[PATCH] spec/bsps: Deduplicate objxilinxsupport
Tue Feb 7 06:55:48 UTC 2023
On 06.02.23 23:09, Gedare Bloom wrote:
> ok. I'm not sure, maybe we need a note about this in
> https://docs.rtems.org/branches/master/eng/build-system.html
A hint in the documentation would be helpful. Even more helpful would be
a consistency check before patch sets are pulled in. For example, it is
a bug if you have a diamond in the build dependency graph and the nodes
with an indegree greater than one install files. If the nodes with an
indegree greater than one build source files with identical build
options, then this is also a bug. However, a valid special case could be
a node which is built with different build flags, for example:
lib -> grp_a (-DFLAG_A) -> objxyz
  \---> grp_b (-DFLAG_B) -> objxyz
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
