[PATCH 1/4] sb/path: Handle unicode filenames in a source path
chrisj at rtems.org
chrisj at rtems.org
Sat Apr 22 05:23:36 UTC 2023
The change leaves the encoding in that currently exists because
I cannot remember why it is there. If an encoding error happens
return the same path to see if it will work.
source-builder/sb/path.py | 26 ++++++++++++++++++++------
1 file changed, 20 insertions(+), 6 deletions(-)
diff --git a/source-builder/sb/path.py b/source-builder/sb/path.py
index d36e12a..d9e926e 100644
--- a/source-builder/sb/path.py
+++ b/source-builder/sb/path.py
@@ -71,6 +71,20 @@ def shell(path):
path = path.replace('//', '/')
return path
+def host_encode(dpath):
+ '''Encoding the path was present in the RSB however on a ZFS pool I am
+ seeing a failure with a go test in gcc:
+ gcc/testsuite/go.test/test/fixedbugs/issue27836.dir
+ Not encoding works however I am not sure why the encoding was added
+ so the following keeps the encoding and falls back to not encoded
+ if there is an error.0
+ try:
+ return host(dpath).encode('utf8')
+ except:
+ pass
+ return dpath
def basename(path):
path = shell(path)
return shell(os.path.basename(host(path)))
@@ -189,11 +203,11 @@ def removeall(path):
# get to the max path length on Windows.
def _isdir(path):
- hpath = host(path).encode('utf8')
+ hpath = host_encode(path)
return os.path.isdir(hpath) and not os.path.islink(hpath)
def _remove_node(path):
if not os.path.islink(hpath) and not os.access(hpath, os.W_OK):
os.chmod(hpath, stat.S_IWUSR)
if _isdir(path):
@@ -216,7 +230,7 @@ def removeall(path):
_remove_node(dir)
path = shell(path)
if os.path.exists(hpath):
_remove(path)
@@ -317,11 +331,11 @@ def get_size(path, depth = -1):
def _isdir(path):
def _node_size(path):
size = 0
if not os.path.islink(hpath):
size = os.path.getsize(hpath)
@@ -345,7 +359,7 @@ def get_size(path, depth = -1):
return size
path = shell(path)
size = 0
2.37.1
