[PATCH] validation: Improve IRQ handler dispatch test
Sebastian Huber
Fri Feb 3 07:56:03 UTC 2023
Clarify wording. Use a function wrapper for the SMP spurious interrupt setup.
Update #3716.
.../testsuites/validation/validation-intr.yml | 3 +-
...sp-interrupt-handler-dispatch-unchecked.c} | 314 ++++++++++--------
2 files changed, 173 insertions(+), 144 deletions(-)
rename testsuites/validation/{tc-bsp-interrupt-spurious.c => tc-bsp-interrupt-handler-dispatch-unchecked.c} (50%)
diff --git a/spec/build/testsuites/validation/validation-intr.yml b/spec/build/testsuites/validation/validation-intr.yml
index ced15b9490..dc4fc03a2d 100644
--- a/spec/build/testsuites/validation/validation-intr.yml
+++ b/spec/build/testsuites/validation/validation-intr.yml
@@ -10,9 +10,10 @@ features: c cprogram
includes: []
ldflags:
- -Wl,--wrap=bsp_interrupt_handler_default
+- -Wl,--wrap=bsp_interrupt_spurious
links: []
source:
-- testsuites/validation/tc-bsp-interrupt-spurious.c
+- testsuites/validation/tc-bsp-interrupt-handler-dispatch-unchecked.c
- testsuites/validation/tc-intr-clear.c
- testsuites/validation/tc-intr-entry-install.c
- testsuites/validation/tc-intr-entry-remove.c
diff --git a/testsuites/validation/tc-bsp-interrupt-spurious.c b/testsuites/validation/tc-bsp-interrupt-handler-dispatch-unchecked.c
similarity index 50%
rename from testsuites/validation/tc-bsp-interrupt-spurious.c
rename to testsuites/validation/tc-bsp-interrupt-handler-dispatch-unchecked.c
index f1230cb7e0..f6cb5852f1 100644
--- a/testsuites/validation/tc-bsp-interrupt-spurious.c
+++ b/testsuites/validation/tc-bsp-interrupt-handler-dispatch-unchecked.c
@@ -3,11 +3,11 @@
* @file
- * @ingroup RTEMSTestCaseBspReqInterruptSpurious
+ * @ingroup RTEMSTestCaseBspReqInterruptHandlerDispatchUnchecked
- * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 2021, 2023 embedded brains GmbH (http://www.embedded-brains.de)
* modification, are permitted provided that the following conditions
@@ -60,8 +60,8 @@
#include <rtems/test.h>
- * @defgroup RTEMSTestCaseBspReqInterruptSpurious \
- * spec:/bsp/req/interrupt-spurious
+ * @defgroup RTEMSTestCaseBspReqInterruptHandlerDispatchUnchecked \
+ * spec:/bsp/req/interrupt-handler-dispatch-unchecked
* @ingroup RTEMSTestSuiteTestsuitesValidationIntr
@@ -69,44 +69,45 @@
typedef enum {
- BspReqInterruptSpurious_Pre_First_Null,
- BspReqInterruptSpurious_Pre_First_Entry,
- BspReqInterruptSpurious_Pre_First_NA
-} BspReqInterruptSpurious_Pre_First;
+ BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirst_Null,
+ BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirst_Entry,
+ BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirst_NA
+} BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirst;
typedef enum {
- BspReqInterruptSpurious_Pre_FirstAgain_Null,
- BspReqInterruptSpurious_Pre_FirstAgain_Entry,
- BspReqInterruptSpurious_Pre_FirstAgain_NA
-} BspReqInterruptSpurious_Pre_FirstAgain;
+ BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain_Null,
+ BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain_Entry,
+ BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain_NA
+} BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain;
typedef enum {
- BspReqInterruptSpurious_Post_Result_FatalError,
- BspReqInterruptSpurious_Post_Result_Dispatch,
- BspReqInterruptSpurious_Post_Result_NA
-} BspReqInterruptSpurious_Post_Result;
+ BspReqInterruptHandlerDispatchUnchecked_Post_Result_FatalError,
+ BspReqInterruptHandlerDispatchUnchecked_Post_Result_Dispatch,
+ BspReqInterruptHandlerDispatchUnchecked_Post_Result_NA
+} BspReqInterruptHandlerDispatchUnchecked_Post_Result;
typedef enum {
- BspReqInterruptSpurious_Post_FatalSource_SpuriousInterrupt,
- BspReqInterruptSpurious_Post_FatalSource_NA
-} BspReqInterruptSpurious_Post_FatalSource;
+ BspReqInterruptHandlerDispatchUnchecked_Post_FatalSource_SpuriousInterrupt,
+ BspReqInterruptHandlerDispatchUnchecked_Post_FatalSource_NA
+} BspReqInterruptHandlerDispatchUnchecked_Post_FatalSource;
typedef enum {
- BspReqInterruptSpurious_Post_FatalCode_Vector,
- BspReqInterruptSpurious_Post_FatalCode_NA
-} BspReqInterruptSpurious_Post_FatalCode;
+ BspReqInterruptHandlerDispatchUnchecked_Post_FatalCode_Vector,
+ BspReqInterruptHandlerDispatchUnchecked_Post_FatalCode_NA
+} BspReqInterruptHandlerDispatchUnchecked_Post_FatalCode;
typedef struct {
uint8_t Skip : 1;
- uint8_t Pre_First_NA : 1;
- uint8_t Pre_FirstAgain_NA : 1;
+ uint8_t Pre_LoadFirst_NA : 1;
+ uint8_t Pre_LoadFirstAgain_NA : 1;
uint8_t Post_Result : 2;
uint8_t Post_FatalSource : 1;
uint8_t Post_FatalCode : 1;
-} BspReqInterruptSpurious_Entry;
+} BspReqInterruptHandlerDispatchUnchecked_Entry;
- * @brief Test context for spec:/bsp/req/interrupt-spurious test case.
+ * @brief Test context for spec:/bsp/req/interrupt-handler-dispatch-unchecked
+ * test case.
typedef struct {
@@ -192,7 +193,7 @@ typedef struct {
* @brief This member contains the current transition map entry.
- BspReqInterruptSpurious_Entry entry;
+ BspReqInterruptHandlerDispatchUnchecked_Entry entry;
* @brief If this member is true, then the current transition variant
@@ -200,30 +201,30 @@ typedef struct {
bool skip;
} Map;
-} BspReqInterruptSpurious_Context;
+} BspReqInterruptHandlerDispatchUnchecked_Context;
-static BspReqInterruptSpurious_Context
- BspReqInterruptSpurious_Instance;
+static BspReqInterruptHandlerDispatchUnchecked_Context
+ BspReqInterruptHandlerDispatchUnchecked_Instance;
-static const char * const BspReqInterruptSpurious_PreDesc_First[] = {
+static const char * const BspReqInterruptHandlerDispatchUnchecked_PreDesc_LoadFirst[] = {
"Null",
"Entry",
"NA"
-static const char * const BspReqInterruptSpurious_PreDesc_FirstAgain[] = {
+static const char * const BspReqInterruptHandlerDispatchUnchecked_PreDesc_LoadFirstAgain[] = {
"Null",
"Entry",
"NA"
-static const char * const * const BspReqInterruptSpurious_PreDesc[] = {
- BspReqInterruptSpurious_PreDesc_First,
- BspReqInterruptSpurious_PreDesc_FirstAgain,
+static const char * const * const BspReqInterruptHandlerDispatchUnchecked_PreDesc[] = {
+ BspReqInterruptHandlerDispatchUnchecked_PreDesc_LoadFirst,
+ BspReqInterruptHandlerDispatchUnchecked_PreDesc_LoadFirstAgain,
NULL
-typedef BspReqInterruptSpurious_Context Context;
+typedef BspReqInterruptHandlerDispatchUnchecked_Context Context;
static bool test_case_active;
@@ -283,13 +284,34 @@ void __wrap_bsp_interrupt_handler_default( rtems_vector_number vector )
-static void BspReqInterruptSpurious_Pre_First_Prepare(
- BspReqInterruptSpurious_Context *ctx,
- BspReqInterruptSpurious_Pre_First state
+#if defined(RTEMS_SMP)
+void __real_bsp_interrupt_spurious( rtems_vector_number vector );
+void __wrap_bsp_interrupt_spurious( rtems_vector_number vector );
+ if ( test_case_active ) {
+ Context *ctx;
+ ctx = T_fixture_context();
+ if ( *ctx->first == NULL && ctx->first_again != NULL ) {
+ *ctx->first = ctx->first_again;
+ __real_bsp_interrupt_spurious( vector );
+#endif
+static void BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirst_Prepare(
+ BspReqInterruptHandlerDispatchUnchecked_Context *ctx,
+ BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirst state
switch ( state ) {
- case BspReqInterruptSpurious_Pre_First_Null: {
+ case BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirst_Null: {
* While the first loaded value of the pointer to the first interrupt
* entry of the interrupt vector specified by the ``vector`` parameter is
@@ -299,7 +321,7 @@ static void BspReqInterruptSpurious_Pre_First_Prepare(
break;
- case BspReqInterruptSpurious_Pre_First_Entry: {
+ case BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirst_Entry: {
@@ -309,18 +331,18 @@ static void BspReqInterruptSpurious_Pre_First_Prepare(
break;
- case BspReqInterruptSpurious_Pre_First_NA:
+ case BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirst_NA:
break;
-static void BspReqInterruptSpurious_Pre_FirstAgain_Prepare(
- BspReqInterruptSpurious_Pre_FirstAgain state
+static void BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain_Prepare(
+ BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain state
switch ( state ) {
- case BspReqInterruptSpurious_Pre_FirstAgain_Null: {
+ case BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain_Null: {
* While the second loaded value of the pointer to the first interrupt
@@ -330,7 +352,7 @@ static void BspReqInterruptSpurious_Pre_FirstAgain_Prepare(
break;
- case BspReqInterruptSpurious_Pre_FirstAgain_Entry: {
+ case BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain_Entry: {
@@ -340,18 +362,18 @@ static void BspReqInterruptSpurious_Pre_FirstAgain_Prepare(
break;
- case BspReqInterruptSpurious_Pre_FirstAgain_NA:
+ case BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain_NA:
break;
-static void BspReqInterruptSpurious_Post_Result_Check(
- BspReqInterruptSpurious_Post_Result state
+static void BspReqInterruptHandlerDispatchUnchecked_Post_Result_Check(
+ BspReqInterruptHandlerDispatchUnchecked_Post_Result state
switch ( state ) {
- case BspReqInterruptSpurious_Post_Result_FatalError: {
+ case BspReqInterruptHandlerDispatchUnchecked_Post_Result_FatalError: {
* A fatal error shall occur.
@@ -360,7 +382,7 @@ static void BspReqInterruptSpurious_Post_Result_Check(
break;
- case BspReqInterruptSpurious_Post_Result_Dispatch: {
+ case BspReqInterruptHandlerDispatchUnchecked_Post_Result_Dispatch: {
* The interrupt entries installed at the interrupt vector specified by
* the ``vector`` parameter shall be dispatched.
@@ -370,18 +392,18 @@ static void BspReqInterruptSpurious_Post_Result_Check(
break;
- case BspReqInterruptSpurious_Post_Result_NA:
+ case BspReqInterruptHandlerDispatchUnchecked_Post_Result_NA:
break;
-static void BspReqInterruptSpurious_Post_FatalSource_Check(
- BspReqInterruptSpurious_Post_FatalSource state
+static void BspReqInterruptHandlerDispatchUnchecked_Post_FatalSource_Check(
+ BspReqInterruptHandlerDispatchUnchecked_Post_FatalSource state
switch ( state ) {
- case BspReqInterruptSpurious_Post_FatalSource_SpuriousInterrupt: {
+ case BspReqInterruptHandlerDispatchUnchecked_Post_FatalSource_SpuriousInterrupt: {
* The fatal source shall be equal to
* RTEMS_FATAL_SOURCE_SPURIOUS_INTERRUPT.
@@ -390,18 +412,18 @@ static void BspReqInterruptSpurious_Post_FatalSource_Check(
break;
- case BspReqInterruptSpurious_Post_FatalSource_NA:
+ case BspReqInterruptHandlerDispatchUnchecked_Post_FatalSource_NA:
break;
-static void BspReqInterruptSpurious_Post_FatalCode_Check(
- BspReqInterruptSpurious_Post_FatalCode state
+static void BspReqInterruptHandlerDispatchUnchecked_Post_FatalCode_Check(
+ BspReqInterruptHandlerDispatchUnchecked_Post_FatalCode state
switch ( state ) {
- case BspReqInterruptSpurious_Post_FatalCode_Vector: {
+ case BspReqInterruptHandlerDispatchUnchecked_Post_FatalCode_Vector: {
* The fatal code shall be equal to the ``vector`` parameter.
@@ -409,13 +431,13 @@ static void BspReqInterruptSpurious_Post_FatalCode_Check(
break;
- case BspReqInterruptSpurious_Post_FatalCode_NA:
+ case BspReqInterruptHandlerDispatchUnchecked_Post_FatalCode_NA:
break;
-static void BspReqInterruptSpurious_Setup(
+static void BspReqInterruptHandlerDispatchUnchecked_Setup(
ctx->first = NULL;
@@ -431,17 +453,17 @@ static void BspReqInterruptSpurious_Setup(
SetFatalHandler( Fatal, ctx );
-static void BspReqInterruptSpurious_Setup_Wrap( void *arg )
+static void BspReqInterruptHandlerDispatchUnchecked_Setup_Wrap( void *arg )
- BspReqInterruptSpurious_Context *ctx;
+ BspReqInterruptHandlerDispatchUnchecked_Context *ctx;
ctx = arg;
ctx->Map.in_action_loop = false;
- BspReqInterruptSpurious_Setup( ctx );
+ BspReqInterruptHandlerDispatchUnchecked_Setup( ctx );
-static void BspReqInterruptSpurious_Teardown(
+static void BspReqInterruptHandlerDispatchUnchecked_Teardown(
SetFatalHandler( NULL, NULL );
@@ -452,17 +474,17 @@ static void BspReqInterruptSpurious_Teardown(
-static void BspReqInterruptSpurious_Teardown_Wrap( void *arg )
+static void BspReqInterruptHandlerDispatchUnchecked_Teardown_Wrap( void *arg )
ctx = arg;
- BspReqInterruptSpurious_Teardown( ctx );
+ BspReqInterruptHandlerDispatchUnchecked_Teardown( ctx );
-static void BspReqInterruptSpurious_Action(
+static void BspReqInterruptHandlerDispatchUnchecked_Action(
ctx->interrupt_occurred = false;
@@ -471,64 +493,60 @@ static void BspReqInterruptSpurious_Action(
ctx->fatal_source = RTEMS_FATAL_SOURCE_LAST;
ctx->fatal_code = UINT32_MAX;
- #if defined(RTEMS_SMP)
- if ( *ctx->first == NULL && ctx->first_again != NULL ) {
- *ctx->first = ctx->first_again;
- bsp_interrupt_spurious( ctx->test_vector );
- } else
- #endif
- (void) rtems_interrupt_vector_enable( ctx->test_vector );
+ (void) rtems_interrupt_vector_enable( ctx->test_vector );
- CallWithinISRRaise();
- while ( !ctx->interrupt_occurred ) {
- /* Wait */
+ CallWithinISRRaise();
- Disable( ctx );
+ while ( !ctx->interrupt_occurred ) {
+ /* Wait */
+ Disable( ctx );
-static const BspReqInterruptSpurious_Entry
-BspReqInterruptSpurious_Entries[] = {
- { 0, 0, 1, BspReqInterruptSpurious_Post_Result_Dispatch,
- BspReqInterruptSpurious_Post_FatalSource_NA,
- BspReqInterruptSpurious_Post_FatalCode_NA },
+static const BspReqInterruptHandlerDispatchUnchecked_Entry
+BspReqInterruptHandlerDispatchUnchecked_Entries[] = {
+ { 0, 0, 1, BspReqInterruptHandlerDispatchUnchecked_Post_Result_Dispatch,
+ BspReqInterruptHandlerDispatchUnchecked_Post_FatalSource_NA,
+ BspReqInterruptHandlerDispatchUnchecked_Post_FatalCode_NA },
- { 0, 0, 0, BspReqInterruptSpurious_Post_Result_FatalError,
- BspReqInterruptSpurious_Post_FatalCode_Vector },
+ { 0, 0, 0, BspReqInterruptHandlerDispatchUnchecked_Post_Result_FatalError,
+ BspReqInterruptHandlerDispatchUnchecked_Post_FatalCode_Vector },
#else
- { 0, 0, 1, BspReqInterruptSpurious_Post_Result_FatalError,
+ { 0, 0, 1, BspReqInterruptHandlerDispatchUnchecked_Post_Result_FatalError,
#endif
- { 0, 0, 0, BspReqInterruptSpurious_Post_Result_Dispatch,
+ { 0, 0, 0, BspReqInterruptHandlerDispatchUnchecked_Post_Result_Dispatch,
#else
#endif
static const uint8_t
-BspReqInterruptSpurious_Map[] = {
+BspReqInterruptHandlerDispatchUnchecked_Map[] = {
1, 2, 0, 0
-static size_t BspReqInterruptSpurious_Scope( void *arg, char *buf, size_t n )
+static size_t BspReqInterruptHandlerDispatchUnchecked_Scope(
+ void *arg,
+ char *buf,
+ size_t n
ctx = arg;
if ( ctx->Map.in_action_loop ) {
return T_get_scope(
- BspReqInterruptSpurious_PreDesc,
+ BspReqInterruptHandlerDispatchUnchecked_PreDesc,
buf,
n,
ctx->Map.pcs
@@ -538,85 +556,95 @@ static size_t BspReqInterruptSpurious_Scope( void *arg, char *buf, size_t n )
return 0;
-static T_fixture BspReqInterruptSpurious_Fixture = {
- .setup = BspReqInterruptSpurious_Setup_Wrap,
+static T_fixture BspReqInterruptHandlerDispatchUnchecked_Fixture = {
+ .setup = BspReqInterruptHandlerDispatchUnchecked_Setup_Wrap,
.stop = NULL,
- .teardown = BspReqInterruptSpurious_Teardown_Wrap,
- .scope = BspReqInterruptSpurious_Scope,
- .initial_context = &BspReqInterruptSpurious_Instance
+ .teardown = BspReqInterruptHandlerDispatchUnchecked_Teardown_Wrap,
+ .scope = BspReqInterruptHandlerDispatchUnchecked_Scope,
+ .initial_context = &BspReqInterruptHandlerDispatchUnchecked_Instance
-static inline BspReqInterruptSpurious_Entry BspReqInterruptSpurious_PopEntry(
+static inline BspReqInterruptHandlerDispatchUnchecked_Entry
+BspReqInterruptHandlerDispatchUnchecked_PopEntry(
size_t index;
index = ctx->Map.index;
ctx->Map.index = index + 1;
- return BspReqInterruptSpurious_Entries[
- BspReqInterruptSpurious_Map[ index ]
+ return BspReqInterruptHandlerDispatchUnchecked_Entries[
+ BspReqInterruptHandlerDispatchUnchecked_Map[ index ]
-static void BspReqInterruptSpurious_SetPreConditionStates(
+static void BspReqInterruptHandlerDispatchUnchecked_SetPreConditionStates(
ctx->Map.pcs[ 0 ] = ctx->Map.pci[ 0 ];
- if ( ctx->Map.entry.Pre_FirstAgain_NA ) {
- ctx->Map.pcs[ 1 ] = BspReqInterruptSpurious_Pre_FirstAgain_NA;
+ if ( ctx->Map.entry.Pre_LoadFirstAgain_NA ) {
+ ctx->Map.pcs[ 1 ] = BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain_NA;
} else {
ctx->Map.pcs[ 1 ] = ctx->Map.pci[ 1 ];
-static void BspReqInterruptSpurious_TestVariant(
+static void BspReqInterruptHandlerDispatchUnchecked_TestVariant(
- BspReqInterruptSpurious_Pre_First_Prepare( ctx, ctx->Map.pcs[ 0 ] );
- BspReqInterruptSpurious_Pre_FirstAgain_Prepare( ctx, ctx->Map.pcs[ 1 ] );
- BspReqInterruptSpurious_Action( ctx );
- BspReqInterruptSpurious_Post_Result_Check( ctx, ctx->Map.entry.Post_Result );
- BspReqInterruptSpurious_Post_FatalSource_Check(
+ BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirst_Prepare(
+ ctx,
+ ctx->Map.pcs[ 0 ]
+ BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain_Prepare(
+ ctx,
+ ctx->Map.pcs[ 1 ]
+ BspReqInterruptHandlerDispatchUnchecked_Action( ctx );
+ BspReqInterruptHandlerDispatchUnchecked_Post_Result_Check(
+ ctx,
+ ctx->Map.entry.Post_Result
+ BspReqInterruptHandlerDispatchUnchecked_Post_FatalSource_Check(
ctx,
ctx->Map.entry.Post_FatalSource
- BspReqInterruptSpurious_Post_FatalCode_Check(
+ BspReqInterruptHandlerDispatchUnchecked_Post_FatalCode_Check(
ctx,
ctx->Map.entry.Post_FatalCode
- * @fn void T_case_body_BspReqInterruptSpurious( void )
+ * @fn void T_case_body_BspReqInterruptHandlerDispatchUnchecked( void )
T_TEST_CASE_FIXTURE(
- BspReqInterruptSpurious,
- &BspReqInterruptSpurious_Fixture
+ BspReqInterruptHandlerDispatchUnchecked,
+ &BspReqInterruptHandlerDispatchUnchecked_Fixture
ctx->Map.in_action_loop = true;
ctx->Map.index = 0;
for (
- ctx->Map.pci[ 0 ] = BspReqInterruptSpurious_Pre_First_Null;
- ctx->Map.pci[ 0 ] < BspReqInterruptSpurious_Pre_First_NA;
+ ctx->Map.pci[ 0 ] = BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirst_Null;
+ ctx->Map.pci[ 0 ] < BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirst_NA;
++ctx->Map.pci[ 0 ]
for (
- ctx->Map.pci[ 1 ] = BspReqInterruptSpurious_Pre_FirstAgain_Null;
- ctx->Map.pci[ 1 ] < BspReqInterruptSpurious_Pre_FirstAgain_NA;
+ ctx->Map.pci[ 1 ] = BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain_Null;
+ ctx->Map.pci[ 1 ] < BspReqInterruptHandlerDispatchUnchecked_Pre_LoadFirstAgain_NA;
++ctx->Map.pci[ 1 ]
- ctx->Map.entry = BspReqInterruptSpurious_PopEntry( ctx );
- BspReqInterruptSpurious_SetPreConditionStates( ctx );
- BspReqInterruptSpurious_TestVariant( ctx );
+ ctx->Map.entry = BspReqInterruptHandlerDispatchUnchecked_PopEntry( ctx );
+ BspReqInterruptHandlerDispatchUnchecked_SetPreConditionStates( ctx );
+ BspReqInterruptHandlerDispatchUnchecked_TestVariant( ctx );
2.35.3
