[PATCH rtems-docs] eng: Add ObjectsItem details
Sebastian Huber
Tue Feb 7 16:09:04 UTC 2023
On 07.02.23 16:52, Kinsey Moore wrote:
> This adds a section on adding ObjectsItems and some details to the
> definition regarding multiple inclusions.
> eng/build-system.rst | 28 ++++++++++++++++++++++++++++
> eng/req/items.rst | 8 ++++++--
> 2 files changed, 34 insertions(+), 2 deletions(-)
> diff --git a/eng/build-system.rst b/eng/build-system.rst
> index 6974aa8..22cdd5a 100644
> --- a/eng/build-system.rst
> +++ b/eng/build-system.rst
> @@ -489,3 +489,31 @@ Add a link to the new library item using a relative UID:
> links:
> - role: build-dependency
> uid: libnew
> +Add an Object
> +Build objects logically separate relatively independent segments of
> +functionality (i.e. a device driver, an architecture-dependent feature, etc.).
I would change i.e. in "for example".
> +Let *new* be the name of the new object. You can add the new object with:
> +.. code-block:: none
> + $ vi spec/build/cpukit/objnew.yml
> +Define the attributes of your new object according to
> +:ref:`SpecTypeBuildObjectsItemType`.
> +Edit corresponding group item:
> + $ vi spec/build/cpukit/grp.yml
> +Add a link to the new objects item using a relative UID:
> +.. code-block:: yaml
> + links:
> + - role: build-dependency
> + uid: objnew
> diff --git a/eng/req/items.rst b/eng/req/items.rst
> index e718605..5210b4c 100644
> --- a/eng/req/items.rst
> +++ b/eng/req/items.rst
> @@ -649,8 +649,12 @@ Build Objects Item Type
> This type refines the :ref:`SpecTypeBuildItemType` through the ``build-type``
> attribute if the value is ``objects``. This set of attributes specifies a set
> -of object files used to build static libraries or test programs. All explicit
> -attributes shall be specified. The explicit attributes for this type are:
> +of object files used to build static libraries or test programs. Objects Items
> +must not be included on multiple paths through the build dependency graph with
> +identical build options. Violating this can cause race conditions in the build
> +system due to duplicate installs and multiple instances of build tasks. All
> +explicit attributes shall be specified. The explicit attributes for this type
> +are:
> cflags
> The attribute value shall be a list. Each list element shall be a
This part is generated from spec/spec/build-objects.yml in
rtems-central. I would move your new content to this item and regenerate
the file if this is all right for you.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
