[PATCH v2 04/18] ptpd: Add implementation of eventtimer based on kqueue
Gabriel Moyano gabriel.moyano at dlr.de
Mon Apr 17 07:59:17 UTC 2023
 rtemsbsd/ptpd/src/dep/datatypes_dep.h     |  10 ++
 rtemsbsd/ptpd/src/dep/eventtimer.h        |   6 +-
 rtemsbsd/ptpd/src/dep/eventtimer_kqueue.c | 184 ++++++++++++++++++++++
 rtemsbsd/ptpd/src/dep/kqueue.c            |  80 ++++++++++
 rtemsbsd/ptpd/src/dep/net.c               | 111 ++++++++++++-
 rtemsbsd/ptpd/src/dep/ptpd_dep.h          |  11 +-
 rtemsbsd/ptpd/src/protocol.c              |  22 ++-
 rtemsbsd/ptpd/src/ptpd.h                  |   3 +
 8 files changed, 411 insertions(+), 16 deletions(-)
 create mode 100644 rtemsbsd/ptpd/src/dep/eventtimer_kqueue.c
 create mode 100644 rtemsbsd/ptpd/src/dep/kqueue.c
diff --git a/rtemsbsd/ptpd/src/dep/datatypes_dep.h b/rtemsbsd/ptpd/src/dep/datatypes_dep.h
index 77a645c4..9496ed60 100644
--- a/rtemsbsd/ptpd/src/dep/datatypes_dep.h
+++ b/rtemsbsd/ptpd/src/dep/datatypes_dep.h
@@ -43,6 +43,16 @@ typedef struct {
 	int ifIndex;
 } InterfaceInfo;
+* \brief Support for kqueue or select
+#ifdef HAVE_KQUEUE
+#define PTPD_KQUEUE_EVENTS (4) /* 2 for PTP, 2 for PCAP */
+typedef struct kevent PtpNetWaitEvents;
+#else
+typedef struct fd_set PtpNetWaitEvents;
+#endif
 * \brief Struct describing network transport data
diff --git a/rtemsbsd/ptpd/src/dep/eventtimer.h b/rtemsbsd/ptpd/src/dep/eventtimer.h
index 9d41156d..dc4080df 100644
--- a/rtemsbsd/ptpd/src/dep/eventtimer.h
+++ b/rtemsbsd/ptpd/src/dep/eventtimer.h
@@ -51,9 +51,11 @@ struct EventTimer {
 	Boolean (*isRunning) (EventTimer* timer);
 	/* implementation data */
-#ifdef PTPD_PTIMERS
+#ifdef HAVE_KQUEUE
+  int timerId;
+#elif defined PTPD_PTIMERS
 	timer_t timerId;
-#else
+#else /* HAVE_KQUEUE */
 	int32_t itimerInterval;
 	int32_t itimerLeft;
 #endif /* PTPD_PTIMERS */
diff --git a/rtemsbsd/ptpd/src/dep/eventtimer_kqueue.c b/rtemsbsd/ptpd/src/dep/eventtimer_kqueue.c
new file mode 100644
index 00000000..914bbc4a
--- /dev/null
+++ b/rtemsbsd/ptpd/src/dep/eventtimer_kqueue.c
@@ -0,0 +1,184 @@
+ * Copyright (c) 2020      Chris Johns,
+ * All Rights Reserved
+ * modification, are permitted provided that the following conditions are
+ * met:
+ * 1. Redistributions of source code must retain the above copyright notice,
+ *    this list of conditions and the following disclaimer.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHORS ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE AUTHORS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
+ * BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
+ * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
+ * IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * @file   eventtimer_kqueue.c
+ * @date
+ * @brief  EventTimer implementation using kqueue timers
+ * Needs support in the kqueue to pass timer events to here.
+#include "../ptpd.h"
+static void eventTimerStart_kqueue(EventTimer *timer, double interval);
+static void eventTimerStop_kqueue(EventTimer *timer);
+static void eventTimerReset_kqueue(EventTimer *timer);
+static void eventTimerShutdown_kqueue(EventTimer *timer);
+static Boolean eventTimerIsRunning_kqueue(EventTimer *timer);
+static Boolean eventTimerIsExpired_kqueue(EventTimer *timer);
+static int timerInstance;
+void
+setupEventTimer(EventTimer *timer)
+  struct kevent evset;
+	if(timer == NULL) {
+	    return;
+	memset(timer, 0, sizeof(EventTimer));
+	timer->start = eventTimerStart_kqueue;
+	timer->stop = eventTimerStop_kqueue;
+	timer->reset = eventTimerReset_kqueue;
+	timer->shutdown = eventTimerShutdown_kqueue;
+	timer->isExpired = eventTimerIsExpired_kqueue;
+	timer->isRunning = eventTimerIsRunning_kqueue;
+  timer->timerId = ++timerInstance;
+  EV_SET(&evset, timer->timerId, EVFILT_TIMER, EV_ADD | EV_DISABLE, 0, 0, timer);
+  if (kevent(ptpKqueueGet(), &evset, 1, NULL, 0, NULL) < 0)
+      PERROR("kevent timer add | disable");
+  DBGV("Created kqueue timer %s (%d)", timer->id, timer->timerId);
+static void
+eventTimerStart_kqueue(EventTimer *timer, double interval)
+  int kq = ptpKqueueGet();
+  if (kq >= 0) {
+    intptr_t data = interval * 1000000;
+           EVFILT_TIMER, EV_ADD | EV_ENABLE | EV_CLEAR,
+           NOTE_USECONDS, data, timer);
+    DBGV("Timer %s start requested at %ld us interval\n", timer->id, data);
+    if (kevent(kq, &evset, 1, NULL, 0, NULL) < 0) {
+      PERROR("kevent timer add | enable");
+      return;
+    DBG2("timerStart:     Set timer %s to %f\n", timer->id, interval);
+    timer->expired = FALSE;
+    timer->running = TRUE;
+static void
+eventTimerStop_kqueue(EventTimer *timer)
+  if (kq >= 0) {
+    DBGV("Timer %s stop requested\n", timer->id);
+    timer->running = FALSE;
+    DBG2("timerStop: stopped timer %s\n", timer->id);
+static void
+eventTimerReset_kqueue(EventTimer *timer)
+static void
+eventTimerShutdown_kqueue(EventTimer *timer)
+  if (kq >= 0) {
+    EV_SET(&evset, timer->timerId, EVFILT_TIMER, EV_DELETE, 0, 0, timer);
+      PERROR("kevent timer disable");
+  DBG2("timerShutdown: %s\n", timer->id);
+static Boolean
+eventTimerIsRunning_kqueue(EventTimer *timer)
+	DBG2("timerIsRunning:   Timer %s %s running\n", timer->id,
+		timer->running ? "is" : "is not");
+	return timer->running;
+static Boolean
+eventTimerIsExpired_kqueue(EventTimer *timer)
+	Boolean ret;
+	ret = timer->expired;
+	DBG2("timerIsExpired:   Timer %s %s expired\n", timer->id,
+		timer->expired ? "is" : "is not");
+	/* the five monkeys experiment */
+	if(ret) {
+	return ret;
+void
+startEventTimers(void)
+	DBG("initTimer\n");
+void
+shutdownEventTimers(void)
diff --git a/rtemsbsd/ptpd/src/dep/kqueue.c b/rtemsbsd/ptpd/src/dep/kqueue.c
index 00000000..d516c186
--- /dev/null
+++ b/rtemsbsd/ptpd/src/dep/kqueue.c
@@ -0,0 +1,80 @@
+ * met:
+ * @file   kqueue.c
+ * @date
+ * @brief  Kqueue support code
+ * The kqueue is shared between the networking and timer code and there
+ * no shared data in their interfaces so kqueue handle is held here.
+static int kq = -1;
+int
+ptpKqueueGet(void)
+#ifdef HAVE_KQUEUE
+	if(kq < 0) {
+    kq = kqueue();
+    if (kq < 0)
+      PERROR("kqueue failed");
+#endif
+  return kq;
+int
+ptpKqueueWait(struct timespec* ts, struct kevent* events, int nevents)
+  int ret;
+  if (kq < 0) {
+    PERROR("kqueue not initialised");
+    return -1;
+  ret = kevent(kq, NULL, 0, events, nevents, ts);
+  if (ret > 0) {
+    int e;
+    for (e = 0; e < ret; ++e) {
+      DBG2("kevent: %d: %2d: %s\n", e, events[e].ident,
+           events[e].filter == EVFILT_TIMER ? "timer" : "sock");
+      if (events[e].filter == EVFILT_TIMER) {
+        EventTimer* timer = events[e].udata;
+        timer->expired = TRUE;
+  return ret;
diff --git a/rtemsbsd/ptpd/src/dep/net.c b/rtemsbsd/ptpd/src/dep/net.c
index 86db9b83..edee5dc6 100644
--- a/rtemsbsd/ptpd/src/dep/net.c
+++ b/rtemsbsd/ptpd/src/dep/net.c
@@ -149,6 +149,41 @@ isIpMulticast(struct in_addr in)
+/* KQUEUE support to add and delete events */
+static int netKqueueAdd(int fd)
+    int res = 0;
+#ifdef HAVE_KQUEUE
+    if (fd >= 0 && kq >= 0) {
+      EV_SET(&evset, fd, EVFILT_READ, EV_ADD, 0, 0, NULL);
+      res = kevent(kq, &evset, 1, NULL, 0, NULL);
+      if (res == -1)
+        PERROR("kevent sock read add");
+      DBG("add sock kevent: %d --> %d\n", fd, kq);
+#endif
+    return res;
+static int netKqueueDelete(int fd)
+    int res = 0;
+#ifdef HAVE_KQUEUE
+      EV_SET(&evset, fd, EVFILT_READ, EV_DELETE, 0, 0, NULL);
+      if (res == -1)
+        PERROR("kevent sock read delete");
+      DBG("delete sock kevent: %d x-> %d\n", fd, kq);
+#endif
+    return res;
 /* shut down the UDP stuff */
 Boolean
 netShutdown(NetPath * netPath)
@@ -156,20 +191,26 @@ netShutdown(NetPath * netPath)
 	netShutdownMulticast(netPath);
 	/* Close sockets */
-	if (netPath->eventSock >= 0)
+	if (netPath->eventSock >= 0) {
+    netKqueueDelete(netPath->eventSock);
 		close(netPath->eventSock);
 	netPath->eventSock = -1;
-	if (netPath->generalSock >= 0)
+	if (netPath->generalSock >= 0) {
+    netKqueueDelete(netPath->generalSock);
 		close(netPath->generalSock);
 	netPath->generalSock = -1;
 #ifdef PTPD_PCAP
 	if (netPath->pcapEvent != NULL) {
+    netKqueueDelete(netPath->pcapEventSock);
 		pcap_close(netPath->pcapEvent);
 		netPath->pcapEventSock = -1;
 	if (netPath->pcapGeneral != NULL) {
+    netKqueueDelete(netPath->pcapGeneralSock);
 		pcap_close(netPath->pcapGeneral);
 		netPath->pcapGeneralSock = -1;
@@ -1039,6 +1080,10 @@ netInit(NetPath * netPath, RunTimeOpts * rtOpts, PtpClock * ptpClock)
 		return FALSE;
+  if((netKqueueAdd(netPath->eventSock) < 0)
+     || (netKqueueAdd(netPath->generalSock) < 0))
+    return FALSE;
 	/* let's see if we have another interface left before we die */
 	if(!testInterface(rtOpts->ifaceName, rtOpts)) {
@@ -1127,7 +1172,8 @@ netInit(NetPath * netPath, RunTimeOpts * rtOpts, PtpClock * ptpClock)
 		     pcap_get_selectable_fd(netPath->pcapEvent)) < 0) {
 			PERROR("failed to get pcap event fd");
 			return FALSE;
+    netKqueueAdd(netPath->pcapEventSock);
 		if ((netPath->pcapGeneral = pcap_open_live(rtOpts->ifaceName,
 							   PACKET_SIZE, promisc,
 							   PCAP_TIMEOUT,
@@ -1157,14 +1203,17 @@ netInit(NetPath * netPath, RunTimeOpts * rtOpts, PtpClock * ptpClock)
 				PERROR("failed to get pcap general fd");
 				return FALSE;
+      netKqueueAdd(netPath->pcapGeneralSock);
 #endif
 #ifdef PTPD_PCAP
 	if(rtOpts->transport == IEEE_802_3) {
 		/* TX timestamp is not generated for PCAP mode and Ethernet transport */
@@ -1409,18 +1458,52 @@ netInit(NetPath * netPath, RunTimeOpts * rtOpts, PtpClock * ptpClock)
 			rtOpts->managementAclDenyText, rtOpts->managementAclOrder);
 	return TRUE;
 /*Check if data has been received*/
+#ifdef HAVE_KQUEUE
+#if defined PTPD_SNMP
+#error No KQUEUE support for SNMP
+#endif
 int
-netSelect(TimeInternal * timeout, NetPath * netPath, fd_set *readfds)
+netWait(TimeInternal * timeout, NetPath * netPath, PtpNetWaitEvents *readfds)
+	int ret;
+	struct timespec ts, *ts_ptr;
+	if (timeout) {
+		if(isTimeInternalNegative(timeout)) {
+			ERROR("Negative timeout attempted for kevent()\n");
+			return -1;
+		ts.tv_sec = timeout->seconds;
+		ts.tv_nsec = timeout->nanoseconds;
+		ts_ptr = &ts;
+	} else {
+		ts_ptr = NULL;
+  ret = ptpKqueueWait(ts_ptr, readfds, PTPD_KQUEUE_EVENTS);
+	if (ret < 0) {
+		if (errno == EAGAIN || errno == EINTR)
+			ret = 0;
+  return ret;
+int
 	int ret, nfds;
 	struct timeval tv, *tv_ptr;
 	extern const RunTimeOpts rtOpts;
 	struct timeval snmp_timer_wait = { 0, 0}; // initialise to avoid unused warnings when SNMP disabled
@@ -1499,6 +1582,22 @@ if (rtOpts.snmpEnabled) {
 	return ret;
+#endif /* HAVE_KQUEUE */
+Boolean netCheckEvent(int fd, PtpNetWaitEvents * readfds)
+#ifdef HAVE_KQUEUE
+  size_t e;
+  for (e = 0; e < PTPD_KQUEUE_EVENTS; ++e) {
+    if (readfds[e].ident == fd && readfds[e].filter == EVFILT_READ)
+      return TRUE;
+  return FALSE;
+#else
+  return FD_ISSET(fd, readfds);
+#endif
  * store received data from network to "buf" , get and store the
  * SO_TIMESTAMP value in "time" for an event message
diff --git a/rtemsbsd/ptpd/src/dep/ptpd_dep.h b/rtemsbsd/ptpd/src/dep/ptpd_dep.h
index e0bcdf11..2db43f62 100644
--- a/rtemsbsd/ptpd/src/dep/ptpd_dep.h
+++ b/rtemsbsd/ptpd/src/dep/ptpd_dep.h
@@ -377,7 +377,8 @@ UInteger16 msgPackManagementResponse(Octet * buf,MsgHeader*,MsgManagement*,PtpCl
 Boolean testInterface(char* ifaceName, const RunTimeOpts* rtOpts);
 Boolean netInit(NetPath*,RunTimeOpts*,PtpClock*);
 Boolean netShutdown(NetPath*);
-int netSelect(TimeInternal*,NetPath*,fd_set*);
+int netWait(TimeInternal*,NetPath*,PtpNetWaitEvents*);
+Boolean netCheckEvent(int,PtpNetWaitEvents*);
 ssize_t netRecvEvent(Octet*,TimeInternal*,NetPath*,int);
 ssize_t netRecvGeneral(Octet*,NetPath*);
 ssize_t netSendEvent(Octet*,UInteger16,NetPath*,const RunTimeOpts*,Integer32,TimeInternal*);
@@ -389,6 +390,14 @@ Boolean hostLookup(const char* hostname, Integer32* addr);
+/** \name kqueue.c (Kqueue support) */
+int ptpKqueueGet(void);
+int ptpKqueueWait(struct timespec*, struct kevent*, int);
 /** \name snmp.c (SNMP subsystem)
  * -Handle SNMP subsystem*/
diff --git a/rtemsbsd/ptpd/src/protocol.c b/rtemsbsd/ptpd/src/protocol.c
index 1514add2..2ca49d8a 100644
--- a/rtemsbsd/ptpd/src/protocol.c
+++ b/rtemsbsd/ptpd/src/protocol.c
@@ -1450,11 +1450,17 @@ handle(RunTimeOpts *rtOpts, PtpClock *ptpClock)
     ssize_t length = -1;
     TimeInternal timeStamp = { 0, 0 };
-    fd_set readfds;
+#ifdef HAVE_KQUEUE
+    PtpNetWaitEvents readfds[PTPD_KQUEUE_EVENTS] = { 0 };
+    PtpNetWaitEvents * readfds_ptr = &readfds[0];
+#else
+    PtpNetWaitEvents readfds;
+    PtpNetWaitEvents * readfds_ptr = &readfds;
     FD_ZERO(&readfds);
+#endif
     if (!ptpClock->message_activity) {
-	ret = netSelect(NULL, &ptpClock->netPath, &readfds);
+	ret = netWait(NULL, &ptpClock->netPath, readfds_ptr);
 	if (ret < 0) {
 	    PERROR("failed to poll sockets");
 	    ptpClock->counters.messageRecvErrors++;
@@ -1471,7 +1477,8 @@ handle(RunTimeOpts *rtOpts, PtpClock *ptpClock)
 #ifdef PTPD_PCAP
     if (rtOpts->pcap == TRUE) {
-	if (ptpClock->netPath.pcapEventSock >=0 && FD_ISSET(ptpClock->netPath.pcapEventSock, &readfds)) {
+	if (ptpClock->netPath.pcapEventSock >=0
+      && netCheckEvent(ptpClock->netPath.pcapEventSock, readfds_ptr)) {
 	    length = netRecvEvent(ptpClock->msgIbuf, &timeStamp,
 		          &ptpClock->netPath,0);
 	    if (length == 0){ /* timeout, return for now */
@@ -1493,7 +1500,8 @@ handle(RunTimeOpts *rtOpts, PtpClock *ptpClock)
 		processMessage(rtOpts, ptpClock, &timeStamp, length);
-	if (ptpClock->netPath.pcapGeneralSock >=0 && FD_ISSET(ptpClock->netPath.pcapGeneralSock, &readfds)) {
+	if (ptpClock->netPath.pcapGeneralSock >=0
+      && netCheckEvent(ptpClock->netPath.pcapGeneralSock, readfds_ptr)) {
 	    length = netRecvGeneral(ptpClock->msgIbuf, &ptpClock->netPath);
 	    if (length == 0) /* timeout, return for now */
 		return;
@@ -1507,7 +1515,7 @@ handle(RunTimeOpts *rtOpts, PtpClock *ptpClock)
     } else {
 #endif
-	if (FD_ISSET(ptpClock->netPath.eventSock, &readfds)) {
+	if (netCheckEvent(ptpClock->netPath.eventSock, readfds_ptr)) {
 		          &ptpClock->netPath, 0);
 	    if (length < 0) {
@@ -1523,7 +1531,7 @@ handle(RunTimeOpts *rtOpts, PtpClock *ptpClock)
-	if (FD_ISSET(ptpClock->netPath.generalSock, &readfds)) {
+	if (netCheckEvent(ptpClock->netPath.generalSock, readfds_ptr)) {
 	    if (length < 0) {
 		PERROR("failed to receive on the general socket");
diff --git a/rtemsbsd/ptpd/src/ptpd.h b/rtemsbsd/ptpd/src/ptpd.h
index c5287cf5..08090317 100644
--- a/rtemsbsd/ptpd/src/ptpd.h
+++ b/rtemsbsd/ptpd/src/ptpd.h
@@ -83,6 +83,9 @@
 #include <utmp.h>
 #endif /* HAVE_UTMP_H */
 #endif /* HAVE_UTMPX_H */
+#ifdef HAVE_KQUEUE
+#include <sys/event.h>
 #ifdef HAVE_NET_ETHERNET_H
 #include <net/ethernet.h>
2.25.1
