[rtems-source-builder PATCH] rtems: Update tools, kernel and legacy network packages
chrisj at rtems.org
chrisj at rtems.org
Sat Apr 15 01:10:20 UTC 2023
- Tools picks up the stm32h7-stlink to handle SIGTRAP fix.
- RTEMS picks up the motorola_powerpc updates including the mvme2700
BSP and Makefile.inc fixes for building EPICS.
- Legacy networking picks up a number of build system fixes,
network configuration changes and more tests.
rtems/config/tools/rtems-kernel-6.cfg | 6 +++---
rtems/config/tools/rtems-net-legacy-6.cfg | 8 ++++----
rtems/config/tools/rtems-tools-6.cfg | 4 ++--
3 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/rtems/config/tools/rtems-kernel-6.cfg b/rtems/config/tools/rtems-kernel-6.cfg
index 0ee1d04..e2f1d68 100644
--- a/rtems/config/tools/rtems-kernel-6.cfg
+++ b/rtems/config/tools/rtems-kernel-6.cfg
@@ -1,11 +1,11 @@
-# RTEMS 5
+# RTEMS 6
-%define rtems_kernel_version d0b92735b0dfd509e1edb82c7145042b67714f43
+%define rtems_kernel_version 5a37722b066f5792aad80fb5b32fb3c056cf1607
%hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 \
- XyW9t5NSWAU8eAz1HdbFwOWmLMkAHeheeATznvag57QjP4rZYFeHfIws4ttzmSvODHDI16OJw/CLWQQ9l58SIg==
+ UcZlhl2FZhvDKXZnPLnJSYnMQwSgWluTBGfoLII9vNbx4ypxQPE+egN4dZ06H3l5MprrJY96mgNZTfLjI2itcQ==
# The RTEMS build instructions.
diff --git a/rtems/config/tools/rtems-net-legacy-6.cfg b/rtems/config/tools/rtems-net-legacy-6.cfg
index fbc7ab8..984ba09 100644
--- a/rtems/config/tools/rtems-net-legacy-6.cfg
+++ b/rtems/config/tools/rtems-net-legacy-6.cfg
@@ -3,10 +3,10 @@
# branch: main
-%define rtems_net_version 5713f7027984012ea17cdd582e6d0258ee7aa58a
+%define rtems_net_version d22fbcb0412e309850c0f49ab61bc410184b9b5c
%hash sha512 rtems-net-legacy-%{rtems_net_version}.tar.bz2 \
- 0dwnqZP+j9b2IZ7rqiEBndVkqIsURal4L/47pSI4pe0rz48hmWa78DE0915Gf+/+nvsCMB2I/sFAMj+P6AjeeA==
-%define rtems_waf_version 1a118bbcd52138dbdc3236e64bc23fd430a064b1
+ eKESsJ4ra5kbF+IjMvhlLriGUxC2vCfKy/7bnkZyrhcBnfkpIWWqzEj1eB2iqfpy/1p+hcnxIh00ysJF66ptkw==
+%define rtems_waf_version 2c15b90de5c369aa78cd2252a50bba677e9b13f3
%hash sha512 rtems-waf-%{rtems_waf_version}.tar.bz2 \
- wHiMBCaJjnNd8EEnbl5A9qyGwcQ5E+BcG9Q5SwJmlbarcrQ4U6//Q2ni2XNyXtWQzzy959o6YSg8PvVjgEi0vg==
+ gSpj/vTcB9T985HC9xi//gMcYj9rl6AedULvPdFppJ7D1CFIueE+MyfGn+okVtZvnG+tZk1JkR2gvIQNV3mXbQ==
%include tools/rtems-net-legacy-common.cfg
diff --git a/rtems/config/tools/rtems-tools-6.cfg b/rtems/config/tools/rtems-tools-6.cfg
index 042e0fa..b786a47 100644
--- a/rtems/config/tools/rtems-tools-6.cfg
+++ b/rtems/config/tools/rtems-tools-6.cfg
@@ -10,14 +10,14 @@
%define rtems_tools_source rtems-tools-%{rtems_tools_version}
%define rtems_tools_ext xz
%else
- %define rtems_tools_version c8bf7309332990a52ae98ed3926c0f62984e8193
+ %define rtems_tools_version eaf14a654b528b44de14f9da9919555e54324e0d
%define rtems_tools_ext bz2
%endif
%source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
%hash sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
- XOCIuPQ65yZOvPkiTZb3r2T9YAPBg6az3xz5Z2ivkfygSYZgaymSkmpv5yF3QbCXK1Y+2LRUuEp73oymj7vnbA==
+ bcjVLITKdjQLKlalfUptMKLAmvDT0FidARukQHP4rK/8SWpYckPAc8BMMRhS3RX+Ga6NDuxD1Ss/bRlxG6qsdg==
# Optionally enable/disable building the RTEMS Tools via the command line.
2.31.1
