[PATCH 2/5] build: Use CSafeLoader if available
Sebastian Huber
Fri Apr 28 05:38:37 UTC 2023
On 27.04.23 20:27, Gedare Bloom wrote:
> On Wed, Apr 26, 2023 at 11:46 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 27.04.23 02:11, Chris Johns wrote:
>>> On 26/4/2023 6:04 pm, Sebastian Huber wrote:
>>>> The CSafeLoader uses the C libyaml libary to considerably speed up the
>>>> loading of YAML files.
>>> No from me.
>> What do you mean with not for me? You have the CSafeLoader available and
>> it is slow? Do you have some timings before and after the patch set for
>> a "./waf configure" and "./waf build"? On my systems the configure needs
>> less than a second with the CSafeLoader and the waf build setup time is
>> less than 100ms.
>>> I do not agree with conditional states of operation in the build system that
>>> depend on packages a host has installed. If speed is an important factor all
>>> users then I suggest you find a means to have it available automatically on the
>>> hosts we support (Linux, FreeBSD, MacOS, Windows MINGW64 and Cygwin.
>> I am not sure if we should automatically install system Python packages
>> on user machines.
>> The fall back is the Python PyYAML package available through the RTEMS
>> sources. This is what we use currently. For RTEMS users, this is
>> acceptable since they are not supposed to touch the YAML files. For
>> RTEMS maintainers, not having the cache makes working with the build
>> system more efficient.
>> If they system PyYAML package is not installed, then you get now a hint
>> to install it:
>> Setting top to : /home/EB/sebastian_h/src/rtems
>> Setting out to :
>> /home/EB/sebastian_h/src/rtems/build
>> Regenerate the build specification cache. Install the PyYAML Python
>> package to avoid this. The cache regeneration needs a couple of seconds...
>> Configure board support package (BSP) : arm/realview_pbx_a9_qemu
> I have two questions, which are related to Chris's concern I think.
> 1. Are the output of PyYAML and C libyaml guaranteed to be consistent?
I trust the PyYAML maintainers that the SafeLoader and CSafeLoader
produce the same results. With respect to the alternative ItemCache
class implementation in the wscript I am quite confident that this
produces the same results. This part just has to load the item data from
the files. The CSafeLoader based ItemCache has 53 lines of code.
> 2. Why not make C libyaml part of the RTEMS toolchain?
> Any dependencies that exist in the build system are (by definition)
> suitable to be checked/provided by the tool buildset.
Yes, this is an option. If we remove the pickle cache, then we force
everyone to use the libyaml based PyYAML module. Is this really
necessary right now? For most use cases the Python only solution works
fine. If you spend your time developing BSPs, then the CSafeLoader pays off.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
