[PATCH 3/3] bsps/amd64: add a new EFI-based variant of AMD64 BSP
Karel Gardas karel at functional.vision
Fri Apr 21 21:16:11 UTC 2023
The new amd64efi BSP supports:
- multiboot2 boot format. Runs well with GRUB.
- console based on either EFI simple text output or GOP-based framebuffer
- clock based on EFI event/timer API
- early console using either hard-wired PC-AT serial or just memory buffer
- with EFI support disabled the BSP is more or less equivalent to amd64 BSP
  with multiboot2 support
 bsps/x86_64/amd64/clock/eficlock.c            |  109 +
 bsps/x86_64/amd64/console/console.c           |   11 +-
 bsps/x86_64/amd64/console/eficonsole.c        |  250 +
 bsps/x86_64/amd64/console/efigop.c            |  374 ++
 bsps/x86_64/amd64/console/efistop.c           |  107 +
 bsps/x86_64/amd64/console/font_data.h         | 4639 +++++++++++++++++
 bsps/x86_64/amd64/console/outch.c             |  461 ++
 bsps/x86_64/amd64/include/efigop.h            |   46 +
 bsps/x86_64/amd64/include/efistop.h           |   35 +
 bsps/x86_64/amd64/include/multiboot2.h        |  417 ++
 bsps/x86_64/amd64/include/multiboot2impl.h    |   38 +
 bsps/x86_64/amd64/start/bspstart.c            |   16 +-
 bsps/x86_64/amd64/start/efimem.c              |  203 +
 bsps/x86_64/amd64/start/linkcmds              |    6 +-
 bsps/x86_64/amd64/start/multiboot2.c          |  174 +
 bsps/x86_64/amd64/start/start.S               |   72 +
 spec/build/bsps/objefi.yml                    |   17 +
 spec/build/bsps/optefibs.yml                  |   18 +
 spec/build/bsps/opteficonsole.yml             |   29 +
 spec/build/bsps/optefiearlyconsole.yml        |   27 +
 spec/build/bsps/optefigopm.yml                |   20 +
 spec/build/bsps/optefimmapprint.yml           |   18 +
 spec/build/bsps/optefistom.yml                |   21 +
 spec/build/bsps/optmultiboot.yml              |   18 +
 spec/build/bsps/x86_64/amd64/bspamd64efi.yml  |   84 +
 spec/build/bsps/x86_64/amd64/efiabi.yml       |   23 +
 .../build/bsps/x86_64/amd64/optldpagesize.yml |   25 +
 27 files changed, 7253 insertions(+), 5 deletions(-)
 create mode 100644 bsps/x86_64/amd64/clock/eficlock.c
 create mode 100644 bsps/x86_64/amd64/console/eficonsole.c
 create mode 100644 bsps/x86_64/amd64/console/efigop.c
 create mode 100644 bsps/x86_64/amd64/console/efistop.c
 create mode 100644 bsps/x86_64/amd64/console/font_data.h
 create mode 100644 bsps/x86_64/amd64/console/outch.c
 create mode 100644 bsps/x86_64/amd64/include/efigop.h
 create mode 100644 bsps/x86_64/amd64/include/efistop.h
 create mode 100644 bsps/x86_64/amd64/include/multiboot2.h
 create mode 100644 bsps/x86_64/amd64/include/multiboot2impl.h
 create mode 100644 bsps/x86_64/amd64/start/efimem.c
 create mode 100644 bsps/x86_64/amd64/start/multiboot2.c
 create mode 100644 spec/build/bsps/objefi.yml
 create mode 100644 spec/build/bsps/optefibs.yml
 create mode 100644 spec/build/bsps/opteficonsole.yml
 create mode 100644 spec/build/bsps/optefiearlyconsole.yml
 create mode 100644 spec/build/bsps/optefigopm.yml
 create mode 100644 spec/build/bsps/optefimmapprint.yml
 create mode 100644 spec/build/bsps/optefistom.yml
 create mode 100644 spec/build/bsps/optmultiboot.yml
 create mode 100644 spec/build/bsps/x86_64/amd64/bspamd64efi.yml
 create mode 100644 spec/build/bsps/x86_64/amd64/efiabi.yml
 create mode 100644 spec/build/bsps/x86_64/amd64/optldpagesize.yml
diff --git a/bsps/x86_64/amd64/clock/eficlock.c b/bsps/x86_64/amd64/clock/eficlock.c
new file mode 100644
index 0000000000..f5ff9278f6
--- /dev/null
+++ b/bsps/x86_64/amd64/clock/eficlock.c
@@ -0,0 +1,109 @@
+ * Copyright (C) 2023 Karel Gardas
+ * are met:
+#include <bsp.h>
+#include <efi.h>
+#include <stdio.h>
+extern EFI_BOOT_SERVICES *BS;
+static EFI_EVENT clock_event = 0;
+extern void
+Clock_isr( void* );
+#ifndef EFIAPI
+#error "EFIAPI not defined!"
+#endif
+/* no-sse attribute helps with enforcing GCC to generate code which does not use
+   SSE instructions requiring 16 byte alligned access on unaligned data hence
+   producing perfect GP fault. The code with SSE enabled looks:
+EFIAPI void
+efi_clock_tick_notify(EFI_EVENT e, VOID* ctx)
+  10b2ba:       55                      push   rbp
+  10b2bb:       48 89 e5                mov    rbp,rsp
+  10b2be:       57                      push   rdi
+  10b2bf:       56                      push   rsi
+  10b2c0:       48 81 ec a0 00 00 00    sub    rsp,0xa0
+  10b2c7:       8b 02                   mov    eax,DWORD PTR [rdx]
+->10b2c9:       0f 29 b5 50 ff ff ff    movaps XMMWORD PTR [rbp-0xb0],xmm6
+  10b2d0:       0f 29 bd 60 ff ff ff    movaps XMMWORD PTR [rbp-0xa0],xmm7
+  10b2d7:       83 c0 01                add    eax,0x1
+and we get GP @ 10b2c9.
+CAVEAT: This function is to be called from the UEFI which means it needs to callable
+by using MS ABI!
+__attribute__((target("no-sse")))
+EFIAPI void
+efi_clock_tick_notify(EFI_EVENT e, VOID* ctx);
+EFIAPI void
+    Clock_isr(NULL);
+static void
+efi_clock_initialize( void )
+    EFI_STATUS status = BS->CreateEvent
+        (EVT_TIMER | EVT_NOTIFY_SIGNAL,
+         TPL_CALLBACK, (EFI_EVENT_NOTIFY)efi_clock_tick_notify,
+         (VOID*)NULL, &clock_event);
+    if (EFI_ERROR(status)) {
+        printf("EFI: error while creating event in clock initialization!\n");
+    else {
+        printf("EFI: clock event created.\n");
+        /* set periodic timer to signal Clock_isr every 10 milisecond. Value provided
+           here is following UEFI spec in hundred of nanoseconds. */
+        status = BS->SetTimer(clock_event, TimerPeriodic, (10 * 1000 * 10));
+            printf("EFI: error while creating timer in clock initialization!\n");
+            BS->CloseEvent(clock_event);
+        else {
+            printf("EFI: timer for clock event is set.\n");
+#define Clock_driver_support_initialize_hardware() efi_clock_initialize()
+#define CLOCK_DRIVER_USE_DUMMY_TIMECOUNTER
+/* Include shared source clock driver code */
+#include "../../shared/dev/clock/clockimpl.h"
diff --git a/bsps/x86_64/amd64/console/console.c b/bsps/x86_64/amd64/console/console.c
index 5408c57fe7..cc650fcb65 100644
--- a/bsps/x86_64/amd64/console/console.c
+++ b/bsps/x86_64/amd64/console/console.c
@@ -30,6 +30,9 @@
 #include <bsp/console-termios.h>
 #include <rtems/score/cpuimpl.h>
+void
+uart0_output_char(char);
 static uint8_t amd64_uart_get_register(uintptr_t addr, uint8_t i)
   return inport_byte(addr + i);
@@ -61,12 +64,16 @@ const console_device console_device_table[] = {
 const size_t console_device_count = RTEMS_ARRAY_SIZE(console_device_table);
-static void output_char(char c)
+void uart0_output_char(char c)
   rtems_termios_device_context *ctx = console_device_table[0].context;
   ns16550_polled_putchar(ctx, c);
-BSP_output_char_function_type BSP_output_char   = output_char;
+#ifndef BSP_USE_EFI_BOOT_SERVICES
+BSP_output_char_function_type BSP_output_char   = uart0_output_char;
 BSP_polling_getchar_function_type BSP_poll_char = NULL;
+#endif
diff --git a/bsps/x86_64/amd64/console/eficonsole.c b/bsps/x86_64/amd64/console/eficonsole.c
index 0000000000..58bd2b660b
--- /dev/null
+++ b/bsps/x86_64/amd64/console/eficonsole.c
@@ -0,0 +1,250 @@
+ * are met:
+#include <bsp.h>
+#include <efi.h>
+#include <rtems/bspIo.h>
+#include <stdio.h>
+#include <string.h>
+#include <efistop.h>
+#include <efigop.h>
+#include <multiboot2impl.h>
+#ifdef BSP_USE_EFI_BOOT_SERVICES
+extern EFI_HANDLE               IH;
+extern EFI_SYSTEM_TABLE         *ST;
+extern EFI_RUNTIME_SERVICES     *RS;
+extern void uart0_output_char(char c);
+static bool is_efi_console_initialized = false;
+static char output_buffer[4096];
+static int output_buffer_index = 0;
+void
+efi_console_initialize(void);
+EFI_STATUS
+print_gop_info(EFI_GRAPHICS_OUTPUT *gop);
+EFI_STATUS
+check_gop(BOOLEAN verbose);
+static void
+both_output_char(char c);
+static void
+sync_output(void);
+void
+print_ccm_info(EFI_CONSOLE_CONTROL_SCREEN_MODE, BOOLEAN, BOOLEAN);
+void
+print_ccm_info(EFI_CONSOLE_CONTROL_SCREEN_MODE mode, BOOLEAN graphics, BOOLEAN locked)
+    printf("RTEMS: EFI console default mode: ");
+    switch (mode) {
+    case EfiConsoleControlScreenText:
+        printf("text");
+        break;
+    case EfiConsoleControlScreenGraphics:
+        printf("graphics");
+        break;
+    case EfiConsoleControlScreenMaxValue:
+        printf("max value");
+        break;
+    if (graphics) {
+        printf(", graphics is available");
+    if (locked) {
+        printf(", stdin is locked");
+    printf("\n");
+void
+efi_console_initialize( void )
+    EFI_STATUS status;
+    EFI_GUID ConsoleControlGUID = EFI_CONSOLE_CONTROL_PROTOCOL_GUID;
+    EFI_CONSOLE_CONTROL_PROTOCOL *ConsoleControl = NULL;
+    EFI_HANDLE *HandleBuffer = NULL;
+    UINTN HandleCount = 0;
+    BOOLEAN graphics_exists;
+    BOOLEAN locked_stdin;
+    EFI_CONSOLE_CONTROL_SCREEN_MODE mode;
+    BOOLEAN use_text = false;
+    BOOLEAN use_graphic = false;
+    BOOLEAN use_auto = false;
+    int text_mode = -1;
+    int graphic_mode = -1;
+    if (is_efi_console_initialized)
+        return;
+    if (ST == NULL)
+        return;
+    /* try hard to obtain console control */
+    status = ST->BootServices->LocateProtocol(&ConsoleControlGUID, NULL,
+                                              (VOID **)&ConsoleControl);
+        status = ST->BootServices->HandleProtocol( ST->ConsoleOutHandle,
+                                                   &ConsoleControlGUID,
+            status = ST->BootServices->LocateHandleBuffer( ByProtocol,
+                                                           NULL,
+                                                           &HandleCount,
+                                                           &HandleBuffer);
+            if (status == EFI_SUCCESS) {
+                for (int i = 0; i < HandleCount; i++) {
+                    status = ST->BootServices->HandleProtocol( HandleBuffer[i],
+                                                               (VOID*)&ConsoleControl);
+                    if (!EFI_ERROR (status)) {
+                        break;
+                ST->BootServices->FreePool(HandleBuffer);
+    if (strcmp(BSP_EFI_CONSOLE_KIND, "TEXT") == 0) {
+        use_text = true;
+    if (strcmp(BSP_EFI_CONSOLE_KIND, "GRAPHIC") == 0) {
+        use_graphic = true;
+    if (strcmp(BSP_EFI_CONSOLE_KIND, "BOTH") == 0) {
+        use_text = true;
+    if (strcmp(BSP_EFI_CONSOLE_KIND, "AUTO") == 0) {
+        use_auto = true;
+    if (ConsoleControl != NULL) {
+        status = ConsoleControl->GetMode(ConsoleControl, &mode, &graphics_exists, &locked_stdin);
+        if (!EFI_ERROR(status)) {
+            print_ccm_info(mode, graphics_exists, locked_stdin);
+            if (mode == EfiConsoleControlScreenText && use_auto) {
+                use_text = true;
+            if (mode == EfiConsoleControlScreenGraphics && use_auto) {
+        else {
+            /* in case of error from console control, let's use both outputs */
+            use_text = true;
+    else {
+        /* in case of missing console control, let's use both outputs */
+        use_text = true;
+    if (get_boot_arg_int_value(boot_args(), "text_mode", &text_mode) == 0
+        || get_boot_arg_int_value(boot_args(), "graphic_mode", &graphic_mode) == 0) {
+        /* if there is any command-line arg passed to manage console, we give it max
+           priority which means we reset any value set so far. */
+        use_text = false;
+        use_graphic = false;
+    if (get_boot_arg_int_value(boot_args(), "text_mode", &text_mode) == 0) {
+        use_text = true;
+    if (get_boot_arg_int_value(boot_args(), "graphic_mode", &graphic_mode) == 0) {
+    if (use_text)
+        efi_init_text_output(text_mode);
+    if (use_graphic) {
+        efi_init_graphic_output(graphic_mode);
+    if (use_text && use_graphic) {
+        BSP_output_char = both_output_char;
+    else if (use_text) {
+        BSP_output_char = efi_text_output_char;
+    else if (use_graphic) {
+        BSP_output_char = efi_graphic_output_char;
+    sync_output();
+    is_efi_console_initialized = true;
+void
+buffered_output( char c );
+void
+    if (output_buffer_index < (4096 - 1)) {
+        output_buffer[output_buffer_index] = c;
+        output_buffer_index++;
+static void
+both_output_char( char c )
+    efi_text_output_char(c);
+    efi_graphic_output_char(c);
+void
+sync_output()
+    printf("EFI: console sync_output(): there are %d characters in the buffer.\n", output_buffer_index);
+    for (int i = 0; i < output_buffer_index; i++) {
+        BSP_output_char(output_buffer[i]);
+    printf("EFI: console sync_output() done.\n");
+#if (BSP_EFI_EARLY_CONSOLE_KIND == BUFFER)
+BSP_output_char_function_type BSP_output_char   = buffered_output;
+#elif (BSP_EFI_EARLY_CONSOLE_KIND == SERIAL)
+#endif
+BSP_polling_getchar_function_type BSP_poll_char = NULL;
+#endif
diff --git a/bsps/x86_64/amd64/console/efigop.c b/bsps/x86_64/amd64/console/efigop.c
index 0000000000..1369b08962
--- /dev/null
+++ b/bsps/x86_64/amd64/console/efigop.c
@@ -0,0 +1,374 @@
+ * are met:
+#include <bsp.h>
+#include <efi.h>
+#include <rtems/framebuffer.h>
+#include <rtems/fb.h>
+#include <rtems/score/atomic.h>
+#include <rtems/libio.h>
+#include <stdio.h>
+#include <stdlib.h>
+static Atomic_Flag driver_mutex;
+static struct fb_var_screeninfo gopfb_var = {
+                                             .xres = 0,
+                                             .yres = 0,
+                                             .bits_per_pixel = 32
+static struct fb_fix_screeninfo gopfb_fix = {
+                                             .smem_start = NULL,
+                                             .smem_len = 0,
+                                             .type = FB_TYPE_PACKED_PIXELS,
+                                             .visual = FB_VISUAL_TRUECOLOR,
+                                             .line_length = 0
+static EFI_GRAPHICS_OUTPUT*
+find_gop(void);
+static int
+init_gop(EFI_GRAPHICS_OUTPUT*, int);
+static int
+init_fb_from_gop(EFI_GRAPHICS_OUTPUT *gop, struct fb_var_screeninfo* fbvar, struct fb_fix_screeninfo* fbfix);
+extern void rpi_fb_outch(char);
+extern void rpi_video_init(void);
+void
+efi_graphic_output_char(char c)
+    rpi_fb_outch(c);
+rtems_device_driver
+frame_buffer_initialize
+(rtems_device_major_number major,
+ rtems_device_minor_number minor,
+ void *arg)
+    rtems_status_code status;
+    status = rtems_io_register_name(FRAMEBUFFER_DEVICE_0_NAME, major, 0);
+    if (status != RTEMS_SUCCESSFUL) {
+        printf("EFI/GOP: error: can't register /dev/fb0 device.\n");
+        rtems_fatal_error_occurred(status);
+    _Atomic_Flag_clear( &driver_mutex, ATOMIC_ORDER_RELEASE );
+    if (_Atomic_Flag_test_and_set(&driver_mutex, ATOMIC_ORDER_ACQUIRE) != 0) {
+        printf("EFI/GOP: error: can't lock device mutex.\n" );
+        return RTEMS_UNSATISFIED;
+    return RTEMS_SUCCESSFUL;
+frame_buffer_open
+ void *arg)
+    if (gopfb_fix.smem_start == NULL) {
+        printf( "EFI/GOP: framebuffer initialization failed.\n" );
+    memset( (void *) gopfb_fix.smem_start, 255, gopfb_fix.smem_len );
+frame_buffer_close
+ void *arg)
+frame_buffer_read
+ void *arg)
+    rtems_libio_rw_args_t* rw_args = (rtems_libio_rw_args_t*)arg;
+    rw_args->bytes_moved =
+        (( rw_args->offset + rw_args->count) > gopfb_fix.smem_len) ?
+        (gopfb_fix.smem_len - rw_args->offset) : rw_args->count;
+    memcpy( rw_args->buffer,
+            (const void *)(gopfb_fix.smem_start + rw_args->offset),
+            rw_args->bytes_moved);
+frame_buffer_write
+ void *arg)
+        ((rw_args->offset + rw_args->count) > gopfb_fix.smem_len) ?
+    memcpy((void *)(gopfb_fix.smem_start + rw_args->offset),
+           rw_args->buffer,
+frame_buffer_control
+ void *arg)
+    rtems_libio_ioctl_args_t* args = (rtems_libio_ioctl_args_t*)arg;
+    switch (args->command) {
+    case FBIOGET_VSCREENINFO:
+        memcpy(args->buffer, &gopfb_var, sizeof(struct fb_var_screeninfo));
+        args->ioctl_return = 0;
+        break;
+    case FBIOGET_FSCREENINFO:
+        memcpy(args->buffer, &gopfb_fix, sizeof(struct fb_fix_screeninfo));
+        break;
+    case FBIOGETCMAP:
+        /* no palette - truecolor mode */
+        args->ioctl_return = -1;
+    case FBIOPUTCMAP:
+    default:
+int
+efi_init_graphic_output(int hint)
+    EFI_GRAPHICS_OUTPUT* gop = find_gop();
+    if (gop == NULL) {
+        printf("EFI: GOP is not available\n");
+    if (init_gop(gop, hint) < 0) {
+    init_fb_from_gop(gop, &gopfb_var, &gopfb_fix);
+    /* init RPi based character output */
+    rpi_video_init();
+static int
+init_gop(EFI_GRAPHICS_OUTPUT *gop, int hint)
+    if (gop == NULL)
+        return -1;
+    int imax = gop->Mode->MaxMode - 1;
+    if (hint != -1) {
+        /* hint got from command-line does have highest priority */
+        status = gop->SetMode(gop, hint);
+            printf("EFI/GOP: can't set mode to: %d which was set on command line.\n", hint);
+            return -1;
+    else if (strcmp(BSP_EFI_GRAPHICS_OUTPUT_MODE_VALUE, "MAX") == 0) {
+        status = gop->SetMode(gop, imax);
+            printf("EFI/GOP: can't set mode to: %d which should be MAX\n", imax);
+            return -1;
+    else if (strcmp(BSP_EFI_GRAPHICS_OUTPUT_MODE_VALUE, "AUTO") == 0) {
+        status = gop->SetMode(gop, gop->Mode->Mode);
+            printf("EFI/GOP: can't set mode to: %d which should be AUTO (platform preferred value)\n", imax);
+            return -1;
+    else {
+        int vmode = atoi(BSP_EFI_GRAPHICS_OUTPUT_MODE_VALUE);
+        status = gop->SetMode(gop, vmode);
+            printf("EFI/GOP: can't set mode to: %d which is used supplied value.\n", vmode);
+            return -1;
+    return 0;
+static int
+    int i, imax;
+    if (gop == NULL)
+        return -1;
+    imax = gop->Mode->MaxMode;
+    printf("RTEMS: graphic output: current mode: %d, max mode: %d.\n", gop->Mode->Mode, (imax - 1));
+    for (i = 0; i < imax; i++) {
+         EFI_GRAPHICS_OUTPUT_MODE_INFORMATION *Info = NULL;
+         UINTN SizeOfInfo = 0;
+         status = gop->QueryMode(gop, i, &SizeOfInfo, &Info);
+         if (EFI_ERROR(status) && status == EFI_NOT_STARTED) {
+             gop->SetMode(gop, gop->Mode->Mode);
+             printf("ERROR: Bad response from QueryMode: %ld\n", status);
+             continue;
+         printf("%s%d: %dx%d ", memcmp(Info,gop->Mode->Info,sizeof(*Info)) == 0 ? " -> " : "    ", i,
+                Info->HorizontalResolution,
+                Info->VerticalResolution);
+         switch(Info->PixelFormat) {
+             case PixelRedGreenBlueReserved8BitPerColor:
+                 printf("RGBR format, FB @ %p, size: %ld", (void*)gop->Mode->FrameBufferBase, gop->Mode->FrameBufferSize);
+                 break;
+             case PixelBlueGreenRedReserved8BitPerColor:
+                 printf("BGRR format, FB @ %p, size: %ld", (void*)gop->Mode->FrameBufferBase, gop->Mode->FrameBufferSize);
+                 break;
+             case PixelBitMask:
+                 printf("Red:%08x Green:%08x Blue:%08x Reserved:%08x",
+                        Info->PixelInformation.RedMask,
+                        Info->PixelInformation.GreenMask,
+                        Info->PixelInformation.BlueMask,
+                        Info->PixelInformation.ReservedMask);
+                 break;
+             case PixelBltOnly:
+                 printf("(linear fb not available)");
+                 break;
+             default:
+                 printf("(invalid format)");
+                 break;
+        printf(", %d pixels per line\n", Info->PixelsPerScanLine);
+    fbvar->xres = gop->Mode->Info->HorizontalResolution;
+    fbvar->yres = gop->Mode->Info->VerticalResolution;
+    fbfix->smem_start = (void*)gop->Mode->FrameBufferBase;
+    fbfix->smem_len = gop->Mode->FrameBufferSize;
+    fbfix->line_length = gop->Mode->Info->PixelsPerScanLine;
+    return EFI_SUCCESS;
+find_gop()
+    EFI_STATUS status = EFI_SUCCESS;
+    EFI_GRAPHICS_OUTPUT *gop = NULL;
+    EFI_GUID gop_guid = EFI_GRAPHICS_OUTPUT_PROTOCOL_GUID;
+    status = BS->HandleProtocol(ST->ConsoleOutHandle,
+                                &gop_guid,
+                                (VOID **)&gop);
+    if (!EFI_ERROR (status) && gop != NULL) {
+        return gop;
+    status = BS->LocateProtocol(&gop_guid, NULL, (void**)&gop);
+        return gop;
+    // try locating by handle
+    status = BS->LocateHandleBuffer(ByProtocol,
+                                    &gop_guid,
+                                    NULL,
+                                    &HandleCount,
+                                    &HandleBuffer);
+            status = BS->HandleProtocol( HandleBuffer[i],
+                                         &gop_guid,
+                                         (VOID*)&gop);
+                break;
+        BS->FreePool(HandleBuffer);
+        return gop;
+    return NULL;
+void
+rpi_get_var_screen_info(struct fb_var_screeninfo* info)
+    *info = gopfb_var;
+void
+rpi_get_fix_screen_info(struct fb_fix_screeninfo* info)
+    *info = gopfb_fix;
+#endif
diff --git a/bsps/x86_64/amd64/console/efistop.c b/bsps/x86_64/amd64/console/efistop.c
index 0000000000..41eabb541f
--- /dev/null
+++ b/bsps/x86_64/amd64/console/efistop.c
@@ -0,0 +1,107 @@
+ * are met:
+#include <bsp.h>
+#include <efi.h>
+#include <efilib.h>
+#include <stdio.h>
+static void
+print_stop_info(SIMPLE_TEXT_OUTPUT_INTERFACE* stop);
+void
+efi_init_text_output(int hint)
+    int maxval = ST->ConOut->Mode->MaxMode - 1;
+    int curval = ST->ConOut->Mode->Mode;
+    ST->ConOut->Reset(ST->ConOut, true);
+    if (hint != -1) {
+        ST->ConOut->SetMode(ST->ConOut, hint);
+    else if (strcmp(BSP_EFI_SIMPLE_TEXT_OUTPUT_MODE_VALUE, "MAX") == 0) {
+        ST->ConOut->SetMode(ST->ConOut, maxval);
+    else if (strcmp(BSP_EFI_SIMPLE_TEXT_OUTPUT_MODE_VALUE, "AUTO") == 0) {
+        ST->ConOut->SetMode(ST->ConOut, curval);
+    else {
+        ST->ConOut->SetMode(ST->ConOut, atoi(BSP_EFI_SIMPLE_TEXT_OUTPUT_MODE_VALUE));
+    ST->ConOut->EnableCursor(ST->ConOut, TRUE);
+    print_stop_info(ST->ConOut);
+    ST->ConOut->ClearScreen(ST->ConOut);
+void
+efi_text_output_char(char c)
+    char tocpy[2];
+    tocpy[0] = c;
+    tocpy[1] = 0;
+    CHAR16 str[2];
+    cpy8to16(tocpy, str, 2);
+    status = ST->ConOut->TestString(ST->ConOut, str);
+        str[0] = '?';
+    ST->ConOut->OutputString(ST->ConOut, str);
+static void
+    int max_mode = stop->Mode->MaxMode;
+    int current_mode = stop->Mode->Mode;
+    printf("RTEMS: text output: current mode: %d, max mode: %d\n", current_mode, (max_mode - 1));
+    UINTN columns = 0;
+    UINTN rows = 0;
+    for (int i = 0; i < max_mode; i++) {
+        if (current_mode == i)
+            printf(" -> ");
+        else
+            printf("    ");
+        status = stop->QueryMode(stop, i, &columns, &rows);
+            printf("%d. mode: error: can't obtain column x row values.\n", i);
+        else {
+            printf("%d. mode: %ld * %ld\n", i, columns, rows);
+#endif
diff --git a/bsps/x86_64/amd64/console/font_data.h b/bsps/x86_64/amd64/console/font_data.h
index 0000000000..852310cbf9
--- /dev/null
+++ b/bsps/x86_64/amd64/console/font_data.h
@@ -0,0 +1,4639 @@
+ * @file
+ * @ingroup raspberrypi
+ * @brief graphic text console font file
+ * Copyright (c) 2015 Yang Qiao
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE
+#ifndef LIBBSP_ARM_RASPBERRYPI_FONT_DATA_H
+#define LIBBSP_ARM_RASPBERRYPI_FONT_DATA_H
+#define RPI_FONT_CHARS  256
+#define RPI_FONT_WIDTH  8
+#define RPI_FONT_HEIGHT 16
+#define RPI_FONT_SIZE   (RPI_FONT_CHARS * RPI_FONT_HEIGHT)
+static unsigned char rpi_font[RPI_FONT_SIZE] = {
+  /* 0 0x00 '^@' */
+  0x00, /* 00000000 */
+  /* 1 0x01 '^A' */
+  0x7e, /* 01111110 */
+  0x81, /* 10000001 */
+  0xa5, /* 10100101 */
+  0xbd, /* 10111101 */
+  0x99, /* 10011001 */
+  /* 2 0x02 '^B' */
+  0xff, /* 11111111 */
+  0xdb, /* 11011011 */
+  0xc3, /* 11000011 */
+  0xe7, /* 11100111 */
+  /* 3 0x03 '^C' */
+  0x6c, /* 01101100 */
+  0xfe, /* 11111110 */
+  0x7c, /* 01111100 */
+  0x38, /* 00111000 */
+  0x10, /* 00010000 */
+  /* 4 0x04 '^D' */
+  /* 5 0x05 '^E' */
+  0x18, /* 00011000 */
+  0x3c, /* 00111100 */
+  /* 6 0x06 '^F' */
+  /* 7 0x07 '^G' */
+  /* 8 0x08 '^H' */
+  /* 9 0x09 '^I' */
+  0x66, /* 01100110 */
+  0x42, /* 01000010 */
+  /* 10 0x0a '^J' */
+  /* 11 0x0b '^K' */
+  0x1e, /* 00011110 */
+  0x0e, /* 00001110 */
+  0x1a, /* 00011010 */
+  0x32, /* 00110010 */
+  0x78, /* 01111000 */
+  0xcc, /* 11001100 */
+  /* 12 0x0c '^L' */
+  /* 13 0x0d '^M' */
+  0x3f, /* 00111111 */
+  0x33, /* 00110011 */
+  0x30, /* 00110000 */
+  0x70, /* 01110000 */
+  0xf0, /* 11110000 */
+  0xe0, /* 11100000 */
+  /* 14 0x0e '^N' */
+  0x7f, /* 01111111 */
+  0x63, /* 01100011 */
+  0x67, /* 01100111 */
+  0xe6, /* 11100110 */
+  0xc0, /* 11000000 */
+  /* 15 0x0f '^O' */
+  /* 16 0x10 '^P' */
+  0x80, /* 10000000 */
+  0xf8, /* 11111000 */
+  /* 17 0x11 '^Q' */
+  0x02, /* 00000010 */
+  0x06, /* 00000110 */
+  0x3e, /* 00111110 */
+  /* 18 0x12 '^R' */
+  /* 19 0x13 '^S' */
+  /* 20 0x14 '^T' */
+  0x7b, /* 01111011 */
+  0x1b, /* 00011011 */
+  /* 21 0x15 '^U' */
+  0xc6, /* 11000110 */
+  0x60, /* 01100000 */
+  0x0c, /* 00001100 */
+  /* 22 0x16 '^V' */
+  /* 23 0x17 '^W' */
+  /* 24 0x18 '^X' */
+  /* 25 0x19 '^Y' */
+  /* 26 0x1a '^Z' */
+  /* 27 0x1b '^[' */
+  /* 28 0x1c '^\' */
+  /* 29 0x1d '^]' */
+  0x28, /* 00101000 */
+  /* 30 0x1e '^^' */
+  /* 31 0x1f '^_' */
+  /* 32 0x20 ' ' */
+  /* 33 0x21 '!' */
+  /* 34 0x22 '"' */
+  0x24, /* 00100100 */
+  /* 35 0x23 '#' */
+  /* 36 0x24 '$' */
+  0xc2, /* 11000010 */
+  0x86, /* 10000110 */
+  /* 37 0x25 '%' */
+  /* 38 0x26 '&' */
+  0x76, /* 01110110 */
+  0xdc, /* 11011100 */
+  /* 39 0x27 ''' */
+  /* 40 0x28 '(' */
+  /* 41 0x29 ')' */
+  /* 42 0x2a '*' */
+  /* 43 0x2b '+' */
+  /* 44 0x2c ',' */
+  /* 45 0x2d '-' */
+  /* 46 0x2e '.' */
+  /* 47 0x2f '/' */
+  /* 48 0x30 '0' */
+  0xd6, /* 11010110 */
+  /* 49 0x31 '1' */
+  /* 50 0x32 '2' */
+  /* 51 0x33 '3' */
+  /* 52 0x34 '4' */
+  0x1c, /* 00011100 */
+  /* 53 0x35 '5' */
+  0xfc, /* 11111100 */
+  /* 54 0x36 '6' */
+  /* 55 0x37 '7' */
+  /* 56 0x38 '8' */
+  /* 57 0x39 '9' */
+  /* 58 0x3a ':' */
+  /* 59 0x3b ';' */
+  /* 60 0x3c '<' */
+  /* 61 0x3d '=' */
+  /* 62 0x3e '>' */
+  /* 63 0x3f '?' */
+  /* 64 0x40 '@' */
+  0xde, /* 11011110 */
+  /* 65 0x41 'A' */
+  /* 66 0x42 'B' */
+  /* 67 0x43 'C' */
+  /* 68 0x44 'D' */
+  /* 69 0x45 'E' */
+  0x62, /* 01100010 */
+  0x68, /* 01101000 */
+  /* 70 0x46 'F' */
+  /* 71 0x47 'G' */
+  0x3a, /* 00111010 */
+  /* 72 0x48 'H' */
+  /* 73 0x49 'I' */
+  /* 74 0x4a 'J' */
+  /* 75 0x4b 'K' */
+  /* 76 0x4c 'L' */
+  /* 77 0x4d 'M' */
+  0xee, /* 11101110 */
+  /* 78 0x4e 'N' */
+  0xf6, /* 11110110 */
+  0xce, /* 11001110 */
+  /* 79 0x4f 'O' */
+  /* 80 0x50 'P' */
+  /* 81 0x51 'Q' */
+  /* 82 0x52 'R' */
+  /* 83 0x53 'S' */
+  /* 84 0x54 'T' */
+  0x5a, /* 01011010 */
+  /* 85 0x55 'U' */
+  /* 86 0x56 'V' */
+  /* 87 0x57 'W' */
+  /* 88 0x58 'X' */
+  /* 89 0x59 'Y' */
+  /* 90 0x5a 'Z' */
+  /* 91 0x5b '[' */
+  /* 92 0x5c '\' */
+  /* 93 0x5d ']' */
+  /* 94 0x5e '^' */
+  /* 95 0x5f '_' */
+  /* 96 0x60 '`' */
+  /* 97 0x61 'a' */
+  /* 98 0x62 'b' */
+  /* 99 0x63 'c' */
+  /* 100 0x64 'd' */
+  /* 101 0x65 'e' */
+  /* 102 0x66 'f' */
+  0x36, /* 00110110 */
+  /* 103 0x67 'g' */
+  /* 104 0x68 'h' */
+  /* 105 0x69 'i' */
+  /* 106 0x6a 'j' */
+  /* 107 0x6b 'k' */
+  /* 108 0x6c 'l' */
+  /* 109 0x6d 'm' */
+  0xec, /* 11101100 */
+  /* 110 0x6e 'n' */
+  /* 111 0x6f 'o' */
+  /* 112 0x70 'p' */
+  /* 113 0x71 'q' */
+  /* 114 0x72 'r' */
+  /* 115 0x73 's' */
+  /* 116 0x74 't' */
+  /* 117 0x75 'u' */
+  /* 118 0x76 'v' */
+  /* 119 0x77 'w' */
+  /* 120 0x78 'x' */
+  /* 121 0x79 'y' */
+  /* 122 0x7a 'z' */
+  /* 123 0x7b '{' */
+  /* 124 0x7c '|' */
+  /* 125 0x7d '}' */
+  /* 126 0x7e '~' */
+  /* 127 0x7f */
+  /* 128 0x80 */
+  /* 129 0x81 */
+  /* 130 0x82 */
+  /* 131 0x83 */
+  /* 132 0x84 */
+  /* 133 0x85 */
+  /* 134 0x86 */
+  /* 135 0x87 */
+  /* 136 0x88 */
+  /* 137 0x89 */
+  /* 138 0x8a */
+  /* 139 0x8b */
+  /* 140 0x8c */
+  /* 141 0x8d */
+  /* 142 0x8e */
+  /* 143 0x8f */
+  /* 144 0x90 */
+  /* 145 0x91 */
+  0xd8, /* 11011000 */
+  0x6e, /* 01101110 */
+  /* 146 0x92 */
+  /* 147 0x93 */
+  /* 148 0x94 */
+  /* 149 0x95 */
+  /* 150 0x96 */
+  /* 151 0x97 */
+  /* 152 0x98 */
+  /* 153 0x99 */
+  /* 154 0x9a */
+  /* 155 0x9b */
+  /* 156 0x9c */
+  0x64, /* 01100100 */
+  /* 157 0x9d */
+  /* 158 0x9e */
+  0xc4, /* 11000100 */
+  /* 159 0x9f */
+  /* 160 0xa0 */
+  /* 161 0xa1 */
+  /* 162 0xa2 */
+  /* 163 0xa3 */
+  /* 164 0xa4 */
+  /* 165 0xa5 */
+  /* 166 0xa6 */
+  /* 167 0xa7 */
+  /* 168 0xa8 */
+  /* 169 0xa9 */
+  /* 170 0xaa */
+  /* 171 0xab */
+  /* 172 0xac */
+  0x9a, /* 10011010 */
+  /* 173 0xad */
+  /* 174 0xae */
+  /* 175 0xaf */
+  /* 176 0xb0 */
+  0x11, /* 00010001 */
+  0x44, /* 01000100 */
+  /* 177 0xb1 */
+  0x55, /* 01010101 */
+  0xaa, /* 10101010 */
+  /* 178 0xb2 */
+  0xdd, /* 11011101 */
+  0x77, /* 01110111 */
+  /* 179 0xb3 */
+  /* 180 0xb4 */
+  /* 181 0xb5 */
+  /* 182 0xb6 */
+  /* 183 0xb7 */
+  /* 184 0xb8 */
+  /* 185 0xb9 */
+  /* 186 0xba */
+  /* 187 0xbb */
+  /* 188 0xbc */
+  /* 189 0xbd */
+  /* 190 0xbe */
+  /* 191 0xbf */
+  /* 192 0xc0 */
+  0x1f, /* 00011111 */
+  /* 193 0xc1 */
+  /* 194 0xc2 */
+  /* 195 0xc3 */
+  /* 196 0xc4 */
+  /* 197 0xc5 */
+  /* 198 0xc6 */
+  /* 199 0xc7 */
+  0x37, /* 00110111 */
+  /* 200 0xc8 */
+  /* 201 0xc9 */
+  /* 202 0xca */
+  0xf7, /* 11110111 */
+  /* 203 0xcb */
+  /* 204 0xcc */
+  /* 205 0xcd */
+  /* 206 0xce */
+  /* 207 0xcf */
+  /* 208 0xd0 */
+  /* 209 0xd1 */
+  /* 210 0xd2 */
+  /* 211 0xd3 */
+  /* 212 0xd4 */
+  /* 213 0xd5 */
+  /* 214 0xd6 */
+  /* 215 0xd7 */
+  /* 216 0xd8 */
+  /* 217 0xd9 */
+  /* 218 0xda */
+  /* 219 0xdb */
+  /* 220 0xdc */
+  /* 221 0xdd */
+  /* 222 0xde */
+  0x0f, /* 00001111 */
+  /* 223 0xdf */
+  /* 224 0xe0 */
+  /* 225 0xe1 */
+  /* 226 0xe2 */
+  /* 227 0xe3 */
+  /* 228 0xe4 */
+  /* 229 0xe5 */
+  /* 230 0xe6 */
+  /* 231 0xe7 */
+  /* 232 0xe8 */
+  /* 233 0xe9 */
+  /* 234 0xea */
+  /* 235 0xeb */
+  /* 236 0xec */
+  /* 237 0xed */
+  0x03, /* 00000011 */
+  0xf3, /* 11110011 */
+  /* 238 0xee */
+  /* 239 0xef */
+  /* 240 0xf0 */
+  /* 241 0xf1 */
+  /* 242 0xf2 */
+  /* 243 0xf3 */
+  /* 244 0xf4 */
+  /* 245 0xf5 */
+  /* 246 0xf6 */
+  /* 247 0xf7 */
+  /* 248 0xf8 */
+  /* 249 0xf9 */
+  /* 250 0xfa */
+  /* 251 0xfb */
+  /* 252 0xfc */
+  /* 253 0xfd */
+  /* 254 0xfe */
+  /* 255 0xff */
+#endif
diff --git a/bsps/x86_64/amd64/console/outch.c b/bsps/x86_64/amd64/console/outch.c
index 0000000000..3627cc57d8
--- /dev/null
+++ b/bsps/x86_64/amd64/console/outch.c
@@ -0,0 +1,461 @@
+ * @file
+ * @ingroup amd64
+ * @brief displaying characters on the console
+ * NOTE: This file is copied from arm/raspberrypi BSP.
+ *       It is only slightly changed to work with EFI GOP.
+ *       Obvious idea is to refactor whole framebuffer console
+ *       business shared between various BSPs and move that
+ *       properly to bsps/shared and reuse.
+ * based on work by:
+ * Copyright (C) 1998  Eric Valette (valette at crf.canon.fr)
+ *                     Canon Centre Recherche France.
+ *  http://www.rtems.org/license/LICENSE.
+ * Till Straumann <strauman at slac.stanford.edu>, 2003/9:
+ *  - added handling of basic escape sequences (cursor movement
+ *    and erasing; just enough for the line editor 'libtecla' to
+ *    work...)
+#include <bsp.h>
+#include "font_data.h"
+static void wr_cursor(
+  int           r,
+  int           c
+  /* dummy function for now */
+#define TAB_SPACE 4
+#define CONSOLE_BG_COL 0xff
+#define CONSOLE_FG_COL 0x00
+static void          *fb_mem = NULL;
+static unsigned short maxCol;
+static unsigned short maxRow;
+static unsigned short bytes_per_pixel;
+static unsigned int   bytes_per_line;
+static unsigned int   bytes_per_char_line;
+static unsigned char  row;
+static unsigned char  column;
+static unsigned int   nLines;
+static uint32_t       fgx, bgx, eorx;
+static int            rpi_video_initialized;
+static const int video_font_draw_table32[ 16 ][ 4 ] = {
+  { 0x00000000, 0x00000000, 0x00000000, 0x00000000 },
+  { 0x00000000, 0x00000000, 0x00000000, 0x00ffffff },
+  { 0x00000000, 0x00000000, 0x00ffffff, 0x00000000 },
+  { 0x00000000, 0x00000000, 0x00ffffff, 0x00ffffff },
+  { 0x00000000, 0x00ffffff, 0x00000000, 0x00000000 },
+  { 0x00000000, 0x00ffffff, 0x00000000, 0x00ffffff },
+  { 0x00000000, 0x00ffffff, 0x00ffffff, 0x00000000 },
+  { 0x00000000, 0x00ffffff, 0x00ffffff, 0x00ffffff },
+  { 0x00ffffff, 0x00000000, 0x00000000, 0x00000000 },
+  { 0x00ffffff, 0x00000000, 0x00000000, 0x00ffffff },
+  { 0x00ffffff, 0x00000000, 0x00ffffff, 0x00000000 },
+  { 0x00ffffff, 0x00000000, 0x00ffffff, 0x00ffffff },
+  { 0x00ffffff, 0x00ffffff, 0x00000000, 0x00000000 },
+  { 0x00ffffff, 0x00ffffff, 0x00000000, 0x00ffffff },
+  { 0x00ffffff, 0x00ffffff, 0x00ffffff, 0x00000000 },
+  { 0x00ffffff, 0x00ffffff, 0x00ffffff, 0x00ffffff }
+void
+rpi_fb_outch( char c );
+void
+rpi_video_init( void );
+static void scroll( void )
+  int      i, j;      /* Counters */
+  uint8_t *pt_scroll, *pt_bitmap;  /* Pointers on the bit-map  */
+  pt_bitmap = fb_mem;
+  j = 0;
+  pt_bitmap = pt_bitmap + j;
+  pt_scroll = pt_bitmap + bytes_per_char_line;
+  for ( i = j; i < maxRow - 1; i++ ) {
+    memcpy( pt_bitmap, pt_scroll, bytes_per_char_line );
+    pt_bitmap = pt_bitmap + bytes_per_char_line;
+   * Blank characters are displayed on the last line.
+  memset( pt_bitmap, CONSOLE_BG_COL, bytes_per_char_line );
+static void doCRNL(
+  int cr,
+  int nl
+  if ( nl ) {
+    if ( ++row == maxRow ) {
+      scroll();   /* Scroll the screen now */
+      row = maxRow - 1;
+    nLines++;
+  if ( cr )
+    column = 0;
+  /* Move cursor on the next location  */
+  if ( cr || nl ) {
+    wr_cursor( row, column );
+static void advanceCursor( void )
+  if ( ++column == maxCol )
+    doCRNL( 1, 1 );
+  else
+static void gotorc(
+  int r,
+  int c
+  column = c;
+  row = r;
+static void video_drawchars(
+  int           r,
+  int           c,
+  unsigned char ch
+  if ( fb_mem == NULL ) {
+    return;
+  uint8_t *cdat, *dest, *dest0;
+  int      rows, offset;
+  offset = r * bytes_per_char_line + c * bytes_per_pixel * RPI_FONT_WIDTH;
+  dest0 = fb_mem + offset;
+   * only 32-bit per pixel format is supported for now
+  cdat = rpi_font + ch * RPI_FONT_HEIGHT;
+  for ( rows = RPI_FONT_HEIGHT, dest = dest0;
+        rows--; dest += bytes_per_line ) {
+    uint8_t bits = *cdat++;
+    ( (uint32_t *) dest )[ 0 ] =
+      ( video_font_draw_table32
+        [ bits >> 4 ][ 0 ] & eorx ) ^ bgx;
+    ( (uint32_t *) dest )[ 1 ] =
+        [ bits >> 4 ][ 1 ] & eorx ) ^ bgx;
+    ( (uint32_t *) dest )[ 2 ] =
+        [ bits >> 4 ][ 2 ] & eorx ) ^ bgx;
+    ( (uint32_t *) dest )[ 3 ] =
+        [ bits >> 4 ][ 3 ] & eorx ) ^ bgx;
+    ( (uint32_t *) dest )[ 4 ] =
+        [ bits & 15 ][ 0 ] & eorx ) ^ bgx;
+    ( (uint32_t *) dest )[ 5 ] =
+        [ bits & 15 ][ 1 ] & eorx ) ^ bgx;
+    ( (uint32_t *) dest )[ 6 ] =
+        [ bits & 15 ][ 2 ] & eorx ) ^ bgx;
+    ( (uint32_t *) dest )[ 7 ] =
+        [ bits & 15 ][ 3 ] & eorx ) ^ bgx;
+#define ESC ( (char) 27 )
+/* erase current location without moving the cursor */
+#define BLANK ( (char) 0x7f )
+static void videoPutChar( char ch )
+  switch ( ch ) {
+    case '\b': {
+      if ( column )
+        column--;
+      /* Move cursor on the previous location  */
+      return;
+    case '\t': {
+      int i;
+      i = TAB_SPACE - ( column & ( TAB_SPACE - 1 ) );
+      while ( i-- ) {
+        video_drawchars( row, column, ' ' );
+        column += 1;
+        if ( column >= maxCol ) {
+          doCRNL( 1, 1 );
+          return;
+      return;
+    case '\n': {
+      doCRNL( 0, 1 );
+      return;
+    case 7:   {     /* Bell code must be inserted here */
+      return;
+    case '\r': {
+      doCRNL( 1, 0 );
+      return;
+    case BLANK: {
+      return;
+    default: {
+      // *pt_bitmap = (unsigned char)ch | attribute;
+      video_drawchars( row, column, ch );
+      advanceCursor();
+      return;
+/* trivial state machine to handle escape sequences:
+ * KEY:        esc   V    [          DCABHKJ       esc |
+ * STATE:   0 -----> 27 -----> '[' ----------> -1 -----
+ * KEY:     | \other   \ other    \ other         \ other
+ * in state '-1', the DCABHKJ cases are handled
+ * (cursor motion and screen clearing)
+#define DONE ( -1 )
+static int handleEscape(
+  int  oldState,
+  char ch
+  int rval = 0;
+  int ro, co;
+  switch ( oldState ) {
+    case DONE:  /*  means the previous char terminated an ESC sequence... */
+    case 0:
+      if ( 27 == ch ) {
+        rval = 27;   /* START of an ESC sequence */
+      break;
+    case 27:
+      if ( '[' == ch ) {
+        rval = ch;  /* received ESC '[', so far */
+      } else {
+        /* dump suppressed 'ESC'; outch will append the char */
+        videoPutChar( ESC );
+      break;
+    case '[':
+      /* handle 'ESC' '[' sequences here */
+      ro = row;
+      co = column;
+      rval = DONE; /* done */
+      switch ( ch ) {
+        case 'D': /* left */
+          if ( co > 0 )
+            co--;
+          break;
+        case 'C': /* right */
+          if ( co < maxCol )
+            co++;
+          break;
+        case 'A': /* up    */
+          if ( ro > 0 )
+            ro--;
+          break;
+        case 'B': /* down */
+          if ( ro < maxRow )
+            ro++;
+          break;
+        case 'H': /* home */
+          ro = co = 0;
+          break;
+        case 'K': /* clear to end of line */
+          while ( column < maxCol - 1 )
+            videoPutChar( ' ' );
+          videoPutChar( BLANK );
+          break;
+        case 'J':     /* clear to end of screen */
+          while ( ( ( row < maxRow - 1 ) || ( column < maxCol - 1 ) ) )
+          break;
+        default:
+          videoPutChar( '[' );
+          /* DONT move the cursor */
+          ro = -1;
+          rval = 0;
+          break;
+      // /* reset cursor */
+      if ( ro >= 0 )
+        gotorc( ro, co );
+    default:
+      break;
+  return rval;
+static void clear_screen( void )
+  int i, j;
+  for ( j = 0; j < maxRow; j++ ) {
+    for ( i = 0; i < maxCol; i++ ) {
+  column = 0;
+  row = 0;
+void rpi_fb_outch( char c )
+  static int escaped = 0;
+  if ( !( escaped = handleEscape( escaped, c ) ) ) {
+    if ( '\n' == c )
+      videoPutChar( '\r' );
+    videoPutChar( c );
+void rpi_video_init( void )
+  struct fb_var_screeninfo fb_var_info;
+  struct fb_fix_screeninfo fb_fix_info;
+  rpi_get_var_screen_info( &fb_var_info );
+  rpi_get_fix_screen_info( &fb_fix_info );
+  maxCol = fb_var_info.xres / RPI_FONT_WIDTH;
+  maxRow = fb_var_info.yres / RPI_FONT_HEIGHT;
+  bytes_per_pixel = fb_var_info.bits_per_pixel / 8;
+  bytes_per_line = bytes_per_pixel * fb_var_info.xres;
+  bytes_per_char_line = RPI_FONT_HEIGHT * bytes_per_line;
+  fb_mem = RTEMS_DEVOLATILE( void *, fb_fix_info.smem_start );
+  column = 0;
+  row = 0;
+  nLines = 0;
+  fgx = ( CONSOLE_FG_COL << 24 ) |
+        ( CONSOLE_FG_COL << 16 ) |
+        ( CONSOLE_FG_COL << 8 ) |
+        CONSOLE_FG_COL;
+  bgx = ( CONSOLE_BG_COL << 24 ) |
+        ( CONSOLE_BG_COL << 16 ) |
+        ( CONSOLE_BG_COL << 8 ) |
+        CONSOLE_BG_COL;
+  eorx = fgx ^ bgx;
+  clear_screen();
+  rpi_video_initialized = 1;
+/* for old DOS compatibility n-curses type of applications */
+void gotoxy(
+  int x,
+  int y
+int whereX( void );
+int whereY( void );
+void gotoxy(
+  int x,
+  int y
+  gotorc( y, x );
+int whereX( void )
+  return row;
+int whereY( void )
+  return column;
diff --git a/bsps/x86_64/amd64/include/efigop.h b/bsps/x86_64/amd64/include/efigop.h
index 0000000000..0b20cce466
--- /dev/null
+++ b/bsps/x86_64/amd64/include/efigop.h
@@ -0,0 +1,46 @@
+ * are met:
+#include <efi.h>
+int
+efi_init_graphic_output(int);
+void
+efi_graphic_output_char(char);
+/* to support RPi based character output to framebuffer.
+ The functions are declared here in open in order to show if they
+ should not be moved including whole character output to FB somewhere
+ into bsps/shared. */
+void
+rpi_get_var_screen_info(struct fb_var_screeninfo*);
+void
+rpi_get_fix_screen_info(struct fb_fix_screeninfo*);
diff --git a/bsps/x86_64/amd64/include/efistop.h b/bsps/x86_64/amd64/include/efistop.h
index 0000000000..da6203c158
--- /dev/null
+++ b/bsps/x86_64/amd64/include/efistop.h
@@ -0,0 +1,35 @@
+ * are met:
+#include <efi.h>
+void
+efi_init_text_output(int);
+void
+efi_text_output_char(char);
diff --git a/bsps/x86_64/amd64/include/multiboot2.h b/bsps/x86_64/amd64/include/multiboot2.h
index 0000000000..d3f104a18b
--- /dev/null
+++ b/bsps/x86_64/amd64/include/multiboot2.h
@@ -0,0 +1,417 @@
+/*  multiboot2.h - Multiboot 2 header file.  */
+/*  Copyright (C) 1999,2003,2007,2008,2009,2010  Free Software Foundation, Inc.
+ *  Permission is hereby granted, free of charge, to any person obtaining a copy
+ *  of this software and associated documentation files (the "Software"), to
+ *  deal in the Software without restriction, including without limitation the
+ *  rights to use, copy, modify, merge, publish, distribute, sublicense, and/or
+ *  sell copies of the Software, and to permit persons to whom the Software is
+ *  furnished to do so, subject to the following conditions:
+ *  The above copyright notice and this permission notice shall be included in
+ *  all copies or substantial portions of the Software.
+ *  THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ *  IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ *  FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL ANY
+ *  DEVELOPER OR DISTRIBUTOR BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ *  LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ *  FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS
+ *  IN THE SOFTWARE.
+#ifndef _MULTIBOOT2_HEADER_H_
+#define _MULTIBOOT2_HEADER_H_
+/* How many bytes from the start of the file we search for the header.  */
+#define MULTIBOOT_SEARCH 32768
+#define MULTIBOOT_HEADER_ALIGN 8
+/* The magic field should contain this.  */
+#define MULTIBOOT2_HEADER_MAGIC 0xe85250d6
+/* This should be in %eax.  */
+#define MULTIBOOT2_BOOTLOADER_MAGIC 0x36d76289
+/* Alignment of multiboot modules.  */
+#define MULTIBOOT_MOD_ALIGN 0x00001000
+/* Alignment of the multiboot info structure.  */
+#define MULTIBOOT_INFO_ALIGN 0x00000008
+/* Flags set in the 'flags' member of the multiboot header.  */
+#define MULTIBOOT_TAG_ALIGN                  8
+#define MULTIBOOT_TAG_TYPE_END               0
+#define MULTIBOOT_TAG_TYPE_CMDLINE           1
+#define MULTIBOOT_TAG_TYPE_BOOT_LOADER_NAME  2
+#define MULTIBOOT_TAG_TYPE_MODULE            3
+#define MULTIBOOT_TAG_TYPE_BASIC_MEMINFO     4
+#define MULTIBOOT_TAG_TYPE_BOOTDEV           5
+#define MULTIBOOT_TAG_TYPE_MMAP              6
+#define MULTIBOOT_TAG_TYPE_VBE               7
+#define MULTIBOOT_TAG_TYPE_FRAMEBUFFER       8
+#define MULTIBOOT_TAG_TYPE_ELF_SECTIONS      9
+#define MULTIBOOT_TAG_TYPE_APM               10
+#define MULTIBOOT_TAG_TYPE_EFI32             11
+#define MULTIBOOT_TAG_TYPE_EFI64             12
+#define MULTIBOOT_TAG_TYPE_SMBIOS            13
+#define MULTIBOOT_TAG_TYPE_ACPI_OLD          14
+#define MULTIBOOT_TAG_TYPE_ACPI_NEW          15
+#define MULTIBOOT_TAG_TYPE_NETWORK           16
+#define MULTIBOOT_TAG_TYPE_EFI_MMAP          17
+#define MULTIBOOT_TAG_TYPE_EFI_BS            18
+#define MULTIBOOT_TAG_TYPE_EFI32_IH          19
+#define MULTIBOOT_TAG_TYPE_EFI64_IH          20
+#define MULTIBOOT_TAG_TYPE_LOAD_BASE_ADDR    21
+#define MULTIBOOT_HEADER_TAG_END  0
+#define MULTIBOOT_HEADER_TAG_INFORMATION_REQUEST  1
+#define MULTIBOOT_HEADER_TAG_ADDRESS  2
+#define MULTIBOOT_HEADER_TAG_ENTRY_ADDRESS  3
+#define MULTIBOOT_HEADER_TAG_CONSOLE_FLAGS  4
+#define MULTIBOOT_HEADER_TAG_FRAMEBUFFER  5
+#define MULTIBOOT_HEADER_TAG_MODULE_ALIGN  6
+#define MULTIBOOT_HEADER_TAG_EFI_BS  7
+#define MULTIBOOT_HEADER_TAG_ENTRY_ADDRESS_EFI64  9
+#define MULTIBOOT_HEADER_TAG_RELOCATABLE  10
+#define MULTIBOOT_ARCHITECTURE_I386  0
+#define MULTIBOOT_ARCHITECTURE_MIPS32  4
+#define MULTIBOOT_HEADER_TAG_OPTIONAL 1
+#define MULTIBOOT_LOAD_PREFERENCE_NONE 0
+#define MULTIBOOT_LOAD_PREFERENCE_LOW 1
+#define MULTIBOOT_LOAD_PREFERENCE_HIGH 2
+#define MULTIBOOT_CONSOLE_FLAGS_CONSOLE_REQUIRED 1
+#define MULTIBOOT_CONSOLE_FLAGS_EGA_TEXT_SUPPORTED 2
+#ifndef __ASSEMBLER__
+typedef unsigned char multiboot_uint8_t;
+typedef unsigned short multiboot_uint16_t;
+typedef unsigned int multiboot_uint32_t;
+typedef unsigned long long multiboot_uint64_t;
+struct multiboot_header
+  /* Must be MULTIBOOT_MAGIC - see above.  */
+  multiboot_uint32_t magic;
+  /* ISA */
+  multiboot_uint32_t architecture;
+  /* Total header length.  */
+  multiboot_uint32_t header_length;
+  /* The above fields plus this one must equal 0 mod 2^32. */
+  multiboot_uint32_t checksum;
+struct multiboot_header_tag
+  multiboot_uint16_t type;
+  multiboot_uint16_t flags;
+  multiboot_uint32_t size;
+struct multiboot_header_tag_information_request
+  multiboot_uint32_t requests[0];
+struct multiboot_header_tag_address
+  multiboot_uint32_t header_addr;
+  multiboot_uint32_t load_addr;
+  multiboot_uint32_t load_end_addr;
+  multiboot_uint32_t bss_end_addr;
+struct multiboot_header_tag_entry_address
+  multiboot_uint32_t entry_addr;
+struct multiboot_header_tag_console_flags
+  multiboot_uint32_t console_flags;
+struct multiboot_header_tag_framebuffer
+  multiboot_uint32_t width;
+  multiboot_uint32_t height;
+  multiboot_uint32_t depth;
+struct multiboot_header_tag_module_align
+struct multiboot_header_tag_relocatable
+  multiboot_uint32_t min_addr;
+  multiboot_uint32_t max_addr;
+  multiboot_uint32_t align;
+  multiboot_uint32_t preference;
+struct multiboot_color
+  multiboot_uint8_t red;
+  multiboot_uint8_t green;
+  multiboot_uint8_t blue;
+struct multiboot_mmap_entry
+  multiboot_uint64_t addr;
+  multiboot_uint64_t len;
+#define MULTIBOOT_MEMORY_AVAILABLE 1
+#define MULTIBOOT_MEMORY_RESERVED 2
+#define MULTIBOOT_MEMORY_ACPI_RECLAIMABLE 3
+#define MULTIBOOT_MEMORY_NVS 4
+#define MULTIBOOT_MEMORY_BADRAM 5
+  multiboot_uint32_t type;
+  multiboot_uint32_t zero;
+typedef struct multiboot_mmap_entry multiboot_memory_map_t;
+struct multiboot_tag
+struct multiboot_tag_string
+  char string[0];
+struct multiboot_tag_module
+  multiboot_uint32_t mod_start;
+  multiboot_uint32_t mod_end;
+  char cmdline[0];
+struct multiboot_tag_basic_meminfo
+  multiboot_uint32_t mem_lower;
+  multiboot_uint32_t mem_upper;
+struct multiboot_tag_bootdev
+  multiboot_uint32_t biosdev;
+  multiboot_uint32_t slice;
+  multiboot_uint32_t part;
+struct multiboot_tag_mmap
+  multiboot_uint32_t entry_size;
+  multiboot_uint32_t entry_version;
+  struct multiboot_mmap_entry entries[0];
+struct multiboot_vbe_info_block
+  multiboot_uint8_t external_specification[512];
+struct multiboot_vbe_mode_info_block
+  multiboot_uint8_t external_specification[256];
+struct multiboot_tag_vbe
+  multiboot_uint16_t vbe_mode;
+  multiboot_uint16_t vbe_interface_seg;
+  multiboot_uint16_t vbe_interface_off;
+  multiboot_uint16_t vbe_interface_len;
+  struct multiboot_vbe_info_block vbe_control_info;
+  struct multiboot_vbe_mode_info_block vbe_mode_info;
+struct multiboot_tag_framebuffer_common
+  multiboot_uint64_t framebuffer_addr;
+  multiboot_uint32_t framebuffer_pitch;
+  multiboot_uint32_t framebuffer_width;
+  multiboot_uint32_t framebuffer_height;
+  multiboot_uint8_t framebuffer_bpp;
+#define MULTIBOOT_FRAMEBUFFER_TYPE_INDEXED 0
+#define MULTIBOOT_FRAMEBUFFER_TYPE_RGB 1
+#define MULTIBOOT_FRAMEBUFFER_TYPE_EGA_TEXT 2
+  multiboot_uint8_t framebuffer_type;
+  multiboot_uint16_t reserved;
+  struct multiboot_tag_framebuffer_common common;
+  union
+    struct
+      multiboot_uint16_t framebuffer_palette_num_colors;
+      struct multiboot_color framebuffer_palette[0];
+    struct
+      multiboot_uint8_t framebuffer_red_field_position;
+      multiboot_uint8_t framebuffer_red_mask_size;
+      multiboot_uint8_t framebuffer_green_field_position;
+      multiboot_uint8_t framebuffer_green_mask_size;
+      multiboot_uint8_t framebuffer_blue_field_position;
+      multiboot_uint8_t framebuffer_blue_mask_size;
+struct multiboot_tag_elf_sections
+  multiboot_uint32_t num;
+  multiboot_uint32_t entsize;
+  multiboot_uint32_t shndx;
+  char sections[0];
+struct multiboot_tag_apm
+  multiboot_uint16_t version;
+  multiboot_uint16_t cseg;
+  multiboot_uint32_t offset;
+  multiboot_uint16_t cseg_16;
+  multiboot_uint16_t dseg;
+  multiboot_uint16_t cseg_len;
+  multiboot_uint16_t cseg_16_len;
+  multiboot_uint16_t dseg_len;
+struct multiboot_tag_efi32
+  multiboot_uint32_t pointer;
+struct multiboot_tag_efi64
+  multiboot_uint64_t pointer;
+struct multiboot_tag_smbios
+  multiboot_uint8_t major;
+  multiboot_uint8_t minor;
+  multiboot_uint8_t reserved[6];
+  multiboot_uint8_t tables[0];
+struct multiboot_tag_old_acpi
+  multiboot_uint8_t rsdp[0];
+struct multiboot_tag_new_acpi
+struct multiboot_tag_network
+  multiboot_uint8_t dhcpack[0];
+struct multiboot_tag_efi_mmap
+  multiboot_uint32_t descr_size;
+  multiboot_uint32_t descr_vers;
+  multiboot_uint8_t efi_mmap[0];
+struct multiboot_tag_efi32_ih
+struct multiboot_tag_efi64_ih
+struct multiboot_tag_load_base_addr
+  multiboot_uint32_t load_base_addr;
+#endif // __ASSEMBLER__
+#endif // _MULTIBOOT2_HEADER_H_
diff --git a/bsps/x86_64/amd64/include/multiboot2impl.h b/bsps/x86_64/amd64/include/multiboot2impl.h
index 0000000000..cda9337ae4
--- /dev/null
+++ b/bsps/x86_64/amd64/include/multiboot2impl.h
@@ -0,0 +1,38 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * are met:
+void
+process_multiboot2_info(void);
+int
+uefi_bootservices_running(void);
+const char*
+boot_args(void);
+int
+get_boot_arg_int_value(const char*, const char*, int*);
diff --git a/bsps/x86_64/amd64/start/bspstart.c b/bsps/x86_64/amd64/start/bspstart.c
index d1e1e4b2f2..e0e70f97bb 100644
--- a/bsps/x86_64/amd64/start/bspstart.c
+++ b/bsps/x86_64/amd64/start/bspstart.c
@@ -28,9 +28,21 @@
 #include <bsp/bootcard.h>
 #include <libcpu/page.h>
 #include <bsp/irq-generic.h>
+#if defined(BSP_USE_EFI_BOOT_SERVICES) && !defined(BSP_MULTIBOOT_SUPPORT)
+#error "RTEMS amd64efi BSP requires multiboot2 support!"
+#endif
 void bsp_start(void)
-  paging_init();
-  bsp_interrupt_initialize();
+#ifdef BSP_MULTIBOOT_SUPPORT
+    process_multiboot2_info();
+    if (!uefi_bootservices_running()) {
+#endif
+        paging_init();
+        bsp_interrupt_initialize();
+#endif
diff --git a/bsps/x86_64/amd64/start/efimem.c b/bsps/x86_64/amd64/start/efimem.c
index 0000000000..a6ec076a63
--- /dev/null
+++ b/bsps/x86_64/amd64/start/efimem.c
@@ -0,0 +1,203 @@
+ * are met:
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#include <efi.h>
+#include <stdio.h>
+extern Heap_Control *RTEMS_Malloc_Heap;
+void bsp_memory_heap_extend(void);
+static UINT32 total_pages = 0;
+static UINT32 allocated_pages = 0;
+static UINT32 usable_pages = 0;
+static EFI_PHYSICAL_ADDRESS physBuf;
+static int error = 0;
+static int extension_steps = 0;
+#ifdef BSP_EFI_MMAP_PRINTOUT
+static const char*
+efi_memory_type(EFI_MEMORY_TYPE type);
+#endif
+void
+efi_memory_heap_extend( void );
+static UINT64
+heap_size(void)
+    return RTEMS_Malloc_Heap->stats.size;
+static UINT64
+allocate_biggest_block( void )
+    UINT64 sz = 0;
+    EFI_MEMORY_DESCRIPTOR *map = 0, *p = 0;
+    UINTN key = 0, dsz = 0;
+    UINT32 dver = 0;
+    EFI_STATUS status = 0;
+    int i, ndesc = 0;
+    UINT64 to_alloc_pages = 0;
+    bool first_run = false;
+    if (total_pages == 0)
+        first_run = true;
+    // let's see available RAM
+    status = BS->GetMemoryMap(&sz, 0, &key, &dsz, &dver);
+    if (status != EFI_BUFFER_TOO_SMALL) {
+        printf("EFI: Can't determine memory map size\n");
+        return 0;
+    map = malloc(sz);
+    if (map == NULL) {
+        printf("EFI: Can't allocate memory map backing\n");
+        return 0;
+    status = BS->GetMemoryMap(&sz, map, &key, &dsz, &dver);
+        printf("EFI: Can't read memory map\n");
+        free(map);
+        return 0;
+    ndesc = sz / dsz;
+    if (first_run)
+        printf("%23s %12s %8s\n", "Type", "Physical", "#Pages");
+#endif
+    for (i = 0, p = map; i < ndesc;
+         i++, p = NextMemoryDescriptor(p, dsz)) {
+        if (first_run) {
+            printf("%23s %012jx %08jx\n", efi_memory_type(p->Type),
+                   (uintmax_t)p->PhysicalStart, (uintmax_t)p->NumberOfPages);
+#endif
+            if (p->Type != EfiReservedMemoryType)
+                total_pages = total_pages + p->NumberOfPages;
+            if (p->Type == EfiConventionalMemory) {
+                usable_pages = usable_pages + p->NumberOfPages;
+            if (to_alloc_pages < p->NumberOfPages)
+                to_alloc_pages = p->NumberOfPages;
+    status = ST->BootServices->AllocatePages(AllocateAnyPages, EfiLoaderData, to_alloc_pages, &physBuf );
+        /* on some UEFI implementations it is not possible to allocate biggest available block
+           for whatever reasons. In that case, let's go wild and attempt to allocate
+           half of it */
+        error++;
+        status = BS->AllocatePages(AllocateAnyPages, EfiLoaderData, (to_alloc_pages / 2), &physBuf );
+            printf("EFI can't allocate: %lu pages nor half of the amount.\n", to_alloc_pages);
+            free(map);
+            return 0;
+        else {
+            to_alloc_pages = to_alloc_pages / 2;
+    allocated_pages = allocated_pages + to_alloc_pages;
+    sz = to_alloc_pages * 4096;
+    uintptr_t es = 0;
+    es = _Heap_Extend( RTEMS_Malloc_Heap, (void *)physBuf, sz, 0 );
+    free(map);
+    return es;
+void efi_memory_heap_extend( void )
+    int i;
+    UINT64 asz = 0;
+    UINT64 oldsz, newsz = 0;
+    oldsz = heap_size();
+    for (i = 0; i < 1024; i++) {
+        /* let's try 1k alloc attempts */
+        asz = allocate_biggest_block();
+        if (asz == 0)
+            break;
+        extension_steps++;
+    newsz = heap_size();
+    printf("EFI: Total memory: %u pages, %u megabytes\n", total_pages, (total_pages * 4 / 1024));
+    printf("EFI: Usable memory: %u pages, %u megabytes\n", usable_pages, (usable_pages * 4 / 1024));
+    printf("EFI: Allocated memory: %u pages, %u megabytes\n", allocated_pages, (allocated_pages * 4 / 1024));
+    printf("RTEMS: Heap extended in %u steps with %u steps failed.\n", extension_steps, error);
+    uint64_t s = newsz - oldsz;
+    printf("RTEMS: Heap extended by %lu pages, %lu megabytes\n", (s / 4096), ((s / 1024) / 1024));
+static const char*
+    switch (type) {
+    case EfiReservedMemoryType:
+        return "Reserved";
+    case EfiLoaderCode:
+        return "LoaderCode";
+    case EfiLoaderData:
+        return "LoaderData";
+    case EfiBootServicesCode:
+        return "BootServicesCode";
+    case EfiBootServicesData:
+        return "BootServicesData";
+    case EfiRuntimeServicesCode:
+        return "RuntimeServicesCode";
+    case EfiRuntimeServicesData:
+        return "RuntimeServicesData";
+    case EfiConventionalMemory:
+        return "ConventionalMemory";
+    case EfiUnusableMemory:
+        return "UnusableMemory";
+    case EfiACPIReclaimMemory:
+        return "ACPIReclaimMemory";
+    case EfiACPIMemoryNVS:
+        return "ACPIMemoryNVS";
+    case EfiMemoryMappedIO:
+        return "MemoryMappedIO";
+    case EfiMemoryMappedIOPortSpace:
+        return "MemoryMappedIOPortSpace";
+    case EfiPalCode:
+        return "PalCode";
+    case EfiPersistentMemory:
+        return "PersistentMemory";
+    default:
+        return "Unknown Type";
+#endif
diff --git a/bsps/x86_64/amd64/start/linkcmds b/bsps/x86_64/amd64/start/linkcmds
index c7bd54279b..b0de91f160 100644
--- a/bsps/x86_64/amd64/start/linkcmds
+++ b/bsps/x86_64/amd64/start/linkcmds
@@ -28,13 +28,15 @@ RamBase = DEFINED(RamBase)    ? RamBase   :
 /* XXX: Defaulting to 1GiB.
 RamSize = DEFINED(RamSize)    ? RamSize   :
-          DEFINED(_RamSize)   ? _RamSize  : 0x40000000;
+        /* DEFINED(_RamSize)   ? _RamSize  : 0x2000000;*/ /* 32MB */
+        DEFINED(_RamSize)   ? _RamSize  : 0x1000000; /* 16MB */
 RamEnd = RamBase + RamSize;
 SECTIONS
   /* Read-only sections, merged into text segment: */
   PROVIDE (__executable_start = SEGMENT_START("text-segment", 0x00100000)); . = SEGMENT_START("text-segment", 0x00100000) + SIZEOF_HEADERS;
+/*  .multiboot2_header          : { *(.multiboot2_header) }*/
   .interp         : { *(.interp) }
   .note.gnu.build-id : { *(.note.gnu.build-id) }
   .hash           : { *(.hash) }
@@ -88,6 +90,7 @@ SECTIONS
 .plt.sec        : { *(.plt.sec) }
   .text           :
+    KEEP (*(.multiboot2_header))
     *(.text.unlikely .text.*_unlikely .text.unlikely.*)
     *(.text.exit .text.exit.*)
     *(.text.startup .text.startup.*)
@@ -236,6 +239,7 @@ SECTIONS
     *(SORT_BY_NAME (SORT_BY_ALIGNMENT (.noinit*)))
+  . = ALIGN(64);
   .rtemsstack (NOLOAD) :
     *(SORT(.rtemsstack.*))
diff --git a/bsps/x86_64/amd64/start/multiboot2.c b/bsps/x86_64/amd64/start/multiboot2.c
index 0000000000..4dce74834c
--- /dev/null
+++ b/bsps/x86_64/amd64/start/multiboot2.c
@@ -0,0 +1,174 @@
+ * are met:
+#include <bsp.h>
+#include <inttypes.h>
+#include <multiboot2.h>
+#include <rtems/score/heap.h>
+#include <efi.h>
+#include <stdio.h>
+extern void
+efi_console_initialize( void );
+extern void
+efi_memory_heap_extend(void);
+#endif
+extern int _multiboot2_magic;
+extern void* _multiboot2_info_ptr;
+static int already_processed = 0;
+#endif
+static int bootservices_running = 0;
+static char multiboot_boot_args[256];
+void
+process_multiboot2_info()
+    struct multiboot_tag *tag;
+    unsigned size;
+    ST = 0;
+    RS = 0;
+    BS = 0;
+#endif
+    if (already_processed)
+        return;
+    if (_multiboot2_magic == MULTIBOOT2_BOOTLOADER_MAGIC) {
+        if ((*(unsigned*)_multiboot2_info_ptr) & 7) {
+            printf("Multiboot2 info @ %p, unaligned mbi: 0x%x\n", _multiboot2_info_ptr, *(unsigned*)_multiboot2_info_ptr);
+        else {
+            size = *(unsigned*)_multiboot2_info_ptr;
+            printf("Multiboot2 info @ %p, size 0x%x\n", _multiboot2_info_ptr, size);
+            for (tag = (struct multiboot_tag *) (_multiboot2_info_ptr + 8);
+                 tag->type != MULTIBOOT_TAG_TYPE_END;
+                 tag = (struct multiboot_tag *) ((multiboot_uint8_t *) tag + ((tag->size + 7) & ~7))) {
+                switch (tag->type) {
+                case MULTIBOOT_TAG_TYPE_CMDLINE:
+                    printf("Multiboot2 booting arguments: `%s', args len: %d\n",
+                      ((struct multiboot_tag_string *) tag)->string,
+                      ((struct multiboot_tag_string *) tag)->size);
+                    strncpy(multiboot_boot_args, ((struct multiboot_tag_string*)tag)->string, ((struct multiboot_tag_string*)tag)->size);
+                    break;
+                case MULTIBOOT_TAG_TYPE_BOOT_LOADER_NAME:
+                    printf("Multiboot2 loader name: `%s'\n", ((struct multiboot_tag_string *) tag)->string);
+                    break;
+                case MULTIBOOT_TAG_TYPE_FRAMEBUFFER:
+                    struct multiboot_tag_framebuffer* fbtag = (struct multiboot_tag_framebuffer*)tag;
+                    uint64_t fbbase = fbtag->common.framebuffer_addr;
+		    printf("Multiboot2 framebuffer @ %p, resolution: %dx%d, pitch/bpp: %d/%d, type: %d\n",
+                           (void*)fbbase, fbtag->common.framebuffer_width, fbtag->common.framebuffer_height,
+				    fbtag->common.framebuffer_pitch, fbtag->common.framebuffer_bpp,
+				    fbtag->common.framebuffer_type);
+                    break;
+                case MULTIBOOT_TAG_TYPE_EFI64:
+                    printf("EFI64 system table @ 0x%llx\n", ((struct multiboot_tag_efi64 *) tag)->pointer);
+                    ST = ((EFI_SYSTEM_TABLE*)((struct multiboot_tag_efi64 *) tag)->pointer);
+                    BS = ST->BootServices;
+                    RS = ST->RuntimeServices;
+                    efi_console_initialize();
+		    efi_memory_heap_extend();
+                    break;
+                case MULTIBOOT_TAG_TYPE_EFI_BS:
+                    printf("GRUB: EFI boot services running.\n");
+                    bootservices_running = 1;
+                    break;
+                case MULTIBOOT_TAG_TYPE_EFI64_IH:
+                    printf("EFI: 64bit image handle: 0x%llx\n", ((struct multiboot_tag_efi64_ih *) tag)->pointer);
+                    IH = (EFI_HANDLE)((struct multiboot_tag_efi64_ih *) tag)->pointer;
+		    break;
+#endif
+    else {
+        printf("So while not being booted by multiboot2, let's see what's in its magic then?: %dx\n", _multiboot2_magic);
+#endif /* BSP_MULTIBOOT_SUPPORT */
+int
+uefi_bootservices_running()
+    return bootservices_running;
+const char*
+boot_args()
+    return multiboot_boot_args;
+int
+get_boot_arg_int_value(const char* boot_args, const char* arg, int* val)
+    int len_arg = strlen(arg);
+    int len_try = strlen(boot_args) - len_arg;
+    int len_bootargs = strlen(boot_args);
+    char num[10];
+    for (int i = 0; i < len_try; i++) {
+        if (strncmp(&(boot_args[i]), arg, len_arg) == 0) {
+            i = i + len_arg + 1;
+            for (int j = 0; j < 10; j++) {
+                if (boot_args[i + j] != ' ' && i + j < len_bootargs)
+                    num[j] = boot_args[i + j];
+                else {
+                    num[j] = 0;
+                    *val = atoi(num);
+                    return 0;
+    return -1;
diff --git a/bsps/x86_64/amd64/start/start.S b/bsps/x86_64/amd64/start/start.S
index e1a50e05db..e1812e5410 100644
--- a/bsps/x86_64/amd64/start/start.S
+++ b/bsps/x86_64/amd64/start/start.S
@@ -1,6 +1,7 @@
  * Copyright (C) 2018 embedded brains GmbH
@@ -25,6 +26,12 @@
+#include <bspopts.h>
+#endif
 	.text
 	.section	.text._start,"ax", at progbits
 	.p2align 4,,15
@@ -36,6 +43,71 @@ _start:
 	subq	$8, %rsp
 	.cfi_def_cfa_offset 16
 	xorl	%edi, %edi
+        mov    %eax, _multiboot2_magic
+        mov    %rbx, _multiboot2_info_ptr
+#endif
 	movabsq	$boot_card, %rax
 	call	*%rax
 	.cfi_endproc
+multiboot2:
+        ret
+_multiboot2_start:
+	jmp	_start
+	.text
+	.section	.multiboot2_header
+	.p2align	4,,15
+multiboot2_header_start:
+        .long	MULTIBOOT2_HEADER_MAGIC
+        .long 	MULTIBOOT_ARCHITECTURE_I386
+	.long 	multiboot2_header_end - multiboot2_header_start
+        .long   -(MULTIBOOT2_HEADER_MAGIC + MULTIBOOT_ARCHITECTURE_I386 + (multiboot2_header_end - multiboot2_header_start))
+efi_bootservices_start:
+        .short  MULTIBOOT_HEADER_TAG_EFI_BS
+        .short  0
+        .long   efi_bootservices_end - efi_bootservices_start
+efi_bootservices_end:
+efi64_entry_start:
+        .short  MULTIBOOT_HEADER_TAG_ENTRY_ADDRESS_EFI64
+        .short  0
+        .long   efi64_entry_end - efi64_entry_start
+        .long   _start /* directly copied from resulting ELF */
+        /* padding to 8 byte tags allignment */
+        .long   0
+efi64_entry_end:
+info_requests_start:
+        .short  MULTIBOOT_HEADER_TAG_INFORMATION_REQUEST
+        .short  0
+        .long   info_requests_end - info_requests_start
+        .long   MULTIBOOT_TAG_TYPE_EFI64
+        .long   MULTIBOOT_TAG_TYPE_CMDLINE
+        .long   MULTIBOOT_TAG_TYPE_EFI_BS
+#else
+	.long	0
+#endif
+        .long   0
+info_requests_end:
+        /* header end*/
+        .short  MULTIBOOT_HEADER_TAG_END
+        .short  0
+        .long   8
+multiboot2_header_end:
+        .data
+        .global  _multiboot2_magic
+_multiboot2_magic:
+        .long   0
+        .data
+        .global  _multiboot2_info_ptr
+_multiboot2_info_ptr:
+        .quad   0
+#endif
diff --git a/spec/build/bsps/objefi.yml b/spec/build/bsps/objefi.yml
index 0000000000..63f522c8b0
--- /dev/null
+++ b/spec/build/bsps/objefi.yml
@@ -0,0 +1,17 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2023 Karel Gardas
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+- bsps/shared/freebsd/stand/efi/include
+- bsps/shared/freebsd/stand/efi/include/amd64
+install: []
+links: []
+source:
+- bsps/shared/freebsd/stand/efi/libefi/libefi.c
+- bsps/shared/freebsd/stand/efi/libefi/wchar.c
+type: build
diff --git a/spec/build/bsps/optefibs.yml b/spec/build/bsps/optefibs.yml
index 0000000000..ba7900f9ce
--- /dev/null
+++ b/spec/build/bsps/optefibs.yml
@@ -0,0 +1,18 @@
+actions:
+- get-boolean: null
+- env-assign: null
+- define-condition: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: true
+description: |
+  Enable use of EFI boot services.
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_USE_EFI_BOOT_SERVICES
+type: build
diff --git a/spec/build/bsps/opteficonsole.yml b/spec/build/bsps/opteficonsole.yml
index 0000000000..5a6ab676cc
--- /dev/null
+++ b/spec/build/bsps/opteficonsole.yml
@@ -0,0 +1,29 @@
+actions:
+- get-string: null
+- define: null
+- script: |
+    kinds = ["TEXT", "GRAPHIC", "BOTH", "AUTO"]
+    if value not in kinds:
+       conf.fatal("Preferred EFI console '{}' is not one of {}".format(value, kinds))
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: AUTO
+description: |
+  Select preferred EFI console. Possible values are TEXT, GRAPHIC, BOTH and AUTO. The TEXT here will instruct RTEMS to use EFI simple text output protocol. By default
+  EFI also forwards such text output to configured serial port. Details depends on the target platform EFI configuration.
+  The GRAPHIC instructs RTEMS to use EFI graphics output protocol. Advantage of it
+  in comparison with TEXT is that it is available also in the time when boot services
+  are already finished. BOTH tells RTEMS to mirror its output to both TEXT and GRAPHIC. This only
+  applies to platforms where both options are supported. The option which is not supported
+  on target platform is ignored in the RTEMS runtime and only available option is used. Finally AUTO tells RTEMS to use output console
+  preferred by the target platform configuration. In case RTEMS is not able to retrieve EFI console control protocol interface, then BOTH
+  is used instead of AUTO.
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_EFI_CONSOLE_KIND
+type: build
diff --git a/spec/build/bsps/optefiearlyconsole.yml b/spec/build/bsps/optefiearlyconsole.yml
index 0000000000..274e7eab05
--- /dev/null
+++ b/spec/build/bsps/optefiearlyconsole.yml
@@ -0,0 +1,27 @@
+actions:
+- get-string: null
+- script: |
+    kinds = ["SERIAL", "BUFFER"]
+       conf.fatal("Preferred EFI early console '{}' is not one of {}".format(value, kinds))
+    conf.define("BUFFER", "1", False)
+    conf.define("SERIAL", "2", False)
+- define-unquoted: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: BUFFER
+description: |
+  Select preferred EFI early printout console. Possible values here
+  are SERIAL and BUFFER. In case of SERIAL, the tty0/com1 will be used
+  for early printout. In case of BUFFER, all prints will be buffered
+  and once real EFI console is initialized, then whole buffer will be
+  copied to it.
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_EFI_EARLY_CONSOLE_KIND
+type: build
diff --git a/spec/build/bsps/optefigopm.yml b/spec/build/bsps/optefigopm.yml
index 0000000000..845447234a
--- /dev/null
+++ b/spec/build/bsps/optefigopm.yml
@@ -0,0 +1,20 @@
+actions:
+- get-string: null
+- define: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: AUTO
+description: |
+  Define EFI graphics output protocol mode value. Use MAX to select maximum
+  available mode or AUTO to allow automatic selection based on the platform
+  preference. Otherwise use positive integer number to select desired graphics
+  protocol mode which you can get from graphics protocol mode list.
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_EFI_GRAPHICS_OUTPUT_MODE_VALUE
+type: build
diff --git a/spec/build/bsps/optefimmapprint.yml b/spec/build/bsps/optefimmapprint.yml
index 0000000000..b7ef7fcdd2
--- /dev/null
+++ b/spec/build/bsps/optefimmapprint.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: false
+description: |
+  Print EFI memory map on boot.
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_EFI_MMAP_PRINTOUT
+type: build
diff --git a/spec/build/bsps/optefistom.yml b/spec/build/bsps/optefistom.yml
new file mode 100644
index 0000000000..c98a5172ef
--- /dev/null
+++ b/spec/build/bsps/optefistom.yml
@@ -0,0 +1,21 @@
+actions:
+- get-string: null
+- define: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: AUTO
+description: |
+  Define EFI simple text output protocol mode value. Use MAX to select maximum
+  preference. Otherwise use positive integer number to select desired simple
+  text output protocol mode which you can get from simple text protocol mode
+  list.
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_EFI_SIMPLE_TEXT_OUTPUT_MODE_VALUE
+type: build
diff --git a/spec/build/bsps/optmultiboot.yml b/spec/build/bsps/optmultiboot.yml
index 0000000000..369804b591
--- /dev/null
+++ b/spec/build/bsps/optmultiboot.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: true
+description: |
+  Enable multiboot2 support in the startup assembly.
+enabled-by: true
+format: '{}'
+links: []
+name: BSP_MULTIBOOT_SUPPORT
+type: build
diff --git a/spec/build/bsps/x86_64/amd64/bspamd64efi.yml b/spec/build/bsps/x86_64/amd64/bspamd64efi.yml
index 0000000000..4fcfb5d8e1
--- /dev/null
+++ b/spec/build/bsps/x86_64/amd64/bspamd64efi.yml
@@ -0,0 +1,84 @@
+arch: x86_64
+bsp: amd64efi
+build-type: bsp
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+enabled-by: true
+family: amd64
+includes:
+install:
+- destination: ${BSP_INCLUDEDIR}
+  source:
+  - bsps/x86_64/amd64/include/apic.h
+  - bsps/x86_64/amd64/include/bsp.h
+  - bsps/x86_64/amd64/include/clock.h
+  - bsps/x86_64/amd64/include/pic.h
+  - bsps/x86_64/amd64/include/start.h
+- destination: ${BSP_LIBDIR}
+  source:
+  - bsps/x86_64/amd64/start/linkcmds
+links:
+- role: build-dependency
+  uid: ../../obj
+  uid: ../../objirq
+  uid: ../../objmem
+  uid: ../../opto2
+  uid: efiabi
+  uid: start
+  uid: ../grp
+  uid: ../../optmultiboot
+  uid: ../../opteficonsole
+  uid: ../../optefiearlyconsole
+  uid: ../../optefistom
+  uid: ../../optefigopm
+  uid: ../../optefimmapprint
+  uid: ../../optefibs
+  uid: ../../bspopts
+  uid: optldpagesize
+  uid: ../../objefi
+source:
+- bsps/shared/cache/nocache.c
+- bsps/shared/dev/btimer/btimer-cpucounter.c
+- bsps/shared/dev/getentropy/getentropy-cpucounter.c
+- bsps/shared/dev/serial/console-termios-init.c
+- bsps/shared/dev/serial/console-termios.c
+- bsps/shared/irq/irq-default-handler.c
+- bsps/shared/start/bspfatal-default.c
+- bsps/shared/start/bspreset-empty.c
+- bsps/shared/start/gettargethash-default.c
+- bsps/shared/start/sbrk.c
+- bsps/x86_64/amd64/clock/eficlock.c
+- bsps/x86_64/amd64/console/eficonsole.c
+- bsps/x86_64/amd64/console/efistop.c
+- bsps/x86_64/amd64/console/efigop.c
+- bsps/x86_64/amd64/console/outch.c
+- bsps/x86_64/amd64/console/console.c
+- bsps/x86_64/amd64/interrupts/idt.c
+- bsps/x86_64/amd64/interrupts/isr_handler.S
+- bsps/x86_64/amd64/interrupts/pic.c
+- bsps/x86_64/amd64/start/bspstart.c
+- bsps/x86_64/amd64/start/multiboot2.c
+- bsps/x86_64/amd64/start/efimem.c
+- bsps/x86_64/amd64/start/page.c
+type: build
diff --git a/spec/build/bsps/x86_64/amd64/efiabi.yml b/spec/build/bsps/x86_64/amd64/efiabi.yml
index 0000000000..ccf1260879
--- /dev/null
+++ b/spec/build/bsps/x86_64/amd64/efiabi.yml
@@ -0,0 +1,23 @@
+actions:
+- get-string: null
+- split: null
+- env-append: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value:
+  - -fshort-wchar
+  - -maccumulate-outgoing-args
+  - -fno-stack-protector
+  - -fno-stack-check
+  - -mno-red-zone
+  - -mcmodel=large
+description: |
+  ABI flags
+enabled-by: true
+links: []
+name: ABI_FLAGS
+type: build
diff --git a/spec/build/bsps/x86_64/amd64/optldpagesize.yml b/spec/build/bsps/x86_64/amd64/optldpagesize.yml
index 0000000000..f445eae606
--- /dev/null
+++ b/spec/build/bsps/x86_64/amd64/optldpagesize.yml
@@ -0,0 +1,25 @@
+actions:
+- get-integer: null
+- assert-uint32: null
+- env-assign: null
+- set-value: -Wl,-z,max-page-size=${LD_MAX_PAGE_SIZE:#010x}
+- substitute: null
+- env-append: LDFLAGS
+- env-append: PKGCONFIG_LDFLAGS
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: 4096
+description: |
+  Set the value of max-page-size parameter for the GNU linker.
+  By default on x86_64 the linker is using 2MB page size which is
+  too big for creating correctly formed and later recognized multiboot2
+  binaries. Default value 4k used here is working well for the purpose.
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: LD_MAX_PAGE_SIZE
+type: build
2.25.1
