[rtems-net-legacy PATCH 2/3] waf: Enable warnings as an option
chrisj at rtems.org
chrisj at rtems.org
Thu Apr 20 05:33:42 UTC 2023
netlegacy.py | 19 +++++++++++++++----
1 file changed, 15 insertions(+), 4 deletions(-)
diff --git a/netlegacy.py b/netlegacy.py
index 9f27ffc..3ce54c6 100644
--- a/netlegacy.py
+++ b/netlegacy.py
@@ -104,6 +104,10 @@ def options(opt):
default='-O2',
dest='optimization',
help='Optimaization level (default: %default)')
+ copts.add_option('--enable-warnings',
+ action='store_true',
+ dest='warnings',
+ help='Enable warnings for all sources (default: %default)')
def bsp_configure(conf, arch_bsp, mandatory=True):
@@ -129,6 +133,11 @@ def bsp_configure(conf, arch_bsp, mandatory=True):
] + [str(conf.path.find_node(i))
for i in includes] + conf.env.IFLAGS
conf.env.OPTIMIZATION = [conf.options.optimization]
+ if conf.options.warnings:
+ warnings = '-Wall'
+ else:
+ warnings = '-w'
+ conf.env.WARNINGS = [warnings]
# BSPs must define:
# - RTEMS_BSP_NETWORK_DRIVER_NAME
@@ -156,16 +165,18 @@ def build(bld):
version_header(bld)
net_config_header(bld)
+ cflags = bld.env.OPTIMIZATION + bld.env.WARNINGS + ['-g']
if ab in bsp_drivers.source:
bld(target='bspobjs',
features='c',
- cflags=bld.env.OPTIMIZATION + ['-g'],
+ cflags=cflags,
includes=bld.env.IFLAGS,
source=bsp_drivers.source[ab])
bld(target='netobjs',
features='c',
+ cflags=cflags,
defines=['IN_HISTORICAL_NETS=1'],
source=netsources.source.network)
@@ -174,14 +185,14 @@ def build(bld):
bld.stlib(target='pppd',
features='c',
+ cflags=cflags,
use=['networking'],
source=netsources.source.pppd)
bld.stlib(target='nfs',
features='c',
+ cflags=cflags,
use=['networking'],
source=netsources.source.nfsclient)
2.37.1
