[PATCH] score: Avoid cyclic header file dependencies
Sebastian Huber
Mon Apr 24 13:00:33 UTC 2023
There was a cyclic dependency: For RTEMS_STATIC_ANALYSIS we needed
basedefs.h in assert.h. For RTEMS_UNREACHABLE() we needed _Assert() from
assert.h in basedefs.h.
Fix this by introducing _Debug_Unreachable() in basedefs.h.
Add RTEMS_FUNCTION_NAME to basedefs.h and use it in basedefs.h and
assert.h.
Close #4900.
cpukit/include/rtems/score/assert.h | 17 +--
cpukit/include/rtems/score/basedefs.h | 109 +++++++++++--------
cpukit/score/src/debugunreachable.c | 49 +++++++++
spec/build/cpukit/librtemscpu.yml | 1 +
testsuites/validation/tc-basedefs-no-debug.c | 20 ++--
5 files changed, 129 insertions(+), 67 deletions(-)
create mode 100644 cpukit/score/src/debugunreachable.c
diff --git a/cpukit/include/rtems/score/assert.h b/cpukit/include/rtems/score/assert.h
index 9eeccacf76..cff4801036 100644
--- a/cpukit/include/rtems/score/assert.h
+++ b/cpukit/include/rtems/score/assert.h
@@ -71,22 +71,7 @@ extern "C" {
* @note This is based on the code in newlib's assert.h.
#ifndef __RTEMS_ASSERT_FUNCTION
- /* Use g++'s demangled names in C++. */
- #if defined __cplusplus && defined __GNUC__
- #define __RTEMS_ASSERT_FUNCTION __PRETTY_FUNCTION__
- /* C99 requires the use of __func__. */
- #elif __STDC_VERSION__ >= 199901L
- #define __RTEMS_ASSERT_FUNCTION __func__
- /* Older versions of gcc don't have __func__ but can use __FUNCTION__. */
- #elif __GNUC__ >= 2
- #define __RTEMS_ASSERT_FUNCTION __FUNCTION__
- /* failed to detect __func__ support. */
- #else
- #define __RTEMS_ASSERT_FUNCTION ((char *) 0)
- #endif
+ #define __RTEMS_ASSERT_FUNCTION RTEMS_FUNCTION_NAME
#endif /* !__RTEMS_ASSERT_FUNCTION */
#if !defined( RTEMS_SCHEDSIM )
diff --git a/cpukit/include/rtems/score/basedefs.h b/cpukit/include/rtems/score/basedefs.h
index c182ea02ec..96b1d65e27 100644
--- a/cpukit/include/rtems/score/basedefs.h
+++ b/cpukit/include/rtems/score/basedefs.h
@@ -12,7 +12,7 @@
* Copyright (C) 2014 Paval Pisa
* Copyright (C) 2011, 2013 On-Line Applications Research Corporation (OAR)
- * Copyright (C) 2009, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 2009, 2023 embedded brains GmbH (http://www.embedded-brains.de)
* modification, are permitted provided that the following conditions
@@ -355,6 +355,47 @@ extern "C" {
#define RTEMS_EXPAND( _token ) _token
+/* Generated from spec:/rtems/basedefs/if/function-name */
+ * @ingroup RTEMSAPIBaseDefs
+ * @brief Expands to the name of the function containing the use of this
+ * define.
+#if defined(__cplusplus) && defined(__GNUC__)
+ #define RTEMS_FUNCTION_NAME __PRETTY_FUNCTION__
+#else
+ #define RTEMS_FUNCTION_NAME __func__
+#endif
+/* Generated from spec:/rtems/basedefs/if/no-return */
+ * @brief Tells the compiler in a function declaration that this function does
+ * not return.
+#if __cplusplus >= 201103L
+ #define RTEMS_NO_RETURN [[noreturn]]
+#elif __STDC_VERSION__ >= 201112L
+ #define RTEMS_NO_RETURN _Noreturn
+#elif defined(__GNUC__)
+ #define RTEMS_NO_RETURN __attribute__(( __noreturn__ ))
+#else
+#endif
+/* Generated from spec:/rtems/basedefs/if/compiler-no-return-attribute */
+ * @brief Provided for backward compatibility.
+#define RTEMS_COMPILER_NO_RETURN_ATTRIBUTE RTEMS_NO_RETURN
/* Generated from spec:/rtems/basedefs/if/section */
@@ -425,17 +466,25 @@ extern "C" {
#define RTEMS_XCONCAT( _x, _y ) RTEMS_CONCAT( _x, _y )
-/* Generated from spec:/score/basedefs/if/assert-unreachable */
+#if !defined(ASM) && defined(RTEMS_DEBUG)
+ /* Generated from spec:/score/basedefs/if/debug-unreachable */
- * @ingroup RTEMSScore
- * @brief Asserts that this program point is unreachable.
-#if defined(RTEMS_DEBUG)
- #define _Assert_Unreachable() _Assert( 0 )
-#else
- #define _Assert_Unreachable() do { } while ( 0 )
+ * @ingroup RTEMSScore
+ * @brief Terminates the program with a failed assertion.
+ * @param file is the file name.
+ * @param line is the line of the file.
+ * @param func is the function name.
+ RTEMS_NO_RETURN void _Debug_Unreachable(
+ const char *file,
+ int line,
+ const char *func
#endif
#if !defined(ASM)
@@ -614,33 +663,6 @@ extern "C" {
#define RTEMS_NO_INLINE
#endif
-/* Generated from spec:/rtems/basedefs/if/no-return */
- * @ingroup RTEMSAPIBaseDefs
- * @brief Tells the compiler in a function declaration that this function does
- * not return.
-#if __cplusplus >= 201103L
- #define RTEMS_NO_RETURN [[noreturn]]
-#elif __STDC_VERSION__ >= 201112L
- #define RTEMS_NO_RETURN _Noreturn
-#elif defined(__GNUC__)
- #define RTEMS_NO_RETURN __attribute__(( __noreturn__ ))
-#else
-#endif
-/* Generated from spec:/rtems/basedefs/if/compiler-no-return-attribute */
- * @brief Provided for backward compatibility.
-#define RTEMS_COMPILER_NO_RETURN_ATTRIBUTE RTEMS_NO_RETURN
/* Generated from spec:/rtems/basedefs/if/noinit */
@@ -858,14 +880,13 @@ extern "C" {
* @brief Tells the compiler that this program point is unreachable.
-#if defined(__GNUC__)
+#if defined(RTEMS_DEBUG)
#define RTEMS_UNREACHABLE() \
- do { \
- __builtin_unreachable(); \
- _Assert_Unreachable(); \
- } while ( 0 )
+ _Debug_Unreachable( __FILE__, __LINE__, RTEMS_FUNCTION_NAME )
+ #define RTEMS_UNREACHABLE() __builtin_unreachable()
#else
- #define RTEMS_UNREACHABLE() _Assert_Unreachable()
+ #define RTEMS_UNREACHABLE() do { } while ( 0 )
#endif
/* Generated from spec:/rtems/basedefs/if/unused */
diff --git a/cpukit/score/src/debugunreachable.c b/cpukit/score/src/debugunreachable.c
new file mode 100644
index 0000000000..f6c2bf67ca
--- /dev/null
+++ b/cpukit/score/src/debugunreachable.c
@@ -0,0 +1,49 @@
+ * @file
+ * @brief This source file contains the implementation of _Debug_Unreachable().
+ * Copyright (C) 2023 embedded brains GmbH & Co. KG
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/basedefs.h>
+#include <assert.h>
+void _Debug_Unreachable( const char *file, int line, const char *func )
+ __assert_func( file, line, func, "reached unreachable code" );
+#endif
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 2c969aa5f6..e80be5ebf0 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1409,6 +1409,7 @@ source:
- cpukit/score/src/coretodhookunregister.c
- cpukit/score/src/coretodset.c
- cpukit/score/src/debugisthreaddispatchingallowed.c
+- cpukit/score/src/debugunreachable.c
- cpukit/score/src/freechain.c
- cpukit/score/src/futex.c
- cpukit/score/src/gcovdumpinfobase64.c
diff --git a/testsuites/validation/tc-basedefs-no-debug.c b/testsuites/validation/tc-basedefs-no-debug.c
index 2566107730..479f563cdb 100644
--- a/testsuites/validation/tc-basedefs-no-debug.c
+++ b/testsuites/validation/tc-basedefs-no-debug.c
@@ -72,9 +72,9 @@
* - Check that the string is equal to the expected statement.
- * - Expand and stringify _Assert_Unreachable().
+ * - Expand RTEMS_FUNCTION_NAME.
- * - Check that the string is equal to the expected statement.
+ * - Check that the string is equal to the expected function name.
@@ -95,24 +95,30 @@ static void RtemsBasedefsValBasedefsNoDebug_Action_0( void )
0,
IsEqualIgnoreWhiteSpace(
s,
- "do{__builtin_unreachable();do{}while(0);}while(0)"
+ "__builtin_unreachable()"
- * @brief Expand and stringify _Assert_Unreachable().
+ * @brief Expand RTEMS_FUNCTION_NAME.
static void RtemsBasedefsValBasedefsNoDebug_Action_1( void )
const char *s;
- s = RTEMS_XSTRING( _Assert_Unreachable() );
+ s = RTEMS_FUNCTION_NAME;
- * Check that the string is equal to the expected statement.
+ * Check that the string is equal to the expected function name.
- T_step_true( 1, IsEqualIgnoreWhiteSpace( s, "do{}while(0)" ) );
+ T_step_true(
+ 1,
+ IsEqualIgnoreWhiteSpace(
+ s,
+ "RtemsBasedefsValBasedefsNoDebug_Action_1"
2.35.3
