[rtems-net-legacy PATCH] bsd: Add iface calls to help user manage the iface state
chrisj at rtems.org chrisj at rtems.org
Thu Apr 13 02:17:25 UTC 2023
 include/rtems/bsd/iface.h |  62 +++++++++++++++
 netsources.py             |  26 +++----
 rtems/rtems-bsd-iface.c   | 154 ++++++++++++++++++++++++++++++++++++++
 testsuites/wscript        |   8 ++
 wscript                   |   7 +-
 5 files changed, 236 insertions(+), 21 deletions(-)
 create mode 100755 include/rtems/bsd/iface.h
 create mode 100755 rtems/rtems-bsd-iface.c
diff --git a/include/rtems/bsd/iface.h b/include/rtems/bsd/iface.h
new file mode 100755
index 0000000..9e583b8
--- /dev/null
+++ b/include/rtems/bsd/iface.h
@@ -0,0 +1,62 @@
+ * @file
+ * @ingroup rtems_bsd_rtems
+ * @brief This file provide a high level interface to simple interface
+ * support calls.
+ * Copyright (c) 2021. Chris Johns <chrisj at rtems.org>. All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#ifndef _RTEMS_BSD_IFACE_H_
+#define _RTEMS_BSD_IFACE_H_
+#include <stdbool.h>
+#include <sys/socket.h>
+#include <net/if.h>
+#include <net/if_media.h>
+#include <netinet/in.h>
+struct rtems_bsd_iface {
+	char name[IFNAMSIZ];
+	int unit;
+	struct in_addr address;
+	size_t hw_len;
+	uint8_t hw_address[16];
+	struct ifreq ifr;
+	int linkstate;
+ * These calls return 0 is successful and -1 and errno set on error.
+int rtems_bsd_iface_get(const char *name, struct rtems_bsd_iface *iface);
+int rtems_bsd_iface_link_state(const char *name, bool *state);
+#endif
diff --git a/netsources.py b/netsources.py
index be9334d..9f1b7ff 100644
--- a/netsources.py
+++ b/netsources.py
@@ -31,6 +31,7 @@ class source:
         # rtems
         'rtems/mkrootfs.c',
         'rtems/rtems_bootp.c',
+        'rtems/rtems-bsd-iface.c',
         'rtems/rtems_bsdnet_malloc_starvation.c',
         'rtems/rtems_dhcp.c',
         'rtems/rtems_dhcp_failsafe.c',
@@ -223,22 +224,12 @@ class source:
     nfsclient = [
-        'pppd/auth.c',
-        'pppd/ccp.c',
-        'pppd/chap.c',
-        'pppd/chap_ms.c',
-        'pppd/chat.c',
-        'pppd/demand.c',
-        'pppd/fsm.c',
-        'pppd/ipcp.c',
-        'pppd/lcp.c',
-        'pppd/magic.c',
-        'pppd/options.c',
-        'pppd/rtemsmain.c',
-        'pppd/rtemspppd.c',
-        'pppd/sys-rtems.c',
-        'pppd/upap.c',
-        'pppd/utils.c',
+        'nfsclient/proto/mount_prot_xdr.c',
+        'nfsclient/proto/nfs_prot_xdr.c',
+        'nfsclient/src/nfs.c',
+        'nfsclient/src/rpcio.c',
+        'nfsclient/src/sock_mbuf.c',
+        'nfsclient/src/xdr_mbuf.c',
     pppd = [
@@ -316,6 +307,9 @@ header = {
         'rtems/rtems_mii_ioctl.h', 'rtems/rtems_netdb.h',
         'rtems/rtems_netinet_in.h', 'rtems/rtems_syscall.h'
+    'rtems/bsd': [
+        'include/rtems/bsd/iface.h',
     'rtems/bsdnet': ['rtems/bsdnet/_types.h', 'rtems/bsdnet/servers.h'],
     'sys': [
         'sys/callout.h', 'sys/conf.h', 'sys/domain.h', 'sys/kernel.h',
diff --git a/rtems/rtems-bsd-iface.c b/rtems/rtems-bsd-iface.c
index 0000000..0f6432f
--- /dev/null
+++ b/rtems/rtems-bsd-iface.c
@@ -0,0 +1,154 @@
+ * @file
+ * @brief Interface support routines
+ * Copyright (c) 2021. Chris Johns <chrisj at rtems.org>  All rights reserved.
+ * are met:
+ * SUCH DAMAGE.
+#include <errno.h>
+#include <stdio.h>
+#include <string.h>
+#include <sys/ioctl.h>
+#include <unistd.h>
+#include <ifaddrs.h>
+#include <net/if_dl.h>
+#include <rtems/bsd/iface.h>
+#if !defined(RTEMS_BSD_IFACE_TRACE)
+#define RTEMS_BSD_IFACE_TRACE 0
+#endif
+int
+rtems_bsd_iface_get(const char *name, struct rtems_bsd_iface *iface)
+	struct ifaddrs *ifap, *ifa;
+	bool found = false;
+	if (iface == NULL) {
+		errno = EINVAL;
+		return -1;
+	memset(iface, 0, sizeof(*iface));
+	if (getifaddrs(&ifap) != 0) {
+		if (RTEMS_BSD_IFACE_TRACE) {
+			printf("bsd: iface: getifaddrs failed: %s\n", strerror(errno));
+		return -1;
+	for (ifa = ifap; ifa != NULL; ifa = ifa->ifa_next) {
+		if ((ifa->ifa_flags & IFF_LOOPBACK) ||
+		    (ifa->ifa_flags & IFF_POINTOPOINT))
+			continue;
+		if (strcmp(name, ifa->ifa_name) != 0)
+			continue;
+		found = true;
+		if (ifa->ifa_addr->sa_family == AF_LINK) {
+			struct sockaddr_dl *sa;
+			sa = (struct sockaddr_dl *)ifa->ifa_addr;
+			iface->unit = sa->sdl_index;
+			iface->hw_len = sa->sdl_alen;
+			memcpy(iface->hw_address, LLADDR(sa), sa->sdl_alen);
+		} else if (ifa->ifa_addr->sa_family == AF_INET) {
+			struct sockaddr_in sa;
+			memcpy(&sa, ifa->ifa_addr, sizeof(sa));
+			if (sa.sin_addr.s_addr == htonl(INADDR_LOOPBACK))
+				continue;
+			strlcpy(iface->ifr.ifr_name, ifa->ifa_name, IFNAMSIZ);
+			memcpy(&iface->ifr.ifr_addr, ifa->ifa_addr,
+			    ifa->ifa_addr->sa_len);
+			iface->address = sa.sin_addr;
+	freeifaddrs(ifap);
+	if (!found) {
+			printf("bsd: iface: not-found: %s\n", name);
+		errno = ENOENT;
+		return -1;
+	strlcpy(iface->name, name, sizeof(iface->name));
+	return 0;
+int
+rtems_bsd_iface_link_state(const char *name, bool *state)
+	struct rtems_bsd_iface iface;
+	struct ifmediareq ifmr;
+	int s;
+	int rc;
+	*state = false;
+	rc = rtems_bsd_iface_get(name, &iface);
+	if (rc < 0) {
+		return -1;
+	s = socket(iface.ifr.ifr_addr.sa_family, SOCK_DGRAM, 0);
+	if (s < 0) {
+			printf("bsd: iface: link state: socket open failed: %s\n", strerror(errno));
+		return -1;
+	memset(&ifmr, 0, sizeof(ifmr));
+        strlcpy(ifmr.ifm_name, name, sizeof(ifmr.ifm_name));
+        rc = ioctl(s, SIOCGIFMEDIA, (caddr_t)&ifmr);
+	close(s);
+	if (rc < 0) {
+			printf("bsd: iface: link state: socket ioctl failed: %s\n", strerror(errno));
+		return -1;
+	if ((ifmr.ifm_status & IFM_AVALID) != 0) {
+		*state = (ifmr.ifm_status & IFM_ACTIVE) != 0;
+	return 0;
diff --git a/testsuites/wscript b/testsuites/wscript
index 3ce5153..6bfc1eb 100644
--- a/testsuites/wscript
+++ b/testsuites/wscript
@@ -42,6 +42,14 @@ def init(ctx):
     pass
+def options(opt):
+    copts = opt.option_groups['configure options']
+    copts.add_option('--net-test-config',
+                     default='config.inc',
+                     dest='net_config',
+                     help='Network test configuration (default: %default)')
 def configure(conf):
     recurse(conf)
diff --git a/wscript b/wscript
index c365f14..d41f93e 100644
--- a/wscript
+++ b/wscript
@@ -51,11 +51,7 @@ def init(ctx):
 def options(opt):
     rtems.options(opt)
     netlegacy.options(opt)
-    copts = opt.option_groups['configure options']
-    copts.add_option('--net-test-config',
-                     default='config.inc',
-                     dest='net_config',
-                     help='Network test configuration (default: %default)')
+    opt.recurse('testsuites')
 def bsp_configure(conf, arch_bsp):
@@ -64,6 +60,7 @@ def bsp_configure(conf, arch_bsp):
     conf.msg('Configure variant: ', ab)
     conf.setenv(ab, env)
     netlegacy.bsp_configure(conf, arch_bsp)
+    conf.recurse('testsuites')
     conf.setenv(ab)
2.37.1
