[rtems-source-builder PATCH] rtems: Add back gsed that was remove by mistake
Frank Kühndel
frank.kuehndel at embedded-brains.de
Tue Apr 18 12:51:44 UTC 2023
Hello Chris,
I indeed looked into the wrong build. Analyzing the correct results
unfortunately reveals that the issue persists in the current build the
way I described it in my earlier mail. I checked
git head "ae00c59541f21d8c459a33774efade80085c9b4a" and MIPS for
* "openSUSE Leap 15.4" -- failed
* "Fedora Linux 37 (Container Image)" -- failed
* "AlmaLinux 8.7 (Stone Smilodon)" -- failed
* "Debian GNU/Linux 11 (bullseye)" -- OK
* "Ubuntu 22.04.2 LTS" -- OK
* "Ubuntu 20.04.5 LTS" -- OK
This is an excerpt from AlmaLinux build log:
../source-builder/sb-set-builder --rtems-version 6 --prefix /opt/
rtems/6 --with_cxx --with_objc --jobs=12 --trace --log
/home/minna/src/rtems6-devtools-mips-6+git.2312.ae00c59541.x86_64_sb-set-builder.log
6/rtems-mips
Python: 3.6.8 (default, Feb 21 2023, 16:34:36) [GCC 8.5.0 20210514
(Red Hat 8.5.0-16)]
checking whether to use expat... yes
checking for libexpat... no
configure: error: expat is missing or unusable
make[2]: *** [Makefile:11803: configure-gdb] Error 1
make[2]: Leaving directory
'/home/minna/src/rtems-source-builder/rtems/build/mipstx39-rtems6-gdb-13.1-x86_64-linux-gnu-1/build'
make[1]: *** [Makefile:1004: all] Error 2
make[1]: Leaving directory
shell cmd failed: /bin/sh -ex
/home/minna/src/rtems-source-builder/rtems/build/mipstx39-rtems6-gdb-13.1-x86_64-linux-gnu-1/do-build
error: building mipstx39-rtems6-gdb-13.1-x86_64-linux-gnu-1
See error report:
rsb-report-mipstx39-rtems6-gdb-13.1-x86_64-linux-gnu-1.txt
Note: In some cases the error appears only in
the complete build log (see --log option)
As I wrote before, this is only to inform you in case your are
interested. I do not need a fix.
Sorry again for the confusion and greetings,
Frank
On 4/18/23 12:16, Frank Kühndel wrote:
> Subject:
> Re: [rtems-source-builder PATCH] rtems: Add back gsed that was remove by
> mistake
> From:
> Frank Kühndel <frank.kuehndel at embedded-brains.de>
> Date:
> 4/18/23, 12:16
> To:
> chrisj at rtems.org, devel at rtems.org
> Hello Chris,
> I mistakenly looked into to the wrong build. I am currently checking
> this again. This is most likely an error of mine.
> Sorry for the confusion
> Frank
> On 4/18/23 11:54, Frank Kühndel wrote:
>> Subject:
>> by mistake
>> From:
>> Date:
>> 4/18/23, 11:54
>> To:
>> Hello Chris,
>> first of all, I do not use MIPS. So I have no troubles if it builds or
>> not. I only want to report an observation from our continuous
>> integration (CI) server.
>> In the past the MIPS builds failed due to the fact that the packages
>> (lib)gmp-devel and (lib)expat-devel where not installed in the
>> containers. A minor nuisance because all other RTEMS tools do build
>> without these. I never understood why in case of MIPS the host must
>> provide native packages given the fact that "gmp" and "expat" are
>> apparently configured in the MIPS "bset".
>> You recent patch thankfully improved the situation. Our CI builds MIPS
>> on Debian and Ubuntu, now. I do not fully understand why but I believe
>> those where the distros where the native gmp-devel packet was needed
>> before your patch.
>> For Alamalinux, Fedora and OpenSUSE the MIPS build still fails
>> (apparently for the same reason they failed before your patch):
>> See error report:
>> This is the end of the build log from Alamlinux 8.7. The error logs
>> from the other distributions are identical.
>> As I indicated before, you do not need to look into this or fix this
>> issue for me as I do not use MIPS and I can easily add the required
>> (lib)expat-devel packet to those containers. I just write because I
>> thought you maybe interested in knowing this detail.
>> Greetings
>> Frank
>> On 4/15/23 00:56, chrisj at rtems.org wrote:
>>> From: Chris Johns<chrisj at rtems.org>
>>> - Build GNU sed for hosts that it is not installed on for the MIPS
>>> tools.
>>> rtems/config/tools/rtems-default-tools.bset | 3 ++-
>>> 1 file changed, 2 insertions(+), 1 deletion(-)
>>> diff --git a/rtems/config/tools/rtems-default-tools.bset
>>> b/rtems/config/tools/rtems-default-tools.bset
>>> index 0291786..35c9235 100644
>>> --- a/rtems/config/tools/rtems-default-tools.bset
>>> +++ b/rtems/config/tools/rtems-default-tools.bset
>>> @@ -6,7 +6,7 @@
>>> # available
>>> %define _internal_gsed_path %{_tmpinternal}
>>> -%defineifnot with_rtems_gmp textproc/gsed-internal
>>> +%defineifnot with_rtems_gsed textproc/gsed-internal
>>> # GNU tools need texinfo for makeinfo to build documentation
>>> %define _internal_texinfo_path %{_tmpinternal}
>>> @@ -21,6 +21,7 @@
>>> %{with_rtems_dtc}
>>> %{with_rtems_expat}
>>> %{with_rtems_gmp}
>>> +%{with_rtems_gsed}
>>> %{with_rtems_texinfo}
>>> %{with_rtems_gdb}
>>> %{with_rtems_binutils}
>>> -- 2.37.1
>> embedded brains GmbH & Co. KG
>> Herr Frank KÜHNDEL
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: frank.kuehndel at embedded-brains.de
>> phone: +49-89-18 94 741 - 23
>> mobile: +49-176-15 22 06 - 11
>> Registergericht: Amtsgericht München
>> Registernummer: HRA 117265
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
>> devel mailing list
>> devel at rtems.org
> Herr Frank KÜHNDEL
> Dornierstr. 4
> 82178 Puchheim
> Germany
> devel mailing list
> devel at rtems.org
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
