[PATCH v2] bsps/aarch64: Enable MMU during remaps
Chris Johns
chrisj at rtems.org
Tue Apr 18 02:33:08 UTC 2023
Looks good. OK to push.
On 18/4/2023 11:41 am, Kinsey Moore wrote:
> The MMU must be enabled during mapping changes and TLB invalidations.
> When this is not the case, TLB updates do not occur correctly in all
> cases. This is especially apparent when changing a block entry to a
> table entry when remapping small memory ranges in an otherwise
> contiguous block.
> bsps/aarch64/shared/mmu/vmsav8-64.c | 7 ++++---
> 1 file changed, 4 insertions(+), 3 deletions(-)
> diff --git a/bsps/aarch64/shared/mmu/vmsav8-64.c b/bsps/aarch64/shared/mmu/vmsav8-64.c
> index 270b9319ad..c426dec900 100644
> --- a/bsps/aarch64/shared/mmu/vmsav8-64.c
> +++ b/bsps/aarch64/shared/mmu/vmsav8-64.c
> @@ -54,10 +54,12 @@ rtems_status_code aarch64_mmu_map(
> return RTEMS_INVALID_ADDRESS;
> - /* Disable interrupts so they don't run while the MMU is disabled */
> + * Disable interrupts so they don't run while the MMU tables are being
> + * modified.
> _ISR_Local_disable( level );
> - aarch64_mmu_disable();
> sc = aarch64_mmu_map_block(
> (uint64_t *) bsp_translation_table_base,
> 0x0,
> @@ -72,7 +74,6 @@ rtems_status_code aarch64_mmu_map(
> _AARCH64_Data_synchronization_barrier();
> _AARCH64_Instruction_synchronization_barrier();
> - aarch64_mmu_enable();
> _ISR_Local_enable( level );
