if [ "$candidate" == "ntp" ]; then
+	echo -e "- you configure NTP integration in the PTPd configuration file\n";
+    fi
+fi
+systemctl status ${candidate}d > /dev/null 2>&1
+%else
+service ${candidate}d status > /dev/null 2>&1
+%endif
+ret=$?
+if [ $ret == 3 ]; then
+    echo -e "** ${candidate}d not running - good.\n";
+elif [ $ret == 0 ]; then
+    echo "** ${candidate}d running - consider stopping before running ptpd unless:"
+    fi
+fi
+fi
+echo
+done
+%preun
+if [ $1 = 0 ]; then
+systemctl stop %{servicename} > /dev/null 2>&1
+systemctl disable %{servicename}  >/dev/null 2>&1
+%else
+    service %{servicename} stop > /dev/null 2>&1
+    /sbin/chkconfig --del %{servicename}
+%endif
+fi
+%postun
+if [ "$1" -ge "1" ]; then
+  service %{servicename} condrestart > /dev/null 2>&1
+fi
+%files
+%defattr(-,root,root)
+%{_sbindir}/ptpd2
+%{_unitdir}/%{servicename}.service
+%else
+%config			%{_initrddir}/%{servicename}
+%endif
+%config(noreplace)	%{_sysconfdir}/sysconfig/%{servicename}
+%config(noreplace)	%{_sysconfdir}/ptpd2.conf
+%config(noreplace)	%{_datadir}/ptpd/templates.conf
+%{_mandir}/man8/*
+%{_mandir}/man5/*
+%{_datadir}/snmp/mibs/*
+%{_datadir}/ptpd/*
+%changelog
+* Thu Oct 23 2015 Wojciech Owczarek <wojciech at owczarek.co.uk> 2.3.2-1
+- version 2.3.2
+* Wed Jul 1 2015 Wojciech Owczarek <wojciech at owczarek.co.uk> 2.3.1-2
+- spec updated for OSes with systemd
+- chrony detection added to postinstall checks
+* Wed Jun 24 2015 Wojciech Owczarek <wojciech at owczarek.co.uk> 2.3.1-1
+* Mon Jun 15 2015 Wojciech Owczarek <wojciech at owczarek.co.uk> 2.3.1-0.99.rc5
+* Mon Jun 01 2015 Wojciech Owczarek <wojciech at owczarek.co.uk> 2.3.1-0.99.rc4
+- rc5 release, adds leap seconds file and config files
+* Wed Apr 15 2015 Wojciech Owczarek <wojciech at owczarek.co.uk> 2.3.1-0.99.rc4.pre2
+* Mon Apr 13 2015 Wojciech Owczarek <wojciech at owczarek.co.uk> 2.3.1-0.99.rc4.pre1
+* Tue Oct 07 2014 Wojciech Owczarek <wojciech at owczarek.co.uk> 2.3.1-0.99.rc3
+* Fri Jul 25 2014 Wojciech Owczarek <wojciech at owczarek.co.uk> 2.3.1-0.99.rc2
+* Thu Jun 26 2014 Wojciech Owczarek <wojciech at owczarek.co.uk> 2.3.1-0.99.rc1
+* Thu Nov 21 2013 Wojciech Owczarek <wojciech at owczarek.co.uk> 2.3.0-1
+- Added the PTPBASE SNMP MIB
+* Wed Nov 13 2013 Wojciech Owczarek <wojciech at owczarek.co.uk> 2.3.0-0.99-rc2
+- Initial public spec file and scripts for RHEL
diff --git a/freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.sysconfig b/freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.sysconfig
index 00000000..66de96ce
--- /dev/null
+++ b/freebsd/contrib/ptpd/packagebuild/rpm-rh/ptpd.sysconfig
@@ -0,0 +1,10 @@
+# Config file location
+PTPD_CONFIG_FILE="/etc/ptpd2.conf"
+# Lock / PID file location
+PTPD_PID_FILE="/var/run/ptpd2.lock"
+# Status file location
+PTPD_STATUS_FILE="/var/run/ptpd2.status"
+# Any extra command-line options
+PTPD_EXTRA_OPTIONS=""
diff --git a/freebsd/contrib/ptpd/packagebuild/rpm-rh/rpmbuild.sh b/freebsd/contrib/ptpd/packagebuild/rpm-rh/rpmbuild.sh
new file mode 100755
index 00000000..f8646122
--- /dev/null
+++ b/freebsd/contrib/ptpd/packagebuild/rpm-rh/rpmbuild.sh
@@ -0,0 +1,101 @@
+#!/bin/sh
+if [ ! -z "$DEBUG" ]; then
+    set -x
+fi
+# ptpd RPM building script
+# (c) 2013-2015: Wojciech Owczarek, PTPd project
+while [[ $# -gt 0 ]]; do
+    opt="$1";
+    shift;              #expose next argument
+    case "$opt" in
+        "--tag" )
+            # Add git-based tag
+            ADD_TAG=1;;
+        "--service2" )
+            # Create ptpd2 service
+            SERVICESUFFIX='2';;
+        *) cat >&2 <<EOF
+Invalid option: $opt (remainder $@)
+Supported options:
+    --tag: add a git-based tag to the rpm release
+    --service2: generate the service as ptpd2 (instead of default ptpd)
+EOF
+           exit 1;;
+    esac
+done
+SPEC=ptpd.spec
+PWD=`pwd`
+if [ `basename $PWD` != 'rpm-rh' ]; then
+    # deleting rpm is dangerous
+    echo "Can only be run from packagebuild/rpm-rh subdir in repo"
+    exit 1
+fi
+rm *.rpm
+for dep in rpm-build `grep BuildRequires ptpd.spec | sed "s/^.*: //" |grep -v systemd | tr '\n' ' '`; do
+    rpm -q $dep --quiet || { echo "Error: $dep not installed"; exit 1; }
+done
+# build both versions: normal and slave-only
+for slaveonly in 0 1; do
+    cd $PWD
+    BUILDDIR=`mktemp -d /tmp/tmpbuild.XXXXXXXXX`
+    rm -rf $BUILDDIR
+    for dir in BUILD BUILDROOT RPMS SOURCES SPECS SRPMS; do
+        mkdir -p $BUILDDIR/$dir;
+    done
+    TARBALL=`cat $SPEC | grep ^Source0 | awk '{ print $2; }'`
+    # hack: dist hook now removes rpms from this dir before dist packaging:
+    # this is how we preserve them...
+    mv *.rpm ../..
+    ( cd ../..; autoreconf -vi; ./configure; make dist; )
+    # and in they go again...
+    mv ../../*.rpm .
+    mv ../../$TARBALL .
+    for sourcefile in `grep ^Source $SPEC | awk '{print $2;}'`; do
+        cp -f $sourcefile $BUILDDIR/SOURCES
+    done
+    cp -f $SPEC $BUILDDIR/SPECS
+    ARCHIVE=`cat $SPEC | egrep "Name|Version|Release" | awk 'BEGIN {ORS="-";} NR<3 { print $2;} NR>=3 {ORS=""; print $2}'`
+    RPMFILE=$BUILDDIR/RPMS/`uname -m`/$ARCHIVE.`uname -m`.rpm
+    SRPMFILE=$BUILDDIR/SRPMS/$ARCHIVE.src.rpm
+    if [ -z "$ADD_TAG" ]; then
+        TAG_ARG='__gittag notag' # cannot be empty
+    else
+        tag=`git log --format=.%ct.%h -1` # based on last commit, timestamp for increasing versions
+        TAG_ARG="gittag $tag"
+    fi
+    if [ -z "$SERVICESUFFIX" ]; then
+        SERVICESUFFIX_ARG='__servicesuffix nosuffix' # cannot be empty
+    else
+        SERVICESUFFIX_ARG="servicesuffix $SERVICESUFFIX"
+    fi
+    rpmbuild --define "$TAG_ARG" --define "$SERVICESUFFIX_ARG" --define "build_slaveonly $slaveonly" --define "_topdir $BUILDDIR" -ba $BUILDDIR/SPECS/$SPEC && {
+        find $BUILDDIR -name "*.rpm" -exec mv {} $PWD \;
+    rm -rf $BUILDDIR
+    rm $TARBALL
+    echo "Moved rpms to $PWD"
+done
diff --git a/freebsd/contrib/ptpd/src/Doxyfile b/freebsd/contrib/ptpd/src/Doxyfile
index 00000000..94c85155
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/Doxyfile
@@ -0,0 +1,1511 @@
+# Doxyfile 1.5.8
+# This file describes the settings to be used by the documentation system
+# doxygen (www.doxygen.org) for a project
+# All text after a hash (#) is considered a comment and will be ignored
+# The format is:
+#       TAG = value [value, ...]
+# For lists items can also be appended using:
+#       TAG += value [value, ...]
+# Values that contain spaces should be placed between quotes (" ")
+# Project related configuration options
+# This tag specifies the encoding used for all characters in the config file
+# that follow. The default is UTF-8 which is also the encoding used for all
+# text before the first occurrence of this tag. Doxygen uses libiconv (or the
+# iconv built into libc) for the transcoding. See
+# http://www.gnu.org/software/libiconv for the list of possible encodings.
+DOXYFILE_ENCODING      = UTF-8
+# The PROJECT_NAME tag is a single word (or a sequence of words surrounded
+# by quotes) that should identify the project.
+PROJECT_NAME           = PTPDv2
+# The PROJECT_NUMBER tag can be used to enter a project or revision number.
+# This could be handy for archiving the generated documentation or
+# if some version control system is used.
+PROJECT_NUMBER         =
+# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute)
+# base path where the generated documentation will be put.
+# If a relative path is entered, it will be relative to the location
+# where doxygen was started. If left blank the current directory will be used.
+OUTPUT_DIRECTORY       = Doxygen
+# If the CREATE_SUBDIRS tag is set to YES, then doxygen will create
+# 4096 sub-directories (in 2 levels) under the output directory of each output
+# format and will distribute the generated files over these directories.
+# Enabling this option can be useful when feeding doxygen a huge amount of
+# source files, where putting all generated files in the same directory would
+# otherwise cause performance problems for the file system.
+CREATE_SUBDIRS         = NO
+# The OUTPUT_LANGUAGE tag is used to specify the language in which all
+# documentation generated by doxygen is written. Doxygen will use this
+# information to generate all constant output in the proper language.
+# The default language is English, other supported languages are:
+# Afrikaans, Arabic, Brazilian, Catalan, Chinese, Chinese-Traditional,
+# Croatian, Czech, Danish, Dutch, Farsi, Finnish, French, German, Greek,
+# Hungarian, Italian, Japanese, Japanese-en (Japanese with English messages),
+# Korean, Korean-en, Lithuanian, Norwegian, Macedonian, Persian, Polish,
+# Portuguese, Romanian, Russian, Serbian, Serbian-Cyrilic, Slovak, Slovene,
+# Spanish, Swedish, and Ukrainian.
+OUTPUT_LANGUAGE        = English
+# If the BRIEF_MEMBER_DESC tag is set to YES (the default) Doxygen will
+# include brief member descriptions after the members that are listed in
+# the file and class documentation (similar to JavaDoc).
+# Set to NO to disable this.
+BRIEF_MEMBER_DESC      = YES
+# If the REPEAT_BRIEF tag is set to YES (the default) Doxygen will prepend
+# the brief description of a member or function before the detailed description.
+# Note: if both HIDE_UNDOC_MEMBERS and BRIEF_MEMBER_DESC are set to NO, the
+# brief descriptions will be completely suppressed.
+REPEAT_BRIEF           = YES
+# This tag implements a quasi-intelligent brief description abbreviator
+# that is used to form the text in various listings. Each string
+# in this list, if found as the leading text of the brief description, will be
+# stripped from the text and the result after processing the whole list, is
+# used as the annotated text. Otherwise, the brief description is used as-is.
+# If left blank, the following values are used ("$name" is automatically
+# replaced with the name of the entity): "The $name class" "The $name widget"
+# "The $name file" "is" "provides" "specifies" "contains"
+# "represents" "a" "an" "the"
+ABBREVIATE_BRIEF       =
+# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
+# Doxygen will generate a detailed section even if there is only a brief
+# description.
+ALWAYS_DETAILED_SEC    = NO
+# If the INLINE_INHERITED_MEMB tag is set to YES, doxygen will show all
+# inherited members of a class in the documentation of that class as if those
+# members were ordinary class members. Constructors, destructors and assignment
+# operators of the base classes will not be shown.
+INLINE_INHERITED_MEMB  = NO
+# If the FULL_PATH_NAMES tag is set to YES then Doxygen will prepend the full
+# path before files name in the file list and in the header files. If set
+# to NO the shortest path that makes the file name unique will be used.
+FULL_PATH_NAMES        = YES
+# If the FULL_PATH_NAMES tag is set to YES then the STRIP_FROM_PATH tag
+# can be used to strip a user-defined part of the path. Stripping is
+# only done if one of the specified strings matches the left-hand part of
+# the path. The tag can be used to show relative paths in the file list.
+# If left blank the directory from which doxygen is run is used as the
+# path to strip.
+STRIP_FROM_PATH        =
+# The STRIP_FROM_INC_PATH tag can be used to strip a user-defined part of
+# the path mentioned in the documentation of a class, which tells
+# the reader which header file to include in order to use a class.
+# If left blank only the name of the header file containing the class
+# definition is used. Otherwise one should specify the include paths that
+# are normally passed to the compiler using the -I flag.
+STRIP_FROM_INC_PATH    =
+# If the SHORT_NAMES tag is set to YES, doxygen will generate much shorter
+# (but less readable) file names. This can be useful is your file systems
+# doesn't support long names like on DOS, Mac, or CD-ROM.
+SHORT_NAMES            = NO
+# If the JAVADOC_AUTOBRIEF tag is set to YES then Doxygen
+# will interpret the first line (until the first dot) of a JavaDoc-style
+# comment as the brief description. If set to NO, the JavaDoc
+# comments will behave just like regular Qt-style comments
+# (thus requiring an explicit @brief command for a brief description.)
+JAVADOC_AUTOBRIEF      = YES
+# If the QT_AUTOBRIEF tag is set to YES then Doxygen will
+# interpret the first line (until the first dot) of a Qt-style
+# comment as the brief description. If set to NO, the comments
+# will behave just like regular Qt-style comments (thus requiring
+# an explicit \brief command for a brief description.)
+QT_AUTOBRIEF           = NO
+# The MULTILINE_CPP_IS_BRIEF tag can be set to YES to make Doxygen
+# treat a multi-line C++ special comment block (i.e. a block of //! or ///
+# comments) as a brief description. This used to be the default behaviour.
+# The new default is to treat a multi-line C++ comment block as a detailed
+# description. Set this tag to YES if you prefer the old behaviour instead.
+MULTILINE_CPP_IS_BRIEF = NO
+# If the INHERIT_DOCS tag is set to YES (the default) then an undocumented
+# member inherits the documentation from any documented member that it
+# re-implements.
+INHERIT_DOCS           = YES
+# If the SEPARATE_MEMBER_PAGES tag is set to YES, then doxygen will produce
+# a new page for each member. If set to NO, the documentation of a member will
+# be part of the file/class/namespace that contains it.
+SEPARATE_MEMBER_PAGES  = NO
+# The TAB_SIZE tag can be used to set the number of spaces in a tab.
+# Doxygen uses this value to replace tabs by spaces in code fragments.
+TAB_SIZE               = 8
+# This tag can be used to specify a number of aliases that acts
+# as commands in the documentation. An alias has the form "name=value".
+# For example adding "sideeffect=\par Side Effects:\n" will allow you to
+# put the command \sideeffect (or @sideeffect) in the documentation, which
+# will result in a user-defined paragraph with heading "Side Effects:".
+# You can put \n's in the value part of an alias to insert newlines.
+ALIASES                =
+# Set the OPTIMIZE_OUTPUT_FOR_C tag to YES if your project consists of C
+# sources only. Doxygen will then generate output that is more tailored for C.
+# For instance, some of the names that are used will be different. The list
+# of all members will be omitted, etc.
+OPTIMIZE_OUTPUT_FOR_C  = YES
+# Set the OPTIMIZE_OUTPUT_JAVA tag to YES if your project consists of Java
+# Java. For instance, namespaces will be presented as packages, qualified
+# scopes will look different, etc.
+OPTIMIZE_OUTPUT_JAVA   = NO
+# Set the OPTIMIZE_FOR_FORTRAN tag to YES if your project consists of Fortran
+# Fortran.
+OPTIMIZE_FOR_FORTRAN   = NO
+# Set the OPTIMIZE_OUTPUT_VHDL tag to YES if your project consists of VHDL
+# sources. Doxygen will then generate output that is tailored for
+# VHDL.
+OPTIMIZE_OUTPUT_VHDL   = NO
+# Doxygen selects the parser to use depending on the extension of the files it parses.
+# With this tag you can assign which parser to use for a given extension.
+# Doxygen has a built-in mapping, but you can override or extend it using this tag.
+# The format is ext=language, where ext is a file extension, and language is one of
+# the parsers supported by doxygen: IDL, Java, Javascript, C#, C, C++, D, PHP,
+# Objective-C, Python, Fortran, VHDL, C, C++. For instance to make doxygen treat
+# .inc files as Fortran files (default is PHP), and .f files as C (default is Fortran),
+# use: inc=Fortran f=C
+EXTENSION_MAPPING      =
+# If you use STL classes (i.e. std::string, std::vector, etc.) but do not want
+# to include (a tag file for) the STL sources as input, then you should
+# set this tag to YES in order to let doxygen match functions declarations and
+# definitions whose arguments contain STL classes (e.g. func(std::string); v.s.
+# func(std::string) {}). This also make the inheritance and collaboration
+# diagrams that involve STL classes more complete and accurate.
+BUILTIN_STL_SUPPORT    = NO
+# If you use Microsoft's C++/CLI language, you should set this option to YES to
+# enable parsing support.
+CPP_CLI_SUPPORT        = NO
+# Set the SIP_SUPPORT tag to YES if your project consists of sip sources only.
+# Doxygen will parse them like normal C++ but will assume all classes use public
+# instead of private inheritance when no explicit protection keyword is present.
+SIP_SUPPORT            = NO
+# For Microsoft's IDL there are propget and propput attributes to indicate getter
+# and setter methods for a property. Setting this option to YES (the default)
+# will make doxygen to replace the get and set methods by a property in the
+# documentation. This will only work if the methods are indeed getting or
+# setting a simple type. If this is not the case, or you want to show the
+# methods anyway, you should set this option to NO.
+IDL_PROPERTY_SUPPORT   = YES
+# If member grouping is used in the documentation and the DISTRIBUTE_GROUP_DOC
+# tag is set to YES, then doxygen will reuse the documentation of the first
+# member in the group (if any) for the other members of the group. By default
+# all members of a group must be documented explicitly.
+DISTRIBUTE_GROUP_DOC   = NO
+# Set the SUBGROUPING tag to YES (the default) to allow class member groups of
+# the same type (for instance a group of public functions) to be put as a
+# subgroup of that type (e.g. under the Public Functions section). Set it to
+# NO to prevent subgrouping. Alternatively, this can be done per class using
+# the \nosubgrouping command.
+SUBGROUPING            = YES
+# When TYPEDEF_HIDES_STRUCT is enabled, a typedef of a struct, union, or enum
+# is documented as struct, union, or enum with the name of the typedef. So
+# typedef struct TypeS {} TypeT, will appear in the documentation as a struct
+# with name TypeT. When disabled the typedef will appear as a member of a file,
+# namespace, or class. And the struct will be named TypeS. This can typically
+# be useful for C code in case the coding convention dictates that all compound
+# types are typedef'ed and only the typedef is referenced, never the tag name.
+TYPEDEF_HIDES_STRUCT   = NO
+# The SYMBOL_CACHE_SIZE determines the size of the internal cache use to
+# determine which symbols to keep in memory and which to flush to disk.
+# When the cache is full, less often used symbols will be written to disk.
+# For small to medium size projects (<1000 input files) the default value is
+# probably good enough. For larger projects a too small cache size can cause
+# doxygen to be busy swapping symbols to and from disk most of the time
+# causing a significant performance penality.
+# If the system has enough physical memory increasing the cache will improve the
+# performance by keeping more symbols in memory. Note that the value works on
+# a logarithmic scale so increasing the size by one will rougly double the
+# memory usage. The cache size is given by this formula:
+# 2^(16+SYMBOL_CACHE_SIZE). The valid range is 0..9, the default is 0,
+# corresponding to a cache size of 2^16 = 65536 symbols
+SYMBOL_CACHE_SIZE      = 0
+# Build related configuration options
+# If the EXTRACT_ALL tag is set to YES doxygen will assume all entities in
+# documentation are documented, even if no documentation was available.
+# Private class members and static file members will be hidden unless
+# the EXTRACT_PRIVATE and EXTRACT_STATIC tags are set to YES
+EXTRACT_ALL            = YES
+# If the EXTRACT_PRIVATE tag is set to YES all private members of a class
+# will be included in the documentation.
+EXTRACT_PRIVATE        = YES
+# If the EXTRACT_STATIC tag is set to YES all static members of a file
+EXTRACT_STATIC         = YES
+# If the EXTRACT_LOCAL_CLASSES tag is set to YES classes (and structs)
+# defined locally in source files will be included in the documentation.
+# If set to NO only classes defined in header files are included.
+EXTRACT_LOCAL_CLASSES  = YES
+# This flag is only useful for Objective-C code. When set to YES local
+# methods, which are defined in the implementation section but not in
+# the interface are included in the documentation.
+# If set to NO (the default) only methods in the interface are included.
+EXTRACT_LOCAL_METHODS  = YES
+# If this flag is set to YES, the members of anonymous namespaces will be
+# extracted and appear in the documentation as a namespace called
+# 'anonymous_namespace{file}', where file will be replaced with the base
+# name of the file that contains the anonymous namespace. By default
+# anonymous namespace are hidden.
+EXTRACT_ANON_NSPACES   = NO
+# If the HIDE_UNDOC_MEMBERS tag is set to YES, Doxygen will hide all
+# undocumented members of documented classes, files or namespaces.
+# If set to NO (the default) these members will be included in the
+# various overviews, but no documentation section is generated.
+# This option has no effect if EXTRACT_ALL is enabled.
+HIDE_UNDOC_MEMBERS     = NO
+# If the HIDE_UNDOC_CLASSES tag is set to YES, Doxygen will hide all
+# undocumented classes that are normally visible in the class hierarchy.
+# If set to NO (the default) these classes will be included in the various
+# overviews. This option has no effect if EXTRACT_ALL is enabled.
+HIDE_UNDOC_CLASSES     = NO
+# If the HIDE_FRIEND_COMPOUNDS tag is set to YES, Doxygen will hide all
+# friend (class|struct|union) declarations.
+# If set to NO (the default) these declarations will be included in the
+# documentation.
+HIDE_FRIEND_COMPOUNDS  = NO
+# If the HIDE_IN_BODY_DOCS tag is set to YES, Doxygen will hide any
+# documentation blocks found inside the body of a function.
+# If set to NO (the default) these blocks will be appended to the
+# function's detailed documentation block.
+HIDE_IN_BODY_DOCS      = NO
+# The INTERNAL_DOCS tag determines if documentation
+# that is typed after a \internal command is included. If the tag is set
+# to NO (the default) then the documentation will be excluded.
+# Set it to YES to include the internal documentation.
+INTERNAL_DOCS          = NO
+# If the CASE_SENSE_NAMES tag is set to NO then Doxygen will only generate
+# file names in lower-case letters. If set to YES upper-case letters are also
+# allowed. This is useful if you have classes or files whose names only differ
+# in case and if your file system supports case sensitive file names. Windows
+# and Mac users are advised to set this option to NO.
+CASE_SENSE_NAMES       = YES
+# If the HIDE_SCOPE_NAMES tag is set to NO (the default) then Doxygen
+# will show members with their full class and namespace scopes in the
+# documentation. If set to YES the scope will be hidden.
+HIDE_SCOPE_NAMES       = NO
+# If the SHOW_INCLUDE_FILES tag is set to YES (the default) then Doxygen
+# will put a list of the files that are included by a file in the documentation
+# of that file.
+SHOW_INCLUDE_FILES     = YES
+# If the INLINE_INFO tag is set to YES (the default) then a tag [inline]
+# is inserted in the documentation for inline members.
+INLINE_INFO            = YES
+# If the SORT_MEMBER_DOCS tag is set to YES (the default) then doxygen
+# will sort the (detailed) documentation of file and class members
+# alphabetically by member name. If set to NO the members will appear in
+# declaration order.
+SORT_MEMBER_DOCS       = YES
+# If the SORT_BRIEF_DOCS tag is set to YES then doxygen will sort the
+# brief documentation of file, namespace and class members alphabetically
+# by member name. If set to NO (the default) the members will appear in
+SORT_BRIEF_DOCS        = NO
+# If the SORT_GROUP_NAMES tag is set to YES then doxygen will sort the
+# hierarchy of group names into alphabetical order. If set to NO (the default)
+# the group names will appear in their defined order.
+SORT_GROUP_NAMES       = NO
+# If the SORT_BY_SCOPE_NAME tag is set to YES, the class list will be
+# sorted by fully-qualified names, including namespaces. If set to
+# NO (the default), the class list will be sorted only by class name,
+# not including the namespace part.
+# Note: This option is not very useful if HIDE_SCOPE_NAMES is set to YES.
+# Note: This option applies only to the class list, not to the
+# alphabetical list.
+SORT_BY_SCOPE_NAME     = NO
+# The GENERATE_TODOLIST tag can be used to enable (YES) or
+# disable (NO) the todo list. This list is created by putting \todo
+# commands in the documentation.
+GENERATE_TODOLIST      = YES
+# The GENERATE_TESTLIST tag can be used to enable (YES) or
+# disable (NO) the test list. This list is created by putting \test
+GENERATE_TESTLIST      = YES
+# The GENERATE_BUGLIST tag can be used to enable (YES) or
+# disable (NO) the bug list. This list is created by putting \bug
+GENERATE_BUGLIST       = YES
+# The GENERATE_DEPRECATEDLIST tag can be used to enable (YES) or
+# disable (NO) the deprecated list. This list is created by putting
+# \deprecated commands in the documentation.
+GENERATE_DEPRECATEDLIST= YES
+# The ENABLED_SECTIONS tag can be used to enable conditional
+# documentation sections, marked by \if sectionname ... \endif.
+ENABLED_SECTIONS       =
+# The MAX_INITIALIZER_LINES tag determines the maximum number of lines
+# the initial value of a variable or define consists of for it to appear in
+# the documentation. If the initializer consists of more lines than specified
+# here it will be hidden. Use a value of 0 to hide initializers completely.
+# The appearance of the initializer of individual variables and defines in the
+# documentation can be controlled using \showinitializer or \hideinitializer
+# command in the documentation regardless of this setting.
+MAX_INITIALIZER_LINES  = 30
+# Set the SHOW_USED_FILES tag to NO to disable the list of files generated
+# at the bottom of the documentation of classes and structs. If set to YES the
+# list will mention the files that were used to generate the documentation.
+SHOW_USED_FILES        = YES
+# If the sources in your project are distributed over multiple directories
+# then setting the SHOW_DIRECTORIES tag to YES will show the directory hierarchy
+# in the documentation. The default is NO.
+SHOW_DIRECTORIES       = NO
+# Set the SHOW_FILES tag to NO to disable the generation of the Files page.
+# This will remove the Files entry from the Quick Index and from the
+# Folder Tree View (if specified). The default is YES.
+SHOW_FILES             = YES
+# Set the SHOW_NAMESPACES tag to NO to disable the generation of the
+# Namespaces page.
+# This will remove the Namespaces entry from the Quick Index
+# and from the Folder Tree View (if specified). The default is YES.
+SHOW_NAMESPACES        = YES
+# The FILE_VERSION_FILTER tag can be used to specify a program or script that
+# doxygen should invoke to get the current version for each file (typically from
+# the version control system). Doxygen will invoke the program by executing (via
+# popen()) the command <command> <input-file>, where <command> is the value of
+# the FILE_VERSION_FILTER tag, and <input-file> is the name of an input file
+# provided by doxygen. Whatever the program writes to standard output
+# is used as the file version. See the manual for examples.
+FILE_VERSION_FILTER    =
+# The LAYOUT_FILE tag can be used to specify a layout file which will be parsed by
+# doxygen. The layout file controls the global structure of the generated output files
+# in an output format independent way. The create the layout file that represents
+# doxygen's defaults, run doxygen with the -l option. You can optionally specify a
+# file name after the option, if omitted DoxygenLayout.xml will be used as the name
+# of the layout file.
+LAYOUT_FILE            =
+# configuration options related to warning and progress messages
+# The QUIET tag can be used to turn on/off the messages that are generated
+# by doxygen. Possible values are YES and NO. If left blank NO is used.
+QUIET                  = NO
+# The WARNINGS tag can be used to turn on/off the warning messages that are
+# generated by doxygen. Possible values are YES and NO. If left blank
+# NO is used.
+WARNINGS               = YES
+# If WARN_IF_UNDOCUMENTED is set to YES, then doxygen will generate warnings
+# for undocumented members. If EXTRACT_ALL is set to YES then this flag will
+# automatically be disabled.
+WARN_IF_UNDOCUMENTED   = YES
+# If WARN_IF_DOC_ERROR is set to YES, doxygen will generate warnings for
+# potential errors in the documentation, such as not documenting some
+# parameters in a documented function, or documenting parameters that
+# don't exist or using markup commands wrongly.
+WARN_IF_DOC_ERROR      = YES
+# This WARN_NO_PARAMDOC option can be abled to get warnings for
+# functions that are documented, but have no documentation for their parameters
+# or return value. If set to NO (the default) doxygen will only warn about
+# wrong or incomplete parameter documentation, but not about the absence of
+# documentation.
+WARN_NO_PARAMDOC       = NO
+# The WARN_FORMAT tag determines the format of the warning messages that
+# doxygen can produce. The string should contain the $file, $line, and $text
+# tags, which will be replaced by the file and line number from which the
+# warning originated and the warning text. Optionally the format may contain
+# $version, which will be replaced by the version of the file (if it could
+# be obtained via FILE_VERSION_FILTER)
+WARN_FORMAT            = "$file:$line: $text"
+# The WARN_LOGFILE tag can be used to specify a file to which warning
+# and error messages should be written. If left blank the output is written
+# to stderr.
+WARN_LOGFILE           =
+# configuration options related to the input files
+# The INPUT tag can be used to specify the files and/or directories that contain
+# documented source files. You may enter file names like "myfile.cpp" or
+# directories like "/usr/src/myproject". Separate the files or directories
+# with spaces.
+INPUT                  =
+# This tag can be used to specify the character encoding of the source files
+# that doxygen parses. Internally doxygen uses the UTF-8 encoding, which is
+# also the default input encoding. Doxygen uses libiconv (or the iconv built
+# into libc) for the transcoding. See http://www.gnu.org/software/libiconv for
+# the list of possible encodings.
+INPUT_ENCODING         = UTF-8
+# If the value of the INPUT tag contains directories, you can use the
+# FILE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
+# and *.h) to filter out the source-files in the directories. If left
+# blank the following patterns are tested:
+# *.c *.cc *.cxx *.cpp *.c++ *.java *.ii *.ixx *.ipp *.i++ *.inl *.h *.hh *.hxx
+# *.hpp *.h++ *.idl *.odl *.cs *.php *.php3 *.inc *.m *.mm *.py *.f90
+FILE_PATTERNS          =
+# The RECURSIVE tag can be used to turn specify whether or not subdirectories
+# should be searched for input files as well. Possible values are YES and NO.
+# If left blank NO is used.
+RECURSIVE              = YES
+# The EXCLUDE tag can be used to specify files and/or directories that should
+# excluded from the INPUT source files. This way you can easily exclude a
+# subdirectory from a directory tree whose root is specified with the INPUT tag.
+EXCLUDE                =
+# The EXCLUDE_SYMLINKS tag can be used select whether or not files or
+# directories that are symbolic links (a Unix filesystem feature) are excluded
+# from the input.
+EXCLUDE_SYMLINKS       = NO
+# EXCLUDE_PATTERNS tag to specify one or more wildcard patterns to exclude
+# certain files from those directories. Note that the wildcards are matched
+# against the file with absolute path, so to exclude all test directories
+# for example use the pattern */test/*
+EXCLUDE_PATTERNS       =
+# The EXCLUDE_SYMBOLS tag can be used to specify one or more symbol names
+# (namespaces, classes, functions, etc.) that should be excluded from the
+# output. The symbol name can be a fully qualified name, a word, or if the
+# wildcard * is used, a substring. Examples: ANamespace, AClass,
+# AClass::ANamespace, ANamespace::*Test
+EXCLUDE_SYMBOLS        =
+# The EXAMPLE_PATH tag can be used to specify one or more files or
+# directories that contain example code fragments that are included (see
+# the \include command).
+EXAMPLE_PATH           =
+# If the value of the EXAMPLE_PATH tag contains directories, you can use the
+# EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
+# blank all files are included.
+EXAMPLE_PATTERNS       =
+# If the EXAMPLE_RECURSIVE tag is set to YES then subdirectories will be
+# searched for input files to be used with the \include or \dontinclude
+# commands irrespective of the value of the RECURSIVE tag.
+# Possible values are YES and NO. If left blank NO is used.
+EXAMPLE_RECURSIVE      = NO
+# The IMAGE_PATH tag can be used to specify one or more files or
+# directories that contain image that are included in the documentation (see
+# the \image command).
+IMAGE_PATH             =
+# The INPUT_FILTER tag can be used to specify a program that doxygen should
+# invoke to filter for each input file. Doxygen will invoke the filter program
+# by executing (via popen()) the command <filter> <input-file>, where <filter>
+# is the value of the INPUT_FILTER tag, and <input-file> is the name of an
+# input file. Doxygen will then use the output that the filter program writes
+# to standard output.
+# If FILTER_PATTERNS is specified, this tag will be
+# ignored.
+INPUT_FILTER           =
+# The FILTER_PATTERNS tag can be used to specify filters on a per file pattern
+# basis.
+# Doxygen will compare the file name with each pattern and apply the
+# filter if there is a match.
+# The filters are a list of the form:
+# pattern=filter (like *.cpp=my_cpp_filter). See INPUT_FILTER for further
+# info on how filters are used. If FILTER_PATTERNS is empty, INPUT_FILTER
+# is applied to all files.
+FILTER_PATTERNS        =
+# If the FILTER_SOURCE_FILES tag is set to YES, the input filter (if set using
+# INPUT_FILTER) will be used to filter the input files when producing source
+# files to browse (i.e. when SOURCE_BROWSER is set to YES).
+FILTER_SOURCE_FILES    = NO
+# configuration options related to source browsing
+# If the SOURCE_BROWSER tag is set to YES then a list of source files will
+# be generated. Documented entities will be cross-referenced with these sources.
+# Note: To get rid of all source code in the generated output, make sure also
+# VERBATIM_HEADERS is set to NO.
+SOURCE_BROWSER         = YES
+# Setting the INLINE_SOURCES tag to YES will include the body
+# of functions and classes directly in the documentation.
+INLINE_SOURCES         = NO
+# Setting the STRIP_CODE_COMMENTS tag to YES (the default) will instruct
+# doxygen to hide any special comment blocks from generated source code
+# fragments. Normal C and C++ comments will always remain visible.
+STRIP_CODE_COMMENTS    = YES
+# If the REFERENCED_BY_RELATION tag is set to YES
+# then for each documented function all documented
+# functions referencing it will be listed.
+REFERENCED_BY_RELATION = YES
+# If the REFERENCES_RELATION tag is set to YES
+# then for each documented function all documented entities
+# called/used by that function will be listed.
+REFERENCES_RELATION    = YES
+# If the REFERENCES_LINK_SOURCE tag is set to YES (the default)
+# and SOURCE_BROWSER tag is set to YES, then the hyperlinks from
+# functions in REFERENCES_RELATION and REFERENCED_BY_RELATION lists will
+# link to the source code.
+# Otherwise they will link to the documentation.
+REFERENCES_LINK_SOURCE = YES
+# If the USE_HTAGS tag is set to YES then the references to source code
+# will point to the HTML generated by the htags(1) tool instead of doxygen
+# built-in source browser. The htags tool is part of GNU's global source
+# tagging system (see http://www.gnu.org/software/global/global.html). You
+# will need version 4.8.6 or higher.
+USE_HTAGS              = YES
+# If the VERBATIM_HEADERS tag is set to YES (the default) then Doxygen
+# will generate a verbatim copy of the header file for each class for
+# which an include is specified. Set to NO to disable this.
+VERBATIM_HEADERS       = YES
+# configuration options related to the alphabetical class index
+# If the ALPHABETICAL_INDEX tag is set to YES, an alphabetical index
+# of all compounds will be generated. Enable this if the project
+# contains a lot of classes, structs, unions or interfaces.
+ALPHABETICAL_INDEX     = YES
+# If the alphabetical index is enabled (see ALPHABETICAL_INDEX) then
+# the COLS_IN_ALPHA_INDEX tag can be used to specify the number of columns
+# in which this list will be split (can be a number in the range [1..20])
+COLS_IN_ALPHA_INDEX    = 5
+# In case all classes in a project start with a common prefix, all
+# classes will be put under the same header in the alphabetical index.
+# The IGNORE_PREFIX tag can be used to specify one or more prefixes that
+# should be ignored while generating the index headers.
+IGNORE_PREFIX          =
+# configuration options related to the HTML output
+# If the GENERATE_HTML tag is set to YES (the default) Doxygen will
+# generate HTML output.
+GENERATE_HTML          = YES
+# The HTML_OUTPUT tag is used to specify where the HTML docs will be put.
+# If a relative path is entered the value of OUTPUT_DIRECTORY will be
+# put in front of it. If left blank `html' will be used as the default path.
+HTML_OUTPUT            = html
+# The HTML_FILE_EXTENSION tag can be used to specify the file extension for
+# each generated HTML page (for example: .htm,.php,.asp). If it is left blank
+# doxygen will generate files with .html extension.
+HTML_FILE_EXTENSION    = .html
+# The HTML_HEADER tag can be used to specify a personal HTML header for
+# each generated HTML page. If it is left blank doxygen will generate a
+# standard header.
+HTML_HEADER            =
+# The HTML_FOOTER tag can be used to specify a personal HTML footer for
+# standard footer.
+HTML_FOOTER            =
+# The HTML_STYLESHEET tag can be used to specify a user-defined cascading
+# style sheet that is used by each HTML page. It can be used to
+# fine-tune the look of the HTML output. If the tag is left blank doxygen
+# will generate a default style sheet. Note that doxygen will try to copy
+# the style sheet file to the HTML output directory, so don't put your own
+# stylesheet in the HTML output directory as well, or it will be erased!
+HTML_STYLESHEET        =
+# If the HTML_ALIGN_MEMBERS tag is set to YES, the members of classes,
+# files or namespaces will be aligned in HTML using tables. If set to
+# NO a bullet list will be used.
+HTML_ALIGN_MEMBERS     = YES
+# If the HTML_DYNAMIC_SECTIONS tag is set to YES then the generated HTML
+# documentation will contain sections that can be hidden and shown after the
+# page has loaded. For this to work a browser that supports
+# JavaScript and DHTML is required (for instance Mozilla 1.0+, Firefox
+# Netscape 6.0+, Internet explorer 5.0+, Konqueror, or Safari).
+GENERATE_HTMLHELP      = NO
+# If the GENERATE_DOCSET tag is set to YES, additional index files
+# will be generated that can be used as input for Apple's Xcode 3
+# integrated development environment, introduced with OSX 10.5 (Leopard).
+# To create a documentation set, doxygen will generate a Makefile in the
+# HTML output directory. Running make will produce the docset in that
+# directory and running "make install" will install the docset in
+# ~/Library/Developer/Shared/Documentation/DocSets so that Xcode will find
+# it at startup.
+# See http://developer.apple.com/tools/creatingdocsetswithdoxygen.html for more information.
+GENERATE_DOCSET        = NO
+# When GENERATE_DOCSET tag is set to YES, this tag determines the name of the
+# feed. A documentation feed provides an umbrella under which multiple
+# documentation sets from a single provider (such as a company or product suite)
+# can be grouped.
+DOCSET_FEEDNAME        = "Doxygen generated docs"
+# When GENERATE_DOCSET tag is set to YES, this tag specifies a string that
+# should uniquely identify the documentation set bundle. This should be a
+# reverse domain-name style string, e.g. com.mycompany.MyDocSet. Doxygen
+# will append .docset to the name.
+DOCSET_BUNDLE_ID       = org.doxygen.Project
+# If the GENERATE_HTMLHELP tag is set to YES, additional index files
+# will be generated that can be used as input for tools like the
+# Microsoft HTML help workshop to generate a compiled HTML help file (.chm)
+# of the generated HTML documentation.
+# If the GENERATE_HTMLHELP tag is set to YES, the CHM_FILE tag can
+# be used to specify the file name of the resulting .chm file. You
+# can add a path in front of the file if the result should not be
+# written to the html output directory.
+CHM_FILE               =
+# If the GENERATE_HTMLHELP tag is set to YES, the HHC_LOCATION tag can
+# be used to specify the location (absolute path including file name) of
+# the HTML help compiler (hhc.exe). If non-empty doxygen will try to run
+# the HTML help compiler on the generated index.hhp.
+HHC_LOCATION           =
+# If the GENERATE_HTMLHELP tag is set to YES, the GENERATE_CHI flag
+# controls if a separate .chi index file is generated (YES) or that
+# it should be included in the master .chm file (NO).
+GENERATE_CHI           = NO
+# If the GENERATE_HTMLHELP tag is set to YES, the CHM_INDEX_ENCODING
+# is used to encode HtmlHelp index (hhk), content (hhc) and project file
+# content.
+CHM_INDEX_ENCODING     =
+# If the GENERATE_HTMLHELP tag is set to YES, the BINARY_TOC flag
+# controls whether a binary table of contents is generated (YES) or a
+# normal table of contents (NO) in the .chm file.
+BINARY_TOC             = NO
+# The TOC_EXPAND flag can be set to YES to add extra items for group members
+# to the contents of the HTML help documentation and to the tree view.
+TOC_EXPAND             = NO
+# If the GENERATE_QHP tag is set to YES and both QHP_NAMESPACE and QHP_VIRTUAL_FOLDER
+# are set, an additional index file will be generated that can be used as input for
+# Qt's qhelpgenerator to generate a Qt Compressed Help (.qch) of the generated
+# HTML documentation.
+GENERATE_QHP           = NO
+# If the QHG_LOCATION tag is specified, the QCH_FILE tag can
+# be used to specify the file name of the resulting .qch file.
+# The path specified is relative to the HTML output folder.
+QCH_FILE               =
+# The QHP_NAMESPACE tag specifies the namespace to use when generating
+# Qt Help Project output. For more information please see
+# http://doc.trolltech.com/qthelpproject.html#namespace
+QHP_NAMESPACE          =
+# The QHP_VIRTUAL_FOLDER tag specifies the namespace to use when generating
+# http://doc.trolltech.com/qthelpproject.html#virtual-folders
+QHP_VIRTUAL_FOLDER     = doc
+# If QHP_CUST_FILTER_NAME is set, it specifies the name of a custom filter to add.
+# For more information please see
+# http://doc.trolltech.com/qthelpproject.html#custom-filters
+QHP_CUST_FILTER_NAME   =
+# The QHP_CUST_FILT_ATTRS tag specifies the list of the attributes of the custom filter to add.For more information please see
+# <a href="http://doc.trolltech.com/qthelpproject.html#custom-filters">Qt Help Project / Custom Filters</a>.
+QHP_CUST_FILTER_ATTRS  =
+# The QHP_SECT_FILTER_ATTRS tag specifies the list of the attributes this project's
+# filter section matches.
+# <a href="http://doc.trolltech.com/qthelpproject.html#filter-attributes">Qt Help Project / Filter Attributes</a>.
+QHP_SECT_FILTER_ATTRS  =
+# If the GENERATE_QHP tag is set to YES, the QHG_LOCATION tag can
+# be used to specify the location of Qt's qhelpgenerator.
+# If non-empty doxygen will try to run qhelpgenerator on the generated
+# .qhp file.
+QHG_LOCATION           =
+# The DISABLE_INDEX tag can be used to turn on/off the condensed index at
+# top of each HTML page. The value NO (the default) enables the index and
+# the value YES disables it.
+DISABLE_INDEX          = NO
+# This tag can be used to set the number of enum values (range [1..20])
+# that doxygen will group on one line in the generated HTML documentation.
+ENUM_VALUES_PER_LINE   = 4
+# The GENERATE_TREEVIEW tag is used to specify whether a tree-like index
+# structure should be generated to display hierarchical information.
+# If the tag value is set to FRAME, a side panel will be generated
+# containing a tree-like index structure (just like the one that
+# is generated for HTML Help). For this to work a browser that supports
+# JavaScript, DHTML, CSS and frames is required (for instance Mozilla 1.0+,
+# Netscape 6.0+, Internet explorer 5.0+, or Konqueror). Windows users are
+# probably better off using the HTML help feature. Other possible values
+# for this tag are: HIERARCHIES, which will generate the Groups, Directories,
+# and Class Hierarchy pages using a tree view instead of an ordered list;
+# ALL, which combines the behavior of FRAME and HIERARCHIES; and NONE, which
+# disables this behavior completely. For backwards compatibility with previous
+# releases of Doxygen, the values YES and NO are equivalent to FRAME and NONE
+# respectively.
+GENERATE_TREEVIEW      = NONE
+# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be
+# used to set the initial width (in pixels) of the frame in which the tree
+# is shown.
+TREEVIEW_WIDTH         = 250
+# Use this tag to change the font size of Latex formulas included
+# as images in the HTML documentation. The default is 10. Note that
+# when you change the font size after a successful doxygen run you need
+# to manually remove any form_*.png images from the HTML output directory
+# to force them to be regenerated.
+FORMULA_FONTSIZE       = 10
+# configuration options related to the LaTeX output
+# If the GENERATE_LATEX tag is set to YES (the default) Doxygen will
+# generate Latex output.
+GENERATE_LATEX         = NO
+# The LATEX_OUTPUT tag is used to specify where the LaTeX docs will be put.
+# put in front of it. If left blank `latex' will be used as the default path.
+LATEX_OUTPUT           = latex
+# The LATEX_CMD_NAME tag can be used to specify the LaTeX command name to be
+# invoked. If left blank `latex' will be used as the default command name.
+LATEX_CMD_NAME         = latex
+# The MAKEINDEX_CMD_NAME tag can be used to specify the command name to
+# generate index for LaTeX. If left blank `makeindex' will be used as the
+# default command name.
+MAKEINDEX_CMD_NAME     = makeindex
+# If the COMPACT_LATEX tag is set to YES Doxygen generates more compact
+# LaTeX documents. This may be useful for small projects and may help to
+# save some trees in general.
+COMPACT_LATEX          = NO
+# The PAPER_TYPE tag can be used to set the paper type that is used
+# by the printer. Possible values are: a4, a4wide, letter, legal and
+# executive. If left blank a4wide will be used.
+PAPER_TYPE             = a4wide
+# The EXTRA_PACKAGES tag can be to specify one or more names of LaTeX
+# packages that should be included in the LaTeX output.
+EXTRA_PACKAGES         =
+# The LATEX_HEADER tag can be used to specify a personal LaTeX header for
+# the generated latex document. The header should contain everything until
+# the first chapter. If it is left blank doxygen will generate a
+# standard header. Notice: only use this tag if you know what you are doing!
+LATEX_HEADER           =
+# If the PDF_HYPERLINKS tag is set to YES, the LaTeX that is generated
+# is prepared for conversion to pdf (using ps2pdf). The pdf file will
+# contain links (just like the HTML output) instead of page references
+# This makes the output suitable for online browsing using a pdf viewer.
+PDF_HYPERLINKS         = YES
+# If the USE_PDFLATEX tag is set to YES, pdflatex will be used instead of
+# plain latex in the generated Makefile. Set this option to YES to get a
+# higher quality PDF documentation.
+USE_PDFLATEX           = YES
+# If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \\batchmode.
+# command to the generated LaTeX files. This will instruct LaTeX to keep
+# running if errors occur, instead of asking the user for help.
+# This option is also used when generating formulas in HTML.
+LATEX_BATCHMODE        = NO
+# If LATEX_HIDE_INDICES is set to YES then doxygen will not
+# include the index chapters (such as File Index, Compound Index, etc.)
+# in the output.
+LATEX_HIDE_INDICES     = NO
+# configuration options related to the RTF output
+# If the GENERATE_RTF tag is set to YES Doxygen will generate RTF output
+# The RTF output is optimized for Word 97 and may not look very pretty with
+# other RTF readers or editors.
+GENERATE_RTF           = NO
+# The RTF_OUTPUT tag is used to specify where the RTF docs will be put.
+# put in front of it. If left blank `rtf' will be used as the default path.
+RTF_OUTPUT             = rtf
+# If the COMPACT_RTF tag is set to YES Doxygen generates more compact
+# RTF documents. This may be useful for small projects and may help to
+COMPACT_RTF            = NO
+# If the RTF_HYPERLINKS tag is set to YES, the RTF that is generated
+# will contain hyperlink fields. The RTF file will
+# contain links (just like the HTML output) instead of page references.
+# This makes the output suitable for online browsing using WORD or other
+# programs which support those fields.
+# Note: wordpad (write) and others do not support links.
+RTF_HYPERLINKS         = NO
+# Load stylesheet definitions from file. Syntax is similar to doxygen's
+# config file, i.e. a series of assignments. You only have to provide
+# replacements, missing definitions are set to their default value.
+RTF_STYLESHEET_FILE    =
+# Set optional variables used in the generation of an rtf document.
+# Syntax is similar to doxygen's config file.
+RTF_EXTENSIONS_FILE    =
+# configuration options related to the man page output
+# If the GENERATE_MAN tag is set to YES (the default) Doxygen will
+# generate man pages
+GENERATE_MAN           = YES
+# The MAN_OUTPUT tag is used to specify where the man pages will be put.
+# put in front of it. If left blank `man' will be used as the default path.
+MAN_OUTPUT             = man
+# The MAN_EXTENSION tag determines the extension that is added to
+# the generated man pages (default is the subroutine's section .3)
+MAN_EXTENSION          = .3
+# If the MAN_LINKS tag is set to YES and Doxygen generates man output,
+# then it will generate one additional man file for each entity
+# documented in the real man page(s). These additional files
+# only source the real man page, but without them the man command
+# would be unable to find the correct page. The default is NO.
+MAN_LINKS              = NO
+# configuration options related to the XML output
+# If the GENERATE_XML tag is set to YES Doxygen will
+# generate an XML file that captures the structure of
+# the code including all documentation.
+GENERATE_XML           = NO
+# The XML_OUTPUT tag is used to specify where the XML pages will be put.
+# put in front of it. If left blank `xml' will be used as the default path.
+XML_OUTPUT             = xml
+# The XML_SCHEMA tag can be used to specify an XML schema,
+# which can be used by a validating XML parser to check the
+# syntax of the XML files.
+XML_SCHEMA             =
+# The XML_DTD tag can be used to specify an XML DTD,
+XML_DTD                =
+# If the XML_PROGRAMLISTING tag is set to YES Doxygen will
+# dump the program listings (including syntax highlighting
+# and cross-referencing information) to the XML output. Note that
+# enabling this will significantly increase the size of the XML output.
+XML_PROGRAMLISTING     = YES
+# configuration options for the AutoGen Definitions output
+# If the GENERATE_AUTOGEN_DEF tag is set to YES Doxygen will
+# generate an AutoGen Definitions (see autogen.sf.net) file
+# that captures the structure of the code including all
+# documentation. Note that this feature is still experimental
+# and incomplete at the moment.
+GENERATE_AUTOGEN_DEF   = NO
+# configuration options related to the Perl module output
+# If the GENERATE_PERLMOD tag is set to YES Doxygen will
+# generate a Perl module file that captures the structure of
+# the code including all documentation. Note that this
+# feature is still experimental and incomplete at the
+# moment.
+GENERATE_PERLMOD       = NO
+# If the PERLMOD_LATEX tag is set to YES Doxygen will generate
+# the necessary Makefile rules, Perl scripts and LaTeX code to be able
+# to generate PDF and DVI output from the Perl module output.
+PERLMOD_LATEX          = NO
+# If the PERLMOD_PRETTY tag is set to YES the Perl module output will be
+# nicely formatted so it can be parsed by a human reader.
+# This is useful
+# if you want to understand what is going on.
+# On the other hand, if this
+# tag is set to NO the size of the Perl module output will be much smaller
+# and Perl will parse it just the same.
+PERLMOD_PRETTY         = YES
+# The names of the make variables in the generated doxyrules.make file
+# are prefixed with the string contained in PERLMOD_MAKEVAR_PREFIX.
+# This is useful so different doxyrules.make files included by the same
+# Makefile don't overwrite each other's variables.
+PERLMOD_MAKEVAR_PREFIX =
+# Configuration options related to the preprocessor
+# If the ENABLE_PREPROCESSING tag is set to YES (the default) Doxygen will
+# evaluate all C-preprocessor directives found in the sources and include
+# files.
+ENABLE_PREPROCESSING   = YES
+# If the MACRO_EXPANSION tag is set to YES Doxygen will expand all macro
+# names in the source code. If set to NO (the default) only conditional
+# compilation will be performed. Macro expansion can be done in a controlled
+# way by setting EXPAND_ONLY_PREDEF to YES.
+MACRO_EXPANSION        = NO
+# If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES
+# then the macro expansion is limited to the macros specified with the
+# PREDEFINED and EXPAND_AS_DEFINED tags.
+EXPAND_ONLY_PREDEF     = NO
+# If the SEARCH_INCLUDES tag is set to YES (the default) the includes files
+# in the INCLUDE_PATH (see below) will be search if a #include is found.
+SEARCH_INCLUDES        = YES
+# The INCLUDE_PATH tag can be used to specify one or more directories that
+# contain include files that are not input files but should be processed by
+# the preprocessor.
+INCLUDE_PATH           =
+# You can use the INCLUDE_FILE_PATTERNS tag to specify one or more wildcard
+# patterns (like *.h and *.hpp) to filter out the header-files in the
+# directories. If left blank, the patterns specified with FILE_PATTERNS will
+# be used.
+INCLUDE_FILE_PATTERNS  =
+# The PREDEFINED tag can be used to specify one or more macro names that
+# are defined before the preprocessor is started (similar to the -D option of
+# gcc). The argument of the tag is a list of macros of the form: name
+# or name=definition (no spaces). If the definition and the = are
+# omitted =1 is assumed. To prevent a macro definition from being
+# undefined via #undef or recursively expanded use the := operator
+# instead of the = operator.
+PREDEFINED             =
+# If the MACRO_EXPANSION and EXPAND_ONLY_PREDEF tags are set to YES then
+# this tag can be used to specify a list of macro names that should be expanded.
+# The macro definition that is found in the sources will be used.
+# Use the PREDEFINED tag if you want to use a different macro definition.
+EXPAND_AS_DEFINED      =
+# If the SKIP_FUNCTION_MACROS tag is set to YES (the default) then
+# doxygen's preprocessor will remove all function-like macros that are alone
+# on a line, have an all uppercase name, and do not end with a semicolon. Such
+# function macros are typically used for boiler-plate code, and will confuse
+# the parser if not removed.
+SKIP_FUNCTION_MACROS   = YES
+# Configuration::additions related to external references
+# The TAGFILES option can be used to specify one or more tagfiles.
+# Optionally an initial location of the external documentation
+# can be added for each tagfile. The format of a tag file without
+# this location is as follows:
+# TAGFILES = file1 file2 ...
+# Adding location for the tag files is done as follows:
+# TAGFILES = file1=loc1 "file2 = loc2" ...
+# where "loc1" and "loc2" can be relative or absolute paths or
+# URLs. If a location is present for each tag, the installdox tool
+# does not have to be run to correct the links.
+# Note that each tag file must have a unique name
+# (where the name does NOT include the path)
+# If a tag file is not located in the directory in which doxygen
+# is run, you must also specify the path to the tagfile here.
+TAGFILES               =
+# When a file name is specified after GENERATE_TAGFILE, doxygen will create
+# a tag file that is based on the input files it reads.
+GENERATE_TAGFILE       =
+# If the ALLEXTERNALS tag is set to YES all external classes will be listed
+# in the class index. If set to NO only the inherited external classes
+# will be listed.
+ALLEXTERNALS           = NO
+# If the EXTERNAL_GROUPS tag is set to YES all external groups will be listed
+# in the modules index. If set to NO, only the current project's groups will
+# be listed.
+EXTERNAL_GROUPS        = YES
+# The PERL_PATH should be the absolute path and name of the perl script
+# interpreter (i.e. the result of `which perl').
+PERL_PATH              = /usr/bin/perl
+# Configuration options related to the dot tool
+# If the CLASS_DIAGRAMS tag is set to YES (the default) Doxygen will
+# generate a inheritance diagram (in HTML, RTF and LaTeX) for classes with base
+# or super classes. Setting the tag to NO turns the diagrams off. Note that
+# this option is superseded by the HAVE_DOT option below. This is only a
+# fallback. It is recommended to install and use dot, since it yields more
+# powerful graphs.
+CLASS_DIAGRAMS         = YES
+# You can define message sequence charts within doxygen comments using the \msc
+# command. Doxygen will then run the mscgen tool (see
+# http://www.mcternan.me.uk/mscgen/) to produce the chart and insert it in the
+# documentation. The MSCGEN_PATH tag allows you to specify the directory where
+# the mscgen tool resides. If left empty the tool is assumed to be found in the
+# default search path.
+MSCGEN_PATH            =
+# If set to YES, the inheritance and collaboration graphs will hide
+# inheritance and usage relations if the target is undocumented
+# or is not a class.
+HIDE_UNDOC_RELATIONS   = YES
+# If you set the HAVE_DOT tag to YES then doxygen will assume the dot tool is
+# available from the path. This tool is part of Graphviz, a graph visualization
+# toolkit from AT&T and Lucent Bell Labs. The other options in this section
+# have no effect if this option is set to NO (the default)
+HAVE_DOT               = YES
+# By default doxygen will write a font called FreeSans.ttf to the output
+# directory and reference it in all dot files that doxygen generates. This
+# font does not include all possible unicode characters however, so when you need
+# these (or just want a differently looking font) you can specify the font name
+# using DOT_FONTNAME. You need need to make sure dot is able to find the font,
+# which can be done by putting it in a standard location or by setting the
+# DOTFONTPATH environment variable or by setting DOT_FONTPATH to the directory
+# containing the font.
+DOT_FONTNAME           = FreeSans
+# The DOT_FONTSIZE tag can be used to set the size of the font of dot graphs.
+# The default size is 10pt.
+DOT_FONTSIZE           = 10
+# By default doxygen will tell dot to use the output directory to look for the
+# FreeSans.ttf font (which doxygen will put there itself). If you specify a
+# different font using DOT_FONTNAME you can set the path where dot
+# can find it using this tag.
+DOT_FONTPATH           =
+# If the CLASS_GRAPH and HAVE_DOT tags are set to YES then doxygen
+# will generate a graph for each documented class showing the direct and
+# indirect inheritance relations. Setting this tag to YES will force the
+# the CLASS_DIAGRAMS tag to NO.
+CLASS_GRAPH            = YES
+# If the COLLABORATION_GRAPH and HAVE_DOT tags are set to YES then doxygen
+# indirect implementation dependencies (inheritance, containment, and
+# class references variables) of the class with other documented classes.
+COLLABORATION_GRAPH    = YES
+# If the GROUP_GRAPHS and HAVE_DOT tags are set to YES then doxygen
+# will generate a graph for groups, showing the direct groups dependencies
+GROUP_GRAPHS           = YES
+# If the UML_LOOK tag is set to YES doxygen will generate inheritance and
+# collaboration diagrams in a style similar to the OMG's Unified Modeling
+# Language.
+UML_LOOK               = NO
+# If set to YES, the inheritance and collaboration graphs will show the
+# relations between templates and their instances.
+TEMPLATE_RELATIONS     = NO
+# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDE_GRAPH, and HAVE_DOT
+# tags are set to YES then doxygen will generate a graph for each documented
+# file showing the direct and indirect include dependencies of the file with
+# other documented files.
+INCLUDE_GRAPH          = YES
+# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDED_BY_GRAPH, and
+# HAVE_DOT tags are set to YES then doxygen will generate a graph for each
+# documented header file showing the documented files that directly or
+# indirectly include this file.
+INCLUDED_BY_GRAPH      = YES
+# If the CALL_GRAPH and HAVE_DOT options are set to YES then
+# doxygen will generate a call dependency graph for every global function
+# or class method. Note that enabling this option will significantly increase
+# the time of a run. So in most cases it will be better to enable call graphs
+# for selected functions only using the \callgraph command.
+CALL_GRAPH             = YES
+# If the CALLER_GRAPH and HAVE_DOT tags are set to YES then
+# doxygen will generate a caller dependency graph for every global function
+# the time of a run. So in most cases it will be better to enable caller
+# graphs for selected functions only using the \callergraph command.
+CALLER_GRAPH           = YES
+# If the GRAPHICAL_HIERARCHY and HAVE_DOT tags are set to YES then doxygen
+# will graphical hierarchy of all classes instead of a textual one.
+GRAPHICAL_HIERARCHY    = YES
+# If the DIRECTORY_GRAPH, SHOW_DIRECTORIES and HAVE_DOT tags are set to YES
+# then doxygen will show the dependencies a directory has on other directories
+# in a graphical way. The dependency relations are determined by the #include
+# relations between the files in the directories.
+DIRECTORY_GRAPH        = YES
+# The DOT_IMAGE_FORMAT tag can be used to set the image format of the images
+# generated by dot. Possible values are png, jpg, or gif
+# If left blank png will be used.
+DOT_IMAGE_FORMAT       = png
+# The tag DOT_PATH can be used to specify the path where the dot tool can be
+# found. If left blank, it is assumed the dot tool can be found in the path.
+DOT_PATH               =
+# The DOTFILE_DIRS tag can be used to specify one or more directories that
+# contain dot files that are included in the documentation (see the
+# \dotfile command).
+DOTFILE_DIRS           =
+# The DOT_GRAPH_MAX_NODES tag can be used to set the maximum number of
+# nodes that will be shown in the graph. If the number of nodes in a graph
+# becomes larger than this value, doxygen will truncate the graph, which is
+# visualized by representing a node as a red box. Note that doxygen if the
+# number of direct children of the root node in a graph is already larger than
+# DOT_GRAPH_MAX_NODES then the graph will not be shown at all. Also note
+# that the size of a graph can be further restricted by MAX_DOT_GRAPH_DEPTH.
+DOT_GRAPH_MAX_NODES    = 50
+# The MAX_DOT_GRAPH_DEPTH tag can be used to set the maximum depth of the
+# graphs generated by dot. A depth value of 3 means that only nodes reachable
+# from the root by following a path via at most 3 edges will be shown. Nodes
+# that lay further from the root node will be omitted. Note that setting this
+# option to 1 or 2 may greatly reduce the computation time needed for large
+# code bases. Also note that the size of a graph can be further restricted by
+# DOT_GRAPH_MAX_NODES. Using a depth of 0 means no depth restriction.
+MAX_DOT_GRAPH_DEPTH    = 0
+# Set the DOT_TRANSPARENT tag to YES to generate images with a transparent
+# background. This is disabled by default, because dot on Windows does not
+# seem to support this out of the box. Warning: Depending on the platform used,
+# enabling this option may lead to badly anti-aliased labels on the edges of
+# a graph (i.e. they become hard to read).
+DOT_TRANSPARENT        = YES
+# Set the DOT_MULTI_TARGETS tag to YES allow dot to generate multiple output
+# files in one run (i.e. multiple -o and -T options on the command line). This
+# makes dot run faster, but since only newer versions of dot (>1.8.10)
+# support this, this feature is disabled by default.
+DOT_MULTI_TARGETS      = NO
+# If the GENERATE_LEGEND tag is set to YES (the default) Doxygen will
+# generate a legend page explaining the meaning of the various boxes and
+# arrows in the dot generated graphs.
+GENERATE_LEGEND        = YES
+# If the DOT_CLEANUP tag is set to YES (the default) Doxygen will
+# remove the intermediate dot files that are used to generate
+# the various graphs.
+DOT_CLEANUP            = YES
+# Options related to the search engine
+# The SEARCHENGINE tag specifies whether or not a search engine should be
+# used. If set to NO the values of all tags below this one will be ignored.
+SEARCHENGINE           = YES
diff --git a/freebsd/contrib/ptpd/src/Makefile.am b/freebsd/contrib/ptpd/src/Makefile.am
new file mode 100644
index 00000000..e2970000
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/Makefile.am
@@ -0,0 +1,102 @@
+# Makefile for ptpd2
+AUTOMAKE_OPTIONS = subdir-objects
+lib_LTLIBRARIES = $(LIBPTPD2_LIBS_LA)
+sbin_PROGRAMS = ptpd2
+man_MANS = ptpd2.8 ptpd2.conf.5
+AM_CFLAGS	= $(SNMP_CFLAGS) $(PCAP_CFLAGS) -Wall -fexceptions
+AM_CPPFLAGS	= $(SNMP_CPPFLAGS) $(PCAP_CPPFLAGS)
+AM_LDFLAGS	= $(SNMP_LIBS) $(PCAP_LIBS)
+if LINUX_KERNEL_HEADERS
+AM_CFLAGS += $(LINUX_KERNEL_INCLUDES)
+endif
+AM_CPPFLAGS    += -DDATADIR='"$(datadir)"' $(PTP_DBL) $(PTP_DAEMON) $(PTP_EXP) $(PTP_SNMP) $(PTP_PCAP) $(PTP_STATISTICS) $(PTP_SLAVE_ONLY) $(PTP_PTIMERS) $(PTP_UNICAST_MAX) $(PTP_DISABLE_SOTIMESTAMPING)
+NULL=
+#VERSION = 2.3.1
+#SHAREDLIBVER = $(SHAREDLIB).$(VERSION)
+#	ptp_timers.c
+EXTRA_DIST = def
+ptpd2_SOURCES =				\
+	arith.c				\
+	bmc.c				\
+	constants.h			\
+	ptp_primitives.h		\
+	ptp_datatypes.h			\
+	datatypes.h			\
+	dep/constants_dep.h		\
+	dep/datatypes_dep.h		\
+	dep/ipv4_acl.h			\
+	dep/ipv4_acl.c			\
+	dep/msg.c			\
+	dep/net.c			\
+	dep/ptpd_dep.h			\
+	dep/eventtimer.h		\
+	dep/eventtimer.c		\
+	ptp_timers.h			\
+	ptp_timers.c			\
+	dep/servo.c			\
+	dep/iniparser/dictionary.h	\
+	dep/iniparser/iniparser.h	\
+	dep/iniparser/dictionary.c	\
+	dep/iniparser/iniparser.c	\
+	dep/configdefaults.h		\
+	dep/configdefaults.c		\
+	dep/daemonconfig.h		\
+	dep/daemonconfig.c		\
+	dep/startup.c			\
+	dep/sys.c			\
+	display.c			\
+	management.c			\
+	signaling.c			\
+	protocol.c			\
+	dep/ntpengine/ntp_isc_md5.c	\
+	dep/ntpengine/ntp_isc_md5.h	\
+	dep/ntpengine/ntpdcontrol.c	\
+	dep/ntpengine/ntpdcontrol.h	\
+	timingdomain.h			\
+	timingdomain.c			\
+	dep/alarms.h			\
+	dep/alarms.c			\
+	ptpd.c				\
+	ptpd.h				\
+	$(NULL)
+# SNMP
+if SNMP
+ptpd2_SOURCES += dep/snmp.c
+endif
+# STATISTICS
+if STATISTICS
+ptpd2_SOURCES += dep/statistics.h
+ptpd2_SOURCES += dep/statistics.c
+ptpd2_SOURCES += dep/outlierfilter.h
+ptpd2_SOURCES += dep/outlierfilter.c
+endif
+# posix timers
+if PTIMERS
+ptpd2_SOURCES +=dep/eventtimer_posix.c
+else
+ptpd2_SOURCES +=dep/eventtimer_itimer.c
+endif
+CSCOPE = cscope
+GTAGS = gtags
+DOXYGEN = doxygen
+TAGFILES = GPATH GRTAGS GSYMS GTAGS cscope.in.out cscope.out cscope.po.out
+dist:
+	cd .. && make dist
+#tags:
+#	$(CSCOPE) -R -q -b
+#	$(GTAGS)
+#	$(DOXYGEN) Doxyfile
diff --git a/freebsd/contrib/ptpd/src/Makefile.old b/freebsd/contrib/ptpd/src/Makefile.old
index 00000000..c2eda70d
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/Makefile.old
@@ -0,0 +1,109 @@
+# Compile time defines:
+#   -DRUNTIME_DEBUG
+#     if defined:    all debug messages are included, and are either selected at startup (-B)
+#                    and runtime (SIGUSR2) (implies -DPTPD_DBGV) using syslog,
+#                    add "*.debug /var/log/debug" to /etc/rsyslog.conf to see debug messages
+#     if undefined:  individual defines select which messages will be included and presented (old behaviour)
+#  -DPTPD_DBG     basic debug messages
+#  -DPTPD_DBG2    adds basic protocol messages, +ignored messages reasons
+#  -DPTPD_DBGV    adds all debug messages
+#   -DPTPD_NO_DAEMON             forces option -c
+#   -DPTPD_EXPERIMENTAL           Allows non-standard compliant experimental options:
+#                                   -U: Hybrid mode
+#                                   -I: choose multicast group
+#   -DPTPD_SNMP                   Enables SNMP agent support (PTP-MIB)
+# Mutually exclusive defines (useful for testing):
+#   -DDBG_SIGUSR2_CHANGE_DOMAIN: SIGUSR2 cycles the PTP domain number
+#   -DDBG_SIGUSR2_CHANGE_DEBUG:  SIGUSR2 cycles the current debug level (if RUNTIME_DEBUG is defined)
+VERSION = 2.3.0
+RM = rm -f
+SYMLINK = ln -s
+# SNMP support?
+SNMP = yes
+# start with CFLAGS += ..., so additional CFLAGs can be specified e.g. on the make command line
+CFLAGS += -Wall -g -fPIC
+CFLAGS += -DRUNTIME_DEBUG
+#CFLAGS += -DPTPD_DBG
+#CFLAGS += -DPTPD_DBG2
+#CFLAGS += -DPTPD_DBGV
+#CFLAGS += -DPTPD_NO_DAEMON
+#CFLAGS += -DDBG_SIGUSR2_CHANGE_DOMAIN
+CFLAGS += -DDBG_SIGUSR2_CHANGE_DEBUG
+CFLAGS += -DPTPD_EXPERIMENTAL
+LDFLAGS = -lm -lrt
+STATICLIBFLAGS = rcs
+SHAREDLIBFLAGS = -shared -Wl,-soname
+PROG = ptpd2
+STATICLIB = libptpd2.a
+SHAREDLIB = libptpd2.so
+SHAREDLIBVER = $(SHAREDLIB).$(VERSION)
+SRCS = ptpd.c arith.c bmc.c protocol.c display.c management.c \
+	dep/msg.c dep/net.c dep/servo.c dep/startup.c dep/sys.c dep/timer.c
+# SNMP
+ifeq ($(SNMP),yes)
+LDFLAGS += `net-snmp-config --agent-libs`
+CFLAGS  += `net-snmp-config --base-cflags`
+CFLAGS  += -DPTPD_SNMP
+SRCS    += dep/snmp.c
+endif
+OBJS = $(SRCS:.c=.o)
+HDRS = ptpd.h constants.h datatypes.h \
+	dep/ptpd_dep.h dep/constants_dep.h dep/datatypes_dep.h
+CSCOPE = cscope
+GTAGS = gtags
+DOXYGEN = doxygen
+.c.o:
+	$(CC) -c $(CFLAGS) $(CPPFLAGS) -o $@ $<
+$(PROG): $(OBJS)
+	$(CC) -o $@ $(OBJS) $(LDFLAGS)
+$(STATICLIB): $(OBJS)
+	$(AR) $(STATICLIBFLAGS) $(STATICLIB) $(OBJS)
+$(SHAREDLIB): $(OBJS)
+	$(CC) $(SHAREDLIBFLAGS),$(SHAREDLIB) -o $(SHAREDLIB) $(OBJS)
+        # create shared lib symlink with ptpd version extension
+	$(SYMLINK) $(SHAREDLIB) $(SHAREDLIBVER)
+all: $(PROG) $(STATICLIB) $(SHAREDLIB)
+$(OBJS): $(HDRS)
+tags:
+	$(CSCOPE) -R -q -b
+	$(GTAGS)
+	$(DOXYGEN) Doxyfile
+clean:
+	$(RM) $(PROG) $(STATICLIB) $(SHAREDLIB) $(SHAREDLIBVER) $(OBJS) $(TAGFILES) make.out
+realclean: clean
+	$(RM) $(TAGFILES)
diff --git a/freebsd/contrib/ptpd/src/arith.c b/freebsd/contrib/ptpd/src/arith.c
index 00000000..4c13d616
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/arith.c
@@ -0,0 +1,373 @@
+ * Copyright (c) 2012-2015 Wojciech Owczarek,
+ * Copyright (c) 2011-2012 George V. Neville-Neil,
+ *                         Steven Kreuzer,
+ *                         Martin Burnicki,
+ *                         Jan Breuer,
+ *                         Gael Mace,
+ *                         Alexandre Van Kempen,
+ *                         Inaqui Delgado,
+ *                         Rick Ratzel,
+ *                         National Instruments.
+ * Copyright (c) 2009-2010 George V. Neville-Neil,
+ *                         Steven Kreuzer,
+ *                         Jan Breuer,
+ *                         Gael Mace,
+ * Copyright (c) 2005-2008 Kendall Correll, Aidan Williams
+ * All Rights Reserved
+ * modification, are permitted provided that the following conditions are
+ * met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ *    this list of conditions and the following disclaimer.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE AUTHORS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
+ * BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
+ * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
+ * IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * @file   arith.c
+ * @date   Tue Jul 20 16:12:51 2010
+ * @brief  Time format conversion routines and additional math functions.
+#include "ptpd.h"
+void
+internalTime_to_integer64(TimeInternal internal, Integer64 *bigint)
+	int64_t scaledNanoseconds;
+	scaledNanoseconds = internal.seconds;
+	scaledNanoseconds *= 1000000000;
+	scaledNanoseconds += internal.nanoseconds;
+	scaledNanoseconds <<= 16;
+	bigint->msb = (scaledNanoseconds >> 32) & 0x00000000ffffffff;
+	bigint->lsb = scaledNanoseconds & 0x00000000ffffffff;
+void
+integer64_to_internalTime(Integer64 bigint, TimeInternal * internal)
+	int sign;
+	scaledNanoseconds = bigint.msb;
+	scaledNanoseconds <<=32;
+	scaledNanoseconds += bigint.lsb;
+	/*determine sign of result big integer number*/
+	if (scaledNanoseconds < 0) {
+		scaledNanoseconds = -scaledNanoseconds;
+		sign = -1;
+	} else {
+		sign = 1;
+	/*fractional nanoseconds are excluded (see 5.3.2)*/
+	scaledNanoseconds >>= 16;
+	internal->seconds = sign * (scaledNanoseconds / 1000000000);
+	internal->nanoseconds = sign * (scaledNanoseconds % 1000000000);
+void
+fromInternalTime(const TimeInternal * internal, Timestamp * external)
+	 * fromInternalTime is only used to convert time given by the system
+	 * to a timestamp.  As a consequence, no negative value can normally
+	 * be found in (internal)
+	 * Note that offsets are also represented with TimeInternal structure,
+	 * and can be negative, but offset are never convert into Timestamp
+	 * so there is no problem here.
+	if ((internal->seconds & ~INT_MAX) ||
+	    (internal->nanoseconds & ~INT_MAX)) {
+		DBG("Negative value canno't be converted into timestamp \n");
+		return;
+	} else {
+		external->secondsField.lsb = internal->seconds;
+		external->nanosecondsField = internal->nanoseconds;
+		external->secondsField.msb = 0;
+void
+toInternalTime(TimeInternal * internal, const Timestamp * external)
+	/* Program will not run after 2038... */
+	if (external->secondsField.lsb < INT_MAX) {
+		internal->seconds = external->secondsField.lsb;
+		internal->nanoseconds = external->nanosecondsField;
+	} else {
+		DBG("Clock servo canno't be executed : "
+		    "seconds field is higher than signed integer (32bits) \n");
+		return;
+void
+ts_to_InternalTime(const struct timespec *a,  TimeInternal * b)
+	b->seconds = a->tv_sec;
+	b->nanoseconds = a->tv_nsec;
+void
+tv_to_InternalTime(const struct timeval *a,  TimeInternal * b)
+	b->nanoseconds = a->tv_usec * 1000;
+void
+normalizeTime(TimeInternal * r)
+	r->seconds += r->nanoseconds / 1000000000;
+	r->nanoseconds -= (r->nanoseconds / 1000000000) * 1000000000;
+	if (r->seconds > 0 && r->nanoseconds < 0) {
+		r->seconds -= 1;
+		r->nanoseconds += 1000000000;
+	} else if (r->seconds < 0 && r->nanoseconds > 0) {
+		r->seconds += 1;
+		r->nanoseconds -= 1000000000;
+void
+addTime(TimeInternal * r, const TimeInternal * x, const TimeInternal * y)
+	r->seconds = x->seconds + y->seconds;
+	r->nanoseconds = x->nanoseconds + y->nanoseconds;
+	normalizeTime(r);
+void
+subTime(TimeInternal * r, const TimeInternal * x, const TimeInternal * y)
+	r->seconds = x->seconds - y->seconds;
+	r->nanoseconds = x->nanoseconds - y->nanoseconds;
+	normalizeTime(r);
+/// Divide an internal time value
+/// @param r the time to convert
+/// @param divisor
+#if 0
+/* TODO: this function could be simplified, as currently it is only called to halve the time */
+void
+divTime(TimeInternal *r, int divisor)
+	uint64_t nanoseconds;
+	if (divisor <= 0)
+		return;
+	nanoseconds = ((uint64_t)r->seconds * 1000000000) + r->nanoseconds;
+	nanoseconds /= divisor;
+	r->seconds = 0;
+	r->nanoseconds = nanoseconds;
+	normalizeTime(r);
+#endif
+void
+div2Time(TimeInternal *r)
+	r->nanoseconds += (r->seconds % 2) * 1000000000;
+	r->seconds /= 2;
+	r->nanoseconds /= 2;
+	normalizeTime(r);
+/* clear an internal time value */
+void
+clearTime(TimeInternal *r)
+	r->seconds     = 0;
+	r->nanoseconds = 0;
+/* sets a time value to a certain nanoseconds */
+void
+nano_to_Time(TimeInternal *x, int nano)
+	x->seconds     = 0;
+	x->nanoseconds = nano;
+	normalizeTime(x);
+/* greater than operation */
+int
+gtTime(const TimeInternal *x, const TimeInternal *y)
+	TimeInternal r;
+	subTime(&r, x, y);
+	return !isTimeInternalNegative(&r);
+/* remove sign from variable */
+void
+absTime(TimeInternal *r)
+	/* Make sure signs are the same */
+	normalizeTime(r);
+	r->seconds       = abs(r->seconds);
+	r->nanoseconds   = abs(r->nanoseconds);
+/* if 2 time values are close enough for X nanoseconds */
+int
+is_Time_close(const TimeInternal *x, const TimeInternal *y, int nanos)
+	TimeInternal r1;
+	TimeInternal r2;
+	// first, subtract the 2 values. then call abs(),
+	// then call gtTime for requested the number of nanoseconds
+	subTime(&r1, x, y);
+	absTime(&r1);
+	nano_to_Time(&r2, nanos);
+	return !gtTime(&r1, &r2);
+int
+check_timestamp_is_fresh2(const TimeInternal * timeA, const TimeInternal * timeB)
+	int ret;
+	// maximum 1 millisecond offset
+	ret = is_Time_close(timeA, timeB, 1000000);
+	DBG2("check_timestamp_is_fresh: %d\n ", ret);
+	return ret;
+int
+check_timestamp_is_fresh(const TimeInternal * timeA)
+	TimeInternal timeB;
+	getTime(&timeB);
+	return check_timestamp_is_fresh2(timeA, &timeB);
+int
+isTimeInternalNegative(const TimeInternal * p)
+	return (p->seconds < 0) || (p->nanoseconds < 0);
+double
+secondsToMidnight(void)
+	TimeInternal now;
+	double stm, ret;
+	getTime(&now);
+	stm = 86400.0 - (now.seconds % 86400);
+	ret =  (stm - now.nanoseconds / 1E9);
+	return ret;
+double
+getPauseAfterMidnight(Integer8 announceInterval, int pausePeriod)
+	double ai = pow(2,announceInterval);
+	if (pausePeriod > 2.0 * ai)
+		return (pausePeriod);
+	else
+		return (2.0 * ai);
+double
+timeInternalToDouble(const TimeInternal * p)
+	double sign = (p->seconds < 0 || p->nanoseconds < 0 ) ? -1.0 : 1.0;
+	return (sign * ( abs(p->seconds) + abs(p->nanoseconds) / 1E9 ));
+TimeInternal
+doubleToTimeInternal(const double d)
+	TimeInternal t = {0, 0};
+	t.seconds = trunc(d);
+	t.nanoseconds = (d - (t.seconds + 0.0)) * 1E9;
+	return t;
+/* FNV-1 hash, 32-bit, optional modulo limiter */
+uint32_t
+fnvHash(void *input, size_t len, int modulo)
+    int i = 0;
+    static uint32_t prime = 16777619;
+    static uint32_t basis = 2166136261;
+    uint32_t hash = basis;
+    uint8_t *buf = (uint8_t*)input;
+    for(i = 0; i < len; i++)  {
+        hash *= prime;
+        hash ^= *(buf + i);
+    return (modulo > 0 ? hash % modulo : hash);
diff --git a/freebsd/contrib/ptpd/src/bmc.c b/freebsd/contrib/ptpd/src/bmc.c
index 00000000..b5249aba
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/bmc.c
@@ -0,0 +1,779 @@
+ *                         Steven Kreuzer,
+ *                         Jan Breuer,
+ *                         Gael Mace,
+ *                         Inaqui Delgado,
+ *                         Rick Ratzel,
+ *                         Steven Kreuzer,
+ *                         Jan Breuer,
+ *                         Gael Mace,
+ * met:
+ * @file   bmc.c
+ * @date   Wed Jun 23 09:36:09 2010
+ * @brief  Best master clock selection code.
+ * The functions in this file are used by the daemon to select the
+ * best master clock from any number of possibilities.
+#include "ptpd.h"
+/* Init ptpClock with run time values (initialization constants are in constants.h)*/
+void initData(RunTimeOpts *rtOpts, PtpClock *ptpClock)
+	int i,j;
+	j=0;
+	DBG("initData\n");
+	/* Default data set */
+	ptpClock->defaultDS.twoStepFlag = TWO_STEP_FLAG;
+	 * init clockIdentity with MAC address and 0xFF and 0xFE. see
+	 * spec 7.5.2.2.2
+	for (i=0;i<CLOCK_IDENTITY_LENGTH;i++)
+		if (i==3) ptpClock->defaultDS.clockIdentity[i]=0xFF;
+		else if (i==4) ptpClock->defaultDS.clockIdentity[i]=0xFE;
+		else
+		  ptpClock->defaultDS.clockIdentity[i]=ptpClock->netPath.interfaceID[j];
+		  j++;
+	ptpClock->portDS.lastMismatchedDomain = -1;
+	if(rtOpts->pidAsClockId) {
+	    uint16_t pid = htons(getpid());
+	    memcpy(ptpClock->defaultDS.clockIdentity + 3, &pid, 2);
+	ptpClock->bestMaster = NULL;
+	ptpClock->defaultDS.numberPorts = NUMBER_PORTS;
+	ptpClock->disabled = rtOpts->portDisabled;
+	memset(ptpClock->userDescription, 0, sizeof(ptpClock->userDescription));
+	memcpy(ptpClock->userDescription, rtOpts->portDescription, strlen(rtOpts->portDescription));
+	memset(&ptpClock->profileIdentity,0,6);
+	if(rtOpts->ipMode == IPMODE_UNICAST && rtOpts->unicastNegotiation) {
+		memcpy(&ptpClock->profileIdentity, &PROFILE_ID_TELECOM,6);
+	if(rtOpts->ipMode == IPMODE_MULTICAST &&rtOpts->delayMechanism == E2E) {
+		memcpy(&ptpClock->profileIdentity, &PROFILE_ID_DEFAULT_E2E,6);
+	if(rtOpts->ipMode == IPMODE_MULTICAST &&rtOpts->delayMechanism == P2P) {
+		memcpy(&ptpClock->profileIdentity, &PROFILE_ID_DEFAULT_P2P,6);
+	if(rtOpts->dot1AS) {
+		memcpy(&ptpClock->profileIdentity, &PROFILE_ID_802_1AS,6);
+	ptpClock->defaultDS.clockQuality.clockAccuracy =
+		rtOpts->clockQuality.clockAccuracy;
+	ptpClock->defaultDS.clockQuality.clockClass = rtOpts->clockQuality.clockClass;
+	ptpClock->defaultDS.clockQuality.offsetScaledLogVariance =
+		rtOpts->clockQuality.offsetScaledLogVariance;
+	ptpClock->defaultDS.priority1 = rtOpts->priority1;
+	ptpClock->defaultDS.priority2 = rtOpts->priority2;
+	ptpClock->defaultDS.domainNumber = rtOpts->domainNumber;
+	if(rtOpts->slaveOnly) {
+		ptpClock->defaultDS.slaveOnly = TRUE;
+		rtOpts->clockQuality.clockClass = SLAVE_ONLY_CLOCK_CLASS;
+		ptpClock->defaultDS.clockQuality.clockClass = SLAVE_ONLY_CLOCK_CLASS;
+/* Port configuration data set */
+	 * PortIdentity Init (portNumber = 1 for an ardinary clock spec
+	 * 7.5.2.3)
+	copyClockIdentity(ptpClock->portDS.portIdentity.clockIdentity,
+			ptpClock->defaultDS.clockIdentity);
+	ptpClock->portDS.portIdentity.portNumber = rtOpts->portNumber;
+	/* select the initial rate of delayreqs until we receive the first announce message */
+	ptpClock->portDS.logMinDelayReqInterval = rtOpts->initial_delayreq;
+	clearTime(&ptpClock->portDS.peerMeanPathDelay);
+	ptpClock->portDS.logAnnounceInterval = rtOpts->logAnnounceInterval;
+	ptpClock->portDS.announceReceiptTimeout = rtOpts->announceReceiptTimeout;
+	ptpClock->portDS.logSyncInterval = rtOpts->logSyncInterval;
+	ptpClock->portDS.delayMechanism = rtOpts->delayMechanism;
+	ptpClock->portDS.logMinPdelayReqInterval = rtOpts->logMinPdelayReqInterval;
+	ptpClock->portDS.versionNumber = VERSION_PTP;
+	    ptpClock->portDS.transportSpecific = TSP_ETHERNET_AVB;
+	} else {
+	    ptpClock->portDS.transportSpecific = TSP_DEFAULT;
+	 *  Initialize random number generator using same method as ptpv1:
+	 *  seed is now initialized from the last bytes of our mac addres (collected in net.c:findIface())
+	srand((ptpClock->netPath.interfaceID[PTP_UUID_LENGTH - 1] << 8) +
+	    ptpClock->netPath.interfaceID[PTP_UUID_LENGTH - 2]);
+	/*Init other stuff*/
+	ptpClock->number_foreign_records = 0;
+  	ptpClock->max_foreign_records = rtOpts->max_foreign_records;
+/* memcmp behaviour: -1: a<b, 1: a>b, 0: a=b */
+int
+cmpPortIdentity(const PortIdentity *a, const PortIdentity *b)
+    int comp;
+    /* compare clock identity first */
+    comp = memcmp(a->clockIdentity, b->clockIdentity, CLOCK_IDENTITY_LENGTH);
+    if(comp !=0) {
+	return comp;
+    /* then compare portNumber */
+    if(a->portNumber > b->portNumber) {
+	return 1;
+    if(a->portNumber < b->portNumber) {
+	return -1;
+    return 0;
+/* compare portIdentity to an empty one */
+Boolean portIdentityEmpty(PortIdentity *portIdentity) {
+    PortIdentity zero;
+    memset(&zero, 0, sizeof(PortIdentity));
+    if (!cmpPortIdentity(portIdentity, &zero)) {
+	return TRUE;
+    return FALSE;
+/* compare portIdentity to all ones port identity */
+Boolean portIdentityAllOnes(PortIdentity *portIdentity) {
+    PortIdentity allOnes;
+    memset(&allOnes, 0xFF, sizeof(PortIdentity));
+    if (!cmpPortIdentity(portIdentity, &allOnes)) {
+        return TRUE;
+    return FALSE;
+/*Local clock is becoming Master. Table 13 (9.3.5) of the spec.*/
+void m1(const RunTimeOpts *rtOpts, PtpClock *ptpClock)
+	/*Current data set update*/
+	ptpClock->currentDS.stepsRemoved = 0;
+	clearTime(&ptpClock->currentDS.offsetFromMaster);
+	clearTime(&ptpClock->currentDS.meanPathDelay);
+	copyClockIdentity(ptpClock->parentDS.parentPortIdentity.clockIdentity,
+	ptpClock->parentDS.parentPortIdentity.portNumber = ptpClock->portDS.portIdentity.portNumber;
+	ptpClock->parentDS.parentStats = DEFAULT_PARENTS_STATS;
+	ptpClock->parentDS.observedParentClockPhaseChangeRate = 0;
+	ptpClock->parentDS.observedParentOffsetScaledLogVariance = 0;
+	copyClockIdentity(ptpClock->parentDS.grandmasterIdentity,
+	ptpClock->parentDS.grandmasterClockQuality.clockAccuracy =
+		ptpClock->defaultDS.clockQuality.clockAccuracy;
+	ptpClock->parentDS.grandmasterClockQuality.clockClass =
+		ptpClock->defaultDS.clockQuality.clockClass;
+	ptpClock->parentDS.grandmasterClockQuality.offsetScaledLogVariance =
+		ptpClock->defaultDS.clockQuality.offsetScaledLogVariance;
+	ptpClock->parentDS.grandmasterPriority1 = ptpClock->defaultDS.priority1;
+	ptpClock->parentDS.grandmasterPriority2 = ptpClock->defaultDS.priority2;
+        ptpClock->portDS.logMinDelayReqInterval = rtOpts->logMinDelayReqInterval;
+	/*Time Properties data set*/
+	ptpClock->timePropertiesDS.currentUtcOffsetValid = rtOpts->timeProperties.currentUtcOffsetValid;
+	ptpClock->timePropertiesDS.currentUtcOffset = rtOpts->timeProperties.currentUtcOffset;
+	ptpClock->timePropertiesDS.timeTraceable = rtOpts->timeProperties.timeTraceable;
+	ptpClock->timePropertiesDS.frequencyTraceable = rtOpts->timeProperties.frequencyTraceable;
+	ptpClock->timePropertiesDS.ptpTimescale = rtOpts->timeProperties.ptpTimescale;
+	ptpClock->timePropertiesDS.timeSource = rtOpts->timeProperties.timeSource;
+	if(ptpClock->timePropertiesDS.ptpTimescale &&
+	    (secondsToMidnight() < rtOpts->leapSecondNoticePeriod)) {
+	    ptpClock->timePropertiesDS.leap59 = ptpClock->clockStatus.leapDelete;
+	    ptpClock->timePropertiesDS.leap61 = ptpClock->clockStatus.leapInsert;
+	} else {
+	    ptpClock->timePropertiesDS.leap59 = FALSE;
+	    ptpClock->timePropertiesDS.leap61 = FALSE;
+/* first cut on a passive mode specific BMC actions */
+void p1(PtpClock *ptpClock, const RunTimeOpts *rtOpts)
+	/* make sure we revert to ARB timescale in Passive mode*/
+	if(ptpClock->portDS.portState == PTP_PASSIVE){
+/*Local clock is synchronized to Ebest Table 16 (9.3.5) of the spec*/
+void s1(MsgHeader *header,MsgAnnounce *announce,PtpClock *ptpClock, const RunTimeOpts *rtOpts)
+	Boolean firstUpdate = !cmpPortIdentity(&ptpClock->parentDS.parentPortIdentity, &ptpClock->portDS.portIdentity);
+	TimePropertiesDS tpPrevious = ptpClock->timePropertiesDS;
+	Boolean previousLeap59 = FALSE;
+	Boolean previousLeap61 = FALSE;
+	Boolean leapChange = FALSE;
+	Integer16 previousUtcOffset = 0;
+	previousLeap59 = ptpClock->timePropertiesDS.leap59;
+	previousLeap61 = ptpClock->timePropertiesDS.leap61;
+	previousUtcOffset = ptpClock->timePropertiesDS.currentUtcOffset;
+	/* Current DS */
+	ptpClock->currentDS.stepsRemoved = announce->stepsRemoved + 1;
+	/* Parent DS */
+	       header->sourcePortIdentity.clockIdentity);
+		header->sourcePortIdentity.portNumber;
+			announce->grandmasterIdentity);
+		announce->grandmasterClockQuality.clockAccuracy;
+		announce->grandmasterClockQuality.clockClass;
+		announce->grandmasterClockQuality.offsetScaledLogVariance;
+	ptpClock->parentDS.grandmasterPriority1 = announce->grandmasterPriority1;
+	ptpClock->parentDS.grandmasterPriority2 = announce->grandmasterPriority2;
+	/* use the granted interval if using signaling, otherwise we would try to arm a timer for 2^127! */
+	if(rtOpts->unicastNegotiation && ptpClock->parentGrants != NULL && ptpClock->parentGrants->grantData[ANNOUNCE_INDEXED].granted) {
+            ptpClock->portDS.logAnnounceInterval = ptpClock->parentGrants->grantData[ANNOUNCE_INDEXED].logInterval;
+        } else if (header->logMessageInterval != UNICAST_MESSAGEINTERVAL) {
+    	    ptpClock->portDS.logAnnounceInterval = header->logMessageInterval;
+	/* Timeproperties DS */
+	ptpClock->timePropertiesDS.currentUtcOffset = announce->currentUtcOffset;
+	if (ptpClock->portDS.portState != PTP_PASSIVE && ptpClock->timePropertiesDS.currentUtcOffsetValid &&
+			!IS_SET(header->flagField1, UTCV)) {
+		if(rtOpts->alwaysRespectUtcOffset)
+			WARNING("UTC Offset no longer valid and ptpengine:always_respect_utc_offset is set: continuing as normal\n");
+		else
+			WARNING("UTC Offset no longer valid - clock jump expected\n");
+        /* "Valid" is bit 2 in second octet of flagfield */
+        ptpClock->timePropertiesDS.currentUtcOffsetValid = IS_SET(header->flagField1, UTCV);
+	/* set PTP_PASSIVE-specific state */
+	p1(ptpClock, rtOpts);
+	/* only set leap flags in slave state - info from leap file takes priority*/
+	if (ptpClock->portDS.portState == PTP_SLAVE) {
+	    if(ptpClock->clockStatus.override) {
+		ptpClock->timePropertiesDS.currentUtcOffset = ptpClock->clockStatus.utcOffset;
+	    } else {
+		ptpClock->timePropertiesDS.leap59 = IS_SET(header->flagField1, LI59);
+		ptpClock->timePropertiesDS.leap61 = IS_SET(header->flagField1, LI61);
+        ptpClock->timePropertiesDS.timeTraceable = IS_SET(header->flagField1, TTRA);
+        ptpClock->timePropertiesDS.frequencyTraceable = IS_SET(header->flagField1, FTRA);
+        ptpClock->timePropertiesDS.ptpTimescale = IS_SET(header->flagField1, PTPT);
+        ptpClock->timePropertiesDS.timeSource = announce->timeSource;
+	/* if Announce was accepted from some domain, so be it */
+	if(rtOpts->anyDomain || rtOpts->unicastNegotiation) {
+	    ptpClock->defaultDS.domainNumber = header->domainNumber;
+	 * tell the clock source to update TAI offset, but only if timescale is
+	 * PTP not ARB - spec section 7.2
+        if (ptpClock->timePropertiesDS.ptpTimescale &&
+	    (ptpClock->timePropertiesDS.currentUtcOffsetValid || rtOpts->alwaysRespectUtcOffset) &&
+            (ptpClock->timePropertiesDS.currentUtcOffset != previousUtcOffset)) {
+	      INFO("UTC offset is now %d\n",
+		    ptpClock->timePropertiesDS.currentUtcOffset);
+		ptpClock->clockStatus.utcOffset = ptpClock->timePropertiesDS.currentUtcOffset;
+		ptpClock->clockStatus.update = TRUE;
+	if(!firstUpdate && memcmp(&tpPrevious,&ptpClock->timePropertiesDS, sizeof(TimePropertiesDS))) {
+	    /* this is an event - will be picked up and dispatched, no need to set false */
+	    SET_ALARM(ALRM_TIMEPROP_CHANGE, TRUE);
+	/* non-slave logic done, exit if not slave */
+        if (ptpClock->portDS.portState != PTP_SLAVE) {
+		return;
+	/* Leap second handling */
+	if(ptpClock->timePropertiesDS.leap59 && ptpClock->timePropertiesDS.leap61) {
+		DBG("Both Leap59 and Leap61 flags set!\n");
+		ptpClock->counters.protocolErrors++;
+		return;
+	/* One of the flags has been cleared */
+	leapChange = ((previousLeap59 && !ptpClock->timePropertiesDS.leap59) ||
+            		    (previousLeap61 && !ptpClock->timePropertiesDS.leap61));
+	if(ptpClock->leapSecondPending && leapChange && !ptpClock->leapSecondInProgress) {
+		WARNING("Leap second event aborted by GM!\n");
+		ptpClock->leapSecondPending = FALSE;
+		ptpClock->leapSecondInProgress = FALSE;
+		timerStop(&ptpClock->timers[LEAP_SECOND_PAUSE_TIMER]);
+		ptpClock->clockStatus.leapInsert = FALSE;
+		ptpClock->clockStatus.leapDelete = FALSE;
+	 * one of the leap second flags is lit
+	 * but we have no event pending
+	/* changes in flags while not waiting for leap second */
+	if(!ptpClock->leapSecondPending &&  !ptpClock->leapSecondInProgress) {
+	    if(rtOpts->leapSecondHandling == LEAP_ACCEPT) {
+		ptpClock->clockStatus.leapInsert = ptpClock->timePropertiesDS.leap61;
+		ptpClock->clockStatus.leapDelete = ptpClock->timePropertiesDS.leap59;
+		if(ptpClock->timePropertiesDS.leap61 || ptpClock->timePropertiesDS.leap59) {
+		    /* only set the flag, the rest happens in doState() */
+		    ptpClock->leapSecondPending = TRUE;
+	/* UTC offset has changed */
+	if(previousUtcOffset != ptpClock->timePropertiesDS.currentUtcOffset) {
+		WARNING("UTC offset changed from %d to %d with "
+			 "no leap second pending!\n",
+				previousUtcOffset,
+	    } else {
+			WARNING("UTC offset changed from %d to %d\n",
+				previousUtcOffset,ptpClock->timePropertiesDS.currentUtcOffset);
+/*Copy local data set into header and announce message. 9.3.4 table 12*/
+static void
+copyD0(MsgHeader *header, MsgAnnounce *announce, PtpClock *ptpClock)
+	announce->grandmasterPriority1 = ptpClock->defaultDS.priority1;
+	copyClockIdentity(announce->grandmasterIdentity,
+	announce->grandmasterClockQuality.clockClass =
+	announce->grandmasterClockQuality.clockAccuracy =
+	announce->grandmasterClockQuality.offsetScaledLogVariance =
+	announce->grandmasterPriority2 = ptpClock->defaultDS.priority2;
+	announce->stepsRemoved = 0;
+	copyClockIdentity(header->sourcePortIdentity.clockIdentity,
+	/* Copy TimePropertiesDS into FlagField1 */
+        header->flagField1 = ptpClock->timePropertiesDS.leap61			<< 0;
+        header->flagField1 |= ptpClock->timePropertiesDS.leap59			<< 1;
+        header->flagField1 |= ptpClock->timePropertiesDS.currentUtcOffsetValid	<< 2;
+        header->flagField1 |= ptpClock->timePropertiesDS.ptpTimescale		<< 3;
+        header->flagField1 |= ptpClock->timePropertiesDS.timeTraceable		<< 4;
+        header->flagField1 |= ptpClock->timePropertiesDS.frequencyTraceable	<< 5;
+/*Data set comparison bewteen two foreign masters (9.3.4 fig 27)
+ * return similar to memcmp() */
+static Integer8
+bmcDataSetComparison(const ForeignMasterRecord *a, const ForeignMasterRecord *b, const PtpClock *ptpClock, const RunTimeOpts *rtOpts)
+	DBGV("Data set comparison \n");
+	short comp = 0;
+	/* disqualification comes above anything else */
+	if(a->disqualified > b->disqualified) {
+	    return -1;
+	if(a->disqualified < b->disqualified) {
+	    return 1;
+	/*Identity comparison*/
+	comp = memcmp(a->announce.grandmasterIdentity,b->announce.grandmasterIdentity,CLOCK_IDENTITY_LENGTH);
+	if (comp!=0)
+		goto dataset_comp_part_1;
+	  /* Algorithm part2 Fig 28 */
+	if (a->announce.stepsRemoved > b->announce.stepsRemoved+1)
+		return 1;
+	if (a->announce.stepsRemoved+1 < b->announce.stepsRemoved)
+		return -1;
+	/* A within 1 of B */
+	if (a->announce.stepsRemoved > b->announce.stepsRemoved) {
+		comp = memcmp(a->header.sourcePortIdentity.clockIdentity,ptpClock->parentDS.parentPortIdentity.clockIdentity,CLOCK_IDENTITY_LENGTH);
+		if(comp < 0)
+			return -1;
+		if(comp > 0)
+			return 1;
+		DBG("Sender=Receiver : Error -1");
+		return 0;
+	if (a->announce.stepsRemoved < b->announce.stepsRemoved) {
+		comp = memcmp(b->header.sourcePortIdentity.clockIdentity,ptpClock->parentDS.parentPortIdentity.clockIdentity,CLOCK_IDENTITY_LENGTH);
+		if(comp < 0)
+			return -1;
+		if(comp > 0)
+			return 1;
+		return 0;
+	/*  steps removed A = steps removed B */
+	comp = memcmp(a->header.sourcePortIdentity.clockIdentity,b->header.sourcePortIdentity.clockIdentity,CLOCK_IDENTITY_LENGTH);
+	if (comp<0) {
+		return -1;
+	if (comp>0) {
+		return 1;
+	/* identity A = identity B */
+	if (a->header.sourcePortIdentity.portNumber < b->header.sourcePortIdentity.portNumber)
+		return -1;
+	if (a->header.sourcePortIdentity.portNumber > b->header.sourcePortIdentity.portNumber)
+		return 1;
+	DBG("Sender=Receiver : Error -2");
+	return 0;
+	  /* Algorithm part 1 Fig 27 */
+dataset_comp_part_1:
+	/* OPTIONAL domain comparison / any domain */
+	if(rtOpts->anyDomain) {
+	    /* part 1: preferred domain wins */
+	    if(a->header.domainNumber == rtOpts->domainNumber && b->header.domainNumber != ptpClock->defaultDS.domainNumber)
+		return -1;
+	    if(a->header.domainNumber != rtOpts->domainNumber && b->header.domainNumber == ptpClock->defaultDS.domainNumber)
+		return 1;
+	    /* part 2: lower domain wins */
+	    if(a->header.domainNumber < b->header.domainNumber)
+		return -1;
+	    if(a->header.domainNumber > b->header.domainNumber)
+		return 1;
+	/* Compare localPreference - only used by slaves when using unicast negotiation */
+	DBGV("bmcDataSetComparison a->localPreference: %d, b->localPreference: %d\n", a->localPreference, b->localPreference);
+	if(a->localPreference < b->localPreference) {
+	    return -1;
+	if(a->localPreference > b->localPreference) {
+	    return 1;
+	/* Compare GM priority1 */
+	if (a->announce.grandmasterPriority1 < b->announce.grandmasterPriority1)
+		return -1;
+	if (a->announce.grandmasterPriority1 > b->announce.grandmasterPriority1)
+		return 1;
+	/* non-standard BMC extension to prioritise GMs with UTC valid */
+	if(rtOpts->preferUtcValid) {
+		Boolean utcA = IS_SET(a->header.flagField1, UTCV);
+		Boolean utcB = IS_SET(b->header.flagField1, UTCV);
+		if(utcA > utcB)
+			return -1;
+		if(utcA < utcB)
+			return 1;
+	/* Compare GM class */
+	if (a->announce.grandmasterClockQuality.clockClass <
+			b->announce.grandmasterClockQuality.clockClass)
+		return -1;
+	if (a->announce.grandmasterClockQuality.clockClass >
+		return 1;
+	/* Compare GM accuracy */
+	if (a->announce.grandmasterClockQuality.clockAccuracy <
+			b->announce.grandmasterClockQuality.clockAccuracy)
+		return -1;
+	if (a->announce.grandmasterClockQuality.clockAccuracy >
+		return 1;
+	/* Compare GM offsetScaledLogVariance */
+	if (a->announce.grandmasterClockQuality.offsetScaledLogVariance <
+			b->announce.grandmasterClockQuality.offsetScaledLogVariance)
+		return -1;
+	if (a->announce.grandmasterClockQuality.offsetScaledLogVariance >
+		return 1;
+	/* Compare GM priority2 */
+	if (a->announce.grandmasterPriority2 < b->announce.grandmasterPriority2)
+		return -1;
+	if (a->announce.grandmasterPriority2 > b->announce.grandmasterPriority2)
+		return 1;
+	/* Compare GM identity */
+	if (comp < 0)
+		return -1;
+	else if (comp > 0)
+		return 1;
+	return 0;
+/*State decision algorithm 9.3.3 Fig 26*/
+static UInteger8
+bmcStateDecision(ForeignMasterRecord *foreign, const RunTimeOpts *rtOpts, PtpClock *ptpClock)
+	Integer8 comp;
+	Boolean newBM;
+	ForeignMasterRecord me;
+	memset(&me, 0, sizeof(me));
+	me.localPreference = LOWEST_LOCALPREFERENCE;
+	newBM = ((memcmp(foreign->header.sourcePortIdentity.clockIdentity,
+			    ptpClock->parentDS.parentPortIdentity.clockIdentity,CLOCK_IDENTITY_LENGTH)) ||
+		(foreign->header.sourcePortIdentity.portNumber != ptpClock->parentDS.parentPortIdentity.portNumber));
+	if (ptpClock->defaultDS.slaveOnly) {
+		/* master has changed: mark old grants for cancellation - refreshUnicastGrants will pick this up */
+		if(newBM && (ptpClock->parentGrants != NULL)) {
+		    ptpClock->previousGrants = ptpClock->parentGrants;
+		s1(&foreign->header,&foreign->announce,ptpClock, rtOpts);
+		if(rtOpts->unicastNegotiation) {
+			ptpClock->parentGrants = findUnicastGrants(&ptpClock->parentDS.parentPortIdentity, 0,
+						ptpClock->unicastGrants, &ptpClock->grantIndex, ptpClock->unicastDestinationCount,
+					    FALSE);
+		if (newBM) {
+		/* New BM #1 */
+			SET_ALARM(ALRM_MASTER_CHANGE, TRUE);
+			displayPortIdentity(&foreign->header.sourcePortIdentity,
+					    "New best master selected:");
+			ptpClock->counters.bestMasterChanges++;
+				displayStatus(ptpClock, "State: ");
+				if(rtOpts->calibrationDelay) {
+					ptpClock->isCalibrated = FALSE;
+					timerStart(&ptpClock->timers[CALIBRATION_DELAY_TIMER], rtOpts->calibrationDelay);
+                if(rtOpts->unicastNegotiation && ptpClock->parentGrants != NULL) {
+			me.localPreference = ptpClock->parentGrants->localPreference;
+		return PTP_SLAVE;
+	if ((!ptpClock->number_foreign_records) &&
+	    (ptpClock->portDS.portState == PTP_LISTENING))
+		return PTP_LISTENING;
+//	copyD0(&me.headerk->msgTmpHeader,&ptpClock->msgTmp.announce,ptpClock);
+	copyD0(&me.header, &me.announce, ptpClock);
+	DBGV("local clockQuality.clockClass: %d \n", ptpClock->defaultDS.clockQuality.clockClass);
+	comp = bmcDataSetComparison(&me, foreign, ptpClock, rtOpts);
+	if (ptpClock->defaultDS.clockQuality.clockClass < 128) {
+		if (comp < 0) {
+			m1(rtOpts, ptpClock);
+			return PTP_MASTER;
+		} else if (comp > 0) {
+			s1(&foreign->header, &foreign->announce, ptpClock, rtOpts);
+			if (newBM) {
+			/* New BM #2 */
+			return PTP_PASSIVE;
+		} else {
+			DBG("Error in bmcDataSetComparison..\n");
+	} else {
+		if (comp < 0) {
+			m1(rtOpts,ptpClock);
+			s1(&foreign->header, &foreign->announce,ptpClock, rtOpts);
+			if (newBM) {
+			/* New BM #3 */
+				if(ptpClock->portDS.portState == PTP_SLAVE)
+			return PTP_SLAVE;
+		} else {
+	/*  MB: Is this the return code below correct? */
+	/*  Anyway, it's a valid return code. */
+	return PTP_FAULTY;
+UInteger8
+bmc(ForeignMasterRecord *foreignMaster,
+    const RunTimeOpts *rtOpts, PtpClock *ptpClock)
+	Integer16 i,best;
+	DBGV("number_foreign_records : %d \n", ptpClock->number_foreign_records);
+	if (!ptpClock->number_foreign_records)
+		if (ptpClock->portDS.portState == PTP_MASTER)	{
+			return ptpClock->portDS.portState;
+	for (i=1,best = 0; i<ptpClock->number_foreign_records;i++)
+		if ((bmcDataSetComparison(&foreignMaster[i], &foreignMaster[best],
+					  ptpClock, rtOpts)) < 0)
+			best = i;
+	DBGV("Best record : %d \n",best);
+	ptpClock->foreign_record_best = best;
+	ptpClock->bestMaster = &foreignMaster[best];
+	return (bmcStateDecision(ptpClock->bestMaster,
+				 rtOpts,ptpClock));
diff --git a/freebsd/contrib/ptpd/src/constants.h b/freebsd/contrib/ptpd/src/constants.h
index 00000000..4bb6d2a6
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/constants.h
@@ -0,0 +1,470 @@
+#ifndef CONSTANTS_H_
+#define CONSTANTS_H_
+*\file
+* \brief Default values and constants used in ptpdv2
+* This header file includes all default values used during initialization
+* and enumeration defined in the spec
+#define PTPD_PROGNAME "ptpd2"
+/* FIXME: make these parameterized, either through command-line options or make variables */
+/* wowczarek at 25oct15: fixed: product description suffix is variables:product_description */
+/* user description is ptpengine:port_description */
+#define MANUFACTURER_ID_OUI0 \
+  0xFF
+#define MANUFACTURER_ID_OUI1 \
+  0xFF
+#define MANUFACTURER_ID_OUI2 \
+  0xFF
+#define PROTOCOL \
+  "IEEE 802.3"
+#define PRODUCT_DESCRIPTION \
+  "ptpd;"PACKAGE_VERSION";%s"
+#ifndef PTPD_SLAVE_ONLY
+#define USER_VERSION \
+  PACKAGE_VERSION
+#else
+  PACKAGE_VERSION"-slaveonly"
+#endif /* PTPD_SLAVE_ONLY */
+#define REVISION \
+  ";;"USER_VERSION""
+#define PROFILE_ID_DEFAULT_E2E "\x00\x1B\x19\x00\x01\x00"
+#define PROFILE_ID_DEFAULT_P2P "\x00\x1B\x19\x00\x02\x00"
+#define PROFILE_ID_TELECOM     "\x00\x19\xA7\x00\x01\x02"
+#define PROFILE_ID_802_1AS     "\x00\x80\xC2\x00\x01\x00"
+#define USER_DESCRIPTION \
+  "PTPd"
+#define USER_DESCRIPTION_MAX 128
+/* implementation specific constants */
+#define DEFAULT_INBOUND_LATENCY      	0       /* in nsec */
+#define DEFAULT_OUTBOUND_LATENCY     	0       /* in nsec */
+#define DEFAULT_NO_RESET_CLOCK       	FALSE
+#define DEFAULT_DOMAIN_NUMBER        	0
+#define DEFAULT_DELAY_MECHANISM      	E2E     // TODO
+#define DEFAULT_AP                   	10
+#define DEFAULT_AI                   	1000
+#define DEFAULT_DELAY_S              	6
+#define DEFAULT_ANNOUNCE_INTERVAL    	1      /* 0 in 802.1AS */
+/* Master mode operates in ARB (UTC) timescale, without TAI+leap seconds */
+#define DEFAULT_UTC_OFFSET           	0
+#define DEFAULT_UTC_VALID            	FALSE
+#define DEFAULT_PDELAYREQ_INTERVAL   	1      /* -4 in 802.1AS */
+#define DEFAULT_DELAYREQ_INTERVAL    	0      /* new value from page 237 of the standard */
+#define DEFAULT_SYNC_INTERVAL        	0      /* -7 in 802.1AS */  /* from page 237 of the standard */
+/* number of announces we need to lose until a time out occurs. Thus it is 12 seconds */
+#define DEFAULT_ANNOUNCE_RECEIPT_TIMEOUT 6     /* 3 by default */
+#define DEFAULT_FAILURE_WAITTIME	10     /* sleep for 10 seconds on failure once operational */
+#define DEFAULT_QUALIFICATION_TIMEOUT	2
+#define DEFAULT_FOREIGN_MASTER_TIME_WINDOW 4
+#define DEFAULT_FOREIGN_MASTER_THRESHOLD 2
+/* g.8265.1 local preference, lowest value */
+#define LOWEST_LOCALPREFERENCE 255
+section 7.6.2.4, page 55:
+248     Default. This clockClass shall be used if none of the other clockClass definitions apply.
+13      Shall designate a clock that is synchronized to an application-specific source of time. The timescale distributed
+        shall be ARB. A clockClass 13 clock shall not be a slave to another clock in the domain.
+#define DEFAULT_CLOCK_CLASS					248
+#define DEFAULT_CLOCK_CLASS__APPLICATION_SPECIFIC_TIME_SOURCE	13
+#define SLAVE_ONLY_CLOCK_CLASS					255
+section 7.6.2.5, page 56:
+0x20      Time accurate to 25ns
+0x31      Time accurate to > 10s
+0xFE      Unkown accuracy
+#define DEFAULT_CLOCK_ACCURACY		0xFE
+#define DEFAULT_PRIORITY1		128
+#define DEFAULT_PRIORITY2		128        /* page 238, default priority is the midpoint, to allow easy control of the BMC algorithm */
+/* page 238:  τ, see 7.6.3.2: The default initialization value shall be 1.0 s.  */
+//#define DEFAULT_CLOCK_VARIANCE 	        28768 /* To be determined in 802.1AS. */
+#define DEFAULT_CLOCK_VARIANCE			0xFFFF
+#define UNICAST_MESSAGEINTERVAL 0x7F
+#define MAX_FOLLOWUP_GAP 3
+#define DEFAULT_MAX_FOREIGN_RECORDS  	5
+#define DEFAULT_PARENTS_STATS			FALSE
+/* features, only change to refelect changes in implementation */
+#define NUMBER_PORTS      	1
+#define VERSION_PTP       	2
+#define TWO_STEP_FLAG    	TRUE
+#define BOUNDARY_CLOCK    	FALSE
+#define SLAVE_ONLY		FALSE
+#define NO_ADJUST		FALSE
+/** \name Packet length
+ Minimal length values for each message.
+ If TLV used length could be higher.*/
+#define HEADER_LENGTH					34
+#define ANNOUNCE_LENGTH					64
+#define SYNC_LENGTH					44
+#define FOLLOW_UP_LENGTH				44
+#define PDELAY_REQ_LENGTH				54
+#define DELAY_REQ_LENGTH				44
+#define DELAY_RESP_LENGTH				54
+#define PDELAY_RESP_LENGTH 				54
+#define PDELAY_RESP_FOLLOW_UP_LENGTH  			54
+#define MANAGEMENT_LENGTH				48
+#define SIGNALING_LENGTH				44
+#define TLV_LENGTH					6
+#define TL_LENGTH					4
+/*Enumeration defined in tables of the spec*/
+ * \brief Domain Number (Table 2 in the spec)*/
+enum {
+	DFLT_DOMAIN_NUMBER = 0, ALT1_DOMAIN_NUMBER, ALT2_DOMAIN_NUMBER, ALT3_DOMAIN_NUMBER
+ * \brief Network Protocol  (Table 3 in the spec)*/
+enum {
+	UDP_IPV4=1,UDP_IPV6,IEEE_802_3,DeviceNet,ControlNet,PROFINET
+ * \brief Time Source (Table 7 in the spec)*/
+enum {
+	ATOMIC_CLOCK=0x10,GPS=0x20,TERRESTRIAL_RADIO=0x30,PTP=0x40,NTP=0x50,HAND_SET=0x60,OTHER=0x90,INTERNAL_OSCILLATOR=0xA0
+ * \brief Delay mechanism (Table 9 in the spec)*/
+enum {
+	E2E=1,P2P=2,DELAY_DISABLED=0xFE
+/* clock accuracy constant definitions (table 6) */
+enum {
+	ACC_25NS	= 0x20,
+	ACC_100NS 	= 0x21,
+	ACC_250NS	= 0x22,
+	ACC_1US		= 0x23,
+	ACC_2_5US	= 0x24,
+	ACC_10US	= 0x25,
+	ACC_25US	= 0x26,
+	ACC_100US	= 0x27,
+	ACC_250US	= 0x28,
+	ACC_1MS		= 0x29,
+	ACC_2_5MS	= 0x2A,
+	ACC_10MS	= 0x2B,
+	ACC_25MS	= 0x2C,
+	ACC_100MS	= 0x2D,
+	ACC_250MS	= 0x2E,
+	ACC_1S		= 0x2F,
+	ACC_10S		= 0x30,
+	ACC_10SPLUS	= 0x31,
+	ACC_UNKNOWN	= 0xFE
+ * \brief PTP Management Message managementId values (Table 40 in the spec)
+/* SLAVE_ONLY conflicts with another constant, so scope with MM_ */
+enum {
+	/* Applicable to all node types */
+	MM_NULL_MANAGEMENT=0x0000,
+	MM_CLOCK_DESCRIPTION=0x0001,
+	MM_USER_DESCRIPTION=0x0002,
+	MM_SAVE_IN_NON_VOLATILE_STORAGE=0x0003,
+	MM_RESET_NON_VOLATILE_STORAGE=0x0004,
+	MM_INITIALIZE=0x0005,
+	MM_FAULT_LOG=0x0006,
+	MM_FAULT_LOG_RESET=0x0007,
+	/* Reserved: 0x0008 - 0x1FFF */
+	/* Applicable to ordinary and boundary clocks */
+	MM_DEFAULT_DATA_SET=0x2000,
+	MM_CURRENT_DATA_SET=0x2001,
+	MM_PARENT_DATA_SET=0x2002,
+	MM_TIME_PROPERTIES_DATA_SET=0x2003,
+	MM_PORT_DATA_SET=0x2004,
+	MM_PRIORITY1=0x2005,
+	MM_PRIORITY2=0x2006,
+	MM_DOMAIN=0x2007,
+	MM_SLAVE_ONLY=0x2008,
+	MM_LOG_ANNOUNCE_INTERVAL=0x2009,
+	MM_ANNOUNCE_RECEIPT_TIMEOUT=0x200A,
+	MM_LOG_SYNC_INTERVAL=0x200B,
+	MM_VERSION_NUMBER=0x200C,
+	MM_ENABLE_PORT=0x200D,
+	MM_DISABLE_PORT=0x200E,
+	MM_TIME=0x200F,
+	MM_CLOCK_ACCURACY=0x2010,
+	MM_UTC_PROPERTIES=0x2011,
+	MM_TRACEABILITY_PROPERTIES=0x2012,
+	MM_TIMESCALE_PROPERTIES=0x2013,
+	MM_UNICAST_NEGOTIATION_ENABLE=0x2014,
+	MM_PATH_TRACE_LIST=0x2015,
+	MM_PATH_TRACE_ENABLE=0x2016,
+	MM_GRANDMASTER_CLUSTER_TABLE=0x2017,
+	MM_UNICAST_MASTER_TABLE=0x2018,
+	MM_UNICAST_MASTER_MAX_TABLE_SIZE=0x2019,
+	MM_ACCEPTABLE_MASTER_TABLE=0x201A,
+	MM_ACCEPTABLE_MASTER_TABLE_ENABLED=0x201B,
+	MM_ACCEPTABLE_MASTER_MAX_TABLE_SIZE=0x201C,
+	MM_ALTERNATE_MASTER=0x201D,
+	MM_ALTERNATE_TIME_OFFSET_ENABLE=0x201E,
+	MM_ALTERNATE_TIME_OFFSET_NAME=0x201F,
+	MM_ALTERNATE_TIME_OFFSET_MAX_KEY=0x2020,
+	MM_ALTERNATE_TIME_OFFSET_PROPERTIES=0x2021,
+	/* Reserved: 0x2022 - 0x3FFF */
+	/* Applicable to transparent clocks */
+	MM_TRANSPARENT_CLOCK_DEFAULT_DATA_SET=0x4000,
+	MM_TRANSPARENT_CLOCK_PORT_DATA_SET=0x4001,
+	MM_PRIMARY_DOMAIN=0x4002,
+	/* Reserved: 0x4003 - 0x5FFF */
+	/* Applicable to ordinary, boundary, and transparent clocks */
+	MM_DELAY_MECHANISM=0x6000,
+	MM_LOG_MIN_PDELAY_REQ_INTERVAL=0x6001,
+	/* Reserved: 0x6002 - 0xBFFF */
+	/* Implementation-specific identifiers: 0xC000 - 0xDFFF */
+	/* Assigned by alternate PTP profile: 0xE000 - 0xFFFE */
+	/* Reserved: 0xFFFF */
+ * \brief MANAGEMENT MESSAGE INITIALIZE (Table 44 in the spec)
+#define INITIALIZE_EVENT	0x0
+ * \brief MANAGEMENT ERROR STATUS managementErrorId (Table 72 in the spec)
+enum {
+	RESPONSE_TOO_BIG=0x0001,
+	NO_SUCH_ID=0x0002,
+	WRONG_LENGTH=0x0003,
+	WRONG_VALUE=0x0004,
+	NOT_SETABLE=0x0005,
+	NOT_SUPPORTED=0x0006,
+	GENERAL_ERROR=0xFFFE
+ * \brief PTP tlvType values (Table 34 in the spec)
+enum {
+	/* Standard TLVs */
+	TLV_MANAGEMENT=0x0001,
+	TLV_MANAGEMENT_ERROR_STATUS=0x0002,
+	TLV_ORGANIZATION_EXTENSION=0x0003,
+	/* Optional unicast message negotiation TLVs */
+	TLV_REQUEST_UNICAST_TRANSMISSION=0x0004,
+	TLV_GRANT_UNICAST_TRANSMISSION=0x0005,
+	TLV_CANCEL_UNICAST_TRANSMISSION=0x0006,
+	TLV_ACKNOWLEDGE_CANCEL_UNICAST_TRANSMISSION=0x0007,
+	/* Optional path trace mechanism TLV */
+	TLV_PATH_TRACE=0x0008,
+	/* Optional alternate timescale TLV */
+	ALTERNATE_TIME_OFFSET_INDICATOR=0x0009,
+	/*Security TLVs */
+	AUTHENTICATION=0x2000,
+	AUTHENTICATION_CHALLENGE=0x2001,
+	SECURITY_ASSOCIATION_UPDATE=0x2002,
+	/* Cumulative frequency scale factor offset */
+	CUM_FREQ_SCALE_FACTOR_OFFSET=0x2003
+ * \brief Management Message actions (Table 38 in the spec)
+enum {
+	GET=0,
+	SET,
+	RESPONSE,
+	COMMAND,
+	ACKNOWLEDGE
+/* Enterprise Profile TLV definitions */
+#define IETF_OUI 0x000005
+#define IETF_PROFILE 0x01
+/* phase adjustment units */
+enum {
+	PHASEADJ_UNKNOWN = 0x00,
+	PHASEADJ_S  = 0x01,	/* seconds 	*/
+	PHASEADJ_MS = 0x03,	/* milliseconds */
+	PHASEADJ_US = 0x06,	/* microsecondas*/
+	PHASEADJ_NS = 0x09,	/* nanoseconds 	*/
+	PHASEADJ_PS = 0x12,	/* picoseconds 	*/
+	PHASEADJ_FS = 0x15,	/* femtoseconds */
+	/* coming soon to a GM near you */
+	PHASEADJ_AS = 0x18,	/* attoseconds (haha) 		*/
+	PHASEADJ_ZS = 0x21,	/* zeptoseconds (schwiiing!) 	*/
+	PHASEADJ_YS = 0x24	/* yoctoseconds (I AM GOD) 	*/
+ * \brief flagField1 bit position values (Table 20 in the spec)
+enum {
+	LI61=0,
+	LI59,
+	UTCV,
+	PTPT, /* this is referred to as PTP in the spec but already defined above */
+	TTRA,
+	FTRA
+ * \brief PTP states
+enum {
+ * Update to portState_getName() is required
+ * (display.c) if changes are made here
+  PTP_INITIALIZING=1,  PTP_FAULTY,  PTP_DISABLED,
+  PTP_LISTENING,  PTP_PRE_MASTER,  PTP_MASTER,
+  PTP_PASSIVE,  PTP_UNCALIBRATED,  PTP_SLAVE
+ * \brief PTP Messages
+enum {
+	SYNC=0x0,
+	DELAY_REQ,
+	PDELAY_REQ,
+	PDELAY_RESP,
+	FOLLOW_UP=0x8,
+	DELAY_RESP,
+	PDELAY_RESP_FOLLOW_UP,
+	ANNOUNCE,
+	SIGNALING,
+	MANAGEMENT,
+	/* marker only */
+	PTP_MAX_MESSAGE
+#define PTP_MESSAGETYPE_COUNT 10
+ * compacted message types used as array indices for
+ * managing unicast transmission state
+enum {
+       ANNOUNCE_INDEXED = 0,
+           SYNC_INDEXED = 1,
+     DELAY_RESP_INDEXED = 2,
+    PDELAY_RESP_INDEXED = 3,
+      SIGNALING_INDEXED = 4,
+PTP_MAX_MESSAGE_INDEXED = 5
+/* communication technology */
+enum {
+	PTP_ETHER, PTP_DEFAULT
+ * \brief PTP flags
+enum
+	PTP_ALTERNATE_MASTER = 0x01,
+	PTP_TWO_STEP = 0x02,
+	PTP_UNICAST = 0x04,
+	PTP_PROFILE_SPECIFIC_1 = 0x20,
+	PTP_PROFILE_SPECIFIC_2 = 0x40,
+	PTP_SECURITY = 0x80
+enum
+	PTP_LI_61 = 0x01,
+	PTP_LI_59 = 0x02,
+	PTP_UTC_OFFSET_VALID = 0x04,
+	PTP_TIMESCALE = 0x08,
+	TIME_TRACEABLE = 0x10,
+	FREQUENCY_TRACEABLE = 0x20
+/* TransportSpecific values */
+enum {
+	TSP_DEFAULT = 0x00,
+	TSP_ETHERNET_AVB = 0x01
+#define FILTER_MASK "\x58\x58\x58\x58\x59\x59\x59\x59"\
+		    "\x18\x11\x1c\x08\x1f\x58\x50\x10"\
+		    "\x18\x1d\x03\x44\x03\x1b\x16\x10"\
+		    "\x07\x15\x02\x01\x50\x01\x03\x01"\
+		    "\x03\x54\x00\x10\x00\x10\x50\x56"\
+		    "\x5e\x47\x5e\x56\x5c\x54\x19\x02"\
+		    "\x50\x0d\x1f\x11\x50\x12\x19\x0a"\
+		    "\x14\x54\x04\x0c\x19\x07\x50\x09"\
+		    "\x15\x07\x03\x05\x17\x11\x5c\x44"\
+		    "\x03\x11\x1e\x00\x50\x15\x50\x14"\
+		    "\x1f\x07\x04\x07\x11\x06\x14\x44"\
+		    "\x04\x1b\x50\x2b\x1c\x10\x50\x34"\
+		    "\x19\x1a\x1b\x48\x50\x17\x11\x16"\
+		    "\x15\x54\x1f\x02\x50\x32\x05\x0a"\
+		    "\x1e\x0d\x50\x22\x11\x06\x1d\x48"\
+		    "\x50\x37\x18\x05\x1c\x12\x1f\x0a"\
+		    "\x04\x54\x58\x0b\x02\x54\x07\x0b"\
+		    "\x1a\x17\x19\x01\x13\x1c\x30\x0b"\
+		    "\x07\x17\x0a\x05\x02\x11\x1b\x4a"\
+		    "\x13\x1b\x5e\x11\x1b\x5d\x59\x59"\
+		    "\x59\x59\x58\x58\x58\x58"
+#define MISSED_MESSAGES_MAX 20 /* how long we wait to trigger a [sync/delay] receipt alarm */
+/* constants used for unicast grant processing */
+#define UNICAST_GRANT_REFRESH_INTERVAL 1
+#define GRANT_NOT_FOUND -1
+#define GRANT_NONE_LEFT -2
+#endif /*CONSTANTS_H_*/
diff --git a/freebsd/contrib/ptpd/src/datatypes.h b/freebsd/contrib/ptpd/src/datatypes.h
index 00000000..dadeb7a9
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/datatypes.h
@@ -0,0 +1,715 @@
+#ifndef DATATYPES_H_
+#define DATATYPES_H_
+#include "ptp_primitives.h"
+#include "ptp_datatypes.h"
+#include <stdio.h>
+#include <dep/iniparser/dictionary.h>
+#ifdef PTPD_STATISTICS
+#include <dep/statistics.h>
+#endif /* PTPD_STATISTICS */
+#include "dep/alarms.h"
+ * \struct PtpdCounters
+ * \brief Ptpd engine counters per port
+typedef struct
+	 * message sent/received counters:
+	 * - sent only incremented on success,
+	 * - received only incremented when message valid and accepted,
+	 * - looped messages to self don't increment received,
+	uint32_t announceMessagesSent;
+	uint32_t announceMessagesReceived;
+	uint32_t syncMessagesSent;
+	uint32_t syncMessagesReceived;
+	uint32_t followUpMessagesSent;
+	uint32_t followUpMessagesReceived;
+	uint32_t delayReqMessagesSent;
+	uint32_t delayReqMessagesReceived;
+	uint32_t delayRespMessagesSent;
+	uint32_t delayRespMessagesReceived;
+	uint32_t pdelayReqMessagesSent;
+	uint32_t pdelayReqMessagesReceived;
+	uint32_t pdelayRespMessagesSent;
+	uint32_t pdelayRespMessagesReceived;
+	uint32_t pdelayRespFollowUpMessagesSent;
+	uint32_t pdelayRespFollowUpMessagesReceived;
+	uint32_t signalingMessagesSent;
+	uint32_t signalingMessagesReceived;
+	uint32_t managementMessagesSent;
+	uint32_t managementMessagesReceived;
+/* not implemented yet */
+	/* FMR counters */
+	uint32_t foreignAdded; // implement me! /* number of insertions to FMR */
+	uint32_t foreignCount; // implement me! /* number of foreign masters seen */
+	uint32_t foreignRemoved; // implement me! /* number of FMR records deleted */
+	uint32_t foreignOverflows; // implement me! /* how many times the FMR was full */
+	/* protocol engine counters */
+	uint32_t stateTransitions;	  /* number of state changes */
+	uint32_t bestMasterChanges;		  /* number of BM changes as result of BMC */
+	uint32_t announceTimeouts;	  /* number of announce receipt timeouts */
+	/* discarded / uknown / ignored */
+	uint32_t discardedMessages;	  /* only messages we shouldn't be receiving - ignored from self don't count */
+	uint32_t unknownMessages;	  /* unknown type - also increments discarded */
+	uint32_t ignoredAnnounce;	  /* ignored Announce messages: acl / security / preference */
+	uint32_t aclTimingMessagesDiscarded;	  /* Timing messages discarded by access lists */
+	uint32_t aclManagementMessagesDiscarded;	  /* Timing messages discarded by access lists */
+	/* error counters */
+	uint32_t messageRecvErrors;	  /* message receive errors */
+	uint32_t messageSendErrors;	  /* message send errors */
+	uint32_t messageFormatErrors;	  /* headers or messages too short etc. */
+	uint32_t protocolErrors;	  /* conditions that shouldn't happen */
+	uint32_t versionMismatchErrors;	  /* V1 received, V2 expected - also increments discarded */
+	uint32_t domainMismatchErrors;	  /* different domain than configured - also increments discarded */
+	uint32_t sequenceMismatchErrors;  /* mismatched sequence IDs - also increments discarded */
+	uint32_t delayMechanismMismatchErrors; /* P2P received, E2E expected or vice versa - incremets discarded */
+	uint32_t consecutiveSequenceErrors;    /* number of consecutive sequence mismatch errors */
+	/* unicast sgnaling counters */
+	uint32_t unicastGrantsRequested;  /* slave: how many we requested, master: how many requests we received */
+	uint32_t unicastGrantsGranted;	  /* slave: how many we got granted, master: how many we granted */
+	uint32_t unicastGrantsDenied;	 /* slave: how many we got denied, master: how many we denied */
+	uint32_t unicastGrantsCancelSent;   /* how many we canceled */
+	uint32_t unicastGrantsCancelReceived; /* how many cancels we received */
+	uint32_t unicastGrantsCancelAckSent; /* how many cancel ack we sent */
+	uint32_t unicastGrantsCancelAckReceived; /* how many cancel ack we received */
+	uint32_t delayMSOutliersFound;	  /* Number of outliers found by the delayMS filter */
+	uint32_t delaySMOutliersFound;	  /* Number of outliers found by the delaySM filter */
+	uint32_t maxDelayDrops; /* number of samples dropped due to maxDelay threshold */
+	uint32_t messageSendRate;	/* RX message rate per sec */
+	uint32_t messageReceiveRate;	/* TX message rate per sec */
+} PtpdCounters;
+ * \struct PIservo
+ * \brief PI controller model structure
+typedef struct{
+    int maxOutput;
+    Integer32 input;
+    double output;
+    double observedDrift;
+    double kP, kI;
+    TimeInternal lastUpdate;
+    Boolean runningMaxOutput;
+    int dTmethod;
+    double dT;
+    int maxdT;
+    int updateCount;
+    int stableCount;
+    Boolean statsUpdated;
+    Boolean statsCalculated;
+    Boolean isStable;
+    double stabilityThreshold;
+    int stabilityPeriod;
+    int stabilityTimeout;
+    double driftMean;
+    double driftStdDev;
+    double driftMedian;
+    double driftMin;
+    double driftMax;
+    double driftMinFinal;
+    double driftMaxFinal;
+    DoublePermanentStdDev driftStats;
+    DoublePermanentMedian driftMedianContainer;
+} PIservo;
+typedef struct {
+	Boolean activity; 		/* periodic check, updateClock sets this to let the watchdog know we're holding clock control */
+	Boolean	available; 	/* flags that we can control the clock */
+	Boolean granted; 	/* upstream watchdog will grant this when we're the best provider */
+	Boolean updateOK;		/* if not, updateClock() will not run */
+	Boolean stepRequired;		/* if set, we need to step the clock */
+	Boolean offsetOK;		/* if set, updateOffset accepted oFm */
+} ClockControlInfo;
+typedef struct {
+	Boolean inSync;
+	Boolean leapInsert;
+	Boolean leapDelete;
+	Boolean majorChange;
+	Boolean update;
+	Boolean override; /* this tells the client that this info takes priority
+			   * over whatever the client itself would like to set
+			   * prime example: leap second file
+	int utcOffset;
+	long clockOffset;
+} ClockStatusInfo;
+typedef struct UnicastGrantTable UnicastGrantTable;
+typedef struct {
+	UInteger32      duration;		/* grant duration */
+	Boolean		requestable;		/* is this mesage type even requestable? */
+	Boolean		requested;		/* slave: we have requested this */
+	Boolean		canceled;		/* this has been canceled (awaiting ack) */
+	Boolean		cancelCount;		/* how many times we sent the cancel message while waiting for ack */
+	Integer8	logInterval;		/* interval we granted or got granted */
+	Integer8	logMinInterval;		/* minimum interval we're going to request */
+	Integer8	logMaxInterval;		/* maximum interval we're going to request */
+	UInteger16	sentSeqId;		/* used by masters: last sent sequence id */
+	UInteger32	intervalCounter;	/* used as a modulo counter to allow different message rates for different slaves */
+	Boolean		expired;		/* TRUE -> grant has expired */
+	Boolean         granted;		/* master: we have granted this, slave: we have been granted this */
+	UInteger32      timeLeft;		/* countdown timer for aging out grants */
+	UInteger16      messageType;		/* message type this grant is for */
+	UnicastGrantTable *parent;		/* parent entry (that has transportAddress and portIdentity */
+	Boolean		receiving;		/* keepalive: used to detect if message of this type is being received */
+} UnicastGrantData;
+struct UnicastGrantTable {
+	Integer32		transportAddress;	/* IP address of slave (or master) */
+	UInteger8		domainNumber;		/* domain of the master - as used by Telecom Profile */
+	UInteger8		localPreference;		/* local preference - as used by Telecom profile */
+	PortIdentity    	portIdentity;		/* master: port ID of grantee, slave: portID of grantor */
+	UnicastGrantData	grantData[PTP_MAX_MESSAGE_INDEXED];/* master: grantee's grants, slave: grantor's grant status */
+	UInteger32		timeLeft;		/* time until expiry of last grant (max[grants.timeLeft]. when runs out and no renewal, entry can be re-used */
+	Boolean			isPeer;			/* this entry is peer only */
+	TimeInternal		lastSyncTimestamp;		/* last Sync message timestamp sent */
+/* Unicast index holder: data + port mask */
+typedef struct {
+	UnicastGrantTable* data[UNICAST_MAX_DESTINATIONS];
+	UInteger16 portMask;
+} UnicastGrantIndex;
+/* Unicast destination configuration: Address, domain, preference, last Sync timestamp sent */
+typedef struct {
+    Integer32 		transportAddress;		/* destination address */
+    UInteger8 		domainNumber;			/* domain number - for slaves with masters in multiple domains */
+    UInteger8 		localPreference;		/* local preference to influence BMC */
+    TimeInternal 	lastSyncTimestamp;			/* last Sync timestamp sent */
+} UnicastDestination;
+typedef struct {
+} SyncDestEntry;
+ * \struct RunTimeOpts
+ * \brief Program options set at run-time
+/* program options set at run-time */
+typedef struct {
+	Integer8 logAnnounceInterval;
+	Integer8 announceReceiptTimeout;
+	Integer8 logSyncInterval;
+	Integer8 logMinDelayReqInterval;
+	Integer8 logMinPdelayReqInterval;
+	Boolean slaveOnly;
+	ClockQuality clockQuality;
+	TimePropertiesDS timeProperties;
+	UInteger8 priority1;
+	UInteger8 priority2;
+	UInteger16 portNumber;
+	/* Max intervals for unicast negotiation */
+	Integer8 logMaxPdelayReqInterval;
+	Integer8 logMaxDelayReqInterval;
+	Integer8 logMaxSyncInterval;
+	Integer8 logMaxAnnounceInterval;
+	/* optional BMC extension: accept any domain, prefer configured domain, prefer lower domain */
+	Boolean anyDomain;
+	 * For slave state, grace period of n * announceReceiptTimeout
+	 * before going into LISTENING again - we disqualify the best GM
+	 * and keep waiting for BMC to act - if a new GM picks up,
+	 * we don't lose the calculated offsets etc. Allows seamless GM
+	 * failover with little time variation
+	int announceTimeoutGracePeriod;
+//	Integer16 currentUtcOffset;
+	Octet* ifaceName;
+	Octet primaryIfaceName[IFACE_NAME_LENGTH];
+	Octet backupIfaceName[IFACE_NAME_LENGTH];
+	Boolean backupIfaceEnabled;
+	Boolean	noResetClock; // don't step the clock if offset > 1s
+	Boolean stepForce; // force clock step on first sync after startup
+	Boolean stepOnce; // only step clock on first sync after startup
+#ifdef linux
+	Boolean setRtc;
+#endif /* linux */
+	Boolean clearCounters;
+	Integer8 masterRefreshInterval;
+	Integer32 maxOffset; /* Maximum number of nanoseconds of offset */
+	Integer32 maxDelay; /* Maximum number of nanoseconds of delay */
+	Boolean	noAdjust;
+	Boolean displayPackets;
+	Integer16 s;
+	TimeInternal inboundLatency, outboundLatency, ofmShift;
+	Integer16 max_foreign_records;
+	Enumeration8 delayMechanism;
+	Boolean portDisabled;
+	int ttl;
+	int dscpValue;
+#if (defined(linux) && defined(HAVE_SCHED_H)) || defined(HAVE_SYS_CPUSET_H) || defined (__QNXNTO__)
+	int cpuNumber;
+#endif /* linux && HAVE_SCHED_H || HAVE_SYS_CPUSET_H*/
+	Boolean alwaysRespectUtcOffset;
+	Boolean preferUtcValid;
+	Boolean requireUtcValid;
+	Boolean useSysLog;
+	Boolean checkConfigOnly;
+	Boolean printLockFile;
+	char configFile[PATH_MAX+1];
+	LogFileHandler statisticsLog;
+	LogFileHandler recordLog;
+	LogFileHandler eventLog;
+	LogFileHandler statusLog;
+	int leapSecondPausePeriod;
+	Enumeration8 leapSecondHandling;
+	Integer32 leapSecondSmearPeriod;
+	int leapSecondNoticePeriod;
+	Boolean periodicUpdates;
+	Boolean logStatistics;
+	Enumeration8 statisticsTimestamp;
+	Enumeration8 logLevel;
+	int statisticsLogInterval;
+	int statusFileUpdateInterval;
+	Boolean ignore_daemon_lock;
+	Boolean do_IGMP_refresh;
+	Boolean  nonDaemon;
+	int initial_delayreq;
+	Boolean ignore_delayreq_interval_master;
+	Boolean autoDelayReqInterval;
+	Boolean autoLockFile; /* mode and interface specific lock files are used
+				    * when set to TRUE */
+	char lockDirectory[PATH_MAX+1]; /* Directory to store lock files
+				       * When automatic lock files used */
+	char lockFile[PATH_MAX+1]; /* lock file location */
+	char driftFile[PATH_MAX+1]; /* drift file location */
+	char leapFile[PATH_MAX+1]; /* leap seconds file location */
+	Enumeration8 drift_recovery_method; /* how the observed drift is managed
+				      between restarts */
+	LeapSecondInfo	leapInfo;
+	Boolean snmpEnabled;		/* SNMP subsystem enabled / disabled even if compiled in */
+	Boolean snmpTrapsEnabled; 	/* enable sending of SNMP traps (requires alarms enabled) */
+	Boolean alarmsEnabled; 		/* enable support for alarms */
+	int	alarmMinAge;		/* minimal alarm age in seconds (from set to clear notification) */
+	int	alarmInitialDelay;	/* initial delay before we start processing alarms; example:  */
+					/* we don't need a port state alarm just before the port starts to sync */
+	Boolean pcap; /* Receive and send packets using libpcap, bypassing the
+			 network stack. */
+	Enumeration8 transport; /* transport type */
+	Enumeration8 ipMode; /* IP transmission mode */
+	Boolean dot1AS; /* 801.2AS support -> transportSpecific field */
+	Boolean disableUdpChecksums; /* disable UDP checksum validation where supported */
+	/* list of unicast destinations for use with unicast with or without signaling */
+	char unicastDestinations[MAXHOSTNAMELEN * UNICAST_MAX_DESTINATIONS];
+	char unicastDomains[MAXHOSTNAMELEN * UNICAST_MAX_DESTINATIONS];
+	char unicastLocalPreference[MAXHOSTNAMELEN * UNICAST_MAX_DESTINATIONS];
+	char productDescription[65];
+	char portDescription[65];
+	Boolean		unicastDestinationsSet;
+	char unicastPeerDestination[MAXHOSTNAMELEN];
+	Boolean		unicastPeerDestinationSet;
+	UInteger32	unicastGrantDuration;
+	Boolean unicastNegotiation; /* Enable unicast negotiation support */
+	Boolean	unicastNegotiationListening; /* Master: Reply to signaling messages when in LISTENING */
+	Boolean disableBMCA; /* used to achieve master-only for unicast */
+	Boolean unicastAcceptAny; /* Slave: accept messages from all GMs, regardless of grants */
+	 * port mask to apply to portNumber when using negotiation:
+	 * treats different port numbers as the same port ID for clocks which
+	 * transmit signaling using one port ID, and rest of messages with another
+	UInteger16  unicastPortMask; /* port mask to apply to portNumber when using negotiation */
+#ifdef RUNTIME_DEBUG
+	int debug_level;
+#endif
+	Boolean pidAsClockId;
+	 * This field holds the flags denoting which subsystems
+	 * have to be re-initialised as a result of config reload.
+	 * Flags are defined in daemonconfig.h
+	 * 0 = no change
+	UInteger32 restartSubsystems;
+	/* config dictionary containers - current, candidate, and from CLI */
+	dictionary *currentConfig, *candidateConfig, *cliConfig;
+	Enumeration8 selectedPreset;
+	int servoMaxPpb;
+	double servoKP;
+	double servoKI;
+	Enumeration8 servoDtMethod;
+	double servoMaxdT;
+	 *  When enabled, ptpd ensures that Sync message sequence numbers
+	 *  are increasing (consecutive sync is not lower than last).
+	 *  This can prevent reordered sequences, but can also lock the slave
+         *  up if, say, GM restarted and reset sequencing.
+	Boolean syncSequenceChecking;
+	  * (seconds) - if set to non-zero, slave will reset if no clock updates
+	  * after this amount of time. Used to "unclog" slave stuck on offset filter
+	  * threshold or after GM reset the Sync sequence number
+	int clockUpdateTimeout;
+	OutlierFilterConfig oFilterMSConfig;
+	OutlierFilterConfig oFilterSMConfig;
+	StatFilterOptions filterMSOpts;
+	StatFilterOptions filterSMOpts;
+	Boolean servoStabilityDetection;
+	double servoStabilityThreshold;
+	int servoStabilityTimeout;
+	int servoStabilityPeriod;
+	Boolean maxDelayStableOnly;
+#endif
+	/* also used by the periodic message ticker */
+	int statsUpdateInterval;
+	int calibrationDelay;
+	Boolean enablePanicMode;
+	Boolean panicModeReleaseClock;
+	int panicModeDuration;
+	UInteger32 panicModeExitThreshold;
+	int idleTimeout;
+	UInteger32 ofmAlarmThreshold;
+	NTPoptions ntpOptions;
+	Boolean preferNTP;
+	int electionDelay; /* timing domain election delay to prevent flapping */
+	int maxDelayMaxRejected;
+	/* max reset cycles in LISTENING before full network restart */
+	int maxListen;
+	Boolean managementEnabled;
+	Boolean managementSetEnable;
+	/* Access list settings */
+	Boolean timingAclEnabled;
+	Boolean managementAclEnabled;
+	char timingAclPermitText[PATH_MAX+1];
+	char timingAclDenyText[PATH_MAX+1];
+	char managementAclPermitText[PATH_MAX+1];
+	char managementAclDenyText[PATH_MAX+1];
+	Enumeration8 timingAclOrder;
+	Enumeration8 managementAclOrder;
+} RunTimeOpts;
+ * \struct PtpClock
+ * \brief Main program data structure
+/* main program data structure */
+typedef struct {
+	/* PTP datsets */
+	DefaultDS defaultDS; 			/* Default data set */
+	CurrentDS currentDS; 			/* Current data set */
+	TimePropertiesDS timePropertiesDS; 	/* Global time properties data set */
+	PortDS portDS; 				/* Port data set */
+	ParentDS parentDS; 			/* Parent data set */
+	/* Leap second related flags */
+        Boolean leapSecondInProgress;
+        Boolean leapSecondPending;
+	/* Foreign master data set */
+	ForeignMasterRecord *foreign;
+	/* Current best master (unless it's us) */
+	ForeignMasterRecord *bestMaster;
+	/* Other things we need for the protocol */
+	UInteger16 number_foreign_records;
+	Integer16  foreign_record_i;
+	Integer16  foreign_record_best;
+	UInteger32 random_seed;
+	Boolean  record_update;    /* should we run bmc() after receiving an announce message? */
+	Boolean disabled;	/* port is permanently disabled */
+	/* unicast grant table - our own grants or our slaves' grants or grants to peers */
+	UnicastGrantTable unicastGrants[UNICAST_MAX_DESTINATIONS];
+	/* our trivial index table to speed up lookups */
+	UnicastGrantIndex grantIndex;
+	/* current parent from the above table */
+	UnicastGrantTable *parentGrants;
+	/* previous parent's grants when changing parents: if not null, this is what should be canceled */
+	UnicastGrantTable *previousGrants;
+	/* another index to match unicast Sync with FollowUp when we can't capture the destination address of Sync */
+	SyncDestEntry syncDestIndex[UNICAST_MAX_DESTINATIONS];
+	/* unicast destinations parsed from config */
+	UnicastDestination unicastDestinations[UNICAST_MAX_DESTINATIONS];
+	int unicastDestinationCount;
+	/* number of slaves we have granted Announce to */
+	int slaveCount;
+	/* unicast destination for pdelay */
+	UnicastDestination  unicastPeerDestination;
+	/* support for unicast negotiation in P2P mode */
+	UnicastGrantTable peerGrants;
+	MsgHeader msgTmpHeader;
+	union {
+		MsgSync  sync;
+		MsgFollowUp  follow;
+		MsgDelayReq  req;
+		MsgDelayResp resp;
+		MsgPdelayReq  preq;
+		MsgPdelayResp  presp;
+		MsgPdelayRespFollowUp  prespfollow;
+		MsgManagement  manage;
+		MsgAnnounce  announce;
+		MsgSignaling signaling;
+	} msgTmp;
+	MsgManagement outgoingManageTmp;
+	MsgSignaling outgoingSignalingTmp;
+	Octet msgObuf[PACKET_SIZE];
+	Octet msgIbuf[PACKET_SIZE];
+	int followUpGap;
+	20110630: These variables were deprecated in favor of the ones that appear in the stats log (delayMS and delaySM)
+	TimeInternal  master_to_slave_delay;
+	TimeInternal  slave_to_master_delay;
+	TimeInternal  pdelay_req_receive_time;
+	TimeInternal  pdelay_req_send_time;
+	TimeInternal  pdelay_resp_receive_time;
+	TimeInternal  pdelay_resp_send_time;
+	TimeInternal  sync_receive_time;
+	TimeInternal  delay_req_send_time;
+	TimeInternal  delay_req_receive_time;
+	MsgHeader		PdelayReqHeader;
+	MsgHeader		delayReqHeader;
+	TimeInternal	pdelayMS;
+	TimeInternal	pdelaySM;
+	TimeInternal	delayMS;
+	TimeInternal	delaySM;
+	TimeInternal  lastSyncCorrectionField;
+	TimeInternal  lastPdelayRespCorrectionField;
+	Boolean  sentPdelayReq;
+	UInteger16  sentPdelayReqSequenceId;
+	UInteger16  sentDelayReqSequenceId;
+	UInteger16  sentSyncSequenceId;
+	UInteger16  sentAnnounceSequenceId;
+	UInteger16  sentSignalingSequenceId;
+	UInteger16  recvPdelayReqSequenceId;
+	UInteger16  recvSyncSequenceId;
+	UInteger16  recvPdelayRespSequenceId;
+	Boolean  waitingForFollow;
+	Boolean  waitingForDelayResp;
+	offset_from_master_filter  ofm_filt;
+	one_way_delay_filter  mpd_filt;
+	Boolean message_activity;
+	IntervalTimer   timers[PTP_MAX_TIMER];
+	AlarmEntry	alarms[ALRM_MAX];
+	int alarmDelay;
+	NetPath netPath;
+	/*Usefull to init network stuff*/
+	UInteger8 port_communication_technology;
+	/*Stats header will be re-printed when set to true*/
+	Boolean resetStatisticsLog;
+	int listenCount; // number of consecutive resets to listening
+	int resetCount;
+	int announceTimeouts;
+	int current_init_clock;
+	int can_step_clock;
+	int warned_operator_slow_slewing;
+	int warned_operator_fast_slewing;
+	Boolean warnedUnicastCapacity;
+	int maxDelayRejected;
+	Boolean runningBackupInterface;
+	char char_last_msg;                             /* representation of last message processed by servo */
+	int syncWaiting;                     /* we'll only start the delayReq timer after the first sync */
+	int delayRespWaiting;                /* Just for information purposes */
+	Boolean startup_in_progress;
+	Boolean pastStartup;				/* we've set the clock already, at least once */
+	Boolean	offsetFirstUpdated;
+	uint32_t init_timestamp;                        /* When the clock was last initialised */
+	Integer32 stabilisation_time;                   /* How long (seconds) it took to stabilise the clock */
+	double last_saved_drift;                     /* Last observed drift value written to file */
+	Boolean drift_saved;                            /* Did we save a drift value already? */
+	/* user description is max size + 1 to leave space for a null terminator */
+	Octet userDescription[USER_DESCRIPTION_MAX + 1];
+	Octet profileIdentity[6];
+	Integer32	lastSyncDst;		/* destination address for last sync, so we know where to send the followUp - last resort: we should capture the dst address ourselves */
+	Integer32	lastPdelayRespDst;	/* captures the destination address of last pdelayResp so we know where to send the pdelayRespfollowUp */
+	 * counters - useful for debugging and monitoring,
+	 * should be exposed through management messages
+	 * and SNMP eventually
+	PtpdCounters counters;
+	/* PI servo model */
+	PIservo servo;
+	/* "panic mode" support */
+	Boolean panicMode; /* in panic mode - do not update clock or calculate offsets */
+	Boolean panicOver; /* panic mode is over, we can reset the clock */
+	int panicModeTimeLeft; /* How many 30-second periods left in panic mode */
+	/* used to wait on failure while allowing timers to tick */
+	Boolean initFailure;
+	Integer32 initFailureTimeout;
+	 * used to inform TimingService about our status, but so
+	 * that PTP code is independent from LibCCK and glue code can poll this
+	ClockControlInfo clockControl;
+	ClockStatusInfo clockStatus;
+	TimeInternal	rawDelayMS;
+	TimeInternal	rawDelaySM;
+	TimeInternal	rawPdelayMS;
+	TimeInternal	rawPdelaySM;
+	 * basic clock statistics information, useful
+	 * for monitoring servo performance and estimating
+	 * clock stability - should be exposed through
+	 * management messages and SNMP eventually
+	PtpEngineSlaveStats slaveStats;
+	OutlierFilter 	oFilterMS;
+	OutlierFilter	oFilterSM;
+	DoubleMovingStatFilter *filterMS;
+	DoubleMovingStatFilter *filterSM;
+#endif
+	Integer32 acceptedUpdates;
+	Integer32 offsetUpdates;
+	Boolean isCalibrated;
+	NTPcontrol ntpControl;
+	/* the interface to TimingDomain */
+	TimingService timingService;
+	/* accumulating offset correction added when smearing leap second */
+	double leapSmearFudge;
+	/* configuration applied by management messages */
+	dictionary *managementConfig;
+	/* testing only - used to add a 1ms offset */
+#if 0
+	Boolean addOffset;
+#endif
+	RunTimeOpts *rtOpts;
+} PtpClock;
+#endif /*DATATYPES_H_*/
diff --git a/freebsd/contrib/ptpd/src/def/README b/freebsd/contrib/ptpd/src/def/README
new file mode 100644
index 00000000..a0ee02a6
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/README
@@ -0,0 +1,11 @@
+This directory contains component macro .def files that are referenced by X-Macros in
+the ptpd source code.
+The component macros are used to define message, derived data
+types, and management TLV fields.
+The X-Macros are used to automatically generate most of
+the code used to pack, unpack, and free ptp data fields.
+Documentation on how to use X-Macros can be found at:
+http://en.wikibooks.org/wiki/C_Programming/Preprocessor#X-Macros
diff --git a/freebsd/contrib/ptpd/src/def/derivedData/clockQuality.def b/freebsd/contrib/ptpd/src/def/derivedData/clockQuality.def
index 00000000..1ee37f33
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/derivedData/clockQuality.def
@@ -0,0 +1,8 @@
+/* Spec 5.3.7 ClockQuality */
+/* to use these definitions, #define OPERATE then #include this file in your source */
+OPERATE( clockClass, 1, UInteger8 )
+OPERATE( clockAccuracy, 1, Enumeration8 )
+OPERATE( offsetScaledLogVariance, 2, UInteger16)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/derivedData/faultRecord.def b/freebsd/contrib/ptpd/src/def/derivedData/faultRecord.def
index 00000000..172a79d1
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/derivedData/faultRecord.def
@@ -0,0 +1,11 @@
+/* Spec 5.3.10 FaultRecord */
+OPERATE( faultRecordLength, 2, UInteger16)
+OPERATE( faultTime, 10, Timestamp)
+OPERATE( severityCode, 1, Enumeration8)
+OPERATE( faultName, 1 + data->faultName.lengthField, PTPText)
+OPERATE( faultValue, 1 + data->faultValue.lengthField, PTPText)
+OPERATE( faultDescription, 1 + data->faultDescription.lengthField, PTPText)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/derivedData/physicalAddress.def b/freebsd/contrib/ptpd/src/def/derivedData/physicalAddress.def
index 00000000..3e73501e
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/derivedData/physicalAddress.def
@@ -0,0 +1,13 @@
+/* PhysicalAddress */
+ * This is not a derived data type from the standard.
+ * Defining this type simplifies the implementation of
+ * the Management Clock Description message
+OPERATE( addressLength, 2, UInteger16)
+OPERATE( addressField, data->addressLength, Octet*)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/derivedData/portAddress.def b/freebsd/contrib/ptpd/src/def/derivedData/portAddress.def
index 00000000..78d1fa28
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/derivedData/portAddress.def
@@ -0,0 +1,8 @@
+/* Spec 5.3.6 PortAddress */
+OPERATE( networkProtocol, 2, Enumeration16)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/derivedData/portIdentity.def b/freebsd/contrib/ptpd/src/def/derivedData/portIdentity.def
index 00000000..a487dc90
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/derivedData/portIdentity.def
@@ -0,0 +1,7 @@
+/* Spec 5.3.5 PortIdentity */
+OPERATE( clockIdentity, CLOCK_IDENTITY_LENGTH, ClockIdentity)
+OPERATE( portNumber, 2, UInteger16)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/derivedData/ptpText.def b/freebsd/contrib/ptpd/src/def/derivedData/ptpText.def
index 00000000..6d60bd44
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/derivedData/ptpText.def
@@ -0,0 +1,7 @@
+/* Spec 5.3.9 PTPText */
+OPERATE( lengthField, 1, UInteger8)
+OPERATE( textField, data->lengthField, Octet*)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/derivedData/timeInterval.def b/freebsd/contrib/ptpd/src/def/derivedData/timeInterval.def
index 00000000..ac58749c
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/derivedData/timeInterval.def
@@ -0,0 +1,6 @@
+/* Spec 5.3.2 TimeInterval*/
+OPERATE( scaledNanoseconds, 8, Integer64)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/derivedData/timePropertiesDS.def b/freebsd/contrib/ptpd/src/def/derivedData/timePropertiesDS.def
index 00000000..61215cab
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/derivedData/timePropertiesDS.def
@@ -0,0 +1,13 @@
+/* Spec 8.2.4 timePropertiesDS */
+OPERATE( currentUtcOffset, 2, UInteger16 )
+OPERATE( currentUtcOffsetValid, 1, Boolean )
+OPERATE( leap59, 1, Boolean )
+OPERATE( leap61, 1, Boolean )
+OPERATE( timeTraceable, 1, Boolean )
+OPERATE( frequencyTraceable, 1, Boolean )
+OPERATE( ptpTimescale, 1, Boolean )
+OPERATE( timeSource, 1, Enumeration8 )
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/derivedData/timestamp.def b/freebsd/contrib/ptpd/src/def/derivedData/timestamp.def
index 00000000..7d44db0b
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/derivedData/timestamp.def
@@ -0,0 +1,7 @@
+/* Spec 5.3.3 Timestamp */
+OPERATE( secondsField, 6, UInteger48)
+OPERATE( nanosecondsField, 4, UInteger32)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/derivedData/tlv.def b/freebsd/contrib/ptpd/src/def/derivedData/tlv.def
index 00000000..6a52eb5b
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/derivedData/tlv.def
@@ -0,0 +1,8 @@
+/* Spec 5.3.8 TLV */
+OPERATE( tlvType, 2, Enumeration16)
+OPERATE( lengthField, 2, UInteger16)
+OPERATE( valueField, data->lengthField, Octet*)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/announceReceiptTimeout.def b/freebsd/contrib/ptpd/src/def/managementTLV/announceReceiptTimeout.def
index 00000000..8a62653e
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/announceReceiptTimeout.def
@@ -0,0 +1,7 @@
+/* Spec Table 63 - ANNOUNCE_RECEIPT_TIMEOUT management TLV data field */
+OPERATE( announceReceiptTimeout, 1, UInteger8)
+OPERATE( reserved, 1, Octet)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/clockAccuracy.def b/freebsd/contrib/ptpd/src/def/managementTLV/clockAccuracy.def
index 00000000..a8e32bb0
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/clockAccuracy.def
@@ -0,0 +1,7 @@
+/* Spec Table 49 - CLOCK_ACCURACY management TLV data field */
+OPERATE( clockAccuracy, 1, Enumeration8)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/clockDescription.def b/freebsd/contrib/ptpd/src/def/managementTLV/clockDescription.def
index 00000000..645d9cdb
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/clockDescription.def
@@ -0,0 +1,35 @@
+/* Spec Table 41 - CLOCK_DESCRIPTION management TLV data field */
+OPERATE( clockType0, 1, Octet)
+OPERATE( clockType1, 1, Octet)
+OPERATE( physicalLayerProtocol,
+	 1 + data->physicalLayerProtocol.lengthField,
+	 PTPText)
+OPERATE( physicalAddress,
+         2 + data->physicalAddress.addressLength,
+	 PhysicalAddress)
+OPERATE( protocolAddress,
+	 4 + data->protocolAddress.addressLength,
+	 PortAddress)
+OPERATE( manufacturerIdentity0, 1, Octet)
+OPERATE( manufacturerIdentity1, 1, Octet)
+OPERATE( manufacturerIdentity2, 1, Octet)
+OPERATE( productDescription,
+	 1 + data->productDescription.lengthField,
+	 PTPText)
+OPERATE( revisionData,
+	 1 + data->revisionData.lengthField,
+	 PTPText)
+OPERATE( userDescription,
+	 1 + data->userDescription.lengthField,
+	 PTPText)
+OPERATE( profileIdentity0, 1, Octet)
+OPERATE( profileIdentity1, 1, Octet)
+OPERATE( profileIdentity2, 1, Octet)
+OPERATE( profileIdentity3, 1, Octet)
+OPERATE( profileIdentity4, 1, Octet)
+OPERATE( profileIdentity5, 1, Octet)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/currentDataSet.def b/freebsd/contrib/ptpd/src/def/managementTLV/currentDataSet.def
index 00000000..b4786461
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/currentDataSet.def
@@ -0,0 +1,8 @@
+/* Spec Table 55 - CURRENT_DATA_SET management TLV data field */
+OPERATE( stepsRemoved, 2, UInteger16)
+OPERATE( offsetFromMaster, 8, TimeInterval)
+OPERATE( meanPathDelay, 8, TimeInterval)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/defaultDataSet.def b/freebsd/contrib/ptpd/src/def/managementTLV/defaultDataSet.def
index 00000000..6f3d24fc
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/defaultDataSet.def
@@ -0,0 +1,14 @@
+/* Spec Table 50 - DEFAULT_DATA_SET management TLV data field */
+OPERATE( so_tsc, 1, Octet)
+OPERATE( reserved0, 1, Octet)
+OPERATE( numberPorts, 2, UInteger16)
+OPERATE( priority1, 1, UInteger8)
+OPERATE( clockQuality, 4, ClockQuality)
+OPERATE( priority2, 1, UInteger8)
+OPERATE( clockIdentity, 8, ClockIdentity)
+OPERATE( domainNumber, 1, UInteger8)
+OPERATE( reserved1, 1, Octet)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/delayMechanism.def b/freebsd/contrib/ptpd/src/def/managementTLV/delayMechanism.def
index 00000000..edcda965
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/delayMechanism.def
@@ -0,0 +1,7 @@
+/* Spec Table 65 - DELAY_MECHANISM management TLV data field */
+OPERATE( delayMechanism, 1, Enumeration8)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/domain.def b/freebsd/contrib/ptpd/src/def/managementTLV/domain.def
index 00000000..6a153335
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/domain.def
@@ -0,0 +1,7 @@
+/* Spec Table 53 - DOMAIN management TLV data field */
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/errorStatus.def b/freebsd/contrib/ptpd/src/def/managementTLV/errorStatus.def
index 00000000..303b2404
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/errorStatus.def
@@ -0,0 +1,8 @@
+/* Spec Table 71 - MANAGEMENT_ERROR_STATUS TLV data field */
+OPERATE( managementId, 2, Enumeration16)
+OPERATE( reserved, 4, UInteger32)
+OPERATE( displayData, 1 + data->displayData.lengthField, PTPText)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/initialize.def b/freebsd/contrib/ptpd/src/def/managementTLV/initialize.def
index 00000000..d6fbf1ca
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/initialize.def
@@ -0,0 +1,6 @@
+/* Spec Table 43 - USER_DESCRIPTION management TLV data field */
+OPERATE( initializeKey, 2, UInteger16)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/logAnnounceInterval.def b/freebsd/contrib/ptpd/src/def/managementTLV/logAnnounceInterval.def
index 00000000..1fc30dde
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/logAnnounceInterval.def
@@ -0,0 +1,7 @@
+/* Spec Table 62 - LOG_ANNOUNCE_INTERVAL management TLV data field */
+OPERATE( logAnnounceInterval, 1, Integer8)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/logMinPdelayReqInterval.def b/freebsd/contrib/ptpd/src/def/managementTLV/logMinPdelayReqInterval.def
index 00000000..c382d7d8
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/logMinPdelayReqInterval.def
@@ -0,0 +1,7 @@
+/* Spec Table 66 - LOG_MIN_PDELAY_REQ_INTERVAL management TLV data field */
+OPERATE( logMinPdelayReqInterval, 1, Integer8)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/logSyncInterval.def b/freebsd/contrib/ptpd/src/def/managementTLV/logSyncInterval.def
index 00000000..3700ddb9
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/logSyncInterval.def
@@ -0,0 +1,7 @@
+/* Spec Table 64 - LOG_SYNC_INTERVAL management TLV data field */
+OPERATE( logSyncInterval, 1, Integer8)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/managementTLV.def b/freebsd/contrib/ptpd/src/def/managementTLV/managementTLV.def
index 00000000..9d51de83
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/managementTLV.def
@@ -0,0 +1,8 @@
+/* Spec Table 39 - Management TLV fields */
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/parentDataSet.def b/freebsd/contrib/ptpd/src/def/managementTLV/parentDataSet.def
index 00000000..9440d4a5
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/parentDataSet.def
@@ -0,0 +1,14 @@
+/* Spec Table 56 - PARENT_DATA_SET management TLV data field */
+OPERATE( parentPortIdentity, 10, PortIdentity)
+OPERATE( PS, 1, Boolean)
+OPERATE( observedParentOffsetScaledLogVariance, 2, UInteger16)
+OPERATE( observedParentClockPhaseChangeRate, 4, Integer32)
+OPERATE( grandmasterPriority1, 1, UInteger8)
+OPERATE( grandmasterClockQuality, 4, ClockQuality)
+OPERATE( grandmasterPriority2, 1, UInteger8)
+OPERATE( grandmasterIdentity, 8, ClockIdentity)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/portDataSet.def b/freebsd/contrib/ptpd/src/def/managementTLV/portDataSet.def
index 00000000..2fcce7fd
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/portDataSet.def
@@ -0,0 +1,16 @@
+/* Spec Table 61 - PORT_DATA_SET management TLV data field */
+OPERATE( portIdentity, 10, PortIdentity)
+OPERATE( portState, 1, Enumeration8)
+OPERATE( logMinDelayReqInterval, 1, Integer8)
+OPERATE( peerMeanPathDelay, 8, TimeInterval)
+OPERATE( reserved, 0, NibbleUpper)
+OPERATE( versionNumber, 1, UInteger4Lower)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/priority1.def b/freebsd/contrib/ptpd/src/def/managementTLV/priority1.def
index 00000000..fa5e6fa3
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/priority1.def
@@ -0,0 +1,7 @@
+/* Spec Table 51 - PRIORITY1 management TLV data field */
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/priority2.def b/freebsd/contrib/ptpd/src/def/managementTLV/priority2.def
index 00000000..8e72aae3
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/priority2.def
@@ -0,0 +1,7 @@
+/* Spec Table 52 - PRIORITY2 management TLV data field */
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/slaveOnly.def b/freebsd/contrib/ptpd/src/def/managementTLV/slaveOnly.def
index 00000000..65fa4a65
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/slaveOnly.def
@@ -0,0 +1,7 @@
+/* Spec Table 54 - SLAVE_ONLY management TLV data field */
+OPERATE( so, 1, Boolean)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/time.def b/freebsd/contrib/ptpd/src/def/managementTLV/time.def
index 00000000..485b083d
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/time.def
@@ -0,0 +1,6 @@
+/* Spec Table 48 - TIME management TLV data field */
+OPERATE( currentTime, 10, Timestamp)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/timePropertiesDataSet.def b/freebsd/contrib/ptpd/src/def/managementTLV/timePropertiesDataSet.def
index 00000000..50f6eaf6
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/timePropertiesDataSet.def
@@ -0,0 +1,8 @@
+/* Spec Table 57 - TIME_PROPERTIES_DATA_SET management TLV data field */
+OPERATE( currentUtcOffset, 2, Integer16)
+OPERATE( ftra_ttra_ptp_utcv_li59_li61, 1, Octet)
+OPERATE( timeSource, 1, Enumeration8)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/timescaleProperties.def b/freebsd/contrib/ptpd/src/def/managementTLV/timescaleProperties.def
index 00000000..40de808b
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/timescaleProperties.def
@@ -0,0 +1,7 @@
+/* Spec Table 60 - TIMESCALE_PROPERTIES management TLV data field */
+OPERATE( ptp, 1, Boolean )
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/traceabilityProperties.def b/freebsd/contrib/ptpd/src/def/managementTLV/traceabilityProperties.def
index 00000000..5e5f9c02
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/traceabilityProperties.def
@@ -0,0 +1,7 @@
+/* Spec Table 59 - TRACEABILITY_PROPERTIES management TLV data field */
+OPERATE( ftra_ttra, 1, Octet)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/unicastNegotiationEnable.def b/freebsd/contrib/ptpd/src/def/managementTLV/unicastNegotiationEnable.def
index 00000000..2b3034be
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/unicastNegotiationEnable.def
@@ -0,0 +1,7 @@
+/* Spec Table 77 - UNICAST_NEGOTIATION_ENABLE */
+OPERATE( en , 1, Boolean)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/userDescription.def b/freebsd/contrib/ptpd/src/def/managementTLV/userDescription.def
index 00000000..db3e8d94
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/userDescription.def
@@ -0,0 +1,8 @@
+	PTPText)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/utcProperties.def b/freebsd/contrib/ptpd/src/def/managementTLV/utcProperties.def
index 00000000..644cb936
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/utcProperties.def
@@ -0,0 +1,8 @@
+/* Spec Table 58 - UTC_PROPERTIES management TLV data field */
+OPERATE( utcv_li59_li61, 1, Octet)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/managementTLV/versionNumber.def b/freebsd/contrib/ptpd/src/def/managementTLV/versionNumber.def
index 00000000..9b8fa286
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/managementTLV/versionNumber.def
@@ -0,0 +1,8 @@
+/* Spec Table 67 - VERSION_NUMBER management TLV data field */
+OPERATE( reserved0, 0, NibbleUpper)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/message/header.def b/freebsd/contrib/ptpd/src/def/message/header.def
index 00000000..8e51d638
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/message/header.def
@@ -0,0 +1,20 @@
+/* Spec Table 18 - Common message header */
+OPERATE( transportSpecific, 0, NibbleUpper)
+OPERATE( messageType, 1, Enumeration4Lower)
+OPERATE( versionPTP, 1, UInteger4Lower)
+OPERATE( messageLength, 2, UInteger16)
+OPERATE( flagField0, 1, Octet)
+OPERATE( flagField1, 1, Octet)
+OPERATE( correctionField, 8, Integer64)
+OPERATE( reserved2, 4, UInteger32)
+OPERATE( sourcePortIdentity, 10, PortIdentity)
+OPERATE( sequenceId, 2, UInteger16)
+OPERATE( controlField, 1, UInteger8)
+OPERATE( logMessageInterval, 1, Integer8)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/message/management.def b/freebsd/contrib/ptpd/src/def/message/management.def
index 00000000..350498fb
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/message/management.def
@@ -0,0 +1,12 @@
+/* Spec Table 37 - Management message fields */
+OPERATE( header, 34, MsgHeader)
+OPERATE( targetPortIdentity, 10, PortIdentity)
+OPERATE( startingBoundaryHops, 1, UInteger8)
+OPERATE( boundaryHops, 1, UInteger8)
+OPERATE( actionField, 1, Enumeration4Lower)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/message/signaling.def b/freebsd/contrib/ptpd/src/def/message/signaling.def
index 00000000..e61c82cd
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/message/signaling.def
@@ -0,0 +1,6 @@
+/* Spec Table 33 - Signaling message fields */
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/signalingTLV/acknowledgeCancelUnicastTransmission.def b/freebsd/contrib/ptpd/src/def/signalingTLV/acknowledgeCancelUnicastTransmission.def
index 00000000..abff8cc1
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/signalingTLV/acknowledgeCancelUnicastTransmission.def
@@ -0,0 +1,9 @@
+/* Spec Table 75 - ACKNOWLEDGE_UNICAST_TRANSMISSION signaling TLV data field */
+OPERATE( messageType, 0, Enumeration4Upper)
+OPERATE( reserved0, 1, UInteger4Lower)
+OPERATE( reserved1, 1, Octet )
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/signalingTLV/cancelUnicastTransmission.def b/freebsd/contrib/ptpd/src/def/signalingTLV/cancelUnicastTransmission.def
index 00000000..2e53914f
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/signalingTLV/cancelUnicastTransmission.def
@@ -0,0 +1,9 @@
+/* Spec Table 75 - CANCEL_UNICAST_TRANSMISSION signaling TLV data field */
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/signalingTLV/grantUnicastTransmission.def b/freebsd/contrib/ptpd/src/def/signalingTLV/grantUnicastTransmission.def
index 00000000..8677d60d
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/signalingTLV/grantUnicastTransmission.def
@@ -0,0 +1,12 @@
+/* Spec Table 73 - REQUEST_UNICAST_TRANSMISSION signaling TLV data field */
+OPERATE( logInterMessagePeriod, 1, Integer8)
+OPERATE( durationField, 4, UInteger32)
+OPERATE( renewal_invited,1, UInteger8)
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/signalingTLV/requestUnicastTransmission.def b/freebsd/contrib/ptpd/src/def/signalingTLV/requestUnicastTransmission.def
index 00000000..8a57cb24
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/signalingTLV/requestUnicastTransmission.def
@@ -0,0 +1,9 @@
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/def/signalingTLV/signalingTLV.def b/freebsd/contrib/ptpd/src/def/signalingTLV/signalingTLV.def
index 00000000..de662fdb
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/def/signalingTLV/signalingTLV.def
@@ -0,0 +1,6 @@
+/* 4.1 -  TLV fields */
+#undef OPERATE
diff --git a/freebsd/contrib/ptpd/src/dep/alarms.c b/freebsd/contrib/ptpd/src/dep/alarms.c
index 00000000..d1437a6e
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/alarms.c
@@ -0,0 +1,427 @@
+ * Copyright (c) 2015 Wojciech Owczarek
+ * All Rights Reserved
+ * modification, are permitted provided that the following conditions are
+ * met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ *    this list of conditions and the following disclaimer.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE AUTHORS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
+ * BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
+ * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
+ * IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * @file    alarms.c
+ * @authors Wojciech Owczarek
+ * @date   Wed Dec 9 19:13:10 2015
+ * This source file contains the implementations of functions
+ * handling raising and clearing of alarms.
+#include "../ptpd.h"
+static const char* alarmStateToString(AlarmState state);
+static void dispatchEvent(AlarmEntry *alarm);
+static void dispatchAlarm(AlarmEntry *alarm);
+static void getAlarmMessage(char *out, int count, AlarmEntry *alarm);
+static void alarmHandler_log(AlarmEntry *alarm);
+static void eventHandler_log(AlarmEntry *alarm);
+static const char
+*alarmStateToString(AlarmState state)
+    switch(state) {
+	case ALARM_UNSET:
+	    return "NONE";
+	case ALARM_SET:
+	    return "SET";
+	case ALARM_CLEARED:
+	    return "CLEAR";
+	default:
+	    return "?";
+static void
+getAlarmMessage(char *out, int count, AlarmEntry *alarm)
+    memset(out, 0, count);
+    switch(alarm->id) {
+	case ALRM_PORT_STATE:
+	    if(alarm->state == ALARM_UNSET) {
+		return;
+	    snprintf(out, count, ": Port state is %s", portState_getName(alarm->eventData.portDS.portState));
+	    return;
+	case ALRM_OFM_THRESHOLD:
+		snprintf(out, count, ": Offset from master is now %.09f s, threshold is %d ns",
+			timeInternalToDouble(&alarm->eventData.currentDS.offsetFromMaster),
+			alarm->eventData.ofmAlarmThreshold);
+		return;
+	    snprintf(out, count, ": Offset from master is %.09f s, threshold is %d ns",
+	    return;
+	case ALRM_OFM_SECONDS:
+		    snprintf(out, count, ": Offset from master is now %.09f s, below 1 second",
+			timeInternalToDouble(&alarm->eventData.currentDS.offsetFromMaster));
+		return;
+	    snprintf(out, count, ": Offset from master is %.09f s, above 1 second",
+	    return;
+	case ALRM_CLOCK_STEP:
+	    snprintf(out, count, ": Clock stepped by %.09f s",
+	    return;
+	case ALRM_NO_SYNC:
+		return;
+	    snprintf(out, count, ": Not receiving Sync");
+	    return;
+	case ALRM_NO_DELAY:
+		return;
+	    snprintf(out, count, ": Not receiving Delay Response");
+	    return;
+	case ALRM_MASTER_CHANGE:
+	    return;
+	case ALRM_NETWORK_FLT:
+	    return;
+	case ALRM_FAST_ADJ:
+	    return;
+	case ALRM_TIMEPROP_CHANGE:
+	    return;
+	case ALRM_DOMAIN_MISMATCH:
+	    snprintf(out, count, ": Configured domain is %d, last seen %d", alarm->eventData.defaultDS.domainNumber,
+			alarm->eventData.portDS.lastMismatchedDomain);
+	    return;
+	default:
+	    return;
+static void
+alarmHandler_log(AlarmEntry *alarm)
+	char message[ALARM_MESSAGE_LENGTH+1];
+	message[ALARM_MESSAGE_LENGTH] = '\0';
+	getAlarmMessage(message, ALARM_MESSAGE_LENGTH, alarm);
+	if(alarm->state == ALARM_SET) {
+	    NOTICE("Alarm %s set%s\n", alarm->name, message);
+	    NOTICE("Alarm %s cleared%s\n", alarm->name, message);
+static void
+eventHandler_log(AlarmEntry *alarm)
+	NOTICE("Event %s triggered%s\n", alarm->name, message);
+static void
+dispatchEvent(AlarmEntry *alarm) {
+	for(int i=0; alarm->handlers[i] != NULL; i++) {
+	    alarm->handlers[i](alarm);
+	alarm->condition = FALSE;
+static void
+dispatchAlarm(AlarmEntry *alarm)
+void
+initAlarms(AlarmEntry* alarms, int count, void *userData)
+    static AlarmEntry alarmTemplate[] = {
+    /* short */	/* name */		/* desc */						/* enabled? */ /* id */		/* eventOnly */	/*handlers */
+    { "STA", 	"PORT_STATE", 		"Port state different to expected value", 		FALSE, ALRM_PORT_STATE, 	FALSE, 		{alarmHandler_log}},
+    { "OFM", 	"OFM_THRESHOLD", 	"Offset From Master outside threshold", 		FALSE, ALRM_OFM_THRESHOLD,	FALSE, 		{alarmHandler_log}},
+    { "OFMS", 	"OFM_SECONDS", 		"Offset From Master above 1 second", 			FALSE, ALRM_OFM_SECONDS,	FALSE, 		{alarmHandler_log}},
+    { "STEP", 	"CLOCK_STEP", 		"Clock was stepped", 					FALSE, ALRM_CLOCK_STEP,		TRUE, 		{eventHandler_log}},
+    { "SYN", 	"NO_SYNC", 		"Clock is not receiving Sync messages",			FALSE, ALRM_NO_SYNC,		FALSE, 		{alarmHandler_log}},
+    { "DLY", 	"NO_DELAY", 		"Clock is not receiving (p)Delay responses",		FALSE, ALRM_NO_DELAY,		FALSE, 		{alarmHandler_log}},
+    { "MSTC", 	"MASTER_CHANGE", 	"Best master has changed",				FALSE, ALRM_MASTER_CHANGE,	TRUE, 		{eventHandler_log}},
+    { "NWFL", 	"NETWORK_FAULT", 	"A network fault has occurred",				FALSE, ALRM_NETWORK_FLT,	FALSE, 		{alarmHandler_log}},
+    { "FADJ", 	"FAST_ADJ", 		"Clock is being adjusted too fast", 			FALSE, ALRM_FAST_ADJ,		FALSE, 		{alarmHandler_log}},
+    { "TPR", 	"TIMEPROP_CHANGE", 	"Time properties have changed",				FALSE, ALRM_TIMEPROP_CHANGE,	TRUE, 		{eventHandler_log}},
+    { "DOM", 	"DOMAIN_MISMATCH", 	"Clock is receiving all messages from incorrect domain",FALSE, ALRM_DOMAIN_MISMATCH,	FALSE, 		{alarmHandler_log}}
+    if(count > ALRM_MAX) return;
+    memset(alarms, 0, count * sizeof(AlarmEntry));
+    memcpy(alarms, alarmTemplate, sizeof(alarmTemplate));
+    for(int i = 0; i < count; i++) {
+	alarms[i].userData = userData;
+ * we are passing a generic pointer because eventually the alarm will have a "source" field,
+ * that being PTP, NTP or any other subsystem, which may have separate routines to handle this
+void
+configureAlarms(AlarmEntry *alarms, int count, void * userData)
+    PtpClock *ptpClock = (PtpClock*) userData;
+	alarms[i].minAge = ptpClock->rtOpts->alarmMinAge;
+	alarms[i].enabled = ptpClock->rtOpts->alarmsEnabled;
+#ifdef PTPD_SNMP
+	if(ptpClock->rtOpts->snmpEnabled && ptpClock->rtOpts->snmpTrapsEnabled) {
+	    DBG("SNMP alarm handler attached for %s\n", alarms[i].name);
+	    alarms[i].handlers[1] = alarmHandler_snmp;
+	} else {
+	    alarms[i].handlers[1] = NULL;
+#endif
+void
+enableAlarms(AlarmEntry* alarms, int count, Boolean enabled)
+	alarms[i].enabled = enabled;
+void
+setAlarmCondition(AlarmEntry *alarm, Boolean condition, PtpClock *ptpClock)
+	if(!alarm->enabled) {
+	    return;
+	Boolean change = condition ^ alarm->condition;
+	/* if there is no change, exit */
+	if(!change) {
+	    return;
+	/* condition has cleared but event has not yet been processed - don't touch it */
+	if(!condition && alarm->unhandled) {
+	    return;
+	/* capture event data and time if condition is met */
+	capturePtpEventData(&alarm->eventData, ptpClock, ptpClock->rtOpts);
+	if(condition) {
+	    getTime(&alarm->timeSet);
+	} else {
+	    getTime(&alarm->timeCleared);
+	DBG("Alarm %s condition set to %s\n", alarm->name, condition ? "TRUE" : "FALSE");
+	alarm->age = 0;
+	alarm->condition = condition;
+	alarm->unhandled = TRUE;
+void
+capturePtpEventData(PtpEventData *eventData, PtpClock *ptpClock, RunTimeOpts *rtOpts)
+    eventData->defaultDS = ptpClock->defaultDS;
+    eventData->currentDS = ptpClock->currentDS;
+    eventData->timePropertiesDS = ptpClock->timePropertiesDS;
+    eventData->portDS = ptpClock->portDS;
+    eventData->parentDS = ptpClock->parentDS;
+    if(ptpClock->bestMaster != NULL) {
+	eventData->bestMaster = *ptpClock->bestMaster;
+    } else {
+	memset(&eventData->bestMaster, 0, sizeof(ForeignMasterRecord));
+    eventData->ofmAlarmThreshold = rtOpts->ofmAlarmThreshold;
+ * this is our asynchronous event/alarm processor / state machine. ALARM_TIMEOUT_PERIOD protects us from alarms flapping,
+ * and ensures that an alarm will last at least n seconds: notification is processed only when the alarm is set for the
+ * first time (from UNSET state), and is not cancelled until the timeout passes (in the meantime, alarm condition can be
+ * triggered again and timer is reset, so it can flap at will), and cancel notification will only be sent when the condition
+ * has cleared and timeout has passed.
+void
+updateAlarms(AlarmEntry *alarms, int count)
+    DBG("updateAlarms()\n");
+    AlarmEntry *alarm;
+    AlarmState lastState;
+	alarm = &alarms[i];
+	    continue;
+	lastState = alarm->state;
+	/* this is a one-off event */
+	if(alarm->eventOnly) {
+	    if(alarm->condition) {
+		dispatchEvent(alarm);
+	} else {
+	/* this is an alarm */
+	    if(!alarm->condition) {
+		/* condition is false, alarm is cleared and aged out: unset */
+		if(alarm->state == ALARM_CLEARED && alarm->age >= alarm->minAge ) {
+		    alarm->state = ALARM_UNSET;
+		    /* inform, run handlers */
+		    dispatchAlarm(alarm);
+		    clearTime(&alarm->timeSet);
+		    clearTime(&alarm->timeCleared);
+		/* condition is false and alarm was set - clear and wait for age out */
+		} else if (alarm->state == ALARM_SET) {
+		    alarm->state = ALARM_CLEARED;
+	    /* condition is true and age is 0: condition just changed */
+	    } else if (alarm->age == 0) {
+		alarm->state = ALARM_SET;
+		/* react only if alarm was set from unset (don't inform multiple times until it fully clears */
+		if(lastState == ALARM_UNSET) {
+	    alarm->age+=ALARM_UPDATE_INTERVAL;
+	alarm->unhandled = FALSE;
+void
+displayAlarms(AlarmEntry *alarms, int count)
+    INFO("----------------------------------------------\n");
+    INFO("              Alarm status: \n");
+    INFO("ALARM NAME\t| STATE    | DESCRIPTION\n");
+    for(int i=0; i < count; i++) {
+	if(alarms[i].eventOnly) continue;
+	INFO("%-15s\t| %-8s | %s\n",  alarms[i].name,
+				    alarmStateToString(alarms[i].state),
+				    alarms[i].description);
+/* populate @output with a one-line alarm summary, consisting of multiple:
+ *  ALCD[x]
+ * where:
+ * - ALCD is the short name(code)
+ * - x is "!" when alarm is set
+ * - x is "." when alarm is cleared
+ * - when alarm is gone (unset) its code is not listed
+ * Returning the number of bytes written. When output is null, only the number of bytes needed is returned
+ * (e.g. to allow us to allocate a buffer)
+int
+getAlarmSummary(char * output, int size, AlarmEntry *alarms, int count)
+    int len = 0;
+    int i = 0;
+    char item[9];
+    if(output != NULL) {
+	memset(output, 0, size);
+    for(i=0; i < count; i++) {
+	memset(item, 0, 8);
+	    continue;
+	strncpy(item, alarm->shortName, 4);
+	snprintf(item + strlen(item), 5, "[%s] ", alarm->state == ALARM_SET ? "!" : ".");
+	    strncat(output, item, size - len);
+	len += strlen(item) + 1;
+    return len + 1;
diff --git a/freebsd/contrib/ptpd/src/dep/alarms.h b/freebsd/contrib/ptpd/src/dep/alarms.h
index 00000000..0a1d3f18
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/alarms.h
@@ -0,0 +1,100 @@
+#ifndef PTPDALARMS_H_
+#define PTPDALARMS_H_
+ * Copyright (c) 2015      Wojciech Owczarek,
+ * met:
+ * @file    alarms.h
+ * Data type and function definitions related to
+ * handling raising and clearing alarms.
+#include "../datatypes.h"
+#define DOMAIN_MISMATCH_MIN 10	/* trigger domain mismatch alarm after at least 10 mismatches */
+#define ALARM_UPDATE_INTERVAL 1 /* how often we process alarms */
+#define ALARM_TIMEOUT_PERIOD 30	/* minimal alarm age to clear */
+#define ALARM_HANDLERS_MAX 3	/* max number of alarm handlers */
+#define ALARM_MESSAGE_LENGTH 100/* length of an alarm-specific message string */
+/* explicitly numbered because these are referenced in the MIB as textual convention */
+typedef enum {
+	ALRM_PORT_STATE = 0,		/*x done*/
+	ALRM_OFM_THRESHOLD = 1,		/*x done */
+	ALRM_OFM_SECONDS = 2, 		/*x done*/
+	ALRM_CLOCK_STEP = 3,		/*x done*/
+	ALRM_NO_SYNC = 4,		/*x done*/
+	ALRM_NO_DELAY = 5, 			/*x done*/
+	ALRM_MASTER_CHANGE = 6, 		/*x done*/
+	ALRM_NETWORK_FLT = 7,		/*x done*/
+	ALRM_FAST_ADJ = 8,			/*+/- currently only at maxppb */
+	ALRM_TIMEPROP_CHANGE = 9,		/*x done*/
+	ALRM_DOMAIN_MISMATCH = 10, 		/*+/- currently only when all packets come from an incorrect domain */
+	ALRM_MAX
+} AlarmType;
+typedef enum {
+	ALARM_UNSET = 0,		/* idle */
+	ALARM_SET = 1,			/* condition has been triggerd */
+	ALARM_CLEARED = 2		/* condition has cleared */
+} AlarmState;
+struct _alarmEntry {
+	char shortName[5];		/* short code i.e. OFS, DLY, SYN, FLT etc. */
+	char name[31];			/* full name i.e. OFFSET_THRESHOLD, NO_DELAY, NO_SYNC etc. */
+	char description[101];		/* text description */
+	Boolean enabled;		/* is the alarm operational ? */
+	uint8_t id; 			/* alarm ID */
+	Boolean eventOnly;		/* this is only an event - don't manage state, just dispatch/inform when condition is met */
+	void (*handlers[ALARM_HANDLERS_MAX])(struct _alarmEntry *); /* alarm handlers */
+	void * userData;		/* user data pointer */
+	Boolean unhandled;		/* this event is pending pick-up - prevets from clearing condition until it's handled */
+	uint32_t age;			/* age of alarm in current state (seconds) */
+	uint32_t minAge;			/* minimum age of alarm (time between set and clear notification - condition can go away earlier */
+	AlarmState state;		/* state of the alarm */
+	Boolean condition;		/* is the alarm condition met? (so we can check conditions and set alarms separately */
+	TimeInternal timeSet;		/* time when set */
+	TimeInternal timeCleared;	/* time when cleared */
+	Boolean internalOnly;		/* do not display in status file / indicate that the alarm is internal only */
+	PtpEventData eventData;		/* the event data union - so we can capture any data we need without the need to capture a whole PtpClock */
+typedef struct _alarmEntry AlarmEntry;
+void initAlarms(AlarmEntry* alarms, int count, void* userData); 			/* fill an array with initial alarm data */
+void configureAlarms(AlarmEntry* alarms, int count, void* userData); 			/* fill an array with initial alarm data */
+void enableAlarms(AlarmEntry* alarms, int count, Boolean enabled); 			/* enable/disable all alarms */
+void updateAlarms(AlarmEntry *alarms, int count);					/* dispatch alarms: age, set, clear alarms etc. */
+void displayAlarms(AlarmEntry *alarms, int count);					/* display a formatted alarm summary table */
+int  getAlarmSummary(char * output, int size, AlarmEntry *alarms, int count);		/* produce a one-line alarm summary string */
+void handleAlarm(AlarmEntry *alarms, void *userData);
+#endif /*PTPDALARMS_H_*/
diff --git a/freebsd/contrib/ptpd/src/dep/configdefaults.c b/freebsd/contrib/ptpd/src/dep/configdefaults.c
index 00000000..16509b00
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/configdefaults.c
@@ -0,0 +1,675 @@
+/* Copyright (c) 2013-2015 Wojciech Owczarek,
+ * met:
+ * @file   configtemplates.c
+ * @date   Mon Oct 12 03:25:32 2015
+ * @brief  Definitions of configuration templates
+#define CONFIG_ISTRUE(key) \
+	(iniparser_getboolean(dict,key,FALSE)==TRUE)
+#define CONFIG_ISSET(key) \
+	(strcmp(iniparser_getstring(dict, key, ""),"") != 0)
+#define IS_QUIET()\
+	( CONFIG_ISTRUE("%quiet%:%quiet%") )
+ * static definition of configuration templates - maximum 100 settings per template,
+ * as defined in configtemplates.h. Template for a template below.
+/* =============== configuration templates begin ===============*/
+static const ConfigTemplate configTemplates[] = {
+    { "g8265-e2e-master", "ITU-T G.8265.1 (Telecom profile) unicast master", {
+	{"ptpengine:preset", "masteronly"},
+	{"ptpengine:ip_mode", "unicast"},
+	{"ptpengine:unicast_negotiation", "y"},
+	{"ptpengine:domain", "4"},
+	{"ptpengine:disable_bmca", "y"},
+	{"ptpengine:delay_mechanism", "E2E"},
+	{"ptpengine:log_sync_interval", "-6"},
+	{"ptpengine:log_delayreq_interval", "-6"},
+	{"ptpengine:announce_receipt_timeout", "3"},
+	{"ptpengine:priority1", "128"},
+	{"ptpengine:priority2", "128"},
+	{NULL}}
+    { "g8265-e2e-slave", "ITU-T G.8265.1 (Telecom profile) unicast slave", {
+	{"ptpengine:preset", "slaveonly"},
+	{NULL}}
+    { "layer2-p2p-master", "Layer 2 master using Peer to Peer", {
+	{"ptpengine:transport","ethernet"},
+	{"ptpengine:delay_mechanism","P2P"},
+	{"ptpengine:preset","masteronly"},
+	{NULL}}
+    { "layer2-p2p-slave", "Layer 2 slave running End to End", {
+	{"ptpengine:delay_mechanism","E2E"},
+	{"ptpengine:preset","slaveonly"},
+	{NULL}}
+    { "valid-utc-properties", "Basic property set to announce valid UTC, UTC offset and leap seconds", {
+	{"ptpengine:ptp_timescale","PTP"},
+	{"ptpengine:time_traceable","y"},
+	{"ptpengine:frequency_traceable","y"},
+	{"clock:leap_seconds_file", DATADIR"/"PACKAGE_NAME"/leap-seconds.list"},
+	 * UTC offset value and UTC offset valid flag
+	 * will be announced if leap file is parsed and up to date
+	{NULL}}
+    { "full-logging", "Enable logging for all facilities (statistics, status, log file)", {
+	{"global:log_status", "y"},
+	{"global:status_file", "/var/run/ptpd2.status"},
+	{"global:statistics_log_interval", "1"},
+	{"global:lock_file", "/var/run/ptpd2.pid"},
+	{"global:log_statistics", "y"},
+	{"global:statistics_file", "/var/log/ptpd2.statistics"},
+//	{"global:statistics_file_truncate", "n"},
+	{"global:log_file", "/var/log/ptpd2.log"},
+	{"global:statistics_timestamp_format", "both"},
+	{NULL}}
+    { "full-logging-instance", "Logging for all facilities using 'instance' variable which the user should provide", {
+	{"global:status_file", "@rundir@/ptpd2. at instance@.status"},
+	{"global:lock_file", "@rundir@/ptpd2. at instance@.pid"},
+	{"global:statistics_file", "@logdir@/ptpd2. at instance@.statistics"},
+	{"global:log_file", "@logdir@/ptpd2. at instance@.log"},
+	{NULL}}
+    {NULL}
+/* =============== configuration templates end ===============*/
+/* template of a template looks like this... */
+    { "template-name", "template description", {
+	{"section:key","value"},
+	{NULL}}
+	{NULL}}
+/* Load all rtOpts defaults */
+void
+loadDefaultSettings( RunTimeOpts* rtOpts )
+	/* Wipe the memory first to avoid unconsistent behaviour - no need to set Boolean to FALSE, int to 0 etc. */
+	memset(rtOpts, 0, sizeof(RunTimeOpts));
+	rtOpts->logAnnounceInterval = DEFAULT_ANNOUNCE_INTERVAL;
+	rtOpts->logSyncInterval = DEFAULT_SYNC_INTERVAL;
+	rtOpts->logMinPdelayReqInterval = DEFAULT_PDELAYREQ_INTERVAL;
+	rtOpts->clockQuality.clockAccuracy = DEFAULT_CLOCK_ACCURACY;
+	rtOpts->clockQuality.clockClass = DEFAULT_CLOCK_CLASS;
+	rtOpts->clockQuality.offsetScaledLogVariance = DEFAULT_CLOCK_VARIANCE;
+	rtOpts->priority1 = DEFAULT_PRIORITY1;
+	rtOpts->priority2 = DEFAULT_PRIORITY2;
+	rtOpts->domainNumber = DEFAULT_DOMAIN_NUMBER;
+	rtOpts->portNumber = NUMBER_PORTS;
+	rtOpts->anyDomain = FALSE;
+	rtOpts->transport = UDP_IPV4;
+	/* timePropertiesDS */
+	rtOpts->timeProperties.currentUtcOffsetValid = DEFAULT_UTC_VALID;
+	rtOpts->timeProperties.currentUtcOffset = DEFAULT_UTC_OFFSET;
+	rtOpts->timeProperties.timeSource = INTERNAL_OSCILLATOR;
+	rtOpts->timeProperties.timeTraceable = FALSE;
+	rtOpts->timeProperties.frequencyTraceable = FALSE;
+	rtOpts->timeProperties.ptpTimescale = TRUE;
+	rtOpts->ipMode = IPMODE_MULTICAST;
+	rtOpts->dot1AS = FALSE;
+	rtOpts->disableUdpChecksums = TRUE;
+	rtOpts->unicastNegotiation = FALSE;
+	rtOpts->unicastNegotiationListening = FALSE;
+	rtOpts->disableBMCA = FALSE;
+	rtOpts->unicastGrantDuration = 300;
+	rtOpts->unicastAcceptAny = FALSE;
+	rtOpts->unicastPortMask = 0;
+	rtOpts->noAdjust = NO_ADJUST;  // false
+	rtOpts->logStatistics = TRUE;
+	rtOpts->statisticsTimestamp = TIMESTAMP_DATETIME;
+	rtOpts->periodicUpdates = FALSE; /* periodically log a status update */
+	/* Deep display of all packets seen by the daemon */
+	rtOpts->displayPackets = FALSE;
+	rtOpts->s = DEFAULT_DELAY_S;
+	rtOpts->inboundLatency.nanoseconds = DEFAULT_INBOUND_LATENCY;
+	rtOpts->outboundLatency.nanoseconds = DEFAULT_OUTBOUND_LATENCY;
+	rtOpts->max_foreign_records = DEFAULT_MAX_FOREIGN_RECORDS;
+	rtOpts->nonDaemon = FALSE;
+	 * defaults for new options
+	rtOpts->ignore_delayreq_interval_master = FALSE;
+	rtOpts->do_IGMP_refresh = TRUE;
+	rtOpts->useSysLog       = FALSE;
+	rtOpts->announceReceiptTimeout  = DEFAULT_ANNOUNCE_RECEIPT_TIMEOUT;
+	rtOpts->debug_level = LOG_INFO;			/* by default debug messages as disabled, but INFO messages and below are printed */
+#endif
+	rtOpts->ttl = 64;
+	rtOpts->delayMechanism   = DEFAULT_DELAY_MECHANISM;
+	rtOpts->noResetClock     = DEFAULT_NO_RESET_CLOCK;
+	rtOpts->portDisabled	 = FALSE;
+	rtOpts->stepOnce	 = FALSE;
+	rtOpts->stepForce	 = FALSE;
+#ifdef HAVE_LINUX_RTC_H
+	rtOpts->setRtc		 = FALSE;
+#endif /* HAVE_LINUX_RTC_H */
+	rtOpts->clearCounters = FALSE;
+	rtOpts->statisticsLogInterval = 0;
+	rtOpts->initial_delayreq = DEFAULT_DELAYREQ_INTERVAL;
+	rtOpts->logMinDelayReqInterval = DEFAULT_DELAYREQ_INTERVAL;
+	rtOpts->autoDelayReqInterval = TRUE;
+	rtOpts->masterRefreshInterval = 60;
+	/* maximum values for unicast negotiation */
+    	rtOpts->logMaxPdelayReqInterval = 5;
+	rtOpts->logMaxDelayReqInterval = 5;
+	rtOpts->logMaxSyncInterval = 5;
+	rtOpts->logMaxAnnounceInterval = 5;
+	rtOpts->drift_recovery_method = DRIFT_KERNEL;
+	strncpy(rtOpts->lockDirectory, DEFAULT_LOCKDIR, PATH_MAX);
+	strncpy(rtOpts->driftFile, DEFAULT_DRIFTFILE, PATH_MAX);
+/*	strncpy(rtOpts->lockFile, DEFAULT_LOCKFILE, PATH_MAX); */
+	rtOpts->autoLockFile = FALSE;
+	rtOpts->snmpEnabled = FALSE;
+	rtOpts->snmpTrapsEnabled = FALSE;
+	rtOpts->alarmsEnabled = FALSE;
+	rtOpts->alarmInitialDelay = 0;
+	rtOpts->alarmMinAge = 30;
+	/* This will only be used if the "none" preset is configured */
+#ifndef PTPD_SLAVE_ONLY
+	rtOpts->slaveOnly = FALSE;
+#else
+	rtOpts->slaveOnly = TRUE;
+#endif /* PTPD_SLAVE_ONLY */
+	/* Otherwise default to slave only via the preset */
+	rtOpts->selectedPreset = PTP_PRESET_SLAVEONLY;
+	rtOpts->pidAsClockId = FALSE;
+	strncpy(rtOpts->portDescription,"ptpd", sizeof(rtOpts->portDescription));
+	/* highest possible */
+	rtOpts->logLevel = LOG_ALL;
+	/* ADJ_FREQ_MAX by default */
+	rtOpts->servoMaxPpb = ADJ_FREQ_MAX / 1000;
+	/* kP and kI are scaled to 10000 and are gains now - values same as originally */
+	rtOpts->servoKP = 0.1;
+	rtOpts->servoKI = 0.001;
+	rtOpts->servoDtMethod = DT_CONSTANT;
+	/* when measuring dT, use a maximum of 5 sync intervals (would correspond to avg 20% discard rate) */
+	rtOpts->servoMaxdT = 5.0;
+	/* disabled by default */
+	rtOpts->announceTimeoutGracePeriod = 0;
+	/* currentUtcOffsetValid compatibility flags */
+	rtOpts->alwaysRespectUtcOffset = TRUE;
+	rtOpts->preferUtcValid = FALSE;
+	rtOpts->requireUtcValid = FALSE;
+	/* Try 46 for expedited forwarding */
+	rtOpts->dscpValue = 0;
+	rtOpts-> cpuNumber = -1;
+#endif /* (linux && HAVE_SCHED_H) || HAVE_SYS_CPUSET_H*/
+#ifdef PTPD_STATISTICS
+	rtOpts->oFilterMSConfig.enabled = FALSE;
+	rtOpts->oFilterMSConfig.discard = TRUE;
+	rtOpts->oFilterMSConfig.autoTune = TRUE;
+	rtOpts->oFilterMSConfig.stepDelay = FALSE;
+	rtOpts->oFilterMSConfig.alwaysFilter = FALSE;
+	rtOpts->oFilterMSConfig.stepThreshold = 1000000;
+	rtOpts->oFilterMSConfig.stepLevel = 500000;
+	rtOpts->oFilterMSConfig.capacity = 20;
+	rtOpts->oFilterMSConfig.threshold = 1.0;
+	rtOpts->oFilterMSConfig.weight = 1;
+	rtOpts->oFilterMSConfig.minPercent = 20;
+	rtOpts->oFilterMSConfig.maxPercent = 95;
+	rtOpts->oFilterMSConfig.thresholdStep = 0.1;
+	rtOpts->oFilterMSConfig.minThreshold = 0.1;
+	rtOpts->oFilterMSConfig.maxThreshold = 5.0;
+	rtOpts->oFilterMSConfig.delayCredit = 200;
+	rtOpts->oFilterMSConfig.creditIncrement = 10;
+	rtOpts->oFilterMSConfig.maxDelay = 1500;
+	rtOpts->oFilterSMConfig.enabled = FALSE;
+	rtOpts->oFilterSMConfig.discard = TRUE;
+	rtOpts->oFilterSMConfig.autoTune = TRUE;
+	rtOpts->oFilterSMConfig.stepDelay = FALSE;
+	rtOpts->oFilterSMConfig.alwaysFilter = FALSE;
+	rtOpts->oFilterSMConfig.stepThreshold = 1000000;
+	rtOpts->oFilterSMConfig.stepLevel = 500000;
+	rtOpts->oFilterSMConfig.capacity = 20;
+	rtOpts->oFilterSMConfig.threshold = 1.0;
+	rtOpts->oFilterSMConfig.weight = 1;
+	rtOpts->oFilterSMConfig.minPercent = 20;
+	rtOpts->oFilterSMConfig.maxPercent = 95;
+	rtOpts->oFilterSMConfig.thresholdStep = 0.1;
+	rtOpts->oFilterSMConfig.minThreshold = 0.1;
+	rtOpts->oFilterSMConfig.maxThreshold = 5.0;
+	rtOpts->oFilterSMConfig.delayCredit = 200;
+	rtOpts->oFilterSMConfig.creditIncrement = 10;
+	rtOpts->oFilterSMConfig.maxDelay = 1500;
+	rtOpts->filterMSOpts.enabled = FALSE;
+	rtOpts->filterMSOpts.filterType = FILTER_MIN;
+	rtOpts->filterMSOpts.windowSize = 4;
+	rtOpts->filterMSOpts.windowType = WINDOW_SLIDING;
+	rtOpts->filterSMOpts.enabled = FALSE;
+	rtOpts->filterSMOpts.filterType = FILTER_MIN;
+	rtOpts->filterSMOpts.windowSize = 4;
+	rtOpts->filterSMOpts.windowType = WINDOW_SLIDING;
+	/* How often refresh statistics (seconds) */
+	rtOpts->statsUpdateInterval = 30;
+	/* Servo stability detection settings follow */
+	rtOpts->servoStabilityDetection = FALSE;
+	/* Stability threshold (ppb) - observed drift std dev value considered stable */
+	rtOpts->servoStabilityThreshold = 10;
+	/* How many consecutive statsUpdateInterval periods of observed drift std dev within threshold  means stable servo */
+	rtOpts->servoStabilityPeriod = 1;
+	/* How many minutes without servo stabilisation means servo has not stabilised */
+	rtOpts->servoStabilityTimeout = 10;
+	/* How long to wait for one-way delay prefiltering */
+	rtOpts->calibrationDelay = 0;
+	/* if set to TRUE and maxDelay is defined, only check against threshold if servo is stable */
+	rtOpts->maxDelayStableOnly = FALSE;
+	/* if set to non-zero, reset slave if more than this amount of consecutive delay measurements was above maxDelay */
+	rtOpts->maxDelayMaxRejected = 0;
+#endif
+	/* status file options */
+	rtOpts->statusFileUpdateInterval = 1;
+	rtOpts->ofmAlarmThreshold = 0;
+	/* panic mode options */
+	rtOpts->enablePanicMode = FALSE;
+	rtOpts->panicModeDuration = 2;
+	rtOpts->panicModeExitThreshold = 0;
+	/* full network reset after 5 times in listening */
+	rtOpts->maxListen = 5;
+	rtOpts->panicModeReleaseClock = FALSE;
+	rtOpts->ntpOptions.enableEngine = FALSE;
+	rtOpts->ntpOptions.enableControl = FALSE;
+	rtOpts->ntpOptions.enableFailover = FALSE;
+	rtOpts->ntpOptions.failoverTimeout = 120;
+	rtOpts->ntpOptions.checkInterval = 15;
+	rtOpts->ntpOptions.keyId = 0;
+	strncpy(rtOpts->ntpOptions.hostAddress,"localhost",MAXHOSTNAMELEN); 	/* not configurable, but could be */
+	rtOpts->preferNTP = FALSE;
+	rtOpts->leapSecondPausePeriod = 5;
+	/* by default, announce the leap second 12 hours before the event:
+	 * Clause 9.4 paragraph 5 */
+	rtOpts->leapSecondNoticePeriod = 43200;
+	rtOpts->leapSecondHandling = LEAP_ACCEPT;
+	rtOpts->leapSecondSmearPeriod = 86400;
+/* timing domain */
+	rtOpts->idleTimeout = 120; /* idle timeout */
+	rtOpts->electionDelay = 15; /* anti-flapping delay */
+/* Log file settings */
+	rtOpts->statisticsLog.logID = "statistics";
+	rtOpts->statisticsLog.openMode = "a+";
+	rtOpts->statisticsLog.logFP = NULL;
+	rtOpts->statisticsLog.truncateOnReopen = FALSE;
+	rtOpts->statisticsLog.unlinkOnClose = FALSE;
+	rtOpts->statisticsLog.maxSize = 0;
+	rtOpts->recordLog.logID = "record";
+	rtOpts->recordLog.openMode = "a+";
+	rtOpts->recordLog.logFP = NULL;
+	rtOpts->recordLog.truncateOnReopen = FALSE;
+	rtOpts->recordLog.unlinkOnClose = FALSE;
+	rtOpts->recordLog.maxSize = 0;
+	rtOpts->eventLog.logID = "log";
+	rtOpts->eventLog.openMode = "a+";
+	rtOpts->eventLog.logFP = NULL;
+	rtOpts->eventLog.truncateOnReopen = FALSE;
+	rtOpts->eventLog.unlinkOnClose = FALSE;
+	rtOpts->eventLog.maxSize = 0;
+	rtOpts->statusLog.logID = "status";
+	rtOpts->statusLog.openMode = "w";
+	strncpy(rtOpts->statusLog.logPath, DEFAULT_STATUSFILE, PATH_MAX);
+	rtOpts->statusLog.logFP = NULL;
+	rtOpts->statusLog.truncateOnReopen = FALSE;
+	rtOpts->statusLog.unlinkOnClose = TRUE;
+/* Management message support settings */
+	rtOpts->managementEnabled = TRUE;
+	rtOpts->managementSetEnable = FALSE;
+/* IP ACL settings */
+	rtOpts->timingAclEnabled = FALSE;
+	rtOpts->managementAclEnabled = FALSE;
+	rtOpts->timingAclOrder = ACL_DENY_PERMIT;
+	rtOpts->managementAclOrder = ACL_DENY_PERMIT;
+	// by default we don't check Sync message sequence continuity
+	rtOpts->syncSequenceChecking = FALSE;
+	rtOpts->clockUpdateTimeout = 0;
+/* The PtpEnginePreset structure for reference:
+typedef struct {
+    char* presetName;
+    Boolean slaveOnly;
+    Boolean noAdjust;
+    UInteger8_option clockClass;
+} PtpEnginePreset;
+PtpEnginePreset
+getPtpPreset(int presetNumber, RunTimeOpts* rtOpts)
+	PtpEnginePreset ret;
+	memset(&ret,0,sizeof(ret));
+	switch(presetNumber) {
+	case PTP_PRESET_SLAVEONLY:
+		ret.presetName="slaveonly";
+		ret.slaveOnly = TRUE;
+		ret.noAdjust = FALSE;
+		ret.clockClass.minValue = SLAVE_ONLY_CLOCK_CLASS;
+		ret.clockClass.maxValue = SLAVE_ONLY_CLOCK_CLASS;
+		ret.clockClass.defaultValue = SLAVE_ONLY_CLOCK_CLASS;
+		break;
+	case PTP_PRESET_MASTERSLAVE:
+		ret.presetName = "masterslave";
+		ret.slaveOnly = FALSE;
+		ret.clockClass.minValue = 128;
+		ret.clockClass.maxValue = 254;
+		ret.clockClass.defaultValue = DEFAULT_CLOCK_CLASS;
+		break;
+	case PTP_PRESET_MASTERONLY:
+		ret.presetName = "masteronly";
+		ret.noAdjust = TRUE;
+		ret.clockClass.minValue = 0;
+		ret.clockClass.maxValue = 127;
+		ret.clockClass.defaultValue = DEFAULT_CLOCK_CLASS__APPLICATION_SPECIFIC_TIME_SOURCE;
+		break;
+	default:
+		ret.presetName = "none";
+		ret.slaveOnly = rtOpts->slaveOnly;
+		ret.noAdjust = rtOpts->noAdjust;
+		ret.clockClass.maxValue = 255;
+		ret.clockClass.defaultValue = rtOpts->clockQuality.clockClass;
+	return ret;
+/* Apply template search from dictionary src to dictionary dst */
+static int
+applyTemplateFromDictionary(dictionary *dict, dictionary *src, char *search, int overwrite) {
+	char *key, *value, *pos;
+	int i = 0;
+	int found;
+	/* -1 on not found, 0+ on actual applies */
+	found = -1;
+	for(i=0; i<src->n; i++) {
+	    key = src->key[i];
+	    value = src->val[i];
+	    pos = strstr(key, ":");
+	    if(value != NULL  && pos != NULL) {
+		*pos =  '\0';
+		pos++;
+		if(!strcmp(search, key) && (strstr(pos,":") != NULL)) {
+		    if(found < 0) found = 0;
+		    if( overwrite || !CONFIG_ISSET(pos)) {
+			DBG("template %s setting %s to %s\n", search, pos, value);
+			dictionary_set(dict, pos, value);
+			found++;
+		/* reverse the damage - no need for strdup() */
+		pos--;
+		*pos = ':';
+	return found;
+static void loadFileList(dictionary *dict, char *list) {
+    char* stash;
+    char* text_;
+    char* text__;
+    char *filename;
+    if(dict == NULL) return;
+    if(!strlen(list)) return;
+    text_=strdup(list);
+    for(text__=text_;; text__=NULL) {
+	filename=strtok_r(text__,", ;\t",&stash);
+	if(filename==NULL) break;
+	if(!iniparser_merge_file(dict, filename,1)) {
+	    ERROR("Could not load template file %s\n", filename);
+	} else {
+	    INFO("Loaded template file %s\n",filename);
+    if(text_ != NULL) {
+	free(text_);
+/* split list to tokens, look for each template and apply it if found */
+int
+applyConfigTemplates(dictionary *target, char *templateNames, char *files) {
+    ConfigTemplate *template = NULL;
+    TemplateOption *option = NULL;
+    char *templateName = NULL;
+    int iFound = -1;
+    int fFound = -1;
+    dictionary *fileDict;
+    dictionary *dict;
+    char* stash;
+    char* text_;
+    char* text__;
+    if(target == NULL) {
+	return 0;
+    if(!strlen(templateNames)) return 0;
+    fileDict = dictionary_new(0);
+    dict = dictionary_new(0);
+    loadFileList(fileDict, DEFAULT_TEMPLATE_FILE);
+    loadFileList(fileDict, files);
+    text_=strdup(templateNames);
+	iFound = -1;
+	fFound = -1;
+	/* apply from built-in templates */
+	templateName=strtok_r(text__,", ;\t",&stash);
+	if(templateName==NULL) break;
+	template = (ConfigTemplate*)configTemplates;
+	while(template->name != NULL) {
+	    if(!strcmp(template->name, templateName)) {
+		if(iFound < 0) iFound = 0;
+		DBG("Loading built-in config template %s\n", template->name);
+		option = (TemplateOption*)template->options;
+		    while(option->name != NULL) {
+			dictionary_set(dict, option->name, option->value);
+			DBG("----> %s = %s",option->name, option->value);
+			option++;
+			iFound++;
+		break;
+	    template++;
+	/* apply from previously loaded files */
+	fFound = applyTemplateFromDictionary(dict, fileDict, templateName, 1);
+	if (!IS_QUIET()) {
+	    if((iFound < 0) && (fFound < 0)) {
+		WARNING("Configuration template \"%s\" not found\n", templateName);
+	    } else {
+		if(fFound < 0) fFound = 0;
+		NOTICE("Applied configuration template \"%s\" (%d matches)\n", templateName,
+			iFound + fFound);
+	free(text_);
+    /* preserve existing settings */
+    dictionary_merge(dict, target, 0 , !IS_QUIET(), NULL);
+    dictionary_del(&fileDict);
+    dictionary_del(&dict);
+    return 0;
+/* dump the list of templates provided */
+void
+dumpConfigTemplates() {
+	printf("\n");
+		printf("   Template: %s\n", template->name);
+		printf("Description: %s\n\n", template->description);
+			printf("\t\t%s=\"%s\"\n", option->name, option->value);
+			option++;
+	    template++;
+	    printf("\n-\n\n");
diff --git a/freebsd/contrib/ptpd/src/dep/configdefaults.h b/freebsd/contrib/ptpd/src/dep/configdefaults.h
index 00000000..4bca18ae
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/configdefaults.h
@@ -0,0 +1,52 @@
+ * @file   configdefaults.h
+ * @brief  definitions related to config templates and defaults
+#ifndef PTPD_CONFIGDEFAULTS_H_
+#define PTPD_CONFIGDEFAULTS_H_
+#include <stddef.h>
+#include "iniparser/iniparser.h"
+#define DEFAULT_TEMPLATE_FILE DATADIR"/"PACKAGE_NAME"/templates.conf"
+typedef struct {
+    char * name;
+    char * value;
+} TemplateOption;
+typedef struct {
+    char * name;
+    char * description;
+    TemplateOption options[100];
+} ConfigTemplate;
+/* Structure defining a PTP engine preset */
+typedef struct {
+    char* presetName;
+    Boolean noAdjust;
+} PtpEnginePreset;
+/* Preset definitions */
+enum {
+    PTP_PRESET_NONE,
+    PTP_PRESET_SLAVEONLY,
+    PTP_PRESET_MASTERSLAVE,
+    PTP_PRESET_MASTERONLY,
+    PTP_PRESET_MAX
+void loadDefaultSettings( RunTimeOpts* rtOpts );
+int applyConfigTemplates(dictionary *dict, char *templateNames, char *files);
+PtpEnginePreset getPtpPreset(int presetNumber, RunTimeOpts* rtOpts);
+void dumpConfigTemplates();
+#endif /* PTPD_CONFIGDEFAULTS_H_ */
diff --git a/freebsd/contrib/ptpd/src/dep/constants_dep.h b/freebsd/contrib/ptpd/src/dep/constants_dep.h
index 00000000..ad0f39f6
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/constants_dep.h
@@ -0,0 +1,251 @@
+/* constants_dep.h */
+#ifndef CONSTANTS_DEP_H
+#define CONSTANTS_DEP_H
+*\file
+* \brief Plateform-dependent constants definition
+* This header defines all includes and constants which are plateform-dependent
+* ptpdv2 is only implemented for linux, NetBSD and FreeBSD
+/* platform dependent */
+#if !defined(linux) && !defined(__NetBSD__) && !defined(__FreeBSD__) && \
+  !defined(__APPLE__) && !defined(__OpenBSD__) && !defined(__sun) && !defined(__QNXNTO__)
+#error PTPD hasn't been ported to this OS - should be possible \
+if it's POSIX compatible, if you succeed, report it to ptpd-devel at sourceforge.net
+#endif
+#ifdef	linux
+#include<netinet/in.h>
+#include<net/if.h>
+#include<net/if_arp.h>
+#include <ifaddrs.h>
+#define IFACE_NAME_LENGTH         IF_NAMESIZE
+#define NET_ADDRESS_LENGTH        INET_ADDRSTRLEN
+#define IFCONF_LENGTH 10
+#define octet ether_addr_octet
+#endif /* linux */
+#if defined(__NetBSD__) || defined(__FreeBSD__) || defined(__APPLE__) || defined(__OpenBSD__) || defined(__sun) || defined(__QNXNTO__)
+# include <sys/types.h>
+# include <sys/socket.h>
+#ifdef HAVE_SYS_SOCKIO_H
+#include <sys/sockio.h>
+#endif /* HAVE_SYS_SOCKIO_H */
+# include <netinet/in.h>
+# include <net/if.h>
+# include <net/if_dl.h>
+# include <net/if_types.h>
+#ifdef HAVE_NET_IF_ETHER_H
+#  include <net/if_ether.h>
+#endif
+#ifdef HAVE_SYS_UIO_H
+#  include <sys/uio.h>
+#endif
+#ifdef HAVE_NET_ETHERNET_H
+#  include <net/ethernet.h>
+#endif
+# define IFACE_NAME_LENGTH         IF_NAMESIZE
+# define NET_ADDRESS_LENGTH        INET_ADDRSTRLEN
+#ifdef HAVE_SYS_PARAM_H
+#include <sys/param.h>
+#endif /* HAVE_SYS_PARAM_H */
+#ifdef __QNXNTO__
+#include <sys/neutrino.h>
+#include <sys/syspage.h>
+#define BSD_INTERFACE_FUNCTIONS
+#endif /* __QNXNTO __ */
+#if !defined(ETHER_ADDR_LEN) && defined(ETHERADDRL)
+#	define ETHER_ADDR_LEN ETHERADDRL
+#endif /* ETHER_ADDR_LEN && ETHERADDRL */
+#ifndef ETHER_HDR_LEN
+#	define ETHER_HDR_LEN sizeof (struct ether_header)
+# define IFCONF_LENGTH 10
+# define adjtimex ntp_adjtime
+#endif
+#ifdef HAVE_MACHINE_ENDIAN_H
+#	include <machine/endian.h>
+#endif /* HAVE_MACHINE_ENDIAN_H */
+#ifdef HAVE_ENDIAN_H
+#	include <endian.h>
+#endif /* HAVE_ENDIAN_H */
+#ifdef HAVE_SYS_ISA_DEFS_H
+#	include <sys/isa_defs.h>
+#endif /* HAVE_SYS_ISA_DEFS_H */
+# if BYTE_ORDER == LITTLE_ENDIAN || defined(_LITTLE_ENDIAN) || (defined(__BYTE_ORDER) && __BYTE_ORDER == __LITTLE_ENDIAN)
+#   define PTPD_LSBF
+# elif BYTE_ORDER == BIG_ENDIAN || defined(_BIG_ENDIAN) || (defined(__BYTE_ORDER) && __BYTE_ORDER == __BIG_ENDIAN)
+#   define PTPD_MSBF
+# endif
+#define CLOCK_IDENTITY_LENGTH 8
+#define ADJ_FREQ_MAX 500000
+/* UDP/IPv4 dependent */
+#ifndef INADDR_LOOPBACK
+#define INADDR_LOOPBACK 0x7f000001UL
+#endif
+#define SUBDOMAIN_ADDRESS_LENGTH  4
+#define PORT_ADDRESS_LENGTH       2
+#define PTP_UUID_LENGTH           6
+#define FLAG_FIELD_LENGTH         2
+#define PACKET_SIZE  300
+#define PACKET_BEGIN_UDP (ETHER_HDR_LEN + sizeof(struct ip) + \
+	    sizeof(struct udphdr))
+#define PACKET_BEGIN_ETHER (ETHER_HDR_LEN)
+#define PTP_EVENT_PORT    319
+#define PTP_GENERAL_PORT  320
+#define DEFAULT_PTP_DOMAIN_ADDRESS     "224.0.1.129"
+#define PEER_PTP_DOMAIN_ADDRESS        "224.0.0.107"
+/* 802.3 Support */
+#define PTP_ETHER_DST "01:1b:19:00:00:00"
+#define PTP_ETHER_TYPE 0x88f7
+#define PTP_ETHER_PEER "01:80:c2:00:00:0E"
+#ifdef PTPD_UNICAST_MAX
+#define UNICAST_MAX_DESTINATIONS PTPD_UNICAST_MAX
+#else
+#define UNICAST_MAX_DESTINATIONS 16
+#endif /* PTPD_UNICAST_MAX */
+/* dummy clock driver designation in preparation for generic clock driver API */
+#define DEFAULT_CLOCKDRIVER "kernelclock"
+/* default lock file location and mode */
+#define DEFAULT_LOCKMODE F_WRLCK
+#define DEFAULT_LOCKDIR "/var/run"
+#define DEFAULT_LOCKFILE_NAME PTPD_PROGNAME".lock"
+//define DEFAULT_LOCKFILE_PATH  DEFAULT_LOCKDIR"/"DEFAULT_LOCKFILE_NAME
+#define DEFAULT_FILE_PERMS (S_IRUSR|S_IWUSR|S_IRGRP|S_IROTH)
+/* default drift file location */
+#define DEFAULT_DRIFTFILE "/etc/"PTPD_PROGNAME"_"DEFAULT_CLOCKDRIVER".drift"
+/* default status file location */
+#define DEFAULT_STATUSFILE DEFAULT_LOCKDIR"/"PTPD_PROGNAME".status"
+/* Highest log level (default) catches all */
+#define LOG_ALL LOG_DEBUGV
+/* Difference between Unix time / UTC and NTP time */
+#define NTP_EPOCH 2208988800ULL
+/* wait a maximum of 10 ms for a late TX timestamp */
+#define LATE_TXTIMESTAMP_US 10000
+/* drift recovery metod for use with -F */
+enum {
+	DRIFT_RESET = 0,
+	DRIFT_KERNEL,
+	DRIFT_FILE
+/* IP transmission mode */
+enum {
+	IPMODE_MULTICAST = 0,
+	IPMODE_UNICAST,
+	IPMODE_HYBRID,
+#if 0
+	IPMODE_UNICAST_SIGNALING
+#endif
+/* log timestamp mode */
+enum {
+	TIMESTAMP_DATETIME,
+	TIMESTAMP_UNIX,
+	TIMESTAMP_BOTH
+/* servo dT calculation mode */
+enum {
+	DT_NONE,
+	DT_CONSTANT,
+	DT_MEASURED
+/* StatFilter op type */
+enum {
+	FILTER_NONE,
+	FILTER_MEAN,
+	FILTER_MIN,
+	FILTER_MAX,
+	FILTER_ABSMIN,
+	FILTER_ABSMAX,
+	FILTER_MEDIAN,
+	FILTER_MAXVALUE
+/* StatFilter window type */
+enum {
+	WINDOW_INTERVAL,
+	WINDOW_SLIDING,
+//	WINDOW_OVERLAPPING
+/* Leap second handling */
+enum {
+	LEAP_ACCEPT,
+	LEAP_IGNORE,
+	LEAP_STEP,
+	LEAP_SMEAR
+/* Alarm codes */
+enum {
+	ALARM_PORTSTATE,
+	ALARM_OFFSET_THRESHOLD,
+	ALARM_CLOCK_STEP,
+	ALARM_OFFSET_1SEC
+#define MM_STARTING_BOUNDARY_HOPS  0x7fff
+/* others */
+/* bigger screen size constants */
+#define SCREEN_BUFSZ  228
+#define SCREEN_MAXSZ  180
+/* default size for string buffers */
+#define BUF_SIZE  1000
+#define NANOSECONDS_MAX 999999999
+// limit operator messages to once every X seconds
+#define OPERATOR_MESSAGES_INTERVAL 300.0
+#define MAX_SEQ_ERRORS 50
+#define MAXTIMESTR 32
+#endif /*CONSTANTS_DEP_H_*/
diff --git a/freebsd/contrib/ptpd/src/dep/daemonconfig.c b/freebsd/contrib/ptpd/src/dep/daemonconfig.c
new file mode 100644
index 00000000..5b55895f
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/daemonconfig.c
@@ -0,0 +1,3192 @@
+ * Copyright (c) 2013-2015 Wojciech Owczarek,
+ * met:
+ * @file   daemonconfig.c
+ * @date   Sun May 27 00:45:32 2013
+ * @brief  Code to handle configuration file and default settings
+ * Functions in this file deal with config file parsing, reloading,
+ * loading default parameters, parsing command-line options, printing
+ * help output, etc.
+ * Helper macros - this is effectively the API for using the new config file interface.
+ * The macros below cover all operations required in parsing the configuration.
+ * This allows the parseConfig() function to be very straightforward and easy to expand
+ * - it pretty much only uses macros at this stage. The use of macros reduces the
+ * complexity of the parseConfig fuction. A lot of the macros are designed to work
+ * within parseConfig - they assume the existence of the "dictionary*" dict variable.
+static void printComment(const char* helptext);
+static int configSettingChanged(dictionary *oldConfig, dictionary *newConfig, const char *key);
+static void warnRestart(const char *key, int flags);
+static int configMapBoolean(int opCode, void *opArg,  dictionary* dict,
+	dictionary *target, const char * key, int restartFlags, Boolean *var, Boolean def, const char* helptext);
+static int configMapString(int opCode, void *opArg,  dictionary *dict,
+	dictionary *target, const char *key, int restartFlags, char *var, int size, char *def, const char* helptext);
+static int checkRangeInt(dictionary *dict, const char *key, int rangeFlags, int minBound, int maxBound);
+static int configMapInt(int opCode, void *opArg,  dictionary *dict,
+	dictionary *target, const char *key, int restartFlags, int intType, void *var, int def,
+	const char *helptext, int rangeFlags, int minBound, int maxBound);
+static int checkRangeDouble(dictionary *dict, const char *key, int rangeFlags, double minBound, double maxBound);
+static int configMapDouble(int opCode, void *opArg,  dictionary *dict,
+	dictionary *target, const char *key, int restartFlags, double *var, double def,
+	const char *helptext, int rangeFlags, double minBound, double maxBound);
+static int configMapSelectValue(int opCode, void *opArg,  dictionary *dict,
+	dictionary *target, const char* key, int restartFlags, uint8_t *var, int def, const char *helptext, ...);
+static void parseUserVariables(dictionary *dict, dictionary *target);
+static void findUnknownSettings(int opCode, dictionary* source, dictionary* dict);
+/* Basic helper macros */
+#define STRING_EMPTY(string)\
+	(!strcmp(string,""))
+#define CONFIG_ISPRESENT(key) \
+	(iniparser_find_entry(dict, key) != 0)
+#define DICT_ISTRUE(dict,key) \
+/* Macros handling required settings, triggers, conflicts and dependencies */
+#define CONFIG_KEY_REQUIRED(key) \
+	if( !(opCode & CFGOP_PARSE_QUIET) && !(opCode & CFGOP_HELP_FULL) && !(opCode & CFGOP_HELP_SINGLE)  && !CONFIG_ISSET(key) )\
+	    ERROR("Configuration error: option \"%s\" is required\n", key); \
+	    parseResult = FALSE;\
+#define CONFIG_KEY_DEPENDENCY(key1, key2) \
+	if( CONFIG_ISSET(key1) && \
+	    !CONFIG_ISSET(key2)) \
+	    if(!(opCode & CFGOP_PARSE_QUIET))\
+		ERROR("Configuration error: option \"%s\" requires option \"%s\"\n", key1, key2); \
+#define CONFIG_KEY_CONFLICT(key1, key2) \
+	    CONFIG_ISSET(key2)) \
+		ERROR("Configuration error: option \"%s\" cannot be used with option \"%s\"\n", key1, key2); \
+#define CONFIG_KEY_CONDITIONAL_WARNING_NOTSET(condition,dep,messageText) \
+	if ( (condition) && \
+	    !CONFIG_ISSET(dep) ) \
+		WARNING("Warning: %s\n", messageText); \
+#define CONFIG_KEY_CONDITIONAL_WARNING_ISSET(condition,dep,messageText) \
+	    CONFIG_ISSET(dep) ) \
+#define CONFIG_KEY_CONDITIONAL_DEPENDENCY(key,condition,stringval,dep) \
+		ERROR("Configuration error: option \"%s=%s\" requires option \"%s\"\n", key, stringval, dep); \
+#define CONFIG_KEY_CONDITIONAL_CONFLICT(key,condition,stringval,dep) \
+		ERROR("Configuration error: option \"%s=%s\" cannot be used with option \"%s\"\n", key, stringval, dep); \
+#define CONFIG_KEY_VALUE_FORBIDDEN(key,condition,stringval,message) \
+	    CONFIG_ISSET(key) ) \
+		ERROR("Configuration error: option \"%s=%s\" cannot be used: \n%s", key, stringval, message); \
+#define CONFIG_KEY_TRIGGER(key,variable,value, otherwise) \
+	if (CONFIG_ISSET(key) ) \
+	    variable = value;\
+	 } else { \
+	    variable = otherwise;\
+#define CONFIG_KEY_CONDITIONAL_TRIGGER(condition,variable,value,otherwise) \
+	if ((condition)) \
+	    variable = value; \
+	 } else { \
+	    variable = otherwise; \
+#define CONFIG_KEY_CONDITIONAL_ASSERTION(key,condition,warningtext) \
+		ERROR("%s\n", warningtext); \
+#define CONFIG_CONDITIONAL_ASSERTION(condition,warningtext) \
+	if ( (condition) ) \
+/* Macro printing a warning for a deprecated command-line option */
+#define WARN_DEPRECATED_COMMENT( old,new,long,key,comment )\
+printf("Note: The use of '-%c' option is deprecated %s- consider using '-%c' (--%s) or the %s setting\n",\
+	old, comment, new, long, key);
+#define WARN_DEPRECATED(old,new,long,key)\
+	WARN_DEPRECATED_COMMENT( old,new,long,key,"")
+#define CONFIG_KEY_ALIAS(src,dest) \
+		if(!STRING_EMPTY(dictionary_get(dict,src,""))) {\
+		    dictionary_set(dict,dest,dictionary_get(dict,src,""));\
+		    dictionary_unset(dict,src);\
+/* Output a potentially multi-line string, prefixed with ;s */
+static void
+printComment(const char* helptext)
+    int i, len;
+    len = strlen(helptext);
+    if(len > 0)
+	printf("\n; ");
+    for (i = 0; i < len; i++) {
+	printf("%c",helptext[i]);
+	if(helptext[i]=='\n') {
+	    printf("; ");
+	    while(i < len) {
+		if( helptext[++i]!=' ' && helptext[i]!='\t') {
+		    i--;
+		    break;
+    printf("\n");
+static int
+configSettingChanged(dictionary *oldConfig, dictionary *newConfig, const char *key)
+    return(strcmp(
+		    dictionary_get(newConfig, key,""),
+		    dictionary_get(oldConfig, key,"")
+		) != 0 );
+/* warn about restart required if needed */
+static void
+warnRestart(const char *key, int flags)
+	if(flags & PTPD_RESTART_DAEMON) {
+		NOTIFY("Change of %s setting requires "PTPD_PROGNAME" restart\n",key);
+	} else {
+		DBG("Setting %s changed, restart of subsystem %d required\n",key,flags);
+static int
+configMapBoolean(int opCode, void *opArg,  dictionary* dict, dictionary *target,
+		    const char * key, int restartFlags, Boolean *var, Boolean def, const char* helptext)
+	if(opCode & CFGOP_RESTART_FLAGS) {
+	    if(CONFIG_ISSET(key)) {
+		*(int*)opArg |= restartFlags;
+		if(opCode & CFGOP_RESTART_FLAGS && !(opCode & CFGOP_PARSE_QUIET)) {
+		    warnRestart(key, restartFlags);
+	    return 1;
+	} else if(opCode & CFGOP_HELP_FULL || opCode & CFGOP_HELP_SINGLE) {
+		char *helpKey = (char*)opArg;
+		if((opCode & CFGOP_HELP_SINGLE)){
+		    if (strcmp(key, helpKey)) {
+			return 1;
+		    } else {
+			/* this way we tell the caller that we have already found the setting we were looking for */
+			helpKey[0] = '\0';
+		printf("setting: %s (--%s)\n", key, key);
+		printf("   type: BOOLEAN (value must start with t/T/y/Y/1/f/F/n/N/0)\n");
+		printf("  usage: %s\n", helptext);
+		printf("default: %s\n", def ? "Y" : "N");
+		printf("\n");
+		return 1;
+	} else {
+		if (!CONFIG_ISPRESENT(key)) {
+		    *var = def;
+		    dictionary_set(target,key,(*var)?"Y":"N");
+		    if(strcmp(helptext, "") && opCode & CFGOP_PRINT_DEFAULT) {
+			    printComment(helptext);
+			    printf("%s = %s\n", key,(*var)?"Y":"N");
+		    return 1;
+		} else if(!CONFIG_ISSET(key) || iniparser_getboolean(dict,key,-1) == -1) {
+		    if(!(opCode & CFGOP_PARSE_QUIET)) {
+			ERROR("Configuration error: option \"%s='%s'\" has unknown boolean value:  must start with 0/1/t/T/f/F/y/Y/n/N\n",key,iniparser_getstring(dict,key,""));
+		    dictionary_set(target,key,""); /* suppress the "unknown entry" warning for malformed boolean values */ \
+		    return 0;
+		} else {
+		    *var=iniparser_getboolean(dict,key,def);
+			    printComment(helptext);\
+		    return 1;
+static int
+configMapString(int opCode, void *opArg,  dictionary *dict, dictionary *target,
+	const char *key, int restartFlags, char *var, int size, char *def, const char* helptext)
+	    return 1;
+			return 1;
+		    } else {
+		printf("   type: STRING\n");
+		printf("default: %s\n", (strcmp(def, "") == 0) ? "[none]" : def);
+		printf("\n");\
+		return 1;
+	} else {
+		char *tmpstring = iniparser_getstring(dict,key,def);
+		/* do not overwrite the same pointer with the same pointer */
+		if (var!=tmpstring) {
+		    strncpy(var, tmpstring, size);
+		    var[size-1] = '\0';
+		dictionary_set(target, key, tmpstring);
+		if(strcmp(helptext,"") && opCode & CFGOP_PRINT_DEFAULT) {
+			printf("%s = %s\n", key,tmpstring);
+		return 1;
+static int
+checkRangeInt(dictionary *dict, const char *key, int rangeFlags, int minBound, int maxBound)
+	int tmpdouble = iniparser_getint(dict,key,minBound);
+	int ret = 1;
+	switch(rangeFlags) {
+	    case RANGECHECK_NONE:
+		return ret;
+	    case RANGECHECK_RANGE:
+		ret = !(tmpdouble < minBound || tmpdouble > maxBound);
+		break;
+	    case RANGECHECK_MIN:
+		ret = !(tmpdouble < minBound);
+		break;
+	    case RANGECHECK_MAX:
+		ret = !(tmpdouble > maxBound);
+		break;
+	    default:
+		return 0;
+	return ret;
+static int
+configMapInt(int opCode, void *opArg,  dictionary *dict, dictionary *target, const char *key, int restartFlags, int intType,
+		void *var, int def, const char *helptext, int rangeFlags,
+		int minBound, int maxBound)
+	int ret = 0;
+	    return 1;
+		    return 1;
+		} else {
+		printf("   type: INT\n");\
+		printf("default: %d\n", def);
+		printf("\n");
+		return 1;
+		printf("   type: INT ");
+		if( minBound != maxBound )
+		    printf("(min: %d, max: %d)\n", minBound, maxBound);
+		else
+		    printf("(only value of %d allowed)", minBound);
+		printf("\n");
+		printf("\n");
+		return 1;
+		printf("   type: INT (min: %d)\n", minBound);
+		printf("\n");
+		return 1;
+		printf("   type: FLOAT (max: %d)\n", maxBound);
+		printf("\n");
+		return 1;
+	    default:
+		return 0;
+	} else {
+		char buf[50];
+		int userVar = iniparser_getint(dict,key,def);
+		switch(intType) {
+		    case INTTYPE_INT:
+			*(int*)var = userVar;
+			break;
+		    case INTTYPE_I8:
+			*(int8_t*)var = (int8_t)userVar;
+			break;
+		    case INTTYPE_U8:
+			*(uint8_t*)var = (uint8_t)userVar;
+			break;
+		    case INTTYPE_I16:
+			*(int16_t*)var = (int16_t)userVar;
+			break;
+		    case INTTYPE_U16:
+			*(uint16_t*)var = (uint16_t)userVar;
+			break;
+		    case INTTYPE_I32:
+			*(int32_t*)var = (int32_t)userVar;
+			break;
+		    case INTTYPE_U32:
+			*(uint32_t*)var = (uint32_t)userVar;
+			break;
+		    default:
+			break;
+		memset(buf, 0, 50);
+		snprintf(buf, 50, "%d", userVar);
+		dictionary_set(target,key,buf);
+		    printf("%s = %s\n", key,buf);
+		ret = checkRangeInt(dict, key, rangeFlags, minBound, maxBound);
+		if(!ret && !(opCode & CFGOP_PARSE_QUIET)) {
+				ERROR("Configuration error: option \"%s=%s\" not within allowed range: %d..%d\n", key, buf, minBound, maxBound);
+			    break;
+				ERROR("Configuration error: option \"%s=%s\" below allowed minimum: %d\n", key, buf, minBound);
+			    break;
+				ERROR("Configuration error: option \"%s=%s\" above allowed maximum: %d\n", key, buf, maxBound);
+			    break;
+			default:
+			    return ret;
+		return ret;
+static int
+checkRangeDouble(dictionary *dict, const char *key, int rangeFlags, double minBound, double maxBound)
+	double tmpdouble = iniparser_getdouble(dict,key,minBound);
+	int ret = 1;
+		return ret;
+		break;
+		break;
+		break;
+	    default:
+		return 0;
+	return ret;
+static int
+configMapDouble(int opCode, void *opArg,  dictionary *dict, dictionary *target, const char *key, int restartFlags,
+		    double *var, double def, const char *helptext, int rangeFlags,
+		    double minBound, double maxBound)
+	int ret = 0;
+	    return 1;
+		    return 1;
+		} else {
+		printf("   type: FLOAT\n");\
+		printf("default: %f\n", def);
+		printf("\n");
+		return 1;
+		printf("   type: FLOAT ");
+		    printf("(min: %f, max: %f)\n", minBound, maxBound);
+		else
+		    printf("(only value of %f allowed)", minBound);
+		printf("\n");
+		printf("\n");
+		return 1;
+		printf("   type: FLOAT(min: %f)\n", minBound);
+		printf("\n");
+		return 1;
+		printf("   type: FLOAT(max: %f)\n", maxBound);
+		printf("\n");
+		return 1;
+	    default:
+		return 0;
+	} else {
+		char buf[50];
+		*var = iniparser_getdouble(dict,key,def);
+		snprintf(buf, 50, "%f", *var);
+		ret = checkRangeDouble(dict, key, rangeFlags, minBound, maxBound);
+				ERROR("Configuration error: option \"%s=%f\" not within allowed range: %f..%f\n", key, *var, minBound, maxBound);
+			    break;
+				ERROR("Configuration error: option \"%s=%f\" below allowed minimum: %f\n", key, *var, minBound);
+			    break;
+				ERROR("Configuration error: option \"%s=%f\" above allowed maximum: %f\n", key, *var, maxBound);
+			    break;
+			default:
+			    return ret;
+		return ret;
+static int
+configMapSelectValue(int opCode, void *opArg,  dictionary *dict, dictionary *target,
+const char* key, int restartFlags, uint8_t *var, int def, const char *helptext, ...)
+    int ret;
+    int i;
+    /* fixed maximum to avoid while(1) */
+    int maxCount = 100;
+    char *name = NULL;
+    char *keyValue;
+    char *defValue = NULL;
+    int value;
+    va_list ap;
+    int selectedValue = -1;
+    char sbuf[SCREEN_BUFSZ];
+    int len = 0;
+    memset(sbuf, 0, sizeof(sbuf));
+    keyValue = iniparser_getstring(dict, key, "");
+    va_start(ap, helptext);
+    for(i=0; i < maxCount; i++) {
+	name = (char*)va_arg(ap, char*);
+	if(name == NULL) break;
+	value = (int)va_arg(ap, int);
+	len += snprintf(sbuf + len, sizeof(sbuf) - len, "%s ", name);
+	if(value == def) {
+	    defValue = strdup(name);
+	if(!strcmp(name, keyValue)) {
+	    selectedValue = value;
+    if(!strcmp(keyValue, "")) {
+	selectedValue = def;
+	keyValue = iniparser_getstring(dict, key, defValue);
+    va_end(ap);
+	    return 1;
+			return 1;
+		    } else {
+		printf("   type: SELECT\n");
+		printf("options: %s\n", sbuf);
+		printf("default: %s\n", defValue);
+		printf("\n");
+		ret = 1;
+		goto result;
+	} else {
+		dictionary_set(target, key, keyValue);
+		if(selectedValue < 0) {
+			ERROR("Configuration error: option \"%s\" has unknown value: %s - allowed values: %s\n", key, keyValue, sbuf);
+		    ret = 0;
+		} else {
+		    *var = (uint8_t)selectedValue;
+		        printf("; Options: %s\n", sbuf);
+		        printf("%s = %s\n", key,keyValue);
+		    ret = 1;
+result:
+    if(defValue != NULL) {
+	free(defValue);
+    return ret;
+void setConfig(dictionary *dict, const char* key, const char *value)
+    if(dict == NULL) {
+	return;
+    dictionary_set(dict, key, value);
+static void
+parseUserVariables(dictionary *dict, dictionary *target)
+    int i = 0;
+    char *search, *replace, *key;
+    char varname[100];
+    memset(varname, 0, sizeof(varname));
+    for(i = 0; i < dict->n; i++) {
+	key = dict->key[i];
+	/* key starts with "variables" */
+        if(strstr(key,"variables:") == key) {
+		/* this cannot fail if we are here */
+		search = strstr(key,":");
+		search++;
+		replace = dictionary_get(dict, key, "");
+		snprintf(varname, sizeof(varname), "@%s@", search);
+		DBGV("replacing %s with %s in config\n", varname, replace);
+		dictionary_replace(dict, varname, replace);
+		dictionary_set(target, key, replace);
+ * Iterate through dictionary dict (template) and check for keys in source
+ * that are not present in the template - display only.
+static void
+findUnknownSettings(int opCode, dictionary* source, dictionary* dict)
+    int i = 0;
+    if( source == NULL || dict == NULL) return;
+    for(i = 0; i < source->n; i++) {
+	/* skip if the key is null or is a section */
+        if(source->key[i] == NULL || strstr(source->key[i],":") == NULL)
+            continue;
+		    if ( !iniparser_find_entry(dict, source->key[i]) && !(opCode & CFGOP_PARSE_QUIET) )
+			WARNING("Unknown configuration entry: %s - setting will be ignored\n", source->key[i]);
+ * IT HAPPENS HERE
+ * Map all options from @dict dictionary to corresponding @rtopts fields,
+ * using existing @rtopts fields as defaults. Return a dictionary free
+ * of unknown options, with explicitly set defaults.
+ * NOTE: when adding options, also map them in checkSubsystemRestart to
+ * ensure correct config reload behaviour.
+dictionary*
+parseConfig ( int opCode, void *opArg, dictionary* dict, RunTimeOpts *rtOpts )
+ * This function assumes that rtOpts has got all the defaults loaded,
+ * hence the default values for all options are taken from rtOpts.
+ * Therefore loadDefaultSettings should normally be used before parseConfig
+  * WARNING: for ease of use, a limited number of keys is set
+  * via getopt in loadCommanLineOptions(). When renaming settings, make sure
+  * you check it  for inconsistencies. If we decide to
+  * drop all short options in favour of section:key only,
+  * this warning can be removed.
+	 * Prepare the target dictionary. Every mapped option will be set in
+	 * the target dictionary, including the defaults which are typically
+	 * not present in the original dictionary. As a result, the target
+	 * will contain all the mapped options with explicitly set defaults
+	 * if they were not present in the original dictionary. In the end
+	 * of this function we return this pointer. The resulting dictionary
+	 * is complete and free of any unknown options. In the end, warning
+	 * is issued for unknown options. On any errors, NULL is returned
+	dictionary* target = dictionary_new(0);
+	Boolean parseResult = TRUE;
+	PtpEnginePreset ptpPreset;
+		INFO("Checking configuration\n");
+	 * apply the configuration template(s) as statically defined in configdefaults.c
+	 * and in template files. The list of templates and files is comma, space or tab separated.
+	 * names. Any templates are applied before anything else: so any settings after this can override
+	if (CONFIG_ISPRESENT("global:config_templates")) {
+	    applyConfigTemplates(
+		    dict,
+		    dictionary_get(dict, "global:config_templates", ""),
+		    dictionary_get(dict, "global:template_files", "")
+	    /* also set the template names in the target dictionary */
+	    dictionary_set(target, "global:config_templates", dictionary_get(dict, "global:config_templates", ""));
+	    dictionary_set(target, "global:template_files", dictionary_get(dict, "global:template_files", ""));
+	/* set automatic variables */
+	/* @pid@ */
+	tmpsnprintf(tmpStr, 20, "%d", (uint32_t)getpid());
+	dictionary_set(dict, "variables:pid", tmpStr);
+	/* @hostname@ */
+	char hostName[MAXHOSTNAMELEN+1];
+	memset(hostName, 0, MAXHOSTNAMELEN + 1);
+        gethostname(hostName, MAXHOSTNAMELEN);
+	dictionary_set(dict, "variables:hostname", hostName);
+	parseUserVariables(dict, target);
+	dictionary_unset(dict, "variables:pid");
+	dictionary_unset(target, "variables:pid");
+	dictionary_unset(dict, "variables:hostname");
+	dictionary_unset(target, "variables:hostname");
+/* ============= BEGIN CONFIG MAPPINGS, TRIGGERS AND DEPENDENCIES =========== */
+/* ===== ptpengine section ===== */
+	CONFIG_KEY_REQUIRED("ptpengine:interface");
+	parseResult &= configMapString(opCode, opArg, dict, target, "ptpengine:interface",
+		PTPD_RESTART_NETWORK, rtOpts->primaryIfaceName, sizeof(rtOpts->primaryIfaceName), rtOpts->primaryIfaceName,
+	"Network interface to use - eth0, igb0 etc. (required).");
+	parseResult &= configMapString(opCode, opArg, dict, target, "ptpengine:backup_interface",
+		PTPD_RESTART_NETWORK, rtOpts->backupIfaceName, sizeof(rtOpts->backupIfaceName), rtOpts->backupIfaceName,
+		"Backup network interface to use - eth0, igb0 etc. When no GM available, \n"
+	"	 slave will keep alternating between primary and secondary until a GM is found.\n");
+	CONFIG_KEY_TRIGGER("ptpengine:backup_interface", rtOpts->backupIfaceEnabled,TRUE,FALSE);
+	/* Preset option names have to be mapped to defined presets - no free strings here */
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "ptpengine:preset",
+		PTPD_RESTART_PROTOCOL, &rtOpts->selectedPreset, rtOpts->selectedPreset,
+		"PTP engine preset:\n"
+	"	 none	     = Defaults, no clock class restrictions\n"
+	"        masteronly  = Master, passive when not best master (clock class 0..127)\n"
+	"        masterslave = Full IEEE 1588 implementation:\n"
+	"                      Master, slave when not best master\n"
+	"	 	       (clock class 128..254)\n"
+	"        slaveonly   = Slave only (clock class 255 only)\n",
+				(getPtpPreset(PTP_PRESET_NONE, rtOpts)).presetName,		PTP_PRESET_NONE,
+				(getPtpPreset(PTP_PRESET_MASTERONLY, rtOpts)).presetName,	PTP_PRESET_MASTERONLY,
+				(getPtpPreset(PTP_PRESET_MASTERSLAVE, rtOpts)).presetName,	PTP_PRESET_MASTERSLAVE,
+				(getPtpPreset(PTP_PRESET_SLAVEONLY, rtOpts)).presetName,		PTP_PRESET_SLAVEONLY, NULL
+	CONFIG_KEY_CONDITIONAL_CONFLICT("ptpengine:preset",
+	 			    rtOpts->selectedPreset == PTP_PRESET_MASTERSLAVE,
+	 			    "masterslave",
+	 			    "ptpengine:unicast_negotiation");
+	ptpPreset = getPtpPreset(rtOpts->selectedPreset, rtOpts);
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "ptpengine:transport",
+		PTPD_RESTART_NETWORK, &rtOpts->transport, rtOpts->transport,
+		"Transport type for PTP packets. Ethernet transport requires libpcap support.",
+				"ipv4",		UDP_IPV4,
+#if 0
+				"ipv6",		UDP_IPV6,
+#endif
+				"ethernet", 	IEEE_802_3, NULL
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:dot1as", PTPD_UPDATE_DATASETS, &rtOpts->dot1AS, rtOpts->dot1AS,
+		"Enable TransportSpecific field compatibility with 802.1AS / AVB (requires Ethernet transport)");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:disabled", PTPD_RESTART_PROTOCOL, &rtOpts->portDisabled, rtOpts->portDisabled,
+		"Disable PTP port. Causes the PTP state machine to stay in PTP_DISABLED state indefinitely,\n"
+	"        until it is re-enabled via configuration change or ENABLE_PORT management message.");
+	CONFIG_KEY_CONDITIONAL_WARNING_ISSET((rtOpts->transport != IEEE_802_3) && rtOpts->dot1AS,
+	 			    "ptpengine:dot1as",
+				"802.1AS compatibility can only be used with the Ethernet transport\n");
+	CONFIG_KEY_CONDITIONAL_TRIGGER(rtOpts->transport != IEEE_802_3, rtOpts->dot1AS,FALSE, rtOpts->dot1AS);
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "ptpengine:ip_mode",
+		PTPD_RESTART_NETWORK, &rtOpts->ipMode, rtOpts->ipMode,
+		"IP transmission mode (requires IP transport) - hybrid mode uses\n"
+	"	 multicast for sync and announce, and unicast for delay request and\n"
+	"	 response; unicast mode uses unicast for all transmission.\n"
+	"	 When unicast mode is selected, destination IP(s) may need to be configured\n"
+	"	(ptpengine:unicast_destinations).",
+				"multicast", 	IPMODE_MULTICAST,
+				"unicast", 	IPMODE_UNICAST,
+				"hybrid", 	IPMODE_HYBRID, NULL
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:unicast_negotiation",
+		PTPD_RESTART_PROTOCOL, &rtOpts->unicastNegotiation, rtOpts->unicastNegotiation,
+		"Enable unicast negotiation support using signaling messages\n");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:unicast_any_master",
+		PTPD_RESTART_NONE, &rtOpts->unicastAcceptAny, rtOpts->unicastAcceptAny,
+		"When using unicast negotiation (slave), accept PTP messages from any master.\n"
+	"        By default, only messages from acceptable masters (ptpengine:unicast_destinations)\n"
+	"        are accepted, and only if transmission was granted by the master\n");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:unicast_port_mask",
+		PTPD_RESTART_PROTOCOL, INTTYPE_U16, &rtOpts->unicastPortMask, rtOpts->unicastPortMask,
+		"PTP port number wildcard mask applied onto port identities when running\n"
+	"        unicast negotiation: allows multiple port identities to be accepted as one.\n"
+	"	 This option can be used as a workaround where a node sends signaling messages and\n"
+	"	 timing messages with different port identities", RANGECHECK_RANGE, 0,65535);
+	CONFIG_KEY_CONDITIONAL_WARNING_ISSET((rtOpts->transport == IEEE_802_3) && rtOpts->unicastNegotiation,
+	 			    "ptpengine:unicast_negotiation",
+				"Unicast negotiation cannot be used with Ethernet transport\n");
+	CONFIG_KEY_CONDITIONAL_WARNING_ISSET((rtOpts->ipMode != IPMODE_UNICAST) && rtOpts->unicastNegotiation,
+				"Unicast negotiation can only be used with unicast transmission\n");
+	/* disable unicast negotiation unless running unicast */
+	CONFIG_KEY_CONDITIONAL_TRIGGER(rtOpts->transport == IEEE_802_3, rtOpts->unicastNegotiation,FALSE, rtOpts->unicastNegotiation);
+	CONFIG_KEY_CONDITIONAL_TRIGGER(rtOpts->ipMode != IPMODE_UNICAST, rtOpts->unicastNegotiation,FALSE, rtOpts->unicastNegotiation);
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:disable_bmca",
+		PTPD_RESTART_PROTOCOL, &rtOpts->disableBMCA, rtOpts->disableBMCA,
+		"Disable Best Master Clock Algorithm for unicast masters:\n"
+	"        Only effective for masteronly preset - all Announce messages\n"
+	"        will be ignored and clock will transition directly into MASTER state.\n");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:unicast_negotiation_listening",
+		PTPD_RESTART_NONE, &rtOpts->unicastNegotiationListening, rtOpts->unicastNegotiationListening,
+		"When unicast negotiation enabled on a master clock, \n"
+	"	 reply to transmission requests also in LISTENING state.");
+#if defined(PTPD_PCAP) && defined(__sun) && !defined(PTPD_EXPERIMENTAL)
+	if(CONFIG_ISTRUE("ptpengine:use_libpcap"))
+	INFO("Libpcap support is currently marked broken/experimental on Solaris platforms.\n"
+	     "To test it, please build with --enable-experimental-options\n");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:use_libpcap",
+		PTPD_RESTART_NETWORK, &rtOpts->pcap,FALSE,
+		"Use libpcap for sending and receiving traffic (automatically enabled\n"
+	"	 in Ethernet mode).");
+	/* cannot set ethernet transport without libpcap */
+	CONFIG_KEY_VALUE_FORBIDDEN("ptpengine:transport",
+				    rtOpts->transport == IEEE_802_3,
+				    "ethernet",
+	    "Libpcap support is currently marked broken/experimental on Solaris platforms.\n"
+	    "To test it and use the Ethernet transport, please build with --enable-experimental-options\n");
+#elif defined(PTPD_PCAP)
+		PTPD_RESTART_NETWORK, &rtOpts->pcap, rtOpts->pcap,
+	/* in ethernet mode, activate pcap and overwrite previous setting */
+	CONFIG_KEY_CONDITIONAL_TRIGGER(rtOpts->transport==IEEE_802_3, rtOpts->pcap,TRUE, rtOpts->pcap);
+#else
+	INFO("Libpcap support disabled or not available. Please install libpcap,\n"
+	     "build without --disable-pcap, or try building with ---with-pcap-config\n"
+	     " to use ptpengine:use_libpcap.\n");
+				    "ethernet",
+	    "Libpcap support disabled or not available. Please install libpcap,\n"
+	     "to use Ethernet transport. "PTPD_PROGNAME" was built with no libpcap support.\n");
+#endif /* PTPD_PCAP */
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:disable_udp_checksums",
+		PTPD_RESTART_NETWORK, &rtOpts->disableUdpChecksums, rtOpts->disableUdpChecksums,
+		"Disable UDP checksum validation on UDP sockets (Linux only).\n"
+	"        Workaround for situations where a node (like Transparent Clock).\n"
+	"        does not rewrite checksums\n");
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "ptpengine:delay_mechanism",
+		PTPD_RESTART_PROTOCOL, &rtOpts->delayMechanism, rtOpts->delayMechanism,
+		 "Delay detection mode used - use DELAY_DISABLED for syntonisation only\n"
+	"	 (no full synchronisation).",
+				delayMechToString(E2E),		E2E,
+				delayMechToString(P2P),		P2P,
+				delayMechToString(DELAY_DISABLED), DELAY_DISABLED, NULL
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:domain",
+		PTPD_RESTART_PROTOCOL, INTTYPE_U8, &rtOpts->domainNumber, rtOpts->domainNumber,
+		"PTP domain number.", RANGECHECK_RANGE, 0,127);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:port_number", PTPD_UPDATE_DATASETS, INTTYPE_U16, &rtOpts->portNumber, rtOpts->portNumber,
+			    "PTP port number (part of PTP Port Identity - not UDP port).\n"
+		    "        For ordinary clocks (single port), the default should be used, \n"
+		    "        but when running multiple instances to simulate a boundary clock, \n"
+		    "        The port number can be changed.",RANGECHECK_RANGE,1,65534);
+	parseResult &= configMapString(opCode, opArg, dict, target, "ptpengine:port_description",
+		PTPD_UPDATE_DATASETS, rtOpts->portDescription, sizeof(rtOpts->portDescription), rtOpts->portDescription,
+	"Port description (returned in the userDescription field of PORT_DESCRIPTION management message and USER_DESCRIPTION"
+	"        management message) - maximum 64 characters");
+	parseResult &= configMapString(opCode, opArg, dict, target, "variables:product_description",
+		PTPD_UPDATE_DATASETS, rtOpts->productDescription, sizeof(rtOpts->productDescription), rtOpts->productDescription,"");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:any_domain",
+		PTPD_RESTART_PROTOCOL, &rtOpts->anyDomain, rtOpts->anyDomain,
+		"Usability extension: if enabled, a slave-only clock will accept\n"
+	"	 masters from any domain, while preferring the configured domain,\n"
+	"	 and preferring lower domain number.\n"
+	"	 NOTE: this behaviour is not part of the standard.");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:slave_only",
+		PTPD_RESTART_NONE, &rtOpts->slaveOnly, ptpPreset.slaveOnly,
+		 "Slave only mode (sets clock class to 255, overriding value from preset).");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:inbound_latency",
+		PTPD_RESTART_NONE, INTTYPE_I32, &rtOpts->inboundLatency.nanoseconds, rtOpts->inboundLatency.nanoseconds,
+	"Specify latency correction (nanoseconds) for incoming packets.", RANGECHECK_NONE, 0,0);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:outbound_latency",
+		PTPD_RESTART_NONE, INTTYPE_I32, &rtOpts->outboundLatency.nanoseconds, rtOpts->outboundLatency.nanoseconds,
+	"Specify latency correction (nanoseconds) for outgoing packets.", RANGECHECK_NONE,0,0);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:offset_shift",
+		PTPD_RESTART_NONE, INTTYPE_I32, &rtOpts->ofmShift.nanoseconds, rtOpts->ofmShift.nanoseconds,
+	"Apply an arbitrary shift (nanoseconds) to offset from master when\n"
+	"	 in slave state. Value can be positive or negative - useful for\n"
+	"	 correcting for antenna latencies, delay assymetry\n"
+	"	 and IP stack latencies. This will not be visible in the offset \n"
+	"	 from master value - only in the resulting clock correction.", RANGECHECK_NONE, 0,0);
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:always_respect_utc_offset",
+		PTPD_RESTART_NONE, &rtOpts->alwaysRespectUtcOffset, rtOpts->alwaysRespectUtcOffset,
+		"Compatibility option: In slave state, always respect UTC offset\n"
+	"	 announced by best master, even if the the\n"
+	"	 currrentUtcOffsetValid flag is announced FALSE.\n"
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:prefer_utc_offset_valid",
+		PTPD_RESTART_NONE, &rtOpts->preferUtcValid, rtOpts->preferUtcValid,
+		"Compatibility extension to BMC algorithm: when enabled,\n"
+	"	 BMC for both master and save clocks will prefer masters\n"
+	"	 nannouncing currrentUtcOffsetValid as TRUE.\n"
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:require_utc_offset_valid",
+		PTPD_RESTART_NONE, &rtOpts->requireUtcValid, rtOpts->requireUtcValid,
+		"Compatibility option: when enabled, ptpd2 will ignore\n"
+	"	 Announce messages from masters announcing currentUtcOffsetValid\n"
+	"	 as FALSE.\n"
+	/* from 30 seconds to 7 days */
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:unicast_grant_duration",
+		PTPD_RESTART_PROTOCOL, INTTYPE_U32, &rtOpts->unicastGrantDuration, rtOpts->unicastGrantDuration,
+		"Time (seconds) unicast messages are requested for by slaves\n"
+	"	 when using unicast negotiation, and maximum time unicast message\n"
+	"	 transmission is granted to slaves by masters\n", RANGECHECK_RANGE, 30, 604800);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:log_announce_interval", PTPD_UPDATE_DATASETS, INTTYPE_I8, &rtOpts->logAnnounceInterval, rtOpts->logAnnounceInterval,
+		"PTP announce message interval in master state. When using unicast negotiation, for\n"
+	"	 slaves this is the minimum interval requested, and for masters\n"
+	"	 this is the only interval granted.\n"
+#ifdef PTPD_EXPERIMENTAL
+    "	"LOG2_HELP,RANGECHECK_RANGE,-30,30);
+#else
+    "	"LOG2_HELP,RANGECHECK_RANGE,-4,7);
+#endif
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:log_announce_interval_max", PTPD_UPDATE_DATASETS, INTTYPE_I8, &rtOpts->logMaxAnnounceInterval, rtOpts->logMaxAnnounceInterval,
+		"Maximum Announce message interval requested by slaves "
+		"when using unicast negotiation,\n"
+#else
+    "	"LOG2_HELP,RANGECHECK_RANGE,-1,7);
+#endif
+	CONFIG_CONDITIONAL_ASSERTION(rtOpts->logAnnounceInterval >= rtOpts->logMaxAnnounceInterval,
+					"ptpengine:log_announce_interval value must be lower than ptpengine:log_announce_interval_max\n");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:announce_receipt_timeout", PTPD_UPDATE_DATASETS, INTTYPE_I8, &rtOpts->announceReceiptTimeout, rtOpts->announceReceiptTimeout,
+		"PTP announce receipt timeout announced in master state.",RANGECHECK_RANGE,2,255);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:announce_receipt_grace_period",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->announceTimeoutGracePeriod, rtOpts->announceTimeoutGracePeriod,
+		"PTP announce receipt timeout grace period in slave state:\n"
+	"	 when announce receipt timeout occurs, disqualify current best GM,\n"
+	"	 then wait n times announce receipt timeout before resetting.\n"
+	"	 Allows for a seamless GM failover when standby GMs are slow\n"
+	"	 to react. When set to 0, this option is not used.", RANGECHECK_RANGE,
+	0,20);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:log_sync_interval", PTPD_UPDATE_DATASETS, INTTYPE_I8, &rtOpts->logSyncInterval, rtOpts->logSyncInterval,
+		"PTP sync message interval in master state. When using unicast negotiation, for\n"
+#else
+    "	"LOG2_HELP,RANGECHECK_RANGE,-7,7);
+#endif
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:log_sync_interval_max", PTPD_UPDATE_DATASETS, INTTYPE_I8, &rtOpts->logMaxSyncInterval, rtOpts->logMaxSyncInterval,
+		"Maximum Sync message interval requested by slaves "
+#else
+#endif
+	CONFIG_CONDITIONAL_ASSERTION(rtOpts->logSyncInterval >= rtOpts->logMaxSyncInterval,
+					"ptpengine:log_sync_interval value must be lower than ptpengine:log_sync_interval_max\n");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:log_delayreq_override", PTPD_UPDATE_DATASETS, &rtOpts->ignore_delayreq_interval_master,
+	rtOpts->ignore_delayreq_interval_master,
+		 "Override the Delay Request interval announced by best master.");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:log_delayreq_auto", PTPD_UPDATE_DATASETS, &rtOpts->autoDelayReqInterval,
+	rtOpts->autoDelayReqInterval,
+		 "Automatically override the Delay Request interval\n"
+	"         if the announced value is 127 (0X7F), such as in\n"
+	"         unicast messages (unless using unicast negotiation)");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:log_delayreq_interval_initial",
+		PTPD_RESTART_NONE, INTTYPE_I8, &rtOpts->initial_delayreq, rtOpts->initial_delayreq,
+		"Delay request interval used before receiving first delay response\n"
+#else
+#endif
+	/* take the delayreq_interval from config, otherwise use the initial setting as default */
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:log_delayreq_interval", PTPD_UPDATE_DATASETS, INTTYPE_I8, &rtOpts->logMinDelayReqInterval, rtOpts->initial_delayreq,
+		"Minimum delay request interval announced when in master state,\n"
+	"	 in slave state overrides the master interval,\n"
+	"	 required in hybrid mode. When using unicast negotiation, for\n"
+	"	 this is the minimum interval granted.\n"
+#else
+#endif
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:log_delayreq_interval_max", PTPD_UPDATE_DATASETS, INTTYPE_I8, &rtOpts->logMaxDelayReqInterval, rtOpts->logMaxDelayReqInterval,
+		"Maximum Delay Response interval requested by slaves "
+#else
+#endif
+	CONFIG_CONDITIONAL_ASSERTION(rtOpts->logMinDelayReqInterval >= rtOpts->logMaxDelayReqInterval,
+					"ptpengine:log_delayreq_interval value must be lower than ptpengine:log_delayreq_interval_max\n");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:log_peer_delayreq_interval",
+		PTPD_RESTART_NONE, INTTYPE_I8, &rtOpts->logMinPdelayReqInterval, rtOpts->logMinPdelayReqInterval,
+		"Minimum peer delay request message interval in peer to peer delay mode.\n"
+	"        When using unicast negotiation, this is the minimum interval requested, \n"
+	"	 and the only interval granted.\n"
+#else
+#endif
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:log_peer_delayreq_interval_max",
+		PTPD_RESTART_NONE, INTTYPE_I8, &rtOpts->logMaxPdelayReqInterval, rtOpts->logMaxPdelayReqInterval,
+		"Maximum Peer Delay Response interval requested by slaves "
+#else
+#endif
+	CONFIG_CONDITIONAL_ASSERTION(rtOpts->logMinPdelayReqInterval >= rtOpts->logMaxPdelayReqInterval,
+					"ptpengine:log_peer_delayreq_interval value must be lower than ptpengine:log_peer_delayreq_interval_max\n");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:foreignrecord_capacity",
+		PTPD_RESTART_DAEMON, INTTYPE_I16, &rtOpts->max_foreign_records, rtOpts->max_foreign_records,
+	"Foreign master record size (Maximum number of foreign masters).",RANGECHECK_RANGE,5,10);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:ptp_allan_variance", PTPD_UPDATE_DATASETS, INTTYPE_U16, &rtOpts->clockQuality.offsetScaledLogVariance, rtOpts->clockQuality.offsetScaledLogVariance,
+	"Specify Allan variance announced in master state.",RANGECHECK_RANGE,0,65535);
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "ptpengine:ptp_clock_accuracy", PTPD_UPDATE_DATASETS, &rtOpts->clockQuality.clockAccuracy, rtOpts->clockQuality.clockAccuracy,
+	"Clock accuracy range announced in master state.",
+				accToString(ACC_25NS),		ACC_25NS,
+				accToString(ACC_100NS),		ACC_100NS,
+				accToString(ACC_250NS),		ACC_250NS,
+				accToString(ACC_1US),		ACC_1US,
+				accToString(ACC_2_5US),		ACC_2_5US,
+				accToString(ACC_10US), 		ACC_10US,
+				accToString(ACC_25US), 		ACC_25US,
+				accToString(ACC_100US),		ACC_100US,
+				accToString(ACC_250US),		ACC_250US,
+				accToString(ACC_1MS), 		ACC_1MS,
+				accToString(ACC_2_5MS),		ACC_2_5MS,
+				accToString(ACC_10MS), 		ACC_10MS,
+				accToString(ACC_25MS),		ACC_25MS,
+				accToString(ACC_100MS),		ACC_100MS,
+				accToString(ACC_250MS),		ACC_250MS,
+				accToString(ACC_1S), 		ACC_1S,
+				accToString(ACC_10S), 		ACC_10S,
+				accToString(ACC_10SPLUS),	ACC_10SPLUS,
+				accToString(ACC_UNKNOWN),	ACC_UNKNOWN, NULL
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:utc_offset", PTPD_UPDATE_DATASETS, INTTYPE_I16, &rtOpts->timeProperties.currentUtcOffset, rtOpts->timeProperties.currentUtcOffset,
+		 "Underlying time source UTC offset announced in master state.", RANGECHECK_NONE,0,0);
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:utc_offset_valid", PTPD_UPDATE_DATASETS, &rtOpts->timeProperties.currentUtcOffsetValid,
+	rtOpts->timeProperties.currentUtcOffsetValid,
+		 "Underlying time source UTC offset validity announced in master state.");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:time_traceable", PTPD_UPDATE_DATASETS, &rtOpts->timeProperties.timeTraceable,
+	rtOpts->timeProperties.timeTraceable,
+		 "Underlying time source time traceability announced in master state.");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:frequency_traceable", PTPD_UPDATE_DATASETS, &rtOpts->timeProperties.frequencyTraceable,
+	rtOpts->timeProperties.frequencyTraceable,
+		 "Underlying time source frequency traceability announced in master state.");
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "ptpengine:ptp_timescale", PTPD_UPDATE_DATASETS, (uint8_t*)&rtOpts->timeProperties.ptpTimescale, rtOpts->timeProperties.ptpTimescale,
+		"Time scale announced in master state (with ARB, UTC properties\n"
+	"	 are ignored by slaves). When clock class is set to 13 (application\n"
+	"	 specific), this value is ignored and ARB is used.",
+				"PTP",		TRUE,
+				"ARB",			FALSE, NULL
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "ptpengine:ptp_timesource", PTPD_UPDATE_DATASETS, &rtOpts->timeProperties.timeSource, rtOpts->timeProperties.timeSource,
+	"Time source announced in master state.",
+				"ATOMIC_CLOCK",		ATOMIC_CLOCK,
+				"GPS",			GPS,
+				"TERRESTRIAL_RADIO",	TERRESTRIAL_RADIO,
+				"PTP",			PTP,
+				"NTP",			NTP,
+				"HAND_SET",		HAND_SET,
+				"OTHER",		OTHER,
+				"INTERNAL_OSCILLATOR",	INTERNAL_OSCILLATOR, NULL
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:clock_class", PTPD_UPDATE_DATASETS, INTTYPE_U8, &rtOpts->clockQuality.clockClass,ptpPreset.clockClass.defaultValue,
+		"Clock class - announced in master state. Always 255 for slave-only.\n"
+	"	 Minimum, maximum and default values are controlled by presets.\n"
+	"	 If set to 13 (application specific time source), announced \n"
+	"	 time scale is always set to ARB. This setting controls the\n"
+	"	 states a PTP port can be in. If below 128, port will only\n"
+	"	 be in MASTER or PASSIVE states (master only). If above 127,\n"
+	"	 port will be in MASTER or SLAVE states.", RANGECHECK_RANGE,
+	ptpPreset.clockClass.minValue,ptpPreset.clockClass.maxValue);
+	/* ClockClass = 13 triggers ARB */
+	CONFIG_KEY_CONDITIONAL_TRIGGER(rtOpts->clockQuality.clockClass==DEFAULT_CLOCK_CLASS__APPLICATION_SPECIFIC_TIME_SOURCE,
+					rtOpts->timeProperties.ptpTimescale,FALSE, rtOpts->timeProperties.ptpTimescale);
+	/* ClockClass = 14 triggers ARB */
+	CONFIG_KEY_CONDITIONAL_TRIGGER(rtOpts->clockQuality.clockClass==14,
+	/* ClockClass = 6 triggers PTP*/
+	CONFIG_KEY_CONDITIONAL_TRIGGER(rtOpts->clockQuality.clockClass==6,
+					rtOpts->timeProperties.ptpTimescale,TRUE, rtOpts->timeProperties.ptpTimescale);
+	/* ClockClass = 7 triggers PTP*/
+	CONFIG_KEY_CONDITIONAL_TRIGGER(rtOpts->clockQuality.clockClass==7,
+	/* ClockClass = 255 triggers slaveOnly */
+	CONFIG_KEY_CONDITIONAL_TRIGGER(rtOpts->clockQuality.clockClass==SLAVE_ONLY_CLOCK_CLASS, rtOpts->slaveOnly,TRUE,FALSE);
+	/* ...and vice versa */
+	CONFIG_KEY_CONDITIONAL_TRIGGER(rtOpts->slaveOnly==TRUE, rtOpts->clockQuality.clockClass,SLAVE_ONLY_CLOCK_CLASS, rtOpts->clockQuality.clockClass);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:priority1", PTPD_UPDATE_DATASETS, INTTYPE_U8, &rtOpts->priority1, rtOpts->priority1,
+		"Priority 1 announced in master state,used for Best Master\n"
+	"	 Clock selection.",RANGECHECK_RANGE,0,248);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:priority2", PTPD_UPDATE_DATASETS, INTTYPE_U8, &rtOpts->priority2, rtOpts->priority2,
+		"Priority 2 announced in master state, used for Best Master\n"
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:max_listen",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->maxListen, rtOpts->maxListen,
+		 "Number of consecutive resets to LISTENING before full network reset\n",RANGECHECK_MIN,1,0);
+	 * TODO: in unicast and hybrid mode, automativally override master delayreq interval with a default,
+	 * rather than require setting it manually.
+	/* hybrid mode -> should specify delayreq interval: override set in the bottom of this function */
+	CONFIG_KEY_CONDITIONAL_WARNING_NOTSET(rtOpts->ipMode == IPMODE_HYBRID,
+    		    "ptpengine:log_delayreq_interval",
+		    "It is recommended to manually set the delay request interval (ptpengine:log_delayreq_interval) to required value in hybrid mode"
+	/* unicast mode -> should specify delayreq interval if we can become a slave */
+	CONFIG_KEY_CONDITIONAL_WARNING_NOTSET(rtOpts->ipMode == IPMODE_UNICAST &&
+		    rtOpts->clockQuality.clockClass > 127,
+		    "It is recommended to manually set the delay request interval (ptpengine:log_delayreq_interval) to required value in unicast mode"
+	CONFIG_KEY_ALIAS("ptpengine:unicast_address","ptpengine:unicast_destinations");
+	/* unicast signaling slave -> must specify unicast destination(s) */
+	CONFIG_KEY_CONDITIONAL_DEPENDENCY("ptpengine:ip_mode",
+				     rtOpts->clockQuality.clockClass > 127 &&
+				    rtOpts->ipMode == IPMODE_UNICAST &&
+				    rtOpts->unicastNegotiation,
+				    "unicast",
+				    "ptpengine:unicast_destinations");
+	/* unicast master without signaling - must specify unicast destinations */
+				     rtOpts->clockQuality.clockClass <= 127 &&
+				    !rtOpts->unicastNegotiation,
+				    "unicast",
+	CONFIG_KEY_TRIGGER("ptpengine:unicast_destinations", rtOpts->unicastDestinationsSet,TRUE, rtOpts->unicastDestinationsSet);
+	parseResult &= configMapString(opCode, opArg, dict, target, "ptpengine:unicast_destinations",
+		PTPD_RESTART_NETWORK, rtOpts->unicastDestinations, sizeof(rtOpts->unicastDestinations), rtOpts->unicastDestinations,
+		"Specify unicast slave addresses for unicast master operation, or unicast\n"
+	"	 master addresses for slave operation. Format is similar to an ACL: comma,\n"
+	"        tab or space-separated IPv4 unicast addresses, one or more. For a slave,\n"
+	"        when unicast negotiation is used, setting this is mandatory.");
+	parseResult &= configMapString(opCode, opArg, dict, target, "ptpengine:unicast_domains",
+		PTPD_RESTART_NETWORK, rtOpts->unicastDomains, sizeof(rtOpts->unicastDomains), rtOpts->unicastDomains,
+		"Specify PTP domain number for each configured unicast destination (ptpengine:unicast_destinations).\n"
+	"	 This is only used by slave-only clocks using unicast destinations to allow for each master\n"
+	"        to be in a separate domain, such as with Telecom Profile. The number of entries should match the number\n"
+	"        of unicast destinations, otherwise unconfigured domains or domains set to 0 are set to domain configured in\n"
+	"        ptpengine:domain. The format is a comma, tab or space-separated list of 8-bit unsigned integers (0 .. 255)");
+	parseResult &= configMapString(opCode, opArg, dict, target, "ptpengine:unicast_local_preference",
+		PTPD_RESTART_NETWORK, rtOpts->unicastLocalPreference, sizeof(rtOpts->unicastLocalPreference), rtOpts->unicastLocalPreference,
+		"Specify a local preference for each configured unicast destination (ptpengine:unicast_destinations).\n"
+	"	 This is only used by slave-only clocks using unicast destinations to allow for each master's\n"
+	"        BMC selection to be influenced by the slave, such as with Telecom Profile. The number of entries should match the number\n"
+	"        of unicast destinations, otherwise unconfigured preference is set to 0 (highest).\n"
+	"        The format is a comma, tab or space-separated list of 8-bit unsigned integers (0 .. 255)");
+	/* unicast P2P - must specify unicast peer destination */
+	CONFIG_KEY_CONDITIONAL_DEPENDENCY("ptpengine:delay_mechanism",
+					rtOpts->delayMechanism == P2P &&
+				    rtOpts->ipMode == IPMODE_UNICAST,
+				    "P2P",
+				    "ptpengine:unicast_peer_destination");
+	CONFIG_KEY_TRIGGER("ptpengine:unicast_peer_destination", rtOpts->unicastPeerDestinationSet,TRUE, rtOpts->unicastPeerDestinationSet);
+	parseResult &= configMapString(opCode, opArg, dict, target, "ptpengine:unicast_peer_destination",
+		PTPD_RESTART_NETWORK, rtOpts->unicastPeerDestination, sizeof(rtOpts->unicastPeerDestination), rtOpts->unicastPeerDestination,
+		"Specify peer unicast adress for P2P unicast. Mandatory when\n"
+	"	 running unicast mode and P2P delay mode.");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:management_enable",
+		PTPD_RESTART_NONE, &rtOpts->managementEnabled, rtOpts->managementEnabled,
+	"Enable handling of PTP management messages.");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:management_set_enable",
+		PTPD_RESTART_NONE, &rtOpts->managementSetEnable, rtOpts->managementSetEnable,
+	"Accept SET and COMMAND management messages.");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:igmp_refresh",
+		PTPD_RESTART_NONE, &rtOpts->do_IGMP_refresh, rtOpts->do_IGMP_refresh,
+	"Send explicit IGMP joins between engine resets and periodically\n"
+	"	 in master state.");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:master_igmp_refresh_interval",
+		PTPD_RESTART_PROTOCOL, INTTYPE_I8, &rtOpts->masterRefreshInterval, rtOpts->masterRefreshInterval,
+		"Periodic IGMP join interval (seconds) in master state when running\n"
+		"	 IPv4 multicast: when set below 10 or when ptpengine:igmp_refresh\n"
+		"	 is disabled, this setting has no effect.",RANGECHECK_RANGE,0,255);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:multicast_ttl",
+		PTPD_RESTART_NETWORK, INTTYPE_INT, &rtOpts->ttl, rtOpts->ttl,
+		"Multicast time to live for multicast PTP packets (ignored and set to 1\n"
+	"	 for peer to peer messages).",RANGECHECK_RANGE,1,64);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:ip_dscp",
+		PTPD_RESTART_NETWORK, INTTYPE_INT, &rtOpts->dscpValue, rtOpts->dscpValue,
+		"DiffServ CodepPoint for packet prioritisation (decimal). When set to zero, \n"
+	"	 this option is not used. Use 46 for Expedited Forwarding (0x2e).",RANGECHECK_RANGE,0,63);
+#ifdef PTPD_STATISTICS
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:sync_stat_filter_enable",
+		PTPD_RESTART_FILTERS, &rtOpts->filterMSOpts.enabled, rtOpts->filterMSOpts.enabled,
+		 "Enable statistical filter for Sync messages.");
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "ptpengine:sync_stat_filter_type",
+		PTPD_RESTART_FILTERS, &rtOpts->filterMSOpts.filterType, rtOpts->filterMSOpts.filterType,
+		"Type of filter used for Sync message filtering",
+	"none", FILTER_NONE,
+	"mean", FILTER_MEAN,
+	"min", FILTER_MIN,
+	"max", FILTER_MAX,
+	"absmin", FILTER_ABSMIN,
+	"absmax", FILTER_ABSMAX,
+	"median", FILTER_MEDIAN, NULL);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:sync_stat_filter_window",
+		PTPD_RESTART_FILTERS, INTTYPE_INT, &rtOpts->filterMSOpts.windowSize, rtOpts->filterMSOpts.windowSize,
+		"Number of samples used for the Sync statistical filter",RANGECHECK_RANGE,3,128);
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "ptpengine:sync_stat_filter_window_type",
+		PTPD_RESTART_FILTERS, &rtOpts->filterMSOpts.windowType, rtOpts->filterMSOpts.windowType,
+		"Sample window type used for Sync message statistical filter. Delay Response outlier filter action.\n"
+	"        Sliding window is continuous, interval passes every n-th sample only.",
+	"sliding", WINDOW_SLIDING,
+	"interval", WINDOW_INTERVAL, NULL);
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:delay_stat_filter_enable",
+		PTPD_RESTART_FILTERS, &rtOpts->filterSMOpts.enabled, rtOpts->filterSMOpts.enabled,
+		 "Enable statistical filter for Delay messages.");
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "ptpengine:delay_stat_filter_type",
+		PTPD_RESTART_FILTERS, &rtOpts->filterSMOpts.filterType, rtOpts->filterSMOpts.filterType,
+		"Type of filter used for Delay message statistical filter",
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:delay_stat_filter_window",
+		PTPD_RESTART_FILTERS, INTTYPE_INT, &rtOpts->filterSMOpts.windowSize, rtOpts->filterSMOpts.windowSize,
+		"Number of samples used for the Delay statistical filter",RANGECHECK_RANGE,3,128);
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "ptpengine:delay_stat_filter_window_type",
+		PTPD_RESTART_FILTERS, &rtOpts->filterSMOpts.windowType, rtOpts->filterSMOpts.windowType,
+		"Sample window type used for Delay message statistical filter\n"
+	"        Sliding window is continuous, interval passes every n-th sample only",
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:delay_outlier_filter_enable",
+		PTPD_RESTART_FILTERS, &rtOpts->oFilterSMConfig.enabled, rtOpts->oFilterSMConfig.enabled,
+		 "Enable outlier filter for the Delay Response component in slave state");
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "ptpengine:delay_outlier_filter_action",
+		PTPD_RESTART_NONE, (uint8_t*)&rtOpts->oFilterSMConfig.discard, rtOpts->oFilterSMConfig.discard,
+		"Delay Response outlier filter action. If set to 'filter', outliers are\n"
+	"	 replaced with moving average.",
+	"discard", TRUE,
+	"filter", FALSE, NULL);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:delay_outlier_filter_capacity",
+		PTPD_RESTART_FILTERS, INTTYPE_INT, &rtOpts->oFilterSMConfig.capacity, rtOpts->oFilterSMConfig.capacity,
+		"Number of samples in the Delay Response outlier filter buffer",RANGECHECK_RANGE,10,STATCONTAINER_MAX_SAMPLES);
+	parseResult &= configMapDouble(opCode, opArg, dict, target, "ptpengine:delay_outlier_filter_threshold",
+		PTPD_RESTART_NONE, &rtOpts->oFilterSMConfig.threshold, rtOpts->oFilterSMConfig.threshold,
+		"Delay Response outlier filter threshold (: multiplier for Peirce's maximum\n"
+	"	 standard deviation. When set below 1.0, filter is tighter, when set above\n"
+	"	 1.0, filter is looser than standard Peirce's test.\n"
+	"        When autotune enabled, this is the starting threshold.", RANGECHECK_RANGE, 0.001, 1000.0);
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:delay_outlier_filter_always_filter",
+		PTPD_RESTART_NONE, &rtOpts->oFilterSMConfig.alwaysFilter, rtOpts->oFilterSMConfig.alwaysFilter,
+		"Always run the Delay Response outlier filter, even if clock is being slewed at maximum rate");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:delay_outlier_filter_autotune_enable",
+		PTPD_RESTART_FILTERS, &rtOpts->oFilterSMConfig.autoTune, rtOpts->oFilterSMConfig.autoTune,
+		"Enable automatic threshold control for Delay Response outlier filter.");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:delay_outlier_filter_autotune_minpercent",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->oFilterSMConfig.minPercent, rtOpts->oFilterSMConfig.minPercent,
+		"Delay Response outlier filter autotune low watermark - minimum percentage\n"
+	"	 of discarded samples in the update period before filter is tightened\n"
+	"	 by the autotune step value.",RANGECHECK_RANGE,0,99);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:delay_outlier_filter_autotune_maxpercent",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->oFilterSMConfig.maxPercent, rtOpts->oFilterSMConfig.maxPercent,
+		"Delay Response outlier filter autotune high watermark - maximum percentage\n"
+	"	 of discarded samples in the update period before filter is loosened\n"
+	"	 by the autotune step value.",RANGECHECK_RANGE,1,100);
+	parseResult &= configMapDouble(opCode, opArg, dict, target, "ptpengine:delay_outlier_autotune_step",
+		PTPD_RESTART_NONE, &rtOpts->oFilterSMConfig.thresholdStep, rtOpts->oFilterSMConfig.thresholdStep,
+		"The value the Delay Response outlier filter threshold is increased\n"
+	"	 or decreased by when auto-tuning.", RANGECHECK_RANGE, 0.01,10.0);
+	parseResult &= configMapDouble(opCode, opArg, dict, target, "ptpengine:delay_outlier_filter_autotune_minthreshold",
+		PTPD_RESTART_NONE, &rtOpts->oFilterSMConfig.minThreshold, rtOpts->oFilterSMConfig.minThreshold,
+		"Minimum Delay Response filter threshold value used when auto-tuning", RANGECHECK_RANGE, 0.01,10.0);
+	parseResult &= configMapDouble(opCode, opArg, dict, target, "ptpengine:delay_outlier_filter_autotune_maxthreshold",
+		PTPD_RESTART_NONE, &rtOpts->oFilterSMConfig.maxThreshold, rtOpts->oFilterSMConfig.maxThreshold,
+		"Maximum Delay Response filter threshold value used when auto-tuning", RANGECHECK_RANGE, 0.01,10.0);
+	CONFIG_CONDITIONAL_ASSERTION(rtOpts->oFilterSMConfig.maxPercent <= rtOpts->oFilterSMConfig.minPercent,
+					"ptpengine:delay_outlier_filter_autotune_maxpercent value has to be greater "
+					"than ptpengine:delay_outlier_filter_autotune_minpercent\n");
+	CONFIG_CONDITIONAL_ASSERTION(rtOpts->oFilterSMConfig.maxThreshold <= rtOpts->oFilterSMConfig.minThreshold,
+					"ptpengine:delay_outlier_filter_autotune_maxthreshold value has to be greater "
+					"than ptpengine:delay_outlier_filter_autotune_minthreshold\n");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:delay_outlier_filter_stepdetect_enable",
+		PTPD_RESTART_FILTERS, &rtOpts->oFilterSMConfig.stepDelay, rtOpts->oFilterSMConfig.stepDelay,
+		"Enable Delay filter step detection (delaySM) to block when certain level exceeded");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:delay_outlier_filter_stepdetect_threshold",
+		PTPD_RESTART_NONE, INTTYPE_I32, &rtOpts->oFilterSMConfig.stepThreshold, rtOpts->oFilterSMConfig.stepThreshold,
+		"Delay Response step detection threshold. Step detection is performed\n"
+	"	 only when delaySM is below this threshold (nanoseconds)", RANGECHECK_RANGE, 50000, NANOSECONDS_MAX);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:delay_outlier_filter_stepdetect_level",
+		PTPD_RESTART_NONE, INTTYPE_I32, &rtOpts->oFilterSMConfig.stepLevel, rtOpts->oFilterSMConfig.stepLevel,
+		"Delay Response step level. When step detection enabled and operational,\n"
+	"	 delaySM above this level (nanosecond) is considered a clock step and updates are paused", RANGECHECK_RANGE,50000, NANOSECONDS_MAX);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:delay_outlier_filter_stepdetect_credit",
+		PTPD_RESTART_FILTERS, INTTYPE_I32, &rtOpts->oFilterSMConfig.delayCredit, rtOpts->oFilterSMConfig.delayCredit,
+		"Initial credit (number of samples) the Delay step detection filter can block for\n"
+	"	 When credit is exhausted, filter stops blocking. Credit is gradually restored",RANGECHECK_RANGE,50,1000);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:delay_outlier_filter_stepdetect_credit_increment",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->oFilterSMConfig.creditIncrement, rtOpts->oFilterSMConfig.creditIncrement,
+		"Amount of credit for the Delay step detection filter restored every full sample window",RANGECHECK_RANGE,1,100);
+	parseResult &= configMapDouble(opCode, opArg, dict, target, "ptpengine:delay_outlier_weight",
+		PTPD_RESTART_NONE, &rtOpts->oFilterSMConfig.weight, rtOpts->oFilterSMConfig.weight,
+		"Delay Response outlier weight: if an outlier is detected, determines\n"
+	"	 the amount of its deviation from mean that is used to build the standard\n"
+	"	 deviation statistics and influence further outlier detection.\n"
+	"	 When set to 1.0, the outlier is used as is.", RANGECHECK_RANGE, 0.01, 2.0);
+    parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:sync_outlier_filter_enable",
+		PTPD_RESTART_FILTERS, &rtOpts->oFilterMSConfig.enabled, rtOpts->oFilterMSConfig.enabled,
+		"Enable outlier filter for the Sync component in slave state.");
+    parseResult &= configMapSelectValue(opCode, opArg, dict, target, "ptpengine:sync_outlier_filter_action",
+		PTPD_RESTART_NONE, (uint8_t*)&rtOpts->oFilterMSConfig.discard, rtOpts->oFilterMSConfig.discard,
+		"Sync outlier filter action. If set to 'filter', outliers are replaced\n"
+	"	 with moving average.",
+     "discard", TRUE,
+     parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:sync_outlier_filter_capacity",
+		PTPD_RESTART_FILTERS, INTTYPE_INT, &rtOpts->oFilterMSConfig.capacity, rtOpts->oFilterMSConfig.capacity,
+    "Number of samples in the Sync outlier filter buffer.",RANGECHECK_RANGE,10,STATCONTAINER_MAX_SAMPLES);
+    parseResult &= configMapDouble(opCode, opArg, dict, target, "ptpengine:sync_outlier_filter_threshold",
+		PTPD_RESTART_NONE, &rtOpts->oFilterMSConfig.threshold, rtOpts->oFilterMSConfig.threshold,
+		"Sync outlier filter threshold: multiplier for the Peirce's maximum standard\n"
+	"	 deviation. When set below 1.0, filter is tighter, when set above 1.0,\n"
+	"	 filter is looser than standard Peirce's test.", RANGECHECK_RANGE, 0.001, 1000.0);
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:sync_outlier_filter_always_filter",
+		PTPD_RESTART_NONE, &rtOpts->oFilterMSConfig.alwaysFilter, rtOpts->oFilterMSConfig.alwaysFilter,
+		"Always run the Sync outlier filter, even if clock is being slewed at maximum rate");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:sync_outlier_filter_autotune_enable",
+		PTPD_RESTART_FILTERS, &rtOpts->oFilterMSConfig.autoTune, rtOpts->oFilterMSConfig.autoTune,
+		"Enable automatic threshold control for Sync outlier filter.");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:sync_outlier_filter_autotune_minpercent",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->oFilterMSConfig.minPercent, rtOpts->oFilterMSConfig.minPercent,
+		"Sync outlier filter autotune low watermark - minimum percentage\n"
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:sync_outlier_filter_autotune_maxpercent",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->oFilterMSConfig.maxPercent, rtOpts->oFilterMSConfig.maxPercent,
+		"Sync outlier filter autotune high watermark - maximum percentage\n"
+	parseResult &= configMapDouble(opCode, opArg, dict, target, "ptpengine:sync_outlier_autotune_step",
+		PTPD_RESTART_NONE, &rtOpts->oFilterMSConfig.thresholdStep, rtOpts->oFilterMSConfig.thresholdStep,
+		"Value the Sync outlier filter threshold is increased\n"
+	parseResult &= configMapDouble(opCode, opArg, dict, target, "ptpengine:sync_outlier_filter_autotune_minthreshold",
+		PTPD_RESTART_NONE, &rtOpts->oFilterMSConfig.minThreshold, rtOpts->oFilterMSConfig.minThreshold,
+		"Minimum Sync outlier filter threshold value used when auto-tuning", RANGECHECK_RANGE, 0.01,10.0);
+	parseResult &= configMapDouble(opCode, opArg, dict, target, "ptpengine:sync_outlier_filter_autotune_maxthreshold",
+		PTPD_RESTART_NONE, &rtOpts->oFilterMSConfig.maxThreshold, rtOpts->oFilterMSConfig.maxThreshold,
+		"Maximum Sync outlier filter threshold value used when auto-tuning", RANGECHECK_RANGE, 0.01,10.0);
+	CONFIG_CONDITIONAL_ASSERTION(rtOpts->oFilterMSConfig.maxPercent <= rtOpts->oFilterMSConfig.minPercent,
+					"ptpengine:sync_outlier_filter_autotune_maxpercent value has to be greater "
+					"than ptpengine:sync_outlier_filter_autotune_minpercent\n");
+	CONFIG_CONDITIONAL_ASSERTION(rtOpts->oFilterMSConfig.maxThreshold <= rtOpts->oFilterMSConfig.minThreshold,
+					"ptpengine:sync_outlier_filter_autotune_maxthreshold value has to be greater "
+					"than ptpengine:sync_outlier_filter_autotune_minthreshold\n");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:sync_outlier_filter_stepdetect_enable",
+		PTPD_RESTART_FILTERS, &rtOpts->oFilterMSConfig.stepDelay, rtOpts->oFilterMSConfig.stepDelay,
+		"Enable Sync filter step detection (delayMS) to block when certain level exceeded.");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:sync_outlier_filter_stepdetect_threshold",
+		PTPD_RESTART_NONE, INTTYPE_I32, &rtOpts->oFilterMSConfig.stepThreshold, rtOpts->oFilterMSConfig.stepThreshold,
+		"Sync step detection threshold. Step detection is performed\n"
+	"	 only when delayMS is below this threshold (nanoseconds)", RANGECHECK_RANGE,100000, NANOSECONDS_MAX);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:sync_outlier_filter_stepdetect_level",
+		PTPD_RESTART_NONE, INTTYPE_I32, &rtOpts->oFilterMSConfig.stepLevel, rtOpts->oFilterMSConfig.stepLevel,
+		"Sync step level. When step detection enabled and operational,\n"
+	"	 delayMS above this level (nanosecond) is considered a clock step and updates are paused", RANGECHECK_RANGE,100000, NANOSECONDS_MAX);
+	CONFIG_CONDITIONAL_ASSERTION(rtOpts->oFilterMSConfig.stepThreshold <= (rtOpts->oFilterMSConfig.stepLevel + 100000),
+					"ptpengine:sync_outlier_filter_stepdetect_threshold  has to be at least "
+					"100 us (100000) greater than ptpengine:sync_outlier_filter_stepdetect_level\n");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:sync_outlier_filter_stepdetect_credit",
+		PTPD_RESTART_FILTERS, INTTYPE_INT, &rtOpts->oFilterMSConfig.delayCredit, rtOpts->oFilterMSConfig.delayCredit,
+		"Initial credit (number of samples) the Sync step detection filter can block for.\n"
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:sync_outlier_filter_stepdetect_credit_increment",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->oFilterMSConfig.creditIncrement, rtOpts->oFilterMSConfig.creditIncrement,
+		"Amount of credit for the Sync step detection filter restored every full sample window",RANGECHECK_RANGE,1,100);
+	parseResult &= configMapDouble(opCode, opArg, dict, target, "ptpengine:sync_outlier_weight",
+		PTPD_RESTART_NONE, &rtOpts->oFilterMSConfig.weight, rtOpts->oFilterMSConfig.weight,
+		"Sync outlier weight: if an outlier is detected, this value determines the\n"
+	"	 amount of its deviation from mean that is used to build the standard \n"
+        parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:calibration_delay",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->calibrationDelay, rtOpts->calibrationDelay,
+		"Delay between moving to slave state and enabling clock updates (seconds).\n"
+	"	 This allows one-way delay to stabilise before starting clock updates.\n"
+	"	 Activated when going into slave state and during slave's GM failover.\n"
+	"	 0 - not used.",RANGECHECK_RANGE,0,300);
+#endif /* PTPD_STATISTICS */
+        parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:idle_timeout",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->idleTimeout, rtOpts->idleTimeout,
+		"PTP idle timeout: if PTPd is in SLAVE state and there have been no clock\n"
+	"	 updates for this amout of time, PTPd releases clock control.\n", RANGECHECK_RANGE,10,3600);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:offset_alarm_threshold", PTPD_UPDATE_DATASETS, INTTYPE_U32, &rtOpts->ofmAlarmThreshold, rtOpts->ofmAlarmThreshold,
+		 "PTP slave offset from master threshold (nanoseconds - absolute value)\n"
+	"	 When offset exceeds this value, an alarm is raised (also SNMP trap if configured).\n"
+	"	 0 = disabled.", RANGECHECK_NONE,0,NANOSECONDS_MAX);
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:panic_mode",
+		PTPD_RESTART_NONE, &rtOpts->enablePanicMode, rtOpts->enablePanicMode,
+		"Enable panic mode: when offset from master is above 1 second, stop updating\n"
+	"	 the clock for a period of time and then step the clock if offset remains\n"
+	"	 above 1 second.");
+    parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:panic_mode_duration",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->panicModeDuration, rtOpts->panicModeDuration,
+		"Duration (minutes) of the panic mode period (no clock updates) when offset\n"
+	"	 above 1 second detected.",RANGECHECK_RANGE,1,60);
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:panic_mode_release_clock",
+		PTPD_RESTART_NONE, &rtOpts->panicModeReleaseClock, rtOpts->panicModeReleaseClock,
+		"When entering panic mode, release clock control while panic mode lasts\n"
+ 	"	 if ntpengine:* configured, this will fail over to NTP,\n"
+	"	 if not set, PTP will hold clock control during panic mode.");
+    parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:panic_mode_exit_threshold",
+		PTPD_RESTART_NONE, INTTYPE_U32, &rtOpts->panicModeExitThreshold, rtOpts->panicModeExitThreshold,
+		"Do not exit panic mode until offset drops below this value (nanoseconds).\n"
+	"	 0 = not used.",RANGECHECK_RANGE,0,NANOSECONDS_MAX);
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:pid_as_clock_identity",
+		PTPD_RESTART_PROTOCOL, &rtOpts->pidAsClockId, rtOpts->pidAsClockId,
+	"Use PTPd's process ID as the middle part of the PTP clock ID - useful for running multiple instances.");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:ntp_failover",
+		PTPD_RESTART_NONE, &rtOpts->ntpOptions.enableFailover, rtOpts->ntpOptions.enableFailover,
+		"Fail over to NTP when PTP time sync not available - requires\n"
+	"	 ntpengine:enabled, but does not require the rest of NTP configuration:\n"
+	"	 will warn instead of failing over if cannot control ntpd.");
+	CONFIG_KEY_DEPENDENCY("ptpengine:ntp_failover", "ntpengine:enabled");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:ntp_failover_timeout",
+		PTPD_RESTART_NTPCONFIG, INTTYPE_INT, &rtOpts->ntpOptions.failoverTimeout,
+								rtOpts->ntpOptions.failoverTimeout,
+		"NTP failover timeout in seconds: time between PTP slave going into\n"
+	"	 LISTENING state, and releasing clock control. 0 = fail over immediately.", RANGECHECK_RANGE,0, 1800);
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:prefer_ntp",
+		PTPD_RESTART_NTPCONFIG, &rtOpts->preferNTP, rtOpts->preferNTP,
+		"Prefer NTP time synchronisation. Only use PTP when NTP not available,\n"
+	"	 could be used when NTP runs with a local GPS receiver or another reference");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:panic_mode_ntp",
+		"Legacy option from 2.3.0: same as ptpengine:panic_mode_release_clock");
+	CONFIG_KEY_DEPENDENCY("ptpengine:panic_mode_ntp", "ntpengine:enabled");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:sigusr2_clears_counters",
+		PTPD_RESTART_NONE, &rtOpts->clearCounters, rtOpts->clearCounters,
+		"Clear counters after dumping all counter values on SIGUSR2.");
+	/* Defining the ACLs enables ACL matching */
+	CONFIG_KEY_TRIGGER("ptpengine:timing_acl_permit", rtOpts->timingAclEnabled,TRUE, rtOpts->timingAclEnabled);
+	CONFIG_KEY_TRIGGER("ptpengine:timing_acl_deny", rtOpts->timingAclEnabled,TRUE, rtOpts->timingAclEnabled);
+	CONFIG_KEY_TRIGGER("ptpengine:management_acl_permit", rtOpts->managementAclEnabled,TRUE, rtOpts->managementAclEnabled);
+	CONFIG_KEY_TRIGGER("ptpengine:management_acl_deny", rtOpts->managementAclEnabled,TRUE, rtOpts->managementAclEnabled);
+	parseResult &= configMapString(opCode, opArg, dict, target, "ptpengine:timing_acl_permit",
+		PTPD_RESTART_ACLS, rtOpts->timingAclPermitText, sizeof(rtOpts->timingAclPermitText), rtOpts->timingAclPermitText,
+		"Permit access control list for timing packets. Format is a series of \n"
+        "        comma, space or tab separated  network prefixes: IPv4 addresses or full CIDR notation a.b.c.d/x,\n"
+        "        where a.b.c.d is the subnet and x is the decimal mask, or a.b.c.d/v.x.y.z where a.b.c.d is the\n"
+        "        subnet and v.x.y.z is the 4-octet mask. The match is performed on the source IP address of the\n"
+        "        incoming messages. IP access lists are only supported when using the IP transport.");
+	parseResult &= configMapString(opCode, opArg, dict, target, "ptpengine:timing_acl_deny",
+		PTPD_RESTART_ACLS, rtOpts->timingAclDenyText, sizeof(rtOpts->timingAclDenyText), rtOpts->timingAclDenyText,
+		"Deny access control list for timing packets. Format is a series of \n"
+	parseResult &= configMapString(opCode, opArg, dict, target, "ptpengine:management_acl_permit",
+		PTPD_RESTART_ACLS, rtOpts->managementAclPermitText, sizeof(rtOpts->managementAclPermitText), rtOpts->managementAclPermitText,
+		"Permit access control list for management messages. Format is a series of \n"
+	parseResult &= configMapString(opCode, opArg, dict, target, "ptpengine:management_acl_deny",
+		PTPD_RESTART_ACLS, rtOpts->managementAclDenyText, sizeof(rtOpts->managementAclDenyText), rtOpts->managementAclDenyText,
+		"Deny access control list for management messages. Format is a series of \n"
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "ptpengine:timing_acl_order",
+		PTPD_RESTART_ACLS, &rtOpts->timingAclOrder, rtOpts->timingAclOrder,
+		"Order in which permit and deny access lists are evaluated for timing\n"
+	"	 packets, the evaluation process is the same as for Apache httpd.",
+				"permit-deny", 	ACL_PERMIT_DENY,
+				"deny-permit", 	ACL_DENY_PERMIT, NULL
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "ptpengine:management_acl_order",
+		PTPD_RESTART_ACLS, &rtOpts->managementAclOrder, rtOpts->managementAclOrder,
+		"Order in which permit and deny access lists are evaluated for management\n"
+	"	 messages, the evaluation process is the same as for Apache httpd.",
+	/* Ethernet mode disables ACL processing*/
+	CONFIG_KEY_CONDITIONAL_TRIGGER(rtOpts->transport == IEEE_802_3, rtOpts->timingAclEnabled,FALSE, rtOpts->timingAclEnabled);
+	CONFIG_KEY_CONDITIONAL_TRIGGER(rtOpts->transport == IEEE_802_3, rtOpts->managementAclEnabled,FALSE, rtOpts->managementAclEnabled);
+/* ===== clock section ===== */
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "clock:no_adjust",
+		PTPD_RESTART_NONE, &rtOpts->noAdjust,ptpPreset.noAdjust,
+	"Do not adjust the clock");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "clock:no_reset",
+		PTPD_RESTART_NONE, &rtOpts->noResetClock, rtOpts->noResetClock,
+	"Do not step the clock - only slew");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "clock:step_startup_force",
+		PTPD_RESTART_NONE, &rtOpts->stepForce, rtOpts->stepForce,
+	"Force clock step on first sync after startup regardless of offset and clock:no_reset");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "clock:step_startup",
+		PTPD_RESTART_NONE, &rtOpts->stepOnce, rtOpts->stepOnce,
+		"Step clock on startup if offset >= 1 second, ignoring\n"
+	"        panic mode and clock:no_reset");
+#ifdef HAVE_LINUX_RTC_H
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "clock:set_rtc_on_step",
+		PTPD_RESTART_NONE, &rtOpts->setRtc, rtOpts->setRtc,
+	"Attempt setting the RTC when stepping clock (Linux only - FreeBSD does \n"
+	"        this for us. WARNING: this will always set the RTC to OS clock time,\n"
+	"        regardless of time zones, so this assumes that RTC runs in UTC or \n"
+	"        at least in the same timescale as PTP. true at least on most \n"
+	"        single-boot x86 Linux systems.");
+#endif /* HAVE_LINUX_RTC_H */
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "clock:drift_handling",
+		PTPD_RESTART_NONE, &rtOpts->drift_recovery_method, rtOpts->drift_recovery_method,
+		"Observed drift handling method between servo restarts:\n"
+	"	 reset: set to zero (not recommended)\n"
+	"	 preserve: use kernel value,\n"
+	"	 file: load/save to drift file on startup/shutdown, use kernel\n"
+	"	 value inbetween. To specify drift file, use the clock:drift_file setting."
+				"reset", 	DRIFT_RESET,
+				"preserve", 	DRIFT_KERNEL,
+				"file", 	DRIFT_FILE, NULL
+	parseResult &= configMapString(opCode, opArg, dict, target, "clock:drift_file",
+		PTPD_RESTART_NONE, rtOpts->driftFile, sizeof(rtOpts->driftFile), rtOpts->driftFile,
+	"Specify drift file");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "clock:leap_second_pause_period",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->leapSecondPausePeriod,
+		rtOpts->leapSecondPausePeriod,
+		"Time (seconds) before and after midnight that clock updates should pe suspended for\n"
+	"	 during a leap second event. The total duration of the pause is twice\n"
+	"        the configured duration",RANGECHECK_RANGE,5,600);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "clock:leap_second_notice_period",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->leapSecondNoticePeriod,
+		rtOpts->leapSecondNoticePeriod,
+		"Time (seconds) before midnight that PTPd starts announcing the leap second\n"
+	"	 if it's running as master",RANGECHECK_RANGE,3600,86400);
+	parseResult &= configMapString(opCode, opArg, dict, target, "clock:leap_seconds_file",
+		PTPD_RESTART_NONE, rtOpts->leapFile, sizeof(rtOpts->leapFile), rtOpts->leapFile,
+	"Specify leap second file location - up to date version can be downloaded from \n"
+	"        http://www.ietf.org/timezones/data/leap-seconds.list");
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "clock:leap_second_handling",
+		PTPD_RESTART_NONE, &rtOpts->leapSecondHandling, rtOpts->leapSecondHandling,
+		"Behaviour during a leap second event:\n"
+	"	 accept: inform the OS kernel of the event\n"
+	"	 ignore: do nothing - ends up with a 1-second offset which is then slewed\n"
+	"	 step: similar to ignore, but steps the clock immediately after the leap second event\n"
+	"        smear: do not inform kernel, gradually introduce the leap second before the event\n"
+	"               by modifying clock offset (see clock:leap_second_smear_period)",
+				"accept", 	LEAP_ACCEPT,
+				"ignore", 	LEAP_IGNORE,
+				"step", 	LEAP_STEP,
+				"smear",	LEAP_SMEAR, NULL
+	parseResult &= configMapInt(opCode, opArg, dict, target, "clock:leap_second_smear_period",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->leapSecondSmearPeriod,
+		rtOpts->leapSecondSmearPeriod,
+		"Time period (Seconds) over which the leap second is introduced before the event.\n"
+	"	 Example: when set to 86400 (24 hours), an extra 11.5 microseconds is added every second"
+	,RANGECHECK_RANGE,3600,86400);
+#ifdef HAVE_STRUCT_TIMEX_TICK
+	/* This really is clock specific - different clocks may allow different ranges */
+	parseResult &= configMapInt(opCode, opArg, dict, target, "clock:max_offset_ppm",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->servoMaxPpb, rtOpts->servoMaxPpb,
+		"Maximum absolute frequency shift which can be applied to the clock servo\n"
+	"	 when slewing the clock. Expressed in parts per million (1 ppm = shift of\n"
+	"	 1 us per second. Values above 512 will use the tick duration correction\n"
+	"	 to allow even faster slewing. Default maximum is 512 without using tick.", RANGECHECK_RANGE,
+	ADJ_FREQ_MAX/1000,ADJ_FREQ_MAX/500);
+#endif /* HAVE_STRUCT_TIMEX_TICK */
+	 * TimeProperties DS - in future when clock driver API is implemented,
+	 * a slave PTP engine should inform a clock about this, and then that
+	 * clock should pass this information to any master PTP engines, unless
+	 * we override this. here. For now we just supply this to RtOpts.
+/* ===== servo section ===== */
+	parseResult &= configMapInt(opCode, opArg, dict, target, "servo:delayfilter_stiffness",
+		PTPD_RESTART_NONE, INTTYPE_I16, &rtOpts->s, rtOpts->s,
+	"One-way delay filter stiffness.", RANGECHECK_NONE,0,0);
+	parseResult &= configMapDouble(opCode, opArg, dict, target, "servo:kp",
+		PTPD_RESTART_NONE, &rtOpts->servoKP, rtOpts->servoKP,
+	"Clock servo PI controller proportional component gain (kP).", RANGECHECK_MIN, 0.000001, 0);
+	parseResult &= configMapDouble(opCode, opArg, dict, target, "servo:ki",
+		PTPD_RESTART_NONE, &rtOpts->servoKI, rtOpts->servoKI,
+	"Clock servo PI controller integral component gain (kI).", RANGECHECK_MIN, 0.000001,0);
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "servo:dt_method",
+		PTPD_RESTART_NONE, &rtOpts->servoDtMethod, rtOpts->servoDtMethod,
+		"How servo update interval (delta t) is calculated:\n"
+	"	 none:     servo not corrected for update interval (dt always 1),\n"
+	"	 constant: constant value (target servo update rate - sync interval for PTP,\n"
+	"	 measured: servo measures how often it's updated and uses this interval.",
+			"none", DT_NONE,
+			"constant", DT_CONSTANT,
+			"measured", DT_MEASURED, NULL
+	parseResult &= configMapDouble(opCode, opArg, dict, target, "servo:dt_max",
+		PTPD_RESTART_NONE, &rtOpts->servoMaxdT, rtOpts->servoMaxdT,
+		"Maximum servo update interval (delta t) when using measured servo update interval\n"
+	"	 (servo:dt_method = measured), specified as sync interval multiplier.", RANGECHECK_RANGE, 1.5,100.0);
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "servo:stability_detection",
+		PTPD_RESTART_NONE, &rtOpts->servoStabilityDetection,
+							rtOpts->servoStabilityDetection,
+		 "Enable clock synchronisation servo stability detection\n"
+	"	 (based on standard deviation of the observed drift value)\n"
+	"	 - drift will be saved to drift file / cached when considered stable,\n"
+	"	 also clock stability status will be logged.");
+	parseResult &= configMapDouble(opCode, opArg, dict, target, "servo:stability_threshold",
+		PTPD_RESTART_NONE, &rtOpts->servoStabilityThreshold,
+							rtOpts->servoStabilityThreshold,
+		"Specify the observed drift standard deviation threshold in parts per\n"
+	"	 billion (ppb) - if stanard deviation is within the threshold, servo\n"
+	"	 is considered stable.", RANGECHECK_RANGE, 1.0,10000.0);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "servo:stability_period",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->servoStabilityPeriod,
+							rtOpts->servoStabilityPeriod,
+		"Specify for how many statistics update intervals the observed drift\n"
+	"	standard deviation has to stay within threshold to be considered stable.", RANGECHECK_RANGE,
+	1,100);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "servo:stability_timeout",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->servoStabilityTimeout,
+							rtOpts->servoStabilityTimeout,
+		"Specify after how many minutes without stabilisation servo is considered\n"
+	"	 unstable. Assists with logging servo stability information and\n"
+	"	 allows to preserve observed drift if servo cannot stabilise.\n", RANGECHECK_RANGE,
+	1,60);
+#endif
+	parseResult &= configMapInt(opCode, opArg, dict, target, "servo:max_delay",
+		PTPD_RESTART_NONE, INTTYPE_I32, &rtOpts->maxDelay, rtOpts->maxDelay,
+		"Do accept master to slave delay (delayMS - from Sync message) or slave to master delay\n"
+	"	 (delaySM - from Delay messages) if greater than this value (nanoseconds). 0 = not used.", RANGECHECK_RANGE,
+	0,NANOSECONDS_MAX);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "servo:max_delay_max_rejected",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->maxDelayMaxRejected, rtOpts->maxDelayMaxRejected,
+		"Maximum number of consecutive delay measurements exceeding maxDelay threshold,\n"
+	"	 before slave is reset.", RANGECHECK_MIN,0,0);
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "servo:max_delay_stable_only",
+		PTPD_RESTART_NONE, &rtOpts->maxDelayStableOnly, rtOpts->maxDelayStableOnly,
+		"If servo:max_delay is set, perform the check only if clock servo has stabilised.\n");
+#endif
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ptpengine:sync_sequence_checking",
+		PTPD_RESTART_NONE, &rtOpts->syncSequenceChecking, rtOpts->syncSequenceChecking,
+		"When enabled, Sync messages will only be accepted if sequence ID is increasing."
+	"        This is limited to 50 dropped messages.\n");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ptpengine:clock_update_timeout",
+		PTPD_RESTART_PROTOCOL, INTTYPE_INT, &rtOpts->clockUpdateTimeout, rtOpts->clockUpdateTimeout,
+		"If set to non-zero, timeout in seconds, after which the slave resets if no clock updates made. \n", RANGECHECK_RANGE,
+		0, 3600);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "servo:max_offset",
+		PTPD_RESTART_NONE, INTTYPE_I32, &rtOpts->maxOffset, rtOpts->maxOffset,
+		"Do not reset the clock if offset from master is greater\n"
+	"        than this value (nanoseconds). 0 = not used.", RANGECHECK_RANGE,
+/* ===== global section ===== */
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "global:enable_alarms",
+	    PTPD_RESTART_ALARMS, &rtOpts->alarmsEnabled, rtOpts->alarmsEnabled,
+		 "Enable support for alarm and event notifications.\n");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "global:alarm_timeout",
+		PTPD_RESTART_ALARMS, INTTYPE_INT, &rtOpts->alarmMinAge, rtOpts->alarmMinAge,
+		"Mininmum alarm age (seconds) - minimal time between alarm set and clear notifications.\n"
+	"	 The condition can clear while alarm lasts, but notification (log or SNMP) will only \n"
+	"	 be triggered after the timeout. This option prevents from alarms flapping.", RANGECHECK_RANGE, 0, 3600);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "global:alarm_initial_delay",
+		PTPD_RESTART_DAEMON, INTTYPE_INT, &rtOpts->alarmInitialDelay, rtOpts->alarmInitialDelay,
+		"Delay the start of alarm processing (seconds) after ptpd startup. This option \n"
+	"	 allows to avoid unnecessary alarms before PTPd starts synchronising.\n",
+	RANGECHECK_RANGE, 0, 3600);
+#ifdef PTPD_SNMP
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "global:enable_snmp",
+		PTPD_RESTART_DAEMON, &rtOpts->snmpEnabled, rtOpts->snmpEnabled,
+	"Enable SNMP agent (if compiled with PTPD_SNMP).");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "global:enable_snmp_traps",
+	    PTPD_RESTART_ALARMS, &rtOpts->snmpTrapsEnabled, rtOpts->snmpTrapsEnabled,
+		 "Enable sending SNMP traps (only if global:enable_alarms set and global:enable_snmp set).\n");
+#else
+	if(!(opCode & CFGOP_PARSE_QUIET) && CONFIG_ISTRUE("global:enable_snmp"))
+	    INFO("SNMP support not enabled. Please compile with PTPD_SNMP to use global:enable_snmp\n");
+	if(!(opCode & CFGOP_PARSE_QUIET) && CONFIG_ISTRUE("global:enable_snmp_traps"))
+	    INFO("SNMP support not enabled. Please compile with PTPD_SNMP to use global:enable_snmp_traps\n");
+#endif /* PTPD_SNMP */
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "global:use_syslog",
+		PTPD_RESTART_LOGGING, &rtOpts->useSysLog, rtOpts->useSysLog,
+		"Send log messages to syslog. Disabling this\n"
+	"        sends all messages to stdout (or speficied log file).");
+	parseResult &= configMapString(opCode, opArg, dict, target, "global:lock_file",
+		PTPD_RESTART_DAEMON, rtOpts->lockFile, sizeof(rtOpts->lockFile), rtOpts->lockFile,
+	"Lock file location");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "global:auto_lockfile",
+		PTPD_RESTART_DAEMON, &rtOpts->autoLockFile, rtOpts->autoLockFile,
+	"	 Use mode specific and interface specific lock file\n"
+	"	 (overrides global:lock_file).");
+	parseResult &= configMapString(opCode, opArg, dict, target, "global:lock_directory",
+		PTPD_RESTART_DAEMON, rtOpts->lockDirectory, sizeof(rtOpts->lockDirectory), rtOpts->lockDirectory,
+		 "Lock file directory: used with automatic mode-specific lock files,\n"
+	"	 also used when no lock file is specified. When lock file\n"
+	"	 is specified, it's expected to be an absolute path.");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "global:ignore_lock",
+		PTPD_RESTART_DAEMON, &rtOpts->ignore_daemon_lock, rtOpts->ignore_daemon_lock,
+	"Skip lock file checking and locking.");
+	/* if quality file specified, enable quality recording  */
+	CONFIG_KEY_TRIGGER("global:quality_file", rtOpts->recordLog.logEnabled,TRUE,FALSE);
+	parseResult &= configMapString(opCode, opArg, dict, target, "global:quality_file",
+		PTPD_RESTART_LOGGING, rtOpts->recordLog.logPath, sizeof(rtOpts->recordLog.logPath), rtOpts->recordLog.logPath,
+		"File used to record data about sync packets. Enables recording when set.");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "global:quality_file_max_size",
+		PTPD_RESTART_LOGGING, INTTYPE_U32, &rtOpts->recordLog.maxSize, rtOpts->recordLog.maxSize,
+		"Maximum sync packet record file size (in kB) - file will be truncated\n"
+	"	if size exceeds the limit. 0 - no limit.", RANGECHECK_MIN,0,0);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "global:quality_file_max_files",
+		PTPD_RESTART_LOGGING, INTTYPE_INT, &rtOpts->recordLog.maxFiles, rtOpts->recordLog.maxFiles,
+		"Enable log rotation of the sync packet record file up to n files.\n"
+	"	 0 - do not rotate.\n", RANGECHECK_RANGE,0, 100);
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "global:quality_file_truncate",
+		PTPD_RESTART_LOGGING, &rtOpts->recordLog.truncateOnReopen, rtOpts->recordLog.truncateOnReopen,
+		"Truncate the sync packet record file every time it is (re) opened:\n"
+	"	 startup and SIGHUP.");
+	/* if status file specified, enable status logging*/
+	CONFIG_KEY_TRIGGER("global:status_file", rtOpts->statusLog.logEnabled,TRUE,FALSE);
+	parseResult &= configMapString(opCode, opArg, dict, target, "global:status_file",
+		PTPD_RESTART_LOGGING, rtOpts->statusLog.logPath, sizeof(rtOpts->statusLog.logPath), rtOpts->statusLog.logPath,
+	"File used to log "PTPD_PROGNAME" status information.");
+	/* status file can be disabled even if specified */
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "global:log_status",
+		PTPD_RESTART_NONE, &rtOpts->statusLog.logEnabled, rtOpts->statusLog.logEnabled,
+		"Enable / disable writing status information to file.");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "global:status_update_interval",
+		PTPD_RESTART_LOGGING, INTTYPE_INT, &rtOpts->statusFileUpdateInterval, rtOpts->statusFileUpdateInterval,
+		"Status file update interval in seconds.", RANGECHECK_RANGE,
+	1,30);
+#ifdef RUNTIME_DEBUG
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "global:debug_level",
+		PTPD_RESTART_NONE, (uint8_t*)&rtOpts->debug_level, rtOpts->debug_level,
+	"Specify debug level (if compiled with RUNTIME_DEBUG).",
+				"LOG_INFO", 	LOG_INFO,
+				"LOG_DEBUG", 	LOG_DEBUG,
+				"LOG_DEBUG1", 	LOG_DEBUG1,
+				"LOG_DEBUG2", 	LOG_DEBUG2,
+				"LOG_DEBUG3", 	LOG_DEBUG3,
+				"LOG_DEBUGV", 	LOG_DEBUGV, NULL
+#else
+	if (!(opCode & CFGOP_PARSE_QUIET) && CONFIG_ISSET("global:debug_level"))
+	    INFO("Runtime debug not enabled. Please compile with RUNTIME_DEBUG to use global:debug_level.\n");
+#endif /* RUNTIME_DEBUG */
+     * Log files are reopened and / or re-created on SIGHUP anyway,
+	/* if log file specified, enable file logging - otherwise disable */
+	CONFIG_KEY_TRIGGER("global:log_file", rtOpts->eventLog.logEnabled,TRUE,FALSE);
+	parseResult &= configMapString(opCode, opArg, dict, target, "global:log_file",
+		PTPD_RESTART_LOGGING, rtOpts->eventLog.logPath, sizeof(rtOpts->eventLog.logPath), rtOpts->eventLog.logPath,
+		"Specify log file path (event log). Setting this enables logging to file.");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "global:log_file_max_size",
+		PTPD_RESTART_LOGGING, INTTYPE_U32, &rtOpts->eventLog.maxSize, rtOpts->eventLog.maxSize,
+		"Maximum log file size (in kB) - log file will be truncated if size exceeds\n"
+	"	 the limit. 0 - no limit.", RANGECHECK_MIN,0,0);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "global:log_file_max_files",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->eventLog.maxFiles, rtOpts->eventLog.maxFiles,
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "global:log_file_truncate",
+		PTPD_RESTART_LOGGING, &rtOpts->eventLog.truncateOnReopen, rtOpts->eventLog.truncateOnReopen,
+		"Truncate the log file every time it is (re) opened: startup and SIGHUP.");
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "global:log_level",
+		PTPD_RESTART_NONE, &rtOpts->logLevel, rtOpts->logLevel,
+		"Specify log level (only messages at this priority or higer will be logged).\n"
+	"	 The minimal level is LOG_ERR. LOG_ALL enables debug output if compiled with\n"
+	"	 RUNTIME_DEBUG.",
+				"LOG_ERR", 	LOG_ERR,
+				"LOG_WARNING", 	LOG_WARNING,
+				"LOG_NOTICE", 	LOG_NOTICE,
+				"LOG_ALL",	LOG_ALL, NULL
+	/* if statistics file specified, enable statistics logging - otherwise disable  - log_statistics also controlled further below*/
+	CONFIG_KEY_TRIGGER("global:statistics_file", rtOpts->statisticsLog.logEnabled,TRUE,FALSE);
+	CONFIG_KEY_TRIGGER("global:statistics_file", rtOpts->logStatistics,TRUE,FALSE);
+	parseResult &= configMapString(opCode, opArg, dict, target, "global:statistics_file",
+		PTPD_RESTART_LOGGING, rtOpts->statisticsLog.logPath, sizeof(rtOpts->statisticsLog.logPath), rtOpts->statisticsLog.logPath,
+		"Specify statistics log file path. Setting this enables logging of \n"
+	"	 statistics, but can be overriden with global:log_statistics.");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "global:statistics_log_interval",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->statisticsLogInterval, rtOpts->statisticsLogInterval,
+		 "Log timing statistics every n seconds for Sync and Delay messages\n"
+	"	 (0 - log all).",RANGECHECK_MIN,0,0);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "global:statistics_file_max_size",
+		PTPD_RESTART_LOGGING, INTTYPE_U32, &rtOpts->statisticsLog.maxSize, rtOpts->statisticsLog.maxSize,
+		"Maximum statistics log file size (in kB) - log file will be truncated\n"
+	"	 if size exceeds the limit. 0 - no limit.",RANGECHECK_MIN,0,0);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "global:statistics_file_max_files",
+		PTPD_RESTART_LOGGING, INTTYPE_INT, &rtOpts->statisticsLog.maxFiles, rtOpts->statisticsLog.maxFiles,
+		"Enable log rotation of the statistics file up to n files. 0 - do not rotate.", RANGECHECK_RANGE,0, 100);
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "global:statistics_file_truncate",
+		PTPD_RESTART_LOGGING, &rtOpts->statisticsLog.truncateOnReopen, rtOpts->statisticsLog.truncateOnReopen,
+		"Truncate the statistics file every time it is (re) opened: startup and SIGHUP.");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "global:dump_packets",
+		PTPD_RESTART_NONE, &rtOpts->displayPackets, rtOpts->displayPackets,
+		"Dump the contents of every PTP packet");
+	/* this also checks if the verbose_foreground flag is set correctly */
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "global:verbose_foreground",
+		PTPD_RESTART_DAEMON, &rtOpts->nonDaemon, rtOpts->nonDaemon,
+		"Run in foreground with statistics and all messages logged to stdout.\n"
+	"	 Overrides log file and statistics file settings and disables syslog.\n");
+	if(CONFIG_ISTRUE("global:verbose_foreground")) {
+		rtOpts->useSysLog    = FALSE;
+		rtOpts->logStatistics = TRUE;
+		rtOpts->statisticsLogInterval = 0;
+		rtOpts->eventLog.logEnabled = FALSE;
+		rtOpts->statisticsLog.logEnabled = FALSE;
+	 * this HAS to be executed after the verbose_foreground mapping because of the same
+	 * default field used for both. verbose_foreground triggers nonDaemon which is OK,
+	 * but we don't want foreground=y to switch on verbose_foreground if not set.
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "global:foreground",
+		"Run in foreground - ignored when global:verbose_foreground is set");
+		rtOpts->nonDaemon = TRUE;
+	/* If this is processed after verbose_foreground, we can still control logStatistics */
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "global:log_statistics",
+		PTPD_RESTART_NONE, &rtOpts->logStatistics, rtOpts->logStatistics,
+		"Log timing statistics for every PTP packet received\n");
+	parseResult &= configMapSelectValue(opCode, opArg, dict, target, "global:statistics_timestamp_format",
+		PTPD_RESTART_NONE, &rtOpts->statisticsTimestamp, rtOpts->statisticsTimestamp,
+		"Timestamp format used when logging timing statistics\n"
+	"        (when global:log_statistics is enabled):\n"
+	"        datetime - formatttted date and time: YYYY-MM-DD hh:mm:ss.uuuuuu\n"
+	"        unix - Unix timestamp with nanoseconds: s.ns\n"
+	"        both - Formatted date and time, followed by unix timestamp\n"
+	"               (adds one extra field  to the log)\n",
+		"datetime",	TIMESTAMP_DATETIME,
+		"unix",		TIMESTAMP_UNIX,
+		"both",		TIMESTAMP_BOTH, NULL
+	/* If statistics file is enabled but logStatistics isn't, disable logging to file */
+	CONFIG_KEY_CONDITIONAL_TRIGGER(rtOpts->statisticsLog.logEnabled && !rtOpts->logStatistics,
+					rtOpts->statisticsLog.logEnabled, FALSE, rtOpts->statisticsLog.logEnabled);
+#if (defined(linux) && defined(HAVE_SCHED_H)) || defined(HAVE_SYS_CPUSET_H) || defined (__QNXNTO__)
+	parseResult &= configMapInt(opCode, opArg, dict, target, "global:cpuaffinity_cpucore", PTPD_CHANGE_CPUAFFINITY, INTTYPE_INT, &rtOpts->cpuNumber, rtOpts->cpuNumber,
+		"Bind "PTPD_PROGNAME" process to a selected CPU core number.\n"
+	"        0 = first CPU core, etc. -1 = do not bind to a single core.", RANGECHECK_RANGE,
+	-1,255);
+#endif /* (linux && HAVE_SCHED_H) || HAVE_SYS_CPUSET_H */
+	parseResult &= configMapInt(opCode, opArg, dict, target, "global:statistics_update_interval",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->statsUpdateInterval,
+								rtOpts->statsUpdateInterval,
+		"Clock synchronisation statistics update interval in seconds\n", RANGECHECK_RANGE,1, 60);
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "global:periodic_updates",
+		PTPD_RESTART_LOGGING, &rtOpts->periodicUpdates, rtOpts->periodicUpdates,
+		"Log a status update every time statistics are updated (global:statistics_update_interval).\n"
+	"        The updates are logged even when ptpd is configured without statistics support");
+	CONFIG_CONDITIONAL_ASSERTION( rtOpts->servoStabilityDetection && (
+				    (rtOpts->statsUpdateInterval * rtOpts->servoStabilityPeriod) / 60 >=
+				    rtOpts->servoStabilityTimeout),
+			"The configured servo stabilisation timeout has to be longer than\n"
+		"	 servo stabilisation period");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "global:timingdomain_election_delay",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->electionDelay, rtOpts->electionDelay,
+		" Delay (seconds) before releasing a time service (NTP or PTP)"
+	"        and electing a new one to control a clock. 0 = elect immediately\n", RANGECHECK_RANGE,0, 3600);
+/* ===== ntpengine section ===== */
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ntpengine:enabled",
+		PTPD_RESTART_NTPENGINE, &rtOpts->ntpOptions.enableEngine, rtOpts->ntpOptions.enableEngine,
+	"Enable NTPd integration");
+	parseResult &= configMapBoolean(opCode, opArg, dict, target, "ntpengine:control_enabled",
+		PTPD_RESTART_NONE, &rtOpts->ntpOptions.enableControl, rtOpts->ntpOptions.enableControl,
+	"Enable control over local NTPd daemon");
+	CONFIG_KEY_DEPENDENCY("ntpengine:control_enabled", "ntpengine:enabled");
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ntpengine:check_interval",
+		PTPD_RESTART_NTPCONFIG, INTTYPE_INT, &rtOpts->ntpOptions.checkInterval,
+								rtOpts->ntpOptions.checkInterval,
+		"NTP control check interval in seconds\n", RANGECHECK_RANGE, 5, 600);
+	parseResult &= configMapInt(opCode, opArg, dict, target, "ntpengine:key_id",
+		PTPD_RESTART_NONE, INTTYPE_INT, &rtOpts->ntpOptions.keyId, rtOpts->ntpOptions.keyId,
+		 "NTP key number - must be configured as a trusted control key in ntp.conf,\n"
+	"	  and be non-zero for the ntpengine:control_enabled setting to take effect.\n", RANGECHECK_RANGE,0, 65535);
+	parseResult &= configMapString(opCode, opArg, dict, target, "ntpengine:key",
+		PTPD_RESTART_NONE, rtOpts->ntpOptions.key, sizeof(rtOpts->ntpOptions.key), rtOpts->ntpOptions.key,
+		"NTP key (plain text, max. 20 characters) - must match the key configured in\n"
+	"	 ntpd's keys file, and must be non-zero for the ntpengine:control_enabled\n"
+	"	 setting to take effect.\n");
+	CONFIG_KEY_DEPENDENCY("ntpengine:control:enabled", "ntpengine:key_id");
+	CONFIG_KEY_DEPENDENCY("ntpengine:control:enabled", "ntpengine:key");
+/* ============== END CONFIG MAPPINGS, TRIGGERS AND DEPENDENCIES =========== */
+/* ==== Any additional logic should go here ===== */
+	rtOpts->ifaceName = rtOpts->primaryIfaceName;
+	/* Check timing packet ACLs */
+	if(rtOpts->timingAclEnabled) {
+		int pResult, dResult;
+		if((pResult = maskParser(rtOpts->timingAclPermitText, NULL)) == -1)
+			ERROR("Error while parsing timing permit access list: \"%s\"\n",
+				rtOpts->timingAclPermitText);
+		if((dResult = maskParser(rtOpts->timingAclDenyText, NULL)) == -1)
+			ERROR("Error while parsing timing deny access list: \"%s\"\n",
+				rtOpts->timingAclDenyText);
+		/* -1 = ACL format error*/
+		if(pResult == -1 || dResult == -1) {
+			parseResult = FALSE;
+			rtOpts->timingAclEnabled = FALSE;
+		/* 0 = no entries - we simply don't match */
+		if(pResult == 0 && dResult == 0) {
+	/* Check management message ACLs */
+	if(rtOpts->managementAclEnabled) {
+		if((pResult = maskParser(rtOpts->managementAclPermitText, NULL)) == -1)
+			ERROR("Error while parsing management permit access list: \"%s\"\n",
+				rtOpts->managementAclPermitText);
+		if((dResult = maskParser(rtOpts->managementAclDenyText, NULL)) == -1)
+			ERROR("Error while parsing management deny access list: \"%s\"\n",
+				rtOpts->managementAclDenyText);
+			rtOpts->managementAclEnabled = FALSE;
+	/* Scale the maxPPM to PPB */
+	rtOpts->servoMaxPpb *= 1000;
+	/* Shift DSCP to accept the 6-bit value */
+	rtOpts->dscpValue = rtOpts->dscpValue << 2;
+	 * We're in hybrid mode and we haven't specified the delay request interval:
+	 * use override with a default value
+	if((rtOpts->ipMode == IPMODE_HYBRID) &&
+	 !CONFIG_ISSET("ptpengine:log_delayreq_interval"))
+		rtOpts->ignore_delayreq_interval_master=TRUE;
+	 * We're in unicast slave-capable mode and we haven't specified the delay request interval:
+	if((rtOpts->ipMode == IPMODE_UNICAST &&
+	    rtOpts->clockQuality.clockClass > 127) &&
+	 * construct the lock file name based on operation mode:
+	 * if clock class is <128 (master only), use "master" and interface name
+	 * if clock class is >127 (can be slave), use clock driver and interface name
+	if(rtOpts->autoLockFile) {
+	    memset(rtOpts->lockFile, 0, PATH_MAX);
+	    snprintf(rtOpts->lockFile, PATH_MAX,
+		    "%s/"PTPD_PROGNAME"_%s_%s.lock",
+		    rtOpts->lockDirectory,
+		    (rtOpts->clockQuality.clockClass<128 && !rtOpts->slaveOnly) ? "master" : DEFAULT_CLOCKDRIVER,
+		    rtOpts->ifaceName);
+	    DBG("Automatic lock file name is: %s\n", rtOpts->lockFile);
+	 * Otherwise use default lock file name, with the specified lock directory
+	 * which will be set do default from constants_dep.h if not configured
+	} else {
+		if(!CONFIG_ISSET("global:lock_file"))
+				"%s/%s", rtOpts->lockDirectory, DEFAULT_LOCKFILE_NAME);
+/* ==== END additional logic */
+	if(opCode & CFGOP_PARSE) {
+		findUnknownSettings(opCode, dict, target);
+		if (parseResult)
+			INFO("Configuration OK\n");
+		    else
+			ERROR("There are errors in the configuration - see previous messages\n");
+	if ((opCode & CFGOP_PARSE || opCode & CFGOP_PARSE_QUIET) && parseResult) {
+		return target;
+	dictionary_del(&target);
+	return NULL;
+ * Wrapper around iniparser_load, which loads the ini file
+ * contents into an existing dictionary - iniparser_load
+ * creates a new dictionary
+Boolean
+loadConfigFile(dictionary **target, RunTimeOpts *rtOpts)
+	dictionary *dict;
+	if ( (dict = iniparser_load(rtOpts->configFile)) == NULL) {
+		ERROR("Could not load configuration file: %s\n", rtOpts->configFile);
+		return FALSE;
+	dictionary_merge( dict, *target, 0, 0, NULL);
+	dictionary_del(&dict);
+	return TRUE;
+ * this function scans argv looking for what looks like correctly formatted
+ * long options in the form "--section:key=value", "-section:key=value",
+ * "--section:key value" and "-section:key value".
+ * it then clears them from argv so that getopt can deal with the rest.
+ * This is in a way better than getopt_long() because we don't need to
+ * pre-define all possible options. Unknown or malformed ones are ignored.
+void
+loadCommandLineKeys(dictionary* dict, int argc,char** argv)
+    int i;
+    char key[PATH_MAX],val[PATH_MAX];
+    for ( i=0; i<argc; i++) {
+	if( strlen(argv[i]) > 3 &&
+	    index(argv[i],':') != NULL ) {
+	/* check if the option is passed as sec:key=value */
+	if (sscanf(argv[i],"--%[-_a-zA-Z0-9:]=%s",key,val)==2 ||
+	    sscanf(argv[i],"-%[-_a-zA-Z0-9:]=%s",key,val)==2) {
+	/* wipe the used argv entry so that getopt doesn't get confused */
+		argv[i]="";
+	    } else
+	 * there are no optional arguments for key:sec options - if there's no =,
+	 * the next argument is the value.
+	if (sscanf(argv[i],"--%[-_a-zA-Z0-9:]",key)==1 ||
+	    sscanf(argv[i],"-%[-_a-zA-Z0-9:]",key)==1 ) {
+		argv[i]="";
+		memset(val, 0, PATH_MAX);
+		if (i+1 < argc) {
+		    if( (argv[i+1][0]!='-') &&
+			( (strlen(argv[i+i]) > 1) && argv[i+1][1] !='-' )) {
+			strncpy(val,argv[i+1],PATH_MAX);
+			argv[i+1]="";
+	 * there is no argument --sec:key=val
+	else {
+		val[0] = '\0';
+		key[0] = '\0';
+	if(strlen(key) > 0) {
+		DBGV("setting loaded from command line: %s = %s\n",key,val);
+		dictionary_set(dict, key, val);
+ * Create a dummy rtOpts with defaults, create a dummy dictionary,
+ * Set the "secret" key in the dictionary, causing parseConfig
+ * to switch from parse mode to print default mode
+void
+printDefaultConfig()
+	RunTimeOpts rtOpts;
+	dictionary *dict;
+	loadDefaultSettings(&rtOpts);
+	dict = dictionary_new(0);
+	printf( "; ========================================\n");
+	printf( "; "USER_DESCRIPTION" version "USER_VERSION" default configuration\n");
+	printf( "; ========================================\n\n");
+	printf( "; NOTE: the following settings are affected by ptpengine:preset selection:\n"
+		";           ptpengine:slave_only\n"
+		";           clock:no_adjust\n"
+		";           ptpengine:clock_class - allowed range and default value\n"
+		"; To see all preset settings, run "PTPD_PROGNAME" -H (--long-help)\n");
+	/* NULL will always be returned in this mode */
+	parseConfig(CFGOP_PRINT_DEFAULT | CFGOP_PARSE_QUIET, NULL, dict, &rtOpts);
+	printf("\n; ========= newline required in the end ==========\n\n");
+ * to switch from parse mode to help mode.
+void
+printConfigHelp()
+	dictionary *dict;
+	printf("\n============== Full list of "PTPD_PROGNAME" settings ========\n\n");
+	parseConfig(CFGOP_HELP_FULL | CFGOP_PARSE_QUIET, NULL, dict, &rtOpts);
+ * to switch from parse mode to help mode, for a selected key only.
+void
+printSettingHelp(char* key)
+	dictionary *dict;
+	char* origKey = strdup(key);
+	printf("\n");
+	parseConfig(CFGOP_HELP_SINGLE | CFGOP_PARSE_QUIET, key, dict, &rtOpts);
+	/* if the setting has been found (and help printed), the first byte will be cleared */
+	if(key[0] != '\0') {
+	    printf("Unknown setting: %s\n\n", origKey);
+	printf("Use -H or --long-help to show help for all settings.\n\n");
+	free(origKey);
+ * Handle standard options with getopt_long. Returns FALSE if ptpd should not continue.
+ * If a required setting, such as interface name, or a setting
+ * requiring a range check is to be set via getopts_long,
+ * the respective currentConfig dictionary entry should be set,
+ * instead of just setting the rtOpts field.
+Boolean loadCommandLineOptions(RunTimeOpts* rtOpts, dictionary* dict, int argc, char** argv, Integer16* ret) {
+	int c;
+#ifdef HAVE_GETOPT_LONG
+	int opt_index = 0;
+#endif /* HAVE_GETOPT_LONG */
+	*ret = 0;
+	/* there's NOTHING wrong with this */
+	if(argc==1) {
+			*ret = 1;
+			goto short_help;
+	 * A minimal set of long and short CLI options,
+	 * for basic operations only. Maintained compatibility
+	 * with previous versions. Any other settings
+	 * should be given in the config file or using
+	 * --section:key options
+	static struct option long_options[] = {
+	    {"config-file",	required_argument, 0, 'c'},
+	    {"check-config",	optional_argument, 0, 'k'},
+	    {"interface",	required_argument, 0, 'i'},
+	    {"domain",		required_argument, 0, 'd'},
+	    {"slaveonly",	no_argument,	   0, 's'},
+	    {"masterslave",	no_argument,	   0, 'm'},
+	    {"masteronly",	no_argument,	   0, 'M'},
+	    {"hybrid",		no_argument,	   0, 'y'},
+	    {"e2e",		optional_argument, 0, 'E'},
+	    {"p2p",		optional_argument, 0, 'P'},
+	    {"noadjust",	optional_argument, 0, 'n'},
+	    {"ignore-lock",	optional_argument, 0, 'L'},
+	    {"auto-lock",	optional_argument, 0, 'A'},
+	    {"lockfile",	optional_argument, 0, 'l'},
+	    {"print-lockfile",	optional_argument, 0, 'p'},
+	    {"lock-directory",	required_argument, 0, 'R'},
+	    {"log-file",	required_argument, 0, 'f'},
+	    {"statistics-file",	required_argument, 0, 'S'},
+	    {"delay-interval",	required_argument, 0, 'r'},
+	    {"delay-override",	no_argument, 	   0, 'a'},
+	    {"debug",		no_argument,	   0, 'D'},
+	    {"version",		optional_argument, 0, 'v'},
+	    {"foreground",	no_argument,	   0, 'C'},
+	    {"verbose",		no_argument,	   0, 'V'},
+	    {"help",		optional_argument, 0, 'h'},
+	    {"long-help",	no_argument,	   0, 'H'},
+	    {"explain",		required_argument, 0, 'e'},
+	    {"default-config",  optional_argument, 0, 'O'},
+	    {"templates",	required_argument, 0, 't'},
+	    {"show-templates",  no_argument,	   0, 'T'},
+	    {"unicast",		optional_argument, 0, 'U'},
+	    {"unicast-negotiation",		optional_argument, 0, 'g'},
+	    {"unicast-destinations",		required_argument, 0, 'u'},
+	    {0,			0		 , 0, 0}
+	while ((c = getopt_long(argc, argv, "?c:kb:i:d:sgmGMWyUu:nf:S:r:DvCVHTt:he:Y:tOLEPAaR:l:p", long_options, &opt_index)) != -1) {
+#else
+	while ((c = getopt(argc, argv, "?c:kb:i:d:sgmGMWyUu:nf:S:r:DvCVHTt:he:Y:tOLEPAaR:l:p")) != -1) {
+#endif
+	    switch(c) {
+/* non-config options first */
+		/* getopt error or an actual ? */
+		case '?':
+			printf("Run "PTPD_PROGNAME" with -h to see available command-line options.\n");
+			printf("Run "PTPD_PROGNAME" with -H or --long-help to show detailed help for all settings.\n\n");
+			*ret = 1;
+			return FALSE;
+		case 'h':
+short_help:
+			printf("\n");
+			printShortHelp();
+			return FALSE;
+		case 'H':
+			printLongHelp();
+			return FALSE;
+		case 'e':
+			if(strlen(optarg) > 0)
+			    printSettingHelp(optarg);
+			return FALSE;
+		case 'O':
+			printDefaultConfig();
+			return FALSE;
+		case 'T':
+			dumpConfigTemplates();
+			return FALSE;
+/* regular ptpd options */
+		/* config file path */
+		case 'c':
+			strncpy(rtOpts->configFile, optarg, PATH_MAX);
+			break;
+		/* check configuration and exit */
+		case 'k':
+			rtOpts->checkConfigOnly = TRUE;
+			break;
+		/* interface */
+		case 'b':
+			WARN_DEPRECATED('b', 'i', "interface", "ptpengine:interface");
+		case 'i':
+			/* if we got a number here, we've been given the domain number */
+			if( (c=='i') && strlen(optarg) > 0 && isdigit((unsigned char)optarg[0]) ) {
+				WARN_DEPRECATED_COMMENT('i', 'd', "domain", "ptpengine:domain",
+				"for specifying domain number ");
+				dictionary_set(dict,"ptpengine:domain", optarg);
+			} else
+				dictionary_set(dict,"ptpengine:interface", optarg);
+			break;
+		/* domain */
+		case 'd':
+			break;
+		case 's':
+			dictionary_set(dict,"ptpengine:preset", "slaveonly");
+			break;
+		/* master/slave */
+		case 'W':
+			WARN_DEPRECATED('W', 'm', "masterslave", "ptpengine:preset=masterslave");
+		case 'm':
+			dictionary_set(dict,"ptpengine:preset", "masterslave");
+			break;
+		/* master only */
+		case 'G':
+			WARN_DEPRECATED('G', 'M', "masteronly", "ptpengine:preset=masteronly");
+		case 'M':
+			dictionary_set(dict,"ptpengine:preset", "masteronly");
+			break;
+		case 'y':
+			dictionary_set(dict,"ptpengine:ip_mode", "hybrid");
+			break;
+		/* unicast */
+		case 'U':
+			dictionary_set(dict,"ptpengine:ip_mode", "unicast");
+			break;
+		case 'g':
+			dictionary_set(dict,"ptpengine:unicast_negotiation", "y");
+			break;
+		case 'u':
+			dictionary_set(dict,"ptpengine:unicast_destinations", optarg);
+			break;
+		case 'n':
+			dictionary_set(dict,"clock:no_adjust", "Y");
+			break;
+		/* log file */
+		case 'f':
+			dictionary_set(dict,"global:log_file", optarg);
+			break;
+		/* statistics file */
+		case 'S':
+			dictionary_set(dict,"global:statistics_file", optarg);
+			break;
+		case 't':
+			dictionary_set(dict,"global:config_templates", optarg);
+		/* Override delay request interval from master */
+		case 'a':
+			dictionary_set(dict,"ptpengine:log_delayreq_override", "Y");
+			break;
+		/* Delay request interval - needed for hybrid mode */
+		case 'Y':
+			WARN_DEPRECATED('Y', 'r', "delay-interval", "ptpengine:log_delayreq_interval");
+		case 'r':
+			dictionary_set(dict,"ptpengine:log_delayreq_interval", optarg);
+			break;
+                case 'D':
+                        (rtOpts->debug_level)++;
+                        if(rtOpts->debug_level > LOG_DEBUGV ){
+                                rtOpts->debug_level = LOG_DEBUGV;
+#else
+                        printf("Runtime debug not enabled. Please compile with RUNTIME_DEBUG\n");
+#endif
+			break;
+		/* print version string */
+		case 'v':
+			printf(PTPD_PROGNAME" version "USER_VERSION
+#ifdef CODE_REVISION
+			CODE_REVISION
+			" built on "BUILD_DATE
+#endif
+			"\n");
+			return FALSE;
+		/* run in foreground */
+		case 'C':
+			rtOpts->nonDaemon=1;
+			dictionary_set(dict,"global:foreground", "Y");
+			break;
+		/* verbose mode */
+		case 'V':
+			dictionary_set(dict,"global:verbose_foreground", "Y");
+			break;
+		/* Skip locking */
+		case 'L':
+			dictionary_set(dict,"global:ignore_lock", "Y");
+			break;
+		/* End to end delay detection mode */
+		case 'E':
+			dictionary_set(dict,"ptpengine:delay_mechanism", "E2E");
+			break;
+		/* Peer to peer delay detection mode */
+		case 'P':
+			dictionary_set(dict,"ptpengine:delay_mechanism", "P2P");
+			break;
+		/* Auto-lock */
+		case 'A':
+			dictionary_set(dict,"global:auto_lock", "Y");
+			break;
+		/* Print lock file only */
+		case 'p':
+			rtOpts->printLockFile = TRUE;
+			break;
+		/* Lock file */
+		case 'l':
+			dictionary_set(dict,"global:lock_file", optarg);
+			break;
+		/* Lock directory */
+		case 'R':
+			dictionary_set(dict,"global:lock_directory", optarg);
+			break;
+		default:
+			break;
+return TRUE;
+/* Display informatin about the built-in presets */
+void
+printPresetHelp()
+	int i = 0;
+	PtpEnginePreset preset;
+	RunTimeOpts defaultOpts;
+	loadDefaultSettings(&defaultOpts);
+	printf("\n==================AVAILABLE PTP ENGINE PRESETS===============\n\n");
+    for(i = PTP_PRESET_NONE; i < PTP_PRESET_MAX; i++) {
+	preset = getPtpPreset(i, &defaultOpts);
+	printf("        preset name: %s\n", preset.presetName);
+	printf("         slave only: %s\n", preset.slaveOnly ? "TRUE" : "FALSE");
+	printf("allow clock control: %s\n", preset.noAdjust ? "FALSE" : "TRUE");
+	printf("default clock class: %d%s\n", preset.clockClass.defaultValue,
+	    preset.clockClass.minValue == preset.clockClass.maxValue ?
+		    " (only allowed value)" : "");
+	if (preset.clockClass.minValue != preset.clockClass.maxValue) {
+	printf("  clock class range: %d..%d\n",
+		preset.clockClass.minValue,
+		preset.clockClass.maxValue);
+	printf("\n");
+	printf("\n=============================================================\n");
+/* print "short" help - standard parameters only */
+void
+printShortHelp()
+	printf(
+			USER_DESCRIPTION" "USER_VERSION"\n"
+			"\n"
+			"usage: "PTPD_PROGNAME" <options> < --section:key=value...>\n"
+			"\n"
+			"WARNING: Any command-line options take priority over options from config file!\n"
+#ifndef HAVE_GETOPT_LONG
+			"WARNING: *** long options below (--some-option) are not supported on this system! \n"
+			"NOTE:    *** config file style options (--section:key=value) are still supported\n"
+#endif
+			"\n"
+			"Basic options: \n"
+			"\n"
+			"-c --config-file [path] 	Configuration file\n"
+			"-k --check-config		Check configuration and exit\n"
+			"-v --version			Print version string\n"
+			"-h --help			Show this help screen\n"
+			"-H --long-help			Show detailed help for all settings and behaviours\n"
+			"-e --explain [section:key]	Show help for a single setting\n"
+			"-O --default-config		Output default configuration (usable as config file)\n"
+			"-L --ignore-lock		Skip lock file checks and locking\n"
+			"-A --auto-lock			Use preset / port mode specific lock files\n"
+			"-l --lockfile [path]		Specify path to lock file\n"
+			"-p --print-lockfile		Print path to lock file and exit (useful for init scripts)\n"
+			"-R --lock-directory [path]	Directory to store lock files\n"
+			"-f --log-file [path]		global:log_file=[path]		Log file\n"
+			"-S --statistics-file [path]	global:statistics_file=[path]	Statistics file\n"
+			"-T --show-templates		display available configuration templates\n"
+			"-t --templates [name],[name],[...]\n"
+			"                               apply configuration template(s) - see man(5) ptpd2.conf\n"
+			"\n"
+			"Basic PTP protocol and daemon configuration options: \n"
+			"\n"
+			"Command-line option		Config key(s)			Description\n"
+			"------------------------------------------------------------------------------------\n"
+			"-i --interface [dev]		ptpengine:interface=<dev>	Interface to use (required)\n"
+			"-d --domain [n] 		ptpengine:domain=<n>		PTP domain number\n"
+			"-s --slaveonly	 	 	ptpengine:preset=slaveonly	Slave only mode\n"
+			"-m --masterslave 		ptpengine:preset=masterslave	Master, slave when not best GM\n"
+			"-M --masteronly 		ptpengine:preset=masteronly	Master, passive when not best GM\n"
+			"-y --hybrid			ptpengine:ip_mode=hybrid	Hybrid mode (multicast for sync\n"
+			"								and announce, unicast for delay\n"
+			"								request and response)\n"
+			"-U --unicast			ptpengine:ip_mode=unicast	Unicast mode\n"
+			"-g --unicast-negotiation	ptpengine:unicast_negotiation=y Enable unicast negotiation (signaling)\n"
+			"-u --unicast-destinations 	ptpengine:ip_mode=unicast	Unicast destination list\n"
+			"     [ip/host, ...]		ptpengine:unicast_destinations=<ip/host, ...>\n\n"
+			"-E --e2e			ptpengine:delay_mechanism=E2E	End to end delay detection\n"
+			"-P --p2p			ptpengine:delay_mechanism=P2P	Peer to peer delay detection\n"
+			"\n"
+			"-a --delay-override 		ptpengine:log_delayreq_override Override delay request interval\n"
+			"                                                               announced by master\n"
+			"-r --delay-interval [n] 	ptpengine:log_delayreq_interval=<n>	Delay request interval\n"
+			"									(log 2)\n"
+			"\n"
+			"-n --noadjust			clock:no_adjust			Do not adjust the clock\n"
+			"-D<DD...> --debug		global:debug_level=<level>	Debug level\n"
+			"-C --foreground			global:foreground=<Y/N>		Don't run in background\n"
+			"-V --verbose			global:verbose_foreground=<Y/N>	Run in foreground, log all\n"
+			"								messages to standard output\n"
+			"\n"
+			"\n"
+			PTPD_PROGNAME" accepts a configuration file (.ini style) where settings are either\n"
+			"grouped into sections:\n\n"
+			"[section]\n"
+			"; comment\n"
+			"key = value\n\n"
+			"or are specified as:\n\n"
+			"section:key = value\n\n"
+			"All settings can also be supplied as command-line parameters (after other options):\n"
+			"\n"
+			"--section:key=<value> --section:key <value> -section:key=<value> -section:key <value>\n"
+			"\n"
+			"To see the full help for all configurable options, run: "PTPD_PROGNAME" with -H or --long-help\n"
+			"To see help for a single setting only, run: "PTPD_PROGNAME" with -e (--explain) [section:key]\n"
+			"To see all default settings with descriptions, run: "PTPD_PROGNAME" with -O (--default-config)\n"
+			"\n"
+			"\n"
+			USER_DESCRIPTION" compatibility options for migration from versions below 2.3.0:\n"
+			"\n"
+			"-b [dev]			Network interface to use\n"
+			"-i [n]				PTP domain number\n"
+			"-G				'Master mode with NTP' (ptpengine:preset=masteronly)\n"
+			"-W				'Master mode without NTP' (ptpengine:preset=masterslave) \n"
+			"-Y [n]				Delay request interval (log 2)\n"
+			"-t 				Do not adjust the clock\n"
+			"\n"
+			"Note 1: the above parameters are deprecated and their use will issue a warning.\n"
+			"Note 2: -U and -g options have been re-purposed in 2.3.1.\n"
+			"\n\n"
+/* Print the full help */
+void
+printLongHelp()
+	printShortHelp();
+	printConfigHelp();
+	printPresetHelp();
+	printf("\n"
+		"                  Configuration templates available (see man(5) ptpd2.conf):\n"
+		"\n usage:\n"
+		"                         -t [name],[name],...\n"
+		"                --templates [name],[name],...\n"
+		"  --global:config_templates=[name],[name],...\n\n");
+	printf("========================\n");
+	printf("\n"
+		"Possible internal states:\n"
+		"  init:        INITIALIZING\n"
+		"  flt:         FAULTY\n"
+		"  lstn_init:   LISTENING (first time)\n"
+		"  lstn_reset:  LISTENING (non first time)\n"
+		"  pass:        PASSIVE Master (not best in BMC, not announcing)\n"
+		"  uncl:        UNCALIBRATED\n"
+		"  slv:         SLAVE\n"
+		"  pmst:        PRE Master\n"
+		"  mst:         ACTIVE Master\n"
+		"  dsbl:        DISABLED\n"
+		"  ?:           UNKNOWN state\n"
+		"\n"
+		"Handled signals:\n"
+		"  SIGHUP         Reload configuration file and close / re-open log files\n"
+		"  SIGUSR1        Manually step clock to current OFM value\n"
+		"                 (overides clock:no_reset, but honors clock:no_adjust)\n"
+		"  SIGUSR2	  Dump all PTP protocol counters to current log target\n"
+		"                 (and clear if ptpengine:sigusr2_clears_counters set)\n"
+		"\n"
+		"  SIGINT|SIGTERM Close open files, remove lock file and exit cleanly\n"
+		"  SIGKILL        Force an unclean exit\n"
+				"\n"
+		"BMC Algorithm defaults:\n"
+		"  Software:   P1(128) > Class(13|248) > Accuracy(\"unk\"/0xFE)   > Variance(65536) > P2(128)\n"
+ * Iterate through every key in newConfig and compare to oldConfig,
+ * return TRUE if both equal, otherwise FALSE;
+Boolean
+compareConfig(dictionary* newConfig, dictionary* oldConfig)
+    int i = 0;
+    if( newConfig == NULL || oldConfig == NULL) return -1;
+    for(i = 0; i < newConfig->n; i++) {
+        if(newConfig->key[i] == NULL)
+            continue;
+	if(strcmp(newConfig->val[i], dictionary_get(oldConfig, newConfig->key[i],"")) != 0 ) {
+		DBG("Setting %s changed from '%s' to '%s'\n", newConfig->key[i],dictionary_get(oldConfig, newConfig->key[i],""),
+		    newConfig->val[i]);
+		return FALSE;
+return TRUE;
+/* Compare two configurations and set flags to mark components requiring restart */
+int checkSubsystemRestart(dictionary* newConfig, dictionary* oldConfig, RunTimeOpts *rtOpts)
+	int restartFlags = 0;
+	dictionary *tmpDict = dictionary_new(0);
+	char *a, *b, *key;
+	int i;
+	/* both should be post-parse so will have all settings and thus same number of keys */
+	    key = newConfig->key[i];
+	    if(key == NULL) {
+		continue;
+	    a = dictionary_get(oldConfig, key, "");
+	    b = dictionary_get(newConfig, key, "");
+	    if(strcmp(a,b)) {
+		DBG("+ setting %s changed from %s to %s\n", key, a, b);
+		dictionary_set(tmpDict, key, "x");
+	/* run parser in restart check mode */
+	parseConfig(CFGOP_RESTART_FLAGS | CFGOP_PARSE_QUIET, &restartFlags, tmpDict, rtOpts);
+	dictionary_del(&tmpDict);
+	/* ========= Any additional logic goes here =========== */
+	/* Set of possible PTP port states has changed */
+	if(configSettingChanged(oldConfig, newConfig, "ptpengine:slave_only") ||
+		configSettingChanged(oldConfig, newConfig, "ptpengine:clock_class")) {
+		int clockClass_old = iniparser_getint(oldConfig,"ptpengine:ptp_clockclass",0);
+		int clockClass_new = iniparser_getint(newConfig,"ptpengine:ptp_clockclass",0);
+		 * We're changing from a mode where slave state is possible
+		 * to a master only mode, or vice versa
+		if ((clockClass_old < 128 && clockClass_new > 127) ||
+		(clockClass_old > 127 && clockClass_new < 128)) {
+			/* If we are in auto lockfile mode, trigger a check if other locks match */
+			if( !configSettingChanged(oldConfig, newConfig, "global:auto_lockfile") &&
+			    DICT_ISTRUE(oldConfig, "global:auto_lockfile")) {
+				restartFlags|=PTPD_CHECK_LOCKS;
+			/* We can potentially be running in a different mode now, restart protocol */
+			restartFlags|=PTPD_RESTART_PROTOCOL;
+	/* Flag for config options that can be applied on the fly - only to trigger a log message */
+	if(restartFlags == 0)
+	    restartFlags = PTPD_RESTART_NONE;
+	return restartFlags;
diff --git a/freebsd/contrib/ptpd/src/dep/daemonconfig.h b/freebsd/contrib/ptpd/src/dep/daemonconfig.h
new file mode 100644
index 00000000..9ae2e66a
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/daemonconfig.h
@@ -0,0 +1,89 @@
+ * @file   daemonconfig.h
+ * @brief  definitions related to config file handling.
+#ifndef PTPD_DAEMONCONFIG_H_
+#define PTPD_DAEMONCONFIG_H_
+#include "iniparser/iniparser.h"
+#include "configdefaults.h"
+/* Config reload - component restart status flags */
+/* No restart required - can continue with new config */
+#define PTPD_RESTART_NONE	1 << 0
+/* PTP port datasetw can be updated without restarting FSM */
+#define PTPD_UPDATE_DATASETS	1 << 1
+/* PTP FSM port re-initialisation required (PTP_INITIALIZING) */
+#define PTPD_RESTART_PROTOCOL	1 << 2
+/* Network config changed: PTP_INITIALIZING handles this so far */
+#define PTPD_RESTART_NETWORK	1 << 3
+/* Logging config changes: log files need closed / reopened */
+#define PTPD_RESTART_LOGGING	1 << 4
+/* Configuration changes need checking lock files */
+#define PTPD_CHECK_LOCKS	1 << 5
+/* CPU core has changed */
+#define PTPD_CHANGE_CPUAFFINITY 1 << 6
+/* Configuration changes require daemon restart */
+#define PTPD_RESTART_DAEMON	1 << 7
+#ifdef PTPD_STATISTICS
+/* Configuration changes require filter restart */
+#define PTPD_RESTART_FILTERS	1 << 8
+#endif
+#define PTPD_RESTART_ACLS	1 << 9
+#define PTPD_RESTART_NTPENGINE	1 << 10
+#define PTPD_RESTART_NTPCONFIG	1 << 11
+#define PTPD_RESTART_ALARMS	1 << 12
+#define LOG2_HELP "(expressed as log 2 i.e. -1=0.5s, 0=1s, 1=2s etc.)"
+#define MAX_LINE_SIZE 1024
+/* int/double range check flags */
+enum {
+    RANGECHECK_NONE,
+    RANGECHECK_RANGE,
+    RANGECHECK_MIN,
+    RANGECHECK_MAX
+/* int type to cast parsed config data to */
+enum {
+    INTTYPE_INT,
+    INTTYPE_I8,
+    INTTYPE_U8,
+    INTTYPE_I16,
+    INTTYPE_U16,
+    INTTYPE_I32,
+    INTTYPE_U32
+/* config parser operations */
+#define    CFGOP_PARSE 		1<<0	/* parse all config options, return success/failure */
+#define    CFGOP_PARSE_QUIET	1<<1	/* parse config but display no warnings */
+#define    CFGOP_PRINT_DEFAULT	1<<2	/* print default settings only */
+#define    CFGOP_HELP_FULL	1<<3	/* print help for all settings */
+#define    CFGOP_HELP_SINGLE	1<<4	/* print help for one entry */
+#define    CFGOP_RESTART_FLAGS	1<<5	/* return subsystems affected by config changes */
+Boolean loadConfigFile (dictionary**, RunTimeOpts*);
+void loadCommandLineKeys(dictionary*, int, char**);
+Boolean loadCommandLineOptions(RunTimeOpts*, dictionary*, int, char** , Integer16*);
+dictionary* parseConfig (int, void*, dictionary*, RunTimeOpts*);
+int reloadConfig ( RunTimeOpts*, PtpClock* );
+Boolean compareConfig(dictionary* source, dictionary* target);
+int checkSubsystemRestart(dictionary* newConfig, dictionary* oldConfig, RunTimeOpts *rtOpts);
+void printConfigHelp();
+void printDefaultConfig();
+void printShortHelp();
+void printLongHelp();
+void printSettingHelp(char*);
+void setConfig(dictionary *dict, const char* key, const char *value);
+#endif /*PTPD_DAEMONCONFIG_H_*/
diff --git a/freebsd/contrib/ptpd/src/dep/datatypes_dep.h b/freebsd/contrib/ptpd/src/dep/datatypes_dep.h
index 00000000..77a645c4
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/datatypes_dep.h
@@ -0,0 +1,179 @@
+#ifndef DATATYPES_DEP_H_
+#define DATATYPES_DEP_H_
+#include "../ptp_primitives.h"
+*\file
+* \brief Implementation specific datatype
+* \brief Struct used to average the offset from master
+* The FIR filtering of the offset from master input is a simple, two-sample average
+typedef struct {
+    Integer32  nsec_prev, y;
+} offset_from_master_filter;
+* \brief Struct used to average the one way delay
+* It is a variable cutoff/delay low-pass, infinite impulse response (IIR) filter.
+*  The one-way delay filter has the difference equation: s*y[n] - (s-1)*y[n-1] = x[n]/2 + x[n-1]/2, where increasing the stiffness (s) lowers the cutoff and increases the delay.
+typedef struct {
+    Integer32  s_exp;
+} one_way_delay_filter;
+* \brief Struct containing interface information and capabilities
+typedef struct {
+        struct sockaddr afAddress;
+        unsigned char hwAddress[14];
+        Boolean hasHwAddress;
+        Boolean hasAfAddress;
+        int addressFamily;
+        unsigned int flags;
+	int ifIndex;
+} InterfaceInfo;
+* \brief Struct describing network transport data
+typedef struct {
+	Integer32 eventSock, generalSock;
+	Integer32 multicastAddr, peerMulticastAddr;
+	/* Interface address and capability descriptor */
+	InterfaceInfo interfaceInfo;
+	/* used by IGMP refresh */
+	struct in_addr interfaceAddr;
+	/* Typically MAC address - outer 6 octers of ClockIdendity */
+	Octet interfaceID[ETHER_ADDR_LEN];
+	/* source address of last received packet - used for unicast replies to Delay Requests */
+	Integer32 lastSourceAddr;
+	/* destination address of last received packet - used for unicast FollowUp for multiple slaves*/
+	Integer32 lastDestAddr;
+	uint64_t sentPackets;
+	uint64_t receivedPackets;
+	uint64_t sentPacketsTotal;
+	uint64_t receivedPacketsTotal;
+#ifdef PTPD_PCAP
+	pcap_t *pcapEvent;
+	pcap_t *pcapGeneral;
+	Integer32 pcapEventSock;
+	Integer32 pcapGeneralSock;
+#endif
+	Integer32 headerOffset;
+	/* used for tracking the last TTL set */
+	int ttlGeneral;
+	int ttlEvent;
+	Boolean joinedPeer;
+	Boolean joinedGeneral;
+	struct ether_addr etherDest;
+	struct ether_addr peerEtherDest;
+	Boolean txTimestampFailure;
+	Ipv4AccessList* timingAcl;
+	Ipv4AccessList* managementAcl;
+} NetPath;
+typedef struct {
+	char* logID;
+	char* openMode;
+	char logPath[PATH_MAX+1];
+	FILE* logFP;
+	Boolean logEnabled;
+	Boolean truncateOnReopen;
+	Boolean unlinkOnClose;
+	uint32_t lastHash;
+	UInteger32 maxSize;
+	UInteger32 fileSize;
+	int maxFiles;
+} LogFileHandler;
+typedef struct{
+    UInteger8 minValue;
+    UInteger8 maxValue;
+    UInteger8 defaultValue;
+} UInteger8_option;
+typedef struct{
+    Integer32  minValue;
+    Integer32  maxValue;
+    Integer32  defaultValue;
+} Integer32_option;
+typedef struct{
+    UInteger32  minValue;
+    UInteger32  maxValue;
+    UInteger32  defaultValue;
+} UInteger32_option;
+typedef struct{
+    Integer16  minValue;
+    Integer16  maxValue;
+    Integer16  defaultValue;
+} Integer16_option;
+typedef struct{
+    UInteger16  minValue;
+    UInteger16  maxValue;
+    UInteger16  defaultValue;
+} UInteger16_option;
+typedef union { uint32_t *uintval; int32_t *intval; double *doubleval; Boolean *boolval; char *strval; } ConfigPointer;
+typedef union { uint32_t uintval; int32_t intval; double doubleval; Boolean boolval; char *strval; } ConfigSetting;
+typedef struct ConfigOption ConfigOption;
+struct ConfigOption {
+    char *key;
+    enum { CO_STRING, CO_INT, CO_UINT, CO_DOUBLE, CO_BOOL, CO_SELECT } type;
+    enum { CO_MIN, CO_MAX, CO_RANGE, CO_STRLEN } restriction;
+    ConfigPointer target;
+    ConfigPointer defvalue;
+    ConfigSetting constraint1;
+    ConfigSetting constraint2;
+    int restartFlags;
+    ConfigOption *next;
+typedef struct {
+    int currentOffset;
+    int nextOffset;
+    int leapType;
+    Integer32 startTime;
+    Integer32 endTime;
+    Boolean valid;
+    Boolean offsetValid;
+} LeapSecondInfo;
+#endif /*DATATYPES_DEP_H_*/
diff --git a/freebsd/contrib/ptpd/src/dep/eventtimer.c b/freebsd/contrib/ptpd/src/dep/eventtimer.c
index 00000000..de98338f
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/eventtimer.c
@@ -0,0 +1,133 @@
+ * Copyright (c) 2015      Wojciech Owczarek,
+ * All Rights Reserved
+ * modification, are permitted provided that the following conditions are
+ * met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ *    this list of conditions and the following disclaimer.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE AUTHORS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
+ * BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
+ * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
+ * IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * @file   timer.c
+ * @date   Wed Oct 1 00:41:26 2014
+ * @brief  Common code for the EventTimer object
+ * Creation and deletion plus maintaining a linked list of
+ * all created instances.
+#include "../ptpd.h"
+/* linked list - so that we can control all registered objects centrally */
+static EventTimer *_first = NULL;
+static EventTimer *_last = NULL;
+EventTimer
+*createEventTimer(const char* id)
+	EventTimer *timer;
+        if ( !(timer = calloc (1, sizeof(EventTimer))) ) {
+            return NULL;
+	setupEventTimer(timer);
+        strncpy(timer->id, id, EVENTTIMER_MAX_DESC);
+	/* maintain the linked list */
+	if(_first == NULL) {
+		_first = timer;
+	if(_last != NULL) {
+	    timer->_prev = _last;
+	    timer->_prev->_next = timer;
+	_last = timer;
+	timer->_first = _first;
+	DBGV("created itimer eventtimer %s\n", timer->id);
+        return timer;
+void
+freeEventTimer
+(EventTimer **timer)
+	if(timer == NULL) {
+	    return;
+	EventTimer *ptimer = *timer;
+	if(ptimer == NULL) {
+	    return;
+	ptimer->shutdown(ptimer);
+	if(ptimer->_prev != NULL) {
+		if(ptimer == _last) {
+			_last = ptimer->_prev;
+		if(ptimer->_next != NULL) {
+			ptimer->_prev->_next = ptimer->_next;
+		} else {
+			ptimer->_prev->_next = NULL;
+	/* last one */
+	} else if (ptimer->_next == NULL) {
+		_first = NULL;
+		if(ptimer == _first) {
+			_first = ptimer->_next;
+			ptimer->_next->_prev = ptimer->_prev;
+		} else {
+			ptimer->_next->_prev = NULL;
+	if(*timer != NULL) {
+	    free(*timer);
+	*timer = NULL;
diff --git a/freebsd/contrib/ptpd/src/dep/eventtimer.h b/freebsd/contrib/ptpd/src/dep/eventtimer.h
index 00000000..9d41156d
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/eventtimer.h
@@ -0,0 +1,77 @@
+#ifndef EVENTTIMER_H_
+#define EVENTTIMER_H_
+ * met:
+#define EVENTTIMER_MAX_DESC		20
+#define EVENTTIMER_MIN_INTERVAL_US	250 /* 4000/sec */
+typedef struct EventTimer EventTimer;
+struct EventTimer {
+	/* data */
+	char id[EVENTTIMER_MAX_DESC + 1];
+	Boolean expired;
+	Boolean running;
+	/* "methods" */
+	void (*start) (EventTimer* timer, double interval);
+	void (*stop) (EventTimer* timer);
+	void (*reset) (EventTimer* timer);
+	void (*shutdown) (EventTimer* timer);
+	Boolean (*isExpired) (EventTimer* timer);
+	Boolean (*isRunning) (EventTimer* timer);
+	/* implementation data */
+#ifdef PTPD_PTIMERS
+	timer_t timerId;
+#else
+	int32_t itimerInterval;
+	int32_t itimerLeft;
+#endif /* PTPD_PTIMERS */
+	/* linked list */
+	EventTimer *_first;
+	EventTimer *_next;
+	EventTimer *_prev;
+EventTimer *createEventTimer(const char *id);
+void freeEventTimer(EventTimer **timer);
+void setupEventTimer(EventTimer *timer);
+void startEventTimers();
+void shutdownEventTimers();
+#endif /* EVENTTIMER_H_ */
diff --git a/freebsd/contrib/ptpd/src/dep/eventtimer_itimer.c b/freebsd/contrib/ptpd/src/dep/eventtimer_itimer.c
index 00000000..2fa0c3ac
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/eventtimer_itimer.c
@@ -0,0 +1,239 @@
+ * Copyright (c) 2012-2015 Wojciech Owczarek,
+ * Copyright (c) 2011-2012 George V. Neville-Neil,
+ *                         Steven Kreuzer,
+ *                         Martin Burnicki,
+ *                         Jan Breuer,
+ *                         Gael Mace,
+ *                         Alexandre Van Kempen,
+ *                         Inaqui Delgado,
+ *                         Rick Ratzel,
+ *                         National Instruments.
+ * Copyright (c) 2009-2010 George V. Neville-Neil,
+ *                         Steven Kreuzer,
+ *                         Jan Breuer,
+ *                         Gael Mace,
+ * Copyright (c) 2005-2008 Kendall Correll, Aidan Williams
+ * met:
+ * @file   eventtimer_itimer.c
+ * @brief  EventTimer implementation using interval timers
+ * The original interval timer timer implementation.
+#define US_TIMER_INTERVAL (31250)
+static volatile unsigned int elapsed;
+static void eventTimerStart_itimer(EventTimer *timer, double interval);
+static void eventTimerStop_itimer(EventTimer *timer);
+static void eventTimerReset_itimer(EventTimer *timer);
+static void eventTimerShutdown_itimer(EventTimer *timer);
+static Boolean eventTimerIsRunning_itimer(EventTimer *timer);
+static Boolean eventTimerIsExpired_itimer(EventTimer *timer);
+static void itimerUpdate(EventTimer *et);
+static void timerSignalHandler(int sig);
+void
+setupEventTimer(EventTimer *timer)
+	    return;
+	memset(timer, 0, sizeof(EventTimer));
+	timer->start = eventTimerStart_itimer;
+	timer->stop = eventTimerStop_itimer;
+	timer->reset = eventTimerReset_itimer;
+	timer->shutdown = eventTimerShutdown_itimer;
+	timer->isExpired = eventTimerIsExpired_itimer;
+	timer->isRunning = eventTimerIsRunning_itimer;
+static void
+eventTimerStart_itimer(EventTimer *timer, double interval)
+	timer->expired = FALSE;
+	timer->running = TRUE;
+	 *  US_TIMER_INTERVAL defines the minimum interval between sigalarms.
+	 *  timerStart has a float parameter for the interval, which is casted to integer.
+	 *  very small amounts are forced to expire ASAP by setting the interval to 1
+	timer->itimerLeft = (interval * 1E6) / US_TIMER_INTERVAL;
+	if(timer->itimerLeft == 0){
+		 * the interval is too small, raise it to 1 to make sure it expires ASAP
+		timer->itimerLeft = 1;
+	timer->itimerInterval = timer->itimerLeft;
+	DBG2("timerStart:     Set timer %s to %f  New interval: %d; new left: %d\n", timer->id, interval, timer->itimerLeft , timer->itimerInterval);
+static void
+eventTimerStop_itimer(EventTimer *timer)
+	timer->itimerInterval = 0;
+	timer->running = FALSE;
+	DBG2("timerStop:      Stopping timer %s\n", timer->id);
+static void
+itimerUpdate(EventTimer *et)
+	EventTimer *timer = NULL;
+	if (elapsed <= 0)
+		return;
+	 * if time actually passed, then decrease every timer left
+	 * the one(s) that went to zero or negative are:
+	 *  a) rearmed at the original time (ignoring the time that may have passed ahead)
+	 *  b) have their expiration latched until timerExpired() is called
+	for(timer = et->_first; timer != NULL; timer = timer->_next) {
+	    if ( (timer->itimerInterval > 0) && ((timer->itimerLeft -= elapsed) <= 0)) {
+			timer->itimerLeft = timer->itimerInterval;
+			timer->expired = TRUE;
+		DBG("TimerUpdate:    Timer %s has now expired.  Re-armed with interval %d\n", timer->id, timer->itimerInterval);
+	elapsed = 0;
+static void
+eventTimerReset_itimer(EventTimer *timer)
+static void
+eventTimerShutdown_itimer(EventTimer *timer)
+static Boolean
+eventTimerIsRunning_itimer(EventTimer *timer)
+	itimerUpdate(timer);
+	DBG2("timerIsRunning:   Timer %s %s running\n", timer->id,
+		timer->running ? "is" : "is not");
+	return timer->running;
+static Boolean
+eventTimerIsExpired_itimer(EventTimer *timer)
+	Boolean ret;
+	ret = timer->expired;
+	DBG2("timerIsExpired:   Timer %s %s expired\n", timer->id,
+		timer->expired ? "is" : "is not");
+	if(ret) {
+	return ret;
+void
+startEventTimers(void)
+	struct itimerval itimer;
+	DBG("initTimer\n");
+#ifdef __sun
+	sigset(SIGALRM, SIG_IGN);
+#else
+	signal(SIGALRM, SIG_IGN);
+#endif /* __sun */
+	elapsed = 0;
+	itimer.it_value.tv_sec = itimer.it_interval.tv_sec = 0;
+	itimer.it_value.tv_usec = itimer.it_interval.tv_usec =
+	    US_TIMER_INTERVAL;
+#ifdef __sun
+	sigset(SIGALRM, timerSignalHandler);
+#else
+	signal(SIGALRM, timerSignalHandler);
+#endif /* __sun */
+	setitimer(ITIMER_REAL, &itimer, 0);
+void
+shutdownEventTimers(void)
+#ifdef __sun
+#else
+#endif /* __sun */
+static void
+timerSignalHandler(int sig)
+	elapsed++;
+	/* be sure to NOT call DBG in asynchronous handlers! */
diff --git a/freebsd/contrib/ptpd/src/dep/eventtimer_posix.c b/freebsd/contrib/ptpd/src/dep/eventtimer_posix.c
index 00000000..16164fd7
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/eventtimer_posix.c
@@ -0,0 +1,239 @@
+ * met:
+ * @file   eventtimer_posix.c
+ * @brief  EventTimer implementation using POSIX timers
+ * The less signal intensive timer implementation,
+ * allowing for high(er) message intervals.
+#define TIMER_SIGNAL SIGALRM
+/* timers should be based on CLOCK_MONOTONIC,
+ *   but if it's not implemented, use CLOCK_REALTIME
+#ifdef _POSIX_MONOTONIC_CLOCK
+#define CLK_TYPE CLOCK_MONOTONIC
+#else
+#define CLK_TYPE CLOCK_REALTIME
+#endif /* CLOCK_MONOTONIC */
+static void eventTimerStart_posix(EventTimer *timer, double interval);
+static void eventTimerStop_posix(EventTimer *timer);
+static void eventTimerReset_posix(EventTimer *timer);
+static void eventTimerShutdown_posix(EventTimer *timer);
+static Boolean eventTimerIsRunning_posix(EventTimer *timer);
+static Boolean eventTimerIsExpired_posix(EventTimer *timer);
+static void timerSignalHandler(int sig, siginfo_t *info, void *usercontext);
+void
+	struct sigevent sev;
+	    return;
+	memset(&sev, 0, sizeof(sev));
+	timer->start = eventTimerStart_posix;
+	timer->stop = eventTimerStop_posix;
+	timer->reset = eventTimerReset_posix;
+	timer->shutdown = eventTimerShutdown_posix;
+	timer->isExpired = eventTimerIsExpired_posix;
+	timer->isRunning = eventTimerIsRunning_posix;
+	sev.sigev_notify = SIGEV_SIGNAL;
+	sev.sigev_signo = TIMER_SIGNAL;
+	sev.sigev_value.sival_ptr = timer;
+	if(timer_create(CLK_TYPE, &sev, &timer->timerId) == -1) {
+	    PERROR("Could not create posix timer %s", timer->id);
+	} else {
+	    DBGV("Created posix timer %s ",timer->id);
+static void
+eventTimerStart_posix(EventTimer *timer, double interval)
+	struct timespec ts;
+	struct itimerspec its;
+	memset(&its, 0, sizeof(its));
+	ts.tv_sec = interval;
+	ts.tv_nsec = (interval - ts.tv_sec) * 1E9;
+	if(!ts.tv_sec && ts.tv_nsec < EVENTTIMER_MIN_INTERVAL_US * 1000) {
+	    ts.tv_nsec = EVENTTIMER_MIN_INTERVAL_US * 1000;
+	DBGV("Timer %s start requested at %d.%4d sec interval\n", timer->id, ts.tv_sec, ts.tv_nsec);
+	its.it_interval = ts;
+	its.it_value = ts;
+	if (timer_settime(timer->timerId, 0, &its, NULL) < 0) {
+		PERROR("could not arm posix timer %s", timer->id);
+		return;
+	DBG2("timerStart:     Set timer %s to %f\n", timer->id, interval);
+static void
+eventTimerStop_posix(EventTimer *timer)
+	DBGV("Timer %s stop requested\n", timer->id);
+		PERROR("could not stop posix timer %s", timer->id);
+		return;
+	DBG2("timerStop: stopped timer %s\n", timer->id);
+static void
+eventTimerReset_posix(EventTimer *timer)
+static void
+eventTimerShutdown_posix(EventTimer *timer)
+	if(timer_delete(timer->timerId) == -1) {
+	    PERROR("Could not delete timer %s!", timer->id);
+static Boolean
+eventTimerIsRunning_posix(EventTimer *timer)
+static Boolean
+eventTimerIsExpired_posix(EventTimer *timer)
+	Boolean ret;
+	/* the five monkeys experiment */
+	if(ret) {
+	return ret;
+void
+	struct sigaction sa;
+#ifdef __sun
+#else
+#endif /* __sun */
+	sa.sa_flags = SA_SIGINFO;
+	sa.sa_sigaction = timerSignalHandler;
+	sigemptyset(&sa.sa_mask);
+	if(sigaction(TIMER_SIGNAL, &sa, NULL) == -1) {
+	    PERROR("Could not initialise timer handler");
+void
+#ifdef __sun
+#else
+#endif /* __sun */
+/* this only ever gets called when a timer expires */
+static void
+timerSignalHandler(int sig, siginfo_t *info, void *usercontext)
+	/* retrieve the user data structure */
+	EventTimer * timer = (EventTimer*)info->si_value.sival_ptr;
+	/* Ignore if the signal wasn't sent by a timer */
+	if(info->si_code != SI_TIMER)
+		return;
+	/* Hopkirk (deceased) */
+	if(timer != NULL) {
diff --git a/freebsd/contrib/ptpd/src/dep/iniparser/AUTHORS b/freebsd/contrib/ptpd/src/dep/iniparser/AUTHORS
index 00000000..f847f923
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/iniparser/AUTHORS
@@ -0,0 +1,7 @@
+Author: Nicolas Devillard <ndevilla at free.fr>
+This tiny library has received countless contributions and I have
+not kept track of all the people who contributed. Let them be thanked
+for their ideas, code, suggestions, corrections, enhancements!
+Further enhancements by Wojciech Owczarek for the PTPd project
diff --git a/freebsd/contrib/ptpd/src/dep/iniparser/LICENSE b/freebsd/contrib/ptpd/src/dep/iniparser/LICENSE
index 00000000..5a3a80ba
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/iniparser/LICENSE
@@ -0,0 +1,21 @@
+Copyright (c) 2000-2011 by Nicolas Devillard.
+MIT License
+Permission is hereby granted, free of charge, to any person obtaining a
+copy of this software and associated documentation files (the "Software"),
+to deal in the Software without restriction, including without limitation
+the rights to use, copy, modify, merge, publish, distribute, sublicense,
+and/or sell copies of the Software, and to permit persons to whom the
+Software is furnished to do so, subject to the following conditions:
+The above copyright notice and this permission notice shall be included in
+all copies or substantial portions of the Software.
+THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
+AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+DEALINGS IN THE SOFTWARE.
diff --git a/freebsd/contrib/ptpd/src/dep/iniparser/README b/freebsd/contrib/ptpd/src/dep/iniparser/README
index 00000000..bc697876
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/iniparser/README
@@ -0,0 +1,12 @@
+Welcome to iniParser -- version 3.1
+released 08 Apr 2012
+This modules offers parsing of ini files from the C level.
+See a complete documentation in HTML format, from this directory
+open the file html/index.html with any HTML-capable browser.
+Enjoy!
+N.Devillard
+Sun Apr  8 16:38:09 CEST 2012
diff --git a/freebsd/contrib/ptpd/src/dep/iniparser/dictionary.c b/freebsd/contrib/ptpd/src/dep/iniparser/dictionary.c
index 00000000..ffe35791
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/iniparser/dictionary.c
@@ -0,0 +1,520 @@
+   @file    dictionary.c
+   @author  N. Devillard
+   @brief   Implements a dictionary for string variables.
+   This module implements a simple dictionary object, i.e. a list
+   of string/string associations. This object is useful to store e.g.
+   informations retrieved from a configuration file (ini files).
+                                Includes
+#include "dictionary.h"
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <unistd.h>
+/** Maximum value size for integers and doubles. */
+#define MAXVALSZ    1024
+/** Minimal allocated number of entries in a dictionary */
+#define DICTMINSZ   64
+/** Invalid key token */
+#define DICT_INVALID_KEY    ((char*)-1)
+                            Private functions
+/* Doubles the allocated size associated to a pointer */
+/* 'size' is the current allocated size. */
+static void * mem_double(void * ptr, int size)
+    void * newptr ;
+    newptr = calloc(2*size, 1);
+    if (newptr==NULL) {
+        return NULL ;
+    memcpy(newptr, ptr, size);
+    free(ptr);
+    return newptr ;
+  @brief    Duplicate a string
+  @param    s String to duplicate
+  @return   Pointer to a newly allocated string, to be freed with free()
+  This is a replacement for strdup(). This implementation is provided
+  for systems that do not have it.
+static char * xstrdup(const char * s)
+    char * t ;
+    if (!s)
+        return NULL ;
+    t = (char*)calloc(strlen(s)+1,sizeof(char)) ;
+    if (t) {
+        strncpy(t,s,strlen(s));
+    return t ;
+                            Function codes
+  @brief    Compute the hash key for a string.
+  @param    key     Character string to use for key.
+  @return   1 unsigned int on at least 32 bits.
+  This hash function has been taken from an Article in Dr Dobbs Journal.
+  This is normally a collision-free function, distributing keys evenly.
+  The key is stored anyway in the struct so that collision can be avoided
+  by comparing the key itself in last resort.
+unsigned dictionary_hash(const char * key)
+    int         len ;
+    unsigned    hash ;
+    int         i ;
+    len = strlen(key);
+    for (hash=0, i=0 ; i<len ; i++) {
+        hash += (unsigned)key[i] ;
+        hash += (hash<<10);
+        hash ^= (hash>>6) ;
+    hash += (hash <<3);
+    hash ^= (hash >>11);
+    hash += (hash <<15);
+    return hash ;
+  @brief    Create a new dictionary object.
+  @param    size    Optional initial size of the dictionary.
+  @return   1 newly allocated dictionary objet.
+  This function allocates a new dictionary object of given size and returns
+  it. If you do not know in advance (roughly) the number of entries in the
+  dictionary, give size=0.
+dictionary * dictionary_new(int size)
+    dictionary  *   d ;
+    /* If no size was specified, allocate space for DICTMINSZ */
+    if (size<DICTMINSZ) size=DICTMINSZ ;
+    if (!(d = (dictionary *)calloc(1, sizeof(dictionary)))) {
+        return NULL;
+    d->size = size ;
+    d->val  = (char **)calloc(size, sizeof(char*));
+    d->key  = (char **)calloc(size, sizeof(char*));
+    d->hash = (unsigned int *)calloc(size, sizeof(unsigned));
+    return d ;
+  @brief    Delete a dictionary object
+  @param    d   dictionary object to deallocate.
+  @return   void
+  Deallocate a dictionary object and all memory associated to it.
+void dictionary_del(dictionary ** d)
+    int     i ;
+    if (*d==NULL) return ;
+    for (i=0 ; i<(*d)->size ; i++) {
+        if ((*d)->key[i]!=NULL)
+            free((*d)->key[i]);
+        if ((*d)->val[i]!=NULL)
+            free((*d)->val[i]);
+    free((*d)->val);
+    free((*d)->key);
+    free((*d)->hash);
+    free(*d);
+    *d = NULL;
+    return ;
+  @brief    Get a value from a dictionary.
+  @param    d       dictionary object to search.
+  @param    key     Key to look for in the dictionary.
+  @param    def     Default value to return if key not found.
+  @return   1 pointer to internally allocated character string.
+  This function locates a key in a dictionary and returns a pointer to its
+  value, or the passed 'def' pointer if no such key can be found in
+  dictionary. The returned character pointer points to data internal to the
+  dictionary object, you should not try to free it or modify it.
+char * dictionary_get(dictionary * d, const char * key, char * def)
+    unsigned    hash ;
+    int         i ;
+    hash = dictionary_hash(key);
+    for (i=0 ; i<d->size ; i++) {
+        if (d->key[i]==NULL)
+            continue ;
+        /* Compare hash */
+        if (hash==d->hash[i]) {
+            /* Compare string, to avoid hash collisions */
+            if (!strcmp(key, d->key[i])) {
+                return d->val[i] ;
+    return def ;
+  @brief    Set a value in a dictionary.
+  @param    d       dictionary object to modify.
+  @param    key     Key to modify or add.
+  @param    val     Value to add.
+  @return   int     0 if Ok, anything else otherwise
+  If the given key is found in the dictionary, the associated value is
+  replaced by the provided one. If the key cannot be found in the
+  dictionary, it is added to it.
+  It is Ok to provide a NULL value for val, but NULL values for the dictionary
+  or the key are considered as errors: the function will return immediately
+  in such a case.
+  Notice that if you dictionary_set a variable to NULL, a call to
+  dictionary_get will return a NULL value: the variable will be found, and
+  its value (NULL) is returned. In other words, setting the variable
+  content to NULL is equivalent to deleting the variable from the
+  dictionary. It is not possible (in this implementation) to have a key in
+  the dictionary without value.
+  This function returns non-zero in case of failure.
+int dictionary_set(dictionary * d, const char * key, const char * val)
+    int         i ;
+    unsigned    hash ;
+    if (d==NULL || key==NULL) return -1 ;
+    /* Compute hash for this key */
+    hash = dictionary_hash(key) ;
+    /* Find if value is already in dictionary */
+    if (d->n>0) {
+                continue ;
+            if (hash==d->hash[i]) { /* Same hash value */
+                if (!strcmp(key, d->key[i])) {   /* Same key */
+                    /* Found a value: modify and return */
+                    if (d->val[i]!=NULL)
+                        free(d->val[i]);
+                    d->val[i] = val ? xstrdup(val) : NULL ;
+                    /* Value has been modified: return */
+                    return 0 ;
+    /* Add a new value */
+    /* See if dictionary needs to grow */
+    if (d->n==d->size) {
+        /* Reached maximum size: reallocate dictionary */
+        d->val  = (char **)mem_double(d->val,  d->size * sizeof(char*)) ;
+        d->key  = (char **)mem_double(d->key,  d->size * sizeof(char*)) ;
+        d->hash = (unsigned int *)mem_double(d->hash, d->size * sizeof(unsigned)) ;
+        if ((d->val==NULL) || (d->key==NULL) || (d->hash==NULL)) {
+            /* Cannot grow dictionary */
+            return -1 ;
+        /* Double size */
+        d->size *= 2 ;
+    /* Insert key in the first empty slot. Start at d->n and wrap at
+       d->size. Because d->n < d->size this will necessarily
+       terminate. */
+    for (i=d->n ; d->key[i] ; ) {
+        if(++i == d->size) i = 0;
+    /* Copy key */
+    d->key[i]  = xstrdup(key);
+    d->hash[i] = hash;
+    d->n ++ ;
+    return 0 ;
+  @brief    Delete a key in a dictionary
+  @param    key     Key to remove.
+  @return   void
+  This function deletes a key in a dictionary. Nothing is done if the
+  key cannot be found.
+void dictionary_unset(dictionary * d, const char * key)
+    unsigned    hash ;
+    int         i ;
+    if (key == NULL) {
+        return;
+            continue ;
+                /* Found key */
+                break ;
+    if (i>=d->size)
+        /* Key not found */
+        return ;
+    free(d->key[i]);
+    d->key[i] = NULL ;
+    if (d->val[i]!=NULL) {
+        free(d->val[i]);
+        d->val[i] = NULL ;
+    d->hash[i] = 0 ;
+    d->n -- ;
+    return ;
+  @brief    Replace string in all values of a dictionary
+  @param    search     string to be replaced
+  @param    replace    string to replace with
+  @return   void
+  This function globally replaces all occurrences of one string in the ditcionary
+  with another in key values.
+void dictionary_replace(dictionary * d, const char * search, const char * replace)
+    int bufsize = MAXVALSZ;
+    char out[bufsize+1];
+    char *in = NULL;
+    char *val = NULL;
+    char *found = NULL;
+    int i = 0, j = 0;
+    int maxcount = 0;
+    char *pos = NULL;
+    char *data = NULL;
+    if (search==NULL || replace==NULL ) return;
+    for(i = 0; i < d->n; i++) {
+	memset(out, 0, bufsize+1);
+	/* skip if the key is null or is a section */
+        if(d->key[i] == NULL || strstr(d->key[i],":") == NULL)
+            continue;
+	val = dictionary_get(d, d->key[i], "");
+	data = strdup(val);
+	in = data;
+	found=strstr(in, search);
+	if(found != NULL) {
+	     do {
+		pos=found;
+		for (j=0; j < strlen(search); j++) {
+		    *pos='\0';
+		    pos++;
+		maxcount = bufsize - strlen(out);
+		maxcount = (maxcount < 0) ? 0 : maxcount;
+		strncat(out,in,maxcount);
+		strncat(out,replace,maxcount);
+		in = pos;
+		} while (found != NULL);
+	    if(*pos != 0) {
+		strncat(out,pos,maxcount);
+	dictionary_set(d, d->key[i], out);
+	printf("Replaced token \"%s\" with \"%s\": \"%s\" -> \"%s\"\n",
+		search, replace, val, out);
+	free(data);
+  @brief    Dump a dictionary to an opened file pointer.
+  @param    d   Dictionary to dump
+  @param    f   Opened file pointer.
+  @return   void
+  Dumps a dictionary onto an opened file pointer. Key pairs are printed out
+  as @c [Key]=[Value], one per line. It is Ok to provide stdout or stderr as
+  output file pointers.
+void dictionary_dump(dictionary * d, FILE * out)
+    int     i ;
+    if (d==NULL || out==NULL) return ;
+    if (d->n<1) {
+        fprintf(out, "empty dictionary\n");
+        return ;
+        if (d->key[i]) {
+            fprintf(out, "%20s\t[%s]\n",
+                    d->key[i],
+                    d->val[i] ? d->val[i] : "UNDEF");
+    return ;
+int dictionary_merge(dictionary* source, dictionary* dest, int overwrite, int warn, const char* warnStr)
+    int i = 0;
+    int clobber = 1;
+    if( source == NULL || dest == NULL) return -1;
+    if(warnStr == NULL) warnStr = "";
+    for(i = 0; i < source->n; i++) {
+	clobber = 1;
+        if(source->key[i] == NULL)
+            continue;
+	/* do not overwrite with an empty key */
+	if((source->val[i] == NULL) || (strlen(source->val[i])==0))
+	    continue;
+	/* no need to warn for settings whose value will not change */
+	if((strcmp(dictionary_get(dest,source->key[i],""),"") != 0) &&
+		    (strcmp(dictionary_get(dest,source->key[i],""),source->val[i]) != 0)) {
+		if(overwrite && warn) {
+		    WARNING("Warning: %s=\"%s\" : value \"%s\" takes priority %s\n",
+				source->key[i], dictionary_get(dest,source->key[i],""),
+				source->val[i], warnStr);
+		if(!overwrite) {
+		    clobber = 0;
+        if (clobber) {
+	    if(dictionary_set( dest, source->key[i], source->val[i]) != 0) {
+		return -1;
+    return 0;
+/* Test code */
+#ifdef TESTDIC
+#define NVALS 20000
+int main(int argc, char *argv[])
+    dictionary  *   d ;
+    char    *   val ;
+    int         i ;
+    char        cval[90] ;
+    /* Allocate dictionary */
+    printf("allocating...\n");
+    d = dictionary_new(0);
+    /* Set values in dictionary */
+    printf("setting %d values...\n", NVALS);
+    for (i=0 ; i<NVALS ; i++) {
+        sprintf(cval, "%04d", i);
+        dictionary_set(d, cval, "salut");
+    printf("getting %d values...\n", NVALS);
+        val = dictionary_get(d, cval, DICT_INVALID_KEY);
+        if (val==DICT_INVALID_KEY) {
+            printf("cannot get value for key [%s]\n", cval);
+    printf("unsetting %d values...\n", NVALS);
+        dictionary_unset(d, cval);
+    if (d->n != 0) {
+        printf("error deleting values\n");
+    printf("deallocating...\n");
+    dictionary_del(&d);
+    return 0 ;
+#endif
+/* vim: set ts=4 et sw=4 tw=75 */
diff --git a/freebsd/contrib/ptpd/src/dep/iniparser/dictionary.h b/freebsd/contrib/ptpd/src/dep/iniparser/dictionary.h
index 00000000..cf1027e7
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/iniparser/dictionary.h
@@ -0,0 +1,189 @@
+   @file    dictionary.h
+#ifndef _DICTIONARY_H_
+#define _DICTIONARY_H_
+                                Includes
+#include <syslog.h>
+void logMessage(int priority, const char *format, ...);
+#ifndef WARNING
+#define WARNING(x, ...)   logMessage(LOG_WARNING, x, ##__VA_ARGS__)
+#endif /* WARNING */
+#include <stdio.h>
+                                New types
+  @brief    Dictionary object
+  This object contains a list of string/string associations. Each
+  association is identified by a unique string key. Looking up values
+  in the dictionary is speeded up by the use of a (hopefully collision-free)
+  hash function.
+typedef struct _dictionary_ {
+    int             n ;     /** Number of entries in dictionary */
+    int             size ;  /** Storage size */
+    char        **  val ;   /** List of string values */
+    char        **  key ;   /** List of string keys */
+    unsigned     *  hash ;  /** List of hash values for keys */
+} dictionary ;
+                            Function prototypes
+unsigned dictionary_hash(const char * key);
+dictionary * dictionary_new(int size);
+  @return   void
+void dictionary_del(dictionary ** vd);
+char * dictionary_get(dictionary * d, const char * key, char * def);
+  in such a case.
+int dictionary_set(dictionary * vd, const char * key, const char * val);
+  @return   void
+void dictionary_unset(dictionary * d, const char * key);
+  @return   void
+void dictionary_replace(dictionary * d, const char * search, const char * replace);
+  @return   void
+void dictionary_dump(dictionary * d, FILE * out);
+int dictionary_merge(dictionary * source, dictionary * dest, int overwrite, int warn, const char* warnStr);
+#endif
diff --git a/freebsd/contrib/ptpd/src/dep/iniparser/iniparser.c b/freebsd/contrib/ptpd/src/dep/iniparser/iniparser.c
index 00000000..04443e5b
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/iniparser/iniparser.c
@@ -0,0 +1,771 @@
+   @file    iniparser.c
+   @brief   Parser for ini files.
+/*---------------------------- Includes ------------------------------------*/
+#include <ctype.h>
+#include "iniparser.h"
+/*---------------------------- Defines -------------------------------------*/
+#define ASCIILINESZ         (1024)
+#define INI_INVALID_KEY     ((char*)-1)
+                        Private to this module
+ * This enum stores the status for each parsed line (internal use only).
+typedef enum _line_status_ {
+    LINE_UNPROCESSED,
+    LINE_ERROR,
+    LINE_EMPTY,
+    LINE_COMMENT,
+    LINE_SECTION,
+    LINE_VALUE
+} line_status ;
+  @brief    Convert a string to lowercase.
+  @param    s   String to convert.
+  @return   ptr to statically allocated string.
+  This function returns a pointer to a statically allocated string
+  containing a lowercased version of the input string. Do not free
+  or modify the returned string! Since the returned string is statically
+  allocated, it will be modified at each function call (not re-entrant).
+static char * strlwc(const char * s)
+    static char l[ASCIILINESZ+1];
+    int i ;
+    if (s==NULL) return NULL ;
+    memset(l, 0, ASCIILINESZ+1);
+    i=0 ;
+    while (s[i] && i<ASCIILINESZ) {
+        l[i] = (char)tolower((int)s[i]);
+        i++ ;
+    l[ASCIILINESZ]=(char)0;
+    return l ;
+  @brief    Remove blanks at the beginning and the end of a string.
+  @param    s   String to parse.
+  This function returns a pointer to a statically allocated string,
+  which is identical to the input string, except that all blank
+  characters at the end and the beg. of the string have been removed.
+  Do not free or modify the returned string! Since the returned string
+  is statically allocated, it will be modified at each function call
+  (not re-entrant).
+static char * strstrip(const char * s)
+    char * last ;
+    while (isspace((int)*s) && *s) s++;
+    strncpy(l, s, ASCIILINESZ);
+    last = l + strlen(l);
+    while (last > l) {
+        if (!isspace((int)*(last-1)))
+            break ;
+        last -- ;
+    *last = (char)0;
+    return (char*)l ;
+  @brief    Get number of sections in a dictionary
+  @param    d   Dictionary to examine
+  @return   int Number of sections found in dictionary
+  This function returns the number of sections found in a dictionary.
+  The test to recognize sections is done on the string stored in the
+  dictionary: a section name is given as "section" whereas a key is
+  stored as "section:key", thus the test looks for entries that do not
+  contain a colon.
+  This clearly fails in the case a section name contains a colon, but
+  this should simply be avoided.
+  This function returns -1 in case of error.
+int iniparser_getnsec(dictionary * d)
+    int i ;
+    int nsec ;
+    if (d==NULL) return -1 ;
+    nsec=0 ;
+            continue ;
+        if (strchr(d->key[i], ':')==NULL) {
+            nsec ++ ;
+    return nsec ;
+  @brief    Get name for section n in a dictionary.
+  @param    n   Section number (from 0 to nsec-1).
+  @return   Pointer to char string
+  This function locates the n-th section in a dictionary and returns
+  its name as a pointer to a string statically allocated inside the
+  dictionary. Do not free or modify the returned string!
+  This function returns NULL in case of error.
+char * iniparser_getsecname(dictionary * d, int n)
+    int i ;
+    int foundsec ;
+    if (d==NULL || n<0) return NULL ;
+    foundsec=0 ;
+            continue ;
+            foundsec++ ;
+            if (foundsec>n)
+                break ;
+    if (foundsec<=n) {
+        return NULL ;
+    return d->key[i] ;
+  @param    d   Dictionary to dump.
+  @param    f   Opened file pointer to dump to.
+  @return   void
+  This function prints out the contents of a dictionary, one element by
+  line, onto the provided file pointer. It is OK to specify @c stderr
+  or @c stdout as output files. This function is meant for debugging
+  purposes mostly.
+void iniparser_dump(dictionary * d, FILE * f)
+    int     i ;
+    if (d==NULL || f==NULL) return ;
+            continue ;
+            fprintf(f, "[%s]=[%s]\n", d->key[i], d->val[i]);
+        } else {
+            fprintf(f, "[%s]=UNDEF\n", d->key[i]);
+    return ;
+  @brief    Save a dictionary to a loadable ini file
+  @return   void
+  This function dumps a given dictionary into a loadable ini file.
+  It is Ok to specify @c stderr or @c stdout as output files.
+void iniparser_dump_ini(dictionary * d, FILE * f)
+    int     i ;
+    int     nsec ;
+    char *  secname ;
+    nsec = iniparser_getnsec(d);
+    if (nsec<1) {
+        /* No section in file: dump all keys as they are */
+                continue ;
+            fprintf(f, "%s = %s\n", d->key[i], d->val[i]);
+        return ;
+    for (i=0 ; i<nsec ; i++) {
+        secname = iniparser_getsecname(d, i) ;
+        iniparser_dumpsection_ini(d, secname, f) ;
+    fprintf(f, "\n");
+    return ;
+  @brief    Save a dictionary section to a loadable ini file
+  @param    s   Section name of dictionary to dump
+  @return   void
+  This function dumps a given section of a given dictionary into a loadable ini
+  file.  It is Ok to specify @c stderr or @c stdout as output files.
+void iniparser_dumpsection_ini(dictionary * d, char * s, FILE * f)
+    int     j ;
+    char    keym[ASCIILINESZ+1];
+    int     seclen ;
+    if (! iniparser_find_entry(d, s)) return ;
+    seclen  = (int)strlen(s);
+    fprintf(f, "\n[%s]\n", s);
+    snprintf(keym, ASCIILINESZ, "%s:", s);
+    for (j=0 ; j<d->size ; j++) {
+        if (d->key[j]==NULL)
+            continue ;
+        if (!strncmp(d->key[j], keym, seclen+1)) {
+            fprintf(f,
+                    "%-30s = %s\n",
+                    d->key[j]+seclen+1,
+                    d->val[j] ? d->val[j] : "");
+    fprintf(f, "\n");
+    return ;
+  @brief    Get the number of keys in a section of a dictionary.
+  @param    s   Section name of dictionary to examine
+  @return   Number of keys in section
+int iniparser_getsecnkeys(dictionary * d, char * s)
+    int     seclen, nkeys ;
+    int j ;
+    nkeys = 0;
+    if (d==NULL) return nkeys;
+    if (! iniparser_find_entry(d, s)) return nkeys;
+            continue ;
+            nkeys++;
+    return nkeys;
+  @return   pointer to statically allocated character strings
+  This function queries a dictionary and finds all keys in a given section.
+  Each pointer in the returned char pointer-to-pointer is pointing to
+  a string allocated in the dictionary; do not free or modify them.
+char ** iniparser_getseckeys(dictionary * d, char * s)
+    char **keys;
+    int i, j ;
+    keys = NULL;
+    if (d==NULL) return keys;
+    if (! iniparser_find_entry(d, s)) return keys;
+    nkeys = iniparser_getsecnkeys(d, s);
+    keys = (char**) malloc(nkeys*sizeof(char*));
+    i = 0;
+            continue ;
+            keys[i] = d->key[j];
+            i++;
+    return keys;
+  @brief    Get the string associated to a key
+  @param    d       Dictionary to search
+  @param    key     Key string to look for
+  This function queries a dictionary for a key. A key as read from an
+  ini file is given as "section:key". If the key cannot be found,
+  the pointer passed as 'def' is returned.
+  The returned char pointer is pointing to a string allocated in
+  the dictionary, do not free or modify it.
+char * iniparser_getstring(dictionary * d, const char * key, char * def)
+    char * lc_key ;
+    char * sval ;
+        return def ;
+    lc_key = strlwc(key);
+    sval = dictionary_get(d, lc_key, def);
+    return sval ;
+  @brief    Get the string associated to a key, convert to an int
+  @param    notfound Value to return in case of error
+  @return   integer
+  the notfound value is returned.
+  Supported values for integers include the usual C notation
+  so decimal, octal (starting with 0) and hexadecimal (starting with 0x)
+  are supported. Examples:
+  "42"      ->  42
+  "042"     ->  34 (octal -> decimal)
+  "0x42"    ->  66 (hexa  -> decimal)
+  Warning: the conversion may overflow in various ways. Conversion is
+  totally outsourced to strtol(), see the associated man page for overflow
+  handling.
+  Credits: Thanks to A. Becker for suggesting strtol()
+int iniparser_getint(dictionary * d, const char * key, int notfound)
+    char    *   str ;
+    str = iniparser_getstring(d, key, INI_INVALID_KEY);
+    if (str==INI_INVALID_KEY) return notfound ;
+    return (int)strtol(str, NULL, 0);
+  @brief    Get the string associated to a key, convert to a double
+  @return   double
+double iniparser_getdouble(dictionary * d, const char * key, double notfound)
+    char    *   str ;
+    return atof(str);
+  @brief    Get the string associated to a key, convert to a boolean
+  @return   integer
+  A true boolean is found if one of the following is matched:
+  - A string starting with 'y'
+  - A string starting with 'Y'
+  - A string starting with 't'
+  - A string starting with 'T'
+  - A string starting with '1'
+  A false boolean is found if one of the following is matched:
+  - A string starting with 'n'
+  - A string starting with 'N'
+  - A string starting with 'f'
+  - A string starting with 'F'
+  - A string starting with '0'
+  The notfound value returned if no boolean is identified, does not
+  necessarily have to be 0 or 1.
+int iniparser_getboolean(dictionary * d, const char * key, int notfound)
+    char    *   c ;
+    int         ret ;
+    c = iniparser_getstring(d, key, INI_INVALID_KEY);
+    if (c==INI_INVALID_KEY) return notfound ;
+    if (c[0]=='y' || c[0]=='Y' || c[0]=='1' || c[0]=='t' || c[0]=='T') {
+        ret = 1 ;
+    } else if (c[0]=='n' || c[0]=='N' || c[0]=='0' || c[0]=='f' || c[0]=='F') {
+        ret = 0 ;
+    } else {
+        ret = notfound ;
+    return ret;
+  @brief    Finds out if a given entry exists in a dictionary
+  @param    ini     Dictionary to search
+  @param    entry   Name of the entry to look for
+  @return   integer 1 if entry exists, 0 otherwise
+  Finds out if a given entry exists in the dictionary. Since sections
+  are stored as keys with NULL associated values, this is the only way
+  of querying for the presence of sections in a dictionary.
+int iniparser_find_entry(
+    dictionary  *   ini,
+    const char  *   entry
+    int found=0 ;
+    if (iniparser_getstring(ini, entry, INI_INVALID_KEY)!=INI_INVALID_KEY) {
+        found = 1 ;
+    return found ;
+  @brief    Set an entry in a dictionary.
+  @param    ini     Dictionary to modify.
+  @param    entry   Entry to modify (entry name)
+  @param    val     New value to associate to the entry.
+  @return   int 0 if Ok, -1 otherwise.
+  If the given entry can be found in the dictionary, it is modified to
+  contain the provided value. If it cannot be found, -1 is returned.
+  It is Ok to set val to NULL.
+int iniparser_set(dictionary * ini, const char * entry, const char * val)
+    char section[ASCIILINESZ+1];
+    if(sscanf(entry,":%[^:]:",section)>0)
+	dictionary_set(ini,section,NULL);
+    if(sscanf(entry,"%[^:]:",section)>0)
+    return dictionary_set(ini, strlwc(entry), val) ;
+  @brief    Delete an entry in a dictionary
+  @param    entry   Entry to delete (entry name)
+  @return   void
+  If the given entry can be found, it is deleted from the dictionary.
+void iniparser_unset(dictionary * ini, const char * entry)
+    dictionary_unset(ini, strlwc(entry));
+  @brief    Load a single line from an INI file
+  @param    input_line  Input line, may be concatenated multi-line input
+  @param    section     Output space to store section
+  @param    key         Output space to store key
+  @param    value       Output space to store value
+  @return   line_status value
+static line_status iniparser_line(
+    const char * input_line,
+    char * section,
+    char * key,
+    char * value)
+    line_status sta ;
+    char        line[ASCIILINESZ+1];
+    int         len ;
+    memset(line, 0, ASCIILINESZ + 1);
+    strncpy(line, strstrip(input_line), ASCIILINESZ);
+    len = (int)strlen(line);
+    sta = LINE_UNPROCESSED ;
+    if (len<1) {
+        /* Empty line */
+        sta = LINE_EMPTY ;
+    } else if (line[0]=='#' || line[0]==';') {
+        /* Comment line */
+        sta = LINE_COMMENT ;
+    } else if (line[0]=='[' && line[len-1]==']') {
+        /* Section name */
+        sscanf(line, "[%[^]]", section);
+        strncpy(section, strstrip(section), ASCIILINESZ);
+        strncpy(section, strlwc(section), ASCIILINESZ);
+        sta = LINE_SECTION ;
+    } else if (sscanf (line, "%[^=] = \"%[^\"]\"", key, value) == 2
+           ||  sscanf (line, "%[^=] = '%[^\']'",   key, value) == 2
+           ||  sscanf (line, "%[^=] = %[^;#]",     key, value) == 2) {
+        /* Usual key=value, with or without comments */
+        strncpy(key, strstrip(key), ASCIILINESZ);
+        strncpy(key, strlwc(key), ASCIILINESZ);
+        strncpy(value, strstrip(value), ASCIILINESZ);
+         * sscanf cannot handle '' or "" as empty values
+         * this is done here
+        if (!strcmp(value, "\"\"") || (!strcmp(value, "''"))) {
+            value[0]=0 ;
+        sta = LINE_VALUE ;
+    } else if (sscanf(line, "%[^=] = %[;#]", key, value)==2
+           ||  sscanf(line, "%[^=] %[=]", key, value) == 2) {
+         * Special cases:
+         * key=
+         * key=;
+         * key=#
+        value[0]=0 ;
+    } else {
+        /* Generate syntax error */
+        sta = LINE_ERROR ;
+    return sta ;
+  @brief    Parse an ini file and return an allocated dictionary object
+  @param    ininame Name of the ini file to read.
+  @return   Pointer to newly allocated dictionary
+  This is the parser for ini files. This function is called, providing
+  the name of the file to be read. It returns a dictionary object that
+  should not be accessed directly, but through accessor functions
+  instead.
+  The returned dictionary must be freed using iniparser_freedict().
+dictionary * iniparser_load(const char * ininame)
+    FILE * in ;
+    char line    [ASCIILINESZ+1] ;
+    char section [ASCIILINESZ+1] ;
+    char key     [ASCIILINESZ+1] ;
+    char tmp     [ASCIILINESZ+1] ;
+    char val     [ASCIILINESZ+1] ;
+    int  last=0 ;
+    int  len ;
+    int  lineno=0 ;
+    int  errs=0;
+    dictionary * dict ;
+    if ((in=fopen(ininame, "r"))==NULL) {
+        fprintf(stderr, "iniparser: cannot open %s\n", ininame);
+        return NULL ;
+    dict = dictionary_new(0) ;
+    if (!dict) {
+        fclose(in);
+        return NULL ;
+    memset(line,    0, ASCIILINESZ);
+    memset(section, 0, ASCIILINESZ);
+    memset(key,     0, ASCIILINESZ);
+    memset(val,     0, ASCIILINESZ);
+    memset(tmp,     0, ASCIILINESZ);
+    last=0 ;
+    while (fgets(line+last, ASCIILINESZ-last, in)!=NULL) {
+        lineno++ ;
+        len = (int)strlen(line)-1;
+        if (len==0)
+            continue;
+        /* Safety check against buffer overflows */
+        if (line[len]!='\n') {
+            fprintf(stderr,
+                    "iniparser: input line too long or no newline in the end in %s (%d)\n",
+                    ininame,
+                    lineno);
+            dictionary_del(&dict);
+            fclose(in);
+            return NULL ;
+        /* Get rid of \n and spaces at end of line */
+        while ((len>=0) &&
+                ((line[len]=='\n') || (isspace((unsigned char)line[len])))) {
+            line[len]=0 ;
+            len-- ;
+        /* Detect multi-line */
+        if (line[len]=='\\') {
+            /* Multi-line value */
+            last=len ;
+            continue ;
+        } else {
+            last=0 ;
+        switch (iniparser_line(line, section, key, val)) {
+            case LINE_EMPTY:
+            case LINE_COMMENT:
+            break ;
+            case LINE_SECTION:
+            errs = dictionary_set(dict, section, NULL);
+            break ;
+            case LINE_VALUE:
+            snprintf(tmp, ASCIILINESZ, "%s%s%s", section, strlen(section)==0?"":":", key);
+            errs = dictionary_set(dict, tmp, val) ;
+            break ;
+            case LINE_ERROR:
+            fprintf(stderr, "iniparser: syntax error in %s (%d):\n",
+                    ininame,
+                    lineno);
+            fprintf(stderr, "-> %s\n", line);
+            errs++ ;
+            break;
+            default:
+            break ;
+        last=0;
+        if (errs<0) {
+            fprintf(stderr, "iniparser: memory allocation failure\n");
+            break ;
+    if (errs) {
+        dict = NULL ;
+    fclose(in);
+    return dict ;
+int iniparser_merge_file(dictionary *dict, const char *filename, int overwrite) {
+    dictionary *src;
+    if ((src = iniparser_load(filename)) == NULL) {
+	return 0;
+    dictionary_merge(src, dict, overwrite, 0, NULL);
+    dictionary_del(&src);
+    return 1;
+  @brief    Free all memory associated to an ini dictionary
+  @param    d Dictionary to free
+  @return   void
+  Free all memory associated to an ini dictionary.
+  It is mandatory to call this function before the dictionary object
+  gets out of the current context.
+void iniparser_freedict(dictionary ** d)
+    dictionary_del(d);
diff --git a/freebsd/contrib/ptpd/src/dep/iniparser/iniparser.h b/freebsd/contrib/ptpd/src/dep/iniparser/iniparser.h
index 00000000..a247ac60
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/iniparser/iniparser.h
@@ -0,0 +1,311 @@
+   @file    iniparser.h
+#ifndef _INIPARSER_H_
+#define _INIPARSER_H_
+                                Includes
+#include <stdio.h>
+ * The following #include is necessary on many Unixes but not Linux.
+ * It is not needed for Windows platforms.
+ * Uncomment it if needed.
+/* #include <unistd.h> */
+  contain a colon.
+int iniparser_getnsec(dictionary * d);
+char * iniparser_getsecname(dictionary * d, int n);
+  @return   void
+void iniparser_dump_ini(dictionary * d, FILE * f);
+  @return   void
+void iniparser_dumpsection_ini(dictionary * d, char * s, FILE * f);
+  @return   void
+  purposes mostly.
+void iniparser_dump(dictionary * d, FILE * f);
+int iniparser_getsecnkeys(dictionary * d, char * s);
+char ** iniparser_getseckeys(dictionary * d, char * s);
+char * iniparser_getstring(dictionary * d, const char * key, char * def);
+  @return   integer
+  - "42"      ->  42
+  - "042"     ->  34 (octal -> decimal)
+  - "0x42"    ->  66 (hexa  -> decimal)
+  handling.
+int iniparser_getint(dictionary * d, const char * key, int notfound);
+  @return   double
+double iniparser_getdouble(dictionary * d, const char * key, double notfound);
+  @return   integer
+int iniparser_getboolean(dictionary * d, const char * key, int notfound);
+int iniparser_set(dictionary * ini, const char * entry, const char * val);
+  @return   void
+void iniparser_unset(dictionary * ini, const char * entry);
+int iniparser_find_entry(dictionary * ini, const char * entry) ;
+  instead.
+dictionary * iniparser_load(const char * ininame);
+int iniparser_merge_file(dictionary *dict, const char * filename, int overwrite);
+dictionary * iniparser_load_list(const char* list);
+  @return   void
+void iniparser_freedict(dictionary ** d);
+#endif
diff --git a/freebsd/contrib/ptpd/src/dep/ipv4_acl.c b/freebsd/contrib/ptpd/src/dep/ipv4_acl.c
index 00000000..5b2bba3d
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/ipv4_acl.c
@@ -0,0 +1,486 @@
+ * Copyright (c) 2013-2014 Wojciech Owczarek,
+ * met:
+ * @file 	   ipv4_acl.c
+ * @date   Sun Oct 13 21:02:23 2013
+ * @brief  Code to handle IPv4 access control lists
+ * Functions in this file parse, create and match IPv4 ACLs.
+#include "string.h"
+ * strdup + free are used across code using strtok_r, so as to
+ * protect the original string, as strtok* modify it.
+/* count tokens in string delimited by delim */
+static int countTokens(const char* text, const char* delim) {
+    int count=0;
+    char* stash = NULL;
+    char* text_;
+    char* text__;
+    if(text==NULL || delim==NULL)
+	return 0;
+    text_=strdup(text);
+    for(text__=text_,count=0;strtok_r(text__,delim, &stash) != NULL; text__=NULL) {
+	    count++;
+    free(text_);
+    return count;
+/* Parse a dotted-decimal string into an uint8_t array - return -1 on error */
+static int ipToArray(const char* text, uint8_t dest[], int maxOctets, Boolean isMask)
+    char* text_;
+    char* text__;
+    char* subtoken;
+    char* endptr;
+    long octet;
+    int count = 0;
+    int result = 0;
+    memset(&dest[0], 0, maxOctets * sizeof(uint8_t));
+    for(text__=text_;;text__=NULL) {
+	if(count > maxOctets) {
+	    result = -1;
+	    goto end;
+	subtoken = strtok_r(text__,".",&stash);
+	if(subtoken == NULL)
+		goto end;
+	errno = 0;
+	octet=strtol(subtoken,&endptr,10);
+	if(errno!=0 || !IN_RANGE(octet,0,255)) {
+	    result = -1;
+	    goto end;
+	dest[count++] = (uint8_t)octet;
+	/* If we're parsing a mask and an octet is less than 0xFF, whole rest is zeros */
+	if(isMask && octet < 255)
+		goto end;
+    end:
+    free(text_);
+    return result;
+/* Parse a single net mask into an AclEntry */
+static int parseAclEntry(const char* line, AclEntry* acl) {
+    int result = 1;
+    char* text_;
+    char* token;
+    char* endptr;
+    long octet = 0;
+    uint8_t net_octets[4];
+    uint8_t mask_octets[4];
+    if(line == NULL || acl == NULL)
+	return -1;
+    if(countTokens(line,"/") == 0)
+	return -1;
+    text_=strdup(line);
+    token=strtok_r(text_,"/",&stash);
+    if((countTokens(token,".") > 4) ||
+	(countTokens(token,".") < 1) ||
+	(ipToArray(token,net_octets,4,0) < 0)) {
+	    result=-1;
+	    goto end;
+    acl->network = (net_octets[0] << 24) | (net_octets[1] << 16) | ( net_octets[2] << 8) | net_octets[3];
+    token=strtok_r(NULL,"/",&stash);
+    if(token == NULL) {
+	acl->netmask=32;
+	acl->bitmask=~0;
+    } else if(countTokens(token,".") == 1) {
+	errno = 0;
+	octet = strtol(token,&endptr,10);
+	if(errno != 0 || !IN_RANGE(octet,0,32)) {
+		result = -1;
+		goto end;
+	if(octet == 0)
+	    acl->bitmask = 0;
+	else
+	    acl->bitmask = ~0 << (32 - octet);
+	acl->netmask = (uint16_t)octet;
+    } else if((countTokens(token,".") > 4) ||
+	(ipToArray(token,mask_octets,4,1) < 0)) {
+	    result=-1;
+	    goto end;
+    } else {
+	acl->bitmask = (mask_octets[0] << 24) | (mask_octets[1] << 16) | ( mask_octets[2] << 8) | mask_octets[3];
+	uint32_t tmp = acl->bitmask;
+	int count = 0;
+	for(tmp = acl->bitmask;tmp<<count;count++);
+	acl->netmask=count;
+    end:
+    free(text_);
+    acl->network &= acl->bitmask;
+    return result;
+/* qsort() compare function for sorting ACL entries */
+static int
+cmpAclEntry(const void *p1, const void *p2)
+	const AclEntry *left = p1;
+	const AclEntry *right = p2;
+	if(left->network > right->network)
+		return 1;
+	if(left->network < right->network)
+		return -1;
+	return 0;
+/* Parse an ACL string into an aclEntry table and return number of entries. output can be NULL */
+int
+maskParser(const char* input, AclEntry* output)
+    char* token;
+    char* stash;
+    int found = 0;
+    char* text_;
+    char* text__;
+    AclEntry tmp;
+    tmp.hitCount=0;
+    if(strlen(input)==0) return 0;
+    text_=strdup(input);
+	token=strtok_r(text__,", ;\t",&stash);
+	if(token==NULL) break;
+	if(parseAclEntry(token,&tmp)<1) {
+	    found = -1;
+	    break;
+	if(output != NULL)
+	    output[found]=tmp;
+	found++;
+	if(found && (output != NULL))
+		qsort(output, found, sizeof(AclEntry), cmpAclEntry);
+	/* We got input but found nothing - error */
+	if (!found)
+		found = -1;
+	free(text_);
+	return found;
+/* Create a maskTable from a text ACL */
+static MaskTable*
+createMaskTable(const char* input)
+	MaskTable* ret;
+	int masksFound = maskParser(input, NULL);
+	if(masksFound>=0) {
+		ret=(MaskTable*)calloc(1,sizeof(MaskTable));
+		ret->entries = (AclEntry*)calloc(masksFound, sizeof(AclEntry));
+		ret->numEntries = maskParser(input,ret->entries);
+		return ret;
+	} else {
+		ERROR("Error while parsing access list: \"%s\"\n", input);
+		return NULL;
+/* Print the contents of a single mask table */
+static void
+dumpMaskTable(MaskTable* table)
+	int i;
+	uint32_t network;
+	if(table == NULL)
+	    return;
+	INFO("number of entries: %d\n",table->numEntries);
+	if(table->entries != NULL) {
+		for(i = 0; i < table->numEntries; i++) {
+		    AclEntry this = table->entries[i];
+#ifdef PTPD_MSBF
+		    network = this.network;
+#else
+		    network = htonl(this.network);
+#endif
+		    INFO("%d.%d.%d.%d/%d\t(0x%.8x/0x%.8x), matches: %d\n",
+		    *((uint8_t*)&network), *((uint8_t*)&network+1),
+		    *((uint8_t*)&network+2), *((uint8_t*)&network+3), this.netmask,
+		    this.network, this.bitmask, this.hitCount);
+/* Free a MaskTable structure */
+static void freeMaskTable(MaskTable** table)
+    if(*table == NULL)
+	return;
+    if((*table)->entries != NULL) {
+	free((*table)->entries);
+	(*table)->entries = NULL;
+    free(*table);
+    *table = NULL;
+/* Destroy an Ipv4AccessList structure */
+void
+freeIpv4AccessList(Ipv4AccessList** acl)
+	if(*acl == NULL)
+	    return;
+	freeMaskTable(&(*acl)->permitTable);
+	freeMaskTable(&(*acl)->denyTable);
+	free(*acl);
+	*acl = NULL;
+/* Structure initialisation for Ipv4AccessList */
+Ipv4AccessList*
+createIpv4AccessList(const char* permitList, const char* denyList, int processingOrder)
+	Ipv4AccessList* ret;
+	ret = (Ipv4AccessList*)calloc(1,sizeof(Ipv4AccessList));
+	ret->permitTable = createMaskTable(permitList);
+	ret->denyTable = createMaskTable(denyList);
+	if(ret->permitTable == NULL || ret->denyTable == NULL) {
+		freeIpv4AccessList(&ret);
+		return NULL;
+	ret->processingOrder = processingOrder;
+	return ret;
+/* Match an IP address against a MaskTable */
+static int
+matchAddress(const uint32_t addr, MaskTable* table)
+	int i;
+	if(table == NULL || table->entries == NULL || table->numEntries==0)
+	    return -1;
+		DBGV("addr: %08x, addr & mask: %08x, network: %08x\n",addr, table->entries[i].bitmask & addr, table->entries[i].network);
+		if((table->entries[i].bitmask & addr) == table->entries[i].network) {
+			table->entries[i].hitCount++;
+			return 1;
+	return 0;
+/* Test an IP address against an ACL */
+int
+matchIpv4AccessList(Ipv4AccessList* acl, const uint32_t addr)
+	int ret;
+	int matchPermit = 0;
+	int matchDeny = 0;
+	/* Non-functional ACL permits everything */
+	if(acl == NULL) {
+		ret = 1;
+		goto end;
+	if(acl->permitTable != NULL)
+		matchPermit = matchAddress(addr,acl->permitTable) > 0;
+	if(acl->denyTable != NULL)
+		matchDeny = matchAddress(addr,acl->denyTable) > 0;
+	switch(acl->processingOrder) {
+		case ACL_PERMIT_DENY:
+			if(!matchPermit) {
+				ret = 0;
+				break;
+			if(matchDeny) {
+				ret = 0;
+				break;
+			ret = 1;
+			break;
+		default:
+		case ACL_DENY_PERMIT:
+			if (matchDeny && !matchPermit) {
+				ret = 0;
+				break;
+			else {
+				ret = 1;
+				break;
+	end:
+	if(ret)
+	    acl->passedCounter++;
+	else
+	    acl->droppedCounter++;
+	return ret;
+/* Dump the contents and hit counters of an ACL */
+void dumpIpv4AccessList(Ipv4AccessList* acl)
+		    INFO("\n\n");
+	if(acl == NULL) {
+		    INFO("(uninitialised ACL)\n");
+		    return;
+		    INFO("ACL order: deny,permit\n");
+		    INFO("Passed packets: %d, dropped packets: %d\n",
+				acl->passedCounter, acl->droppedCounter);
+		    INFO("--------\n");
+		    INFO("Deny list:\n");
+		    dumpMaskTable(acl->denyTable);
+		    INFO("Permit list:\n");
+		    dumpMaskTable(acl->permitTable);
+		break;
+		default:
+		    INFO("ACL order: permit,deny\n");
+		break;
+		    INFO("\n\n");
+/* Clear counters in a MaskTable */
+static void
+clearMaskTableCounters(MaskTable* table)
+	int i, count;
+	if(table==NULL || table->numEntries==0)
+		return;
+	count = table->numEntries;
+	for(i=0; i<count; i++) {
+		table->entries[i].hitCount = 0;
+/* Clear ACL counter */
+void clearIpv4AccessListCounters(Ipv4AccessList* acl) {
+	if(acl == NULL)
+		return;
+	acl->passedCounter=0;
+	acl->droppedCounter=0;
+	clearMaskTableCounters(acl->permitTable);
+	clearMaskTableCounters(acl->denyTable);
diff --git a/freebsd/contrib/ptpd/src/dep/ipv4_acl.h b/freebsd/contrib/ptpd/src/dep/ipv4_acl.h
new file mode 100644
index 00000000..65f7cd1d
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/ipv4_acl.h
@@ -0,0 +1,52 @@
+ * @file   ipv4_acl.h
+ * @brief  definitions related to IPv4 access control list handling
+#ifndef PTPD_IPV4_ACL_H_
+#define PTPD_IPV4_ACL_H_
+#define IN_RANGE(num, min,max) \
+	(num >= min && num <= max)
+enum {
+	ACL_PERMIT_DENY,
+	ACL_DENY_PERMIT
+typedef struct {
+	uint32_t network;
+	uint32_t bitmask;
+	uint16_t netmask;
+	uint32_t hitCount;
+} AclEntry;
+typedef struct {
+	int numEntries;
+	AclEntry* entries;
+} MaskTable;
+typedef struct {
+	MaskTable* permitTable;
+	MaskTable* denyTable;
+	int processingOrder;
+	uint32_t passedCounter;
+	uint32_t droppedCounter;
+} Ipv4AccessList;
+/* Parse string into AclEntry array */
+int maskParser(const char* input, AclEntry* output);
+void freeIpv4AccessList(Ipv4AccessList** acl);
+/* Initialise an Ipv4AccessList structure */
+Ipv4AccessList* createIpv4AccessList(const char* permitList, const char* denyList, int processingOrder);
+/* Match on an IP address */
+int matchIpv4AccessList(Ipv4AccessList* acl, const uint32_t addr);
+/* Display the contents and hit counters of an access list */
+void dumpIpv4AccessList(Ipv4AccessList* acl);
+/* Clear counters */
+void clearIpv4AccessListCounters(Ipv4AccessList* acl);
+#endif /* PTPD_IPV4_ACL_H_ */
diff --git a/freebsd/contrib/ptpd/src/dep/msg.c b/freebsd/contrib/ptpd/src/dep/msg.c
index 00000000..346fb821
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/msg.c
@@ -0,0 +1,2757 @@
+ *                         Steven Kreuzer,
+ *                         Jan Breuer,
+ *                         Gael Mace,
+ *                         Inaqui Delgado,
+ *                         Rick Ratzel,
+ *                         Steven Kreuzer,
+ *                         Jan Breuer,
+ *                         Gael Mace,
+ * met:
+ * @file   msg.c
+ * @author George Neville-Neil <gnn at neville-neil.com>
+ * @date   Tue Jul 20 16:17:05 2010
+ * @brief  Functions to pack and unpack messages.
+ * See spec annex d
+extern RunTimeOpts rtOpts;
+#define PACK_SIMPLE( type ) \
+void pack##type( void* from, void* to ) \
+	*(type *)to = *(type *)from; \
+void unpack##type( void* from, void* to, PtpClock *ptpClock ) \
+	pack##type( from, to ); \
+#define PACK_ENDIAN( type, size ) \
+	*(type *)to = flip##size( *(type *)from ); \
+#define PACK_LOWER_AND_UPPER( type ) \
+void pack##type##Lower( void* from, void* to ) \
+        *(char *)to = *(char *)to & 0xF0; \
+        *(char *)to = *(char *)to | *(type *)from; \
+void pack##type##Upper( void* from, void* to ) \
+        *(char *)to = *(char *)to & 0x0F; \
+        *(char *)to = *(char *)to | (*(type *)from << 4); \
+void unpack##type##Lower( void* from, void* to, PtpClock *ptpClock ) \
+        *(type *)to = *(char *)from & 0x0F; \
+void unpack##type##Upper( void* from, void* to, PtpClock *ptpClock ) \
+        *(type *)to = (*(char *)from >> 4) & 0x0F; \
+PACK_SIMPLE( Boolean )
+PACK_SIMPLE( UInteger8 )
+PACK_SIMPLE( Octet )
+PACK_SIMPLE( Enumeration8 )
+PACK_SIMPLE( Integer8 )
+PACK_ENDIAN( Enumeration16, 16 )
+PACK_ENDIAN( Integer16, 16 )
+PACK_ENDIAN( UInteger16, 16 )
+PACK_ENDIAN( Integer32, 32 )
+PACK_ENDIAN( UInteger32, 32 )
+PACK_LOWER_AND_UPPER( Enumeration4 )
+PACK_LOWER_AND_UPPER( UInteger4 )
+PACK_LOWER_AND_UPPER( Nibble )
+/* The free function is intentionally empty. However, this simplifies
+ * the procedure to deallocate complex data types
+#define FREE( type ) \
+void free##type( void* x) \
+FREE ( Boolean )
+FREE ( UInteger8 )
+FREE ( Octet )
+FREE ( Enumeration8 )
+FREE ( Integer8 )
+FREE ( Enumeration16 )
+FREE ( Integer16 )
+FREE ( UInteger16 )
+FREE ( Integer32 )
+FREE ( UInteger32 )
+FREE ( Enumeration4 )
+FREE ( UInteger4 )
+FREE ( Nibble )
+static inline int bufGuard(int max, long base, int len, long beginning, int size);
+ * check if data we want to read is within the allocated buffer,
+ * and if it is within the message length given.
+static inline int
+bufGuard(int max, long base, int len, long beginning, int size)
+#ifdef RUNTIME_DEBUG
+	int ok = ((beginning - base) < len) && ((beginning + size - base) < len) &&
+		((beginning - base) < max) && ((beginning + size - base) < max);
+	printf("bufGuard: beginning %ld end %ld: maxlen: %d size %d (%ld %ld %d): %s\n",
+		beginning - base, beginning + size - base, len, size, base,
+		beginning, size, ok ? "OK" : "!");
+#endif
+	return(
+	    ((beginning - base) < len) && ((beginning + size - base) < len) &&
+void
+unpackUInteger48( void *buf, void *i, PtpClock *ptpClock)
+	unpackUInteger16(buf, &((UInteger48*)i)->msb, ptpClock);
+	unpackUInteger32(buf + 2, &((UInteger48*)i)->lsb, ptpClock);
+void
+packUInteger48( void *i, void *buf)
+	packUInteger16(&((UInteger48*)i)->msb, buf);
+	packUInteger32(&((UInteger48*)i)->lsb, buf + 2);
+void
+unpackInteger64( void *buf, void *i, PtpClock *ptpClock)
+	unpackInteger32(buf, &((Integer64*)i)->msb, ptpClock);
+	unpackUInteger32(buf + 4, &((Integer64*)i)->lsb, ptpClock);
+void
+packInteger64( void* i, void *buf )
+	packInteger32(&((Integer64*)i)->msb, buf);
+	packUInteger32(&((Integer64*)i)->lsb, buf + 4);
+/* NOTE: the unpack functions for management messages can probably be refactored into a macro */
+int
+unpackMMSlaveOnly( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+	int offset = 0;
+	XMALLOC(m->tlv->dataField, sizeof(MMSlaveOnly));
+	MMSlaveOnly* data = (MMSlaveOnly*)m->tlv->dataField;
+	/* see src/def/README for a note on this X-macro */
+	#define OPERATE( name, size, type ) \
+		if(!bufGuard(PACKET_SIZE, (long)buf, m->header.messageLength, (long)(buf + baseOffset + MANAGEMENT_LENGTH + TLV_LENGTH + offset), size)) return 0;\
+		unpack##type( buf + baseOffset + MANAGEMENT_LENGTH + TLV_LENGTH + offset,\
+			      &data->name, ptpClock ); \
+		offset = offset + size;
+	#include "../def/managementTLV/slaveOnly.def"
+	#ifdef PTPD_DBG
+	mMSlaveOnly_display(data, ptpClock);
+	#endif /* PTPD_DBG */
+	return 1;
+/* NOTE: the pack functions for management messsages can probably be refactored into a macro */
+UInteger16
+packMMSlaveOnly( MsgManagement* m, Octet *buf)
+	int offset = 0;
+		pack##type( &data->name,\
+			    buf + MANAGEMENT_LENGTH + TLV_LENGTH + offset ); \
+	/* return length */
+	return offset;
+int
+unpackMMClockDescription( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+	int offset = 0;
+	XMALLOC(m->tlv->dataField, sizeof(MMClockDescription));
+	MMClockDescription* data = (MMClockDescription*)m->tlv->dataField;
+	memset(data, 0, sizeof(MMClockDescription));
+	#include "../def/managementTLV/clockDescription.def"
+	#ifdef PTPD_DBG
+	mMClockDescription_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMClockDescription( MsgManagement* m, Octet *buf)
+	int offset = 0;
+	Octet pad = 0;
+	data->reserved = 0;
+			    buf + MANAGEMENT_LENGTH + TLV_LENGTH + offset); \
+	/* is the TLV length odd? TLV must be even according to Spec 5.3.8 */
+	if(offset % 2) {
+		/* add pad of 1 according to Table 41 to make TLV length even */
+		packOctet(&pad, buf + MANAGEMENT_LENGTH + TLV_LENGTH + offset);
+		offset = offset + 1;
+	return offset;
+void
+freeMMClockDescription( MMClockDescription* data)
+		free##type( &data->name);
+int
+unpackMMUserDescription( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+	int offset = 0;
+	XMALLOC(m->tlv->dataField, sizeof(MMUserDescription));
+	MMUserDescription* data = (MMUserDescription*)m->tlv->dataField;
+	memset(data, 0, sizeof(MMUserDescription));
+	#include "../def/managementTLV/userDescription.def"
+	#ifdef PTPD_DBG
+	/* mMUserDescription_display(data, ptpClock); */
+	return 1;
+UInteger16
+packMMUserDescription( MsgManagement* m, Octet *buf)
+	int offset = 0;
+	Octet pad = 0;
+	if(offset % 2) {
+	return offset;
+void
+freeMMUserDescription( MMUserDescription* data)
+int unpackMMInitialize( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMInitialize));
+        MMInitialize* data = (MMInitialize*)m->tlv->dataField;
+        #include "../def/managementTLV/initialize.def"
+        #ifdef PTPD_DBG
+        mMInitialize_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMInitialize( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        /* return length*/
+        return offset;
+int unpackMMDefaultDataSet( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMDefaultDataSet));
+        MMDefaultDataSet* data = (MMDefaultDataSet*)m->tlv->dataField;
+        #include "../def/managementTLV/defaultDataSet.def"
+        #ifdef PTPD_DBG
+        mMDefaultDataSet_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMDefaultDataSet( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMCurrentDataSet( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMCurrentDataSet));
+        MMCurrentDataSet* data = (MMCurrentDataSet*)m->tlv->dataField;
+        #include "../def/managementTLV/currentDataSet.def"
+        #ifdef PTPD_DBG
+        mMCurrentDataSet_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMCurrentDataSet( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMParentDataSet( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMParentDataSet));
+        MMParentDataSet* data = (MMParentDataSet*)m->tlv->dataField;
+        #include "../def/managementTLV/parentDataSet.def"
+        #ifdef PTPD_DBG
+        mMParentDataSet_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMParentDataSet( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMTimePropertiesDataSet( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMTimePropertiesDataSet));
+        MMTimePropertiesDataSet* data = (MMTimePropertiesDataSet*)m->tlv->dataField;
+        #include "../def/managementTLV/timePropertiesDataSet.def"
+        #ifdef PTPD_DBG
+        mMTimePropertiesDataSet_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMTimePropertiesDataSet( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMPortDataSet( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMPortDataSet));
+        MMPortDataSet* data = (MMPortDataSet*)m->tlv->dataField;
+        #include "../def/managementTLV/portDataSet.def"
+        #ifdef PTPD_DBG
+        mMPortDataSet_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMPortDataSet( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMPriority1( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMPriority1));
+        MMPriority1* data = (MMPriority1*)m->tlv->dataField;
+        #include "../def/managementTLV/priority1.def"
+        #ifdef PTPD_DBG
+        mMPriority1_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMPriority1( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMPriority2( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMPriority2));
+        MMPriority2* data = (MMPriority2*)m->tlv->dataField;
+        #include "../def/managementTLV/priority2.def"
+        #ifdef PTPD_DBG
+        mMPriority2_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMPriority2( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMDomain( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMDomain));
+        MMDomain* data = (MMDomain*)m->tlv->dataField;
+        #include "../def/managementTLV/domain.def"
+        #ifdef PTPD_DBG
+        mMDomain_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMDomain( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMLogAnnounceInterval( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMLogAnnounceInterval));
+        MMLogAnnounceInterval* data = (MMLogAnnounceInterval*)m->tlv->dataField;
+        #include "../def/managementTLV/logAnnounceInterval.def"
+        #ifdef PTPD_DBG
+        mMLogAnnounceInterval_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMLogAnnounceInterval( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMAnnounceReceiptTimeout( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField,sizeof(MMAnnounceReceiptTimeout));
+        MMAnnounceReceiptTimeout* data = (MMAnnounceReceiptTimeout*)m->tlv->dataField;
+        #include "../def/managementTLV/announceReceiptTimeout.def"
+        #ifdef PTPD_DBG
+        mMAnnounceReceiptTimeout_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMAnnounceReceiptTimeout( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMLogSyncInterval( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMLogSyncInterval));
+        MMLogSyncInterval* data = (MMLogSyncInterval*)m->tlv->dataField;
+        #include "../def/managementTLV/logSyncInterval.def"
+        #ifdef PTPD_DBG
+        mMLogSyncInterval_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMLogSyncInterval( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMVersionNumber( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMVersionNumber));
+        MMVersionNumber* data = (MMVersionNumber*)m->tlv->dataField;
+        #include "../def/managementTLV/versionNumber.def"
+        #ifdef PTPD_DBG
+        mMVersionNumber_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMVersionNumber( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMTime( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMTime));
+        MMTime* data = (MMTime*)m->tlv->dataField;
+        #include "../def/managementTLV/time.def"
+        #ifdef PTPD_DBG
+        mMTime_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMTime( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMClockAccuracy( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMClockAccuracy));
+        MMClockAccuracy* data = (MMClockAccuracy*)m->tlv->dataField;
+        #include "../def/managementTLV/clockAccuracy.def"
+        #ifdef PTPD_DBG
+        mMClockAccuracy_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMClockAccuracy( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMUtcProperties( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMUtcProperties));
+        MMUtcProperties* data = (MMUtcProperties*)m->tlv->dataField;
+        #include "../def/managementTLV/utcProperties.def"
+        #ifdef PTPD_DBG
+        mMUtcProperties_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMUtcProperties( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMTraceabilityProperties( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMTraceabilityProperties));
+        MMTraceabilityProperties* data = (MMTraceabilityProperties*)m->tlv->dataField;
+        #include "../def/managementTLV/traceabilityProperties.def"
+        #ifdef PTPD_DBG
+        mMTraceabilityProperties_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMTraceabilityProperties( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMTimescaleProperties( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMTimescaleProperties));
+        MMTimescaleProperties* data = (MMTimescaleProperties*)m->tlv->dataField;
+        #include "../def/managementTLV/timescaleProperties.def"
+	data->ptp = (data->ptp & 0x08) >> 3;
+        #ifdef PTPD_DBG
+        mMTimescaleProperties_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMTimescaleProperties( MsgManagement* m, Octet *buf)
+        int offset = 0;
+	data->ptp = (data->ptp << 3) & 0x08;
+        return offset;
+int unpackMMUnicastNegotiationEnable( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMUnicastNegotiationEnable));
+        MMUnicastNegotiationEnable* data = (MMUnicastNegotiationEnable*)m->tlv->dataField;
+        #include "../def/managementTLV/unicastNegotiationEnable.def"
+        #ifdef PTPD_DBG
+        mMUnicastNegotiationEnable_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMUnicastNegotiationEnable( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMDelayMechanism( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMDelayMechanism));
+        MMDelayMechanism* data = (MMDelayMechanism*)m->tlv->dataField;
+        #include "../def/managementTLV/delayMechanism.def"
+        #ifdef PTPD_DBG
+        mMDelayMechanism_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMDelayMechanism( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMLogMinPdelayReqInterval( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMLogMinPdelayReqInterval));
+        MMLogMinPdelayReqInterval* data = (MMLogMinPdelayReqInterval*)m->tlv->dataField;
+        #include "../def/managementTLV/logMinPdelayReqInterval.def"
+        #ifdef PTPD_DBG
+        mMLogMinPdelayReqInterval_display(data, ptpClock);
+	return 1;
+UInteger16
+packMMLogMinPdelayReqInterval( MsgManagement* m, Octet *buf)
+        int offset = 0;
+        return offset;
+int unpackMMErrorStatus( Octet *buf, int baseOffset, MsgManagement* m, PtpClock* ptpClock)
+        int offset = 0;
+        XMALLOC(m->tlv->dataField, sizeof(MMErrorStatus));
+        MMErrorStatus* data = (MMErrorStatus*)m->tlv->dataField;
+        #include "../def/managementTLV/errorStatus.def"
+        #ifdef PTPD_DBG
+        mMErrorStatus_display(data, ptpClock);
+	return 1;
+void
+freeMMErrorStatus( MMErrorStatus* data)
+UInteger16
+packMMErrorStatus( MsgManagement* m, Octet *buf)
+        int offset = 0;
+	Octet pad = 0;
+	if(offset % 2) {
+	return offset;
+void
+unpackSMRequestUnicastTransmission( Octet *buf, MsgSignaling* m, PtpClock* ptpClock)
+	int offset = 0;
+	XMALLOC(m->tlv->valueField, sizeof(SMRequestUnicastTransmission));
+	SMRequestUnicastTransmission* data = (SMRequestUnicastTransmission*)m->tlv->valueField;
+		unpack##type( buf + SIGNALING_LENGTH + TL_LENGTH + offset,\
+	#include "../def/signalingTLV/requestUnicastTransmission.def"
+	#ifdef PTPD_DBG
+	sMRequestUnicastTransmission_display(data, ptpClock);
+UInteger16
+packSMRequestUnicastTransmission( MsgSignaling* m, Octet *buf)
+	int offset = 0;
+			    buf + SIGNALING_LENGTH + TL_LENGTH + offset ); \
+	return offset;
+void
+unpackSMGrantUnicastTransmission( Octet *buf, MsgSignaling* m, PtpClock* ptpClock)
+	int offset = 0;
+	XMALLOC(m->tlv->valueField, sizeof(SMGrantUnicastTransmission));
+	SMGrantUnicastTransmission* data = (SMGrantUnicastTransmission*)m->tlv->valueField;
+	#ifdef PTPD_DBG
+	sMGrantUnicastTransmission_display(data, ptpClock);
+UInteger16
+packSMGrantUnicastTransmission( MsgSignaling* m, Octet *buf)
+	int offset = 0;
+	#include "../def/signalingTLV/grantUnicastTransmission.def"
+	return offset;
+void
+unpackSMCancelUnicastTransmission( Octet *buf, MsgSignaling* m, PtpClock* ptpClock)
+	int offset = 0;
+	XMALLOC(m->tlv->valueField, sizeof(SMCancelUnicastTransmission));
+	SMCancelUnicastTransmission* data = (SMCancelUnicastTransmission*)m->tlv->valueField;
+	#include "../def/signalingTLV/cancelUnicastTransmission.def"
+	#ifdef PTPD_DBG
+	sMCancelUnicastTransmission_display(data, ptpClock);
+UInteger16
+packSMCancelUnicastTransmission( MsgSignaling* m, Octet *buf)
+	int offset = 0;
+	return offset;
+void
+unpackSMAcknowledgeCancelUnicastTransmission( Octet *buf, MsgSignaling* m, PtpClock* ptpClock)
+	int offset = 0;
+	XMALLOC(m->tlv->valueField, sizeof(SMAcknowledgeCancelUnicastTransmission));
+	SMAcknowledgeCancelUnicastTransmission* data = (SMAcknowledgeCancelUnicastTransmission*)m->tlv->valueField;
+	#include "../def/signalingTLV/acknowledgeCancelUnicastTransmission.def"
+	#ifdef PTPD_DBG
+	sMAcknowledgeCancelUnicastTransmission_display(data, ptpClock);
+UInteger16
+packSMAcknowledgeCancelUnicastTransmission( MsgSignaling* m, Octet *buf)
+	int offset = 0;
+	return offset;
+void
+unpackClockIdentity( Octet *buf, ClockIdentity *c, PtpClock *ptpClock)
+	int i;
+	for(i = 0; i < CLOCK_IDENTITY_LENGTH; i++) {
+		unpackOctet((buf+i),&((*c)[i]), ptpClock);
+void packClockIdentity( ClockIdentity *c, Octet *buf)
+	int i;
+		packOctet(&((*c)[i]),(buf+i));
+void
+freeClockIdentity( ClockIdentity *c) {
+	/* nothing to free */
+void
+unpackClockQuality( Octet *buf, ClockQuality *c, PtpClock *ptpClock)
+	int offset = 0;
+	ClockQuality* data = c;
+	#define OPERATE( name, size, type) \
+		unpack##type (buf + offset, &data->name, ptpClock); \
+	#include "../def/derivedData/clockQuality.def"
+void
+packClockQuality( ClockQuality *c, Octet *buf)
+	int offset = 0;
+	ClockQuality *data = c;
+		pack##type (&data->name, buf + offset); \
+void
+freeClockQuality( ClockQuality *c)
+void
+unpackTimeInterval( Octet *buf, TimeInterval *t, PtpClock *ptpClock)
+        int offset = 0;
+        TimeInterval* data = t;
+        #include "../def/derivedData/timeInterval.def"
+void
+packTimeInterval( TimeInterval *t, Octet *buf)
+        int offset = 0;
+        TimeInterval *data = t;
+void
+freeTimeInterval( TimeInterval *t)
+void
+unpackTimestamp( Octet *buf, Timestamp *t, PtpClock *ptpClock)
+        int offset = 0;
+        Timestamp* data = t;
+        #include "../def/derivedData/timestamp.def"
+void
+packTimestamp( Timestamp *t, Octet *buf)
+        int offset = 0;
+        Timestamp *data = t;
+void
+freeTimestamp( Timestamp *t)
+void
+unpackPortIdentity( Octet *buf, PortIdentity *p, PtpClock *ptpClock)
+	int offset = 0;
+	PortIdentity* data = p;
+	#include "../def/derivedData/portIdentity.def"
+void
+packPortIdentity( PortIdentity *p, Octet *buf)
+	int offset = 0;
+	PortIdentity *data = p;
+void
+freePortIdentity( PortIdentity *p)
+void
+unpackPortAddress( Octet *buf, PortAddress *p, PtpClock *ptpClock)
+	unpackEnumeration16( buf, &p->networkProtocol, ptpClock);
+	unpackUInteger16( buf+2, &p->addressLength, ptpClock);
+	if(p->addressLength) {
+		XMALLOC(p->addressField, p->addressLength);
+		memcpy( p->addressField, buf+4, p->addressLength);
+	} else {
+		p->addressField = NULL;
+void
+packPortAddress(PortAddress *p, Octet *buf)
+	packEnumeration16(&p->networkProtocol, buf);
+	packUInteger16(&p->addressLength, buf+2);
+		memcpy( buf+4, p->addressField, p->addressLength);
+void
+freePortAddress(PortAddress *p)
+	if(p->addressField) {
+		free(p->addressField);
+void
+unpackPTPText( Octet *buf, PTPText *s, PtpClock *ptpClock)
+	unpackUInteger8( buf, &s->lengthField, ptpClock);
+	if(s->lengthField) {
+		XMALLOC(s->textField, s->lengthField);
+		memcpy( s->textField, buf+1, s->lengthField);
+	} else {
+		s->textField = NULL;
+void
+packPTPText(PTPText *s, Octet *buf)
+	packUInteger8(&s->lengthField, buf);
+		memcpy( buf+1, s->textField, s->lengthField);
+void
+freePTPText(PTPText *s)
+	if(s->textField) {
+		free(s->textField);
+void
+unpackPhysicalAddress( Octet *buf, PhysicalAddress *p, PtpClock *ptpClock)
+	unpackUInteger16( buf, &p->addressLength, ptpClock);
+		memcpy( p->addressField, buf+2, p->addressLength);
+	} else {
+void
+packPhysicalAddress(PhysicalAddress *p, Octet *buf)
+	packUInteger16(&p->addressLength, buf);
+		memcpy( buf+2, p->addressField, p->addressLength);
+void
+freePhysicalAddress(PhysicalAddress *p)
+void
+copyClockIdentity( ClockIdentity dest, ClockIdentity src)
+	memcpy(dest, src, CLOCK_IDENTITY_LENGTH);
+void
+copyPortIdentity( PortIdentity *dest, PortIdentity *src)
+	copyClockIdentity(dest->clockIdentity, src->clockIdentity);
+	dest->portNumber = src->portNumber;
+void
+unpackMsgHeader(Octet *buf, MsgHeader *header, PtpClock *ptpClock)
+	int offset = 0;
+	MsgHeader* data = header;
+	#include "../def/message/header.def"
+void
+packMsgHeader(MsgHeader *h, Octet *buf)
+	int offset = 0;
+	/* set uninitalized bytes to zero */
+	h->reserved0 = 0;
+	h->reserved1 = 0;
+	h->reserved2 = 0;
+		pack##type( &h->name, buf + offset ); \
+void
+unpackManagementTLV(Octet *buf, int baseOffset, MsgManagement *m, PtpClock* ptpClock)
+	int offset = 0;
+	XMALLOC(m->tlv, sizeof(ManagementTLV));
+	/* read the management TLV */
+		unpack##type( buf + baseOffset + MANAGEMENT_LENGTH + offset, &m->tlv->name, ptpClock ); \
+	#include "../def/managementTLV/managementTLV.def"
+void
+packManagementTLV(ManagementTLV *tlv, Octet *buf)
+	int offset = 0;
+		pack##type( &tlv->name, buf + MANAGEMENT_LENGTH + offset ); \
+void
+freeManagementTLV(MsgManagement *m)
+        /* cleanup outgoing managementTLV */
+        if(m->tlv) {
+                if(m->tlv->dataField) {
+                        if(m->tlv->tlvType == TLV_MANAGEMENT) {
+                                freeMMTLV(m->tlv);
+                        } else if(m->tlv->tlvType == TLV_MANAGEMENT_ERROR_STATUS) {
+                                freeMMErrorStatusTLV(m->tlv);
+                        free(m->tlv->dataField);
+			m->tlv->dataField = NULL;
+                free(m->tlv);
+		m->tlv = NULL;
+void
+packMsgManagement(MsgManagement *m, Octet *buf)
+	int offset = 0;
+	MsgManagement *data = m;
+	/* set unitialized bytes to zero */
+	m->reserved0 = 0;
+	m->reserved1 = 0;
+	#include "../def/message/management.def"
+void unpackMsgManagement(Octet *buf, MsgManagement *m, PtpClock *ptpClock)
+	int offset = 0;
+	MsgManagement* data = m;
+	#ifdef PTPD_DBG
+	msgManagement_display(data);
+void
+unpackSignalingTLV(Octet *buf, MsgSignaling *m, PtpClock* ptpClock)
+	int offset = 0;
+	XMALLOC(m->tlv, sizeof(SignalingTLV));
+	/* read the signaling TLV */
+		unpack##type( buf + SIGNALING_LENGTH + offset, &m->tlv->name, ptpClock ); \
+	#include "../def/signalingTLV/signalingTLV.def"
+void
+packSignalingTLV(SignalingTLV *tlv, Octet *buf)
+	int offset = 0;
+		pack##type( &tlv->name, buf + SIGNALING_LENGTH + offset ); \
+void
+freeSignalingTLV(MsgSignaling *m)
+        /* cleanup outgoing signaling TLV */
+        if(m->tlv) {
+                if(m->tlv->valueField) {
+                        free(m->tlv->valueField);
+			m->tlv->valueField = NULL;
+                free(m->tlv);
+		m->tlv = NULL;
+void
+packMsgSignaling(MsgSignaling *m, Octet *buf)
+	int offset = 0;
+	MsgSignaling *data = m;
+	#include "../def/message/signaling.def"
+void
+unpackMsgSignaling(Octet *buf, MsgSignaling *m, PtpClock *ptpClock)
+	int offset = 0;
+	MsgSignaling* data = m;
+	#ifdef PTPD_DBG
+	msgSignaling_display(data);
+/*Unpack Header from IN buffer to msgTmpHeader field */
+void
+msgUnpackHeader(Octet * buf, MsgHeader * header)
+	header->transportSpecific = (*(Nibble *) (buf + 0)) >> 4;
+	header->messageType = (*(Enumeration4 *) (buf + 0)) & 0x0F;
+	header->versionPTP = (*(UInteger4 *) (buf + 1)) & 0x0F;
+	/* force reserved bit to zero if not */
+	header->messageLength = flip16(*(UInteger16 *) (buf + 2));
+	header->domainNumber = (*(UInteger8 *) (buf + 4));
+	header->flagField0 = (*(Octet *) (buf + 6));
+	header->flagField1 = (*(Octet *) (buf + 7));
+	memcpy(&header->correctionField.msb, (buf + 8), 4);
+	memcpy(&header->correctionField.lsb, (buf + 12), 4);
+	header->correctionField.msb = flip32(header->correctionField.msb);
+	header->correctionField.lsb = flip32(header->correctionField.lsb);
+	copyClockIdentity(header->sourcePortIdentity.clockIdentity, (buf + 20));
+	header->sourcePortIdentity.portNumber =
+		flip16(*(UInteger16 *) (buf + 28));
+	header->sequenceId = flip16(*(UInteger16 *) (buf + 30));
+	header->controlField = (*(UInteger8 *) (buf + 32));
+	header->logMessageInterval = (*(Integer8 *) (buf + 33));
+#ifdef PTPD_DBG
+	msgHeader_display(header);
+#endif /* PTPD_DBG */
+/*Pack header message into OUT buffer of ptpClock*/
+void
+msgPackHeader(Octet * buf, PtpClock * ptpClock)
+	/* (spec annex D) */
+	*(UInteger8 *) (buf + 0) = ptpClock->portDS.transportSpecific << 4;
+	*(UInteger4 *) (buf + 1) = ptpClock->portDS.versionNumber;
+	*(UInteger8 *) (buf + 4) = ptpClock->defaultDS.domainNumber;
+	/* clear flag field - message packing functions should populate it */
+	memset((buf + 6), 0, 2);
+	memset((buf + 8), 0, 8);
+	copyClockIdentity((buf + 20), ptpClock->portDS.portIdentity.clockIdentity);
+	*(UInteger16 *) (buf + 28) = flip16(ptpClock->portDS.portIdentity.portNumber);
+	/* LogMessageInterval defaults to 0x7F, will be set to another value if needed as per table 24*/
+	*(UInteger8 *) (buf + 33) = 0x7F;
+#ifndef PTPD_SLAVE_ONLY
+/*Pack SYNC message into OUT buffer of ptpClock*/
+void
+msgPackSync(Octet * buf, UInteger16 sequenceId, Timestamp * originTimestamp, PtpClock * ptpClock)
+	msgPackHeader(buf, ptpClock);
+	/* changes in header */
+	*(char *)(buf + 0) = *(char *)(buf + 0) & 0xF0;
+	/* RAZ messageType */
+	*(char *)(buf + 0) = *(char *)(buf + 0) | 0x00;
+	/* Two step flag - table 20: Sync and PdelayResp only */
+	if (ptpClock->defaultDS.twoStepFlag)
+		*(UInteger8 *) (buf + 6) |= PTP_TWO_STEP;
+	/* Table 19 */
+	*(UInteger16 *) (buf + 2) = flip16(SYNC_LENGTH);
+	*(UInteger16 *) (buf + 30) = flip16(sequenceId);
+	*(UInteger8 *) (buf + 32) = 0x00;
+	 /* Table 24 - unless it's multicast, logMessageInterval remains    0x7F */
+	 if(rtOpts.transport == IEEE_802_3 || rtOpts.ipMode != IPMODE_UNICAST )
+		*(Integer8 *) (buf + 33) = ptpClock->portDS.logSyncInterval;
+	/* Sync message */
+	*(UInteger16 *) (buf + 34) = flip16(originTimestamp->secondsField.msb);
+	*(UInteger32 *) (buf + 36) = flip32(originTimestamp->secondsField.lsb);
+	*(UInteger32 *) (buf + 40) = flip32(originTimestamp->nanosecondsField);
+#endif /* PTPD_SLAVE_ONLY */
+/*Unpack Sync message from IN buffer */
+void
+msgUnpackSync(Octet * buf, MsgSync * sync)
+	sync->originTimestamp.secondsField.msb =
+		flip16(*(UInteger16 *) (buf + 34));
+	sync->originTimestamp.secondsField.lsb =
+		flip32(*(UInteger32 *) (buf + 36));
+	sync->originTimestamp.nanosecondsField =
+		flip32(*(UInteger32 *) (buf + 40));
+#ifdef PTPD_DBG
+	msgSync_display(sync);
+/* When building slave only, this code does not get compiled */
+/*Pack Announce message into OUT buffer of ptpClock*/
+void
+msgPackAnnounce(Octet * buf, UInteger16 sequenceId, Timestamp * originTimestamp, PtpClock * ptpClock)
+	UInteger16 stepsRemoved;
+	*(char *)(buf + 0) = *(char *)(buf + 0) | 0x0B;
+	/* Table 19 */
+	*(UInteger16 *) (buf + 2) = flip16(ANNOUNCE_LENGTH);
+	*(UInteger8 *) (buf + 32) = 0x05;
+	/* Table 24: for Announce, logMessageInterval is never 0x7F */
+	*(Integer8 *) (buf + 33) = ptpClock->portDS.logAnnounceInterval;
+	/* Announce message */
+	*(Integer16 *) (buf + 44) = flip16(ptpClock->timePropertiesDS.currentUtcOffset);
+	*(UInteger8 *) (buf + 47) = ptpClock->parentDS.grandmasterPriority1;
+	*(UInteger8 *) (buf + 48) = ptpClock->defaultDS.clockQuality.clockClass;
+	*(Enumeration8 *) (buf + 49) = ptpClock->defaultDS.clockQuality.clockAccuracy;
+	*(UInteger16 *) (buf + 50) =
+		flip16(ptpClock->defaultDS.clockQuality.offsetScaledLogVariance);
+	*(UInteger8 *) (buf + 52) = ptpClock->parentDS.grandmasterPriority2;
+	copyClockIdentity((buf + 53), ptpClock->parentDS.grandmasterIdentity);
+	/* resolve bugs #37 and #40 - alignment errors on ARMv5 */
+	stepsRemoved = flip16(ptpClock->currentDS.stepsRemoved);
+	memcpy(buf + 61, &stepsRemoved, sizeof(UInteger16));
+	*(Enumeration8 *) (buf + 63) = ptpClock->timePropertiesDS.timeSource;
+	 * TimePropertiesDS in FlagField, 2nd octet - spec 13.3.2.6 table 20
+	 * Could / should have used constants here PTP_LI_61 etc, but this is clean
+	*(UInteger8*) (buf + 7) = ptpClock->timePropertiesDS.leap61			<< 0;
+	*(UInteger8*) (buf + 7) |= (ptpClock->timePropertiesDS.leap59)			<< 1;
+	*(UInteger8*) (buf + 7) |= (ptpClock->timePropertiesDS.currentUtcOffsetValid)	<< 2;
+	*(UInteger8*) (buf + 7) |= (ptpClock->timePropertiesDS.ptpTimescale)		<< 3;
+	*(UInteger8*) (buf + 7) |= (ptpClock->timePropertiesDS.timeTraceable)		<< 4;
+	*(UInteger8*) (buf + 7) |= (ptpClock->timePropertiesDS.frequencyTraceable)	<< 5;
+/*Unpack Announce message from IN buffer of ptpClock to msgtmp.Announce*/
+void
+msgUnpackAnnounce(Octet * buf, MsgAnnounce * announce)
+	announce->originTimestamp.secondsField.msb =
+	announce->originTimestamp.secondsField.lsb =
+	announce->originTimestamp.nanosecondsField =
+	announce->currentUtcOffset = flip16(*(UInteger16 *) (buf + 44));
+	announce->grandmasterPriority1 = *(UInteger8 *) (buf + 47);
+	announce->grandmasterClockQuality.clockClass =
+		*(UInteger8 *) (buf + 48);
+	announce->grandmasterClockQuality.clockAccuracy =
+		*(Enumeration8 *) (buf + 49);
+	announce->grandmasterClockQuality.offsetScaledLogVariance =
+		flip16(*(UInteger16 *) (buf + 50));
+	announce->grandmasterPriority2 = *(UInteger8 *) (buf + 52);
+	copyClockIdentity(announce->grandmasterIdentity, (buf + 53));
+	memcpy(&stepsRemoved, buf + 61, sizeof(UInteger16));
+	announce->stepsRemoved = flip16(stepsRemoved);
+	announce->timeSource = *(Enumeration8 *) (buf + 63);
+	#ifdef PTPD_DBG
+	msgAnnounce_display(announce);
+#ifndef PTPD_SLAVE_ONLY /* does not get compiled when building slave only */
+/*pack Follow_up message into OUT buffer of ptpClock*/
+void
+msgPackFollowUp(Octet * buf, Timestamp * preciseOriginTimestamp, PtpClock * ptpClock, const UInteger16 sequenceId)
+	*(char *)(buf + 0) = *(char *)(buf + 0) | 0x08;
+	/* Table 19 */
+	*(UInteger16 *) (buf + 2) = flip16(FOLLOW_UP_LENGTH);
+	*(UInteger8 *) (buf + 32) = 0x02;
+	 if(rtOpts.transport == IEEE_802_3 || rtOpts.ipMode != IPMODE_UNICAST)
+	/* Follow_up message */
+		flip16(preciseOriginTimestamp->secondsField.msb);
+		flip32(preciseOriginTimestamp->secondsField.lsb);
+		flip32(preciseOriginTimestamp->nanosecondsField);
+/*Unpack Follow_up message from IN buffer of ptpClock to msgtmp.follow*/
+void
+msgUnpackFollowUp(Octet * buf, MsgFollowUp * follow)
+	follow->preciseOriginTimestamp.secondsField.msb =
+	follow->preciseOriginTimestamp.secondsField.lsb =
+	follow->preciseOriginTimestamp.nanosecondsField =
+	#ifdef PTPD_DBG
+	msgFollowUp_display(follow);
+/*pack PdelayReq message into OUT buffer of ptpClock*/
+void
+msgPackPdelayReq(Octet * buf, Timestamp * originTimestamp, PtpClock * ptpClock)
+	*(char *)(buf + 0) = *(char *)(buf + 0) | 0x02;
+	/* Table 19 */
+	*(UInteger16 *) (buf + 2) = flip16(PDELAY_REQ_LENGTH);
+	*(UInteger16 *) (buf + 30) = flip16(ptpClock->sentPdelayReqSequenceId);
+	/* Table 23 */
+	*(Integer8 *) (buf + 33) = 0x7F;
+	/* Table 24 */
+	/* Pdelay_req message */
+	memset((buf + 44), 0, 10);
+	/* RAZ reserved octets */
+/*pack delayReq message into OUT buffer of ptpClock*/
+void
+msgPackDelayReq(Octet * buf, Timestamp * originTimestamp, PtpClock * ptpClock)
+	*(char *)(buf + 0) = *(char *)(buf + 0) | 0x01;
+	/* Table 19 */
+	*(UInteger16 *) (buf + 2) = flip16(DELAY_REQ_LENGTH);
+	/* -- PTP_UNICAST flag will be set in netsend* if needed */
+	*(UInteger16 *) (buf + 30) = flip16(ptpClock->sentDelayReqSequenceId);
+	*(UInteger8 *) (buf + 32) = 0x01;
+	/* Table 23 */
+	/* Table 24 */
+/*pack delayResp message into OUT buffer of ptpClock*/
+void
+msgPackDelayResp(Octet * buf, MsgHeader * header, Timestamp * receiveTimestamp, PtpClock * ptpClock)
+	*(char *)(buf + 0) = *(char *)(buf + 0) | 0x09;
+	/* Table 19 */
+	*(UInteger16 *) (buf + 2) = flip16(DELAY_RESP_LENGTH);
+	*(UInteger8 *) (buf + 4) = header->domainNumber;
+	/* Copy correctionField of PdelayReqMessage */
+	*(Integer32 *) (buf + 8) = flip32(header->correctionField.msb);
+	*(Integer32 *) (buf + 12) = flip32(header->correctionField.lsb);
+	*(UInteger16 *) (buf + 30) = flip16(header->sequenceId);
+	*(UInteger8 *) (buf + 32) = 0x03;
+	 /* really tempting to cheat here, at least for hybrid, but standard is a standard */
+	if ((header->flagField0 & PTP_UNICAST) != PTP_UNICAST) {
+	    *(Integer8 *) (buf + 33) = ptpClock->portDS.logMinDelayReqInterval;
+	/* Pdelay_resp message */
+		flip16(receiveTimestamp->secondsField.msb);
+	*(UInteger32 *) (buf + 36) = flip32(receiveTimestamp->secondsField.lsb);
+	*(UInteger32 *) (buf + 40) = flip32(receiveTimestamp->nanosecondsField);
+	copyClockIdentity((buf + 44), header->sourcePortIdentity.clockIdentity);
+	*(UInteger16 *) (buf + 52) =
+		flip16(header->sourcePortIdentity.portNumber);
+/*pack PdelayResp message into OUT buffer of ptpClock*/
+void
+msgPackPdelayResp(Octet * buf, MsgHeader * header, Timestamp * requestReceiptTimestamp, PtpClock * ptpClock)
+	*(char *)(buf + 0) = *(char *)(buf + 0) | 0x03;
+	/* Table 19 */
+	*(UInteger16 *) (buf + 2) = flip16(PDELAY_RESP_LENGTH);
+	/* Table 23 */
+	/* Table 24 */
+	*(UInteger16 *) (buf + 34) = flip16(requestReceiptTimestamp->secondsField.msb);
+	*(UInteger32 *) (buf + 36) = flip32(requestReceiptTimestamp->secondsField.lsb);
+	*(UInteger32 *) (buf + 40) = flip32(requestReceiptTimestamp->nanosecondsField);
+	*(UInteger16 *) (buf + 52) = flip16(header->sourcePortIdentity.portNumber);
+/*Unpack delayReq message from IN buffer of ptpClock to msgtmp.req*/
+void
+msgUnpackDelayReq(Octet * buf, MsgDelayReq * delayreq)
+	delayreq->originTimestamp.secondsField.msb =
+	delayreq->originTimestamp.secondsField.lsb =
+	delayreq->originTimestamp.nanosecondsField =
+	#ifdef PTPD_DBG
+	msgDelayReq_display(delayreq);
+/*Unpack PdelayReq message from IN buffer of ptpClock to msgtmp.req*/
+void
+msgUnpackPdelayReq(Octet * buf, MsgPdelayReq * pdelayreq)
+	pdelayreq->originTimestamp.secondsField.msb =
+	pdelayreq->originTimestamp.secondsField.lsb =
+	pdelayreq->originTimestamp.nanosecondsField =
+	#ifdef PTPD_DBG
+	msgPdelayReq_display(pdelayreq);
+/*Unpack delayResp message from IN buffer of ptpClock to msgtmp.presp*/
+void
+msgUnpackDelayResp(Octet * buf, MsgDelayResp * resp)
+	resp->receiveTimestamp.secondsField.msb =
+	resp->receiveTimestamp.secondsField.lsb =
+	resp->receiveTimestamp.nanosecondsField =
+	copyClockIdentity(resp->requestingPortIdentity.clockIdentity,
+	       (buf + 44));
+	resp->requestingPortIdentity.portNumber =
+		flip16(*(UInteger16 *) (buf + 52));
+	#ifdef PTPD_DBG
+	msgDelayResp_display(resp);
+/*Unpack PdelayResp message from IN buffer of ptpClock to msgtmp.presp*/
+void
+msgUnpackPdelayResp(Octet * buf, MsgPdelayResp * presp)
+	presp->requestReceiptTimestamp.secondsField.msb =
+	presp->requestReceiptTimestamp.secondsField.lsb =
+	presp->requestReceiptTimestamp.nanosecondsField =
+	copyClockIdentity(presp->requestingPortIdentity.clockIdentity,
+	       (buf + 44));
+	presp->requestingPortIdentity.portNumber =
+	#ifdef PTPD_DBG
+	msgPdelayResp_display(presp);
+/*pack PdelayRespfollowup message into OUT buffer of ptpClock*/
+void
+msgPackPdelayRespFollowUp(Octet * buf, MsgHeader * header, Timestamp * responseOriginTimestamp, PtpClock * ptpClock, const UInteger16 sequenceId)
+	*(char *)(buf + 0) = *(char *)(buf + 0) | 0x0A;
+	/* Table 19 */
+	*(UInteger16 *) (buf + 2) = flip16(PDELAY_RESP_FOLLOW_UP_LENGTH);
+	/* Table 23 */
+	/* Table 24 */
+	/* Pdelay_resp_follow_up message */
+		flip16(responseOriginTimestamp->secondsField.msb);
+		flip32(responseOriginTimestamp->secondsField.lsb);
+		flip32(responseOriginTimestamp->nanosecondsField);
+void
+msgUnpackPdelayRespFollowUp(Octet * buf, MsgPdelayRespFollowUp * prespfollow)
+	prespfollow->responseOriginTimestamp.secondsField.msb =
+	prespfollow->responseOriginTimestamp.secondsField.lsb =
+	prespfollow->responseOriginTimestamp.nanosecondsField =
+	copyClockIdentity(prespfollow->requestingPortIdentity.clockIdentity,
+	       (buf + 44));
+	prespfollow->requestingPortIdentity.portNumber =
+#ifdef PTPD_DBG
+        msgPdelayRespFollowUp_display(prespfollow);
+/* Pack Management message into OUT buffer */
+void
+msgPackManagementTLV(Octet *buf, MsgManagement *outgoing, PtpClock *ptpClock)
+        DBGV("packing ManagementTLV message \n");
+	UInteger16 dataLength = 0;
+	switch(outgoing->tlv->managementId)
+	case MM_NULL_MANAGEMENT:
+	case MM_SAVE_IN_NON_VOLATILE_STORAGE:
+	case MM_RESET_NON_VOLATILE_STORAGE:
+	case MM_ENABLE_PORT:
+	case MM_DISABLE_PORT:
+		dataLength = 0;
+		break;
+	case MM_CLOCK_DESCRIPTION:
+		dataLength = packMMClockDescription(outgoing, buf);
+		#ifdef PTPD_DBG
+				(MMClockDescription*)outgoing->tlv->dataField, ptpClock);
+		break;
+        case MM_USER_DESCRIPTION:
+                dataLength = packMMUserDescription(outgoing, buf);
+                #ifdef PTPD_DBG
+                mMUserDescription_display(
+                                (MMUserDescription*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_INITIALIZE:
+                dataLength = packMMInitialize(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMInitialize*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_DEFAULT_DATA_SET:
+                dataLength = packMMDefaultDataSet(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMDefaultDataSet*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_CURRENT_DATA_SET:
+                dataLength = packMMCurrentDataSet(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMCurrentDataSet*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_PARENT_DATA_SET:
+                dataLength = packMMParentDataSet(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMParentDataSet*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_TIME_PROPERTIES_DATA_SET:
+                dataLength = packMMTimePropertiesDataSet(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMTimePropertiesDataSet*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_PORT_DATA_SET:
+                dataLength = packMMPortDataSet(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMPortDataSet*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_PRIORITY1:
+                dataLength = packMMPriority1(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMPriority1*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_PRIORITY2:
+                dataLength = packMMPriority2(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMPriority2*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_DOMAIN:
+                dataLength = packMMDomain(outgoing, buf);
+                #ifdef PTPD_DBG
+                mMDomain_display(
+                                (MMDomain*)outgoing->tlv->dataField, ptpClock);
+                break;
+	case MM_SLAVE_ONLY:
+		dataLength = packMMSlaveOnly(outgoing, buf);
+		#ifdef PTPD_DBG
+				(MMSlaveOnly*)outgoing->tlv->dataField, ptpClock);
+		break;
+        case MM_LOG_ANNOUNCE_INTERVAL:
+                dataLength = packMMLogAnnounceInterval(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMLogAnnounceInterval*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_ANNOUNCE_RECEIPT_TIMEOUT:
+                dataLength = packMMAnnounceReceiptTimeout(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMAnnounceReceiptTimeout*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_LOG_SYNC_INTERVAL:
+                dataLength = packMMLogSyncInterval(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMLogSyncInterval*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_VERSION_NUMBER:
+                dataLength = packMMVersionNumber(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMVersionNumber*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_TIME:
+                dataLength = packMMTime(outgoing, buf);
+                #ifdef PTPD_DBG
+                mMTime_display(
+                                (MMTime*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_CLOCK_ACCURACY:
+                dataLength = packMMClockAccuracy(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMClockAccuracy*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_UTC_PROPERTIES:
+                dataLength = packMMUtcProperties(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMUtcProperties*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_TRACEABILITY_PROPERTIES:
+                dataLength = packMMTraceabilityProperties(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMTraceabilityProperties*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_UNICAST_NEGOTIATION_ENABLE:
+                dataLength = packMMUnicastNegotiationEnable(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMUnicastNegotiationEnable*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_DELAY_MECHANISM:
+                dataLength = packMMDelayMechanism(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMDelayMechanism*)outgoing->tlv->dataField, ptpClock);
+                break;
+        case MM_LOG_MIN_PDELAY_REQ_INTERVAL:
+                dataLength = packMMLogMinPdelayReqInterval(outgoing, buf);
+                #ifdef PTPD_DBG
+                                (MMLogMinPdelayReqInterval*)outgoing->tlv->dataField, ptpClock);
+                break;
+	default:
+		DBGV("packing management msg: unsupported id \n");
+	/* set the outgoing tlv lengthField to 2 + N where 2 is the managementId field
+         * and N is dataLength, the length of the management tlv dataField field.
+	 * See Table 39 of the spec.
+	outgoing->tlv->lengthField = 2 + dataLength;
+	packManagementTLV((ManagementTLV*)outgoing->tlv, buf);
+/* Pack ManagementErrorStatusTLV message into OUT buffer */
+void
+msgPackManagementErrorStatusTLV(Octet *buf, MsgManagement *outgoing,
+				PtpClock *ptpClock)
+        DBGV("packing ManagementErrorStatusTLV message \n");
+	dataLength = packMMErrorStatus(outgoing, buf);
+	#ifdef PTPD_DBG
+	mMErrorStatus_display((MMErrorStatus*)outgoing->tlv->dataField, ptpClock);
+	/* set the outgoing tlv lengthField to 2 + (6 + N) where 2 is the
+ 	 * managementErrorId field and (6 + N) is dataLength, where 6 is
+ 	 * the managementId and reserved field and N is the displayData field
+ 	 * and optional pad field. See Table 71 of the spec.
+/* Pack  singaling message into OUT buffer */
+void
+msgPackSignalingTLV(Octet *buf, MsgSignaling *outgoing, PtpClock *ptpClock)
+        DBGV("packing SignalingTLV message \n");
+	switch(outgoing->tlv->tlvType)
+	case TLV_REQUEST_UNICAST_TRANSMISSION:
+		dataLength = packSMRequestUnicastTransmission(outgoing, buf);
+		break;
+	case TLV_GRANT_UNICAST_TRANSMISSION:
+		dataLength = packSMGrantUnicastTransmission(outgoing, buf);
+		break;
+	case TLV_CANCEL_UNICAST_TRANSMISSION:
+		dataLength = packSMCancelUnicastTransmission(outgoing, buf);
+		break;
+	case TLV_ACKNOWLEDGE_CANCEL_UNICAST_TRANSMISSION:
+		dataLength = packSMAcknowledgeCancelUnicastTransmission(outgoing, buf);
+		break;
+	default:
+		DBGV("packing signaling msg: unsupported tlv type \n");
+	outgoing->tlv->lengthField = dataLength;
+	packSignalingTLV((SignalingTLV*)outgoing->tlv, buf);
+void
+freeMMTLV(ManagementTLV* tlv) {
+	DBGV("cleanup managementTLV data\n");
+	switch(tlv->managementId)
+		DBGV("cleanup clock description \n");
+		freeMMClockDescription((MMClockDescription*)tlv->dataField);
+		break;
+		DBGV("cleanup user description \n");
+		freeMMUserDescription((MMUserDescription*)tlv->dataField);
+		break;
+	case MM_DOMAIN:
+	case MM_TIME:
+	default:
+		DBGV("no managementTLV data to cleanup \n");
+void
+freeMMErrorStatusTLV(ManagementTLV *tlv) {
+	DBGV("cleanup managementErrorStatusTLV data \n");
+	freeMMErrorStatus((MMErrorStatus*)tlv->dataField);
+void
+msgPackManagement(Octet *buf, MsgManagement *outgoing, PtpClock *ptpClock)
+	DBGV("packing management message \n");
+	packMsgManagement(outgoing, buf);
+ * Unpack Management message from IN buffer of ptpClock to msgtmp.manage
+ * return TRUE if there are more packed TLVs left in the message
+Boolean
+msgUnpackManagement(Octet *buf, MsgManagement * manage, MsgHeader * header, PtpClock *ptpClock, const int tlvOffset)
+	unpackMsgManagement(buf, manage, ptpClock);
+	if ( manage->header.messageLength >= (MANAGEMENT_LENGTH + tlvOffset + TL_LENGTH) )
+		unpackManagementTLV(buf, tlvOffset, manage, ptpClock);
+		/* at this point, we know what managementTLV we have, so return and
+		 * let someone else handle the data */
+		manage->tlv->dataField = NULL;
+		return TRUE;
+	else /* no (more) TLV attached to this message */
+		manage->tlv = NULL;
+		return FALSE;
+void
+msgPackSignaling(Octet *buf, MsgSignaling *outgoing, PtpClock *ptpClock)
+	DBGV("packing signaling message \n");
+	packMsgSignaling(outgoing, buf);
+ * Unpack Signaling message from IN buffer of ptpClock to msgtmp.signaling
+ * return TRUE if there are more packed TLVs left in the message.
+Boolean
+msgUnpackSignaling(Octet *buf, MsgSignaling * signaling, MsgHeader * header, PtpClock *ptpClock, const int tlvOffset)
+	unpackMsgSignaling(buf, signaling, ptpClock);
+	if ( signaling->header.messageLength >= (SIGNALING_LENGTH + tlvOffset + TL_LENGTH) )
+		unpackSignalingTLV(buf + tlvOffset, signaling, ptpClock);
+		DBGV("Signaling seq %d: Found TLV type 0x%04x: %d bytes left\n", header->sequenceId,
+			signaling->tlv->tlvType,signaling->header.messageLength - SIGNALING_LENGTH - tlvOffset);
+		signaling->tlv->valueField = NULL;
+		return TRUE;
+	else /* no (more) TLVs attached to this message */
+		signaling->tlv = NULL;
+		DBGV("Signaling seq %d: No more TLVs in message\n", header->sequenceId);
+		return FALSE;
+ * Dump the most recent packet in the daemon
+ * @param ptpClock The central clock structure
+void msgDump(PtpClock *ptpClock)
+#if defined(freebsd)
+	static int dumped = 0;
+#endif /* FreeBSD */
+	msgDebugHeader(&ptpClock->msgTmpHeader);
+	switch (ptpClock->msgTmpHeader.messageType) {
+	case SYNC:
+		msgDebugSync(&ptpClock->msgTmp.sync);
+		break;
+	case ANNOUNCE:
+		msgDebugAnnounce(&ptpClock->msgTmp.announce);
+		break;
+	case FOLLOW_UP:
+		msgDebugFollowUp(&ptpClock->msgTmp.follow);
+		break;
+	case DELAY_REQ:
+		msgDebugDelayReq(&ptpClock->msgTmp.req);
+		break;
+	case DELAY_RESP:
+		msgDebugDelayResp(&ptpClock->msgTmp.resp);
+		break;
+	case MANAGEMENT:
+		msgDebugManagement(&ptpClock->msgTmp.manage);
+		break;
+	case SIGNALING:
+		NOTIFY("* msgDebugSignaling not implemented *\n");
+		/* TODO: IMPLEMENT ME */
+		/* msgDebugSignaling(&ptpClock->msgTmp.signaling); */
+		break;
+	default:
+		NOTIFY("msgDump:unrecognized message\n");
+		break;
+	/* Only dump the first time, after that just do a message. */
+	if (dumped != 0)
+		return;
+	dumped++;
+	NOTIFY("msgDump: core file created.\n");
+	switch(rfork(RFFDG|RFPROC|RFNOWAIT)) {
+	case -1:
+		NOTIFY("could not fork to core dump! errno: %s",
+		       strerror(errno));
+		break;
+	case 0:
+		abort(); /* Generate a core dump */
+	default:
+		/* This default intentionally left blank. */
+		break;
+ * Dump a PTP message header
+ * @param header a pre-filled msg header structure
+void msgDebugHeader(MsgHeader *header)
+	NOTIFY("msgDebugHeader: messageType %d\n", header->messageType);
+	NOTIFY("msgDebugHeader: versionPTP %d\n", header->versionPTP);
+	NOTIFY("msgDebugHeader: messageLength %d\n", header->messageLength);
+	NOTIFY("msgDebugHeader: domainNumber %d\n", header->domainNumber);
+	NOTIFY("msgDebugHeader: flags %02hhx %02hhx\n",
+	       header->flagField0, header->flagField1);
+	NOTIFY("msgDebugHeader: correctionfield %d\n", header->correctionField);
+	NOTIFY("msgDebugHeader: sourcePortIdentity.clockIdentity "
+	       "%02hhx:%02hhx:%02hhx:%02hhx:%02hhx:%02hhx%02hhx:%02hhx\n",
+	       header->sourcePortIdentity.clockIdentity[0],
+	       header->sourcePortIdentity.clockIdentity[1],
+	       header->sourcePortIdentity.clockIdentity[2],
+	       header->sourcePortIdentity.clockIdentity[3],
+	       header->sourcePortIdentity.clockIdentity[4],
+	       header->sourcePortIdentity.clockIdentity[5],
+	       header->sourcePortIdentity.clockIdentity[6],
+	       header->sourcePortIdentity.clockIdentity[7]);
+	NOTIFY("msgDebugHeader: sourcePortIdentity.portNumber %d\n",
+	       header->sourcePortIdentity.portNumber);
+	NOTIFY("msgDebugHeader: sequenceId %d\n", header->sequenceId);
+	NOTIFY("msgDebugHeader: controlField %d\n", header->controlField);
+	NOTIFY("msgDebugHeader: logMessageIntervale %d\n",
+	       header->logMessageInterval);
+ * Dump the contents of a sync packet
+ * @param sync A pre-filled MsgSync structure
+void msgDebugSync(MsgSync *sync)
+	NOTIFY("msgDebugSync: originTimestamp.seconds %u\n",
+	       sync->originTimestamp.secondsField);
+	NOTIFY("msgDebugSync: originTimestamp.nanoseconds %d\n",
+	       sync->originTimestamp.nanosecondsField);
+ * Dump the contents of a announce packet
+ * @param sync A pre-filled MsgAnnounce structure
+void msgDebugAnnounce(MsgAnnounce *announce)
+	NOTIFY("msgDebugAnnounce: originTimestamp.seconds %u\n",
+	       announce->originTimestamp.secondsField);
+	NOTIFY("msgDebugAnnounce: originTimestamp.nanoseconds %d\n",
+	       announce->originTimestamp.nanosecondsField);
+	NOTIFY("msgDebugAnnounce: currentUTCOffset %d\n",
+	       announce->currentUtcOffset);
+	NOTIFY("msgDebugAnnounce: grandmasterPriority1 %d\n",
+	       announce->grandmasterPriority1);
+	NOTIFY("msgDebugAnnounce: grandmasterClockQuality.clockClass %d\n",
+	       announce->grandmasterClockQuality.clockClass);
+	NOTIFY("msgDebugAnnounce: grandmasterClockQuality.clockAccuracy %d\n",
+	       announce->grandmasterClockQuality.clockAccuracy);
+	NOTIFY("msgDebugAnnounce: "
+	       "grandmasterClockQuality.offsetScaledLogVariance %d\n",
+	       announce->grandmasterClockQuality.offsetScaledLogVariance);
+	NOTIFY("msgDebugAnnounce: grandmasterPriority2 %d\n",
+	       announce->grandmasterPriority2);
+	NOTIFY("msgDebugAnnounce: grandmasterClockIdentity "
+	       announce->grandmasterIdentity[0],
+	       announce->grandmasterIdentity[1],
+	       announce->grandmasterIdentity[2],
+	       announce->grandmasterIdentity[3],
+	       announce->grandmasterIdentity[4],
+	       announce->grandmasterIdentity[5],
+	       announce->grandmasterIdentity[6],
+	       announce->grandmasterIdentity[7]);
+	NOTIFY("msgDebugAnnounce: stepsRemoved %d\n",
+	       announce->stepsRemoved);
+	NOTIFY("msgDebugAnnounce: timeSource %d\n",
+	       announce->timeSource);
+ * NOT IMPLEMENTED
+ * @param req
+void msgDebugDelayReq(MsgDelayReq *req) {}
+ * Dump the contents of a followup packet
+ * @param follow A pre-fille MsgFollowUp structure
+void msgDebugFollowUp(MsgFollowUp *follow)
+	NOTIFY("msgDebugFollowUp: preciseOriginTimestamp.seconds %u\n",
+	       follow->preciseOriginTimestamp.secondsField);
+	NOTIFY("msgDebugFollowUp: preciseOriginTimestamp.nanoseconds %d\n",
+	       follow->preciseOriginTimestamp.nanosecondsField);
+ * Dump the contents of a delay response packet
+ * @param resp a pre-filled MsgDelayResp structure
+void msgDebugDelayResp(MsgDelayResp *resp)
+	NOTIFY("msgDebugDelayResp: delayReceiptTimestamp.seconds %u\n",
+	       resp->receiveTimestamp.secondsField);
+	NOTIFY("msgDebugDelayResp: delayReceiptTimestamp.nanoseconds %d\n",
+	       resp->receiveTimestamp.nanosecondsField);
+	NOTIFY("msgDebugDelayResp: requestingPortIdentity.clockIdentity "
+	       resp->requestingPortIdentity.clockIdentity[0],
+	       resp->requestingPortIdentity.clockIdentity[1],
+	       resp->requestingPortIdentity.clockIdentity[2],
+	       resp->requestingPortIdentity.clockIdentity[3],
+	       resp->requestingPortIdentity.clockIdentity[4],
+	       resp->requestingPortIdentity.clockIdentity[5],
+	       resp->requestingPortIdentity.clockIdentity[6],
+	       resp->requestingPortIdentity.clockIdentity[7]);
+	NOTIFY("msgDebugDelayResp: requestingPortIdentity.portNumber %d\n",
+	       resp->requestingPortIdentity.portNumber);
+ * Dump the contents of management packet
+ * @param manage a pre-filled MsgManagement structure
+void msgDebugManagement(MsgManagement *manage)
+	NOTIFY("msgDebugDelayManage: targetPortIdentity.clockIdentity "
+	       "%02hhx:%02hhx:%02hhx:%02hhx:%02hhx:%02hhx:%02hhx:%02hhx\n",
+	       manage->targetPortIdentity.clockIdentity[0],
+	       manage->targetPortIdentity.clockIdentity[1],
+	       manage->targetPortIdentity.clockIdentity[2],
+	       manage->targetPortIdentity.clockIdentity[3],
+	       manage->targetPortIdentity.clockIdentity[4],
+	       manage->targetPortIdentity.clockIdentity[5],
+	       manage->targetPortIdentity.clockIdentity[6],
+	       manage->targetPortIdentity.clockIdentity[7]);
+	NOTIFY("msgDebugDelayManage: targetPortIdentity.portNumber %d\n",
+	       manage->targetPortIdentity.portNumber);
+	NOTIFY("msgDebugManagement: startingBoundaryHops %d\n",
+	       manage->startingBoundaryHops);
+	NOTIFY("msgDebugManagement: boundaryHops %d\n", manage->boundaryHops);
+	NOTIFY("msgDebugManagement: actionField %d\n", manage->actionField);
+	NOTIFY("msgDebugManagement: tvl %s\n", manage->tlv);
diff --git a/freebsd/contrib/ptpd/src/dep/net.c b/freebsd/contrib/ptpd/src/dep/net.c
index 00000000..7e185728
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/net.c
@@ -0,0 +1,2300 @@
+ * Copyright (c) 2014-2015 Wojciech Owczarek,
+ *                         George V. Neville-Neil
+ * Copyright (c) 2012-2013 George V. Neville-Neil,
+ *                         Wojciech Owczarek.
+ * Copyright (c) 2011-2012 George V. Neville-Neil,
+ *                         Steven Kreuzer,
+ *                         Martin Burnicki,
+ *                         Jan Breuer,
+ *                         Gael Mace,
+ *                         Alexandre Van Kempen,
+ *                         Inaqui Delgado,
+ *                         Rick Ratzel,
+ *                         National Instruments.
+ * Copyright (c) 2009-2010 George V. Neville-Neil,
+ *                         Steven Kreuzer,
+ *                         Jan Breuer,
+ *                         Gael Mace,
+ * Copyright (c) 2005-2008 Kendall Correll, Aidan Williams
+ * All Rights Reserved
+ * modification, are permitted provided that the following conditions are
+ * met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ *    this list of conditions and the following disclaimer.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE AUTHORS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
+ * BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
+ * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
+ * IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * @file   net.c
+ * @date   Tue Jul 20 16:17:49 2010
+ * @brief  Functions to interact with the network sockets and NIC driver.
+#include "../ptpd.h"
+#ifdef PTPD_PCAP
+#ifdef HAVE_PCAP_PCAP_H
+#include <pcap/pcap.h>
+#else /* !HAVE_PCAP_PCAP_H */
+/* Cases like RHEL5 and others where only pcap.h exists */
+#ifdef HAVE_PCAP_H
+#include <pcap.h>
+#endif /* HAVE_PCAP_H */
+#endif
+#define PCAP_TIMEOUT 1 /* expressed in milliseconds */
+#endif
+#if defined PTPD_SNMP
+#include <net-snmp/net-snmp-config.h>
+#include <net-snmp/net-snmp-includes.h>
+#include <net-snmp/agent/net-snmp-agent-includes.h>
+#endif
+/* choose kernel-level nanoseconds or microseconds resolution on the client-side */
+#if !defined(SO_TIMESTAMPING) && !defined(SO_TIMESTAMPNS) && !defined(SO_TIMESTAMP) && !defined(SO_BINTIME)
+#error No kernel-level support for packet timestamping detected!
+#endif
+#ifdef SO_TIMESTAMPING
+#include <linux/net_tstamp.h>
+#include <linux/sockios.h>
+#include <linux/ethtool.h>
+#endif /* SO_TIMESTAMPING */
+ * shutdown the IPv4 multicast for specific address
+ * @param netPath
+ * @param multicastAddr
+ * @return TRUE if successful
+static Boolean
+netShutdownMulticastIPv4(NetPath * netPath, Integer32 multicastAddr)
+	struct ip_mreq imr;
+	if(!multicastAddr || !netPath->interfaceAddr.s_addr) {
+		return TRUE;
+	/* Close General Multicast */
+	imr.imr_multiaddr.s_addr = multicastAddr;
+	imr.imr_interface.s_addr = netPath->interfaceAddr.s_addr;
+	setsockopt(netPath->eventSock, IPPROTO_IP, IP_DROP_MEMBERSHIP,
+		   &imr, sizeof(struct ip_mreq));
+	setsockopt(netPath->generalSock, IPPROTO_IP, IP_DROP_MEMBERSHIP,
+	return TRUE;
+ * shutdown the multicast (both General and Peer)
+ * @param netPath
+static Boolean
+netShutdownMulticast(NetPath * netPath)
+	netShutdownMulticastIPv4(netPath, netPath->multicastAddr);
+	netPath->multicastAddr = 0;
+	/* Close Peer Multicast */
+	netShutdownMulticastIPv4(netPath, netPath->peerMulticastAddr);
+	netPath->peerMulticastAddr = 0;
+	return TRUE;
+ * For future use: Check if IPv4 address is multiast -
+ * If first 4 bits of an address are 0xE (1110), it's multicast
+static Boolean
+isIpMulticast(struct in_addr in)
+        if((ntohl(in.s_addr) >> 28) == 0x0E )
+	    return TRUE;
+	return FALSE;
+/* shut down the UDP stuff */
+Boolean
+netShutdown(NetPath * netPath)
+	netShutdownMulticast(netPath);
+	/* Close sockets */
+	if (netPath->eventSock >= 0)
+		close(netPath->eventSock);
+	netPath->eventSock = -1;
+	if (netPath->generalSock >= 0)
+		close(netPath->generalSock);
+	netPath->generalSock = -1;
+#ifdef PTPD_PCAP
+	if (netPath->pcapEvent != NULL) {
+		pcap_close(netPath->pcapEvent);
+		netPath->pcapEventSock = -1;
+	if (netPath->pcapGeneral != NULL) {
+		pcap_close(netPath->pcapGeneral);
+		netPath->pcapGeneralSock = -1;
+#endif
+	freeIpv4AccessList(&netPath->timingAcl);
+	freeIpv4AccessList(&netPath->managementAcl);
+	return TRUE;
+/* Check if interface ifaceName exists. Return 1 on success, 0 when interface doesn't exists, -1 on failure.
+static int
+interfaceExists(char* ifaceName)
+    int ret;
+    struct ifaddrs *ifaddr, *ifa;
+    if(!strlen(ifaceName)) {
+	DBG("interfaceExists called for an empty interface!");
+	return 0;
+    if(getifaddrs(&ifaddr) == -1) {
+	PERROR("Could not get interface list");
+	ret = -1;
+	goto end;
+    for (ifa = ifaddr; ifa != NULL; ifa = ifa->ifa_next) {
+	if(ifa->ifa_name == NULL) continue;
+	if(!strcmp(ifaceName, ifa->ifa_name)) {
+	    ret = 1;
+	    goto end;
+    ret = 0;
+    DBG("Interface not found: %s\n", ifaceName);
+end:
+   freeifaddrs(ifaddr);
+    return ret;
+static int
+getInterfaceFlags(char* ifaceName, unsigned int* flags)
+    int ret;
+	return 0;
+	ret = -1;
+	goto end;
+	    *flags = ifa->ifa_flags;
+	    ret = 1;
+	    goto end;
+    ret = 0;
+end:
+    return ret;
+/* Try getting addr address of family family from interface ifaceName.
+   Return 1 on success, 0 when no suitable address available, -1 on failure.
+static int
+getInterfaceAddress(char* ifaceName, int family, struct sockaddr* addr) {
+    int ret;
+	ret = -1;
+	goto end;
+	/* ifa_addr not always present - link layer may come first */
+	if(ifa->ifa_addr == NULL) continue;
+	if(!strcmp(ifaceName, ifa->ifa_name) && ifa->ifa_addr->sa_family == family) {
+		memcpy(addr, ifa->ifa_addr, sizeof(struct sockaddr));
+    		ret = 1;
+    		goto end;
+    ret = 0;
+end:
+    return ret;
+/* Try getting hwAddrSize bytes of ifaceName hardware address,
+   and place them in hwAddr. Return 1 on success, 0 when no suitable
+   hw address available, -1 on failure.
+static int
+getHwAddress (char* ifaceName, unsigned char* hwAddr, int hwAddrSize)
+    int ret;
+	return 0;
+/* BSD* - AF_LINK gives us access to the hw address via struct sockaddr_dl */
+#if defined(AF_LINK) && !defined(__sun)
+	ret = -1;
+	goto end;
+	if(!strcmp(ifaceName, ifa->ifa_name) && ifa->ifa_addr->sa_family == AF_LINK) {
+		struct sockaddr_dl* sdl = (struct sockaddr_dl *)ifa->ifa_addr;
+		if(sdl->sdl_type == IFT_ETHER || sdl->sdl_type == IFT_L2VLAN) {
+			memcpy(hwAddr, LLADDR(sdl),
+			hwAddrSize <= sizeof(sdl->sdl_data) ?
+			hwAddrSize : sizeof(sdl->sdl_data));
+			ret = 1;
+			goto end;
+		} else {
+			DBGV("Unsupported hardware address family on %s\n", ifaceName);
+			ret = 0;
+			goto end;
+    ret = 0;
+end:
+    return ret;
+#else
+/* Linux and Solaris family which also have SIOCGIFHWADDR/SIOCGLIFHWADDR */
+    int sockfd;
+    struct ifreq ifr;
+    sockfd = socket(AF_INET, SOCK_DGRAM, 0);
+    if(sockfd < 0) {
+	PERROR("Could not open test socket");
+	return -1;
+    memset(&ifr, 0, sizeof(ifr));
+    strncpy(ifr.ifr_name, ifaceName, IFACE_NAME_LENGTH);
+    if (ioctl(sockfd, SIOCGIFHWADDR, &ifr) < 0) {
+            DBGV("failed to request hardware address for %s", ifaceName);
+	    ret = -1;
+	    goto end;
+#ifdef HAVE_STRUCT_IFREQ_IFR_HWADDR
+    int af = ifr.ifr_hwaddr.sa_family;
+#else
+    int af = ifr.ifr_addr.sa_family;
+#endif /* HAVE_STRUCT_IFREQ_IFR_HWADDR */
+    if (    af == ARPHRD_ETHER
+	 || af == ARPHRD_IEEE802
+#ifdef ARPHRD_INFINIBAND
+	 || af == ARPHRD_INFINIBAND
+#endif
+	    memcpy(hwAddr, ifr.ifr_hwaddr.sa_data, hwAddrSize);
+#else
+    	    memcpy(hwAddr, ifr.ifr_addr.sa_data, hwAddrSize);
+	    ret = 1;
+	} else {
+	    ret = 0;
+end:
+    close(sockfd);
+    return ret;
+#endif /* AF_LINK */
+static int getInterfaceIndex(char *ifaceName)
+#ifndef SIOCGIFINDEX
+    return -1;
+#else
+    int sockfd;
+    struct ifreq ifr;
+    if(sockfd < 0) {
+	PERROR("Could not retrieve interface index for %s",ifaceName);
+	return -1;
+    if (ioctl(sockfd, SIOCGIFINDEX, &ifr) < 0) {
+	    close(sockfd);
+	    return -1;
+    close(sockfd);
+#if defined(HAVE_STRUCT_IFREQ_IFR_INDEX)
+    return ifr.ifr_index;
+#elif defined(HAVE_STRUCT_IFREQ_IFR_IFINDEX)
+    return ifr.ifr_ifindex;
+#else
+    return 0;
+#endif
+#endif /* !SIOCGIFINDEX */
+static Boolean getInterfaceInfo(char* ifaceName, InterfaceInfo* ifaceInfo)
+    int res;
+    res = interfaceExists(ifaceName);
+    if (res == -1) {
+	return FALSE;
+    } else if (res == 0) {
+	ERROR("Interface %s does not exist.\n", ifaceName);
+	return FALSE;
+    res = getInterfaceAddress(ifaceName, ifaceInfo->addressFamily, &ifaceInfo->afAddress);
+    if (res == -1) {
+	return FALSE;
+    ifaceInfo->hasAfAddress = res;
+    res = getHwAddress(ifaceName, (unsigned char*)ifaceInfo->hwAddress, 6);
+    if (res == -1) {
+	return FALSE;
+    ifaceInfo->hasHwAddress = res;
+    res = getInterfaceFlags(ifaceName, &ifaceInfo->flags);
+    if (res == -1) {
+	return FALSE;
+    res  = getInterfaceIndex(ifaceName);
+    if(res == -1) {
+	ifaceInfo->ifIndex = 0;
+    } else {
+	ifaceInfo->ifIndex = res;
+    return TRUE;
+Boolean
+testInterface(char * ifaceName, const RunTimeOpts* rtOpts)
+	InterfaceInfo info;
+	info.addressFamily = AF_INET;
+	if(getInterfaceInfo(ifaceName, &info) != 1)
+		return FALSE;
+	switch(rtOpts->transport) {
+	    case UDP_IPV4:
+		if(!info.hasAfAddress) {
+		    ERROR("Interface %s has no IPv4 address set\n", ifaceName);
+		    return FALSE;
+		break;
+	    case IEEE_802_3:
+		if(!info.hasHwAddress) {
+		    ERROR("Interface %s has no supported hardware address - possibly not an Ethernet interface\n", ifaceName);
+		    return FALSE;
+		break;
+	    default:
+		ERROR("Unsupported transport: %d\n", rtOpts->transport);
+		return FALSE;
+    if(!(info.flags & IFF_UP) || !(info.flags & IFF_RUNNING))
+	    WARNING("Interface %s seems to be down. PTPd will not operate correctly until it's up.\n", ifaceName);
+    if(info.flags & IFF_LOOPBACK)
+	    WARNING("Interface %s is a loopback interface.\n", ifaceName);
+    if(!(info.flags & IFF_MULTICAST)
+	    && rtOpts->transport==UDP_IPV4
+	    && rtOpts->ipMode != IPMODE_UNICAST) {
+	    WARNING("Interface %s is not multicast capable.\n", ifaceName);
+	return TRUE;
+ * Init the multcast for specific IPv4 address
+ * @param netPath
+static Boolean
+netInitMulticastIPv4(NetPath * netPath, Integer32 multicastAddr)
+	/* multicast send only on specified interface */
+	if (setsockopt(netPath->eventSock, IPPROTO_IP, IP_MULTICAST_IF,
+		       &netPath->interfaceAddr, sizeof(struct in_addr)) < 0
+	    || setsockopt(netPath->generalSock, IPPROTO_IP, IP_MULTICAST_IF,
+	    < 0) {
+		PERROR("error while setting outgoig multicast interface "
+			"(IP_MULTICAST_IF)");
+		return FALSE;
+	/* join multicast group (for receiving) on specified interface */
+	if (setsockopt(netPath->eventSock, IPPROTO_IP, IP_ADD_MEMBERSHIP,
+		       &imr, sizeof(struct ip_mreq)) < 0
+	    || setsockopt(netPath->generalSock, IPPROTO_IP, IP_ADD_MEMBERSHIP,
+			  &imr, sizeof(struct ip_mreq)) < 0) {
+		PERROR("failed to join the multicast group");
+		return FALSE;
+	return TRUE;
+ * Init the multcast (both General and Peer)
+ * @param netPath
+ * @param rtOpts
+static Boolean
+netInitMulticast(NetPath * netPath,  const RunTimeOpts * rtOpts)
+	struct in_addr netAddr;
+	char addrStr[NET_ADDRESS_LENGTH+1];
+	/* do not join multicast in unicast mode */
+	if(rtOpts->ipMode == IPMODE_UNICAST)
+		return TRUE;
+	/* Init General multicast IP address */
+	strncpy(addrStr, DEFAULT_PTP_DOMAIN_ADDRESS, NET_ADDRESS_LENGTH);
+	if (!inet_aton(addrStr, &netAddr)) {
+		ERROR("failed to encode multicast address: %s\n", addrStr);
+		return FALSE;
+	/* this allows for leaving groups only if joined */
+	netPath->joinedGeneral = TRUE;
+	netPath->multicastAddr = netAddr.s_addr;
+	if(!netInitMulticastIPv4(netPath, netPath->multicastAddr)) {
+		return FALSE;
+	/* End of General multicast Ip address init */
+	if(rtOpts->delayMechanism != P2P) {
+		return TRUE;
+	/* Init Peer multicast IP address */
+	strncpy(addrStr, PEER_PTP_DOMAIN_ADDRESS, NET_ADDRESS_LENGTH);
+		return FALSE;
+	/* track if we have joined the p2p mcast group */
+	netPath->joinedPeer = TRUE;
+	netPath->peerMulticastAddr = netAddr.s_addr;
+	if(!netInitMulticastIPv4(netPath, netPath->peerMulticastAddr)) {
+		return FALSE;
+	/* End of Peer multicast Ip address init */
+	return TRUE;
+static Boolean
+netSetMulticastTTL(int sockfd, int ttl) {
+#if defined(__OpenBSD__) || defined(__sun)
+	uint8_t temp = (uint8_t) ttl;
+#else
+	int temp = ttl;
+#endif
+	if (setsockopt(sockfd, IPPROTO_IP, IP_MULTICAST_TTL,
+		       &temp, sizeof(temp)) < 0) {
+	    PERROR("Failed to set socket multicast time-to-live");
+	    return FALSE;
+	return TRUE;
+static Boolean
+netSetMulticastLoopback(NetPath * netPath, Boolean value) {
+	uint8_t temp = value ? 1 : 0;
+#else
+	int temp = value ? 1 : 0;
+#endif
+	DBG("Going to set multicast loopback with %d \n", temp);
+	if (setsockopt(netPath->eventSock, IPPROTO_IP, IP_MULTICAST_LOOP,
+		PERROR("Failed to set multicast loopback");
+		return FALSE;
+	return TRUE;
+#if defined(SO_TIMESTAMPING) && defined(SO_TIMESTAMPNS)
+static Boolean
+getTxTimestamp(NetPath* netPath,TimeInternal* timeStamp) {
+	extern PtpClock *G_ptpClock;
+	ssize_t length;
+	fd_set tmpSet;
+	struct timeval timeOut = {0,0};
+	int val = 1;
+	int i = 0;
+	if(netPath->txTimestampFailure)
+		goto failure;
+	FD_ZERO(&tmpSet);
+	FD_SET(netPath->eventSock, &tmpSet);
+	if(select(netPath->eventSock + 1, &tmpSet, NULL, NULL, &timeOut) > 0) {
+		if (FD_ISSET(netPath->eventSock, &tmpSet)) {
+			length = netRecvEvent(G_ptpClock->msgIbuf, timeStamp,
+			    netPath, MSG_ERRQUEUE);
+			if (length > 0) {
+				DBG("getTxTimestamp: Grabbed sent msg via errqueue: %d bytes, at %d.%d\n", length, timeStamp->seconds, timeStamp->nanoseconds);
+				return TRUE;
+			} else if (length < 0) {
+				DBG("getTxTimestamp: Failed to poll error queue for SO_TIMESTAMPING transmit time\n");
+				G_ptpClock->counters.messageRecvErrors++;
+			} else if (length == 0) {
+				DBG("getTxTimestamp: Received no data from TX error queue\n");
+	/* we're desperate here, aren't we... */
+	for(i = 0; i < 3; i++) {
+	    length = netRecvEvent(G_ptpClock->msgIbuf, timeStamp, netPath, MSG_ERRQUEUE);
+	    if(length > 0) {
+		DBG("getTxTimestamp: SO_TIMESTAMPING - delayed TX timestamp caught\n");
+		return TRUE;
+	    usleep(10);
+	/* try for the last time: sleep and poll the error queue, if nothing, consider SO_TIMESTAMPING inoperable */
+	usleep(LATE_TXTIMESTAMP_US);
+	if(length > 0) {
+		DBG("getTxTimestamp: SO_TIMESTAMPING - even more delayed TX timestamp caught\n");
+		return TRUE;
+	} else {
+		DBG("getTxTimestamp: SO_TIMESTAMPING - TX timestamp retry failed - will use loop from now on\n");
+failure:
+	DBG("net.c: SO_TIMESTAMPING TX software timestamp failure - reverting to SO_TIMESTAMPNS\n");
+	/* unset SO_TIMESTAMPING first! otherwise we get an always-exiting select! */
+	val = 0;
+	if(setsockopt(netPath->eventSock, SOL_SOCKET, SO_TIMESTAMPING, &val, sizeof(int)) < 0) {
+		DBG("getTxTimestamp: failed to unset SO_TIMESTAMPING");
+	val = 1;
+	if(setsockopt(netPath->eventSock, SOL_SOCKET, SO_TIMESTAMPNS, &val, sizeof(int)) < 0) {
+		DBG("getTxTimestamp: failed to revert to SO_TIMESTAMPNS");
+	return FALSE;
+ * Initialize timestamping of packets
+ * @param netPath
+static Boolean
+netInitTimestamping(NetPath * netPath, const RunTimeOpts * rtOpts)
+	int val = 1;
+	Boolean result = TRUE;
+#if defined(SO_TIMESTAMPING) && defined(SO_TIMESTAMPNS)/* Linux - current API */
+	DBG("netInitTimestamping: trying to use SO_TIMESTAMPING\n");
+	val = SOF_TIMESTAMPING_TX_SOFTWARE |
+	    SOF_TIMESTAMPING_RX_SOFTWARE |
+	    SOF_TIMESTAMPING_SOFTWARE;
+/* unless compiled with PTPD_EXPERIMENTAL, check if we support the desired tstamp capabilities */
+#ifndef PTPD_EXPERIMENTAL
+#ifdef ETHTOOL_GET_TS_INFO
+       struct ethtool_ts_info tsInfo;
+	struct ifreq ifRequest;
+        int res;
+        memset(&tsInfo, 0, sizeof(tsInfo));
+        memset(&ifRequest, 0, sizeof(ifRequest));
+        tsInfo.cmd = ETHTOOL_GET_TS_INFO;
+        strncpy( ifRequest.ifr_name, rtOpts->ifaceName, IFNAMSIZ - 1);
+        ifRequest.ifr_data = (char *) &tsInfo;
+        res = ioctl(netPath->eventSock, SIOCETHTOOL, &ifRequest);
+	if (res < 0) {
+		PERROR("Could not retrieve ethtool timestamping capabilities for %s - reverting to SO_TIMESTAMPNS",
+			    rtOpts->ifaceName);
+		val = 1;
+		netPath->txTimestampFailure = FALSE;
+	} else if((tsInfo.so_timestamping & val) != val) {
+		DBGV("Required SO_TIMESTAMPING flags not supported - reverting to SO_TIMESTAMPNS\n");
+		val = 1;
+		netPath->txTimestampFailure = TRUE;
+#else
+	val = 1;
+#endif /* ETHTOOL_GET_TS_INFO */
+#endif /* PTPD_EXPERIMENTAL */
+	if(val == 1) {
+	    if (setsockopt(netPath->eventSock, SOL_SOCKET, SO_TIMESTAMPNS, &val, sizeof(int)) < 0) {
+		    PERROR("netInitTimestamping: failed to enable SO_TIMESTAMPNS");
+		    result = FALSE;
+	} else {
+	    if (setsockopt(netPath->eventSock, SOL_SOCKET, SO_TIMESTAMPING, &val, sizeof(int)) < 0) {
+		    PERROR("netInitTimestamping: failed to enable SO_TIMESTAMPING");
+		    result = FALSE;
+	if (result == TRUE) {
+	    DBG("SO_TIMESTAMP%s initialised\n",(val==1)?"NS":"ING");
+#elif defined(SO_TIMESTAMPNS) /* Linux, Apple */
+	DBG("netInitTimestamping: trying to use SO_TIMESTAMPNS\n");
+		result = FALSE;
+#elif defined(SO_BINTIME) /* FreeBSD */
+	DBG("netInitTimestamping: trying to use SO_BINTIME\n");
+	if (setsockopt(netPath->eventSock, SOL_SOCKET, SO_BINTIME, &val, sizeof(int)) < 0) {
+		PERROR("netInitTimestamping: failed to enable SO_BINTIME");
+		result = FALSE;
+#else
+	result = FALSE;
+#endif
+/* fallback method */
+#if defined(SO_TIMESTAMP) /* Linux, Apple, FreeBSD */
+	if (!result) {
+		DBG("netInitTimestamping: trying to use SO_TIMESTAMP\n");
+		if (setsockopt(netPath->eventSock, SOL_SOCKET, SO_TIMESTAMP, &val, sizeof(int)) < 0) {
+			PERROR("netInitTimestamping: failed to enable SO_TIMESTAMP");
+			result = FALSE;
+		result = TRUE;
+#endif
+	return result;
+Boolean
+hostLookup(const char* hostname, Integer32* addr)
+	if (hostname[0]) {
+		/* Attempt a DNS lookup first. */
+		struct hostent *host;
+#ifdef HAVE_GETHOSTBYNAME2
+		host = gethostbyname2(hostname, AF_INET);
+#else
+		host = getipnodebyname(hostname, AF_INET, AI_DEFAULT, &errno);
+#endif /* HAVE_GETHOSTBYNAME2 */
+                if (host != NULL) {
+			if (host->h_length != 4) {
+				PERROR("unicast host resolved to non ipv4"
+				       "address");
+				return FALSE;
+			*addr =
+				*(uint32_t *)host->h_addr_list[0];
+			return TRUE;
+		} else {
+			/* Maybe it's a dotted quad. */
+			if (!inet_aton(hostname, &netAddr)) {
+				ERROR("failed to encode unicast address: %s\n",
+				      hostname);
+				return FALSE;
+				*addr = netAddr.s_addr;
+				return TRUE;
+return FALSE;
+/* parse a list of hosts to a list of IP addresses */
+static int parseUnicastConfig(const RunTimeOpts *rtOpts, int maxCount, UnicastDestination * output)
+    char* token;
+    char* stash;
+    int found = 0;
+    int total = 0;
+    char* text_;
+    char* text__;
+    int tmp = 0;
+    if(strlen(rtOpts->unicastDestinations)==0) return 0;
+    text_=strdup(rtOpts->unicastDestinations);
+    for(text__=text_;found < maxCount; text__=NULL) {
+	token=strtok_r(text__,", ;\t",&stash);
+	if(token==NULL) break;
+	if(hostLookup(token, &output[found].transportAddress)) {
+	DBG("hostList %d host: %s addr %08x\n", found, token, output[found]);
+	    found++;
+    if(text_ != NULL) {
+	free(text_);
+    if(!found) {
+	return 0;
+    total = found;
+    found = 0;
+    text_=strdup(rtOpts->unicastDomains);
+    for(text__=text_;found < total; text__=NULL) {
+	if (sscanf(token,"%d", &tmp)) {
+	    DBG("hostList %dth host: domain %d\n", found, tmp);
+	    output[found].domainNumber = tmp;
+	    found++;
+	free(text_);
+    found = 0;
+    text_=strdup(rtOpts->unicastLocalPreference);
+	tmp = LOWEST_LOCALPREFERENCE;
+	if(token!=NULL) {
+	    if (sscanf(token,"%d", &tmp) != 1) {
+	DBG("hostList %dth host: preference %d\n", found, tmp);
+	output[found].localPreference = tmp;
+	found++;
+	free(text_);
+    return total;
+ * Init all network transports
+ * @param netPath
+ * @param rtOpts
+ * @param ptpClock
+Boolean
+netInit(NetPath * netPath, RunTimeOpts * rtOpts, PtpClock * ptpClock)
+#ifdef __QNXNTO__
+	unsigned char temp;
+#else
+	int temp;
+#endif
+	struct sockaddr_in addr;
+#ifdef PTPD_PCAP
+	struct bpf_program program;
+	char errbuf[PCAP_ERRBUF_SIZE];
+#endif
+	DBG("netInit\n");
+#ifdef PTPD_PCAP
+	netPath->pcapEvent = NULL;
+	netPath->pcapGeneral = NULL;
+#endif
+#ifdef PTPD_PCAP
+	if (rtOpts->transport == IEEE_802_3) {
+		netPath->headerOffset = PACKET_BEGIN_ETHER;
+#ifdef HAVE_STRUCT_ETHER_ADDR_OCTET
+		memcpy(netPath->etherDest.octet, ether_aton(PTP_ETHER_DST), ETHER_ADDR_LEN);
+		memcpy(netPath->peerEtherDest.octet, ether_aton(PTP_ETHER_PEER), ETHER_ADDR_LEN);
+#else
+		memcpy(netPath->etherDest.ether_addr_octet, ether_aton(PTP_ETHER_DST), ETHER_ADDR_LEN);
+		memcpy(netPath->peerEtherDest.ether_addr_octet, ether_aton(PTP_ETHER_PEER), ETHER_ADDR_LEN);
+#endif /* HAVE_STRUCT_ETHER_ADDR_OCTET */
+	} else
+#endif
+		netPath->headerOffset = PACKET_BEGIN_UDP;
+	/* open sockets */
+	if ((netPath->eventSock = socket(PF_INET, SOCK_DGRAM,
+					 IPPROTO_UDP)) < 0
+	    || (netPath->generalSock = socket(PF_INET, SOCK_DGRAM,
+					      IPPROTO_UDP)) < 0) {
+		PERROR("failed to initialize sockets");
+		return FALSE;
+	/* let's see if we have another interface left before we die */
+	if(!testInterface(rtOpts->ifaceName, rtOpts)) {
+		/* backup not enabled - exit */
+		if(!rtOpts->backupIfaceEnabled)
+		    return FALSE;
+		/* backup enabled - try the other interface */
+		ptpClock->runningBackupInterface = !ptpClock->runningBackupInterface;
+		rtOpts->ifaceName = (ptpClock->runningBackupInterface)?rtOpts->backupIfaceName : rtOpts->primaryIfaceName;
+		NOTICE("Last resort - attempting to switch to %s interface\n", ptpClock->runningBackupInterface ? "backup" : "primary");
+		/* if this fails, we have no reason to live */
+		    return FALSE;
+	netPath->interfaceInfo.addressFamily = AF_INET;
+	/* the if is here only to get rid of an unused result warning. */
+	if( getInterfaceInfo(rtOpts->ifaceName, &netPath->interfaceInfo)!= 1)
+		return FALSE;
+	/* No HW address, we'll use the protocol address to form interfaceID -> clockID */
+	if( !netPath->interfaceInfo.hasHwAddress && netPath->interfaceInfo.hasAfAddress ) {
+		uint32_t addr = ((struct sockaddr_in*)&(netPath->interfaceInfo.afAddress))->sin_addr.s_addr;
+		memcpy(netPath->interfaceID, &addr, 2);
+		memcpy(netPath->interfaceID + 4, &addr + 2, 2);
+	/* Initialise interfaceID with hardware address */
+	} else {
+		    memcpy(&netPath->interfaceID, &netPath->interfaceInfo.hwAddress,
+			    sizeof(netPath->interfaceID) <= sizeof(netPath->interfaceInfo.hwAddress) ?
+				    sizeof(netPath->interfaceID) : sizeof(netPath->interfaceInfo.hwAddress)
+	DBG("Listening on IP: %s\n",inet_ntoa(
+		((struct sockaddr_in*)&(netPath->interfaceInfo.afAddress))->sin_addr));
+#ifdef PTPD_PCAP
+	if (rtOpts->pcap == TRUE) {
+		int promisc = (rtOpts->transport == IEEE_802_3 ) ? 1 : 0;
+		if ((netPath->pcapEvent = pcap_open_live(rtOpts->ifaceName,
+							 PACKET_SIZE, promisc,
+							 PCAP_TIMEOUT,
+							 errbuf)) == NULL) {
+			PERROR("failed to open event pcap");
+			return FALSE;
+/* libpcap - new way - may be required for non-default buffer sizes  */
+		netPath->pcapEvent = pcap_create(rtOpts->ifaceName, errbuf);
+		pcap_set_promisc(netPath->pcapEvent, promisc);
+		pcap_set_snaplen(netPath->pcapEvent, PACKET_SIZE);
+		pcap_set_timeout(netPath->pcapEvent, PCAP_TIMEOUT);
+		pcap_set_buffer_size(netPath->pcapEvent, 1024 * 2 * UNICAST_MAX_DESTINATIONS);
+		pcap_activate(netPath->pcapEvent);
+		if (pcap_compile(netPath->pcapEvent, &program,
+				 ( rtOpts->transport == IEEE_802_3 ) ?
+				    "ether proto 0x88f7":
+				( rtOpts->ipMode == IPMODE_UNICAST ) ?
+				    "udp port 319 and not multicast" :
+				 ( rtOpts->ipMode != IPMODE_MULTICAST ) ?
+					 "udp port 319" :
+				 "host (224.0.1.129 or 224.0.0.107) and udp port 319" ,
+				 1, 0) < 0) {
+			PERROR("failed to compile pcap event filter");
+			pcap_perror(netPath->pcapEvent, "ptpd2");
+			return FALSE;
+		if (pcap_setfilter(netPath->pcapEvent, &program) < 0) {
+			PERROR("failed to set pcap event filter");
+			return FALSE;
+		pcap_freecode(&program);
+		if ((netPath->pcapEventSock =
+		     pcap_get_selectable_fd(netPath->pcapEvent)) < 0) {
+			PERROR("failed to get pcap event fd");
+			return FALSE;
+		if ((netPath->pcapGeneral = pcap_open_live(rtOpts->ifaceName,
+							   PCAP_TIMEOUT,
+			PERROR("failed to open general pcap");
+			return FALSE;
+		if (rtOpts->transport != IEEE_802_3) {
+			if (pcap_compile(netPath->pcapGeneral, &program,
+					    "udp port 320 and not multicast" :
+						 "udp port 320" :
+					 "host (224.0.1.129 or 224.0.0.107) and udp port 320" ,
+					 1, 0) < 0) {
+				PERROR("failed to compile pcap general filter");
+				pcap_perror(netPath->pcapGeneral, "ptpd2");
+				return FALSE;
+			if (pcap_setfilter(netPath->pcapGeneral, &program) < 0) {
+				PERROR("failed to set pcap general filter");
+				return FALSE;
+			if ((netPath->pcapGeneralSock =
+			     pcap_get_selectable_fd(netPath->pcapGeneral)) < 0) {
+				PERROR("failed to get pcap general fd");
+				return FALSE;
+#endif
+#ifdef PTPD_PCAP
+	if(rtOpts->transport == IEEE_802_3) {
+		/* TX timestamp is not generated for PCAP mode and Ethernet transport */
+	} else {
+#endif
+		/* save interface address for IGMP refresh */
+		    struct sockaddr_in* sin = (struct sockaddr_in*)&(netPath->interfaceInfo.afAddress);
+		    netPath->interfaceAddr = sin->sin_addr;
+		DBG("Local IP address used : %s \n", inet_ntoa(netPath->interfaceAddr));
+		temp = 1;			/* allow address reuse */
+		if (setsockopt(netPath->eventSock, SOL_SOCKET, SO_REUSEADDR,
+			       &temp, sizeof(int)) < 0
+		    || setsockopt(netPath->generalSock, SOL_SOCKET, SO_REUSEADDR,
+				  &temp, sizeof(int)) < 0) {
+			DBG("failed to set socket reuse\n");
+		/* disable UDP checksum validation (Linux) */
+#ifdef SO_NO_CHECK
+		if(rtOpts->disableUdpChecksums) {
+			if (setsockopt(netPath->eventSock, SOL_SOCKET, SO_NO_CHECK , &temp,
+			sizeof(int)) < 0
+			|| setsockopt(netPath->generalSock, SOL_SOCKET, SO_NO_CHECK , &temp,
+			    sizeof(int)) < 0) {
+			    WARNING("Could not disable UDP checksum validation\n");
+#endif /* SO_NO_CHECK */
+		/* bind sockets */
+		 * need INADDR_ANY to receive both unicast and multicast,
+		 * but only need interface address for unicast
+		if(rtOpts->ipMode == IPMODE_UNICAST ||
+		   rtOpts->ignore_daemon_lock) {
+			addr.sin_addr = netPath->interfaceAddr;
+		} else {
+			addr.sin_addr.s_addr = htonl(INADDR_ANY);
+		addr.sin_family = AF_INET;
+		addr.sin_port = htons(PTP_EVENT_PORT);
+		if (bind(netPath->eventSock, (struct sockaddr *)&addr,
+			sizeof(struct sockaddr_in)) < 0) {
+			PERROR("failed to bind event socket");
+			return FALSE;
+		addr.sin_port = htons(PTP_GENERAL_PORT);
+		if (bind(netPath->generalSock, (struct sockaddr *)&addr,
+			PERROR("failed to bind general socket");
+			return FALSE;
+#ifdef SO_RCVBUF
+                /* try increasing receive buffers for unicast Sync processing */
+                if(rtOpts->ipMode == IPMODE_UNICAST && !rtOpts->slaveOnly) {
+                    uint32_t n = 0;
+                    socklen_t nlen = sizeof(n);
+                    if (getsockopt(netPath->eventSock, SOL_SOCKET, SO_RCVBUF, &n, &nlen) < 0) {
+                        n = 0;
+                    DBG("eventSock rcvbuff : %d\n", n);
+                    if(n < (UNICAST_MAX_DESTINATIONS * 1024)) {
+                        n = UNICAST_MAX_DESTINATIONS * 1024;
+                        if (setsockopt(netPath->eventSock, SOL_SOCKET, SO_RCVBUF, &n, sizeof(n)) < 0) {
+                            DBG("Failed to increase event socket receive buffer\n");
+                    if (getsockopt(netPath->generalSock, SOL_SOCKET, SO_RCVBUF, &n, &nlen) < 0) {
+                        n = 0;
+                    DBG("genetalSock rcvbuff : %d\n", n);
+                        if (setsockopt(netPath->generalSock, SOL_SOCKET, SO_RCVBUF, &n, sizeof(n)) < 0) {
+                            DBG("Failed to increase general socket receive buffer\n");
+#endif /* SO_RCVBUF */
+#ifdef USE_BINDTODEVICE
+#ifdef linux
+		 * The following code makes sure that the data is only
+		 * received on the specified interface.  Without this option,
+		 * it's possible to receive PTP from another interface, and
+		 * confuse the protocol.  Calling bind() with the IP address
+		 * of the device instead of INADDR_ANY does not work.
+		 * More info:
+		 *   http://developerweb.net/viewtopic.php?id=6471
+		 *   http://stackoverflow.com/questions/1207746/problems-with-so-bindtodevice-linux-socket-option
+		 * wowczarek: 2.3.1-rc4 at jun0215: this breaks the manual packet looping,
+		 * so may only be used for multicast-only
+		if ( rtOpts->ipMode == IPMODE_MULTICAST ) {
+		    if (setsockopt(netPath->eventSock, SOL_SOCKET, SO_BINDTODEVICE,
+				rtOpts->ifaceName, strlen(rtOpts->ifaceName)) < 0
+			|| setsockopt(netPath->generalSock, SOL_SOCKET, SO_BINDTODEVICE,
+				rtOpts->ifaceName, strlen(rtOpts->ifaceName)) < 0){
+			PERROR("failed to call SO_BINDTODEVICE on the interface");
+			return FALSE;
+#endif
+#endif
+		/* Set socket dscp */
+		if(rtOpts->dscpValue) {
+			if (setsockopt(netPath->eventSock, IPPROTO_IP, IP_TOS,
+				 &rtOpts->dscpValue, sizeof(int)) < 0
+			    || setsockopt(netPath->generalSock, IPPROTO_IP, IP_TOS,
+				&rtOpts->dscpValue, sizeof(int)) < 0) {
+				    PERROR("Failed to set socket DSCP bits");
+				    return FALSE;
+		if(rtOpts->unicastDestinationsSet) {
+		    ptpClock->unicastDestinationCount = parseUnicastConfig(rtOpts,
+			    UNICAST_MAX_DESTINATIONS, ptpClock->unicastDestinations);
+			    DBG("configured %d unicast destinations\n",ptpClock->unicastDestinationCount);
+		if(rtOpts->delayMechanism==P2P && rtOpts->ipMode==IPMODE_UNICAST) {
+			ptpClock->unicastPeerDestination.transportAddress = 0;
+		    	if(rtOpts->unicastPeerDestinationSet &&
+				rtOpts->delayMechanism==P2P && !hostLookup(rtOpts->unicastPeerDestination,
+				&ptpClock->unicastPeerDestination.transportAddress)) {
+			    ERROR("Could not parse P2P unicast destination %s:\n",
+				    rtOpts->unicastPeerDestination);
+			    return FALSE;
+			} else if(!rtOpts->unicastPeerDestinationSet) {
+			    ERROR("No P2P unicast destination specified\n");
+			    return FALSE;
+		if(rtOpts->ipMode != IPMODE_UNICAST) {
+			/* init UDP Multicast on both Default and Peer addresses */
+			if (!netInitMulticast(netPath, rtOpts))
+				return FALSE;
+			/* set socket time-to-live  */
+			if(!netSetMulticastTTL(netPath->eventSock,rtOpts->ttl) ||
+			    !netSetMulticastTTL(netPath->generalSock,rtOpts->ttl))
+				return FALSE;
+			/* start tracking TTL */
+			netPath->ttlEvent = rtOpts->ttl;
+			netPath->ttlGeneral = rtOpts->ttl;
+		/* try enabling the capture of destination address */
+#ifdef IP_PKTINFO
+		temp = 1;
+		setsockopt(netPath->eventSock, IPPROTO_IP, IP_PKTINFO, &temp, sizeof(int));
+#endif /* IP_PKTINFO */
+#ifdef IP_RECVDSTADDR
+		temp = 1;
+		setsockopt(netPath->eventSock, IPPROTO_IP, IP_RECVDSTADDR, &temp, sizeof(int));
+#endif
+			/* Reset the failure indicator when (re)starting network */
+			/* for SO_TIMESTAMPING we're receiving transmitted packets via ERRQUEUE */
+			temp = 0;
+#else
+			/* enable loopback */
+			temp = 1;
+#endif
+		/* make timestamps available through recvmsg() */
+		if (!netInitTimestamping(netPath,rtOpts)) {
+			ERROR("Failed to enable packet time stamping\n");
+			return FALSE;
+		/* If we failed to initialise SO_TIMESTAMPING, enable mcast loopback */
+			temp = 1;
+#endif
+			if(!netSetMulticastLoopback(netPath, temp)) {
+				return FALSE;
+#ifdef PTPD_PCAP
+#endif
+	/* Compile ACLs */
+	if(rtOpts->timingAclEnabled) {
+		netPath->timingAcl=createIpv4AccessList(rtOpts->timingAclPermitText,
+			rtOpts->timingAclDenyText, rtOpts->timingAclOrder);
+	if(rtOpts->managementAclEnabled) {
+		netPath->managementAcl=createIpv4AccessList(rtOpts->managementAclPermitText,
+			rtOpts->managementAclDenyText, rtOpts->managementAclOrder);
+	return TRUE;
+/*Check if data has been received*/
+int
+netSelect(TimeInternal * timeout, NetPath * netPath, fd_set *readfds)
+	int ret, nfds;
+	struct timeval tv, *tv_ptr;
+	extern const RunTimeOpts rtOpts;
+	struct timeval snmp_timer_wait = { 0, 0}; // initialise to avoid unused warnings when SNMP disabled
+	int snmpblock = 0;
+#endif
+	if (timeout) {
+		if(isTimeInternalNegative(timeout)) {
+			ERROR("Negative timeout attempted for select()\n");
+			return -1;
+		tv.tv_sec = timeout->seconds;
+		tv.tv_usec = timeout->nanoseconds / 1000;
+		tv_ptr = &tv;
+	} else {
+		tv_ptr = NULL;
+	FD_ZERO(readfds);
+	nfds = 0;
+#ifdef PTPD_PCAP
+	if (netPath->pcapEventSock >= 0) {
+		FD_SET(netPath->pcapEventSock, readfds);
+		if (netPath->pcapGeneralSock >= 0)
+			FD_SET(netPath->pcapGeneralSock, readfds);
+		nfds = netPath->pcapEventSock;
+		if (netPath->pcapEventSock < netPath->pcapGeneralSock)
+			nfds = netPath->pcapGeneralSock;
+	} else if (netPath->eventSock >= 0) {
+#endif
+		FD_SET(netPath->eventSock, readfds);
+			FD_SET(netPath->generalSock, readfds);
+		nfds = netPath->eventSock;
+		if (netPath->eventSock < netPath->generalSock)
+			nfds = netPath->generalSock;
+#ifdef PTPD_PCAP
+#endif
+	nfds++;
+if (rtOpts.snmpEnabled) {
+	snmpblock = 1;
+	if (tv_ptr) {
+		snmpblock = 0;
+		memcpy(&snmp_timer_wait, tv_ptr, sizeof(struct timeval));
+	snmp_select_info(&nfds, readfds, &snmp_timer_wait, &snmpblock);
+	if (snmpblock == 0)
+		tv_ptr = &snmp_timer_wait;
+#endif
+	ret = select(nfds, readfds, 0, 0, tv_ptr);
+	if (ret < 0) {
+		if (errno == EAGAIN || errno == EINTR)
+			return 0;
+	/* Maybe we have received SNMP related data */
+	if (ret > 0) {
+		snmp_read(readfds);
+	} else if (ret == 0) {
+		snmp_timeout();
+		run_alarms();
+	netsnmp_check_outstanding_agent_requests();
+#endif
+	return ret;
+ * store received data from network to "buf" , get and store the
+ * SO_TIMESTAMP value in "time" for an event message
+ * @note Should this function be merged with netRecvGeneral(), below?
+ * Jan Breuer: I think that netRecvGeneral should be
+ * simplified. Timestamp returned by this function is never
+ * used. According to this, netInitTimestamping can be also simplified
+ * to initialize timestamping only on eventSock.
+ * @param buf
+ * @param time
+ * @param netPath
+ * @return
+ssize_t
+netRecvEvent(Octet * buf, TimeInternal * time, NetPath * netPath, int flags)
+	ssize_t ret = 0;
+	struct msghdr msg;
+	struct iovec vec[1];
+	struct sockaddr_in from_addr;
+#ifdef PTPD_PCAP
+	struct pcap_pkthdr *pkt_header;
+	const u_char *pkt_data;
+#endif
+#if defined(__QNXNTO__) && defined(PTPD_EXPERIMENTAL)
+	TimeInternal tmpTime;
+	/* get system time interpolated with TSC / clockCycles as soon as we have data on the socket */
+	getTime(&tmpTime);
+#endif
+	union {
+		struct cmsghdr cm;
+		char	control[256];
+	}     cmsg_un;
+	struct cmsghdr *cmsg;
+#if defined(SO_TIMESTAMPNS) || defined(SO_TIMESTAMPING)
+	struct timespec * ts;
+	struct bintime * bt;
+	struct timespec ts;
+#endif
+	struct timeval * tv;
+#endif
+	Boolean timestampValid = FALSE;
+	netPath->lastDestAddr = 0;
+#ifdef PTPD_PCAP
+	if (netPath->pcapEvent == NULL) { /* Using sockets */
+#endif
+		vec[0].iov_base = buf;
+		vec[0].iov_len = PACKET_SIZE;
+		memset(&msg, 0, sizeof(msg));
+		memset(&from_addr, 0, sizeof(from_addr));
+		memset(buf, 0, PACKET_SIZE);
+		memset(&cmsg_un, 0, sizeof(cmsg_un));
+		msg.msg_name = (caddr_t)&from_addr;
+		msg.msg_namelen = sizeof(from_addr);
+		msg.msg_iov = vec;
+		msg.msg_iovlen = 1;
+		msg.msg_control = cmsg_un.control;
+		msg.msg_controllen = sizeof(cmsg_un.control);
+		msg.msg_flags = 0;
+		ret = recvmsg(netPath->eventSock, &msg, flags | MSG_DONTWAIT);
+		if (ret <= 0) {
+				return 0;
+			return ret;
+		if (msg.msg_flags & MSG_TRUNC) {
+			ERROR("received truncated message\n");
+			return 0;
+		/* get time stamp of packet */
+		if (!time) {
+			ERROR("null receive time stamp argument\n");
+			return 0;
+		if (msg.msg_flags & MSG_CTRUNC) {
+			ERROR("received truncated ancillary data\n");
+			return 0;
+#if defined(HAVE_DECL_MSG_ERRQUEUE) && HAVE_DECL_MSG_ERRQUEUE
+		if(!(flags & MSG_ERRQUEUE))
+#endif
+		netPath->lastSourceAddr = from_addr.sin_addr.s_addr;
+		netPath->receivedPacketsTotal++;
+		/* do not report "from self" */
+		if(!netPath->lastSourceAddr || (netPath->lastSourceAddr != netPath->interfaceAddr.s_addr)) {
+		    netPath->receivedPackets++;
+		if (msg.msg_controllen <= 0) {
+			ERROR("received short ancillary data (%ld/%ld)\n",
+			      (long)msg.msg_controllen, (long)sizeof(cmsg_un.control));
+			return 0;
+		for (cmsg = CMSG_FIRSTHDR(&msg); cmsg != NULL;
+		     cmsg = CMSG_NXTHDR(&msg, cmsg)) {
+#ifdef IP_PKTINFO
+			if ((cmsg->cmsg_level == IPPROTO_IP) &&
+			    (cmsg->cmsg_type == IP_PKTINFO)) {
+				struct in_pktinfo *pi =
+				(struct in_pktinfo *) CMSG_DATA(cmsg);
+				netPath->lastDestAddr = pi->ipi_addr.s_addr;
+				DBG("IP_PKTINFO Dst: %s\n", inet_ntoa(pi->ipi_addr));
+#endif
+			    (cmsg->cmsg_type == IP_RECVDSTADDR)) {
+				struct in_addr *pa = (struct in_addr *) CMSG_DATA(cmsg);
+				netPath->lastDestAddr = pa->s_addr;
+				DBG("IP_RECVDSTADDR Dst: %s\n", inet_ntoa(*pa));
+#endif
+			if (cmsg->cmsg_level == SOL_SOCKET) {
+				if(cmsg->cmsg_type == SO_TIMESTAMPING ||
+				    cmsg->cmsg_type == SO_TIMESTAMPNS) {
+					ts = (struct timespec *)CMSG_DATA(cmsg);
+					time->seconds = ts->tv_sec;
+					time->nanoseconds = ts->tv_nsec;
+					timestampValid = TRUE;
+					DBG("rcvevent: SO_TIMESTAMP%s %s time stamp: %us %dns\n", netPath->txTimestampFailure ?
+					    "NS" : "ING",
+					    (flags & MSG_ERRQUEUE) ? "(TX)" : "(RX)" , time->seconds, time->nanoseconds);
+					break;
+				if(cmsg->cmsg_type == SCM_TIMESTAMPNS) {
+					DBGV("kernel NANO recv time stamp %us %dns\n",
+					     time->seconds, time->nanoseconds);
+					break;
+				if(cmsg->cmsg_type == SCM_BINTIME) {
+					bt = (struct bintime *)CMSG_DATA(cmsg);
+					bintime2timespec(bt, &ts);
+					time->seconds = ts.tv_sec;
+					time->nanoseconds = ts.tv_nsec;
+					break;
+#endif
+				if(cmsg->cmsg_type == SCM_TIMESTAMP) {
+					tv = (struct timeval *)CMSG_DATA(cmsg);
+					time->seconds = tv->tv_sec;
+					time->nanoseconds = tv->tv_usec * 1000;
+					DBGV("kernel MICRO recv time stamp %us %dns\n",
+#endif
+		if (!timestampValid) {
+			 * do not try to get by with recording the time here, better
+			 * to fail because the time recorded could be well after the
+			 * message receive, which would put a big spike in the
+			 * offset signal sent to the clock servo
+			DBG("netRecvEvent: no receive time stamp\n");
+			return 0;
+#ifdef PTPD_PCAP
+#endif
+#ifdef PTPD_PCAP
+	else { /* Using PCAP */
+		/* Discard packet on socket */
+		if (netPath->eventSock >= 0) {
+			recv(netPath->eventSock, buf, PACKET_SIZE, MSG_DONTWAIT);
+		if ((ret = pcap_next_ex(netPath->pcapEvent, &pkt_header,
+					&pkt_data)) < 1) {
+			if (ret < 0)
+				INFO("netRecvEvent: pcap_next_ex failed %s\n",
+				     pcap_geterr(netPath->pcapEvent));
+			return 0;
+	/* Make sure this is IP (could dot1q get here?) */
+	if( ntohs(*(u_short *)(pkt_data + 12)) != ETHERTYPE_IP) {
+		if( ntohs(*(u_short *)(pkt_data + 12)) != PTP_ETHER_TYPE) {
+		DBG("PCAP payload ethertype received not IP or PTP: 0x%04x\n",
+		    ntohs(*(u_short *)(pkt_data + 12)));
+		/* do not count packets if from self */
+		} else if(memcmp(&netPath->interfaceInfo.hwAddress, pkt_data + 6, 6)) {
+	} else {
+	    /* Retrieve source IP from the payload - 14 eth + 12 IP */
+	    netPath->lastSourceAddr = *(Integer32 *)(pkt_data + 26);
+	    /* Retrieve destination IP from the payload - 14 eth + 16 IP */
+	    netPath->lastDestAddr = *(Integer32 *)(pkt_data + 30);
+	    /* do not count packets from self */
+	    if(netPath->lastSourceAddr != netPath->interfaceAddr.s_addr) {
+		/* XXX Total cheat */
+		memcpy(buf, pkt_data + netPath->headerOffset,
+		       pkt_header->caplen - netPath->headerOffset);
+		time->seconds = pkt_header->ts.tv_sec;
+		time->nanoseconds = pkt_header->ts.tv_usec * 1000;
+		DBGV("netRecvEvent: kernel PCAP recv time stamp %us %dns\n",
+		fflush(NULL);
+		ret = pkt_header->caplen - netPath->headerOffset;
+#endif
+	*time = tmpTime;
+#endif
+	return ret;
+ * store received data from network to "buf" get and store the
+ * SO_TIMESTAMP value in "time" for a general message
+ * @param buf
+ * @param time
+ * @param netPath
+ * @return
+ssize_t
+netRecvGeneral(Octet * buf, NetPath * netPath)
+	ssize_t ret = 0;
+#ifdef PTPD_PCAP
+#endif
+	socklen_t from_addr_len = sizeof(from_addr);
+	netPath->lastSourceAddr = 0;
+#ifdef PTPD_PCAP
+	if (netPath->pcapGeneral == NULL) {
+#endif
+		ret=recvfrom(netPath->generalSock, buf, PACKET_SIZE, MSG_DONTWAIT, (struct sockaddr*)&from_addr, &from_addr_len);
+		return ret;
+#ifdef PTPD_PCAP
+#endif
+#ifdef PTPD_PCAP
+			recv(netPath->generalSock, buf, PACKET_SIZE, MSG_DONTWAIT);
+		if (( ret = pcap_next_ex(netPath->pcapGeneral, &pkt_header,
+			if (ret < 0)
+				DBGV("netRecvGeneral: pcap_next_ex failed %d %s\n",
+				     ret, pcap_geterr(netPath->pcapGeneral));
+			return 0;
+	} else {
+		fflush(NULL);
+#endif
+	return ret;
+#ifdef PTPD_PCAP
+ssize_t
+netSendPcapEther(Octet * buf,  UInteger16 length,
+			struct ether_addr * dst, struct ether_addr * src,
+			pcap_t * pcap) {
+	Octet ether[ETHER_HDR_LEN + PACKET_SIZE];
+	memcpy(ether, dst->octet, ETHER_ADDR_LEN);
+	memcpy(ether + ETHER_ADDR_LEN, src->octet, ETHER_ADDR_LEN);
+#else
+	memcpy(ether, dst->ether_addr_octet, ETHER_ADDR_LEN);
+	memcpy(ether + ETHER_ADDR_LEN, src->ether_addr_octet, ETHER_ADDR_LEN);
+	*((short *)&ether[2 * ETHER_ADDR_LEN]) = htons(PTP_ETHER_TYPE);
+	memcpy(ether + ETHER_HDR_LEN, buf, length);
+	return pcap_inject(pcap, ether, ETHER_HDR_LEN + length);
+#endif
+// destinationAddress: destination:
+//   if filled, send to this unicast dest;
+//   if zero, sending to multicast.
+/// TODO: merge these 2 functions into one
+ssize_t
+netSendEvent(Octet * buf, UInteger16 length, NetPath * netPath,
+	     const RunTimeOpts *rtOpts, Integer32 destinationAddress, TimeInternal * tim)
+	ssize_t ret;
+#endif
+#ifdef PTPD_PCAP
+	/* In PCAP Ethernet mode, we use pcapEvent for receiving all messages
+	 * and pcapGeneral for sending all messages
+	if ((netPath->pcapGeneral != NULL) && (rtOpts->transport == IEEE_802_3 )) {
+		ret = netSendPcapEther(buf, length,
+			&netPath->etherDest,
+			(struct ether_addr *)netPath->interfaceID,
+			netPath->pcapGeneral);
+		if (ret <= 0)
+			DBG("Error sending ether multicast event message\n");
+		else {
+			netPath->sentPackets++;
+			netPath->sentPacketsTotal++;
+        } else {
+#endif
+		if (destinationAddress ) {
+			addr.sin_addr.s_addr = destinationAddress;
+			 * This function is used for PTP only anyway - for now.
+			 * If we're sending to a unicast address, set the UNICAST flag.
+			 * Transport API in LibCCK / 2.4 uses a callback for this,
+			 * so the client can do something with the payload before it's sent,
+			 * depending if it's unicast or multicast.
+			*(char *)(buf + 6) |= PTP_UNICAST;
+			ret = sendto(netPath->eventSock, buf, length, 0,
+				     (struct sockaddr *)&addr,
+				     sizeof(struct sockaddr_in));
+			if (ret <= 0)
+				DBG("Error sending unicast event message\n");
+			else {
+#ifndef SO_TIMESTAMPING
+			*tim = tmpTime;
+#else
+			 * Need to forcibly loop back the packet since
+			 * we are not using multicast.
+			addr.sin_addr.s_addr = netPath->interfaceAddr.s_addr;
+			if (ret <= 0)
+				DBGV("Error looping back unicast event message\n");
+#endif
+#else
+#ifdef PTPD_PCAP
+			if((netPath->pcapEvent == NULL) && !netPath->txTimestampFailure) {
+#else
+			if(!netPath->txTimestampFailure) {
+#endif /* PTPD_PCAP */
+				if(!getTxTimestamp(netPath, tim)) {
+					if (tim) {
+						clearTime(tim);
+				/* We've had a TX timestamp receipt timeout - falling back to packet looping */
+				if (ret <= 0)
+					DBG("Error looping back unicast event message\n");
+		} else {
+			addr.sin_addr.s_addr = netPath->multicastAddr;
+                        /* Is TTL OK? */
+			if(netPath->ttlEvent != rtOpts->ttl) {
+				/* Try restoring TTL */
+			if (netSetMulticastTTL(netPath->eventSock,rtOpts->ttl)) {
+			if (ret <= 0)
+				DBG("Error sending multicast event message\n");
+			else {
+#ifdef PTPD_PCAP
+#else
+					if (tim) {
+						clearTime(tim);
+					/* Try re-enabling MULTICAST_LOOP */
+					netSetMulticastLoopback(netPath, TRUE);
+#ifdef PTPD_PCAP
+#endif
+	return ret;
+ssize_t
+netSendGeneral(Octet * buf, UInteger16 length, NetPath * netPath,
+	       const const RunTimeOpts *rtOpts, Integer32 destinationAddress)
+	ssize_t ret;
+#ifdef PTPD_PCAP
+	if ((netPath->pcapGeneral != NULL) && (rtOpts->transport == IEEE_802_3)) {
+		if (ret <= 0)
+			DBG("Error sending ether multicast general message\n");
+		else {
+	} else {
+#endif
+		if(destinationAddress) {
+			 * This function is used for PTP only anyway...
+			ret = sendto(netPath->generalSock, buf, length, 0,
+			if (ret <= 0)
+				DBG("Error sending unicast general message\n");
+			else {
+		} else {
+                        /* Is TTL OK? */
+			if(netPath->ttlGeneral != rtOpts->ttl) {
+				if (netSetMulticastTTL(netPath->generalSock,rtOpts->ttl)) {
+			if (ret <= 0)
+				DBG("Error sending multicast general message\n");
+			else {
+#ifdef PTPD_PCAP
+#endif
+	return ret;
+ssize_t
+netSendPeerGeneral(Octet * buf, UInteger16 length, NetPath * netPath, const RunTimeOpts *rtOpts, Integer32 dst)
+	ssize_t ret;
+#ifdef PTPD_PCAP
+			&netPath->peerEtherDest,
+		if (ret <= 0)
+			DBG("error sending ether multicast general message\n");
+	} else if (dst)
+#else
+	if (dst)
+#endif
+		addr.sin_addr.s_addr = dst;
+		if (ret <= 0)
+			DBG("Error sending unicast peer general message\n");
+	} else {
+		addr.sin_addr.s_addr = netPath->peerMulticastAddr;
+		/* is TTL already 1 ? */
+		if(netPath->ttlGeneral != 1) {
+			/* Try setting TTL to 1 */
+			if (netSetMulticastTTL(netPath->generalSock,1)) {
+				netPath->ttlGeneral = 1;
+		if (ret <= 0)
+			DBG("Error sending multicast peer general message\n");
+	if (ret > 0) {
+	return ret;
+ssize_t
+netSendPeerEvent(Octet * buf, UInteger16 length, NetPath * netPath, const RunTimeOpts *rtOpts, Integer32 dst, TimeInternal * tim)
+	ssize_t ret;
+#ifdef PTPD_PCAP
+		if (ret <= 0)
+	} else if (dst)
+#else
+	if (dst)
+#endif
+		if (ret <= 0)
+			DBG("Error sending unicast peer event message\n");
+		if (ret <= 0)
+			DBG("Error looping back unicast peer event message\n");
+#else
+#ifdef PTPD_PCAP
+#else
+				if (tim) {
+					clearTime(tim);
+		if(netPath->txTimestampFailure) {
+			if (ret <= 0)
+	} else {
+		if(netPath->ttlEvent != 1) {
+			if (netSetMulticastTTL(netPath->eventSock,1)) {
+			    netPath->ttlEvent = 1;
+		if (ret <= 0)
+			DBG("Error sending multicast peer event message\n");
+				if (tim) {
+					clearTime(tim);
+	if (ret > 0) {
+	return ret;
+ * refresh IGMP on a timeout
+Boolean
+netRefreshIGMP(NetPath * netPath, const RunTimeOpts * rtOpts, PtpClock * ptpClock)
+	DBG("netRefreshIGMP\n");
+	if(netPath->joinedGeneral) {
+	if(netPath->joinedPeer) {
+	/* suspend process 100 milliseconds, to make sure the kernel sends the IGMP_leave properly */
+	usleep(100*1000);
+	if (!netInitMulticast(netPath, rtOpts)) {
+		return FALSE;
+	return TRUE;
diff --git a/freebsd/contrib/ptpd/src/dep/ntpengine/ntp_isc_md5.c b/freebsd/contrib/ptpd/src/dep/ntpengine/ntp_isc_md5.c
new file mode 100644
index 00000000..e4e34ac9
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/ntpengine/ntp_isc_md5.c
@@ -0,0 +1,273 @@
+ * This file contains the minimal set of declarations and constants
+ * extracted from the ISC MD5 code and ntpdc code included with NTP 4
+ * distribution version 4.2.6p5 to allow computing the MD5 digest
+ * for NTP type 7 packets
+/* Original copyright notice */
+ * Copyright (C) 2004-2007  Internet Systems Consortium, Inc. ("ISC")
+ * Copyright (C) 2000, 2001  Internet Software Consortium.
+ * Permission to use, copy, modify, and/or distribute this software for any
+ * purpose with or without fee is hereby granted, provided that the above
+ * copyright notice and this permission notice appear in all copies.
+ * THE SOFTWARE IS PROVIDED "AS IS" AND ISC DISCLAIMS ALL WARRANTIES WITH
+ * REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF MERCHANTABILITY
+ * AND FITNESS.  IN NO EVENT SHALL ISC BE LIABLE FOR ANY SPECIAL, DIRECT,
+ * INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES WHATSOEVER RESULTING FROM
+ * LOSS OF USE, DATA OR PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE
+ * OR OTHER TORTIOUS ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR
+ * PERFORMANCE OF THIS SOFTWARE.
+#include "../../ptpd.h"
+#include "ntp_isc_md5.h"
+void    ntp_memset      (char *, int, int);
+#define memcmp(a, b, c)         bcmp(a, b, (int)(c))
+#define memmove(t, f, c)        bcopy(f, t, (int)(c))
+#define memcpy(t, f, c)         bcopy(f, t, (int)(c))
+#define memset(a, x, c)         if (0 == (x)) \
+                                        bzero(a, (int)(c)); \
+                                else \
+                                        ntp_memset((char *)(a), x, c)
+static void
+byteSwap(uint32_t *buf, unsigned words)
+	unsigned char *p = (unsigned char *)buf;
+	do {
+		*buf++ = (uint32_t)((unsigned)p[3] << 8 | p[2]) << 16 |
+			((unsigned)p[1] << 8 | p[0]);
+		p += 4;
+	} while (--words);
+ * Start MD5 accumulation.  Set bit count to 0 and buffer to mysterious
+ * initialization constants.
+void
+isc_md5_init(isc_md5_t *ctx) {
+	ctx->buf[0] = 0x67452301;
+	ctx->buf[1] = 0xefcdab89;
+	ctx->buf[2] = 0x98badcfe;
+	ctx->buf[3] = 0x10325476;
+	ctx->bytes[0] = 0;
+	ctx->bytes[1] = 0;
+void
+isc_md5_invalidate(isc_md5_t *ctx) {
+	memset(ctx, 0, sizeof(isc_md5_t));
+/*! The four core functions - F1 is optimized somewhat */
+/* #define F1(x, y, z) (x & y | ~x & z) */
+#define F1(x, y, z) (z ^ (x & (y ^ z)))
+#define F2(x, y, z) F1(z, x, y)
+#define F3(x, y, z) (x ^ y ^ z)
+#define F4(x, y, z) (y ^ (x | ~z))
+/*! This is the central step in the MD5 algorithm. */
+#define MD5STEP(f,w,x,y,z,in,s) \
+	 (w += f(x,y,z) + in, w = (w<<s | w>>(32-s)) + x)
+ * The core of the MD5 algorithm, this alters an existing MD5 hash to
+ * reflect the addition of 16 longwords of new data.  MD5Update blocks
+ * the data and converts bytes into longwords for this routine.
+static void
+transform(uint32_t buf[4], uint32_t const in[16]) {
+	register uint32_t a, b, c, d;
+	a = buf[0];
+	b = buf[1];
+	c = buf[2];
+	d = buf[3];
+	MD5STEP(F1, a, b, c, d, in[0] + 0xd76aa478, 7);
+	MD5STEP(F1, d, a, b, c, in[1] + 0xe8c7b756, 12);
+	MD5STEP(F1, c, d, a, b, in[2] + 0x242070db, 17);
+	MD5STEP(F1, b, c, d, a, in[3] + 0xc1bdceee, 22);
+	MD5STEP(F1, a, b, c, d, in[4] + 0xf57c0faf, 7);
+	MD5STEP(F1, d, a, b, c, in[5] + 0x4787c62a, 12);
+	MD5STEP(F1, c, d, a, b, in[6] + 0xa8304613, 17);
+	MD5STEP(F1, b, c, d, a, in[7] + 0xfd469501, 22);
+	MD5STEP(F1, a, b, c, d, in[8] + 0x698098d8, 7);
+	MD5STEP(F1, d, a, b, c, in[9] + 0x8b44f7af, 12);
+	MD5STEP(F1, c, d, a, b, in[10] + 0xffff5bb1, 17);
+	MD5STEP(F1, b, c, d, a, in[11] + 0x895cd7be, 22);
+	MD5STEP(F1, a, b, c, d, in[12] + 0x6b901122, 7);
+	MD5STEP(F1, d, a, b, c, in[13] + 0xfd987193, 12);
+	MD5STEP(F1, c, d, a, b, in[14] + 0xa679438e, 17);
+	MD5STEP(F1, b, c, d, a, in[15] + 0x49b40821, 22);
+	MD5STEP(F2, a, b, c, d, in[1] + 0xf61e2562, 5);
+	MD5STEP(F2, d, a, b, c, in[6] + 0xc040b340, 9);
+	MD5STEP(F2, c, d, a, b, in[11] + 0x265e5a51, 14);
+	MD5STEP(F2, b, c, d, a, in[0] + 0xe9b6c7aa, 20);
+	MD5STEP(F2, a, b, c, d, in[5] + 0xd62f105d, 5);
+	MD5STEP(F2, d, a, b, c, in[10] + 0x02441453, 9);
+	MD5STEP(F2, c, d, a, b, in[15] + 0xd8a1e681, 14);
+	MD5STEP(F2, b, c, d, a, in[4] + 0xe7d3fbc8, 20);
+	MD5STEP(F2, a, b, c, d, in[9] + 0x21e1cde6, 5);
+	MD5STEP(F2, d, a, b, c, in[14] + 0xc33707d6, 9);
+	MD5STEP(F2, c, d, a, b, in[3] + 0xf4d50d87, 14);
+	MD5STEP(F2, b, c, d, a, in[8] + 0x455a14ed, 20);
+	MD5STEP(F2, a, b, c, d, in[13] + 0xa9e3e905, 5);
+	MD5STEP(F2, d, a, b, c, in[2] + 0xfcefa3f8, 9);
+	MD5STEP(F2, c, d, a, b, in[7] + 0x676f02d9, 14);
+	MD5STEP(F2, b, c, d, a, in[12] + 0x8d2a4c8a, 20);
+	MD5STEP(F3, a, b, c, d, in[5] + 0xfffa3942, 4);
+	MD5STEP(F3, d, a, b, c, in[8] + 0x8771f681, 11);
+	MD5STEP(F3, c, d, a, b, in[11] + 0x6d9d6122, 16);
+	MD5STEP(F3, b, c, d, a, in[14] + 0xfde5380c, 23);
+	MD5STEP(F3, a, b, c, d, in[1] + 0xa4beea44, 4);
+	MD5STEP(F3, d, a, b, c, in[4] + 0x4bdecfa9, 11);
+	MD5STEP(F3, c, d, a, b, in[7] + 0xf6bb4b60, 16);
+	MD5STEP(F3, b, c, d, a, in[10] + 0xbebfbc70, 23);
+	MD5STEP(F3, a, b, c, d, in[13] + 0x289b7ec6, 4);
+	MD5STEP(F3, d, a, b, c, in[0] + 0xeaa127fa, 11);
+	MD5STEP(F3, c, d, a, b, in[3] + 0xd4ef3085, 16);
+	MD5STEP(F3, b, c, d, a, in[6] + 0x04881d05, 23);
+	MD5STEP(F3, a, b, c, d, in[9] + 0xd9d4d039, 4);
+	MD5STEP(F3, d, a, b, c, in[12] + 0xe6db99e5, 11);
+	MD5STEP(F3, c, d, a, b, in[15] + 0x1fa27cf8, 16);
+	MD5STEP(F3, b, c, d, a, in[2] + 0xc4ac5665, 23);
+	MD5STEP(F4, a, b, c, d, in[0] + 0xf4292244, 6);
+	MD5STEP(F4, d, a, b, c, in[7] + 0x432aff97, 10);
+	MD5STEP(F4, c, d, a, b, in[14] + 0xab9423a7, 15);
+	MD5STEP(F4, b, c, d, a, in[5] + 0xfc93a039, 21);
+	MD5STEP(F4, a, b, c, d, in[12] + 0x655b59c3, 6);
+	MD5STEP(F4, d, a, b, c, in[3] + 0x8f0ccc92, 10);
+	MD5STEP(F4, c, d, a, b, in[10] + 0xffeff47d, 15);
+	MD5STEP(F4, b, c, d, a, in[1] + 0x85845dd1, 21);
+	MD5STEP(F4, a, b, c, d, in[8] + 0x6fa87e4f, 6);
+	MD5STEP(F4, d, a, b, c, in[15] + 0xfe2ce6e0, 10);
+	MD5STEP(F4, c, d, a, b, in[6] + 0xa3014314, 15);
+	MD5STEP(F4, b, c, d, a, in[13] + 0x4e0811a1, 21);
+	MD5STEP(F4, a, b, c, d, in[4] + 0xf7537e82, 6);
+	MD5STEP(F4, d, a, b, c, in[11] + 0xbd3af235, 10);
+	MD5STEP(F4, c, d, a, b, in[2] + 0x2ad7d2bb, 15);
+	MD5STEP(F4, b, c, d, a, in[9] + 0xeb86d391, 21);
+	buf[0] += a;
+	buf[1] += b;
+	buf[2] += c;
+	buf[3] += d;
+ * Update context to reflect the concatenation of another buffer full
+ * of bytes.
+void
+isc_md5_update(isc_md5_t *ctx, const unsigned char *buf, unsigned int len) {
+	uint32_t t;
+	/* Update byte count */
+	t = ctx->bytes[0];
+	if ((ctx->bytes[0] = t + len) < t)
+		ctx->bytes[1]++;	/* Carry from low to high */
+	t = 64 - (t & 0x3f);	/* Space available in ctx->in (at least 1) */
+	if (t > len) {
+		memcpy((unsigned char *)ctx->in + 64 - t, buf, len);
+		return;
+	/* First chunk is an odd size */
+	memcpy((unsigned char *)ctx->in + 64 - t, buf, t);
+	byteSwap(ctx->in, 16);
+	transform(ctx->buf, ctx->in);
+	buf += t;
+	len -= t;
+	/* Process data in 64-byte chunks */
+	while (len >= 64) {
+		memcpy(ctx->in, buf, 64);
+		buf += 64;
+		len -= 64;
+	/* Handle any remaining bytes of data. */
+	memcpy(ctx->in, buf, len);
+ * Final wrapup - pad to 64-byte boundary with the bit pattern
+ * 1 0* (64-bit count of bits processed, MSB-first)
+void
+isc_md5_final(isc_md5_t *ctx, unsigned char *digest) {
+	int count = ctx->bytes[0] & 0x3f;    /* Number of bytes in ctx->in */
+	unsigned char *p = (unsigned char *)ctx->in + count;
+	/* Set the first char of padding to 0x80.  There is always room. */
+	*p++ = 0x80;
+	/* Bytes of padding needed to make 56 bytes (-8..55) */
+	count = 56 - 1 - count;
+	if (count < 0) {	/* Padding forces an extra block */
+		memset(p, 0, count + 8);
+		p = (unsigned char *)ctx->in;
+		count = 56;
+	memset(p, 0, count);
+	byteSwap(ctx->in, 14);
+	/* Append length in bits and transform */
+	ctx->in[14] = ctx->bytes[0] << 3;
+	ctx->in[15] = ctx->bytes[1] << 3 | ctx->bytes[0] >> 29;
+	byteSwap(ctx->buf, 4);
+	memcpy(digest, ctx->buf, 16);
+	memset(ctx, 0, sizeof(isc_md5_t));	/* In case it's sensitive */
+ * MD5authencrypt - generate message digest
+ * Returns length of MAC including key ID and digest.
+int
+MD5authencrypt(
+	char *key,		/* key pointer */
+	uint32_t *pkt,		/* packet pointer */
+	int	length,
+	keyid_t keyid
+	u_char	digest[64];
+	u_int	len;
+	PTPD_EVP_MD_CTX ctx;
+        pkt[length / 4] = htonl(keyid);
+	EVP_DigestInit(&ctx);
+	EVP_DigestUpdate(&ctx, (u_char *)key, (u_int)strlen(key));
+	EVP_DigestUpdate(&ctx, (u_char *)pkt, (u_int)length);
+	EVP_DigestFinal(&ctx, digest, &len);
+	memmove((u_char *)pkt + length + 4, digest, len);
+	return (len + 4);
diff --git a/freebsd/contrib/ptpd/src/dep/ntpengine/ntp_isc_md5.h b/freebsd/contrib/ptpd/src/dep/ntpengine/ntp_isc_md5.h
index 00000000..236c0e4b
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/ntpengine/ntp_isc_md5.h
@@ -0,0 +1,99 @@
+ * extracted from the ISC MD5 code included with NTP 4 distribution
+ * version 4.2.6p5 to allow computing the MAC for NTP type 7 packets
+/* $Id: md5.h,v 1.16 2007/06/19 23:47:18 tbox Exp $ */
+/*! \file isc/md5.h
+ * \brief This is the header file for the MD5 message-digest algorithm.
+ * The algorithm is due to Ron Rivest.  This code was
+ * written by Colin Plumb in 1993, no copyright is claimed.
+ * This code is in the public domain; do with it what you wish.
+ * Equivalent code is available from RSA Data Security, Inc.
+ * This code has been tested against that, and is equivalent,
+ * except that you don't need to include two pages of legalese
+ * with every copy.
+ * To compute the message digest of a chunk of bytes, declare an
+ * MD5Context structure, pass it to MD5Init, call MD5Update as
+ * needed on buffers full of bytes, and then call MD5Final, which
+ * will fill a supplied 16-byte array with the digest.
+ * Changed so as no longer to depend on Colin Plumb's `usual.h'
+ * header definitions; now uses stuff from dpkg's config.h
+ *  - Ian Jackson <ijackson at nyx.cs.du.edu>.
+ * Still in the public domain.
+#ifndef ISC_MD5_H
+#define ISC_MD5_H 1
+#ifdef HAVE_STRINGS_H
+#include <strings.h>
+#endif /* HAVE_STRINGS_H */
+#define ISC_MD5_DIGESTLENGTH 16U
+typedef struct {
+	uint32_t buf[4];
+	uint32_t bytes[2];
+	uint32_t in[16];
+} isc_md5_t;
+void
+isc_md5_init(isc_md5_t *ctx);
+void
+isc_md5_invalidate(isc_md5_t *ctx);
+void
+isc_md5_update(isc_md5_t *ctx, const unsigned char *buf, unsigned int len);
+void
+isc_md5_final(isc_md5_t *ctx, unsigned char *digest);
+  typedef isc_md5_t             MD5_CTX;
+# define MD5Init(c)             isc_md5_init(c)
+# define MD5Update(c, p, s)     isc_md5_update(c, p, s)
+# define MD5Final(d, c)         isc_md5_final((c), (d)) /* swapped */
+  typedef MD5_CTX                       PTPD_EVP_MD_CTX;
+# define EVP_DigestInit(c)              MD5Init(c)
+# define EVP_DigestUpdate(c, p, s)      MD5Update(c, p, s)
+# define EVP_DigestFinal(c, d, pdl)     \
+        do {                            \
+                MD5Final((d), (c));     \
+                *(pdl) = 16;            \
+        } while (0)
+#define NID_md5  4
+#define JAN_1970 2208988800UL
+#define FRAC 4294967296LL
+int MD5authencrypt( char *key, uint32_t *pkt, int length, keyid_t keyid );
+#endif /* ISC_MD5_H */
diff --git a/freebsd/contrib/ptpd/src/dep/ntpengine/ntpdcontrol.c b/freebsd/contrib/ptpd/src/dep/ntpengine/ntpdcontrol.c
index 00000000..0c83adb1
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/ntpengine/ntpdcontrol.c
@@ -0,0 +1,874 @@
+ * Copyright (c) 2013-2015 Wojciech Owczarek,
+ * met:
+ * @file   ntpdcontrol.c
+ * @date   Tue Jul 20 22:19:20 2013
+ * @brief  Functions allowing remote control of the ntpd daemon
+ *         using mode 7 packets
+ * This code is largely based on the source code of the ntpdc utility from the
+ * NTP distribution version 4.2.6p5 and is mostly a bridge between PTPd2 APIs
+ * and NTPDc code - functionality so far is limited to setting and clearing system
+ * flags to allow failover to- and -from (local) NTP
+/* Original NTP4 copyright notice */
+ * Copyright (c) University of Delaware 1992-2011                      *
+ * Permission to use, copy, modify, and distribute this software and   *
+ * its documentation for any purpose with or without fee is hereby     *
+ * granted, provided that the above copyright notice appears in all    *
+ * copies and that both the copyright notice and this permission       *
+ * notice appear in supporting documentation, and that the name        *
+ * University of Delaware not be used in advertising or publicity      *
+ * pertaining to distribution of the software without specific,        *
+ * written prior permission. The University of Delaware makes no       *
+ * representations about the suitability this software for any         *
+ * purpose. It is provided "as is" without express or implied          *
+ * warranty.                                                           *
+#define NTP_PORT 123
+char *ntpdc_pktdata;
+Boolean
+ntpInit(NTPoptions* options, NTPcontrol* control)
+	int res = TRUE;
+	TimingService service = control->timingService;
+	control->sockFD = -1;
+	if(!options->enableEngine)
+	    return FALSE;
+	memset(control, 0, sizeof(*control));
+	/* preserve TimingService... temporary */
+	control->timingService = service;
+	if(!hostLookup(options->hostAddress, &control->serverAddress)) {
+                control->serverAddress = 0;
+		return FALSE;
+        if ((control->sockFD = socket(PF_INET, SOCK_DGRAM, IPPROTO_UDP)) < 0 ) {
+                PERROR("failed to initalize NTP control socket");
+                return FALSE;
+	/* This will attempt to read the ntpd control flags for the first time */
+	res = ntpdInControl(options, control);
+       if (res != INFO_YES && res != INFO_NO) {
+		return FALSE;
+	DBGV("NTPd original flags: %d\n", control->originalFlags);
+	return TRUE;
+Boolean
+ntpShutdown(NTPoptions* options, NTPcontrol* control)
+	/* Attempt reverting ntpd flags to the original value */
+	if(control->flagsCaptured) {
+		/* we only control the kernel and ntp flags */
+	/* just to avoid -Wunused* */
+#ifdef RUNTIME_DEBUG
+		int resC = ntpdClearFlags(options, control, ~(control->originalFlags) & (INFO_FLAG_KERNEL | INFO_FLAG_NTP));
+		int resS = ntpdSetFlags(options, control, control->originalFlags & (INFO_FLAG_KERNEL | INFO_FLAG_NTP));
+		DBGV("Attempting to revert NTPd flags to %d - result: clear %d set %d\n", control->originalFlags,
+			    resC, resS);
+#else
+		ntpdClearFlags(options, control, ~(control->originalFlags) & (INFO_FLAG_KERNEL | INFO_FLAG_NTP));
+		ntpdSetFlags(options, control, control->originalFlags & (INFO_FLAG_KERNEL | INFO_FLAG_NTP));
+#endif /* RUNTIME_DEBUG */
+        if (control->sockFD > 0)
+                close(control->sockFD);
+	return TRUE;
+static ssize_t
+ntpSend(NTPcontrol* control, Octet * buf, UInteger16 length)
+        ssize_t ret = -1;
+        addr.sin_port = htons(NTP_PORT);
+        if (control->serverAddress) {
+                addr.sin_addr.s_addr = control->serverAddress;
+                ret = sendto(control->sockFD, buf, length, 0,
+                if (ret <= 0)
+                        INFO("error sending NTP control message\n");
+        return ret;
+ * Default values we use
+#define	DEFHOST		"localhost"	/* default host name */
+#define	DEFTIMEOUT	(5)		/* 5 second time out */
+#define	DEFSTIMEOUT	(2)		/* 2 second time out after first */
+#define	DEFDELAY	0x51EB852	/* 20 milliseconds, l_fp fraction */
+#define	LENHOSTNAME	256		/* host name is 256 characters long */
+#define	MAXCMDS		100		/* maximum commands on cmd line */
+#define	MAXHOSTS	200		/* maximum hosts on cmd line */
+#define	MAXLINE		512		/* maximum line length */
+#define	MAXTOKENS	(1+1+MAXARGS+MOREARGS+2)	/* maximum number of usable tokens */
+#define	SCREENWIDTH  	78		/* nominal screen width in columns */
+#define	INITDATASIZE	(sizeof(struct resp_pkt) * 16)
+#define	INCDATASIZE	(sizeof(struct resp_pkt) * 8)
+ * These are used to help the magic with old and new versions of ntpd.
+#define IMPL_XNTPD      3
+int impl_ver = IMPL_XNTPD;
+#define REQ_LEN_NOMAC   (offsetof(struct req_pkt, keyid))
+static int req_pkt_size = REQ_LEN_NOMAC;
+#define	ERR_INCOMPLETE		16
+#define	ERR_TIMEOUT		17
+static void
+get_systime(
+        l_fp *now               /* system time */
+        double dtemp;
+#if defined(HAVE_CLOCK_GETTIME) || defined(HAVE_GETCLOCK)
+        struct timespec ts;     /* seconds and nanoseconds */
+         * Convert Unix clock from seconds and nanoseconds to seconds.
+# ifdef HAVE_CLOCK_GETTIME
+        clock_gettime(CLOCK_REALTIME, &ts);
+# else
+        getclock(TIMEOFDAY, &ts);
+# endif
+        now->l_i = ts.tv_sec + JAN_1970;
+        dtemp = ts.tv_nsec / 1e9;
+#else /* HAVE_CLOCK_GETTIME || HAVE_GETCLOCK */
+        struct timeval tv;      /* seconds and microseconds */
+         * Convert Unix clock from seconds and microseconds to seconds.
+        gettimeofday(&tv, NULL);
+        now->l_i = tv.tv_sec + JAN_1970;
+        dtemp = tv.tv_usec / 1e6;
+#endif /* HAVE_CLOCK_GETTIME || HAVE_GETCLOCK */
+         * Renormalize to seconds past 1900 and fraction.
+//        dtemp += sys_residual;
+        if (dtemp >= 1) {
+                dtemp -= 1;
+                now->l_i++;
+        } else if (dtemp < -1) {
+                dtemp += 1;
+                now->l_i--;
+        dtemp *= FRAC;
+        now->l_uf = (uint32_t)dtemp;
+static int
+NTPDCrequest(
+	NTPoptions* options,
+	NTPcontrol* control,
+	int reqcode,
+	int auth,
+	u_int qitems,
+	size_t qsize,
+	char *qdata
+	l_fp delay_time = { .l_ui=0, .l_uf=0x51EB852};
+	struct req_pkt qpkt;
+	size_t	datasize;
+	size_t	reqsize;
+	l_fp	ts;
+	l_fp *	ptstamp;
+	int	maclen;
+	static char *key;
+	key=calloc(21,sizeof(char));
+	strncpy(key,options->key,20);
+	memset(&qpkt, 0, sizeof(qpkt));
+	qpkt.rm_vn_mode = RM_VN_MODE(0, 0, 0);
+	qpkt.implementation = (u_char)3;
+	qpkt.request = (u_char)reqcode;
+	datasize = qitems * qsize;
+	if (datasize && qdata != NULL) {
+		memcpy(qpkt.data, qdata, datasize);
+		qpkt.err_nitems = ERR_NITEMS(0, qitems);
+		qpkt.mbz_itemsize = MBZ_ITEMSIZE(qsize);
+	} else {
+		qpkt.err_nitems = ERR_NITEMS(0, 0);
+		qpkt.mbz_itemsize = MBZ_ITEMSIZE(qsize);  /* allow for optional first item */
+	if (!auth) {
+		qpkt.auth_seq = AUTH_SEQ(0, 0);
+		return ntpSend(control, (Octet *)&qpkt, req_pkt_size);
+		qpkt.auth_seq = AUTH_SEQ(1, 0);
+		reqsize = req_pkt_size;
+	ptstamp = (void *)((u_char *)&qpkt + reqsize);
+	ptstamp--;
+	get_systime(&ts);
+	L_ADD(&ts, &delay_time);
+	HTONL_FP(&ts, ptstamp);
+	maclen = MD5authencrypt(key, (void *)&qpkt, reqsize,options->keyId);
+	free(key);
+	if (!maclen || (maclen != (16 + sizeof(keyid_t))))
+		ERROR("Error while computing NTP MD5 hash\n");
+		return 1;
+	return ntpSend(control, (Octet *)&qpkt, reqsize + maclen);
+ * checkitems - utility to print a message if no items were returned
+static int
+checkitems(
+	int items
+	if (items == 0) {
+		return 0;
+	return 1;
+ * checkitemsize - utility to print a message if the item size is wrong
+static int
+checkitemsize(
+	int itemsize,
+	int expected
+	if (itemsize != expected) {
+		return 0;
+	return 1;
+ * check1item - check to make sure we have exactly one item
+static int
+check1item(
+	int items
+	if (items == 0) {
+		return 0;
+	if (items > 1) {
+		return 0;
+	return 1;
+static int
+NTPDCresponse(
+	int reqcode,
+	int *ritems,
+	int *rsize,
+	char **rdata,
+	int esize
+	struct resp_pkt rpkt;
+	struct timeval tvo;
+	int items;
+	int i;
+	int size;
+	int datasize;
+	char *datap;
+	char *tmp_data;
+	char haveseq[MAXSEQ+1];
+	int firstpkt;
+	int lastseq;
+	int numrecv;
+	int seq;
+	fd_set fds;
+	int n;
+	int pad;
+	int retries = NTP_EINTR_RETRIES;
+        int ntpdc_pktdatasize;
+	int implcode=(u_char)3;
+	static  struct timeval tvout = { DEFTIMEOUT, 0 };   /* time out for reads */
+	static  struct timeval tvsout = { DEFSTIMEOUT, 0 }; /* secondary time out */
+//	static char *currenthost = "localhost";
+        ntpdc_pktdatasize = INITDATASIZE;
+        ntpdc_pktdata = realloc(ntpdc_pktdata,INITDATASIZE);
+	 * This is pretty tricky.  We may get between 1 and many packets
+	 * back in response to the request.  We peel the data out of
+	 * each packet and collect it in one long block.  When the last
+	 * packet in the sequence is received we'll know how many we
+	 * should have had.  Note we use one long time out, should reconsider.
+	*ritems = 0;
+	*rsize = 0;
+	firstpkt = 1;
+	numrecv = 0;
+	lastseq = 999;	/* too big to be a sequence number */
+	memset(haveseq, 0, sizeof(haveseq));
+    again:
+	if (firstpkt)
+		tvo = tvout;
+	else
+		tvo = tvsout;
+	do {
+	    FD_ZERO(&fds);
+	    FD_SET(control->sockFD, &fds);
+	    n = select(control->sockFD+1, &fds, (fd_set *)0, (fd_set *)0, &tvo);
+	    if(n == -1) {
+		if(errno == EINTR) {
+		DBG("NTPDCresponse(): EINTR caught\n");
+		    retries--;
+		} else {
+		    retries = 0;
+	} while ((n == -1) && retries);
+	if (n == -1) {
+	    DBG("NTPDCresponse(): select failed - not EINTR: %s\n", strerror(errno));
+		return -1;
+	if (n == 0) {
+		DBG("NTP response select timeout");
+		if (firstpkt) {
+			return ERR_TIMEOUT;
+		} else {
+			return ERR_INCOMPLETE;
+	n = recv(control->sockFD, (char *)&rpkt, sizeof(rpkt), 0);
+	if (n == -1) {
+	    DBG("NTP response recv failed\n");
+	    return -1;
+	 * Check for format errors.  Bug proofing.
+	if (n < RESP_HEADER_SIZE) {
+		goto again;
+	if (INFO_VERSION(rpkt.rm_vn_mode) > NTP_VERSION ||
+	    INFO_VERSION(rpkt.rm_vn_mode) < NTP_OLDVERSION) {
+/*		if (debug)
+		    printf("Packet received with version %d\n",
+			   INFO_VERSION(rpkt.rm_vn_mode));
+		goto again;
+	if (INFO_MODE(rpkt.rm_vn_mode) != MODE_PRIVATE) {
+/*		if (debug)
+		    printf("Packet received with mode %d\n",
+			   INFO_MODE(rpkt.rm_vn_mode));
+		goto again;
+	if (INFO_IS_AUTH(rpkt.auth_seq)) {
+		if (debug)
+		    printf("Encrypted packet received\n");
+		goto again;
+	if (!ISRESPONSE(rpkt.rm_vn_mode)) {
+		if (debug)
+		    printf("Received request packet, wanted response\n");
+		goto again;
+	if (INFO_MBZ(rpkt.mbz_itemsize) != 0) {
+		if (debug)
+		    printf("Received packet with nonzero MBZ field!\n");
+		goto again;
+	 * Check implementation/request.  Could be old data getting to us.
+	if (rpkt.implementation != implcode || rpkt.request != reqcode) {
+		if (debug)
+		    printf(
+			    "Received implementation/request of %d/%d, wanted %d/%d",
+			    rpkt.implementation, rpkt.request,
+			    implcode, reqcode);
+		goto again;
+	 * Check the error code.  If non-zero, return it.
+	if (INFO_ERR(rpkt.err_nitems) != INFO_OKAY) {
+		if (debug && ISMORE(rpkt.rm_vn_mode)) {
+			printf("Error code %d received on not-final packet\n",
+			       INFO_ERR(rpkt.err_nitems));
+		return (int)INFO_ERR(rpkt.err_nitems);
+	 * Collect items and size.  Make sure they make sense.
+	items = INFO_NITEMS(rpkt.err_nitems);
+	size = INFO_ITEMSIZE(rpkt.mbz_itemsize);
+	if (esize > size)
+		pad = esize - size;
+	else
+		pad = 0;
+	datasize = items * size;
+	if ((size_t)datasize > (n-RESP_HEADER_SIZE)) {
+/*		if (debug)
+		    printf(
+			    "Received items %d, size %d (total %d), data in packet is %lu\n",
+			    items, size, datasize, (u_long)(n-RESP_HEADER_SIZE));
+		goto again;
+	 * If this isn't our first packet, make sure the size matches
+	 * the other ones.
+	if (!firstpkt && esize != *rsize) {
+/*		if (debug)
+		    printf("Received itemsize %d, previous %d\n",
+			   size, *rsize);
+		goto again;
+	 * If we've received this before, +toss it
+	seq = INFO_SEQ(rpkt.auth_seq);
+	if (haveseq[seq]) {
+/*		if (debug)
+		    printf("Received duplicate sequence number %d\n", seq);
+		goto again;
+	haveseq[seq] = 1;
+	 * If this is the last in the sequence, record that.
+	if (!ISMORE(rpkt.rm_vn_mode)) {
+		if (lastseq != 999) {
+			DBGV("NTPDC Received second end sequence packet\n");
+			goto again;
+		lastseq = seq;
+	*rdata = datap = ntpdc_pktdata;
+	 * So far, so good.  Copy this data into the output array.
+	if ((datap + datasize + (pad * items)) > (ntpdc_pktdata + ntpdc_pktdatasize)) {
+		int offset = datap - ntpdc_pktdata;
+		ntpdc_pktdatasize += INCDATASIZE;
+		ntpdc_pktdata = realloc(ntpdc_pktdata, (size_t)ntpdc_pktdatasize);
+		*rdata = ntpdc_pktdata; /* might have been realloced ! */
+		datap = ntpdc_pktdata + offset;
+	 * We now move the pointer along according to size and number of
+	 * items.  This is so we can play nice with older implementations
+	tmp_data = rpkt.data;
+	for (i = 0; i < items; i++) {
+		memcpy(datap, tmp_data, (unsigned)size);
+		tmp_data += size;
+		memset(datap + size, 0, pad);
+		datap += size + pad;
+	if (firstpkt) {
+		firstpkt = 0;
+		*rsize = size + pad;
+	*ritems += items;
+	 * Finally, check the count of received packets.  If we've got them
+	 * all, return
+	++numrecv;
+	if (numrecv <= lastseq)
+		goto again;
+	return INFO_OKAY;
+static int
+NTPDCquery(
+	int reqcode,
+	int auth,
+	int qitems,
+	int qsize,
+	char *qdata,
+	int *ritems,
+	int *rsize,
+	char **rdata,
+ 	int quiet_mask,
+	int esize
+	int res;
+	char junk[512];
+	fd_set fds;
+	struct timeval tvzero;
+//	int implcode=(u_char)3;
+	 * Poll the socket and clear out any pending data
+again:
+	do {
+		tvzero.tv_sec = tvzero.tv_usec = 0;
+		FD_ZERO(&fds);
+		res = select(control->sockFD+1, &fds, (fd_set *)0, (fd_set *)0, &tvzero);
+		if (res == -1) {
+			if((errno == EINTR) && retries ) {
+			    DBG("NTPDCquery(): select EINTR caught");
+			    retries--;
+			    res = 1;
+			    continue;
+			DBG("NTPDCquery(): select() error - not EINTR: %s\n", strerror(errno));
+			return -1;
+		} else if (res > 0) {
+		    (void) recv(control->sockFD, junk, sizeof junk, 0);
+	} while (res > 0);
+	 * send a request
+	res = NTPDCrequest(options, control, reqcode, auth, qitems, qsize, qdata);
+	if (res <= 0) {
+		return res;
+	 * Get the response.  If we got a standard error, print a message
+	res = NTPDCresponse(options, control, reqcode, ritems, rsize, rdata, esize);
+	 * Try to be compatible with older implementations of ntpd.
+	if (res == INFO_ERR_FMT && req_pkt_size != 48) {
+#if defined(RUNTIME_DEBUG) || defined (PTPD_DBGV)
+		int oldsize  = req_pkt_size;
+		switch(req_pkt_size) {
+		case REQ_LEN_NOMAC:
+			req_pkt_size = 160;
+			break;
+		case 160:
+			req_pkt_size = 48;
+			break;
+		if (impl_ver == IMPL_XNTPD) {
+			DBGV(
+			    "NTPDC ***Warning changing to older implementation\n");
+			return INFO_ERR_IMPL;
+		DBGV(
+		    "NTPDC ***Warning changing the request packet size from %d to %d\n",
+		    oldsize, req_pkt_size);
+		goto again;
+	return res;
+int
+ntpdControlFlags(NTPoptions* options, NTPcontrol* control, int req, int flags)
+	struct conf_sys_flags sys;
+	int items;
+	int itemsize;
+	char *dummy;
+	int res;
+	sys.flags = 0;
+	res = 0;
+	sys.flags = flags;
+	sys.flags = htonl(sys.flags);
+	res = NTPDCquery(options, control, req, 1, 1,
+		      sizeof(struct conf_sys_flags), (char *)&sys, &items,
+		      &itemsize, &dummy, 0, sizeof(struct conf_sys_flags));
+	if ((res != INFO_OKAY) && (sys.flags == 0))
+	    return 0;
+	if (res != INFO_OKAY) {
+	switch (res) {
+	case -1:
+		if(!control->requestFailed) ERROR("Cannot connect to NTP daemon\n");
+		break;
+	case INFO_ERR_AUTH:
+		if(!control->requestFailed) ERROR("NTP permission denied: check key id, password and NTP configuration\n");
+		break;
+	case ERR_TIMEOUT:
+		if(!control->requestFailed) ERROR("Timeout while connecting to NTP daemon\n");
+		break;
+	default:
+	ERROR("NTP protocol error\n");
+	return res;
+int
+ntpdSetFlags(NTPoptions* options, NTPcontrol* control, int flags)
+	int res;
+	ntpdc_pktdata = malloc(INITDATASIZE);
+	DBGV("Setting NTP flags %d\n", flags);
+	res=ntpdControlFlags(options, control, REQ_SET_SYS_FLAG, flags);
+	free(ntpdc_pktdata);
+	return res;
+int
+ntpdClearFlags(NTPoptions* options, NTPcontrol* control, int flags)
+	int res;
+	DBGV("Clearing NTP flags %d\n", flags);
+	res=ntpdControlFlags(options, control, REQ_CLR_SYS_FLAG, flags);
+	return res;
+int
+ntpdInControl(NTPoptions* options, NTPcontrol* control)
+	struct info_sys *is;
+	int items;
+	int itemsize;
+	int res;
+	res = NTPDCquery(options, control, REQ_SYS_INFO, 0, 0, 0, (char *)NULL,
+		      &items, &itemsize, (void *)&is, 0,
+		      sizeof(struct info_sys));
+	if ( res != 0 )
+	    goto end;
+	if (!check1item(items)) {
+	    res=INFO_ERR_EMPTY;
+	    goto end;
+	if (!checkitemsize(itemsize, sizeof(struct info_sys)) &&
+	    !checkitemsize(itemsize, v4sizeof(struct info_sys))) {
+	    goto end;
+	if (is->flags & INFO_FLAG_NTP) DBGV("NTP flag seen: ntp\n");
+	if (is->flags & INFO_FLAG_KERNEL) DBGV("NTP flag seen: kernel\n");
+	if(!control->flagsCaptured) {
+		control->originalFlags = is->flags;
+		control->originalFlags &= (INFO_FLAG_KERNEL | INFO_FLAG_NTP);
+		control->flagsCaptured = TRUE;
+		res = INFO_YES;
+		goto end;
+	if ((is->flags & INFO_FLAG_NTP) || (is->flags & INFO_FLAG_KERNEL))
+		res=INFO_YES;
+	} else  {
+		res=INFO_NO;
+	end:
+	switch (res) {
+	case -1:
+		DBG("Could not connect to NTP daemon\n");
+		break;
+	case ERR_TIMEOUT:
+		DBG("Timeout while connecting to NTP daemon\n");
+		break;
+		DBG("NTP permission denied: check NTP key id, key and if key is trusted and is a request key\n");
+		break;
+	default:
+	return res;
diff --git a/freebsd/contrib/ptpd/src/dep/ntpengine/ntpdcontrol.h b/freebsd/contrib/ptpd/src/dep/ntpengine/ntpdcontrol.h
index 00000000..fde9707e
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/ntpengine/ntpdcontrol.h
@@ -0,0 +1,362 @@
+ * ntpdcontrol.h - definitions for the ntpd remote query and control facility
+#ifndef NTPDCONTROL_H
+#define NTPDCONTROL_H
+#include "../../timingdomain.h"
+typedef struct {
+	Boolean enableEngine;
+	Boolean enableControl;
+	Boolean enableFailover;
+	int failoverTimeout;
+	int checkInterval;
+	int keyId;
+	char key[20];
+	Octet hostAddress[MAXHOSTNAMELEN];
+} NTPoptions;
+typedef struct {
+	Boolean operational;
+	Boolean enabled;
+	Boolean isRequired;
+	Boolean inControl;
+	Boolean isFailOver;
+	Boolean checkFailed;
+	Boolean requestFailed;
+	Boolean flagsCaptured;
+	int originalFlags;
+	Integer32 serverAddress;
+	Integer32 sockFD;
+	struct TimingService timingService;
+} NTPcontrol;
+Boolean ntpInit(NTPoptions* options, NTPcontrol* control);
+Boolean ntpShutdown(NTPoptions* options, NTPcontrol* control);
+int ntpdControlFlags(NTPoptions* options, NTPcontrol* control, int req, int flags);
+int ntpdSetFlags(NTPoptions* options, NTPcontrol* control, int flags);
+int ntpdClearFlags(NTPoptions* options, NTPcontrol* control, int flags);
+int ntpdInControl(NTPoptions* options, NTPcontrol* control);
+//Boolean ntpdControl(NTPoptions* options, NTPcontrol* control, Boolean quiet);
+#define NTPCONTROL_YES		128
+#define NTPCONTROL_NO		129
+#define NTPCONTROL_AUTHERR	18
+#define NTPCONTROL_TIMEOUT	19
+#define NTPCONTROL_PROTOERR	20
+#define NTPCONTROL_NETERR	21
+typedef struct {
+        union {
+                uint32_t Xl_ui;
+                int32_t Xl_i;
+        } Ul_i;
+        union {
+                uint32_t Xl_uf;
+                int32_t Xl_f;
+        } Ul_f;
+} l_fp;
+#define l_ui    Ul_i.Xl_ui              /* unsigned integral part */
+#define l_i     Ul_i.Xl_i               /* signed integral part */
+#define l_uf    Ul_f.Xl_uf              /* unsigned fractional part */
+#define l_f     Ul_f.Xl_f               /* signed fractional part */
+#define M_ADD(r_i, r_f, a_i, a_f)       /* r += a */ \
+        do { \
+                register uint32_t lo_tmp; \
+                register uint32_t hi_tmp; \
+                lo_tmp = ((r_f) & 0xffff) + ((a_f) & 0xffff); \
+                hi_tmp = (((r_f) >> 16) & 0xffff) + (((a_f) >> 16) & 0xffff); \
+                if (lo_tmp & 0x10000) \
+                        hi_tmp++; \
+		(r_f) = ((hi_tmp & 0xffff) << 16) | (lo_tmp & 0xffff); \
+		(r_i) += (a_i); \
+		if (hi_tmp & 0x10000) \
+		(r_i)++; \
+	} while (0)
+#define L_ADD(r, a)     M_ADD((r)->l_ui, (r)->l_uf, (a)->l_ui, (a)->l_uf)
+#define HTONL_FP(h, n) do { (n)->l_ui = htonl((h)->l_ui); \
+		    (n)->l_uf = htonl((h)->l_uf); } while (0)
+typedef unsigned short associd_t; /* association ID */
+typedef int32_t keyid_t;        /* cryptographic key ID */
+typedef uint32_t tstamp_t;       /* NTP seconds timestamp */
+typedef int32_t s_fp;
+typedef uint32_t u_fp;
+typedef char s_char;
+#define MAX_MAC_LEN     (6 * sizeof(uint32_t))   /* SHA */
+ * A request packet.  These are almost a fixed length.
+struct req_pkt {
+	u_char rm_vn_mode;		/* response, more, version, mode */
+	u_char auth_seq;		/* key, sequence number */
+	u_char implementation;		/* implementation number */
+	u_char request;			/* request number */
+	u_short err_nitems;		/* error code/number of data items */
+	u_short mbz_itemsize;		/* item size */
+	char data[128 + 48];	/* data area [32 prev](176 byte max) */
+					/* struct conf_peer must fit */
+	l_fp tstamp;			/* time stamp, for authentication */
+	keyid_t keyid;			/* (optional) encryption key */
+	char mac[MAX_MAC_LEN-sizeof(keyid_t)]; /* (optional) auth code */
+ * The req_pkt_tail structure is used by ntpd to adjust for different
+ * packet sizes that may arrive.
+struct req_pkt_tail {
+/* MODE_PRIVATE request packet header length before optional items. */
+#define	REQ_LEN_HDR	(offsetof(struct req_pkt, data))
+/* MODE_PRIVATE request packet fixed length without MAC. */
+/* MODE_PRIVATE req_pkt_tail minimum size (16 octet digest) */
+#define REQ_TAIL_MIN	\
+	(sizeof(struct req_pkt_tail) - (MAX_MAC_LEN - MAX_MD5_LEN))
+ * A MODE_PRIVATE response packet.  The length here is variable, this
+ * is a maximally sized one.  Note that this implementation doesn't
+ * authenticate responses.
+#define	RESP_HEADER_SIZE	(offsetof(struct resp_pkt, data))
+#define	RESP_DATA_SIZE		(500)
+struct resp_pkt {
+	char data[RESP_DATA_SIZE];	/* data area */
+ * Information error codes
+#define	INFO_OKAY	0
+#define	INFO_ERR_IMPL	1	/* incompatable implementation */
+#define	INFO_ERR_REQ	2	/* unknown request code */
+#define	INFO_ERR_FMT	3	/* format error */
+#define	INFO_ERR_NODATA	4	/* no data for this request */
+#define	INFO_ERR_AUTH	7	/* authentication failure */
+#define INFO_ERR_EMPTY	8 	/* wowczarek: problem with response items */
+#define INFO_YES	126	/* wowczarek: NTP is controlling the OS clock */
+#define INFO_NO		127	/* wowczarek: NTP is not controlling the OS clock */
+ * Maximum sequence number.
+#define	MAXSEQ	127
+ * Bit setting macros for multifield items.
+#define	RESP_BIT	0x80
+#define	MORE_BIT	0x40
+#define	ISRESPONSE(rm_vn_mode)	(((rm_vn_mode)&RESP_BIT)!=0)
+#define	ISMORE(rm_vn_mode)	(((rm_vn_mode)&MORE_BIT)!=0)
+#define INFO_VERSION(rm_vn_mode) ((u_char)(((rm_vn_mode)>>3)&0x7))
+#define	INFO_MODE(rm_vn_mode)	((rm_vn_mode)&0x7)
+#define	RM_VN_MODE(resp, more, version)		\
+				((u_char)(((resp)?RESP_BIT:0)\
+				|((more)?MORE_BIT:0)\
+				|((version?version:(NTP_OLDVERSION+1))<<3)\
+				|(MODE_PRIVATE)))
+#define	INFO_IS_AUTH(auth_seq)	(((auth_seq) & 0x80) != 0)
+#define	INFO_SEQ(auth_seq)	((auth_seq)&0x7f)
+#define	AUTH_SEQ(auth, seq)	((u_char)((((auth)!=0)?0x80:0)|((seq)&0x7f)))
+#define	INFO_ERR(err_nitems)	((u_short)((ntohs(err_nitems)>>12)&0xf))
+#define	INFO_NITEMS(err_nitems)	((u_short)(ntohs(err_nitems)&0xfff))
+#define	ERR_NITEMS(err, nitems)	(htons((u_short)((((u_short)(err)<<12)&0xf000)\
+				|((u_short)(nitems)&0xfff))))
+#define	INFO_MBZ(mbz_itemsize)	((ntohs(mbz_itemsize)>>12)&0xf)
+#define	INFO_ITEMSIZE(mbz_itemsize)	((u_short)(ntohs(mbz_itemsize)&0xfff))
+#define	MBZ_ITEMSIZE(itemsize)	(htons((u_short)(itemsize)))
+ * Implementation numbers.  One for universal use and one for ntpd.
+#define	IMPL_UNIV	0
+#define	IMPL_XNTPD_OLD	2	/* Used by pre ipv6 ntpdc */
+#define	IMPL_XNTPD	3	/* Used by post ipv6 ntpdc */
+ * Some limits related to authentication.  Frames which are
+ * authenticated must include a time stamp which differs from
+ * the receive time stamp by no more than 10 seconds.
+#define	INFO_TS_MAXSKEW	10.
+#define NTP_OLDVERSION  ((u_char)1)
+#define MODE_PRIVATE    7
+ * Universal request codes go here.  There aren't any.
+ * NTPD request codes go here.
+#define	REQ_PEER_LIST		0	/* return list of peers */
+#define	REQ_PEER_LIST_SUM	1	/* return summary info for all peers */
+#define	REQ_PEER_INFO		2	/* get standard information on peer */
+#define	REQ_PEER_STATS		3	/* get statistics for peer */
+#define	REQ_SYS_INFO		4	/* get system information */
+#define	REQ_SYS_STATS		5	/* get system stats */
+#define	REQ_IO_STATS		6	/* get I/O stats */
+#define REQ_MEM_STATS		7	/* stats related to peer list maint */
+#define	REQ_LOOP_INFO		8	/* info from the loop filter */
+#define	REQ_TIMER_STATS		9	/* get timer stats */
+#define	REQ_CONFIG		10	/* configure a new peer */
+#define	REQ_UNCONFIG		11	/* unconfigure an existing peer */
+#define	REQ_SET_SYS_FLAG	12	/* set system flags */
+#define	REQ_CLR_SYS_FLAG	13	/* clear system flags */
+#define	REQ_MONITOR		14	/* (not used) */
+#define	REQ_NOMONITOR		15	/* (not used) */
+#define	REQ_GET_RESTRICT	16	/* return restrict list */
+#define	REQ_RESADDFLAGS		17	/* add flags to restrict list */
+#define	REQ_RESSUBFLAGS		18	/* remove flags from restrict list */
+#define	REQ_UNRESTRICT		19	/* remove entry from restrict list */
+#define	REQ_MON_GETLIST		20	/* return data collected by monitor */
+#define	REQ_RESET_STATS		21	/* reset stat counters */
+#define	REQ_RESET_PEER		22	/* reset peer stat counters */
+#define	REQ_REREAD_KEYS		23	/* reread the encryption key file */
+#define	REQ_DO_DIRTY_HACK	24	/* (not used) */
+#define	REQ_DONT_DIRTY_HACK	25	/* (not used) */
+#define	REQ_TRUSTKEY		26	/* add a trusted key */
+#define	REQ_UNTRUSTKEY		27	/* remove a trusted key */
+#define	REQ_AUTHINFO		28	/* return authentication info */
+#define REQ_TRAPS		29	/* return currently set traps */
+#define	REQ_ADD_TRAP		30	/* add a trap */
+#define	REQ_CLR_TRAP		31	/* clear a trap */
+#define	REQ_REQUEST_KEY		32	/* define a new request keyid */
+#define	REQ_CONTROL_KEY		33	/* define a new control keyid */
+#define	REQ_GET_CTLSTATS	34	/* get stats from the control module */
+#define	REQ_GET_LEAPINFO	35	/* (not used) */
+#define	REQ_GET_CLOCKINFO	36	/* get clock information */
+#define	REQ_SET_CLKFUDGE	37	/* set clock fudge factors */
+#define REQ_GET_KERNEL		38	/* get kernel pll/pps information */
+#define	REQ_GET_CLKBUGINFO	39	/* get clock debugging info */
+#define	REQ_SET_PRECISION	41	/* (not used) */
+#define	REQ_MON_GETLIST_1	42	/* return collected v1 monitor data */
+#define	REQ_HOSTNAME_ASSOCID	43	/* Here is a hostname + assoc_id */
+#define REQ_IF_STATS		44	/* get interface statistics */
+#define REQ_IF_RELOAD		45	/* reload interface list */
+/* Determine size of pre-v6 version of structures */
+#define v4sizeof(type)		offsetof(type, v6_flag)
+ * Flags in the peer information returns
+#define	INFO_FLAG_CONFIG	0x1
+#define	INFO_FLAG_SYSPEER	0x2
+#define INFO_FLAG_BURST		0x4
+#define	INFO_FLAG_REFCLOCK	0x8
+#define	INFO_FLAG_PREFER	0x10
+#define	INFO_FLAG_AUTHENABLE	0x20
+#define	INFO_FLAG_SEL_CANDIDATE	0x40
+#define	INFO_FLAG_SHORTLIST	0x80
+#define	INFO_FLAG_IBURST	0x100
+ * Flags in the system information returns
+#define INFO_FLAG_BCLIENT	0x1
+#define INFO_FLAG_AUTHENTICATE	0x2
+#define INFO_FLAG_NTP		0x4
+#define INFO_FLAG_KERNEL	0x8
+#define INFO_FLAG_MONITOR	0x40
+#define INFO_FLAG_FILEGEN	0x80
+#define INFO_FLAG_CAL		0x10
+#define INFO_FLAG_PPS_SYNC	0x20
+ * System info.  Mostly the sys.* variables, plus a few unique to
+ * the implementation.
+struct info_sys {
+	uint32_t peer;		/* system peer address (v4) */
+	u_char peer_mode;	/* mode we are syncing to peer in */
+	u_char leap;		/* system leap bits */
+	u_char stratum;		/* our stratum */
+	s_char precision;	/* local clock precision */
+	s_fp rootdelay;		/* delay from sync source */
+	u_fp rootdispersion;	/* dispersion from sync source */
+	uint32_t refid;		/* reference ID of sync source */
+	l_fp reftime;		/* system reference time */
+	uint32_t poll;		/* system poll interval */
+	u_char flags;		/* system flags */
+	u_char unused1;		/* unused */
+	u_char unused2;		/* unused */
+	u_char unused3;		/* unused */
+	s_fp bdelay;		/* default broadcast offset */
+	s_fp frequency;		/* frequency residual (scaled ppm)  */
+	l_fp authdelay;		/* default authentication delay */
+	u_fp stability;		/* clock stability (scaled ppm) */
+	u_int v6_flag;		/* is this v6 or not */
+	u_int unused4;		/* unused, padding for peer6 */
+	struct in6_addr peer6;	/* system peer address (v6) */
+ * Structure for carrying system flags.
+struct conf_sys_flags {
+	uint32_t flags;
+ * System flags we can set/clear
+#define	SYS_FLAG_BCLIENT	0x01
+#define	SYS_FLAG_PPS		0x02
+#define SYS_FLAG_NTP		0x04
+#define SYS_FLAG_KERNEL		0x08
+#define SYS_FLAG_MONITOR	0x10
+#define SYS_FLAG_FILEGEN	0x20
+#define SYS_FLAG_AUTH		0x40
+#define SYS_FLAG_CAL		0x80
+#define NTP_VERSION     ((u_char)4)
+/* how many time select() will retry on EINTR */
+#define NTP_EINTR_RETRIES 5
+#endif /* NTPDCONTROL_H */
diff --git a/freebsd/contrib/ptpd/src/dep/outlierfilter.c b/freebsd/contrib/ptpd/src/dep/outlierfilter.c
index 00000000..fe3efe10
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/outlierfilter.c
@@ -0,0 +1,369 @@
+ * Copyright (c) 2014      Wojciech Owczarek,
+ * All Rights Reserved
+ * modification, are permitted provided that the following conditions are
+ * met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ *    this list of conditions and the following disclaimer.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE AUTHORS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
+ * BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
+ * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
+ * IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * @file   outlierfilter.c
+ * @date   Fri Aug 22 16:18:33 2014
+ * @brief  Code to handle outlier filter routines
+ * Outlier filter mechanics extracted into separate source
+ * in preparation for 2.4's OOP-like model
+#include "../ptpd.h"
+#ifdef LOCAL_PREFIX
+#undef LOCAL_PREFIX
+#endif
+#define LOCAL_PREFIX "OutlierFilter"
+static int outlierFilterInit(OutlierFilter *filter, OutlierFilterConfig *config, const char* id);
+static int outlierFilterReset(OutlierFilter *filter);
+static int outlierFilterShutdown(OutlierFilter *filter);
+static int outlierFilterTune(OutlierFilter *filter);
+static void outlierFilterUpdate(OutlierFilter *filter);
+static Boolean outlierFilterConfigure(OutlierFilter *filter, OutlierFilterConfig *config);
+static Boolean outlierFilterFilter(OutlierFilter *filter, double sample);
+static int outlierFilterDisplay(OutlierFilter *filter);
+int
+outlierFilterSetup(OutlierFilter *filter)
+	if(filter == NULL) {
+	    return 0;
+	memset(filter, 0, sizeof(OutlierFilter));
+	filter->init 		= outlierFilterInit;
+	filter->shutdown 	= outlierFilterShutdown;
+	filter->reset 		= outlierFilterReset;
+	filter->filter		= outlierFilterFilter;
+	filter->display		= outlierFilterDisplay;
+	filter->configure	= outlierFilterConfigure;
+	filter->update		= outlierFilterUpdate;
+	return 1;
+static int
+outlierFilterInit(OutlierFilter *filter, OutlierFilterConfig *config, const char* id) {
+	filter->config = *config;
+	 if (config->enabled) {
+                filter->rawStats = createDoubleMovingStdDev(config->capacity);
+                strncpy(filter->id, id, OUTLIERFILTER_MAX_DESC);
+                strncpy(filter->rawStats->identifier, id, 10);
+                filter->filteredStats = createDoubleMovingMean(config->capacity);
+                filter->threshold = config->threshold;
+        } else {
+                filter->rawStats = NULL;
+                filter->filteredStats = NULL;
+                resetDoublePermanentMean(&filter->outlierStats);
+                resetDoublePermanentMean(&filter->acceptedStats);
+		filter->delayCredit = filter->config.delayCredit;
+	return 1;
+static int
+outlierFilterReset(OutlierFilter *filter) {
+	resetDoubleMovingStdDev(filter->rawStats);
+	resetDoubleMovingMean(filter->filteredStats);
+	filter->lastOutlier = FALSE;
+	filter->threshold = filter->config.threshold;
+	filter->delay = 0;
+	filter->totalDelay = 0;
+	filter->blocking = FALSE;
+	return 1;
+static int
+outlierFilterShutdown(OutlierFilter *filter) {
+         if(filter->rawStats != NULL ) {
+        	freeDoubleMovingStdDev(&filter->rawStats);
+	if(filter->filteredStats != NULL ) {
+                freeDoubleMovingMean(&filter->filteredStats);
+	return 1;
+static
+int outlierFilterTune(OutlierFilter *filter) {
+	DBG("tuning outlier filter: %s\n", filter->id);
+	if(!filter->config.autoTune || (filter->autoTuneSamples < 1)) {
+	    return 1;
+	filter->autoTuneScore = round(((filter->autoTuneOutliers + 0.0)  / (filter->autoTuneSamples + 0.0)) * 100.0);
+	if(filter->autoTuneScore < filter->config.minPercent) {
+		filter->threshold -= filter->config.thresholdStep;
+		if(filter->threshold < filter->config.minThreshold) {
+			filter->threshold = filter->config.minThreshold;
+	if(filter->autoTuneScore > filter->config.maxPercent) {
+		filter->threshold += filter->config.thresholdStep;
+		if(filter->threshold > filter->config.maxThreshold) {
+			filter->threshold = filter->config.maxThreshold;
+	DBG("%s filter autotune: counter %d, samples %d, outliers, %d percentage %d, new threshold %.02f\n",
+		filter->id, filter->rawStats->meanContainer->counter, filter->autoTuneSamples,
+		filter->autoTuneOutliers, filter->autoTuneScore,
+		filter->threshold);
+	filter->autoTuneSamples  = 0;
+	filter->autoTuneOutliers  = 0;
+	return 1;
+static void
+outlierFilterUpdate(OutlierFilter *filter)
+	/* not used yet */
+static Boolean
+outlierFilterConfigure(OutlierFilter *filter, OutlierFilterConfig *config)
+	/* restart needed */
+	if(filter->config.capacity != config->capacity) {
+		return TRUE;
+	filter->reset(filter);
+	return FALSE;
+/* 2 x fairy dust, 3 x unicorn droppings, 1 x magic beanstalk juice. blend, spray on the affected area twice per day */
+static Boolean
+outlierFilterFilter(OutlierFilter *filter, double sample)
+	/* true = accepted - this is to tell the user if we advised to throw away the sample */
+	Boolean ret = TRUE;
+	/* step change: outlier mean - accepted mean from last sampling period */
+	double step = 0.0;
+	if(!filter->config.enabled) {
+		filter->output = sample;
+		return TRUE;
+	step = fabs(filter->outlierStats.mean - filter->acceptedStats.bufferedMean);
+	if(filter->config.autoTune) {
+		filter->autoTuneSamples++;
+	/* no outlier first - more convenient this way */
+	if(!isDoublePeircesOutlier(filter->rawStats, sample, filter->threshold) && (filter->delay == 0)) {
+		/* filter is about to accept after a blocking period */
+		if(filter->consecutiveOutliers) {
+			DBG_LOCAL_ID(filter,"consecutive: %d, mean: %.09fm accepted bmean: %.09f\n", filter->consecutiveOutliers,
+				filter->outlierStats.mean,filter->acceptedStats.bufferedMean);
+				/* we are about to open up but the offset has risen above step level, we will block again, but not forever */
+				if(filter->config.stepDelay &&
+				    (fabs(filter->acceptedStats.bufferedMean) < ((filter->config.stepThreshold + 0.0) / 1E9)) &&
+				    (step > ((filter->config.stepLevel + 0.0) / 1E9))) {
+				    /* if we're to enter blocking, we need 2 * consecutiveOutliers credit */
+				    /* if we're already blocking, we just need enough credit */
+				    /* if we're already blocking, make sure we block no more than maxDelay */
+				    if((filter->blocking && ((filter->config.maxDelay > filter->totalDelay) && (filter->delayCredit >= filter->consecutiveOutliers))) ||
+					    (!filter->blocking && (filter->delayCredit >= filter->consecutiveOutliers * 2 ))) {
+					    if(!filter->blocking) {
+						INFO_LOCAL_ID(filter,"%.03f us step detected, filter will now block\n", step * 1E6);
+					    DBG_LOCAL_ID(filter,"step: %.09f, credit left %d, requesting %d\n",step,
+						    filter->delayCredit, filter->consecutiveOutliers);
+					    filter->delay = filter->consecutiveOutliers;
+					    filter->totalDelay += filter->consecutiveOutliers;
+					    filter->delayCredit -= filter->consecutiveOutliers;
+					    filter->blocking = TRUE;
+					    filter->lastOutlier = TRUE;
+					    DBG_LOCAL_ID(filter,"maxdelay: %d, totaldelay: %d\n",filter->config.maxDelay, filter->totalDelay);
+					    return FALSE;
+				    /* much love for the ultra magnetic, cause everybody knows you never got enough credit */
+				    /* we either ran out of credit while blocking, or we did not have enough to start with */
+				    } else {
+					if(filter->blocking) {
+					    INFO_LOCAL_ID(filter,"blocking time exhausted, filter will stop blocking\n");
+					} else {
+					    INFO_LOCAL_ID(filter,"%.03f us step detected but filter cannot block\n", step * 1E6);
+					DBG_LOCAL_ID(filter,"credit out (has %d, needed %d)\n", filter->delayCredit, filter->consecutiveOutliers);
+				/* NO STEP */
+				} else {
+					if (filter->blocking) {
+					    INFO_LOCAL_ID(filter,"step event over, filter will stop blocking\n");
+				if(filter->totalDelay != 0) {
+					DBG_LOCAL_ID(filter,"Total waited %d\n", filter->totalDelay);
+		filter->consecutiveOutliers = 0;
+		feedDoublePermanentMean(&filter->acceptedStats, sample);
+	/* it's an outlier, Sir! */
+	} else {
+		feedDoublePermanentMean(&filter->outlierStats, sample);
+		if(filter->delay) {
+			DBG_LOCAL_ID(filter,"delay left: %d\n", filter->delay);
+			filter->delay--;
+			return FALSE;
+		filter->autoTuneOutliers++;
+		filter->consecutiveOutliers++;
+		if(filter->config.discard) {
+			ret = FALSE;
+		} else {
+			filter->output = filter->filteredStats->mean;
+		DBG_LOCAL_ID(filter,"Outlier: %.09f\n", sample);
+		/* Allow [weight] * [deviation from mean] to influence std dev in the next outlier checks */
+		sample = filter->rawStats->meanContainer->mean + filter->config.weight * ( sample - filter->rawStats->meanContainer->mean);
+	/* keep stats containers updated */
+	feedDoubleMovingStdDev(filter->rawStats, sample);
+	feedDoubleMovingMean(filter->filteredStats, filter->output);
+	/* re-tune filter twice per window */
+	if( (filter->rawStats->meanContainer->counter % ( filter->rawStats->meanContainer->capacity / 2)) == 0) {
+		outlierFilterTune(filter);
+	/* replenish filter credit once per window */
+	if( filter->config.stepDelay && ((filter->rawStats->meanContainer->counter % filter->rawStats->meanContainer->capacity) == 0)) {
+		filter->delayCredit += filter->config.creditIncrement;
+		if(filter->delayCredit >= filter->config.delayCredit) {
+		DBG_LOCAL_ID(filter,"credit added, now %d\n", filter->delayCredit);
+	return ret;
+static int outlierFilterDisplay(OutlierFilter *filter) {
+	char *id = filter->id;
+	INFO("%s outlier filter info:\n",
+	    id);
+	INFO("            %s.threshold : %.02f\n",
+	    id, filter->config.threshold);
+	INFO("             %s.autotune : %s\n",
+	    id, (filter->config.autoTune) ? "Y" : "N");
+	if(!filter->config.autoTune) {
+	    return 0;
+	INFO("              %s.percent : %d\n",
+	    id, filter->autoTuneScore);
+	INFO("         %s.minThreshold : %.02f\n",
+	    id, filter->config.minThreshold);
+	INFO("         %s.maxThreshold : %.02f\n",
+	    id, filter->config.maxThreshold);
+	INFO("                 %s.thresholdStep : %.02f\n",
+	    id, filter->config.thresholdStep);
+	return 1;
diff --git a/freebsd/contrib/ptpd/src/dep/outlierfilter.h b/freebsd/contrib/ptpd/src/dep/outlierfilter.h
index 00000000..873a8ff5
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/outlierfilter.h
@@ -0,0 +1,125 @@
+#ifndef OUTLIERFILTER_H_
+#define OUTLIERFILTER_H_
+#include <dep/statistics.h>
+#define OUTLIERFILTER_MAX_DESC 20
+ * met:
+ * @file   outlierfilter.h
+ * @brief  Function definitions for the outlier filter
+typedef struct {
+    Boolean enabled;
+    Boolean discard;
+    Boolean autoTune;
+    Boolean stepDelay;
+    /* the user may have some conditions under which we should not filter.
+       this is to hint them that we would like to always filter.
+    Boolean alwaysFilter;
+    int capacity;
+    double threshold;
+    double weight;
+    int minPercent;
+    int maxPercent;
+    double thresholdStep;
+    double minThreshold;
+    double maxThreshold;
+    /* if absolute value outside this threshold, do not filter. negative = disabled */
+    double maxAcceptable;
+    /* accepted sample threshold at which step detection is active */
+    int32_t stepThreshold;
+    /* value which is considered a step */
+    int32_t stepLevel;
+    /* delay credit - gets used for waiting when step detected */
+    int delayCredit;
+    /* credit replenishment unit */
+    int creditIncrement;
+    /* safeguard - maximum credit */
+    int maxDelay;
+} OutlierFilterConfig;
+typedef struct OutlierFilter OutlierFilter;
+struct OutlierFilter {
+    char id [OUTLIERFILTER_MAX_DESC + 1];
+    OutlierFilterConfig config;
+    DoubleMovingStdDev* rawStats;
+    DoubleMovingMean* filteredStats;
+    DoublePermanentMean outlierStats;
+    DoublePermanentMean acceptedStats;
+    Boolean lastOutlier;
+    double threshold;
+    double output;
+    int autoTuneSamples;
+    int autoTuneOutliers;
+    int autoTuneScore;
+    int consecutiveOutliers;
+    int delay;
+    int totalDelay;
+    int delayCredit;
+    Boolean blocking;
+    /* 'methods' */
+    int (*init)		(OutlierFilter *filter, OutlierFilterConfig *config, const char *id);
+    int (*shutdown)	(OutlierFilter *filter);
+    int (*reset)	(OutlierFilter *filter);
+    Boolean (*filter)	(OutlierFilter *filter, double sample);
+    Boolean (*configure) (OutlierFilter *filter, OutlierFilterConfig *config);
+    int (*display)	(OutlierFilter *filter);
+    void (*update)	(OutlierFilter *filter);
+/* OutlierFilter *oFilterCreate(OutlierFilterConfig *options, const char *id); */
+int outlierFilterSetup(OutlierFilter *filter);
+#endif /*OUTLIERFILTER_H_*/
diff --git a/freebsd/contrib/ptpd/src/dep/ptpd_dep.h b/freebsd/contrib/ptpd/src/dep/ptpd_dep.h
index 00000000..10663afb
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/ptpd_dep.h
@@ -0,0 +1,516 @@
+ * @file   ptpd_dep.h
+ * @brief  External definitions for inclusion elsewhere.
+#ifndef PTPD_DEP_H_
+#define PTPD_DEP_H_
+#undef PTPD_DBGV
+#define PTPD_DBGV
+#endif
+ /** \name System messages*/
+// Syslog ordering. We define extra debug levels above LOG_DEBUG for internal use - but message() doesn't pass these to SysLog
+// extended from <sys/syslog.h>
+#define LOG_DEBUG1   7
+#define LOG_DEBUG2   8
+#define LOG_DEBUG3   9
+#define LOG_DEBUGV   9
+#define EMERGENCY(x, ...) logMessage(LOG_EMERG, x, ##__VA_ARGS__)
+#define ALERT(x, ...)     logMessage(LOG_ALERT, x, ##__VA_ARGS__)
+#define CRITICAL(x, ...)  logMessage(LOG_CRIT, x, ##__VA_ARGS__)
+#define ERROR(x, ...)  logMessage(LOG_ERR, x, ##__VA_ARGS__)
+#define PERROR(x, ...)    logMessage(LOG_ERR, x "      (strerror: %m)\n", ##__VA_ARGS__)
+#define WARNING(x, ...)   logMessage(LOG_WARNING, x, ##__VA_ARGS__)
+#define NOTIFY(x, ...) logMessage(LOG_NOTICE, x, ##__VA_ARGS__)
+#define NOTICE(x, ...)    logMessage(LOG_NOTICE, x, ##__VA_ARGS__)
+#define INFO(x, ...)   logMessage(LOG_INFO, x, ##__VA_ARGS__)
+#define EMERGENCY_LOCAL(x, ...)	EMERGENCY(LOCAL_PREFIX": " x,##__VA_ARGS__)
+#define ALERT_LOCAL(x, ...)	ALERT(LOCAL_PREFIX": " x, ##__VA_ARGS__)
+#define CRITICAL_LOCAL(x, ...)	CRITICAL(LOCAL_PREFIX": " x, ##__VA_ARGS__)
+#define ERROR_LOCAL(x, ...)	ERROR(LOCAL_PREFIX": " x, ##__VA_ARGS__)
+#define PERROR_LOCAL(x, ...)	PERROR(LOCAL_PREFIX": " x, ##__VA_ARGS__)
+#define WARNING_LOCAL(x, ...)	WARNING(LOCAL_PREFIX": " x, ##__VA_ARGS__)
+#define NOTIFY_LOCAL(x, ...)	NOTIFY(LOCAL_PREFIX": " x, ##__VA_ARGS__)
+#define NOTIC_LOCALE(x, ...)	NOTICE(LOCAL_PREFIX": " x, ##__VA_ARGS__)
+#define INFO_LOCAL(x, ...)	INFO(LOCAL_PREFIX": " x, ##__VA_ARGS__)
+#define EMERGENCY_LOCAL_ID(o,x, ...)	EMERGENCY(LOCAL_PREFIX".%s: "x,o->id,##__VA_ARGS__)
+#define ALERT_LOCAL_ID(o,x, ...)	ALERT(LOCAL_PREFIX".%s: "x,o->id, ##__VA_ARGS__)
+#define CRITICAL_LOCAL_ID(o,x, ...)	CRITICAL(LOCAL_PREFIX".%s: "x,o->id, ##__VA_ARGS__)
+#define ERROR_LOCAL_ID(o,x, ...)	ERROR(LOCAL_PREFIX".%s: "x,o->id, ##__VA_ARGS__)
+#define PERROR_LOCAL_ID(o,x, ...)	PERROR(LOCAL_PREFIX".%s: "x,o->id, ##__VA_ARGS__)
+#define WARNING_LOCAL_ID(o,x, ...)	WARNING(LOCAL_PREFIX".%s: "x,o->id, ##__VA_ARGS__)
+#define NOTIFY_LOCAL_ID(o,x, ...)	NOTIFY(LOCAL_PREFIX".%s: "x,o->id, ##__VA_ARGS__)
+#define NOTICE_LOCAL_ID(o,x, ...)	NOTICE(LOCAL_PREFIX".%s: "x,o->id, ##__VA_ARGS__)
+#define INFO_LOCAL_ID(o,x, ...)		INFO(LOCAL_PREFIX".%s: "x,o->id, ##__VA_ARGS__)
+#if defined(__FILE__) && defined(__LINE__)
+#define MARKER INFO("Marker: %s:%d\n", __FILE__, __LINE__)
+#else
+#define MARKER INFO("Marker\n")
+#endif
+#include <assert.h>
+  list of per-module defines:
+./dep/sys.c:#define PRINT_MAC_ADDRESSES
+./dep/timer.c:#define US_TIMER_INTERVAL 125000
+#define USE_BINDTODEVICE
+// enable this line to show debug numbers in nanoseconds instead of microseconds
+// #define DEBUG_IN_NS
+#define DBG_UNIT_US (1000)
+#define DBG_UNIT_NS (1)
+#ifdef DEBUG_IN_NS
+#define DBG_UNIT DBG_UNIT_NS
+#else
+#define DBG_UNIT DBG_UNIT_US
+#endif
+/** \name Debug messages*/
+#ifdef PTPD_DBGV
+#undef PTPD_DBG
+#undef PTPD_DBG2
+#define PTPD_DBG
+#define PTPD_DBG2
+#define DBGV(x, ...) logMessage(LOG_DEBUGV, x, ##__VA_ARGS__)
+#define DBGV_LOCAL(x, ...) DBGV(LOCAL_PREFIX": " x,##__VA_ARGS__)
+#define DBGV_LOCAL_ID(o,x, ...)	DBGV(LOCAL_PREFIX".%s:"x,o->id,##__VA_ARGS__)
+#else
+#define DBGV_LOCAL_ID(x, ...)
+#endif
+ * new debug level DBG2:
+ * this is above DBG(), but below DBGV() (to avoid changing hundreds of lines)
+#ifdef PTPD_DBG2
+#undef PTPD_DBG
+#define PTPD_DBG
+#define DBG2(x, ...) logMessage(LOG_DEBUG2, x, ##__VA_ARGS__)
+#define DBG2_LOCAL(x, ...) DBG2(LOCAL_PREFIX": " x,##__VA_ARGS__)
+#define DBG2_LOCAL_ID(o,x, ...)	DBG2(LOCAL_PREFIX".%s:"x,o->id,##__VA_ARGS__)
+#else
+#define DBG2_LOCAL_ID(x, ...)
+#endif
+#ifdef PTPD_DBG
+#define DBG(x, ...) logMessage(LOG_DEBUG, x, ##__VA_ARGS__)
+#define DBG_LOCAL(x, ...) DBG(LOCAL_PREFIX": " x,##__VA_ARGS__)
+#define DBG_LOCAL_ID(o,x, ...)	DBG(LOCAL_PREFIX".%s:"x,o->id,##__VA_ARGS__)
+#else
+#define DBG_LOCAL_ID(x, ...)
+#endif
+/** \name Endian corrections*/
+#if defined(PTPD_MSBF)
+#define shift8(x,y)   ( (x) << ((3-y)<<3) )
+#define shift16(x,y)  ( (x) << ((1-y)<<4) )
+#elif defined(PTPD_LSBF)
+#define shift8(x,y)   ( (x) << ((y)<<3) )
+#define shift16(x,y)  ( (x) << ((y)<<4) )
+#endif
+#define flip16(x) htons(x)
+#define flip32(x) htonl(x)
+/* i don't know any target platforms that do not have htons and htonl,
+   but here are generic funtions just in case */
+#define flip16(x) (x)
+#define flip32(x) (x)
+static inline Integer16 flip16(Integer16 x)
+   return (((x) >> 8) & 0x00ff) | (((x) << 8) & 0xff00);
+static inline Integer32 flip32(x)
+  return (((x) >> 24) & 0x000000ff) | (((x) >> 8 ) & 0x0000ff00) |
+         (((x) << 8 ) & 0x00ff0000) | (((x) << 24) & 0xff000000);
+#endif
+/** \name Bit array manipulations*/
+#define getFlag(x,y)  !!( *(UInteger8*)((x)+((y)<8?1:0)) &   (1<<((y)<8?(y):(y)-8)) )
+#define setFlag(x,y)    ( *(UInteger8*)((x)+((y)<8?1:0)) |=   1<<((y)<8?(y):(y)-8)  )
+#define clearFlag(x,y)  ( *(UInteger8*)((x)+((y)<8?1:0)) &= ~(1<<((y)<8?(y):(y)-8)) )
+#define DEFAULT_TOKEN_DELIM ", ;\t"
+ * foreach loop across substrings from var, delimited by delim, placing
+ * each token in targetvar on iteration, using id variable name prefix
+ * to allow nesting (each loop uses an individual set of variables)
+#define foreach_token_begin(id, var, targetvar, delim) {\
+    char* id_stash; \
+    char* id_text_; \
+    char* id_text__; \
+    char* targetvar; \
+    id_text_=strdup(var); \
+    for(id_text__ = id_text_;; id_text__=NULL) { \
+	targetvar = strtok_r(id_text__, delim, &id_stash); \
+	if(targetvar==NULL) break;
+#define foreach_token_end(id) } \
+    if(id_text_ != NULL) { \
+	free(id_text_); \
+/** \name msg.c
+ *-Pack and unpack PTP messages */
+void msgUnpackHeader(Octet * buf,MsgHeader*);
+void msgUnpackAnnounce (Octet * buf,MsgAnnounce*);
+void msgUnpackSync(Octet * buf,MsgSync*);
+void msgUnpackFollowUp(Octet * buf,MsgFollowUp*);
+void msgUnpackDelayReq(Octet * buf, MsgDelayReq * delayreq);
+void msgUnpackDelayResp(Octet * buf,MsgDelayResp *);
+void msgUnpackPdelayReq(Octet * buf,MsgPdelayReq*);
+void msgUnpackPdelayResp(Octet * buf,MsgPdelayResp*);
+void msgUnpackPdelayRespFollowUp(Octet * buf,MsgPdelayRespFollowUp*);
+Boolean msgUnpackManagement(Octet * buf,MsgManagement*, MsgHeader*, PtpClock *ptpClock, const int tlvOffset);
+Boolean msgUnpackSignaling(Octet * buf,MsgSignaling*, MsgHeader*, PtpClock *ptpClock, const int tlvOffset);
+void msgPackHeader(Octet * buf,PtpClock*);
+#ifndef PTPD_SLAVE_ONLY
+void msgPackAnnounce(Octet * buf, UInteger16, Timestamp*, PtpClock*);
+void msgPackSync(Octet * buf, UInteger16, Timestamp*, PtpClock*);
+#endif /* PTPD_SLAVE_ONLY */
+void msgPackFollowUp(Octet * buf,Timestamp*,PtpClock*, const UInteger16);
+void msgPackDelayReq(Octet * buf,Timestamp *,PtpClock *);
+void msgPackDelayResp(Octet * buf,MsgHeader *,Timestamp *,PtpClock *);
+void msgPackPdelayReq(Octet * buf,Timestamp*,PtpClock*);
+void msgPackPdelayResp(Octet * buf,MsgHeader*,Timestamp*,PtpClock*);
+void msgPackPdelayRespFollowUp(Octet * buf,MsgHeader*,Timestamp*,PtpClock*, const UInteger16);
+void msgPackManagement(Octet * buf,MsgManagement*,PtpClock*);
+void msgPackSignaling(Octet * buf,MsgSignaling*,PtpClock*);
+void msgPackManagementRespAck(Octet *,MsgManagement*,PtpClock*);
+void msgPackManagementTLV(Octet *,MsgManagement*, PtpClock*);
+void msgPackSignalingTLV(Octet *,MsgSignaling*, PtpClock*);
+void msgPackManagementErrorStatusTLV(Octet *,MsgManagement*,PtpClock*);
+void freeMMErrorStatusTLV(ManagementTLV*);
+void freeMMTLV(ManagementTLV*);
+void msgDump(PtpClock *ptpClock);
+void msgDebugHeader(MsgHeader *header);
+void msgDebugSync(MsgSync *sync);
+void msgDebugAnnounce(MsgAnnounce *announce);
+void msgDebugDelayReq(MsgDelayReq *req);
+void msgDebugFollowUp(MsgFollowUp *follow);
+void msgDebugDelayResp(MsgDelayResp *resp);
+void msgDebugManagement(MsgManagement *manage);
+void copyClockIdentity( ClockIdentity dest, ClockIdentity src);
+void copyPortIdentity( PortIdentity * dest, PortIdentity * src);
+void unpackMsgSignaling(Octet *, MsgSignaling*, PtpClock*);
+void packMsgSignaling(MsgSignaling*, Octet *);
+void unpackSignalingTLV(Octet*, MsgSignaling*, PtpClock*);
+void packSignalingTLV(SignalingTLV*, Octet*);
+void freeSignalingTLV(MsgSignaling*);
+void unpackMsgManagement(Octet *, MsgManagement*, PtpClock*);
+void packMsgManagement(MsgManagement*, Octet *);
+void unpackManagementTLV(Octet*, int, MsgManagement*, PtpClock*);
+void packManagementTLV(ManagementTLV*, Octet*);
+void freeManagementTLV(MsgManagement*);
+int unpackMMClockDescription( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMClockDescription( MsgManagement*, Octet*);
+void freeMMClockDescription( MMClockDescription*);
+int unpackMMUserDescription( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMUserDescription( MsgManagement*, Octet*);
+void freeMMUserDescription( MMUserDescription*);
+int unpackMMErrorStatus( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMErrorStatus( MsgManagement*, Octet*);
+void freeMMErrorStatus( MMErrorStatus*);
+int unpackMMInitialize( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMInitialize( MsgManagement*, Octet*);
+int unpackMMDefaultDataSet( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMDefaultDataSet( MsgManagement*, Octet*);
+int unpackMMCurrentDataSet( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMCurrentDataSet( MsgManagement*, Octet*);
+int unpackMMParentDataSet( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMParentDataSet( MsgManagement*, Octet*);
+int unpackMMTimePropertiesDataSet( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMTimePropertiesDataSet( MsgManagement*, Octet*);
+int unpackMMPortDataSet( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMPortDataSet( MsgManagement*, Octet*);
+int unpackMMPriority1( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMPriority1( MsgManagement*, Octet*);
+int unpackMMPriority2( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMPriority2( MsgManagement*, Octet*);
+int unpackMMDomain( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMDomain( MsgManagement*, Octet*);
+int unpackMMSlaveOnly( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMSlaveOnly( MsgManagement*, Octet* );
+int unpackMMLogAnnounceInterval( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMLogAnnounceInterval( MsgManagement*, Octet*);
+int unpackMMAnnounceReceiptTimeout( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMAnnounceReceiptTimeout( MsgManagement*, Octet*);
+int unpackMMLogSyncInterval( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMLogSyncInterval( MsgManagement*, Octet*);
+int unpackMMVersionNumber( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMVersionNumber( MsgManagement*, Octet*);
+int unpackMMTime( Octet* buf, int, MsgManagement*, PtpClock * );
+UInteger16 packMMTime( MsgManagement*, Octet*);
+int unpackMMClockAccuracy( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMClockAccuracy( MsgManagement*, Octet*);
+int unpackMMUtcProperties( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMUtcProperties( MsgManagement*, Octet*);
+int unpackMMTraceabilityProperties( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMTraceabilityProperties( MsgManagement*, Octet*);
+int unpackMMTimescaleProperties( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMTimescaleProperties( MsgManagement*, Octet*);
+int unpackMMUnicastNegotiationEnable( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMUnicastNegotiationEnable( MsgManagement*, Octet*);
+int unpackMMDelayMechanism( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMDelayMechanism( MsgManagement*, Octet*);
+int unpackMMLogMinPdelayReqInterval( Octet* buf, int, MsgManagement*, PtpClock* );
+UInteger16 packMMLogMinPdelayReqInterval( MsgManagement*, Octet*);
+/* Signaling TLV packing / unpacking functions */
+void unpackSMRequestUnicastTransmission( Octet* buf, MsgSignaling*, PtpClock* );
+UInteger16 packSMRequestUnicastTransmission( MsgSignaling*, Octet*);
+void unpackSMGrantUnicastTransmission( Octet* buf, MsgSignaling*, PtpClock* );
+UInteger16 packSMGrantUnicastTransmission( MsgSignaling*, Octet*);
+void unpackSMCancelUnicastTransmission( Octet* buf, MsgSignaling*, PtpClock* );
+UInteger16 packSMCancelUnicastTransmission( MsgSignaling*, Octet*);
+void unpackSMAcknowledgeCancelUnicastTransmission( Octet* buf, MsgSignaling*, PtpClock* );
+UInteger16 packSMAcknowledgeCancelUnicastTransmission( MsgSignaling*, Octet*);
+void unpackPortAddress( Octet* buf, PortAddress*, PtpClock*);
+void packPortAddress( PortAddress*, Octet*);
+void freePortAddress( PortAddress*);
+void unpackPTPText( Octet* buf, PTPText*, PtpClock*);
+void packPTPText( PTPText*, Octet*);
+void freePTPText( PTPText*);
+void unpackPhysicalAddress( Octet* buf, PhysicalAddress*, PtpClock*);
+void packPhysicalAddress( PhysicalAddress*, Octet*);
+void freePhysicalAddress( PhysicalAddress*);
+void unpackClockIdentity( Octet* buf, ClockIdentity *c, PtpClock*);
+void packClockIdentity( ClockIdentity *c, Octet* buf);
+void freeClockIdentity( ClockIdentity *c);
+void unpackClockQuality( Octet* buf, ClockQuality *c, PtpClock*);
+void packClockQuality( ClockQuality *c, Octet* buf);
+void freeClockQuality( ClockQuality *c);
+void unpackTimeInterval( Octet* buf, TimeInterval *t, PtpClock*);
+void packTimeInterval( TimeInterval *t, Octet* buf);
+void freeTimeInterval( TimeInterval *t);
+void unpackPortIdentity( Octet* buf, PortIdentity *p, PtpClock*);
+void packPortIdentity( PortIdentity *p, Octet*  buf);
+void freePortIdentity( PortIdentity *p);
+void unpackTimestamp( Octet* buf, Timestamp *t, PtpClock*);
+void packTimestamp( Timestamp *t, Octet* buf);
+void freeTimestamp( Timestamp *t);
+UInteger16 msgPackManagementResponse(Octet * buf,MsgHeader*,MsgManagement*,PtpClock*);
+/** \name net.c (Unix API dependent)
+ * -Init network stuff, send and receive datas*/
+Boolean testInterface(char* ifaceName, const RunTimeOpts* rtOpts);
+Boolean netInit(NetPath*,RunTimeOpts*,PtpClock*);
+Boolean netShutdown(NetPath*);
+int netSelect(TimeInternal*,NetPath*,fd_set*);
+ssize_t netRecvEvent(Octet*,TimeInternal*,NetPath*,int);
+ssize_t netRecvGeneral(Octet*,NetPath*);
+ssize_t netSendEvent(Octet*,UInteger16,NetPath*,const RunTimeOpts*,Integer32,TimeInternal*);
+ssize_t netSendGeneral(Octet*,UInteger16,NetPath*,const RunTimeOpts*,Integer32 );
+ssize_t netSendPeerGeneral(Octet*,UInteger16,NetPath*,const RunTimeOpts*, Integer32);
+ssize_t netSendPeerEvent(Octet*,UInteger16,NetPath*,const RunTimeOpts*,Integer32,TimeInternal*);
+Boolean netRefreshIGMP(NetPath *, const RunTimeOpts *, PtpClock *);
+Boolean hostLookup(const char* hostname, Integer32* addr);
+#if defined PTPD_SNMP
+/** \name snmp.c (SNMP subsystem)
+ * -Handle SNMP subsystem*/
+void snmpInit(RunTimeOpts *, PtpClock *);
+void snmpShutdown();
+void eventHandler_snmp(AlarmEntry *alarm);
+void alarmHandler_snmp(AlarmEntry *alarm);
+//void sendNotif(int eventType, PtpEventData *eventData);
+#endif
+/** \name servo.c
+ * -Clock servo*/
+void initClock(const RunTimeOpts*,PtpClock*);
+void updatePeerDelay (one_way_delay_filter*, const RunTimeOpts*,PtpClock*,TimeInternal*,Boolean);
+void updateDelay (one_way_delay_filter*, const RunTimeOpts*, PtpClock*,TimeInternal*);
+void updateOffset(TimeInternal*,TimeInternal*,
+  offset_from_master_filter*,const RunTimeOpts*,PtpClock*,TimeInternal*);
+void checkOffset(const RunTimeOpts*, PtpClock*);
+void updateClock(const RunTimeOpts*,PtpClock*);
+void stepClock(const RunTimeOpts * rtOpts, PtpClock * ptpClock);
+/** \name startup.c (Unix API dependent)
+ * -Handle with runtime options*/
+int setCpuAffinity(int cpu);
+int logToFile(RunTimeOpts * rtOpts);
+int recordToFile(RunTimeOpts * rtOpts);
+PtpClock * ptpdStartup(int,char**,Integer16*,RunTimeOpts*);
+void ptpdShutdown(PtpClock * ptpClock);
+void checkSignals(RunTimeOpts * rtOpts, PtpClock * ptpClock);
+void restartSubsystems(RunTimeOpts *rtOpts, PtpClock *ptpClock);
+void applyConfig(dictionary *baseConfig, RunTimeOpts *rtOpts, PtpClock *ptpClock);
+void enable_runtime_debug(void );
+void disable_runtime_debug(void );
+void ntpSetup(RunTimeOpts *rtOpts, PtpClock *ptpClock);
+#define D_ON      do { enable_runtime_debug();  } while (0);
+#define D_OFF     do { disable_runtime_debug( ); } while (0);
+/** \name sys.c (Unix API dependent)
+ * -Manage timing system API*/
+/* new debug methods to debug time variables */
+char *time2st(const TimeInternal * p);
+void DBG_time(const char *name, const TimeInternal  p);
+void logMessage(int priority, const char *format, ...);
+void updateLogSize(LogFileHandler* handler);
+Boolean maintainLogSize(LogFileHandler* handler);
+int restartLog(LogFileHandler* handler, Boolean quiet);
+void restartLogging(RunTimeOpts* rtOpts);
+void stopLogging(RunTimeOpts* rtOpts);
+void logStatistics(PtpClock *ptpClock);
+void periodicUpdate(const RunTimeOpts *rtOpts, PtpClock *ptpClock);
+void displayStatus(PtpClock *ptpClock, const char *prefixMessage);
+void displayPortIdentity(PortIdentity *port, const char *prefixMessage);
+int snprint_PortIdentity(char *s, int max_len, const PortIdentity *id);
+Boolean nanoSleep(TimeInternal*);
+void getTime(TimeInternal*);
+void getTimeMonotonic(TimeInternal*);
+void setTime(TimeInternal*);
+#ifdef linux
+void setRtc(TimeInternal *);
+#endif /* linux */
+double getRand(void);
+int lockFile(int fd);
+int checkLockStatus(int fd, short lockType, int *lockPid);
+int checkFileLockable(const char *fileName, int *lockPid);
+Boolean checkOtherLocks(RunTimeOpts *rtOpts);
+void recordSync(UInteger16 sequenceId, TimeInternal * time);
+void adjFreq_wrapper(const RunTimeOpts * rtOpts, PtpClock * ptpClock, double adj);
+Boolean adjFreq(double);
+double getAdjFreq(void);
+#ifdef HAVE_SYS_TIMEX_H
+void informClockSource(PtpClock* ptpClock);
+/* Helper function to manage ntpadjtime / adjtimex flags */
+void setTimexFlags(int flags, Boolean quiet);
+void unsetTimexFlags(int flags, Boolean quiet);
+int getTimexFlags(void);
+Boolean checkTimexFlags(int flags);
+#if defined(MOD_TAI) &&  NTP_API == 4
+void setKernelUtcOffset(int utc_offset);
+Boolean getKernelUtcOffset(int *utc_offset);
+#endif /* MOD_TAI */
+#endif /* HAVE_SYS_TIMEX_H */
+/* Observed drift save / recovery functions */
+void restoreDrift(PtpClock * ptpClock, const RunTimeOpts * rtOpts, Boolean quiet);
+void saveDrift(PtpClock * ptpClock, const RunTimeOpts * rtOpts, Boolean quiet);
+int parseLeapFile(char * path, LeapSecondInfo *info);
+void
+resetWarnings(const RunTimeOpts * rtOpts, PtpClock * ptpClock);
+void setupPIservo(PIservo* servo, const RunTimeOpts* rtOpts);
+void resetPIservo(PIservo* servo);
+double runPIservo(PIservo* servo, const Integer32 input);
+#ifdef PTPD_STATISTICS
+void updatePtpEngineStats (PtpClock* ptpClock, const RunTimeOpts* rtOpts);
+#endif /* PTPD_STATISTICS */
+void writeStatusFile(PtpClock *ptpClock, const RunTimeOpts *rtOpts, Boolean quiet);
+void updateXtmp (TimeInternal oldTime, TimeInternal newTime);
+#endif /*PTPD_DEP_H_*/
diff --git a/freebsd/contrib/ptpd/src/dep/servo.c b/freebsd/contrib/ptpd/src/dep/servo.c
new file mode 100644
index 00000000..f348763a
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/servo.c
@@ -0,0 +1,1262 @@
+ * Copyright (c) 2012-2015 Wojciech Owczarek,
+ * Copyright (c) 2011-2012 George V. Neville-Neil,
+ *                         Steven Kreuzer,
+ *                         Martin Burnicki,
+ *                         Jan Breuer,
+ *                         Gael Mace,
+ *                         Alexandre Van Kempen,
+ *                         Inaqui Delgado,
+ *                         Rick Ratzel,
+ *                         National Instruments.
+ * Copyright (c) 2009-2010 George V. Neville-Neil,
+ *                         Steven Kreuzer,
+ *                         Jan Breuer,
+ *                         Gael Mace,
+ * Copyright (c) 2005-2008 Kendall Correll, Aidan Williams
+ * met:
+ * @file   servo.c
+ * @date   Tue Jul 20 16:19:19 2010
+ * @brief  Code which implements the clock servo in software.
+#define CLAMP(var,bound) {\
+    if(var < -bound) {\
+	var = -bound;\
+    if(var > bound) {\
+	var = bound;\
+static void checkServoStable(PtpClock *ptpClock, const RunTimeOpts *rtOpts);
+#endif
+void
+	ptpClock->warned_operator_slow_slewing = 0;
+	ptpClock->warned_operator_fast_slewing = 0;
+	ptpClock->warnedUnicastCapacity = FALSE;
+	//ptpClock->seen_servo_stable_first_time = FALSE;
+void
+initClock(const RunTimeOpts * rtOpts, PtpClock * ptpClock)
+	DBG("initClock\n");
+	/* If we've been suppressing ntpdc error messages, show them once again */
+	ptpClock->ntpControl.requestFailed = FALSE;
+	ptpClock->disabled = rtOpts->portDisabled;
+/* do not reset frequency here - restoreDrift will do it if necessary */
+/* 2.3.1: restoreDrift now always compiled - this is no longer needed */
+#if 0
+	ptpClock->servo.observedDrift = 0;
+#endif
+	/* clear vars */
+	/* clean more original filter variables */
+	clearTime(&ptpClock->currentDS.offsetFromMaster);
+	clearTime(&ptpClock->currentDS.meanPathDelay);
+	clearTime(&ptpClock->delaySM);
+	clearTime(&ptpClock->delayMS);
+	ptpClock->ofm_filt.y           = 0;
+	ptpClock->ofm_filt.nsec_prev   = 0;
+	ptpClock->mpd_filt.s_exp       = 0;  /* clears one-way delay filter */
+	ptpClock->offsetFirstUpdated   = FALSE;
+	ptpClock->char_last_msg='I';
+	resetWarnings(rtOpts, ptpClock);
+	/* For Hybrid mode */
+//	ptpClock->masterAddr = 0;
+	ptpClock->maxDelayRejected = 0;
+void
+updateDelay(one_way_delay_filter * mpd_filt, const RunTimeOpts * rtOpts, PtpClock * ptpClock, TimeInternal * correctionField)
+	/* updates paused, leap second pending - do nothing */
+	if(ptpClock->leapSecondInProgress)
+		return;
+	DBGV("updateDelay\n");
+	/* todo: do all intermediate calculations on temp vars */
+	TimeInternal prev_meanPathDelay = ptpClock->currentDS.meanPathDelay;
+	ptpClock->char_last_msg = 'D';
+	Boolean maxDelayHit = FALSE;
+		/* if maxDelayStableOnly configured, only check once servo is stable */
+		Boolean checkThreshold = rtOpts-> maxDelayStableOnly ?
+		    (ptpClock->servo.isStable && rtOpts->maxDelay) :
+		    (rtOpts->maxDelay);
+#else
+		Boolean checkThreshold = rtOpts->maxDelay;
+#endif
+		//perform basic checks, using local variables only
+		TimeInternal slave_to_master_delay;
+		/* calc 'slave_to_master_delay' */
+		subTime(&slave_to_master_delay, &ptpClock->delay_req_receive_time,
+			&ptpClock->delay_req_send_time);
+		if (checkThreshold && /* If maxDelay is 0 then it's OFF */
+		    ptpClock->offsetFirstUpdated) {
+			if ((slave_to_master_delay.nanoseconds < 0) &&
+			    (abs(slave_to_master_delay.nanoseconds) > rtOpts->maxDelay)) {
+				INFO("updateDelay aborted, "
+				     "delay (sec: %d ns: %d) is negative\n",
+				     slave_to_master_delay.seconds,
+				     slave_to_master_delay.nanoseconds);
+				INFO("send (sec: %d ns: %d)\n",
+				     ptpClock->delay_req_send_time.seconds,
+				     ptpClock->delay_req_send_time.nanoseconds);
+				INFO("recv (sec: %d n	s: %d)\n",
+				     ptpClock->delay_req_receive_time.seconds,
+				     ptpClock->delay_req_receive_time.nanoseconds);
+				goto finish;
+			if (slave_to_master_delay.seconds && checkThreshold) {
+				INFO("updateDelay aborted, slave to master delay %d.%d greater than 1 second\n",
+				if (rtOpts->displayPackets)
+					msgDump(ptpClock);
+				goto finish;
+			if (slave_to_master_delay.nanoseconds > rtOpts->maxDelay) {
+				ptpClock->counters.maxDelayDrops++;
+				DBG("updateDelay aborted, slave to master delay %d greater than "
+				     "administratively set maximum %d\n",
+				     slave_to_master_delay.nanoseconds,
+				     rtOpts->maxDelay);
+				if(rtOpts->maxDelayMaxRejected) {
+                                    maxDelayHit = TRUE;
+				    /* if we blocked maxDelayMaxRejected samples, reset the slave to unblock the filter */
+				    if(++ptpClock->maxDelayRejected > rtOpts->maxDelayMaxRejected) {
+					    WARNING("%d consecutive measurements above %d threshold - resetting slave\n",
+							rtOpts->maxDelayMaxRejected, slave_to_master_delay.nanoseconds);
+					    toState(PTP_LISTENING, rtOpts, ptpClock);
+				goto finish;
+			} else {
+				ptpClock->maxDelayRejected=0;
+	 * The packet has passed basic checks, so we'll:
+	 *   - update the global delaySM variable
+	 *   - calculate a new filtered MPD
+	if (ptpClock->offsetFirstUpdated) {
+		Integer16 s;
+		 * calc 'slave_to_master_delay' (Master to Slave delay is
+		 * already computed in updateOffset )
+		DBG("==> UpdateDelay():   %s\n",
+			dump_TimeInternal2("Req_RECV:", &ptpClock->delay_req_receive_time,
+			"Req_SENT:", &ptpClock->delay_req_send_time));
+	/* raw value before filtering */
+	subTime(&ptpClock->rawDelaySM, &ptpClock->delay_req_receive_time,
+/* testing only: step detection */
+#if 0
+	TimeInternal bob;
+	bob.nanoseconds = -1000000;
+	bob.seconds = 0;
+	if(ptpClock->addOffset) {
+	    	addTime(&ptpClock->rawDelaySM, &ptpClock->rawDelaySM, &bob);
+#endif
+	/* run the delayMS stats filter */
+	if(rtOpts->filterSMOpts.enabled) {
+	    if(!feedDoubleMovingStatFilter(ptpClock->filterSM, timeInternalToDouble(&ptpClock->rawDelaySM))) {
+		    return;
+	    ptpClock->rawDelaySM = doubleToTimeInternal(ptpClock->filterSM->output);
+	/* run the delaySM outlier filter */
+	if(!rtOpts->noAdjust && ptpClock->oFilterSM.config.enabled && (ptpClock->oFilterSM.config.alwaysFilter || !ptpClock->servo.runningMaxOutput) ) {
+		if(ptpClock->oFilterSM.filter(&ptpClock->oFilterSM, timeInternalToDouble(&ptpClock->rawDelaySM))) {
+			ptpClock->delaySM = doubleToTimeInternal(ptpClock->oFilterSM.output);
+		} else {
+			ptpClock->counters.delaySMOutliersFound++;
+			/* If the outlier filter has blocked the sample, "reverse" the last maxDelay action */
+			if (maxDelayHit) {
+				    ptpClock->maxDelayRejected--;
+			goto finish;
+	} else {
+		ptpClock->delaySM = ptpClock->rawDelaySM;
+#else
+		subTime(&ptpClock->delaySM, &ptpClock->delay_req_receive_time,
+#endif
+		/* update MeanPathDelay */
+		addTime(&ptpClock->currentDS.meanPathDelay, &ptpClock->delaySM,
+			&ptpClock->delayMS);
+		/* Subtract correctionField */
+		subTime(&ptpClock->currentDS.meanPathDelay, &ptpClock->currentDS.meanPathDelay,
+			correctionField);
+		/* Compute one-way delay */
+		div2Time(&ptpClock->currentDS.meanPathDelay);
+		if (ptpClock->currentDS.meanPathDelay.seconds) {
+			DBG("update delay: cannot filter with large OFM, "
+				"clearing filter\n");
+			INFO("Servo: Ignoring delayResp because of large OFM\n");
+			mpd_filt->s_exp = mpd_filt->nsec_prev = 0;
+			/* revert back to previous value */
+			ptpClock->currentDS.meanPathDelay = prev_meanPathDelay;
+			goto finish;
+		if(ptpClock->currentDS.meanPathDelay.nanoseconds < 0){
+			DBG("update delay: found negative value for OWD, "
+			    "so ignoring this value: %d\n",
+				ptpClock->currentDS.meanPathDelay.nanoseconds);
+			goto finish;
+		/* avoid overflowing filter */
+		s = rtOpts->s;
+		while (abs(mpd_filt->y) >> (31 - s))
+			--s;
+		/* crank down filter cutoff by increasing 's_exp' */
+		if (mpd_filt->s_exp < 1)
+			mpd_filt->s_exp = 1;
+		else if (mpd_filt->s_exp < 1 << s)
+			++mpd_filt->s_exp;
+		else if (mpd_filt->s_exp > 1 << s)
+			mpd_filt->s_exp = 1 << s;
+		/* filter 'meanPathDelay' */
+		double fy =
+			(double)((mpd_filt->s_exp - 1.0) *
+			mpd_filt->y / (mpd_filt->s_exp + 0.0) +
+			(ptpClock->currentDS.meanPathDelay.nanoseconds / 2.0 +
+			 mpd_filt->nsec_prev / 2.0) / (mpd_filt->s_exp + 0.0));
+		mpd_filt->nsec_prev = ptpClock->currentDS.meanPathDelay.nanoseconds;
+		mpd_filt->y = round(fy);
+		ptpClock->currentDS.meanPathDelay.nanoseconds = mpd_filt->y;
+		DBGV("delay filter %d, %d\n", mpd_filt->y, mpd_filt->s_exp);
+	} else {
+		DBG("Ignoring delayResp because we didn't receive any sync yet\n");
+		ptpClock->counters.discardedMessages++;
+finish:
+DBG("UpdateDelay: Max delay hit: %d\n", maxDelayHit);
+	/* don't churn on stats containers with the old value if we've discarded an outlier */
+	if(!(ptpClock->oFilterSM.config.enabled && ptpClock->oFilterSM.config.discard && ptpClock->oFilterSM.lastOutlier)) {
+		feedDoublePermanentStdDev(&ptpClock->slaveStats.mpdStats, timeInternalToDouble(&ptpClock->currentDS.meanPathDelay));
+		feedDoublePermanentMedian(&ptpClock->slaveStats.mpdMedianContainer, timeInternalToDouble(&ptpClock->currentDS.meanPathDelay));
+		if(!ptpClock->slaveStats.mpdStatsUpdated) {
+			if(timeInternalToDouble(&ptpClock->currentDS.meanPathDelay) != 0.0){
+			ptpClock->slaveStats.mpdMax = timeInternalToDouble(&ptpClock->currentDS.meanPathDelay);
+			ptpClock->slaveStats.mpdMin = timeInternalToDouble(&ptpClock->currentDS.meanPathDelay);
+			ptpClock->slaveStats.mpdStatsUpdated = TRUE;
+		} else {
+		    ptpClock->slaveStats.mpdMax = max(ptpClock->slaveStats.mpdMax, timeInternalToDouble(&ptpClock->currentDS.meanPathDelay));
+		    ptpClock->slaveStats.mpdMin = min(ptpClock->slaveStats.mpdMin, timeInternalToDouble(&ptpClock->currentDS.meanPathDelay));
+	logStatistics(ptpClock);
+void
+updatePeerDelay(one_way_delay_filter * mpd_filt, const RunTimeOpts * rtOpts, PtpClock * ptpClock, TimeInternal * correctionField, Boolean twoStep)
+	Integer16 s;
+		return;
+	DBGV("updatePeerDelay\n");
+	ptpClock->char_last_msg = 'P';
+	if (twoStep) {
+		subTime(&ptpClock->pdelayMS,
+			&ptpClock->pdelay_resp_receive_time,
+			&ptpClock->pdelay_resp_send_time);
+		subTime(&ptpClock->pdelaySM,
+			&ptpClock->pdelay_req_receive_time,
+			&ptpClock->pdelay_req_send_time);
+		/* update 'one_way_delay' */
+		addTime(&ptpClock->portDS.peerMeanPathDelay,
+			&ptpClock->pdelayMS,
+			&ptpClock->pdelaySM);
+		subTime(&ptpClock->portDS.peerMeanPathDelay,
+			&ptpClock->portDS.peerMeanPathDelay, correctionField);
+		div2Time(&ptpClock->portDS.peerMeanPathDelay);
+	} else {
+		/* One step clock */
+	if (ptpClock->portDS.peerMeanPathDelay.seconds) {
+		/* cannot filter with secs, clear filter */
+		return;
+	s = rtOpts->s;
+		--s;
+	mpd_filt->y = (mpd_filt->s_exp - 1) *
+		mpd_filt->y / mpd_filt->s_exp +
+		(ptpClock->portDS.peerMeanPathDelay.nanoseconds / 2 +
+		 mpd_filt->nsec_prev / 2) / mpd_filt->s_exp;
+	mpd_filt->nsec_prev = ptpClock->portDS.peerMeanPathDelay.nanoseconds;
+	ptpClock->portDS.peerMeanPathDelay.nanoseconds = mpd_filt->y;
+	if(ptpClock->portDS.portState == PTP_SLAVE)
+void
+updateOffset(TimeInternal * send_time, TimeInternal * recv_time,
+    offset_from_master_filter * ofm_filt, const RunTimeOpts * rtOpts, PtpClock * ptpClock, TimeInternal * correctionField)
+	ptpClock->clockControl.offsetOK = FALSE;
+	DBGV("UTCOffset: %d | leap 59: %d |  leap61: %d\n",
+	     ptpClock->timePropertiesDS.currentUtcOffset,ptpClock->timePropertiesDS.leap59,ptpClock->timePropertiesDS.leap61);
+	/* prepare time constant for servo*/
+	ptpClock->servo.maxdT = rtOpts->servoMaxdT;
+	if(ptpClock->portDS.logSyncInterval == UNICAST_MESSAGEINTERVAL) {
+		ptpClock->servo.dT = 1;
+		if(rtOpts->unicastNegotiation && ptpClock->parentGrants && ptpClock->parentGrants->grantData[SYNC].granted) {
+			ptpClock->servo.dT = pow(2,ptpClock->parentGrants->grantData[SYNC].logInterval);
+	} else {
+		ptpClock->servo.dT = pow(2, ptpClock->portDS.logSyncInterval);
+	/* multiply interval if interval filter used on delayMS */
+	if(rtOpts->filterMSOpts.enabled && rtOpts->filterMSOpts.windowType != WINDOW_SLIDING) {
+	    ptpClock->servo.dT *= rtOpts->filterMSOpts.windowSize;
+#endif
+		return;
+	DBGV("==> updateOffset\n");
+		Boolean checkThreshold = (rtOpts->maxDelayStableOnly ?
+		    (rtOpts->maxDelay));
+#else
+#endif
+	//perform basic checks, using only local variables
+	TimeInternal master_to_slave_delay;
+	/* calc 'master_to_slave_delay' */
+	subTime(&master_to_slave_delay, recv_time, send_time);
+	if (checkThreshold) { /* If maxDelay is 0 then it's OFF */
+		if (master_to_slave_delay.seconds && checkThreshold) {
+			INFO("updateOffset aborted, master to slave delay greater than 1"
+			     " second.\n");
+			/* msgDump(ptpClock); */
+			return;
+		if (abs(master_to_slave_delay.nanoseconds) > rtOpts->maxDelay) {
+			DBG("updateOffset aborted, master to slave delay %d greater than "
+			     master_to_slave_delay.nanoseconds,
+					    WARNING("%d consecutive delay measurements above %d threshold - resetting slave\n",
+							rtOpts->maxDelayMaxRejected, master_to_slave_delay.nanoseconds);
+			    } else {
+			return;
+	// used for stats feedback
+	ptpClock->char_last_msg='S';
+	 *   - run the filters
+	 *   - update the global delayMS variable
+	 *   - calculate the new filtered OFM
+	subTime(&ptpClock->rawDelayMS, recv_time, send_time);
+DBG("UpdateOffset: max delay hit: %d\n", maxDelayHit);
+	TimeInternal bob;
+	bob.nanoseconds = 1000000;
+	bob.seconds = 0;
+	    	addTime(&ptpClock->rawDelayMS, &ptpClock->rawDelayMS, &bob);
+	if(rtOpts->filterMSOpts.enabled) {
+	    /* FALSE if filter wants to skip the update */
+	    if(!feedDoubleMovingStatFilter(ptpClock->filterMS, timeInternalToDouble(&ptpClock->rawDelayMS))) {
+		    goto finish;
+	    ptpClock->rawDelayMS = doubleToTimeInternal(ptpClock->filterMS->output);
+	/* run the delayMS outlier filter */
+	if(!rtOpts->noAdjust && ptpClock->oFilterMS.config.enabled && (ptpClock->oFilterMS.config.alwaysFilter || !ptpClock->servo.runningMaxOutput)) {
+		if(ptpClock->oFilterMS.filter(&ptpClock->oFilterMS, timeInternalToDouble(&ptpClock->rawDelayMS))) {
+			ptpClock->delayMS = doubleToTimeInternal(ptpClock->oFilterMS.output);
+		} else {
+			ptpClock->counters.delayMSOutliersFound++;
+			goto finish;
+	} else {
+		ptpClock->delayMS = ptpClock->rawDelayMS;
+#else
+	/* Used just for End to End mode. */
+	subTime(&ptpClock->delayMS, recv_time, send_time);
+#endif
+	/* Take care of correctionField */
+		&ptpClock->delayMS, correctionField);
+	/* update 'offsetFromMaster' */
+	if (ptpClock->portDS.delayMechanism == P2P) {
+		subTime(&ptpClock->currentDS.offsetFromMaster,
+			&ptpClock->portDS.peerMeanPathDelay);
+	/* (End to End mode or disabled - if disabled, meanpath delay is zero) */
+	} else if (ptpClock->portDS.delayMechanism == E2E ||
+	    ptpClock->portDS.delayMechanism == DELAY_DISABLED ) {
+			&ptpClock->currentDS.meanPathDelay);
+	if (ptpClock->currentDS.offsetFromMaster.seconds) {
+		ofm_filt->nsec_prev = 0;
+		ptpClock->offsetFirstUpdated = TRUE;
+		ptpClock->clockControl.offsetOK = TRUE;
+		SET_ALARM(ALRM_OFM_SECONDS, TRUE);
+		goto finish;
+	} else {
+		SET_ALARM(ALRM_OFM_SECONDS, FALSE);
+		if(rtOpts->ofmAlarmThreshold) {
+		    if( abs(ptpClock->currentDS.offsetFromMaster.nanoseconds)
+			> rtOpts->ofmAlarmThreshold) {
+			SET_ALARM(ALRM_OFM_THRESHOLD, TRUE);
+		    } else {
+			SET_ALARM(ALRM_OFM_THRESHOLD, FALSE);
+	/* filter 'offsetFromMaster' */
+	ofm_filt->y = ptpClock->currentDS.offsetFromMaster.nanoseconds / 2 +
+		ofm_filt->nsec_prev / 2;
+	ofm_filt->nsec_prev = ptpClock->currentDS.offsetFromMaster.nanoseconds;
+	ptpClock->currentDS.offsetFromMaster.nanoseconds = ofm_filt->y;
+	/* Apply the offset shift */
+	subTime(&ptpClock->currentDS.offsetFromMaster, &ptpClock->currentDS.offsetFromMaster,
+	&rtOpts->ofmShift);
+	DBGV("offset filter %d\n", ofm_filt->y);
+	 * Offset must have been computed at least one time before
+	 * computing end to end delay
+	if(!ptpClock->oFilterMS.lastOutlier) {
+            feedDoublePermanentStdDev(&ptpClock->slaveStats.ofmStats, timeInternalToDouble(&ptpClock->currentDS.offsetFromMaster));
+            feedDoublePermanentMedian(&ptpClock->slaveStats.ofmMedianContainer, timeInternalToDouble(&ptpClock->currentDS.offsetFromMaster));
+		if(!ptpClock->slaveStats.ofmStatsUpdated) {
+			if(timeInternalToDouble(&ptpClock->currentDS.offsetFromMaster) != 0.0){
+			ptpClock->slaveStats.ofmMax = timeInternalToDouble(&ptpClock->currentDS.offsetFromMaster);
+			ptpClock->slaveStats.ofmMin = timeInternalToDouble(&ptpClock->currentDS.offsetFromMaster);
+			ptpClock->slaveStats.ofmStatsUpdated = TRUE;
+		} else {
+		    ptpClock->slaveStats.ofmMax = max(ptpClock->slaveStats.ofmMax, timeInternalToDouble(&ptpClock->currentDS.offsetFromMaster));
+		    ptpClock->slaveStats.ofmMin = min(ptpClock->slaveStats.ofmMin, timeInternalToDouble(&ptpClock->currentDS.offsetFromMaster));
+finish:
+	DBGV("\n--Offset Correction-- \n");
+	DBGV("Raw offset from master:  %10ds %11dns\n",
+	    ptpClock->delayMS.seconds,
+	    ptpClock->delayMS.nanoseconds);
+	DBGV("\n--Offset and Delay filtered-- \n");
+		DBGV("one-way delay averaged (P2P):  %10ds %11dns\n",
+		    ptpClock->portDS.peerMeanPathDelay.seconds,
+		    ptpClock->portDS.peerMeanPathDelay.nanoseconds);
+	} else if (ptpClock->portDS.delayMechanism == E2E) {
+		DBGV("one-way delay averaged (E2E):  %10ds %11dns\n",
+		    ptpClock->currentDS.meanPathDelay.seconds,
+	DBGV("offset from master:      %10ds %11dns\n",
+	    ptpClock->currentDS.offsetFromMaster.seconds,
+	    ptpClock->currentDS.offsetFromMaster.nanoseconds);
+	DBGV("observed drift:          %10d\n", ptpClock->servo.observedDrift);
+void
+stepClock(const RunTimeOpts * rtOpts, PtpClock * ptpClock)
+	if(rtOpts->noAdjust){
+		WARNING("Could not step clock - clock adjustment disabled\n");
+		return;
+	SET_ALARM(ALRM_CLOCK_STEP, TRUE);
+	ptpClock->clockControl.stepRequired = FALSE;
+	TimeInternal oldTime, newTime;
+	/*No need to reset the frequency offset: if we're far off, it will quickly get back to a high value */
+	getTime(&oldTime);
+	subTime(&newTime, &oldTime, &ptpClock->currentDS.offsetFromMaster);
+	setTime(&newTime);
+	ptpClock->clockStatus.majorChange = TRUE;
+	initClock(rtOpts, ptpClock);
+	if(ptpClock->defaultDS.clockQuality.clockClass > 127)
+		restoreDrift(ptpClock, rtOpts, TRUE);
+	ptpClock->servo.runningMaxOutput = FALSE;
+	toState(PTP_FAULTY, rtOpts, ptpClock);		/* make a full protocol reset */
+        if(rtOpts->calibrationDelay) {
+                ptpClock->isCalibrated = FALSE;
+void
+warn_operator_fast_slewing(const RunTimeOpts * rtOpts, PtpClock * ptpClock, double adj)
+	if(ptpClock->warned_operator_fast_slewing == 0){
+		if ((adj >= rtOpts->servoMaxPpb) || ((adj <= -rtOpts->servoMaxPpb))){
+			ptpClock->warned_operator_fast_slewing = 1;
+			NOTICE("Servo: Going to slew the clock with the maximum frequency adjustment\n");
+void
+warn_operator_slow_slewing(const RunTimeOpts * rtOpts, PtpClock * ptpClock )
+	if(ptpClock->warned_operator_slow_slewing == 0){
+		ptpClock->warned_operator_slow_slewing = 1;
+		/* rule of thumb: at tick rate 10000, slewing at the maximum speed took 0.5ms per second */
+		float estimated = (((abs(ptpClock->currentDS.offsetFromMaster.seconds)) + 0.0) * 2.0 * 1000.0 / 3600.0);
+		ALERT("Servo: %d seconds offset detected, will take %.1f hours to slew\n",
+			estimated
+ * this is a wrapper around adjFreq to abstract extra operations
+void
+adjFreq_wrapper(const RunTimeOpts * rtOpts, PtpClock * ptpClock, double adj)
+    if (rtOpts->noAdjust){
+		DBGV("adjFreq2: noAdjust on, returning\n");
+		return;
+ * adjFreq simulation for QNX: correct clock by x ns per tick over clock adjust interval,
+ * to make it equal adj ns per second. Makes sense only if intervals are regular.
+#ifdef __QNXNTO__
+      struct _clockadjust clockadj;
+      struct _clockperiod period;
+      if (ClockPeriod (CLOCK_REALTIME, 0, &period, 0) < 0)
+          return;
+	CLAMP(adj,ptpClock->servo.maxOutput);
+	/* adjust clock for the duration of 0.9 clock update period in ticks (so we're done before the next) */
+	clockadj.tick_count = 0.9 * ptpClock->servo.dT * 1E9 / (period.nsec + 0.0);
+	/* scale adjustment per second to adjustment per single tick */
+	clockadj.tick_nsec_inc = (adj * ptpClock->servo.dT / clockadj.tick_count) / 0.9;
+	DBGV("QNX: adj: %.09f, dt: %.09f, ticks per dt: %d, inc per tick %d\n",
+		adj, ptpClock->servo.dT, clockadj.tick_count, clockadj.tick_nsec_inc);
+	if (ClockAdjust(CLOCK_REALTIME, &clockadj, NULL) < 0) {
+	    DBGV("QNX: failed to call ClockAdjust: %s\n", strerror(errno));
+/* regular adjFreq */
+#elif defined(HAVE_SYS_TIMEX_H)
+	DBG2("     adjFreq2: call adjfreq to %.09f us \n", adj / DBG_UNIT);
+	adjFreq(adj);
+/* otherwise use adjtime */
+#else
+	struct timeval tv;
+	tv.tv_sec = 0;
+	tv.tv_usec = (adj / 1000);
+	if((ptpClock->servo.dT > 0) && (ptpClock->servo.dT < 1.0)) {
+	    tv.tv_usec *= ptpClock->servo.dT;
+	adjtime(&tv, NULL);
+#endif
+/* check if it's OK to update the clock, deal with panic mode, call for clock step */
+void checkOffset(const RunTimeOpts *rtOpts, PtpClock *ptpClock)
+	/* unless offset OK */
+	ptpClock->clockControl.updateOK = FALSE;
+	/* if false, updateOffset does not want us to continue */
+	if(!ptpClock->clockControl.offsetOK) {
+		DBGV("checkOffset: !offsetOK\n");
+		return;
+	if(rtOpts->noAdjust) {
+		DBGV("checkOffset: noAdjust\n");
+		/* in case if noAdjust has changed */
+		ptpClock->clockControl.available = FALSE;
+		return;
+	/* Leap second pending: do not update clock */
+        if(ptpClock->leapSecondInProgress) {
+	    /* let the watchdog know that we still want to hold the clock control */
+	    DBGV("checkOffset: leapSecondInProgress\n");
+	    ptpClock->clockControl.activity = TRUE;
+	    return;
+	/* check if we are allowed to step the clock */
+	if(!ptpClock->pastStartup && (
+	    rtOpts->stepForce || (rtOpts->stepOnce && ptpClock->currentDS.offsetFromMaster.seconds)
+	    if(rtOpts->stepForce) WARNING("First clock update - will step the clock\n");
+	    if(rtOpts->stepOnce) WARNING("First clock update and offset >= 1 second - will step the clock\n");
+	    ptpClock->clockControl.stepRequired = TRUE;
+	    ptpClock->clockControl.updateOK = TRUE;
+	    ptpClock->pastStartup = TRUE;
+	    return;
+	/* check if offset within allowed limit */
+	if (rtOpts->maxOffset && ((abs(ptpClock->currentDS.offsetFromMaster.nanoseconds) > abs(rtOpts->maxOffset)) ||
+		ptpClock->currentDS.offsetFromMaster.seconds)) {
+		INFO("Offset %d.%09d greater than "
+			 "administratively set maximum %d\n. Will not update clock",
+		ptpClock->currentDS.offsetFromMaster.nanoseconds, rtOpts->maxOffset);
+		return;
+	/* offset above 1 second */
+		if(!rtOpts->enablePanicMode) {
+			if (!rtOpts->noResetClock)
+				CRITICAL("Offset above 1 second (%.09f s). Clock will step.\n",
+					    timeInternalToDouble(&ptpClock->currentDS.offsetFromMaster));
+			return;
+		/* still in panic mode, do nothing */
+		if(ptpClock->panicMode) {
+			DBG("checkOffset: still in panic mode\n");
+			/* if we have not released clock control, keep the heartbeats going */
+			if (ptpClock->clockControl.available) {
+			/* if for some reason we don't have clock control and not configured to release it, re-acquire it */
+			} else if(!rtOpts->panicModeReleaseClock) {
+				ptpClock->clockControl.available = TRUE;
+			/* and vice versa - in case the setting has changed */
+			} else {
+			return;
+		if(ptpClock->panicOver) {
+			if (rtOpts->noResetClock)
+				CRITICAL("Panic mode timeout - accepting current offset. Clock will be slewed at maximum rate.\n");
+			else
+				CRITICAL("Panic mode timeout - accepting current offset. Clock will step.\n");
+			ptpClock->panicOver = FALSE;
+			timerStop(&ptpClock->timers[PANIC_MODE_TIMER]);
+			return;
+		CRITICAL("Offset above 1 second (%.09f s)  - entering panic mode. Clock updates paused.\n",
+		ptpClock->panicMode = TRUE;
+		ptpClock->panicModeTimeLeft = 6 * rtOpts->panicModeDuration;
+		timerStart(&ptpClock->timers[PANIC_MODE_TIMER], 10);
+		/* do not release if not configured to do so */
+		if(rtOpts->panicModeReleaseClock) {
+		return;
+	/* offset below 1 second - exit panic mode if no threshold or if below threshold,
+	 * but make sure we stayed in panic mode for at least one interval,
+	 * so that we avoid flapping.
+	if(rtOpts->enablePanicMode && ptpClock->panicMode &&
+	    (ptpClock->panicModeTimeLeft != (2 * rtOpts->panicModeDuration)) ) {
+		if (rtOpts->panicModeExitThreshold == 0) {
+			ptpClock->panicMode = FALSE;
+			NOTICE("Offset below 1 second again: resuming clock control\n");
+			/* we can control the clock again */
+		} else if ( abs(ptpClock->currentDS.offsetFromMaster.nanoseconds) < rtOpts->panicModeExitThreshold ) {
+			NOTICE("Offset below %d ns threshold: resuming clock control\n",
+	/* can this even happen if offset is < 1 sec? */
+	if(rtOpts->enablePanicMode && ptpClock->panicOver) {
+			NOTICE("Panic mode timeout and offset below 1 second again: resuming clock control\n");
+void
+updateClock(const RunTimeOpts * rtOpts, PtpClock * ptpClock)
+		DBGV("updateClock: noAdjust - skipped clock update\n");
+		return;
+	if(!ptpClock->clockControl.updateOK) {
+		DBGV("updateClock: !clockUpdateOK - skipped clock update\n");
+		return;
+	DBGV("==> updateClock\n");
+	if(ptpClock->clockControl.stepRequired) {
+		if (!rtOpts->noResetClock) {
+			stepClock(rtOpts, ptpClock);
+			return;
+		} else {
+			if(ptpClock->currentDS.offsetFromMaster.nanoseconds > 0)
+				ptpClock->servo.observedDrift = rtOpts->servoMaxPpb;
+			else
+				ptpClock->servo.observedDrift = -rtOpts->servoMaxPpb;
+			warn_operator_slow_slewing(rtOpts, ptpClock);
+			adjFreq_wrapper(rtOpts, ptpClock, -ptpClock->servo.observedDrift);
+		return;
+	if (ptpClock->clockControl.granted) {
+	/* only run the servo if we are calibrted - if calibration delay configured */
+	if((!rtOpts->calibrationDelay) || ptpClock->isCalibrated) {
+		/* Adjust the clock first -> the PI controller runs here */
+		adjFreq_wrapper(rtOpts, ptpClock, runPIservo(&ptpClock->servo, ptpClock->currentDS.offsetFromMaster.nanoseconds));
+		warn_operator_fast_slewing(rtOpts, ptpClock, ptpClock->servo.observedDrift);
+		/* let the clock source know it's being synced */
+		ptpClock->clockStatus.inSync = TRUE;
+		ptpClock->clockStatus.clockOffset = (ptpClock->currentDS.offsetFromMaster.seconds * 1E9 +
+						ptpClock->currentDS.offsetFromMaster.nanoseconds) / 1000;
+		ptpClock->clockStatus.update = TRUE;
+	SET_ALARM(ALRM_FAST_ADJ, ptpClock->servo.runningMaxOutput);
+	/* we are ready to control the clock */
+	/* Clock has been updated - or was eligible for an update - restart the timeout timer*/
+	if(rtOpts->clockUpdateTimeout > 0) {
+		DBG("Restarted clock update timeout timer\n");
+		timerStart(&ptpClock->timers[CLOCK_UPDATE_TIMER],rtOpts->clockUpdateTimeout);
+	feedDoublePermanentStdDev(&ptpClock->servo.driftStats, ptpClock->servo.observedDrift);
+	feedDoublePermanentMedian(&ptpClock->servo.driftMedianContainer, ptpClock->servo.observedDrift);
+	if(!ptpClock->servo.statsUpdated) {
+	    if(ptpClock->servo.observedDrift != 0.0){
+		ptpClock->servo.driftMax = ptpClock->servo.observedDrift;
+		ptpClock->servo.driftMin = ptpClock->servo.observedDrift;
+		ptpClock->servo.statsUpdated = TRUE;
+	} else {
+	ptpClock->servo.driftMax = max(ptpClock->servo.driftMax, ptpClock->servo.observedDrift);
+	ptpClock->servo.driftMin = min(ptpClock->servo.driftMin, ptpClock->servo.observedDrift);
+#endif
+void
+setupPIservo(PIservo* servo, const const RunTimeOpts* rtOpts)
+    servo->maxOutput = rtOpts->servoMaxPpb;
+    servo->kP = rtOpts->servoKP;
+    servo->kI = rtOpts->servoKI;
+    servo->dTmethod = rtOpts->servoDtMethod;
+    servo->stabilityThreshold = rtOpts->servoStabilityThreshold;
+    servo->stabilityPeriod = rtOpts->servoStabilityPeriod;
+    servo->stabilityTimeout = (60 / rtOpts->statsUpdateInterval) * rtOpts->servoStabilityTimeout;
+#endif
+void
+resetPIservo(PIservo* servo)
+/* not needed: restoreDrift handles this */
+/*   servo->observedDrift = 0; */
+    servo->input = 0;
+    servo->output = 0;
+    servo->lastUpdate.seconds = 0;
+    servo->lastUpdate.nanoseconds = 0;
+double
+runPIservo(PIservo* servo, const Integer32 input)
+        double dt;
+        TimeInternal now, delta;
+        switch (servo->dTmethod) {
+        case DT_MEASURED:
+                getTimeMonotonic(&now);
+                if(servo->lastUpdate.seconds == 0 &&
+                servo->lastUpdate.nanoseconds == 0) {
+                        dt = servo->dT;
+                } else {
+                        subTime(&delta, &now, &servo->lastUpdate);
+                        dt = delta.seconds + delta.nanoseconds / 1E9;
+                /* Don't use dT longer then max update interval multiplier */
+                if(dt > (servo->maxdT * servo->dT))
+                        dt = (servo->maxdT + 0.0) * servo->dT;
+                break;
+        case DT_CONSTANT:
+                dt = servo->dT;
+		break;
+        case DT_NONE:
+        default:
+                dt = 1.0;
+                break;
+        if(dt <= 0.0)
+            dt = 1.0;
+	servo->input = input;
+	if (servo->kP < 0.000001)
+		servo->kP = 0.000001;
+	if (servo->kI < 0.000001)
+		servo->kI = 0.000001;
+	servo->observedDrift +=
+		dt * ((input + 0.0 ) * servo->kI);
+	if(servo->observedDrift >= servo->maxOutput) {
+		servo->observedDrift = servo->maxOutput;
+		servo->runningMaxOutput = TRUE;
+		servo->stableCount = 0;
+		servo->updateCount = 0;
+		servo->isStable = FALSE;
+	else if(servo->observedDrift <= -servo->maxOutput) {
+		servo->observedDrift = -servo->maxOutput;
+	} else {
+		servo->runningMaxOutput = FALSE;
+	servo->output = (servo->kP * (input + 0.0) ) + servo->observedDrift;
+	if(servo->dTmethod == DT_MEASURED)
+		servo->lastUpdate = now;
+	DBGV("Servo dt: %.09f, input (ofm): %d, output(adj): %.09f, accumulator (observed drift): %.09f\n", dt, input, servo->output, servo->observedDrift);
+	return -servo->output;
+static void
+checkServoStable(PtpClock *ptpClock, const RunTimeOpts *rtOpts)
+        DBG("servo stablecount: %d\n",ptpClock->servo.stableCount);
+	/* if not calibrated, do nothing */
+	if( !rtOpts->calibrationDelay || ptpClock->isCalibrated ) {
+		++ptpClock->servo.updateCount;
+	} else {
+		return;
+	/* check if we're below the threshold or not */
+	if(ptpClock->servo.runningMaxOutput || !ptpClock->acceptedUpdates ||
+	    (ptpClock->servo.driftStdDev > ptpClock->servo.stabilityThreshold)) {
+	    ptpClock->servo.stableCount = 0;
+	} else if (ptpClock->servo.driftStdDev <= ptpClock->servo.stabilityThreshold) {
+	    ptpClock->servo.stableCount++;
+	/* Servo considered stable - drift std dev below threshold for n measurements - saving drift*/
+        if(ptpClock->servo.stableCount >= ptpClock->servo.stabilityPeriod) {
+		if(!ptpClock->servo.isStable) {
+                        NOTICE("Clock servo now within stability threshold of %.03f ppb\n",
+				ptpClock->servo.stabilityThreshold);
+                saveDrift(ptpClock, rtOpts, ptpClock->servo.isStable);
+		ptpClock->servo.isStable = TRUE;
+		ptpClock->servo.updateCount = 0;
+	/* servo not stable within max interval */
+        } else if(ptpClock->servo.updateCount >= ptpClock->servo.stabilityTimeout) {
+		if(ptpClock->servo.isStable) {
+                        WARNING("Clock servo outside stability threshold (%.03f ppb dev > %.03f ppb thr). Too many warnings may mean the threshold is too low.\n",
+			    ptpClock->servo.driftStdDev,
+                        ptpClock->servo.isStable = FALSE;
+		} else {
+                        if(ptpClock->servo.runningMaxOutput) {
+				WARNING("Clock servo outside stability threshold after %d seconds - running at maximum rate.\n",
+					rtOpts->statsUpdateInterval * ptpClock->servo.stabilityTimeout);
+                        } else {
+                                WARNING("Clock servo outside stability threshold %d seconds after last check. Saving current observed drift.\n",
+				saveDrift(ptpClock, rtOpts, FALSE);
+void
+updatePtpEngineStats (PtpClock* ptpClock, const RunTimeOpts* rtOpts)
+	DBG("Refreshing slave engine stats counters\n");
+		DBG("samples used: %d/%d = %.03f\n", ptpClock->acceptedUpdates, ptpClock->offsetUpdates, (ptpClock->acceptedUpdates + 0.0) / (ptpClock->offsetUpdates + 0.0));
+	ptpClock->slaveStats.mpdMean = ptpClock->slaveStats.mpdStats.meanContainer.mean;
+	ptpClock->slaveStats.mpdStdDev = ptpClock->slaveStats.mpdStats.stdDev;
+	ptpClock->slaveStats.mpdMedian = ptpClock->slaveStats.mpdMedianContainer.median;
+	ptpClock->slaveStats.mpdMinFinal = ptpClock->slaveStats.mpdMin;
+	ptpClock->slaveStats.mpdMaxFinal = ptpClock->slaveStats.mpdMax;
+	ptpClock->slaveStats.ofmMean = ptpClock->slaveStats.ofmStats.meanContainer.mean;
+	ptpClock->slaveStats.ofmStdDev = ptpClock->slaveStats.ofmStats.stdDev;
+	ptpClock->slaveStats.ofmMedian = ptpClock->slaveStats.ofmMedianContainer.median;
+	ptpClock->slaveStats.ofmMinFinal = ptpClock->slaveStats.ofmMin;
+	ptpClock->slaveStats.ofmMaxFinal = ptpClock->slaveStats.ofmMax;
+	ptpClock->slaveStats.statsCalculated = TRUE;
+	ptpClock->servo.driftMean = ptpClock->servo.driftStats.meanContainer.mean;
+	ptpClock->servo.driftStdDev = ptpClock->servo.driftStats.stdDev;
+	ptpClock->servo.driftMedian = ptpClock->servo.driftMedianContainer.median;
+	ptpClock->servo.statsCalculated = TRUE;
+	ptpClock->servo.driftMinFinal = ptpClock->servo.driftMin;
+	ptpClock->servo.driftMaxFinal = ptpClock->servo.driftMax;
+	resetDoublePermanentMean(&ptpClock->oFilterMS.acceptedStats);
+	resetDoublePermanentMean(&ptpClock->oFilterSM.acceptedStats);
+	if(ptpClock->slaveStats.mpdStats.meanContainer.count >= 10.0) {
+		resetDoublePermanentStdDev(&ptpClock->slaveStats.mpdStats);
+		resetDoublePermanentMedian(&ptpClock->slaveStats.mpdMedianContainer);
+		ptpClock->slaveStats.ofmStatsUpdated = FALSE;
+		ptpClock->slaveStats.mpdStatsUpdated = FALSE;
+	if(ptpClock->slaveStats.ofmStats.meanContainer.count >= 10.0) {
+		resetDoublePermanentStdDev(&ptpClock->slaveStats.ofmStats);
+		resetDoublePermanentMedian(&ptpClock->slaveStats.ofmMedianContainer);
+	if(ptpClock->servo.driftStats.meanContainer.count >= 10.0)
+		resetDoublePermanentStdDev(&ptpClock->servo.driftStats);
+	resetDoublePermanentMedian(&ptpClock->servo.driftMedianContainer);
+	ptpClock->servo.statsUpdated = FALSE;
+	if(rtOpts->servoStabilityDetection && ptpClock->clockControl.granted) {
+		checkServoStable(ptpClock, rtOpts);
+	ptpClock->offsetUpdates = 0;
+	ptpClock->acceptedUpdates = 0;
diff --git a/freebsd/contrib/ptpd/src/dep/snmp.c b/freebsd/contrib/ptpd/src/dep/snmp.c
index 00000000..ae15eafd
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/snmp.c
@@ -0,0 +1,2186 @@
+ * Copyright (c) 2015 Wojciech Owczarek
+ * Copyright (c) 2012 The IMS Company
+ *                    Vincent Bernat
+ * All Rights Reserved
+ * modification, are permitted provided that the following conditions are
+ * met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ *    this list of conditions and the following disclaimer.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE AUTHORS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
+ * BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
+ * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
+ * IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * @file   snmp.c
+ * @author Vincent Bernat <bernat at luffy.cx>
+ * @date   Sat Jun 23 23:08:05 2012
+ * @brief  SNMP related functions
+#include "../ptpd.h"
+#include <net-snmp/net-snmp-config.h>
+#include <net-snmp/net-snmp-includes.h>
+#include <net-snmp/agent/net-snmp-agent-includes.h>
+//static void sendNotif(int event);
+static void sendNotif(int eventType, PtpEventData *eventData);
+/* Hard to get header... */
+extern int header_generic(struct variable *, oid *, size_t *, int,
+			  size_t *, WriteMethod **);
+enum {
+    /* PTPBASE-MIB core */
+    PTPBASE_SYSTEM_PROFILE = 1,
+    PTPBASE_DOMAIN_CLOCK_PORTS_TOTAL,
+    PTPBASE_SYSTEM_DOMAIN_TOTALS,
+    PTPBASE_CLOCK_CURRENT_DS_STEPS_REMOVED,
+    PTPBASE_CLOCK_CURRENT_DS_OFFSET_FROM_MASTER,
+    PTPBASE_CLOCK_CURRENT_DS_MEAN_PATH_DELAY,
+    PTPBASE_CLOCK_PARENT_DS_PARENT_PORT_ID,
+    PTPBASE_CLOCK_PARENT_DS_PARENT_STATS,
+    PTPBASE_CLOCK_PARENT_DS_OFFSET,
+    PTPBASE_CLOCK_PARENT_DS_CLOCK_PH_CH_RATE,
+    PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_IDENTITY,
+    PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_PRIO1,
+    PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_PRIO2,
+    PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_QUALITY_CLASS,
+    PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_QUALITY_ACCURACY,
+    PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_QUALITY_OFFSET,
+    PTPBASE_CLOCK_DEFAULT_DS_TWO_STEP_FLAG,
+    PTPBASE_CLOCK_DEFAULT_DS_CLOCK_IDENTITY,
+    PTPBASE_CLOCK_DEFAULT_DS_PRIO1,
+    PTPBASE_CLOCK_DEFAULT_DS_PRIO2,
+    PTPBASE_CLOCK_DEFAULT_DS_SLAVE_ONLY,
+    PTPBASE_CLOCK_DEFAULT_DS_QUALITY_CLASS,
+    PTPBASE_CLOCK_DEFAULT_DS_QUALITY_ACCURACY,
+    PTPBASE_CLOCK_DEFAULT_DS_QUALITY_OFFSET,
+    PTPBASE_CLOCK_DEFAULT_DS_DOMAIN_NUMBER,     /* PTPd addition */
+    PTPBASE_CLOCK_TIME_PROPERTIES_DS_CURRENT_UTC_OFFSET_VALID,
+    PTPBASE_CLOCK_TIME_PROPERTIES_DS_CURRENT_UTC_OFFSET,
+    PTPBASE_CLOCK_TIME_PROPERTIES_DS_LEAP59,
+    PTPBASE_CLOCK_TIME_PROPERTIES_DS_LEAP61,
+    PTPBASE_CLOCK_TIME_PROPERTIES_DS_TIME_TRACEABLE,
+    PTPBASE_CLOCK_TIME_PROPERTIES_DS_FREQ_TRACEABLE,
+    PTPBASE_CLOCK_TIME_PROPERTIES_DS_PTP_TIMESCALE,
+    PTPBASE_CLOCK_TIME_PROPERTIES_DS_SOURCE,
+    PTPBASE_CLOCK_PORT_NAME,
+    PTPBASE_CLOCK_PORT_ROLE,
+    PTPBASE_CLOCK_PORT_SYNC_ONE_STEP,
+    PTPBASE_CLOCK_PORT_CURRENT_PEER_ADDRESS_TYPE,
+    PTPBASE_CLOCK_PORT_CURRENT_PEER_ADDRESS,
+    PTPBASE_CLOCK_PORT_NUM_ASSOCIATED_PORTS,
+    PTPBASE_CLOCK_PORT_DS_PORT_NAME,
+    PTPBASE_CLOCK_PORT_DS_PORT_IDENTITY,
+    PTPBASE_CLOCK_PORT_DS_ANNOUNCEMENT_INTERVAL,
+    PTPBASE_CLOCK_PORT_DS_ANNOUNCE_RCT_TIMEOUT,
+    PTPBASE_CLOCK_PORT_DS_SYNC_INTERVAL,
+    PTPBASE_CLOCK_PORT_DS_MIN_DELAY_REQ_INTERVAL,
+    PTPBASE_CLOCK_PORT_DS_PEER_DELAY_REQ_INTERVAL,
+    PTPBASE_CLOCK_PORT_DS_DELAY_MECH,
+    PTPBASE_CLOCK_PORT_DS_PEER_MEAN_PATH_DELAY,
+    PTPBASE_CLOCK_PORT_DS_GRANT_DURATION,
+    PTPBASE_CLOCK_PORT_DS_PTP_VERSION,
+    PTPBASE_CLOCK_PORT_DS_PEER_MEAN_PATH_DELAY_STRING,     /* PTPd addition */
+    PTPBASE_CLOCK_PORT_DS_LAST_MISMATCHED_DOMAIN,     /* PTPd addition */
+    PTPBASE_CLOCK_PORT_RUNNING_NAME,
+    PTPBASE_CLOCK_PORT_RUNNING_STATE,
+    PTPBASE_CLOCK_PORT_RUNNING_ROLE,
+    PTPBASE_CLOCK_PORT_RUNNING_INTERFACE_INDEX,
+    PTPBASE_CLOCK_PORT_RUNNING_IPVERSION,
+    PTPBASE_CLOCK_PORT_RUNNING_ENCAPSULATION_TYPE,
+    PTPBASE_CLOCK_PORT_RUNNING_TX_MODE,
+    PTPBASE_CLOCK_PORT_RUNNING_RX_MODE,
+    PTPBASE_CLOCK_PORT_RUNNING_PACKETS_RECEIVED,
+    PTPBASE_CLOCK_PORT_RUNNING_PACKETS_SENT,
+    /* PTPd additions to PTPBASE-MIB */
+    PTPBASE_CLOCK_CURRENT_DS_OFFSET_FROM_MASTER_STRING,
+    PTPBASE_CLOCK_CURRENT_DS_MEAN_PATH_DELAY_STRING,
+    PTPBASE_CLOCK_CURRENT_DS_OFFSET_FROM_MASTER_THRESHOLD,
+    PTPBASE_CLOCK_PARENT_DS_PARENT_PORT_ADDRESS_TYPE,
+    PTPBASE_CLOCK_PARENT_DS_PARENT_PORT_ADDRESS,
+    /* ptpbasePtpPortMessageCounters */
+    PTPBASE_PORT_MESSAGE_COUNTERS_CLEAR,
+    PTPBASE_PORT_MESSAGE_COUNTERS_CLEAR_ALL,
+    PTPBASE_PORT_MESSAGE_COUNTERS_TOTAL_SENT,
+    PTPBASE_PORT_MESSAGE_COUNTERS_TOTAL_RECEIVED,
+    PTPBASE_PORT_MESSAGE_COUNTERS_ANNOUNCE_SENT,
+    PTPBASE_PORT_MESSAGE_COUNTERS_ANNOUNCE_RECEIVED,
+    PTPBASE_PORT_MESSAGE_COUNTERS_SYNC_SENT,
+    PTPBASE_PORT_MESSAGE_COUNTERS_SYNC_RECEIVED,
+    PTPBASE_PORT_MESSAGE_COUNTERS_FOLLOWUP_SENT,
+    PTPBASE_PORT_MESSAGE_COUNTERS_FOLLOWUP_RECEIVED,
+    PTPBASE_PORT_MESSAGE_COUNTERS_DELAYREQ_SENT,
+    PTPBASE_PORT_MESSAGE_COUNTERS_DELAYREQ_RECEIVED,
+    PTPBASE_PORT_MESSAGE_COUNTERS_DELAYRESP_SENT,
+    PTPBASE_PORT_MESSAGE_COUNTERS_DELAYRESP_RECEIVED,
+    PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYREQ_SENT,
+    PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYREQ_RECEIVED,
+    PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYRESP_SENT,
+    PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYRESP_RECEIVED,
+    PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYRESP_FOLLOWUP_SENT,
+    PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYRESP_FOLLOWUP_RECEIVED,
+    PTPBASE_PORT_MESSAGE_COUNTERS_SIGNALING_SENT,
+    PTPBASE_PORT_MESSAGE_COUNTERS_SIGNALING_RECEIVED,
+    PTPBASE_PORT_MESSAGE_COUNTERS_MANAGEMENT_SENT,
+    PTPBASE_PORT_MESSAGE_COUNTERS_MANAGEMENT_RECEIVED,
+    PTPBASE_PORT_MESSAGE_COUNTERS_DISCARDED_MESSAGES,
+    PTPBASE_PORT_MESSAGE_COUNTERS_UNKNOWN_MESSAGES,
+    /* ptpBasePtpProtocolCounters */
+    PTPBASE_PORT_PROTOCOL_COUNTERS_CLEAR,
+    PTPBASE_PORT_PROTOCOL_COUNTERS_FOREIGN_ADDED,
+    PTPBASE_PORT_PROTOCOL_COUNTERS_FOREIGN_COUNT,
+    PTPBASE_PORT_PROTOCOL_COUNTERS_FOREIGN_REMOVED,
+    PTPBASE_PORT_PROTOCOL_COUNTERS_FOREIGN_OVERFLOWS,
+    PTPBASE_PORT_PROTOCOL_COUNTERS_STATE_TRANSITIONS,
+    PTPBASE_PORT_PROTOCOL_COUNTERS_BEST_MASTER_CHANGES,
+    PTPBASE_PORT_PROTOCOL_COUNTERS_ANNOUNCE_TIMEOUTS,
+    /* ptpBasePtpErrorCounters */
+    PTPBASE_PORT_ERROR_COUNTERS_CLEAR,
+    PTPBASE_PORT_ERROR_COUNTERS_MESSAGE_RECV,
+    PTPBASE_PORT_ERROR_COUNTERS_MESSAGE_SEND,
+    PTPBASE_PORT_ERROR_COUNTERS_MESSAGE_FORMAT,
+    PTPBASE_PORT_ERROR_COUNTERS_PROTOCOL,
+    PTPBASE_PORT_ERROR_COUNTERS_VERSION_MISMATCH,
+    PTPBASE_PORT_ERROR_COUNTERS_DOMAIN_MISMATCH,
+    PTPBASE_PORT_ERROR_COUNTERS_SEQUENCE_MISMATCH,
+    PTPBASE_PORT_ERROR_COUNTERS_DELAYMECH_MISMATCH,
+    /* ptpBasePtpUnicastNegotiationCounters */
+    PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_CLEAR,
+    PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_REQUESTED,
+    PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_GRANTED,
+    PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_DENIED,
+    PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_CANCEL_SENT,
+    PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_CANCEL_RECEIVED,
+    PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_CANCEL_ACK_SENT,
+    PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_CANCEL_ACK_RECEIVED,
+    /* ptpBasePtpPerformanceCounters */
+    PTPBASE_PORT_PERFORMANCE_COUNTERS_MESSAGE_SEND_RATE,
+    PTPBASE_PORT_PERFORMANCE_COUNTERS_MESSAGE_RECEIVE_RATE,
+    /* ptpBasePtpSecurityCounters */
+    PTPBASE_PORT_SECURITY_COUNTERS_CLEAR,
+    PTPBASE_PORT_SECURITY_COUNTERS_TIMING_ACL_DISCARDED,
+    PTPBASE_PORT_SECURITY_COUNTERS_MANAGEMENT_ACL_DISCARDED,
+    /* ptpBaseSlaveOfmStatistics */
+    PTPBASE_SLAVE_OFM_STATS_CURRENT_VALUE,
+    PTPBASE_SLAVE_OFM_STATS_CURRENT_VALUE_STRING,
+    PTPBASE_SLAVE_OFM_STATS_PERIOD_SECONDS,
+    PTPBASE_SLAVE_OFM_STATS_VALID,
+    PTPBASE_SLAVE_OFM_STATS_MIN,
+    PTPBASE_SLAVE_OFM_STATS_MAX,
+    PTPBASE_SLAVE_OFM_STATS_MEAN,
+    PTPBASE_SLAVE_OFM_STATS_STDDEV,
+    PTPBASE_SLAVE_OFM_STATS_MEDIAN,
+    PTPBASE_SLAVE_OFM_STATS_MIN_STRING,
+    PTPBASE_SLAVE_OFM_STATS_MAX_STRING,
+    PTPBASE_SLAVE_OFM_STATS_MEAN_STRING,
+    PTPBASE_SLAVE_OFM_STATS_STDDEV_STRING,
+    PTPBASE_SLAVE_OFM_STATS_MEDIAN_STRING,
+    /* ptpBaseSlaveMpdStatistics */
+    PTPBASE_SLAVE_MPD_STATS_CURRENT_VALUE,
+    PTPBASE_SLAVE_MPD_STATS_CURRENT_VALUE_STRING,
+    PTPBASE_SLAVE_MPD_STATS_PERIOD_SECONDS,
+    PTPBASE_SLAVE_MPD_STATS_VALID,
+    PTPBASE_SLAVE_MPD_STATS_MIN,
+    PTPBASE_SLAVE_MPD_STATS_MAX,
+    PTPBASE_SLAVE_MPD_STATS_MEAN,
+    PTPBASE_SLAVE_MPD_STATS_STDDEV,
+    PTPBASE_SLAVE_MPD_STATS_MEDIAN,
+    PTPBASE_SLAVE_MPD_STATS_MIN_STRING,
+    PTPBASE_SLAVE_MPD_STATS_MAX_STRING,
+    PTPBASE_SLAVE_MPD_STATS_MEAN_STRING,
+    PTPBASE_SLAVE_MPD_STATS_STDDEV_STRING,
+    PTPBASE_SLAVE_MPD_STATS_MEDIAN_STRING,
+    /* ptpBaseSlaveFreqAdjStatistics */
+    PTPBASE_SLAVE_FREQADJ_STATS_CURRENT_VALUE,
+    PTPBASE_SLAVE_FREQADJ_STATS_PERIOD_SECONDS,
+    PTPBASE_SLAVE_FREQADJ_STATS_VALID,
+    PTPBASE_SLAVE_FREQADJ_STATS_MIN,
+    PTPBASE_SLAVE_FREQADJ_STATS_MAX,
+    PTPBASE_SLAVE_FREQADJ_STATS_MEAN,
+    PTPBASE_SLAVE_FREQADJ_STATS_STDDEV,
+    PTPBASE_SLAVE_FREQADJ_STATS_MEDIAN,
+    /* ptpBasePtpdSpecificCounters */
+    PTPBASE_PTPD_SPECIFIC_COUNTERS_CLEAR,
+    PTPBASE_PTPD_SPECIFIC_COUNTERS_IGNORED_ANNOUNCE,
+    PTPBASE_PTPD_SPECIFIC_COUNTERS_CONSECUTIVE_SEQUENCE_ERRORS,
+    PTPBASE_PTPD_SPECIFIC_COUNTERS_DELAYMS_OUTLIERS_FOUND,
+    PTPBASE_PTPD_SPECIFIC_COUNTERS_DELAYSM_OUTLIERS_FOUND,
+    PTPBASE_PTPD_SPECIFIC_COUNTERS_MAX_DELAY_DROPS,
+    /* ptpBasePtpdSpecificData */
+    PTPBASE_PTPD_SPECIFIC_DATA_RAW_DELAYMS,
+    PTPBASE_PTPD_SPECIFIC_DATA_RAW_DELAYMS_STRING,
+    PTPBASE_PTPD_SPECIFIC_DATA_RAW_DELAYSM,
+    PTPBASE_PTPD_SPECIFIC_DATA_RAW_DELAYSM_STRING
+/* trap / notification definitions */
+enum {
+	PTPBASE_NOTIFS_EXPECTED_PORT_STATE,
+	PTPBASE_NOTIFS_UNEXPECTED_PORT_STATE,
+	PTPBASE_NOTIFS_SLAVE_OFFSET_THRESHOLD_EXCEEDED,
+	PTPBASE_NOTIFS_SLAVE_OFFSET_THRESHOLD_ACCEPTABLE,
+	PTPBASE_NOTIFS_SLAVE_CLOCK_STEP,
+	PTPBASE_NOTIFS_SLAVE_NO_SYNC,
+	PTPBASE_NOTIFS_SLAVE_RECEIVING_SYNC,
+	PTPBASE_NOTIFS_SLAVE_NO_DELAY,
+	PTPBASE_NOTIFS_SLAVE_RECEIVING_DELAY,
+	PTPBASE_NOTIFS_BEST_MASTER_CHANGE,
+	PTPBASE_NOTIFS_NETWORK_FAULT,
+	PTPBASE_NOTIFS_NETWORK_FAULT_CLEARED,
+	PTPBASE_NOTIFS_FREQADJ_FAST,
+	PTPBASE_NOTIFS_FREQADJ_NORMAL,
+	PTPBASE_NOTIFS_OFFSET_SECONDS,
+	PTPBASE_NOTIFS_OFFSET_SUB_SECONDS,
+	PTPBASE_NOTIFS_TIMEPROPERTIESDS_CHANGE,
+	PTPBASE_NOTIFS_DOMAIN_MISMATCH,
+	PTPBASE_NOTIFS_DOMAIN_MISMATCH_CLEARED,
+#define SNMP_PTP_ORDINARY_CLOCK 1
+#define SNMP_PTP_CLOCK_INSTANCE 1	/* Only one instance */
+#define SNMP_PTP_PORT_MASTER 1
+#define SNMP_PTP_PORT_SLAVE  2
+#define SNMP_IPv4 1
+#define SNMP_PTP_TX_UNICAST 1
+#define SNMP_PTP_TX_MULTICAST 2
+#define SNMP_PTP_TX_MULTICAST_MIX 3
+#define TRUTHVALUE_TRUE 1
+#define TRUTHVALUE_FALSE 2
+#define TO_TRUTHVALUE(a) \
+	(a ? TRUTHVALUE_TRUE : TRUTHVALUE_FALSE)
+#define PTPBASE_MIB_OID \
+	1, 3, 6, 1, 4, 1, 46649, 1, 1
+#define PTPBASE_MIB_INDEX2 \
+	snmpPtpClock->defaultDS.domainNumber, SNMP_PTP_CLOCK_INSTANCE
+#define PTPBASE_MIB_INDEX3 \
+	snmpPtpClock->defaultDS.domainNumber, SNMP_PTP_ORDINARY_CLOCK, SNMP_PTP_CLOCK_INSTANCE
+#define PTPBASE_MIB_INDEX4 \
+	snmpPtpClock->defaultDS.domainNumber, SNMP_PTP_ORDINARY_CLOCK, SNMP_PTP_CLOCK_INSTANCE, snmpPtpClock->portDS.portIdentity.portNumber
+static oid  ptp_oid[] = { PTPBASE_MIB_OID };
+static PtpClock *snmpPtpClock;
+static RunTimeOpts *snmpRtOpts;
+/* Helper functions to build header_*indexed_table() functions.  Those
+   functions keep an internal state. They are not reentrant!
+struct snmpHeaderIndex {
+	struct variable *vp;
+	oid             *name;	 /* Requested/returned OID */
+	size_t          *length; /* Length of above OID */
+	int              exact;
+	oid              best[MAX_OID_LEN]; /* Best OID */
+	size_t           best_len;	    /* Best OID length */
+	void            *entity;	    /* Best entity */
+static int
+snmpHeaderInit(struct snmpHeaderIndex *idx,
+	       struct variable *vp, oid *name, size_t *length,
+	       int exact, size_t *var_len, WriteMethod **write_method)
+	/* If the requested OID name is less than OID prefix we
+	   handle, adjust it to our prefix. */
+        if ((snmp_oid_compare(name, *length, vp->name, vp->namelen)) < 0) {
+                memcpy(name, vp->name, sizeof(oid) * vp->namelen);
+                *length = vp->namelen;
+	/* Now, we can only handle OID matching our prefix. Those two
+	   tests are not really necessary since NetSNMP won't give us
+	   OID "above" our prefix. But this makes unit tests
+	   easier.  */
+	if (*length < vp->namelen) return 0;
+	if (memcmp(name, vp->name, vp->namelen * sizeof(oid))) return 0;
+	if(write_method != NULL) *write_method = 0;
+	*var_len = sizeof(long);
+	/* Initialize our header index structure */
+	idx->vp = vp;
+	idx->name = name;
+	idx->length = length;
+	idx->exact = exact;
+	idx->best_len = 0;
+	idx->entity = NULL;
+	return 1;
+static void
+snmpHeaderIndexAdd(struct snmpHeaderIndex *idx,
+		   oid *index, size_t len, void *entity)
+	int      result;
+	oid     *target;
+	size_t   target_len;
+        target = idx->name + idx->vp->namelen;
+        target_len = *idx->length - idx->vp->namelen;
+	if ((result = snmp_oid_compare(index, len, target, target_len)) < 0)
+		return;		/* Too small. */
+	if (idx->exact) {
+		if (result == 0) {
+			memcpy(idx->best, index, sizeof(oid) * len);
+			idx->best_len = len;
+			idx->entity = entity;
+			return;
+		return;
+	if (result == 0)
+	if (idx->best_len == 0 ||
+	    (snmp_oid_compare(index, len,
+			      idx->best,
+			      idx->best_len) < 0)) {
+static void*
+snmpHeaderIndexBest(struct snmpHeaderIndex *idx)
+	if (idx->entity == NULL)
+		return NULL;
+	if (idx->exact) {
+		if (snmp_oid_compare(idx->name + idx->vp->namelen,
+				     *idx->length - idx->vp->namelen,
+				     idx->best, idx->best_len) == 0)
+			return idx->entity;
+		return NULL;
+	memcpy(idx->name + idx->vp->namelen,
+	       idx->best, sizeof(oid) * idx->best_len);
+	*idx->length = idx->vp->namelen + idx->best_len;
+#define SNMP_LOCAL_VARIABLES			\
+	static unsigned long long_ret;		\
+	static struct counter64 counter64_ret;	\
+	static uint32_t ipaddr;			\
+	Integer32 i32_ret;			\
+	Integer64 bigint;			\
+	struct snmpHeaderIndex idx;		\
+	static char tmpStr[64];			\
+	(void)long_ret;				\
+	(void)counter64_ret;			\
+	(void)ipaddr;				\
+	(void)bigint;				\
+	(void)i32_ret;				\
+	(void)tmpStr;				\
+	(void)idx
+#define SNMP_INDEXED_TABLE			\
+	if (!snmpHeaderInit(&idx, vp, name,	\
+			    length, exact,	\
+			    var_len,		\
+			    write_method))	\
+		return NULL
+#define SNMP_ADD_INDEX(index, len, w)		\
+	snmpHeaderIndexAdd(&idx, index, len, w)
+#define SNMP_BEST_MATCH				\
+	snmpHeaderIndexBest(&idx)
+#define SNMP_OCTETSTR(V, L)			\
+	( *var_len = L,				\
+	  (u_char *)V )
+#define SNMP_COUNTER64(V)			\
+	( counter64_ret.low = (V) & 0xffffffff,	\
+	  counter64_ret.high = (V) >> 32,	\
+	  *var_len = sizeof (counter64_ret),	\
+	  (u_char*)&counter64_ret )
+#define SNMP_TIMEINTERNAL(V)				\
+	( *var_len = sizeof(counter64_ret),		\
+	  internalTime_to_integer64(V, &bigint),	\
+	  counter64_ret.low = htonl(bigint.lsb),	\
+	  counter64_ret.high = htonl(bigint.msb),      	\
+	  (u_char *)&counter64_ret )
+#define SNMP_INTEGER(V)		    \
+	( long_ret = (V),	    \
+	  *var_len = sizeof (long_ret),		\
+	  (u_char*)&long_ret )
+#define SNMP_IPADDR(A)				\
+	( ipaddr = A,				\
+	  *var_len = sizeof (ipaddr),		\
+	  (u_char*)&ipaddr )
+#define SNMP_GAUGE SNMP_INTEGER
+#define SNMP_UNSIGNED SNMP_INTEGER
+#define SNMP_TRUE SNMP_INTEGER(1)
+#define SNMP_FALSE SNMP_INTEGER(2)
+#define SNMP_BOOLEAN(V)				\
+	(V == TRUE)?SNMP_TRUE:SNMP_FALSE
+#define SNMP_SIGNATURE struct variable *vp,	\
+		oid *name,			\
+		size_t *length,			\
+		int exact,			\
+		size_t *var_len,		\
+		WriteMethod **write_method
+ * Handle SNMP scalar values.
+static u_char*
+snmpScalars(SNMP_SIGNATURE) {
+    SNMP_LOCAL_VARIABLES;
+    if (header_generic(vp, name, length, exact, var_len, write_method))
+	    return NULL;
+    switch (vp->magic) {
+    case PTPBASE_SYSTEM_PROFILE:
+	    return SNMP_INTEGER(1);
+    return NULL;
+ * Handle ptpbaseSystemTable
+static u_char*
+snmpSystemTable(SNMP_SIGNATURE) {
+	oid index[2];
+	SNMP_INDEXED_TABLE;
+	/* We only have one index: one domain, one instance */
+	index[0] = snmpPtpClock->defaultDS.domainNumber;
+	index[1] = SNMP_PTP_CLOCK_INSTANCE;
+	SNMP_ADD_INDEX(index, 2, snmpPtpClock);
+	if (!SNMP_BEST_MATCH) return NULL;
+	case PTPBASE_DOMAIN_CLOCK_PORTS_TOTAL:
+		return SNMP_GAUGE(snmpPtpClock->defaultDS.numberPorts);
+	return NULL;
+ * Handle ptpbaseSystemDomainTable
+static u_char*
+snmpSystemDomainTable(SNMP_SIGNATURE) {
+	oid index[1];
+	/* We only have one index: ordinary clock */
+	index[0] = SNMP_PTP_ORDINARY_CLOCK;
+	SNMP_ADD_INDEX(index, 1, snmpPtpClock);
+	case PTPBASE_SYSTEM_DOMAIN_TOTALS:
+		/* We only handle one domain... */
+		return SNMP_UNSIGNED(1);
+	return NULL;
+ * Handle various ptpbaseClock*DSTable
+static u_char*
+snmpClockDSTable(SNMP_SIGNATURE) {
+	oid index[3];
+	memset(tmpStr, 0, sizeof(tmpStr));
+	/* We only have one valid index */
+	index[1] = SNMP_PTP_ORDINARY_CLOCK;
+	index[2] = SNMP_PTP_CLOCK_INSTANCE;
+	SNMP_ADD_INDEX(index, 3, snmpPtpClock);
+	/* ptpbaseClockCurrentDSTable */
+	case PTPBASE_CLOCK_CURRENT_DS_STEPS_REMOVED:
+		return SNMP_UNSIGNED(snmpPtpClock->currentDS.stepsRemoved);
+	case PTPBASE_CLOCK_CURRENT_DS_OFFSET_FROM_MASTER:
+		return SNMP_TIMEINTERNAL(snmpPtpClock->currentDS.offsetFromMaster);
+	case PTPBASE_CLOCK_CURRENT_DS_MEAN_PATH_DELAY:
+		return SNMP_TIMEINTERNAL(snmpPtpClock->currentDS.meanPathDelay);
+	/* PTPd: offsets as string */
+	case PTPBASE_CLOCK_CURRENT_DS_OFFSET_FROM_MASTER_STRING:
+		snprintf(tmpStr, 64, "%.09f", timeInternalToDouble(&snmpPtpClock->currentDS.offsetFromMaster));
+		return SNMP_OCTETSTR(&tmpStr, strlen(tmpStr));
+	case PTPBASE_CLOCK_CURRENT_DS_MEAN_PATH_DELAY_STRING:
+		snprintf(tmpStr, 64, "%.09f", timeInternalToDouble(&snmpPtpClock->currentDS.meanPathDelay));
+	case PTPBASE_CLOCK_CURRENT_DS_OFFSET_FROM_MASTER_THRESHOLD:
+		return SNMP_INTEGER(snmpRtOpts->ofmAlarmThreshold);
+	/* ptpbaseClockParentDSTable */
+	case PTPBASE_CLOCK_PARENT_DS_PARENT_PORT_ID:
+		return SNMP_OCTETSTR(&snmpPtpClock->parentDS.parentPortIdentity,
+				     sizeof(PortIdentity));
+	case PTPBASE_CLOCK_PARENT_DS_PARENT_STATS:
+		return SNMP_BOOLEAN(snmpPtpClock->parentDS.parentStats);
+	case PTPBASE_CLOCK_PARENT_DS_OFFSET:
+		return SNMP_INTEGER(snmpPtpClock->parentDS.observedParentOffsetScaledLogVariance);
+	case PTPBASE_CLOCK_PARENT_DS_CLOCK_PH_CH_RATE:
+		return SNMP_INTEGER(snmpPtpClock->parentDS.observedParentClockPhaseChangeRate);
+	case PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_IDENTITY:
+		return SNMP_OCTETSTR(&snmpPtpClock->parentDS.grandmasterIdentity,
+				     sizeof(ClockIdentity));
+	case PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_PRIO1:
+		return SNMP_UNSIGNED(snmpPtpClock->parentDS.grandmasterPriority1);
+	case PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_PRIO2:
+		return SNMP_UNSIGNED(snmpPtpClock->parentDS.grandmasterPriority2);
+	case PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_QUALITY_CLASS:
+		return SNMP_UNSIGNED(snmpPtpClock->parentDS.grandmasterClockQuality.clockClass);
+	case PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_QUALITY_ACCURACY:
+		return SNMP_INTEGER(snmpPtpClock->parentDS.grandmasterClockQuality.clockAccuracy);
+	case PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_QUALITY_OFFSET:
+		return SNMP_INTEGER(snmpPtpClock->parentDS.grandmasterClockQuality.offsetScaledLogVariance);
+	/* PTPd addition */
+	case PTPBASE_CLOCK_PARENT_DS_PARENT_PORT_ADDRESS_TYPE:
+		/* Only supports IPv4 */
+		return SNMP_INTEGER(SNMP_IPv4);
+	case PTPBASE_CLOCK_PARENT_DS_PARENT_PORT_ADDRESS:
+		if(snmpRtOpts->transport != UDP_IPV4)
+		    return SNMP_IPADDR(0);
+		if(!snmpPtpClock->bestMaster)
+		return SNMP_IPADDR(snmpPtpClock->bestMaster->sourceAddr);
+	/* ptpbaseClockDefaultDSTable */
+	case PTPBASE_CLOCK_DEFAULT_DS_TWO_STEP_FLAG:
+		return SNMP_BOOLEAN(snmpPtpClock->defaultDS.twoStepFlag);
+	case PTPBASE_CLOCK_DEFAULT_DS_CLOCK_IDENTITY:
+		return SNMP_OCTETSTR(&snmpPtpClock->defaultDS.clockIdentity,
+	case PTPBASE_CLOCK_DEFAULT_DS_PRIO1:
+		return SNMP_UNSIGNED(snmpPtpClock->defaultDS.priority1);
+	case PTPBASE_CLOCK_DEFAULT_DS_PRIO2:
+		return SNMP_UNSIGNED(snmpPtpClock->defaultDS.priority2);
+	case PTPBASE_CLOCK_DEFAULT_DS_SLAVE_ONLY:
+		return SNMP_BOOLEAN(snmpPtpClock->defaultDS.slaveOnly);
+	case PTPBASE_CLOCK_DEFAULT_DS_QUALITY_CLASS:
+		return SNMP_UNSIGNED(snmpPtpClock->defaultDS.clockQuality.clockClass);
+	case PTPBASE_CLOCK_DEFAULT_DS_QUALITY_ACCURACY:
+		return SNMP_INTEGER(snmpPtpClock->defaultDS.clockQuality.clockAccuracy);
+	case PTPBASE_CLOCK_DEFAULT_DS_QUALITY_OFFSET:
+		return SNMP_INTEGER(snmpPtpClock->defaultDS.clockQuality.offsetScaledLogVariance);
+	case PTPBASE_CLOCK_DEFAULT_DS_DOMAIN_NUMBER:
+		return SNMP_INTEGER(snmpPtpClock->defaultDS.domainNumber);
+	/* ptpbaseClockTimePropertiesDSTable */
+	case PTPBASE_CLOCK_TIME_PROPERTIES_DS_CURRENT_UTC_OFFSET_VALID:
+		return SNMP_BOOLEAN(snmpPtpClock->timePropertiesDS.currentUtcOffsetValid);
+	case PTPBASE_CLOCK_TIME_PROPERTIES_DS_CURRENT_UTC_OFFSET:
+		return SNMP_INTEGER(snmpPtpClock->timePropertiesDS.currentUtcOffset);
+	case PTPBASE_CLOCK_TIME_PROPERTIES_DS_LEAP59:
+		return SNMP_BOOLEAN(snmpPtpClock->timePropertiesDS.leap59);
+	case PTPBASE_CLOCK_TIME_PROPERTIES_DS_LEAP61:
+		return SNMP_BOOLEAN(snmpPtpClock->timePropertiesDS.leap61);
+	case PTPBASE_CLOCK_TIME_PROPERTIES_DS_TIME_TRACEABLE:
+		return SNMP_BOOLEAN(snmpPtpClock->timePropertiesDS.timeTraceable);
+	case PTPBASE_CLOCK_TIME_PROPERTIES_DS_FREQ_TRACEABLE:
+		return SNMP_BOOLEAN(snmpPtpClock->timePropertiesDS.frequencyTraceable);
+	case PTPBASE_CLOCK_TIME_PROPERTIES_DS_PTP_TIMESCALE:
+		return SNMP_BOOLEAN(snmpPtpClock->timePropertiesDS.ptpTimescale);
+	case PTPBASE_CLOCK_TIME_PROPERTIES_DS_SOURCE:
+		return SNMP_INTEGER(snmpPtpClock->timePropertiesDS.timeSource);
+	return NULL;
+ * Handle ptpbaseClockPort*Table
+static u_char*
+snmpClockPortTable(SNMP_SIGNATURE) {
+	oid index[4];
+	index[3] = snmpPtpClock->portDS.portIdentity.portNumber;
+	SNMP_ADD_INDEX(index, 4, snmpPtpClock);
+	/* ptpbaseClockPortTable */
+	case PTPBASE_CLOCK_PORT_NAME:
+	case PTPBASE_CLOCK_PORT_DS_PORT_NAME:
+	case PTPBASE_CLOCK_PORT_RUNNING_NAME:
+		return SNMP_OCTETSTR(snmpPtpClock->userDescription,
+				     strlen(snmpPtpClock->userDescription));
+	case PTPBASE_CLOCK_PORT_ROLE:
+		return SNMP_INTEGER((snmpPtpClock->portDS.portState == PTP_MASTER)?
+				    SNMP_PTP_PORT_MASTER:SNMP_PTP_PORT_SLAVE);
+	case PTPBASE_CLOCK_PORT_SYNC_ONE_STEP:
+		return (snmpPtpClock->defaultDS.twoStepFlag == TRUE)?SNMP_FALSE:SNMP_TRUE;
+	case PTPBASE_CLOCK_PORT_CURRENT_PEER_ADDRESS_TYPE:
+	case PTPBASE_CLOCK_PORT_CURRENT_PEER_ADDRESS:
+		return(SNMP_IPADDR(snmpPtpClock->netPath.interfaceAddr.s_addr));
+	case PTPBASE_CLOCK_PORT_NUM_ASSOCIATED_PORTS:
+		if(snmpPtpClock->portDS.portState == PTP_MASTER && snmpRtOpts->unicastNegotiation) {
+			return SNMP_INTEGER(snmpPtpClock->slaveCount);
+		if(snmpPtpClock->portDS.portState == PTP_MASTER && snmpPtpClock->unicastDestinationCount) {
+			return SNMP_INTEGER(snmpPtpClock->unicastDestinationCount);
+		if(snmpPtpClock->portDS.portState == PTP_SLAVE) {
+			return SNMP_INTEGER(snmpPtpClock->number_foreign_records);
+		return SNMP_INTEGER(0);
+	/* ptpbaseClockPortDSTable */
+	case PTPBASE_CLOCK_PORT_DS_PORT_IDENTITY:
+		return SNMP_OCTETSTR(&snmpPtpClock->portDS.portIdentity,
+	case PTPBASE_CLOCK_PORT_DS_ANNOUNCEMENT_INTERVAL:
+		/* TODO: is it really logAnnounceInterval? */
+		return SNMP_INTEGER(snmpPtpClock->portDS.logAnnounceInterval);
+	case PTPBASE_CLOCK_PORT_DS_ANNOUNCE_RCT_TIMEOUT:
+		return SNMP_INTEGER(snmpPtpClock->portDS.announceReceiptTimeout);
+	case PTPBASE_CLOCK_PORT_DS_SYNC_INTERVAL:
+		/* TODO: is it really logSyncInterval? */
+		return SNMP_INTEGER(snmpPtpClock->portDS.logSyncInterval);
+	case PTPBASE_CLOCK_PORT_DS_MIN_DELAY_REQ_INTERVAL:
+		/* TODO: is it really logMinDelayReqInterval? */
+		return SNMP_INTEGER(snmpPtpClock->portDS.logMinDelayReqInterval);
+	case PTPBASE_CLOCK_PORT_DS_PEER_DELAY_REQ_INTERVAL:
+		/* TODO: is it really logMinPdelayReqInterval? */
+		return SNMP_INTEGER(snmpPtpClock->portDS.logMinPdelayReqInterval);
+	case PTPBASE_CLOCK_PORT_DS_DELAY_MECH:
+		return SNMP_INTEGER(snmpPtpClock->portDS.delayMechanism);
+	case PTPBASE_CLOCK_PORT_DS_PEER_MEAN_PATH_DELAY:
+		return SNMP_TIMEINTERNAL(snmpPtpClock->portDS.peerMeanPathDelay);
+	case PTPBASE_CLOCK_PORT_DS_GRANT_DURATION:
+		if(snmpRtOpts->unicastNegotiation && snmpPtpClock->parentGrants) {
+			return SNMP_UNSIGNED(snmpPtpClock->parentGrants->grantData[SYNC_INDEXED].duration);
+		return SNMP_UNSIGNED(0);
+	case PTPBASE_CLOCK_PORT_DS_PTP_VERSION:
+		return SNMP_INTEGER(snmpPtpClock->portDS.versionNumber);
+	case PTPBASE_CLOCK_PORT_DS_PEER_MEAN_PATH_DELAY_STRING:
+		snprintf(tmpStr, 64, "%.09f", timeInternalToDouble(&snmpPtpClock->portDS.peerMeanPathDelay));
+	case PTPBASE_CLOCK_PORT_DS_LAST_MISMATCHED_DOMAIN:
+		return SNMP_INTEGER(snmpPtpClock->portDS.lastMismatchedDomain);
+	/* ptpbaseClockPortRunningTable */
+	case PTPBASE_CLOCK_PORT_RUNNING_STATE:
+		return SNMP_INTEGER(snmpPtpClock->portDS.portState);
+	case PTPBASE_CLOCK_PORT_RUNNING_ROLE:
+	case PTPBASE_CLOCK_PORT_RUNNING_INTERFACE_INDEX:
+		return SNMP_INTEGER(snmpPtpClock->netPath.interfaceInfo.ifIndex);
+	case PTPBASE_CLOCK_PORT_RUNNING_IPVERSION:
+		/* IPv4 only */
+		return SNMP_INTEGER(4);
+	case PTPBASE_CLOCK_PORT_RUNNING_ENCAPSULATION_TYPE:
+		/* None. Moreover, the format is not really described in the MIB... */
+	case PTPBASE_CLOCK_PORT_RUNNING_TX_MODE:
+	case PTPBASE_CLOCK_PORT_RUNNING_RX_MODE:
+		if (snmpRtOpts->ipMode == IPMODE_UNICAST)
+			return SNMP_INTEGER(SNMP_PTP_TX_UNICAST);
+		if (snmpRtOpts->ipMode == IPMODE_HYBRID)
+			return SNMP_INTEGER(SNMP_PTP_TX_MULTICAST_MIX);
+		return SNMP_INTEGER(SNMP_PTP_TX_MULTICAST);
+	case PTPBASE_CLOCK_PORT_RUNNING_PACKETS_RECEIVED:
+		return SNMP_COUNTER64(snmpPtpClock->netPath.receivedPacketsTotal);
+	case PTPBASE_CLOCK_PORT_RUNNING_PACKETS_SENT:
+		return SNMP_COUNTER64(snmpPtpClock->netPath.sentPacketsTotal);
+	return NULL;
+/* clear counter sets based on oid. WARNING: USES MAGIC NUMBERS... */
+static int
+snmpWriteClearCounters (int action, u_char *var_val, u_char var_val_type, size_t var_val_len,
+			    u_char *statP, oid *name, size_t name_len) {
+	/* table: 6 oids from end (index fields, entry, field) */
+	oid myOid1 = name[name_len - 1 - 6];
+	/* field: 4 oids from end (index fields) */
+	oid myOid2 = name[name_len - 1 - 4];
+	if(var_val_type != ASN_INTEGER) {
+	    return SNMP_ERR_WRONGTYPE;
+	if(var_val_len > sizeof(long)) {
+	    return SNMP_ERR_WRONGLENGTH;
+	if(action==COMMIT) {
+	    long *val = (long*) var_val;
+	    if (*val == TRUTHVALUE_TRUE) {
+		switch (myOid1) {
+		    case 12: /* message counters */
+				/* all counters */
+				if(myOid2 == 5) {
+					memset(&snmpPtpClock->counters, 0, sizeof(PtpdCounters));
+					return SNMP_ERR_NOERROR;
+				/* message counters */
+				if(myOid2 == 6) {
+					snmpPtpClock->counters.announceMessagesSent = 0;
+					snmpPtpClock->counters.announceMessagesReceived = 0;
+					snmpPtpClock->counters.syncMessagesSent = 0;
+					snmpPtpClock->counters.syncMessagesReceived = 0;
+					snmpPtpClock->counters.followUpMessagesSent = 0;
+					snmpPtpClock->counters.followUpMessagesReceived = 0;
+					snmpPtpClock->counters.delayReqMessagesSent = 0;
+					snmpPtpClock->counters.delayReqMessagesReceived = 0;
+					snmpPtpClock->counters.delayRespMessagesSent = 0;
+					snmpPtpClock->counters.delayRespMessagesReceived = 0;
+					snmpPtpClock->counters.pdelayReqMessagesSent = 0;
+					snmpPtpClock->counters.pdelayReqMessagesReceived = 0;
+					snmpPtpClock->counters.pdelayRespMessagesSent = 0;
+					snmpPtpClock->counters.pdelayRespMessagesReceived = 0;
+					snmpPtpClock->counters.pdelayRespFollowUpMessagesSent = 0;
+					snmpPtpClock->counters.pdelayRespFollowUpMessagesReceived = 0;
+					snmpPtpClock->counters.signalingMessagesSent = 0;
+					snmpPtpClock->counters.signalingMessagesReceived = 0;
+					snmpPtpClock->counters.managementMessagesSent = 0;
+					snmpPtpClock->counters.managementMessagesReceived = 0;
+					snmpPtpClock->counters.discardedMessages = 0;
+					snmpPtpClock->counters.unknownMessages = 0;
+			break;
+		    case 13: /* protocol counters */
+				/* clear counters */
+				if(myOid2 == 5) {
+					snmpPtpClock->counters.foreignAdded = 0;
+					/* snmpPtpClock->counters.foreignCount = 0; */ /* we don't clear this */
+					snmpPtpClock->counters.foreignRemoved = 0;
+					snmpPtpClock->counters.foreignOverflows = 0;
+					snmpPtpClock->counters.stateTransitions = 0;
+					snmpPtpClock->counters.bestMasterChanges = 0;
+					snmpPtpClock->counters.announceTimeouts = 0;
+			break;
+		    case 14: /* error counters */
+				if(myOid2 == 5) {
+					snmpPtpClock->counters.messageRecvErrors = 0;
+					snmpPtpClock->counters.messageSendErrors = 0;
+					snmpPtpClock->counters.messageFormatErrors = 0;
+					snmpPtpClock->counters.protocolErrors = 0;
+					snmpPtpClock->counters.versionMismatchErrors = 0;
+					snmpPtpClock->counters.domainMismatchErrors = 0;
+					snmpPtpClock->counters.sequenceMismatchErrors = 0;
+					snmpPtpClock->counters.delayMechanismMismatchErrors = 0;
+			break;
+		    case 15: /* unicast negotiation counters */
+				if(myOid2 == 5) {
+					snmpPtpClock->counters.unicastGrantsRequested = 0;
+					snmpPtpClock->counters.unicastGrantsGranted = 0;
+					snmpPtpClock->counters.unicastGrantsDenied = 0;
+					snmpPtpClock->counters.unicastGrantsCancelSent = 0;
+					snmpPtpClock->counters.unicastGrantsCancelReceived = 0;
+					snmpPtpClock->counters.unicastGrantsCancelAckSent = 0;
+					snmpPtpClock->counters.unicastGrantsCancelAckReceived = 0;
+			break;
+		    case 17: /* security counters */
+				if(myOid2 == 5) {
+					snmpPtpClock->counters.aclTimingMessagesDiscarded = 0;
+					snmpPtpClock->counters.aclManagementMessagesDiscarded = 0;
+			break;
+		    case 21: /* ptpd counters */
+				if(myOid2 == 5) {
+					snmpPtpClock->counters.consecutiveSequenceErrors = 0;
+					snmpPtpClock->counters.ignoredAnnounce = 0;
+#ifdef PTPD_STATISTICS
+					snmpPtpClock->counters.delayMSOutliersFound = 0;
+					snmpPtpClock->counters.delaySMOutliersFound = 0;
+#endif
+					snmpPtpClock->counters.maxDelayDrops = 0;
+			break;
+		    default:
+			return SNMP_ERR_WRONGVALUE;
+ * Handle ptpbasePtpPortMessageCounters
+static u_char*
+snmpPtpPortMessageCountersTable(SNMP_SIGNATURE) {
+	oid index[4];
+	case PTPBASE_PORT_MESSAGE_COUNTERS_CLEAR:
+	    *write_method = snmpWriteClearCounters;
+	    return SNMP_FALSE;
+	case PTPBASE_PORT_MESSAGE_COUNTERS_CLEAR_ALL:
+	case PTPBASE_PORT_MESSAGE_COUNTERS_TOTAL_SENT:
+	    return SNMP_INTEGER(snmpPtpClock->netPath.sentPacketsTotal);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_TOTAL_RECEIVED:
+	    return SNMP_INTEGER(snmpPtpClock->netPath.receivedPacketsTotal);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_ANNOUNCE_SENT:
+	    return SNMP_INTEGER(snmpPtpClock->counters.announceMessagesSent);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_ANNOUNCE_RECEIVED:
+	    return SNMP_INTEGER(snmpPtpClock->counters.announceMessagesReceived);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_SYNC_SENT:
+	    return SNMP_INTEGER(snmpPtpClock->counters.syncMessagesSent);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_SYNC_RECEIVED:
+	    return SNMP_INTEGER(snmpPtpClock->counters.syncMessagesReceived);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_FOLLOWUP_SENT:
+	    return SNMP_INTEGER(snmpPtpClock->counters.followUpMessagesSent);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_FOLLOWUP_RECEIVED:
+	    return SNMP_INTEGER(snmpPtpClock->counters.followUpMessagesReceived);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_DELAYREQ_SENT:
+	    return SNMP_INTEGER(snmpPtpClock->counters.delayReqMessagesSent);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_DELAYREQ_RECEIVED:
+	    return SNMP_INTEGER(snmpPtpClock->counters.delayReqMessagesReceived);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_DELAYRESP_SENT:
+	    return SNMP_INTEGER(snmpPtpClock->counters.delayRespMessagesSent);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_DELAYRESP_RECEIVED:
+	    return SNMP_INTEGER(snmpPtpClock->counters.delayRespMessagesReceived);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYREQ_SENT:
+	    return SNMP_INTEGER(snmpPtpClock->counters.pdelayReqMessagesSent);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYREQ_RECEIVED:
+	    return SNMP_INTEGER(snmpPtpClock->counters.pdelayReqMessagesReceived);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYRESP_SENT:
+	    return SNMP_INTEGER(snmpPtpClock->counters.pdelayRespMessagesSent);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYRESP_RECEIVED:
+	    return SNMP_INTEGER(snmpPtpClock->counters.pdelayRespMessagesReceived);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYRESP_FOLLOWUP_SENT:
+	    return SNMP_INTEGER(snmpPtpClock->counters.pdelayRespFollowUpMessagesSent);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYRESP_FOLLOWUP_RECEIVED:
+	    return SNMP_INTEGER(snmpPtpClock->counters.pdelayRespFollowUpMessagesReceived);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_SIGNALING_SENT:
+	    return SNMP_INTEGER(snmpPtpClock->counters.signalingMessagesSent);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_SIGNALING_RECEIVED:
+	    return SNMP_INTEGER(snmpPtpClock->counters.signalingMessagesReceived);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_MANAGEMENT_SENT:
+	    return SNMP_INTEGER(snmpPtpClock->counters.managementMessagesSent);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_MANAGEMENT_RECEIVED:
+	    return SNMP_INTEGER(snmpPtpClock->counters.managementMessagesReceived);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_DISCARDED_MESSAGES:
+	    return SNMP_INTEGER(snmpPtpClock->counters.discardedMessages);
+	case PTPBASE_PORT_MESSAGE_COUNTERS_UNKNOWN_MESSAGES:
+	    return SNMP_INTEGER(snmpPtpClock->counters.unknownMessages);
+	return NULL;
+ * Handle ptpbasePtpPortProtocolCounters
+static u_char*
+snmpPtpPortProtocolCountersTable(SNMP_SIGNATURE) {
+	oid index[4];
+    case PTPBASE_PORT_PROTOCOL_COUNTERS_CLEAR:
+    case PTPBASE_PORT_PROTOCOL_COUNTERS_FOREIGN_ADDED:
+	return SNMP_INTEGER(snmpPtpClock->counters.foreignAdded);
+    case PTPBASE_PORT_PROTOCOL_COUNTERS_FOREIGN_COUNT:
+	return SNMP_INTEGER(snmpPtpClock->counters.foreignCount);
+    case PTPBASE_PORT_PROTOCOL_COUNTERS_FOREIGN_REMOVED:
+	return SNMP_INTEGER(snmpPtpClock->counters.foreignRemoved);
+    case PTPBASE_PORT_PROTOCOL_COUNTERS_FOREIGN_OVERFLOWS:
+	return SNMP_INTEGER(snmpPtpClock->counters.foreignOverflows);
+    case PTPBASE_PORT_PROTOCOL_COUNTERS_STATE_TRANSITIONS:
+	return SNMP_INTEGER(snmpPtpClock->counters.stateTransitions);
+    case PTPBASE_PORT_PROTOCOL_COUNTERS_BEST_MASTER_CHANGES:
+	return SNMP_INTEGER(snmpPtpClock->counters.bestMasterChanges);
+    case PTPBASE_PORT_PROTOCOL_COUNTERS_ANNOUNCE_TIMEOUTS:
+	return SNMP_INTEGER(snmpPtpClock->counters.announceTimeouts);
+	return NULL;
+ * Handle ptpbasePtpPortErrorCounters
+static u_char*
+snmpPtpPortErrorCountersTable(SNMP_SIGNATURE) {
+	oid index[4];
+    case PTPBASE_PORT_ERROR_COUNTERS_CLEAR:
+    case PTPBASE_PORT_ERROR_COUNTERS_MESSAGE_RECV:
+	return SNMP_INTEGER(snmpPtpClock->counters.messageRecvErrors);
+    case PTPBASE_PORT_ERROR_COUNTERS_MESSAGE_SEND:
+	return SNMP_INTEGER(snmpPtpClock->counters.messageSendErrors);
+    case PTPBASE_PORT_ERROR_COUNTERS_MESSAGE_FORMAT:
+	return SNMP_INTEGER(snmpPtpClock->counters.messageFormatErrors);
+    case PTPBASE_PORT_ERROR_COUNTERS_PROTOCOL:
+	return SNMP_INTEGER(snmpPtpClock->counters.protocolErrors);
+    case PTPBASE_PORT_ERROR_COUNTERS_VERSION_MISMATCH:
+	return SNMP_INTEGER(snmpPtpClock->counters.versionMismatchErrors);
+    case PTPBASE_PORT_ERROR_COUNTERS_DOMAIN_MISMATCH:
+	return SNMP_INTEGER(snmpPtpClock->counters.domainMismatchErrors);
+    case PTPBASE_PORT_ERROR_COUNTERS_SEQUENCE_MISMATCH:
+	return SNMP_INTEGER(snmpPtpClock->counters.sequenceMismatchErrors);
+    case PTPBASE_PORT_ERROR_COUNTERS_DELAYMECH_MISMATCH:
+	return SNMP_INTEGER(snmpPtpClock->counters.delayMechanismMismatchErrors);
+	return NULL;
+ * Handle ptpbasePtpPortUnicastNegotiationCounters
+static u_char*
+snmpPtpPortUnicastNegotiationCountersTable(SNMP_SIGNATURE) {
+	oid index[4];
+    case PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_CLEAR:
+    case PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_REQUESTED:
+	return SNMP_INTEGER(snmpPtpClock->counters.unicastGrantsRequested);
+    case PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_GRANTED:
+	return SNMP_INTEGER(snmpPtpClock->counters.unicastGrantsGranted);
+    case PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_DENIED:
+	return SNMP_INTEGER(snmpPtpClock->counters.unicastGrantsDenied);
+    case PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_CANCEL_SENT:
+	return SNMP_INTEGER(snmpPtpClock->counters.unicastGrantsCancelSent);
+    case PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_CANCEL_RECEIVED:
+	return SNMP_INTEGER(snmpPtpClock->counters.unicastGrantsCancelReceived);
+    case PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_CANCEL_ACK_SENT:
+	return SNMP_INTEGER(snmpPtpClock->counters.unicastGrantsCancelAckSent);
+    case PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_CANCEL_ACK_RECEIVED:
+	return SNMP_INTEGER(snmpPtpClock->counters.unicastGrantsCancelAckReceived);
+	return NULL;
+ * Handle ptpbasePtpPortPerformanceCounters
+static u_char*
+snmpPtpPortPerformanceCountersTable(SNMP_SIGNATURE) {
+	oid index[4];
+    case PTPBASE_PORT_PERFORMANCE_COUNTERS_MESSAGE_SEND_RATE:
+	return SNMP_INTEGER(snmpPtpClock->counters.messageSendRate);
+    case PTPBASE_PORT_PERFORMANCE_COUNTERS_MESSAGE_RECEIVE_RATE:
+	return SNMP_INTEGER(snmpPtpClock->counters.messageReceiveRate);
+	return NULL;
+ * Handle ptpbasePtpPortSecurityCounters
+static u_char*
+snmpPtpPortSecurityCountersTable(SNMP_SIGNATURE) {
+	oid index[4];
+    case PTPBASE_PORT_SECURITY_COUNTERS_CLEAR:
+    case PTPBASE_PORT_SECURITY_COUNTERS_TIMING_ACL_DISCARDED:
+	return SNMP_INTEGER(snmpPtpClock->counters.aclTimingMessagesDiscarded);
+    case PTPBASE_PORT_SECURITY_COUNTERS_MANAGEMENT_ACL_DISCARDED:
+	return SNMP_INTEGER(snmpPtpClock->counters.aclManagementMessagesDiscarded);
+	return NULL;
+ * Handle slaveOfmStatisticsTable
+static u_char*
+snmpSlaveOfmStatsTable(SNMP_SIGNATURE) {
+	oid index[3];
+	case PTPBASE_SLAVE_OFM_STATS_CURRENT_VALUE:
+	case PTPBASE_SLAVE_OFM_STATS_CURRENT_VALUE_STRING:
+	case PTPBASE_SLAVE_OFM_STATS_PERIOD_SECONDS:
+		return SNMP_INTEGER(snmpRtOpts->statsUpdateInterval);
+	case PTPBASE_SLAVE_OFM_STATS_VALID:
+		return SNMP_BOOLEAN(snmpPtpClock->slaveStats.statsCalculated);
+	case PTPBASE_SLAVE_OFM_STATS_MIN:
+		return SNMP_TIMEINTERNAL(doubleToTimeInternal(snmpPtpClock->slaveStats.ofmMinFinal));
+	case PTPBASE_SLAVE_OFM_STATS_MAX:
+		return SNMP_TIMEINTERNAL(doubleToTimeInternal(snmpPtpClock->slaveStats.ofmMaxFinal));
+	case PTPBASE_SLAVE_OFM_STATS_MEAN:
+		return SNMP_TIMEINTERNAL(doubleToTimeInternal(snmpPtpClock->slaveStats.ofmMean));
+	case PTPBASE_SLAVE_OFM_STATS_STDDEV:
+		return SNMP_TIMEINTERNAL(doubleToTimeInternal(snmpPtpClock->slaveStats.ofmStdDev));
+	case PTPBASE_SLAVE_OFM_STATS_MEDIAN:
+		return SNMP_TIMEINTERNAL(doubleToTimeInternal(snmpPtpClock->slaveStats.ofmMedian));
+	case PTPBASE_SLAVE_OFM_STATS_MIN_STRING:
+		snprintf(tmpStr, 64, "%.09f", snmpPtpClock->slaveStats.ofmMinFinal);
+	case PTPBASE_SLAVE_OFM_STATS_MAX_STRING:
+		snprintf(tmpStr, 64, "%.09f", snmpPtpClock->slaveStats.ofmMaxFinal);
+	case PTPBASE_SLAVE_OFM_STATS_MEAN_STRING:
+		snprintf(tmpStr, 64, "%.09f", snmpPtpClock->slaveStats.ofmMean);
+	case PTPBASE_SLAVE_OFM_STATS_STDDEV_STRING:
+		snprintf(tmpStr, 64, "%.09f", snmpPtpClock->slaveStats.ofmStdDev);
+	case PTPBASE_SLAVE_OFM_STATS_MEDIAN_STRING:
+		snprintf(tmpStr, 64, "%.09f", snmpPtpClock->slaveStats.ofmMedian);
+#endif
+	return NULL;
+ * Handle slaveMpdStatisticsTable
+static u_char*
+snmpSlaveMpdStatsTable(SNMP_SIGNATURE) {
+	oid index[3];
+	case PTPBASE_SLAVE_MPD_STATS_CURRENT_VALUE:
+	case PTPBASE_SLAVE_MPD_STATS_CURRENT_VALUE_STRING:
+	case PTPBASE_SLAVE_MPD_STATS_PERIOD_SECONDS:
+	case PTPBASE_SLAVE_MPD_STATS_VALID:
+	case PTPBASE_SLAVE_MPD_STATS_MIN:
+		return SNMP_TIMEINTERNAL(doubleToTimeInternal(snmpPtpClock->slaveStats.mpdMinFinal));
+	case PTPBASE_SLAVE_MPD_STATS_MAX:
+		return SNMP_TIMEINTERNAL(doubleToTimeInternal(snmpPtpClock->slaveStats.mpdMaxFinal));
+	case PTPBASE_SLAVE_MPD_STATS_MEAN:
+		return SNMP_TIMEINTERNAL(doubleToTimeInternal(snmpPtpClock->slaveStats.mpdMean));
+	case PTPBASE_SLAVE_MPD_STATS_STDDEV:
+		return SNMP_TIMEINTERNAL(doubleToTimeInternal(snmpPtpClock->slaveStats.mpdStdDev));
+	case PTPBASE_SLAVE_MPD_STATS_MEDIAN:
+		return SNMP_TIMEINTERNAL(doubleToTimeInternal(snmpPtpClock->slaveStats.mpdMedian));
+	case PTPBASE_SLAVE_MPD_STATS_MIN_STRING:
+		snprintf(tmpStr, 64, "%.09f", snmpPtpClock->slaveStats.mpdMinFinal);
+	case PTPBASE_SLAVE_MPD_STATS_MAX_STRING:
+		snprintf(tmpStr, 64, "%.09f", snmpPtpClock->slaveStats.mpdMaxFinal);
+	case PTPBASE_SLAVE_MPD_STATS_MEAN_STRING:
+		snprintf(tmpStr, 64, "%.09f", snmpPtpClock->slaveStats.mpdMean);
+	case PTPBASE_SLAVE_MPD_STATS_STDDEV_STRING:
+		snprintf(tmpStr, 64, "%.09f", snmpPtpClock->slaveStats.mpdStdDev);
+	case PTPBASE_SLAVE_MPD_STATS_MEDIAN_STRING:
+		snprintf(tmpStr, 64, "%.09f", snmpPtpClock->slaveStats.mpdMedian);
+#endif
+	return NULL;
+ * Handle slaveFreqAdjStatisticsTable
+static u_char*
+snmpSlaveFreqAdjStatsTable(SNMP_SIGNATURE) {
+	oid index[3];
+	    case PTPBASE_SLAVE_FREQADJ_STATS_CURRENT_VALUE:
+		return SNMP_INTEGER(snmpPtpClock->servo.observedDrift);
+	    case PTPBASE_SLAVE_FREQADJ_STATS_PERIOD_SECONDS:
+	    case PTPBASE_SLAVE_FREQADJ_STATS_VALID:
+		return SNMP_BOOLEAN(snmpPtpClock->servo.statsCalculated);
+	    case PTPBASE_SLAVE_FREQADJ_STATS_MIN:
+		return SNMP_INTEGER(snmpPtpClock->servo.driftMinFinal);
+	    case PTPBASE_SLAVE_FREQADJ_STATS_MAX:
+		return SNMP_INTEGER(snmpPtpClock->servo.driftMaxFinal);
+	    case PTPBASE_SLAVE_FREQADJ_STATS_MEAN:
+		return SNMP_INTEGER(snmpPtpClock->servo.driftMean);
+	    case PTPBASE_SLAVE_FREQADJ_STATS_STDDEV:
+		return SNMP_INTEGER(snmpPtpClock->servo.driftStdDev);
+	    case PTPBASE_SLAVE_FREQADJ_STATS_MEDIAN:
+		return SNMP_INTEGER(snmpPtpClock->servo.driftMedian);
+#endif
+	return NULL;
+ * Handle ptpbasePtpdSpecificCounters
+static u_char*
+snmpPtpdSpecificCountersTable(SNMP_SIGNATURE) {
+	oid index[4];
+    case PTPBASE_PTPD_SPECIFIC_COUNTERS_CLEAR:
+    case PTPBASE_PTPD_SPECIFIC_COUNTERS_IGNORED_ANNOUNCE:
+	return SNMP_INTEGER(snmpPtpClock->counters.ignoredAnnounce);
+    case PTPBASE_PTPD_SPECIFIC_COUNTERS_CONSECUTIVE_SEQUENCE_ERRORS:
+	return SNMP_INTEGER(snmpPtpClock->counters.consecutiveSequenceErrors);
+    case PTPBASE_PTPD_SPECIFIC_COUNTERS_DELAYMS_OUTLIERS_FOUND:
+	return SNMP_INTEGER(snmpPtpClock->counters.delayMSOutliersFound);
+    case PTPBASE_PTPD_SPECIFIC_COUNTERS_DELAYSM_OUTLIERS_FOUND:
+	return SNMP_INTEGER(snmpPtpClock->counters.delaySMOutliersFound);
+#endif
+    case PTPBASE_PTPD_SPECIFIC_COUNTERS_MAX_DELAY_DROPS:
+	return SNMP_INTEGER(snmpPtpClock->counters.maxDelayDrops);
+	return NULL;
+ * Handle ptpBasePtpdSpecificData
+static u_char*
+snmpPtpdSpecificDataTable(SNMP_SIGNATURE) {
+	oid index[3];
+	    case PTPBASE_PTPD_SPECIFIC_DATA_RAW_DELAYMS:
+		return SNMP_TIMEINTERNAL(snmpPtpClock->rawDelayMS);
+	    case PTPBASE_PTPD_SPECIFIC_DATA_RAW_DELAYMS_STRING:
+		snprintf(tmpStr, 64, "%.09f", timeInternalToDouble(&snmpPtpClock->rawDelayMS));
+	    case PTPBASE_PTPD_SPECIFIC_DATA_RAW_DELAYSM:
+		return SNMP_TIMEINTERNAL(snmpPtpClock->rawDelaySM);
+	    case PTPBASE_PTPD_SPECIFIC_DATA_RAW_DELAYSM_STRING:
+		snprintf(tmpStr, 64, "%.09f", timeInternalToDouble(&snmpPtpClock->rawDelaySM));
+#endif
+	return NULL;
+ * MIB definition
+static struct variable7 snmpVariables[] = {
+	/* ptpbaseSystemTable */
+	{ PTPBASE_DOMAIN_CLOCK_PORTS_TOTAL, ASN_GAUGE, HANDLER_CAN_RONLY,
+	  snmpSystemTable, 5, {1, 1, 1, 1, 3}},
+	/* ptpbaseSystemDomainTable */
+	{ PTPBASE_SYSTEM_DOMAIN_TOTALS, ASN_UNSIGNED, HANDLER_CAN_RONLY,
+	  snmpSystemDomainTable, 5, {1, 1, 2, 1, 2}},
+	/* Scalars */
+	{ PTPBASE_SYSTEM_PROFILE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpScalars, 3, {1, 1, 3}},
+	{ PTPBASE_CLOCK_CURRENT_DS_STEPS_REMOVED, ASN_UNSIGNED, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 1, 1, 4}},
+	{ PTPBASE_CLOCK_CURRENT_DS_OFFSET_FROM_MASTER, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 1, 1, 5}},
+	{ PTPBASE_CLOCK_CURRENT_DS_MEAN_PATH_DELAY, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 1, 1, 6}},
+	/* PTPd enhancements */
+	{ PTPBASE_CLOCK_CURRENT_DS_OFFSET_FROM_MASTER_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 1, 1, 7}},
+	{ PTPBASE_CLOCK_CURRENT_DS_MEAN_PATH_DELAY_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 1, 1, 8}},
+	{ PTPBASE_CLOCK_CURRENT_DS_OFFSET_FROM_MASTER_THRESHOLD, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 1, 1, 9}},
+	{ PTPBASE_CLOCK_PARENT_DS_PARENT_PORT_ID, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 2, 1, 4}},
+	{ PTPBASE_CLOCK_PARENT_DS_PARENT_STATS, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 2, 1, 5}},
+	{ PTPBASE_CLOCK_PARENT_DS_OFFSET, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 2, 1, 6}},
+	{ PTPBASE_CLOCK_PARENT_DS_CLOCK_PH_CH_RATE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 2, 1, 7}},
+	{ PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_IDENTITY, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 2, 1, 8}},
+	{ PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_PRIO1, ASN_UNSIGNED, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 2, 1, 9}},
+	{ PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_PRIO2, ASN_UNSIGNED, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 2, 1, 10}},
+	{ PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_QUALITY_CLASS, ASN_UNSIGNED, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 2, 1, 11}},
+	{ PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_QUALITY_ACCURACY, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 2, 1, 12}},
+	{ PTPBASE_CLOCK_PARENT_DS_GM_CLOCK_QUALITY_OFFSET, ASN_UNSIGNED, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 2, 1, 13}},
+	{ PTPBASE_CLOCK_PARENT_DS_PARENT_PORT_ADDRESS_TYPE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 2, 1, 14}},
+	{ PTPBASE_CLOCK_PARENT_DS_PARENT_PORT_ADDRESS, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 2, 1, 15}},
+	{ PTPBASE_CLOCK_DEFAULT_DS_TWO_STEP_FLAG, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 3, 1, 4}},
+	{ PTPBASE_CLOCK_DEFAULT_DS_CLOCK_IDENTITY, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 3, 1, 5}},
+	{ PTPBASE_CLOCK_DEFAULT_DS_PRIO1, ASN_UNSIGNED, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 3, 1, 6}},
+	{ PTPBASE_CLOCK_DEFAULT_DS_PRIO2, ASN_UNSIGNED, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 3, 1, 7}},
+	{ PTPBASE_CLOCK_DEFAULT_DS_SLAVE_ONLY, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 3, 1, 8}},
+	{ PTPBASE_CLOCK_DEFAULT_DS_QUALITY_CLASS, ASN_UNSIGNED, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 3, 1, 9}},
+	{ PTPBASE_CLOCK_DEFAULT_DS_QUALITY_ACCURACY, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 3, 1, 10}},
+	{ PTPBASE_CLOCK_DEFAULT_DS_QUALITY_OFFSET, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 3, 1, 11}},
+	/* PTPd addition - this is part of the index, but if you use snmpgetnext, you guess the indexes */
+	{ PTPBASE_CLOCK_DEFAULT_DS_DOMAIN_NUMBER, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 3, 1, 12}},
+	/* ptpbaseClockRunningTable: no data available for this table? */
+	{ PTPBASE_CLOCK_TIME_PROPERTIES_DS_CURRENT_UTC_OFFSET_VALID, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 5, 1, 4}},
+	{ PTPBASE_CLOCK_TIME_PROPERTIES_DS_CURRENT_UTC_OFFSET, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 5, 1, 5}},
+	{ PTPBASE_CLOCK_TIME_PROPERTIES_DS_LEAP59, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 5, 1, 6}},
+	{ PTPBASE_CLOCK_TIME_PROPERTIES_DS_LEAP61, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 5, 1, 7}},
+	{ PTPBASE_CLOCK_TIME_PROPERTIES_DS_TIME_TRACEABLE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 5, 1, 8}},
+	{ PTPBASE_CLOCK_TIME_PROPERTIES_DS_FREQ_TRACEABLE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 5, 1, 9}},
+	{ PTPBASE_CLOCK_TIME_PROPERTIES_DS_PTP_TIMESCALE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 5, 1, 10}},
+	{ PTPBASE_CLOCK_TIME_PROPERTIES_DS_SOURCE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockDSTable, 5, {1, 2, 5, 1, 11}},
+	{ PTPBASE_CLOCK_PORT_NAME, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 7, 1, 5}},
+	{ PTPBASE_CLOCK_PORT_ROLE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 7, 1, 6}},
+	{ PTPBASE_CLOCK_PORT_SYNC_ONE_STEP, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 7, 1, 7}},
+	{ PTPBASE_CLOCK_PORT_CURRENT_PEER_ADDRESS_TYPE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 7, 1, 8}},
+	{ PTPBASE_CLOCK_PORT_CURRENT_PEER_ADDRESS, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 7, 1, 9}},
+	{ PTPBASE_CLOCK_PORT_NUM_ASSOCIATED_PORTS, ASN_GAUGE, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 7, 1, 10}},
+	{ PTPBASE_CLOCK_PORT_DS_PORT_NAME, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 8, 1, 5}},
+	{ PTPBASE_CLOCK_PORT_DS_PORT_IDENTITY, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 8, 1, 6}},
+	{ PTPBASE_CLOCK_PORT_DS_ANNOUNCEMENT_INTERVAL, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 8, 1, 7}},
+	{ PTPBASE_CLOCK_PORT_DS_ANNOUNCE_RCT_TIMEOUT, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 8, 1, 8}},
+	{ PTPBASE_CLOCK_PORT_DS_SYNC_INTERVAL, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 8, 1, 9}},
+	{ PTPBASE_CLOCK_PORT_DS_MIN_DELAY_REQ_INTERVAL, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 8, 1, 10}},
+	{ PTPBASE_CLOCK_PORT_DS_PEER_DELAY_REQ_INTERVAL, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 8, 1, 11}},
+	{ PTPBASE_CLOCK_PORT_DS_DELAY_MECH, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 8, 1, 12}},
+	{ PTPBASE_CLOCK_PORT_DS_PEER_MEAN_PATH_DELAY, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 8, 1, 13}},
+	{ PTPBASE_CLOCK_PORT_DS_GRANT_DURATION, ASN_UNSIGNED, HANDLER_CAN_RONLY,
+	   snmpClockPortTable, 5, {1, 2, 8, 1, 14}},
+	{ PTPBASE_CLOCK_PORT_DS_PTP_VERSION, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 8, 1, 15}},
+	{ PTPBASE_CLOCK_PORT_DS_PEER_MEAN_PATH_DELAY_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 8, 1, 16}},
+	{ PTPBASE_CLOCK_PORT_DS_LAST_MISMATCHED_DOMAIN, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 8, 1, 17}},
+	{ PTPBASE_CLOCK_PORT_RUNNING_NAME, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 9, 1, 5}},
+	{ PTPBASE_CLOCK_PORT_RUNNING_STATE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 9, 1, 6}},
+	{ PTPBASE_CLOCK_PORT_RUNNING_ROLE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 9, 1, 7}},
+	{ PTPBASE_CLOCK_PORT_RUNNING_INTERFACE_INDEX, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 9, 1, 8}},
+	{ PTPBASE_CLOCK_PORT_RUNNING_IPVERSION, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 9, 1, 9}},
+	{ PTPBASE_CLOCK_PORT_RUNNING_ENCAPSULATION_TYPE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 9, 1, 10}},
+	{ PTPBASE_CLOCK_PORT_RUNNING_TX_MODE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 9, 1, 11}},
+	{ PTPBASE_CLOCK_PORT_RUNNING_RX_MODE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 9, 1, 12}},
+	{ PTPBASE_CLOCK_PORT_RUNNING_PACKETS_RECEIVED, ASN_COUNTER64, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 9, 1, 13}},
+	{ PTPBASE_CLOCK_PORT_RUNNING_PACKETS_SENT, ASN_COUNTER64, HANDLER_CAN_RONLY,
+	  snmpClockPortTable, 5, {1, 2, 9, 1, 14}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_CLEAR_ALL, ASN_INTEGER, HANDLER_CAN_RWRITE,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 5}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_CLEAR, ASN_INTEGER, HANDLER_CAN_RWRITE,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 6}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_TOTAL_SENT, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 7}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_TOTAL_RECEIVED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 8}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_ANNOUNCE_SENT, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 9}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_ANNOUNCE_RECEIVED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 10}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_SYNC_SENT, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 11}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_SYNC_RECEIVED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 12}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_FOLLOWUP_SENT, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 13}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_FOLLOWUP_RECEIVED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 14}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_DELAYREQ_SENT, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 15}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_DELAYREQ_RECEIVED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 16}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_DELAYRESP_SENT, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 17}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_DELAYRESP_RECEIVED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 18}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYREQ_SENT, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 19}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYREQ_RECEIVED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 20}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYRESP_SENT, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 21}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYRESP_RECEIVED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 22}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYRESP_FOLLOWUP_SENT, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 23}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_PDELAYRESP_FOLLOWUP_RECEIVED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 24}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_SIGNALING_SENT, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 25}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_SIGNALING_RECEIVED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 26}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_MANAGEMENT_SENT, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 27}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_MANAGEMENT_RECEIVED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 28}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_DISCARDED_MESSAGES, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 29}},
+	{ PTPBASE_PORT_MESSAGE_COUNTERS_UNKNOWN_MESSAGES, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortMessageCountersTable, 5, {1, 2, 12, 1, 30}},
+	/* ptpbasePtpPortProtocolCounters */
+	{ PTPBASE_PORT_PROTOCOL_COUNTERS_CLEAR, ASN_INTEGER, HANDLER_CAN_RWRITE,
+	  snmpPtpPortProtocolCountersTable, 5, {1, 2, 13, 1, 5}},
+	{ PTPBASE_PORT_PROTOCOL_COUNTERS_FOREIGN_ADDED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortProtocolCountersTable, 5, {1, 2, 13, 1, 6}},
+	{ PTPBASE_PORT_PROTOCOL_COUNTERS_FOREIGN_COUNT, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortProtocolCountersTable, 5, {1, 2, 13, 1, 7}},
+	{ PTPBASE_PORT_PROTOCOL_COUNTERS_FOREIGN_REMOVED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortProtocolCountersTable, 5, {1, 2, 13, 1, 8}},
+	{ PTPBASE_PORT_PROTOCOL_COUNTERS_FOREIGN_OVERFLOWS, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortProtocolCountersTable, 5, {1, 2, 13, 1, 9}},
+	{ PTPBASE_PORT_PROTOCOL_COUNTERS_STATE_TRANSITIONS, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortProtocolCountersTable, 5, {1, 2, 13, 1, 10}},
+	{ PTPBASE_PORT_PROTOCOL_COUNTERS_BEST_MASTER_CHANGES, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortProtocolCountersTable, 5, {1, 2, 13, 1, 11}},
+	{ PTPBASE_PORT_PROTOCOL_COUNTERS_ANNOUNCE_TIMEOUTS, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortProtocolCountersTable, 5, {1, 2, 13, 1, 12}},
+	/* ptpbasePtpPortErrorCounters */
+	{ PTPBASE_PORT_ERROR_COUNTERS_CLEAR, ASN_INTEGER, HANDLER_CAN_RWRITE,
+	  snmpPtpPortErrorCountersTable, 5, {1, 2, 14, 1, 5}},
+	{ PTPBASE_PORT_ERROR_COUNTERS_MESSAGE_RECV, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortErrorCountersTable, 5, {1, 2, 14, 1, 6}},
+	{ PTPBASE_PORT_ERROR_COUNTERS_MESSAGE_SEND, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortErrorCountersTable, 5, {1, 2, 14, 1, 7}},
+	{ PTPBASE_PORT_ERROR_COUNTERS_MESSAGE_FORMAT, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortErrorCountersTable, 5, {1, 2, 14, 1, 8}},
+	{ PTPBASE_PORT_ERROR_COUNTERS_PROTOCOL, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortErrorCountersTable, 5, {1, 2, 14, 1, 9}},
+	{ PTPBASE_PORT_ERROR_COUNTERS_VERSION_MISMATCH, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortErrorCountersTable, 5, {1, 2, 14, 1, 10}},
+	{ PTPBASE_PORT_ERROR_COUNTERS_DOMAIN_MISMATCH, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortErrorCountersTable, 5, {1, 2, 14, 1, 11}},
+	{ PTPBASE_PORT_ERROR_COUNTERS_SEQUENCE_MISMATCH, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortErrorCountersTable, 5, {1, 2, 14, 1, 12}},
+	{ PTPBASE_PORT_ERROR_COUNTERS_DELAYMECH_MISMATCH, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortErrorCountersTable, 5, {1, 2, 14, 1, 13}},
+	/* ptpbasePtpPortUnicastNegotiationCounters */
+	{ PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_CLEAR, ASN_INTEGER, HANDLER_CAN_RWRITE,
+	  snmpPtpPortUnicastNegotiationCountersTable, 5, {1, 2, 15, 1, 5}},
+	{ PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_REQUESTED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortUnicastNegotiationCountersTable, 5, {1, 2, 15, 1, 6}},
+	{ PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_GRANTED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortUnicastNegotiationCountersTable, 5, {1, 2, 15, 1, 7}},
+	{ PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_DENIED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortUnicastNegotiationCountersTable, 5, {1, 2, 15, 1, 8}},
+	{ PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_CANCEL_SENT, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortUnicastNegotiationCountersTable, 5, {1, 2, 15, 1, 9}},
+	{ PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_CANCEL_RECEIVED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortUnicastNegotiationCountersTable, 5, {1, 2, 15, 1, 10}},
+	{ PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_CANCEL_ACK_SENT, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortUnicastNegotiationCountersTable, 5, {1, 2, 15, 1, 11}},
+	{ PTPBASE_PORT_UNICAST_NEGOTIATION_COUNTERS_GRANTS_CANCEL_ACK_RECEIVED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortUnicastNegotiationCountersTable, 5, {1, 2, 15, 1, 12}},
+	/* ptpbasePtpPortPerformanceCounters - no clear here */
+	{ PTPBASE_PORT_PERFORMANCE_COUNTERS_MESSAGE_SEND_RATE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortPerformanceCountersTable, 5, {1, 2, 16, 1, 5}},
+	{ PTPBASE_PORT_PERFORMANCE_COUNTERS_MESSAGE_RECEIVE_RATE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortPerformanceCountersTable, 5, {1, 2, 16, 1, 6}},
+	/* ptpbasePtpPortSecurityCounters */
+	{ PTPBASE_PORT_SECURITY_COUNTERS_CLEAR, ASN_INTEGER, HANDLER_CAN_RWRITE,
+	  snmpPtpPortSecurityCountersTable, 5, {1, 2, 17, 1, 5}},
+	{ PTPBASE_PORT_SECURITY_COUNTERS_TIMING_ACL_DISCARDED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortSecurityCountersTable, 5, {1, 2, 17, 1, 6}},
+	{ PTPBASE_PORT_SECURITY_COUNTERS_MANAGEMENT_ACL_DISCARDED, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpPortSecurityCountersTable, 5, {1, 2, 17, 1, 7}},
+	{ PTPBASE_SLAVE_OFM_STATS_CURRENT_VALUE, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveOfmStatsTable, 5, {1, 2, 18, 1, 4}},
+	{ PTPBASE_SLAVE_OFM_STATS_CURRENT_VALUE_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveOfmStatsTable, 5, {1, 2, 18, 1, 5}},
+	{ PTPBASE_SLAVE_OFM_STATS_PERIOD_SECONDS, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpSlaveOfmStatsTable, 5, {1, 2, 18, 1, 6}},
+	{ PTPBASE_SLAVE_OFM_STATS_VALID, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpSlaveOfmStatsTable, 5, {1, 2, 18, 1, 7}},
+	{ PTPBASE_SLAVE_OFM_STATS_MIN, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveOfmStatsTable, 5, {1, 2, 18, 1, 8}},
+	{ PTPBASE_SLAVE_OFM_STATS_MAX, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveOfmStatsTable, 5, {1, 2, 18, 1, 9}},
+	{ PTPBASE_SLAVE_OFM_STATS_MEAN, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveOfmStatsTable, 5, {1, 2, 18, 1, 10}},
+	{ PTPBASE_SLAVE_OFM_STATS_STDDEV, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveOfmStatsTable, 5, {1, 2, 18, 1, 11}},
+	{ PTPBASE_SLAVE_OFM_STATS_MEDIAN, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveOfmStatsTable, 5, {1, 2, 18, 1, 12}},
+	{ PTPBASE_SLAVE_OFM_STATS_MIN_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveOfmStatsTable, 5, {1, 2, 18, 1, 13}},
+	{ PTPBASE_SLAVE_OFM_STATS_MAX_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveOfmStatsTable, 5, {1, 2, 18, 1, 14}},
+	{ PTPBASE_SLAVE_OFM_STATS_MEAN_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveOfmStatsTable, 5, {1, 2, 18, 1, 15}},
+	{ PTPBASE_SLAVE_OFM_STATS_STDDEV_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveOfmStatsTable, 5, {1, 2, 18, 1, 16}},
+	{ PTPBASE_SLAVE_OFM_STATS_MEDIAN_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveOfmStatsTable, 5, {1, 2, 18, 1, 17}},
+	{ PTPBASE_SLAVE_MPD_STATS_CURRENT_VALUE, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveMpdStatsTable, 5, {1, 2, 19, 1, 4}},
+	{ PTPBASE_SLAVE_MPD_STATS_CURRENT_VALUE_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveMpdStatsTable, 5, {1, 2, 19, 1, 5}},
+	{ PTPBASE_SLAVE_MPD_STATS_PERIOD_SECONDS, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpSlaveMpdStatsTable, 5, {1, 2, 19, 1, 6}},
+	{ PTPBASE_SLAVE_MPD_STATS_VALID, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpSlaveMpdStatsTable, 5, {1, 2, 19, 1, 7}},
+	{ PTPBASE_SLAVE_MPD_STATS_MIN, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveMpdStatsTable, 5, {1, 2, 19, 1, 8}},
+	{ PTPBASE_SLAVE_MPD_STATS_MAX, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveMpdStatsTable, 5, {1, 2, 19, 1, 9}},
+	{ PTPBASE_SLAVE_MPD_STATS_MEAN, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveMpdStatsTable, 5, {1, 2, 19, 1, 10}},
+	{ PTPBASE_SLAVE_MPD_STATS_STDDEV, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveMpdStatsTable, 5, {1, 2, 19, 1, 11}},
+	{ PTPBASE_SLAVE_MPD_STATS_MEDIAN, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveMpdStatsTable, 5, {1, 2, 19, 1, 12}},
+	{ PTPBASE_SLAVE_MPD_STATS_MIN_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveMpdStatsTable, 5, {1, 2, 19, 1, 13}},
+	{ PTPBASE_SLAVE_MPD_STATS_MAX_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveMpdStatsTable, 5, {1, 2, 19, 1, 14}},
+	{ PTPBASE_SLAVE_MPD_STATS_MEAN_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveMpdStatsTable, 5, {1, 2, 19, 1, 15}},
+	{ PTPBASE_SLAVE_MPD_STATS_STDDEV_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveMpdStatsTable, 5, {1, 2, 19, 1, 16}},
+	{ PTPBASE_SLAVE_MPD_STATS_MEDIAN_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpSlaveMpdStatsTable, 5, {1, 2, 19, 1, 17}},
+	{ PTPBASE_SLAVE_FREQADJ_STATS_CURRENT_VALUE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpSlaveFreqAdjStatsTable, 5, {1, 2, 20, 1, 4}},
+	{ PTPBASE_SLAVE_FREQADJ_STATS_PERIOD_SECONDS, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpSlaveFreqAdjStatsTable, 5, {1, 2, 20, 1, 5}},
+	{ PTPBASE_SLAVE_FREQADJ_STATS_VALID, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpSlaveFreqAdjStatsTable, 5, {1, 2, 20, 1, 6}},
+	{ PTPBASE_SLAVE_FREQADJ_STATS_MIN, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpSlaveFreqAdjStatsTable, 5, {1, 2, 20, 1, 7}},
+	{ PTPBASE_SLAVE_FREQADJ_STATS_MAX, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpSlaveFreqAdjStatsTable, 5, {1, 2, 20, 1, 8}},
+	{ PTPBASE_SLAVE_FREQADJ_STATS_MEAN, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpSlaveFreqAdjStatsTable, 5, {1, 2, 20, 1, 9}},
+	{ PTPBASE_SLAVE_FREQADJ_STATS_STDDEV, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpSlaveFreqAdjStatsTable, 5, {1, 2, 20, 1, 10}},
+	{ PTPBASE_SLAVE_FREQADJ_STATS_MEDIAN, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpSlaveFreqAdjStatsTable, 5, {1, 2, 20, 1, 11}},
+	/* ptpbasePtpdSpecificCounters */
+	{ PTPBASE_PTPD_SPECIFIC_COUNTERS_CLEAR, ASN_INTEGER, HANDLER_CAN_RWRITE,
+	  snmpPtpdSpecificCountersTable, 5, {1, 2, 21, 1, 5}},
+	{ PTPBASE_PTPD_SPECIFIC_COUNTERS_IGNORED_ANNOUNCE, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpdSpecificCountersTable, 5, {1, 2, 21, 1, 6}},
+	{ PTPBASE_PTPD_SPECIFIC_COUNTERS_CONSECUTIVE_SEQUENCE_ERRORS, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpdSpecificCountersTable, 5, {1, 2, 21, 1, 7}},
+	{ PTPBASE_PTPD_SPECIFIC_COUNTERS_DELAYMS_OUTLIERS_FOUND, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpdSpecificCountersTable, 5, {1, 2, 21, 1, 8}},
+	{ PTPBASE_PTPD_SPECIFIC_COUNTERS_DELAYSM_OUTLIERS_FOUND, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpdSpecificCountersTable, 5, {1, 2, 21, 1, 9}},
+	{ PTPBASE_PTPD_SPECIFIC_COUNTERS_MAX_DELAY_DROPS, ASN_INTEGER, HANDLER_CAN_RONLY,
+	  snmpPtpdSpecificCountersTable, 5, {1, 2, 21, 1, 10}},
+	/* ptpBasePtpdSpecificData*/
+	{ PTPBASE_PTPD_SPECIFIC_DATA_RAW_DELAYMS, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpPtpdSpecificDataTable, 5, {1, 2, 22, 1, 4}},
+	{ PTPBASE_PTPD_SPECIFIC_DATA_RAW_DELAYMS_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpPtpdSpecificDataTable, 5, {1, 2, 22, 1, 5}},
+	{ PTPBASE_PTPD_SPECIFIC_DATA_RAW_DELAYSM, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpPtpdSpecificDataTable, 5, {1, 2, 22, 1, 6}},
+	{ PTPBASE_PTPD_SPECIFIC_DATA_RAW_DELAYSM_STRING, ASN_OCTET_STR, HANDLER_CAN_RONLY,
+	  snmpPtpdSpecificDataTable, 5, {1, 2, 22, 1, 7}}
+ * Log messages from NetSNMP subsystem.
+static int
+snmpLogCallback(int major, int minor,
+		void *serverarg, void *clientarg)
+	struct snmp_log_message *slm = (struct snmp_log_message *)serverarg;
+	char *msg = strdup (slm->msg);
+	if (msg) msg[strlen(msg)-1] = '\0';
+	switch (slm->priority)
+	case LOG_EMERG:   EMERGENCY("snmp[emerg]: %s\n",   msg?msg:slm->msg); break;
+	case LOG_ALERT:   ALERT    ("snmp[alert]: %s\n",   msg?msg:slm->msg); break;
+	case LOG_CRIT:    CRITICAL ("snmp[crit]: %s\n",    msg?msg:slm->msg); break;
+	case LOG_ERR:     ERROR    ("snmp[err]: %s\n",     msg?msg:slm->msg); break;
+	case LOG_WARNING: WARNING  ("snmp[warning]: %s\n", msg?msg:slm->msg); break;
+	case LOG_NOTICE:  NOTICE   ("snmp[notice]: %s\n",  msg?msg:slm->msg); break;
+	case LOG_INFO:    INFO     ("snmp[info]: %s\n",    msg?msg:slm->msg); break;
+	case LOG_DEBUG:   DBGV     ("snmp[debug]: %s\n",   msg?msg:slm->msg); break;
+	free(msg);
+static int
+getNotifIndex(int eventType) {
+	switch (eventType) {
+		case PTPBASE_NOTIFS_UNEXPECTED_PORT_STATE:
+		    return 1;
+		case PTPBASE_NOTIFS_EXPECTED_PORT_STATE:
+		    return 2;
+		case PTPBASE_NOTIFS_SLAVE_OFFSET_THRESHOLD_EXCEEDED:
+		    return 3;
+		case PTPBASE_NOTIFS_SLAVE_OFFSET_THRESHOLD_ACCEPTABLE:
+		    return 4;
+		case PTPBASE_NOTIFS_SLAVE_CLOCK_STEP:
+		    return 5;
+		case PTPBASE_NOTIFS_SLAVE_NO_SYNC:
+		    return 6;
+		case PTPBASE_NOTIFS_SLAVE_RECEIVING_SYNC:
+		    return 7;
+		case PTPBASE_NOTIFS_SLAVE_NO_DELAY:
+		    return 8;
+		case PTPBASE_NOTIFS_SLAVE_RECEIVING_DELAY:
+		    return 9;
+		case PTPBASE_NOTIFS_BEST_MASTER_CHANGE:
+		    return 10;
+		case PTPBASE_NOTIFS_NETWORK_FAULT:
+		    return 11;
+		case PTPBASE_NOTIFS_NETWORK_FAULT_CLEARED:
+		    return 12;
+		case PTPBASE_NOTIFS_FREQADJ_FAST:
+		    return 13;
+		case PTPBASE_NOTIFS_FREQADJ_NORMAL:
+		    return 14;
+		case PTPBASE_NOTIFS_OFFSET_SECONDS:
+		    return 15;
+		case PTPBASE_NOTIFS_OFFSET_SUB_SECONDS:
+		    return 16;
+		case PTPBASE_NOTIFS_TIMEPROPERTIESDS_CHANGE:
+		    return 17;
+		case PTPBASE_NOTIFS_DOMAIN_MISMATCH:
+		    return 18;
+		case PTPBASE_NOTIFS_DOMAIN_MISMATCH_CLEARED:
+		    return 19;
+		default:
+		    return 0;
+static void
+populateNotif (netsnmp_variable_list** varBinds, int eventType, PtpEventData *eventData) {
+			oid portStateOid[] = { PTPBASE_MIB_OID, 1, 2, 9, 1, 6, PTPBASE_MIB_INDEX4 };
+			snmp_varlist_add_variable(varBinds, portStateOid, OID_LENGTH(portStateOid),
+			    ASN_INTEGER, (u_char *) &eventData->portDS.portState, sizeof(eventData->portDS.portState));
+		    return;
+			struct counter64 ofmNum;
+			Integer64  tmpi64;
+			internalTime_to_integer64(eventData->currentDS.offsetFromMaster, &tmpi64);
+			ofmNum.low = htonl(tmpi64.lsb);
+			ofmNum.high = htonl(tmpi64.msb);
+			tmpsnprintf(ofmStr, 64, "%.09f", timeInternalToDouble(&eventData->currentDS.offsetFromMaster));
+			oid ofmOid[] = { PTPBASE_MIB_OID, 1, 2, 1, 1, 5, PTPBASE_MIB_INDEX3 };
+			oid ofmStringOid[] = { PTPBASE_MIB_OID, 1, 2, 1, 1, 8, PTPBASE_MIB_INDEX3 };
+			oid thresholdOid[] = { PTPBASE_MIB_OID, 1, 2, 1, 1, 9, PTPBASE_MIB_INDEX3 };
+			snmp_varlist_add_variable(varBinds, ofmOid, OID_LENGTH(ofmOid),
+			    ASN_OCTET_STR, (u_char *) &ofmNum, sizeof(ofmNum));
+			snmp_varlist_add_variable(varBinds, ofmStringOid, OID_LENGTH(ofmStringOid),
+			    ASN_OCTET_STR, (u_char *) ofmStr, strlen(ofmStr));
+			snmp_varlist_add_variable(varBinds, thresholdOid, OID_LENGTH(thresholdOid),
+			    ASN_INTEGER, (u_char *) &eventData->ofmAlarmThreshold, sizeof(snmpRtOpts->ofmAlarmThreshold));
+		    return;
+		    return;
+		    return;
+			oid portIdOid[] = { PTPBASE_MIB_OID, 1, 2, 2, 1, 4 , PTPBASE_MIB_INDEX3 };
+			oid portAddrTypeOid[] = { PTPBASE_MIB_OID, 1, 2, 2, 1, 14, PTPBASE_MIB_INDEX3 };
+			oid portAddrOid[] = { PTPBASE_MIB_OID, 1, 2, 2, 1, 15, PTPBASE_MIB_INDEX3 };
+			oid gmClockIdOid[] = { PTPBASE_MIB_OID, 1, 2, 2, 1, 8, PTPBASE_MIB_INDEX3 };
+			oid gmPriority1Oid[] = { PTPBASE_MIB_OID, 1, 2, 2, 1, 9, PTPBASE_MIB_INDEX3 };
+			oid gmPriority2Oid[] = { PTPBASE_MIB_OID, 1, 2, 2, 1, 10, PTPBASE_MIB_INDEX3 };
+			oid gmClockClassOid[] = { PTPBASE_MIB_OID, 1, 2, 2, 1, 11, PTPBASE_MIB_INDEX3 };
+			oid utcOffsetOid[] = { PTPBASE_MIB_OID, 1, 2, 5, 1 , 5, PTPBASE_MIB_INDEX3 };
+			oid utcOffsetValidOid[] = { PTPBASE_MIB_OID, 1, 2, 5, 1, 4, PTPBASE_MIB_INDEX3 };
+			unsigned long addrType = SNMP_IPv4;
+			unsigned long priority1 = eventData->parentDS.grandmasterPriority1;
+			unsigned long priority2 = eventData->parentDS.grandmasterPriority2;
+			unsigned long clockClass = eventData->parentDS.grandmasterClockQuality.clockClass;
+			unsigned long utcOffset = eventData->timePropertiesDS.currentUtcOffset;
+			unsigned long utcOffsetValid = TO_TRUTHVALUE(eventData->timePropertiesDS.currentUtcOffsetValid);
+			snmp_varlist_add_variable(varBinds, portIdOid, OID_LENGTH(portIdOid),
+			    ASN_OCTET_STR, (u_char *) &eventData->parentDS.parentPortIdentity, sizeof(PortIdentity));
+			snmp_varlist_add_variable(varBinds, portAddrTypeOid, OID_LENGTH(portAddrTypeOid),
+			    ASN_INTEGER, (u_char *) &addrType, sizeof(addrType));
+			snmp_varlist_add_variable(varBinds, portAddrOid, OID_LENGTH(portAddrOid),
+			    ASN_OCTET_STR, (u_char *) &eventData->bestMaster.sourceAddr, sizeof(eventData->bestMaster.sourceAddr));
+			snmp_varlist_add_variable(varBinds, gmClockIdOid, OID_LENGTH(gmClockIdOid),
+			    ASN_OCTET_STR, (u_char *) &eventData->parentDS.grandmasterIdentity, sizeof(ClockIdentity));
+			snmp_varlist_add_variable(varBinds, gmPriority1Oid, OID_LENGTH(gmPriority1Oid),
+			    ASN_UNSIGNED, (u_char *) &priority1, sizeof(priority1));
+			snmp_varlist_add_variable(varBinds, gmPriority2Oid, OID_LENGTH(gmPriority2Oid),
+			    ASN_UNSIGNED, (u_char *) &priority2, sizeof(priority2));
+			snmp_varlist_add_variable(varBinds, gmClockClassOid, OID_LENGTH(gmClockClassOid),
+			    ASN_UNSIGNED, (u_char *) &clockClass, sizeof(clockClass));
+			snmp_varlist_add_variable(varBinds, utcOffsetOid, OID_LENGTH(utcOffsetOid),
+			    ASN_INTEGER, (u_char *) &utcOffset, sizeof(utcOffset));
+			snmp_varlist_add_variable(varBinds, utcOffsetValidOid, OID_LENGTH(utcOffsetValidOid),
+			    ASN_INTEGER, (u_char *) &utcOffsetValid, sizeof(utcOffsetValid));
+		    return;
+		    return;
+		    return;
+			Integer64  tmpi64;
+		    return;
+			oid leap59Oid[] = { PTPBASE_MIB_OID, 1, 2, 5, 1 , 6, PTPBASE_MIB_INDEX3 };
+			oid leap61Oid[] = { PTPBASE_MIB_OID, 1, 2, 5, 1 , 7, PTPBASE_MIB_INDEX3 };
+			oid timeTraceableOid[] = { PTPBASE_MIB_OID, 1, 2, 5, 1 , 8, PTPBASE_MIB_INDEX3 };
+			oid frequencyTraceableOid[] = { PTPBASE_MIB_OID, 1, 2, 5, 1 , 9, PTPBASE_MIB_INDEX3 };
+			oid ptpTimescaleOid[] = { PTPBASE_MIB_OID, 1, 2, 5, 1 , 10, PTPBASE_MIB_INDEX3 };
+			oid timeSourceOid[] = { PTPBASE_MIB_OID, 1, 2, 5, 1 , 11, PTPBASE_MIB_INDEX3 };
+			unsigned long leap59 = TO_TRUTHVALUE(eventData->timePropertiesDS.leap61);
+			unsigned long leap61 = TO_TRUTHVALUE(eventData->timePropertiesDS.leap61);
+			unsigned long timeTraceable = TO_TRUTHVALUE(eventData->timePropertiesDS.timeTraceable);
+			unsigned long frequencyTraceable = TO_TRUTHVALUE(eventData->timePropertiesDS.frequencyTraceable);
+			unsigned long ptpTimescale = TO_TRUTHVALUE(eventData->timePropertiesDS.ptpTimescale);
+			unsigned long timeSource = eventData->timePropertiesDS.timeSource;
+			snmp_varlist_add_variable(varBinds, leap59Oid, OID_LENGTH(leap59Oid),
+			    ASN_INTEGER, (u_char *) &leap59, sizeof(leap59));
+			snmp_varlist_add_variable(varBinds, leap61Oid, OID_LENGTH(leap61Oid),
+			    ASN_INTEGER, (u_char *) &leap61, sizeof(leap61));
+			snmp_varlist_add_variable(varBinds, timeTraceableOid, OID_LENGTH(timeTraceableOid),
+			    ASN_INTEGER, (u_char *) &timeTraceable, sizeof(timeTraceable));
+			snmp_varlist_add_variable(varBinds, frequencyTraceableOid, OID_LENGTH(frequencyTraceableOid),
+			    ASN_INTEGER, (u_char *) &frequencyTraceable, sizeof(frequencyTraceable));
+			snmp_varlist_add_variable(varBinds, ptpTimescaleOid, OID_LENGTH(ptpTimescaleOid),
+			    ASN_INTEGER, (u_char *) &ptpTimescale, sizeof(ptpTimescale));
+			snmp_varlist_add_variable(varBinds, timeSourceOid, OID_LENGTH(timeSourceOid),
+			    ASN_INTEGER, (u_char *) &timeSource, sizeof(timeSource));
+		    return;
+			oid domainNumberOid[] = { PTPBASE_MIB_OID, 1, 2, 3, 1, 12, PTPBASE_MIB_INDEX3 };
+			oid lastMismatchedDomainOid[] = { PTPBASE_MIB_OID, 1, 2, 8, 1, 17, PTPBASE_MIB_INDEX4 };
+			unsigned long domainNumber = eventData->defaultDS.domainNumber;
+			unsigned long lastMismatchedDomain = eventData->portDS.lastMismatchedDomain;
+			snmp_varlist_add_variable(varBinds, domainNumberOid, OID_LENGTH(domainNumberOid),
+			    ASN_INTEGER, (u_char *) &domainNumber, sizeof(domainNumber));
+			snmp_varlist_add_variable(varBinds, lastMismatchedDomainOid, OID_LENGTH(lastMismatchedDomainOid),
+			    ASN_INTEGER, (u_char *) &lastMismatchedDomain, sizeof(lastMismatchedDomain));
+		    return;
+		    return;
+		default:
+		    return;
+static void
+sendNotif(int eventType, PtpEventData *eventData) {
+    /* snmpTrapOID.0 */
+    oid trapOid[] = { 1, 3, 6, 1, 6, 3, 1, 1, 4, 1, 0 };
+    netsnmp_variable_list *varBinds = NULL;
+    int notifIndex = getNotifIndex(eventType);
+    if(!notifIndex) {
+	DBG("SNMP trap request for unknown event type: %d\n", eventType);
+	return;
+    /* the notification  oid*/
+    oid notifOid[] = { PTPBASE_MIB_OID, 0, (oid)notifIndex };
+    /* add notification oid */
+    snmp_varlist_add_variable(&varBinds, trapOid, OID_LENGTH(trapOid),
+		ASN_OBJECT_ID, (u_char *) notifOid, OID_LENGTH(notifOid) * sizeof(oid));
+    /* add the accompanying varbinds */
+    populateNotif(&varBinds, eventType, eventData);
+    send_v2trap(varBinds);
+    snmp_free_varbind(varBinds);
+ * Initialisation of SNMP subsystem.
+void
+snmpInit(RunTimeOpts *rtOpts, PtpClock *ptpClock) {
+	netsnmp_enable_subagent();
+	snmp_disable_log();
+	snmp_enable_calllog();
+	snmp_register_callback(SNMP_CALLBACK_LIBRARY,
+			       SNMP_CALLBACK_LOGGING,
+			       snmpLogCallback,
+			       NULL);
+	init_agent("ptpAgent");
+	REGISTER_MIB("ptpMib", snmpVariables, variable7, ptp_oid);
+	init_snmp("ptpAgent");
+	/* Currently, ptpd only handles one clock. We put it in a
+	 * global variable for the need of our subsystem. */
+	snmpPtpClock = ptpClock;
+	snmpRtOpts = rtOpts;
+ * Clean up and shut down the SNMP subagent
+void
+snmpShutdown() {
+	unregister_mib(ptp_oid, sizeof(ptp_oid) / sizeof(oid));
+	snmp_shutdown("ptpMib");
+	SOCK_CLEANUP;
+void
+alarmHandler_snmp(AlarmEntry *alarm)
+	int notifId = -1;
+	if(alarm->state == ALARM_SET) {
+	    DBG("[snmp] Alarm %s set trap processed\n", alarm->name);
+	    switch(alarm->id) {
+		case ALRM_PORT_STATE:
+		    notifId = PTPBASE_NOTIFS_UNEXPECTED_PORT_STATE;
+		    break;
+		case ALRM_OFM_THRESHOLD:
+		    notifId = PTPBASE_NOTIFS_SLAVE_OFFSET_THRESHOLD_EXCEEDED;
+		    break;
+		case ALRM_OFM_SECONDS:
+		    notifId = PTPBASE_NOTIFS_OFFSET_SECONDS;
+		    break;
+		case ALRM_NO_SYNC:
+		    notifId = PTPBASE_NOTIFS_SLAVE_NO_SYNC;
+		    break;
+		case ALRM_NO_DELAY:
+		    notifId = PTPBASE_NOTIFS_SLAVE_NO_DELAY;
+		    break;
+		case ALRM_NETWORK_FLT:
+		    notifId = PTPBASE_NOTIFS_NETWORK_FAULT;
+		    break;
+		case ALRM_FAST_ADJ:
+		    notifId = PTPBASE_NOTIFS_FREQADJ_FAST;
+		    break;
+		case ALRM_DOMAIN_MISMATCH:
+		    notifId = PTPBASE_NOTIFS_DOMAIN_MISMATCH;
+		    break;
+	if(alarm->state == ALARM_UNSET) {
+	    DBG("[snmp] Alarm %s clear trap processed\n", alarm->name);
+		    notifId = PTPBASE_NOTIFS_EXPECTED_PORT_STATE;
+		    break;
+		    notifId = PTPBASE_NOTIFS_SLAVE_OFFSET_THRESHOLD_ACCEPTABLE;
+		    break;
+		    notifId = PTPBASE_NOTIFS_OFFSET_SUB_SECONDS;
+		    break;
+		    notifId = PTPBASE_NOTIFS_SLAVE_RECEIVING_SYNC;
+		    break;
+		    notifId = PTPBASE_NOTIFS_SLAVE_RECEIVING_DELAY;
+		    break;
+		    notifId = PTPBASE_NOTIFS_NETWORK_FAULT_CLEARED;
+		    break;
+		    notifId = PTPBASE_NOTIFS_FREQADJ_NORMAL;
+		    break;
+		    notifId = PTPBASE_NOTIFS_DOMAIN_MISMATCH_CLEARED;
+		    break;
+	if(alarm->eventOnly) {
+	    DBG("[snmp] Event %s notification processed\n", alarm->name);
+		case ALRM_CLOCK_STEP:
+		    notifId = PTPBASE_NOTIFS_SLAVE_CLOCK_STEP;
+		    break;
+		case ALRM_MASTER_CHANGE:
+		    notifId = PTPBASE_NOTIFS_BEST_MASTER_CHANGE;
+		    break;
+		case ALRM_TIMEPROP_CHANGE:
+		    notifId = PTPBASE_NOTIFS_TIMEPROPERTIESDS_CHANGE;
+		    break;
+		default:
+		    break;
+	if(notifId >= 0) {
+	    sendNotif(notifId, &alarm->eventData);
+	    return;
+	DBG("Unhandled SNMP event id 0x%x\n", alarm->id);
diff --git a/freebsd/contrib/ptpd/src/dep/startup.c b/freebsd/contrib/ptpd/src/dep/startup.c
new file mode 100644
index 00000000..a9011736
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/startup.c
@@ -0,0 +1,1020 @@
+ * Copyright (c) 2014-2015 Wojciech Owczarek,
+ * Copyright (c) 2012-2013 George V. Neville-Neil,
+ *                         Wojciech Owczarek
+ * Copyright (c) 2011-2012 George V. Neville-Neil,
+ *                         Steven Kreuzer,
+ *                         Martin Burnicki,
+ *                         Jan Breuer,
+ *                         Gael Mace,
+ *                         Alexandre Van Kempen,
+ *                         Inaqui Delgado,
+ *                         Rick Ratzel,
+ *                         National Instruments.
+ * Copyright (c) 2009-2010 George V. Neville-Neil,
+ *                         Steven Kreuzer,
+ *                         Jan Breuer,
+ *                         Gael Mace,
+ * Copyright (c) 2005-2008 Kendall Correll, Aidan Williams
+ * All Rights Reserved
+ * modification, are permitted provided that the following conditions are
+ * met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ *    this list of conditions and the following disclaimer.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE AUTHORS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
+ * BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
+ * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
+ * IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * @file   startup.c
+ * @date   Wed Jun 23 09:33:27 2010
+ * @brief  Code to handle daemon startup, including command line args
+ * The function in this file are called when the daemon starts up
+ * and include the getopt() command line argument parsing.
+#include "../ptpd.h"
+ * valgrind 3.5.0 currently reports no errors (last check: 20110512)
+ * valgrind 3.4.1 lacks an adjtimex handler
+ * to run:   sudo valgrind --show-reachable=yes --leak-check=full --track-origins=yes -- ./ptpd2 -c ...
+  to test daemon locking and startup sequence itself, try:
+  function s()  { set -o pipefail ;  eval "$@" |  sed 's/^/\t/' ; echo $?;  }
+  sudo killall ptpd2
+  s ./ptpd2
+  s sudo ./ptpd2
+  s sudo ./ptpd2 -t -g
+  s sudo ./ptpd2 -t -g -b eth0
+  ps -ef | grep ptpd2
+ * Synchronous signal processing:
+ * original idea: http://www.openbsd.org/cgi-bin/cvsweb/src/usr.sbin/ntpd/ntpd.c?rev=1.68;content-type=text%2Fplain
+volatile sig_atomic_t	 sigint_received  = 0;
+volatile sig_atomic_t	 sigterm_received = 0;
+volatile sig_atomic_t	 sighup_received  = 0;
+volatile sig_atomic_t	 sigusr1_received = 0;
+volatile sig_atomic_t	 sigusr2_received = 0;
+/* Pointer to the current lock file */
+FILE* G_lockFilePointer;
+ * Function to catch signals asynchronously.
+ * Assuming that the daemon periodically calls checkSignals(), then all operations are safely done synchrously at a later opportunity.
+ * Please do NOT call any functions inside this handler - especially DBG() and its friends, or any glibc.
+void catchSignals(int sig)
+	switch (sig) {
+	case SIGINT:
+		sigint_received = 1;
+		break;
+	case SIGTERM:
+		sigterm_received = 1;
+		break;
+	case SIGHUP:
+		sighup_received = 1;
+		break;
+	case SIGUSR1:
+		sigusr1_received = 1;
+		break;
+	case SIGUSR2:
+		sigusr2_received = 1;
+		break;
+	default:
+		 * TODO: should all other signals be catched, and handled as SIGINT?
+		 * Reason: currently, all other signals are just uncatched, and the OS kills us.
+		 * The difference is that we could then close the open files properly.
+		break;
+ * exit the program cleanly
+void
+do_signal_close(PtpClock * ptpClock)
+	timingDomain.shutdown(&timingDomain);
+	NOTIFY("Shutdown on close signal\n");
+	exit(0);
+void
+applyConfig(dictionary *baseConfig, RunTimeOpts *rtOpts, PtpClock *ptpClock)
+	Boolean reloadSuccessful = TRUE;
+	/* Load default config to fill in the blanks in the config file */
+	RunTimeOpts tmpOpts;
+	loadDefaultSettings(&tmpOpts);
+	/* Check the new configuration for errors, fill in the blanks from defaults */
+	if( ( rtOpts->candidateConfig = parseConfig(CFGOP_PARSE, NULL, baseConfig, &tmpOpts)) == NULL ) {
+	    WARNING("Configuration has errors, reload aborted\n");
+	    return;
+	/* Check for changes between old and new configuration */
+	if(compareConfig(rtOpts->candidateConfig,rtOpts->currentConfig)) {
+	    INFO("Configuration unchanged\n");
+	    goto cleanup;
+	 * Mark which subsystems have to be restarted. Most of this will be picked up by doState()
+	 * If there are errors past config correctness (such as non-existent NIC,
+	 * or lock file clashes if automatic lock files used - abort the mission
+	rtOpts->restartSubsystems =
+	    checkSubsystemRestart(rtOpts->candidateConfig, rtOpts->currentConfig, rtOpts);
+	/* If we're told to re-check lock files, do it: tmpOpts already has what rtOpts should */
+	if( (rtOpts->restartSubsystems & PTPD_CHECK_LOCKS) &&
+	    tmpOpts.autoLockFile && !checkOtherLocks(&tmpOpts)) {
+		reloadSuccessful = FALSE;
+	/* If the network configuration has changed, check if the interface is OK */
+	if(rtOpts->restartSubsystems & PTPD_RESTART_NETWORK) {
+		INFO("Network configuration changed - checking interface(s)\n");
+		if(!testInterface(tmpOpts.primaryIfaceName, &tmpOpts)) {
+		    ERROR("Error: Cannot use %s interface\n",tmpOpts.primaryIfaceName);
+		if(rtOpts->backupIfaceEnabled && !testInterface(tmpOpts.backupIfaceName, &tmpOpts)) {
+		    rtOpts->restartSubsystems = -1;
+		    ERROR("Error: Cannot use %s interface as backup\n",tmpOpts.backupIfaceName);
+#if (defined(linux) && defined(HAVE_SCHED_H)) || defined(HAVE_SYS_CPUSET_H) || defined(__QNXNTO__)
+        /* Changing the CPU affinity mask */
+        if(rtOpts->restartSubsystems & PTPD_CHANGE_CPUAFFINITY) {
+                NOTIFY("Applying CPU binding configuration: changing selected CPU core\n");
+                if(setCpuAffinity(tmpOpts.cpuNumber) < 0) {
+                        if(tmpOpts.cpuNumber == -1) {
+                                ERROR("Could not unbind from CPU core %d\n", rtOpts->cpuNumber);
+                        } else {
+                                ERROR("Could bind to CPU core %d\n", tmpOpts.cpuNumber);
+                } else {
+                        if(tmpOpts.cpuNumber > -1)
+                                INFO("Successfully bound "PTPD_PROGNAME" to CPU core %d\n", tmpOpts.cpuNumber);
+                        else
+                                INFO("Successfully unbound "PTPD_PROGNAME" from cpu core CPU core %d\n", rtOpts->cpuNumber);
+#endif
+	if(!reloadSuccessful) {
+		ERROR("New configuration cannot be applied - aborting reload\n");
+		rtOpts->restartSubsystems = 0;
+		goto cleanup;
+		 * Commit changes to rtOpts and currentConfig
+		 * (this should never fail as the config has already been checked if we're here)
+		 * However if this DOES fail, some default has been specified out of range -
+		 * this is the only situation where parse will succeed but commit not:
+		 * disable quiet mode to show what went wrong, then die.
+		if (rtOpts->currentConfig) {
+			dictionary_del(&rtOpts->currentConfig);
+		if ( (rtOpts->currentConfig = parseConfig(CFGOP_PARSE_QUIET, NULL, rtOpts->candidateConfig,rtOpts)) == NULL) {
+			CRITICAL("************ "PTPD_PROGNAME": parseConfig returned NULL during config commit"
+				 "  - this is a BUG - report the following: \n");
+			if ((rtOpts->currentConfig = parseConfig(CFGOP_PARSE, NULL, rtOpts->candidateConfig,rtOpts)) == NULL)
+			    CRITICAL("*****************" PTPD_PROGNAME" shutting down **********************\n");
+			 * Could be assert(), but this should be done any time this happens regardless of
+			 * compile options. Anyhow, if we're here, the daemon will no doubt segfault soon anyway
+			abort();
+	/* clean up */
+	cleanup:
+		dictionary_del(&rtOpts->candidateConfig);
+ * Signal handler for HUP which tells us to swap the log file
+ * and reload configuration file if specified
+ * @param sig
+void
+do_signal_sighup(RunTimeOpts * rtOpts, PtpClock * ptpClock)
+	NOTIFY("SIGHUP received\n");
+#ifdef RUNTIME_DEBUG
+	if(rtOpts->transport == UDP_IPV4 && rtOpts->ipMode != IPMODE_UNICAST) {
+		DBG("SIGHUP - running an ipv4 multicast based mode, re-sending IGMP joins\n");
+		netRefreshIGMP(&ptpClock->netPath, rtOpts, ptpClock);
+#endif /* RUNTIME_DEBUG */
+	/* if we don't have a config file specified, we're done - just reopen log files*/
+	if(strlen(rtOpts->configFile) !=  0) {
+	    dictionary* tmpConfig = dictionary_new(0);
+	    /* Try reloading the config file */
+	    NOTIFY("Reloading configuration file: %s\n",rtOpts->configFile);
+            if(!loadConfigFile(&tmpConfig, rtOpts)) {
+		    dictionary_del(&tmpConfig);
+	    } else {
+		    dictionary_merge(rtOpts->cliConfig, tmpConfig, 1, 1, "from command line");
+		    applyConfig(tmpConfig, rtOpts, ptpClock);
+	/* tell the service it can perform any HUP-triggered actions */
+	ptpClock->timingService.reloadRequested = TRUE;
+	if(rtOpts->recordLog.logEnabled ||
+	    rtOpts->eventLog.logEnabled ||
+	    (rtOpts->statisticsLog.logEnabled))
+		INFO("Reopening log files\n");
+	restartLogging(rtOpts);
+	if(rtOpts->statisticsLog.logEnabled)
+		ptpClock->resetStatisticsLog = TRUE;
+void
+restartSubsystems(RunTimeOpts *rtOpts, PtpClock *ptpClock)
+			DBG("RestartSubsystems: %d\n",rtOpts->restartSubsystems);
+		    /* So far, PTP_INITIALIZING is required for both network and protocol restart */
+		    if((rtOpts->restartSubsystems & PTPD_RESTART_PROTOCOL) ||
+			(rtOpts->restartSubsystems & PTPD_RESTART_NETWORK)) {
+				NOTIFY("Applying network configuration: going into PTP_INITIALIZING\n");
+			    /* These parameters have to be passed to ptpClock before re-init */
+			    ptpClock->defaultDS.clockQuality.clockClass = rtOpts->clockQuality.clockClass;
+			    ptpClock->defaultDS.slaveOnly = rtOpts->slaveOnly;
+			    ptpClock->disabled = rtOpts->portDisabled;
+			    if(rtOpts->restartSubsystems & PTPD_RESTART_PROTOCOL) {
+				INFO("Applying protocol configuration: going into %s\n",
+				ptpClock->disabled ? "PTP_DISABLED" : "PTP_INITIALIZING");
+			    /* Move back to primary interface only during configuration changes. */
+			    ptpClock->runningBackupInterface = FALSE;
+			    toState(ptpClock->disabled ? PTP_DISABLED : PTP_INITIALIZING, rtOpts, ptpClock);
+		    } else {
+		    /* Nothing happens here for now - SIGHUP handler does this anyway */
+		    if(rtOpts->restartSubsystems & PTPD_UPDATE_DATASETS) {
+				NOTIFY("Applying PTP engine configuration: updating datasets\n");
+				updateDatasets(ptpClock, rtOpts);
+		    if(rtOpts->restartSubsystems & PTPD_RESTART_LOGGING) {
+				NOTIFY("Applying logging configuration: restarting logging\n");
+    		if(rtOpts->restartSubsystems & PTPD_RESTART_ACLS) {
+            		NOTIFY("Applying access control list configuration\n");
+            		/* re-compile ACLs */
+            		freeIpv4AccessList(&ptpClock->netPath.timingAcl);
+            		freeIpv4AccessList(&ptpClock->netPath.managementAcl);
+            		if(rtOpts->timingAclEnabled) {
+                    	    ptpClock->netPath.timingAcl=createIpv4AccessList(rtOpts->timingAclPermitText,
+                                rtOpts->timingAclDenyText, rtOpts->timingAclOrder);
+            		if(rtOpts->managementAclEnabled) {
+                    	    ptpClock->netPath.managementAcl=createIpv4AccessList(rtOpts->managementAclPermitText,
+                                rtOpts->managementAclDenyText, rtOpts->managementAclOrder);
+    		if(rtOpts->restartSubsystems & PTPD_RESTART_ALARMS) {
+		    NOTIFY("Applying alarm configuration\n");
+		    configureAlarms(ptpClock->alarms, ALRM_MAX, (void*)ptpClock);
+                    /* Reinitialising the outlier filter containers */
+                    if(rtOpts->restartSubsystems & PTPD_RESTART_FILTERS) {
+                                NOTIFY("Applying filter configuration: re-initialising filters\n");
+				freeDoubleMovingStatFilter(&ptpClock->filterMS);
+				freeDoubleMovingStatFilter(&ptpClock->filterSM);
+				ptpClock->oFilterMS.shutdown(&ptpClock->oFilterMS);
+				ptpClock->oFilterSM.shutdown(&ptpClock->oFilterSM);
+				outlierFilterSetup(&ptpClock->oFilterMS);
+				outlierFilterSetup(&ptpClock->oFilterSM);
+				ptpClock->oFilterMS.init(&ptpClock->oFilterMS,&rtOpts->oFilterMSConfig, "delayMS");
+				ptpClock->oFilterSM.init(&ptpClock->oFilterSM,&rtOpts->oFilterSMConfig, "delaySM");
+				if(rtOpts->filterMSOpts.enabled) {
+					ptpClock->filterMS = createDoubleMovingStatFilter(&rtOpts->filterMSOpts,"delayMS");
+				if(rtOpts->filterSMOpts.enabled) {
+					ptpClock->filterSM = createDoubleMovingStatFilter(&rtOpts->filterSMOpts, "delaySM");
+#endif /* PTPD_STATISTICS */
+            if(rtOpts->restartSubsystems & PTPD_RESTART_NTPENGINE && timingDomain.serviceCount > 1) {
+		ptpClock->ntpControl.timingService.shutdown(&ptpClock->ntpControl.timingService);
+	    if((rtOpts->restartSubsystems & PTPD_RESTART_NTPENGINE) ||
+        	(rtOpts->restartSubsystems & PTPD_RESTART_NTPCONFIG)) {
+        	ntpSetup(rtOpts, ptpClock);
+		if((rtOpts->restartSubsystems & PTPD_RESTART_NTPENGINE) && rtOpts->ntpOptions.enableEngine) {
+		    timingServiceSetup(&ptpClock->ntpControl.timingService);
+		    ptpClock->ntpControl.timingService.init(&ptpClock->ntpControl.timingService);
+		ptpClock->timingService.dataSet.priority1 = rtOpts->preferNTP;
+		timingDomain.electionDelay = rtOpts->electionDelay;
+		if(timingDomain.electionLeft > timingDomain.electionDelay) {
+			timingDomain.electionLeft = timingDomain.electionDelay;
+		timingDomain.services[0]->holdTime = rtOpts->ntpOptions.failoverTimeout;
+		if(timingDomain.services[0]->holdTimeLeft >
+			timingDomain.services[0]->holdTime) {
+			timingDomain.services[0]->holdTimeLeft =
+			rtOpts->ntpOptions.failoverTimeout;
+		ptpClock->timingService.timeout = rtOpts->idleTimeout;
+		    /* Update PI servo parameters */
+		    setupPIservo(&ptpClock->servo, rtOpts);
+		    /* Config changes don't require subsystem restarts - acknowledge it */
+		    if(rtOpts->restartSubsystems == PTPD_RESTART_NONE) {
+				NOTIFY("Applying configuration\n");
+		    if(rtOpts->restartSubsystems != -1)
+ * This function should be called regularly from the main loop
+void
+checkSignals(RunTimeOpts * rtOpts, PtpClock * ptpClock)
+	 * note:
+	 * alarm signals are handled in a similar way in dep/timer.c
+	if(sigint_received || sigterm_received){
+		do_signal_close(ptpClock);
+	if(sighup_received){
+		do_signal_sighup(rtOpts, ptpClock);
+	sighup_received=0;
+	if(sigusr1_received){
+	    if(ptpClock->portDS.portState == PTP_SLAVE){
+		    WARNING("SIGUSR1 received, stepping clock to current known OFM\n");
+                    stepClock(rtOpts, ptpClock);
+//		    ptpClock->clockControl.stepRequired = TRUE;
+	    } else {
+		    ERROR("SIGUSR1 received - will not step clock, not in PTP_SLAVE state\n");
+	sigusr1_received = 0;
+	if(sigusr2_received){
+/* testing only: testing step detection */
+#if 0
+		ptpClock->addOffset ^= 1;
+		INFO("a: %d\n", ptpClock->addOffset);
+		sigusr2_received = 0;
+		return;
+#endif
+		displayCounters(ptpClock);
+		displayAlarms(ptpClock->alarms, ALRM_MAX);
+			INFO("\n\n");
+			INFO("** Timing message ACL:\n");
+			dumpIpv4AccessList(ptpClock->netPath.timingAcl);
+			INFO("\n\n");
+			INFO("** Management message ACL:\n");
+			dumpIpv4AccessList(ptpClock->netPath.managementAcl);
+		if(rtOpts->clearCounters) {
+			clearCounters(ptpClock);
+			NOTIFY("PTP engine counters cleared\n");
+#ifdef PTPD_STATISTICS
+		if(rtOpts->oFilterSMConfig.enabled) {
+			ptpClock->oFilterSM.display(&ptpClock->oFilterSM);
+		if(rtOpts->oFilterMSConfig.enabled) {
+			ptpClock->oFilterMS.display(&ptpClock->oFilterMS);
+/* These functions are useful to temporarily enable Debug around parts of code, similar to bash's "set -x" */
+void enable_runtime_debug(void )
+	extern RunTimeOpts rtOpts;
+	rtOpts.debug_level = max(LOG_DEBUGV, rtOpts.debug_level);
+void disable_runtime_debug(void )
+	rtOpts.debug_level = LOG_INFO;
+#endif
+int
+writeLockFile(RunTimeOpts * rtOpts)
+	int lockPid = 0;
+	DBGV("Checking lock file: %s\n", rtOpts->lockFile);
+	if ( (G_lockFilePointer=fopen(rtOpts->lockFile, "w+")) == NULL) {
+		PERROR("Could not open lock file %s for writing", rtOpts->lockFile);
+		return(0);
+	if (lockFile(fileno(G_lockFilePointer)) < 0) {
+		if ( checkLockStatus(fileno(G_lockFilePointer),
+			DEFAULT_LOCKMODE, &lockPid) == 0) {
+			     ERROR("Another "PTPD_PROGNAME" instance is running: %s locked by PID %d\n",
+				    rtOpts->lockFile, lockPid);
+		} else {
+			PERROR("Could not acquire lock on %s:", rtOpts->lockFile);
+		goto failure;
+	if(ftruncate(fileno(G_lockFilePointer), 0) == -1) {
+		PERROR("Could not truncate %s: %s",
+			rtOpts->lockFile, strerror(errno));
+		goto failure;
+	if ( fprintf(G_lockFilePointer, "%ld\n", (long)getpid()) == -1) {
+		PERROR("Could not write to lock file %s: %s",
+		goto failure;
+	INFO("Successfully acquired lock on %s\n", rtOpts->lockFile);
+	fflush(G_lockFilePointer);
+	return(1);
+	failure:
+	fclose(G_lockFilePointer);
+	return(0);
+void
+ptpdShutdown(PtpClock * ptpClock)
+         * go into DISABLED state so the FSM can call any PTP-specific shutdown actions,
+	 * such as canceling unicast transmission
+	toState(PTP_DISABLED, &rtOpts, ptpClock);
+	/* process any outstanding events before exit */
+	updateAlarms(ptpClock->alarms, ALRM_MAX);
+	netShutdown(&ptpClock->netPath);
+	free(ptpClock->foreign);
+	/* free management and signaling messages, they can have dynamic memory allocated */
+	if(ptpClock->msgTmpHeader.messageType == MANAGEMENT)
+		freeManagementTLV(&ptpClock->msgTmp.manage);
+	freeManagementTLV(&ptpClock->outgoingManageTmp);
+	if(ptpClock->msgTmpHeader.messageType == SIGNALING)
+		freeSignalingTLV(&ptpClock->msgTmp.signaling);
+	freeSignalingTLV(&ptpClock->outgoingSignalingTmp);
+#ifdef PTPD_SNMP
+	snmpShutdown();
+#endif /* PTPD_SNMP */
+#ifndef PTPD_STATISTICS
+	/* Not running statistics code - write observed drift to driftfile if enabled, inform user */
+	if(ptpClock->defaultDS.slaveOnly && !ptpClock->servo.runningMaxOutput)
+		saveDrift(ptpClock, &rtOpts, FALSE);
+#else
+	/* We are running statistics code - save drift on exit only if we're not monitoring servo stability */
+	if(!rtOpts.servoStabilityDetection && !ptpClock->servo.runningMaxOutput)
+	if (rtOpts.currentConfig != NULL)
+		dictionary_del(&rtOpts.currentConfig);
+	if(rtOpts.cliConfig != NULL)
+		dictionary_del(&rtOpts.cliConfig);
+	timerShutdown(ptpClock->timers);
+	free(ptpClock);
+	ptpClock = NULL;
+	extern PtpClock* G_ptpClock;
+	G_ptpClock = NULL;
+	/* properly clean lockfile (eventough new deaemons can acquire the lock after we die) */
+	if(!rtOpts.ignore_daemon_lock && G_lockFilePointer != NULL) {
+	    G_lockFilePointer = NULL;
+	unlink(rtOpts.lockFile);
+	if(rtOpts.statusLog.logEnabled) {
+		/* close and remove the status file */
+		if(rtOpts.statusLog.logFP != NULL) {
+			fclose(rtOpts.statusLog.logFP);
+			rtOpts.statusLog.logFP = NULL;
+		unlink(rtOpts.statusLog.logPath);
+	stopLogging(&rtOpts);
+void dump_command_line_parameters(int argc, char **argv)
+	int i = 0;
+	char sbuf[1000];
+	char *st = sbuf;
+	int len = 0;
+	*st = '\0';
+	for(i=0; i < argc; i++){
+		if(strcmp(argv[i],"") == 0)
+		    continue;
+		len += snprintf(sbuf + len,
+					     sizeof(sbuf) - len,
+					     "%s ", argv[i]);
+	INFO("Starting %s daemon with parameters:      %s\n", PTPD_PROGNAME, sbuf);
+PtpClock *
+ptpdStartup(int argc, char **argv, Integer16 * ret, RunTimeOpts * rtOpts)
+	PtpClock * ptpClock;
+	TimeInternal tmpTime;
+	int i = 0;
+	 * Set the default mode for all newly created files - previously
+	 * this was not the case for log files. This adds consistency
+	 * and allows to use FILE* vs. fds everywhere
+	umask(~DEFAULT_FILE_PERMS);
+	/* get some entropy in... */
+	getTime(&tmpTime);
+	srand(tmpTime.seconds ^ tmpTime.nanoseconds);
+	 * If a required setting, such as interface name, or a setting
+	 * requiring a range check is to be set via getopts_long,
+	 * the respective currentConfig dictionary entry should be set,
+	 * instead of just setting the rtOpts field.
+	 * Config parameter evaluation priority order:
+	 * 	1. Any dictionary keys set in the getopt_long loop
+	 * 	2. CLI long section:key type options
+	 * 	3. Any built-in config templates
+	 *	4. Any templates loaded from template file
+	 * 	5. Config file (parsed last), merged with 2. and 3 - will be overwritten by CLI options
+	 * 	6. Defaults and any rtOpts fields set in the getopt_long loop
+	 * Load defaults. Any options set here and further inside loadCommandLineOptions()
+	 * by setting rtOpts fields, will be considered the defaults
+	 * for config file and section:key long options.
+	loadDefaultSettings(rtOpts);
+	/* initialise the config dictionary */
+	rtOpts->candidateConfig = dictionary_new(0);
+	rtOpts->cliConfig = dictionary_new(0);
+	/* parse all long section:key options and clean up argv for getopt */
+	loadCommandLineKeys(rtOpts->cliConfig,argc,argv);
+	/* parse the normal short and long options, exit on error */
+	if (!loadCommandLineOptions(rtOpts, rtOpts->cliConfig, argc, argv, ret)) {
+	    goto fail;
+	/* Display startup info and argv if not called with -? or -H */
+		NOTIFY("%s version %s starting\n",USER_DESCRIPTION, USER_VERSION);
+		dump_command_line_parameters(argc, argv);
+	 * we try to catch as many error conditions as possible, but before we call daemon().
+	 * the exception is the lock file, as we get a new pid when we call daemon(),
+	 * so this is checked twice: once to read, second to read/write
+	if(geteuid() != 0)
+		printf("Error: "PTPD_PROGNAME" daemon can only be run as root\n");
+			*ret = 1;
+			goto fail;
+	/* Have we got a config file? */
+	if(strlen(rtOpts->configFile) > 0) {
+		/* config file settings overwrite all others, except for empty strings */
+		INFO("Loading configuration file: %s\n",rtOpts->configFile);
+		if(loadConfigFile(&rtOpts->candidateConfig, rtOpts)) {
+			dictionary_merge(rtOpts->cliConfig, rtOpts->candidateConfig, 1, 1, "from command line");
+		} else {
+		    *ret = 1;
+		    goto configcheck;
+	} else {
+	 * This is where the final checking  of the candidate settings container happens.
+	 * A dictionary is returned with only the known options, explicitly set to defaults
+	 * if not present. NULL is returned on any config error - parameters missing, out of range,
+	 * etc. The getopt loop in loadCommandLineOptions() only sets keys verified here.
+	if( ( rtOpts->currentConfig = parseConfig(CFGOP_PARSE, NULL, rtOpts->candidateConfig,rtOpts)) == NULL ) {
+	    *ret = 1;
+	    goto configcheck;
+	/* we've been told to print the lock file and exit cleanly */
+	if(rtOpts->printLockFile) {
+	    printf("%s\n", rtOpts->lockFile);
+	    *ret = 0;
+	    goto fail;
+	/* we don't need the candidate config any more */
+	/* Check network before going into background */
+	if(!testInterface(rtOpts->primaryIfaceName, rtOpts)) {
+	    ERROR("Error: Cannot use %s interface\n",rtOpts->primaryIfaceName);
+	    *ret = 1;
+	    goto configcheck;
+	if(rtOpts->backupIfaceEnabled && !testInterface(rtOpts->backupIfaceName, rtOpts)) {
+	    ERROR("Error: Cannot use %s interface as backup\n",rtOpts->backupIfaceName);
+	    *ret = 1;
+	    goto configcheck;
+configcheck:
+	 * We've been told to check config only - clean exit before checking locks
+	if(rtOpts->checkConfigOnly) {
+	    if(*ret != 0) {
+		printf("Configuration has errors\n");
+		*ret = 1;
+	    else
+		printf("Configuration OK\n");
+	    goto fail;
+	/* Previous errors - exit */
+	if(*ret !=0)
+		goto fail;
+	/* First lock check, just to be user-friendly to the operator */
+	if(!rtOpts->ignore_daemon_lock) {
+		if(!writeLockFile(rtOpts)){
+			/* check and create Lock */
+			ERROR("Error: file lock failed (use -L or global:ignore_lock to ignore lock file)\n");
+			*ret = 3;
+			goto fail;
+		/* check for potential conflicts when automatic lock files are used */
+		if(!checkOtherLocks(rtOpts)) {
+			*ret = 3;
+			goto fail;
+	/* Manage log files: stats, log, status and quality file */
+	/* Allocate memory after we're done with other checks but before going into daemon */
+	ptpClock = (PtpClock *) calloc(1, sizeof(PtpClock));
+	if (!ptpClock) {
+		PERROR("Error: Failed to allocate memory for protocol engine data");
+		*ret = 2;
+		goto fail;
+	} else {
+		DBG("allocated %d bytes for protocol engine data\n",
+		    (int)sizeof(PtpClock));
+		ptpClock->foreign = (ForeignMasterRecord *)
+			calloc(rtOpts->max_foreign_records,
+			       sizeof(ForeignMasterRecord));
+		if (!ptpClock->foreign) {
+			PERROR("failed to allocate memory for foreign "
+			       "master data");
+			*ret = 2;
+			free(ptpClock);
+			goto fail;
+		} else {
+			DBG("allocated %d bytes for foreign master data\n",
+			    (int)(rtOpts->max_foreign_records *
+				  sizeof(ForeignMasterRecord)));
+	/* Init to 0 net buffer */
+	memset(ptpClock->msgIbuf, 0, PACKET_SIZE);
+	memset(ptpClock->msgObuf, 0, PACKET_SIZE);
+	/* Init outgoing management message */
+	ptpClock->outgoingManageTmp.tlv = NULL;
+	/*  DAEMON */
+#ifdef PTPD_NO_DAEMON
+	if(!rtOpts->nonDaemon){
+		rtOpts->nonDaemon=TRUE;
+#endif
+		 * fork to daemon - nochdir non-zero to preserve the working directory:
+		 * allows relative paths to be used for log files, config files etc.
+		 * Always redirect stdout/err to /dev/null
+		if (daemon(1,0) == -1) {
+			PERROR("Failed to start as daemon");
+			*ret = 3;
+			goto fail;
+		INFO("  Info:    Now running as a daemon\n");
+		 * Wait for the parent process to terminate, but not forever.
+		 * On some systems this happened after we tried re-acquiring
+		 * the lock, so the lock would fail. Hence, we wait.
+		for (i = 0; i < 1000000; i++) {
+			/* Once we've been reaped by init, parent PID will be 1 */
+			if(getppid() == 1)
+				break;
+			usleep(1);
+	/* Second lock check, to replace the contents with our own new PID and re-acquire the advisory lock */
+	if(!rtOpts->nonDaemon && !rtOpts->ignore_daemon_lock){
+			*ret = 3;
+			goto fail;
+	/* Try binding to a single CPU core if configured to do so */
+	if(rtOpts->cpuNumber > -1) {
+    		if(setCpuAffinity(rtOpts->cpuNumber) < 0) {
+		    ERROR("Could not bind to CPU core %d\n", rtOpts->cpuNumber);
+		} else {
+		    INFO("Successfully bound "PTPD_PROGNAME" to CPU core %d\n", rtOpts->cpuNumber);
+#endif
+	/* set up timers */
+	if(!timerSetup(ptpClock->timers)) {
+		PERROR("failed to set up event timers");
+		*ret = 2;
+		free(ptpClock);
+		goto fail;
+	ptpClock->rtOpts = rtOpts;
+	/* init alarms */
+	initAlarms(ptpClock->alarms, ALRM_MAX, (void*)ptpClock);
+	ptpClock->alarmDelay = rtOpts->alarmInitialDelay;
+	/* we're delaying alarm processing - disable alarms for now */
+	if(ptpClock->alarmDelay) {
+	    enableAlarms(ptpClock->alarms, ALRM_MAX, FALSE);
+	/* establish signal handlers */
+	signal(SIGINT,  catchSignals);
+	signal(SIGTERM, catchSignals);
+	signal(SIGHUP,  catchSignals);
+	signal(SIGUSR1, catchSignals);
+	signal(SIGUSR2, catchSignals);
+#if defined PTPD_SNMP
+	/* Start SNMP subsystem */
+	if (rtOpts->snmpEnabled)
+		snmpInit(rtOpts, ptpClock);
+#endif
+	NOTICE(USER_DESCRIPTION" started successfully on %s using \"%s\" preset (PID %d)\n",
+			    rtOpts->ifaceName,
+			    (getPtpPreset(rtOpts->selectedPreset,rtOpts)).presetName,
+			    getpid());
+#endif
+#ifdef PTPD_PCAP
+		ptpClock->netPath.pcapEventSock = -1;
+		ptpClock->netPath.pcapGeneralSock = -1;
+#endif /* PTPD_PCAP */
+		ptpClock->netPath.generalSock = -1;
+		ptpClock->netPath.eventSock = -1;
+	*ret = 0;
+	return ptpClock;
+fail:
+	dictionary_del(&rtOpts->cliConfig);
+	return 0;
+void
+ntpSetup (RunTimeOpts *rtOpts, PtpClock *ptpClock)
+	TimingService *ts = &ptpClock->ntpControl.timingService;
+	if (rtOpts->ntpOptions.enableEngine) {
+	    timingDomain.services[1] = ts;
+	    strncpy(ts->id, "NTP0", TIMINGSERVICE_MAX_DESC);
+	    ts->dataSet.priority1 = 0;
+	    ts->dataSet.type = TIMINGSERVICE_NTP;
+	    ts->config = &rtOpts->ntpOptions;
+	    ts->controller = &ptpClock->ntpControl;
+	    /* for now, NTP is considered always active, so will never go idle */
+	    ts->timeout = 60;
+	    ts->updateInterval = rtOpts->ntpOptions.checkInterval;
+	    timingDomain.serviceCount = 2;
+	} else {
+	    timingDomain.serviceCount = 1;
+	    timingDomain.services[1] = NULL;
+	    if(timingDomain.best == ts || timingDomain.current == ts || timingDomain.preferred == ts) {
+		timingDomain.best = timingDomain.current = timingDomain.preferred = NULL;
diff --git a/freebsd/contrib/ptpd/src/dep/statistics.c b/freebsd/contrib/ptpd/src/dep/statistics.c
index 00000000..c35629f8
--- /dev/null
+++ b/freebsd/contrib/ptpd/src/dep/statistics.c
@@ -0,0 +1,1047 @@
+ * Copyright (c) 2013-2015 Wojciech Owczarek
+ * met:
+ * @file    statistics.c
+ * @authors Wojciech Owczarek
+ * @date   Sun Jul 7 13:28:10 2013
+ * This souece file contains the implementations of functions maintaining and
+ * computing statistical information.
+static int cmpInt32 (const void *vA, const void *vB) {
+	int32_t a = *(int32_t*)vA;
+	int32_t b = *(int32_t*)vB;
+	return ((a < b) ? -1 : (a > b) ? 1 : 0);
+static int cmpDouble (const void *vA, const void *vB) {
+	double a = *(double*)vA;
+	double b = *(double*)vB;
+static int cmpAbsInt32 (const void *vA, const void *vB) {
+	int32_t a = abs(*(int32_t*)vA);
+	int32_t b = abs(*(int32_t*)vB);
+static int cmpAbsDouble (const void *vA, const void *vB) {
+	double a = fabs(*(double*)vA);
+	double b = fabs(*(double*)vB);
+static int32_t median3Int(int32_t *bucket, int count)
+	int32_t sortedSamples[count];
+	memcpy(sortedSamples, bucket, count * sizeof(int32_t));
+	switch (count) {
+	    case 1:
+		return bucket[0];
+	    case 2:
+		return (bucket[0] + bucket[1]) / 2;
+	    case 3:
+		qsort(sortedSamples, count, sizeof(int32_t), cmpInt32);
+		return sortedSamples[1];
+	    default:
+		return 0;
+static double median3Double(double *bucket, int count)
+	double sortedSamples[count];
+	memcpy(sortedSamples, bucket, count * sizeof(double));
+	switch (count) {
+	    case 1:
+		return bucket[0];
+	    case 2:
+		return (bucket[0] + bucket[1]) / 2.0;
+	    case 3:
+		qsort(sortedSamples, count, sizeof(double), cmpInt32);
+	    default:
+		return 0;
+void
+resetIntPermanentMean(IntPermanentMean* container) {
+	container->previous = container->mean;
+	container->mean = 0;
+	container->count = 0;
+int32_t
+feedIntPermanentMean(IntPermanentMean* container, int32_t sample)
+	container->mean += ( sample - container-> mean ) / ++container->count;
+	if(container->previous) {
+	    container->bufferedMean = (container->previous + container->mean) / 2;
+	} else {
+	    container->bufferedMean = container->mean;
+	return container->mean;
+void
+resetIntPermanentStdDev(IntPermanentStdDev* container) {
+	resetIntPermanentMean(&container->meanContainer);
+	container->squareSum = 0;
+	container->stdDev = 0;
+int32_t
+feedIntPermanentStdDev(IntPermanentStdDev* container, int32_t sample)
+	container->squareSum += ( sample - container->meanContainer.mean) *
+		    ( sample - feedIntPermanentMean(&container->meanContainer, sample ));
+	if(container->meanContainer.count > 1) {
+		container->stdDev = sqrt( container->squareSum /
+			(container->meanContainer.count - 1) );
+	} else {
+	return container->stdDev;
+void
+resetIntPermanentMedian(IntPermanentMedian* container) {
+	memset(container, 0, sizeof(IntPermanentMedian));
+int32_t
+feedIntPermanentMedian(IntPermanentMedian* container, int32_t sample)
+	    container->bucket[container->count] = sample;
+	    container->count++;
+	    container->median = median3Int(container->bucket, container->count);
+	    if(container->count == 3) {
+		container->count=1;
+		container->bucket[1] = container->bucket[2] = 0;
+		container->bucket[0] = container->median;
+	    return container->median;
+void
+resetDoublePermanentMean(DoublePermanentMean* container)
+	if(container == NULL)
+	    return;
+	container->mean = 0.0;
+double
+feedDoublePermanentMean(DoublePermanentMean* container, double sample)
+	} else {
+void
+resetDoublePermanentStdDev(DoublePermanentStdDev* container)
+	    return;
+	resetDoublePermanentMean(&container->meanContainer);
+	container->squareSum = 0.0;
+	container->stdDev = 0.0;
+double
+feedDoublePermanentStdDev(DoublePermanentStdDev* container, double sample)
+		    ( sample - feedDoublePermanentMean(&container->meanContainer, sample )) ;
+		container->stdDev = sqrt(container->squareSum /
+			((container->meanContainer.count+0.0) - 1.0)) ;
+	} else {
+void
+resetDoublePermanentMedian(DoublePermanentMedian* container)
+	memset(container, 0, sizeof(DoublePermanentMedian));
+double
+feedDoublePermanentMedian(DoublePermanentMedian* container, double sample)
+	container->median = median3Double(container->bucket, container->count);
+/* Moving statistics - up to last n samples */
+IntMovingMean*
+createIntMovingMean(int capacity)
+	IntMovingMean* container;
+	if ( !(container = calloc (1, sizeof(IntMovingMean))) ) {
+	    return NULL;
+	container->capacity = (capacity > STATCONTAINER_MAX_SAMPLES ) ?
+			STATCONTAINER_MAX_SAMPLES : capacity;
+	if ( !(container->samples = calloc (container->capacity, sizeof(int32_t))) ) {
+	    free(container);
+	    return NULL;
+	return container;
+void
+freeIntMovingMean(IntMovingMean** container)
+	free((*container)->samples);
+	free(*container);
+	*container = NULL;
+void
+resetIntMovingMean(IntMovingMean* container)
+	    return;
+	container->sum = 0;
+	memset(container->samples, 0, sizeof(&container->samples));
+int32_t
+feedIntMovingMean(IntMovingMean* container, int32_t sample)
+	if(container == NULL) return 0;
+        /* sample buffer is full */
+        if ( container->count == container->capacity ) {
+		/* keep the sum current - drop the oldest value */
+		container->sum -= container->samples[0];
+		/* shift the sample buffer left, dropping the oldest sample */
+		memmove(container->samples, container->samples + 1,
+			sizeof(sample) * (container->capacity - 1) );
+		/* counter will be incremented further, so we decrement it here */
+		container->count--;
+		container->full = TRUE;
+	container->samples[container->count++] = sample;
+	container->sum += sample;
+	container->mean = container->sum / container->count;
+IntMovingStdDev* createIntMovingStdDev(int capacity)
+	IntMovingStdDev* container;
+	if ( !(container = calloc (1, sizeof(IntMovingStdDev))) ) {
+		return NULL;
+	if((container->meanContainer = createIntMovingMean(capacity))
+		== NULL) {
+		free(container);
+		return NULL;
+	return container;
+void
+freeIntMovingStdDev(IntMovingStdDev** container)
+	freeIntMovingMean(&((*container)->meanContainer));
+	free(*container);
+void
+resetIntMovingStdDev(IntMovingStdDev* container)
+	    return;
+	resetIntMovingMean(container->meanContainer);
+int32_t
+feedIntMovingStdDev(IntMovingStdDev* container, int32_t sample)
+	int i = 0;
+		return 0;
+	feedIntMovingMean(container->meanContainer, sample);
+	if (container->meanContainer->count < 2) {
+	} else {
+		for(i = 0; i < container->meanContainer->count; i++) {
+			container->squareSum += ( container->meanContainer->samples[i] - container->meanContainer->mean ) *
+						( container->meanContainer->samples[i] - container->meanContainer->mean );
+		container->stdDev = sqrt ( container->squareSum /
+					    (container->meanContainer->count - 1 ));
+DoubleMovingMean*
+createDoubleMovingMean(int capacity)
+	DoubleMovingMean* container;
+	if ( !(container = calloc (1, sizeof(DoubleMovingMean))) ) {
+	    return NULL;
+	if ( !(container->samples = calloc(container->capacity, sizeof(double))) ) {
+	    free(container);
+	    return NULL;
+	return container;
+void
+freeDoubleMovingMean(DoubleMovingMean** container)
+	if(*container == NULL) {
+	    return;
+	free(*container);
+void
+resetDoubleMovingMean(DoubleMovingMean* container)
+	    return;
+	container->counter = 0;
+double
+feedDoubleMovingMean(DoubleMovingMean* container, double sample)
+	    return 0;
+		container->counter++;
+		container->counter = container->counter % container->capacity;
+//		INFO("c: %d\n", container->counter);
+DoubleMovingStdDev* createDoubleMovingStdDev(int capacity)
+	DoubleMovingStdDev* container;
+	if ( !(container = calloc (1, sizeof(DoubleMovingStdDev))) ) {
+		return NULL;
+	if((container->meanContainer = createDoubleMovingMean(capacity))
+		== NULL) {
+		free(container);
+		return NULL;
+	return container;
+void
+freeDoubleMovingStdDev(DoubleMovingStdDev** container)
+	freeDoubleMovingMean(&((*container)->meanContainer));
+	free(*container);
+void
+resetDoubleMovingStdDev(DoubleMovingStdDev* container)
+	    return;
+	resetDoubleMovingMean(container->meanContainer);
+double
+feedDoubleMovingStdDev(DoubleMovingStdDev* container, double sample)
+	int i = 0;
+		return 0.0;
+	feedDoubleMovingMean(container->meanContainer, sample);
+	} else {
+					    (container->meanContainer->count - 1));
+	if(container->meanContainer->counter == 0) {
+		container->periodicStdDev = container->stdDev;
+	return contain
