[PATCH 2/5] build: Use CSafeLoader if available
Gedare Bloom
gedare at rtems.org
Thu Apr 27 18:27:03 UTC 2023
On Wed, Apr 26, 2023 at 11:46 PM Sebastian Huber
> On 27.04.23 02:11, Chris Johns wrote:
> > On 26/4/2023 6:04 pm, Sebastian Huber wrote:
> >> The CSafeLoader uses the C libyaml libary to considerably speed up the
> >> loading of YAML files.
> > No from me.
> What do you mean with not for me? You have the CSafeLoader available and
> it is slow? Do you have some timings before and after the patch set for
> a "./waf configure" and "./waf build"? On my systems the configure needs
> less than a second with the CSafeLoader and the waf build setup time is
> less than 100ms.
> > I do not agree with conditional states of operation in the build system that
> > depend on packages a host has installed. If speed is an important factor all
> > users then I suggest you find a means to have it available automatically on the
> > hosts we support (Linux, FreeBSD, MacOS, Windows MINGW64 and Cygwin.
> I am not sure if we should automatically install system Python packages
> on user machines.
> The fall back is the Python PyYAML package available through the RTEMS
> sources. This is what we use currently. For RTEMS users, this is
> acceptable since they are not supposed to touch the YAML files. For
> RTEMS maintainers, not having the cache makes working with the build
> system more efficient.
> If they system PyYAML package is not installed, then you get now a hint
> to install it:
> Setting top to : /home/EB/sebastian_h/src/rtems
> Setting out to :
> /home/EB/sebastian_h/src/rtems/build
> Regenerate the build specification cache. Install the PyYAML Python
> package to avoid this. The cache regeneration needs a couple of seconds...
> Configure board support package (BSP) : arm/realview_pbx_a9_qemu
I have two questions, which are related to Chris's concern I think.
1. Are the output of PyYAML and C libyaml guaranteed to be consistent?
2. Why not make C libyaml part of the RTEMS toolchain?
Any dependencies that exist in the build system are (by definition)
suitable to be checked/provided by the tool buildset.
Gedare
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
