Change build specification files from YAML to JSON?
Tue Apr 25 18:01:01 UTC 2023
On 25.04.23 13:02, Karel Gardas wrote:
> On 4/25/23 12:32, Sebastian Huber wrote:
>> On 25.04.23 12:10, Karel Gardas wrote:
>>> On 4/25/23 11:03, Sebastian Huber wrote:
>>>> On 25.04.23 11:00, Karel Gardas wrote:
>>>>> On 4/25/23 09:35, Sebastian Huber wrote:
>>>>>> The change from YAML to JSON for the build specification files is
>>>>>> just an implementation detail of the new build system. For the
>>>>>> users of the new build system nothing changes.
>>>>> Let me ask for clarification. Does this yaml -> json transition
>>>>> include (or not) files in RTEMS spec directory, e.g. files here:
>>>>> https://git.rtems.org/rtems/tree/spec
>>>> It would affect all YAML files in this directory and no other files.
>>> Oh. Let me ask, what is your future plan with the spec files?
>>> Considering you would like to move them to JSON, would you also like
>>> to provide some DSL + compiler which would generates those? Or would
>>> you just like to keep JSON and have developers editing those?
>> I would keep the JSON and have developer editing those.
>> An alternative to changing the format could be to use the CSafeLoader
>> of the system yaml module if it is available. It is not as fast as the
>> JSON loader, but acceptable (0.65s to 0.2s on my machine for loading
>> the items).
> Sorry for perhaps silly question, but why do you invest that much energy
> in optimizing build speed -- by fraction of seconds here? I so far fail
> so to see driving motivation force hence my question...
We have a fraction of a second if we use the CSafeLoader and no item
cache. Currently we use the SafeLoader which results in about 5 seconds.
I would like to use the build system for more stuff, so this could grow
to 10, 15, or more seconds which then start to get annoying if you work
frequently with it.
Given the performance of the CSafeLoader I will probably use it and keep
the YAML format.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
