[PATCH v3 1/3] cpukit/flash: Add API for Flash devices
Kinsey Moore
kinsey.moore at oarcorp.com
Mon Apr 24 03:25:23 UTC 2023
Great, if you could add a note to that IOCTL to that effect before commit, that'd be great since consumers shouldn't rely on it to alter their consumption of the API. Otherwise, looks good to me!
Kinsey
On Apr 23, 2023, at 21:45, Aaron Nyholm <aaron.nyholm at unfoldedeffective.com<mailto:aaron.nyholm at unfoldedeffective.com>> wrote:
Yes, it is purely informational. It just returns the 3-byte JEDEC ID.
Regards,
Aaron.
------- Original Message -------
On Monday, April 24th, 2023 at 12:35 PM, Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
I noticed that there is provision here to pass through the JEDEC ID from the physical device (obtained by a JEDEC parameter page read, ONFI parameter page read, or other mechanism).
Is this intended to be purely informational?
Kinsey
On Thu, Apr 20, 2023 at 2:23 AM <aaron.nyholm at unfoldedeffective.com> wrote:
From: Aaron Nyholm <aaron.nyholm at southerninnovation.com>
cpukit/dev/flash/flashdev.c | 849 ++++++++++++++++++++++++++++
cpukit/include/dev/flash/flashdev.h | 458 +++++++++++++++
spec/build/cpukit/librtemscpu.yml | 4 +
3 files changed, 1311 insertions(+)
create mode 100644 cpukit/dev/flash/flashdev.c
create mode 100644 cpukit/include/dev/flash/flashdev.h
diff --git a/cpukit/dev/flash/flashdev.c b/cpukit/dev/flash/flashdev.c
new file mode 100644
index 0000000000..03343f015f
--- /dev/null
+++ b/cpukit/dev/flash/flashdev.c
@@ -0,0 +1,849 @@
+ * Copyright (C) 2023 Aaron Nyholm
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <dev/flash/flashdev.h>
+#include <rtems/imfs.h>
+#include <rtems/score/assert.h>
+#include <errno.h>
+#include <fcntl.h>
+#include <stdlib.h>
+#include <string.h>
+#include <unistd.h>
+#define RTEMS_FLASHDEV_REGION_ALLOC_FULL 0xFFFFFFFFUL
+#define RTEMS_FLASHDEV_REGION_UNDEFINED 0xFFFFFFFFUL
+#define RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH 32
+static int rtems_flashdev_do_init(
+ rtems_flashdev *flash,
+ void ( *destroy )( rtems_flashdev *flash )
+static int rtems_flashdev_ioctl_erase(
+ rtems_libio_t *iop,
+ void *arg
+static off_t rtems_flashdev_get_region_offset(
+static size_t rtems_flashdev_get_region_size(
+static int rtems_flashdev_ioctl_set_region(
+ void *arg
+static int rtems_flashdev_ioctl_create_region(
+ rtems_flashdev_region *region_in
+static int rtems_flashdev_ioctl_update_region(
+static int rtems_flashdev_ioctl_clear_region(
+static uint32_t rtems_flashdev_ioctl_jedec_id(
+static uint32_t rtems_flashdev_ioctl_flash_type(
+ void *arg
+static int rtems_flashdev_ioctl_pageinfo_offset(
+ void *arg
+static int rtems_flashdev_ioctl_pageinfo_index(
+ void *arg
+static int rtems_flashdev_ioctl_page_count(
+ void *arg
+static int rtems_flashdev_ioctl_write_block_size(
+ void *arg
+static int rtems_flashdev_get_addr(
+ size_t count,
+ off_t *addr
+static int rtems_flashdev_update_and_return(
+ int status,
+ size_t count,
+ off_t new_offset
+static uint32_t rtems_flashdev_find_unalloced_region(
+ rtems_flashdev_region_table *region_table
+static uint32_t rtems_flashdev_set_region(
+ rtems_flashdev_region_table *region_table,
+ int index
+static uint32_t rtems_flashdev_unset_region(
+ int index
+static uint32_t rtems_flashdev_check_allocation(
+ int index
+static uint32_t rtems_flashdev_get_region_index(
+ return (uint32_t)iop->data0;
+static int rtems_flashdev_is_region_defined(
+ return (rtems_flashdev_get_region_index( iop ) != RTEMS_FLASHDEV_REGION_UNDEFINED);
+static void rtems_flashdev_set_region_index(
+ uint32_t index
+ iop->data0 = index;
+static int rtems_flashdev_check_offset_region(
+ off_t offset
+ if ( ( rtems_flashdev_is_region_defined( iop ) ) &&
+ ( offset > rtems_flashdev_get_region_size( flash, iop ) ) ) {
+ rtems_set_errno_and_return_minus_one( EINVAL );
+ return 0;
+static void rtems_flashdev_obtain( rtems_flashdev *flash )
+ rtems_recursive_mutex_lock( &flash->mutex );
+static void rtems_flashdev_release( rtems_flashdev *flash )
+ rtems_recursive_mutex_unlock( &flash->mutex );
+static ssize_t rtems_flashdev_read(
+ void *buffer,
+ size_t count
+ rtems_flashdev *flash = IMFS_generic_get_context_by_iop( iop );
+ off_t addr;
+ int status;
+ if ( flash->read == NULL ) {
+ return 0;
+ /* Get flash address */
+ status = rtems_flashdev_get_addr( flash, iop, count, &addr );
+ if ( status == -1 ) {
+ return status;
+ /* Read flash */
+ rtems_flashdev_obtain( flash );
+ status = ( *flash->read )( flash, addr, count, buffer );
+ rtems_flashdev_release( flash );
+ /* Update offset and return */
+ return rtems_flashdev_update_and_return( iop, status, count, addr + count );
+static ssize_t rtems_flashdev_write(
+ const void *buffer,
+ size_t count
+ off_t addr;
+ int status;
+ if ( flash->write == NULL ) {
+ return 0;
+ return status;
+ /* Write to flash */
+ status = ( *flash->write )( flash, addr, count, buffer );
+static int rtems_flashdev_ioctl(
+ ioctl_command_t command,
+ void *arg
+ int err = 0;
+ switch ( command ) {
+ case RTEMS_FLASHDEV_IOCTL_OBTAIN:
+ err = 0;
+ break;
+ case RTEMS_FLASHDEV_IOCTL_RELEASE:
+ err = 0;
+ break;
+ case RTEMS_FLASHDEV_IOCTL_JEDEC_ID:
+ *( (uint32_t *) arg ) = rtems_flashdev_ioctl_jedec_id( flash );
+ err = 0;
+ break;
+ case RTEMS_FLASHDEV_IOCTL_ERASE:
+ err = rtems_flashdev_ioctl_erase( flash, iop, arg );
+ break;
+ case RTEMS_FLASHDEV_IOCTL_REGION_SET:
+ err = rtems_flashdev_ioctl_set_region( flash, iop, arg );
+ break;
+ case RTEMS_FLASHDEV_IOCTL_REGION_UNSET:
+ err = rtems_flashdev_ioctl_clear_region( flash, iop );
+ break;
+ case RTEMS_FLASHDEV_IOCTL_TYPE:
+ err = rtems_flashdev_ioctl_flash_type( flash, arg );
+ break;
+ case RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET:
+ err = rtems_flashdev_ioctl_pageinfo_offset( flash, arg );
+ break;
+ case RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX:
+ err = rtems_flashdev_ioctl_pageinfo_index( flash, arg );
+ break;
+ case RTEMS_FLASHDEV_IOCTL_PAGE_COUNT:
+ err = rtems_flashdev_ioctl_page_count( flash, arg );
+ break;
+ case RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE:
+ err = rtems_flashdev_ioctl_write_block_size( flash, arg );
+ break;
+ if ( err != 0 ) {
+ rtems_set_errno_and_return_minus_one( err );
+ } else {
+ return 0;
+static off_t rtems_flashdev_lseek(
+ off_t offset,
+ int whence
+ off_t tmp_offset;
+ if ( offset < 0 ) {
+ switch ( whence ) {
+ case SEEK_CUR:
+ tmp_offset = iop->offset + offset;
+ break;
+ case SEEK_SET:
+ tmp_offset = offset;
+ break;
+ case SEEK_END:
+ default:
+ if ( ( rtems_flashdev_is_region_defined(iop) ) &&
+ ( tmp_offset > rtems_flashdev_get_region_size( flash, iop ) ) ) {
+ iop->offset = tmp_offset;
+ return iop->offset;
+static int rtems_flashdev_close( rtems_libio_t *iop )
+ rtems_flashdev_ioctl_clear_region( flash, iop );
+ return rtems_filesystem_default_close( iop );
+static int rtems_flashdev_open(
+ const char *path,
+ int oflag,
+ mode_t mode
+ int ret = rtems_filesystem_default_open( iop, path, oflag, mode );
+ rtems_flashdev_set_region_index(iop, RTEMS_FLASHDEV_REGION_UNDEFINED);
+ return ret;
+static const rtems_filesystem_file_handlers_r rtems_flashdev_handler = {
+ .open_h = rtems_flashdev_open,
+ .close_h = rtems_flashdev_close,
+ .read_h = rtems_flashdev_read,
+ .write_h = rtems_flashdev_write,
+ .ioctl_h = rtems_flashdev_ioctl,
+ .lseek_h = rtems_flashdev_lseek,
+ .fstat_h = IMFS_stat,
+ .ftruncate_h = rtems_filesystem_default_ftruncate,
+ .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
+ .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
+ .fcntl_h = rtems_filesystem_default_fcntl,
+ .kqfilter_h = rtems_filesystem_default_kqfilter,
+ .mmap_h = rtems_filesystem_default_mmap,
+ .poll_h = rtems_filesystem_default_poll,
+ .readv_h = rtems_filesystem_default_readv,
+ .writev_h = rtems_filesystem_default_writev };
+static void rtems_flashdev_node_destroy( IMFS_jnode_t *node )
+ rtems_flashdev *flash;
+ flash = IMFS_generic_get_context_by_node( node );
+ ( *flash->destroy )( flash );
+ IMFS_node_destroy_default( node );
+static const IMFS_node_control
+ rtems_flashdev_node_control = IMFS_GENERIC_INITIALIZER(
+ &rtems_flashdev_handler,
+ IMFS_node_initialize_generic,
+ rtems_flashdev_node_destroy
+int rtems_flashdev_register( rtems_flashdev *flash, const char *flash_path )
+ int rv;
+ rtems_flashdev_region_table *table = flash->region_table;
+ int alloc_array_len;
+ rv = IMFS_make_generic_node( flash_path,
+ S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO,
+ &rtems_flashdev_node_control,
+ flash );
+ if ( rv != 0 ) {
+ if (table != NULL) {
+ alloc_array_len = table->max_regions/RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH +
+ ((table->max_regions%RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH) != 0);
+ for
+ int i = 0;
+ i < alloc_array_len;
+ i++
+ table->bit_allocator[i] = 0;
+ return rv;
+ rtems_recursive_mutex_init( &flash->mutex, "RTEMS_FLASHDEV Flash" );
+ flash->destroy = destroy;
+ flash->read = NULL;
+ flash->write = NULL;
+ flash->erase = NULL;
+ flash->jedec_id = NULL;
+ flash->flash_type = NULL;
+ flash->page_info_by_offset = NULL;
+ flash->page_info_by_index = NULL;
+ flash->page_count = NULL;
+ flash->write_block_size = NULL;
+ flash->region_table = NULL;
+ return 0;
+void rtems_flashdev_destroy( rtems_flashdev *flash )
+ rtems_recursive_mutex_destroy( &flash->mutex );
+void rtems_flashdev_destroy_and_free( rtems_flashdev *flash )
+ if ( flash == NULL ) {
+ return;
+ rtems_recursive_mutex_destroy( &( flash->mutex ) );
+ free( flash );
+ flash = NULL;
+ return;
+int rtems_flashdev_init( rtems_flashdev *flash )
+ memset( flash, 0, sizeof( *flash ) );
+ return rtems_flashdev_do_init( flash, rtems_flashdev_destroy );
+rtems_flashdev *rtems_flashdev_alloc_and_init( size_t size )
+ rtems_flashdev *flash = NULL;
+ if ( size >= sizeof( *flash ) ) {
+ flash = calloc( 1, size );
+ if ( flash != NULL ) {
+ int rv;
+ rv = rtems_flashdev_do_init( flash, rtems_flashdev_destroy_and_free );
+ if ( rv != 0 ) {
+ free( flash );
+ return NULL;
+ return flash;
+ size_t count,
+ off_t *addr
+ off_t new_offset;
+ /* Check address is in valid region */
+ new_offset = iop->offset + count;
+ if (rtems_flashdev_check_offset_region(flash, iop, new_offset)) {
+ return -1;
+ /* Get address for operation */
+ if ( !rtems_flashdev_is_region_defined( iop ) ) {
+ *addr = iop->offset;
+ } else {
+ *addr = ( iop->offset + rtems_flashdev_get_region_offset( flash, iop ) );
+ return 0;
+ int status,
+ size_t count,
+ off_t new_offset
+ if ( status == 0 ) {
+ iop->offset = new_offset;
+ return count;
+ } else {
+ rtems_set_errno_and_return_minus_one( status );
+ void *arg
+ rtems_flashdev_region *erase_args_1;
+ off_t check_offset;
+ int status;
+ if ( flash->erase == NULL ) {
+ return 0;
+ erase_args_1 = (rtems_flashdev_region *) arg;
+ /* Check erasing valid region */
+ check_offset = erase_args_1->offset + erase_args_1->size;
+ if ( rtems_flashdev_is_region_defined( iop ) && (
+ rtems_flashdev_check_offset_region(flash, iop, check_offset) ||
+ ( erase_args_1->offset <
+ rtems_flashdev_get_region_offset( flash, iop ) ) ) ) {
+ /* Erase flash */
+ status = ( *flash->erase )( flash, erase_args_1->offset, erase_args_1->size );
+ return status;
+ void *arg
+ rtems_flashdev_region *region_in;
+ region_in = (rtems_flashdev_region *) arg;
+ if (flash->region_table == NULL) {
+ rtems_set_errno_and_return_minus_one( ENOMEM );
+ if ( !rtems_flashdev_is_region_defined( iop ) &&
+ rtems_flashdev_find_unalloced_region(table)
+ == RTEMS_FLASHDEV_REGION_ALLOC_FULL)
+ /* New region to allocate and all regions allocated */
+ } else if ( !rtems_flashdev_is_region_defined( iop ) &&
+ rtems_flashdev_find_unalloced_region(table) !=
+ RTEMS_FLASHDEV_REGION_ALLOC_FULL ) {
+ /* New region to allocate and space to allocate region */
+ return rtems_flashdev_ioctl_create_region( flash, iop, region_in );
+ } else {
+ /* Updating existing region */
+ return rtems_flashdev_ioctl_update_region( flash, iop, region_in );
+ int i;
+ /* Find unallocated region slot */
+ i = rtems_flashdev_find_unalloced_region(flash->region_table);
+ /* Set region values */
+ table->regions[ i ].offset = region_in->offset;
+ table->regions[ i ].size = region_in->size;
+ /* Set region as allocated and link iop */
+ rtems_flashdev_set_region(flash->region_table, i);
+ rtems_flashdev_set_region_index( iop, i );
+ return 0;
+ uint32_t region_index = rtems_flashdev_get_region_index( iop );
+ * If region index is larger then maximum region index or region
+ * index at given index is undefined return an error.
+ if (
+ ( region_index >= flash->region_table->max_regions ) ||
+ ( rtems_flashdev_check_allocation( table, region_index ) == 0)
+ table->regions[ region_index ].offset = region_in->offset;
+ table->regions[ region_index ].size = region_in->size;
+ return 0;
+ /* Check region to clear */
+ if ( region_index == RTEMS_FLASHDEV_REGION_UNDEFINED ) {
+ /* Clear region */
+ rtems_flashdev_unset_region( flash->region_table, region_index );
+ rtems_flashdev_set_region_index( iop, RTEMS_FLASHDEV_REGION_UNDEFINED );
+ return 0;
+ return table->regions[ rtems_flashdev_get_region_index( iop ) ].offset;
+ return table->regions[ rtems_flashdev_get_region_index( iop ) ].size;
+static uint32_t rtems_flashdev_ioctl_jedec_id( rtems_flashdev *flash )
+ if ( flash->jedec_id == NULL ) {
+ return 0;
+ } else {
+ return ( *flash->jedec_id )( flash );
+ void *arg
+ rtems_flashdev_flash_type *type = (rtems_flashdev_flash_type*)arg;
+ if ( flash->flash_type == NULL ) {
+ return 0;
+ } else {
+ return ( *flash->flash_type )( flash, type );
+ void *arg
+ rtems_flashdev_ioctl_page_info *page_info;
+ if ( arg == NULL ) {
+ if ( flash->page_info_by_offset == NULL ) {
+ return 0;
+ } else {
+ page_info = (rtems_flashdev_ioctl_page_info *) arg;
+ return ( *flash->page_info_by_offset )( flash,
+ page_info->location,
+ &page_info->page_info.offset,
+ &page_info->page_info.size );
+static int rtems_flashdev_ioctl_pageinfo_index( rtems_flashdev *flash,
+ void *arg )
+ if ( flash->page_info_by_index == NULL ) {
+ return 0;
+ } else {
+ return ( *flash->page_info_by_index )( flash,
+static int rtems_flashdev_ioctl_page_count( rtems_flashdev *flash, void *arg )
+ if ( flash->page_count == NULL ) {
+ return 0;
+ } else {
+ return ( *flash->page_count )( flash, ( (int *) arg ) );
+ void *arg
+ if ( flash->write_block_size == NULL ) {
+ return 0;
+ } else {
+ return ( *flash->write_block_size )( flash, ( (size_t *) arg ) );
+ int final_index =
+ ( region_table->max_regions / RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH );
+ for ( int i = 0; i < final_index; i++ ) {
+ /* If region the next 32 regions are full check the next allocator */
+ if (region_table->bit_allocator[ i ] == RTEMS_FLASHDEV_REGION_ALLOC_FULL) {
+ continue;
+ for (int x = 0; x < RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH; x++) {
+ if ( ! ( ( ( region_table->bit_allocator[ i ] ) >> x ) & 1UL ) ) {
+ return RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH * i + x;
+ for
+ int i = 0;
+ i < ( region_table->max_regions % RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH );
+ i++
+ if ( ! ( ( ( region_table->bit_allocator[ final_index ] ) >> i ) & 1UL ) ) {
+ return RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH * final_index + i;
+ return RTEMS_FLASHDEV_REGION_ALLOC_FULL;
+ int index
+ int array_index = index / RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH;
+ int shift = index % RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH;
+ region_table->bit_allocator[ array_index ] |= 1UL << shift;
+ return index;
+ int index
+ region_table->bit_allocator[ array_index ] &= ~( 1UL << shift );
+ return index;
+ int index
+ int shift = index%RTEMS_FLASHDEV_REGION_BITALLOC_LENGTH;
+ return ( ( region_table->bit_allocator[ array_index ] >> shift ) & 1UL );
diff --git a/cpukit/include/dev/flash/flashdev.h b/cpukit/include/dev/flash/flashdev.h
index 0000000000..aee585d252
--- /dev/null
+++ b/cpukit/include/dev/flash/flashdev.h
@@ -0,0 +1,458 @@
+ * @file
+ * @ingroup Flash
+ * @brief Generic Flash API
+ * are met:
+#ifndef _DEV_FLASHDEV_H
+#define _DEV_FLASHDEV_H
+#include <rtems/thread.h>
+#include <sys/types.h>
+typedef struct rtems_flashdev rtems_flashdev;
+ * @defgroup Generic Flash API
+ * @ingroup RTEMSDeviceDrivers
+ * @brief Generic Flash API to wrap specific device drivers.
+/* IOCTL Calls */
+ * @brief Obtains the flash device.
+ * This command has no argument.
+#define RTEMS_FLASHDEV_IOCTL_OBTAIN 0
+ * @brief Releases the flash device.
+#define RTEMS_FLASHDEV_IOCTL_RELEASE 1
+ * @brief Returns the JEDEC ID of the flash device.
+ * @param[out] jedec_id Pointer to uint32_t in which the JEDEC ID is
+ * returned in.
+#define RTEMS_FLASHDEV_IOCTL_JEDEC_ID 2
+ * @brief Erases flash device.
+ * @param[in] erase_args Pointer to rtems_flashdev_region struct
+ * containing offset and size of erase to be performed.
+#define RTEMS_FLASHDEV_IOCTL_ERASE 3
+ * @brief Set a region that limits read, write and erase calls to within it.
+ * Regions are file descriptor specific and limited to a single region per
+ * file descriptor and 32 regions total per flash device. Regions can be
+ * changed or updated by calling this IOCTL again.
+ * @param[in] region Pointer to rtems_flashdev_region struct containing
+ * base and length of defined region.
+#define RTEMS_FLASHDEV_IOCTL_REGION_SET 4
+ * @brief Removes the set region on the file descriptor.
+#define RTEMS_FLASHDEV_IOCTL_REGION_UNSET 5
+ * @brief Returns the type of flash device (e.g. NOR or NAND).
+ * @param[out] flash_type Pointer to integer which is set to the flash
+ * type macro value.
+#define RTEMS_FLASHDEV_IOCTL_TYPE 6
+ * @brief Get the size and address of flash page at given offset
+ * The offset ignores the region limiting. To find page of region
+ * limited offset add the base of the region to the desired offset.
+ * @param[in,out] rtems_flashdev_ioctl_page_info arg Pointer to struct
+ * with offset and space for return values.
+#define RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET 7
+ * @brief Get the size and address of nth flash page where n is index passed in.
+ * The index ignores the region limiting.
+ * with index and space for return values.
+#define RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX 8
+ * @brief Get the number of pages in flash device.
+ * @param[out] count Integer containing the number of pages.
+#define RTEMS_FLASHDEV_IOCTL_PAGE_COUNT 9
+ * @brief Get the minimum write size supported by the driver.
+ * @param[out] count Integer containing the minimum write size.
+#define RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE 10
+ * @brief The maximum number of region limited file descriptors
+ * allowed to be open at once.
+#define RTEMS_FLASHDEV_MAX_REGIONS 32
+ * @brief Enum for flash type returned from IOCTL call.
+typedef enum rtems_flashdev_flash_type {
+ * @brief The flash device is NOR flash.
+ RTEMS_FLASHDEV_NOR,
+ * @brief The flash device is NAND flash.
+ RTEMS_FLASHDEV_NAND
+} rtems_flashdev_flash_type;
+ * @brief General definition for on flash device.
+typedef struct rtems_flashdev_region {
+ * @brief Base of region.
+ off_t offset;
+ * @brief Length of region.
+ size_t size;
+} rtems_flashdev_region;
+ * @brief Struct holding region definitions
+typedef struct rtems_flashdev_region_table {
+ * @brief The maximum regions that can be defined at once.
+ int max_regions;
+ * @brief Pointer to array of rtems_flashdev_region of length
+ * max_regions
+ rtems_flashdev_region* regions;
+ * @brief Array of uint32_t acting as bit allocator
+ * for regions array.
+ uint32_t *bit_allocator;
+} rtems_flashdev_region_table;
+ * @brief Page information returned from IOCTL calls.
+typedef struct rtems_flashdev_ioctl_page_info {
+ * @brief Offset or index to find page at.
+ off_t location;
+ * @brief Information returned about the page. Including the
+ * base offset and size of page.
+ rtems_flashdev_region page_info;
+} rtems_flashdev_ioctl_page_info;
+ * @brief Flash device.
+struct rtems_flashdev {
+ * @brief Call to the device driver to read the flash device.
+ * @param[in] flash Pointer to flash device.
+ * @param[in] offset Address to read from.
+ * @param[in] count Number of bytes to read.
+ * @param[out] buffer Buffer for data to be read into.
+ * @retval 0 Successful operation.
+ * @retval 1 Failed operation.
+ int ( *read )(
+ uintptr_t offset,
+ size_t count,
+ void *buffer
+ * @brief Call to the device driver to write to the flash device.
+ * @param[in] offset Address to write to.
+ * @param[in] buffer Buffer for data to be written from.
+ int ( *write )(
+ uintptr_t offset,
+ size_t count,
+ * @brief Call to the device driver to erase the flash device.
+ * @param[in] offset Address to erase at.
+ * @param[in] count Number of bytes to erase.
+ int ( *erase )(
+ uintptr_t offset,
+ size_t count
+ * @brief Call to the device driver to return the JEDEC ID.
+ * @param[in] flash The flash device.
+ * @retval JEDEC ID.
+ uint32_t ( *jedec_id )(
+ * @brief Call to the device driver to return the flash type.
+ * @param[out] type The type of flash device.
+ * @retbal Other Failure
+ int ( *flash_type )(
+ * @brief Call to device driver to get size and offset of page at
+ * given offset.
+ * @param[in] search_offset The offset of the page which info is to be
+ * returned.
+ * @param[out] page_offset The offset of the start of the page
+ * @param[out] page_size The size of the page
+ * @retval 0 Success.
+ * @retval non-zero Failed.
+ int ( *page_info_by_offset )(
+ off_t search_offset,
+ off_t *page_offset,
+ size_t *page_size
+ * given index.
+ * @param[in] search_index The index of the page which info is to be returned.
+ int ( *page_info_by_index )(
+ rtems_flashdev *flashdev,
+ off_t search_index,
+ size_t *page_size
+ * @brief Call to device driver to return the number of pages on the flash
+ * device.
+ * @param[out] page_count The number of pages on the flash device.
+ int ( *page_count )(
+ int *page_count
+ * @brief Call to device driver to return the minimum write size of the
+ * flash device.
+ * @param[out] write_block_size The minimum write size of the flash device.
+ int ( *write_block_size )(
+ size_t *write_block_size
+ * @brief Destroys the flash device.
+ * @brief Pointer to device driver.
+ void *driver;
+ * @brief Mutex to protect the flash device access.
+ rtems_recursive_mutex mutex;
+ * @brief Region table defining size and memory for region allocations
+ rtems_flashdev_region_table *region_table;
+ * @brief Allocate and initialize the flash device.
+ * After a successful allocation and initialization of the flash device
+ * it must be destroyed via rtems_flashdev_destroy_and_free().
+ * @param[in] size The number of bytes to allocate.
+ * @retval NULL Failed to set up flash device.
+ * @retval non-NULL The new flash device.
+ size_t size
+ * @brief Initialize the flash device.
+ * After a successful initialization of the flash device it must be
+ * destroyed via rtems_flashdev_destory().
+ * After initialization and before registration read, write, erase, jedec_id
+ * and flash_type functions need to be set in the flashdev.
+ * @param[in] flash The flash device to initialize.
+ * @retval 1 Failed to set up flash device.
+ * @retval 0 Successful set up of flash device.
+ * @brief Register the flash device.
+ * This function always claims ownership of the flash device.
+ * @param[in] flash_path The path to the flash device file.
+ * @retval non-zero Failed operation.
+ const char *flash_path
+ * @brief Destroys the flash device and frees its memory.
+#endif /* _DEV_FLASHDEV_H */
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 2c969aa5f6..86c5c8ff2b 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -52,6 +52,9 @@ install:
- destination: ${BSP_INCLUDEDIR}/dev/spi
source:
- cpukit/include/dev/spi/spi.h
+- destination: ${BSP_INCLUDEDIR}/dev/flash
+ source:
+ - cpukit/include/dev/flash/flashdev.h
- destination: ${BSP_INCLUDEDIR}/dev/can
source:
- cpukit/include/dev/can/can.h
@@ -522,6 +525,7 @@ links:
- role: build-dependency
uid: vckey
source:
+- cpukit/dev/flash/flashdev.c
- cpukit/dev/i2c/eeprom.c
- cpukit/dev/i2c/fpga-i2c-slave.c
- cpukit/dev/i2c/gpio-nxp-pca9535.c
2.25.1
________________________________
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230424/16e19107/attachment-0001.htm>
