[PATCH v2 15/18] ptpd: Add config file
Gabriel Moyano gabriel.moyano at dlr.de
Mon Apr 17 07:59:28 UTC 2023
 rtemsbsd/include/ptpd/config.h | 248 +++++++++++++++++++++++++++++++++
 1 file changed, 248 insertions(+)
 create mode 100644 rtemsbsd/include/ptpd/config.h
diff --git a/rtemsbsd/include/ptpd/config.h b/rtemsbsd/include/ptpd/config.h
new file mode 100644
index 00000000..a050a3f9
--- /dev/null
+++ b/rtemsbsd/include/ptpd/config.h
@@ -0,0 +1,248 @@
+/* config.h.  Generated from config.h.in by configure.  */
+/* config.h.in.  Generated from configure.ac by autoheader.  */
+/* build date year-month-day */
+#define BUILD_DATE "20200629"
+/* Define to 1 if you have the <arpa/inet.h> header file. */
+#define HAVE_ARPA_INET_H 1
+/* Define to 1 if you have the `clock_gettime' function. */
+#define HAVE_CLOCK_GETTIME 1
+/* Define to 1 if you have the declaration of `MSG_ERRQUEUE', and to 0 if you
+   don't. */
+#define HAVE_DECL_MSG_ERRQUEUE 0
+/* Define to 1 if you have the declaration of `POSIX_TIMERS_SUPPORTED', and to
+   0 if you don't. */
+#define HAVE_DECL_POSIX_TIMERS_SUPPORTED 0
+/* Define to 1 if you have the <dlfcn.h> header file. */
+#define HAVE_DLFCN_H 1
+/* Define to 1 if you have the `dup2' function. */
+#define HAVE_DUP2 1
+/* Define to 1 if you have the <endian.h> header file. */
+#define HAVE_ENDIAN_H 1
+/* Define to 1 if you have the <fcntl.h> header file. */
+#define HAVE_FCNTL_H 1
+/* Define to 1 if you have the `ftruncate' function. */
+#define HAVE_FTRUNCATE 1
+/* Define to 1 if you have the `gethostbyname2' function. */
+#define HAVE_GETHOSTBYNAME2 1
+/* Define to 1 if you have the <getopt.h> header file. */
+#define HAVE_GETOPT_H 1
+/* Define to 1 if you have the `gettimeofday' function. */
+#define HAVE_GETTIMEOFDAY 1
+/* Define to 1 if you have the `glob' function. */
+#define HAVE_GLOB 1
+/* Define to 1 if you have the <glob.h> header file. */
+#define HAVE_GLOB_H 1
+/* Define to 1 if you have the <ifaddrs.h> header file. */
+#define HAVE_IFADDRS_H 1
+/* Define to 1 if you have the `inet_ntoa' function. */
+#define HAVE_INET_NTOA 1
+/* Define to 1 if you have the <inttypes.h> header file. */
+#define HAVE_INTTYPES_H 1
+/* Define to 1 if you have the <limits.h> header file. */
+#define HAVE_LIMITS_H 1
+/* Define to 1 if you have the <machine/endian.h> header file. */
+#define HAVE_MACHINE_ENDIAN_H 1
+/* Define to 1 if your system has a GNU libc compatible `malloc' function, and
+   to 0 otherwise. */
+#define HAVE_MALLOC 0
+/* Define to 1 if you have the <math.h> header file. */
+#define HAVE_MATH_H 1
+/* Define to 1 if you have the <memory.h> header file. */
+#define HAVE_MEMORY_H 1
+/* Define to 1 if you have the `memset' function. */
+#define HAVE_MEMSET 1
+/* Define to 1 if you have the <netdb.h> header file. */
+#define HAVE_NETDB_H 1
+/* Define to 1 if you have the <netinet/if_ether.h> header file. */
+#define HAVE_NETINET_IF_ETHER_H 1
+/* Define to 1 if you have the <netinet/in.h> header file. */
+#define HAVE_NETINET_IN_H 1
+/* Define to 1 if you have the <netinet/in_systm.h> header file. */
+#define HAVE_NETINET_IN_SYSTM_H 1
+/* Define to 1 if you have the <net/ethernet.h> header file. */
+#define HAVE_NET_ETHERNET_H 1
+/* Define to 1 if you have the <net/if_arp.h> header file. */
+#define HAVE_NET_IF_ARP_H 1
+/* Define to 1 if you have the <net/if.h> header file. */
+#define HAVE_NET_IF_H 1
+/* Define to 1 if you have the `pow' function. */
+#define HAVE_POW 1
+/* Define to 1 if you have the <sched.h> header file. */
+#define HAVE_SCHED_H 1
+/* Define to 1 if you have the `select' function. */
+#define HAVE_SELECT 1
+/* Define to 1 if you have the `kqueue' function. */
+#define HAVE_KQUEUE 1
+/* Define to 1 if you have the `signal' function. */
+#define HAVE_SIGNAL 1
+/* Define to 1 if you have the `socket' function. */
+#define HAVE_SOCKET 1
+/* Define to 1 if stdbool.h conforms to C99. */
+#define HAVE_STDBOOL_H 1
+/* Define to 1 if you have the <stdint.h> header file. */
+#define HAVE_STDINT_H 1
+/* Define to 1 if you have the <stdlib.h> header file. */
+#define HAVE_STDLIB_H 1
+/* Define to 1 if you have the `strchr' function. */
+#define HAVE_STRCHR 1
+/* Define to 1 if you have the `strdup' function. */
+#define HAVE_STRDUP 1
+/* Define to 1 if you have the `strerror' function. */
+#define HAVE_STRERROR 1
+/* Define to 1 if you have the `strftime' function. */
+#define HAVE_STRFTIME 1
+/* Define to 1 if you have the <strings.h> header file. */
+#define HAVE_STRINGS_H 1
+/* Define to 1 if you have the <string.h> header file. */
+#define HAVE_STRING_H 1
+/* Define to 1 if you have the `strtol' function. */
+#define HAVE_STRTOL 1
+/* Define to 1 if `octet' is a member of `struct ether_addr'. */
+#define HAVE_STRUCT_ETHER_ADDR_OCTET 1
+/* Define to 1 if `ifr_index' is a member of `struct ifreq'. */
+#define HAVE_STRUCT_IFREQ_IFR_INDEX 1
+/* Define to 1 if `tai' is a member of `struct ntptimeval'. */
+#define HAVE_STRUCT_NTPTIMEVAL_TAI 1
+/* Define to 1 if you have the <syslog.h> header file. */
+#define HAVE_SYSLOG_H 1
+/* Define to 1 if you have the <sys/cpuset.h> header file. */
+#define HAVE_SYS_CPUSET_H 1
+/* Define to 1 if you have the <sys/ioctl.h> header file. */
+#define HAVE_SYS_IOCTL_H 1
+/* Define to 1 if you have the <sys/param.h> header file. */
+#define HAVE_SYS_PARAM_H 1
+/* Define to 1 if you have the <sys/select.h> header file. */
+#define HAVE_SYS_SELECT_H 1
+/* Define to 1 if you have the <sys/socket.h> header file. */
+#define HAVE_SYS_SOCKET_H 1
+/* Define to 1 if you have the <sys/sockio.h> header file. */
+#define HAVE_SYS_SOCKIO_H 1
+/* Define to 1 if you have the <sys/stat.h> header file. */
+#define HAVE_SYS_STAT_H 1
+/* Define to 1 if you have the <sys/timex.h> header file. */
+#define HAVE_SYS_TIMEX_H 1
+/* Define to 1 if you have the <sys/time.h> header file. */
+#define HAVE_SYS_TIME_H 1
+/* Define to 1 if you have the <sys/types.h> header file. */
+#define HAVE_SYS_TYPES_H 1
+/* Define to 1 if you have the <sys/uio.h> header file. */
+#define HAVE_SYS_UIO_H 1
+/* Define to 1 if you have the <unistd.h> header file. */
+#define HAVE_UNISTD_H 1
+/* Define to 1 if you have the `vprintf' function. */
+#define HAVE_VPRINTF 1
+/* Define to 1 if the system has the type `_Bool'. */
+#define HAVE__BOOL 1
+/* Define to the sub-directory where libtool stores uninstalled libraries. */
+#define LT_OBJDIR ".libs/"
+/* Name of package */
+#define PACKAGE "ptpd"
+/* Define to the address where bug reports for this package should be sent. */
+#define PACKAGE_BUGREPORT "ptpd-bugs at nwtime.org"
+/* Define to the full name of this package. */
+#define PACKAGE_NAME "ptpd"
+/* Define to the full name and version of this package. */
+#define PACKAGE_STRING "ptpd 2.3.2"
+/* Define to the one symbol short name of this package. */
+#define PACKAGE_TARNAME "ptpd"
+/* Define to the home page for this package. */
+#define PACKAGE_URL "http://ptpd.sourceforge.net"
+/* Define to the version of this package. */
+#define PACKAGE_VERSION "2.3.2"
+/* Define as the return type of signal handlers (`int' or `void'). */
+#define RETSIGTYPE void
+/* Define to the type of arg 1 for `select'. */
+#define SELECT_TYPE_ARG1 int
+/* Define to the type of args 2, 3 and 4 for `select'. */
+#define SELECT_TYPE_ARG234 (fd_set *)
+/* Define to the type of arg 5 for `select'. */
+#define SELECT_TYPE_ARG5 (struct timeval *)
+/* Define to 1 if you have the ANSI C header files. */
+#define STDC_HEADERS 1
+/* Define to 1 if you can safely include both <sys/time.h> and <time.h>. */
+#define TIME_WITH_SYS_TIME 1
+/* Version number of package */
+#define VERSION "2.3.2"
+/* Define to rpl_malloc if the replacement function should be used. */
+#define malloc rpl_malloc
2.25.1
