[PATCH] bsps/aarch64: Enable MMU during remaps
Hesham Almatary
heshamelmatary at gmail.com
Tue Apr 18 00:11:29 UTC 2023
On Mon, 17 Apr 2023 at 23:10, Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> The MMU must be enabled during mapping changes and TLB invalidations.
> When this is not the case, TLB updates do not occur correctly in all
> cases. This is especially apparent when changing a block entry to a
> table entry when remapping small memory ranges in an otherwise
> contiguous block.
> bsps/aarch64/shared/mmu/vmsav8-64.c | 2 --
> 1 file changed, 2 deletions(-)
> diff --git a/bsps/aarch64/shared/mmu/vmsav8-64.c b/bsps/aarch64/shared/mmu/vmsav8-64.c
> index 270b9319ad..39173c2fc6 100644
> --- a/bsps/aarch64/shared/mmu/vmsav8-64.c
> +++ b/bsps/aarch64/shared/mmu/vmsav8-64.c
> @@ -57,7 +57,6 @@ rtems_status_code aarch64_mmu_map(
> /* Disable interrupts so they don't run while the MMU is disabled */
Do you need to update that comment?
> _ISR_Local_disable( level );
> - aarch64_mmu_disable();
> sc = aarch64_mmu_map_block(
> (uint64_t *) bsp_translation_table_base,
> 0x0,
> @@ -72,7 +71,6 @@ rtems_status_code aarch64_mmu_map(
> _AARCH64_Data_synchronization_barrier();
> _AARCH64_Instruction_synchronization_barrier();
> - aarch64_mmu_enable();
> _ISR_Local_enable( level );
> 2.30.2
> devel mailing list
> devel at rtems.org
Regards,
Hesham
